[GRASS-SVN] r33837 - grass/trunk/locale/po
Sun Oct 12 03:15:47 EDT 2008
Author: neteler
Date: 2008-10-12 03:15:47 -0400 (Sun, 12 Oct 2008)
New Revision: 33837
Added:
   grass/trunk/locale/po/grasswxpy_el.po
   grass/trunk/locale/po/grasslibs_el.po
updated
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2008-10-12 07:14:27 UTC (rev 33836)
+++ grass/trunk/locale/po/grasslibs_el.po	2008-10-12 07:15:47 UTC (rev 33837)
@@ -1,284 +1,345 @@
-# translation of grasslibs_el.po to Greek
-# Greek translation of grasslibs.pot
+# translation of grasslibs_el.po to Greek - Báóßëåéïò Áíôùíßïõ
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2007 GRASS Development Team
 # Carlos Davila <carluti at users.sourceforge.net>, 2007.
+# Vasilios Antoniou <antoniou_v at yahoo.gr>, 2008.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_el\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2008-01-24 17:42+0100\n"
-"PO-Revision-Date: 2007-03-23 16:35+0100\n"
-"Last-Translator: Carlos Davila <carluti at users.sourceforge.net>\n"
-"Language-Team: Greek <grass-translations at lists.osgeo.org>\n"
+"PO-Revision-Date: 2008-10-01 14:42+0300\n"
+"Last-Translator: Vasilios Antoniou <antoniou_v at yahoo.gr>\n"
+"Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=ISO-8859-7\n"
 "Content-Transfer-Encoding: 8bit\n"
+"X-Generator: KBabel 1.11.4\n"
 #: ../lib/gpde/test/test_tools.c:34
 msgid ""
 "\n"
 "++ Running math tool unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç ôåóô ìáèçìáôéêÞò ìïíÜäáò ++"
 #: ../lib/gpde/test/test_tools.c:39
 msgid ""
 "\n"
 "-- math tool unit tests failure --"
 msgstr ""
+"\n"
+"-- Áðïôõ÷ßá åêôÝëåóçò ôåóô ìáèçìáôéêÞò ìïíÜäáò --"
 #: ../lib/gpde/test/test_tools.c:41
 msgid ""
 "\n"
 "-- math tool unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷Þò åêôÝëåóç ôåóô ìáèçìáôéêÞò ìïíÜäáò ++"
 #: ../lib/gpde/test/test_arrays.c:48
 msgid ""
 "\n"
 "++ Running array unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç ôåóô ìïíÜäáò ðßíáêá++"
 #: ../lib/gpde/test/test_arrays.c:50
 msgid "\t 1. testing 2d arrays"
-msgstr ""
+msgstr "\t 1. äïêßìç ðßíáêá 2 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_arrays.c:53
 msgid "\t 2. testing 3d arrays"
-msgstr ""
+msgstr "\t 1. äïêßìç ðßíáêá 3 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_arrays.c:57
 msgid ""
 "\n"
 "-- Array unit tests failure --"
 msgstr ""
+"\n"
+"-- Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
 #: ../lib/gpde/test/test_arrays.c:59
 msgid ""
 "\n"
 "-- Array unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò ðßíáêá --"
 #: ../lib/gpde/test/test_heat.c:33
 msgid ""
 "\n"
 "++ Running heat flow integration tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìþí èåñìéêÞò ñïÞò ++"
 #: ../lib/gpde/test/test_heat.c:35
 msgid "\t 1. testing 2d heat flow"
-msgstr ""
+msgstr "\t 1. äïêéìÞ èåñìéêÞò ñïÞò 2 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_heat.c:37
 msgid "\t 2. testing 3d heat flow"
-msgstr ""
+msgstr "\t 1. äïêéìÞ èåñìéêÞò ñïÞò 3 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_heat.c:40
 msgid ""
 "\n"
 "-- heat flow integration tests failure --"
 msgstr ""
+"\n"
+"-- Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò èåñìéêÞò ñïÞò --"
 #: ../lib/gpde/test/test_heat.c:42
 msgid ""
 "\n"
 "-- heat flow integration tests finished successfully --"
 msgstr ""
+"\n"
+"-- Åðéôõ÷Þò åêôÝëåóçò äïêéìÞò èåñìéêÞò ñïÞò --"
 #: ../lib/gpde/test/test_les.c:34
 msgid ""
 "\n"
 "++ Running les creation unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
 #: ../lib/gpde/test/test_les.c:39
 msgid ""
 "\n"
 "-- les creation unit tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
 #: ../lib/gpde/test/test_les.c:41
 msgid ""
 "\n"
 "-- les creation unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò ìïíÜäáò äçìéïõñãßáò les ++"
 #: ../lib/gpde/test/test_les.c:95
 msgid "\t * testing les creation in parallel\n"
-msgstr ""
+msgstr "\t * äïêéìÞ äçìéïõñãßáò les ðáñÜëëçëá\n"
 #: ../lib/gpde/test/test_les.c:126
 msgid "\t * testing les creation in serial\n"
-msgstr ""
+msgstr "\t * äïêéìÞ äçìéïõñãßáò les óåéñéáêÜ\n"
 #: ../lib/gpde/test/test_main.c:49
 msgid "Choose the unit tests to run"
-msgstr ""
+msgstr "ÅðéëÝîôå ôéò ìïíÜäåò ðïõ èÝëåôå íá åêôåëÝóåôå"
 #: ../lib/gpde/test/test_main.c:56
 msgid "Choose the integration tests to run"
-msgstr ""
+msgstr "ÅðéëÝîôå ôéò ìïíÜäåò åíóùìÜôùóçò ðïõ èÝëåôå íá åêôåëÝóåôå"
 #: ../lib/gpde/test/test_main.c:61
 msgid "Run all unit tests"
-msgstr ""
+msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí ìïíÜäáò"
 #: ../lib/gpde/test/test_main.c:65
 msgid "Run all integration tests"
-msgstr ""
+msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí åíóùìÜôùóçò"
 #: ../lib/gpde/test/test_main.c:69
 msgid "Run all unit and integration tests"
-msgstr ""
+msgstr "ÅêôÝëåóç üëùí ôùí äïêéìþí åíóùìÜôùóçò êáé ìïíÜäáò"
 #: ../lib/gpde/test/test_main.c:85
 msgid "test, gpde"
-msgstr ""
+msgstr "äïêéìÞ, gpde"
 #: ../lib/gpde/test/test_main.c:87
 msgid "Performs unit and integration tests for gpde library"
-msgstr ""
+msgstr "Åêôåëåß äïêéìÝò ìïíÜäáò êáé åíóùìÜôùóçò ãéá ôçí âéâëéïèÞêç gpde"
 #: ../lib/gpde/test/test_gwflow.c:43
 msgid ""
 "\n"
 "++ Running gwflow integration tests ++"
 msgstr ""
+"\n"
+"++ Åêôåëïýíôáé äïêéìÝò åíóùìÜôùóçò gwflow ++"
 #: ../lib/gpde/test/test_gwflow.c:45
 msgid "\t 1. testing 2d gwflow"
-msgstr ""
+msgstr "\t 1. äïêéìÞ 2 äéáóôÜóåùí gwflow"
 #: ../lib/gpde/test/test_gwflow.c:48
 msgid "\t 2. testing 3d gwflow"
-msgstr ""
+msgstr "\t 1. äïêéìÞ 3 äéáóôÜóåùí gwflow"
 #: ../lib/gpde/test/test_gwflow.c:52
 msgid ""
 "\n"
 "-- gwflow integration tests failure --"
 msgstr ""
+"\n"
+"-- áðïôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
 #: ../lib/gpde/test/test_gwflow.c:54
 msgid ""
 "\n"
 "-- gwflow integration tests finished successfully --"
 msgstr ""
+"\n"
+"-- Åðéôõ÷ßá äïêéìÞò åíóùìÜôùóçò gwflow --"
 #: ../lib/gpde/test/test_geom.c:36
 msgid ""
 "\n"
 "++ Running geom_data unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìÞò geom_data ++"
 #: ../lib/gpde/test/test_geom.c:41
 msgid ""
 "\n"
 "-- geom_data unit tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò geom_data ++"
 #: ../lib/gpde/test/test_geom.c:43
 msgid ""
 "\n"
 "-- geom_data unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò geom_data ++"
 #: ../lib/gpde/test/test_solute_transport.c:43
 msgid ""
 "\n"
 "++ Running solute_transport integration tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìÞò åíóùìÜôùóçò solute_transport ++"
 #: ../lib/gpde/test/test_solute_transport.c:45
 msgid "\t 1. testing 2d solute_transport"
-msgstr ""
+msgstr "\t 1. ÄïêéìÞò 2 äéáóôÜóåùí solute_transport"
 #: ../lib/gpde/test/test_solute_transport.c:48
 msgid "\t 2. testing 3d solute_transport"
-msgstr ""
+msgstr "\t 1. ÄïêéìÞò 3 äéáóôÜóåùí solute_transport"
 #: ../lib/gpde/test/test_solute_transport.c:52
 msgid ""
 "\n"
 "-- solute_transport integration tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò åíóùìÜôùóçò solute_transport ++"
 #: ../lib/gpde/test/test_solute_transport.c:55
 msgid ""
 "\n"
 "-- solute_transport integration tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò åíóùìÜôùóçò solute_transport ++"
 #: ../lib/gpde/test/test_assemble.c:42
 msgid ""
 "\n"
 "++ Running assembling unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò assembling ++"
 #: ../lib/gpde/test/test_assemble.c:44
 msgid "\t 1. testing 2d assembling"
-msgstr ""
+msgstr "\t 1. äïêéìÞò assembling 2 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_assemble.c:47
 msgid "\t 2. testing 3d assembling"
-msgstr ""
+msgstr "\t 1. äïêéìÞò assembling 3 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_assemble.c:51
 msgid ""
 "\n"
 "-- Assembling unit tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò assembling ++"
 #: ../lib/gpde/test/test_assemble.c:53
 msgid ""
 "\n"
 "-- Assembling unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò assembling ++"
 #: ../lib/gpde/test/test_gradient.c:42
 msgid ""
 "\n"
 "++ Running gradient unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò gradient ++"
 #: ../lib/gpde/test/test_gradient.c:44
 msgid "\t 1. testing 2d gradient"
-msgstr ""
+msgstr "\t 1. äïêéìÞò gradient 2 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_gradient.c:47
 msgid "\t 2. testing 3d gradient"
-msgstr ""
+msgstr "\t 1. äïêéìÞò gradient 3 äéáóôÜóåùí"
 #: ../lib/gpde/test/test_gradient.c:51
 msgid ""
 "\n"
 "-- Gradient unit tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò gradient ++"
 #: ../lib/gpde/test/test_gradient.c:53
 msgid ""
 "\n"
 "-- Gradient unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò gradient ++"
 #: ../lib/gpde/test/test_solvers.c:37
 msgid ""
 "\n"
 "++ Running solver unit tests ++"
 msgstr ""
+"\n"
+"++ ÅêôÝëåóç äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
 #: ../lib/gpde/test/test_solvers.c:42
 msgid ""
 "\n"
 "-- Solver unit tests failure --"
 msgstr ""
+"\n"
+"++ Áðïôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
 #: ../lib/gpde/test/test_solvers.c:44
 msgid ""
 "\n"
 "-- Solver unit tests finished successfully --"
 msgstr ""
+"\n"
+"++ Åðéôõ÷ßá åêôÝëåóçò äïêéìÞò ìïíÜäïò åðßëõóçò (solver) ++"
 #: ../lib/gpde/N_solvers_classic_iter.c:57
 #: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers.c:56
@@ -286,7 +347,7 @@
 #: ../lib/gpde/N_solvers_krylov.c:78 ../lib/gpde/N_solvers_krylov.c:255
 #: ../lib/gpde/N_solvers_krylov.c:423 ../lib/gpde/N_solvers_krylov.c:832
 msgid "The linear equation system is not quadratic"
-msgstr ""
+msgstr "Ç ãñáììéêÞ óõíÜñôçóç äåí åßíáé 2ïõ âáèìïý"
 #: ../lib/gpde/N_solvers_classic_iter.c:152
 #, c-format
@@ -311,15 +372,17 @@
 #: ../lib/gpde/N_parse_options.c:59
 msgid ""
 "The type of solver which should solve the symmetric linear equation system"
-msgstr ""
+msgstr "Ï ôýðïò ôïõ åðéëýôç ðïõ ðéèáíÜ ëýíåé ôï óõììåôñéêü ãñáììéêü óýóôçìá"
 #: ../lib/gpde/N_parse_options.c:71
 msgid "The type of solver which should solve the linear equation system"
-msgstr ""
+msgstr "Ï ôýðïò ôïõ åðéëýôç ðïõ ðéèáíÜ ëýíåé ôï ãñáììéêü óýóôçìá"
 #: ../lib/gpde/N_parse_options.c:80
 msgid "Maximum number of iteration used to solver the linear equation system"
 msgstr ""
+"ÌÝãéóôïò áñéèìüò åðáíáëÞøåùí ðïõ ÷ñçóéìïðïéÞèçêáí óôïí åðéëýôç ãéá ôï "
+"ãñáììéêü óýóôçìá"
 #: ../lib/gpde/N_parse_options.c:89
 msgid ""
@@ -334,74 +397,74 @@
 #: ../lib/gpde/N_parse_options.c:105
 msgid "The calculation time in seconds"
-msgstr ""
+msgstr "Ï ÷ñüíïò õðïëïãßæåôáé óå äåõôåñüëåðôá"
 #: ../lib/gpde/N_arrays_io.c:55
 #, c-format
 msgid "Raster map <%s> not found"
-msgstr ""
+msgstr "Ï ÷Üñôçò raster  <%s> äåí âñÝèçêå"
 #: ../lib/gpde/N_arrays_io.c:67
 #, c-format
 msgid "Unable to open raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
 #: ../lib/gpde/N_arrays_io.c:96
 #, c-format
 msgid "Reading raster map <%s> into memory"
-msgstr ""
+msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> óôç ìíÞìç"
 #: ../lib/gpde/N_arrays_io.c:103
 msgid "Could not get raster row"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò (row) ôïõ ÷Üñôç"
 #: ../lib/gpde/N_arrays_io.c:149 ../lib/gpde/N_arrays_io.c:231
 msgid "Unable to close input map"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ ÷Üñôç input"
 #: ../lib/gpde/N_arrays_io.c:178
 msgid "N_array_2d * array is empty"
-msgstr ""
+msgstr "N_array_2d * ðßíáêáò êåíüò"
 #: ../lib/gpde/N_arrays_io.c:190
 #, c-format
 msgid "Unable to create raster map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
 #: ../lib/gpde/N_arrays_io.c:199
 #, c-format
 msgid "Write 2d array to raster map <%s>"
-msgstr ""
+msgstr "ÅããñáöÞ ðßíáêá 2 äéáóôÜóåùí óôïí raster ÷Üñôç <%s>"
 #: ../lib/gpde/N_arrays_io.c:215 ../lib/gpde/N_arrays_io.c:220
 #: ../lib/gpde/N_arrays_io.c:225
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to write rast row %i"
-msgstr ""
+msgstr "Áäõíáìßá åããñáöÞò ãñáììÞ raster %i"
 #: ../lib/gpde/N_arrays_io.c:282
 #, c-format
 msgid "Requested g3d map <%s> not found"
-msgstr ""
+msgstr "Ï ÷Üñôçò g3d <%s> äåí âñÞèçêå"
 #: ../lib/gpde/N_arrays_io.c:290 ../lib/gpde/N_arrays_io.c:428
 #, c-format
 msgid "Error opening g3d map <%s>"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
 #: ../lib/gpde/N_arrays_io.c:318
 #, c-format
 msgid "Read g3d map <%s> into the memory"
-msgstr ""
+msgstr "Öüñôùóç ôïõ g3d ÷Üñôç <%s> óôç ìíÞìç"
 #: ../lib/gpde/N_arrays_io.c:371 ../lib/gpde/N_arrays_io.c:469
 msgid "Error closing g3d file"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôï êëåßóéìï ôïõ g3d áñ÷åßïõ"
 #: ../lib/gpde/N_arrays_io.c:430
 #, c-format
 msgid "Write 3d array to g3d map <%s>"
-msgstr ""
+msgstr "ÅããñáöÞ ðßíáêá 3 äéáóôÜóåùí óôïí g3d ÷Üñôç <%s>"
 #: ../lib/gpde/N_solvers.c:51
 msgid "The gauss elimination solver does not work with sparse matrices"
@@ -426,7 +489,7 @@
 #: ../lib/gpde/N_solvers.c:167 ../lib/gpde/N_solvers_krylov.c:84
 #: ../lib/gpde/N_solvers_krylov.c:261
 msgid "Matrix is not symmetric!"
