[GRASS-SVN] r33831 - in grass-addons/gipe: . i.latlong
Sun Oct 12 00:30:25 EDT 2008
Author: ychemin
Date: 2008-10-12 00:30:24 -0400 (Sun, 12 Oct 2008)
New Revision: 33831
Added:
   grass-addons/gipe/i.latlong/
   grass-addons/gipe/i.latlong/Makefile
   grass-addons/gipe/i.latlong/i.latlong.html
   grass-addons/gipe/i.latlong/main.c
Removed:
   grass-addons/gipe/i.latitude/
   grass-addons/gipe/i.longitude/
   grass-addons/gipe/Makefile.imagery
   grass-addons/gipe/gmmenu.tcl
   grass-addons/gipe/menudata.py
   grass-addons/gipe/readme.gipe
Merged i.latitude/i.longitude into i.latlong
Modified: grass-addons/gipe/Makefile.imagery
--- grass-addons/gipe/Makefile.imagery	2008-10-12 01:17:36 UTC (rev 33830)
+++ grass-addons/gipe/Makefile.imagery	2008-10-12 04:30:24 UTC (rev 33831)
@@ -35,9 +35,8 @@
 	i.evapo.senay \
 	i.evapo.time_integration \
 	i.evapo.TSA \
-	i.latitude \
+	i.latlong \
 	i.lmf \
-	i.longitude \
 	i.modis.stateqa \
 	i.sattime \
 	i.sunhours \
Modified: grass-addons/gipe/gmmenu.tcl
--- grass-addons/gipe/gmmenu.tcl	2008-10-12 01:17:36 UTC (rev 33830)
+++ grass-addons/gipe/gmmenu.tcl	2008-10-12 04:30:24 UTC (rev 33831)
@@ -582,8 +582,7 @@
 				{command {[G_msg "Water"]} {} "i.water" {} -command {execute i.water }}
 				{command {[G_msg "Emissivity (generic from NDVI)"]} {} "i.emissivity" {} -command {execute i.emissivity }}
 				{separator}
-				{command {[G_msg "Latitude map"]} {} "i.latitude" {} -command {execute i.latitude }}
-				{command {[G_msg "Longitude map"]} {} "i.longitude" {} -command {execute i.longitude }}
+				{command {[G_msg "Lat/long maps"]} {} "i.latlong" {} -command {execute i.latlong }}
 				{command {[G_msg "Sunshine hours (potential)"]} {} "i.sunhours" {} -command {execute i.sunhours }}
 				{command {[G_msg "Satellite overpass time"]} {} "i.sattime" {} -command {execute i.sattime }}
 				{separator}
Added: grass-addons/gipe/i.latlong/Makefile
--- grass-addons/gipe/i.latlong/Makefile	                        (rev 0)
+++ grass-addons/gipe/i.latlong/Makefile	2008-10-12 04:30:24 UTC (rev 33831)
@@ -0,0 +1,15 @@
+MODULE_TOPDIR = ../..
+PGM = i.latlong
+LIBES =  $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
+EXTRA_INC = $(PROJINC)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+ifneq ($(USE_LARGEFILES),)
+	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
+endif
+default: cmd
Added: grass-addons/gipe/i.latlong/i.latlong.html
--- grass-addons/gipe/i.latlong/i.latlong.html	                        (rev 0)
+++ grass-addons/gipe/i.latlong/i.latlong.html	2008-10-12 04:30:24 UTC (rev 33831)
@@ -0,0 +1,26 @@
+<H2>DESCRIPTION</H2>
+<EM>i.latlong</EM> creates a latitude (degree decimal) map, or longitude if the -l flag is used, from any map in any projection using PROJ.4 library.
+This is an input to r.sun and i.evapo.potrad.
+<H2>NOTES</H2>
+The proj <A HREF="http://www.remotesensing.org/proj/">website</A>.
+<H2>TODO</H2>
+Datum corrected reprojection is not implemented.
