[GRASS-SVN] r33894 - grass/trunk/locale/po
Thu Oct 16 02:01:10 EDT 2008
Author: neteler
Date: 2008-10-16 02:00:55 -0400 (Thu, 16 Oct 2008)
New Revision: 33894
   grass/trunk/locale/po/grasslibs_ar.po
   grass/trunk/locale/po/grasslibs_cs.po
   grass/trunk/locale/po/grasslibs_de.po
   grass/trunk/locale/po/grasslibs_el.po
   grass/trunk/locale/po/grasslibs_es.po
   grass/trunk/locale/po/grasslibs_fr.po
   grass/trunk/locale/po/grasslibs_hi.po
   grass/trunk/locale/po/grasslibs_it.po
   grass/trunk/locale/po/grasslibs_ja.po
   grass/trunk/locale/po/grasslibs_ko.po
   grass/trunk/locale/po/grasslibs_lv.po
   grass/trunk/locale/po/grasslibs_mr.po
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_ru.po
   grass/trunk/locale/po/grasslibs_sl.po
   grass/trunk/locale/po/grasslibs_th.po
   grass/trunk/locale/po/grasslibs_tr.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
   grass/trunk/locale/po/grassmods_ar.po
   grass/trunk/locale/po/grassmods_cs.po
   grass/trunk/locale/po/grassmods_de.po
   grass/trunk/locale/po/grassmods_es.po
   grass/trunk/locale/po/grassmods_fr.po
   grass/trunk/locale/po/grassmods_hi.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ja.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_lv.po
   grass/trunk/locale/po/grassmods_mr.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_pt.po
   grass/trunk/locale/po/grassmods_pt_br.po
   grass/trunk/locale/po/grassmods_ru.po
   grass/trunk/locale/po/grassmods_sl.po
   grass/trunk/locale/po/grassmods_th.po
   grass/trunk/locale/po/grassmods_tr.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasstcl_cs.po
   grass/trunk/locale/po/grasstcl_de.po
   grass/trunk/locale/po/grasstcl_es.po
   grass/trunk/locale/po/grasstcl_fr.po
   grass/trunk/locale/po/grasstcl_it.po
   grass/trunk/locale/po/grasstcl_ja.po
   grass/trunk/locale/po/grasstcl_lv.po
   grass/trunk/locale/po/grasstcl_pl.po
   grass/trunk/locale/po/grasstcl_pt.po
   grass/trunk/locale/po/grasstcl_pt_br.po
   grass/trunk/locale/po/grasstcl_ru.po
   grass/trunk/locale/po/grasstcl_th.po
   grass/trunk/locale/po/grasstcl_tr.po
   grass/trunk/locale/po/grasstcl_vi.po
   grass/trunk/locale/po/grasstcl_zh.po
   grass/trunk/locale/po/grasswxpy_cs.po
   grass/trunk/locale/po/grasswxpy_de.po
   grass/trunk/locale/po/grasswxpy_es.po
   grass/trunk/locale/po/grasswxpy_ru.po
   grass/trunk/locale/po/grasswxpy_tr.po
merged messages from GRASS 6.4.svn
Modified: grass/trunk/locale/po/grasslibs_ar.po
--- grass/trunk/locale/po/grasslibs_ar.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_ar.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -513,9 +513,9 @@
 msgstr "datum لم يمكن فتح ملف جدول : %s"
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
+msgstr "datum لم يمكن فتح ملف جدول : %s"
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1249,12 +1249,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "لم يمكن فتح ملف مؤقت"
+msgstr "%s: لم يمكن فتح ملف  الطبوغرافية للكتابة\n"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -1966,9 +1966,9 @@
 msgstr "لقبول الأساس المخزن"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
+msgstr "خطأ: محاولة لتحديث خريطة ليست ضمن مجموعة الخرائط الحالية"
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2029,7 +2029,7 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "<%s> فى مجموعة الخريطة <%s>"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2226,7 +2226,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "[%s] لم يتم ايجاد [%s] فى"
+msgstr "[%s] لم يتم ايجاد"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2289,9 +2289,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -3829,9 +3829,9 @@
 msgstr "غير موجود'%s' الفيكتور"
 #: ../lib/ogsf/GS2.c:1638
-#, c-format
+#, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
@@ -4201,7 +4201,7 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
-msgstr " %s لم يمكن فتح"
+msgstr "لم يمكن فتحه %s فى %s"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
@@ -4352,470 +4352,480 @@
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "لم يتم كتابة روابط قاعدة البيانات"
+msgid "Cannot describe table <%s>"
+msgstr "لم يتم كتابة روابط قاعدة البيانات"
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#~ msgstr "خطا - نهاية الملف من شاشة العرض\n"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "خطا - نهاية الملف من شاشة العرض\n"
 #, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "لم يتم اختيار شاشة العرض\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "لم يتم اختيار شاشة العرض\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr " <%s> بدء عرض الشاشة\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr " <%s> بدء عرض الشاشة\n"
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "محاولة اتصال خاطئة\n"
-#~ "\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"محاولة اتصال خاطئة\n"
+"\n"
 #, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr "محاولة الإتصال استغرقت وقت طويل- ربما يوجد خطا من السيرفر\n"
+msgid "Probably an error with the server."
+msgstr "محاولة الإتصال استغرقت وقت طويل- ربما يوجد خطا من السيرفر\n"
 #, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "فشل الإتصال\n"
+msgid "Connection failed."
+msgstr "فشل الإتصال\n"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "%s: لم يمكن فتح ملف  الطبوغرافية للكتابة\n"
+msgid "Cannot read topo for line [%d]"
 #, fuzzy
-#~ msgid "Unable to open temporary file"
-#~ msgstr "لم يمكن فتحه %s فى %s"
+msgid "Unable to open temporary file"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "RETURN أضغط   لألغاء الأمر\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "RETURN أضغط   لألغاء الأمر\n"
-#~ msgid "Cannot open temp file"
-#~ msgstr "لم يمكن فتح ملف مؤقت"
+msgid "Cannot open temp file"
+msgstr "لم يمكن فتح ملف مؤقت"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ellipsoid تحديد اسم ال \n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"ellipsoid تحديد اسم ال \n"
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "'list' لعرض ما هو متاح أكتب\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "'list' لعرض ما هو متاح أكتب\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ellipsoid غير صالح\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"ellipsoid غير صالح\n"
 #, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "غير صالح '%s' اسم الملف الفيكتورى المخرج"
+msgid "Output name '%s' is not valid rast name."
+msgstr "غير صالح '%s' اسم الملف الفيكتورى المخرج"
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "مستخدم كمدخل '%s' الفيكتور المخرج"
+msgid "Output map '%s' is used as input"
+msgstr "مستخدم كمدخل '%s' الفيكتور المخرج"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum تحديد اسم ال \n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
+"datum تحديد اسم ال \n"
-#~ msgid "Enter 'list' for the list of available datums\n"
+msgid "Enter 'list' for the list of available datums\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum غير صالح\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum غير صالح\n"
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr " فارغة %s@%s الخريطة الراسترية"
+msgid " The raster map %s@%s is empty"
+msgstr " فارغة %s@%s الخريطة الراسترية"
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "    1: ألوان عشوائية \n"
+msgid "    1:  Random colors\n"
+msgstr "    1: ألوان عشوائية \n"
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "    2:  أحمر, أخضر, أزرق\n"
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr "    2:  أحمر, أخضر, أزرق\n"
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "    3:  موجات لونية\n"
+msgid "    3:  Color wave\n"
+msgstr "    3:  موجات لونية\n"
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "    4:  مقياس رمادى\n"
+msgid "    4:  Gray scale\n"
+msgstr "    4:  مقياس رمادى\n"
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "    5:  لون رصاصى أتجاهى\n"
+msgid "    5:  Aspect\n"
+msgstr "    5:  لون رصاصى أتجاهى\n"
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "    6:  ألوان قوس قزح\n"
+msgid "    6:  Rainbow colors\n"
+msgstr "    6:  ألوان قوس قزح\n"
-#~ msgid "RETURN  quit\n"
-#~ msgstr "RETURN للخروج اضغط\n"
+msgid "RETURN  quit\n"
+msgstr "RETURN للخروج اضغط\n"
-#~ msgid "%s not found"
-#~ msgstr "%s غير موجود"
+msgid "%s not found"
+msgstr "%s غير موجود"
-#~ msgid "with titles"
-#~ msgstr "بعناوين"
+msgid "with titles"
+msgstr "بعناوين"
-#~ msgid "(no title)"
-#~ msgstr "(بدون عنوان)"
+msgid "(no title)"
+msgstr "(بدون عنوان)"
-#~ msgid "     key: %s\n"
-#~ msgstr "     chiave: %s\n"
+msgid "     key: %s\n"
+msgstr "     chiave: %s\n"
-#~ msgid "Is this correct? "
-#~ msgstr " هل هذا صحيح؟"
+msgid "Is this correct? "
+msgstr " هل هذا صحيح؟"
-#~ msgid "to accept the default"
-#~ msgstr "لقبول الأساس المخزن"
+msgid "to accept the default"
+msgstr "لقبول الأساس المخزن"
-#~ msgid "to cancel request"
-#~ msgstr "لألغاء الأمر"
+msgid "to cancel request"
+msgstr "لألغاء الأمر"
-#~ msgid "Enter a new %s file name"
-#~ msgstr "أدخل أسم ملف جديد %s "
+msgid "Enter a new %s file name"
+msgstr "أدخل أسم ملف جديد %s "
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr " %s أدخل أسم ملف موجود"
+msgid "Enter the name of an existing %s file"
+msgstr " %s أدخل أسم ملف موجود"
-#~ msgid "Enter %s file name"
-#~ msgstr " %s أدخل أسم ملف"
+msgid "Enter %s file name"
+msgstr " %s أدخل أسم ملف"
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr " %s 'list'أكتب  لعرض الملفات المتاحة\n"
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr " %s 'list'أكتب  لعرض الملفات المتاحة\n"
-#~ msgid "Enter 'list -f' for "
-#~ msgstr " 'list -f' أكتب"
+msgid "Enter 'list -f' for "
+msgstr " 'list -f' أكتب"
-#~ msgid "a list %s"
-#~ msgstr " %s لعرض القائمة"
+msgid "a list %s"
+msgstr " %s لعرض القائمة"
-#~ msgid "an extended list"
-#~ msgstr "قائمة مطولة"
+msgid "an extended list"
+msgstr "قائمة مطولة"
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "%s RETURN أضغط \n"
+msgid "Hit RETURN %s\n"
+msgstr "%s RETURN أضغط \n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
+msgid ""
+"\n"
+"** %s - not found **\n"
-#~ msgid "ask: can't happen"
-#~ msgstr "لا يمكن حدوثه"
+msgid "ask: can't happen"
+msgstr "لا يمكن حدوثه"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "لم يمكن قراءة الملف الرئيسى [%s in %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "لم يمكن قراءة الملف الرئيسى [%s in %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "لا يمكن فتح ملفها الرئيسى[%s in %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "لا يمكن فتح ملفها الرئيسى[%s in %s]"
 #, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "لم يمكن محو الخط"
+msgid "Cannot get field info"
+msgstr "لم يمكن محو الخط"
 #, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
-#~ msgid "Building topology ...\n"
-#~ msgstr "يتم الان بناء الطبولوجى ...\n"
+msgid "Building topology ...\n"
+msgstr "يتم الان بناء الطبولوجى ...\n"
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d مساحات بنيت      \n"
-#~ "%d جزر بنيت\n"
+msgid ""
+"\r%d areas built      \n"
+"%d isles built\n"
+msgstr ""
+"\r%d مساحات بنيت      \n"
+"%d جزر بنيت\n"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
+msgid "Cannot open database <%s> by driver <%s>"
 #, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "لم يمكن إعادة كتابة الخط"
+msgid "Cannot rewrite line"
+msgstr "لم يمكن إعادة كتابة الخط"
-#~ msgid "Cannot delete line"
+msgid "Cannot delete line"
-#~ msgid "Output name '%s' is not valid vector name."
+msgid "Output name '%s' is not valid vector name."
 #, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "%s لم يمكن محو الفيكتور الموجود"
+msgid "Cannot open existing vector map <%s>"
+msgstr "%s لم يمكن محو الفيكتور الموجود"
 #, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "%s لم يمكن فتح ملف فيكتورى جديد"
+msgid "Cannot open new vector %s"
+msgstr "%s لم يمكن فتح ملف فيكتورى جديد"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "'%s' لم يمكن فتح ملف التاريخ للفيكتور"
+msgid "Cannot open history file for vector '%s'"
+msgstr "'%s' لم يمكن فتح ملف التاريخ للفيكتور"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "'%s' لم يمكن رصد بيانات الملف"
+msgid "Could not stat file '%s'"
+msgstr "'%s' لم يمكن رصد بيانات الملف"
 #, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "%s لم يمكن فتح فيكتور قديم"
+msgid "Can't open directory %s"
+msgstr "%s لم يمكن فتح فيكتور قديم"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "لم يمكن رصد أحصائيات %s\n"
+msgid "Can't stat %s\n"
+msgstr "لم يمكن رصد أحصائيات %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr " مستخدم <%s> الراصد \n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr " مستخدم <%s> الراصد \n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr " <%s> يستخدم الراصد %s المستخدم\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr " <%s> يستخدم الراصد %s المستخدم\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr " <%s> لم يتم غلق الراصد\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr " <%s> لم يتم غلق الراصد\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "لم يتم الأتصال بجهاز الشاشة\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "لم يتم الأتصال بجهاز الشاشة\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "غير فعال <%s> راصد الشاشة\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "غير فعال <%s> راصد الشاشة\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "غير متصل...\n"
+msgid "Not connected...\n"
+msgstr "غير متصل...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "لم يتم الإتصال بالشاشة سيتم اعادة المحاولة مرة اخرى\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "لم يتم الإتصال بالشاشة سيتم اعادة المحاولة مرة اخرى\n"
 #, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "حجم الخلية = %d\n"
+msgid "Size of cell in fp maps = %d"
+msgstr "حجم الخلية = %d\n"
 #, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "هو النوع المنحدد لكتابة خرائط عشرية = %d\n"
+msgid "type for writing floating maps = %d"
+msgstr "هو النوع المنحدد لكتابة خرائط عشرية = %d\n"
 #, fuzzy
-#~ msgid "current window = %p"
-#~ msgstr "النافذة الحالية = %p\n"
+msgid "current window = %p"
+msgstr "النافذة الحالية = %p\n"
 #, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "وضع النافذة؟ %d\n"
+msgid "Flag: window set? %d"
+msgstr "وضع النافذة؟ %d\n"
 #, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "واصف الملف لقناع أتوماتيكى %d\n"
+msgid "File descriptor for automatic mask %d"
+msgstr "واصف الملف لقناع أتوماتيكى %d\n"
 #, fuzzy
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "قناع أتوماتيكى %d\n"
+msgid "Flag denoting automatic masking %d"
+msgstr "قناع أتوماتيكى %d\n"
 #, fuzzy
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "نطاق قناع الخلية %p\n"
+msgid "CELL mask buffer %p"
+msgstr "نطاق قناع الخلية %p\n"
 #, fuzzy
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "النطاق لقراءة صفوف منعدمة القيمة %p\n"
+msgid "buffer for reading null rows %p"
+msgstr "النطاق لقراءة صفوف منعدمة القيمة %p\n"
 #, fuzzy
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "قبيل وبعيد بيانات مضغوطة النطاق %p\n"
+msgid "Pre/post compressed data buffer %p"
+msgstr "قبيل وبعيد بيانات مضغوطة النطاق %p\n"
 #, fuzzy
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "حجم النطاق المضغوط %d\n"
+msgid "sizeof compressed_buf %d"
+msgstr "حجم النطاق المضغوط %d\n"
 #, fuzzy
-#~ msgid "work data buffer %p"
-#~ msgstr "نطاق البيانات العاملة %p\n"
+msgid "work data buffer %p"
+msgstr "نطاق البيانات العاملة %p\n"
 #, fuzzy
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "حجم نطاق البيانات العاملة %d\n"
+msgid "sizeof work_buf %d"
+msgstr "حجم نطاق البيانات العاملة %d\n"
 #, fuzzy
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "حجم نطاق البيانات المنعدمة القيمة %d\n"
+msgid "sizeof null_buf %d"
+msgstr "حجم نطاق البيانات المنعدمة القيمة %d\n"
 #, fuzzy
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "حجم نطاق القناع %d\n"
+msgid "sizeof mask_buf %d"
+msgstr "حجم نطاق القناع %d\n"
 #, fuzzy
-#~ msgid "Histogram request %d"
-#~ msgstr "(طلب مدرج أحصائى (هيستوجرام %d\n"
+msgid "Histogram request %d"
+msgstr "(طلب مدرج أحصائى (هيستوجرام %d\n"
 #, fuzzy
-#~ msgid "G_dump: file #%d"
-#~ msgstr "ملف #%d\n"
+msgid "G_dump: file #%d"
+msgstr "ملف #%d\n"
 #, fuzzy
-#~ msgid "open mode = %d"
-#~ msgstr "وضع مفتوح = %d\n"
+msgid "open mode = %d"
+msgstr "وضع مفتوح = %d\n"
 #, fuzzy
-#~ msgid "Cell header %p"
-#~ msgstr "عنوان رأسى للخلية %p\n"
+msgid "Cell header %p"
+msgstr "عنوان رأسى للخلية %p\n"
 #, fuzzy
-#~ msgid "Table reclass %p"
-#~ msgstr "أعادة تصنيف الجدول %p\n"
+msgid "Table reclass %p"
+msgstr "أعادة تصنيف الجدول %p\n"
 #, fuzzy
-#~ msgid "Cell stats %p"
-#~ msgstr "أحصائيات الخلية %p\n"
+msgid "Cell stats %p"
+msgstr "أحصائيات الخلية %p\n"
 #, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "تركيب النطاق %p\n"
+msgid "Range structure %p"
+msgstr "تركيب النطاق %p\n"
 #, fuzzy
-#~ msgid "float Range structure %p"
-#~ msgstr "تركيب النطاق العشرى %p\n"
+msgid "float Range structure %p"
+msgstr "تركيب النطاق العشرى %p\n"
 #, fuzzy
-#~ msgid "want histogram?  %d"
-#~ msgstr "(تريد  مدرج أحصائى(هيستوجرام  %d\n"
+msgid "want histogram?  %d"
+msgstr "(تريد  مدرج أحصائى(هيستوجرام  %d\n"
 #, fuzzy
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "تصنيف أتوماتيكى %d\n"
+msgid "Automatic reclass flag %d"
+msgstr "تصنيف أتوماتيكى %d\n"
 #, fuzzy
-#~ msgid "File row addresses %p"
-#~ msgstr "أماكن صفوف الملف %p\n"
+msgid "File row addresses %p"
+msgstr "أماكن صفوف الملف %p\n"
 #, fuzzy
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "البيانات لأعمدة النافذة %p\n"
+msgid "Data to window col mapping %p"
+msgstr "البيانات لأعمدة النافذة %p\n"
 #, fuzzy
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "اثوابت البيانات لصفوف النافذة %f,%f\n"
+msgid "Data to window row constants %f,%f"
+msgstr "اثوابت البيانات لصفوف النافذة %f,%f\n"
 #, fuzzy
-#~ msgid "Current data row in memory %d"
-#~ msgstr "صف البيانات الحالية فى الذاكرة %d\n"
+msgid "Current data row in memory %d"
+msgstr "صف البيانات الحالية فى الذاكرة %d\n"
 #, fuzzy
-#~ msgid "Current null row in memory %d"
-#~ msgstr "هو الصف المنعدم الحالى فى الذاكرة %d\n"
+msgid "Current null row in memory %d"
+msgstr "هو الصف المنعدم الحالى فى الذاكرة %d\n"
 #, fuzzy
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "هو عدد البيتات لكل خلية فى الصف الحالى %d\n"
+msgid "nbytes per cell for current row %d"
+msgstr "هو عدد البيتات لكل خلية فى الصف الحالى %d\n"
 #, fuzzy
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "نطاق البيانات غير المضغوطة %s\n"
+msgid "Decompressed data buffer %s"
+msgstr "نطاق البيانات غير المضغوطة %s\n"
 #, fuzzy
-#~ msgid "bytes per cell %d"
-#~ msgstr "بيتة لكل خلية %d\n"
+msgid "bytes per cell %d"
+msgstr "بيتة لكل خلية %d\n"
 #, fuzzy
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "النوع: صحيح, عشرى, أم مضاعف %d\n"
+msgid "type: int, float or double map %d"
+msgstr "النوع: صحيح, عشرى, أم مضاعف %d\n"
 #, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "اسم مؤقت للملفات الجديدة %s\n"
+msgid "Temporary name for NEW files %s"
+msgstr "اسم مؤقت للملفات الجديدة %s\n"
 #, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "اسم مؤقت للملفات المنعدمة الجديدة %s\n"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "اسم مؤقت للملفات المنعدمة الجديدة %s\n"
 #, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr " مجموعة الخرائط للملف المفتوح %s\n"
+msgid "Mapset of open file %s"
+msgstr " مجموعة الخرائط للملف المفتوح %s\n"
 #, fuzzy
-#~ msgid "io error warning given %d"
-#~ msgstr "خطأ أدخال وأخراج %d\n"
+msgid "io error warning given %d"
+msgstr "خطأ أدخال وأخراج %d\n"
 #, fuzzy
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "مصفوفة الصفوف المنعدمة[%d] = %p\n"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "مصفوفة الصفوف المنعدمة[%d] = %p\n"
 #, fuzzy
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "نطاق البيانات لقراءة الصفوف المنعدمة %p\n"
+msgid "data buffer for reading null rows %p"
+msgstr "نطاق البيانات لقراءة الصفوف المنعدمة %p\n"
 #, fuzzy
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "اصغرعدد وقيمة منعدمة لصف فى الذاكرة %d\n"
+msgid "Minimum row null row number in memory %d"
+msgstr "اصغرعدد وقيمة منعدمة لصف فى الذاكرة %d\n"
 #, fuzzy
-#~ msgid "G_dump: end"
+msgid "G_dump: end"
+msgstr "ملف #%d\n"
 #, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
 #, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "غير متاح << %s >> الموقع"
+msgid "Color file for [%s] not available"
+msgstr "غير متاح << %s >> الموقع"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
 #, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr " %s datum  خطأ فى قراءة أحداثيات أزاحة ال "
+msgid "Error reading datum shift parameters for %s from table"
+msgstr " %s datum  خطأ فى قراءة أحداثيات أزاحة ال "
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr " %s للملف ellipsoid  خطأ فى قراءة أحداثيات ال "
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr " %s للملف ellipsoid  خطأ فى قراءة أحداثيات ال "
-#~ msgid "Reading sites list ...                  "
-#~ msgstr "قراءة قائمة المواقع ...............      "
+msgid "Reading sites list ...                  "
+msgstr "قراءة قائمة المواقع ...............      "
-#~ msgid "failed to guess format"
-#~ msgstr "عطل فى تخمين التشكيل"
+msgid "failed to guess format"
+msgstr "عطل فى تخمين التشكيل"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "غير موجود فى ملف المواقع %i الحقل العشرى"
+msgid "decimal field %i not present in sites file"
+msgstr "غير موجود فى ملف المواقع %i الحقل العشرى"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr "('%' أيجاد قيم ليس لهل قيم عشرية (مبتدأ ب"
+msgid ""
+"I'm finding records that do not have a floating point attributes (fields "
+"prefixed with '%')."
+msgstr "('%' أيجاد قيم ليس لهل قيم عشرية (مبتدأ ب"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "لا يوجد عدد أبعاد فى الملف"
+msgid "No n-dims in site_list"
+msgstr "لا يوجد عدد أبعاد فى الملف"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "لا توجد خواص مضاعفة القيمة فى قائمة الموقع"
+msgid "No double attributes in site_list"
+msgstr "لا توجد خواص مضاعفة القيمة فى قائمة الموقع"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "لا توجد خواص زخرفية فى قائمة الموقع"
+msgid "No string attributes in site_list"
+msgstr "لا توجد خواص زخرفية فى قائمة الموقع"
-#~ msgid "String attribute index out of range"
-#~ msgstr "دليل الخواص الزخرفية خارج النطاق"
+msgid "String attribute index out of range"
+msgstr "دليل الخواص الزخرفية خارج النطاق"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "G_readsites_xyz()! نوع خاصية غير معروف\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "G_readsites_xyz()! نوع خاصية غير معروف\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "عطل فى تحويل خاصية زخرفية"
+msgid "Failed to convert string attribute."
+msgstr "عطل فى تحويل خاصية زخرفية"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "خطا: GISBASE لم يتم تعريف\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "خطا: GISBASE لم يتم تعريف\n"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "لم يمكن توفير ذاكرة كافية\n"
+#, fuzzy
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s> فى مجموعة الخريطة <%s>"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "[%s] لم يتم ايجاد [%s] فى"
Modified: grass/trunk/locale/po/grasslibs_cs.po
--- grass/trunk/locale/po/grasslibs_cs.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_cs.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -4249,7 +4249,7 @@
 #, fuzzy
-msgstr "Nelze otevøít <%s>"
+msgstr "Nelze otevøít soubor %s"
 #, fuzzy
@@ -4397,345 +4397,345 @@
 msgid "Unable to define new light"
 msgstr "Nelze definovat novou linii"
-#~ msgid "one moment...\n"
-#~ msgstr "momentíèek...\n"
+msgid "one moment...\n"
+msgstr "momentíèek...\n"
-#~ msgid "No help available for command [%s]\n"
-#~ msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
+msgid "No help available for command [%s]\n"
+msgstr "Nápovìda pro pøíkaz [%s] není dostupná\n"
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "stisknìte RETURN pro pokraèování -->"
+msgid "hit RETURN to continue -->"
+msgstr "stisknìte RETURN pro pokraèování -->"
-#~ msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
-#~ msgstr "BUG (delete_area_cats_from_cidx): Plocha %d neexistuje"
+msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
+msgstr "BUG (delete_area_cats_from_cidx): Plocha %d neexistuje"
-#~ msgid "Attempt to delete dead line"
-#~ msgstr "Pokus o odstranìní mrtvé linie"
+msgid "Attempt to delete dead line"
+msgstr "Pokus o odstranìní mrtvé linie"
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Nedostatek pamìti pro alokaci gaussianu"
+msgid "Insufficent memory for allocation of gaussian"
+msgstr "Nedostatek pamìti pro alokaci gaussianu"
-#~ msgid "Graphics driver [%s] started"
-#~ msgstr "Grafický ovladaè [%s] spu¹tìn"
+msgid "Graphics driver [%s] started"
+msgstr "Grafický ovladaè [%s] spu¹tìn"
-#~ msgid "Unknown command: %d last: %d"
-#~ msgstr "Neznámý pøíkaz: %d poslední: %d"
+msgid "Unknown command: %d last: %d"
+msgstr "Neznámý pøíkaz: %d poslední: %d"
-#~ msgid "Monitor: get_command: Premature EOF"
-#~ msgstr "Monitor: get_command: Neoèekávaný konec souboru (EOF)"
+msgid "Monitor: get_command: Premature EOF"
+msgstr "Monitor: get_command: Neoèekávaný konec souboru (EOF)"
-#~ msgid "Unable to open file %s"
-#~ msgstr "Nelze otevøít soubor %s"
+msgid "Unable to open file %s"
-#~ msgstr "%s nenalezen"
+msgstr "%s nenalezen"
-#~ msgid "ERROR in reading %s"
-#~ msgstr "CHYBA pøi ètení %s"
+msgid "ERROR in reading %s"
+msgstr "CHYBA pøi ètení %s"
-#~ msgstr "Nelze otevøít doèasný soubor"
+msgstr "Nelze otevøít doèasný soubor"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Specifikujte prosím mapovou projekci\n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+"\n"
+"\n"
+"Specifikujte prosím mapovou projekci\n"
-#~ msgid "Enter 'list' for the list of available projections\n"
-#~ msgstr "Zadejte 'list' pro výpis dostupných mapových projekcí\n"
+msgid "Enter 'list' for the list of available projections\n"
+msgstr "Zadejte 'list' pro výpis dostupných mapových projekcí\n"
-#~ msgstr "Pro ukonèení po¾adavku stisknìte RETURN\n"
+msgstr "Pro ukonèení po¾adavku stisknìte RETURN\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neplatná mapová projekce\n"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+"\n"
+"neplatná mapová projekce\n"
-#~ msgstr "s titulky"
+msgstr "s titulky"
-#~ msgstr "(bez titulku)"
+msgid "(no title)"
+msgstr "(bez titulku)"
-#~ msgid "Unable to get GIS_LOCK enviroment variable value"
-#~ msgstr "Nelze získat hodnotu promìnné prostøedí GIS_LOCK"
+msgid "Unable to get GIS_LOCK enviroment variable value"
+msgstr "Nelze získat hodnotu promìnné prostøedí GIS_LOCK"
-#~ msgstr " Rastrová mapa %s@%s je prázdná"
+msgstr " Rastrová mapa %s@%s je prázdná"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Tabulka barev potøebná pro soubor [%s] v mapsetu [%s].\n"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr ""
+"\n"
+"\n"
+"Tabulka barev potøebná pro soubor [%s] v mapsetu [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Urèete prosím po¾adovaný typ:\n"
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr ""
+"\n"
+"Urèete prosím po¾adovaný typ:\n"
-#~ msgstr "    1:  Náhodné barvy:\n"
+msgstr "    1:  Náhodné barvy:\n"
-#~ msgstr "    2:  Èervená, zelená a modrá\n"
+msgstr "    2:  Èervená, zelená a modrá\n"
-#~ msgstr "    3:  Barevná vlna\n"
+msgstr "    3:  Barevná vlna\n"
-#~ msgstr "    4:  Odstíny ¹edi\n"
+msgstr "    4:  Odstíny ¹edi\n"
-#~ msgstr "    5:  Expozice\n"
+msgstr "    5:  Expozice\n"
-#~ msgstr "    6:  Barvy duhy\n"
+msgstr "    6:  Barvy duhy\n"
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "    7: Od èervené pøes ¾lutou k zelené\n"
+msgid "    7:  Red through yellow to green\n"
+msgstr "    7: Od èervené pøes ¾lutou k zelené\n"
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "    8:  Od zelené pøes ¾lutou k èervené\n"
+msgid "    8:  Green through yellow to red\n"
+msgstr "    8:  Od zelené pøes ¾lutou k èervené\n"
-#~ msgstr "RETURN  konec\n"
+msgstr "RETURN  konec\n"
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr ""
-#~ "\n"
-#~ "%s neplatné; Zkuste to znova > "
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr ""
+"\n"
+"%s neplatné; Zkuste to znova > "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Specifikujte prosím vý¹kový systém (datum)\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Specifikujte prosím vý¹kový systém (datum)\n"
-#~ msgstr "Zadejte 'list' pro výpis dostupných vý¹kových systémù (datumù)\n"
+msgstr "Zadejte 'list' pro výpis dostupných vý¹kových systémù (datumù)\n"
-#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr "nebo 'custom' pokud si pøejete vlo¾it volitelné parametry\n"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "nebo 'custom' pokud si pøejete vlo¾it volitelné parametry\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neplatný vý¹kový systém (datum)\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"neplatný vý¹kový systém (datum)\n"
-#~ msgstr "pro zru¹ení po¾adavku"
+msgstr "pro zru¹ení po¾adavku"
-#~ msgstr "Zadejte název nového %s souboru"
+msgstr "Zadejte název nového %s souboru"
-#~ msgstr "Zadejte název existujícího %s souboru"
+msgstr "Zadejte název existujícího %s souboru"
-#~ msgstr "Zadejte název %s souboru"
+msgstr "Zadejte název %s souboru"
-#~ msgstr "Zadejte 'list' pro výpis existujících %s souborù\n"
+msgstr "Zadejte 'list' pro výpis existujících %s souborù\n"
-#~ msgstr "Zadejte 'list -f' pro"
+msgstr "Zadejte 'list -f' pro"
-#~ msgstr "výpis %s"
+msgid "a list %s"
+msgstr "výpis %s"
-#~ msgstr "roz¹íøený výpis"
+msgstr "roz¹íøený výpis"
-#~ msgstr "Stisknìte RETURN %s\n"
+msgstr "Stisknìte RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - nenalezeno **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - nenalezeno **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr ""
-#~ "\n"
-#~ "** %s existuje. Pøepsat? "
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr ""
+"\n"
+"** %s existuje. Pøepsat? "
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> neplatné jméno **\n"
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+"\n"
+"**<%s> neplatné jméno **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - neplatný po¾adavek **\n"
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr ""
+"\n"
+"** %s - neplatný po¾adavek **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - existuje, zvolte jiné jméno **\n"
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr ""
+"\n"
+"** %s - existuje, zvolte jiné jméno **\n"
-#~ msgstr "ask: nemù¾e nastat"
+msgstr "ask: nemù¾e nastat"
-#~ msgid "<%s>: bad mapset"
-#~ msgstr "<%s>: neplatný mapset"
+msgid "<%s>: bad mapset"
+msgstr "<%s>: neplatný mapset"
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr ""
-#~ "\n"
-#~ "PØEPÍNAÈ: Nastavit následující pøepínaè?\n"
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr ""
+"\n"
+"PØEPÍNAÈ: Nastavit následující pøepínaè?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "VOLBY:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"VOLBY:   %s\n"
-#~ msgstr "     klíè: %s\n"
+msgid "     key: %s\n"
+msgstr "     klíè: %s\n"
-#~ msgid "  format: %s\n"
-#~ msgstr "  formát: %s\n"
+msgid "  format: %s\n"
+msgstr "  formát: %s\n"
-#~ msgid " default: %s\n"
-#~ msgstr " výchozí: %s\n"
+msgid " default: %s\n"
+msgstr " výchozí: %s\n"
-#~ msgid "required: %s\n"
-#~ msgstr "povinný: %s\n"
+msgid "required: %s\n"
+msgstr "povinný: %s\n"
-#~ msgid "multiple: %s\n"
-#~ msgstr "vícenásobný: %s\n"
+msgid "multiple: %s\n"
+msgstr "vícenásobný: %s\n"
-#~ msgid "enter option > "
-#~ msgstr "zadejte volbu > "
+msgid "enter option > "
+msgstr "zadejte volbu > "
-#~ msgid "   Try again? "
-#~ msgstr "   Zkusit znovu? "
+msgid "   Try again? "
+msgstr "   Zkusit znovu? "
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "Promiòte, ale %s není akceptován.\n"
+msgid "Sorry, %s is not accepted.\n"
+msgstr "Promiòte, ale %s není akceptován.\n"
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bylo vybráno:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Bylo vybráno:\n"
+"  %s\n"
-#~ msgstr "Je to správnì? "
+msgstr "Je to správnì? "
-#~ msgstr "pou¾ít výchozí"
+msgstr "pou¾ít výchozí"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Specifikujte prosím referenèní elipsoid\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Specifikujte prosím referenèní elipsoid\n"
-#~ msgstr "Zadejte 'list' pro výpis dostupných ref. elipsoidù\n"
+msgstr "Zadejte 'list' pro výpis dostupných ref. elipsoidù\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neplatný ref. elipsoid\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"neplatný ref. elipsoid\n"
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "CHYBA %s grafického ovladaèe\n"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "CHYBA %s grafického ovladaèe\n"
-#~ msgid "Unable to allocate memory\n"
-#~ msgstr "Nelze alokovat pamì»\n"
+msgid "Unable to allocate memory\n"
+msgstr "Nelze alokovat pamì»\n"
-#~ msgstr "CHYBA - eof z grafického monitoru.\n"
+msgstr "CHYBA - eof z grafického monitoru.\n"
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "Upozornìní - ¾ádná odezva od grafického monitoru <%s>.\n"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "Upozornìní - ¾ádná odezva od grafického monitoru <%s>.\n"
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "Zkontrolujte zda-li je my¹ stále aktivní.\n"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "Zkontrolujte zda-li je my¹ stále aktivní.\n"
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
-#~ msgstr "CHYBA - ¾ádná odezva od grafického monitoru <%s>.\n"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "CHYBA - ¾ádná odezva od grafického monitoru <%s>.\n"
-#~ msgstr "Nebyl zvolen ¾ádný grafický monitor pro výstup."
+msgstr "Nebyl zvolen ¾ádný grafický monitor pro výstup."
-#~ msgstr "Pro výbìr grafického monitoru zavolejte \"d.mon\"."
+msgstr "Pro výbìr grafického monitoru zavolejte \"d.mon\"."
-#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "Nelze získat soket pro monitor <%s>."
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "Nelze získat soket pro monitor <%s>."
-#~ msgid "No socket to connect to for monitor <%s>."
-#~ msgstr "Není dostupný ¾ádný soket pro pøipojení k monitoru <%s>."
+msgid "No socket to connect to for monitor <%s>."
+msgstr "Není dostupný ¾ádný soket pro pøipojení k monitoru <%s>."
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr "Soket je ji¾ pou¾íván nebo není akceptováno spojení."
+msgid "Socket is already in use or not accepting connections."
+msgstr "Soket je ji¾ pou¾íván nebo není akceptováno spojení."
-#~ msgid "Use d.mon to select a monitor"
-#~ msgstr "Pro výbìr grafického monitoru zavolejte d.mon."
+msgid "Use d.mon to select a monitor"
+msgstr "Pro výbìr grafického monitoru zavolejte d.mon."
-#~ msgstr "Pokus o pøipojení k nìèemu, co není soketem."
+msgstr "Pokus o pøipojení k nìèemu, co není soketem."
-#~ msgid "Probably program error."
-#~ msgstr "Pravdìpodobnì chyba programu."
+msgid "Probably program error."
+msgstr "Pravdìpodobnì chyba programu."
-#~ msgid "Connect attempt timed out."
-#~ msgstr "Pøipojení selhalo."
+msgid "Connect attempt timed out."
+msgstr "Pøipojení selhalo."
-#~ msgstr "Pravdìpodobnì je chyba na stranì serveru."
+msgstr "Pravdìpodobnì je chyba na stranì serveru."
-#~ msgid ""
-#~ "discontinuities algorithm: %i class breaks or more are not statistically "
-#~ "significant at alpha=0.05"
-#~ msgstr ""
-#~ "Ukonèení algoritmu: %i hranic intervalù nebo více nejsou statisticky "
-#~ "významné pro alfa=0,05"
+msgid ""
+"discontinuities algorithm: %i class breaks or more are not statistically "
+"significant at alpha=0.05"
+msgstr ""
+"Ukonèení algoritmu: %i hranic intervalù nebo více nejsou statisticky "
+"významné pro alfa=0,05"
Modified: grass/trunk/locale/po/grasslibs_de.po
--- grass/trunk/locale/po/grasslibs_de.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_de.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -4515,494 +4515,492 @@
 msgstr "Kann Datei %s nicht öffnen."
 #, fuzzy
-#~ msgstr "Kann Tabelle <%s> nicht beschreiben"
+msgstr "Kann Tabelle <%s> nicht beschreiben"
-#~ msgstr "Unbekanntes Kommando: %d zuletzt: %d"
+msgstr "Unbekanntes Kommando: %d zuletzt: %d"
-#~ msgstr "Monitor: get_command: Vorzeitiges EOF"
+msgstr "Monitor: get_command: Vorzeitiges EOF"
-#~ msgstr "Grafiktreiber [%s] gestartet"
+msgstr "Grafiktreiber [%s] gestartet"
-#~ msgstr "Graphik-Treiber liefert FEHLER %s.\n"
+msgstr "Graphik-Treiber liefert FEHLER %s.\n"
-#~ msgstr "FEHLER - Unerwartetes Dateiende vom Monitor übermittelt.\n"
+msgstr "FEHLER - Unerwartetes Dateiende vom Monitor übermittelt.\n"
-#~ msgstr "Warnung - keine Antwort vom Graphikmonitor <%s>.\n"
+msgstr "Warnung - keine Antwort vom Graphikmonitor <%s>.\n"
-#~ msgstr "Kontrollieren Sie bitte, ob die Maus noch aktiv ist.\n"
+msgstr "Kontrollieren Sie bitte, ob die Maus noch aktiv ist.\n"
-#~ msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
+msgstr "Fehler - keine Antwort vom Graphikmonitor <%s>.\n"
-#~ msgstr "Kein Graphik-Monitor wurde für den Output selektiert."
+msgstr "Kein Graphik-Monitor wurde für den Output selektiert."
-#~ msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
+msgstr "Bitte benutzen Sie \"d.mon\", um einen Graphik-Monitor auszuwählen."
-#~ msgstr "Für Monitor <%s> konnte kein Socket hergestellt werden."
+msgstr "Für Monitor <%s> konnte kein Socket hergestellt werden."
-#~ msgstr "Keine Socket-Verbindung für Monitor <%s> vorhanden."
+msgstr "Keine Socket-Verbindung für Monitor <%s> vorhanden."
-#~ msgstr "Socket wird bereits benutzt oder akzeptiert keine Verbindungen."
+msgstr "Socket wird bereits benutzt oder akzeptiert keine Verbindungen."
-#~ msgstr ""
-#~ "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
+msgstr "Versuche eine Verbindung zu etwas herzustellen, was kein Socket ist."
-#~ msgstr "Wahrscheinlich ein Fehler mit dem Server."
+msgstr "Wahrscheinlich ein Fehler mit dem Server."
-#~ msgstr "Verbindung fehlgeschlagen."
+msgstr "Verbindung fehlgeschlagen."
 #, fuzzy
-#~ msgstr "Versuch, eine tote Fläche zu löschen"
+msgstr "Versuch, eine tote Fläche zu löschen"
 #, fuzzy
-#~ msgid "Unable to connect lines %d,%d"
-#~ msgstr "Kann Datei head nicht lesen"
+msgid "Unable to connect lines %d,%d"
+msgstr "Kann Datei head nicht lesen"
-#~ msgstr "Kann Datei %s nicht öffnen."
+msgstr "Kann Datei %s nicht öffnen."
 #, fuzzy
-#~ msgstr "Drücken Sie RETURN, um abzubrechen.\n"
+msgstr "Drücken Sie RETURN, um abzubrechen.\n"
-#~ msgstr "Kann temporäre Datei nicht öffnen."
+msgstr "Kann temporäre Datei nicht öffnen."
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bitte spezifizieren Sie einen Ellipsoiden\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Bitte spezifizieren Sie einen Ellipsoiden\n"
-#~ msgstr "Geben Sie 'list' für eine Liste der verfügbaren Ellipsoiden ein.\n"
+msgstr "Geben Sie 'list' für eine Liste der verfügbaren Ellipsoiden ein.\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Ungültiger Ellipsoid\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Ungültiger Ellipsoid\n"
 #, fuzzy
-#~ msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
+msgstr "Ausgabename '%s' ist kein erlaubter Rasterkartenname."
 #, fuzzy
-#~ msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
+msgstr "Ergebniskarte '%s' ist gleichzeitig Eingabekarte."
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bitte spezifizieren Sie ein Datum\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Bitte spezifizieren Sie ein Datum\n"
-#~ msgstr "Geben Sie 'list' für eine Liste der verfügbaren Datums ein\n"
+msgstr "Geben Sie 'list' für eine Liste der verfügbaren Datums ein\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Ungültiges Datum\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"Ungültiges Datum\n"
-#~ msgstr "Bitte RETURN zum Weitermachen drücken -->"
+msgstr "Bitte RETURN zum Weitermachen drücken -->"
 #, fuzzy
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "Kann nicht zum Verzeichnis %s wechseln."
+msgid "unable to open raster map [%s in %s]"
+msgstr "Kann nicht zum Verzeichnis %s wechseln."
-#~ msgstr "einen Moment bitte...\n"
+msgstr "einen Moment bitte...\n"
-#~ msgstr "Leider keine Hilfe für das Kommando [%s] verfügbar.\n"
+msgstr "Leider keine Hilfe für das Kommando [%s] verfügbar.\n"
-#~ msgstr " Die Rasterkarte %s@%s ist leer."
+msgstr " Die Rasterkarte %s@%s ist leer."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Farbtabelle wird für die Datei [%s] in Mapset [%s] benötigt.\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Farbtabelle wird für die Datei [%s] in Mapset [%s] benötigt.\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bitte identifizieren Sie den entsprechenden Typ:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Bitte identifizieren Sie den entsprechenden Typ:\n"
-#~ msgstr "    1:  Zufällige Farben\n"
+msgstr "    1:  Zufällige Farben\n"
-#~ msgstr "    2:  Rote, grüne und blaue Farbrampen\n"
+msgstr "    2:  Rote, grüne und blaue Farbrampen\n"
-#~ msgstr "    3:  Farbenwelle\n"
+msgstr "    3:  Farbenwelle\n"
-#~ msgstr "    4:  Graustufen\n"
+msgstr "    4:  Graustufen\n"
-#~ msgstr "    5:  Farbe speziell für Hangneigungskarten\n"
+msgstr "    5:  Farbe speziell für Hangneigungskarten\n"
-#~ msgstr "    6:  Regenbogenfarben\n"
+msgstr "    6:  Regenbogenfarben\n"
-#~ msgstr "    7:  Von rot über gelb zu grün\n"
+msgstr "    7:  Von rot über gelb zu grün\n"
-#~ msgstr "    8:  Von grün über gelb zu rot\n"
+msgstr "    8:  Von grün über gelb zu rot\n"
-#~ msgstr "RETURN  um abzubrechen\n"
+msgstr "RETURN  um abzubrechen\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s ist ungültig; Bitte nocheinmal probieren > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s ist ungültig; Bitte nocheinmal probieren > "
-#~ msgstr "%s nicht gefunden"
+msgstr "%s nicht gefunden"
-#~ msgstr "FEHLER beim Lesen von %s"
+msgstr "FEHLER beim Lesen von %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Bitte spezifizieren Sie eine Projektion\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Bitte spezifizieren Sie eine Projektion\n"
-#~ msgstr "Geben Sie 'list' für eine Liste der verfügbaren Projektionen ein.\n"
+msgstr "Geben Sie 'list' für eine Liste der verfügbaren Projektionen ein.\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Ungültige Projektion\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Ungültige Projektion\n"
-#~ msgstr "mit Titeln"
+msgstr "mit Titeln"
-#~ msgstr "(kein Titel)"
+msgid "(no title)"
+msgstr "(kein Titel)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "FLAG: Soll das folgende Flag gesetzt werden?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"FLAG: Soll das folgende Flag gesetzt werden?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPTION:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPTION:   %s\n"
-#~ msgstr "     Key: %s\n"
+msgid "     key: %s\n"
+msgstr "     Key: %s\n"
-#~ msgstr "  Format: %s\n"
+msgstr "  Format: %s\n"
-#~ msgstr " Standard: %s\n"
+msgstr " Standard: %s\n"
-#~ msgstr "benötigt werden: %s\n"
+msgstr "benötigt werden: %s\n"
-#~ msgstr "vielfach: %s\n"
+msgstr "vielfach: %s\n"
-#~ msgstr "Geben Sie eine Option ein > "
+msgstr "Geben Sie eine Option ein > "
-#~ msgstr "   Nochmal versuchen? "
+msgstr "   Nochmal versuchen? "
-#~ msgstr "Tut mir leid, %s wird nicht akzeptiert.\n"
+msgstr "Tut mir leid, %s wird nicht akzeptiert.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Sie haben ausgewählt:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Sie haben ausgewählt:\n"
+"  %s\n"
-#~ msgstr "Ist das richtig?"
+msgstr "Ist das richtig?"
-#~ msgstr "Zum Akzeptieren der Standardeinstellung"
+msgstr "Zum Akzeptieren der Standardeinstellung"
-#~ msgstr "um die Aktion abzubrechen"
+msgstr "um die Aktion abzubrechen"
-#~ msgstr "Bitte geben Sie einen neuen %s Dateinamen ein."
+msgstr "Bitte geben Sie einen neuen %s Dateinamen ein."
-#~ msgstr "Bitte geben Sie den Namen einer existierenden %s Datei ein."
+msgstr "Bitte geben Sie den Namen einer existierenden %s Datei ein."
-#~ msgstr "Bitte geben Sie %s Dateinamen ein."
+msgstr "Bitte geben Sie %s Dateinamen ein."
-#~ msgstr ""
-#~ "Bitte geben Sie 'list' für eine Liste der bereits existierenden %s "
-#~ "Dateien ein.\n"
+msgstr ""
+"Bitte geben Sie 'list' für eine Liste der bereits existierenden %s Dateien "
+"ein.\n"
-#~ msgstr "Geben Sie 'list -f' für "
+msgstr "Geben Sie 'list -f' für "
-#~ msgstr "eine Liste %s ein."
+msgid "a list %s"
+msgstr "eine Liste %s ein."
-#~ msgstr "eine erweiterte Liste ein."
+msgstr "eine erweiterte Liste ein."
-#~ msgstr "Drücken Sie RETURN %s\n"
+msgstr "Drücken Sie RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - leider nicht gefunden **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - leider nicht gefunden **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s existiert. Soll sie überschrieben werden? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s existiert. Soll sie überschrieben werden? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> unerlaubter Name **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> unerlaubter Name **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - unerlaubte Anfrage **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - unerlaubte Anfrage **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - existiert bereits, bitte wählen Sie einen anderen Namen **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - existiert bereits, bitte wählen Sie einen anderen Namen **\n"
-#~ msgstr "Frage: Das kann nicht passieren"
+msgstr "Frage: Das kann nicht passieren"
-#~ msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
+msgstr "Ungenügend Speicher zum Allokieren der Gausschen..."
 #, fuzzy
 #, fuzzy
-#~ msgstr "Kann range Datei für [%s in %s] nicht lesen."
+msgstr "Kann range Datei für [%s in %s] nicht lesen."
 #, fuzzy
 #, fuzzy
-#~ msgstr "Kann die Layer-Informationen nicht abfragen."
+msgstr "Kann die Layer-Informationen nicht abfragen."
 #, fuzzy
-#~ msgstr "Kann Datenbank '%s' nicht öffnen."
+msgstr "Kann Datenbank '%s' nicht öffnen."
 #, fuzzy
-#~ msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
+msgstr "Bitte Topologie für Vektorkarte <'%s> neu erzeugen\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d Flächen erstellt \n"
-#~ "%d Inselflächen erstellt\n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d Flächen erstellt \n"
+"%d Inselflächen erstellt\n"
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgid "Column type not supported"
-#~ msgstr "OGR Feature Typ %d wird nicht unterstützt."
+msgid "Column type not supported"
+msgstr "OGR Feature Typ %d wird nicht unterstützt."
 #, fuzzy
-#~ msgid "OGR feature type [%d] not supported"
+msgid "OGR feature type [%d] not supported"
 #, fuzzy
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_write_line() wird für dieses Format/Level nicht unterstützt."
 #, fuzzy
-#~ msgid "Vect_delete_line() for this format/level not supported"
+msgid "Vect_delete_line() for this format/level not supported"
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Kann Rasterkarte [%s in %s] nicht öffnen."
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "Kann die Debug-Datei '%s' nicht öffnen."
+msgstr "Kann die Debug-Datei '%s' nicht öffnen."
 #, fuzzy
-#~ msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
+msgstr "Kann die History-Datei für die Vektorkarte <%s> nicht öffnen."
 #, fuzzy
 #, fuzzy
-#~ msgid "Starting lu solver method"
-#~ msgstr "Starte lu-Solver Methode"
+msgid "Starting lu solver method"
+msgstr "Starte lu-Solver Methode"
 #, fuzzy
-#~ msgid "%s - ** illegal name **"
-#~ msgstr ""
-#~ "\n"
+msgid "%s - ** illegal name **"
+msgstr ""
+"\n"
 #, fuzzy
-#~ msgid "Gauss-Seidel -- iteration %5i error %g\n"
-#~ msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
+msgid "Gauss-Seidel -- iteration %5i error %g\n"
+msgstr "sparse SOR -- Durchlauf %5i Fehler %g\n"
 #, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
 #, fuzzy
-#~ msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
+msgstr "Fehler - Monitor <%s> wird bereits benutzt.\n"
-#~ msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
+msgstr "Fehler - Monitor <%s> wird bereits von %s benutzt.\n"
-#~ msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
+msgstr "Fehler - Kann den Locking-Prozess für Monitor <%s> nicht beenden.\n"
-#~ msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
+msgstr "Fehler - Kann keine Pipe zum Graphik-Gerät aufbauen.\n"
-#~ msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
+msgstr "Fehler - Graphik-Monitor <%s> läuft nicht!\n"
 #, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Nicht verbunden...\n"
+msgstr "Nicht verbunden...\n"
-#~ msgstr ""
-#~ "Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres "
-#~ "Mal.\n"
+msgstr ""
+"Kann nicht mit einem Monitor verbinden. Versuche es noch ein weiteres Mal.\n"
-#~ msgstr "Kann keinen Speicher belegen.\n"
+msgstr "Kann keinen Speicher belegen.\n"
 #, fuzzy
-#~ msgstr "<%s> in Mapset <%s>"
+msgstr "<%s> in Mapset <%s>"
Modified: grass/trunk/locale/po/grasslibs_el.po
--- grass/trunk/locale/po/grasslibs_el.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_el.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -587,9 +587,9 @@
 msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
 #: ../lib/db/dbmi_client/copy_tab.c:231
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> is not integer"
-msgstr "Ï äéáíõóìáôéêüò ÷Üñôçò <%s> äåí âñÝèçêå"
+msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:248
 #, fuzzy, c-format
@@ -725,9 +725,9 @@
 msgstr ""
 #: ../lib/vector/diglib/plus_area.c:304
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to delete not registered isle %d from area %d"
-msgstr "ÐñïóðÜèåéá áíÜãíùóçò ôïðïãñáößáò ãéá êåíÞ (dead) åðéöÜíåéá (%d)"
+msgstr ""
 #: ../lib/vector/diglib/plus_area.c:342
 msgid "Attempt to delete dead area"
@@ -771,7 +771,7 @@
 #: ../lib/vector/diglib/plus.c:308
 #, fuzzy
 msgid "Unable to read topo for areas"
-msgstr "Áäõíáìßá áíÜãíùóçò head áñ÷åßïõ"
+msgstr "Áäõíáìßá áíÜãíùóçò ôùí ðåñéï÷þí"
 #: ../lib/vector/diglib/plus.c:313
 #, fuzzy, c-format
@@ -1013,11 +1013,9 @@
 msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/open.c:531
-#, fuzzy, c-format
+#, c-format
 msgid "%s is not in the current mapset (%s)"
 msgstr ""
-"Ï äéáíõóìáôéêüò ÷Üñôçò ðïõ äåí áíÞêåé óôï ôñÝ÷ïí mapset äåí ìðïñåß íá "
-"áíïßîåé ãéá åíçìÝñùóç"
 #: ../lib/vector/Vlib/open.c:540 ../lib/vector/Vlib/map.c:176
 #: ../lib/vector/Vlib/map.c:313
@@ -1864,7 +1862,7 @@
 #: ../lib/vector/Vlib/write.c:239
 #, fuzzy, c-format
 msgid "Unable to feature %d from vector map <%s>"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ éóôïñéêïý ôïõ äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
 #: ../lib/vector/Vlib/write.c:265
 #, fuzzy, c-format
@@ -2121,7 +2119,7 @@
 #: ../lib/g3d/g3drange.c:72
 #, fuzzy, c-format
 msgid "Unable to open range file for [%s in %s]"
-msgstr "Áäõíáìßá áíïßãìáôïò ôïõ ÷Üñôç raster <%s>"
+msgstr "Áäõíáìßá áíïßãìáôïò áñ÷åßïõ ãéá åããñáöÞ <%s>"
 #: ../lib/g3d/g3drange.c:78 ../lib/g3d/g3drange.c:88
 #, fuzzy, c-format
@@ -2254,11 +2252,9 @@
 msgstr ""
 #: ../lib/gis/opencell.c:228
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
 msgstr ""
 #: ../lib/gis/opencell.c:235
 #, c-format
@@ -3043,9 +3039,8 @@
 msgstr ""
 #: ../lib/gis/parser.c:1976
-#, fuzzy
 msgid "Unable to spawn the 'wish' program"
-msgstr "Áäõíáìßá áíïßãìáôïò êáôáëüãïõ óõóôÞìáôïò '%s'"
+msgstr ""
 #: ../lib/gis/parser.c:1995
 msgid "Unable to determine program name"
@@ -3679,9 +3674,9 @@
 msgstr "ÓöÜëìá êáôÜ ôçí åããñáöÞ ôïõ ÷Üñôç"
 #: ../lib/ogsf/gsd_img_mpeg.c:298
-#, fuzzy, c-format
+#, c-format
 msgid "Opening MPEG stream <%s>..."