-msgstr ""
+msgstr "Ï ðßíáêáò äåí åßíáé óõììåôñéêüò!"
 #: ../lib/gpde/N_solvers.c:171
 msgid "Starting cholesky decomposition solver"
@@ -435,7 +498,7 @@
 #: ../lib/gpde/N_solvers.c:174 ../lib/gpde/N_solvers_krylov.c:190
 #: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
 msgid "Unable to solve the linear equation system"
-msgstr ""
+msgstr "Áäõíáìßá ëýóçò ôïõ ãñáììéêïý óõóôÞìáôïò"
 #: ../lib/gpde/N_solvers_krylov.c:198
 #, c-format
@@ -471,101 +534,108 @@
 #, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
 msgstr ""
+"Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. Äåí ðñÝðåé íá ðåñéÝ÷åé  '.'  Þ 'íá åßíáé "
+"êåíüò'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:30
 #, c-format
 msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr ""
+msgstr "Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. ÐñÝðåé íá îåêéíÜ ìå ãñÜììá.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:36
 #, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
 msgstr ""
+"Ìç åðéôñåðôÞ ïíïìáóßá ðßíáêá <%s>. Ï ÷áñáêôÞñáò <%c> äåí ðñÝðåé íá "
+"÷ñçóéìïðïéçèåß.\n"
 #: ../lib/db/dbmi_client/column.c:106
 #, c-format
 msgid "Cannot describe table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
 #: ../lib/driver/parse_ftcap.c:33
 #, c-format
 msgid "%s: Unable to read font definition file; use the default"
 msgstr ""
+"%s: Áäõíáìßá áíÜãíùóçò ôïõ áñ÷åßïõ ãñáììáôïóåéñÜò, ÷ñçóéìïðïéÞóôå ôï "
+"ðñïåðéëåãìÝíï"
 #: ../lib/driver/parse_ftcap.c:39
 #, c-format
 msgid "%s: No font definition file"
-msgstr ""
+msgstr "%s: Äåí õðáñ÷åéï áñ÷åßï ãñáììáôïóåéñÜò"
 #: ../lib/driver/command.c:517
 #, c-format
 msgid "Unknown command: %d last: %d"
-msgstr ""
+msgstr "¶ãíùóôç åíôïëÞ: %d last: %d"
 #: ../lib/driver/command.c:559
 msgid "Monitor: get_command: Premature EOF"
-msgstr ""
+msgstr "Monitor: get_command: Premature EOF"
 #: ../lib/driver/main.c:89
 #, c-format
 msgid "Graphics driver [%s] started"
-msgstr ""
+msgstr "Åêêßíçóç ôïõ ïäçãïý êÜñôáò ãñáöéêþí [%s]"
 #: ../lib/raster/rem_io.c:43
 #, c-format
 msgid "ERROR %s from graphics driver.\n"
-msgstr ""
+msgstr "ÓÖÁËÌÁ %s áðü ôïí ïäçãüò êÜñôáò ãñáöéêþí.\n"
 #: ../lib/raster/rem_io.c:172
 #, c-format
 msgid "Unable to allocate memory\n"
-msgstr ""
+msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
 #: ../lib/raster/rem_io.c:225
 #, c-format
 msgid "ERROR - eof from graphics monitor.\n"
-msgstr ""
+msgstr "ÓÖÁËÌÁ - eof áðü ôçí ïèüíç ãñáöéêþí.\n"
 #: ../lib/raster/rem_io.c:244
 #, c-format
 msgid "Warning - no response from graphics monitor <%s>.\n"
-msgstr ""
+msgstr "Ðñïóï÷Þ - êáìßá áðüêñéóç áðü ôçí ïèüíç ãñáöéêþí <%s>.\n"
 #: ../lib/raster/rem_io.c:246
 #, c-format
 msgid "Check to see if the mouse is still active.\n"
-msgstr ""
+msgstr "ÄïêéìÜóôå áí ôïí ðïíôßêé (mouse) áðïêñßíåôáé.\n"
 #: ../lib/raster/rem_io.c:251
 #, c-format
 msgid "ERROR - no response from graphics monitor <%s>.\n"
-msgstr ""
+msgstr "ÓÖÁËÌÁ - êáìßá áðüêñéóç áðï ôçí ïèüíç ãñáöéêþí <%s>.\n"
 #: ../lib/raster/io_sock.c:65
 msgid "No graphics monitor has been selected for output."
-msgstr ""
+msgstr "Äåí Ý÷åé åðéëïãÞ êáìßá ïèüíç ãñáöéêþí ùò Ýîïäïò."
 #: ../lib/raster/io_sock.c:66
 msgid "Please run \"d.mon\" to select a graphics monitor."
 msgstr ""
+"Ðáñáêáëþ åêôåëÝóôå ôçí åíôïëÞ \"d.mon\" ãéá íá åðéëÝîåôå ïèüíç ãñáöéêþí."
 #: ../lib/raster/io_sock.c:75
 #, c-format
 msgid "Failed to get socket name for monitor <%s>."
-msgstr ""
+msgstr "Áäõíáìßá ëÞøçò ïíüìáôïò áðü ôçí ïèüíç <%s>."
 #: ../lib/raster/io_sock.c:85
 #, c-format
 msgid "No socket to connect to for monitor <%s>."
-msgstr ""
+msgstr "Äåí õðÜñ÷åé óýíäåóç ôïõ socket ãéá óýíäåóç óôçí ïèüíç <%s>."
 #: ../lib/raster/io_sock.c:105
 msgid "Socket is already in use or not accepting connections."
-msgstr ""
+msgstr "Ôï socket ÷ñçóéìïðïéÞôáé Þäç êáé äåí äÝ÷åôáé Üëëåò óõíäÝóåéò."
 #: ../lib/raster/io_sock.c:106
 msgid "Use d.mon to select a monitor"
-msgstr ""
+msgstr "×ñçóéìïðïéÞóôå ôçí åíôïëÞ  d.mon ãéá íá åðéëÝîåôå ïèüíç"
 #: ../lib/raster/io_sock.c:113
 msgid "Trying to connect to something not a socket."
@@ -573,19 +643,19 @@
 #: ../lib/raster/io_sock.c:114
 msgid "Probably program error."
-msgstr ""
+msgstr "Ðéèáíü ëÜèïò ôïõ ðñïãñÜììáôïò."
 #: ../lib/raster/io_sock.c:120
 msgid "Connect attempt timed out."
-msgstr ""
+msgstr "Ç ðñïóðÜèåéá óýíäåóçò áðÝôõ÷å (timed out)."
 #: ../lib/raster/io_sock.c:121
 msgid "Probably an error with the server."
-msgstr ""
+msgstr "Ðéèáíü ðñüâëçìá ìå ôïí äéáêïìéóôÞ (server)."
 #: ../lib/raster/io_sock.c:129
 msgid "Connection failed."
-msgstr ""
+msgstr "ÓöÜëìá óýíäåóçò."
 #: ../lib/vector/diglib/plus_area.c:211 ../lib/vector/diglib/plus_area.c:648
 #: ../lib/vector/diglib/plus_area.c:654
@@ -603,9 +673,9 @@
 msgstr ""
 #: ../lib/vector/diglib/plus_area.c:316
-#, c-format
+#, fuzzy, c-format
 msgid "Attempt to delete not registered isle [%d] from area [%d]"
-msgstr ""
+msgstr "ÐñïóðÜèåéá áíÜãíùóçò ôïðïãñáößáò ãéá êåíÞ (dead) åðéöÜíåéá (%d)"
 #: ../lib/vector/diglib/plus_area.c:354
 msgid "Attempt to delete dead area"
@@ -617,50 +687,54 @@
 msgstr ""
 #: ../lib/vector/diglib/plus_area.c:413
-#, c-format
+#, fuzzy, c-format
 msgid "Attempt to delete area [%d] info from dead isle [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus_area.c:741
-#, c-format
+#, fuzzy, c-format
 msgid "Attempt to delete isle [%d] info from dead area [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:318
+#, fuzzy
 msgid "Cannot read topo for nodes"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò [%d]"
 #: ../lib/vector/diglib/plus.c:324
-#, c-format
+#, fuzzy, c-format
 msgid "Cannot read topo for node [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:329
+#, fuzzy
 msgid "Cannot read topo for lines"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:335
 #, c-format
 msgid "Cannot read topo for line [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:340
+#, fuzzy
 msgid "Cannot read topo for areas"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò ôùí ðåñéï÷þí"
 #: ../lib/vector/diglib/plus.c:346
-#, c-format
+#, fuzzy, c-format
 msgid "Cannot read topo for area [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:351
+#, fuzzy
 msgid "Cannot read topo for isles"
-msgstr ""
 #: ../lib/vector/diglib/plus.c:357
-#, c-format
+#, fuzzy, c-format
 msgid "Cannot read topo for isle [%d]"
-msgstr ""
 #: ../lib/vector/diglib/plus_node.c:244
 #, c-format
@@ -673,21 +747,21 @@
 #: ../lib/vector/Vlib/close.c:36 ../lib/vector/Vlib/read.c:27
 #: ../lib/vector/Vlib/rewind.c:34 ../lib/vector/Vlib/write.c:38
 msgid "Requested format is not compiled in this version"
-msgstr ""
+msgstr "Ôï óõãêåêñéìÝíï format äåí ãßíåé compiled ãéá ôçí Ýêäïóç áõôÞ"
 #: ../lib/vector/Vlib/build.c:143
 #, c-format
 msgid "Building topology for vector map <%s>...\n"
-msgstr ""
+msgstr "Äçìéïõñãßá ôïðïëïãßáò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>...\n"
 #: ../lib/vector/Vlib/build.c:156
 msgid "Topology was built\n"
-msgstr ""
+msgstr "Ç ôïðïëïãßá äçìéïõñãÞèçêå\n"
 #: ../lib/vector/Vlib/build.c:168
 #, c-format
 msgid "Number of nodes     :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò êüìâùí     :   %d\n"
 #: ../lib/vector/Vlib/build.c:169
 #, c-format
@@ -697,22 +771,22 @@
 #: ../lib/vector/Vlib/build.c:170
 #, c-format
 msgid "Number of points    :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò óçìåßùí    :   %d\n"
 #: ../lib/vector/Vlib/build.c:171
 #, c-format
 msgid "Number of lines     :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò ãñáììþí     :   %d\n"
 #: ../lib/vector/Vlib/build.c:172
 #, c-format
 msgid "Number of boundaries:   %d\n"
-msgstr ""
+msgstr "Áñéèìüò óõíïñéáêþí ãñáììþí:   %d\n"
 #: ../lib/vector/Vlib/build.c:173
 #, c-format
 msgid "Number of centroids :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò êÝíôñùí ðïëõãþíïõ :   %d\n"
 #: ../lib/vector/Vlib/build.c:176
 #, c-format
@@ -722,12 +796,12 @@
 #: ../lib/vector/Vlib/build.c:179
 #, c-format
 msgid "Number of kernels   :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò ðõñÞíùí   :   %d\n"
 #: ../lib/vector/Vlib/build.c:214
 #, c-format
 msgid "Number of areas     :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò ðåñéï÷þí     :   %d\n"
 #: ../lib/vector/Vlib/build.c:215
 #, c-format
@@ -737,26 +811,26 @@
 #: ../lib/vector/Vlib/build.c:218
 #, c-format
 msgid "Number of incorrect boundaries   :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò ëáíèáóìÝíùí óõíïñéáêþí ãñáììþí (boundaries)   :   %d\n"
 #: ../lib/vector/Vlib/build.c:221
 #, c-format
 msgid "Number of centroids outside area :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò êÝíôñùí ðïëõãþíùí Ýîù áðü ôçí ðåñéï÷Þ :   %d\n"
 #: ../lib/vector/Vlib/build.c:224
 #, c-format
 msgid "Number of duplicate centroids    :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò äéðëþí êÝíôñùí ðïëõãþíùí    :   %d\n"
 #: ../lib/vector/Vlib/build.c:227
 #, c-format
 msgid "Number of areas without centroid :   %d\n"
-msgstr ""
+msgstr "Áñéèìüò ðåñéï÷þí ÷ùñßò êÝíôñá :   %d\n"
 #: ../lib/vector/Vlib/build.c:230
 msgid "Number of areas     :   -\n"
-msgstr ""
+msgstr "Áñéèìüò ðåñéï÷þí     :   -\n"
 #: ../lib/vector/Vlib/build.c:231
 msgid "Number of isles     :   -\n"
@@ -765,24 +839,25 @@
 #: ../lib/vector/Vlib/build.c:261
 #, c-format
 msgid "Unable to open topo file for write <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ ãéá åããñáöÞ <%s>"
 #: ../lib/vector/Vlib/build.c:269
 msgid "Error writing out topo file"
-msgstr ""
+msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ ÷Üñôç"
 #: ../lib/vector/Vlib/build.c:405
 #, c-format
 msgid "Unable open spatial index file for write <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ðßíáêá ÷ùñéêþí äåäïìÝíùí ãéá åããñáöÞ <%s>"
 #: ../lib/vector/Vlib/build.c:413
 msgid "Error writing out spatial index file"
-msgstr ""
+msgstr "ÓöÜëìá åããñáöÞò ÷ùñéêþí äåäïìÝíùí óôï áñ÷åßï"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
 msgstr ""
+"Ç 3äéÜóôáôç áðåéêüíéóç äåí õðïóôçñßæåôáé áðü ôï Vect_segment_intersection()"
 #: ../lib/vector/Vlib/intersect.c:265
 msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
@@ -801,64 +876,68 @@
 #: ../lib/vector/Vlib/legal_vname.c:110 ../lib/vector/Vlib/map.c:305
 #, c-format
 msgid "Vector map <%s> not found"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
 #: ../lib/vector/Vlib/open.c:166
 msgid ""
 "Vector map which is not in the current mapset cannot be opened for update"
 msgstr ""
+"Ï äéáíõóìáôéêüò ÷Üñôçò ðïõ äåí áíÞêåé óôï ôñÝ÷ïí mapset äåí ìðïñåß íá "
+"áíïßîåé ãéá åíçìÝñùóç"
 #: ../lib/vector/Vlib/open.c:184
 #, c-format
 msgid "Unable to open vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:194 ../lib/vector/Vlib/open.c:254
 #: ../lib/vector/Vlib/open.c:271
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to open vector map <%s> on topology level %d"
-msgstr ""
+msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
 #: ../lib/vector/Vlib/open.c:195
 msgid "Unable to read head file"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò head áñ÷åßïõ"
 #: ../lib/vector/Vlib/open.c:215
 #, c-format
 msgid "Unable to open topology file for vector map <%s>"
 msgstr ""
+"Áäõíáìßá áíïßãìáôïò ôïðïëïãéêïý áñ÷åßïõ ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:238
 #, c-format
 msgid "Unable to open category index file for vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ õðïìíÞìáôïò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:319 ../lib/vector/Vlib/open.c:530
 #, c-format
 msgid "Unable to open history file for vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:496 ../lib/vector/Vlib/map.c:169
 #: ../lib/vector/Vlib/map.c:293
 #, c-format
 msgid "Vector map name is not SQL compliant"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé óõìâáôüò ìå SQL"
 #: ../lib/vector/Vlib/open.c:503 ../lib/vector/Vlib/map.c:173
 #: ../lib/vector/Vlib/map.c:297
 #, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
 msgstr ""
+"Ï äéáíõóìáôéêüò ÷Üñôçò <%s> õðÜñ÷åé Þäç êáé èá áíôéêáôáóôáèåß (overwritten)"
 #: ../lib/vector/Vlib/open.c:507 ../lib/vector/Vlib/map.c:176
 #, c-format
 msgid "Unable to delete vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äéáãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:521
 #, c-format
 msgid "Unable to create vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:576
 #, c-format
@@ -872,13 +951,13 @@
 #: ../lib/vector/Vlib/open.c:694
 #, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr ""
+msgstr "Ðáñáêáëþ îáíáöôéÜîôå ôçí ôïðïëïãßá ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s@%s>"
 #: ../lib/vector/Vlib/snap.c:119 ../lib/vector/Vlib/snap.c:159
 #: ../lib/vector/Vlib/break_polygons.c:191
 #: ../lib/vector/Vlib/break_polygons.c:198
 msgid "Registering points"
-msgstr ""
+msgstr "ÅããñáöÞ óçìåßùí"
 #: ../lib/vector/Vlib/snap.c:168
 msgid "All vertices"
@@ -886,7 +965,7 @@
 #: ../lib/vector/Vlib/snap.c:169
 msgid "Registered points"
-msgstr ""
+msgstr "ÅããåãñáìÝíá óçìåßá"
 #: ../lib/vector/Vlib/snap.c:214
 msgid "Nodes marked as anchor"
@@ -911,42 +990,51 @@
 #: ../lib/vector/Vlib/close.c:126
 #, c-format
 msgid "Unable to close vector <%s>"
-msgstr ""
+msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
 #: ../lib/vector/Vlib/legal_vname.c:43
 #, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
 msgstr ""
+"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. äåí ðñÝðåé íá ðåñéÝ÷åé '.' Þ  "
+"'NULL'."