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.evapo.potrad.html">i.evapo.potrad</A><br>
+<A HREF="r.sun.html">r.sun</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines.<br>
+<p>
+<i>Last changed: $Date: 2008/10/12 12:25:55 $</i>
Added: grass-addons/gipe/i.latlong/main.c
--- grass-addons/gipe/i.latlong/main.c	                        (rev 0)
+++ grass-addons/gipe/i.latlong/main.c	2008-10-12 04:30:24 UTC (rev 33831)
@@ -0,0 +1,174 @@
+ * MODULE:       i.latlong
+ * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE:      Calculates the longitude of the pixels in the map.
+ * COPYRIGHT:    (C) 2002-2008 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *   	    	 License (>=v2). Read the file COPYING that comes with GRASS
+ *   	    	 for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/gprojects.h>
+#include <grass/glocale.h>
+int main(int argc, char *argv[])
+    struct Cell_head cellhd;	/*region+header info */
+    char *mapset;		/*mapset name */
+    int nrows, ncols;
+    int row, col;
+    int not_ll = 0;		/*if proj is not lat/long, it will be 1. */
+    struct GModule *module;
+    struct Option *input1, *output1;
+    struct Flag *flag1;
+    struct History history;	/*metadata */
+    struct pj_info iproj;
+    struct pj_info oproj;
+    char *name;			/*input raster name */
+    char *result1;		/*output raster name */
+    int infd;
+    int outfd1;
+    char *in;
+    int i = 0, j = 0;
+    double xp, yp;
+    double xmin, ymin;
+    double xmax, ymax;
+    double stepx, stepy;
+    double latitude, longitude;
+    void *inrast;
+    DCELL * outrast1;
+    RASTER_MAP_TYPE data_type_output = DCELL_TYPE;
+    RASTER_MAP_TYPE data_type_inrast;
+	G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("longitude, projection");
+    module->description = _("creates a longitude map");
+	/* Define the different options */
+	input1 = G_define_standard_option(G_OPT_R_INPUT);
+    input1->description = _("Name of the input map");
+    output1 = G_define_standard_option(G_OPT_R_OUTPUT);
+    output1->description = _("Name of the output longitude layer");
+    flag1 = G_define_flag();
+    flag1->key = 'l';
+    flag1->description = _("Loongitude output");
+	if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    in = input1->answer;
+    result1 = output1->answer;
+	mapset = G_find_cell2(in, "");
+    if (mapset == NULL) {
+	G_fatal_error(_("cell file [%s] not found"), in);
+    data_type_inrast = G_raster_map_type(in, mapset);
+    if ((infd = G_open_cell_old(in, mapset)) < 0)
+	G_fatal_error(_("Cannot open cell file [%s]"), in);
+    if (G_get_cellhd(in, mapset, &cellhd) < 0)
+	G_fatal_error(_("Cannot read file header of [%s])"), in);
+    inrast = G_allocate_raster_buf(data_type_inrast);
+    stepx = cellhd.ew_res;
+    stepy = cellhd.ns_res;
+    xmin = cellhd.west;
+    xmax = cellhd.east;
+    ymin = cellhd.south;
+    ymax = cellhd.north;
+    nrows = G_window_rows();
+    ncols = G_window_cols();
+	/*Shamelessly stolen from r.sun !!!!    */
+	/* Set up parameters for projection to lat/long if necessary */
+    if ((G_projection() != PROJECTION_LL))
+	not_ll = 1;
+	struct Key_Value *in_proj_info, *in_unit_info;
+	if ((in_proj_info = G_get_projinfo()) == NULL)
+	    G_fatal_error(_("Can't get projection info of current location"));
+	if ((in_unit_info = G_get_projunits()) == NULL)
+	    G_fatal_error(_("Can't get projection units of current location"));
+	if (pj_get_kv(&iproj, in_proj_info, in_unit_info) < 0)