-msgstr "Öüñôùóç ôïõ raster ÷Üñôç <%s> óôç ìíÞìç"
+msgstr ""
 #: ../lib/ogsf/gsd_img_mpeg.c:306
 msgid "Unable to deduce output format from file extension: using MPEG"
@@ -3852,11 +3847,9 @@
-#, fuzzy, c-format
+#, c-format
 msgstr ""
@@ -4218,7 +4211,7 @@
 #, fuzzy
+msgstr "Áäõíáìßá äéáãñáöÞò áñ÷åßïõ '%s'"
 #, fuzzy
@@ -4365,141 +4358,138 @@
 msgstr "Áäõíáìßá åýñåóçò óçìåßïõ óôï ðïëýãùíï"
-#~ msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
+msgstr "Áäõíáìßá ðåñéãñáöÞò ðßíáêá <%s>"
-#~ msgstr "¶ãíùóôç åíôïëÞ: %d last: %d"
+msgstr "¶ãíùóôç åíôïëÞ: %d last: %d"
-#~ msgstr "Monitor: get_command: Premature EOF"
+msgstr "Monitor: get_command: Premature EOF"
-#~ msgstr "Åêêßíçóç ôïõ ïäçãïý êÜñôáò ãñáöéêþí [%s]"
+msgstr "Åêêßíçóç ôïõ ïäçãïý êÜñôáò ãñáöéêþí [%s]"
-#~ msgstr "ÓÖÁËÌÁ %s áðü ôïí ïäçãüò êÜñôáò ãñáöéêþí.\n"
+msgstr "ÓÖÁËÌÁ %s áðü ôïí ïäçãüò êÜñôáò ãñáöéêþí.\n"
-#~ msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
+msgstr "Áäõíáìßá êáôáíïìÞò (allocate) ìíÞìçò\n"
-#~ msgstr "ÓÖÁËÌÁ - eof áðü ôçí ïèüíç ãñáöéêþí.\n"
+msgstr "ÓÖÁËÌÁ - eof áðü ôçí ïèüíç ãñáöéêþí.\n"
-#~ msgstr "Ðñïóï÷Þ - êáìßá áðüêñéóç áðü ôçí ïèüíç ãñáöéêþí <%s>.\n"
+msgstr "Ðñïóï÷Þ - êáìßá áðüêñéóç áðü ôçí ïèüíç ãñáöéêþí <%s>.\n"
-#~ msgstr "ÄïêéìÜóôå áí ôïí ðïíôßêé (mouse) áðïêñßíåôáé.\n"
+msgstr "ÄïêéìÜóôå áí ôïí ðïíôßêé (mouse) áðïêñßíåôáé.\n"
-#~ msgstr "ÓÖÁËÌÁ - êáìßá áðüêñéóç áðï ôçí ïèüíç ãñáöéêþí <%s>.\n"
+msgstr "ÓÖÁËÌÁ - êáìßá áðüêñéóç áðï ôçí ïèüíç ãñáöéêþí <%s>.\n"
-#~ msgstr "Äåí Ý÷åé åðéëïãÞ êáìßá ïèüíç ãñáöéêþí ùò Ýîïäïò."
+msgstr "Äåí Ý÷åé åðéëïãÞ êáìßá ïèüíç ãñáöéêþí ùò Ýîïäïò."
-#~ msgstr ""
-#~ "Ðáñáêáëþ åêôåëÝóôå ôçí åíôïëÞ \"d.mon\" ãéá íá åðéëÝîåôå ïèüíç ãñáöéêþí."
+msgstr ""
+"Ðáñáêáëþ åêôåëÝóôå ôçí åíôïëÞ \"d.mon\" ãéá íá åðéëÝîåôå ïèüíç ãñáöéêþí."
-#~ msgstr "Áäõíáìßá ëÞøçò ïíüìáôïò áðü ôçí ïèüíç <%s>."
+msgstr "Áäõíáìßá ëÞøçò ïíüìáôïò áðü ôçí ïèüíç <%s>."
-#~ msgstr "Äåí õðÜñ÷åé óýíäåóç ôïõ socket ãéá óýíäåóç óôçí ïèüíç <%s>."
+msgstr "Äåí õðÜñ÷åé óýíäåóç ôïõ socket ãéá óýíäåóç óôçí ïèüíç <%s>."
-#~ msgstr "Ôï socket ÷ñçóéìïðïéÞôáé Þäç êáé äåí äÝ÷åôáé Üëëåò óõíäÝóåéò."
+msgstr "Ôï socket ÷ñçóéìïðïéÞôáé Þäç êáé äåí äÝ÷åôáé Üëëåò óõíäÝóåéò."
-#~ msgstr "×ñçóéìïðïéÞóôå ôçí åíôïëÞ  d.mon ãéá íá åðéëÝîåôå ïèüíç"
+msgstr "×ñçóéìïðïéÞóôå ôçí åíôïëÞ  d.mon ãéá íá åðéëÝîåôå ïèüíç"
-#~ msgstr "Ðéèáíü ëÜèïò ôïõ ðñïãñÜììáôïò."
+msgstr "Ðéèáíü ëÜèïò ôïõ ðñïãñÜììáôïò."
-#~ msgstr "Ç ðñïóðÜèåéá óýíäåóçò áðÝôõ÷å (timed out)."
+msgstr "Ç ðñïóðÜèåéá óýíäåóçò áðÝôõ÷å (timed out)."
-#~ msgstr "Ðéèáíü ðñüâëçìá ìå ôïí äéáêïìéóôÞ (server)."
+msgstr "Ðéèáíü ðñüâëçìá ìå ôïí äéáêïìéóôÞ (server)."
-#~ msgstr "ÓöÜëìá óýíäåóçò."
+msgstr "ÓöÜëìá óýíäåóçò."
 #, fuzzy
-#~ msgid "Cannot read topo for nodes"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò [%d]"
+msgid "Cannot read topo for nodes"
+msgstr "Áäõíáìßá áíÜãíùóçò ôçò ãñáììÞò [%d]"
 #, fuzzy
-#~ msgid "Cannot read topo for node [%d]"
+msgid "Cannot read topo for node [%d]"
 #, fuzzy
-#~ msgid "Cannot read topo for lines"
+msgid "Cannot read topo for lines"
 #, fuzzy
-#~ msgid "Cannot read topo for areas"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ôùí ðåñéï÷þí"
+msgid "Cannot read topo for areas"
 #, fuzzy
-#~ msgid "Cannot read topo for area [%d]"
+msgid "Cannot read topo for area [%d]"
 #, fuzzy
-#~ msgid "Cannot read topo for isles"
+msgid "Cannot read topo for isles"
 #, fuzzy
-#~ msgid "Cannot read topo for isle [%d]"
+msgid "Cannot read topo for isle [%d]"
 #, fuzzy
-#~ msgid "Unable to open vector map <%s> on topology level %d"
-#~ msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
+msgid "Unable to open vector map <%s> on topology level %d"
+msgstr "Áäõíáìßá áíôéãñáöÞò äéáíõóìáôéêïý ÷Üñôç <%s> óå <%s>"
 #, fuzzy
-#~ msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
+msgstr "BUG (Vect_build_sidx_from_topo): ç åðéöÜíåéá äåí õðÜñ÷åé"
 #, fuzzy
-#~ msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
+msgid "BUG (add_area_cats_to_cidx): Area %d does not exist"
 #, fuzzy
-#~ msgid "Registering lines: "
-#~ msgstr "ÅããñáöÞ óçìåßùí"
+msgid "Registering lines: "
+msgstr "ÅããñáöÞ óçìåßùí"
 #, fuzzy
-#~ msgid "Unable to rewrite line %d"
-#~ msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
+msgid "Unable to rewrite line %d"
+msgstr "Áäõíáìßá áíÜãíùóçò ãñáììÞò %d"
 #, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
-#~ msgstr ""
-#~ "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s> óôï ôïðïëïãéêü åðßðåäï %d"
+msgid "Unable to delete line %d, vector map <%s> is not opened on topo level 2"
+msgstr "Áäõíáìßá áíïßãìáôïò äéáíõóìáôéêïý ÷Üñôç <%s> óôï ôïðïëïãéêü åðßðåäï %d"
 #, fuzzy
-#~ msgid ""
-#~ "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
-#~ msgstr ""
-#~ "Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå "
-#~ "êáôÜóôáóç åããñáöÞò (WRITE mode)"
+msgid "Unable to delete line %d, vector map <%s> is not opened in 'write' mode"
+msgstr ""
+"Áäõíáìßá óýíäåóçò âÜóçò äåäïìÝíùí, ï ÷Üñôçò äåí åßíáé áíïéêôüò óå êáôÜóôáóç "
+"åããñáöÞò (WRITE mode)"
 #, fuzzy
-#~ msgid "Unable to delete line %d from vector map <%s>"
-#~ msgstr "Áäõíáìßá äçìéïõñãßáò äéáíõóìáôéêïý ÷Üñôç <%s>"
+msgid "Unable to delete line %d from vector map <%s>"
 #, fuzzy
-#~ msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
+msgstr "Ôï åîáãþìåíï üíïìá ôïõ äéáíõóìáôéêïý ÷Üñôç <%s> äåí åßíáé åðéôñåðôü"
 #, fuzzy
-#~ msgstr ""
-#~ "Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
-#~ "äåäïìÝíùí."
+msgstr ""
+"Ï åîáãüìåíïò äéáíõóìáôéêüò ÷Üñôçò <%s> ÷ñçóéìïðïéåßôáé ãéá åéóáãùãÞ "
+"äåäïìÝíùí."
Modified: grass/trunk/locale/po/grasslibs_es.po
--- grass/trunk/locale/po/grasslibs_es.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_es.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -600,9 +600,9 @@
 msgstr "No se puede abrir el archivo que contiene la tabla del elipsoide <%s>"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "No se puede abrir el archivo que contiene la tabla del elipsoide <%s>"
@@ -2387,7 +2387,7 @@
 #, fuzzy, c-format
-msgstr "No se puede encontrar [%s] en [%s]"
+msgstr "No se puede encontrar [%s] "
 #, fuzzy, c-format
@@ -2450,9 +2450,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -4028,9 +4028,11 @@
 msgstr "Mapa vectorial <%s> no encontrado"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"[%s] en el directorio de mapas [%s] - está en una zona diferente [%d] de la "
+"región actual [%d]"
@@ -4407,7 +4409,7 @@
 #, fuzzy
-msgstr "No se puede abrir %s"
+msgstr "No se puede abrir el archivo %s "
 #, fuzzy
@@ -4557,353 +4559,359 @@
 msgstr "No se puede reescribir la línea %d"
-#~ msgstr "No se puede describir la tabla <%s>"
+msgstr "No se puede describir la tabla <%s>"
-#~ msgstr "Comando desconocido: %d último: %d"
+msgstr "Comando desconocido: %d último: %d"
-#~ msgstr "Monitor: get_command: EOF prematuro"
+msgstr "Monitor: get_command: EOF prematuro"
-#~ msgstr "Controlador gráfico [%s] iniciado"
+msgstr "Controlador gráfico [%s] iniciado"
-#~ msgstr "ERROR %s del driver de gráficos.\n"
+msgstr "ERROR %s del driver de gráficos.\n"
-#~ msgstr "No se puede asignar memoria\n"
+msgstr "No se puede asignar memoria\n"
-#~ msgstr "ERROR - eof del monitor de gráficos.\n"
+msgstr "ERROR - eof del monitor de gráficos.\n"
-#~ msgstr "Atención - No hay repuesta del monitor de gráficos <%s>.\n"
+msgstr "Atención - No hay repuesta del monitor de gráficos <%s>.\n"
-#~ msgstr "Verifique si el mouse aun está activo.\n"
+msgstr "Verifique si el mouse aun está activo.\n"
-#~ msgstr "ERROR - el monitor de gráficos <%s> no reponde.\n"
+msgstr "ERROR - el monitor de gráficos <%s> no reponde.\n"
-#~ msgstr "No se ha seleccionado ningún monitor de gráficos para la salida."
+msgstr "No se ha seleccionado ningún monitor de gráficos para la salida."
-#~ msgstr "Por favor ejecute \"d.mon\" para seleccionar monitor gráfico."
+msgstr "Por favor ejecute \"d.mon\" para seleccionar monitor gráfico."
-#~ msgstr "Error al obtener el nombre del socket para el monitor <%s>."
+msgstr "Error al obtener el nombre del socket para el monitor <%s>."
-#~ msgstr "Ningún socket al que conectar para el monitor <%s>."
+msgstr "Ningún socket al que conectar para el monitor <%s>."
-#~ msgstr "El socket está siendo utilizado o no acepta conexiones."
+msgstr "El socket está siendo utilizado o no acepta conexiones."
-#~ msgstr "Use d.mon para seleccionar un monitor gráfico"
+msgstr "Use d.mon para seleccionar un monitor gráfico"
-#~ msgstr "Conectando a un dispositivo que no es un socket."
+msgstr "Conectando a un dispositivo que no es un socket."
-#~ msgstr "Probablemente error en el programa."
+msgstr "Probablemente error en el programa."
-#~ msgstr "Tiempo de conexión excedido."
+msgstr "Tiempo de conexión excedido."
-#~ msgstr "Probablemente un error con el servidor."
+msgstr "Probablemente un error con el servidor."
-#~ msgstr "Fallo en la conexión."
+msgstr "Fallo en la conexión."
-#~ msgstr "BUG (delete_area_cats_from_cidx): el área %d no existe"
+msgstr "BUG (delete_area_cats_from_cidx): el área %d no existe"
-#~ msgstr "Intento de borrar una línea muerta"
+msgstr "Intento de borrar una línea muerta"
-#~ msgstr "No se puede abrir el archivo %s "
-#~ msgstr "No se puede abrir el archivo temporal"
+msgstr "No se puede abrir el archivo temporal"
-#~ msgstr "Presione ENTER para cancelar la solicitud\n"
+msgstr "Presione ENTER para cancelar la solicitud\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor especifique el nombre del elipsoide\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor especifique el nombre del elipsoide\n"
-#~ msgstr "Teclee 'list' para mostrar la lista de elipsoides disponibles\n"
+msgstr "Teclee 'list' para mostrar la lista de elipsoides disponibles\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "elipsoide inválido\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"elipsoide inválido\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor especifique el nombre del datum\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor especifique el nombre del datum\n"
-#~ msgstr "Introduzca 'list' para ver la lista de datums disponibles\n"
+msgstr "Introduzca 'list' para ver la lista de datums disponibles\n"
-#~ msgstr ""
-#~ "o 'personalizar' si quieres introducir parámetros de personalización\n"
+msgstr "o 'personalizar' si quieres introducir parámetros de personalización\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum no válido\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum no válido\n"
-#~ msgstr "Presiona ENTER para continuar -->"
+msgstr "Presiona ENTER para continuar -->"
-#~ msgstr "no es posible abrir el ráster |%s en %s]"
+msgstr "no es posible abrir el ráster |%s en %s]"
-#~ msgstr "un momento...\n"
+msgstr "un momento...\n"
-#~ msgstr "No hay ayuda disponible para el comando [%s]\n"
+msgstr "No hay ayuda disponible para el comando [%s]\n"
-#~ msgstr "El ráster %s@%s está vacío"
+msgstr "El ráster %s@%s está vacío"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "La tabla de colores es necesaria para el archivo |%s] en el directorio de "
-#~ "mapas [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"La tabla de colores es necesaria para el archivo |%s] en el directorio de "
+"mapas [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor identifique el tipo deseado:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor identifique el tipo deseado:\n"
-#~ msgstr "    1:  Colores aleatorios\n"
+msgstr "    1:  Colores aleatorios\n"
-#~ msgstr "    2:  Paleta de colores rojo, verde y azul\n"
+msgstr "    2:  Paleta de colores rojo, verde y azul\n"
-#~ msgstr "    3:  Variedad de colores\n"
+msgstr "    3:  Variedad de colores\n"
-#~ msgstr "    4:  Escala de gris\n"
+msgstr "    4:  Escala de gris\n"
-#~ msgstr "    5:  Aspecto\n"
+msgstr "    5:  Aspecto\n"
-#~ msgstr "    6:  Colores del arcoiris\n"
+msgstr "    6:  Colores del arcoiris\n"
-#~ msgstr "    7:  Rojo a verde a través de amarillo\n"
+msgstr "    7:  Rojo a verde a través de amarillo\n"
-#~ msgstr "    8:  Verde a rojo a través de amarillo\n"
+msgstr "    8:  Verde a rojo a través de amarillo\n"
-#~ msgstr "ENTER  salir\n"
+msgstr "ENTER  salir\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s es inválido; Intente nuevamente > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s es inválido; Intente nuevamente > "
-#~ msgstr "%s no encontrado"
+msgstr "%s no encontrado"
-#~ msgstr "ERROR de lectura %s"
+msgstr "ERROR de lectura %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Por favor indique el nombre de la proyección\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Por favor indique el nombre de la proyección\n"
-#~ msgstr "Teclee 'list' para mostrar la lista de proyecciones disponibles\n"
+msgstr "Teclee 'list' para mostrar la lista de proyecciones disponibles\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "proyección inválida\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"proyección inválida\n"
-#~ msgstr "con títulos"
+msgstr "con títulos"
-#~ msgstr "(no hay título)"
+msgid "(no title)"
+msgstr "(no hay título)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPCIÓN: ¿Definir la siguiente opción?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"OPCIÓN: ¿Definir la siguiente opción?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPCIÓN:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPCIÓN:   %s\n"
-#~ msgstr "     clave: %s\n"
+msgid "     key: %s\n"
+msgstr "     clave: %s\n"
-#~ msgstr "  formato: %s\n"
+msgstr "  formato: %s\n"
-#~ msgstr " por defecto: %s\n"
+msgstr " por defecto: %s\n"
-#~ msgstr "se requiere: %s\n"
+msgstr "se requiere: %s\n"
-#~ msgstr "múltiple: %s\n"
+msgstr "múltiple: %s\n"
-#~ msgstr "introduce una opción > "
+msgstr "introduce una opción > "
-#~ msgstr "   ¿Intentar de nuevo? "
+msgstr "   ¿Intentar de nuevo? "
-#~ msgstr "Lo siento, %s no se acepta.\n"
+msgstr "Lo siento, %s no se acepta.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Usted ha seleccionado:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Usted ha seleccionado:\n"
+"  %s\n"
-#~ msgstr "¿Es correcto? "
+msgstr "¿Es correcto? "
-#~ msgstr "para aceptar los valores por defecto"
+msgstr "para aceptar los valores por defecto"
-#~ msgstr "para cancelar"
+msgstr "para cancelar"
-#~ msgstr "Entre un nombre nuevo  %s para el archivo"
+msgstr "Entre un nombre nuevo  %s para el archivo"
-#~ msgstr "Entre el nombre de un archivo %s existente"
+msgstr "Entre el nombre de un archivo %s existente"
-#~ msgstr "Entre nombre del archivo %s"
+msgstr "Entre nombre del archivo %s"
-#~ msgstr "Teclee 'list' para mostrar una lista de archivos %s existentes\n"
+msgstr "Teclee 'list' para mostrar una lista de archivos %s existentes\n"
-#~ msgstr "Entre 'list -f' para "
+msgstr "Entre 'list -f' para "
-#~ msgstr "una lista %s"
+msgid "a list %s"
+msgstr "una lista %s"
-#~ msgstr "una lista extendida"
+msgstr "una lista extendida"
-#~ msgstr "Presione ENTER %s\n"
+msgstr "Presione ENTER %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - no encontrado **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - no encontrado **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s existe. ¿Desea sobrescribir? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s existe. ¿Desea sobrescribir? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**nombre <%s> no admitido **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**nombre <%s> no admitido **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - requerimiento ilegal **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - requerimiento ilegal **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - existe, seleccione otro nombre **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - existe, seleccione otro nombre **\n"
-#~ msgstr "pregunta: no puede suceder"
+msgstr "pregunta: no puede suceder"
-#~ msgstr "Memoria insuficiente para emplazar gaussian"
+msgstr "Memoria insuficiente para emplazar gaussian"
-#~ msgstr "No se pueden conectar las líneas %d,%d"
+msgstr "No se pueden conectar las líneas %d,%d"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "El nombre de salida '%s' no es un nombre de ráster válido."
+msgid "Output name '%s' is not valid rast name."
+msgstr "El nombre de salida '%s' no es un nombre de ráster válido."
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "Mapa final '%s' esta siendo utilizado como entrada"
+msgid "Output map '%s' is used as input"
+msgstr "Mapa final '%s' esta siendo utilizado como entrada"
 #, fuzzy
-#~ msgid "Translating colors from fp raster map <%s>"
-#~ msgstr "No se puede abrir el mapa ráster <%s>"
+msgid "Translating colors from fp raster map <%s>"
+msgstr "No se puede abrir el mapa ráster <%s>"
+#, fuzzy
+#~ msgstr "<%s> en el directorio de mapas <%s>"
+#~ msgstr "No se puede encontrar [%s] en [%s]"
Modified: grass/trunk/locale/po/grasslibs_fr.po
--- grass/trunk/locale/po/grasslibs_fr.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_fr.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -523,9 +523,9 @@
 msgstr "impossible d'ouvrir le fichier de l'ellipsoïde: %s"
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
+msgstr "impossible d'ouvrir le fichier de l'ellipsoïde: %s"
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1264,12 +1264,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "Impossible d'ouvrir le fichier temporaire"
+msgstr "Impossible de calculer le centroïde de l'entité surfacique %d"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -2001,9 +2001,11 @@
 msgstr "pour accepter le choix par défaut"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
 msgstr ""
+"Bug: tentative de mise à jour d'une couche qui n'est pas dans le jeu de "
+"données (mapset) courant."
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2066,7 +2068,9 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "pas de fichier %s disponible dans le jeu de données (mapset) actuel\n"
+msgstr ""
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2276,7 +2280,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "impossible de trouver [%s] dans [%s]"
+msgstr "[%s] introuvable"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2340,9 +2344,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -3941,9 +3945,11 @@
 msgstr "Le vecteur d'entrée '%s' n'a pas été trouvé"
 #: ../lib/ogsf/GS2.c:1638
-#, c-format
+#, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
+"[%s] dans le jeu de données (mapset) [%s] - est dans une zone différente [%"
+"d] de celle de la région courante [%d]"
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
@@ -4330,7 +4336,7 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
-msgstr "Impossible d'ouvrir %s"
+msgstr "Impossible d'ouvrir le fichier %s dans %s"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
@@ -4481,675 +4487,680 @@
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
+msgid "Cannot describe table <%s>"
+msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgstr "ERREUR %s du pilote graphique.\n"
+msgstr "ERREUR %s du pilote graphique.\n"
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#~ msgstr "ERREUR - le moniteur graphique a renvoyé eof.\n"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "ERREUR - le moniteur graphique a renvoyé eof.\n"
-#~ msgstr "Attention - le moniteur graphique <%s> ne répond pas.\n"
+msgstr "Attention - le moniteur graphique <%s> ne répond pas.\n"
-#~ msgstr "Vérifiez que la souris est toujours active.\n"
+msgstr "Vérifiez que la souris est toujours active.\n"
-#~ msgstr "ERREUR - le moniteur graphique <%s> ne répond pas.\n"
+msgstr "ERREUR - le moniteur graphique <%s> ne répond pas.\n"
 #, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "Aucun moniteur graphique n'a été sélectionné pour l'affichage.\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "Aucun moniteur graphique n'a été sélectionné pour l'affichage.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr ""
-#~ "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique.\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique.\n"
 #, fuzzy
-#~ msgstr "Echec lors de l'obtention du nom de socket pour le moniteur <%s>.\n"
+msgstr "Echec lors de l'obtention du nom de socket pour le moniteur <%s>.\n"
 #, fuzzy
-#~ msgstr "Aucune socket où se connecter pour le moniteur <%s>.\n"
+msgstr "Aucune socket où se connecter pour le moniteur <%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "La socket est déjà utilisée ou n'accepte pas les connexions.\n"
-#~ "Utilisez d.mon pour sélectionner un moniteur\n"
+msgstr ""
+"La socket est déjà utilisée ou n'accepte pas les connexions.\n"
+"Utilisez d.mon pour sélectionner un moniteur\n"
 #, fuzzy
-#~ msgstr ""
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Tentative de connexion à quelque chose qui n'est pas une socket.\n"
-#~ "Certainement dû à une erreur du programme.\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"Tentative de connexion à quelque chose qui n'est pas une socket.\n"
+"Certainement dû à une erreur du programme.\n"
 #, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr ""
-#~ "Délai de connexion dépassé. Certainement dû à un problème avec le "
-#~ "serveur.\n"
+msgid "Probably an error with the server."
+msgstr ""
+"Délai de connexion dépassé. Certainement dû à un problème avec le serveur.\n"
 #, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "Echec de la connexion.\n"
+msgid "Connection failed."
+msgstr "Echec de la connexion.\n"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "Impossible de lire l'histogramme pour [%s dans %s]"
+msgid "Cannot read topo for line [%d]"
+msgstr "Impossible de lire l'histogramme pour [%s dans %s]"
 #, fuzzy
-#~ msgstr "Impossible d'ouvrir le fichier %s dans %s"
 #, fuzzy
-#~ msgid "Unable to open temporary file"
+msgid "Unable to open temporary file"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Pressez RETOUR pour abandonner\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "Pressez RETOUR pour abandonner\n"
-#~ msgid "Cannot open temp file"
-#~ msgstr "Impossible d'ouvrir le fichier temporaire"
+msgid "Cannot open temp file"
+msgstr "Impossible d'ouvrir le fichier temporaire"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Veuillez spécifier un nom d'ellipsoïde\n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"Veuillez spécifier un nom d'ellipsoïde\n"
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "Entrer 'list' pour une liste des ellipsoïdes existants\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "Entrer 'list' pour une liste des ellipsoïdes existants\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ellipsoïde invalide\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"ellipsoïde invalide\n"
 #, fuzzy
-#~ msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
+msgstr "Le nom de sortie '%s' n'est pas un nom de vecteur valide."
-#~ msgstr "La couche de sortie '%s' est utilisée en entrée"
+msgstr "La couche de sortie '%s' est utilisée en entrée"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Veuillez spécifier un nom de datum\n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
+"Veuillez spécifier un nom de datum\n"
-#~ msgid "Enter 'list' for the list of available datums\n"
-#~ msgstr "Entrer 'list' pour une liste des datums existants\n"
+msgid "Enter 'list' for the list of available datums\n"
+msgstr "Entrer 'list' pour une liste des datums existants\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum invalide\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum invalide\n"
-#~ msgstr "pressez RETOUR pour continuer -->"
+msgstr "pressez RETOUR pour continuer -->"
-#~ msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
+msgstr "impossible d'ouvrir la couche raster |%s dans %s]"
-#~ msgstr "veuillez patienter...\n"
+msgstr "veuillez patienter...\n"
-#~ msgstr "Aucune aide disponible pour la commande [%s]\n"
+msgstr "Aucune aide disponible pour la commande [%s]\n"
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr "La couche raster %s@%s est vide"
+msgid " The raster map %s@%s is empty"
+msgstr "La couche raster %s@%s est vide"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de "
-#~ "données (mapset) [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"La table des couleurs est nécessaire pour le fichier |%s] dans le jeu de "
+"données (mapset) [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Veuillez sélectionner le type désiré:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Veuillez sélectionner le type désiré:\n"
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "    1:  Couleurs aléatoires\n"
+msgid "    1:  Random colors\n"
+msgstr "    1:  Couleurs aléatoires\n"
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "    2:  Palette de rouge, vert et bleu\n"
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr "    2:  Palette de rouge, vert et bleu\n"
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "    3:  Vague de couleur\n"
+msgid "    3:  Color wave\n"
+msgstr "    3:  Vague de couleur\n"
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "    4:  Nuances de gris\n"
+msgid "    4:  Gray scale\n"
+msgstr "    4:  Nuances de gris\n"
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "    5:  Aspect\n"
+msgid "    5:  Aspect\n"
+msgstr "    5:  Aspect\n"
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "    6:  Couleurs de l'arc-en-ciel\n"
+msgid "    6:  Rainbow colors\n"
+msgstr "    6:  Couleurs de l'arc-en-ciel\n"
-#~ msgstr "    7:  Rouge en passant par le jaune et le vert\n"
+msgstr "    7:  Rouge en passant par le jaune et le vert\n"
-#~ msgstr "    8:  Vert en passant par le jaune et le rouge\n"
+msgstr "    8:  Vert en passant par le jaune et le rouge\n"
-#~ msgid "RETURN  quit\n"
-#~ msgstr "RETOUR  quitter\n"
+msgid "RETURN  quit\n"
+msgstr "RETOUR  quitter\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s est invalide; Essayez de nouveau > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s est invalide; Essayez de nouveau > "
-#~ msgid "%s not found"
-#~ msgstr "%s introuvable"
+msgid "%s not found"
+msgstr "%s introuvable"
-#~ msgstr "ERREUR en lisant %s"
+msgstr "ERREUR en lisant %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Veuillez indiquer un nom de projection\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Veuillez indiquer un nom de projection\n"
-#~ msgstr "Entrer 'list' pour une liste des projections disponibles\n"
+msgstr "Entrer 'list' pour une liste des projections disponibles\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "projection invalide\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"projection invalide\n"
-#~ msgid "with titles"
-#~ msgstr "avec les titres"
+msgid "with titles"
+msgstr "avec les titres"
-#~ msgid "(no title)"
-#~ msgstr "(aucun titre)"
+msgid "(no title)"
+msgstr "(aucun titre)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "DRAPEAU: Avez-vous placé ce drapeau?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"DRAPEAU: Avez-vous placé ce drapeau?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPTION:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPTION:   %s\n"
-#~ msgid "     key: %s\n"
-#~ msgstr "     clé: %s\n"
+msgid "     key: %s\n"
+msgstr "     clé: %s\n"
-#~ msgstr "  format: %s\n"
+msgstr "  format: %s\n"
-#~ msgstr " par défaut: %s\n"
+msgstr " par défaut: %s\n"
-#~ msgstr "obligatoire: %s\n"
+msgstr "obligatoire: %s\n"
-#~ msgstr "multiple: %s\n"
+msgstr "multiple: %s\n"
-#~ msgstr "entrez une option > "
+msgstr "entrez une option > "
-#~ msgstr "   Essayer à nouveau? "
+msgstr "   Essayer à nouveau? "
-#~ msgstr "Désolé, %s n'est pas acceptée.\n"
+msgstr "Désolé, %s n'est pas acceptée.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Vous avez choisi:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Vous avez choisi:\n"
+"  %s\n"
-#~ msgid "Is this correct? "
-#~ msgstr "Est-ce correct? "
+msgid "Is this correct? "
+msgstr "Est-ce correct? "
-#~ msgid "to accept the default"
-#~ msgstr "pour accepter le choix par défaut"
+msgid "to accept the default"
+msgstr "pour accepter le choix par défaut"
-#~ msgid "to cancel request"
-#~ msgstr "pour abandonner la requète"
+msgid "to cancel request"
+msgstr "pour abandonner la requète"
-#~ msgid "Enter a new %s file name"
-#~ msgstr "Entrez un nouveau nom de fichier %s"
+msgid "Enter a new %s file name"
+msgstr "Entrez un nouveau nom de fichier %s"
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr "Entrez le nom d'un fichier %s existant"
+msgid "Enter the name of an existing %s file"
+msgstr "Entrez le nom d'un fichier %s existant"
-#~ msgid "Enter %s file name"
-#~ msgstr "Entrez un nom de fichier %s"
+msgid "Enter %s file name"
+msgstr "Entrez un nom de fichier %s"
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "Entrez 'list' pour une liste des fichiers %s existants\n"
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr "Entrez 'list' pour une liste des fichiers %s existants\n"
-#~ msgid "Enter 'list -f' for "
-#~ msgstr "Entrez 'list -f' pour "
+msgid "Enter 'list -f' for "
+msgstr "Entrez 'list -f' pour "
-#~ msgid "a list %s"
-#~ msgstr "une liste %s"
+msgid "a list %s"
+msgstr "une liste %s"
-#~ msgid "an extended list"
-#~ msgstr "une liste étendue"
+msgid "an extended list"
+msgstr "une liste étendue"
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "Pressez RETOUR %s\n"
+msgid "Hit RETURN %s\n"
+msgstr "Pressez RETOUR %s\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - introuvable **\n"
+msgid ""
+"\n"
+"** %s - not found **\n"
+msgstr ""
+"\n"
+"** %s - introuvable **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s existe. d'accord pour l'écraser? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s existe. d'accord pour l'écraser? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> nom illégal **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> nom illégal **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - requête illégale **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - requête illégale **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - existe, sélectionnez un autre nom **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - existe, sélectionnez un autre nom **\n"
-#~ msgid "ask: can't happen"
-#~ msgstr "demande: ne peut pas survenir"
+msgid "ask: can't happen"
+msgstr "demande: ne peut pas survenir"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Impossible de lire l'en-tête de fichier pour [%s dans %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Impossible de lire l'en-tête de fichier pour [%s dans %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Impossible d'ouvrir le fichier d'en-tête pour [%s dans %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Impossible d'ouvrir le fichier d'en-tête pour [%s dans %s]"
 #, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "Impossible de récupérer les infos de la couche"
+msgid "Cannot get field info"
+msgstr "Impossible de récupérer les infos de la couche"
 #, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
-#~ msgid "Building topology ...\n"
-#~ msgstr "Construction de la topologie ...\n"
+msgid "Building topology ...\n"
+msgstr "Construction de la topologie ...\n"
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d surfaces construites      \n"
-#~ "%d îles construites\n"
+msgid ""
+"\r%d areas built      \n"
+"%d isles built\n"
+msgstr ""
+"\r%d surfaces construites      \n"
+"%d îles construites\n"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
+msgid "Cannot open database <%s> by driver <%s>"
 #, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
 #, fuzzy
-#~ msgstr "Le type d'objet OGR %d n'est pas géré"
+msgstr "Le type d'objet OGR %d n'est pas géré"
 #, fuzzy
-#~ msgstr "Vect_rewrite_line() n'est pas supportée pour ce format/niveau"
+msgstr "Vect_rewrite_line() n'est pas supportée pour ce format/niveau"
-#~ msgstr "Vect_delete_line() n'est pas supportée pour ce format/niveau"
+msgstr "Vect_delete_line() n'est pas supportée pour ce format/niveau"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "Impossible de réécrire la ligne"
+msgid "Cannot rewrite line"
+msgstr "Impossible de réécrire la ligne"
-#~ msgid "Cannot delete line"
-#~ msgstr "Impossible de supprimer la ligne"
+msgid "Cannot delete line"
+msgstr "Impossible de supprimer la ligne"
-#~ msgid "Output name '%s' is not valid vector name."
+msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Impossible de copier le vecteur '%s' vers '%s'"
+msgstr "Impossible de copier le vecteur '%s' vers '%s'"
 #, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Impossible de supprimer le vecteur %s"
+msgid "Cannot open existing vector map <%s>"
+msgstr "Impossible de supprimer le vecteur %s"
 #, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Impossible d'ouvrir le nouveau vecteur %s"
+msgid "Cannot open new vector %s"
+msgstr "Impossible d'ouvrir le nouveau vecteur %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "Impossible d'ouvrir le fichier d'historique pour le vecteur '%s'"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "Impossible d'obtenir des informations sur le fichier '%s'"
+msgid "Could not stat file '%s'"
+msgstr "Impossible d'obtenir des informations sur le fichier '%s'"
 #, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Impossible d'ouvrir l'ancien vecteur %s"
+msgid "Can't open directory %s"
+msgstr "Impossible d'ouvrir l'ancien vecteur %s"
-#~ msgstr "%s - ** nom illégal **"
+msgstr "%s - ** nom illégal **"
-#~ msgstr "Aucun moniteur graphique correspondant à <%s>.\n"
+msgstr "Aucun moniteur graphique correspondant à <%s>.\n"
-#~ msgstr ""
-#~ "Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique "
-#~ "valide.\n"
+msgstr ""
+"Veuillez lancer \"d.mon\" pour sélectionner un moniteur graphique valide.\n"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Impossible d'obtenir des informations sur %s\n"
+msgid "Can't stat %s\n"
+msgstr "Impossible d'obtenir des informations sur %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est en cours d'utilisation.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Erreur - Le moniteur <%s> est en cours d'utilisation.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Erreur - Le moniteur <%s> est utilisé par %s.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Erreur - Le moniteur <%s> est utilisé par %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Erreur - Impossible de bloquer le moniteur <%s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Erreur - Impossible de bloquer le moniteur <%s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Erreur - Impossible de créer un tube vers la sortie graphique.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Erreur - Impossible de créer un tube vers la sortie graphique.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Erreur - Le moniteur graphique <%s> n'est pas lancé!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Erreur - Le moniteur graphique <%s> n'est pas lancé!\n"
-#~ msgstr "Veuillez démarrer le moniteur graphique <%s>.\n"
+msgstr "Veuillez démarrer le moniteur graphique <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Aucune connexion...\n"
+msgid "Not connected...\n"
+msgstr "Aucune connexion...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr ""
-#~ "Impossible de se connecter au moniteur. Nous allons essayer encore une "
-#~ "fois.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr ""
+"Impossible de se connecter au moniteur. Nous allons essayer encore une "
+"fois.\n"
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "G_dump: mémoire allouée à G__"
+msgid "G_dump: memory allocated to G__"
+msgstr "G_dump: mémoire allouée à G__"
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr ""
-#~ "Taille de cellule dans les couches en nombres en virgule flottante = %d"
+msgid "Size of cell in fp maps = %d"
+msgstr ""
+"Taille de cellule dans les couches en nombres en virgule flottante = %d"
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr ""
-#~ "type d'écriture pour les couches en nombres en virgule flottante = %d"
+msgid "type for writing floating maps = %d"
+msgstr "type d'écriture pour les couches en nombres en virgule flottante = %d"
-#~ msgid "current window = %p"
-#~ msgstr "fenêtre courante = %p"
+msgid "current window = %p"
+msgstr "fenêtre courante = %p"
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Drapeau: fenêtre définie? %d"
+msgid "Flag: window set? %d"
+msgstr "Drapeau: fenêtre définie? %d"
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Descripteur de fichier pour le masque automatique %d"
+msgid "File descriptor for automatic mask %d"
+msgstr "Descripteur de fichier pour le masque automatique %d"
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "Drapeau signifiant un masquage automatique %d"
+msgid "Flag denoting automatic masking %d"
+msgstr "Drapeau signifiant un masquage automatique %d"
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "Tampon du masque de CELLULE %p"
+msgid "CELL mask buffer %p"
+msgstr "Tampon du masque de CELLULE %p"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "tampon pour lire les lignes nulles %p"
+msgid "buffer for reading null rows %p"
+msgstr "tampon pour lire les lignes nulles %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Tampon pour les données compressées pre/post %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Tampon pour les données compressées pre/post %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "sizeof compressed_buf %d"
+msgid "sizeof compressed_buf %d"
+msgstr "sizeof compressed_buf %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "tampon des données de travail %p"
+msgid "work data buffer %p"
+msgstr "tampon des données de travail %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "sizeof work_buf %d"
+msgid "sizeof work_buf %d"
+msgstr "sizeof work_buf %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "sizeof null_buf %d"
+msgid "sizeof null_buf %d"
+msgstr "sizeof null_buf %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "sizeof  mask_buf %d"
+msgid "sizeof mask_buf %d"
+msgstr "sizeof  mask_buf %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Demande de construction d'un histogramme %d"
+msgid "Histogram request %d"
+msgstr "Demande de construction d'un histogramme %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: fichier #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump: fichier #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "mode d'ouverture = %d"
+msgid "open mode = %d"
+msgstr "mode d'ouverture = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "En-tête de cellule %p"
+msgid "Cell header %p"
+msgstr "En-tête de cellule %p"
-#~ msgid "Table reclass %p"
-#~ msgstr "Tableau de reclassification %p"
+msgid "Table reclass %p"
+msgstr "Tableau de reclassification %p"
-#~ msgid "Cell stats %p"
-#~ msgstr "Statistiques de cellule %p"
+msgid "Cell stats %p"
+msgstr "Statistiques de cellule %p"
-#~ msgid "Range structure %p"
-#~ msgstr "Structure de l'intervalle %p"
+msgid "Range structure %p"
+msgstr "Structure de l'intervalle %p"
-#~ msgid "float Range structure %p"
-#~ msgstr "structure de l'intervalle en nombres en virgule flottante %p"
+msgid "float Range structure %p"
+msgstr "structure de l'intervalle en nombres en virgule flottante %p"
-#~ msgid "want histogram?  %d"
-#~ msgstr "un histogramme?..%d"
+msgid "want histogram?  %d"
+msgstr "un histogramme?..%d"
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "Drapeau de reclassification automatique %d"
+msgid "Automatic reclass flag %d"
+msgstr "Drapeau de reclassification automatique %d"
-#~ msgid "File row addresses %p"
-#~ msgstr "Adresses de la ligne du fichier %p"
+msgid "File row addresses %p"
+msgstr "Adresses de la ligne du fichier %p"
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "Donnée du tracé de la colonne dans la fenêtre %p"
+msgid "Data to window col mapping %p"
+msgstr "Donnée du tracé de la colonne dans la fenêtre %p"
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "Données des constantes de lignes dans la fenêtre %f,%f"
+msgid "Data to window row constants %f,%f"
+msgstr "Données des constantes de lignes dans la fenêtre %f,%f"
-#~ msgid "Current data row in memory %d"
-#~ msgstr "Lignes de données actuellement en mémoire %d"
+msgid "Current data row in memory %d"
+msgstr "Lignes de données actuellement en mémoire %d"
-#~ msgid "Current null row in memory %d"
-#~ msgstr "Ligne vide courante en mémoire %d"
+msgid "Current null row in memory %d"
+msgstr "Ligne vide courante en mémoire %d"
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "Nombre d'octets par cellule pour la ligne courante %d"
+msgid "nbytes per cell for current row %d"
+msgstr "Nombre d'octets par cellule pour la ligne courante %d"
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Tampon de données décompressées %s"
+msgid "Decompressed data buffer %s"
+msgstr "Tampon de données décompressées %s"
-#~ msgid "bytes per cell %d"
-#~ msgstr "octets par cellule %d"
+msgid "bytes per cell %d"
+msgstr "octets par cellule %d"
-#~ msgid "type: int, float or double map %d"
-#~ msgstr ""
-#~ "type: entier(int), nombre en virgule flottante (float) ou double couche %d"
+msgid "type: int, float or double map %d"
+msgstr ""
+"type: entier(int), nombre en virgule flottante (float) ou double couche %d"
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichiers %s"
+msgid "Temporary name for NEW files %s"
+msgstr "Nom temporaire pour les NOUVEAUX fichiers %s"
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Nom temporaire pour les NOUVEAUX fichier %s NULS"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Nom temporaire pour les NOUVEAUX fichier %s NULS"
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Mapset du fichier ouvert %s"
+msgid "Mapset of open file %s"
+msgstr "Mapset du fichier ouvert %s"
-#~ msgid "io error warning given %d"
-#~ msgstr "erreur d'entrée/sortie renvoyée %d"
+msgid "io error warning given %d"
+msgstr "erreur d'entrée/sortie renvoyée %d"
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "flux xdr pour lire fp %p"
+msgid "xdr stream for reading fp %p"
+msgstr "flux xdr pour lire fp %p"
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS array[%d] = %p"
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "tampon de données pour lire les lignes nulles %p"
+msgid "data buffer for reading null rows %p"
+msgstr "tampon de données pour lire les lignes nulles %p"
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Nombre minimum d'une ligne d'une ligne nulle en mémoire %d"
+msgid "Minimum row null row number in memory %d"
+msgstr "Nombre minimum d'une ligne d'une ligne nulle en mémoire %d"
-#~ msgid "Quant ptr = %p"
-#~ msgstr "Quant ptr = %p"
+msgid "Quant ptr = %p"
+msgstr "Quant ptr = %p"
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: fin"
+msgid "G_dump: end"
+msgstr "G_dump: fin"
 #, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
 #, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "aucun fichier %s disponible\n"
+msgid "Color file for [%s] not available"
+msgstr "aucun fichier %s disponible\n"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
 #, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Too many open raster maps"
-#~ msgstr "Trop de fichiers raster ouverts"
+msgid "Too many open raster maps"
+msgstr "Trop de fichiers raster ouverts"
-#~ msgid "Too many open files"
-#~ msgstr "Trop de fichiers ouverts"
+msgid "Too many open files"
+msgstr "Trop de fichiers ouverts"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ERREUR: Géodatabase (GISBASE) sans valeur\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "ERREUR: Géodatabase (GISBASE) sans valeur\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant le paramètre de décalage du datum dans la table pour %s"
+msgid "Error reading datum shift parameters for %s from table"
+msgstr ""
+"Erreur en lisant le paramètre de décalage du datum dans la table pour %s"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr ""
-#~ "Erreur en lisant les paramètres de l'ellipsoïde depuis la table pour %s"
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr ""
+"Erreur en lisant les paramètres de l'ellipsoïde depuis la table pour %s"
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "Pas de champ ellipsoïde %s dans le fichier %s de %s"
+msgid "No ellipsoid field %s in file %s in %s"
+msgstr "Pas de champ ellipsoïde %s dans le fichier %s de %s"
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "valeur invalide: champ %s dans le fichier %s de %s"
+msgid "invalid value: field %s in file %s in %s"
+msgstr "valeur invalide: champ %s dans le fichier %s de %s"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "Pas de n-dims dans site_list"
+msgid "No n-dims in site_list"
+msgstr "Pas de n-dims dans site_list"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "Aucun attribut double dans site_list"
+msgid "No double attributes in site_list"
+msgstr "Aucun attribut double dans site_list"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "Pas d'attribut chaîne de caractère dans site_list"
+msgid "No string attributes in site_list"
+msgstr "Pas d'attribut chaîne de caractère dans site_list"
-#~ msgid "String attribute index out of range"
-#~ msgstr "Index de l'attribut chaîne en dehors des limites"
+msgid "String attribute index out of range"
+msgstr "Index de l'attribut chaîne en dehors des limites"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "Attribut inconnu dans l'appel a G_readsites_xyz()!\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "Attribut inconnu dans l'appel a G_readsites_xyz()!\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "Echec lors de la conversion de l'attribut."
+msgid "Failed to convert string attribute."
+msgstr "Echec lors de la conversion de l'attribut."
-#~ msgid "Reading sites list ...                  "
-#~ msgstr "Lecture de la liste des sites...        "
+msgid "Reading sites list ...                  "
+msgstr "Lecture de la liste des sites...        "
-#~ msgid "failed to guess format"
-#~ msgstr "impossible de deviner le format"
+msgid "failed to guess format"
+msgstr "impossible de deviner le format"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "le champ décimal %i n'est pas présent dans le fichier de sites"
+msgid "decimal field %i not present in sites file"
+msgstr "le champ décimal %i n'est pas présent dans le fichier de sites"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr ""
-#~ "J'ai trouvé des enregistrements sans attribut en virgule flottante "
-#~ "(champs préfixés par '%')"
+msgid ""
+"I'm finding records that do not have a floating point attributes (fields "
+"prefixed with '%')."
+msgstr ""
+"J'ai trouvé des enregistrements sans attribut en virgule flottante (champs "
+"préfixés par '%')"
-#~ msgid "WARNING: can not create a new process\n"
-#~ msgstr "ATTENTION: impossible de créer un nouveau processus\n"
+msgid "WARNING: can not create a new process\n"
+msgstr "ATTENTION: impossible de créer un nouveau processus\n"
-#~ msgid "Select type: point, line, boundary, centroid or area"
-#~ msgstr "Sélectionnez un type: point, ligne, intervalle, centroïde ou zone"
+msgid "Select type: point, line, boundary, centroid or area"
+msgstr "Sélectionnez un type: point, ligne, intervalle, centroïde ou zone"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà."
+msgid "The vector '%s' already exists."
+msgstr "Le vecteur '%s' existe déjà."
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "Allocation mémoire impossible\n"
+#, fuzzy
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s> dans le jeu de données (mapset) <%s>"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "impossible de trouver [%s] dans [%s]"
Modified: grass/trunk/locale/po/grasslibs_hi.po
--- grass/trunk/locale/po/grasslibs_hi.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_hi.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -512,9 +512,9 @@
 msgstr "का"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "का"
@@ -1243,12 +1243,12 @@
 #, fuzzy
-msgstr "के लिए n"
+msgstr "के लिए"
 #, fuzzy
-msgstr "के लिए n"
+msgstr "के लिए"
@@ -1960,9 +1960,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "है नहीं."
@@ -2023,7 +2023,7 @@
 #, fuzzy, c-format
-msgstr "n"
+msgstr "है नहीं."
@@ -2281,9 +2281,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "का"
 #, fuzzy, c-format
@@ -3859,9 +3859,9 @@
 msgstr "नहीं"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "है नहीं."
@@ -4386,570 +4386,580 @@
 msgstr "का"
 #, fuzzy
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "त्रुटि n"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "त्रुटि n"
 #, fuzzy
+msgstr "त्रुटि n"
 #, fuzzy
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "चेतावनी n"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "चेतावनी n"
 #, fuzzy
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "है n"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "है n"
 #, fuzzy
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "त्रुटि n"
 #, fuzzy
-#~ msgstr "नहीं के लिए n"
+msgstr "नहीं के लिए n"
 #, fuzzy
-#~ msgstr "a n"
+msgstr "a n"
 #, fuzzy
-#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "के लिए n"
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "No socket to connect to for monitor <%s>."
+msgid "No socket to connect to for monitor <%s>."
 #, fuzzy
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr "है नहीं a n"
+msgid "Socket is already in use or not accepting connections."
+msgstr "है नहीं a n"
 #, fuzzy
-#~ msgid "Use d.mon to select a monitor"
-#~ msgstr "a n"
+msgid "Use d.mon to select a monitor"
+msgstr "a n"
 #, fuzzy
-#~ msgstr "नहीं a प्रोग्राम त्रुटि n"
+msgstr "नहीं a प्रोग्राम त्रुटि n"
 #, fuzzy
+msgstr "त्रुटि n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "का"
+msgstr "का"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "के लिए का n"
+msgstr "के लिए का n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "है नहीं."
+msgstr "है नहीं."
 #, fuzzy
-#~ msgstr "है"
+msgstr "है"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+msgstr "n"
 #, fuzzy
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "one moment...\n"
-#~ msgstr "एक n"
+msgid "one moment...\n"
+msgstr "एक n"
 #, fuzzy
-#~ msgid "No help available for command [%s]\n"
+msgid "No help available for command [%s]\n"
 #, fuzzy
-#~ msgstr "है"
+msgstr "है"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr "n के लिए n"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr "n के लिए n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "स्केल n"
+msgstr "स्केल n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "इंद्रधनुष n"
+msgstr "इंद्रधनुष n"
 #, fuzzy
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "n"
+msgid "    7:  Red through yellow to green\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "n"
+msgid "    8:  Green through yellow to red\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr "n अवैध कोशिश करें "
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr "n अवैध कोशिश करें "
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "ERROR in reading %s"
-#~ msgstr "त्रुटि"
+msgid "ERROR in reading %s"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr "n n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid "Enter 'list' for the list of available projections\n"
+msgid "Enter 'list' for the list of available projections\n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "शीर्षक"
+msgid "(no title)"
+msgstr "शीर्षक"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr "सेट n"
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr "सेट n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "n"
+msgid "     key: %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  format: %s\n"
-#~ msgstr "n"
+msgid "  format: %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid " default: %s\n"
-#~ msgstr "n"
+msgid " default: %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "required: %s\n"
-#~ msgstr "n"
+msgid "required: %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "multiple: %s\n"
-#~ msgstr "n"
+msgid "multiple: %s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "   Try again? "
-#~ msgstr "कोशिश करें "
+msgid "   Try again? "
+msgstr "कोशिश करें "
 #, fuzzy
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "खेद है है नहीं n"
+msgid "Sorry, %s is not accepted.\n"
+msgstr "खेद है है नहीं n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ " n"
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+"\n"
+" n"
 #, fuzzy
-#~ msgstr "है "
+msgstr "है "
 #, fuzzy
-#~ msgstr "a"
+msgstr "a"
 #, fuzzy
-#~ msgstr "का"
+msgstr "का"
 #, fuzzy
-#~ msgstr "के लिए a का n"
+msgstr "के लिए a का n"
 #, fuzzy
-#~ msgstr "f के लिए "
+msgstr "f के लिए "
 #, fuzzy
-#~ msgstr "a"
+msgid "a list %s"
+msgstr "a"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "n नहीं n"
+msgid ""
+"\n"
+msgstr "n नहीं n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr "n "
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr "n "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr "n n"
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr "n n"
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr "n n"
 #, fuzzy
-#~ msgstr "पूछें"
+msgstr "पूछें"
 #, fuzzy
+msgstr "के लिए n"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
+msgstr "के लिए n"
 #, fuzzy
-#~ msgstr "लिंक ."
+msgstr "लिंक ."
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ msgstr "n n"
+msgid ""
+"%d isles built\n"
+msgstr "n n"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Column type not supported"
-#~ msgstr "विशेषता नहीं"
+msgid "Column type not supported"
+msgstr "विशेषता नहीं"
 #, fuzzy
-#~ msgid "OGR feature type [%d] not supported"
+msgid "OGR feature type [%d] not supported"
 #, fuzzy
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "के लिए नहीं"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "के लिए नहीं"
 #, fuzzy
-#~ msgid "Vect_delete_line() for this format/level not supported"
+msgid "Vect_delete_line() for this format/level not supported"
 #, fuzzy
+msgstr "है नहीं."
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "नहीं n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "a n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "a n"
 #, fuzzy
-#~ msgstr "n"
+msgstr "n"
 #, fuzzy
-#~ msgstr "त्रुटि है n"
+msgstr "त्रुटि है n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "त्रुटि नहीं के लिए n"
+msgstr "त्रुटि नहीं के लिए n"
 #, fuzzy
-#~ msgstr "त्रुटि सेट n"
+msgstr "त्रुटि सेट n"
 #, fuzzy
-#~ msgstr "त्रुटि नहीं चल रहा है... n"
+msgstr "त्रुटि नहीं चल रहा है... n"
 #, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "प्रारंभ n"
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "प्रारंभ n"
 #, fuzzy
-#~ msgstr "कनेक्टेड n"
+msgstr "कनेक्टेड n"
 #, fuzzy
-#~ msgstr "अधिक n"
+msgstr "अधिक n"
 #, fuzzy
-#~ msgstr "जी जी"
+msgstr "जी जी"
 #, fuzzy
-#~ msgstr "का"
+msgstr "का"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "ध्वज सेट"
+msgstr "ध्वज सेट"
 #, fuzzy
-#~ msgstr "फ़ाइल के लिए स्वचालित"
+msgstr "फ़ाइल के लिए स्वचालित"
 #, fuzzy
-#~ msgstr "ध्वज स्वचालित"
+msgstr "ध्वज स्वचालित"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "जी"
+msgstr "जी"
 #, fuzzy
-#~ msgstr "सीमा"
+msgstr "सीमा"
 #, fuzzy
-#~ msgstr "सीमा"
+msgstr "सीमा"
 #, fuzzy
-#~ msgstr "फ़ाइल"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgstr "f f"
+msgstr "f f"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "बाइट्स"
+msgstr "बाइट्स"
 #, fuzzy
-#~ msgstr "अस्थायी के लिए"
+msgstr "अस्थायी के लिए"
 #, fuzzy
 #, fuzzy
-#~ msgstr "का"
+msgstr "का"
 #, fuzzy
-#~ msgstr "त्रुटि"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "संख्या"
+msgstr "संख्या"
 #, fuzzy
-#~ msgstr "जी"
+msgstr "जी"
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgstr "के लिए"
+msgstr "के लिए"
 #, fuzzy
-#~ msgstr "त्रुटि नहीं सेट n"
+msgstr "त्रुटि नहीं सेट n"
 #, fuzzy
-#~ msgstr "त्रुटि के लिए"
+msgstr "त्रुटि के लिए"
 #, fuzzy
 #, fuzzy
-#~ msgstr "नहीं फील्ड"
+msgstr "नहीं फील्ड"
 #, fuzzy
-#~ msgstr "अवैध फील्ड"
+msgstr "अवैध फील्ड"
 #, fuzzy
-#~ msgstr "फील्ड i नहीं वर्तमान"
+msgstr "फील्ड i नहीं वर्तमान"
 #, fuzzy
-#~ msgid ""
-#~ msgstr "मी नहीं a बिन्दु."
+msgid ""
+msgstr "मी नहीं a बिन्दु."