 #: ../lib/vector/Vlib/legal_vname.c:49
 #, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
 msgstr ""
+"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. ÐñÝðåé íá îåêéíÜ ìå ãñÜììá."
 #: ../lib/vector/Vlib/legal_vname.c:56
 #, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
 msgstr ""
+"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç <%s>. Ï ÷áñáêôÞñáò '%c' äåí "
+"åðéôñÝðåôáé."
 #: ../lib/vector/Vlib/legal_vname.c:66
 #, c-format
 msgid ""
 "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
 msgstr ""
+"Ìç åðéôñåðôü üíïìá äéáíõóìáôéêüõ ÷Üñôç  <%s>. Ç ëÝîç êëåéäß SQL äåí ìðïñåß "
+"íá ÷ñçóéìïðïéçèåß þò üíïìá ôïõ ÷Üñôç."
 #: ../lib/vector/Vlib/legal_vname.c:95 ../lib/vector/Vlib/legal_vname.c:97
 #, c-format
 msgid "Output vector map name <%s> is not valid map name"
-msgstr ""
+msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
 #: ../lib/vector/Vlib/legal_vname.c:128 ../lib/vector/Vlib/legal_vname.c:130
 #, c-format
 msgid "Output vector map <%s> is used as input"
 msgstr ""
+"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
+"äåäïìÝíùí."
 #: ../lib/vector/Vlib/cindex.c:30
 msgid "Category index is not up to date"
-msgstr ""
+msgstr "Ï êáôÜëïãïò ôùí êáôçãïñéþí äåí åßíáé åíçìåñùìÝíïò"
 #: ../lib/vector/Vlib/cindex.c:62 ../lib/vector/Vlib/cindex.c:129
 #: ../lib/vector/Vlib/cindex.c:148 ../lib/vector/Vlib/cindex.c:171
@@ -982,22 +1070,26 @@
 #: ../lib/vector/Vlib/clean_nodes.c:52 ../lib/vector/Vlib/clean_nodes.c:216
 msgid "Modifications"
-msgstr ""
+msgstr "ÌåôáôñïðÝò"
 #: ../lib/vector/Vlib/read.c:99
+#, fuzzy
 msgid "Vector map is not opened"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò äåí åßíáé áíïéêôüò"
 #: ../lib/vector/Vlib/read.c:102
-#, c-format
+#, fuzzy, c-format
 msgid ""
 "Vect_read_line(): line %d is not reasonable (max line in vector map: %d)"
 msgstr ""
+"Vect_read_line():ãñáììÞ %d äåí Ý÷åé ëïãéêÞ (max ãñáììÞ óôïí äéáíõóìáôéêü "
+"÷Üñôç: %d)"
 #: ../lib/vector/Vlib/dangles.c:122 ../lib/vector/Vlib/dangles.c:211
 #: ../lib/vector/Vlib/dangles.c:219
+#, fuzzy
 msgid "Removed dangles"
-msgstr ""
+msgstr "Ðåñéï÷Ýò ðïõ áöáéñÝèçêáí"
 #: ../lib/vector/Vlib/array.c:97
 #, c-format
@@ -1020,36 +1112,37 @@
 #, c-format
 msgid "Database connection not defined for layer %d"
 msgstr ""
+"Äåí Ý÷åé êáèïñéóôåß ç óýíäåóç ìå ôç âÜóç äåäïìÝíùí ãéá ôï åðßðåäï (layer) %d"
 #: ../lib/vector/Vlib/array.c:270 ../lib/vector/Vlib/map.c:249
 #: ../lib/vector/Vlib/map.c:376 ../lib/vector/Vlib/map.c:578
 #: ../lib/vector/Vlib/net.c:176 ../lib/vector/Vlib/net.c:313
 #, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
 #: ../lib/vector/Vlib/array.c:280
 #, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr ""
+msgstr "Áäõíáìßá åðéëïãÞò ôçò åããñáöÞò <%s> (êëåéäß %s, üðïõ %s)"
 #: ../lib/vector/Vlib/break_polygons.c:200
 msgid "All points (vertices)"
-msgstr ""
+msgstr "¼ëá ôá óçìåßá (vertices)"
 #: ../lib/vector/Vlib/break_polygons.c:201
 msgid "Registered points (unique coordinates)"
-msgstr ""
+msgstr "ÅããåãñáìÝíá óçìåßá (ìïíáäéêÝò óõíôåôáãìÝíåò)"
 #: ../lib/vector/Vlib/break_polygons.c:202
 msgid "Points marked for break"
-msgstr ""
+msgstr "Óçìåßá \"óçìáäåìÝíá\" ãéá óðÜóéìï (break)"
 #: ../lib/vector/Vlib/break_polygons.c:208
 #: ../lib/vector/Vlib/break_polygons.c:272
 #: ../lib/vector/Vlib/break_polygons.c:292
 msgid "Breaks"
-msgstr ""
+msgstr "\"Óðáóßìáôá\" (breaks)"
 #: ../lib/vector/Vlib/bridges.c:118 ../lib/vector/Vlib/bridges.c:191
 #: ../lib/vector/Vlib/bridges.c:197
@@ -1058,20 +1151,21 @@
 #: ../lib/vector/Vlib/poly.c:243
 msgid "Unable to find point in polygon"
-msgstr ""
+msgstr "Áäõíáìßá åýñåóçò óçìåßïõ óôï ðïëýãùíï"
 #: ../lib/vector/Vlib/poly.c:661
+#, fuzzy
 msgid "Conditions failed"
-msgstr ""
+msgstr "Ïé óõíèÞêåò áðÝôõ÷áí"
 #: ../lib/vector/Vlib/cats.c:46
 msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
+msgstr "Vect_new_cats_struct(): ç ìíÞìç ãÝìéóå"
 #: ../lib/vector/Vlib/cats.c:135
 #, c-format
 msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
+msgstr "ÐÜñá ðïëëÝò êáôçãïñßåò (%d), äåí ìðïñåß íá cat %d (åðßðåäï %d)"
 #: ../lib/vector/Vlib/cats.c:398
 #, c-format
@@ -1079,60 +1173,64 @@
 msgstr ""
 #: ../lib/vector/Vlib/sindex.c:97
+#, fuzzy
 msgid "Not implemented"
-msgstr ""
+msgstr "Äåí Ý÷åé åöáñìïóôåß"
 #: ../lib/vector/Vlib/sindex.c:108
 #, c-format
 msgid "Unable to delete item %d from spatial index"
-msgstr ""
+msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôïõ áíôéêåéìÝíïõ %d áðü ôï ÷ùñéêü ðßíáêá"
 #: ../lib/vector/Vlib/sindex.c:127
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topo level 2"
 msgstr ""
+"Áäõíáìßá äçìéïñãßáò ÷ùñéêïý ðßíáêá áðü ôçí ôïðïëïãßá, ï äéáíõóìáôéêüò ÷Üñôçò "
+"äåí åßíáé áíïéêôüò óôï topo level 2"
 #: ../lib/vector/Vlib/sindex.c:169
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
-msgstr ""
+msgstr "BUG (Vect_build_sidx_from_topo): êüìâïò äåí õðÜñ÷åé"
 #: ../lib/vector/Vlib/sindex.c:180
 msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
-msgstr ""
+msgstr "BUG (Vect_build_sidx_from_topo): ç ãñáììÞ äåí õðÜñ÷åé"
 #: ../lib/vector/Vlib/sindex.c:198
 msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
-msgstr ""
+msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
 #: ../lib/vector/Vlib/sindex.c:216
 msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
 msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:38
-#, c-format
+#, fuzzy, c-format
 msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
-msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:60
-#, c-format
+#, fuzzy, c-format
 msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
-msgstr ""
 #: ../lib/vector/Vlib/write_nat.c:565
+#, fuzzy
 msgid "Attempt to delete dead line"
-msgstr ""
+msgstr "ÐñïóðÜèåéá äéáãñáöÞò Üêõñçò ãñáììÞò"
 #: ../lib/vector/Vlib/level_two.c:217 ../lib/vector/Vlib/level_two.c:242
 #: ../lib/vector/Vlib/level_two.c:266 ../lib/vector/Vlib/level_two.c:285
 #: ../lib/vector/Vlib/level_two.c:303 ../lib/vector/Vlib/level_two.c:322
 #, c-format
 msgid "Vector map <%s> is not open on level >= 2"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí åßíáé áíïéêôüò óå åðßðåäï >= 2"
 #: ../lib/vector/Vlib/graph.c:107 ../lib/vector/Vlib/net.c:380
 msgid "GngFlatten error"
-msgstr ""
+msgstr "GngFlatten óöÜëìá"
 #: ../lib/vector/Vlib/graph.c:137
 msgid "Unable to add network arc"
@@ -1141,31 +1239,32 @@
 #: ../lib/vector/Vlib/graph.c:218 ../lib/vector/Vlib/net.c:449
 #, c-format
 msgid "dglShortestPath error: %s"
-msgstr ""
+msgstr "dglShortestPath óöÜëìá: %s"
 #: ../lib/vector/Vlib/build_nat.c:93
 msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
+msgstr "Áäõíáìßá ðñïóèÞêçò åðéöÜíåéáò (÷Üñôçò êëåéóôüò, ôïðïãñáößá óùóìÝíç)"
 #: ../lib/vector/Vlib/build_nat.c:101
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
+msgstr "Unable to add isle (÷Üñôçò êëåéóôüò, ôïðïãñáößá óùóìÝíç)"
 #: ../lib/vector/Vlib/build_nat.c:110
 msgid "Area of size = 0.0 ignored"
-msgstr ""
+msgstr "ÅðéöÜíåéá ìåãÝèïõò = 0.0 áãíïåßôáé"
 #: ../lib/vector/Vlib/build_nat.c:147
 msgid "Request to find area outside nonexisting isle"
 msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:485
+#, fuzzy
 msgid "Registering lines: "
-msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:492
 msgid "Unable to read vector map"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
 #: ../lib/vector/Vlib/build_nat.c:526
 msgid "Primitives registered"
@@ -1173,15 +1272,17 @@
 #: ../lib/vector/Vlib/build_nat.c:536
 msgid "Building areas: "
-msgstr ""
+msgstr "Äçìéïõñãßá åðéöáíåéþí"
 #: ../lib/vector/Vlib/build_nat.c:553
+#, fuzzy
 msgid "Areas built"
-msgstr ""
+msgstr "ÅðéöÜíåéåò äçìéïõñãÞèçêáí"
+#, fuzzy
 msgid "Isles built"
-msgstr ""
 #: ../lib/vector/Vlib/build_nat.c:561
 msgid "Attaching islands: "
@@ -1197,6 +1298,8 @@
 "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
+"Ôá áñ÷åßá óõíôåôáãìÝíùí (coor) ôùí äéáíõóìáôéêþí ÷áñôþí <%s@%s> åßíáé "
+"ìåãáëýôåñá áðü üóï èá Ýðñåðå (%ld bytes excess)"
 #: ../lib/vector/Vlib/open_nat.c:146
 #, c-format
@@ -1204,11 +1307,13 @@
 "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
 "missing)."
 msgstr ""
+"ìéêñüôåñá áðü üóï èá Ýðñåðå (%ld bytes missing)."