+	    G_fatal_error(_("Can't get projection key values of current location"));
+	G_free_key_value(in_proj_info);
+	G_free_key_value(in_unit_info);
+        /* Set output projection to latlong w/ same ellipsoid */
+	oproj.zone = 0;
+	oproj.meters = 1.;
+	sprintf(oproj.proj, "ll");
+	if ((oproj.pj = pj_latlong_from_proj(iproj.pj)) == NULL)
+	    G_fatal_error(_("Unable to set up lat/long projection parameters"));
+    }				/* End of stolen from r.sun :P */
+    outrast1 = G_allocate_raster_buf(data_type_output);
+    if ((outfd1 = G_open_raster_new(result1, data_type_output)) < 0)
+	G_fatal_error(_("Could not open <%s>"), result1);
+    for (row = 0; row < nrows; row++)
+	DCELL d;
+	DCELL d_lon;
+	DCELL d_lat;
+	G_percent(row, nrows, 2);
+	if (G_get_raster_row(infd, inrast, row, data_type_inrast) < 0)
+	    G_fatal_error(_("Could not read from <%s>"), in);
+	for (col = 0; col < ncols; col++)
+	    latitude = ymax - (row * stepy);
+	    longitude = xmin + (col * stepx);
+	    if (not_ll) {
+		if (pj_do_proj(&longitude, &latitude, &iproj, &oproj) < 0) {
+		    G_fatal_error(_("Error in pj_do_proj"));
+	    else {
+		    /*Do nothing */
+            if(flag1->answer)
+	        d = longitude;
+            else
+	        d = latitude;
+	    outrast1[col] = d;
+	if (G_put_raster_row(outfd1, outrast1, data_type_output) < 0)
+	    G_fatal_error(_("Cannot write to output raster file"));
+    G_free(inrast);
+    G_close_cell(infd);
+    G_free(outrast1);
+    G_close_cell(outfd1);
+    G_short_history(result1, "raster", &history);
+    G_command_history(&history);
+    G_write_history(result1, &history);
+    exit(EXIT_SUCCESS);
Modified: grass-addons/gipe/menudata.py
--- grass-addons/gipe/menudata.py	2008-10-12 01:17:36 UTC (rev 33830)
+++ grass-addons/gipe/menudata.py	2008-10-12 04:30:24 UTC (rev 33831)
@@ -1455,14 +1455,10 @@
                           "self.RunMenuCmd",
                           "i.emissivity"),
-                         (_("Latitude map"),
-                          _("Latitude map"),
+                         (_("Lat/long maps"),
+                          _("Lat/long maps"),
                           "self.RunMenuCmd",
-                          "i.latitude"),
-                         (_("Longitude map"),
-                          _("Longitude map"),
-                          "self.RunMenuCmd",
-                          "i.longitude"),
+                          "i.latlong"),
                          (_("Sunshine hours (potential)"),
                           "self.RunMenuCmd",
Modified: grass-addons/gipe/readme.gipe
--- grass-addons/gipe/readme.gipe	2008-10-12 01:17:36 UTC (rev 33830)
+++ grass-addons/gipe/readme.gipe	2008-10-12 04:30:24 UTC (rev 33831)
@@ -17,6 +17,7 @@
 20081010: Added i.modis.stateqa for cloud, fire, land/water and other interesting MODIS09A flags.
 20081011: Moved r.uslek to main SVN
 20081012: Moved r.usler to main SVN
+20081012: Added i.latlong, removed i.latitude and i.longitude
 Imagery modules
@@ -71,8 +72,7 @@
 -----Utilities-----------------------------------------------------------------------
-i.latitude: 	Calculates latitude by reprojecting without datum transform
-i.longitude: 	Calculates longitude by reprojecting without datum transform
+i.latlong: 	Calculates latitude/longitude by reprojecting without datum transform
 **i.qc.modis:	(Now in Main SVN as i.modis.qc) Converts Terra-MODIS Quality Assessment bits to numeric classes
 i.sattime:	Calculates the time of satellite overpass
 i.sunhours:	Calculates potential sunshine hours
