[GRASS-SVN] r33828 - in grass/trunk/raster: . r.usler
Sat Oct 11 20:42:43 EDT 2008
Author: ychemin
Date: 2008-10-11 20:42:43 -0400 (Sat, 11 Oct 2008)
New Revision: 33828
Added:
   grass/trunk/raster/r.usler/
   grass/trunk/raster/r.usler/Makefile
   grass/trunk/raster/r.usler/elswaify85.c
   grass/trunk/raster/r.usler/foster81.c
   grass/trunk/raster/r.usler/main.c
   grass/trunk/raster/r.usler/morgan74.c
   grass/trunk/raster/r.usler/r.usler.html
   grass/trunk/raster/r.usler/roose75.c
Add r.usler module
Added: grass/trunk/raster/r.usler/Makefile
--- grass/trunk/raster/r.usler/Makefile	                        (rev 0)
+++ grass/trunk/raster/r.usler/Makefile	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.usler
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster/r.usler/elswaify85.c
--- grass/trunk/raster/r.usler/elswaify85.c	                        (rev 0)
+++ grass/trunk/raster/r.usler/elswaify85.c	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,13 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+double elswaify_1985(double annual_pmm)
+    double result;
+    result = ((annual_pmm * 0.35) + 38.5);
+    return result;
Added: grass/trunk/raster/r.usler/foster81.c
--- grass/trunk/raster/r.usler/foster81.c	                        (rev 0)
+++ grass/trunk/raster/r.usler/foster81.c	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,13 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+double foster_1981(double annual_pmm)
+    double result;
+    result = ((annual_pmm * 0.276 * 75.0) / 100.0);
+    return result;
Added: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c	                        (rev 0)
+++ grass/trunk/raster/r.usler/main.c	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,139 @@
+ * MODULE:       r.usler
+ * AUTHOR(S):    Natalia Medvedeva - natmead at gmail.com
+ *		 Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculates USLE R factor
+ * 		 Rainfall Erosion index according to four methods
+ * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+double elswaify_1985(double annaul_pmm);
+double morgan_1974(double annual_pmm);
+double foster_1981(double annual_pmm);
+double roose_1975(double annual_pmm);
+int main(int argc, char *argv[])
+    int nrows, ncols;
+    int row, col;
+    char *nameflag;		/*Switch for particular method */
+    struct GModule *module;
+    struct Option *input1, *input2, *output;
+    struct History history;	/*metadata */
+    char *result;		/*output raster name */
+    int infd_annual_pmm;
+    int outfd;
+    char *annual_pmm;
+    void *inrast_annual_pmm;
+    DCELL * outrast;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("rainfall, erosion, USLE");
+    module->description = _("raster, USLE R factor, Rainfall erosivity index.");
+    /* Define the different options */
+    input1 = G_define_option();
+    input1->key = _("method");
+    input1->type = TYPE_STRING;
+    input1->required = YES;
+    input1->gisprompt = _("Name of method to use");
+    input1->description =
+	_("Name of USLE R equation: roose, morgan, foster, elswaify.");
+    input1->answer = _("morgan");
+    input2 = G_define_standard_option(G_OPT_R_INPUT);
+    input2->description = _("Name of the annual precipitation map");
+    output = G_define_standard_option(G_OPT_R_OUTPUT);
+    output->description = _("Name of the output usler layer");
+    if (G_parser(argc, argv))
+        exit(EXIT_FAILURE);
+    nameflag = input1->answer;
+    annual_pmm = input2->answer;
+    result = output->answer;
+    if ((infd_annual_pmm = G_open_cell_old(annual_pmm, "")) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), annual_pmm);
+    inrast_annual_pmm = G_allocate_d_raster_buf();
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+    outrast = G_allocate_d_raster_buf();
+    /* Create New raster files */
+    if ((outfd = G_open_raster_new(result, DCELL_TYPE)) < 0)
+	G_fatal_error(_("Could not open <%s>"), result);
+    /* Process pixels */
+    for (row = 0; row < nrows; row++)
+        DCELL d;
+	DCELL d_annual_pmm;
+	G_percent(row, nrows, 2);
+	/* read input map */
+	if (G_get_d_raster_row(infd_annual_pmm, inrast_annual_pmm, row) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), annual_pmm);
+	/*process the data */
+	for (col = 0; col < ncols; col++)
+	    d_annual_pmm = ((DCELL *) inrast_annual_pmm)[col];
+	    if (G_is_d_null_value(&d_annual_pmm))
+		G_set_d_null_value(&outrast[col], 1);
+	    else
+                /*calculate morgan       */
+                if (!strcmp(nameflag, "morgan"))
+                    d = morgan_1974(d_annual_pmm);
+		/*calculate roose        */
+		if (!strcmp(nameflag, "roose"))
+		    d = roose_1975(d_annual_pmm);
+		/*calculate foster       */
+		if (!strcmp(nameflag, "foster"))
+		    d = foster_1981(d_annual_pmm);
+		/*calculate elswaify     */
+		if (!strcmp(nameflag, "elswaify"))
+		    d = elswaify_1985(d_annual_pmm);
+	if (G_put_d_raster_row(outfd, outrast) < 0)
+	    G_fatal_error(_("Cannot write to output raster file"));
+    G_free(inrast_annual_pmm);
+    G_close_cell(infd_annual_pmm);
+    G_free(outrast);
+    G_close_cell(outfd);
+    G_short_history(result, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result, &history);
+    exit(EXIT_SUCCESS);
Added: grass/trunk/raster/r.usler/morgan74.c
--- grass/trunk/raster/r.usler/morgan74.c	                        (rev 0)
+++ grass/trunk/raster/r.usler/morgan74.c	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,13 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+    double result;
+    result = (((annual_pmm * 9.28) - 8838.0) * 75.0) / 1000.0;
+    return result;
Added: grass/trunk/raster/r.usler/r.usler.html
--- grass/trunk/raster/r.usler/r.usler.html	                        (rev 0)
+++ grass/trunk/raster/r.usler/r.usler.html	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,24 @@
+<H2>DESCRIPTION</H2>
+<EM>r.usler</EM> calculates USLE R factor for Rainfall erosivity. It enables several empirical equations: Roosle (1975), Morgan (1974), Foster(1981) and El-Swaify (1985).
+<H2>NOTES</H2>
+<H2>TODO</H2>
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.uslek.html">r.uslek</A><br>
+<A HREF="r.watershed.html">r.watershed</A><br>
+</em>
+<H2>AUTHORS</H2>
+Natialia Medvedeva, SIC-ISDC, Ashgabat, Turkmenistan<BR>
+Yann Chemin, SIC-ISDC, Ashgabat, Turkmenistan<BR>
+<p>
+<i>Last changed: $Date: 2008/10/12 08:30:42 $</i>
Added: grass/trunk/raster/r.usler/roose75.c
--- grass/trunk/raster/r.usler/roose75.c	                        (rev 0)
+++ grass/trunk/raster/r.usler/roose75.c	2008-10-12 00:42:43 UTC (rev 33828)
@@ -0,0 +1,13 @@
+#include<stdio.h>
+#include<math.h>
+#include<stdlib.h>
+    double result;
+    result = annual_pmm * 0.5 * 1.73;
+    return result;