 #: ../lib/vector/Vlib/build_ogr.c:257
 #, c-format
 msgid "Unable to calculate centroid for area %d"
-msgstr ""
+msgstr "Áäõíáìßá õðïëïãéóìïý êÝíôñùí ðïëõãþíïõ ãéá ôçí åðéöÜíåéá %d"
 #: ../lib/vector/Vlib/build_ogr.c:292 ../lib/vector/Vlib/read_ogr.c:112
 #: ../lib/vector/Vlib/read_ogr.c:285
@@ -1227,16 +1332,16 @@
 #: ../lib/vector/Vlib/build_ogr.c:336
 msgid "Feature: "
-msgstr ""
+msgstr "×áñáêôçñéóôéêü: "
 #: ../lib/vector/Vlib/build_ogr.c:354
 #, c-format
 msgid "Feature %d without geometry ignored"
-msgstr ""
+msgstr "×áñáêôçñéóôéêü %d ÷ùñßò ãåùìåôñßá áãíïåßôáé"
 #: ../lib/vector/Vlib/build_ogr.c:361
 msgid "OGR feature without ID ignored"
-msgstr ""
+msgstr "OGR ÷áñáêôçñéóôéêü ÷ùñßò ID áãíïåßôáé"
 #: ../lib/vector/Vlib/level.c:39
 msgid "Map structure was never initialized"
@@ -1244,22 +1349,23 @@
 #: ../lib/vector/Vlib/level.c:41
 msgid "Map structure has been closed"
-msgstr ""
+msgstr "Ç äïìÞ ôïõ ÷Üñôç Ý÷åé êëåßóåé"
 #: ../lib/vector/Vlib/area.c:55
+#, fuzzy
 msgid "Attempt to read points of nonexisting area"
-msgstr ""
+msgstr "ÐñïóðÜèåéá ðñïóðåëáóçò óçìåßùí óå åðéöÜíåéá ðïõ äåí õðÜñ÷åé"
 #: ../lib/vector/Vlib/area.c:131
 #, c-format
 msgid "Unable to read line %d"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
 #: ../lib/vector/Vlib/area.c:173 ../lib/vector/Vlib/area.c:205
 #: ../lib/vector/Vlib/area.c:274 ../lib/vector/Vlib/area.c:307
 #, c-format
 msgid "Attempt to read topo for dead area (%d)"
-msgstr ""
 #: ../lib/vector/Vlib/area.c:335
 #, c-format
@@ -1268,22 +1374,22 @@
 #: ../lib/vector/Vlib/open_ogr.c:54
 msgid "OGR format cannot be updated"
-msgstr ""
+msgstr "OGR format äåí ìðïñåß íá áíáíåùèåß"
 #: ../lib/vector/Vlib/open_ogr.c:66
 #, c-format
 msgid "Unable to open OGR data source '%s'"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò OGR ðçãÞ äåäïìÝíùí '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:84
 #, c-format
 msgid "Unable to open layer <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:128
 #, c-format
 msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ fidx ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s@%s>"
 #: ../lib/vector/Vlib/open_ogr.c:144
 #, c-format
@@ -1301,7 +1407,7 @@
 #: ../lib/vector/Vlib/remove_areas.c:56 ../lib/vector/Vlib/remove_areas.c:168
 msgid "Removed areas"
-msgstr ""
 #: ../lib/vector/Vlib/remove_areas.c:93
 msgid "Area is composed of dead boundary"
@@ -1310,99 +1416,107 @@
 #: ../lib/vector/Vlib/remove_duplicates.c:67
 #: ../lib/vector/Vlib/remove_duplicates.c:129
 msgid "Duplicates"
-msgstr ""
+msgstr "ÄéðëÝò åããñáöÝò"
 #: ../lib/vector/Vlib/map.c:55
+#, fuzzy
 msgid "Input vector map is not open"
-msgstr ""
+msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò åéóáãùãÞò äåí åßíáé áíïéêôüò"
 #: ../lib/vector/Vlib/map.c:65 ../lib/vector/Vlib/map.c:78
 #, c-format
 msgid "Unable to read vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/map.c:199 ../lib/vector/Vlib/map.c:308
 #, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
-msgstr ""
 #: ../lib/vector/Vlib/map.c:241 ../lib/vector/Vlib/map.c:355
 #: ../lib/vector/Vlib/map.c:572 ../lib/vector/Vlib/map.c:665
 #, c-format
 msgid "Unable to copy table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
 #: ../lib/vector/Vlib/map.c:253 ../lib/vector/Vlib/map.c:380
 #: ../lib/vector/Vlib/map.c:582
 #, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äçìéïõñãßáò êáôáëüãïõ ãéá ôïí ðßíáêá <%s>, êëåéäß <%s>"
 #: ../lib/vector/Vlib/map.c:369 ../lib/vector/Vlib/map.c:462
 #, c-format
 msgid "Unable to delete table <%s>"
-msgstr ""
+msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
 #: ../lib/vector/Vlib/map.c:417
 #, c-format
 msgid "Invalid vector map name <%s>"
-msgstr ""
+msgstr "ËÜèïò üíïìá äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/map.c:433
 #, c-format
 msgid "Unable to open header file for vector map <%s>"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò header áñ÷åßïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/map.c:453
 #, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
 msgstr ""
+"Áäõíáìßá åýñåóçò ôïõ ðßíáêá <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü "
+"÷Üñôç <%s>"
 #: ../lib/vector/Vlib/map.c:467
 #, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
 msgstr ""
+"Ï ðßíáêáò <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí äéáíõóìáôéêü ÷Üñôç <%s> äåí "
+"õðÜñ÷åé"
 #: ../lib/vector/Vlib/map.c:481
 #, c-format
 msgid "Unable to open directory '%s'"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
 #: ../lib/vector/Vlib/map.c:492
 #, c-format
 msgid "Unable to delete file '%s'"
-msgstr ""
+msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
 #: ../lib/vector/Vlib/map.c:509
 #, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-msgstr ""
+msgstr "Áäõíáìßá ìåôïíïìáóßáò êáôáëüãïõ óõóôÞìáôïò '%s' óå '%s'"
 #: ../lib/vector/Vlib/map.c:517
 #, c-format
 msgid "Unable to remove directory '%s'"
-msgstr ""
+msgstr "Áäõíáìßá ìåôáöïñÜò êáôáëüãïõ óõóôÞìáôïò '%s'"
 #: ../lib/vector/Vlib/map.c:564 ../lib/vector/Vlib/map.c:653
 #, c-format
 msgid "Unable to add database link for vector map <%s>"
 msgstr ""
+"Áäõíáìßá ðñïóèÞêçò óýíäåóçò ìå âÜóç äåäïìÝíùí ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/read_nat.c:146
 msgid "Attempt to read dead line"
 msgstr ""
 #: ../lib/vector/Vlib/overlay.c:76
+#, fuzzy
 msgid "Unknown operator"
-msgstr ""
+msgstr "¶ãíùóôïò ôåëåóôÞò"
 #: ../lib/vector/Vlib/overlay.c:124
 msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
+msgstr "Overlay: ãñáììÝò/üñéá ôýðïé äåí õðïóôçñßæïíôáé áðü AND ôåëåóôÞ"
 #: ../lib/vector/Vlib/overlay.c:127
 msgid "Overlay: area x area types not supported by AND operator"
 msgstr ""
+"Overlay: åðéöÜíåéá x åðéöÜíåéá ôýðïé äåí õðïóôçñßæïíôáé áðü AND ôåëåóôÞ"
 #: ../lib/vector/Vlib/read_ogr.c:165
 msgid "OGR feature without ID"
@@ -1415,39 +1529,45 @@
 #: ../lib/vector/Vlib/field.c:90
 msgid "Layer number must be 1 or greater"
-msgstr ""
+msgstr "Ôï íïýìåñï ôïõ åðéðÝäïõ ðñÝðåé íá åßíáé ìåãáëýôåñï Þ ßóï ìå 1"
 #: ../lib/vector/Vlib/field.c:95
 msgid "Unable to add database link, map is not opened in WRITE mode"
 msgstr ""
+"Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå êáôÜóôáóç "
+"åããñáöÞò (WRITE mode)"
 #: ../lib/vector/Vlib/field.c:101
 msgid "Unable to add database link"
-msgstr ""
+msgstr "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí"
 #: ../lib/vector/Vlib/field.c:107 ../lib/vector/Vlib/field.c:153
 msgid "Unable to write database links"
-msgstr ""
 #: ../lib/vector/Vlib/field.c:221
 #, c-format
 msgid "Layer number %d or name <%s> already exists"
-msgstr ""
+msgstr "Ôï åðßðåäï ìå áñéèìü %d Þ üíïìá <%s> õðÜñ÷åé Þäç"
 #: ../lib/vector/Vlib/field.c:285
+#, fuzzy
 msgid ""
 "Default driver / database set to:\n"
 "driver: dbf\n"
 "database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
 msgstr ""
+"ÐñïåðéëåãìÝíïò ïäçãüò / ç âÜóç äåäïìÝíùí Ý÷åé:\n"
+"driver: dbf\n"
+"database: $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/"
 #: ../lib/vector/Vlib/field.c:295
 msgid "Default driver is not set"
-msgstr ""
+msgstr "Ï ðñïåðéëåãìÝíïò ïäçãüò äåí Ý÷åé êáèïñéóôåß"
 #: ../lib/vector/Vlib/field.c:297
 msgid "Default database is not set"
-msgstr ""
+msgstr "Ç ðñïåðéëåãìÝíç âÜóç äåäïìÝíùí äåí Ý÷åé êáèïñéóôåß"
 #: ../lib/vector/Vlib/field.c:352
 #, c-format
@@ -1591,36 +1711,41 @@
 msgstr ""
 #: ../lib/vector/Vlib/write.c:96
+#, fuzzy
 msgid "Unable to write line, vector map is not opened"
-msgstr ""
 #: ../lib/vector/Vlib/write.c:107
+#, fuzzy
 msgid "Unable to write line (negative offset)"
-msgstr ""
 #: ../lib/vector/Vlib/write.c:143
+#, fuzzy
 msgid "Unable to rewrite line, vector map is not opened"
-msgstr ""
 #: ../lib/vector/Vlib/write.c:154
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to rewrite line %d"
-msgstr ""
 #: ../lib/vector/Vlib/write.c:201
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-msgstr ""
+msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s> óôï ôïðïëïãéêü åðßðåäï %d"
 #: ../lib/vector/Vlib/write.c:206
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
 msgstr ""
 #: ../lib/vector/Vlib/write.c:219
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to delete line %d from vector map <%s>"
-msgstr ""
 #: ../lib/vask/V_support.c:58
 #, c-format
@@ -1908,9 +2033,9 @@
 msgstr ""
 #: ../lib/gis/legal_name.c:75 ../lib/gis/legal_name.c:77
-#, c-format
+#, fuzzy, c-format
 msgid "Output name '%s' is not valid rast name."
-msgstr ""
 #: ../lib/gis/legal_name.c:88 ../lib/gis/legal_name.c:90
 #, c-format
@@ -1918,9 +2043,11 @@
 msgstr ""
 #: ../lib/gis/legal_name.c:109 ../lib/gis/legal_name.c:111
-#, c-format
+#, fuzzy, c-format
 msgid "Output map '%s' is used as input"
 msgstr ""
+"äåäïìÝíùí."
 #: ../lib/gis/debug.c:68
 #, c-format
@@ -1994,9 +2121,9 @@
 msgstr ""
 #: ../lib/gis/opencell.c:185
-#, c-format
+#, fuzzy, c-format
 msgid "unable to open raster map [%s in %s]"
-msgstr ""
 #: ../lib/gis/opencell.c:269
 #, c-format
@@ -2037,19 +2164,19 @@
 msgstr ""
 #: ../lib/gis/opencell.c:936 ../lib/gis/opencell.c:991
-#, c-format
+#, fuzzy, c-format
 msgid "unable to find [%s] in [%s]"
-msgstr ""
 #: ../lib/gis/opencell.c:1043
-#, c-format
+#, fuzzy, c-format
 msgid "unable to find [%s]"
-msgstr ""
 #: ../lib/gis/opencell.c:1049
-#, c-format
+#, fuzzy, c-format
 msgid "Unable to open %s"
-msgstr ""
 #: ../lib/gis/opencell.c:1058
 #, c-format
@@ -2607,9 +2734,9 @@
 msgstr ""
 #: ../lib/gis/mapset_msc.c:49
-#, c-format
+#, fuzzy, c-format
 msgid "can't make mapset element %s (%s)"
-msgstr ""
 #: ../lib/gis/parser.c:345
 msgid "WHERE conditions of SQL statement without 'where' keyword"
@@ -2865,8 +2992,9 @@
 msgstr ""
 #: ../lib/gis/parser.c:1985
+#, fuzzy
 msgid "Unable to spawn wish"
-msgstr ""
 #: ../lib/gis/parser.c:2004
 msgid "Unable to determine program name"
@@ -3852,3 +3980,351 @@
 #: ../lib/rst/interp_float/input2d.c:72
 msgid "Bitmap mask created"
 msgstr ""
+#, fuzzy
+#~ msgid "Unable to start driver <%s>"
+#~ msgstr "Áäõíáìßá êëåéóßìáôïò ôïõ äéáíýóìáôïò <%s>"
+#, fuzzy
+#~ msgid "Unable to get list tables in database <%s>"
+#~ msgstr "Áäõíáìßá äéáãñáöÞò ðßíáêá <%s>"
+#, fuzzy
+#~ msgid "Table <%s> already exists in database <%s>"
+#, fuzzy
+#~ msgid "Unable to open select cursor: '%s'"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
+#, fuzzy
+#~ msgid "Column <%s> not found"
+#~ msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+#, fuzzy
+#~ msgid "Unable to create table <%s>"
+#, fuzzy
+#~ msgid "Unable to fetch data from table <%s>"
+#~ msgstr "Áäõíáìßá áíôéãñáöÞò ðßíáêá <%s>"
+#, fuzzy
+#~ msgid "Unable select records from table <%s>"
+#~ msgstr "Áäõíáìßá åðéëïãÞò ôçò åããñáöÞò <%s> (êëåéäß %s, üðïõ %s)"
+#, fuzzy
+#~ msgid "Unable to open driver <%s>"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò åðéðÝäïõ <%s>"
+#, fuzzy
+#~ msgid "Unable to drop table: '%s'"
+#, fuzzy
+#~ msgid "Unable to describe table <%s>"
+#, fuzzy
+#~ msgid "Unable open database <%s> by driver <%s>"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ôçò âÜóçò äåäïìÝíùí <%s> ìå ôïí ïäçãü <%s>"
+#, fuzzy
+#~ msgid "Unable to delete node %d from spatial index"
+#~ msgstr "Äåí ãßíåôáé ç äéáãñáöÞ ôïõ áíôéêåéìÝíïõ %d áðü ôï ÷ùñéêü ðßíáêá"
+#, fuzzy
+#~ msgid "Unable to delete line %d from spatial index"
+#, fuzzy
+#~ msgid "Attempt to delete sidx for dead area"
+#~ msgstr "ÐñïóðÜèåéá äéáãñáöÞò Üêõñçò ãñáììÞò"
+#, fuzzy
+#~ msgid "Unable to delete area %d from spatial index"
+#, fuzzy
+#~ msgid "Unable to delete isle %d from spatial index"
+#, fuzzy
+#~ msgid "Unable read topology for nodes"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò ôùí ôïðïãñáöéêþí êüìâùí (nodes)"
+#, fuzzy
+#~ msgid "Unable to read topology for node %d"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò ôïõ ôïðïãñáöéêïý êüìâïõ (node) [%d]"
+#, fuzzy
+#~ msgid "Unable read topology for lines"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò ôùí ãñáììþí"
+#, fuzzy
+#~ msgid "Unable to read topology for line %d"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
+#, fuzzy
+#~ msgid "Unable read topology for area %d"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò ôçò ðåñéï÷Þò [%d]"
+#, fuzzy
+#~ msgid "Unable to read topology for isles"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò head áñ÷åßïõ"
+#, fuzzy
+#~ msgid "Unable to read topology for isle %d"
+#, fuzzy
+#~ msgid "Unable to write head to plus file"
+#, fuzzy
+#~ msgid "Unable to write nodes to plus file"
+#~ msgstr "Áäõíáìßá åããñáöÞò ãñáììÞ raster %i"
+#, fuzzy
+#~ msgid "Unable to write lines to plus file"
+#, fuzzy
+#~ msgid "Unable to write areas to plus file"
+#, fuzzy
+#~ msgid "Unable to write isles to plus file"
+#, fuzzy
+#~ msgid "Unknown query tool"
+#~ msgstr "¶ãíùóôïò ôåëåóôÞò"
+#, fuzzy
+#~ msgid "Unable to set category %d for line %d"
+#, fuzzy
+#~ msgid "Unable to delete layer/category %d/%d line %d"
+#~ msgstr "Áäõíáìßá äéáãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to open vector map <%s> on level %d. Try to rebuild vector "
+#~ "topology by v.build."
+#~ msgstr ""
+#~ "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s> óôï ôïðïëïãéêü åðßðåäï %d"
+#, fuzzy
+#~ msgid "%s: Area %d does not exist"
+#~ msgstr "BUG (add_area_cats_to_cidx): Ç åðéöÜíåéá %d äåí õðÜñ÷åé"
+#, fuzzy
+#~ msgid "Attempt to restore alive feature"
+#, fuzzy
+#~ msgid "Registering primitives: "
+#~ msgstr "ÅããñáöÞ óçìåßùí"
+#, fuzzy
+#~ msgid "Unable to find vector map <%s> in <%s>"
+#~ msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
+#, fuzzy
+#~ msgid "Unable to rewrite feature %d"
+#, fuzzy
+#~ msgid ""
+#~ "Unable to restore feature %d, vector map <%s> is not opened on topology "
+#~ "level"
+#~ msgstr ""
+#, fuzzy
+#~ msgid ""
+#~ "Unable to restore feature %d, vector map <%s> is not opened in 'write' "
+#~ "mode"
+#~ msgstr ""
+#~ "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå "
+#~ "êáôÜóôáóç åããñáöÞò (WRITE mode)"
+#, fuzzy
+#~ msgid "Unable to restore feature %d from vector map <%s>"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Output raster map name <%s> is not valid map name"
+#~ msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
+#, fuzzy
+#~ msgid "Output raster map <%s> is used as input"
+#~ msgstr ""
+#~ "Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
+#~ "äåäïìÝíùí."
+#, fuzzy
+#~ msgid "Unable to find <%s@%s>"
+#, fuzzy
+#~ msgid "Raster map <%s> is not in the current mapset (%s)"
+#~ msgstr ""
+#~ "Ï äéáíõóìáôéêüò ÷Üñôçò ðïõ äåí áíÞêåé óôï ôñÝ÷ïí mapset äåí ìðïñåß íá "
+#~ "áíïßîåé ãéá åíçìÝñùóç"
+#, fuzzy
+#~ msgid "Raster map <%s> not found in mapset <%s>"
+#~ msgstr "Ï ÷Üñôçò raster  <%s> äåí âñÝèçêå"
+#, fuzzy
+#~ msgid "Raster map <%s> is not xdr: byte_order: %s"
+#, fuzzy
+#~ msgid "Using <%s@%s>"
+#, fuzzy
+#~ msgid "Unable to locate symbol <%s>"
+#, fuzzy
+#~ msgid "Unable to load GDAL library"
+#~ msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
+#, fuzzy
+#~ msgid "Unable to create rendering context"
+#~ msgstr "Áäõíáìßá äçìéïõñãßáò raster ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Unable to set focus"
+#~ msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
+#, fuzzy
+#~ msgid "Error loading vector map <%s>"
+#~ msgstr "ÓöÜëìá êáôÜ ôï Üíïéãìá ôïõ g3d ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Error loading 3d raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to define new light"
+#~ msgstr "Áäõíáìßá åýñåóçò óçìåßïõ óôï ðïëýãùíï"
+#, fuzzy
+#~ msgid "Unable to read target file for group [%s]"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Vector map <%s> loaded (%d features)"
+#, fuzzy
+#~ msgid "Loading 3d raster map <%s>..."