 #, fuzzy
-#~ msgstr "नहीं n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgstr "का"
+msgstr "का"
 #, fuzzy
-#~ msgstr "जी n"
+msgstr "जी n"
+#, fuzzy
+#~ msgstr "n"
+#, fuzzy
+#~ msgid ""
+#~ "\n"
+#~ "**<%s> illegal name **\n"
+#~ msgstr "n n"
Modified: grass/trunk/locale/po/grasslibs_it.po
--- grass/trunk/locale/po/grasslibs_it.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_it.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -531,9 +531,9 @@
 msgstr "impossibile aprire il file con la tabella dell'ellissoide: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "impossibile aprire il file con la tabella dell'ellissoide: %s"
@@ -1275,12 +1275,12 @@
 #, fuzzy
-msgstr "Non riesco ad aprire il file temp"
+msgstr "Impossibile calcolare il centroide dell'area %d"
 #, fuzzy
@@ -2004,9 +2004,10 @@
 msgstr "Finestra sostituisce il predefinito"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"Bug: attesa di aggiornamento di una mappa non presente nel mapset in uso"
@@ -2068,7 +2069,8 @@
 #, fuzzy, c-format
-msgstr "Nessun file %s disponibile nel mapset in uso\n"
+msgstr ""
@@ -2273,7 +2275,7 @@
 #, fuzzy, c-format
-msgstr "impossibile trovare [%s] in [%s]"
+msgstr "impossibile trovare [%s]"
 #, fuzzy, c-format
@@ -2336,9 +2338,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3910,9 +3912,9 @@
 msgstr "Non riesco a trovare il vettore '%s' di input"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "[%s] nel mapset [%s] - zona [%d] diversa dalla regione in uso [%d]"
@@ -4281,7 +4283,7 @@
 #, fuzzy
-msgstr "Impossibile aprire %s"
+msgstr "Impossibile aprire il file %s in %s"
 #, fuzzy
@@ -4432,610 +4434,619 @@
 #, fuzzy
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgstr "Non posso scrivere i collegamenti del database"
 #, fuzzy
-#~ msgid "Unknown command: %d last: %d"
-#~ msgstr ""
-#~ "\n"
-#~ "Comando sconosciuto: %d ultimo: %d\n"
+msgid "Unknown command: %d last: %d"
+msgstr ""
+"\n"
+"Comando sconosciuto: %d ultimo: %d\n"
-#~ msgid "Monitor: get_command: Premature EOF"
+msgid "Monitor: get_command: Premature EOF"
-#~ msgid "Graphics driver [%s] started"
-#~ msgstr "Driver grafico [%s] avviato"
+msgid "Graphics driver [%s] started"
+msgstr "Driver grafico [%s] avviato"
-#~ msgstr "ERRORE %s dal driver grafico.\n"
+msgstr "ERRORE %s dal driver grafico.\n"
-#~ msgstr "ERRORE - eof del monitor grafico.\n"
+msgstr "ERRORE - eof del monitor grafico.\n"
-#~ msgstr "Attenzione - nessuna risposta dal monitor grafico <%s>.\n"
+msgstr "Attenzione - nessuna risposta dal monitor grafico <%s>.\n"
-#~ msgstr "Controlla se il mouse è ancora attivo.\n"
+msgstr "Controlla se il mouse è ancora attivo.\n"
-#~ msgstr "ERRORE: nessuna risposta dai monitor grafici <%s>.\n"
+msgstr "ERRORE: nessuna risposta dai monitor grafici <%s>.\n"
 #, fuzzy
-#~ msgstr "Non è stato selezionato nessun monitor grafico per l'output.\n"
+msgstr "Non è stato selezionato nessun monitor grafico per l'output.\n"
 #, fuzzy
-#~ msgstr "Per piacere avvia \"d.mon\" per selezionare un monitor grafico.\n"
+msgstr "Per piacere avvia \"d.mon\" per selezionare un monitor grafico.\n"
 #, fuzzy
-#~ msgstr "Fallimento nel dare un nome alla socket per il monitor <%s>.\n"
+msgstr "Fallimento nel dare un nome alla socket per il monitor <%s>.\n"
 #, fuzzy
-#~ msgstr "Nessuna socket per connettersi al monitor <%s>.\n"
+msgstr "Nessuna socket per connettersi al monitor <%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Socket già in uso o non in grado di accettare connessioni.\n"
-#~ "Usa d.mon per selezionare un monitor\n"
+msgstr ""
+"Socket già in uso o non in grado di accettare connessioni.\n"
+"Usa d.mon per selezionare un monitor\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr ""
-#~ "Tentativo di connessione a qualcosa che non è una socket.\n"
-#~ "Probabilmente un errore nel programma\n"
+msgstr ""
+"Tentativo di connessione a qualcosa che non è una socket.\n"
+"Probabilmente un errore nel programma\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Tempo di connessione scaduto. Probabilmente ci sono errore con il "
-#~ "server.\n"
+msgstr ""
+"Tempo di connessione scaduto. Probabilmente ci sono errore con il server.\n"
 #, fuzzy
-#~ msgstr "Connessione fallita.\n"
+msgstr "Connessione fallita.\n"
 #, fuzzy
-#~ msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
+msgstr "Non riesco a leggere l'istogramma per [%s in %s]"
 #, fuzzy
-#~ msgid "Unable to open file %s"
-#~ msgstr "Impossibile aprire il file %s in %s"
+msgid "Unable to open file %s"
 #, fuzzy
-#~ msgstr "Premi INVIO per annullare la richiesta\n"
+msgstr "Premi INVIO per annullare la richiesta\n"
-#~ msgstr "Non riesco ad aprire il file temp"
+msgstr "Non riesco ad aprire il file temp"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Per piacere specifica il nome dell'ellissoide\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Per piacere specifica il nome dell'ellissoide\n"
-#~ msgstr "Digita 'list' per la lista degli ellissoidi disponibili\n"
+msgstr "Digita 'list' per la lista degli ellissoidi disponibili\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ellissoide non valido\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"ellissoide non valido\n"
-#~ msgstr "Il nome '%s' in output non è un nome di raster valido."
+msgstr "Il nome '%s' in output non è un nome di raster valido."
-#~ msgstr "La mappa '%s' in output è utilizzata come input"
+msgstr "La mappa '%s' in output è utilizzata come input"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Per piacere specifica il nome del datum\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Per piacere specifica il nome del datum\n"
-#~ msgstr "Digita 'list' per la lista dei datum disponibili\n"
+msgstr "Digita 'list' per la lista dei datum disponibili\n"
-#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr "o 'custom' se desidera di inserire parametri personalizzati\n"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "o 'custom' se desidera di inserire parametri personalizzati\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum non valido\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum non valido\n"
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "premi INVIO per continuare -->"
+msgid "hit RETURN to continue -->"
+msgstr "premi INVIO per continuare -->"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "impossibile aprire un raster [%s in %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "impossibile aprire un raster [%s in %s]"
-#~ msgstr "Nessun aiuto disponibile per il comando [%s]\n"
+msgstr "Nessun aiuto disponibile per il comando [%s]\n"
-#~ msgstr " La mappa raster %s@%s è vuota"
+msgstr " La mappa raster %s@%s è vuota"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Tabella colori necessaria nel file [%s] per il mapset [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Tabella colori necessaria nel file [%s] per il mapset [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Per piacere specifica il tipo desiderato:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Per piacere specifica il tipo desiderato:\n"
-#~ msgstr "    1:  Colori casuali\n"
+msgstr "    1:  Colori casuali\n"
-#~ msgstr "    2:  Rampe colori di rosso, verde e blu\n"
+msgstr "    2:  Rampe colori di rosso, verde e blu\n"
-#~ msgstr "    3:  Colore onda\n"
+msgstr "    3:  Colore onda\n"
-#~ msgstr "    4:  Scala di grigi\n"
+msgstr "    4:  Scala di grigi\n"
-#~ msgstr "    5:  Aspetto\n"
+msgstr "    5:  Aspetto\n"
-#~ msgstr "    6:  colori dell'arcobaleno\n"
+msgstr "    6:  colori dell'arcobaleno\n"
-#~ msgstr "    7: Da rosso a giallo via verde\n"
+msgstr "    7: Da rosso a giallo via verde\n"
-#~ msgstr "    8:  Da verde a giallo via rosso\n"
+msgstr "    8:  Da verde a giallo via rosso\n"
-#~ msgstr "INVIO  esce\n"
+msgstr "INVIO  esce\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s non valid; Prova ancora > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s non valid; Prova ancora > "
-#~ msgstr "%s non trovato"
+msgstr "%s non trovato"
-#~ msgstr "ERRORE nella lettura %s"
+msgstr "ERRORE nella lettura %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Per piacere specifica il nome della proiezione\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Per piacere specifica il nome della proiezione\n"
-#~ msgstr "Digita 'list' per la lista delle proiezioni disponibili\n"
+msgstr "Digita 'list' per la lista delle proiezioni disponibili\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "proiezione non valida\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"proiezione non valida\n"
-#~ msgstr "con titoli"
+msgstr "con titoli"
-#~ msgstr "(nessun titolo)"
+msgid "(no title)"
+msgstr "(nessun titolo)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "FLAG: Assegnare il seguente flag?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"FLAG: Assegnare il seguente flag?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPZIONE:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPZIONE:   %s\n"
-#~ msgstr "     chiave: %s\n"
+msgid "     key: %s\n"
+msgstr "     chiave: %s\n"
-#~ msgstr " predefinito: %s\n"
+msgstr " predefinito: %s\n"
-#~ msgstr "richiesto: %s\n"
+msgstr "richiesto: %s\n"
-#~ msgstr "multiplo: %s\n"
+msgstr "multiplo: %s\n"
-#~ msgid "enter option > "
-#~ msgstr "inserisci opzione > "
+msgid "enter option > "
+msgstr "inserisci opzione > "
-#~ msgstr "   Provo ancora? "
+msgstr "   Provo ancora? "
-#~ msgstr "Spiacente, %s non è accettabile.\n"
+msgstr "Spiacente, %s non è accettabile.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Hai selezionato:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Hai selezionato:\n"
+"  %s\n"
-#~ msgstr "È corretto? "
+msgstr "È corretto? "
-#~ msgstr "per accettare i valori predefiniti"
+msgstr "per accettare i valori predefiniti"
-#~ msgstr "per annullare la richiesta"
+msgstr "per annullare la richiesta"
-#~ msgstr "Digita un nuovo nome di file %s "
+msgstr "Digita un nuovo nome di file %s "
-#~ msgstr "Digita il nome di un file %s esistente"
+msgstr "Digita il nome di un file %s esistente"
-#~ msgstr "Inserisci il nome del file %s"
+msgstr "Inserisci il nome del file %s"
-#~ msgstr "Digita 'list' per una lista dei %s file esistenti\n"
+msgstr "Digita 'list' per una lista dei %s file esistenti\n"
-#~ msgstr "Digita 'list -f' per "
+msgstr "Digita 'list -f' per "
+msgid "a list %s"
-#~ msgstr "una lista estesa"
+msgstr "una lista estesa"
-#~ msgstr "Premi INVIO %s\n"
+msgstr "Premi INVIO %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - non trovato **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - non trovato **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s esiste già. Procedo alla sovrascrittura? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s esiste già. Procedo alla sovrascrittura? "
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> nome illegale **\n"
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+"\n"
+"**<%s> nome illegale **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - richiesta illegale **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - richiesta illegale **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - esiste, selezionare un altro nome **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - esiste, selezionare un altro nome **\n"
-#~ msgstr "ask.c: non deve succedere"
+msgstr "ask.c: non deve succedere"
-#~ msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
+msgstr "Non riesco a leggere il file di intestazione per [%s in %s]\n"
-#~ msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
+msgstr "Non riesco ad aprire il file di intestazione per [%s in %s]"
 #, fuzzy
-#~ msgstr "Non posso cancellare la linea"
+msgstr "Non posso cancellare la linea"
 #, fuzzy
-#~ msgstr "Creazione topologia...\n"
+msgstr "Creazione topologia...\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d aree create      \n"
-#~ "%d isole create\n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d aree create      \n"
+"%d isole create\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
+msgstr "Vect_rewrite_line() non supportato per questo formato/livello"
-#~ msgstr "Vect_delete_line() non supportato per questo formato/livello"
+msgstr "Vect_delete_line() non supportato per questo formato/livello"
-#~ msgstr "Non riesco a riscrivere la linea"
+msgstr "Non riesco a riscrivere la linea"
-#~ msgstr "Il nome '%s' in output non è valido per un vettore."
+msgstr "Il nome '%s' in output non è valido per un vettore."
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Non posso copiare il vettore '%s' nel '%s'"
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Non posso copiare il vettore '%s' nel '%s'"
 #, fuzzy
-#~ msgstr "Non posso cancellare il vettoriale %s"
+msgstr "Non posso cancellare il vettoriale %s"
 #, fuzzy
-#~ msgstr "Non posso aprire il nuovo vettoriale %s"
+msgstr "Non posso aprire il nuovo vettoriale %s"
-#~ msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
+msgstr "Non riesco ad aprire lo storico per il vettoriale '%s'"
-#~ msgstr "Non riesco a trovare il file \"%s\""
+msgstr "Non riesco a trovare il file \"%s\""
 #, fuzzy
-#~ msgstr "Non riesco ad aprire il vecchio vettoriale %s"
+msgstr "Non riesco ad aprire il vecchio vettoriale %s"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** nome illegale **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** nome illegale **"
-#~ msgstr "Non trovo un monitor grafico per <%s>.\n"
+msgstr "Non trovo un monitor grafico per <%s>.\n"
-#~ msgstr ""
-#~ "Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
+msgstr ""
+"Per piacere avvia \"d.mon\" per selezionare un monitor grafico valido.\n"
 #, fuzzy
-#~ msgstr "Non è possibile trovare %s\n"
+msgstr "Non è possibile trovare %s\n"
-#~ msgstr "Errore - Monitor <%s> in uso.\n"
+msgstr "Errore - Monitor <%s> in uso.\n"
-#~ msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
+msgstr "Errore - il Monitor <%s> è in uso da %s.\n"
-#~ msgstr ""
-#~ "Errore - non riesco a completare il blocco del processo per il monitor <%"
-#~ "s>.\n"
+msgstr ""
+"Errore - non riesco a completare il blocco del processo per il monitor <%"
+"s>.\n"
-#~ msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
+msgstr "Errore - non riesco a creare una pipe al dispositivo grafico.\n"
-#~ msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
+msgstr "Errore -il monitor grafico <%s> non è stato avviato!\n"
-#~ msgstr "Per piacere avvia il monitor grafico <%s>.\n"
+msgstr "Per piacere avvia il monitor grafico <%s>.\n"
-#~ msgstr "Non connesso...\n"
+msgstr "Non connesso...\n"
-#~ msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
+msgstr "Non riesco a collegarmi al monitor. Provo a farlo ancora.\n"
 #, fuzzy
-#~ msgstr "Dimensione della cella delle mappe in fp = %d\n"
+msgstr "Dimensione della cella delle mappe in fp = %d\n"
 #, fuzzy
-#~ msgstr "per mappe raster presenti %d\n"
+msgstr "per mappe raster presenti %d\n"
 #, fuzzy
-#~ msgstr "finestra corrente = %p\n"
+msgstr "finestra corrente = %p\n"
 #, fuzzy
-#~ msgstr "Flag: finestra scelta? %d\n"
+msgstr "Flag: finestra scelta? %d\n"
 #, fuzzy
-#~ msgstr "Descrizione del file per la maschera automatica %d\n"
+msgstr "Descrizione del file per la maschera automatica %d\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "CELL maschera del buffer %p\n"
+msgstr "CELL maschera del buffer %p\n"
-#~ msgstr "buffer di lettura delle righe vuote %p"
+msgstr "buffer di lettura delle righe vuote %p"
-#~ msgstr "Buffer di dati pre/post compressi %p"
+msgstr "Buffer di dati pre/post compressi %p"
-#~ msgstr "dimensione del compressed_buf %d"
+msgstr "dimensione del compressed_buf %d"
-#~ msgstr "work data buffer %p"
+msgstr "work data buffer %p"
-#~ msgstr "dimensione del work_buf %d"
+msgstr "dimensione del work_buf %d"
-#~ msgstr "dimensione null_buf %d"
+msgstr "dimensione null_buf %d"
-#~ msgstr "dimensione mask_buf %d"
+msgstr "dimensione mask_buf %d"
-#~ msgstr "Istogramma richiesto %d"
+msgstr "Istogramma richiesto %d"
-#~ msgstr "G_dump: file #%d"
+msgstr "G_dump: file #%d"
-#~ msgstr "modalità di apertura = %d"
+msgstr "modalità di apertura = %d"
-#~ msgstr "Intestazione cella %p"
+msgstr "Intestazione cella %p"
 #, fuzzy
-#~ msgstr "Tabella di riclassificazione %p\n"
+msgstr "Tabella di riclassificazione %p\n"
 #, fuzzy
-#~ msgstr "Intestazione cella %p\n"
+msgstr "Intestazione cella %p\n"
 #, fuzzy
-#~ msgstr "Struttura intervallo %p\n"
+msgstr "Struttura intervallo %p\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "vuoi un istogramma?  %d\n"
+msgstr "vuoi un istogramma?  %d\n"
 #, fuzzy
-#~ msgstr "nbyte per cella nella riga corrente %d\n"
+msgstr "nbyte per cella nella riga corrente %d\n"
 #, fuzzy
-#~ msgstr "Buffer di dati decompresso %s\n"
+msgstr "Buffer di dati decompresso %s\n"
 #, fuzzy
-#~ msgstr "byte per cella %d\n"
+msgstr "byte per cella %d\n"
 #, fuzzy
-#~ msgstr "tipi: mappa int, float o double %d\n"
+msgstr "tipi: mappa int, float o double %d\n"
 #, fuzzy
-#~ msgstr "Nome temporaneo per NUOVI file %s\n"
+msgstr "Nome temporaneo per NUOVI file %s\n"
 #, fuzzy
-#~ msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
+msgstr "Nome temporaneo per NUOVI file VUOTI %s\n"
 #, fuzzy
-#~ msgstr "Mapset del file d'aprire%s\n"
+msgstr "Mapset del file d'aprire%s\n"
 #, fuzzy
-#~ msgstr "attenzione ho ricevuto un errore di i/o %d\n"
+msgstr "attenzione ho ricevuto un errore di i/o %d\n"
 #, fuzzy
-#~ msgstr "NULL_ROWS array[%d] = %p\n"
+msgstr "NULL_ROWS array[%d] = %p\n"
 #, fuzzy
-#~ msgstr "buffer di lettura delle righe vuote %p\n"
+msgstr "buffer di lettura delle righe vuote %p\n"
 #, fuzzy
-#~ msgstr "G_dump: file #%d\n"
+msgstr "G_dump: file #%d\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "LOCATION  << %s >>  non disponibile"
+msgstr "LOCATION  << %s >>  non disponibile"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Troppi file raster aperti"
+msgstr "Troppi file raster aperti"
-#~ msgstr "Troppi file aperti"
+msgstr "Troppi file aperti"
-#~ msgstr "ERRORE: GISBASE non definito\n"
+msgstr "ERRORE: GISBASE non definito\n"
+#~ msgstr "Impossibile allocare memoria\n"
+#, fuzzy
+#~ msgstr "<%s> nel mapset <%s>"
+#~ msgstr "impossibile trovare [%s] in [%s]"
Modified: grass/trunk/locale/po/grasslibs_ja.po
--- grass/trunk/locale/po/grasslibs_ja.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_ja.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -511,9 +511,9 @@
 msgstr "���"
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
+msgstr "���"
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1991,9 +1991,9 @@
 msgstr ""
 #: ../lib/g3d/g3dopen.c:229
-#, c-format
+#, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr ""
+msgstr "���"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2250,9 +2250,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
+msgstr "���"
 #: ../lib/gis/quant_io.c:89
 #, fuzzy, c-format
@@ -4309,161 +4309,165 @@
 msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "��� %s ������ ����.\n"
+msgstr "��� %s ������ ����.\n"
 #, fuzzy
-#~ msgstr "��� - eof from graphics monitor.\n"
+msgstr "��� - eof from graphics monitor.\n"
 #, fuzzy
-#~ msgstr "������� - ����������<%s> � ����.\n"
+msgstr "������� - ����������<%s> � ����.\n"
 #, fuzzy
-#~ msgstr "����� ���� � ��.\n"
+msgstr "����� ���� � ��.\n"
 #, fuzzy
-#~ msgstr "��� - ����������<%s> � ����.\n"
+msgstr "��� - ����������<%s> � ����.\n"
 #, fuzzy
-#~ msgstr "� ��� ���������������.\n"
+msgstr "� ��� ���������������.\n"
 #, fuzzy
-#~ msgstr "�����\"d.mon\" ����� ������ ����\n"
+msgstr "�����\"d.mon\" ����� ������ ����\n"
 #, fuzzy
-#~ msgstr "����� ���� ���������<%s>.\n"
+msgstr "����� ���� ���������<%s>.\n"
 #, fuzzy
-#~ msgstr "����� ������������������<%s>.\n"
+msgstr "����� ������������������<%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "����������� ��� ������������.\n"
-#~ "�����d.mon ����� ����n"
+msgstr ""
+"����������� ��� ������������.\n"
+"�����d.mon ����� ����n"
 #, fuzzy
 #, fuzzy
-#~ msgstr ""
-#~ "��������� � ������\n"
-#~ "���� ��� �����\n"
+msgstr ""
+"��������� � ������\n"
+"���� ��� �����\n"
 #, fuzzy
-#~ msgstr "��������������� ������ ���� ��� ����\n"
+msgstr "��������������� ������ ���� ��� ����\n"
 #, fuzzy
-#~ msgstr "��������n"
+msgstr "��������n"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "���."
+msgid "Output name '%s' is not valid rast name."
+msgstr "���."
 #, fuzzy
-#~ msgstr "��"
+msgstr "��"
 #, fuzzy
-#~ msgstr "傾斜方位またはdy値を出力するファイル"
+msgstr "傾斜方位またはdy値を出力するファイル"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���."
+msgstr "���."
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "���"
+msgstr "���"
 #, fuzzy
-#~ msgstr "����������<%s> � �����.\n"
+msgstr "����������<%s> � �����.\n"
 #, fuzzy
-#~ msgstr "�����\"d.mon\" ����� �����������\n"
+msgstr "�����\"d.mon\" ����� �����������\n"
 #, fuzzy
-#~ msgstr "��� - ����<%s> ���\n"
+msgstr "��� - ����<%s> ���\n"
 #, fuzzy
-#~ msgstr "��� - � �� ����������(lock) ������<%s>.\n"
+msgstr "��� - � �� ����������(lock) ������<%s>.\n"
 #, fuzzy
-#~ msgstr "��� - ����� (pipe) ������� �����.\n"
+msgstr "��� - ����� (pipe) ������� �����.\n"
 #, fuzzy
-#~ msgstr "��� - ����������<%s> � ����\n"
+msgstr "��� - ����������<%s> � ����\n"
 #, fuzzy
-#~ msgstr "���� ����������<%s>.\n"
+msgstr "���� ����������<%s>.\n"
 #, fuzzy
-#~ msgstr "�������...\n"
+msgstr "�������...\n"
 #, fuzzy
-#~ msgstr "����� ����� ���� ���� ����\n"
+msgstr "����� ����� ���� ���� ����\n"
 #, fuzzy
-#~ msgstr "���: GISBASE � �����\n"
+msgstr "���: GISBASE � �����\n"
+#, fuzzy
+#~ msgstr "����� ���� ���\n"
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_ko.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -510,9 +510,9 @@
 msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
@@ -753,9 +753,8 @@
 msgstr ""
 #: ../lib/vector/vedit/select.c:235
-#, fuzzy
 msgid "Unknown query tool"
-msgstr "알려지지 않은 벡터타입입니다"
+msgstr ""
 #: ../lib/vector/vedit/cats.c:66
 #, fuzzy, c-format
@@ -1524,9 +1523,8 @@
 msgstr "임시파일을 열 수 없습니다"
 #: ../lib/vector/Vlib/overlay.c:74
-#, fuzzy
 msgid "unknown operator"
+msgstr ""
 #: ../lib/vector/Vlib/overlay.c:123
 msgid "Overlay: line/boundary types not supported by AND operator"
@@ -1991,9 +1989,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "'%s' 디버그파일을 열 수 없습니다"
@@ -2252,9 +2250,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3539,9 +3537,9 @@
 #: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
-#, fuzzy, c-format
+#, c-format
 msgid "3D raster map <%s> not found"
-msgstr "마스트 래스터맵 <%s>를 찾을 수 없습니다"
+msgstr ""
 #: ../lib/ogsf/gsd_img_mpeg.c:63
 #, fuzzy
@@ -3703,9 +3701,8 @@
 msgstr ""
 #: ../lib/ogsf/gs_bm.c:124
-#, fuzzy
 msgid "Bitmap mismatch"
-msgstr "비트맵 마스크를 생성했습니다"
+msgstr ""
 #: ../lib/ogsf/gvl_file.c:104
 msgid "Maximum number of datafiles exceeded"
@@ -3841,7 +3838,7 @@
 #: ../lib/gmath/la.c:602
 msgid "Problem in LA procedure."
-msgstr "LA 루틴에 문제가 있습니다"
+msgstr ""
 #: ../lib/gmath/la.c:690
 msgid "Element array has not been allocated"
@@ -3874,71 +3871,71 @@
 #: ../lib/gmath/la.c:835
 msgid "Specified column index is outside range"
-msgstr "지정한 컬럼이 범위를 벗어났습니다"
+msgstr ""
 #: ../lib/gmath/la.c:855
 msgid "Unknown vector type."
+msgstr ""
 #: ../lib/gmath/la.c:980
 msgid "Output vector is uninitialized"
-msgstr "출력벡터가 초기화되지 않았습니다"
+msgstr ""
 #: ../lib/gmath/la.c:985
 msgid "Vectors are not of the same type"
-msgstr "벡터의 타입이 서로 다릅니다"
+msgstr ""
 #: ../lib/gmath/la.c:990
 msgid "Output vector is of incorrect type"
-msgstr "출력벡터의 타입이 틀렸습니다"
+msgstr ""
 #: ../lib/gmath/la.c:995
 msgid "Matrices not allowed"
-msgstr "메트릭스 타입은 허용되지 않습니다"
+msgstr ""
 #: ../lib/gmath/la.c:1001
 msgid "Vectors have differing dimensions"
-msgstr "벡터의 차원이 서로 다릅니다"
+msgstr ""
 #: ../lib/gmath/la.c:1007
 msgid "Output vector has incorrect dimension"
-msgstr "출력벡터의 차원이 틀렸습니다"
+msgstr ""
 #: ../lib/gmath/la.c:1053
 msgid "Vector dimensions out of range"
-msgstr "벡터의 차원이 범위를 벗어났습니다"
+msgstr ""
 #: ../lib/gmath/la.c:1058
 msgid "Row/column out of range"
-msgstr "행/열이 범위를 벗어났습니다"
+msgstr ""
 #: ../lib/gmath/la.c:1273
 msgid "Vector structure is not initialised"
-msgstr "벡터 구조체가 초기화되지 않았습니다"
+msgstr ""
 #: ../lib/gmath/la.c:1394 ../lib/gmath/la.c:1402 ../lib/gmath/la.c:1407
 msgid "Input format error"
-msgstr "입력양식 오류"
+msgstr ""
 #: ../lib/gmath/del2g.c:50
 msgid "    taking FFT of image..."
-msgstr "    이미지의 FFT를 구하는 중..."
+msgstr ""
 #: ../lib/gmath/del2g.c:56
 msgid "    computing del**2 g..."
-msgstr "    del**2 g를 계산 중..."
+msgstr ""
 #: ../lib/gmath/del2g.c:59
 msgid "    taking FFT of del**2 g..."
-msgstr "    del**2 g의 FFT를 구하는 중..."
+msgstr ""
 #: ../lib/gmath/del2g.c:63
 msgid "    multiplying transforms..."
-msgstr "    변환을 곱하는 중..."
+msgstr ""
 #: ../lib/gmath/del2g.c:66
 msgid "    taking inverse FFT..."
-msgstr "    역FFT를 구하는 중..."
+msgstr ""
 #: ../lib/display/draw2.c:1109
 msgid "D_move_abs() called while path not active"
@@ -3963,7 +3960,7 @@
 #: ../lib/display/tran_colr.c:105 ../lib/display/tran_colr.c:107
 #, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: 없는 색상입니다"
+msgstr ""
 #: ../lib/symbol/read.c:206
 #, c-format
@@ -4075,16 +4072,16 @@
 #: ../lib/rst/interp_float/vinput2d.c:397
 msgid "some points outside of region -- will ignore..."
-msgstr "영역밖의 일부 점들은 무시합니다..."
+msgstr ""
 #: ../lib/rst/interp_float/input2d.c:47
 #, c-format
 msgid "Mask raster map <%s> not found"
+msgstr ""
 #: ../lib/rst/interp_float/input2d.c:69
 msgid "Bitmap mask created"
+msgstr ""
 #: ../lib/cairodriver/Raster.c:68
 msgid "Cairo_begin_scaled_raster: Failed to create surface"
@@ -4259,109 +4256,120 @@
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "'%s' 디버그파일을 열 수 없습니다"
+msgid "Cannot describe table <%s>"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "임시파일을 열 수 없습니다"
+msgid "Cannot read topo for line [%d]"
+msgstr "임시파일을 열 수 없습니다"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "취소를 원하시면 RETURN을 누르세요\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "취소를 원하시면 RETURN을 누르세요\n"
-#~ msgid "Cannot open temp file"
+msgid "Cannot open temp file"
-#~ msgstr "제목과 함께"
+msgstr "제목과 함께"
-#~ msgstr "(제목없음)"
+msgid "(no title)"
+msgstr "(제목없음)"
-#~ msgstr "취소를 원하시면"
+msgstr "취소를 원하시면"
-#~ msgstr "새로운 %s 파일명을 입력하세요"
+msgstr "새로운 %s 파일명을 입력하세요"
-#~ msgstr "%s 파일명을 입력하세요"
+msgstr "%s 파일명을 입력하세요"
-#~ msgstr "%s 파일의 열람을 위해서는 'list'를 입력하세요\n"
+msgstr "%s 파일의 열람을 위해서는 'list'를 입력하세요\n"
-#~ msgstr "을(를) 위해서는 'list -f'를 입력하세요"
+msgstr "을(를) 위해서는 'list -f'를 입력하세요"
-#~ msgstr "%s 리스트"
+msgid "a list %s"
+msgstr "%s 리스트"
-#~ msgstr "확장리스트"
+msgstr "확장리스트"
-#~ msgstr "%s RETURN을 누르세요\n"
+msgstr "%s RETURN을 누르세요\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 찾지 못함 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 찾지 못함 **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s을(를) 덮어쓸까요? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s을(를) 덮어쓸까요? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 잘못된 요청 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 잘못된 요청 **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 이미 존재합니다. 다른 이름을 선택하세요 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 이미 존재합니다. 다른 이름을 선택하세요 **\n"
-#~ msgstr "ask: 내부오류"
+msgstr "ask: 내부오류"
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "가우시안 할당을 위한 메모리가 부족합니다"
+msgid "Insufficent memory for allocation of gaussian"
+msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "G_dump: G__에 메모리가 할당되었습니다"
+msgstr "G_dump: G__에 메모리가 할당되었습니다"
 #, fuzzy
+#, fuzzy
+#~ msgid "Unable to open temporary file"
 #~ msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#~ msgid ""
+#~ "\n"
+#~ msgstr ""
+#~ "\n"
+#~ "**<%s> 잘못된 이름 **\n"
Modified: grass/trunk/locale/po/grasslibs_lv.po
--- grass/trunk/locale/po/grasslibs_lv.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_lv.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -527,9 +527,9 @@
 msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "neiespējami atvērt elipsoīda tabulas failu: %s"
@@ -1266,12 +1266,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "Nevar atvērt 'temp'/pagaidu failu"
+msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -1992,9 +1992,9 @@
 msgstr "Logs aizvieto noklusēto"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
+msgstr "Defekts: atteikts papildināt karti,kura nav tekošajā karšu komplektā."
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2055,7 +2055,7 @@
 #, fuzzy, c-format
-msgstr "nav %s faili pieejami pašreizējā karšu biblotēkā\n"
@@ -2255,7 +2255,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "neiespējami atrast [%s] iekš [%s]"
+msgstr "neiespējami atrast [%s]"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2318,9 +2318,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3880,9 +3880,9 @@
 msgstr "Ieejas vektors '%s' nav atrasts"
 #: ../lib/ogsf/GS2.c:1638
-#, c-format
+#, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
@@ -4251,7 +4251,7 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
-msgstr "Neisespējami atvērt %s"
+msgstr "Neiespējami atvērt failu %s iekš %s"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
@@ -4402,637 +4402,647 @@
 #, fuzzy
-#~ msgstr "Nevar atvērt datubāzi %s"
+msgstr "Nevar atvērt datubāzi %s"
-#~ msgstr "KĻŪDA %s no grafiskā draivera.\n"
+msgstr "KĻŪDA %s no grafiskā draivera.\n"
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#~ msgstr "KĻŪDA - eof no grafiskā monitora.\n"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "KĻŪDA - eof no grafiskā monitora.\n"
-#~ msgstr "Brīdinājums - nav atbildes reakcijas no grafiskā monitora <%s>.\n"
+msgstr "Brīdinājums - nav atbildes reakcijas no grafiskā monitora <%s>.\n"
-#~ msgstr "Pārbīdi lai redzētu vai pele vēl ir aktīva.\n"
+msgstr "Pārbīdi lai redzētu vai pele vēl ir aktīva.\n"
-#~ msgstr "KĻŪDA - nav atbildes no grafiskā monitora <%s>\n"
+msgstr "KĻŪDA - nav atbildes no grafiskā monitora <%s>\n"
 #, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "Datu atspoguļošanai netika izvēlēts monitors.\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "Datu atspoguļošanai netika izvēlēts monitors.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "Lūdzu palaid \"d.mon\" lai izvēlētos grafisko monitoru.\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Lūdzu palaid \"d.mon\" lai izvēlētos grafisko monitoru.\n"
 #, fuzzy
-#~ msgstr "Izgāšanās lai iegūtu pieslēguma vietas nosaukumu monitoram <%s>.\n"
+msgstr "Izgāšanās lai iegūtu pieslēguma vietas nosaukumu monitoram <%s>.\n"
 #, fuzzy
-#~ msgstr "Nav pieslēguma vietas lai pieslēgtos monitoram <%s>.\n"
+msgstr "Nav pieslēguma vietas lai pieslēgtos monitoram <%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Kontaktligzda jau tiek lietota vai noraida pieslēgumus.\n"
-#~ "Lieto d.mon lai izvēlētos monitoru\n"
+msgstr ""
+"Kontaktligzda jau tiek lietota vai noraida pieslēgumus.\n"
+"Lieto d.mon lai izvēlētos monitoru\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Meiģinājums pieslēgties kautkam kas nav piesēglma iespējas.\n"
-#~ "Iespējams programmas kļūda.\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"Meiģinājums pieslēgties kautkam kas nav piesēglma iespējas.\n"
+"Iespējams programmas kļūda.\n"
 #, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr "Pieslēgšanās mieģinājuma laika beigas. Iespējama servera kļūda.\n"
+msgid "Probably an error with the server."
+msgstr "Pieslēgšanās mieģinājuma laika beigas. Iespējama servera kļūda.\n"
 #, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "Pieslēgšanās izgāzusies\n"
+msgid "Connection failed."
+msgstr "Pieslēgšanās izgāzusies\n"
 #, fuzzy
-#~ msgstr "Nevar nolasīt histogrammu priekš [%s no %s]"
 #, fuzzy
-#~ msgstr "Neiespējami atvērt failu %s iekš %s"
 #, fuzzy
-#~ msgid "Unable to open temporary file"
+msgid "Unable to open temporary file"
-#~ msgstr "Ievadi RETURN lai  apturētu pieprasījumu\n"
+msgstr "Ievadi RETURN lai  apturētu pieprasījumu\n"
-#~ msgstr "Nevar atvērt 'temp'/pagaidu failu"
+msgstr "Nevar atvērt 'temp'/pagaidu failu"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Lūdzu norādi elipsoīda nosaukumu\n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"Lūdzu norādi elipsoīda nosaukumu\n"
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "Ievadi 'list' lai iegūtu pieejamo elipsoīdu sarakstu\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "Ievadi 'list' lai iegūtu pieejamo elipsoīdu sarakstu\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
-#~ "nederīgs elipsoīds\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"nederīgs elipsoīds\n"
-#~ msgstr "Izejas vārds '%s' nav derīgs rastra nosaukums."
+msgstr "Izejas vārds '%s' nav derīgs rastra nosaukums."
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "Izejas karte '%s' tiek lietota kā iejas karte"
+msgid "Output map '%s' is used as input"
+msgstr "Izejas karte '%s' tiek lietota kā iejas karte"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Lūdzu norādi datuma nosaukumu\n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
+"Lūdzu norādi datuma nosaukumu\n"
-#~ msgid "Enter 'list' for the list of available datums\n"
-#~ msgstr "Ievadi 'list' lai redzētu pieejamos \"datums\"\n"
+msgid "Enter 'list' for the list of available datums\n"
+msgstr "Ievadi 'list' lai redzētu pieejamos \"datums\"\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
-#~ "nederīgs datums\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"nederīgs datums\n"
-#~ msgstr "spied ENTER lai turpinātu -->"
+msgstr "spied ENTER lai turpinātu -->"
-#~ msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
+msgstr "neiespējami atvērt rastra karti [%s iekš %s]"
-#~ msgstr "vienu mirkli...\n"
+msgstr "vienu mirkli...\n"
-#~ msgstr "Nav pieejama palīdzība komandai [%s]\n"
+msgstr "Nav pieejama palīdzība komandai [%s]\n"
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr " Rastra karte %s@%s ir tukša"
+msgid " The raster map %s@%s is empty"
+msgstr " Rastra karte %s@%s ir tukša"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Krāsu tabuli ir nepieciešams fails [%s] karšu biblotēkā [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Krāsu tabuli ir nepieciešams fails [%s] karšu biblotēkā [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Lūdzu identificē izvēlēto tipu:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Lūdzu identificē izvēlēto tipu:\n"
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "    1:  Brīvas izvēlas krāsas\n"
+msgid "    1:  Random colors\n"
+msgstr "    1:  Brīvas izvēlas krāsas\n"
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "    2:  Sarkanas,zaļas un zilas krāsas\n"
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr "    2:  Sarkanas,zaļas un zilas krāsas\n"
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "    3:  Krāsu viļni\n"
+msgid "    3:  Color wave\n"
+msgstr "    3:  Krāsu viļni\n"
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "    4:  Plēkas krāsas\n"
+msgid "    4:  Gray scale\n"
+msgstr "    4:  Plēkas krāsas\n"
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "    5:  Ekspozīcija \n"
+msgid "    5:  Aspect\n"
+msgstr "    5:  Ekspozīcija \n"
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "    6:  Varavīksnes krāsas\n"
+msgid "    6:  Rainbow colors\n"
+msgstr "    6:  Varavīksnes krāsas\n"
-#~ msgstr "    7:  Sarkanais caur dzelteno uz zaļo\n"
+msgstr "    7:  Sarkanais caur dzelteno uz zaļo\n"
-#~ msgstr "    8:  Zaļais caur dzelteno uz sarkano\n"
+msgstr "    8:  Zaļais caur dzelteno uz sarkano\n"
-#~ msgid "RETURN  quit\n"
-#~ msgstr "ATGRIEZT pamest\n"
+msgid "RETURN  quit\n"
+msgstr "ATGRIEZT pamest\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s nederīgs; Meiģini vēlreiz > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s nederīgs; Meiģini vēlreiz > "
-#~ msgid "%s not found"
-#~ msgstr "%s nav atrasts"
+msgid "%s not found"
+msgstr "%s nav atrasts"
-#~ msgstr "KĻŪDA nolasot %s"
+msgstr "KĻŪDA nolasot %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Lūdzu norādi projekta nosaukumu\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Lūdzu norādi projekta nosaukumu\n"
-#~ msgstr "Ievadi 'list', lai iegūtu pieejamo projekciju sarakstu\n"
+msgstr "Ievadi 'list', lai iegūtu pieejamo projekciju sarakstu\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "nederīga projekcija\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"nederīga projekcija\n"
-#~ msgid "with titles"
-#~ msgstr "ar virsrakstiem"
+msgid "with titles"
+msgstr "ar virsrakstiem"
-#~ msgid "(no title)"
-#~ msgstr "(nav virsraksta)"
+msgid "(no title)"
+msgstr "(nav virsraksta)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "KAROGS: Likt sekojošo pazīmi/karogu?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"KAROGS: Likt sekojošo pazīmi/karogu?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPCIJA/PAZĪME:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPCIJA/PAZĪME:   %s\n"
-#~ msgid "     key: %s\n"
-#~ msgstr "     atslēga: %s\n"
+msgid "     key: %s\n"
+msgstr "     atslēga: %s\n"
-#~ msgstr "  formāts: %s\n"
+msgstr "  formāts: %s\n"
-#~ msgstr " noklusēts: %s\n"
+msgstr " noklusēts: %s\n"
-#~ msgstr "prasītais: %s\n"
+msgstr "prasītais: %s\n"
-#~ msgstr "daudzskaitlīgs: %s\n"
+msgstr "daudzskaitlīgs: %s\n"
-#~ msgstr "ievadi opciju/pazīmi > "
+msgstr "ievadi opciju/pazīmi > "
-#~ msgstr "   Meiģini vēl? "
+msgstr "   Meiģini vēl? "
-#~ msgstr "Atvainojiet, %s nav akceptēts.\n"
+msgstr "Atvainojiet, %s nav akceptēts.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Tu esi izvēlējies:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Tu esi izvēlējies:\n"
+"  %s\n"
-#~ msgid "Is this correct? "
-#~ msgstr "Vai tas ir pareizi?"
+msgid "Is this correct? "
+msgstr "Vai tas ir pareizi?"
-#~ msgid "to accept the default"
-#~ msgstr "lai apstiprinātu noklusēto"
+msgid "to accept the default"
+msgstr "lai apstiprinātu noklusēto"
-#~ msgid "to cancel request"
-#~ msgstr "lai apturētu pieprasījumu"
+msgid "to cancel request"
+msgstr "lai apturētu pieprasījumu"
-#~ msgid "Enter a new %s file name"
-#~ msgstr "Ievadi juanu %s faila nosaukumu"
+msgid "Enter a new %s file name"
+msgstr "Ievadi juanu %s faila nosaukumu"
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr "Ievadi eksistējoša %s faila nosaukumu"
+msgid "Enter the name of an existing %s file"
+msgstr "Ievadi eksistējoša %s faila nosaukumu"
-#~ msgid "Enter %s file name"
-#~ msgstr "Ievadi %s faila nosaukumu"
+msgid "Enter %s file name"
+msgstr "Ievadi %s faila nosaukumu"
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "Ievadi 'list' lai redzētu esošo %s failu sarakstu\n"
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr "Ievadi 'list' lai redzētu esošo %s failu sarakstu\n"
-#~ msgid "Enter 'list -f' for "
-#~ msgstr "Ievadi 'list -f' lai "
+msgid "Enter 'list -f' for "
+msgstr "Ievadi 'list -f' lai "
-#~ msgid "a list %s"
-#~ msgstr "saraksts %s"
+msgid "a list %s"
+msgstr "saraksts %s"
-#~ msgid "an extended list"
-#~ msgstr "izvērsts saraksts"
+msgid "an extended list"
+msgstr "izvērsts saraksts"
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "Ievadi RETURN %s\n"
+msgid "Hit RETURN %s\n"
+msgstr "Ievadi RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - nav atrasts **\n"
+msgid ""
+"\n"
+"** %s - not found **\n"
+msgstr ""
+"\n"
+"** %s - nav atrasts **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s eksistē. ok, lai pārrakstītu? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s eksistē. ok, lai pārrakstītu? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> neatļauts nosaukums **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> neatļauts nosaukums **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - neatļauts pieprasījums **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - neatļauts pieprasījums **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - eksistē, izvēlies citu nosaukumu **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - eksistē, izvēlies citu nosaukumu **\n"
-#~ msgid "ask: can't happen"
-#~ msgstr "jautājums: nevar notikt"
+msgid "ask: can't happen"
+msgstr "jautājums: nevar notikt"
 #, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "Nevar iegūt slāņa informāciju"
+msgid "Cannot get field info"
+msgstr "Nevar iegūt slāņa informāciju"
 #, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
-#~ msgid "Building topology ...\n"
-#~ msgstr "Veidojam topoloģiju... \n"
+msgid "Building topology ...\n"
+msgstr "Veidojam topoloģiju... \n"
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d  laukumi izveidoti      \n"
-#~ "%d salas izveidotas\n"
+msgid ""
+"\r%d areas built      \n"
+"%d isles built\n"
+msgstr ""
+"\r%d  laukumi izveidoti      \n"
+"%d salas izveidotas\n"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
+msgid "Cannot open database <%s> by driver <%s>"
 #, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
-#~ msgstr "Vect_rewrite_line() šimformātam/līmenim nav atbalstīta"
+msgstr "Vect_rewrite_line() šimformātam/līmenim nav atbalstīta"
-#~ msgstr "Vect_delete_line() šim formātam/līmenim nav atbalstīta"
+msgstr "Vect_delete_line() šim formātam/līmenim nav atbalstīta"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "Nevar pārrakstīt līniju"
+msgid "Cannot rewrite line"
+msgstr "Nevar pārrakstīt līniju"
-#~ msgid "Cannot delete line"
-#~ msgstr "Nevar dzēst līniju"
+msgid "Cannot delete line"
+msgstr "Nevar dzēst līniju"
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Izejas vārds '%s' nav derīgs vektora nosaukums."
+msgid "Output name '%s' is not valid vector name."
+msgstr "Izejas vārds '%s' nav derīgs vektora nosaukums."
-#~ msgstr "Nevar kopēt vektoru '%s' uz '%s'"
+msgstr "Nevar kopēt vektoru '%s' uz '%s'"
 #, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Nevar izdzēst eksistējošu vektoru %s "
+msgid "Cannot open existing vector map <%s>"
+msgstr "Nevar izdzēst eksistējošu vektoru %s "
 #, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Nevar atvērt jaunu vektoru %s"
+msgid "Cannot open new vector %s"
+msgstr "Nevar atvērt jaunu vektoru %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Nevar atvērt vēsturi vektoram '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "Nevar atvērt vēsturi vektoram '%s'"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "Nevar palaist failu '%s'"
+msgid "Could not stat file '%s'"
+msgstr "Nevar palaist failu '%s'"
 #, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Nevar atvērt veco vektoru %s"
+msgid "Can't open directory %s"
+msgstr "Nevar atvērt veco vektoru %s"
-#~ msgstr "Nav tāds grafiskais monitors kā <%s>.\n"
+msgstr "Nav tāds grafiskais monitors kā <%s>.\n"
-#~ msgstr "Lūdzu palaid \"d.mon\" lai izvēlētos derīgu grafisko monitoru.\n"
+msgstr "Lūdzu palaid \"d.mon\" lai izvēlētos derīgu grafisko monitoru.\n"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Nevar uzsākt %s\n"
+msgid "Can't stat %s\n"
+msgstr "Nevar uzsākt %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Kļūda - Monitots <%s> tiek lietots\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Kļūda - Monitots <%s> tiek lietots\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Kļūda - Monitoru <%s> lieto %s.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Kļūda - Monitoru <%s> lieto %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Kļūda - Nevar pabeigt monitora procesa slēgšanu monitoram <%s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Kļūda - Nevar pabeigt monitora procesa slēgšanu monitoram <%s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Kļūda - Nevar izveidot savienojumu ar grafisko iekārtu.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Kļūda - Nevar izveidot savienojumu ar grafisko iekārtu.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Kļūda - Grafiskais monitors <%s> nedarbojas!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Kļūda - Grafiskais monitors <%s> nedarbojas!\n"
-#~ msgstr "Lūdzu startē grafisko monitoru <%s>.\n"
+msgstr "Lūdzu startē grafisko monitoru <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Nav pieslēdzies...\n"
+msgid "Not connected...\n"
+msgstr "Nav pieslēdzies...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "Nevar pieslēgties monitoram. Tiks mieģināts vēlreiz.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "Nevar pieslēgties monitoram. Tiks mieģināts vēlreiz.\n"
 #, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "Celles izmērs fp maps = %d\n"
+msgid "Size of cell in fp maps = %d"
+msgstr "Celles izmērs fp maps = %d\n"
 #, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "eksist;ejošām rastra kartēm %d\n"
+msgid "type for writing floating maps = %d"
+msgstr "eksist;ejošām rastra kartēm %d\n"
-#~ msgid "current window = %p"
-#~ msgstr "pašreizējais logs = %p"
+msgid "current window = %p"
+msgstr "pašreizējais logs = %p"
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Karogs: izvēlēties logu? %d"
+msgid "Flag: window set? %d"
+msgstr "Karogs: izvēlēties logu? %d"
 #, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Faila deskriptors automātiskai slēpšanai %d\n"
+msgid "File descriptor for automatic mask %d"
+msgstr "Faila deskriptors automātiskai slēpšanai %d\n"
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "Karogs atņemt automātisko maskēšanu %d"
+msgid "Flag denoting automatic masking %d"
+msgstr "Karogs atņemt automātisko maskēšanu %d"
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "CELL maskas bufferis %p"
+msgid "CELL mask buffer %p"
+msgstr "CELL maskas bufferis %p"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "rezerve tukšo rindu lasīšanai %p"
+msgid "buffer for reading null rows %p"
+msgstr "rezerve tukšo rindu lasīšanai %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Pirms/pēc kompresēto datu rzerves buferis %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Pirms/pēc kompresēto datu rzerves buferis %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "compressed_buf izmērs %d"
+msgid "sizeof compressed_buf %d"
+msgstr "compressed_buf izmērs %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "darba bufera izmērs %p"
+msgid "work data buffer %p"
+msgstr "darba bufera izmērs %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "work_buf izmērs %d"
+msgid "sizeof work_buf %d"
+msgstr "work_buf izmērs %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "null_buf izmērs%d"
+msgid "sizeof null_buf %d"
+msgstr "null_buf izmērs%d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "mask_buf  izmērs %d"
+msgid "sizeof mask_buf %d"
+msgstr "mask_buf  izmērs %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "Histogrammas pieprasījums %d"
+msgid "Histogram request %d"
+msgstr "Histogrammas pieprasījums %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: fails #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump: fails #%d"
 #, fuzzy
-#~ msgid "open mode = %d"
-#~ msgstr "atvērtā režijmā = %d\n"
+msgid "open mode = %d"
+msgstr "atvērtā režijmā = %d\n"
 #, fuzzy
-#~ msgid "Cell header %p"
-#~ msgstr "Šūnas iesākums  %p\n"
+msgid "Cell header %p"
+msgstr "Šūnas iesākums  %p\n"
-#~ msgid "Table reclass %p"
-#~ msgstr "Tabulas pārklasificēšana %p"
+msgid "Table reclass %p"
+msgstr "Tabulas pārklasificēšana %p"
-#~ msgid "Cell stats %p"
-#~ msgstr "Å Å«nu statistika %p"
+msgid "Cell stats %p"
+msgstr "Å Å«nu statistika %p"
 #, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "Amplitūdas, loka struktūra %p\n"
+msgid "Range structure %p"
+msgstr "Amplitūdas, loka struktūra %p\n"
 #, fuzzy
-#~ msgid "float Range structure %p"
-#~ msgstr "plūstoša loka struktūra %p\n"
+msgid "float Range structure %p"
+msgstr "plūstoša loka struktūra %p\n"
-#~ msgid "want histogram?  %d"
-#~ msgstr "vēlies histogrammu? %d"
+msgid "want histogram?  %d"
+msgstr "vēlies histogrammu? %d"
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "Automātiskās pārklasificēšanas karogs %d"
+msgid "Automatic reclass flag %d"
+msgstr "Automātiskās pārklasificēšanas karogs %d"
-#~ msgid "File row addresses %p"
-#~ msgstr "Faila līnijas adrese %p"
+msgid "File row addresses %p"
+msgstr "Faila līnijas adrese %p"
 #, fuzzy
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "Data to window col mapping %p\n"
+msgid "Data to window col mapping %p"
+msgstr "Data to window col mapping %p\n"
 #, fuzzy
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "Data to window row constants %f,%f\n"
+msgid "Data to window row constants %f,%f"
+msgstr "Data to window row constants %f,%f\n"
-#~ msgid "Current data row in memory %d"
-#~ msgstr "Tekošā datu rinda/līnija atmiņā  %d"
+msgid "Current data row in memory %d"
+msgstr "Tekošā datu rinda/līnija atmiņā  %d"
-#~ msgid "Current null row in memory %d"
-#~ msgstr "Tekošā nulles līnija atmiņā %d"
+msgid "Current null row in memory %d"
+msgstr "Tekošā nulles līnija atmiņā %d"
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "nbytes uz šūnu tekošājai rindai %d"
+msgid "nbytes per cell for current row %d"
+msgstr "nbytes uz šūnu tekošājai rindai %d"
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Dekompresēto datu buferis %s"
+msgid "Decompressed data buffer %s"
+msgstr "Dekompresēto datu buferis %s"
-#~ msgid "bytes per cell %d"
-#~ msgstr "baiti uz Å¡Å«nu %d"
+msgid "bytes per cell %d"
+msgstr "baiti uz Å¡Å«nu %d"
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "tips: int,float vai double karte %d"
+msgid "type: int, float or double map %d"
+msgstr "tips: int,float vai double karte %d"
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Pagaidu vārds JAUNAJAM failam %s"
+msgid "Temporary name for NEW files %s"
+msgstr "Pagaidu vārds JAUNAJAM failam %s"
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Pagaidu nosaukums NEW NULL failiem %s"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Pagaidu nosaukums NEW NULL failiem %s"
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Atvērto failu karšu biblotēka %s"
+msgid "Mapset of open file %s"
+msgstr "Atvērto failu karšu biblotēka %s"
-#~ msgid "io error warning given %d"
-#~ msgstr "sniegts io kļūdas brīdinājums %d"
+msgid "io error warning given %d"
+msgstr "sniegts io kļūdas brīdinājums %d"
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "xdr plūsma fp nolasīšanai %p"
+msgid "xdr stream for reading fp %p"
+msgstr "xdr plūsma fp nolasīšanai %p"
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS masīvs[%d] = %p"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS masīvs[%d] = %p"
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "datu buferis nolasot nullees līnijas %p"
+msgid "data buffer for reading null rows %p"
+msgstr "datu buferis nolasot nullees līnijas %p"
 #, fuzzy
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Minimum row null row number in memory %d\n"
+msgid "Minimum row null row number in memory %d"
+msgstr "Minimum row null row number in memory %d\n"
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump: beigas"
+msgid "G_dump: end"
+msgstr "G_dump: beigas"
-#~ msgid "Current window not settable"
-#~ msgstr "Pašreizējais logs nav izvēlams"
+msgid "Current window not settable"
+msgstr "Pašreizējais logs nav izvēlams"
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "Krāsu fails priekš [%s] nav pieejams"
+msgid "Color file for [%s] not available"
+msgstr "Krāsu fails priekš [%s] nav pieejams"
-#~ msgid "Cannot use current window"
-#~ msgstr "Nevar lietot pašreizējo logu"
+msgid "Cannot use current window"
+msgstr "Nevar lietot pašreizējo logu"
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "Neiespējami atvērtcellfailu priekš [%s]"
+msgid "Not able to open cellfile for [%s]"
+msgstr "Neiespējami atvērtcellfailu priekš [%s]"
 #, fuzzy
-#~ msgid "Too many open raster maps"
+msgid "Too many open raster maps"
 #, fuzzy
-#~ msgid "Too many open files"
-#~ msgstr "Atvērtā faila nosaukums %s"
+msgid "Too many open files"
+msgstr "Atvērtā faila nosaukums %s"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "KĻŪDA: GISBASE nav noteikta\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "KĻŪDA: GISBASE nav noteikta\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr "Kļūda nolsaot datum mai'mas parametrus priekš %s no  tabulas"
+msgid "Error reading datum shift parameters for %s from table"
+msgstr "Kļūda nolsaot datum mai'mas parametrus priekš %s no  tabulas"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr "Kļūda noasot elipsoīda parametrus laukam %s no tabulas"
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr "Kļūda noasot elipsoīda parametrus laukam %s no tabulas"
 #, fuzzy
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "nederīgs a: lauks %s failā %s pie %s"
+msgid "invalid value: field %s in file %s in %s"
+msgstr "nederīgs a: lauks %s failā %s pie %s"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "Nav n-dims iekš site_list"
+msgid "No n-dims in site_list"
+msgstr "Nav n-dims iekš site_list"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "Nav dubulto atribūtu site_list"
+msgid "No double attributes in site_list"
+msgstr "Nav dubulto atribūtu site_list"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "Nav teksta (string) atribūtu site_list"
+msgid "No string attributes in site_list"
+msgstr "Nav teksta (string) atribūtu site_list"
-#~ msgid "String attribute index out of range"
-#~ msgstr "Teksts(string) atribūta indekss ir arpus diapazona"
+msgid "String attribute index out of range"
+msgstr "Teksts(string) atribūta indekss ir arpus diapazona"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "Nezināms atribūta tips pieprasījumam G_readsites_xyz()!\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "Nezināms atribūta tips pieprasījumam G_readsites_xyz()!\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "Izgāzusies konvertācija taksta (string) atribūtam."
