[GRASS-SVN] r33792 - in grass/branches/develbranch_6: general/g.findfile lib/gis
Thu Oct 9 15:09:40 EDT 2008
Author: martinl
Date: 2008-10-09 15:09:40 -0400 (Thu, 09 Oct 2008)
New Revision: 33792
   grass/branches/develbranch_6/general/g.findfile/main.c
   grass/branches/develbranch_6/lib/gis/file_name.c
   grass/branches/develbranch_6/lib/gis/find_file.c
i18n update (g.findfile)
Modified: grass/branches/develbranch_6/general/g.findfile/main.c
--- grass/branches/develbranch_6/general/g.findfile/main.c	2008-10-09 15:45:35 UTC (rev 33791)
+++ grass/branches/develbranch_6/general/g.findfile/main.c	2008-10-09 19:09:40 UTC (rev 33792)
@@ -6,9 +6,9 @@
  *               Markus Neteler <neteler itc.it>,
  *               Bernhard Reiter <bernhard intevation.de>,
  *               Glynn Clements <glynn gclements.plus.com>,
- *                Jan-Oliver Wagner <jan intevation.de>
+ *               Jan-Oliver Wagner <jan intevation.de>
  * PURPOSE:
- * COPYRIGHT:    (C) 1999-2006 by the GRASS Development Team
+ * COPYRIGHT:    (C) 1999-2008 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -33,8 +33,8 @@
     module = G_define_module();
     module->keywords = _("general");
     module->description =
-	"Searches for GRASS data base files "
-	"and sets variables for the shell.";
+	_("Searches for GRASS data base files "
+	  "and sets variables for the shell.");
     G_gisinit(argv[0]);
@@ -44,20 +44,20 @@
     opt1->key = "element";
     opt1->type = TYPE_STRING;
     opt1->required = YES;
-    opt1->description = "Name of an element";
+    opt1->description = _("Name of an element");
     opt2 = G_define_option();
     opt2->key = "mapset";
     opt2->type = TYPE_STRING;
     opt2->required = NO;
-    opt2->description = "Name of a mapset";
+    opt2->description = _("Name of a mapset");
     opt2->answer = "";
     opt3 = G_define_option();
     opt3->key = "file";
     opt3->type = TYPE_STRING;
     opt3->required = YES;
-    opt3->description = "Name of an existing map";
+    opt3->description = _("Name of an existing map");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -65,13 +65,14 @@
     search_mapset = opt2->answer;
     if (strcmp(".", search_mapset) == 0)
 	search_mapset = G_mapset();
     if (opt2->answer && strlen(opt2->answer) > 0) {
 	char **map_mapset = G_tokenize(opt3->answer, "@");
 	if (G_number_of_tokens(map_mapset) > 1) {
 	    if (strcmp(map_mapset[1], opt2->answer))
-		G_fatal_error(_("Parameter 'file' contains reference to <%s> mapset, but mapset parameter <%s> does not correspond"),
+		G_fatal_error(_("Parameter 'file' contains reference to <%s> mapset, "
+				"but mapset parameter <%s> does not correspond"),
 			      map_mapset[1], opt2->answer);
 	    else
 		strcpy(name, opt3->answer);
@@ -98,5 +99,6 @@
 	fprintf(stdout, "fullname=\n");
 	fprintf(stdout, "file=\n");
     exit(mapset == NULL);
Modified: grass/branches/develbranch_6/lib/gis/file_name.c
--- grass/branches/develbranch_6/lib/gis/file_name.c	2008-10-09 15:45:35 UTC (rev 33791)
+++ grass/branches/develbranch_6/lib/gis/file_name.c	2008-10-09 19:09:40 UTC (rev 33792)
@@ -1,26 +1,35 @@
+   \file file_name.c
- *  char *
- *  G__file_name (path, element, name, maps)
- *      char path[]          buffer to hold resultant full path to file.
- *      const char *element  database element (eg, "cell", "cellhd", etc)
- *      const char *name     name of file to build path to
- *      const char *mapset   mapset name
- *      builds full path names to GIS data files
- *  returns:
- *         pointer to 'path'
- *   note:
- *      if name is of the form nnn at ppp then path is set
- *      as if name had been nnn and mapset had been ppp
- *      (mapset parameter itself is ignored in this case)
+   \brief GIS library - Determice GRASS data base file name
+   (C) 2001-2008 by the GRASS Development Team
+   This program is free software under the
+   GNU General Public License (>=v2).
+   Read the file COPYING that comes with GRASS
+   for details.
+   \author Original author CERL
 #include <string.h>
 #include <grass/gis.h>
+  \brief Builds full path names to GIS data files
+  If name is of the form nnn at ppp then path is set
+  as if name had been nnn and mapset had been ppp
+  (mapset parameter itself is ignored in this case)
+  \param[out] path buffer to hold resultant full path to file
+  \param element database element (eg, "cell", "cellhd", etc)
+  \param name name of file to build path to (fully qualified names allowed)
+  \param mapset mapset name
+  \return pointer to <i>path</i>
 char *G__file_name(char *path,
 		   const char *element, const char *name, const char *mapset)
Modified: grass/branches/develbranch_6/lib/gis/find_file.c
--- grass/branches/develbranch_6/lib/gis/find_file.c	2008-10-09 15:45:35 UTC (rev 33791)
+++ grass/branches/develbranch_6/lib/gis/find_file.c	2008-10-09 19:09:40 UTC (rev 33792)
@@ -1,6 +1,22 @@
+   \file find_file.c
+   \brief GIS library - find GRASS data base files
+   for details.
 #include <string.h>
 #include <unistd.h>
+#include <grass/glocale.h>
 static char *find_file(int misc,
 		       const char *dir,
@@ -55,16 +71,17 @@
 		if (!pselmapset)
 		    pselmapset = pmapset;
 		else
-		    G_warning
-			("'%s/%s' was found in more mapsets (also found in %s).",
-			 element, pname, pmapset);
+		    G_warning(_("'%s/%s' was found in more mapsets (also found in <%s>)"),
+			      element, pname, pmapset);
 		cnt++;
 	if (cnt > 0) {
 	    /* If the same name exists in more mapsets and print a warning */
 	    if (cnt > 1)
-		G_warning("using '%s@%s'.", pname, pselmapset);
+		G_warning(_("Using <%s@%s>"),
+			  pname, pselmapset);
 	    return (char *)pselmapset;
@@ -79,9 +96,11 @@
 	    G__file_name_misc(path, dir, element, pname, pmapset);
 	else
 	    G__file_name(path, element, pname, pmapset);
 	if (access(path, 0) == 0)
 	    return G_store(pmapset);
     return NULL;