+#~ msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> óôç ìíÞìç"
+#, fuzzy
+#~ msgid "3D raster map <%s> not found"
+#, fuzzy
+#~ msgid "Unable to allocate stream"
+#, fuzzy
+#~ msgid "Video codec not found"
+#, fuzzy
+#~ msgid "Unable to open codec"
+#, fuzzy
+#~ msgid "Unable to allocate picture"
+#, fuzzy
+#~ msgid "Unable to allocate temporary picture"
+#, fuzzy
+#~ msgid "Error while writing video frame"
+#~ msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ ÷Üñôç"
+#, fuzzy
+#~ msgid "Unable to find suitable output format"
+#~ msgstr ""
+#~ "Áäõíáìßá åýñåóçò ôïõ ðßíáêá <%s> ðïõ åßíáé óõíäåäåìÝíïò ìå ôïí "
+#~ "äéáíõóìáôéêü ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Invalid output format parameters"
+#~ msgstr "ËÜèïò üíïìá äéáíõóìáôéêïý ÷Üñôç <%s>"
+#, fuzzy
+#~ msgid "Unable to open <%s>"
+#, fuzzy
+#~ msgid "Unable to open file <%s> for writing"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ ãéá åããñáöÞ <%s>"
+#, fuzzy
+#~ msgid "Unable to process vector map - out of memory"
+#~ msgstr "Áäõíáìßá áíÜãíùóçò äéáíõóìáôéêïý ÷Üñôç"
+#, fuzzy
+#~ msgid "Unable to read color file of raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to read category file of raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to read fp range of raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to read range of raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to show discrete FP range (use list"
+#~ msgstr "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí"
+#, fuzzy
+#~ msgid "Unable to allocate memory for a null buffer"
+#, fuzzy
+#~ msgid "Loading raster map <%s>..."
+#, fuzzy
+#~ msgid "Translating colors from raster map <%s>..."
+#~ msgstr "Äçìéïõñãßá ôïðïëïãßáò ãéá ôïí äéáíõóìáôéêü ÷Üñôç <%s>...\n"
+#, fuzzy
+#~ msgid "Unable to open 3D raster map <%s>"
+#~ msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+#, fuzzy
+#~ msgid "Unable to read range of 3D raster map <%s>"
+#, fuzzy
+#~ msgid "Unable to close 3D raster map <%s>"
+#, fuzzy
+#~ msgid "Vector map <%s> loaded (%d points)"
+#, fuzzy
+#~ msgid "Loading failed"
+#~ msgstr "Ïé óõíèÞêåò áðÝôõ÷áí"
Added: grass/trunk/locale/po/grasswxpy_el.po
--- grass/trunk/locale/po/grasswxpy_el.po	                        (rev 0)
+++ grass/trunk/locale/po/grasswxpy_el.po	2008-10-12 07:15:47 UTC (rev 33837)
@@ -0,0 +1,7135 @@
+# translation of grasswxpy_el.po to Greek - Báóßëåéïò Áíôùíßïõ
+# This file is distributed under the same license as the GRASS package.
+# Copyright (C) 2008 GRASS Development Team
+msgid ""
+msgstr ""
+"Project-Id-Version: grasswxpy_el\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2008-10-11 14:54+0200\n"
+"Language-Team: Báóßëåéïò Áíôùíßïõ <grass-translations at lists.osgeo."
+"org>\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=ISO-8859-7\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../gui/wxpython/icons/icon.py:162
+msgid "Unable to load icon theme, using default icon theme..."
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:228
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:230
+msgid "Re-render map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:231
+msgid "Force re-rendering of all layers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:233
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:235
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:237
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:238
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:240
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:241
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:243
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:244
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:246
+msgid "Query raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:247
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:249
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:251
+msgid "Zoom options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:252
+msgid "Display zoom management"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:254
+msgid "Add overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:255
+msgid "Add graphic overlays to map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:257
+msgid "Add scalebar and north arrow"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:259
+msgid "Add legend"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:261
+msgid "Save display to PNG file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:263
+#: ../gui/wxpython/gui_modules/mapdisp.py:3268
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:266
+msgid "Start new display"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:268
+msgid "Create new workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:270
+msgid "Load map layers into workspace"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:272
+#: ../gui/wxpython/gui_modules/menudata.py:35
+msgid "Open existing workspace file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:274
+#: ../gui/wxpython/gui_modules/menudata.py:50
+msgid "Save current workspace to file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:277
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:279
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:281
+msgid "Add command layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:283
+msgid "Add layer group"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:285
+msgid "Add grid or vector labels overlay"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:287 ../gui/wxpython/gui_modules/dbm.py:2281
+msgid "Delete selected layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:289
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:291
+msgid "Show attribute table"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:293
+msgid "Add RGB layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:295
+msgid "Add HIS layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:297
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:299
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:301
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:303
+msgid "Add thematic layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:305
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:307
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:309
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:311
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:313
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:315
+#: ../gui/wxpython/gui_modules/mapdisp.py:3846
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:317
+msgid "Add 3D raster map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:320
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:321 ../gui/wxpython/icons/icon.py:330
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:323
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:324 ../gui/wxpython/icons/icon.py:327
+#: ../gui/wxpython/icons/icon.py:348
+msgid "Left: new point; Middle: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:326
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:329
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:332
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:333 ../gui/wxpython/icons/icon.py:336
+#: ../gui/wxpython/icons/icon.py:339 ../gui/wxpython/icons/icon.py:351
+#: ../gui/wxpython/icons/icon.py:354 ../gui/wxpython/icons/icon.py:357
+#: ../gui/wxpython/icons/icon.py:363 ../gui/wxpython/icons/icon.py:369
+msgid "Left: Select; Middle: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:335
+#: ../gui/wxpython/gui_modules/toolbars.py:689
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:338
+msgid "Delete feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:341
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:342 ../gui/wxpython/icons/icon.py:345
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:344
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:347
+msgid "Edit line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:350
+msgid "Move feature(s)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:353
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:356
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:359 ../gui/wxpython/icons/icon.py:419
+#: ../gui/wxpython/icons/icon.py:423
+#: ../gui/wxpython/gui_modules/nviz_tools.py:945
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:360
+msgid "Settings dialog for digitization tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:362
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:365
+msgid "Quit digitizing tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:367
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:371
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:372
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:375
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:377
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:379
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:381
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:383
+msgid "Draw/re-draw profile"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:385
+msgid "Profile options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:387
+msgid "Create histogram of image or raster file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:389
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:391
+msgid "Select color"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:393
+#: ../gui/wxpython/gui_modules/gdialogs.py:297
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:395
+msgid "Analyze"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:398
+msgid "Set GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:399
+msgid "Define GCP (Ground Control Points)"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:401
+#: ../gui/wxpython/gui_modules/menudata.py:433
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:403
+msgid "Recalculate RMS error"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:405
+msgid "Redraw GCP markers in map displays"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:407
+msgid "Save GCPs to POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:409
+msgid "Add new GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:411
+msgid "Delete selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:413
+msgid "Clear selected GCP"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:415
+msgid "Reload GCPs from selected POINTS file"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:417
+msgid "Quit georectification module"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:420
+msgid "Settings dialog for georectification tool"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:424
+msgid "Show Nviz settings dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:138
+#: ../gui/wxpython/gui_modules/menuform.py:1179
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:186
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:203
+#, python-format
+msgid "Parameter not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:221
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:255
+#: ../gui/wxpython/gui_modules/menuform.py:1408
+msgid "<required>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:256
+#, python-format
+msgid "Parameter %(name)s (%(desc)s) is missing.\n"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:627
+msgid "Enter parameters for "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:631
+msgid " (those in bold typeface are required)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:642
+msgid "Close this window without executing the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:647
+msgid "Show manual page of the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:665
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:666
+msgid "Run the command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:670
+msgid "Abort the running command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:674
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:706
+#: ../gui/wxpython/gui_modules/gdialogs.py:68
+#: ../gui/wxpython/gui_modules/preferences.py:1089
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:715
+#: ../gui/wxpython/gui_modules/preferences.py:1079
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:827
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:882
+#: ../gui/wxpython/gui_modules/menuform.py:895
+#: ../gui/wxpython/gui_modules/menuform.py:1275
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:885
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:923 ../gui/wxpython/wxgui.py:310
+#: ../gui/wxpython/wxgui.py:400
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:930
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1005
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1043
+msgid "Valid range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1198
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1215
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1216
+#: ../gui/wxpython/gui_modules/menudata.py:26
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1217
+#: ../gui/wxpython/gui_modules/location_wizard.py:137
+#: ../gui/wxpython/gui_modules/location_wizard.py:1076
+#: ../gui/wxpython/gui_modules/location_wizard.py:1154
+#: ../gui/wxpython/gui_modules/location_wizard.py:1246
+#: ../gui/wxpython/gui_modules/gdialogs.py:801
+#: ../gui/wxpython/gui_modules/gdialogs.py:811 ../gui/wxpython/gis_set.py:123
+msgid "Browse"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1477
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1511
+#, python-format
+msgid "Unable to fetch interface description for command '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1595
+#, python-format
+msgid "Unable to parse command %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menuform.py:1683
+#, python-format
+msgid "usage: %s <grass command>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:131
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:145
+#: ../gui/wxpython/gis_set.py:99
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:161
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:199
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:210
+#: ../gui/wxpython/gui_modules/location_wizard.py:1839
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:213
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:217
+#: ../gui/wxpython/gui_modules/location_wizard.py:540
+#: ../gui/wxpython/gui_modules/location_wizard.py:1420
+#: ../gui/wxpython/gui_modules/location_wizard.py:1840
+#: ../gui/wxpython/gui_modules/location_wizard.py:1916
+#: ../gui/wxpython/gui_modules/location_wizard.py:2021
+#: ../gui/wxpython/gui_modules/location_wizard.py:2055
+#: ../gui/wxpython/gui_modules/location_wizard.py:2230
+#: ../gui/wxpython/gui_modules/location_wizard.py:2249
+#: ../gui/wxpython/gui_modules/location_wizard.py:2556
+#: ../gui/wxpython/gui_modules/gdialogs.py:144
+#: ../gui/wxpython/gui_modules/gdialogs.py:1000
+#: ../gui/wxpython/gui_modules/mapdisp.py:1138
+#: ../gui/wxpython/gui_modules/mapdisp.py:1769
+#: ../gui/wxpython/gui_modules/mapdisp.py:2718
+#: ../gui/wxpython/gui_modules/preferences.py:1501
+#: ../gui/wxpython/gui_modules/gcmd.py:59
+#: ../gui/wxpython/gui_modules/gcmd.py:82
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:406
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:431
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1224
+#: ../gui/wxpython/gui_modules/georect.py:885
+#: ../gui/wxpython/gui_modules/georect.py:922
+#: ../gui/wxpython/gui_modules/workspace.py:617
+#: ../gui/wxpython/gui_modules/dbm.py:188
+#: ../gui/wxpython/gui_modules/dbm.py:272
+#: ../gui/wxpython/gui_modules/dbm.py:1217
+#: ../gui/wxpython/gui_modules/dbm.py:1321
+#: ../gui/wxpython/gui_modules/dbm.py:1405
+#: ../gui/wxpython/gui_modules/dbm.py:1417
+#: ../gui/wxpython/gui_modules/dbm.py:1431
+#: ../gui/wxpython/gui_modules/dbm.py:1524
+#: ../gui/wxpython/gui_modules/dbm.py:1546
+#: ../gui/wxpython/gui_modules/dbm.py:1686
+#: ../gui/wxpython/gui_modules/dbm.py:1697
+#: ../gui/wxpython/gui_modules/dbm.py:1709
+#: ../gui/wxpython/gui_modules/dbm.py:2554
+#: ../gui/wxpython/gui_modules/dbm.py:2561
+#: ../gui/wxpython/gui_modules/dbm.py:2599
+#: ../gui/wxpython/gui_modules/vdigit.py:1895
+#: ../gui/wxpython/gui_modules/vdigit.py:2073
+#: ../gui/wxpython/gui_modules/vdigit.py:2097 ../gui/wxpython/gis_set.py:672
+#: ../gui/wxpython/wxgui.py:731 ../gui/wxpython/wxgui.py:863
+#: ../gui/wxpython/wxgui.py:872
+msgid "Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:239
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:246
+msgid "Select coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:249
+msgid "Select EPSG code of coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:251
+msgid "Use coordinate system of selected georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:254
+msgid "Use coordinate system of selected WKT or PRJ file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:257
+msgid "Create custom PROJ.4 parameters string for coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:260
+msgid "Use arbitrary non-earth coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:332
+msgid "Choose projection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:347
+#: ../gui/wxpython/gui_modules/location_wizard.py:771
+#: ../gui/wxpython/gui_modules/location_wizard.py:779
+#: ../gui/wxpython/gui_modules/location_wizard.py:964
+#: ../gui/wxpython/gui_modules/location_wizard.py:1254
+msgid "Code"
+msgstr ""
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:350
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:358
+#: ../gui/wxpython/gui_modules/location_wizard.py:793
+#: ../gui/wxpython/gui_modules/location_wizard.py:976
+#: ../gui/wxpython/gui_modules/location_wizard.py:1237
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:539
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:639
+#: ../gui/wxpython/gui_modules/location_wizard.py:1431
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:647
+msgid "Select datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:650
+msgid "Select ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:651
+msgid "Set zone for UTM projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:653
+msgid "Zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:656
+msgid "Hemisphere for zone:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:744
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+msgid "Datum"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:784
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:808
+msgid "Transformation parameters:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:941
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:968
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1069
+#: ../gui/wxpython/gui_modules/location_wizard.py:1128
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1074
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1147
+#: ../gui/wxpython/gui_modules/location_wizard.py:1206
+msgid "Select WKT file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1152
+msgid "WKT file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1225
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1233
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1235
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1247
+msgid "Browse EPSG Codes"
+msgstr ""
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1368
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1419
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1439
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1490
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1512
+msgid "GRASS Database:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1518
+msgid "Location Name:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1524
+msgid "Projection:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1563
+msgid "PROJ.4 definition:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1608
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1609
+msgid "Create new location?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1645
+msgid "Define new GRASS Location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1723
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1725
+#, python-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1739
+#, python-format
+msgid "Unable to create new location. Location <%s> not created."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1741
+#: ../gui/wxpython/gui_modules/location_wizard.py:1749
+#: ../gui/wxpython/gis_set.py:127
+msgid "Location wizard"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1747
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:1837
+#: ../gui/wxpython/gui_modules/location_wizard.py:1915
+#: ../gui/wxpython/gui_modules/location_wizard.py:2020
+#: ../gui/wxpython/gui_modules/location_wizard.py:2094
+#: ../gui/wxpython/gui_modules/location_wizard.py:2125
+msgid "Unable to create new location"
+msgstr ""
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2054
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2095
+#: ../gui/wxpython/gui_modules/location_wizard.py:2126
+msgid "file not found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2149
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2193
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2229
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2248
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2278
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2279
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2302
+#: ../gui/wxpython/gui_modules/location_wizard.py:2583
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2303
+#: ../gui/wxpython/gui_modules/location_wizard.py:2584
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2304
+#: ../gui/wxpython/gui_modules/location_wizard.py:2585
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2345
+#: ../gui/wxpython/gui_modules/location_wizard.py:2587
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2346
+#: ../gui/wxpython/gui_modules/location_wizard.py:2588
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2349
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2357
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2365
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2428
+msgid "North"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2436
+msgid "West"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2456
+msgid "East"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2465
+msgid "South"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2469
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2477
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2555
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2612
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2626
+msgid "List of datum transformations"
+msgstr ""
+#: ../gui/wxpython/gui_modules/location_wizard.py:2630
+msgid "Datums:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:58
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:64
+msgid "Create attribute table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:127
+#: ../gui/wxpython/gui_modules/menudata.py:1201
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:143
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:160
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:163
+msgid "Overwrite?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:203
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:225
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:233
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:304
+#, python-format
+msgid ""
+"Drag %s with mouse in pointer mode to position.\n"
+"Double-click to change options."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:307
+msgid ""
+"\n"