+msgid "Failed to convert string attribute."
+msgstr "Izgāzusies konvertācija taksta (string) atribūtam."
-#~ msgid "Reading sites list ...                  "
-#~ msgstr "Lasam novietojuma sarakstu ...                  "
+msgid "Reading sites list ...                  "
+msgstr "Lasam novietojuma sarakstu ...                  "
-#~ msgid "failed to guess format"
-#~ msgstr "izgāšanās minot formātu"
+msgid "failed to guess format"
+msgstr "izgāšanās minot formātu"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "decimālais lauks %i nav prezentēts novietojuma failos"
+msgid "decimal field %i not present in sites file"
+msgstr "decimālais lauks %i nav prezentēts novietojuma failos"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr ""
-#~ "Atrodu ierakstus, kuri nesatur peldošā punkta (decimāldaļu) atribūtus "
-#~ "(lauku pievienotais prefiks/piedēklis '%')."
+msgid ""
+"I'm finding records that do not have a floating point attributes (fields "
+"prefixed with '%')."
+msgstr ""
+"Atrodu ierakstus, kuri nesatur peldošā punkta (decimāldaļu) atribūtus (lauku "
+"pievienotais prefiks/piedēklis '%')."
 #, fuzzy
-#~ msgid "WARNING: can not create a new process\n"
-#~ msgstr "Nevar izveidot jaunu procesu!"
+msgid "WARNING: can not create a new process\n"
+msgstr "Nevar izveidot jaunu procesu!"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "Neiespējami piešķirt atmiņu\n"
+#, fuzzy
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s>karšu kopā <%s>"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "neiespējami atrast [%s] iekš [%s]"
Modified: grass/trunk/locale/po/grasslibs_mr.po
--- grass/trunk/locale/po/grasslibs_mr.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_mr.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -509,9 +509,9 @@
 msgstr "%s उघडता आले नाही"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "%s उघडता आले नाही"
@@ -1734,7 +1734,7 @@
 #: ../lib/vector/Vlib/write.c:148
 #, fuzzy
 msgid "Unable to write feature (negative offset)"
-msgstr "%s उघडता आले नाही"
+msgstr "temp फाइल उघडता आली नाही"
 #: ../lib/vector/Vlib/write.c:181
 #, fuzzy
@@ -1988,9 +1988,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
@@ -2247,9 +2247,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -4254,177 +4254,184 @@
 #, fuzzy
-#~ msgstr "temp फाइल उघडता आली नाही"
 #, fuzzy
-#~ msgstr "विनंती रद्द करण्यासाठी RETURN बटण दाबा\n"
+msgstr "विनंती रद्द करण्यासाठी RETURN बटण दाबा\n"
-#~ msgstr "पुढे जाण्यासाठी RETURN टाइप करा -->"
+msgstr "पुढे जाण्यासाठी RETURN टाइप करा -->"
-#~ msgid "one moment...\n"
-#~ msgstr "क्षणभर थांबा...\n"
+msgid "one moment...\n"
+msgstr "क्षणभर थांबा...\n"
-#~ msgid "No help available for command [%s]\n"
-#~ msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
+msgid "No help available for command [%s]\n"
+msgstr "[%s] या कमांडसाठी कोणतीही मदत उपलब्ध नाही\n"
-#~ msgstr "%s मिळाले नाही"
+msgstr "%s मिळाले नाही"
-#~ msgid "ERROR in reading %s"
-#~ msgstr "%s वाचताना त्रुटी"
+msgid "ERROR in reading %s"
+msgstr "%s वाचताना त्रुटी"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "कृपया प्रोजेक्शनचे नाव द्या\n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+"\n"
+"\n"
+"कृपया प्रोजेक्शनचे नाव द्या\n"
-#~ msgid "Enter 'list' for the list of available projections\n"
-#~ msgstr "उपलब्ध प्रोजेक्शनची यादी पाहण्यासाठी 'list' टाइप करा\n"
+msgid "Enter 'list' for the list of available projections\n"
+msgstr "उपलब्ध प्रोजेक्शनची यादी पाहण्यासाठी 'list' टाइप करा\n"
-#~ msgstr "शिर्षकांसह"
+msgstr "शिर्षकांसह"
-#~ msgstr "(शिर्षक विरहित)"
+msgid "(no title)"
+msgstr "(शिर्षक विरहित)"
-#~ msgstr "एक नवीन %s फाइलचे नाव द्या"
+msgstr "एक नवीन %s फाइलचे नाव द्या"
-#~ msgstr "%s यादी"
+msgid "a list %s"
+msgstr "%s यादी"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - मिळाली नाही **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - मिळाली नाही **\n"
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "सध्याची विंडो = %p\n"
+msgstr "सध्याची विंडो = %p\n"
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "निशाणी: विंडो सेट?  %d\n"
+msgstr "निशाणी: विंडो सेट?  %d\n"
 #, fuzzy
-#~ msgstr "compressed_buf चा आकार %d\n"
+msgstr "compressed_buf चा आकार %d\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "work_buf चा आकार %d\n"
+msgstr "work_buf चा आकार %d\n"
 #, fuzzy
-#~ msgstr "null_buf चा आकार %d\n"
+msgstr "null_buf चा आकार %d\n"
 #, fuzzy
-#~ msgstr "mask_buf चा आकार %d\n"
+msgstr "mask_buf चा आकार %d\n"
 #, fuzzy
-#~ msgstr "हिस्टोग्रामसाठी विनंती  %d\n"
+msgstr "हिस्टोग्रामसाठी विनंती  %d\n"
 #, fuzzy
-#~ msgstr "G_dump: फाइल #%d\n"
+msgstr "G_dump: फाइल #%d\n"
 #, fuzzy
-#~ msgstr "उघडण्याची पद्धत = %d\n"
+msgstr "उघडण्याची पद्धत = %d\n"
 #, fuzzy
-#~ msgstr "सेल शिर्षक %p\n"
+msgstr "सेल शिर्षक %p\n"
 #, fuzzy
-#~ msgstr "सेल आकडेवारी %p\n"
+msgstr "सेल आकडेवारी %p\n"
 #, fuzzy
-#~ msgstr "रांगाची रचना %p\n"
+msgstr "रांगाची रचना %p\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "हिस्टोग्राम हवा आहे काय?  %d\n"
+msgstr "हिस्टोग्राम हवा आहे काय?  %d\n"
 #, fuzzy
-#~ msgstr "फाइलमधील ओळींचा पत्ता %p\n"
+msgstr "फाइलमधील ओळींचा पत्ता %p\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "नवीन फाइलसाठी तात्पुरते नाव %s\n"
+msgstr "नवीन फाइलसाठी तात्पुरते नाव %s\n"
 #, fuzzy
-#~ msgstr "नवीन नल-फाइलसाठी तात्पुरते नाव %s\n"
+msgstr "नवीन नल-फाइलसाठी तात्पुरते नाव %s\n"
 #, fuzzy
-#~ msgstr "उघडलेल्या फाइलचे नाव %s\n"
+msgstr "उघडलेल्या फाइलचे नाव %s\n"
 #, fuzzy
 #, fuzzy
 #, fuzzy
+#, fuzzy
+#~ msgstr "%s उघडता आले नाही"
+#~ msgid " The raster map %s@%s is empty"
+#~ msgstr "%s@%s हा रास्टर नकाशा रिक्त आहे"
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_pl.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -13,7 +13,7 @@
 "Last-Translator: Robert Szczepanek <grass at szczepanek.pl>\n"
 "Language-Team: Polska <grass-translations at lists.osgeo.org>\n"
 "MIME-Version: 1.0\n"
-"Content-Type: text/plain; charset=utf-8\n"
+"Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "X-Generator: KBabel 1.11.4\n"
@@ -523,9 +523,9 @@
 msgstr "nie można otworzyć pliku elipsoidy: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "nie można otworzyć pliku elipsoidy: %s"
@@ -1257,12 +1257,12 @@
 #, fuzzy
-msgstr "Nie można odczytać nagłówka pliku"
+msgstr "Nie można obliczyć centroid dla powierzchni %d"
 #, fuzzy
@@ -1969,9 +1969,11 @@
 msgstr "aby zaakceptopwać domyślne"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"Mapa, które nie jest w bieżącym mapsecie nie może być otwarta do "
+"uaktualniania."
@@ -2033,7 +2035,9 @@
 #, fuzzy, c-format
-msgstr "brak dostępnych plików %s w bieżącym mapsecie\n"
+msgstr ""
+"uaktualniania."
@@ -2235,7 +2239,7 @@
 #, fuzzy, c-format
-msgstr "nie można znaleźć [%s] in [%s]"
+msgstr "nie można znaleźć [%s]"
 #, fuzzy, c-format
@@ -2298,9 +2302,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3845,9 +3849,11 @@
 msgstr "Nie można znaleźć wektora źródłowego '%s'"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"[%s] w mapsecie [%s] - znajduje się w innej strefie [%d] niż bieżący region "
+"[%d]"
@@ -4221,7 +4227,7 @@
 #, fuzzy
-msgstr "Nie można otworzyć %s"
+msgstr "W %s nie można otworzyć pliku %s"
 #, fuzzy
@@ -4372,435 +4378,446 @@
 #, fuzzy
-#~ msgstr "Nie można otworzyć pliku śledzenia błędu '%s'"
+msgstr "Nie można otworzyć pliku śledzenia błędu '%s'"
 #, fuzzy
-#~ msgid "Unknown command: %d last: %d"
-#~ msgstr ""
-#~ "\n"
-#~ "Nieznane polecenie: %d last: %d\n"
+msgid "Unknown command: %d last: %d"
+msgstr ""
+"\n"
+"Nieznane polecenie: %d last: %d\n"
-#~ msgid "Graphics driver [%s] started"
-#~ msgstr "Sterownik graficzny [%s] uruchomiony"
+msgid "Graphics driver [%s] started"
+msgstr "Sterownik graficzny [%s] uruchomiony"
 #, fuzzy
-#~ msgstr "Monitor nie został wybrany"
+msgstr "Monitor nie został wybrany"
 #, fuzzy
-#~ msgstr "Aby wybrać monitor uruchom \"d.mon\""
+msgstr "Aby wybrać monitor uruchom \"d.mon\""
 #, fuzzy
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr "Gniazdo jest już w użyciu lub nie akceptuje połączeń"
+msgid "Socket is already in use or not accepting connections."
+msgstr "Gniazdo jest już w użyciu lub nie akceptuje połączeń"
-#~ msgid "Use d.mon to select a monitor"
+msgid "Use d.mon to select a monitor"
-#~ msgid "Probably program error."
-#~ msgstr "Prawdopodobnie błąd programu"
+msgid "Probably program error."
+msgstr "Prawdopodobnie błąd programu"
-#~ msgstr "Połączenie nie powiodło się."
+msgstr "Połączenie nie powiodło się."
 #, fuzzy
-#~ msgstr "Nie można odczytać histogramu dla [%s w %s]"
+msgstr "Nie można odczytać histogramu dla [%s w %s]"
 #, fuzzy
-#~ msgid "Unable to connect lines %d,%d"
-#~ msgstr "W %s nie można otworzyć pliku %s"
+msgid "Unable to connect lines %d,%d"
 #, fuzzy
-#~ msgid "Unable to open file %s"
+msgid "Unable to open file %s"
-#~ msgstr "Wciśnij ENTER aby anulować\n"
+msgstr "Wciśnij ENTER aby anulować\n"
-#~ msgstr "Nie można otworzyć pliku tymczasowego"
+msgstr "Nie można otworzyć pliku tymczasowego"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Określ nazwę elipsoidy\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Określ nazwę elipsoidy\n"
-#~ msgstr "Wpisz 'list' aby uzyskać listę dostępnych elipsoid\n"
+msgstr "Wpisz 'list' aby uzyskać listę dostępnych elipsoid\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "niepoprawna elipsoida\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"niepoprawna elipsoida\n"
-#~ msgstr "Nazwa pliku wyjściowego '%s' nie jest poprawną nazwą rastra."
+msgstr "Nazwa pliku wyjściowego '%s' nie jest poprawną nazwą rastra."
-#~ msgstr "Mapa wyjściowa '%s' jest używana jako plik wejścowy"
+msgstr "Mapa wyjściowa '%s' jest używana jako plik wejścowy"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Określ nazwę układ odniesienia\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Określ nazwę układ odniesienia\n"
 #, fuzzy
-#~ msgstr "Wpisz 'list' aby uzyskać listę dostępnych układów odniesienia\n"
+msgstr "Wpisz 'list' aby uzyskać listę dostępnych układów odniesienia\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "niepoprawny układ odniesienia\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"niepoprawny układ odniesienia\n"
-#~ msgstr "wciśnij RETURN, aby kontynuować -->"
+msgstr "wciśnij RETURN, aby kontynuować -->"
-#~ msgstr "nie można otworzyć rastrowej mapy [%s w %s]"
+msgstr "nie można otworzyć rastrowej mapy [%s w %s]"
-#~ msgstr "trwa proces...\n"
+msgstr "trwa proces...\n"
-#~ msgstr "Brak pomocy dla polecenia [%s]\n"
+msgstr "Brak pomocy dla polecenia [%s]\n"
-#~ msgstr "Mapa rastrowa %s@%s jest pusta"
+msgstr "Mapa rastrowa %s@%s jest pusta"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Dla pliku [%s] w mapsecie [%s] niezbędna jest tabela kolorów.\n"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr ""
+"\n"
+"\n"
+"Dla pliku [%s] w mapsecie [%s] niezbędna jest tabela kolorów.\n"
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Określ opisany typ:\n"
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr ""
+"\n"
+"Określ opisany typ:\n"
-#~ msgstr "    4:  Skala szarości\n"
+msgstr "    4:  Skala szarości\n"
-#~ msgstr "    5:  Aspekt\n"
+msgstr "    5:  Aspekt\n"
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "    7:  Czerwony poprzez żółty do zielonego\n"
+msgid "    7:  Red through yellow to green\n"
+msgstr "    7:  Czerwony poprzez żółty do zielonego\n"
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "    8:  Zielony poprzez żółty do czerwonego\n"
+msgid "    8:  Green through yellow to red\n"
+msgstr "    8:  Zielony poprzez żółty do czerwonego\n"
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr ""
-#~ "\n"
-#~ "%s niepoprawny; Spróbuj ponownie > "
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr ""
+"\n"
+"%s niepoprawny; Spróbuj ponownie > "
 #, fuzzy
-#~ msgstr "nie znaleziono %s"
+msgstr "nie znaleziono %s"
-#~ msgstr "BŁĄD podczas wczytywania %s"
+msgstr "BŁĄD podczas wczytywania %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Określ nazwę odwzorowania\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Określ nazwę odwzorowania\n"
-#~ msgstr "Wpisz 'list' aby uzyskać listę dostępnych odwzorowań\n"
+msgstr "Wpisz 'list' aby uzyskać listę dostępnych odwzorowań\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr ""
-#~ "\n"
-#~ "niepoprawne odwzorowanie\n"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+"\n"
+"niepoprawne odwzorowanie\n"
-#~ msgstr "z tytułami"
+msgstr "z tytułami"
-#~ msgstr "(bez tytułu)"
+msgid "(no title)"
+msgstr "(bez tytułu)"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPCJA:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPCJA:   %s\n"
-#~ msgid "  format: %s\n"
-#~ msgstr "  format: %s\n"
+msgid "  format: %s\n"
+msgstr "  format: %s\n"
 #, fuzzy
-#~ msgid " default: %s\n"
-#~ msgstr " domyślnie: %s\n"
+msgid " default: %s\n"
+msgstr " domyślnie: %s\n"
 #, fuzzy
-#~ msgid "required: %s\n"
-#~ msgstr "wymagany: %s\n"
+msgid "required: %s\n"
+msgstr "wymagany: %s\n"
-#~ msgstr "wprowadź opcję >"
+msgstr "wprowadź opcję >"
-#~ msgid "   Try again? "
-#~ msgstr "   Czy ponowić próbę ? "
+msgid "   Try again? "
+msgstr "   Czy ponowić próbę ? "
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "Wartość %s nie jest poprawna\n"
+msgid "Sorry, %s is not accepted.\n"
+msgstr "Wartość %s nie jest poprawna\n"
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Wybrałeś:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Wybrałeś:\n"
+"  %s\n"
-#~ msgstr "Czy to siÄ™ zgadza ?"
+msgstr "Czy to siÄ™ zgadza ?"
-#~ msgstr "aby zaakceptopwać domyślne"
+msgstr "aby zaakceptopwać domyślne"
-#~ msgstr "aby skasować żądanie"
+msgstr "aby skasować żądanie"
-#~ msgstr "Wprowadź nową %s nazwę pliku"
+msgstr "Wprowadź nową %s nazwę pliku"
-#~ msgstr "wprowadź nazwę istniejącego %s pliku"
+msgstr "wprowadź nazwę istniejącego %s pliku"
-#~ msgstr "Wprowadź %s nazwę pliku"
+msgstr "Wprowadź %s nazwę pliku"
-#~ msgstr "Wprowadź 'list' aby wyświetlić listę istniejących %s plików\n"
+msgstr "Wprowadź 'list' aby wyświetlić listę istniejących %s plików\n"
-#~ msgstr "Wprowadź 'list -f' dla "
+msgstr "Wprowadź 'list -f' dla "
-#~ msgstr "lista %s"
+msgid "a list %s"
+msgstr "lista %s"
-#~ msgstr "rozszerzona lista"
+msgstr "rozszerzona lista"
-#~ msgstr "Naciśnij ENTER %s\n"
+msgstr "Naciśnij ENTER %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - nie znaleziono **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - nie znaleziono **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr ""
-#~ "\n"
-#~ "** %s istnieje. nadpisać? "
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr ""
+"\n"
+"** %s istnieje. nadpisać? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> niedozwolona nazwa **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> niedozwolona nazwa **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - niedozwlone żądanie **\n"
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr ""
+"\n"
+"** %s - niedozwlone żądanie **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - istnieje, wybierz innÄ… nazwÄ™ **\n"
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr ""
+"\n"
+"** %s - istnieje, wybierz innÄ… nazwÄ™ **\n"
-#~ msgstr "zbyt mała ilość pamięci do alokacji "
+msgstr "zbyt mała ilość pamięci do alokacji "
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Nie można otworzyć nagłówka pliku dla [%s w %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Nie można otworzyć nagłówka pliku dla [%s w %s]"
-#~ msgstr "Brak informacji o polu"
+msgstr "Brak informacji o polu"
 #, fuzzy
-#~ msgstr "Nie można otworzyć bazy danych %s"
+msgstr "Nie można otworzyć bazy danych %s"
-#~ msgstr "Tworzenie topologii ...\n"
+msgstr "Tworzenie topologii ...\n"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Informacji o warstwie jest niedostępna"
+msgstr "Informacji o warstwie jest niedostępna"
 #, fuzzy
-#~ msgid "OGR feature type [%d] not supported"
-#~ msgstr "Obiekty OGR typu %d nie są obsługiwane"
+msgid "OGR feature type [%d] not supported"
+msgstr "Obiekty OGR typu %d nie są obsługiwane"
-#~ msgstr "Nie można nadpisać linii"
+msgstr "Nie można nadpisać linii"
-#~ msgstr "Nie można usunąć linii"
+msgstr "Nie można usunąć linii"
-#~ msgstr "Nazwa wyniku '%s' nie jest poprawnÄ… nazwÄ… wektora."
+msgstr "Nazwa wyniku '%s' nie jest poprawnÄ… nazwÄ… wektora."
-#~ msgstr "Nie można skopiować wektora '%s' do '%s'"
+msgstr "Nie można skopiować wektora '%s' do '%s'"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Nie można usunąć istniejącego wektora <%s>"
+msgstr "Nie można usunąć istniejącego wektora <%s>"
-#~ msgstr "Nie można otworzyć nowego wektora %s"
+msgstr "Nie można otworzyć nowego wektora %s"
-#~ msgstr "Nie można otworzyć pliku historii dla wektora '%s'"
+msgstr "Nie można otworzyć pliku historii dla wektora '%s'"
-#~ msgid "Setting map window"
-#~ msgstr "Ustawienia okna mapy"
+msgid "Setting map window"
+msgstr "Ustawienia okna mapy"
 #, fuzzy
-#~ msgstr "bieżące okno = %p"
+msgstr "bieżące okno = %p"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Nie można wyczyścić bieżącej grafiki"
+msgid "Can't clear current graphics window"
+msgstr "Nie można wyczyścić bieżącej grafiki"
-#~ msgstr "Plik koloru dla [%s] nie jest dostępny"
+msgstr "Plik koloru dla [%s] nie jest dostępny"
-#~ msgstr "Nie można użyć bieżącego okna"
+msgstr "Nie można użyć bieżącego okna"
-#~ msgstr "Nie można otworzyć cellfile dla [%s]"
+msgstr "Nie można otworzyć cellfile dla [%s]"
-#~ msgid "clearing current graphics window"
-#~ msgstr "czyszczenie bieżącej grafiki"
+msgid "clearing current graphics window"
+msgstr "czyszczenie bieżącej grafiki"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** nazwa niedopuszczalna **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** nazwa niedopuszczalna **"
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "zrzut _G: pamięć ulokowana w G__"
+msgid "G_dump: memory allocated to G__"
+msgstr "zrzut _G: pamięć ulokowana w G__"
-#~ msgstr "Rozmiar komórki w mapach fp = %d"
+msgstr "Rozmiar komórki w mapach fp = %d"
-#~ msgstr "typ zapisu map o wartościach danych zmiennoprzecinkowych = %d"
+msgstr "typ zapisu map o wartościach danych zmiennoprzecinkowych = %d"
-#~ msgstr "Flaga: ustawienie okna? %d"
+msgstr "Flaga: ustawienie okna? %d"
 #, fuzzy
-#~ msgstr "zabezpieczenie przed wczytaniem zerowych wierszy %p"
+msgstr "zabezpieczenie przed wczytaniem zerowych wierszy %p"
 #, fuzzy
-#~ msgstr "Histogram wymaga %d"
+msgstr "Histogram wymaga %d"
-#~ msgstr "G_dump: plik #%d"
+msgstr "G_dump: plik #%d"
-#~ msgstr "Struktura zasięgu %p"
+msgstr "Struktura zasięgu %p"
-#~ msgstr "Bieżący wiersz danych w pamięci %d"
+msgstr "Bieżący wiersz danych w pamięci %d"
-#~ msgstr "Bieżący zerowy wiersz w pamięci %d"
+msgstr "Bieżący zerowy wiersz w pamięci %d"
-#~ msgstr "bajtów na komórkę %d"
+msgstr "bajtów na komórkę %d"
-#~ msgstr "Tymczasowa nazwa dla nowych plików %s"
+msgstr "Tymczasowa nazwa dla nowych plików %s"
-#~ msgstr "Tymczasowa nazwa dla nowych, pustych plików %s"
+msgstr "Tymczasowa nazwa dla nowych, pustych plików %s"
-#~ msgstr "Mapset otwartego pliku: %s"
+msgstr "Mapset otwartego pliku: %s"
-#~ msgstr "tablica NULL_ROWS [%d] = %p"
+msgstr "tablica NULL_ROWS [%d] = %p"
 #, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
 #, fuzzy
+msgstr "lista %s"
 #, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Brak połączenia...\n"
+msgstr "Brak połączenia...\n"
 #, fuzzy
-#~ msgid "Cannot open old vector %s"
+msgid "Cannot open old vector %s"
-#~ msgid "Starting lu solver method"
-#~ msgstr "Rozpoczęto rozwiązywanie metodą LU"
+msgid "Starting lu solver method"
+msgstr "Rozpoczęto rozwiązywanie metodą LU"
+#, fuzzy
+#~ msgstr "W %s nie można otworzyć pliku %s"
+#, fuzzy
+#~ msgstr "<%s> w mapsecie <%s>"
+#~ msgstr "nie można znaleźć [%s] in [%s]"
Modified: grass/trunk/locale/po/grasslibs_pt.po
--- grass/trunk/locale/po/grasslibs_pt.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_pt.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -534,9 +534,9 @@
 msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "não foi possível abrir o arquivo com a tabela de datum: %s"
@@ -1997,9 +1997,9 @@
 msgstr "Janela substituindo o padrão"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "Bug: tentativa de atualizar mapa que não está no mapset atual."
@@ -2060,7 +2060,7 @@
 #, fuzzy, c-format
-msgstr "não há arquivos <%s> disponíveis no mapset ativo\n"
@@ -2262,7 +2262,7 @@
 #, fuzzy, c-format
-msgstr "não consegui encontrar [%s] em [%s]"
+msgstr "não consegui encontrar [%s]"
 #, fuzzy, c-format
@@ -2325,9 +2325,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3866,9 +3866,10 @@
 msgstr "Vetor de entrada '%s' não encontrado"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"[%s] no mapset [%s] - está em uma zona diferente [%d] da região atual [%d]"
@@ -4240,7 +4241,7 @@
 #, fuzzy
-msgstr "não consegui abrir [%s]"
+msgstr "Impossível abrir arquivo %s"
 #, fuzzy
@@ -4390,413 +4391,423 @@
 msgid "Unable to define new light"
-#~ msgstr "Impossível descrever tabela <%s>"
+msgstr "Impossível descrever tabela <%s>"
-#~ msgstr "Comando desconhecido: %d último: %d"
+msgstr "Comando desconhecido: %d último: %d"
-#~ msgid "Monitor: get_command: Premature EOF"
-#~ msgstr "Monitor: get_command: Fim de arquivo prematuro"
+msgid "Monitor: get_command: Premature EOF"
+msgstr "Monitor: get_command: Fim de arquivo prematuro"
-#~ msgstr "Controlador gráfico [%s] iniciado"
+msgstr "Controlador gráfico [%s] iniciado"
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "ERRO %s do dispositivo gráfico.\n"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "ERRO %s do dispositivo gráfico.\n"
-#~ msgstr "ERRO - o monitor gráfico enviou EOF.\n"
+msgstr "ERRO - o monitor gráfico enviou EOF.\n"
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "ATENÇÃO - O monitor gráfico <%s> não está respondendo.\n"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "ATENÇÃO - O monitor gráfico <%s> não está respondendo.\n"
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "Verifique se o mouse ainda está ativo.\n"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "Verifique se o mouse ainda está ativo.\n"
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
-#~ msgstr "ERRO - O monitor gráfico <%s> não está respondendo.\n"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "ERRO - O monitor gráfico <%s> não está respondendo.\n"
-#~ msgstr "O monitor gráfico não foi selecionado como saída."
+msgstr "O monitor gráfico não foi selecionado como saída."
-#~ msgstr "Por favor, execute \"d.mon\" para selecionar um monitor gráfico"
+msgstr "Por favor, execute \"d.mon\" para selecionar um monitor gráfico"
-#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "Falha ao obter nome do soquete para o monitor <%s>."
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "Falha ao obter nome do soquete para o monitor <%s>."
-#~ msgid "No socket to connect to for monitor <%s>."
-#~ msgstr "Não há um soquete para conectar ao monitor <%s>."
+msgid "No socket to connect to for monitor <%s>."
+msgstr "Não há um soquete para conectar ao monitor <%s>."
-#~ msgstr "O soquete já está em uso ou não está aceitando conexões."
+msgstr "O soquete já está em uso ou não está aceitando conexões."
-#~ msgstr "Use \"d.mon\" para selecionar um monitor"
+msgstr "Use \"d.mon\" para selecionar um monitor"
-#~ msgstr "Tentando conectar a algo que não um soquete."
+msgstr "Tentando conectar a algo que não um soquete."
-#~ msgstr "Provável erro no programa."
+msgstr "Provável erro no programa."
-#~ msgid "Connect attempt timed out."
-#~ msgstr "Tempo de conexão excedido"
+msgid "Connect attempt timed out."
+msgstr "Tempo de conexão excedido"
-#~ msgstr "Provavelmente um erro no servidor."
+msgstr "Provavelmente um erro no servidor."
-#~ msgstr "Falha na conexão."
+msgstr "Falha na conexão."
-#~ msgstr "Impossível ler o topologia para linha [%d]"
+msgstr "Impossível ler o topologia para linha [%d]"
 #, fuzzy
-#~ msgid "Attempt to delete dead line"
-#~ msgstr "Tentativa de remover área morta"
+msgid "Attempt to delete dead line"
+msgstr "Tentativa de remover área morta"
-#~ msgstr "Impossível abrir arquivo %s"
 #, fuzzy
-#~ msgstr "Pressione RETURN para cancelar\n"
+msgstr "Pressione RETURN para cancelar\n"
-#~ msgstr "não consegui abrir arquivo temporário"
+msgstr "não consegui abrir arquivo temporário"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor especifique o nome do elipsóide\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor especifique o nome do elipsóide\n"
-#~ msgstr "Digite 'list' para a lista de elipsóides disponíveis\n"
+msgstr "Digite 'list' para a lista de elipsóides disponíveis\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "elipsóide inválido\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"elipsóide inválido\n"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
+msgid "Output name '%s' is not valid rast name."
+msgstr "Nome de arquivo de saída '%s' não é um nome de raster válido."
-#~ msgstr "Mapa de saída '%s' usado como entrada"
+msgstr "Mapa de saída '%s' usado como entrada"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor especifique o nome do datum\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor especifique o nome do datum\n"
-#~ msgstr "Digite 'list' para ver a lista de datums existentes\n"
+msgstr "Digite 'list' para ver a lista de datums existentes\n"
-#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr "ou 'custom'se preferir digitar parâmetros personalizados\n"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "ou 'custom'se preferir digitar parâmetros personalizados\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum inválido\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum inválido\n"
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "Pressione ENTER para continuar -->"
+msgid "hit RETURN to continue -->"
+msgstr "Pressione ENTER para continuar -->"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "não foi possível abrir o mapa raster [%s em %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "não foi possível abrir o mapa raster [%s em %s]"
-#~ msgstr "aguarde...\n"
+msgstr "aguarde...\n"
-#~ msgstr "No há ajuda disponível para o comando [%s]\n"
+msgstr "No há ajuda disponível para o comando [%s]\n"
-#~ msgstr "O raster %s@%s está vazio"
+msgstr "O raster %s@%s está vazio"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Tabela de cores necessária para o arquivo [%s] no mapset [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Tabela de cores necessária para o arquivo [%s] no mapset [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Por favor identifique o tipo desejado:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Por favor identifique o tipo desejado:\n"
-#~ msgstr "    1:  Cores aleatórias\n"
+msgstr "    1:  Cores aleatórias\n"
-#~ msgstr "    2:  Gradientes vermelho, verde, e azul\n"
+msgstr "    2:  Gradientes vermelho, verde, e azul\n"
-#~ msgstr "    3:  Onda de cores variadas\n"
+msgstr "    3:  Onda de cores variadas\n"
-#~ msgstr "    4:  Escala de cinza\n"
+msgstr "    4:  Escala de cinza\n"
-#~ msgstr "    5:  Aspecto\n"
+msgstr "    5:  Aspecto\n"
-#~ msgstr "    6:  Cores do arco-íris\n"
+msgstr "    6:  Cores do arco-íris\n"
-#~ msgstr "    7:  Vermelho, amarelo, verde \n"
+msgstr "    7:  Vermelho, amarelo, verde \n"
-#~ msgstr "    8:  Verde, amarelo, vermelho\n"
+msgstr "    8:  Verde, amarelo, vermelho\n"
-#~ msgstr "<RETURN>  encerra\n"
+msgstr "<RETURN>  encerra\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s é inválido. Tente novamente > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s é inválido. Tente novamente > "
-#~ msgstr "%s não encontrado"
+msgstr "%s não encontrado"
-#~ msgstr "ERRO na leitura de %s"
+msgstr "ERRO na leitura de %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Por favor indique o nome da projeção\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Por favor indique o nome da projeção\n"
-#~ msgstr "Digite 'list' para a lista de projeções disponíveis\n"
+msgstr "Digite 'list' para a lista de projeções disponíveis\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "projeção inválida\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"projeção inválida\n"
-#~ msgstr "com títulos"
+msgstr "com títulos"
-#~ msgstr "(sem título)"
+msgid "(no title)"
+msgstr "(sem título)"
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr ""
-#~ "\n"
-#~ "FLAG: forneça o flag seguinte?\n"
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr ""
+"\n"
+"FLAG: forneça o flag seguinte?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPÇÃO:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPÇÃO:   %s\n"
-#~ msgstr "     chave: %s\n"
+msgid "     key: %s\n"
+msgstr "     chave: %s\n"
-#~ msgstr "  formato: %s\n"
+msgstr "  formato: %s\n"
-#~ msgstr " padrão: %s\n"
+msgstr " padrão: %s\n"
-#~ msgstr "obrigatória: %s\n"
+msgstr "obrigatória: %s\n"
-#~ msgid "multiple: %s\n"
-#~ msgstr "múltipla: %s\n"
+msgid "multiple: %s\n"
+msgstr "múltipla: %s\n"
-#~ msgid "enter option > "
-#~ msgstr "Digite uma opção > "
+msgid "enter option > "
+msgstr "Digite uma opção > "
-#~ msgstr "  Tentar outra vez? "
+msgstr "  Tentar outra vez? "
-#~ msgstr "Desculpe, %s não é aceito.\n"
+msgstr "Desculpe, %s não é aceito.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Você escolheu.:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Você escolheu.:\n"
+"  %s\n"
-#~ msgstr "Isso está certo? "
+msgstr "Isso está certo? "
-#~ msgstr "para aceitar os valores padrão"
+msgstr "para aceitar os valores padrão"
-#~ msgstr "para cancelar"
+msgstr "para cancelar"
-#~ msgstr "Digite um novo nome para o arquivo %s"
+msgstr "Digite um novo nome para o arquivo %s"
-#~ msgstr "Digite o nome de um arquivo %s existente"
+msgstr "Digite o nome de um arquivo %s existente"
-#~ msgstr "Digite o nome do arquivo %s"
+msgstr "Digite o nome do arquivo %s"
-#~ msgstr "Digite 'list' para uma lista dos arquivos %s existentes\n"
+msgstr "Digite 'list' para uma lista dos arquivos %s existentes\n"
-#~ msgstr "Digite 'list -f' para"
+msgstr "Digite 'list -f' para"
-#~ msgstr "uma lista %s"
+msgid "a list %s"
+msgstr "uma lista %s"
-#~ msgstr "uma lista longa"
+msgstr "uma lista longa"
-#~ msgstr "Pressione ENTER %s\n"
+msgstr "Pressione ENTER %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - não encontrado **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - não encontrado **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s existe. deseja sobrescrever? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s existe. deseja sobrescrever? "
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> nome ilegal **\n"
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+"\n"
+"**<%s> nome ilegal **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - requisição ilegal **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - requisição ilegal **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - existe, escolha outro nome **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - existe, escolha outro nome **\n"
-#~ msgstr "pergunta: não pode acontecer"
+msgstr "pergunta: não pode acontecer"
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Memória insuficiente para alocação da gaussiana"
+msgid "Insufficent memory for allocation of gaussian"
+msgstr "Memória insuficiente para alocação da gaussiana"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "não é possível ler o cabeçalho do arquivo para [%s em %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "não é possível ler o cabeçalho do arquivo para [%s em %s]\n"
-#~ msgstr "não é possível abrir o arquivo de cabeçalho para  [%s em %s]"
+msgstr "não é possível abrir o arquivo de cabeçalho para  [%s em %s]"
-#~ msgstr "Impossível obter informação do campo"
+msgstr "Impossível obter informação do campo"
 #, fuzzy
-#~ msgstr "não consegui abrir banco de dados %s"
+msgstr "não consegui abrir banco de dados %s"
-#~ msgstr "Criando topologia ...\n"
+msgstr "Criando topologia ...\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d áreas construídas      \n"
-#~ "%d ilhas construídas\n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d áreas construídas      \n"
+"%d ilhas construídas\n"
-#~ msgstr "Impossível abrir base de dados <%s> com driver <%s>"
+msgstr "Impossível abrir base de dados <%s> com driver <%s>"
-#~ msgstr "Impossível obter informações de coluna"
+msgstr "Impossível obter informações de coluna"
-#~ msgid "Column type not supported"
-#~ msgstr "Tipo da coluna não suportado"
+msgid "Column type not supported"
+msgstr "Tipo da coluna não suportado"
-#~ msgstr "Feição OGR tipo [%d] não suportada"
+msgstr "Feição OGR tipo [%d] não suportada"
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_rewrite_line() não é suportada para este nível/formato"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_rewrite_line() não é suportada para este nível/formato"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "Vect_delete_line() não é suportada para este nível/formato"
+msgid "Vect_delete_line() for this format/level not supported"
+msgstr "Vect_delete_line() não é suportada para este nível/formato"
-#~ msgstr "não consegui reescrever a linha"
+msgstr "não consegui reescrever a linha"
-#~ msgstr "não consegui apagar a linha"
+msgstr "não consegui apagar a linha"
-#~ msgstr "Nome de arquivo de saída %s não é um nome de vetor válido."
+msgstr "Nome de arquivo de saída %s não é um nome de vetor válido."
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "não consegui copiar o vetor '%s' para '%s'"
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "não consegui copiar o vetor '%s' para '%s'"
-#~ msgstr "Impossível abrir mapa vetorial existente <%s>"
+msgstr "Impossível abrir mapa vetorial existente <%s>"
-#~ msgstr "Impossível apagar o vetor existente <%s>"
+msgstr "Impossível apagar o vetor existente <%s>"
-#~ msgstr "não consegui abrir vetor novo %s"
+msgstr "não consegui abrir vetor novo %s"
-#~ msgstr "Não consegui abrir histórico para o vetor %s"
+msgstr "Não consegui abrir histórico para o vetor %s"
-#~ msgstr "não consegui obter informações sobre o arquivo '%s'"
+msgstr "não consegui obter informações sobre o arquivo '%s'"
-#~ msgstr "Impossível abrir diretório %s"
+msgstr "Impossível abrir diretório %s"
+#~ msgstr "não consegui alocar memória\n"
+#, fuzzy
+#~ msgstr "<%s> no mapset <%s>"
+#~ msgstr "não consegui encontrar [%s] em [%s]"
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -526,9 +526,9 @@
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1259,12 +1259,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "não consegui abrir arquivo temporário"
+msgstr "não consegui calcular centróide para área %d"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -1984,9 +1984,9 @@
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2047,7 +2047,7 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "não há arquivos %s disponíveis no mapset ativo\n"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2250,7 +2250,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2313,9 +2313,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -3858,9 +3858,10 @@
 #: ../lib/ogsf/GS2.c:1638
-#, c-format
+#, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
@@ -4230,7 +4231,7 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
+msgstr "não foi possível abrir o arquivo %s em %s"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
@@ -4380,420 +4381,430 @@
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
-#~ msgstr "Monitor: get_command: EOF Prematuro"
+msgstr "Monitor: get_command: EOF Prematuro"
-#~ msgid "ERROR - eof from graphics monitor.\n"
+msgid "ERROR - eof from graphics monitor.\n"
 #, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "O monitor gráfico não foi selecionado como saída.\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "O monitor gráfico não foi selecionado como saída.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "Por favor, execute \"d.mon\" para selecionar um monitor gráfico\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Por favor, execute \"d.mon\" para selecionar um monitor gráfico\n"
 #, fuzzy
-#~ msgstr "não conseguir encontrar o nome do soquete para o monitor ,%s>.\n"
+msgstr "não conseguir encontrar o nome do soquete para o monitor ,%s>.\n"
 #, fuzzy
-#~ msgstr "não há um soquete para conectar o monitor <%s>.\n"
+msgstr "não há um soquete para conectar o monitor <%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "O soquete já está em uso ou não está aceitando conexões.\n"
-#~ "Use d.mon para escolher um monitor\n"
+msgstr ""
+"O soquete já está em uso ou não está aceitando conexões.\n"
+"Use d.mon para escolher um monitor\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Tentando conectar a algo que não um soquete.\n"
-#~ "Provável erro no programa.\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"Tentando conectar a algo que não um soquete.\n"
+"Provável erro no programa.\n"
 #, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr "Tempo de conexão excedido. Provavelmente um erro no servidor.\n"
+msgid "Probably an error with the server."
+msgstr "Tempo de conexão excedido. Provavelmente um erro no servidor.\n"
 #, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "Falha na conexão.\n"
+msgid "Connection failed."
+msgstr "Falha na conexão.\n"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "não consegui ler o histograma para [%s em %s]"
+msgid "Cannot read topo for line [%d]"
+msgstr "não consegui ler o histograma para [%s em %s]"
 #, fuzzy
-#~ msgstr "não foi possível abrir o arquivo %s em %s"
 #, fuzzy
-#~ msgid "Unable to open temporary file"
+msgid "Unable to open temporary file"
-#~ msgid "Hit RETURN to cancel request\n"
+msgid "Hit RETURN to cancel request\n"
-#~ msgid "Cannot open temp file"
+msgid "Cannot open temp file"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
-#~ msgid "Output map '%s' is used as input"
+msgid "Output map '%s' is used as input"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
-#~ msgid "Enter 'list' for the list of available datums\n"
+msgid "Enter 'list' for the list of available datums\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum inválido\n"
-#~ msgid " The raster map %s@%s is empty"
+msgid " The raster map %s@%s is empty"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid "    1:  Random colors\n"
+msgid "    1:  Random colors\n"
-#~ msgid "    2:  Red, green, and blue color ramps\n"
+msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgid "    3:  Color wave\n"
+msgid "    3:  Color wave\n"
-#~ msgid "    4:  Gray scale\n"
+msgid "    4:  Gray scale\n"
-#~ msgid "    5:  Aspect\n"
+msgid "    5:  Aspect\n"
-#~ msgid "    6:  Rainbow colors\n"
+msgid "    6:  Rainbow colors\n"
-#~ msgid "RETURN  quit\n"
+msgid "RETURN  quit\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid "%s not found"
+msgid "%s not found"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid "with titles"
+msgid "with titles"
-#~ msgid "(no title)"
+msgid "(no title)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "OPÇÃO:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"OPÇÃO:   %s\n"
+msgid "     key: %s\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"  %s\n"
+msgid "a list %s"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
 #, fuzzy
-#~ msgstr "não consegui obter informações de camada"
+msgstr "não consegui obter informações de camada"
 #, fuzzy
-#~ msgid ""
-#~ msgstr ""
+msgid ""
+"%d isles built\n"
+msgstr ""
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "Feição OGR tipo %d não suportada)"
+msgstr "Feição OGR tipo %d não suportada)"
 #, fuzzy
 #, fuzzy
-#~ msgstr "não posso apagar o vetor existente %s"
+msgstr "não posso apagar o vetor existente %s"
 #, fuzzy
 #, fuzzy
+#, fuzzy
Modified: grass/trunk/locale/po/grasslibs_ru.po
--- grass/trunk/locale/po/grasslibs_ru.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_ru.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -1,13 +1,13 @@
 # translation of grasslibs_ru.po to Russian
 # This file is distributed under the same license as the GRASS package.
 # Copyright (C) 2006, GRASS Development Team
-# Alex Shevlakov <sixote at yahoo.com>, Maxim Dubinin <sim at gis-lab.info>.
+# Maxim Dubinin <sim at gis-lab.info>, Alex Shevlakov <sixote at yahoo.com>, 2008.
 msgid ""
 msgstr ""
 "Project-Id-Version: grasslibs_ru\n"
 "Report-Msgid-Bugs-To: \n"
 "POT-Creation-Date: 2008-10-11 22:08+0200\n"
-"PO-Revision-Date: 2008-05-05 19:03-0600\n"
+"PO-Revision-Date: 2008-09-29 19:55-0600\n"
 "Last-Translator: Maxim Dubinin <sim at gis-lab.info>\n"
 "Language-Team: Russian <grass-translations at lists.osgeo.org>\n"
@@ -20,18 +20,24 @@
 "\n"
 "++ Running math tool unit tests ++"
 msgstr ""
+"\n"
+"++ идет тестирование инструментов математики ++"
 #: ../lib/gpde/test/test_tools.c:39
 msgid ""
 "\n"
 "-- math tool unit tests failure --"
 msgstr ""
+"\n"
+"-- тестирование инструментов математики окончилось неудачно --"
 #: ../lib/gpde/test/test_tools.c:41
 msgid ""
 "\n"
 "-- math tool unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- тестирование инструментов математики успешно завершено --"
 #: ../lib/gpde/test/test_arrays.c:48
 msgid ""
@@ -66,154 +72,189 @@
 "-- Тест единиц массива успешно пройден --"
 #: ../lib/gpde/test/test_heat.c:33
+#, fuzzy
 msgid ""
 "\n"
 "++ Running heat flow integration tests ++"
 msgstr ""
+"\n"
+"++ Идет тестирование интеграции теплового потока  ++"
 #: ../lib/gpde/test/test_heat.c:35
 msgid "\t 1. testing 2d heat flow"
-msgstr ""
+msgstr "\t 1. тестирование 2d теплового потока"
 #: ../lib/gpde/test/test_heat.c:37
 msgid "\t 2. testing 3d heat flow"
-msgstr ""
+msgstr "\t 2. тестирование 3d теплового потока"
 #: ../lib/gpde/test/test_heat.c:40
 msgid ""
 "\n"
 "-- heat flow integration tests failure --"
 msgstr ""
+"\n"
+"-- тестирование интеграции теплового потока окончилось неудачно --"
 #: ../lib/gpde/test/test_heat.c:42
 msgid ""
 "\n"
 "-- heat flow integration tests finished successfully --"
 msgstr ""
+"\n"
+"-- тестирование интеграции теплового потока успешно завершено --"
 #: ../lib/gpde/test/test_les.c:34
+#, fuzzy
 msgid ""
 "\n"
 "++ Running les creation unit tests ++"
 msgstr ""
+"\n"
+"++ Идет тестирование les creation unit  ++"
 #: ../lib/gpde/test/test_les.c:39
 msgid ""
 "\n"
 "-- les creation unit tests failure --"
 msgstr ""
+"\n"
+"-- тестирование les creation unit окончилось неудачно --"
 #: ../lib/gpde/test/test_les.c:41
 msgid ""
 "\n"
 "-- les creation unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- тестирование les creation unit успешно завершено --"
 #: ../lib/gpde/test/test_les.c:95
+#, fuzzy
 msgid "\t * testing les creation in parallel\n"
-msgstr ""
+msgstr "\t * тестирование создания les параллельно \n"
 #: ../lib/gpde/test/test_les.c:126
 msgid "\t * testing les creation in serial\n"
-msgstr ""
+msgstr "\t * тестирование создания les серийно \n"
 #: ../lib/gpde/test/test_main.c:49
+#, fuzzy
 msgid "Choose the unit tests to run"
-msgstr ""
+msgstr "Выберите тесты единиц"
 #: ../lib/gpde/test/test_main.c:56
 msgid "Choose the integration tests to run"
-msgstr ""
+msgstr "Выберите интеграционные тесты "
 #: ../lib/gpde/test/test_main.c:61
+#, fuzzy
 msgid "Run all unit tests"
-msgstr ""
+msgstr "Выполнить все тесты единиц"
 #: ../lib/gpde/test/test_main.c:65
 msgid "Run all integration tests"
-msgstr ""
+msgstr "Выполнить все интеграционные тесты "
 #: ../lib/gpde/test/test_main.c:69
 msgid "Run all unit and integration tests"
-msgstr ""
+msgstr "Выполнить все тесты единиц и интеграции"
 #: ../lib/gpde/test/test_main.c:85
 msgid "test, gpde"
-msgstr ""
+msgstr "тест, gpde"
 #: ../lib/gpde/test/test_main.c:87
 msgid "Performs unit and integration tests for gpde library"
-msgstr ""
+msgstr "Выполнить тесты единиц и интеграционные тесты для библиотеки gdpe"
 #: ../lib/gpde/test/test_gwflow.c:43
 msgid ""
 "\n"
 "++ Running gwflow integration tests ++"
 msgstr ""
+"\n"
+"++ Идут интеграциионные тесты gwflow ++"
 #: ../lib/gpde/test/test_gwflow.c:45
 msgid "\t 1. testing 2d gwflow"
-msgstr ""
+msgstr "\t 1. тестирование 2d gwflow"
 #: ../lib/gpde/test/test_gwflow.c:48
 msgid "\t 2. testing 3d gwflow"
-msgstr ""
+msgstr "\t 2. тестирование 3d gwflow"
 #: ../lib/gpde/test/test_gwflow.c:52
 msgid ""
 "\n"
 "-- gwflow integration tests failure --"
 msgstr ""
+"\n"
+"-- интеграционные тесты gwflow окончились неудачно --"
 #: ../lib/gpde/test/test_gwflow.c:54
 msgid ""
 "\n"
 "-- gwflow integration tests finished successfully --"
 msgstr ""
+"\n"
+"-- тесты интеграции gwflow завершены успешно --"
 #: ../lib/gpde/test/test_geom.c:36
 msgid ""
 "\n"
 "++ Running geom_data unit tests ++"
 msgstr ""
+"\n"
+"++ Тестирование единицы geom_data ++"
 #: ../lib/gpde/test/test_geom.c:41
 msgid ""
 "\n"
 "-- geom_data unit tests failure --"
 msgstr ""
+"\n"
+"-- тестирование единицы geom_data окончилось неудачно --"
 #: ../lib/gpde/test/test_geom.c:43
 msgid ""
 "\n"
 "-- geom_data unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- тестирование единицы geom_data завершено успешно --"
 #: ../lib/gpde/test/test_solute_transport.c:43
 msgid ""
 "\n"
 "++ Running solute_transport integration tests ++"
 msgstr ""
+"\n"
+"++ Запуск тестирования интеграции solute_transport ++"
 #: ../lib/gpde/test/test_solute_transport.c:45
 msgid "\t 1. testing 2d solute_transport"
-msgstr ""
+msgstr "\t 1. тестирование 2d solute_transport"
 #: ../lib/gpde/test/test_solute_transport.c:48
 msgid "\t 2. testing 3d solute_transport"
-msgstr ""
+msgstr "\t 2. тестирование 3d solute_transport"
 #: ../lib/gpde/test/test_solute_transport.c:52
 msgid ""
 "\n"
 "-- solute_transport integration tests failure --"
 msgstr ""
+"\n"
+"-- тесты интеграции solute_transport окончились неудачно --"
 #: ../lib/gpde/test/test_solute_transport.c:54
 msgid ""
 "\n"
 "-- solute_transport integration tests finished successfully --"
 msgstr ""
+"\n"
+"-- тесты интеграции solute_transport успешно завершены --"
 #: ../lib/gpde/test/test_assemble.c:42
 #, fuzzy
@@ -226,67 +267,83 @@
 #: ../lib/gpde/test/test_assemble.c:44
 msgid "\t 1. testing 2d assembling"
-msgstr ""
+msgstr "\t 1. тестирование 2d assembling"
 #: ../lib/gpde/test/test_assemble.c:47
 msgid "\t 2. testing 3d assembling"
-msgstr ""
+msgstr "\t 2. тестирование 3d assembling"
 #: ../lib/gpde/test/test_assemble.c:51
 msgid ""
 "\n"
 "-- Assembling unit tests failure --"
 msgstr ""
+"\n"
+"-- Тестирование единицы Assembling окончилось неудачно --"
 #: ../lib/gpde/test/test_assemble.c:53
 msgid ""
 "\n"
 "-- Assembling unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- Тестирование единицы Assembling завершено успешно --"
 #: ../lib/gpde/test/test_gradient.c:42
 msgid ""
 "\n"
 "++ Running gradient unit tests ++"
 msgstr ""
+"\n"
+"++ Запуск тестирования единицы gradient ++"
 #: ../lib/gpde/test/test_gradient.c:44
 msgid "\t 1. testing 2d gradient"
-msgstr ""
+msgstr "\t 1. тестирование 2d gradient"
 #: ../lib/gpde/test/test_gradient.c:47
 msgid "\t 2. testing 3d gradient"
-msgstr ""
+msgstr "\t 2. тестирование 3d gradient"
 #: ../lib/gpde/test/test_gradient.c:51
 msgid ""
 "\n"
 "-- Gradient unit tests failure --"
 msgstr ""
+"\n"
+"-- Тестирование единицы Gradient окончилось неудачно --"
 #: ../lib/gpde/test/test_gradient.c:53
 msgid ""
 "\n"
 "-- Gradient unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- Тестирование единицы Gradient завершено успешно --"
 #: ../lib/gpde/test/test_solvers.c:37
 msgid ""
 "\n"
 "++ Running solver unit tests ++"
 msgstr ""
+"\n"
+"++ Запуск тестирования единицы solver ++"
 #: ../lib/gpde/test/test_solvers.c:42
 msgid ""
 "\n"
 "-- Solver unit tests failure --"
 msgstr ""
+"\n"
+"-- Тестирование единицы solver окончилось неудачно --"
 #: ../lib/gpde/test/test_solvers.c:44
 msgid ""
 "\n"
 "-- Solver unit tests finished successfully --"
 msgstr ""
+"\n"
+"-- Тестирование единицы solver завершено успешно --"
 #: ../lib/gpde/N_solvers_classic_iter.c:57
 #: ../lib/gpde/N_solvers_classic_iter.c:94 ../lib/gpde/N_solvers.c:55
@@ -294,55 +351,62 @@
 #: ../lib/gpde/N_solvers_krylov.c:78 ../lib/gpde/N_solvers_krylov.c:255
 #: ../lib/gpde/N_solvers_krylov.c:423 ../lib/gpde/N_solvers_krylov.c:832
 msgid "The linear equation system is not quadratic"
-msgstr ""
+msgstr "Система линейных уравнения не квадратная"
 #: ../lib/gpde/N_solvers_classic_iter.c:152
 #, c-format
 msgid "sparse Jacobi -- iteration %5i error %g\n"
-msgstr ""
+msgstr "разряженность Jacobi -- итерация %5i ошибка %g\n"
 #: ../lib/gpde/N_solvers_classic_iter.c:154
 #, c-format
 msgid "sparse SOR -- iteration %5i error %g\n"
-msgstr ""
+msgstr "разряженность SOR -- итерация %5i ошибка %g\n"
 #: ../lib/gpde/N_solvers_classic_iter.c:197
 #, c-format
 msgid "Jacobi -- iteration %5i error %g\n"
-msgstr ""
+msgstr "Jacobi -- итерация %5i ошибка %g\n"
 #: ../lib/gpde/N_solvers_classic_iter.c:235
 #, c-format
 msgid "SOR -- iteration %5i error %g\n"
-msgstr ""
+msgstr "SOR -- итерация %5i ошибка %g\n"
 #: ../lib/gpde/N_parse_options.c:58
 msgid ""
 "The type of solver which should solve the symmetric linear equation system"
 msgstr ""
+"Этот тип алгоритма должен использоваться для симметричных систем линейных "
+"уравнений"
 #: ../lib/gpde/N_parse_options.c:69
 msgid "The type of solver which should solve the linear equation system"
-msgstr ""
+msgstr "Этот тип алгоритма должен использоваться для систем линейных уравнений"
 #: ../lib/gpde/N_parse_options.c:77
 msgid "Maximum number of iteration used to solver the linear equation system"
 msgstr ""
+"Максимальное количество итераций для решения системы линейных уравнений"
 #: ../lib/gpde/N_parse_options.c:85
 msgid ""
 "Error break criteria for iterative solvers (jacobi, sor, cg or bicgstab)"
 msgstr ""
+"Критерий ошибки прерывания для итерационных алгоритмов (jacobi, sor, cg или "
+"bicgstab)"
 #: ../lib/gpde/N_parse_options.c:93
 msgid ""
 "The relaxation parameter used by the jacobi and sor solver for speedup or "
 "stabilizing"
 msgstr ""
+"Параметр релакции используемый алгоритмами jacobi и sor для ускорения или "
+"стабилизации"
 #: ../lib/gpde/N_parse_options.c:100
 msgid "The calculation time in seconds"
-msgstr ""
+msgstr "Время расчета в секундах"
 #: ../lib/gpde/N_arrays_io.c:55 ../lib/gis/legal_name.c:94
 #: ../lib/gis/legal_name.c:97 ../lib/gis/opencell.c:967
@@ -350,235 +414,232 @@
 #: ../lib/ogsf/Gs3.c:284 ../lib/ogsf/Gs3.c:357 ../lib/ogsf/Gs3.c:472
 #: ../lib/ogsf/Gs3.c:568 ../lib/ogsf/Gs3.c:635 ../lib/ogsf/Gs3.c:692
 #: ../lib/ogsf/Gs3.c:761 ../lib/ogsf/Gs3.c:829 ../lib/ogsf/Gp3.c:54
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> not found"
-msgstr "вектор  "
+msgstr "Растровый слой <%s> не найден"
 #: ../lib/gpde/N_arrays_io.c:67 ../lib/ogsf/Gs3.c:137 ../lib/ogsf/Gs3.c:211
 #: ../lib/ogsf/Gs3.c:368 ../lib/ogsf/Gs3.c:483 ../lib/ogsf/Gs3.c:573
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open raster map <%s>"
-msgstr " "
+msgstr "Невозможно открыть растровый слой <%s>"
 #: ../lib/gpde/N_arrays_io.c:96
-#, fuzzy, c-format
+#, c-format
 msgid "Reading raster map <%s> into memory"
-msgstr " Растровая карта %s@%s пуста"
+msgstr "Чтение растрового слоя <%s> в память"
 #: ../lib/gpde/N_arrays_io.c:103
-#, fuzzy
 msgid "Could not get raster row"
-msgstr " "
+msgstr "Невозможно получить строку растра "
 #: ../lib/gpde/N_arrays_io.c:161 ../lib/gpde/N_arrays_io.c:243
-#, fuzzy
 msgid "Unable to close input map"
-msgstr "Не могу открыть [%s]"
+msgstr "Невозможно закрыть исходный слой"
 #: ../lib/gpde/N_arrays_io.c:190
 msgid "N_array_2d * array is empty"
-msgstr ""
+msgstr "N_array_2d * пустой массив"
 #: ../lib/gpde/N_arrays_io.c:202
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create raster map <%s>"
-msgstr " "
+msgstr "Невозможно создать растровый слой <%s>"
 #: ../lib/gpde/N_arrays_io.c:211
 #, c-format
 msgid "Write 2d array to raster map <%s>"
-msgstr ""
+msgstr "Записать 2d массив в растровый слой <%s>"
 #: ../lib/gpde/N_arrays_io.c:227 ../lib/gpde/N_arrays_io.c:232
 #: ../lib/gpde/N_arrays_io.c:237
 #, fuzzy, c-format
 msgid "Unable to write raster row %i"
-msgstr "карта [%s] - невозможно записать строку %d"
+msgstr "Невозможно записать строку растра %i"
 #: ../lib/gpde/N_arrays_io.c:295
 #, c-format
 msgid "Requested g3d map <%s> not found"
-msgstr ""
+msgstr "Запрашиваемый g3d слой <%s> не найден"
 #: ../lib/gpde/N_arrays_io.c:303 ../lib/gpde/N_arrays_io.c:445
 #, c-format
 msgid "Error opening g3d map <%s>"
-msgstr ""
+msgstr "Ошибка открытия g3d слоя <%s>"
 #: ../lib/gpde/N_arrays_io.c:331
 #, c-format
 msgid "Read g3d map <%s> into the memory"
-msgstr ""
+msgstr "Загрузить g3d слой <%s> в память"
 #: ../lib/gpde/N_arrays_io.c:386 ../lib/gpde/N_arrays_io.c:486
 msgid "Error closing g3d file"
-msgstr ""
+msgstr "Ошибка закрытия g3d файла"
 #: ../lib/gpde/N_arrays_io.c:447
 #, c-format
 msgid "Write 3d array to g3d map <%s>"
-msgstr ""
+msgstr "Записать 3d массив в g3d слой <%s>"
 #: ../lib/gpde/N_solvers.c:50
 msgid "The gauss elimination solver does not work with sparse matrices"
-msgstr ""
+msgstr "Алгоритм гауссова исключения не работает с разряженными матрицами"
 #: ../lib/gpde/N_solvers.c:60
 msgid "Starting direct gauss elimination solver"
-msgstr ""
+msgstr "Запуск алгоритма прямого гауссова исключения"
 #: ../lib/gpde/N_solvers.c:88
 msgid "The lu solver does not work with sparse matrices"
-msgstr ""
+msgstr "Алгоритм lu не работает с разряженными матрицами"
 #: ../lib/gpde/N_solvers.c:98
 msgid "Starting direct lu decomposition solver"
-msgstr ""
+msgstr "Запуск алгоритма lu-декомпозиции"
 #: ../lib/gpde/N_solvers.c:155
 msgid "The cholesky solver does not work with sparse matrices"
-msgstr ""
+msgstr "Алгоритм cholesky не работает с разряженными матрицами"
 #: ../lib/gpde/N_solvers.c:166 ../lib/gpde/N_solvers_krylov.c:84
 #: ../lib/gpde/N_solvers_krylov.c:261
-#, fuzzy
 msgid "Matrix is not symmetric!"