+"Define raster map name for legend in properties dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:358
+#, python-format
+msgid "Legend of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:473
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:486
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:499
+#: ../gui/wxpython/gui_modules/preferences.py:960
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:510
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:601
+msgid "Load"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:636
+msgid "Map layer type:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:647
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:660
+msgid "Filter:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:672
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:728
+#: ../gui/wxpython/gui_modules/gdialogs.py:1081
+#: ../gui/wxpython/gui_modules/dbm.py:959
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:729
+#: ../gui/wxpython/gui_modules/gdialogs.py:1082
+#: ../gui/wxpython/gui_modules/dbm.py:960
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:782
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:796
+msgid "Input DXF file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:797
+msgid "Choose DXF file:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:800
+msgid "Choose DXF file to import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:806
+msgid "Input directory"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:807
+msgid "Choose directory:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:810
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:814
+msgid "Select file extension:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:831
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:839
+msgid "Close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:842
+msgid "&Import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:843
+msgid "Import selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:883
+#, python-format
+msgid " List of %s layers "
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:998
+#, python-format
+msgid ""
+"File <%(file)s>: Unable to get list of DXF layers.\n"
+"\n"
+"%(details)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1044
+#: ../gui/wxpython/gui_modules/dbm.py:2019
+#: ../gui/wxpython/gui_modules/dbm.py:2120
+#: ../gui/wxpython/gui_modules/dbm.py:2356
+#: ../gui/wxpython/gui_modules/dbm.py:3133
+#: ../gui/wxpython/gui_modules/vdigit.py:1382
+#: ../gui/wxpython/gui_modules/vdigit.py:1384
+#: ../gui/wxpython/gui_modules/vdigit.py:1765
+#: ../gui/wxpython/gui_modules/vdigit.py:2196
+msgid "Layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1045
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1046
+msgid "Output vector map name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1128
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1152
+msgid "transparent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gdialogs.py:1155
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1137
+#: ../gui/wxpython/gui_modules/mapdisp.py:1768
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1285
+#: ../gui/wxpython/gui_modules/mapdisp.py:1292
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:1886
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2353
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2404
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2406
+#: ../gui/wxpython/gui_modules/workspace.py:633
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2467
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2541
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2544
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2547
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2552
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2560
+#: ../gui/wxpython/gui_modules/preferences.py:1020
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2564
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2663
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2677
+msgid "Vector digitizer toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2694
+msgid "Georectification toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2706
+#, python-format
+msgid ""
+"Unable to start Nviz. The GLCanvas class has not been included with this "
+"build of wxPython! Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2711
+#, python-format
+msgid ""
+"Unable to start Nviz. Python extension for Nviz was not found or loaded "
+"properly. Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2742
+msgid "Please wait, loading data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:2772
+msgid "Nviz toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3260
+msgid "Page setup"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3264
+msgid "Print preview"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3358
+msgid "No map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3359
+#: ../gui/wxpython/gui_modules/mapdisp.py:3443
+#: ../gui/wxpython/gui_modules/dbm.py:2784 ../gui/wxpython/wxgui.py:1102
+#: ../gui/wxpython/wxgui.py:1470
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3442
+msgid "No vector map selected for querying."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3504
+msgid "Query raster/vector map(s) (display mode)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3512
+msgid "Query vector map (edit mode)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3626
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3633
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3637
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3795
+msgid "Scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3801
+msgid "Show/hide scale and North arrow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3802
+msgid "scale object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3828
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3829
+msgid "legend object"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3894
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:266
+msgid "Zoom to selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3898
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3902
+msgid "Zoom to default region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3906
+msgid "Zoom to saved region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3910
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mapdisp.py:3914
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:359
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:491
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:492
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:493
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:494
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:495
+#: ../gui/wxpython/gui_modules/dbm.py:951
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:496
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:521
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:522
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:523
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:524
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:525
+msgid "dtree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:526
+msgid "ctree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:527
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:528
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:529
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:596
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"       Details: %(detail)s\n"
+"       Line: '%(line)s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:626
+msgid "Uknown settings file location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:657
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:756
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:791
+msgid "User GUI settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:815
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:823
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:825
+#: ../gui/wxpython/gui_modules/georect.py:1541
+#: ../gui/wxpython/gui_modules/profile.py:990
+#: ../gui/wxpython/gui_modules/profile.py:1335
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1269
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:827
+#: ../gui/wxpython/gui_modules/georect.py:1543
+#: ../gui/wxpython/gui_modules/profile.py:992
+#: ../gui/wxpython/gui_modules/profile.py:1337
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1271
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:830
+#: ../gui/wxpython/gui_modules/georect.py:1546
+#: ../gui/wxpython/gui_modules/profile.py:995
+#: ../gui/wxpython/gui_modules/profile.py:1340
+#: ../gui/wxpython/gui_modules/vdigit.py:1075
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:858
+#: ../gui/wxpython/gui_modules/vdigit.py:1136
+#: ../gui/wxpython/gui_modules/nviz_tools.py:956
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:861
+msgid "General settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:872
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:894
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:897
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:910
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:922
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:940
+#: ../gui/wxpython/gui_modules/vdigit.py:1143
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:944
+#: ../gui/wxpython/gui_modules/preferences.py:1560
+#: ../gui/wxpython/gui_modules/profile.py:925
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:955
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:969
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:980
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1000
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1033
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1054
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1057
+msgid "Command dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1069
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1099
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1118
+msgid "Raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1129
+msgid "Make null cells opaque"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1143
+msgid "Vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1149
+#: ../gui/wxpython/gui_modules/nviz_tools.py:569
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1171
+#: ../gui/wxpython/gui_modules/vdigit.py:1364
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1179
+msgid "Highlighting"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1195
+msgid "Line width (in pixels)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1218
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1223
+msgid "Left mouse double click"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1234
+msgid "Encoding"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1245
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1266
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1273
+#: ../gui/wxpython/gui_modules/dbm.py:2142
+#: ../gui/wxpython/gui_modules/dbm.py:2166
+#: ../gui/wxpython/gui_modules/dbm.py:2382
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1299
+#: ../gui/wxpython/gui_modules/menudata.py:27
+msgid "Workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1302
+msgid "Loading workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1314
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1325
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1343
+#: ../gui/wxpython/gui_modules/dbm.py:589
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1346
+msgid "Advanced settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1358
+msgid "Place where to store settings:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1379
+msgid "Icon theme:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1396
+msgid "Note: Requires GUI restart."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1416
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1440
+#, python-format
+msgid "Settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1500
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1567
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1666
+msgid "Set/unset access to mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1680
+#, python-format
+msgid ""
+"Check mapset to make it accessible, uncheck it to hide it.%sNote: PERMANENT "
+"and current mapset are always accessible."
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1747
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1748
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_modules/preferences.py:1749
+msgid "Group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/sqlbuilder.py:43
+#, python-format
+msgid "GRASS SQL Builder: %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:93
+#, python-format
+msgid "Error in command execution %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:101
+msgid "Preferences error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:108
+msgid "Vector digitizer error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:115
+msgid "Attribute table manager error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:122
+msgid "Nviz error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:353
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:356
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:358
+#: ../gui/wxpython/gui_modules/gcmd.py:362
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/gui_modules/gcmd.py:447
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:92
+msgid "Create new color table for raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:94
+#: ../gui/wxpython/gui_modules/colorrules.py:388
+msgid "Enter raster cat values or percents"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:96
+msgid "Create new color table for vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:98
+msgid "Enter vector attribute values or ranges (n or n1 to n2)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:113
+msgid "replace existing color table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:119
+msgid "Layer:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:121
+msgid "Attribute column:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:123
+msgid "RGB color column:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:152
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:200
+msgid "Select raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:202
+msgid "Select vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:391
+#, python-format
+msgid "Enter raster cat values or percents (range = %d-%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/colorrules.py:463
+msgid "Please select attribute column and RGB color column first"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:479
+msgid "Loading raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:483
+msgid "Loading 3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:489
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:491
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:545
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:546
+msgid "Raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:550
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:551
+msgid "3d raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:558
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:609
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:660
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:663
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1185
+#, python-format
+msgid "Vector point layer not found (id=%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1187
+#, python-format
+msgid "Unable to set data layer properties (id=%d)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_mapdisp.py:1191
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:108
+msgid "GRASS GIS Map Display: "
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:118
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:251
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:255
+#: ../gui/wxpython/gui_modules/menudata.py:374
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:262
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:264
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:268
+msgid "Set computational region from selected map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:281
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:284
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:285
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:300
+msgid "Use as background vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:326
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:342
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:333
+msgid "Zoom to selected map (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:335
+msgid "Set computational region from selected map (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:338
+#: ../gui/wxpython/gui_modules/menudata.py:1690
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:340
+#: ../gui/wxpython/gui_modules/profile.py:1109
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:345
+msgid "Nviz properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:404
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:429
+msgid "Unable to display histogram of raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:514
+#, python-format
+msgid "Set opacity <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:588
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:593
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1144
+msgid "Click to edit layer settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:640
+#: ../gui/wxpython/gui_modules/georect.py:302
+msgid "raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:643
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:646
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:649
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:652
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:655
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:658
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:661
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:664
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:667
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:670
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:673
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:676
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:679
+msgid "(double click to set properties)"
+msgstr ""
+msgid "3d raster"
+msgstr ""
+msgid "RGB"
+msgstr ""
+msgid "HIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:738
+msgid "Shaded relief"
+msgstr ""
+msgid "raster cell numbers"
+msgstr ""
+msgid "raster flow arrows"
+msgstr ""
+msgid "vector"
+msgstr ""
+msgid "thematic map"
+msgstr ""
+msgid "thematic charts"
+msgstr ""
+msgid "grid"
+msgstr ""
+msgid "geodesic line"
+msgstr ""
+msgid "rhumbline"
+msgstr ""
+msgid "vector labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:953
+msgid "Please wait, updating data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/wxgui_utils.py:1223
+#, python-format
+msgid "Map <%s> not found."
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:697
+msgid "Duplicate attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:764
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:774
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:782
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:790
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:798
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:806
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:814
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:822
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:830
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:838
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1007
+#: ../gui/wxpython/gui_modules/toolbars.py:1099
+#: ../gui/wxpython/gui_modules/toolbars.py:1172
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1045
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1067
+msgid "Digitize"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1105
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1107
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1114
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/toolbars.py:1178
+#: ../gui/wxpython/gui_modules/toolbars.py:1183
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:52
+#: ../gui/wxpython/gui_modules/mcalc_builder.py:54
+#, python-format
+msgid "GRASS %s Map Calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:107
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:137
+#: ../gui/wxpython/gui_modules/georect.py:140
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:175
+msgid "Set ground control points (GCPs)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:274
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:301
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:308
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:319
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:373
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:384
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:401
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:420
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:431
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:434
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:440
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:491
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:496
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:541
+msgid "Select image/map to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:549
+msgid "Select display image/map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:581
+msgid "You must select a valid image/map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:605
+msgid "Create & manage ground control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:699
+msgid "Select rectification method for rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:700
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:706
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:711
+msgid "Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:777
+#, python-format
+msgid "At least %d GCPs required. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:778
+msgid "Delete GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:879
+#, python-format
+msgid "POINTS file <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:880
+msgid "POINTS file saved"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:883
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:920
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:965
+msgid "RMS Error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:966
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"7+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1037
+msgid "Georectifier settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1127
+#, python-format
+msgid "RMS error for selected points forward: %(fwd)s backward: %(bkw)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1160
+msgid "use| X coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1161
+msgid "Y coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1162
+msgid "E coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1163
+msgid "N coord"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1164
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1165
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1265
+#: ../gui/wxpython/gui_modules/georect.py:1373
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1266
+msgid "Invalid coordinate value. Operation cancelled."
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1384
+msgid "Ground Control Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1398
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1399
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1400
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1401
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1487
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1496
+#: ../gui/wxpython/gui_modules/nviz_tools.py:554
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1243
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1513
+#: ../gui/wxpython/gui_modules/nviz_tools.py:538
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1214
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/georect.py:1573
+#, python-format
+msgid "Georectifier settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:30
+msgid "Enter rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:50
+msgid "Create new color table using color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:51
+msgid "Raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:53
+msgid "Enter color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:56
+msgid "Reclassify raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:57
+msgid "Raster map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:58
+msgid "Reclassified raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:59
+#: ../gui/wxpython/gui_modules/rules.py:71
+msgid "Enter reclassification rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:62
+msgid "Recode raster map using rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:63
+msgid "Raster map to recode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:64
+msgid "Recoded raster map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:65
+msgid "Enter recoding rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:68
+msgid "Reclassify vector map using SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:69
+msgid "Vector map to reclassify:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:70
+msgid "Reclassified vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/rules.py:103
+msgid "overwrite existing file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:616
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:629
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/workspace.py:787
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:29
+msgid "New workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:30
+msgid "Create new workspace file (erase current workspace settings first)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:34
+msgid "Open existing workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:39
+msgid "Load map layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:40 ../gui/wxpython/wxgui.py:741
+msgid "Load map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:44
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:45
+msgid "Load map layers from GRC file to layer tree (not fully implemented)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:49 ../gui/wxpython/wxgui.py:825
+#: ../gui/wxpython/wxgui.py:843
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:54
+msgid "Save workspace as"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:55
+msgid "Save current workspace as file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:59
+msgid "Close current workspace"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:60
+msgid "Close current workspace file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:66
+msgid "Import raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:68
+msgid "Import raster data using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:69
+msgid "Import GDAL supported raster file into a binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:72
+msgid "Multiple raster data import using GDAL"
+msgstr ""
+msgid "Converts selected GDAL layers to GRASS raster maps using r.in.gdal."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:79
+msgid "Aggregate ASCII xyz import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:80
+msgid ""
+"Create a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:84
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:85
+msgid "Converts ASCII raster file to binary raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:89
+msgid "ASCII polygons and lines import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:90
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:95
+msgid "Binary file import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:96
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:100
+msgid "ESRI ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:101
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
+"map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:105
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:106
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:110
+msgid "MAT-File (v.4) import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:111
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:115
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:116
+msgid "Import of SPOT VGT NDVI file into a raster map"
+msgstr ""
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:121
+msgid "Import SRTM HGT files into GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:125
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:126
+msgid ""
+"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:131
+msgid "WMS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:132
+msgid "Downloads and imports data from WMS servers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:137
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:139
+msgid "Import vector data using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:140
+msgid "Convert OGR vector layers to GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:144
+msgid "Multiple vector data import using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:145
+msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:150
+msgid "ASCII points/GRASS ASCII vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:151
+msgid "Creates a vector map from ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:155
+msgid "Old GRASS vector import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:156
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:161
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:162
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:166
+msgid "Multiple DXF layers import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:167
+msgid "Converts selected DXF layers to GRASS vector maps (using v.in.dxf)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:172
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:173
+msgid "Import E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:177
+msgid "Garmin GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:178
+msgid ""
+"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:182
+msgid "GPSBabel GPS import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:183
+msgid ""
+"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
+"file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:187
+msgid "GEOnet import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:188
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:192
+msgid "Matlab and MapGen import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:193
+msgid "Import Mapgen or Matlab vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:198
+msgid "Import grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:200
+msgid "ASCII 3D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:201
+msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:205
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:206
+msgid ""
+"import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 "
+"time step)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:211
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:213
+msgid "Multiple import formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:214
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:220
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:222
+msgid "Multiple export formats using GDAL"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:223
+msgid "Exports GRASS raster map into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:228
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:229
+msgid "Converts a raster map layer into an ASCII text file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:233
+msgid "ASCII x,y,z export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:234
+msgid ""
+"Export a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:239
+msgid "ESRI ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:240
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:244
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:245
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:249
+msgid "MAT-File (v.4) export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:250
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:255
+msgid "Binary export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:256
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:261
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:262
+msgid "Raster File Series to MPEG Conversion Program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:266
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:267
+msgid "Export GRASS raster as non-georeferenced PNG image format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:271
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:272
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:276
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:277
+msgid ""
+"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
+"resolution of the CURRENTLY DEFINED REGION."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:281
+#: ../gui/wxpython/gui_modules/menudata.py:320
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:282
+msgid "Converts a raster map layer into a height-field file for POVRAY."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:286
+msgid "TIFF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:287
+msgid ""
+"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
+"resolution of the currently defined region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:291
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:292
+msgid "Export a raster map to the Virtual Reality Modeling Language (VRML)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:296
+#: ../gui/wxpython/gui_modules/menudata.py:330
+#: ../gui/wxpython/gui_modules/menudata.py:348
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:297
+msgid "Converts raster maps into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:302
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:304
+msgid "Multiple export formats using OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:305
+msgid "Converts to one of the supported OGR vector formats."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:310
+msgid "ASCII points/GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:311
+msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:315
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:316
+msgid "Exports GRASS vector map layers to DXF file format."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:321
+msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:325
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:326
+msgid "Exports a GRASS vector map to SVG."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:331
+msgid "Converts a GRASS binary vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:336
+msgid "Export grid 3D volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:338
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:339
+msgid "Converts a 3D raster map layer into an ASCII text file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:343
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:344
+msgid "Export of GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:349
+msgid "Converts 3D raster maps (G3D) into the VTK-Ascii format"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:355
+msgid "Manage maps and volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:357
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:358
+msgid ""
+"Copies available data files in the user's current mapset search path and "
+"location to the appropriate element directories under the user's current "
+"mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:363
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:364
+msgid ""
+"Lists available GRASS data base files of the user-specified data type to "
+"standard output."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:368
+msgid "List filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:369
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:375
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:380
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:381
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:385
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:386
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:391
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:393
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:394
+msgid "Converts a raster map into a vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:398
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:399
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:403
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:404
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:409
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:410
+msgid "Converts a binary GRASS vector map layer into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:414
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:415
+msgid ""
+"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
+"raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:419
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:420
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:425
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:426
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:434
+msgid "Georectify raster and vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:439
+msgid "NVIZ (requires Tcl/Tk)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:440
+msgid "nviz - Visualization and animation tool for GRASS data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:445
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:446
+msgid "It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:451
+msgid "Postscript plot"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:452
+msgid "Hardcopy PostScript map output utility."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:457
+msgid "E&xit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:458
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:463
+msgid "Config"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:464
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:466
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:467
+#: ../gui/wxpython/gui_modules/menudata.py:472
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:471
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:477
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:479
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:480
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:484
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:485
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:489
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:490
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:494
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:495
+#: ../gui/wxpython/gui_modules/menudata.py:500
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:499
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:504
+msgid "Version"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:505
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:510
+#: ../gui/wxpython/gui_modules/menudata.py:512
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:513
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format). Can also be used to create "
+"GRASS locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:517
+msgid "Projection for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:518
+msgid "Create/edit projection information for current location"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:523
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:524
+msgid "Convert coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:530
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:531
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:536
+msgid "Raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:537
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:539
+msgid "Digitize raster (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:540
+msgid "Digitize raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:545
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:546
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:551
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:552
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:556
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:557
+msgid "Creates explicitly the NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:561
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:562
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:566
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:567
+msgid "Print/add/remove a timestamp for a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:572
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:573
+msgid "Resamples raster map layers using aggregation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:577
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:578
+msgid "Resamples raster map layers using interpolation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:582
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:583
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:587
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:588
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:593
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:594
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:598
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:599
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:604
+msgid "Reproject raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:605
+msgid "Re-projects a raster map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:609
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:610
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:615
+#: ../gui/wxpython/gui_modules/menudata.py:1293
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:617
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:618
+msgid "Creates/modifies the color table associated with a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:622
+msgid "Color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:623
+#: ../gui/wxpython/gui_modules/menudata.py:1294
+msgid "Set colors interactively by entering color rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:628
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:629
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:633
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:634
+msgid ""
+"Combines red, green and blue map layers into a single composite map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:638
+#: ../gui/wxpython/gui_modules/menudata.py:1598
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:639
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:645
+msgid "Query by coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:646
+msgid "Queries raster map layers on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:651
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:652
+msgid ""
+"Creates a raster map layer showing buffer zones surrounding cells that "
+"contain non-NULL category values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:656
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:657
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:661
+#: ../gui/wxpython/gui_modules/nviz_tools.py:251
+#: ../gui/wxpython/gui_modules/nviz_tools.py:432
+#: ../gui/wxpython/gui_modules/nviz_tools.py:850
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:662
+msgid "Create a MASK for limiting raster operation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:666
+msgid "Map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:667
+msgid "Map calculator for raster map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:670
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:672
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:673
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:677
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:678
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:683
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:685
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:686
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:690
+msgid "Raster series"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:691
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:695
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:696
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:701
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:702
+msgid "Calculates category or object oriented statistics."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:707
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:709
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:710
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:714
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:715
+msgid ""
+"Calculates cast shadow areas from sun position and DEM. Either A: exact sun "
+"position is specified, or B: date/time to calculate the sun position by r."
+"sunmask itself."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:720
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:722
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:723
+msgid ""
+"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
+"between different geographic locations on an input elevation raster map "
+"layer whose cell category values represent elevation combined with an input "
+"raster map layer whose cell values represent friction cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:727
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:728
+msgid ""
+"Outputs a raster map layer showing the cumulative cost of moving between "
+"different geographic locations on an input raster map layer whose cell "
+"category values represent cost."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:732
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:733
+msgid "Traces a flow through an elevation model on a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:739
+msgid "Creates shaded relief map from an elevation map (DEM)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:744
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:745
+msgid ""
+"Generates raster map layers of slope, aspect, curvatures and partial "
+"derivatives from a raster map layer of true elevation values. Aspect is "
+"calculated counterclockwise from east."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:749
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:750
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:754
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:755
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:760
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:761
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:766
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:768
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:769
+msgid ""
+"Recategorizes data in a raster map layer by grouping cells that form "
+"physically discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:773
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:774
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:778
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:779
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:785
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:787
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:788
+msgid ""
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:792
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:793
+msgid "Fills lake from seed at given level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:798
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:799
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:803
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:804
+msgid "Flow computation for massive grids (Float version)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:808
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:809
+msgid ""
+"Construction of slope curves (flowlines), flowpath lengths, and flowline "
+"densities (upslope areas) from a raster digital elevation model (DEM)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:814
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:815
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:819
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:820
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:825
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:826
+msgid "Creates topographic index [ln(a/tan(beta))] map from elevation map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:830
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:831
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:836
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:837
+msgid "Generates a raster map layer showing watershed subbasins."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:841
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:842
+msgid "Watershed basin analysis program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:846
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:847
+msgid "Watershed basin creation program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:852
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:854
+msgid "Set up (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:855
+#: ../gui/wxpython/gui_modules/menudata.py:878
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:860
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:861
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:865
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:866
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:870
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:871
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:876
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:879
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:884
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:885
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:889
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:890
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:895
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:896
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:900
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:901
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:905
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:906
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:910
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:911
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:915
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:916
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:920
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:921
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:926
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:927
+#: ../gui/wxpython/gui_modules/menudata.py:943
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:931
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:932
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:936
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:937
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:942
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:947
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:948
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:953
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:955
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:956
+msgid ""
+"Generates three, or four raster map layers showing 1) the base "
+"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
+"direction of the maximum ROS, and optionally 4) the maximum potential "
+"spotting distance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:960
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:961
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:965
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:966
+msgid ""
+"It optionally produces raster maps to contain backlink UTM coordinates for "
+"tracing spread paths."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:972
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:974
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:975
+msgid "Interactively edit cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:980
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:981
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:985
+msgid "Reclassify interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:986
+msgid "Reclassify raster categories interactively by entering reclass rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:990
+msgid "Reclassify using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:991
+msgid ""
+"Creates a new map layer whose category values are based upon a "
+"reclassification of the categories in an existing raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:996
+msgid "Recode interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:997
+msgid ""
+"Recode raster categories interactively by entering recode rules (create new "
+"raster map)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1001
+msgid "Recode using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1002
+msgid ""
+"r.recode.rules - Use ascii rules file to recode categories in raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1007
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1008
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1012
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1013
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1020
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1021
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1024
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1026
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1027
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1031
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1032
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"sites."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1037
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1039
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1040
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1045
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1046
+msgid ""
+"Generates a raster density map from vector points data using a moving 2D "
+"isotropic Gaussian kernel or optionally generates a vector density map on "
+"vector network with a 1D kernel."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1050
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1051
+msgid ""
+"GRASS module to produce a raster map layer of gaussian deviates whose mean "
+"and standard deviation can be expressed by the user. It uses a gaussian "
+"random number generator."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1056
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1057
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1062
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1063
+msgid ""
+"Produces a raster map layer of uniform random deviates whose range can be "
+"expressed by the user."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1067
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1068
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1074
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1075
+msgid ""
+"Produces a vector map layer of specified contours from a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1078
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1080
+msgid "Bilinear from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1081
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1085
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1086
+msgid "Bicubic or bilinear spline interpolation with Tykhonov regularization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1091
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1092
+msgid "Surface interpolation utility for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1096
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1097
+msgid ""
+"Surface interpolation from vector point data by Inverse Distance Squared "
+"Weighting."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1102
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1103
+msgid "Surface generation program from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1107
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1108
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1113
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1114
+msgid ""
+"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1120
+#: ../gui/wxpython/gui_modules/menudata.py:1732
+msgid "Report and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1122
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1123
+msgid "Output basic information about a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1127
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1128
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1133
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1134
+msgid "Generates area statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1138
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1139
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1143
+msgid "Sum category values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1144
+msgid "Sums up the raster cell values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1148
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1149
+msgid "Reports statistics for raster map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1153
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1154
+msgid ""
+"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
+"vector points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1158
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1159
+msgid "Surface area estimation for rasters."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1163
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1164
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1169
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1170
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1174
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1175
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1180
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1181
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1185
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1186
+msgid "Calculates linear regression from two raster maps: y = a + b*x"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1190
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1191
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1198
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1199
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1202
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1207
+msgid "Create/rebuild topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1208
+msgid "Creates topology for GRASS vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1212
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1213
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1217
+msgid "Generalization"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1218
+msgid "Vector based generalization."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1223
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1224
+msgid "Change the type of geometry elements."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1229
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1230
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1235
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1236
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1240
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1241
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1245
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1246
+msgid "Create parallel line to input lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1251
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1252
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1257
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1258
+msgid "Converts vector map to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1262
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1263
+msgid "Extrudes flat vector object to 3D with defined height."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1268
+msgid "Link to OGR"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1269
+msgid ""
+"Available drivers: ESRI Shapefile,MapInfo File,UK .NTF,SDTS,TIGER,S57,DGN,"
+"VRT,REC,Memory,BNA,CSV,GML,GPX,KML,GeoJSON,GMT,SQLite,ODBC,PGeo,PostgreSQL,"
+"AVCBin"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1274
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1275
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1280
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1281
+msgid ""
+"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1285
+msgid "Reproject vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1286
+msgid "Allows projection conversion of vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1299
+msgid "Query with attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1300
+msgid ""
+"Selects vector objects from an existing vector map and creates a new map "
+"containing only the selected objects."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1304
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1305
+msgid "Queries a vector map layer at given locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1309
+msgid "Query with another vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1310
+msgid "Select features from ainput by features from binput"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1315
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1316
+msgid ""
+"Creates a buffer around features of given type (areas must contain centroid)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1319
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1321
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1322
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1326
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1327
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1331
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1332
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1337
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1339
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1340
+msgid "Create Linear Reference System"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1344
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1345
+msgid "Create stationing from input lines, and linear reference system"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1349
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1350
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1354
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1355
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1361
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1362
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1365
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1367
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1368
+msgid ""
+"Centre node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1372
+msgid "Network maintenance"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1373
+msgid "Network maintenance."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1377
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1378
+msgid "Visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1382
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1383
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1387
+msgid "Display shortest route (requires XTerm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1388
+msgid ""
+"Display shortest route along network between 2 nodes (visualization only, "
+"requires XTerm))"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1392
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1393
+msgid ""
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1397
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1398
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1402
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1403
+msgid ""
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1408
+#: ../gui/wxpython/gui_modules/menudata.py:1410
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1411
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1415
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1416
+msgid "Create a new vector map layer by combining other vector map layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1422
+msgid "Change attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1424
+msgid "Manage or report categories"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1425
+msgid "Attach, delete or report vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1429
+msgid "Reclassify objects interactively"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1430
+msgid "Reclassify vector objects interactively by entering SQL rules"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1434
+msgid "Reclassify objects using rules file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1435
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1442
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1443
+msgid "Create a new vector from the current region."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1446
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1448
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1449
+msgid "Uses a GRASS vector points map to produce a convex hull vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1453
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1454