-msgstr " "
+msgstr "Матрица не симметрична! "
 #: ../lib/gpde/N_solvers.c:170
 msgid "Starting cholesky decomposition solver"
-msgstr ""
+msgstr "Запуск алгоритма cholesky-декомпозиции"
 #: ../lib/gpde/N_solvers.c:173 ../lib/gpde/N_solvers_krylov.c:190
 #: ../lib/gpde/N_solvers_krylov.c:357 ../lib/gpde/N_solvers_krylov.c:481
 msgid "Unable to solve the linear equation system"
-msgstr ""
+msgstr "Невозможно решить систему линейных уравнений"
 #: ../lib/gpde/N_solvers_krylov.c:198
 #, c-format
 msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr ""
+msgstr "рязряженность PCG -- итерация %i ошибка  %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:200
 #, c-format
 msgid "PCG -- iteration %i error  %g\n"
-msgstr ""
+msgstr "PCG -- итерация %i ошибка %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:365
 #, c-format
 msgid "Sparse CG -- iteration %i error  %g\n"
-msgstr ""
+msgstr "Разряженность CG -- итерация %i ошибка %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:367
 #, c-format
 msgid "CG -- iteration %i error  %g\n"
-msgstr ""
+msgstr "CG -- итерация %i ошибка %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:530
 #, c-format
 msgid "Sparse BiCGStab -- iteration %i error  %g\n"
-msgstr ""
+msgstr "Разряженность BiCGStab -- итерация %i ошибка %g\n"
 #: ../lib/gpde/N_solvers_krylov.c:533
 #, c-format
 msgid "BiCGStab -- iteration %i error  %g\n"
-msgstr ""
+msgstr "BiCGStab -- итерация %i ошибка %g\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:25
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'.\n"
-msgstr "Неправильное имя таблицы <%s>. Не должно содержать '.' или 'NULL'"
+msgstr "Неправильное имя таблицы <%s>. Не должно содержать '.' или 'NULL'.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:33
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. Must start with a letter.\n"
-msgstr "Неправильное имя таблицы <%s>. Должно начинаться с буквы"
+msgstr "Неправильное имя таблицы <%s>. Должно начинаться с буквы.\n"
 #: ../lib/db/dbmi_base/legal_dbname.c:43
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal table map name <%s>. Character <%c> not allowed.\n"
-msgstr "Неправильное имя таблицы <%s>. Символ <%c> использовать нельзя"
+msgstr "Неправильное имя таблицы <%s>. Символ <%c> использовать нельзя.\n"
 #: ../lib/db/dbmi_client/copy_tab.c:100 ../lib/db/dbmi_client/copy_tab.c:120
 #: ../lib/db/dbmi_client/db.c:41
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to start driver <%s>"
-msgstr "Невозможно открыть файл %s в %s"
+msgstr "Невозможен запуск драйвера <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:105 ../lib/db/dbmi_client/copy_tab.c:126
 #: ../lib/db/dbmi_client/db.c:46 ../lib/db/dbmi_client/delete_tab.c:49
 #: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/map.c:269
 #: ../lib/vector/Vlib/map.c:404 ../lib/vector/Vlib/map.c:616
 #: ../lib/vector/Vlib/net.c:185 ../lib/vector/Vlib/net.c:355
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open database <%s> by driver <%s>"
-msgstr " "
+msgstr "Невозможно открыть БД <%s> с помощью драйвера <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:144
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to get list tables in database <%s>"
-msgstr "невозможно открыть файл таблицы эллипсоидов: %s"
+msgstr "Невозможно получить список таблиц базы данных <%s>"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "Таблица <%s> уже присутствует в базе данных <%s>"
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open select cursor: '%s'"
-msgstr " "
+msgstr "Невозможно открыть выбранный курсор: '%s'"
 #: ../lib/db/dbmi_client/copy_tab.c:231
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> is not integer"
-msgstr "Невозможно описать таблицу <%s>"
+msgstr "Поле <%s> не целочисленное"
 #: ../lib/db/dbmi_client/copy_tab.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> not found"
+msgstr "Поле <%s> не найдено"
 #: ../lib/db/dbmi_client/copy_tab.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create table <%s>"
+msgstr "Невозможно создать таблицу <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:295
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to fetch data from table <%s>"
+msgstr "Невозможно получить данные из таблицы <%s>"
 #: ../lib/db/dbmi_client/copy_tab.c:351
 #, c-format
 msgid "Unknown column type (column <%s>)"
-msgstr ""
+msgstr "Неизвестный тип поля (поле <%s>)"
 #: ../lib/db/dbmi_client/select.c:279
-#, fuzzy, c-format
+#, c-format
 msgid "Unable select records from table <%s>"
-msgstr "Невозможно создать файл заголовка для [%s в %s]"
+msgstr "Невозможно выбрать записи из таблицы <%s>"
 #: ../lib/db/dbmi_client/delete_tab.c:44
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open driver <%s>"
+msgstr "Невозможно открыть драйвер <%s>"
 #: ../lib/db/dbmi_client/delete_tab.c:62
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to drop table: '%s'"
+msgstr "Невозможно удалить таблицу: '%s'"
 #: ../lib/db/dbmi_client/column.c:110
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to describe table <%s>"
+msgstr "Невозможно описать таблицу <%s>"
 #: ../lib/db/dbmi_client/table.c:46
-#, fuzzy, c-format
+#, c-format
 msgid "Unable open database <%s> by driver <%s>"
-msgstr " "
+msgstr "Невозможно открыть базу данных <%s> с помощью драйвера <%s>"
 #: ../lib/driver/parse_ftcap.c:32
 #, c-format
@@ -594,17 +655,17 @@
 #: ../lib/arraystats/class.c:21
 msgid "Discont algorithm currently not available because of bugs"
-msgstr ""
+msgstr "Алгоритм Discont недоступен из-за ошибок"
 #: ../lib/arraystats/class.c:23
 #, c-format
 msgid "%s: Unknown algorithm"
-msgstr ""
+msgstr "%s: Неизвестный алгоритм"
 #: ../lib/arraystats/class.c:26
 #, c-format
 msgid "%s: Error in classification algorithm"
-msgstr ""
+msgstr "%s: Ошибка в алгоритме классификации"
 #: ../lib/arraystats/class.c:221
 #, c-format
@@ -612,6 +673,8 @@
 "There are classbreaks outside the range min-max. Number of classes reduced "
 "to %i, but using probabilities for %i classes."
 msgstr ""
+"Границы классов вне диапазона минимум-максимум. Число классов уменьшено до %"
+"i, используются вероятности для %i классов."
 #: ../lib/pngdriver/Graph_set.c:72
 #, c-format
@@ -629,132 +692,125 @@
 msgstr ""
 #: ../lib/vector/diglib/spindex.c:248
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete node %d from spatial index"
+msgstr "Невозможно удалить узел %d из пространственного индекса"
 #: ../lib/vector/diglib/spindex.c:288
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete line %d from spatial index"
+msgstr "Невозможно удалить линию %d из пространственного индекса"
 #: ../lib/vector/diglib/spindex.c:314
 msgid "Attempt to delete sidx for dead area"
-msgstr ""
+msgstr "Попытка удалить sidx для уже удаленного полигона"
 #: ../lib/vector/diglib/spindex.c:327
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete area %d from spatial index"
+msgstr "Невозможно удалить полигон %d из пространственного индекса"
 #: ../lib/vector/diglib/spindex.c:362
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete isle %d from spatial index"
+msgstr "Невозможно удалить остров %d из пространственного индекса"
 #: ../lib/vector/diglib/plus_area.c:195 ../lib/vector/diglib/plus_area.c:651
 #: ../lib/vector/diglib/plus_area.c:659
 #, c-format
 msgid "Line %d already has area/isle %d to left"
-msgstr ""
+msgstr "У линии %d уже есть полигон/остров %d слева"
 #: ../lib/vector/diglib/plus_area.c:205
 #, c-format
 msgid "Line %d already has area/isle %d to right"
-msgstr ""
+msgstr "У линии %d уже есть полигон/остров %d справа"
 #: ../lib/vector/diglib/plus_area.c:287
 msgid "Attempt to delete isle from dead area"
-msgstr ""
+msgstr "Попытка удалить остров из уже удаленного полигона"
 #: ../lib/vector/diglib/plus_area.c:304
 #, c-format
 msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
+msgstr "Попытка удалить незарегистрированный остров %d из полигона %d"
 #: ../lib/vector/diglib/plus_area.c:342
 msgid "Attempt to delete dead area"
-msgstr ""
+msgstr "Попытка удалить уже удаленный полигон"
 #: ../lib/vector/diglib/plus_area.c:382
 #, c-format
 msgid "Dead centroid %d registered for area (bug in the vector library)"
 msgstr ""
+"Для полигона зарегистрирован удаленный центроид %d (баг в векторной "
+"библиотеке)"
 #: ../lib/vector/diglib/plus_area.c:406
 #, c-format
 msgid "Attempt to delete area %d info from dead isle %d"
-msgstr ""
+msgstr "Попытка удалить информацию о полигоне %d из уже удаленного острова %d"
 #: ../lib/vector/diglib/plus_area.c:749
 #, c-format
 msgid "Attempt to delete isle %d info from dead area %d"
-msgstr ""
+msgstr "Попытка удалить информацию об острове %d из уже удаленного полигона %d"
 #: ../lib/vector/diglib/plus.c:288
-#, fuzzy
 msgid "Unable read topology for nodes"
-msgstr "Невозможно прочесть гистограмму для [%s в %s]"
+msgstr "Невозможно прочесть топологию для узлов"
 #: ../lib/vector/diglib/plus.c:293
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read topology for node %d"
+msgstr "Невозможно прочесть топологию для узла %d"
 #: ../lib/vector/diglib/plus.c:298
-#, fuzzy
 msgid "Unable read topology for lines"
+msgstr "Невозможно прочесть топологию для линий"
 #: ../lib/vector/diglib/plus.c:303
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read topology for line %d"
+msgstr "Невозможно прочесть топологию для линии %d"
 #: ../lib/vector/diglib/plus.c:308
-#, fuzzy
 msgid "Unable to read topo for areas"
-msgstr " "
+msgstr "Невозможно прочитать топо для полигонов"
 #: ../lib/vector/diglib/plus.c:313
-#, fuzzy, c-format
+#, c-format
 msgid "Unable read topology for area %d"
+msgstr "Невозможно прочесть топологию для полигона %d"
 #: ../lib/vector/diglib/plus.c:318
-#, fuzzy
 msgid "Unable to read topology for isles"
-msgstr "Не могу открыть врем. файл"
+msgstr "Невозможно прочитать топологию для островов"
 #: ../lib/vector/diglib/plus.c:323
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read topology for isle %d"
+msgstr "Невозможно прочесть гистограмму для острова %d"
 #: ../lib/vector/diglib/plus.c:345 ../lib/vector/diglib/plus.c:371
-#, fuzzy
 msgid "Unable to write head to plus file"
+msgstr "Невозможно записать заголовок для плюс-файла"
 #: ../lib/vector/diglib/plus.c:350
-#, fuzzy
 msgid "Unable to write nodes to plus file"
-msgstr "невозможно записать quant файл!"
+msgstr "Невозможно записать узлы в плюс-файл"
 #: ../lib/vector/diglib/plus.c:355
-#, fuzzy
 msgid "Unable to write lines to plus file"
+msgstr "Невозможно записать линии в плюс-файл"
 #: ../lib/vector/diglib/plus.c:360
-#, fuzzy
 msgid "Unable to write areas to plus file"
+msgstr "Невозможно записать полигоны в плюс-файл"
 #: ../lib/vector/diglib/plus.c:365
-#, fuzzy
 msgid "Unable to write isles to plus file"
+msgstr "Невозможно записать острова в плюс-файл"
 #: ../lib/vector/diglib/plus_node.c:217
 #, c-format
@@ -762,355 +818,359 @@
 "Attempt to read line angle for the line which is not connected to the node: "
 "node %d, line %d"
 msgstr ""
+"Попытка считать угол линии, которая не соединена с узлом: узел %d, линия %d"
 #: ../lib/vector/vedit/select.c:235
-#, fuzzy
 msgid "Unknown query tool"
-msgstr "неизвестная ошибка"
+msgstr "Неизвестный инструмент запроса"
 #: ../lib/vector/vedit/cats.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to set category %d for line %d"
-msgstr "вектор  "
+msgstr "Невозможно установить категорию %d для линии %d"
 #: ../lib/vector/vedit/cats.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete layer/category %d/%d line %d"
-msgstr " "
+msgstr "Невозможно удалить слой/категорию %d/%d линии %d"
 #: ../lib/vector/Vlib/build.c:31 ../lib/vector/Vlib/open.c:40
 #: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/read.c:30
 #: ../lib/vector/Vlib/rewind.c:36 ../lib/vector/Vlib/write.c:53
 #: ../lib/vector/Vlib/write.c:59
-#, fuzzy
 msgid "Requested format is not compiled in this version"
-msgstr " "
+msgstr "Запрашиваемый формат для этой версии не скомпилирован ."
 #: ../lib/vector/Vlib/build.c:144
-#, fuzzy, c-format
+#, c-format
 msgid "Building topology for vector map <%s>...\n"
-msgstr "вектор    "
+msgstr "Построение топологии для векторного слоя  <%s>...\n"
 #: ../lib/vector/Vlib/build.c:160
 msgid "Topology was built\n"
-msgstr ""
+msgstr "Топология построена\n"
 #: ../lib/vector/Vlib/build.c:172
 #, c-format
 msgid "Number of nodes     :   %d\n"
-msgstr ""
+msgstr "Количество узлов     :   %d\n"
 #: ../lib/vector/Vlib/build.c:173
 #, c-format
 msgid "Number of primitives:   %d\n"
-msgstr ""
+msgstr "Количество примитивов:   %d\n"
 #: ../lib/vector/Vlib/build.c:174
 #, c-format
 msgid "Number of points    :   %d\n"
-msgstr ""
+msgstr "Количество точек    :   %d\n"
 #: ../lib/vector/Vlib/build.c:175
 #, c-format
 msgid "Number of lines     :   %d\n"
-msgstr ""
+msgstr "Количество линий     :   %d\n"
 #: ../lib/vector/Vlib/build.c:176
 #, c-format
 msgid "Number of boundaries:   %d\n"
-msgstr ""
+msgstr "Количество границ:   %d\n"
 #: ../lib/vector/Vlib/build.c:177
 #, c-format
 msgid "Number of centroids :   %d\n"
-msgstr ""
+msgstr "Количество центроидов :   %d\n"
 #: ../lib/vector/Vlib/build.c:180
 #, c-format
 msgid "Number of faces     :   %d\n"
-msgstr ""
+msgstr "Количество граней     :   %d\n"
 #: ../lib/vector/Vlib/build.c:183
 #, c-format
 msgid "Number of kernels   :   %d\n"
-msgstr ""
+msgstr "Количество ядер   :   %d\n"
 #: ../lib/vector/Vlib/build.c:223
 #, c-format
 msgid "Number of areas     :   %d\n"
-msgstr ""
+msgstr "Количество полигонов     :   %d\n"
 #: ../lib/vector/Vlib/build.c:224
 #, c-format
 msgid "Number of isles     :   %d\n"
-msgstr ""
+msgstr "Количество островов     :   %d\n"
 #: ../lib/vector/Vlib/build.c:227
 #, c-format
 msgid "Number of incorrect boundaries   :   %d\n"
-msgstr ""
+msgstr "Количество неправильных границ   :   %d\n"
 #: ../lib/vector/Vlib/build.c:231
 #, c-format
 msgid "Number of centroids outside area :   %d\n"
-msgstr ""
+msgstr "Количество центроидов вне полигонов :   %d\n"
 #: ../lib/vector/Vlib/build.c:235
 #, c-format
 msgid "Number of duplicate centroids    :   %d\n"
-msgstr ""
+msgstr "Количество центроидов-дупликатов    :   %d\n"
 #: ../lib/vector/Vlib/build.c:239
 #, c-format
 msgid "Number of areas without centroid :   %d\n"
-msgstr ""
+msgstr "Количество полигонов без центроидов :   %d\n"
 #: ../lib/vector/Vlib/build.c:244
 msgid "Number of areas     :   -\n"
-msgstr ""
+msgstr "Количество полигонов     :   -\n"
 #: ../lib/vector/Vlib/build.c:245
 msgid "Number of isles     :   -\n"
-msgstr ""
+msgstr "Количество островов     :   -\n"
 #: ../lib/vector/Vlib/build.c:274
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open topo file for write <%s>"
-msgstr " "
+msgstr " Невозможно открыть топо-файл для записи <%s>"
 #: ../lib/vector/Vlib/build.c:282
-#, fuzzy
 msgid "Error writing out topo file"
-msgstr "Ошибка записи в файл с плавающей точкой для карты %s"
+msgstr "Ошибка записи топо файла"
 #: ../lib/vector/Vlib/build.c:425
-#, fuzzy, c-format
+#, c-format
 msgid "Unable open spatial index file for write <%s>"
-msgstr " "
+msgstr "Невозможно открыть для записи пространственный индекс <%s>"
 #: ../lib/vector/Vlib/build.c:433
-#, fuzzy
 msgid "Error writing out spatial index file"
+msgstr "Ошибка записи файл пространственного индекса"
 #: ../lib/vector/Vlib/intersect.c:127
 msgid "3D not supported by Vect_segment_intersection()"
-msgstr ""
+msgstr "Vect_segment_intersection() не поддерживает 3D"
 #: ../lib/vector/Vlib/intersect.c:322
 msgid "Vect_segment_intersection() ERROR (collinear vertical segments)"
 msgstr ""
+"Ошибка Vect_segment_intersection() (коллинеарные вертикальные сегменты)"
 #: ../lib/vector/Vlib/intersect.c:448
 msgid "Vect_segment_intersection() ERROR (collinear non vertical segments)"
 msgstr ""
+"Ошибка Vect_segment_intersection() (коллинеарные не вертикальные сегменты)"
 #: ../lib/vector/Vlib/open.c:100
 #, c-format
 msgid "Programmer requested unknown open level %d"
-msgstr ""
+msgstr "Programmer requested unknown open level %d"
 #: ../lib/vector/Vlib/open.c:168 ../lib/vector/Vlib/legal_vname.c:118
 #: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/map.c:326
 #: ../lib/ogsf/Gv3.c:57 ../lib/ogsf/Gp3.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> not found"
-msgstr "вектор  "
+msgstr "Векторный слой <%s> не найден"
 #: ../lib/vector/Vlib/open.c:179
-#, fuzzy
 msgid ""
 "Vector map which is not in the current mapset cannot be opened for update"
-msgstr " ."
+msgstr ""
+"Векторный слой не находится в текущем наборе и не может быть открыт для "
+"обновления"
 #: ../lib/vector/Vlib/open.c:199 ../lib/ogsf/Gv3.c:63 ../lib/ogsf/Gp3.c:115
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector map <%s>"
-msgstr " "
+msgstr "Невозможно открыть векторный слой <%s>"
 #: ../lib/vector/Vlib/open.c:211 ../lib/vector/Vlib/open.c:279
 #: ../lib/vector/Vlib/open.c:299
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to open vector map <%s> on level %d. Try to rebuild vector topology "
 "by v.build."
-msgstr "вектор  "
+msgstr ""
+"Невозможно открыть векторный слой <%s> на уровне %d. Попробуйте перестроить "
+"векторную топологию с помощью v.build."
 #: ../lib/vector/Vlib/open.c:214
-#, fuzzy
 msgid "Unable to read head file"
+msgstr "Не могу открыть файл заголовка"
 #: ../lib/vector/Vlib/open.c:236
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open topology file for vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл топологии для векторного слоя <%s>"
 #: ../lib/vector/Vlib/open.c:262
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open category index file for vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл индекса категорий для векторного слоя <%s>"
 #: ../lib/vector/Vlib/open.c:353 ../lib/vector/Vlib/open.c:576
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open history file for vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл истории для векторного слоя <%s>"
 #: ../lib/vector/Vlib/open.c:531
-#, fuzzy, c-format
+#, c-format
 msgid "%s is not in the current mapset (%s)"
-msgstr "в текущем наборе файлы %s недоступны\n"
+msgstr "в текущем наборе (%s) файлов %s нет"
 #: ../lib/vector/Vlib/open.c:540 ../lib/vector/Vlib/map.c:176
 #: ../lib/vector/Vlib/map.c:313
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map name is not SQL compliant"
-msgstr " ."
+msgstr "Имя векторного слоя не SQL-совместимо"
 #: ../lib/vector/Vlib/open.c:547 ../lib/vector/Vlib/map.c:187
 #: ../lib/vector/Vlib/map.c:317
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> already exists and will be overwritten"
-msgstr "вектор  ."
+msgstr "Векторный слой <%s> уже существует и будет перезаписан"
 #: ../lib/vector/Vlib/open.c:552 ../lib/vector/Vlib/map.c:191
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete vector map <%s>"
-msgstr " "
+msgstr "Невозможно удалить векторный слой <%s>"
 #: ../lib/vector/Vlib/open.c:566
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create vector map <%s>"
-msgstr " "
+msgstr "Невозможно создать векторный слой <%s>"
 #: ../lib/vector/Vlib/open.c:622
 #, fuzzy, c-format
 msgid "Unable to stat file <%s>"
+msgstr "Невозможно открыть файл статистики <%s>"
 #: ../lib/vector/Vlib/open.c:731
 msgid "Size of 'coor' file differs from value saved in topology file"
 msgstr ""
+"Размер файла 'coor' отличается от значения сохраненного в файле топологии"
 #: ../lib/vector/Vlib/open.c:742
-#, fuzzy, c-format
+#, c-format
 msgid "Please rebuild topology for vector map <%s@%s>"
-msgstr "вектор    "
+msgstr "Пожалуйста, перестройте топологию для векторного слоя <%s@%s>"
 #: ../lib/vector/Vlib/snap.c:124 ../lib/vector/Vlib/snap.c:170
 #: ../lib/vector/Vlib/break_polygons.c:214
 #: ../lib/vector/Vlib/break_polygons.c:221
 msgid "Registering points"
-msgstr ""
+msgstr "Регистрация точек"
 #: ../lib/vector/Vlib/snap.c:180
 msgid "All vertices"
-msgstr ""
+msgstr "Все узлы"
 #: ../lib/vector/Vlib/snap.c:181
 msgid "Registered points"
-msgstr ""
+msgstr "Зарегистрированные точки"
 #: ../lib/vector/Vlib/snap.c:230
 msgid "Nodes marked as anchor"
-msgstr ""
+msgstr "Узлы отмеченные как якоря"
 #: ../lib/vector/Vlib/snap.c:232
 msgid "Nodes marked to be snapped"
-msgstr ""
+msgstr "Узлы отмеченные для прилипания"
 #: ../lib/vector/Vlib/snap.c:243 ../lib/vector/Vlib/snap.c:412
 msgid "Snaps"
-msgstr ""
+msgstr "Прилипание"
 #: ../lib/vector/Vlib/snap.c:421
 msgid "Snapped vertices"
-msgstr ""
+msgstr "Прилепленные вершины"
 #: ../lib/vector/Vlib/snap.c:423
 msgid "New vertices"
-msgstr ""
+msgstr "Новые узлы"
 #: ../lib/vector/Vlib/close.c:134
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close vector <%s>"
-msgstr " "
+msgstr "Невозможно закрыть векторный слой <%s>"
 #: ../lib/vector/Vlib/legal_vname.c:48
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
-msgstr "вектор  "
+msgstr ""
+"Неправильное имя векторного слоя <%s>. Не должно содержать '.' или 'NULL'."
 #: ../lib/vector/Vlib/legal_vname.c:55
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal vector map name <%s>. Must start with a letter."
-msgstr "вектор  "
+msgstr "Неправильное имя векторного слоя <%s>. Должно начинаться с буквы."
 #: ../lib/vector/Vlib/legal_vname.c:63
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal vector map name <%s>. Character '%c' not allowed."
-msgstr "вектор  "
+msgstr "Неправильное имя векторного слоя <%s>. Символ '%c' не разрешен."
 #: ../lib/vector/Vlib/legal_vname.c:70
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Illegal vector map name <%s>. SQL keyword cannot be used as vector map name."
-msgstr "вектор  "
+msgstr ""
+"Неправильное имя векторного слоя <%s>. Ключевое слово SQL не может быть "
+"использовано в имени."
 #: ../lib/vector/Vlib/legal_vname.c:101 ../lib/vector/Vlib/legal_vname.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Output vector map name <%s> is not valid map name"
-msgstr "   ."
+msgstr "Неправильное имя выходного векторного слоя <%s>"
 #: ../lib/vector/Vlib/legal_vname.c:142 ../lib/vector/Vlib/legal_vname.c:146
-#, fuzzy, c-format
+#, c-format
 msgid "Output vector map <%s> is used as input"
-msgstr "   "
+msgstr "Выходной векторный слой <%s> используется как исходный"
 #: ../lib/vector/Vlib/cindex.c:31
 msgid "Category index is not up to date"
-msgstr ""
+msgstr "Устаревший индекс категорий"
 #: ../lib/vector/Vlib/cindex.c:61 ../lib/vector/Vlib/cindex.c:125
 #: ../lib/vector/Vlib/cindex.c:143 ../lib/vector/Vlib/cindex.c:166
 msgid "Invalid layer index (index >= number of layers)"
-msgstr ""
+msgstr "Неправильный индекс слоя (индекс >= число слоев)"
 #: ../lib/vector/Vlib/cindex.c:107
 msgid "Invalid layer index (index < 0 or index >= number of layers)"
-msgstr ""
+msgstr "Неправильный индекс слоя (индекс < 0 или индекс >= число слоев)"
 #: ../lib/vector/Vlib/cindex.c:232
 msgid "Layer or category index out of range"
-msgstr ""
+msgstr "Индекс слоев или категорий вне диапазона"
 #: ../lib/vector/Vlib/cindex.c:283
 msgid "Layer index out of range"
-msgstr ""
+msgstr "Индекс слоя вне диапазона"
 #: ../lib/vector/Vlib/cindex.c:460
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open cidx file <%s> for write"
-msgstr "Невозможно открыть %s для записи"
+msgstr "Невозможно открыть cidx файл <%s> для записи"
 #: ../lib/vector/Vlib/cindex.c:468
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing out category index file <%s>"
+msgstr "Ошибка записи в файл индекса категорий <%s>"
 #: ../lib/vector/Vlib/cindex.c:511
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open category index file for vector map <%s@%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл индекса категорий для векторного слоя <%s@%s>"
 #: ../lib/vector/Vlib/clean_nodes.c:54 ../lib/vector/Vlib/clean_nodes.c:250
 msgid "Modifications"
-msgstr ""
+msgstr "Модификации"
 #: ../lib/vector/Vlib/read.c:99
-#, fuzzy
 msgid "vector map is not opened"
-msgstr "вектор  "
+msgstr "векторный слой не открыт"
 #: ../lib/vector/Vlib/read.c:102
 #, c-format
@@ -1118,25 +1178,27 @@
 "Vect_read_line(): feature id %d is not reasonable (max features in vector "
 "map <%s>: %d)"
 msgstr ""
+"Vect_read_line(): линия с id %d невозможна (максимальное количество объектом "
+"в векторном слое <%s>: %d)"
 #: ../lib/vector/Vlib/dangles.c:173 ../lib/vector/Vlib/dangles.c:272
 #: ../lib/vector/Vlib/dangles.c:284
 msgid "Removed dangles:"
-msgstr ""
+msgstr "Удаленные висящие узлы"
 #: ../lib/vector/Vlib/array.c:98
 #, c-format
 msgid "%d errors in category string."
-msgstr ""
+msgstr "%d ошибок в строке категории."
 #: ../lib/vector/Vlib/array.c:143 ../lib/vector/Vlib/array.c:267
 msgid "Mixed area and other type requested for vector array"
-msgstr ""
+msgstr "Для векторного массива запрашивается смешанный тип объектов"
 #: ../lib/vector/Vlib/array.c:153 ../lib/vector/Vlib/array.c:176
 #: ../lib/vector/Vlib/array.c:301 ../lib/vector/Vlib/array.c:334
 msgid "Not enough space in vector array"
-msgstr ""
+msgstr "Недостаточно места в векторном массиве"
 #: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/map.c:241
 #: ../lib/vector/Vlib/map.c:363 ../lib/vector/Vlib/map.c:469
@@ -1144,190 +1206,189 @@
 #: ../lib/vector/Vlib/net.c:179 ../lib/vector/Vlib/net.c:350
 #, c-format
 msgid "Database connection not defined for layer %d"
-msgstr ""
+msgstr "Для слоя %d не определено соединение с базой данных"
 #: ../lib/vector/Vlib/array.c:292
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr "Невозможно выбрать записи из таблицы <%s> (ключ %s, где %s)"
 #: ../lib/vector/Vlib/break_lines.c:122
 #, c-format
 msgid "%s %5d"
-msgstr ""
+msgstr "%s %5d"
 #: ../lib/vector/Vlib/break_lines.c:122 ../lib/vector/Vlib/break_lines.c:366
 #: ../lib/vector/Vlib/break_lines.c:387
-#, fuzzy
 msgid "Intersections:"
-msgstr "Другая проекция"
+msgstr "Пересечения: "
 #: ../lib/vector/Vlib/break_polygons.c:223
 msgid "All points (vertices)"
-msgstr ""
+msgstr "Все точки (узлы)"
 #: ../lib/vector/Vlib/break_polygons.c:225
 msgid "Registered points (unique coordinates)"
-msgstr ""
+msgstr "Зарегистрированные точки (уникальные координаты)"
 #: ../lib/vector/Vlib/break_polygons.c:226
 msgid "Points marked for break"
-msgstr ""
+msgstr "Точки отмеченные для разрывов"
 #: ../lib/vector/Vlib/break_polygons.c:233
 #: ../lib/vector/Vlib/break_polygons.c:310
 #: ../lib/vector/Vlib/break_polygons.c:333
 msgid "Breaks"
-msgstr ""
+msgstr "Разрывы"
 #: ../lib/vector/Vlib/bridges.c:121 ../lib/vector/Vlib/bridges.c:202
 #: ../lib/vector/Vlib/bridges.c:209
 msgid "Removed bridges"
-msgstr ""
+msgstr "Удаление мостов"
 #: ../lib/vector/Vlib/poly.c:235
-#, fuzzy
 msgid "Unable to find point in polygon"
-msgstr "не могу найти [%s] в [%s]"
+msgstr "Невозможно найти точку в полигоне"
 #: ../lib/vector/Vlib/poly.c:649
-#, fuzzy
 msgid "conditions failed"
-msgstr "Нет подключения\n"
+msgstr "условие не выполнено"
 #: ../lib/vector/Vlib/cats.c:45
 msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
+msgstr "Vect_new_cats_struct(): Не хватает памяти"
 #: ../lib/vector/Vlib/cats.c:129
 #, c-format
 msgid "Too many categories (%d), unable to set cat %d (layer %d)"
 msgstr ""
+"Слишком много категорий (%d), невозможно установить категорию %d (слой %d)"
 #: ../lib/vector/Vlib/cats.c:376
 #, c-format
 msgid "Unable to convert category string '%s' (from '%s') to category range"
 msgstr ""
+"Невозможно сконвертировать строку категории '%s' (из '%s') в диапазон "
+"категорий"
 #: ../lib/vector/Vlib/sindex.c:97
 msgid "not implemented"
-msgstr ""
+msgstr "не предусмотрено"
 #: ../lib/vector/Vlib/sindex.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete item %d from spatial index"
+msgstr "Невозможно удалить запись %d из пространственного индекса"
 #: ../lib/vector/Vlib/sindex.c:127
 msgid ""
 "Unable to build spatial index from topology, vector map is not opened at "
 "topo level 2"
 msgstr ""
+"Невозможно построить пространственный индекс из топологии, векторный слой не "
+"открыт на втором топо уровне"
 #: ../lib/vector/Vlib/sindex.c:169
 msgid "BUG (Vect_build_sidx_from_topo): node does not exist"
-msgstr ""
+msgstr "Ошибка (Vect_build_sidx_from_topo): узел не существует"
 #: ../lib/vector/Vlib/sindex.c:181
 msgid "BUG (Vect_build_sidx_from_topo): line does not exist"
-msgstr ""
+msgstr "Ошибка (Vect_build_sidx_from_topo): линия не существует"
 #: ../lib/vector/Vlib/sindex.c:200
 msgid "BUG (Vect_build_sidx_from_topo): area does not exist"
-msgstr ""
+msgstr "Ошибка (Vect_build_sidx_from_topo): полигон не существует"
 #: ../lib/vector/Vlib/sindex.c:219
 msgid "BUG (Vect_build_sidx_from_topo): isle does not exist"
-msgstr ""
+msgstr "Баг (Vect_build_sidx_from_topo): остров не существует"
 #: ../lib/vector/Vlib/write_nat.c:50 ../lib/vector/Vlib/write_nat.c:83
 #, c-format
 msgid "%s: Area %d does not exist"
-msgstr ""
+msgstr "%s: Полигон %d не существует"
-#, fuzzy
+msgstr "Попытка удалить уже удаленный объект"
-#, fuzzy
+msgstr "Попытка восстановить нормальный объект"
 #: ../lib/vector/Vlib/level_two.c:296 ../lib/vector/Vlib/level_two.c:315
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> is not open on level >= 2"
-msgstr "вектор  "
+msgstr "Векторный слой <%s> не открыт на уровне >= 2"
 #: ../lib/vector/Vlib/graph.c:110 ../lib/vector/Vlib/net.c:432
 msgid "GngFlatten error"
-msgstr ""
+msgstr "ошибка GngFlatten"
 #: ../lib/vector/Vlib/graph.c:143
-#, fuzzy
 msgid "Unable to add network arc"
-msgstr " "
+msgstr "Невозможно добавить сетевую дугу"
 #: ../lib/vector/Vlib/graph.c:231 ../lib/vector/Vlib/net.c:509
 #, c-format
 msgid "dglShortestPath error: %s"
-msgstr ""
+msgstr "ошибка dglShortestPath : %s"
 #: ../lib/vector/Vlib/build_nat.c:96
 msgid "Unable to add area (map closed, topo saved)"
-msgstr ""
+msgstr "Невозможно добавить полигон (слой закрыт, топо сохранено)"
 #: ../lib/vector/Vlib/build_nat.c:105
 msgid "Unable to add isle (map closed, topo saved)"
-msgstr ""
+msgstr "Невозможно добавить остров (слой закрыт, топо сохранено)"
 #: ../lib/vector/Vlib/build_nat.c:115
 msgid "Area of size = 0.0 ignored"
-msgstr ""
+msgstr "Полигон площадью 0.0 пропущен"
 #: ../lib/vector/Vlib/build_nat.c:151
+#, fuzzy
 msgid "Request to find area outside nonexistent isle"
-msgstr ""
+msgstr "Попытка найти полигон вокруг несуществующего острова"
 #: ../lib/vector/Vlib/build_nat.c:510
 msgid "Registering primitives: "
-msgstr ""
+msgstr "Регистрируются примитивы:"
 #: ../lib/vector/Vlib/build_nat.c:520
-#, fuzzy
 msgid "Unable to read vector map"
-msgstr " "
+msgstr "Невозможно прочитать векторный слой"
 #: ../lib/vector/Vlib/build_nat.c:560
 msgid "primitives registered"
-msgstr ""
+msgstr "примитивов зарегистрировано"
 #: ../lib/vector/Vlib/build_nat.c:561
 msgid "vertices registered"
-msgstr ""
+msgstr "узлов зарегистрировано"
 #: ../lib/vector/Vlib/build_nat.c:572
 msgid "Building areas: "
-msgstr ""
+msgstr "Построение полигонов:"
 #: ../lib/vector/Vlib/build_nat.c:595
 msgid "areas built"
-msgstr ""
+msgstr "полигонов построено"
 #: ../lib/vector/Vlib/build_nat.c:596
 msgid "isles built"
-msgstr ""
+msgstr "островов создано"
 #: ../lib/vector/Vlib/build_nat.c:605
 msgid "Attaching islands: "
-msgstr ""
+msgstr "Назначаются острова:"
 #: ../lib/vector/Vlib/build_nat.c:622
 msgid "Attaching centroids: "
-msgstr ""
+msgstr "Назначаются центроиды:"
 #: ../lib/vector/Vlib/open_nat.c:145
 #, c-format
@@ -1335,6 +1396,8 @@
 "Coor files of vector map <%s@%s> is larger than it should be (%ld bytes "
 "excess)"
 msgstr ""
+"Файлы coor векторного слоя <%s@%s> больше, чем они должны быть (на %ld "
+"байтов)"
 #: ../lib/vector/Vlib/open_nat.c:149
 #, c-format
@@ -1342,89 +1405,89 @@
 "Coor files of vector <%s@%s> is shorter than it should be (%ld bytes "
 "missing)."
 msgstr ""
+"Файлы coor векторного слоя <%s@%s> меньше, чем они должны быть (на %ld "
+"байтов)"
 #: ../lib/vector/Vlib/build_ogr.c:275
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to calculate centroid for area %d"
-msgstr "Невозможно выделить память\n"
+msgstr "Невозможно рассчитать центроид для полигона %d"
 #: ../lib/vector/Vlib/build_ogr.c:312 ../lib/vector/Vlib/read_ogr.c:120
 #: ../lib/vector/Vlib/read_ogr.c:306
-#, fuzzy, c-format
+#, c-format
 msgid "OGR feature type %d not supported"
-msgstr " "
+msgstr "тип данных OGR %d не поддерживается"
 #: ../lib/vector/Vlib/build_ogr.c:337
 msgid "Partial build for OGR is not supported"
-msgstr ""
+msgstr "Частичные сборки OGR не поддерживаются"
 #: ../lib/vector/Vlib/build_ogr.c:348
 msgid ""
 "Random read is not supported by OGR for this layer, cannot build support"
-msgstr ""
+msgstr "Для этого слоя OGR не поддерживается cлучайное чтение"
 #: ../lib/vector/Vlib/build_ogr.c:355
-#, fuzzy
 msgid "Feature: "
-msgstr "Тип(ы) объекта(ов)"
+msgstr "Объект: "
 #: ../lib/vector/Vlib/build_ogr.c:373
 #, c-format
 msgid "Feature %d without geometry ignored"
-msgstr ""
+msgstr "Объект %d без геометрии проигнорирован"
 #: ../lib/vector/Vlib/build_ogr.c:380
 msgid "OGR feature without ID ignored"
-msgstr ""
+msgstr "OGR объект без ID проигнорирован"
 #: ../lib/vector/Vlib/level.c:38
-#, fuzzy
 msgid "Map structure was never initialized"
 msgstr "Векторная структура не иннициализирована"
 #: ../lib/vector/Vlib/level.c:40
 msgid "Map structure has been closed"
-msgstr ""
+msgstr "Структура карты закрыта"
 #: ../lib/vector/Vlib/area.c:53
 #, fuzzy
 msgid "Attempt to read points of nonexistent area"
+msgstr "Попытка получить точки из несуществующего полигона"
 #: ../lib/vector/Vlib/area.c:125
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read line %d"
+msgstr "Невозможно прочитать линию %d"
 #: ../lib/vector/Vlib/area.c:164 ../lib/vector/Vlib/area.c:193
 #: ../lib/vector/Vlib/area.c:257 ../lib/vector/Vlib/area.c:286
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to read topo for dead area (%d)"
+msgstr "Невозможно прочесть гистограмму для удаленного полигона (%d)"
 #: ../lib/vector/Vlib/area.c:313
-#, fuzzy, c-format
+#, c-format
 msgid "Attempt to read topo for dead isle (%d)"
+msgstr "Невозможно прочесть гистограмму для удаленного острова  (%d)"
 #: ../lib/vector/Vlib/open_ogr.c:53
 msgid "OGR format cannot be updated"
-msgstr ""
+msgstr "OGR формат не может быть обновлен"
 #: ../lib/vector/Vlib/open_ogr.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open OGR data source '%s'"
-msgstr " "
+msgstr "Невозможно открыть OGR источник данных '%s'"
 #: ../lib/vector/Vlib/open_ogr.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open layer <%s>"
+msgstr "Невозможно открыть слой <%s>"
 #: ../lib/vector/Vlib/open_ogr.c:129
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open fidx file for vector map <%s@%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть fidx файл для векторного слоя <%s@%s>"
 #: ../lib/vector/Vlib/open_ogr.c:147
 #, c-format
@@ -1432,6 +1495,8 @@
 "Feature index format version %d.%d is not supported by this release. Try to "
 "rebuild topology or upgrade GRASS."
 msgstr ""
+"Формат объектного индекса %d.%d не поддерживается этим выпуском. Попробуйте "
+"перестроить топологию или обновить GRASS"
 #: ../lib/vector/Vlib/open_ogr.c:152
 #, c-format
@@ -1439,154 +1504,150 @@
 "Your GRASS version does not fully support feature index format %d.%d of the "
 "vector. Consider to rebuild topology or upgrade GRASS."
 msgstr ""
+"Ваша версия GRASS полностью не поддерживает формат объектного индекса %d.%d "
+"вектора. Попробуйте перестроить топологию или обновить GRASS"
 #: ../lib/vector/Vlib/remove_areas.c:59 ../lib/vector/Vlib/remove_areas.c:180
 msgid "Removed areas"
-msgstr ""
+msgstr "Удаленные полигоны"
 #: ../lib/vector/Vlib/remove_areas.c:98
 msgid "Area is composed of dead boundary"
-msgstr ""
+msgstr "Полигон образова удаленной границей"
 #: ../lib/vector/Vlib/remove_duplicates.c:69
 #: ../lib/vector/Vlib/remove_duplicates.c:117
-#, fuzzy
 msgid "Duplicates"
-msgstr "дважды задано поле восток"
+msgstr "Дубликаты"
 #: ../lib/vector/Vlib/map.c:55
-#, fuzzy
 msgid "input vector map is not open"
-msgstr "вектор  "
+msgstr "исходный векторный слой не открыт"
 #: ../lib/vector/Vlib/map.c:65 ../lib/vector/Vlib/map.c:81
 #: ../lib/ogsf/Gp3.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read vector map <%s>"
-msgstr " "
+msgstr "Невозможно прочитать векторный слой <%s>"
 #: ../lib/vector/Vlib/map.c:180
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find vector map <%s> in <%s>"
-msgstr "невозможно открыть растровую карту [%s в %s]"
+msgstr "Невозможно найти векторный слой <%s> в <%s>"
 #: ../lib/vector/Vlib/map.c:211 ../lib/vector/Vlib/map.c:330
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy vector map <%s> to <%s>"
+msgstr "Невозможно скопировать векторный слой <%s> в <%s>"
 #: ../lib/vector/Vlib/map.c:258 ../lib/vector/Vlib/map.c:380
 #: ../lib/vector/Vlib/map.c:608 ../lib/vector/Vlib/map.c:715
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to copy table <%s>"
+msgstr "Невозможно скопировать таблицу <%s>"
 #: ../lib/vector/Vlib/map.c:274 ../lib/vector/Vlib/map.c:409
 #: ../lib/vector/Vlib/map.c:621
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create index for table <%s>, key <%s>"
+msgstr "Невозможно создать индекс для таблицы <%s>, ключ <%s>"
 #: ../lib/vector/Vlib/map.c:394 ../lib/vector/Vlib/map.c:489
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete table <%s>"
+msgstr "Невозможно удалить таблицу <%s>"
 #: ../lib/vector/Vlib/map.c:443
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid vector map name <%s>"
-msgstr " "
+msgstr "Неправильное имя векторного слоя <%s>"
 #: ../lib/vector/Vlib/map.c:457
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open header file for vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл заголовка для векторного слоя <%s>"
 #: ../lib/vector/Vlib/map.c:479
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find table <%s> linked to vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно найти таблицу <%s> связанную с векторным слоем <%s>"
 #: ../lib/vector/Vlib/map.c:495
-#, fuzzy, c-format
+#, c-format
 msgid "Table <%s> linked to vector map <%s> does not exist"
-msgstr "вектор  "
+msgstr "Таблица <%s> связанная с векторным слоем <%s> не существует"
 #: ../lib/vector/Vlib/map.c:509
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open directory '%s'"
-msgstr " "
+msgstr "Невозможно открыть папку '%s'"
 #: ../lib/vector/Vlib/map.c:523
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to delete file '%s'"
+msgstr "Невозможно удалить файл '%s'"
 #: ../lib/vector/Vlib/map.c:540
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rename directory '%s' to '%s'"
-msgstr " "
+msgstr "Невозможно переименовать папку '%s' в '%s'"
 #: ../lib/vector/Vlib/map.c:548
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to remove directory '%s'"
-msgstr " "
+msgstr "Невозможно удалить папку '%s'"
 #: ../lib/vector/Vlib/map.c:599 ../lib/vector/Vlib/map.c:700
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to add database link for vector map <%s>"
-msgstr "вектор  "
+msgstr "Невозможно добавить связь с базой данных для векторного слоя <%s>"
 #: ../lib/vector/Vlib/read_nat.c:136
-#, fuzzy
 msgid "Attempt to read dead line"
+msgstr "Попытка считать информацию об удаленной линии"
 #: ../lib/vector/Vlib/overlay.c:74
-#, fuzzy
 msgid "unknown operator"
+msgstr "неизвестный оператор"
 #: ../lib/vector/Vlib/overlay.c:123
 msgid "Overlay: line/boundary types not supported by AND operator"
-msgstr ""
+msgstr "Оверлей: типы линия/граница не поддерживаются оператором AND"
 #: ../lib/vector/Vlib/overlay.c:126
 msgid "Overlay: area x area types not supported by AND operator"
-msgstr ""
+msgstr "Оверлей: типы полигон x полигон не поддерживаются оператором AND"
 #: ../lib/vector/Vlib/read_ogr.c:178
 msgid "OGR feature without ID"
-msgstr ""
+msgstr "OGR объект без ID"
 #: ../lib/vector/Vlib/read_ogr.c:378 ../lib/vector/Vlib/read_ogr.c:386
 #, c-format
 msgid "Unable to get feature geometry, FID %ld"
-msgstr ""
+msgstr "Невозможно получить геометрию объекта, FID %ld"
 #: ../lib/vector/Vlib/field.c:89
 msgid "Layer number must be 1 or greater"
-msgstr ""
+msgstr "Номер слоя должен быть 1 или больше"
 #: ../lib/vector/Vlib/field.c:94
-#, fuzzy
 msgid "Unable to add database link, map is not opened in WRITE mode"
-msgstr " ."
+msgstr ""
+"Невозможно добавить связь с базой данных, слой не открыт в режиме записи"
 #: ../lib/vector/Vlib/field.c:100
-#, fuzzy
 msgid "Unable to add database link"
-msgstr "вектор  "
+msgstr "Невозможно связь с базой данных"
 #: ../lib/vector/Vlib/field.c:106 ../lib/vector/Vlib/field.c:151
-#, fuzzy
 msgid "Unable to write database links"
+msgstr "Невозможно записать связи с базой данных"
 #: ../lib/vector/Vlib/field.c:219
-#, fuzzy, c-format
+#, c-format
 msgid "Layer number %d or name <%s> already exists"
-msgstr " "
+msgstr "Слой номер %d или имя <%s> уже существует"
 #: ../lib/vector/Vlib/field.c:298
 #, c-format
@@ -1595,85 +1656,85 @@
 "driver: %s\n"
 "database: %s"
 msgstr ""
+"Драйвер по умолчанию / база данных:\n"
+"драйвер: %s\n"
+"БД: %s"
 #: ../lib/vector/Vlib/field.c:305
-#, fuzzy
 msgid "Default driver is not set"
-msgstr " "
+msgstr "Драйвер по умолчанию не установлен"
 #: ../lib/vector/Vlib/field.c:308
-#, fuzzy
 msgid "Default database is not set"
-msgstr " "
+msgstr "База данных по умолчанию не установлена "
 #: ../lib/vector/Vlib/field.c:367
 #, c-format
 msgid "Requested dblink %d, maximum link number %d"
-msgstr ""
+msgstr "Запрашиваемый dblink %d, максимальное число связей %d"
 #: ../lib/vector/Vlib/field.c:507
-#, fuzzy
 msgid "Unable to open OGR DBMI driver"
-msgstr "Невозможно открыть папку %s"
+msgstr "Невозможно открыть драйвер OGR DBMI"
 #: ../lib/vector/Vlib/field.c:546
 msgid ""
 "All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
 "available in OGR DB table"
 msgstr ""
+"Все тесты FID окончены неудачно. Ни  'FID' ни 'ogc_fid' ни 'ogr_fid' ни "
+"'gid' недоступны в таблице OGR DB"
 #: ../lib/vector/Vlib/field.c:601
 #, c-format
 msgid "Don't know how to read links for format %d"
-msgstr ""
+msgstr "Нет информации как прочитать связи для формата %d"
 #: ../lib/vector/Vlib/field.c:633
-#, fuzzy, c-format
+#, c-format
 msgid "Error in rule on row %d in %s"
-msgstr " "
+msgstr "Ошибка в правиле для ряда %d в %s"
 #: ../lib/vector/Vlib/field.c:686
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open vector database definition file '%s'"
-msgstr "не могу открыть файл таблицы датумов: %s"
+msgstr "Невозможно открыть файл определений векторной базы данных '%s'"
 #: ../lib/vector/Vlib/field.c:774
-#, fuzzy
 msgid "Bug: attempt to update map which is not in current mapset"
-msgstr " ."
+msgstr "Ошибка: попытка обновить слой не содержащийся в текущем наборе ."
 #: ../lib/vector/Vlib/net.c:121
 msgid "Building graph..."
-msgstr ""
+msgstr "Построение графа..."
 #: ../lib/vector/Vlib/net.c:163
-#, fuzzy
 msgid "Unable to build network graph"
-msgstr "вектор  "
+msgstr "Невозможно построить сетевой граф"
 #: ../lib/vector/Vlib/net.c:169
 msgid "Forward costs column not specified"
-msgstr ""
+msgstr "Не выбран столбец forward costs"
 #: ../lib/vector/Vlib/net.c:176
 msgid "Arc field < 1"
-msgstr ""
+msgstr "поле Arc < 1"
 #: ../lib/vector/Vlib/net.c:190 ../lib/vector/Vlib/net.c:207
 #: ../lib/vector/Vlib/net.c:360
-#, fuzzy, c-format
+#, c-format
 msgid "Column <%s> not found in table <%s>"
+msgstr "Поле <%s> не найдено в таблице <%s>"
 #: ../lib/vector/Vlib/net.c:196 ../lib/vector/Vlib/net.c:213
 #: ../lib/vector/Vlib/net.c:366
-#, fuzzy, c-format
+#, c-format
 msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr " "
+msgstr "Тип данных поля <%s> не поддерживается (должен быть числовым)"
 #: ../lib/vector/Vlib/net.c:226
 msgid "Registering arcs..."
-msgstr ""
+msgstr "Регистрируются дуги..."
 #: ../lib/vector/Vlib/net.c:254
 #, c-format
@@ -1681,6 +1742,8 @@
 "Database record for line %d (cat = %d, forward/both direction(s)) not found "
 "(forward/both direction(s) of line skipped)"
 msgstr ""
+"Запись в БД для линии %d (cat = %d, вперед/оба направления) не найден "
+"(вперед/оба направления линии пропущены)"
 #: ../lib/vector/Vlib/net.c:273
 #, c-format
@@ -1688,203 +1751,207 @@
 "Database record for line %d (cat = %d, backword direction) not found"
 "(direction of line skipped)"
 msgstr ""
+"Запись в БД для линии %d (cat = %d, направление назад) не найден "
+"(направление назад пропущено)"
 #: ../lib/vector/Vlib/net.c:322
-#, fuzzy
 msgid "Cannot add network arc"
-msgstr " "
+msgstr "Невозможно добавить сетевую дугу "
 #: ../lib/vector/Vlib/net.c:346
 msgid "Setting node costs..."
-msgstr ""
+msgstr "Устанавливается стоимость для узлов..."
 #: ../lib/vector/Vlib/net.c:402
 #, c-format
 msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
-msgstr ""
+msgstr "Запись в БД для узла  %d (cat = %d) не найдена (стоимость = 0)"
 #: ../lib/vector/Vlib/net.c:429
 msgid "Flattening the graph..."
-msgstr ""
+msgstr "Выпрямление графа"
 #: ../lib/vector/Vlib/net.c:439
 msgid "Graph was built"
-msgstr ""
+msgstr "Граф построен"
 #: ../lib/vector/Vlib/net.c:590
 msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
+msgstr "Неправильное направление линии в Vect_net_get_line_cost()"
 #: ../lib/vector/Vlib/line.c:60 ../lib/ogsf/gsd_img_mpeg.c:317
-#, fuzzy
 msgid "Out of memory"
-msgstr "G_malloc: out of memory"
+msgstr "Нет памяти"
 #: ../lib/vector/Vlib/line.c:199 ../lib/vector/Vlib/line.c:231
-#, fuzzy
 msgid "Index out of range in"
-msgstr "Ряд/колонка вне диапазона"
+msgstr "Индекс вне диапазона в"
 #: ../lib/vector/Vlib/line.c:527
 msgid "Segment outside line, no segment created"
-msgstr ""
+msgstr "Сегмент вне линии, сегмент не создан"
 #: ../lib/vector/Vlib/header.c:95 ../lib/vector/Vlib/header.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open header file of vector <%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл заголовка вектора <%s>"
 #: ../lib/vector/Vlib/header.c:151
 #, c-format
 msgid "Corrupted row in head: %s"
-msgstr ""
+msgstr "Испорченная строка в заголовке  %s"
 #: ../lib/vector/Vlib/header.c:187
-#, fuzzy, c-format
+#, c-format
 msgid "Unknown keyword %s in vector head"
-msgstr "Неизвестная проекция"
+msgstr "Неизвестное ключевое слово %s в заголовке вектора"
 #: ../lib/vector/Vlib/header.c:510 ../lib/gis/proj3.c:64
-#, fuzzy
 msgid "Unknown projection"
 #: ../lib/vector/Vlib/write.c:27 ../lib/vector/Vlib/write.c:33
 #: ../lib/vector/Vlib/write.c:39 ../lib/vector/Vlib/write.c:46
-#, fuzzy
 msgid "for this format/level not supported"
-msgstr " "
+msgstr "для этого формата/уровня не поддерживается "
 #: ../lib/vector/Vlib/write.c:135
-#, fuzzy
 msgid "Unable to write feature, vector map is not opened"
-msgstr " "
+msgstr "Невозможно записать объект, векторный слой не открыт "
 #: ../lib/vector/Vlib/write.c:148
-#, fuzzy
 msgid "Unable to write feature (negative offset)"
+msgstr "Невозможно записать объект (отрицательное смещение)"
 #: ../lib/vector/Vlib/write.c:181
-#, fuzzy
 msgid "Unable to rewrite feature, vector map is not opened"
-msgstr " "
+msgstr "Невозможно перезаписать объект, векторный слой не открыт "
 #: ../lib/vector/Vlib/write.c:194
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to rewrite feature %d"
+msgstr "Невозможно перезаписать объект %d"
 #: ../lib/vector/Vlib/write.c:219
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to delete feature %d, vector map <%s> is not opened on topology level"
-msgstr "   "
+msgstr ""
+"Невозможно удалить объект %d, векторный слой <%s> не открыт на уровне "
+"топологии"
 #: ../lib/vector/Vlib/write.c:225
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to delete feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "   "
+msgstr ""
+"Невозможно удалить объект %d, векторный слой <%s> не открыт в режиме записи"
 #: ../lib/vector/Vlib/write.c:239
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to feature %d from vector map <%s>"
-msgstr " "
+msgstr "Невозможно удалить объект %d из векторного слоя <%s>"
 #: ../lib/vector/Vlib/write.c:265
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to restore feature %d, vector map <%s> is not opened on topology level"
-msgstr "   "
+msgstr ""
+"Невозможно восстановить объект %d, векторный слой <%s> не открыт на уровне "
+"топологии"
 #: ../lib/vector/Vlib/write.c:271
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to restore feature %d, vector map <%s> is not opened in 'write' mode"
-msgstr "   "
+msgstr ""
+"Невозможно восстановить объект %d, векторный слой <%s> не открыт в режиме "
+"записи"
 #: ../lib/vector/Vlib/write.c:285
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to restore feature %d from vector map <%s>"
-msgstr " "
+msgstr "Невозможно восстановить объект %d из векторного слоя <%s>"
 #: ../lib/proj/get_proj.c:148
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid zone %s specified"
-msgstr " "
+msgstr "Указана неправильная зона %s "
 #: ../lib/proj/get_proj.c:228
 msgid "Unable to initialise PROJ.4 with the following parameter list:"
-msgstr ""
+msgstr "Невозможно иннициализировать PROJ.4 со следующим списком параметров:"
 #: ../lib/proj/get_proj.c:236
 #, c-format
 msgid "The error message: %s"
-msgstr ""
+msgstr "Сообщение об ошибке: %s"
 #: ../lib/proj/get_proj.c:294
 msgid "Option input overflowed option table"
-msgstr ""
+msgstr "Ввод опций переполнил таблицу опций"
 #: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to initialize pj cause: %s"
+msgstr "Невозможно инициализировать pj причину: %s"
 #: ../lib/proj/get_proj.c:401
 msgid "Input Projection Parameters"
-msgstr ""
+msgstr "Параметры исходной проекции"
 #: ../lib/proj/get_proj.c:404
 msgid "Input Unit Factor"
-msgstr ""
+msgstr "Исходный фактор единицы"
 #: ../lib/proj/get_proj.c:414
 msgid "Output Projection Parameters"
-msgstr ""
+msgstr "Параметры выходной проекции"
 #: ../lib/proj/get_proj.c:417
 msgid "Output Unit Factor"
-msgstr ""
+msgstr "Выходной фактор единиц"
 #: ../lib/proj/datum.c:271 ../lib/proj/datum.c:336
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open datum table file <%s>"
+msgstr "Невозможно открыть файл таблицы датумов: <%s>"
 #: ../lib/proj/datum.c:284 ../lib/proj/datum.c:350
-#, fuzzy, c-format
+#, c-format
 msgid "Error in datum table file <%s>, line %d"
-msgstr "ошибка в файле таблицы датумов, строка %d"
+msgstr "Ошибка в файле таблицы датумов <%s>, строка %d"
 #: ../lib/proj/convert.c:108
 msgid "Unable parse GRASS PROJ_INFO file"
-msgstr ""
+msgstr "Невозможно обработать PROJ_INFO файл GRASS"
 #: ../lib/proj/convert.c:113
 msgid "Unable get PROJ.4-style parameter string"
-msgstr ""
+msgstr "Невозможно получить строку параметров в стиле PROJ.4"
 #: ../lib/proj/convert.c:125
 #, c-format
 msgid ""
 "OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
 msgstr ""
+"OGR не может обработать строку параметров в стиле PROJ.4: %s (Код ошибки OGR "
+"%d)"
 #: ../lib/proj/convert.c:131
 #, c-format
 msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
 msgstr ""
+"OGR не может получить строку параметров в стиле WKT (Код ошибки OGR %d)"
 #: ../lib/proj/convert.c:384
 msgid "No projection name! Projection parameters likely to be meaningless."
-msgstr ""
+msgstr "Нет имени проекции! Параметры проекции не имеют значения."
 #: ../lib/proj/convert.c:420
 #, c-format
 msgid "Datum <%s> not recognised by GRASS and no parameters found"
-msgstr ""
+msgstr "Датум <%s> не распознан GRASS, параметры не найдены"
 #: ../lib/proj/convert.c:436
 #, c-format
@@ -1892,41 +1959,43 @@
 "Datum <%s> apparently recognised by GRASS but no parameters found. You may "
 "want to look into this."
 msgstr ""
+"Датум <%s> распознан GRASS, но параметры не найдены. Необходимо ваше участие."
 #: ../lib/proj/convert.c:440
-#, c-format
+#, fuzzy, c-format
 msgid ""
 "Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
 "transform parameters unspecified."
 msgstr ""
+"Неправильный номер трансформации %d; валидный диапазон от 1 до %d. Параметры "
+"трансформации датума оставлены незаполненными."
 #: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
 #, c-format
 msgid "pj_transform() failed: %s"
-msgstr ""
+msgstr "pj_transform() неудачен: %s"
 #: ../lib/proj/ellipse.c:75
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid ellipsoid <%s> in file"
-msgstr " "
+msgstr "Неправильный эллипсоид <%s> в файле"
 #: ../lib/proj/ellipse.c:98
 msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
-msgstr ""
+msgstr "В файле отсутствует второй параметр описания эллипсоида (rf, es или b)"
 #: ../lib/proj/ellipse.c:102
-#, fuzzy
 msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
-msgstr " "
+msgstr "Неправильные параметры эллипсоида (a, rf, es или b) в файле"
 #: ../lib/proj/ellipse.c:115
 msgid "No ellipsoid info given in file"
-msgstr ""
+msgstr "В файле нет информации об эллипсоиде"
 #: ../lib/proj/ellipse.c:216 ../lib/gis/get_ellipse.c:283
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open ellipsoid table file <%s>"
+msgstr "Невозможно открыть файл таблицы эллипсоидов <%s>"
 #: ../lib/g3d/g3dparam.c:52
 msgid "Data type used in the output file"
@@ -1954,14 +2023,13 @@
 msgstr "G3d_getStandard3dParams: неправильные размеры тайлов"
 #: ../lib/g3d/g3dparam.c:173
-#, fuzzy
 msgid "Window replacing the default"
-msgstr "чтобы установить по умолчанию"
+msgstr "Окно заменяемое по умолчанию"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
+msgstr "Растрового слоя <%s> нет в текущем наборе (%s)"
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -1981,7 +2049,7 @@
 #: ../lib/g3d/g3dopen.c:96
 msgid "G3d_openCellOld: can't rewind file"
-msgstr "G3d_openCellOld: не могу перемотать файл"
+msgstr "G3d_openCellOld: невозможно перемотать файл"
 #: ../lib/g3d/g3dopen.c:108
 msgid "G3d_openCellOld: error in G3d_readHeader"
@@ -1993,7 +2061,7 @@
 #: ../lib/g3d/g3dopen.c:120
 msgid "G3d_openCellOld: zone does not match window zone"
-msgstr "G3d_openCellOld: зона не совпадает зоне окна"
+msgstr "G3d_openCellOld: зона не совпадает с зоной окна"
 #: ../lib/g3d/g3dopen.c:132 ../lib/g3d/g3dopen.c:149
 msgid "G3d_openCellOld: can't read header"
@@ -2022,7 +2090,7 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2037,7 +2105,7 @@
 msgstr "G3d_openCellNew: ошибка в G3d_fillHeader"
 #: ../lib/g3d/g3dhistory.c:42 ../lib/gis/history.c:132
-#, fuzzy, c-format
+#, c-format
 msgid "can't get history information for [%s] in mapset [%s]"
 msgstr "невозможно прочитать историю для [%s] в наборе [%s]"
@@ -2054,233 +2122,229 @@
 #: ../lib/g3d/g3drange.c:153
 #, fuzzy, c-format
 msgid "Unable to open range file for <%s>"
-msgstr "вектор  "
 #: ../lib/gis/gdal.c:54
 #, fuzzy, c-format
 msgid "Unable to locate symbol <%s>"
 #: ../lib/gis/gdal.c:94
 #, fuzzy
 msgid "Unable to load GDAL library"
-msgstr " "
 #: ../lib/gis/sample.c:71
-#, fuzzy
 msgid "Unknown interpolation type"
-msgstr "неизвестный тип интерполяции"
+msgstr "Неизвестный тип интерполяции"
 #: ../lib/gis/sample.c:284
 msgid "\"no data\" label found; setting to zero"
 msgstr "найдена метка \"no data\"; установлена в ноль"
 #: ../lib/gis/sample.c:299
-#, fuzzy
 msgid "Problem reading raster map"
-msgstr "проблема чтения растрого файла"
+msgstr "Ошибка чтения растрового слоя"
 #: ../lib/gis/put_cellhd.c:26
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create header file for [%s]"
 msgstr "Невозможно создать файл заголовка для [%s]"
 #: ../lib/gis/legal_name.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal filename.  Cannot be '.' or 'NULL'\n"
-msgstr "Неправильно задано имя файла.  Не должно быть '.' или 'NULL'\n"
+msgstr "Неправильное имя файла.  Не должно быть '.' или 'NULL'\n"
 #: ../lib/gis/legal_name.c:47
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal filename. Character <%c> not allowed.\n"
-msgstr "Неправильно задано имя файла. знак <%c> недопустим."
+msgstr "Неправильное имя файла. Знак <%c> недопустим.\n"
 #: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
-#, fuzzy, c-format
+#, c-format
 msgid "Output raster map name <%s> is not valid map name"
-msgstr "   ."
+msgstr "Неправильное имя выходного растрового слоя <%s>"
 #: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
-#, fuzzy, c-format
+#, c-format
 msgid "Output raster map <%s> is used as input"
-msgstr "   "
+msgstr "Выходной растровый слой <%s> используется как исходный"
 #: ../lib/gis/debug.c:69
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open debug file '%s'"
 msgstr "Невозможно открыть debug-файл '%s'"
 #: ../lib/gis/datum.c:160
-#, fuzzy, c-format
+#, c-format
 msgid "unable to open datum table file: %s"
+msgstr "невозможно открыть файл таблицы датумов: %s"
 #: ../lib/gis/datum.c:181
-#, fuzzy, c-format
+#, c-format
 msgid "error in datum table file, line %d"
 #: ../lib/gis/list.c:109
-#, fuzzy, c-format
+#, c-format
 msgid "no %s files available in current mapset\n"
 #: ../lib/gis/list.c:112
-#, fuzzy, c-format
+#, c-format
 msgid "no %s files available in mapset <%s>\n"
-msgstr "в наборе <%s> файлы %s недоступны"
+msgstr "файлы %s недоступны в наборе <%s>\n"
 #: ../lib/gis/list.c:174
-#, fuzzy, c-format
+#, c-format
 msgid "%s files available in mapset <%s>:\n"
-msgstr "%s файлов в наборе данных <%s>:\n"
+msgstr "%s файлы доступны в наборе <%s>:\n"
 #: ../lib/gis/list.c:245
-#, fuzzy
 msgid "G_list: Unknown element type"
 msgstr "G_list: Неизвестный тип элемента"
 #: ../lib/gis/proj2.c:46
-#, fuzzy
 msgid "Latitude-Longitude"
 msgstr "Широта-Долгота"
 #: ../lib/gis/proj2.c:48
-#, fuzzy
 msgid "Other Projection"
 #: ../lib/gis/opencell.c:105
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open raster map <%s@%s>"
-msgstr " "
+msgstr "Невозможно открыть растровый слой <%s@%s>"
 #: ../lib/gis/opencell.c:174
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find <%s@%s>"
-msgstr "не могу найти [%s]"
+msgstr "Невозможно найти <%s@%s>"
 #: ../lib/gis/opencell.c:190
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@%"
 "s> which does not exist"
 msgstr ""
-"невозможно открыть [%s] в [%s] так как он - переклассификация [%s] в [%s] "
-"которая не существует"
+"Невозможно открыть растровый слой <%s@%s> так как он - переклассификация "
+"растрового слоя <%s@%s> которая не существует"
 #: ../lib/gis/opencell.c:214
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr "[%s] в наборе [%s]-формат поля в файле заголовка неверен"
+msgstr "Растровый слой <%s@%s>: формат поля в файле заголовка неверен"
 #: ../lib/gis/opencell.c:221
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Raster map <%s@%s> is in different projection than current region. Found "
 "raster map <%s@%s>, should be <%s>."
 msgstr ""
-"[%s] в наборе [%s] - в проекции отличной от проекции текущего региона:\n"
-" найдена карта [%s] в: <%s>, должно быть <%s> "
+"Растровый слой <%s@%s> в проекции отличной от проекции текущего региона. "
+"Найден растровый слой <%s@%s>, должно быть <%s> ."
 #: ../lib/gis/opencell.c:228
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s> is in different zone (%d) than current region (%d)"
-msgstr "[%s] в наборе [%s] - в другой зоне [%d] чем текущий регион [%d]"
+msgstr "Растровый слой <%s@%s> в другой зоне (%d) чем текущий регион (%d)"
 #: ../lib/gis/opencell.c:235
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s@%s>: bytes per cell (%d) too large"
-msgstr "[%s] в [%s] - байт на ячейку (%d) слишком много"
+msgstr "Растровый слой <%s@%s>: слишком много байт на ячейку (%d) "
 #: ../lib/gis/opencell.c:264
 #, c-format
 msgid "map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
 msgstr ""
+"слой <%s@%s> является связью GDAL но GRASS скомпилирован без поддержки GDAL"
 #: ../lib/gis/opencell.c:604
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr " ."
 #: ../lib/gis/opencell.c:611
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> is an illegal file name"
-msgstr "opencell: %s - неправильное имя файла"
+msgstr "<%s> - неправильное имя файла"
 #: ../lib/gis/opencell.c:622 ../lib/gis/opencell.c:723
 msgid "G__open_raster_new(): no temp files available"
-msgstr ""
+msgstr "G__open_raster_new(): недоступны временные файлы"
 #: ../lib/gis/opencell.c:692
-#, fuzzy
 msgid ""
 "Unable to write embedded null values for raster map open for random access"
 msgstr ""
-"Невозможно записать нулевые значения для карты открытой для случайного "
+"Невозможно записать нулевые значения для слоя открытого для случайного "
 "доступа"
 #: ../lib/gis/opencell.c:897
 msgid "G_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
+msgstr "G_set_fp_type(): может быть вызвано только с FCELL_TYPE или DCELL_TYPE"
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find '%s' in '%s'"
+msgstr "Невозможно найти '%s' в '%s'"
 #: ../lib/gis/opencell.c:965
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> not found in mapset <%s>"
-msgstr "вектор  "
+msgstr "Растровый слой <%s> не найден в наборе <%s>"
 #: ../lib/gis/opencell.c:1026
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find '%s'"
+msgstr "Невозможно найти '%s'"
 #: ../lib/gis/opencell.c:1031
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open '%s'"
-msgstr "Не могу открыть [%s]"
+msgstr "Невозможно открыть [%s]"
 #: ../lib/gis/opencell.c:1041
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid type: field '%s' in file '%s'"
-msgstr "неверный тип: поле %s в файле %s "
+msgstr "Неверный тип: поле '%s' в файле '%s'"
 #: ../lib/gis/opencell.c:1055
-#, fuzzy, c-format
+#, c-format
 msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr "вектор  "
+msgstr "Растровый слой <%s> не xdr: byte_order: %s"
 #: ../lib/gis/opencell.c:1135
 msgid ""
 "G_set_quant_rules() can be called only for raster maps opened for reading"
 msgstr ""
+"G_set_quant_rules() может быть вызван только для растровых слоев для чтения"
 #: ../lib/gis/put_title.c:29
-#, fuzzy, c-format
+#, c-format
 msgid "category information for [%s] in [%s] missing or invalid"
 msgstr "категории для [%s] в [%s] отсутствуют или заданы неверно"
 #: ../lib/gis/put_title.c:39
-#, fuzzy, c-format
+#, c-format
 msgid "G_put_title - can't create a temp file"
-msgstr "G_put_title - не могу создать врем. файл"
+msgstr "G_put_title - невозможно создать временный файл"
 #: ../lib/gis/put_title.c:56
-#, fuzzy, c-format
+#, c-format
 msgid "category information for [%s] in [%s] invalid"
 msgstr "категории для [%s] в [%s] заданы неверно"
 #: ../lib/gis/put_title.c:64
-#, fuzzy, c-format
+#, c-format
 msgid "G_put_title - can't reopen temp file"
-msgstr "G_put_title - не могу заново открыть врем. файл"
+msgstr "G_put_title - невозможно заново открыть временный файл"
 #: ../lib/gis/put_title.c:72
-#, fuzzy, c-format
+#, c-format
 msgid "can't write category information for [%s] in [%s]"
 msgstr "невозможно записать категории для [%s] в [%s]"
@@ -2290,33 +2354,32 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
 #: ../lib/gis/quant_io.c:89
-#, fuzzy, c-format
+#, c-format
 msgid "The floating data range for %s@%s is empty"
-msgstr "Диапазон с плав. точкой для %s@%s пуст"
+msgstr "Диапазон с плавающей точкой для %s@%s пуст"
 #: ../lib/gis/quant_io.c:99
-#, fuzzy, c-format
+#, c-format
 msgid "The integer data range for %s@%s is empty"
-msgstr "Диапазон целых чисел для %s@%s пуст"
+msgstr "Целочисленный диапазон для %s@%s пуст"
 #: ../lib/gis/quant_io.c:168
-#, fuzzy, c-format
+#, c-format
 msgid "quantization file [%s] in mapset [%s] %s"
-msgstr "файл разбиения значений [%s] в наб. данных [%s] %s"
+msgstr "файл разбиения значений [%s] в наборе [%s] %s"
 #: ../lib/gis/system.c:85
 msgid "Can not create a new process!"
 msgstr "Невозможно создать новый процесс!"
 #: ../lib/gis/myname.c:50
-#, fuzzy
 msgid "Unknown Location"
-msgstr "ОБЛАСТЬ неизвестна"
+msgstr "Область неизвестна"
 #: ../lib/gis/color_rules.c:110
 msgid "syntax error"
@@ -2327,9 +2390,8 @@
 msgstr "R/G/B вне диапазона 0-255"
 #: ../lib/gis/color_rules.c:114
-#, fuzzy
 msgid "invalid color name"
-msgstr "Неверное имя цвета"
+msgstr "неверное имя цвета"
 #: ../lib/gis/color_rules.c:116
 msgid "percentage not in range 0-100"
@@ -2340,29 +2402,25 @@
 msgstr "неверное значение"
 #: ../lib/gis/color_rules.c:120
-#, fuzzy
 msgid "unknown error"
 #: ../lib/gis/color_rules.c:151
-#, fuzzy, c-format
+#, c-format
 msgid "bad rule (%s): [%s]"
-msgstr "неправильное правило (%s): %s"
+msgstr "неправильное правило (%s): [%s]"
 #: ../lib/gis/spawn.c:80 ../lib/gis/spawn.c:112
-#, fuzzy
 msgid "Too many arguments"
-msgstr "Слишком много открытых файлов"
+msgstr "Слишком много параметров"
 #: ../lib/gis/spawn.c:133 ../lib/gis/spawn.c:401
-#, fuzzy
 msgid "Unable to create a new process"
-msgstr "Невозможно создать файл заголовка для [%s]"
+msgstr "Невозможно создать новый процесс"
 #: ../lib/gis/spawn.c:142 ../lib/gis/spawn.c:237 ../lib/gis/spawn.c:424
-#, fuzzy
 msgid "Unable to execute command"
+msgstr "Невозможно выполнить команду"
 #: ../lib/gis/spawn.c:262 ../lib/gis/spawn.c:270
 #, c-format
@@ -2390,9 +2448,9 @@
 msgstr "G_spawn: невозможно разблокировать сигнал %d"
 #: ../lib/gis/spawn.c:353
-#, fuzzy, c-format
+#, c-format
 msgid "G_spawn: unable to open file %s"
-msgstr " "
+msgstr "G_spawn: невозможно открыть файл %s"
 #: ../lib/gis/spawn.c:358 ../lib/gis/spawn.c:367
 #, c-format
@@ -2400,53 +2458,52 @@
 msgstr "G_spawn: невозможно дублировать дескриптор %d to %d"
 #: ../lib/gis/spawn.c:416
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to change directory to %s"
-msgstr " "
+msgstr "Невозможно изменить папку %s"
 #: ../lib/gis/mapset.c:39
-#, fuzzy
 msgid "MAPSET is not set"
 msgstr "НАБОР не задан"
 #: ../lib/gis/mapset.c:57 ../lib/gis/gisinit.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "MAPSET %s not found"
 msgstr "НАБОР %s не найден"
 #: ../lib/gis/gisinit.c:54 ../lib/gis/gisinit.c:89
 msgid "Incompatible library version for module"
-msgstr ""
+msgstr "Несовместимая версия библиотеки для модуля"
 #: ../lib/gis/gisinit.c:62
-#, fuzzy, c-format
+#, c-format
 msgid "MAPSET %s - permission denied"
 msgstr "НАБОР %s - доступ запрещен"
 #: ../lib/gis/gisinit.c:108
-#, fuzzy
 msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr "\aОШИБКА: Система не инициализирована. Не выполнен G_gisinit()\n"
+msgstr ""
+"Система не инициализирована. Программистов не выполнен вызов G_gisinit()."
 #: ../lib/gis/range.c:192
-#, fuzzy, c-format
+#, c-format
 msgid "can't read f_range file for [%s in %s]"
 msgstr "невозможно прочитать f_range файл для [%s в %s]"
 #: ../lib/gis/range.c:308
-#, fuzzy, c-format
+#, c-format
 msgid "can't read range file for [%s in %s]"
 msgstr "невозможно прочитать файл диапазона для [%s в %s]"
 #: ../lib/gis/range.c:359 ../lib/gis/range.c:412
-#, fuzzy, c-format
+#, c-format
 msgid "can't write range file for [%s in %s]"
 msgstr "невозможно записать файл диапазона для [%s в %s]"
 #: ../lib/gis/get_row.c:46 ../lib/gis/get_row.c:1049
-#, fuzzy, c-format
+#, c-format
 msgid "Reading raster map <%s@%s> request for row %d is outside region"
-msgstr "[%s в %s] - чтение строки %d за пределами региона"
+msgstr "Чтение растрового слоя <%s@%s> ряд %d находится вне диапазона"
 #: ../lib/gis/get_row.c:324
 #, c-format
@@ -2454,32 +2511,31 @@
 msgstr "cell_values_float: xdr_float завершен неудачно для индекса %d"
 #: ../lib/gis/get_row.c:365
-#, fuzzy, c-format
+#, c-format
 msgid "cell_values_double: xdr_double failed for index %d"
-msgstr "cell_values_double: xdr_double завершен неудачно для индекса %d."
+msgstr "cell_values_double: xdr_double завершен неудачно для индекса %d"
 #: ../lib/gis/get_row.c:621
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading compressed map <%s@%s>, row %d"
-msgstr "ошибка чтения сжатой карты [%s] из набора [%s], ряд %d"
+msgstr "Ошибка чтения сжатой слоя [%s] из набора [%s], ряд %d"
 #: ../lib/gis/get_row.c:624
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading map <%s@%s>, row %d"
-msgstr "ошибка чтения карты [%s] в наборе [%s], ряд %d"
+msgstr "Ошибка чтения слоя <%s@%s>, ряд %d"
 #: ../lib/gis/get_row.c:1031 ../lib/gis/get_row.c:1036
-#, fuzzy, c-format
+#, c-format
 msgid "Error reading null row %d"
-msgstr "ошибка чтения нулевого ряда %d"
+msgstr "Ошибка чтения нулевого ряда %d"
 #: ../lib/gis/get_row.c:1115
-#, fuzzy
 msgid "Unable to realloc buffer"
 msgstr "Невозможно realloc буфер"
 #: ../lib/gis/ls.c:87
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open directory %s"
@@ -2491,39 +2547,40 @@
 "G_set_window(): проекция/зона отличается от текущих открытых растровых карт"
 #: ../lib/gis/format.c:157
-#, fuzzy, c-format
+#, c-format
 msgid "Fail of initial read of compressed file [%s in %s]"
 msgstr "Ошибка чтения сжатого файла [%s в %s]"
 #: ../lib/gis/put_row.c:215
-#, fuzzy, c-format
+#, c-format
 msgid "G_put_map_row: %s is not integer! Use G_put_[f/d]_raster_row()!"
 msgstr "G_put_map_row: %s не целое! Используйте G_put_[f/d]_raster_row()!"
 #: ../lib/gis/put_row.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "%s: map [%s] not open for write - request ignored"
-msgstr "   "
+msgstr "%s: слой [%s] не открыт для записи - запрос игнорирован"
 #: ../lib/gis/put_row.c:259
-#, fuzzy, c-format
+#, c-format
 msgid "%s: map [%s] not open for random write - request ignored"
-msgstr "   "
+msgstr "%s: слой [%s] не открыт для случайной записи - запрос игнорирован"
 #: ../lib/gis/put_row.c:266
-#, fuzzy, c-format
+#, c-format
 msgid "%s: map [%s] not open for sequential write - request ignored"
-msgstr "   "
+msgstr ""
+"%s: слой [%s] не открыт для последовательной записи - запрос игнорирован"
 #: ../lib/gis/put_row.c:270
-#, fuzzy, c-format
+#, c-format
 msgid "%s: unopened file descriptor - request ignored"
-msgstr " "
+msgstr "%s: дескриптор файла не открыт  - запрос игнорирован"
 #: ../lib/gis/put_row.c:310
-#, fuzzy, c-format
+#, c-format
 msgid "map [%s] - unable to write row %d"
-msgstr "карта [%s] - невозможно записать строку %d"
+msgstr "слой [%s] - невозможно записать строку %d"
 #: ../lib/gis/put_row.c:393
 #, c-format
@@ -2536,9 +2593,9 @@
 msgstr "xdr_double завершен неудачно для индекса %d ряда %d"
 #: ../lib/gis/put_row.c:754
-#, fuzzy, c-format
+#, c-format
 msgid "unable to find a temporary null file %s"
-msgstr " "
+msgstr "невозможно найти временный null-файл %s"
 #: ../lib/gis/put_row.c:776 ../lib/gis/put_row.c:781
 #, c-format
@@ -2546,7 +2603,7 @@
 msgstr "ошибка при записи нулевой строки %d"
 #: ../lib/gis/history.c:180
-#, fuzzy, c-format
+#, c-format
 msgid "can't write history information for [%s]"
 msgstr "невозможно записать историю для [%s]"
@@ -2560,23 +2617,27 @@
 "Недостаточно места в файле истории для записи командной строки (truncated)"
 #: ../lib/gis/closecell.c:229
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "closecell: can't move %s\n"
 "to null file %s"
-msgstr "   "
+msgstr ""
+"closecell: невозможно переместить %s\n"
+"в null-файл %s"
 #: ../lib/gis/closecell.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "Error writing floating point format file for map %s"
+msgstr "Ошибка записи в файл с плавающей точкой для слоя %s"
 #: ../lib/gis/closecell.c:301
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "to cell file %s"
-msgstr "   "
+msgstr ""
+"в cell-файл %s"
 #: ../lib/gis/closecell.c:356
 msgid "unable to write quant file!"
@@ -2587,140 +2648,133 @@
 msgstr "невозможно записать файл f_format для CELL карт"
 #: ../lib/gis/home.c:39
-#, fuzzy
 msgid "unable to determine user's home directory"
 msgstr "невозможно определить домашний каталог пользователя"
 #: ../lib/gis/error.c:257
-#, fuzzy
 msgid "WARNING: "
 msgstr "ПРЕДУПРЕЖДЕНИЕ: "
 #: ../lib/gis/error.c:258
-#, fuzzy
 msgid "ERROR: "
 msgstr "ОШИБКА: "
 #: ../lib/gis/get_cellhd.c:71 ../lib/gis/get_cellhd.c:100
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read header file for raster map <%s@%s>."
-msgstr "Невозможно создать файл заголовка для [%s в %s]"
+msgstr "Невозможно прочитать файл заголовка для растрового слоя <%s@%s>."
 #: ../lib/gis/get_cellhd.c:74
-#, fuzzy, c-format
+#, c-format
 msgid " It is a reclass of raster map <%s@%s> "
-msgstr "Это переклассификация [%s в %s]"
+msgstr "Это переклассификация растрового слоя <%s@%s>"
 #: ../lib/gis/get_cellhd.c:78
-#, fuzzy, c-format
+#, c-format
 msgid "which is missing."
-msgstr "который отсутствует"
+msgstr "который отсутствует."
 #: ../lib/gis/get_cellhd.c:80
-#, fuzzy, c-format
+#, c-format
 msgid "whose header file can't be opened."
-msgstr "чей файл заголовка не может быть открыт"
+msgstr "чей файл заголовка не может быть открыт."
 #: ../lib/gis/get_cellhd.c:88
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open header file for raster map <%s@%s>"
-msgstr "вектор  "
+msgstr "Невозможно открыть файл заголовка для растрового слоя <%s@%s>"
 #: ../lib/gis/get_cellhd.c:105
-#, fuzzy, c-format
+#, c-format
 msgid " It is a reclass of raster map <%s@%s> whose header file is invalid."
 msgstr ""
-"Это переклассификация [%s в %s] чей файл заголовка имеет неверный формат\n"
+"Это переклассификация растрового слоя <%s@%s> чей файл заголовка имеет "
+"неверный формат."
 #: ../lib/gis/get_cellhd.c:109
-#, fuzzy, c-format
+#, c-format
 msgid " Invalid format."
-msgstr "Неверный формат\n"
+msgstr "Неверный формат."
 #: ../lib/gis/cats.c:385
-#, fuzzy, c-format
+#, c-format
 msgid "category support for [%s] in mapset [%s] %s"
 msgstr "категории [%s] в наборе [%s] %s"
 #: ../lib/gis/cats.c:421
-#, fuzzy, c-format
+#, c-format
 msgid "category support for vector map [%s] in mapset [%s] %s"
-msgstr "категории векторной карты [%s] в наборе [%s] %s"
+msgstr "категории векторного слоя [%s] в наборе [%s] %s"
 #: ../lib/gis/get_ellipse.c:85
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file %s in <%s>"
-msgstr "Невозможно открыть файл %s в %s"
+msgstr "Невозможно открыть файл %s в <%s>"
 #: ../lib/gis/get_ellipse.c:333
-#, fuzzy, c-format
+#, c-format
 msgid "Lines%s of ellipsoid table file <%s> are invalid"
-msgstr "Неверные линии %s в файле таблицы эллипсоидов <%s>"
+msgstr "Неверные строки %s в файле таблицы эллипсоидов <%s>"
 #: ../lib/gis/get_ellipse.c:335
-#, fuzzy, c-format
+#, c-format
 msgid "Line%s of ellipsoid table file <%s> is invalid"
-msgstr "Неверная линия %s в файле таблицы эллипсоидов <%s>"
+msgstr "Неверная строка %s в файле таблицы эллипсоидов <%s>"
 #: ../lib/gis/get_ellipse.c:355 ../lib/gis/get_ellipse.c:381
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid a: field '%s' in file %s in <%s>"
-msgstr "неверно задано поле a: %s в файле %s в %s"
+msgstr "Неверно задано поле a: '%s' в файле %s в <%s>"
 #: ../lib/gis/get_ellipse.c:368
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid ellipsoid '%s' in file %s in <%s>"
-msgstr "неверно задан эллипсоид %s в файле %s в %s"
+msgstr "Неверный эллипсоид '%s' в файле %s в <%s>"
 #: ../lib/gis/get_ellipse.c:385
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid es: field '%s' in file %s in <%s>"
-msgstr "неверно задано поле es: %s в файле %s в %s"
+msgstr "Неверный параметр es: поле '%s' в файле %s в <%s>"
 #: ../lib/gis/get_ellipse.c:399
-#, fuzzy, c-format
+#, c-format
 msgid "No ellipsoid info given in file %s in <%s>"
-msgstr "Нет информации об эллипсоиде в файле %s в %s"
+msgstr "Нет информации об эллипсоиде в файле %s в <%s>"
 #: ../lib/gis/location.c:44
-#, fuzzy, c-format
+#, c-format
 msgid "LOCATION << %s >> not available"
 msgstr "Область << %s >> недоступна"
 #: ../lib/gis/null_val.c:91
-#, fuzzy
 msgid "EmbedGivenNulls: wrong data type!"
 msgstr "EmbedGivenNulls: неверный тип данных!"
 #: ../lib/gis/null_val.c:112
-#, fuzzy
 msgid "Null values have not been initialized. "
-msgstr "Нулевые величины не были инициализированы."
+msgstr "Нулевые значения не были инициализированы."
 #: ../lib/gis/null_val.c:113
-#, fuzzy
 msgid "G_gisinit() must be called first. "
 msgstr "Сначала нужно вызвать G_gisinit(). "
 #: ../lib/gis/null_val.c:114
-#, fuzzy
 msgid "Please advise GRASS developers of this error.\n"
 msgstr "Сообщите разработчикам GRASS об этой ошибке.\n"
 #: ../lib/gis/null_val.c:223
-#, fuzzy
 msgid "G_set_null_value: wrong data type!"
 msgstr "G_set_null_value: неверный тип данных!"
 #: ../lib/gis/get_projinfo.c:33 ../lib/gis/get_projinfo.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> file not found for location <%s>"
-msgstr "Файл <%s> не найден для области <%s>\n"
+msgstr "Файл <%s> не найден для области <%s>"
 #: ../lib/gis/get_projinfo.c:39 ../lib/gis/get_projinfo.c:66
-#, fuzzy, c-format
+#, c-format
 msgid "ERROR in reading <%s> file for location <%s>"
-msgstr "ОШИБКА чтения файла %s для области %s\n"
+msgstr "ОШИБКА чтения файла %s для области <%s>"
 #: ../lib/gis/distance.c:160
 #, c-format
@@ -2728,11 +2782,13 @@
 "G_distance_point_to_line_segment: shouldn't happen: code=%d P=(%f,%f) S=(%f,%"
 "f)(%f,%f)"
 msgstr ""
+"G_distance_point_to_line_segment: не должно быть: code=%d P=(%f,%f) S=(%f,%f)"
+"(%f,%f)"
 #: ../lib/gis/mapset_msc.c:60
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to make mapset element %s (%s)"
-msgstr "невозможно создать элемент набора %s (%s)"
+msgstr "Невозможно создать элемент набора %s (%s)"
 #: ../lib/gis/parser.c:357
 msgid "WHERE conditions of SQL statement without 'where' keyword"
@@ -2755,33 +2811,28 @@
 msgstr "Название базы данных"
 #: ../lib/gis/parser.c:391
-#, fuzzy
 msgid "Name of attribute column"
 msgstr "Имя поля"
 #: ../lib/gis/parser.c:400
-#, fuzzy
 msgid "Name of attribute column(s)"
 msgstr "Имя поля(ей)"
 #: ../lib/gis/parser.c:411
-#, fuzzy
 msgid "Name of input imagery group"
 msgstr "Имя исходной группы изображений"
 #: ../lib/gis/parser.c:419
-#, fuzzy
 msgid "Name of input imagery subgroup"
-msgstr "Имя исходной группы изображений"
+msgstr "Имя исходной подгруппы изображений"
 #: ../lib/gis/parser.c:429 ../lib/gis/parser.c:454
 msgid "Name of input raster map"
 msgstr "Имя исходной растровой карты"
 #: ../lib/gis/parser.c:438 ../lib/gis/parser.c:463
-#, fuzzy
 msgid "Name of input raster map(s)"
-msgstr "Имя исходной растровой карт(ы)"
+msgstr "Имя исходного(ых) растрового(ых) слоя(слоев)"
 #: ../lib/gis/parser.c:446
 msgid "Name for output raster map"
@@ -2796,44 +2847,36 @@
 msgstr "Имя верхней растровой карты"
 #: ../lib/gis/parser.c:487
-#, fuzzy
 msgid "Name of elevation raster map"
-msgstr "Имя растровой карты рельефа"
+msgstr "Имя растрового слоя высот"
 #: ../lib/gis/parser.c:496
-#, fuzzy
 msgid "Name of elevation raster map(s)"
-msgstr "Имя растровых(ой) карт(ы) рельефа"
+msgstr "Имя растрового(ыз) слоя(слоев) высот"
 #: ../lib/gis/parser.c:506 ../lib/gis/parser.c:531
-#, fuzzy
 msgid "Name of input raster3d map"
-msgstr "Имя исходной raster3d карты"
+msgstr "Имя исходного raster3d слоя"
 #: ../lib/gis/parser.c:515 ../lib/gis/parser.c:540
-#, fuzzy
 msgid "Name of input raster3d map(s)"
-msgstr "Имя исходных(ой) raster3d карт(ы)"
+msgstr "Имя исходного(ых) raster3d слоя(слоев)"
 #: ../lib/gis/parser.c:523
-#, fuzzy
 msgid "Name for output raster3d map"
-msgstr "Имя выходной raster3d карты"
+msgstr "Имя выходного raster3d слоя"
 #: ../lib/gis/parser.c:550 ../lib/gis/parser.c:575
-#, fuzzy
 msgid "Name of input vector map"
-msgstr "Имя исходной векторной карты"
+msgstr "Имя исходного векторного слоя"
 #: ../lib/gis/parser.c:559 ../lib/gis/parser.c:584
-#, fuzzy
 msgid "Name of input vector map(s)"
-msgstr "Имя исходных(ой) векторных(ой) карт(ы)"
+msgstr "Имя исходного(ых) векторного(ых) слоя(слоев)"
 #: ../lib/gis/parser.c:567
-#, fuzzy
 msgid "Name for output vector map"
-msgstr "Имя выходной векторной карты"
+msgstr "Имя выходного векторного слоя"
 #: ../lib/gis/parser.c:593
 msgid "Type"
@@ -2868,12 +2911,10 @@
 msgstr "Пример: 1,3,7-9,13"
 #: ../lib/gis/parser.c:628
-#, fuzzy
 msgid "Name of input file"
 msgstr "Имя исходного файла"
 #: ../lib/gis/parser.c:636
-#, fuzzy
 msgid "Name for output file"
 msgstr "Имя выходного файла"
@@ -2900,18 +2941,22 @@
 #: ../lib/gis/parser.c:811
 #, c-format
 msgid "BUG in descriptions, option '%s' in <%s> does not exist"
-msgstr ""
+msgstr "Ошибка в описаниях, опция %s в <%s> не существует"
 #: ../lib/gis/parser.c:906
 msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
 msgstr ""
+"Используйте либо флаг --quiet либо --verbose, но не оба вместе. "
+"Предполагается --verbose."
 #: ../lib/gis/parser.c:920
 msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
 msgstr ""
+"Предполагается --quiet."
 #: ../lib/gis/parser.c:950
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry <%s> is not a valid option\n"
 msgstr "Извините, опция <%s> неверна\n"
@@ -2975,7 +3020,7 @@
 "Параметры:\n"
 #: ../lib/gis/parser.c:1191
-#, fuzzy, c-format
+#, c-format
 msgid "  %*s   default: %s\n"
 msgstr "  %*s   по умолчанию: %s\n"
@@ -3000,12 +3045,10 @@
 msgstr "Параметры"
 #: ../lib/gis/parser.c:1694
-#, fuzzy
 msgid "Options"
 msgstr "Опции"
 #: ../lib/gis/parser.c:1700
-#, fuzzy
 msgid "Default"
 msgstr "По умолчанию"
@@ -3023,35 +3066,34 @@
 #: ../lib/gis/parser.c:1976
 msgid "Unable to spawn the 'wish' program"
-msgstr ""
+msgstr "Неудается запустить программу 'wish'"
 #: ../lib/gis/parser.c:1995
-#, fuzzy
 msgid "Unable to determine program name"
-msgstr "невозможно определить домашний каталог пользователя"
+msgstr "Невозможно определить имя программы"
 #: ../lib/gis/parser.c:2052
-#, fuzzy, c-format
+#, c-format
 msgid "  %*s   options: "
 msgstr "  %*s   опции: "
 #: ../lib/gis/parser.c:2097 ../lib/gis/parser.c:2112
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry, <%c> is not a valid flag\n"
 msgstr "Извините, флаг <%c> неверен\n"
 #: ../lib/gis/parser.c:2170
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry, <%s=> is ambiguous\n"
 msgstr "Извините, параметр <%s=> неоднозначен\n"
 #: ../lib/gis/parser.c:2176
-#, fuzzy, c-format
+#, c-format
 msgid "Sorry, <%s> is not a valid parameter\n"
 msgstr "Извините, параметр <%s> неверен\n"
 #: ../lib/gis/parser.c:2254
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "ERROR: illegal range syntax for parameter <%s>\n"
@@ -3060,12 +3102,12 @@
 "Ошибка: неверный синтаксис диапазона для параметра <%s>\n"
 #: ../lib/gis/parser.c:2255
-#, fuzzy, c-format
+#, c-format
 msgid "       Presented as: %s\n"
 msgstr "       Представленного как: %s\n"
 #: ../lib/gis/parser.c:2259
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "ERROR: value <%s> out of range for parameter <%s>\n"
@@ -3074,12 +3116,12 @@
 "Ошибка: значение <%s> выходит за диапазон параметра <%s>\n"
 #: ../lib/gis/parser.c:2261
-#, fuzzy, c-format
+#, c-format
 msgid "       Legal range: %s\n"
 msgstr "       Возможный диапазон: %s\n"
 #: ../lib/gis/parser.c:2264
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "ERROR: Missing value for parameter <%s>\n"
@@ -3102,7 +3144,7 @@
 msgstr " опции: %s\n"
 #: ../lib/gis/parser.c:2398
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "ERROR: Required parameter <%s> not set:\n"
@@ -3113,121 +3155,115 @@
 "    (%s).\n"
 #: ../lib/gis/parser.c:2493
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "\n"
 "ERROR: option <%s> must be provided in multiples of %d\n"
 msgstr ""
 "\n"
-"Ошибка: опция <%s> должна задаваться в значениях %d\n"
+"Ошибка: опция <%s> должна задаваться в множественных значениях %d\n"
 #: ../lib/gis/parser.c:2495
-#, fuzzy, c-format
+#, c-format
 msgid "       You provided %d items:\n"
 msgstr "       Вы задали %d раз:\n"
 #: ../lib/gis/parser.c:2553
-#, fuzzy, c-format
+#, c-format
 msgid "ERROR: option <%s>: <%s> exists.\n"
 msgstr "Ошибка: опция <%s>: <%s> существует.\n"
 #: ../lib/gis/reclass.c:143
-#, fuzzy, c-format
+#, c-format
 msgid "Too many reclass categories for [%s in %s]"
 msgstr "Слишком много категорий для реклассификации [%s в %s]"
 #: ../lib/gis/reclass.c:146
-#, fuzzy, c-format
+#, c-format
 msgid "Illegal reclass format in header file for [%s in %s]"
 msgstr "Неправильный формат реклассификации в файле заголовка для [%s в %s]"
 #: ../lib/gis/reclass.c:235
-#, fuzzy
 msgid "Illegal reclass request"
 msgstr "Данная реклассификация невозможна"
 #: ../lib/gis/reclass.c:240
-#, fuzzy
 msgid "Illegal reclass type"
 msgstr "Неправильно задан тип реклассификации"
 #: ../lib/gis/reclass.c:246
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create header file for [%s in %s]"
 #: ../lib/gis/reclass.c:294
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create dependency file in [%s in %s]"
-msgstr "Невозможно создать сопутствующий dependency файл для [%s в %s]"
+msgstr "Невозможно создать файл зависимости для [%s в %s]"
 #: ../lib/gis/quant_rw.c:206
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot write quant rules: map %s is integer"
-msgstr "Невозможно записать правила разбиения значений: карта %s целочисленная"
+msgstr "Невозможно записать правила разбиения значений: слой %s целочисленный "
 #: ../lib/gis/quant_rw.c:215
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot write quant rules for map %s"
-msgstr "Невозможно записать правила разбиения значений для карты %s"
+msgstr "Невозможно записать правила разбиения значений для слоя %s"
 #: ../lib/gis/raster_metadata.c:111
-#, fuzzy, c-format
+#, c-format
 msgid "Can't read %s for [%s in %s]"
-msgstr "Невозможно прочесть гистограмму для [%s в %s]"
+msgstr "Невозможно прочесть %s для [%s в %s]"
 #: ../lib/gis/raster_metadata.c:144
-#, fuzzy, c-format
+#, c-format
 msgid "Can't create %s metadata file for [%s in %s]"
-msgstr "Невозможно прочесть файл заголовка для [%s в %s]\n"
+msgstr "Невозможно создать %s файл метаданных для [%s в %s]"
 #: ../lib/gis/open.c:62
 #, c-format
 msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgstr "G__open(read): набор <%s> не совпадает с xmapset <%s>"
 #: ../lib/gis/open.c:84
 #, c-format
 msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open(write): xmapset <%s> != G_mapset() <%s>"
 #: ../lib/gis/timestamp.c:282
-#, fuzzy, c-format
+#, c-format
 msgid "Can't create timestamp file for %s map %s in mapset %s"
-msgstr "     "
+msgstr "Невозможно создать файл временной метки для %s карты %s в наборе %s"
 #: ../lib/gis/timestamp.c:291
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp specified for %s map %s in mapset %s"
-msgstr "Задана неверная временная метка для %s карты %s в наб. данных %s"
+msgstr "Задана неверная временная метка для %s карты %s в наборе %s"
 #: ../lib/gis/timestamp.c:313
-#, fuzzy, c-format
+#, c-format
 msgid "Can't open timestamp file for %s map %s in mapset %s"
-msgstr "     "
+msgstr "Невозможно открыть файл временной метки для карты %s %s в наборе %s"
 #: ../lib/gis/timestamp.c:322
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid timestamp file for %s map %s in mapset %s"
-msgstr "Неверный формат файла временной метки для %s карты %s в наб. данных %s"
+msgstr "Неверный формат файла временной метки для %s карты %s в наборе %s"
 #: ../lib/gis/adj_cellhd.c:47 ../lib/gis/adj_cellhd.c:199
-#, fuzzy
 msgid "Illegal n-s resolution value"
-msgstr "Неверно задано разрешение n-s"
+msgstr "Неверно задано разрешение север-юг"
 #: ../lib/gis/adj_cellhd.c:51 ../lib/gis/adj_cellhd.c:205
-#, fuzzy
 msgid "Illegal row value"
 msgstr "Неправильная величина строки"
 #: ../lib/gis/adj_cellhd.c:55 ../lib/gis/adj_cellhd.c:211
-#, fuzzy
 msgid "Illegal e-w resolution value"
-msgstr "Неверно задано разрешение e-w"
+msgstr "Неверно задано разрешение восток-запад"
 #: ../lib/gis/adj_cellhd.c:59 ../lib/gis/adj_cellhd.c:217
-#, fuzzy
 msgid "Illegal col value"
 msgstr "Неправильная величина столбца"
@@ -3237,7 +3273,6 @@
 msgstr "Исправление ошибки округления для северной границы (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:84 ../lib/gis/adj_cellhd.c:252
-#, fuzzy
 msgid "Illegal latitude for North"
 msgstr "Неправильная широта для Севера"
@@ -3247,7 +3282,6 @@
 msgstr "Исправление ошибки округления для южной границы (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:95 ../lib/gis/adj_cellhd.c:263
-#, fuzzy
 msgid "Illegal latitude for South"
 msgstr "Неправильная широта для Юга"
@@ -3262,22 +3296,18 @@
 msgstr "Исправление ошибки округления для восточной границы (%g>%g)"
 #: ../lib/gis/adj_cellhd.c:131 ../lib/gis/adj_cellhd.c:299
-#, fuzzy
 msgid "North must be north of South"
 msgstr "Север должен быть к северу от Юга"
 #: ../lib/gis/adj_cellhd.c:133 ../lib/gis/adj_cellhd.c:301
-#, fuzzy
 msgid "North must be larger than South"
 msgstr "Север должен быть больше Юга"
 #: ../lib/gis/adj_cellhd.c:136 ../lib/gis/adj_cellhd.c:304
-#, fuzzy
 msgid "East must be larger than West"
 msgstr "Восток должен быть больше Запада"
 #: ../lib/gis/adj_cellhd.c:155 ../lib/gis/adj_cellhd.c:348
-#, fuzzy
 msgid "Invalid coordinates"
 msgstr "Неверные координаты"
@@ -3306,211 +3336,177 @@
 msgstr "Неправильное значение глубины"
 #: ../lib/gis/adj_cellhd.c:306
-#, fuzzy
 msgid "Top must be larger than Bottom"
 msgstr "Верх должен быть больше Низа"
 #: ../lib/gis/open_misc.c:45
 #, c-format
 msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
-msgstr ""
+msgstr "G__open_misc(read): набор <%s> не совпадает с xmapset <%s>"
 #: ../lib/gis/open_misc.c:67
 #, c-format
 msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
-msgstr ""
+msgstr "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
 #: ../lib/gis/rd_cellhd.c:134
-#, fuzzy
 msgid "duplicate projection field"
 msgstr "дважды задано поле проекции"
 #: ../lib/gis/rd_cellhd.c:144
-#, fuzzy
 msgid "duplicate zone field"
 msgstr "дважды задано поле зоны"
 #: ../lib/gis/rd_cellhd.c:154
-#, fuzzy
 msgid "projection field missing"
 msgstr "отсутствует поле проекции"
 #: ../lib/gis/rd_cellhd.c:156
-#, fuzzy
 msgid "zone field missing"
 msgstr "отсутствует поле зоны"
 #: ../lib/gis/rd_cellhd.c:178
-#, fuzzy
 msgid "duplicate north field"
 msgstr "дважды задано поле север"
 #: ../lib/gis/rd_cellhd.c:186
-#, fuzzy
 msgid "duplicate south field"
 msgstr "дважды задано поле юг"
 #: ../lib/gis/rd_cellhd.c:194
-#, fuzzy
 msgid "duplicate east field"
 #: ../lib/gis/rd_cellhd.c:202
-#, fuzzy
 msgid "duplicate west field"
 msgstr "дважды задано поле запад"
 #: ../lib/gis/rd_cellhd.c:210
-#, fuzzy
 msgid "duplicate top field"
 msgstr "дублирующееся верхнее поле"
 #: ../lib/gis/rd_cellhd.c:218
-#, fuzzy
 msgid "duplicate bottom field"
 msgstr "дублирующееся нижнее поле"
 #: ../lib/gis/rd_cellhd.c:226
-#, fuzzy
 msgid "duplicate e-w resolution field"
-msgstr "дважды задано поле разрешения в-з"
+msgstr "дважды задано поле разрешения восток-запад"
 #: ../lib/gis/rd_cellhd.c:236
-#, fuzzy
 msgid "duplicate 3D e-w resolution field"
-msgstr "дублирующееся поле 3D разрешения восток-запад "
+msgstr "дублирующееся поле разрешения 3D восток-запад"
 #: ../lib/gis/rd_cellhd.c:246
-#, fuzzy
 msgid "duplicate n-s resolution field"
-msgstr "дважды задано поле разрешения с-ю"
+msgstr "дублирующееся поле разрешения север-юг"
 #: ../lib/gis/rd_cellhd.c:256
-#, fuzzy
 msgid "duplicate 3D n-s resolution field"
-msgstr " "
+msgstr "дублирующееся поле разрешения 3D север-юг"
 #: ../lib/gis/rd_cellhd.c:266
-#, fuzzy
 msgid "duplicate t-b resolution field"
 msgstr "дублирующееся поле разрешения верх-низ"
 #: ../lib/gis/rd_cellhd.c:276
-#, fuzzy
 msgid "duplicate rows field"
 msgstr "дважды задано поле строк"
 #: ../lib/gis/rd_cellhd.c:286
-#, fuzzy
 msgid "duplicate 3D rows field"
 msgstr "дублирующее поле 3D строк"
 #: ../lib/gis/rd_cellhd.c:296
-#, fuzzy
 msgid "duplicate cols field"
 msgstr "дважды задано поле столбцов"
 #: ../lib/gis/rd_cellhd.c:306
-#, fuzzy
 msgid "duplicate 3D cols field"
-msgstr "дублирующее поле 3D колонок"
+msgstr "дублирующее поле 3D столбцов"
 #: ../lib/gis/rd_cellhd.c:316
 msgid "duplicate depths field"
 msgstr "дублирующееся поле глубин"
 #: ../lib/gis/rd_cellhd.c:326
-#, fuzzy
 msgid "duplicate format field"
 msgstr "дважды задано поле формата"
 #: ../lib/gis/rd_cellhd.c:334
-#, fuzzy
 msgid "duplicate compressed field"
 msgstr "дважды задано поле сжатия"
 #: ../lib/gis/rd_cellhd.c:345
-#, fuzzy
 msgid "north field missing"
-msgstr "отсутствует поле север"
+msgstr "отсутствует поле north"
 #: ../lib/gis/rd_cellhd.c:347
-#, fuzzy
 msgid "south field missing"
-msgstr "отсутствует поле юг"
+msgstr "отсутствует поле south"
 #: ../lib/gis/rd_cellhd.c:349
-#, fuzzy
 msgid "west field missing"
-msgstr "отсутствует поле запад"
+msgstr "отсутствует поле west"
 #: ../lib/gis/rd_cellhd.c:351
-#, fuzzy
 msgid "east field missing"
-msgstr "отсутствует поле восток"
+msgstr "отсутствует поле east"
 #: ../lib/gis/rd_cellhd.c:353
-#, fuzzy
 msgid "cols field missing"
-msgstr "отсутствует поле столбцов"
+msgstr "отсутствует поле cols"
 #: ../lib/gis/rd_cellhd.c:355
-#, fuzzy
 msgid "rows field missing"
-msgstr "отсутствует поле строк"
+msgstr "отсутствует поле rows"
 #: ../lib/gis/rd_cellhd.c:366
-#, fuzzy
 msgid "ewres3 field missing"
-msgstr "отсутствует"
+msgstr "отсутствует поле ewres3"
 #: ../lib/gis/rd_cellhd.c:368
-#, fuzzy
 msgid "nsres3 field missing"
+msgstr "отсутствует поле nsres3"
 #: ../lib/gis/rd_cellhd.c:370
-#, fuzzy
 msgid "cols3 field missing"
+msgstr "отсутствует поле cols3"
 #: ../lib/gis/rd_cellhd.c:372
-#, fuzzy
 msgid "rows3 field missing"
+msgstr "отсутствует поле rows3"
 #: ../lib/gis/rd_cellhd.c:429
-#, fuzzy, c-format
+#, c-format
 msgid "line %d: <%s>"
 msgstr "строка %d: <%s>"
 #: ../lib/gis/auto_mask.c:64
-#, fuzzy
 msgid "Unable to open automatic MASK file"
-msgstr "Невозможно открыть MASK файл автоматически"
+msgstr "Невозможно открыть автоматически MASK файл "
 #: ../lib/gis/env.c:242
-#, fuzzy
 msgid "GISRC - variable not set"
 msgstr "GISRC - переменная не установлена"
 #: ../lib/gis/env.c:274
-#, fuzzy, c-format
+#, c-format
 msgid "G_getenv(): Variable %s not set"
-msgstr "GISRC - переменная не установлена"
+msgstr "G_getenv(): Переменная %s не установлена"
 #: ../lib/gis/env.c:300
-#, fuzzy, c-format
+#, c-format
 msgid "%s not set"
 msgstr "%s не установлен"
 #: ../lib/gis/done_msg.c:38
-#, fuzzy, c-format
+#, c-format
 msgid "%s complete. %s"
 msgstr "%s завершен. %s"
 #: ../lib/gis/get_window.c:67 ../lib/gis/get_window.c:85
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "region for current mapset %s\n"
 "run \"g.region\""
@@ -3519,17 +3515,16 @@
 "выполните \"g.region\""
 #: ../lib/gis/get_window.c:120
-#, fuzzy, c-format
+#, c-format
 msgid "default region %s"
 msgstr "регион по умолчанию %s"
 #: ../lib/gis/get_window.c:141
-#, fuzzy
 msgid "is not set"
 msgstr "не установлен"
 #: ../lib/gis/get_window.c:150
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "is invalid\n"
 "%s"
@@ -3538,50 +3533,49 @@
 "%s"
 #: ../lib/gis/mask_info.c:40
-#, fuzzy, c-format
+#, c-format
 msgid "<%s> in mapset <%s>"
 msgstr "<%s> в наборе <%s>"
 #: ../lib/gis/mask_info.c:43
-#, fuzzy
 msgid "none"
 msgstr "нет"
 #: ../lib/gis/mask_info.c:46
-#, fuzzy
 msgid "not known"
 msgstr "неизвестно"
 #: ../lib/gis/color_read.c:116
-#, fuzzy, c-format
+#, c-format
 msgid "color support for [%s] in mapset [%s] %s"
 msgstr "поддержка цвета для [%s] в наборе [%s] %s"
 #: ../lib/gis/view.c:177
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s for writing"
 msgstr "Невозможно открыть %s для записи"
 #: ../lib/gis/view.c:263 ../lib/gis/view.c:480
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open %s for reading"
 msgstr "Невозможно открыть %s для чтения"
 #: ../lib/gis/view.c:466
-#, fuzzy, c-format
+#, c-format
 msgid "GRASS window when view was saved:\n"
-msgstr "Окно GRASS в момент сохранения композиции:\n"
+msgstr "Окно GRASS в момент сохранения вида:\n"
 #: ../lib/gis/view.c:546
-#, fuzzy, c-format
+#, c-format
 msgid " Window saved in \"%s\" is completely outside of current GRASS window."