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1458
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1459
+msgid ""
+"Creates a Voronoi diagram from an input vector map containing points or "
+"centroids."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1465
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1466
+msgid "Creates a GRASS vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1469
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1471
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1472
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1476
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1477
+msgid "Create points along input lines in new vector with 2 layers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1481
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1482
+msgid "Randomly generate a 2D/3D vector points map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1486
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1487
+msgid "Random location perturbations of GRASS vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1494
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1495
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1499
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1500
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1505
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1506
+msgid ""
+"Calculates univariate statistics from a GRASS raster map based on vector "
+"polygons and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1510
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1511
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1514
+msgid "Update point attributes from raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1516
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1517
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1521
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1522
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1528
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1530
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1531
+msgid "Outputs basic information about a user-specified vector map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1536
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1537
+msgid "Reports geometry statistics for vectors."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1541
+msgid "Upload or report topology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1542
+msgid "Populate database values from vector features."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1547
+msgid "Univariate attribute statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1548
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1553
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1554
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1558
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1559
+msgid "Tests for normality for points."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1566
+msgid "Imagery"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1567
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1569
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1570
+msgid "Creates, edits, and lists groups and subgroups of imagery files."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1574
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1575
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1580
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1581
+msgid "Mosaics up to 4 images and extends colormap; creates map *.mosaic"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1586
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1588
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1589
+msgid "Auto-balancing of colors for LANDSAT images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1593
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1594
+msgid ""
+"Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
+"transformation function."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1599
+msgid ""
+"Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
+"transformation function"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1605
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1606
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1610
+msgid "Ortho photo rectification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1611
+msgid "Ortho Photo rectification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1616
+msgid "Basic RS processing"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1618
+msgid "MODIS Quality Flags"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1619
+msgid "Extract Modis Quality flags as raster values."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1624
+msgid "Albedo"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1625
+msgid "Albedo from Modis, Aster, Landsat, AVHRR."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1629
+msgid "Vegetation Indices"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1630
+msgid "14 types of vegetation Indices."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1637
+msgid "Brovey sharpening"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1638
+msgid ""
+"Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1641
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1643
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1644
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1649
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1650
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1654
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1655
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1660
+msgid "Interactive input for supervised classification (requires Xterm)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1661
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1665
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1666
+msgid "Generates statistics for i.maxlik from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1670
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1671
+msgid "Generate statistics for i.smap from raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1676
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1678
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1679
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1683
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1684
+msgid "Raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1691
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1695
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1696
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1700
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1701
+msgid "Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1704
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1706
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1707
+msgid "Canonical components analysis (cca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1711
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1712
+msgid "Principal components analysis (pca) program for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1716
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1717
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1721
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1722
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1727
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1728
+msgid "Performs atmospheric correction using the 6S algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1734
+msgid "Bit pattern comparison "
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1735
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1739
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1740
+msgid ""
+"Calculate error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1744
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1745
+msgid "Calculates Optimum-Index-Factor table for LANDSAT TM bands 1-5, & 7"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1752
+msgid "Volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1753
+msgid "Develop volumes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1755
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1756
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1760
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1761
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1768
+msgid "3D Mask"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1769
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1773
+msgid "3D raster map calculator"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1774
+msgid "Map calculator for volumetric map algebra"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1778
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1779
+msgid ""
+"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1783
+msgid "Interpolate volume from points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1784
+msgid ""
+"Interpolates point data to a G3D grid volume using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1788
+msgid "Report and Statistics"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1790
+msgid "Basic volume metadata"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1791
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1798
+#: ../gui/wxpython/gui_modules/dbm.py:2019
+#: ../gui/wxpython/gui_modules/dbm.py:2131
+#: ../gui/wxpython/gui_modules/dbm.py:2370
+msgid "Database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1799
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1801
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1802
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1806
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1807
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1811
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1812
+msgid "List all database drivers."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1816
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1817
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1823
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1825
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1826
+msgid "Prints/sets general DB connection for current mapset and exits."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1830
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1831
+msgid "Sets user/password for driver/database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1836
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1837
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1841
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1842
+msgid ""
+"Creates and adds a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1846
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1847
+msgid "Drops an attribute table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1852
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1853
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1857
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1858
+msgid ""
+"Allows to update a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1862
+#: ../gui/wxpython/gui_modules/dbm.py:765
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1863
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1868
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1869
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1874
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1876
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1877
+msgid "Selects data from table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1881
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1882
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1886
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1887
+msgid "Executes any SQL statement."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1893
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1895
+msgid "Reconnect vector to database"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1896
+msgid "Reconnects vectors to a new database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1900
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1901
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1908
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1910
+msgid "GRASS GIS help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1911
+#: ../gui/wxpython/gui_modules/menudata.py:1916
+msgid "Display the HTML man pages of GRASS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1915
+msgid "GRASS GIS GUI help"
+msgstr ""
+#: ../gui/wxpython/gui_modules/menudata.py:1920
+#: ../gui/wxpython/gui_modules/menudata.py:1921
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:64
+msgid "Profile Analysis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:152
+#: ../gui/wxpython/gui_modules/profile.py:270
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:156
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:158
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:159
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:279
+#, python-format
+msgid "Profile of %s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:305
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:430
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:431
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:641
+msgid "Profile text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:668
+msgid "Profile settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:731
+msgid "Select raster map to profile"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:766
+msgid "Select raster map 1 (required):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:767
+msgid "Select raster map 2 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:768
+msgid "Select raster map 3 (optional):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:862
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:869
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:879
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:900
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:910
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:933
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:947
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:961
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1043
+#: ../gui/wxpython/gui_modules/profile.py:1388
+#, python-format
+msgid "Profile settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1099
+msgid "Profile line settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1114
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1121
+#: ../gui/wxpython/gui_modules/vdigit.py:1148
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1131
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1140
+#: ../gui/wxpython/gui_modules/profile.py:1192
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1164
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1169
+#: ../gui/wxpython/gui_modules/nviz_tools.py:250
+#: ../gui/wxpython/gui_modules/nviz_tools.py:849
+msgid "Color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1175
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1184
+#: ../gui/wxpython/gui_modules/profile.py:1230
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1199
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1214
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1220
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1221
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1239
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1247
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1255
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1279
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1284
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1291
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1297
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/gui_modules/profile.py:1307
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:72
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:166
+msgid "Loading data..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:185
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:236
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:266
+#, python-format
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to cast value '%"
+"(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:289
+msgid "Limit 100000 records."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:306
+#: ../gui/wxpython/gui_modules/dbm.py:657
+#: ../gui/wxpython/gui_modules/dbm.py:978
+#: ../gui/wxpython/gui_modules/dbm.py:1578
+#: ../gui/wxpython/gui_modules/dbm.py:1594
+#: ../gui/wxpython/gui_modules/dbm.py:1719
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:460
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:464
+msgid "Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:495
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:501
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:507
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:510
+msgid "Click here to show database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:511
+msgid "Click here to hide database connection information"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:547
+#: ../gui/wxpython/gui_modules/dbm.py:670
+#: ../gui/wxpython/gui_modules/dbm.py:2137
+#: ../gui/wxpython/gui_modules/dbm.py:2376
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:553
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:557
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:580
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:582
+#: ../gui/wxpython/gui_modules/dbm.py:1826
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:586
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:690
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:703
+msgid "Manage columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:710
+#: ../gui/wxpython/gui_modules/dbm.py:1966
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:721
+msgid "Data type"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:738
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:755
+msgid "Add"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:775
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:785
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:844
+msgid "Layers of vector map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:853
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:955
+#: ../gui/wxpython/gui_modules/dbm.py:1175
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:956
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:957
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:962
+msgid "Highlight selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:963
+msgid "Highlight selected and zoom"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:967
+#: ../gui/wxpython/gui_modules/dbm.py:1852
+#: ../gui/wxpython/gui_modules/dbm.py:1856
+msgid "Extract selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:972
+#: ../gui/wxpython/gui_modules/dbm.py:1461
+#: ../gui/wxpython/gui_modules/vdigit.py:1930
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1004
+#, python-format
+msgid ""
+"Selected data records (%d) will permanently deleted from table. Do you want "
+"to delete them?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1007
+#: ../gui/wxpython/gui_modules/dbm.py:1053
+msgid "Delete records"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1050
+#, python-format
+msgid ""
+"All data records (%d) will permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1186
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1196
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1204
+#: ../gui/wxpython/gui_modules/dbm.py:1307
+#, python-format
+msgid "Casting value '%(value)s' to %(type)s failed."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1215
+msgid "Unable to insert new record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1284
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1319
+msgid "Unable to update existing record."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1403
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1412
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1428
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
+"(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1456
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1459
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1522
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1544
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1685
+#: ../gui/wxpython/gui_modules/dbm.py:1708
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1695
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1780
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1851
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:1929
+#: ../gui/wxpython/gui_modules/dbm.py:2298
+#: ../gui/wxpython/gui_modules/dbm.py:2687
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2126
+#: ../gui/wxpython/gui_modules/dbm.py:2364
+msgid "Driver"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2090
+msgid ""
+"Unable to determine default DB connection settings. Please define DB "
+"connection using db.connect module."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2109
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2161
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2174
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2178
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2182
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2195
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2242
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2284
+msgid "Layer to detele"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2305
+msgid "&Delete layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2349
+msgid "Modify selected layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2421
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2552
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2559
+#, python-format
+msgid "Unable to create new table. Table <%s> already exists in the database."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2596
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2774
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2778
+#, python-format
+msgid ""
+"No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
+"You can disable this message from digitization settings. Or you can create "
+"and link attribute table to the vector map using Attribute Table Manager."
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2797
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2807
+msgid "No attributes found"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2813
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2815
+msgid "Add attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2817
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2821
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2822
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:2838
+#: ../gui/wxpython/gui_modules/vdigit.py:1820
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3076
+msgid "Unknown"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3134
+#: ../gui/wxpython/gui_modules/dbm.py:3370
+#: ../gui/wxpython/gui_modules/vdigit.py:1382
+#: ../gui/wxpython/gui_modules/vdigit.py:1772
+#: ../gui/wxpython/gui_modules/vdigit.py:2197
+msgid "Category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3323
+msgid "Submit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/dbm.py:3467 ../gui/wxpython/wxgui.py:1128
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:303
+#, python-format
+msgid "Command '%s' not yet implemented."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:375
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:477
+msgid ""
+"Please note that the data are left in incosistent stage and can be corrupted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:480
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:486
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/gui_modules/goutput.py:754
+msgid "Unable to encode text. Please set encoding in GUI preferences."
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:94
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:95
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:96
+msgid "Comp. region"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:97
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:98
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:99
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/gui_modules/globalvar.py:100
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:126
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported yet."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:250
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:417
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:448
+msgid "Unable to open file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:615
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:618
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:964
+#: ../gui/wxpython/gui_modules/render.py:1051
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1167
+#, python-format
+msgid "Unable render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/render.py:1201
+#, python-format
+msgid "Unable render overlay <%s>"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:121
+msgid ""
+"Unable to initialize display driver, see README file for more information.\n"
+"\n"
+"Details:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:127
+#: ../gui/wxpython/gui_modules/vdigit.py:134
+#, python-format
+msgid ""
+"Unable to open vector map <%s> for editing.\n"
+"\n"
+"Data are probably corrupted, try to run v.build to rebuild the topology "
+"(Vector->Develop vector map->Create/rebuild topology)."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:646
+msgid "Undo failed, data corrupted."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1070
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1073
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1098
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1166
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1172
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1188
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1193
+#: ../gui/wxpython/gui_modules/vdigit.py:1521
+#: ../gui/wxpython/gui_modules/vdigit.py:1534
+#: ../gui/wxpython/gui_modules/vdigit.py:1538
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1206
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1223
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1236
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1238
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1241
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1253
+msgid "Digitize line features"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1256
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1266
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1269
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1282
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1289
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1294
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1303
+msgid "length"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1308
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1310
+#: ../gui/wxpython/gui_modules/vdigit.py:1333
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1326
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1331
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1371
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1376
+msgid "Add new record into table"
+msgstr ""
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1411
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1399
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1409
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1424
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1429
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1453
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1454
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1455
+msgid "Point"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1456
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1457
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1458
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1459
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1460
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1461
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1462
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1463
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1464
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1465
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1466
+msgid "Area (closed boundary + centroid)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1467
+msgid "Direction"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1514
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1516
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1569
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1728
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1759
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1796
+msgid "Apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1798
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1800
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1890
+#: ../gui/wxpython/gui_modules/vdigit.py:2092
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater then zero."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1924
+msgid "Delete selected"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:1928
+msgid "Delete all"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2072
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2234
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2237
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2244
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2253
+msgid "Step"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2286
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2379
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/gui_modules/vdigit.py:2380
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:40
+msgid "Nviz tools"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:109
+#: ../gui/wxpython/gui_modules/nviz_tools.py:984
+msgid "View"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:118
+msgid "W"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:120
+msgid "N"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:127
+msgid "S"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:129
+msgid "E"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:138
+#: ../gui/wxpython/gui_modules/nviz_tools.py:994
+msgid "Perspective:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:149
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:163
+msgid "Height:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:170
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:184
+msgid "Look at:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:188
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:189
+msgid "north"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:190
+msgid "south"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:191
+msgid "east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:192
+msgid "west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:193
+msgid "north-west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:194
+msgid "north-east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:195
+msgid "south-east"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:196
+msgid "south-west"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:203
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:204
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:242
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:249
+msgid "Topography"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:252
+#: ../gui/wxpython/gui_modules/nviz_tools.py:851
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:253
+#: ../gui/wxpython/gui_modules/nviz_tools.py:852
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:254
+#: ../gui/wxpython/gui_modules/nviz_tools.py:853
+msgid "Emission"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:260
+#: ../gui/wxpython/gui_modules/nviz_tools.py:861
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:262
+#: ../gui/wxpython/gui_modules/nviz_tools.py:866
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:267
+#: ../gui/wxpython/gui_modules/nviz_tools.py:871
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:327
+#: ../gui/wxpython/gui_modules/nviz_tools.py:738
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:334
+#: ../gui/wxpython/gui_modules/nviz_tools.py:745
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:337
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:338
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:339
+msgid "both"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:349
+#: ../gui/wxpython/gui_modules/nviz_tools.py:772
+msgid "Resolution:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:353
+msgid "coarse:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:365
+msgid "fine:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:380
+msgid "Coarse style:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:383
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:384
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:393
+#: ../gui/wxpython/gui_modules/nviz_tools.py:759
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:396
+#: ../gui/wxpython/gui_modules/nviz_tools.py:574
+#: ../gui/wxpython/gui_modules/nviz_tools.py:762
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:397
+#: ../gui/wxpython/gui_modules/nviz_tools.py:763
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:406
+msgid "Wire color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:421
+msgid "All"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:422
+msgid "Use for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:437
+msgid "Mask zeros:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:441
+msgid "by elevation"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:446
+msgid "by color"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:461
+msgid "Position"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:524
+msgid "Show vector lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:532
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1157
+msgid "Vector lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:573
+msgid "on surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:583
+#: ../gui/wxpython/gui_modules/nviz_tools.py:688
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:618
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:626
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1182
+msgid "Vector points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:632
+msgid "Icon size:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:648
+msgid "width:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:664
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:677
+msgid "color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:748
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:749
+msgid "slides"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:794
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:842
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:848
+msgid "Topography level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:962
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:997
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1076
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1106
+msgid "(value)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1009
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1057
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1088
+msgid "(step)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1024
+msgid "Position:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1027
+msgid "(x)"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1054
+msgid "Height"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1073
+msgid "Twist"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1103
+msgid "Z-exag"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1118
+msgid "(step):"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1140
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1164
+msgid "Show lines"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1189
+msgid "Show points"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1198
+msgid "Size:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1229
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1262
+msgid "Default"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1267
+msgid "Restore default settings"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:1507
+#, python-format
+msgid "Nviz settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2122
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2124
+msgid "Level"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2296
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2314
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2332
+msgid "Layer properties"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2440
+#, python-format
+msgid "Vector map <%s> is 3D"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2443
+#, python-format
+msgid "Vector map <%s> is 2D"
+msgstr ""
+#: ../gui/wxpython/gui_modules/nviz_tools.py:2445
+#, python-format
+msgid "%(primitives)d primitives (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:84
+msgid "Choose project location and mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:87
+msgid "Manage"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:89
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s\n"
+"The world's leading open source GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:95
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:101
+msgid ""
+"Project location\n"
+"(projection/coordinate system)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:104
+msgid ""
+"Accessible mapsets\n"
+"(directories of GIS files)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:107
+msgid ""
+"Create new mapset\n"
+"in selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:110
+msgid "Define new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:113
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:118
+msgid "Start GRASS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:125
+msgid "Create mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:129
+msgid "Rename mapset"
+msgstr ""
+msgid "Rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:130
+msgid "Delete mapset"
+msgstr ""
+msgid "Delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:173
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:181
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:206
+#, python-format
+msgid "ERROR: Location <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:218
+#, python-format
+msgid "ERROR: Mapset <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:426 ../gui/wxpython/gis_set.py:450
+#, python-format
+msgid ""
+"Current name: %s\n"
+"Enter new name:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:427
+msgid "Rename selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:438
+msgid "Unable to rename mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:451
+msgid "Rename selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:464
+msgid "Unable to rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:476
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%"
+"(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:481
+msgid "Delete selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:490
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:501
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:505
+msgid "Delete selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:516
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:642
+msgid "Choose GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:657
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:658
+msgid "Create new mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:671
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:702
+msgid "GRASS Quickstart"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:100
+msgid "GRASS GIS Layer Manager (Experimental Prototype)"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:306
+msgid "Map layers for each display"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:431
+msgid "Type GRASS command and run by pressing ENTER"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:552
+msgid ""
+"Workspace is not empty. Do you want to store current settings to workspace "
+"file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:555
+msgid "Save current settings?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:570
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:634 ../gui/wxpython/wxgui.py:639
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed. Invalid file, unable to parse XML "
+"document."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:644 ../gui/wxpython/wxgui.py:749
+#: ../gui/wxpython/wxgui.py:785
+msgid "Please wait, loading workspace..."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:729
+msgid "Unable to read workspace file"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:769
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:808
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:823 ../gui/wxpython/wxgui.py:840
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:862
+#, python-format
+msgid "Unable to open workspace file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:871
+#, python-format
+msgid "Writing current settings to workspace file failed (%s)."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1063
+msgid "Import DXF layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1069
+msgid "Import GDAL layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1075
+msgid "Import OGR layers"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1100
+msgid "Attribute management is available only for vector maps."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1123
+msgid "Please wait, loading attribute data..."
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1436
+#, python-format
+msgid "Do you want to remove map layer %s from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1439
+msgid "Do you want to remove selected map layer from layer tree?"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1443
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/wxgui.py:1469
+msgid "No map layer selected. Operation cancelled."
+msgstr ""