-msgstr " Окно, сохр. в \"%s\" полностью за пределами текущ. окна GRASS."
+msgstr " Окно сохранено в \"%s\" полностью за пределами текущего окна GRASS."
 #: ../lib/gis/view.c:550
-#, fuzzy, c-format
+#, c-format
 msgid ""
 " Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
-msgstr " ."
+msgstr ""
+" Только %d%% окна сохранено в \"%s\" пересекается с текущим окном GRASS."
 #: ../lib/gis/alloc.c:45
 msgid "G_malloc: out of memory"
@@ -3596,59 +3590,59 @@
 msgstr "G_realloc: out of memory"
 #: ../lib/gis/histogram.c:57
-#, fuzzy, c-format
+#, c-format
 msgid "Histogram for [%s in %s] missing (run r.support)"
 msgstr "Гистограмма для [%s в %s] отсутствует (выполните r.support)"
 #: ../lib/gis/histogram.c:65
-#, fuzzy, c-format
+#, c-format
 msgid "Can't read histogram for [%s in %s]"
 #: ../lib/gis/histogram.c:74 ../lib/gis/histogram.c:84
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid histogram file for [%s in %s]"
-msgstr "Неверный формат файла гистограммы [%s в %s]"
+msgstr "Неверный файл гистограммы [%s в %s]"
 #: ../lib/gis/histogram.c:356
-#, fuzzy, c-format
+#, c-format
 msgid "can't create histogram for [%s in %s]"
 msgstr "невозможно создать гистограмму для [%s в %s]"
 #: ../lib/imagery/fopen.c:23
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create file [%s] of group [%s in %s]"
+msgstr "Невозможно создать файл [%s] группы [%s в %s]"
 #: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file [%s] of group [%s in %s]"
+msgstr "Невозможно открыть файл [%s] группы [%s в %s]"
 #: ../lib/imagery/fopen.c:49
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr "не могу найти [%s] в [%s]"
+msgstr "Невозможно найти файл [%s] группы [%s в %s]"
 #: ../lib/imagery/fopen.c:79
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr "Невозможно создать файл [%s] для подгруппы [%s] или группы [%s в %s]"
 #: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
+msgstr "Невозможно открыть файл [%s] для подгруппы [%s] или группы [%s в %s]"
 #: ../lib/imagery/fopen.c:116
 #, c-format
 msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+msgstr "Невозможно найти файл [%s] или подгруппу [%s] группы [%s в %s]"
 #: ../lib/imagery/target.c:38
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read target file for group [%s]"
+msgstr "Невозможно прочитать целевой файл для группы [%s]"
 #: ../lib/psdriver/Graph_set.c:199
 #, c-format
@@ -3668,172 +3662,162 @@
 #: ../lib/ogsf/Gv3.c:249
 #, c-format
 msgid "No features from vector map <%s> fall within current region"
-msgstr ""
+msgstr "Объекты с векторного слоя <%s> не попадают в текущий регион"
 #: ../lib/ogsf/Gv3.c:254
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> loaded (%d features)"
-msgstr "вектор  "
+msgstr "Векторный слой <%s> загружен (%d объектов)"
 #: ../lib/ogsf/gk.c:322
 msgid "Need at least 3 keyframes for spline"
-msgstr ""
+msgstr "Нужно по крайней мере 3 фрейма для сплайна"
 #: ../lib/ogsf/gk.c:624
 msgid "Need at least 2 keyframes for interpolation"
-msgstr ""
+msgstr "Нужно по крайней мере 2 фрейма для интерполяции"
 #: ../lib/ogsf/GVL2.c:249
-#, fuzzy, c-format
+#, c-format
 msgid "Loading 3d raster map <%s>..."
-msgstr " Растровая карта %s@%s пуста"
+msgstr "Загрузка растрового 3d слоя <%s>..."
 #: ../lib/ogsf/Gvl3.c:39 ../lib/ogsf/gvl_file.c:428
-#, fuzzy, c-format
+#, c-format
 msgid "3D raster map <%s> not found"
-msgstr "вектор  "
+msgstr "Растровый 3D слой <%s> не найден"
 #: ../lib/ogsf/gsd_img_mpeg.c:63
-#, fuzzy
 msgid "Unable to allocate stream"
-msgstr "Невозможно выделить память\n"
+msgstr "Невозможно выделить поток"
 #: ../lib/ogsf/gsd_img_mpeg.c:156
-#, fuzzy
 msgid "Video codec not found"
-msgstr "вектор  "
+msgstr "Не найден видео кодэк"
 #: ../lib/ogsf/gsd_img_mpeg.c:162
-#, fuzzy
 msgid "Unable to open codec"
+msgstr "Невозможно открыть кодэк"
 #: ../lib/ogsf/gsd_img_mpeg.c:181
-#, fuzzy
 msgid "Unable to allocate picture"
+msgstr "Невозможно разместить изображение"
 #: ../lib/ogsf/gsd_img_mpeg.c:192
-#, fuzzy
 msgid "Unable to allocate temporary picture"
+msgstr "Невозможно разместить временное изображение"
 #: ../lib/ogsf/gsd_img_mpeg.c:252
-#, fuzzy
 msgid "Error while writing video frame"
-msgstr "Ошибка записи в файл с плавающей точкой для карты %s"
+msgstr "Ошибка записи видео фрэйма"
 #: ../lib/ogsf/gsd_img_mpeg.c:298
 #, c-format
 msgid "Opening MPEG stream <%s>..."
-msgstr ""
+msgstr "Открыть поток MPEG <%s>..."
 #: ../lib/ogsf/gsd_img_mpeg.c:306
 msgid "Unable to deduce output format from file extension: using MPEG"
 msgstr ""
+"Невозможно определить выходной формат по расширению файла: использую MPEG"
 #: ../lib/ogsf/gsd_img_mpeg.c:310
-#, fuzzy
 msgid "Unable to find suitable output format"
-msgstr "вектор  "
+msgstr "Невозможно найти подходящий выходной формат"
 #: ../lib/ogsf/gsd_img_mpeg.c:337
-#, fuzzy
 msgid "Invalid output format parameters"
-msgstr " "
+msgstr "Неправильные параметры выходного формата"
 #: ../lib/ogsf/gsd_img_mpeg.c:351
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open <%s>"
+msgstr "Невозможно открыть <%s>"
 #: ../lib/ogsf/gsd_img_mpeg.c:361
 msgid "NVIZ has not been built with MPEG output support"
-msgstr ""
+msgstr "NVIZ был собран без поддержки выходного формата MPEG"
 #: ../lib/ogsf/gsd_img_ppm.c:53 ../lib/ogsf/gsd_img_ppm.c:96
 #: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:219
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open file <%s> for writing"
-msgstr "Невозможно открыть %s для записи"
+msgstr "Невозможно открыть файл <%s> для записи"
 #: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
 msgid "Unable to process vector map - out of memory"
-msgstr " "
+msgstr "Невозможно обработать векторный слой - нет памяти"
 #: ../lib/ogsf/gsd_legend.c:245
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read color file of raster map <%s>"
+msgstr "Невозможно прочитать цветовой файл для растрового слоя <%s>"
 #: ../lib/ogsf/gsd_legend.c:251
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read category file of raster map <%s>"
+msgstr "Невозможно прочитать файл категорий растрового слоя <%s>"
 #: ../lib/ogsf/gsd_legend.c:268
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read fp range of raster map <%s>"
-msgstr " "
+msgstr "Невозможно прочитать fp диапазон растрового слоя <%s>"
 #: ../lib/ogsf/gsd_legend.c:280
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read range of raster map <%s>"
-msgstr " "
+msgstr "Невозможно прочитать диапазон растрового слоя <%s>"
 #: ../lib/ogsf/gsd_legend.c:294
 msgid "Range request error for legend"
-msgstr ""
+msgstr "Ошибка запроса диапазона легенды"
 #: ../lib/ogsf/gsd_legend.c:384
-#, fuzzy
 msgid "Unable to show discrete FP range (use list"
+msgstr "Невозможно показать дискретный FP диапазон (используйте список"
 #: ../lib/ogsf/gsd_legend.c:500
-#, fuzzy
 msgid "Too many categories to show as discrete!"
-msgstr "Слишком много категорий для реклассификации [%s в %s]"
+msgstr "Слишком много категорий чтобы использовать дискретную легенду!"
 #: ../lib/ogsf/gsd_legend.c:502
 msgid "Try using smaller font!"
-msgstr ""
+msgstr "Попробуйте использовать меньший размер шрифта!"
 #: ../lib/ogsf/Gs3.c:133 ../lib/ogsf/Gs3.c:207 ../lib/ogsf/Gs3.c:364
 #: ../lib/ogsf/Gs3.c:479 ../lib/ogsf/Gs3.c:583
-#, fuzzy
 msgid "Unable to allocate memory for a null buffer"
+msgstr "Невозможно выделить память для нулевого буфера"
 #: ../lib/ogsf/Gs3.c:140 ../lib/ogsf/Gs3.c:214 ../lib/ogsf/Gs3.c:376
 #: ../lib/ogsf/Gs3.c:491 ../lib/ogsf/Gs3.c:586
-#, fuzzy, c-format
+#, c-format
 msgid "Loading raster map <%s>..."
+msgstr "Чтение растрового слоя <%s>..."
 #: ../lib/ogsf/Gs3.c:643
 #, c-format
 msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
 msgstr ""
+"Диапазон цветовой таблицы не соответствует данным (mincol=%d, maxcol=%d"
 #: ../lib/ogsf/Gs3.c:705 ../lib/ogsf/Gs3.c:775
-#, fuzzy, c-format
+#, c-format
 msgid "Translating colors from raster map <%s>..."
-msgstr "вектор    "
+msgstr "Трансляция цветов для растрового слоя  <%s>..."
 #: ../lib/ogsf/Gs3.c:1012
 msgid "View not saved by this program,there may be some inconsistancies"
-msgstr ""
+msgstr "Вид не сохранен этой программой, существуют несостыковки"
 #: ../lib/ogsf/gsds.c:109
 msgid "Maximum number of datasets exceeded"
-msgstr ""
+msgstr "Превышено максимальное число наборов данных"
 #: ../lib/ogsf/gsd_prim.c:146
 #, c-format
 msgid "Color Material: %d"
-msgstr ""
+msgstr "Цвет материала: %d"
 #: ../lib/ogsf/gsd_prim.c:630
 #, c-format
@@ -3841,94 +3825,94 @@
 "gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
 "advise GRASS developers of this error"
 msgstr ""
+"gsd_rot(): %c неправильная спецификация оси. Поворот игнорирован. Свяжитесь "
+"с разработчиками GRASS"
 #: ../lib/ogsf/gsd_surf.c:1742
 msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
 msgstr ""
+"Точки поверхностей секущие плоскость не совпадают. Проверьте разрешение"
+"(разрешения)."
 #: ../lib/ogsf/gsd_label.c:58
 msgid "Max. number of labels reached!"
-msgstr ""
+msgstr "Достигнуто максимальное значение подписей!"
 #: ../lib/ogsf/GK2.c:275 ../lib/ogsf/GK2.c:288
 msgid "Check no. of frames requested and keyframes marked"
-msgstr ""
+msgstr "Проверьте число запрошенных фреймов и отмеченных ключевых фреймов"
 #: ../lib/ogsf/gs_bm.c:124
 msgid "Bitmap mismatch"
-msgstr ""
+msgstr "Несовпадение битмэпов"
 #: ../lib/ogsf/gvl_file.c:104
 msgid "Maximum number of datafiles exceeded"
-msgstr ""
+msgstr "Превышено максимальное количество файлов!"
 #: ../lib/ogsf/gvl_file.c:437
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to open 3D raster map <%s>"
-msgstr " "
+msgstr "Невозможно открыть растровый 3D слой <%s>"
 #: ../lib/ogsf/gvl_file.c:443
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to read range of 3D raster map <%s>"
-msgstr " "
+msgstr "Невозможно прочесть диапазон растрового 3D слоя <%s>"
 #: ../lib/ogsf/gvl_file.c:471
-#, fuzzy, c-format
+#, c-format
 msgid "Unable to close 3D raster map <%s>"
-msgstr " "
+msgstr "Невозможно закрыть растровый 3D слой <%s>"
 #: ../lib/ogsf/trans.c:180
 msgid "Out of matrix stack space"
-msgstr ""
+msgstr "Превышено ограничение на стэк матрицы"
 #: ../lib/ogsf/trans.c:200
 msgid "Tried to pop an empty stack"
-msgstr ""
+msgstr "Попытка получить пустой стэк"
 #: ../lib/ogsf/Gp3.c:204
 #, c-format
 msgid "No points from vector map <%s> fall within current region"
-msgstr ""
+msgstr "Точки векторного слоя <%s> не попадают в текущий регион"
 #: ../lib/ogsf/Gp3.c:209
-#, fuzzy, c-format
+#, c-format
 msgid "Vector map <%s> loaded (%d points)"
-msgstr "вектор  "
+msgstr "Векторный слой <%s> загружен (%d точек)"
 #: ../lib/ogsf/GS2.c:1638
 #, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr ""
+msgstr "Растровый слой <%s> вне текущего региона. Загрузка прервана."
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
 #: ../lib/ogsf/GS2.c:1805
 msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr ""
+msgstr "GS_load_att_map(): Нет памяти. Невозможно загрузить слой"
 #: ../lib/ogsf/GS2.c:1833
-#, fuzzy
 msgid "Loading failed"
-msgstr "Нет подключения\n"
+msgstr "Загрузка не выполнена"
 #: ../lib/ogsf/GS2.c:1837
-#, fuzzy
 msgid "Error finding range"
-msgstr "Слишком много растровых файлов открыты"
+msgstr "Ошибка вычисления диапазона"
 #: ../lib/gmath/la.c:63 ../lib/gmath/la.c:119
 msgid "Matrix dimensions out of range"
 msgstr "Размеры матрицы вне диапазона"
 #: ../lib/gmath/la.c:152
-#, fuzzy
 msgid "Matrix is not initialised fully."
 msgstr "Матрица не полностью иннициализирована."
 #: ../lib/gmath/la.c:157
-#, fuzzy
 msgid "Unable to allocate space for matrix copy"
+msgstr "Невозможно выделить память для копии матрицы"
 #: ../lib/gmath/la.c:246
 msgid "First scalar multiplier must be non-zero"
@@ -3943,14 +3927,12 @@
 msgstr "Порядок матрицы не совпадает"
 #: ../lib/gmath/la.c:271
-#, fuzzy
 msgid "Unable to allocate space for matrix sum"
+msgstr "Невозможно выделить память для суммы матрицы"
 #: ../lib/gmath/la.c:335
-#, fuzzy
 msgid "Unable to allocate space for matrix product"
+msgstr "Невозможно выделить память для продукта матрицы"
 #: ../lib/gmath/la.c:447
 msgid "Input: one or both data matrices uninitialised"
@@ -3989,9 +3971,8 @@
 msgstr "Матрица не прямоугольная, невозможно найти обратную матрицу."
 #: ../lib/gmath/la.c:580
-#, fuzzy
 msgid "Unable to allocate space for matrix"
+msgstr "Невозможно выделить память для матрицы"
 #: ../lib/gmath/la.c:597
 msgid "Matrix is singular"
@@ -4002,7 +3983,6 @@
 msgstr "Проблема в LA процедуре."
 #: ../lib/gmath/la.c:690
-#, fuzzy
 msgid "Element array has not been allocated"
 msgstr "Массив элементов не создан"
@@ -4012,7 +3992,7 @@
 #: ../lib/gmath/la.c:749
 msgid "Specified matrix column index is outside range"
-msgstr "Указанный индекс колонки матрицы находится вне диапазона"
+msgstr "Указанный индекс столбца матрицы находится вне диапазона"
 #: ../lib/gmath/la.c:754 ../lib/gmath/la.c:795 ../lib/gmath/la.c:1108
 #: ../lib/gmath/la.c:1160 ../lib/gmath/la.c:1235
@@ -4020,9 +4000,8 @@
 msgstr "Матрица не иннициализирована"
 #: ../lib/gmath/la.c:759 ../lib/gmath/la.c:800
-#, fuzzy
 msgid "Could not allocate space for vector structure"
-msgstr "Невозможно найти место для векторной структуры"
+msgstr "Невозможно найти место для структуры векта"
 #: ../lib/gmath/la.c:790
 msgid "Specified matrix row index is outside range"
@@ -4034,15 +4013,13 @@
 #: ../lib/gmath/la.c:835
 msgid "Specified column index is outside range"
-msgstr "Указанный индекс колонки находится вне диапазона"
+msgstr "Указанный индекс столбца находится вне диапазона"
 #: ../lib/gmath/la.c:855
-#, fuzzy
 msgid "Unknown vector type."
-msgstr "Неизвестная проекция"
+msgstr "Неизвестный тип вектора."
 #: ../lib/gmath/la.c:980
-#, fuzzy
 msgid "Output vector is uninitialized"
 msgstr "Выходной вектор не иннициализирован"
@@ -4072,7 +4049,7 @@
 #: ../lib/gmath/la.c:1058
 msgid "Row/column out of range"
-msgstr "Ряд/колонка вне диапазона"
+msgstr "Ряд/столбец вне диапазона"
 #: ../lib/gmath/la.c:1273
 msgid "Vector structure is not initialised"
@@ -4123,135 +4100,139 @@
 msgstr ""
 #: ../lib/display/tran_colr.c:105 ../lib/display/tran_colr.c:107
-#, fuzzy, c-format
+#, c-format
 msgid "[%s]: No such color"
-msgstr "[%s]: Несуществующий цвет"
+msgstr "[%s]: Нет цвета"
 #: ../lib/symbol/read.c:206
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot read symbol line coordinates: %s"
-msgstr " "
+msgstr "Невозможно прочитать координаты линейного символа: %s"
 #: ../lib/symbol/read.c:254
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
-msgstr " name at mapset"
+msgstr ""
+"Неправильное имя символа: '%s' (должно быть: группа/имя или группа/имя@набор)"
 #: ../lib/symbol/read.c:278
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot find/open symbol: '%s'"
-msgstr " "
+msgstr "Невозможно найти/открыть символ: '%s'"
 #: ../lib/symbol/read.c:378 ../lib/symbol/read.c:396 ../lib/symbol/read.c:406
 #: ../lib/symbol/read.c:424
-#, fuzzy, c-format
+#, c-format
 msgid "Incorrect symbol color: '%s', using default."
-msgstr " ."
+msgstr "Неправильный символ цвета: '%s', используется символ по-умолчанию."
 #: ../lib/rst/interp_float/segmen2d.c:113
-#, fuzzy
 msgid ""
 "taking too long to find points for interpolation--please change the region "
 "to area where your points are. Continuing calculations..."
-msgstr " ."
+msgstr ""
+"попытка найти точки для интерполяции заняла слишком много времени -- "
+"попробуйте изменить регион на область где точки есть. Вычисление "
+"продолжается..."
 #: ../lib/rst/interp_float/vinput2d.c:73
-#, fuzzy
 msgid "Vector is not 3D"
-msgstr " "
+msgstr "Вектор не 3D "
 #: ../lib/rst/interp_float/vinput2d.c:76
 msgid "Loading data from attribute table ..."
-msgstr ""
+msgstr "Загружаются данные из таблицы аттрибутов"
 #: ../lib/rst/interp_float/vinput2d.c:79
 msgid "Cannot get layer info"
-msgstr ""
+msgstr "Невозможно получить информацию о слое"
 #: ../lib/rst/interp_float/vinput2d.c:87
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot open database %s"
-msgstr " "
+msgstr "Невозможно открыть базу данных %s"
 #: ../lib/rst/interp_float/vinput2d.c:92
-#, fuzzy, c-format
+#, c-format
 msgid "Cannot find z column <%s> (please verify name, e.g. with v.info)"
-msgstr " "
+msgstr ""
+"Невозможно найти столбец z <%s> (проверьте имя, например используя v.info)"
 #: ../lib/rst/interp_float/vinput2d.c:95
-#, fuzzy
 msgid "Column type of z column is not supported (must be integer or double)"
-msgstr " "
+msgstr ""
+"Тип поля для столбца z не поддерживается (должен быть целочисленный или "
+"double)"
 #: ../lib/rst/interp_float/vinput2d.c:106
 msgid "Cannot read column type of smooth column"
-msgstr ""
+msgstr "Невозможно прочитать тип столбца smooth"
 #: ../lib/rst/interp_float/vinput2d.c:108
-#, fuzzy
 msgid "Column type of smooth column (datetime) is not supported"
-msgstr " "
+msgstr "Тип столбца smooth (дата-время) не поддерживается"
 #: ../lib/rst/interp_float/vinput2d.c:110
-#, fuzzy
 msgid "Column type of s column is not supported (must be integer or double)"
-msgstr "   "
+msgstr "Тип столбца s не поддерживается (должен быть целочисленный или double)"
 #: ../lib/rst/interp_float/vinput2d.c:121
 msgid "Reading lines from vector map ... "
-msgstr ""
+msgstr "Чтение линий из векторного слоя ..."
 #: ../lib/rst/interp_float/vinput2d.c:153
 #: ../lib/rst/interp_float/vinput2d.c:271
 #, c-format
 msgid "Database record for cat %d not found"
-msgstr ""
+msgstr "Для категории %d не найдена запись в БД"
 #: ../lib/rst/interp_float/vinput2d.c:234
 msgid "Reading nodes from vector map ... "
-msgstr ""
+msgstr "Чтение узлов из векторного слоя ..."
 #: ../lib/rst/interp_float/vinput2d.c:316
 msgid "strip exists with insufficient data"
 msgstr ""
 #: ../lib/rst/interp_float/vinput2d.c:331
-#, fuzzy, c-format
+#, c-format
 msgid "there are points outside specified 2D/3D region--ignored %d points"
-msgstr " "
+msgstr "есть точки вне указанного 2D/3D региона -- игнорируются %d точек"
 #: ../lib/rst/interp_float/vinput2d.c:334
 #, c-format
 msgid "ignoring %d points -- too dense"
-msgstr ""
+msgstr "точки %d игнорируются -- точки стоят слишком часто"
 #: ../lib/rst/interp_float/vinput2d.c:338
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "%d points given for interpolation (after thinning) is less than given NPMIN=%"
 "d"
-msgstr " "
+msgstr "%d точек для интерполяции (после прореживания) меньше чем NPMIN=%d"
 #: ../lib/rst/interp_float/vinput2d.c:356
-#, fuzzy, c-format
+#, c-format
 msgid ""
 "There are less than %d points for interpolation. No segmentation is "
 "necessary, to run the program faster set segmax=%d (see manual)"
-msgstr "   "
+msgstr ""
+"Точек для интерполяции меньше чем %d. Сегментация не нужна, для ускорения "
+"выполнения программы установите segmax=%d (см. руководство)"
 #: ../lib/rst/interp_float/vinput2d.c:397
 msgid "some points outside of region -- will ignore..."
-msgstr ""
+msgstr "некоторые точки вне региона -- будут проигнорированы"
 #: ../lib/rst/interp_float/input2d.c:47
-#, fuzzy, c-format
+#, c-format
 msgid "Mask raster map <%s> not found"
-msgstr "вектор  "
+msgstr "Растровая маска <%s> не найдена"
 #: ../lib/rst/interp_float/input2d.c:69
 msgid "Bitmap mask created"
-msgstr ""
+msgstr "создана битмэп маска "
 #: ../lib/cairodriver/Raster.c:68
 msgid "Cairo_begin_scaled_raster: Failed to create surface"
@@ -4265,7 +4246,7 @@
 #: ../lib/cairodriver/Graph.c:72
 #, fuzzy
 msgid "Unable to open display"
 #: ../lib/cairodriver/Graph.c:76
 #, c-format
@@ -4275,17 +4256,17 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
+msgstr "Невозможно открыть файл %s"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
 msgid "Unable to query drawable"
+msgstr "Невозможно скопировать таблицу <%s>"
 #: ../lib/cairodriver/Graph.c:91
 #, fuzzy
 msgid "Failed to initialize Xlib surface"
+msgstr "Невозможно инициализировать pj причину: %s"
 #: ../lib/cairodriver/Graph.c:145
 #, c-format
@@ -4300,32 +4281,32 @@
 #: ../lib/cairodriver/Graph.c:312
 #, fuzzy
 msgid "Unknown Cairo surface type"
-msgstr "неизвестный тип интерполяции"
+msgstr "Неизвестный тип интерполяции"
 #: ../lib/cairodriver/Graph.c:317
 #, fuzzy
 msgid "Failed to initialize Cairo surface"
 #: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
 #, fuzzy, c-format
 msgid "Cairo: unable to open output file <%s>"
-msgstr "не могу открыть файл таблицы датумов: %s"
+msgstr "Невозможно открыть файл таблицы датумов: <%s>"
 #: ../lib/cairodriver/write_ppm.c:34
 #, fuzzy, c-format
 msgid "Cairo: unable to open mask file <%s>"
-msgstr " "
 #: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
 #, fuzzy, c-format
 msgid "Cairo: unable to open input file <%s>"
-msgstr " "
 #: ../lib/cairodriver/read_bmp.c:92 ../lib/cairodriver/read_ppm.c:32
 #, fuzzy, c-format
 msgid "Cairo: invalid input file <%s>"
-msgstr "Невозможно найти входную карту '%s'"
+msgstr "Невозможно найти исходный слой '%s'"
 #: ../lib/cairodriver/read_bmp.c:96
 #, c-format
@@ -4335,7 +4316,7 @@
 #: ../lib/cairodriver/Text.c:48
 #, fuzzy, c-format
 msgid "Unable to convert from <%s> to UTF-8"
-msgstr "невозможно открыть растровую карту [%s в %s]"
+msgstr "Невозможно скопировать векторный слой <%s> в <%s>"
 #: ../lib/cairodriver/Text.c:58
 msgid "Some characters could not be converted to UTF-8"
@@ -4349,12 +4330,12 @@
 #: ../lib/cairodriver/read_ppm.c:46
 #, fuzzy, c-format
 msgid "Cairo: unable to open input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:50
 #, fuzzy, c-format
 msgid "Cairo: invalid input mask file <%s>"
 #: ../lib/cairodriver/read_ppm.c:56
 #, c-format
@@ -4369,571 +4350,539 @@
 #: ../lib/nviz/change_view.c:108
 #, c-format
 msgid "Invalid view position coordinates, using %f,%f"
-msgstr ""
+msgstr "Неправильные координаты позиции вида, используется %f,%f"
 #: ../lib/nviz/render.c:108
 msgid "Bad server connection"
-msgstr ""
+msgstr "Плохое соединение с сервером"
 #: ../lib/nviz/render.c:117
-#, fuzzy
 msgid "Unable to create rendering context"
+msgstr "Невозможно создать контекст отрисовки"
 #: ../lib/nviz/position.c:50
-#, fuzzy
 msgid "Unable to set focus"
+msgstr "Невозможно установить фокус"
 #: ../lib/nviz/nviz.c:76
-#, fuzzy, c-format
+#, c-format
 msgid "Invalid color (%s), using \"white\" as default"
-msgstr " ."
+msgstr "Неправильный цвет: (%s), используется \"white\" по умолчанию"
 #: ../lib/nviz/map_obj.c:65
 msgid "Maximum surfaces loaded!"
-msgstr ""
+msgstr "Загружено максимальное количество поверхностей!"
 #: ../lib/nviz/map_obj.c:94
 msgid "Maximum vector line maps loaded!"
-msgstr ""
+msgstr "Загружено максимальное количество линейных векторных слоев!"
 #: ../lib/nviz/map_obj.c:103 ../lib/nviz/map_obj.c:134
-#, fuzzy, c-format
+#, c-format
 msgid "Error loading vector map <%s>"
+msgstr "Ошибка загрузки векторного слоя <%s>"
 #: ../lib/nviz/map_obj.c:122
 msgid "Maximum vector point maps loaded!"
-msgstr ""
+msgstr "Загружено максимальное количество точечных векторных слоев!"
 #: ../lib/nviz/map_obj.c:149
 msgid "Maximum volumes loaded!"
-msgstr ""
+msgstr "Загружено максимальное количество объемов!"
 #: ../lib/nviz/map_obj.c:158
-#, fuzzy, c-format
+#, c-format
 msgid "Error loading 3d raster map <%s>"
+msgstr "Ошибка загрузки растрового 3d слоя <%s>"
 #: ../lib/nviz/map_obj.c:166
 msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr ""
+msgstr "Nviz_new_map_obj(): тип данных не поддерживается"
 #: ../lib/nviz/lights.c:144
-#, fuzzy
 msgid "Unable to define new light"
+msgstr "Невозможно установить новый источник света"
-#, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Невозможно описать таблицу <%s>"
+msgid "Cannot describe table <%s>"
+msgstr "Невозможно описать таблицу <%s>"
-#~ msgid "Unknown command: %d last: %d"
-#~ msgstr "Неизвестная команда: %d last: %d"
+msgid "Unknown command: %d last: %d"
+msgstr "Неизвестная команда: %d last: %d"
-#~ msgid "Monitor: get_command: Premature EOF"
-#~ msgstr "Monitor: get_command: Premature EOF"
+msgid "Monitor: get_command: Premature EOF"
+msgstr "Monitor: get_command: Premature EOF"
-#~ msgid "Graphics driver [%s] started"
-#~ msgstr "Графический драйвер [%s] запущен"
+msgid "Graphics driver [%s] started"
+msgstr "Графический драйвер [%s] запущен"
-#, fuzzy
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "ОШИБКА %s графического драйвера.\n"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "Ошибка %s графического драйвера.\n"
-#, fuzzy
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#~ msgstr "ОШИБКА - eof from graphics monitor.\n"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "Ошибка - eof from graphics monitor.\n"
-#, fuzzy
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "Предупреждение - графический дисплей <%s> не отвечает.\n"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "Предупреждение - графический дисплей <%s> не отвечает.\n"
-#, fuzzy
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "Проверьте, работает ли мышь.\n"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "Проверьте, работает ли мышь.\n"
-#, fuzzy
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
-#~ msgstr "ОШИБКА - графический дисплей <%s> не отвечает.\n"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "Ошибка - графический дисплей <%s> не отвечает.\n"
-#, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "Не выбран графический дисплей для вывода.\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "Не выбран графический дисплей для вывода."
-#, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "Выполните \"d.mon\" для выбора графического дисплея.\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Выполните \"d.mon\" для выбора графического дисплея."
-#, fuzzy
-#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "Невозможно получить сокет для дисплея <%s>.\n"
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "Невозможно получить имя сокета для дисплея <%s>."
-#, fuzzy
-#~ msgid "No socket to connect to for monitor <%s>."
-#~ msgstr "Невозможно соединиться через сокет для дисплея <%s>.\n"
+msgid "No socket to connect to for monitor <%s>."
+msgstr "Невозможно соединиться с дисплеем через сокет <%s>."
-#, fuzzy
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr " "
+msgid "Socket is already in use or not accepting connections."
+msgstr "Сокет уже используется и не допускает соединений "
-#, fuzzy
-#~ msgid "Use d.mon to select a monitor"
+msgid "Use d.mon to select a monitor"
+msgstr "Выполните d.mon для выбора графического дисплея"
-#, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr ""
-#~ "Время для установки соединения закончилось. Вероятна ошибка сервера.\n"
+msgid "Probably an error with the server."
+msgstr "Вероятно ошибка сервера."
-#, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "Нет подключения\n"
+msgid "Connection failed."
+msgstr "Ошибка соединения."
-#, fuzzy
-#~ msgid "Unable to connect lines %d,%d"
-#~ msgstr "Невозможно открыть файл %s в %s"
+msgid "Unable to connect lines %d,%d"
+msgstr "Невозможно соединить линии %d,%d"
-#, fuzzy
-#~ msgid "Unable to open file %s"
+msgid "Unable to open file %s"
-#, fuzzy
-#~ msgid "Unable to open temporary file"
+msgid "Unable to open temporary file"
+msgstr "Невозможно открыть временный файл"
-#, fuzzy
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Нажмите RETURN для отмены\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "Нажмите RETURN для отмены\n"
-#, fuzzy
-#~ msgid "Cannot open temp file"
-#~ msgstr "Не могу открыть временный файл"
+msgid "Cannot open temp file"
+msgstr "Не могу открыть временный файл"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Пожалуйста, задайте имя эллипсоида\n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"Пожалуйста, задайте имя эллипсоида\n"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "Введите 'list' для вывода списка эллипсоидов\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "Введите 'list' для вывода списка эллипсоидов\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
-#~ "неправильный эллипсоид\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"неправильный эллипсоид\n"
-#, fuzzy
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "Выходное имя '%s' - недопустимое имя для растрового файла."
+msgid "Output name '%s' is not valid rast name."
+msgstr "Выходное имя '%s' недопустимое имя для растрового файла."
-#, fuzzy
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "Выходная карта '%s' использована как входная"
+msgid "Output map '%s' is used as input"
+msgstr "Выходной слой '%s' использован как исходный"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Пожалуйста, укажите имя датума\n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
+"Пожалуйста, укажите имя датума\n"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available datums\n"
-#~ msgstr "Введите 'list' для вывода списка доступных датумов\n"
+msgid "Enter 'list' for the list of available datums\n"
+msgstr "Введите 'list' для вывода списка доступных датумов\n"
-#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr "или 'custom' если нужно ввести другие параметры\n"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "или 'custom' если нужно ввести другие параметры\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
-#~ "неправильный датум\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"неправильный датум\n"
-#, fuzzy
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "нажмите RETURN для продолжения -->"
+msgid "hit RETURN to continue -->"
+msgstr "нажмите RETURN для продолжения -->"
-#, fuzzy
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "невозможно открыть растровую карту [%s в %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "невозможно открыть растровый слой [%s в %s]"
-#, fuzzy
-#~ msgid "one moment...\n"
-#~ msgstr "один момент...\n"
+msgid "one moment...\n"
+msgstr "один момент...\n"
-#, fuzzy
-#~ msgid "No help available for command [%s]\n"
-#~ msgstr "Нет справки для команды [%s]\n"
+msgid "No help available for command [%s]\n"
+msgstr "Нет справки для команды [%s]\n"
-#, fuzzy
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr " Растровая карта %s@%s пуста"
+msgid " The raster map %s@%s is empty"
+msgstr " Растровый слой %s@%s пуст"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Необходима цветовая для файла [%s] в наборе [%s].\n"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr ""
+"\n"
+"\n"
+"Необходима цветовая таблица для файла [%s] в наборе [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Пожалуйста, определите нужный тип:\n"
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr ""
+"\n"
+"Пожалуйста, определите нужный тип:\n"
-#, fuzzy
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "    1:  Случайные цвета\n"
+msgid "    1:  Random colors\n"
+msgstr "    1:  Случайные цвета\n"
-#, fuzzy
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "    2:  Красная, зеленая, и синяя цветовая шкала\n"
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr "    2:  Красная, зеленая, синяя цветовая шкала\n"
-#, fuzzy
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "    3:  Цветовая гамма\n"
+msgid "    3:  Color wave\n"
+msgstr "    3:  Цветовая гамма\n"
-#, fuzzy
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "    4:  Оттенки серого\n"
+msgid "    4:  Gray scale\n"
+msgstr "    4:  Оттенки серого\n"
-#, fuzzy
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "    5:  Аспект\n"
+msgid "    5:  Aspect\n"
+msgstr "    5:  Аспект\n"
-#, fuzzy
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "    6:  Радуга\n"
+msgid "    6:  Rainbow colors\n"
+msgstr "    6:  Радуга\n"
-#, fuzzy
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "    7:  От красного через желтый до зеленого\n"
+msgid "    7:  Red through yellow to green\n"
+msgstr "    7:  От красного через желтый до зеленого\n"
-#, fuzzy
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "    8:  От зеленого через желтый до красного\n"
+msgid "    8:  Green through yellow to red\n"
+msgstr "    8:  От зеленого через желтый до красного\n"
-#~ msgid "RETURN  quit\n"
-#~ msgstr "RETURN  quit\n"
+msgid "RETURN  quit\n"
+msgstr "RETURN  quit\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr "%s неверен; Попробуйте еще раз > "
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr ""
+"\n"
+"%s неверен; Попробуйте еще раз > "
-#, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "%s не найден"
+msgid "%s not found"
+msgstr "%s не найден"
-#, fuzzy
-#~ msgid "ERROR in reading %s"
-#~ msgstr "Ошибка чтения %s"
+msgid "ERROR in reading %s"
+msgstr "Ошибка чтения %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Пожалуйста, задайте название проекции\n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+"\n"
+"\n"
+"Пожалуйста, задайте название проекции\n"
-#, fuzzy
-#~ msgid "Enter 'list' for the list of available projections\n"
-#~ msgstr "Введите 'list' для списка возможных проекций\n"
+msgid "Enter 'list' for the list of available projections\n"
+msgstr "Введите 'list' для списка возможных проекций\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr ""
-#~ "\n"
-#~ "неверная проекция\n"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+"\n"
+"неверная проекция\n"
-#, fuzzy
-#~ msgid "with titles"
-#~ msgstr "с названиями"
+msgid "with titles"
+msgstr "с названиями"
-#, fuzzy
-#~ msgid "(no title)"
-#~ msgstr "(без названия)"
+msgid "(no title)"
+msgstr "(без названия)"
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Флаг: Задать следующий флаг?\n"
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr ""
+"\n"
+"Флаг: Задать следующий флаг?\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ " \n"
-#~ "Опция:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"Опция:   %s\n"
-#, fuzzy
-#~ msgid "     key: %s\n"
-#~ msgstr "     ключ: %s\n"
+msgid "     key: %s\n"
+msgstr "     ключ: %s\n"
-#, fuzzy
-#~ msgid "  format: %s\n"
-#~ msgstr "  формат: %s\n"
+msgid "  format: %s\n"
+msgstr "  формат: %s\n"
-#, fuzzy
-#~ msgid " default: %s\n"
-#~ msgstr " по умолчанию: %s\n"
+msgid " default: %s\n"
+msgstr " по умолчанию: %s\n"
-#, fuzzy
-#~ msgid "required: %s\n"
-#~ msgstr "необходимо: %s\n"
+msgid "required: %s\n"
+msgstr "необходимо: %s\n"
-#, fuzzy
-#~ msgid "multiple: %s\n"
-#~ msgstr "множ.: %s\n"
+msgid "multiple: %s\n"
+msgstr "множ.: %s\n"
-#, fuzzy
-#~ msgid "enter option > "
-#~ msgstr "введите опцию > "
+msgid "enter option > "
+msgstr "введите опцию > "
-#, fuzzy
-#~ msgid "   Try again? "
-#~ msgstr "   Попробовать снова? "
+msgid "   Try again? "
+msgstr "   Попробовать снова? "
-#, fuzzy
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "Извините, %s недопустимо.\n"
+msgid "Sorry, %s is not accepted.\n"
+msgstr "Извините, %s недопустимо.\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Вы выбрали:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Вы выбрали:\n"
+"  %s\n"
-#, fuzzy
-#~ msgid "Is this correct? "
-#~ msgstr "Правильно?"
+msgid "Is this correct? "
+msgstr "Правильно?"
-#, fuzzy
-#~ msgid "to accept the default"
-#~ msgstr "чтобы установить по умолчанию"
+msgid "to accept the default"
+msgstr "чтобы установить по умолчанию"
-#, fuzzy
-#~ msgid "to cancel request"
-#~ msgstr "для отмены"
+msgid "to cancel request"
+msgstr "для отмены запроса"
-#, fuzzy
-#~ msgid "Enter a new %s file name"
-#~ msgstr "Введите новое %s имя файла"
+msgid "Enter a new %s file name"
+msgstr "Введите новое %s имя файла"
-#, fuzzy
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr "Введите имя существующего %s файла"
+msgid "Enter the name of an existing %s file"
+msgstr "Введите имя существующего %s файла"
-#, fuzzy
-#~ msgid "Enter %s file name"
-#~ msgstr "Введите %s имя файла"
+msgid "Enter %s file name"
+msgstr "Введите %s имя файла"
-#, fuzzy
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "Введите 'list' для вывода списка существующих %s файлов\n"
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr "Введите 'list' для вывода списка существующих %s файлов\n"
-#, fuzzy
-#~ msgid "Enter 'list -f' for "
-#~ msgstr "Введите 'list -f' для"
+msgid "Enter 'list -f' for "
+msgstr "Введите 'list -f' для"
-#, fuzzy
-#~ msgid "a list %s"
-#~ msgstr "списка %s"
+msgid "a list %s"
+msgstr "список %s"
-#, fuzzy
-#~ msgid "an extended list"
-#~ msgstr "расширеный список"
+msgid "an extended list"
+msgstr "расширеный список"
-#, fuzzy
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "Нажмите RETURN %s\n"
+msgid "Hit RETURN %s\n"
+msgstr "Нажмите RETURN %s\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr " "
+msgid ""
+"\n"
+"** %s - not found **\n"
+msgstr ""
+"\n"
+"** %s - не найден **\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr "  "
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr ""
+"\n"
+"** %s существует. перезаписать? "
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr " "
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+"\n"
+"**<%s> неверное имя **\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr " "
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr ""
+"\n"
+"** %s - неверный запрос **\n"
-#, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr " "
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr ""
+"\n"
+"** %s - существует, выберите другое имя **\n"
-#, fuzzy
-#~ msgid "ask: can't happen"
-#~ msgstr "ask: не может быть"
+msgid "ask: can't happen"
+msgstr "ask: невозможно"
-#~ msgid "Insufficent memory for allocation of gaussian"
-#~ msgstr "Insufficent memory for allocation of gaussian"
+msgid "Insufficent memory for allocation of gaussian"
+msgstr "Insufficent memory for allocation of gaussian"
 #, fuzzy
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Невозможно прочесть файл заголовка для [%s в %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Невозможно прочесть файл заголовка для [%s в %s]\n"
 #, fuzzy
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Невозможно открыть файл заголовка для [%s в %s]\n"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Невозможно открыть файл заголовка для [%s в %s]\n"
 #, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "Не могу открыть врем. файл"
+msgid "Cannot get field info"
+msgstr "Не могу открыть врем. файл"
 #, fuzzy
-#~ msgid "Cannot open database"
-#~ msgstr " "
+msgid "Cannot open database"
+msgstr " "
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
-#~ msgstr " "
+msgid "Cannot open database <%s> by driver <%s>"
+msgstr " "
 #, fuzzy
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "    вектор."
+msgid "Output name '%s' is not valid vector name."
+msgstr "    вектор."
 #, fuzzy
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "вектор    "
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "вектор    "
 #, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
+msgid "Cannot open existing vector map <%s>"
+msgstr "вектор  "
 #, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
+msgstr "вектор  "
 #, fuzzy
-#~ msgid "Cannot open new vector %s"
+msgid "Cannot open new vector %s"
+msgstr "вектор  "
 #, fuzzy
-#~ msgid "Cannot open history file for vector '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "вектор  "
 #, fuzzy
-#~ msgid "Could not stat file '%s'"
-#~ msgstr " "
+msgid "Could not stat file '%s'"
+msgstr " "
 #, fuzzy
-#~ msgid "Can't open directory %s"
+msgid "Can't open directory %s"
+msgstr "вектор  "
 #, fuzzy
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** невозможное имя **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** невозможное имя **"
 #, fuzzy
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Графический дисплей <%s> не существует.\n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "Графический дисплей <%s> не существует.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "Выполните \"d.mon\" для выбора существующего дисплея.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "Выполните \"d.mon\" для выбора существующего дисплея.\n"
 #, fuzzy
-#~ msgid "Can't stat %s\n"
-#~ msgstr " "
+msgid "Can't stat %s\n"
+msgstr " "
 #, fuzzy
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Ошибка - Дисплей <%s> занят.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Ошибка - Дисплей <%s> занят.\n"
 #, fuzzy
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "     "
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "     "
 #, fuzzy
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Ошибка - не было закончено запирание (lock) для дисплея <%s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Ошибка - не было закончено запирание (lock) для дисплея <%s>.\n"
 #, fuzzy
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Ошибка - Нет канала (pipe) к графическому устройству.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Ошибка - Нет канала (pipe) к графическому устройству.\n"
 #, fuzzy
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Ошибка - Графический дисплей <%s> не включен!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Ошибка - Графический дисплей <%s> не включен!\n"
 #, fuzzy
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Включите графический дисплей <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "Включите графический дисплей <%s>.\n"
 #, fuzzy
-#~ msgid "Not connected...\n"
-#~ msgstr "Нет соединения...\n"
+msgid "Not connected...\n"
+msgstr "Нет соединения...\n"
 #, fuzzy
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "Невозможно подключить дисплей. Еще одна попытка.\n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "Невозможно подключить дисплей. Еще одна попытка.\n"
 #, fuzzy
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr " "
+msgid "Decompressed data buffer %s"
+msgstr " "
 #, fuzzy
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr " "
+msgid "Temporary name for NEW files %s"
+msgstr " "
 #, fuzzy
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr " "
+msgid "Temporary name for NEW NULL files %s"
+msgstr " "
 #, fuzzy
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Набор данных  "
+msgid "Mapset of open file %s"
+msgstr "Набор данных  "
 #, fuzzy
-#~ msgid "Color file for [%s] not available"
-#~ msgstr " "
+msgid "Color file for [%s] not available"
+msgstr " "
 #, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr " "
+msgid "Not able to open cellfile for [%s]"
+msgstr " "
 #, fuzzy
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "ОШИБКА: GISBASE не установлен\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "ОШИБКА: GISBASE не установлен\n"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "Невозможно выделить память\n"
+#~ msgid "Trying to connect to something not a socket."
+#~ msgstr "Попытка соединиться с чем-то не являющимся сокетом"
+#~ msgid "Probably program error."
+#~ msgstr "Возможная программная ошибка."
+#~ msgid "Connect attempt timed out."
+#~ msgstr "Время попытки соединения истекло"
+#~ msgid "Unable to get GIS_LOCK enviroment variable value"
+#~ msgstr "Невозможно получить значение переменной среды GIS_LOCK"
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s>: неправильный набор"
+#~ msgid "BUG (delete_area_cats_from_cidx): Area %d does not exist"
+#~ msgstr "Ошибка (delete_area_cats_from_cidx): Полигон %d не существует"
+#~ msgid "Attempt to delete dead line"
+#~ msgstr "Попытка удалить уже удаленную линию"
+#~ msgid "field missing east"
+#~ msgstr "отсутствует поле east"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "невозможно найти [%s] в [%s]"
Modified: grass/trunk/locale/po/grasslibs_sl.po
--- grass/trunk/locale/po/grasslibs_sl.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_sl.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -523,9 +523,9 @@
 msgstr "Nezmo¾en odpreti datoteko s tabelo elipsoida: %s"
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
+msgstr "Nezmo¾en odpreti datoteko s tabelo elipsoida: %s"
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1259,12 +1259,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "Ne morem odpreti temp datoteke"
+msgstr "Ne morem prebrati histograma za [%s v %s]"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -1982,9 +1982,9 @@
 msgstr "za izbrati privzeto"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
+msgstr "Hro¹è: poskus posodobitve sloja, ki ni v trenutnem mapset."
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2045,7 +2045,7 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "v trenutnem \"mapset\" ni datotek z imenom %s\n"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2247,7 +2247,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "ne najdem [%s] v [%s]"
+msgstr "ne najdem [%s]"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2310,9 +2310,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -3884,9 +3884,9 @@
 msgstr "Vneseni vektor '%s' ni bil najden"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "[%s] v \"mapset\" [%s] - v drugi coni [%d] kot trenutna regija [%d]"
@@ -4256,7 +4256,7 @@
 #, fuzzy
-msgstr "Ne morem odpreti %s"
+msgstr "Nezmo¾en odpreti datoteko %s v %s"
 #, fuzzy
@@ -4407,669 +4407,676 @@
 #, fuzzy
-#~ msgstr "Ne morem zapisati povezav z bazo podatkov."
+msgstr "Ne morem zapisati povezav z bazo podatkov."
-#~ msgstr "NAPAKA %s iz grafiènega gonilnika.\n"
+msgstr "NAPAKA %s iz grafiènega gonilnika.\n"
-#~ msgstr "NAPAKA - \"eof\" iz grafiènega monitorja.\n"
+msgstr "NAPAKA - \"eof\" iz grafiènega monitorja.\n"
-#~ msgstr "Opozorilo - grafièni monitor <%s> se ne odziva.\n"
+msgstr "Opozorilo - grafièni monitor <%s> se ne odziva.\n"
-#~ msgstr "Preizkusi ali je mi¹ka ¹e aktivna.\n"
+msgstr "Preizkusi ali je mi¹ka ¹e aktivna.\n"
-#~ msgstr "NAPAKA - grafièni monitor <%s> se ne odziva.\n"
+msgstr "NAPAKA - grafièni monitor <%s> se ne odziva.\n"
 #, fuzzy
-#~ msgstr "Noben grafièni monitor ni izbran za izhod.\n"
+msgstr "Noben grafièni monitor ni izbran za izhod.\n"
 #, fuzzy
-#~ msgstr "Prosim po¾enite \"d.mon\" za izbiro grafiènega monitorja.\n"
+msgstr "Prosim po¾enite \"d.mon\" za izbiro grafiènega monitorja.\n"
 #, fuzzy
-#~ msgstr "Nisem uspel dobiti imena vtiènice za monitor <%s>.\n"
+msgstr "Nisem uspel dobiti imena vtiènice za monitor <%s>.\n"
 #, fuzzy
-#~ msgstr "Ni vtiènice, ki bi jo lahko povezal z monitorjem <%s>.\n"
+msgstr "Ni vtiènice, ki bi jo lahko povezal z monitorjem <%s>.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Vtiènica je ¾e v uporabi ali ne sprejema povezav.\n"
-#~ "Uporabi d.mon za izbiro monitorja\n"
+msgstr ""
+"Vtiènica je ¾e v uporabi ali ne sprejema povezav.\n"
+"Uporabi d.mon za izbiro monitorja\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "Poskus povezave z neèem, kar ni vtiènica.\n"
-#~ "Verjetno je napaka v programu.\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"Poskus povezave z neèem, kar ni vtiènica.\n"
+"Verjetno je napaka v programu.\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Èas za poskus priklopa se je iztekel. Verjetno zaradi napake na "
-#~ "stre¾niku.\n"
+msgstr ""
+"Èas za poskus priklopa se je iztekel. Verjetno zaradi napake na stre¾niku.\n"
 #, fuzzy
-#~ msgstr "Povezava ni uspela.\n"
+msgstr "Povezava ni uspela.\n"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "Ne morem prebrati histograma za [%s v %s]"
+msgid "Cannot read topo for line [%d]"
 #, fuzzy
-#~ msgstr "Nezmo¾en odpreti datoteko %s v %s"
 #, fuzzy
-#~ msgstr "Pritisni RETURN za razveljaviti zahtevo\n"
+msgstr "Pritisni RETURN za razveljaviti zahtevo\n"
-#~ msgstr "Ne morem odpreti temp datoteke"
+msgstr "Ne morem odpreti temp datoteke"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Prosim doloèite ime elipsoida\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Prosim doloèite ime elipsoida\n"
-#~ msgstr "Vpi¹i 'list' za spisek elipsoidov na voljo\n"
+msgstr "Vpi¹i 'list' za spisek elipsoidov na voljo\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neveljaven elipsoid\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"neveljaven elipsoid\n"
 #, fuzzy
-#~ msgstr "Izhodno ime '%s' ni veljavno ime za vektor."
+msgstr "Izhodno ime '%s' ni veljavno ime za vektor."
-#~ msgstr "Izhodni sloj '%s' je uporabljen kot vhodni"
+msgstr "Izhodni sloj '%s' je uporabljen kot vhodni"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Prosim doloèite fundamentalno toèko\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Prosim doloèite fundamentalno toèko\n"
-#~ msgstr "Vpi¹ite 'list' za spisek fundamentalnih toèk, ki so na voljo\n"
+msgstr "Vpi¹ite 'list' za spisek fundamentalnih toèk, ki so na voljo\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neveljavna fundamentalna toèka\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"neveljavna fundamentalna toèka\n"
-#~ msgstr "pritisnite RETURN za nadaljevanje -->"
+msgstr "pritisnite RETURN za nadaljevanje -->"
-#~ msgstr "ne morem odpreti rastrskega sloja [%s v %s]"
+msgstr "ne morem odpreti rastrskega sloja [%s v %s]"
-#~ msgstr "trenutek...\n"
+msgstr "trenutek...\n"
-#~ msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
+msgstr "Za ukaz [%s] ni na voljo pomoèi\n"
-#~ msgstr "Rastrski sloj %s@%s je prazen"
+msgstr "Rastrski sloj %s@%s je prazen"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Datoteka [%s] v \"mapset\" [%s] potrebuje barvno tabelo.\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Datoteka [%s] v \"mapset\" [%s] potrebuje barvno tabelo.\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Prosim identificiraj ¾eleni tip:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Prosim identificiraj ¾eleni tip:\n"
-#~ msgstr "    1:  Nakljuène barve\n"
+msgstr "    1:  Nakljuène barve\n"
-#~ msgstr "    2:  Rdeèe, zeleno modri barvni prehod\n"
+msgstr "    2:  Rdeèe, zeleno modri barvni prehod\n"
-#~ msgstr "    3:  Barvni val\n"
+msgstr "    3:  Barvni val\n"
-#~ msgstr "    4:  Sivinski barvni prehod\n"
+msgstr "    4:  Sivinski barvni prehod\n"
-#~ msgstr "    5:  Senèenje reliefa\n"
+msgstr "    5:  Senèenje reliefa\n"
-#~ msgstr "    6:  Mavrièni barvni prehod\n"
+msgstr "    6:  Mavrièni barvni prehod\n"
-#~ msgstr "    7:  Rdeèe, rumeno, zeleni barvni prehod\n"
+msgstr "    7:  Rdeèe, rumeno, zeleni barvni prehod\n"
-#~ msgstr "    8:  Zeleno, rumeno, rdeèi barvni prehod\n"
+msgstr "    8:  Zeleno, rumeno, rdeèi barvni prehod\n"
-#~ msgstr "RETURN zakljuèi\n"
+msgstr "RETURN zakljuèi\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s neveljaven; Poskusi znova > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s neveljaven; Poskusi znova > "
 #, fuzzy
-#~ msgstr "ne najdem %s"
+msgstr "ne najdem %s"
-#~ msgstr "NAPAKA v branju %s"
+msgstr "NAPAKA v branju %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Prosim podaj ime projekcije\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Prosim podaj ime projekcije\n"
-#~ msgstr "Vnesi 'list' za spisek projekcij, ki so na voljo\n"
+msgstr "Vnesi 'list' za spisek projekcij, ki so na voljo\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "neveljavna projekcija\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"neveljavna projekcija\n"
-#~ msgstr "z naslovi"
+msgstr "z naslovi"
-#~ msgstr "(ni naslova)"
+msgid "(no title)"
+msgstr "(ni naslova)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "IZBIRA: Doloèite naslednjo izbiro?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"IZBIRA: Doloèite naslednjo izbiro?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "MO®NOST:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"MO®NOST:   %s\n"
-#~ msgstr "     kljuè: %s\n"
+msgid "     key: %s\n"
+msgstr "     kljuè: %s\n"
-#~ msgstr "  format: %s\n"
+msgstr "  format: %s\n"
-#~ msgstr " privzet: %s\n"
+msgstr " privzet: %s\n"
-#~ msgstr "zahtevan: %s\n"
+msgstr "zahtevan: %s\n"
-#~ msgstr "veèkraten: %s\n"
+msgstr "veèkraten: %s\n"
-#~ msgstr "vpi¹ite mo¾nost > "
+msgstr "vpi¹ite mo¾nost > "
-#~ msgstr "   Poskusite ¹e enkrat. "
+msgstr "   Poskusite ¹e enkrat. "
-#~ msgstr "Oprostite, %s ni sprejet.\n"
+msgstr "Oprostite, %s ni sprejet.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Izbrali ste:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Izbrali ste:\n"
+"  %s\n"
-#~ msgstr "Ali je to pravilno? "
+msgstr "Ali je to pravilno? "
-#~ msgstr "za izbrati privzeto"
+msgstr "za izbrati privzeto"
-#~ msgstr "za razveljaviti zahtevo"
+msgstr "za razveljaviti zahtevo"
-#~ msgstr "Vnesite novo %s ime datoteke"
+msgstr "Vnesite novo %s ime datoteke"
-#~ msgstr "Vnesite ime obstojeèe %s datoteke"
+msgstr "Vnesite ime obstojeèe %s datoteke"
-#~ msgstr "Vnesite %s ime datoteke"
+msgstr "Vnesite %s ime datoteke"
-#~ msgstr "Vpi¹ite 'list' za spisek obstojeèih %s datotek\n"
+msgstr "Vpi¹ite 'list' za spisek obstojeèih %s datotek\n"
-#~ msgstr "Vpi¹ite 'list' -f za "
+msgstr "Vpi¹ite 'list' -f za "
-#~ msgstr "spisek %s"
+msgid "a list %s"
+msgstr "spisek %s"
-#~ msgstr "raz¹irjen spisek"
+msgstr "raz¹irjen spisek"
-#~ msgstr "Pritisnite RETURN %s\n"
+msgstr "Pritisnite RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - ni bil najden **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - ni bil najden **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s obstaja. Ali ¾elite, prepisati? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s obstaja. Ali ¾elite, prepisati? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> neveljavno ime **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> neveljavno ime **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - neveljavna zahteva **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - neveljavna zahteva **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - obstaja, izberite drugo ime **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - obstaja, izberite drugo ime **\n"
 #, fuzzy
-#~ msgstr "vpra¹aj: ne more se zgoditi"
+msgstr "vpra¹aj: ne more se zgoditi"
-#~ msgstr "Ne morem prebrati datoteke z vzglavjem za [%s v %s]\n"
+msgstr "Ne morem prebrati datoteke z vzglavjem za [%s v %s]\n"
-#~ msgstr "Ne morem odpreti datoteke z vzglavjem za [%s v %s]"
+msgstr "Ne morem odpreti datoteke z vzglavjem za [%s v %s]"
 #, fuzzy
-#~ msgstr "Ne morem zbrisati linije"
+msgstr "Ne morem zbrisati linije"
 #, fuzzy
-#~ msgid "Building topology ...\n"
-#~ msgstr "Gradim topologijo ...\n"
+msgid "Building topology ...\n"
+msgstr "Gradim topologijo ...\n"
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r%d obmoèij zgrajenih      \n"
-#~ "%d otokov zgrajenih\n"
+msgid ""
+"\r%d areas built      \n"
+"%d isles built\n"
+msgstr ""
+"\r%d obmoèij zgrajenih      \n"
+"%d otokov zgrajenih\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "Vect_rewrite_line() za ta format/nivo ni podprt"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "Vect_rewrite_line() za ta format/nivo ni podprt"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "Vect_delete_line() za ta format/nivo ni podprt"
+msgid "Vect_delete_line() for this format/level not supported"
+msgstr "Vect_delete_line() za ta format/nivo ni podprt"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "Ne morem prepisati linije"
+msgid "Cannot rewrite line"
+msgstr "Ne morem prepisati linije"
-#~ msgid "Cannot delete line"
+msgid "Cannot delete line"
-#~ msgstr "Ne morem kopirati '%s' v '%s'"
+msgstr "Ne morem kopirati '%s' v '%s'"
 #, fuzzy
-#~ msgstr "Ne morem zbrisati obstojeèega vektorja %s"
+msgstr "Ne morem zbrisati obstojeèega vektorja %s"
 #, fuzzy
-#~ msgstr "Ne morem odpreti novega vektorja %s"
+msgstr "Ne morem odpreti novega vektorja %s"
-#~ msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
+msgstr "Ne morem odpreti datoteke z zgodovino za vektor '%s'"
 #, fuzzy
-#~ msgstr "Starega vektorja %s ne morem odpreti"
+msgstr "Starega vektorja %s ne morem odpreti"
-#~ msgstr "%s - ** neveljavno ime **"
+msgstr "%s - ** neveljavno ime **"
-#~ msgstr "Grafiènega monitorja z imenom <%s> ni.\n"
+msgstr "Grafiènega monitorja z imenom <%s> ni.\n"
-#~ msgstr ""
-#~ "Prosim po¾enite \"d.mon\" za izbiro veljavnega grafiènega monitorja.\n"
+msgstr "Prosim po¾enite \"d.mon\" za izbiro veljavnega grafiènega monitorja.\n"
-#~ msgstr "Napaka - Monitor <%s> je ¾e v uporabi.\n"
+msgstr "Napaka - Monitor <%s> je ¾e v uporabi.\n"
-#~ msgstr "Napaka - Monitor <%s> ¾e uporablja %s.\n"
+msgstr "Napaka - Monitor <%s> ¾e uporablja %s.\n"
-#~ msgstr "Napaka - Nisem mogel dokonèati zaklepanja za monitor <%s>.\n"
+msgstr "Napaka - Nisem mogel dokonèati zaklepanja za monitor <%s>.\n"
-#~ msgstr "Napaka - Ne morem vzpostaviti cevi do grafiène naprave.\n"
+msgstr "Napaka - Ne morem vzpostaviti cevi do grafiène naprave.\n"
-#~ msgstr "Napaka - Grafièni monitor <%s> ni zagnan!\n"
+msgstr "Napaka - Grafièni monitor <%s> ni zagnan!\n"
-#~ msgstr "Prosim po¾enite grafièni monitor <%s>.\n"
+msgstr "Prosim po¾enite grafièni monitor <%s>.\n"
-#~ msgstr "Ni povezave...\n"
+msgstr "Ni povezave...\n"
-#~ msgstr "Nisem se mogel povezati z monitorjem. Posku¹am ¹e enkrat.\n"
+msgstr "Nisem se mogel povezati z monitorjem. Posku¹am ¹e enkrat.\n"
 #, fuzzy
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "Velikost celice v fp slojih = %d\n"
+msgid "Size of cell in fp maps = %d"
+msgstr "Velikost celice v fp slojih = %d\n"
 #, fuzzy
-#~ msgid "type for writing floating maps = %d"
-#~ msgstr "tip za pisanje slojev s plavajoèo vejico = %d\n"
+msgid "type for writing floating maps = %d"
+msgstr "tip za pisanje slojev s plavajoèo vejico = %d\n"
 #, fuzzy
-#~ msgid "current window = %p"
-#~ msgstr "trenutno okno = %p\n"
+msgid "current window = %p"
+msgstr "trenutno okno = %p\n"
 #, fuzzy
-#~ msgid "Flag: window set? %d"
-#~ msgstr "Izbira: okno nastavljeno? %d\n"
+msgid "Flag: window set? %d"
+msgstr "Izbira: okno nastavljeno? %d\n"
 #, fuzzy
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "Deskriptor datoteke za avtomatièno masko %d\n"
+msgid "File descriptor for automatic mask %d"
+msgstr "Deskriptor datoteke za avtomatièno masko %d\n"
 #, fuzzy
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "Izbira, ki oznaèuje avtomatièno maskiranje %d\n"
+msgid "Flag denoting automatic masking %d"
+msgstr "Izbira, ki oznaèuje avtomatièno maskiranje %d\n"
 #, fuzzy
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "'buffer' delovnih podatkov %p\\n"
+msgid "CELL mask buffer %p"
+msgstr "'buffer' delovnih podatkov %p\\n"
 #, fuzzy
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "buffer za branje 'null' vrstic %p\\n"
+msgid "buffer for reading null rows %p"
+msgstr "buffer za branje 'null' vrstic %p\\n"
 #, fuzzy
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "Podatkovni 'buffer' %p pred/po krèenju\\n"
+msgid "Pre/post compressed data buffer %p"
+msgstr "Podatkovni 'buffer' %p pred/po krèenju\\n"
 #, fuzzy
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "velikost skrèenega 'bufferja': commpressed_buf %d\\n"
+msgid "sizeof compressed_buf %d"
+msgstr "velikost skrèenega 'bufferja': commpressed_buf %d\\n"
 #, fuzzy
-#~ msgid "work data buffer %p"
+msgid "work data buffer %p"
 #, fuzzy
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "velikost delovnih podatkov work_buf %d\n"
+msgid "sizeof work_buf %d"
+msgstr "velikost delovnih podatkov work_buf %d\n"
 #, fuzzy
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "velikost null_buf %d\n"
+msgid "sizeof null_buf %d"
+msgstr "velikost null_buf %d\n"
 #, fuzzy
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "velikost mask_buf %f\n"
+msgid "sizeof mask_buf %d"
+msgstr "velikost mask_buf %f\n"
 #, fuzzy
-#~ msgid "Histogram request %d"
-#~ msgstr "Zahteva po histogramu %d\n"
+msgid "Histogram request %d"
+msgstr "Zahteva po histogramu %d\n"
 #, fuzzy
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump: datoteka #%d\n"
+msgid "G_dump: file #%d"
+msgstr "G_dump: datoteka #%d\n"
 #, fuzzy
-#~ msgid "open mode = %d"
-#~ msgstr "odprti naèin = %d\n"
+msgid "open mode = %d"
+msgstr "odprti naèin = %d\n"
 #, fuzzy
-#~ msgid "Table reclass %p"
-#~ msgstr "Reklasifikacija tabele %p\n"
+msgid "Table reclass %p"
+msgstr "Reklasifikacija tabele %p\n"
 #, fuzzy
-#~ msgid "Range structure %p"
-#~ msgstr "Struktura razpona %p\n"
+msgid "Range structure %p"
+msgstr "Struktura razpona %p\n"
 #, fuzzy
-#~ msgid "float Range structure %p"
+msgid "float Range structure %p"
 #, fuzzy
-#~ msgid "want histogram?  %d"
-#~ msgstr "Ali ¾elite histogram? %d\n"
+msgid "want histogram?  %d"
+msgstr "Ali ¾elite histogram? %d\n"
 #, fuzzy
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "Samodejna izbira reklasifikacije %d\n"
+msgid "Automatic reclass flag %d"
+msgstr "Samodejna izbira reklasifikacije %d\n"
 #, fuzzy
-#~ msgid "File row addresses %p"
-#~ msgstr "Vrstièni naslovi datoteke %p\n"
+msgid "File row addresses %p"
+msgstr "Vrstièni naslovi datoteke %p\n"
 #, fuzzy
-#~ msgid "Current data row in memory %d"
-#~ msgstr "Trenutna vrstica podatkov v spominu %d\\n"
+msgid "Current data row in memory %d"
+msgstr "Trenutna vrstica podatkov v spominu %d\\n"
 #, fuzzy
-#~ msgid "Current null row in memory %d"
-#~ msgstr "Trenutna vrstica null vrednosti v spominu %d\\n"
+msgid "Current null row in memory %d"
+msgstr "Trenutna vrstica null vrednosti v spominu %d\\n"
 #, fuzzy
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "nbajtov na celico v trenutni vrstici %d\n"
+msgid "nbytes per cell for current row %d"
+msgstr "nbajtov na celico v trenutni vrstici %d\n"
 #, fuzzy
-#~ msgstr "Razkrèen (dekomprimiran) podatkovni 'buffer' %s\\n"
+msgstr "Razkrèen (dekomprimiran) podatkovni 'buffer' %s\\n"
 #, fuzzy
-#~ msgid "bytes per cell %d"
-#~ msgstr "bajtov na celico %d\n"
+msgid "bytes per cell %d"
+msgstr "bajtov na celico %d\n"
 #, fuzzy
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "tip: integer, plavajoèa vejica ali 'dvojni' %d\n"
+msgid "type: int, float or double map %d"
+msgstr "tip: integer, plavajoèa vejica ali 'dvojni' %d\n"
 #, fuzzy
-#~ msgstr "Zaèasno ime za NEW datoteke %s\n"
+msgstr "Zaèasno ime za NEW datoteke %s\n"
 #, fuzzy
-#~ msgstr "Zaèasno ime za NEW NULL datoteke %s\n"
+msgstr "Zaèasno ime za NEW NULL datoteke %s\n"
 #, fuzzy
-#~ msgstr "\"Mapset\" odprte datoteke %s\n"
+msgstr "\"Mapset\" odprte datoteke %s\n"
 #, fuzzy
-#~ msgid "io error warning given %d"
-#~ msgstr "io opozorilo za napako %d\n"
+msgid "io error warning given %d"
+msgstr "io opozorilo za napako %d\n"
 #, fuzzy
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "xdr tok za branje fp %p\n"
+msgid "xdr stream for reading fp %p"
+msgstr "xdr tok za branje fp %p\n"
 #, fuzzy
-#~ msgid "NULL_ROWS array[%d] = %p"
-#~ msgstr "NULL_ROWS array[%d] = %p\n"
+msgid "NULL_ROWS array[%d] = %p"
+msgstr "NULL_ROWS array[%d] = %p\n"
 #, fuzzy
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "podatkovni 'buffer' za branje null vrstic %p\n"
+msgid "data buffer for reading null rows %p"
+msgstr "podatkovni 'buffer' za branje null vrstic %p\n"
 #, fuzzy
-#~ msgid "Minimum row null row number in memory %d"
-#~ msgstr "Minimalni row = null row ¹tevilo shranjeno v spominu %d\n"
+msgid "Minimum row null row number in memory %d"
+msgstr "Minimalni row = null row ¹tevilo shranjeno v spominu %d\n"
 #, fuzzy
-#~ msgid "G_dump: end"
+msgid "G_dump: end"
 #, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
 #, fuzzy
-#~ msgstr "LOCATION  << %s >>  ne obstaja"
+msgstr "LOCATION  << %s >>  ne obstaja"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
 #, fuzzy
-#~ msgid "Too many open raster maps"
-#~ msgstr "Preveè odprtih rastrskih slojev"
+msgid "Too many open raster maps"
+msgstr "Preveè odprtih rastrskih slojev"
-#~ msgid "Too many open files"
-#~ msgstr "Preveè odprtih datotek"
+msgid "Too many open files"
+msgstr "Preveè odprtih datotek"
-#~ msgstr "NAPAKA: GISBASE ni nastavljen\n"
+msgstr "NAPAKA: GISBASE ni nastavljen\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr ""
-#~ "Napaka pri branju parametrov premika fundamentalne toèke za %s iz tabele"
+msgid "Error reading datum shift parameters for %s from table"
+msgstr ""
+"Napaka pri branju parametrov premika fundamentalne toèke za %s iz tabele"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr "Napaka pri branju parametrov elipsoida za %s iz tabele"
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr "Napaka pri branju parametrov elipsoida za %s iz tabele"
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "Ni polja za elipsoid %s v datoteki %s v %s"
+msgid "No ellipsoid field %s in file %s in %s"
+msgstr "Ni polja za elipsoid %s v datoteki %s v %s"
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "neveljavna vrednost: polje %s v datoteki %s v %s"
+msgid "invalid value: field %s in file %s in %s"
+msgstr "neveljavna vrednost: polje %s v datoteki %s v %s"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "Ni n-dims v site_list"
+msgid "No n-dims in site_list"
+msgstr "Ni n-dims v site_list"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "Ni dvojnih atributov v site_list"
+msgid "No double attributes in site_list"
+msgstr "Ni dvojnih atributov v site_list"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "V site_list ni atributov tipa \"string\" "
+msgid "No string attributes in site_list"
+msgstr "V site_list ni atributov tipa \"string\" "
-#~ msgid "String attribute index out of range"
-#~ msgstr "Atributni indeks tipa \"string\" je izven razpona"
+msgid "String attribute index out of range"
+msgstr "Atributni indeks tipa \"string\" je izven razpona"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "Nepoznan atributni tip v klicu G_readsites_xyz()!\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "Nepoznan atributni tip v klicu G_readsites_xyz()!\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "Ne morem spremeniti atributnega tipa."
+msgid "Failed to convert string attribute."
+msgstr "Ne morem spremeniti atributnega tipa."
-#~ msgid "Reading sites list ...                  "
-#~ msgstr "Berem spisek toèk ...                  "
+msgid "Reading sites list ...                  "
+msgstr "Berem spisek toèk ...                  "
-#~ msgid "failed to guess format"
-#~ msgstr "ni mi uspelo uganiti formata"
+msgid "failed to guess format"
+msgstr "ni mi uspelo uganiti formata"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "polje za decimalke %i ni prisotno v datoteki s toèkami"
+msgid "decimal field %i not present in sites file"
+msgstr "polje za decimalke %i ni prisotno v datoteki s toèkami"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr ""
-#~ "I¹èem enote, ki nimajo atributov s plavajoèo vejico (polja s predpono "
+msgid ""
+"I'm finding records that do not have a floating point attributes (fields "
+"prefixed with '%')."
+msgstr ""
+"I¹èem enote, ki nimajo atributov s plavajoèo vejico (polja s predpono '%')."
-#~ msgid "WARNING: can not create a new process\n"
-#~ msgstr "OPOZORILO: ne morem ustvariti novega procesa\n"
+msgid "WARNING: can not create a new process\n"
+msgstr "OPOZORILO: ne morem ustvariti novega procesa\n"
-#~ msgid "Select type: point, line, boundary, centroid or area"
-#~ msgstr "Izberi tip: toèka, linija, meja, centroid ali obmoèje"
+msgid "Select type: point, line, boundary, centroid or area"
+msgstr "Izberi tip: toèka, linija, meja, centroid ali obmoèje"
+#~ msgstr "Nezmo¾en dodeliti spomin\n"
+#, fuzzy
+#~ msgstr "<%s> v \"mapset\" <%s>"
+#~ msgstr "ne najdem [%s] v [%s]"
Modified: grass/trunk/locale/po/grasslibs_th.po
--- grass/trunk/locale/po/grasslibs_th.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_th.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -571,9 +571,9 @@
 msgstr "ไม่สามารถเปิดไฟล์ตารางรูปทรงรี: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "ไม่สามารถเปิดไฟล์ตารางรูปทรงรี: %s"
@@ -2033,9 +2033,9 @@
 msgstr "หน้าต่งถูกแทนด้วยค่าตั้งต้น"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "ข้อผิดพลาด: ตั้งใจที่จะปรับปรุงแผนที่ ที่ไม่อยู่ในชุดแผนที่ที่กำลังใช้งาน"
@@ -2096,7 +2096,7 @@
 #, fuzzy, c-format
-msgstr "ไม่มีไฟล์ %s อยู่ในชุดแผนที่ปัจจุบัน\n"
@@ -2294,7 +2294,7 @@
 #, fuzzy, c-format
-msgstr "ไม่สามารถค้นหา [%s] ใน [%s]"
+msgstr "ไม่สามารถค้นหา  [%s]"
 #, fuzzy, c-format
@@ -2357,9 +2357,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3885,9 +3885,9 @@
 msgstr "ไม่พบ ชื่อแผนที่เชิงเส้น <%s>"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "[%s] ชุดแผนที่ [%s] - ในโซนที่แตกต่าง [%d] จากขอบเขตปัจจุบัน [%d]"
@@ -4253,7 +4253,7 @@
 #, fuzzy
-msgstr "ไม่สามารถเปิดได้ %s"
+msgstr "ไม่สามารถเปิดไฟล์ %s ได้"
 #, fuzzy
@@ -4403,391 +4403,401 @@
 msgstr "ไม่สามารถลบไฟล์  '%s'"
-#~ msgstr "ไม่สามารถ บรรยายตารางนี้ได้ <%s>"
+msgstr "ไม่สามารถ บรรยายตารางนี้ได้ <%s>"
-#~ msgstr "ไม่รู้จักคำสั่งนี้: %d ลงท้าย: %d"
+msgstr "ไม่รู้จักคำสั่งนี้: %d ลงท้าย: %d"
-#~ msgstr "ตรวจดู: get_command: Premature EOF"
+msgstr "ตรวจดู: get_command: Premature EOF"
-#~ msgstr "Graphics driver [%s] เริ่มแล้ว"
+msgstr "Graphics driver [%s] เริ่มแล้ว"
-#~ msgstr "ข้อผิดพลาด %s จากตัวขับจอ \n"
+msgstr "ข้อผิดพลาด %s จากตัวขับจอ \n"
-#~ msgstr "ข้อผิดพลาด - EOF จากจอแสดงผล \n"
+msgstr "ข้อผิดพลาด - EOF จากจอแสดงผล \n"
-#~ msgstr "คำเตือน - ไม่มีการตอบสนองจากจอแสดงผล <%s>.\n"
+msgstr "คำเตือน - ไม่มีการตอบสนองจากจอแสดงผล <%s>.\n"
-#~ msgstr "ตรวจสอบ เม้าส์ยังทำงานอยู่หรือไม่ \n"
+msgstr "ตรวจสอบ เม้าส์ยังทำงานอยู่หรือไม่ \n"
-#~ msgstr "ข้อผิดพลาด - ไม่มีการตอบสนองจากจอแสดงผล <%s>.\n"
+msgstr "ข้อผิดพลาด - ไม่มีการตอบสนองจากจอแสดงผล <%s>.\n"
-#~ msgstr "ไม่ได้เลือก จอแสดงผล"
+msgstr "ไม่ได้เลือก จอแสดงผล"
-#~ msgstr "โปรดใช้คำสั่ง  \"d.mon\" เพื่อเลือก จอแสดงผล"
+msgstr "โปรดใช้คำสั่ง  \"d.mon\" เพื่อเลือก จอแสดงผล"
-#~ msgstr "ล้มเหลวที่จะอ่าน socket name จากจอแสดงผล <%s>."
+msgstr "ล้มเหลวที่จะอ่าน socket name จากจอแสดงผล <%s>."
-#~ msgstr "ไม่มี socketที่จะต่อกับจอแสดงผล <%s>."
+msgstr "ไม่มี socketที่จะต่อกับจอแสดงผล <%s>."
-#~ msgstr "Socket ถูกใช้อยู่ หรือไม่ยอมรับการเชื่อมต่อ."
+msgstr "Socket ถูกใช้อยู่ หรือไม่ยอมรับการเชื่อมต่อ."
-#~ msgstr "ใช้คำสั่ง  d.mon เพื่อเลือก จอแสดงผล"
+msgstr "ใช้คำสั่ง  d.mon เพื่อเลือก จอแสดงผล"
-#~ msgstr "ลองเชื่อมต่อกับอย่างอื่นที่ไม่ใช่ socket"
+msgstr "ลองเชื่อมต่อกับอย่างอื่นที่ไม่ใช่ socket"
-#~ msgid "Probably program error."
-#~ msgstr "อาจจะเกิดจากข้อผิดพลาดของ โปรแกรม"
+msgid "Probably program error."
+msgstr "อาจจะเกิดจากข้อผิดพลาดของ โปรแกรม"
-#~ msgid "Connect attempt timed out."
-#~ msgstr "การเชื่อมต่อเกินเวลา"
+msgid "Connect attempt timed out."
+msgstr "การเชื่อมต่อเกินเวลา"
-#~ msgstr "อาจจะเกิดจากข้อผิดพลาดของ เครื่องแม่ข่าย"
+msgstr "อาจจะเกิดจากข้อผิดพลาดของ เครื่องแม่ข่าย"
-#~ msgstr "การเชื่อมต่อล้มเหลว"
+msgstr "การเชื่อมต่อล้มเหลว"
-#~ msgstr "ไม่สามารถอ่าน topo สำหรับ เส้น  [%d]"
+msgstr "ไม่สามารถอ่าน topo สำหรับ เส้น  [%d]"
 #, fuzzy
-#~ msgid "Attempt to delete dead line"
-#~ msgstr "ตั้งใจที่จะลบพื้นที่"
+msgid "Attempt to delete dead line"
+msgstr "ตั้งใจที่จะลบพื้นที่"
-#~ msgstr "ไม่สามารถเปิดไฟล์ %s ได้"
 #, fuzzy
-#~ msgstr "กด RETURN เพื่อยกเลิกคำสั่ง\n"
+msgstr "กด RETURN เพื่อยกเลิกคำสั่ง\n"
-#~ msgstr "ไม่สามารถเปิด temp ไฟล์"
+msgstr "ไม่สามารถเปิด temp ไฟล์"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "โปรดระบุชื่อทรงรี\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"โปรดระบุชื่อทรงรี\n"
-#~ msgstr "ใส่ 'list' เพื่อแสดงรายการ รูปทรงรี\n"
+msgstr "ใส่ 'list' เพื่อแสดงรายการ รูปทรงรี\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "รูปทรงรี ไม่ถูกต้อง\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"รูปทรงรี ไม่ถูกต้อง\n"
-#~ msgstr "ชื่อไฟล์ผลลัพธ์ '%s' ไม่มีชือ่ไฟล์เชิงภาพนี้"
+msgstr "ชื่อไฟล์ผลลัพธ์ '%s' ไม่มีชือ่ไฟล์เชิงภาพนี้"
-#~ msgstr "แผนที่ผลลัพธ์ '%s'ใช้เป็นแผนที่นำเข้า"
+msgstr "แผนที่ผลลัพธ์ '%s'ใช้เป็นแผนที่นำเข้า"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "โปรดระบุชื่อ datum \n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"โปรดระบุชื่อ datum \n"
-#~ msgstr "ใส่ 'list' เพื่อแสดงรายการ datums\n"
+msgstr "ใส่ 'list' เพื่อแสดงรายการ datums\n"
-#~ msgstr "หรือ 'custom' ถ้าคุณต้องการกำหนดค่าตัวแปรเอง \n"
+msgstr "หรือ 'custom' ถ้าคุณต้องการกำหนดค่าตัวแปรเอง \n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "datum ไม่ถูกต้อง\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"datum ไม่ถูกต้อง\n"
-#~ msgstr "กด RETURN เพื่อดำเนินการต่อ -->"
+msgstr "กด RETURN เพื่อดำเนินการต่อ -->"
-#~ msgstr "ไม่สามารถเปิดข้อมูลเชิงภาพได้ [%s ใน %s]"
+msgstr "ไม่สามารถเปิดข้อมูลเชิงภาพได้ [%s ใน %s]"
-#~ msgstr "โปรดรอสักครู่...\n"
+msgstr "โปรดรอสักครู่...\n"
-#~ msgstr "ไม่มีความช่วยเหลือสำหรับคำสั่งนี้ [%s]\n"
+msgstr "ไม่มีความช่วยเหลือสำหรับคำสั่งนี้ [%s]\n"
-#~ msgstr "แผนที่เชิงภาพ %s@%s ว่าเปล่า"
+msgstr "แผนที่เชิงภาพ %s@%s ว่าเปล่า"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ไฟล์นี้ต้องการดารางสี  [%s] ในชุดแผนที่ [%s].\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"ไฟล์นี้ต้องการดารางสี  [%s] ในชุดแผนที่ [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "โปรดระบุชนิดที่จะใช้:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"โปรดระบุชนิดที่จะใช้:\n"
-#~ msgstr "    1:  สีแบบสุ่ม\n"
+msgstr "    1:  สีแบบสุ่ม\n"
-#~ msgstr "    2:  แดง, เขียว, และ น้ำเงิน แบบไล่สี\n"
+msgstr "    2:  แดง, เขียว, และ น้ำเงิน แบบไล่สี\n"
-#~ msgstr "    3:  สีแบบ คลื่น\n"
+msgstr "    3:  สีแบบ คลื่น\n"
-#~ msgstr "    4:  โทนสีเทา\n"
+msgstr "    4:  โทนสีเทา\n"
-#~ msgstr "    5:  สีเชิงมุม\n"
+msgstr "    5:  สีเชิงมุม\n"
-#~ msgstr "    6:  สีรุ้ง\n"
+msgstr "    6:  สีรุ้ง\n"
-#~ msgstr "    7:  แดง ไล่ไป เหลือง ถึง เขียว\n"
+msgstr "    7:  แดง ไล่ไป เหลือง ถึง เขียว\n"
-#~ msgstr "    7:  เขียว ไล่ไป เหลือง ถึง แดง\n"
+msgstr "    7:  เขียว ไล่ไป เหลือง ถึง แดง\n"
-#~ msgstr "RETURN  ออก\n"
+msgstr "RETURN  ออก\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s ไม่ถูกต้อง; ลองใหม่ > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s ไม่ถูกต้อง; ลองใหม่ > "
-#~ msgstr "%s ไม่พบ"
+msgstr "%s ไม่พบ"
-#~ msgstr "เกิดข้อผิดพลาดในการอ่าน  %s"
+msgstr "เกิดข้อผิดพลาดในการอ่าน  %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "โปรดระบุชื่อการฉายภาพ\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"โปรดระบุชื่อการฉายภาพ\n"
-#~ msgstr "ใส่ 'list' เพื่อแสดงรายการ การฉายภาพ\n"
+msgstr "ใส่ 'list' เพื่อแสดงรายการ การฉายภาพ\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "การฉายภาพไม่ถูกต้อง\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"การฉายภาพไม่ถูกต้อง\n"
-#~ msgstr "ด้วย ชื่อเรื่อง"
+msgstr "ด้วย ชื่อเรื่อง"
-#~ msgstr "(ไม่มีชื่อเรื่อง)"
+msgid "(no title)"
+msgstr "(ไม่มีชื่อเรื่อง)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ธง: กำหนดค่าธง?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"ธง: กำหนดค่าธง?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "เงื่อนไข:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"เงื่อนไข:   %s\n"
-#~ msgstr "     เฉพาะ: %s\n"
+msgid "     key: %s\n"
+msgstr "     เฉพาะ: %s\n"
-#~ msgstr "  รูปแบบ: %s\n"
+msgstr "  รูปแบบ: %s\n"
-#~ msgstr " ค่าตั้งต้น: %s\n"
+msgstr " ค่าตั้งต้น: %s\n"
-#~ msgstr "ต้องการ: %s\n"
+msgstr "ต้องการ: %s\n"
-#~ msgstr "หลาย: %s\n"
+msgstr "หลาย: %s\n"
-#~ msgstr "ใส่เงื่อนไข > "
+msgstr "ใส่เงื่อนไข > "
-#~ msgstr "   ลองใหม่? "
+msgstr "   ลองใหม่? "
-#~ msgstr "เสียใจ, %s ไม่ถูกต้อง.\n"
+msgstr "เสียใจ, %s ไม่ถูกต้อง.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "คุณได้เลือก:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"คุณได้เลือก:\n"
+"  %s\n"
-#~ msgstr "อย่างนี้ถูกต้องหรือไม่? "
+msgstr "อย่างนี้ถูกต้องหรือไม่? "
-#~ msgstr "ใช้ค่าตั้งต้น"
+msgstr "ใช้ค่าตั้งต้น"
-#~ msgstr "ยกเลิกการร้องขอ"
+msgstr "ยกเลิกการร้องขอ"
-#~ msgstr "ใส่ชื่อไฟล์ใหม่  %s"
+msgstr "ใส่ชื่อไฟล์ใหม่  %s"
-#~ msgstr "ใส่ชื่อไฟล์ที่มีอยู่แล้ว  %s"
+msgstr "ใส่ชื่อไฟล์ที่มีอยู่แล้ว  %s"
-#~ msgstr "ใส่ชื่อไฟล์  %s"
+msgstr "ใส่ชื่อไฟล์  %s"
-#~ msgstr "ใส่  'list' สำหรับรายการที่มีอยู่แล้ว %s ไฟล์\n"
+msgstr "ใส่  'list' สำหรับรายการที่มีอยู่แล้ว %s ไฟล์\n"
-#~ msgstr "ใส่  'list -f' สำหรับ"
+msgstr "ใส่  'list -f' สำหรับ"
-#~ msgstr "รายการ  %s"
+msgid "a list %s"
+msgstr "รายการ  %s"
-#~ msgstr "รายการขยาย"
+msgstr "รายการขยาย"
-#~ msgstr "กด  RETURN %s\n"
+msgstr "กด  RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - ไม่พบ **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - ไม่พบ **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s มีอยู่แล้ว. คุณต้องการที่จะเขียนทับหรือไม่? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s มีอยู่แล้ว. คุณต้องการที่จะเขียนทับหรือไม่? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> ชื่อไม่ถูกต้อง **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> ชื่อไม่ถูกต้อง **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> คำร้องขอถูกต้อง **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> คำร้องขอถูกต้อง **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - มีอยู่แล้ว, ให้เลือกชื่ออื่น **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - มีอยู่แล้ว, ให้เลือกชื่ออื่น **\n"
-#~ msgstr "ถาม: ไม่สามารถเกิดขึ้นได้"
+msgstr "ถาม: ไม่สามารถเกิดขึ้นได้"
-#~ msgstr "หน่วยความจำไม่พอที่จะเก็บค่า gaussian"
+msgstr "หน่วยความจำไม่พอที่จะเก็บค่า gaussian"
-#~ msgstr "ไม่สามารถอ่านส่วนหัวของไฟล์สำหรับ [%s ใน %s]\n"
+msgstr "ไม่สามารถอ่านส่วนหัวของไฟล์สำหรับ [%s ใน %s]\n"
-#~ msgstr "ไม่สามารถอ่าน header ไฟล์ได้ สำหรับ[%s in %s]"
+msgstr "ไม่สามารถอ่าน header ไฟล์ได้ สำหรับ[%s in %s]"
-#~ msgstr "ไม่สามารถอ่านรายละเอียด field ได้"
+msgstr "ไม่สามารถอ่านรายละเอียด field ได้"
-#~ msgstr "ไม่สามารถเปิดฐานข้อมูลได้"
+msgstr "ไม่สามารถเปิดฐานข้อมูลได้"
-#~ msgid "Could not select from table/column"
-#~ msgstr "ไม่สามารถเลือกจาก ตาราง/column"
+msgid "Could not select from table/column"
+msgstr "ไม่สามารถเลือกจาก ตาราง/column"
-#~ msgstr "กำลังสร้าง topology ...\n"
+msgstr "กำลังสร้าง topology ...\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d สร้างรูปปิด      \n"
-#~ "%d สร้าง isles \n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d สร้างรูปปิด      \n"
+"%d สร้าง isles \n"
-#~ msgstr "ไม่สามารถเปิดฐานข้อมูล <%s> ด้วยตัวขับ <%s>"
+msgstr "ไม่สามารถเปิดฐานข้อมูล <%s> ด้วยตัวขับ <%s>"
-#~ msgstr "ไม่สามารถอ่าน รายละเอียด column"
+msgstr "ไม่สามารถอ่าน รายละเอียด column"
-#~ msgid "Column type not supported"
-#~ msgstr "ไม่รองรับ ชนิด Column นี้"
+msgid "Column type not supported"
+msgstr "ไม่รองรับ ชนิด Column นี้"
-#~ msgid "OGR feature type [%d] not supported"
-#~ msgstr "ข้อมูล ชนิด OGR  [%d] ไม่รองรับ"
+msgid "OGR feature type [%d] not supported"
+msgstr "ข้อมูล ชนิด OGR  [%d] ไม่รองรับ"
-#~ msgstr "Vect_rewrite_line() สำหรับ รูปแบบ/ระดับ  ไม่รองรับ"
+msgstr "Vect_rewrite_line() สำหรับ รูปแบบ/ระดับ  ไม่รองรับ"
-#~ msgstr "Vect_delete_line() สำหรับ รูปแบบ/ระดับ  ไม่รองรับ"
+msgstr "Vect_delete_line() สำหรับ รูปแบบ/ระดับ  ไม่รองรับ"
-#~ msgstr "ไม่สามารถเขียนใหม่"
+msgstr "ไม่สามารถเขียนใหม่"
-#~ msgstr "ไม่สามารถลบ"
+msgstr "ไม่สามารถลบ"
+#~ msgstr "ไม่สามารถจองหน่วยความจำได้\n"
+#, fuzzy
+#~ msgstr "<%s> ในชุดแผนที่ <%s>"
+#~ msgstr "ไม่สามารถค้นหา [%s] ใน [%s]"
Modified: grass/trunk/locale/po/grasslibs_tr.po
--- grass/trunk/locale/po/grasslibs_tr.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_tr.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -510,9 +510,9 @@
 msgstr "elipsoid tablo dosyası açılamıyor: %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "elipsoid tablo dosyası açılamıyor: %s"
@@ -1237,12 +1237,12 @@
 #, fuzzy
-msgstr "Üstbilgi dosyası okunamıyor"
+msgstr "[%d] alanının topolojisi okunamıyor"
 #, fuzzy
@@ -1963,9 +1963,10 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"Geçerli harita takımında olmayan vektör harita güncellemek için açılamıyor"
@@ -2026,7 +2027,8 @@
 #, fuzzy, c-format
-msgstr "Geçerli harita takımında hiç %s dosyası yok\n"
+msgstr ""
@@ -2225,7 +2227,7 @@
 #, fuzzy, c-format
-msgstr "[%s] deki [%s] bulunamıyor"
+msgstr "[%s] bulunamadı"
 #, fuzzy, c-format
@@ -2288,9 +2290,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3819,9 +3821,10 @@
 msgstr "<%s> vektör haritası bulunamadı"
 #: ../lib/ogsf/GS2.c:1638
-#, c-format
+#, fuzzy, c-format
 msgid "Raster map <%s> is outside of current region. Load failed."
 msgstr ""
 #: ../lib/ogsf/GS2.c:1716 ../lib/ogsf/GS2.c:1722 ../lib/ogsf/GS2.c:1730
 #: ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747 ../lib/ogsf/GS2.c:1757
@@ -4188,7 +4191,7 @@
 #: ../lib/cairodriver/Graph.c:81
 #, fuzzy
 msgid "Unable to obtain visual"
-msgstr "%s açılamadı"
+msgstr " %s dosyası açılamıyor"
 #: ../lib/cairodriver/Graph.c:86
 #, fuzzy
@@ -4336,344 +4339,360 @@
 msgstr "'%s' dosyası silinemiyor"
-#~ msgstr "<%s> tablosu tanımlanamıyor"
+msgstr "<%s> tablosu tanımlanamıyor"
-#~ msgstr "bilinmeyen komut:%d sürüyor:%d"
+msgstr "bilinmeyen komut:%d sürüyor:%d"
-#~ msgstr " [%s] grafik sürücüsü başlatılamadı"
+msgstr " [%s] grafik sürücüsü başlatılamadı"
-#~ msgstr "Uyarı - <%s> grafik ekranda hiçbir yanıt yok.\n"
+msgstr "Uyarı - <%s> grafik ekranda hiçbir yanıt yok.\n"
-#~ msgstr "Farenin hala aktif olup olmadığını kontrol ediniz.\n"
+msgstr "Farenin hala aktif olup olmadığını kontrol ediniz.\n"
-#~ msgstr "HATA - <%s> grafik ekranından hiçbir yanıt yok.\n"
+msgstr "HATA - <%s> grafik ekranından hiçbir yanıt yok.\n"
-#~ msgstr "Çıktı için hiçbir ekran seçilmedi."
+msgstr "Çıktı için hiçbir ekran seçilmedi."
-#~ msgstr "Lütfen grafik ekran seçmek için \"d.mon\" komutunu çalıştırın."
+msgstr "Lütfen grafik ekran seçmek için \"d.mon\" komutunu çalıştırın."
-#~ msgstr "<%s> ekranına bağlı soket adı belirlenemiyor."
+msgstr "<%s> ekranına bağlı soket adı belirlenemiyor."
-#~ msgstr "<%s> ekranına hiçbir soket bağlı değil."
+msgstr "<%s> ekranına hiçbir soket bağlı değil."
-#~ msgstr "Soket ya zaten kullanımda yada bağlantıları kabul etmiyor."
+msgstr "Soket ya zaten kullanımda yada bağlantıları kabul etmiyor."
-#~ msgstr "Lütfen grafik ekran seçmek için \"d.mon\" komutunu kullanın"
+msgstr "Lütfen grafik ekran seçmek için \"d.mon\" komutunu kullanın"
-#~ msgstr "Soket olmayan birşeye bağlanmaya çalışıyorsunuz."
+msgstr "Soket olmayan birşeye bağlanmaya çalışıyorsunuz."
-#~ msgstr "Muhtemelen program hatası."
+msgstr "Muhtemelen program hatası."
-#~ msgstr "Bağlantı girişiminde zaman aşımı."
+msgstr "Bağlantı girişiminde zaman aşımı."
-#~ msgstr "Muhtemelen sunucu ile ilgili bir hata."
+msgstr "Muhtemelen sunucu ile ilgili bir hata."
-#~ msgstr "Bağlantıda hata oldu."
+msgstr "Bağlantıda hata oldu."
-#~ msgstr "[%d] çizgisinin topolojisi okunamıyor"
+msgstr "[%d] çizgisinin topolojisi okunamıyor"
 #, fuzzy
-#~ msgstr " %s dosyası açılamıyor"
-#~ msgstr "İstekten vazgeçmek için ENTER'a basın\n"
+msgstr "İstekten vazgeçmek için ENTER'a basın\n"
-#~ msgstr "Geçici dosya açılamıyor"
+msgstr "Geçici dosya açılamıyor"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Lütfen elipsoid adını belirleyiniz\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Lütfen elipsoid adını belirleyiniz\n"
-#~ msgstr "Kullanılabilir elipsoidlerin listesini görmek için 'list' yazın\n"
+msgstr "Kullanılabilir elipsoidlerin listesini görmek için 'list' yazın\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "geçersiz elipsoid\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"geçersiz elipsoid\n"
-#~ msgstr "'%s' çıktı adı geçerli bir raster adı değildir."
+msgstr "'%s' çıktı adı geçerli bir raster adı değildir."
-#~ msgstr "'%s' çıktı haritası girdi olarak kullanılıyor"
+msgstr "'%s' çıktı haritası girdi olarak kullanılıyor"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Lütfen datum adını belirleyiniz\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Lütfen datum adını belirleyiniz\n"
-#~ msgstr "Kullanılabilir datumların listesi için 'list' yazın\n"
+msgstr "Kullanılabilir datumların listesi için 'list' yazın\n"
-#~ msgstr "veya özel değişkenler girmek istiyorsanız 'custom' yazın\n"
+msgstr "veya özel değişkenler girmek istiyorsanız 'custom' yazın\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "geçersiz datum\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"geçersiz datum\n"
-#~ msgstr "Devam etmek için ENTER'a basın -->"
+msgstr "Devam etmek için ENTER'a basın -->"
-#~ msgstr "[%s deki %s] raster haritası açılamıyor"
+msgstr "[%s deki %s] raster haritası açılamıyor"
-#~ msgstr "bir dakika...\n"
+msgstr "bir dakika...\n"
-#~ msgstr "[%s] komutu için yardım yoktur\n"
+msgstr "[%s] komutu için yardım yoktur\n"
-#~ msgstr "%s@%s raster haritası boş"
+msgstr "%s@%s raster haritası boş"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "[%s] harita takımındaki [%s] dosyası için gerekli renk tablosu.\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"[%s] harita takımındaki [%s] dosyası için gerekli renk tablosu.\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Ä°stenen tipi belirleyin:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Ä°stenen tipi belirleyin:\n"
-#~ msgstr "    1:  Rasgele renkler\n"
+msgstr "    1:  Rasgele renkler\n"
-#~ msgstr "    3:  Renk dalgası\n"
+msgstr "    3:  Renk dalgası\n"
-#~ msgstr "    4:  Gri ölçek\n"
+msgstr "    4:  Gri ölçek\n"
-#~ msgstr "    5:  Bakı\n"
+msgstr "    5:  Bakı\n"
-#~ msgstr "    6:  Gökkuşağı renkleri\n"
+msgstr "    6:  Gökkuşağı renkleri\n"
-#~ msgstr "    7:  kırmızıdan sarıya, oradan da yaşile\n"
+msgstr "    7:  kırmızıdan sarıya, oradan da yaşile\n"
-#~ msgstr "    8:  Yeşilden sarıya, oradanda kırmızıya\n"
+msgstr "    8:  Yeşilden sarıya, oradanda kırmızıya\n"
-#~ msgstr "Çıkmak için ENTER'a basın\n"
+msgstr "Çıkmak için ENTER'a basın\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s geçersiz; Tekrar deneyin > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s geçersiz; Tekrar deneyin > "
-#~ msgstr "%s bulunamadı"
+msgstr "%s bulunamadı"
-#~ msgstr "%s'i okumada hata"
+msgstr "%s'i okumada hata"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Lütfen projeksiyon adını belirleyin\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"Lütfen projeksiyon adını belirleyin\n"
-#~ msgstr ""
-#~ "Kullanılabilir projeksiyonların listesini görmek için 'list' yazın\n"
+msgstr "Kullanılabilir projeksiyonların listesini görmek için 'list' yazın\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "geçersiz projeksiyon\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"geçersiz projeksiyon\n"
-#~ msgstr "başlıkla"
+msgstr "başlıkla"
-#~ msgstr "(başlıksız)"
+msgid "(no title)"
+msgstr "(başlıksız)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "FLAMA: tkip eden flamayı seçeyim mi?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"FLAMA: tkip eden flamayı seçeyim mi?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "SEÇENEK:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"SEÇENEK:   %s\n"
-#~ msgstr "    anahtar: %s\n"
+msgid "     key: %s\n"
+msgstr "    anahtar: %s\n"
-#~ msgstr "  biçim: %s\n"
+msgstr "  biçim: %s\n"
-#~ msgstr " varsayılan: %s\n"
+msgstr " varsayılan: %s\n"
-#~ msgstr "gereken: %s\n"
+msgstr "gereken: %s\n"
-#~ msgstr "çoklu: %s\n"
+msgstr "çoklu: %s\n"
-#~ msgstr "seçeneği girin >"
+msgstr "seçeneği girin >"
-#~ msgstr "   Tekrar deneyeyim mi? "
+msgstr "   Tekrar deneyeyim mi? "
-#~ msgstr "Üzgünüm, %s kabul edilmedi.\n"
+msgstr "Üzgünüm, %s kabul edilmedi.\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Seçtiniz:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Seçtiniz:\n"
+"  %s\n"
-#~ msgstr "Bu doÄŸru mu?"
+msgstr "Bu doÄŸru mu?"
-#~ msgstr "varsayılanı kabul et"
+msgstr "varsayılanı kabul et"
-#~ msgstr "İsteği iptal etmek için"
+msgstr "İsteği iptal etmek için"
-#~ msgstr "Yeni bir %s dosya adı girin"
+msgstr "Yeni bir %s dosya adı girin"
-#~ msgstr "Mevcut %s dosyasının adını gir"
+msgstr "Mevcut %s dosyasının adını gir"
-#~ msgstr "%s dosya adını gir"
+msgstr "%s dosya adını gir"
-#~ msgstr "Mevcut %s dosyalar listesi için 'listeyi' gir\n"
+msgstr "Mevcut %s dosyalar listesi için 'listeyi' gir\n"
-#~ msgstr "için 'list -f' gir"
+msgstr "için 'list -f' gir"
-#~ msgstr "%s listesi"
+msgid "a list %s"
+msgstr "%s listesi"
-#~ msgstr "geniÅŸletilmiÅŸ liste"
+msgstr "geniÅŸletilmiÅŸ liste"
-#~ msgstr "Enter'a Bas %s\n"
+msgstr "Enter'a Bas %s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - bulunamadı **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - bulunamadı **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s mevcut. Üzerine yazmak için onaylıyormusunuz? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s mevcut. Üzerine yazmak için onaylıyormusunuz? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - uygun olmayan istek **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - uygun olmayan istek **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - mevcut, başka bir ad seçin **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - mevcut, başka bir ad seçin **\n"
-#~ msgstr "[%s deki %s] için üstbilgi dosyası okunamıyor\n"
+msgstr "[%s deki %s] için üstbilgi dosyası okunamıyor\n"
-#~ msgstr "[%s deki %s] için üstbilgi dosyası açılamıyo"
+msgstr "[%s deki %s] için üstbilgi dosyası açılamıyo"
-#~ msgstr "Çizgi yeniden yazılamıyor"
+msgstr "Çizgi yeniden yazılamıyor"
-#~ msgstr "Çizgi silinemedi"
+msgstr "Çizgi silinemedi"
-#~ msgstr "Topoloji oluÅŸturuluyor...\n"
+msgstr "Topoloji oluÅŸturuluyor...\n"
-#~ msgstr "Alan bilgisi alınamıyor"
+msgstr "Alan bilgisi alınamıyor"
-#~ msgstr "Veritabanı açılamıyor"
+msgstr "Veritabanı açılamıyor"
-#~ msgstr "Tablo veya sütundan seçilemiyor"
+msgstr "Tablo veya sütundan seçilemiyor"
-#~ msgstr "<%s> sürücüsüyle <%s> veritabanı açılamıyor"
+msgstr "<%s> sürücüsüyle <%s> veritabanı açılamıyor"
-#~ msgstr "Sütun bilgisi alınamıyor"
+msgstr "Sütun bilgisi alınamıyor"
-#~ msgstr "[%d] OGR obje tipi desteklenmiyor"
+msgstr "[%d] OGR obje tipi desteklenmiyor"
+#~ msgstr "Hafıza ayrılamıyor\n"
+#, fuzzy
+#~ msgstr "<%s> harita takımındaki <%s>"
+#~ msgid ""
+#~ "\n"
+#~ "**<%s> illegal name **\n"
+#~ msgstr ""
+#~ "\n"
+#~ "**<%s> uygun olmayan ad **\n"
+#~ msgstr "[%s] deki [%s] bulunamıyor"
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_vi.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -522,9 +522,9 @@
 msgstr "không thể mở tập tin bảng ellipsoid : %s"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "không thể mở tập tin bảng ellipsoid : %s"
@@ -1257,12 +1257,12 @@
 #, fuzzy
-msgstr "Không thể mở tập tin tạm"
+msgstr "Không thể tính toán trọng tâm cho vùng %d"
 #, fuzzy
@@ -1978,9 +1978,9 @@
 msgstr "để chấp nhận mặc định"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "'Bọ': cố gắng cập nhật bản đồ không ở trong bộ bản đồ hiện tại."
@@ -2041,7 +2041,7 @@
 #, fuzzy, c-format
-msgstr "Keine %s Dateien im aktuellen Mapset vorhanden\n"
@@ -2245,7 +2245,7 @@
 #, fuzzy, c-format
-msgstr "không thể tìm thấy [%s] trong [%s]"
+msgstr "không thể tìm thấy [%s]"
 #, fuzzy, c-format
@@ -2308,9 +2308,9 @@
 msgstr ""
-#, c-format
+#, fuzzy, c-format
-msgstr ""
 #, c-format
@@ -3869,9 +3869,10 @@
 msgstr "Không tìm thấy vector đầu vào '%s'"
-#, c-format
+#, fuzzy, c-format
 msgstr ""
+"[%s] trong bộ bản đồ [%s] - ở một múi [%d] khác với vùng hiện hành [%d]"
@@ -4247,7 +4248,7 @@
 #, fuzzy
-msgstr "không thể mở %s"
+msgstr "Không thể mở tập tin %s trong %s"
 #, fuzzy
@@ -4398,619 +4399,629 @@
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Không thể mở CSDL"
+msgid "Cannot describe table <%s>"
+msgstr "Không thể mở CSDL"
 #, fuzzy
-#~ msgid "Unknown command: %d last: %d"
-#~ msgstr ""
-#~ "\n"
-#~ "Lệnh không biết: %d sau cùng: %d\n"
+msgid "Unknown command: %d last: %d"
+msgstr ""
+"\n"
+"Lệnh không biết: %d sau cùng: %d\n"
 #, fuzzy
-#~ msgid "Monitor: get_command: Premature EOF"
-#~ msgstr "Màn hình: get_command: EOF sớm\n"
+msgid "Monitor: get_command: Premature EOF"
+msgstr "Màn hình: get_command: EOF sớm\n"
-#~ msgid "ERROR %s from graphics driver.\n"
-#~ msgstr "LỖI %s từ trình điều khiển đồ họa.\n"
+msgid "ERROR %s from graphics driver.\n"
+msgstr "LỖI %s từ trình điều khiển đồ họa.\n"
-#~ msgid "ERROR - eof from graphics monitor.\n"
-#~ msgstr "LỖI - eof từ màn hình đồ họa.\n"
+msgid "ERROR - eof from graphics monitor.\n"
+msgstr "LỖI - eof từ màn hình đồ họa.\n"
-#~ msgid "Warning - no response from graphics monitor <%s>.\n"
-#~ msgstr "Cảnh báo - màn hình đồ họa không phản ứng <%s>.\n"
+msgid "Warning - no response from graphics monitor <%s>.\n"
+msgstr "Cảnh báo - màn hình đồ họa không phản ứng <%s>.\n"
-#~ msgid "Check to see if the mouse is still active.\n"
-#~ msgstr "Kiểm tra xem chuột có vẫn còn hoạt động không.\n"
+msgid "Check to see if the mouse is still active.\n"
+msgstr "Kiểm tra xem chuột có vẫn còn hoạt động không.\n"
-#~ msgid "ERROR - no response from graphics monitor <%s>.\n"
-#~ msgstr "LỖI - màn hình đồ họa không phản ứng <%s>.\n"
+msgid "ERROR - no response from graphics monitor <%s>.\n"
+msgstr "LỖI - màn hình đồ họa không phản ứng <%s>.\n"
 #, fuzzy
-#~ msgid "No graphics monitor has been selected for output."
-#~ msgstr "Không có màn hình đồ họa được chọn cho đầu ra.\n"
+msgid "No graphics monitor has been selected for output."
+msgstr "Không có màn hình đồ họa được chọn cho đầu ra.\n"
 #, fuzzy
-#~ msgid "Please run \"d.mon\" to select a graphics monitor."
-#~ msgstr "Hãy chạy \"d.mon\" để chọn một màn hình đồ họa .\n"
+msgid "Please run \"d.mon\" to select a graphics monitor."
+msgstr "Hãy chạy \"d.mon\" để chọn một màn hình đồ họa .\n"
 #, fuzzy
-#~ msgid "Failed to get socket name for monitor <%s>."
-#~ msgstr "Thất bại khi lấy tên socket cho màn hình <%s>.\n"
+msgid "Failed to get socket name for monitor <%s>."
+msgstr "Thất bại khi lấy tên socket cho màn hình <%s>.\n"
 #, fuzzy
-#~ msgid "No socket to connect to for monitor <%s>."
-#~ msgstr "Không có socket để nối với màn hình <%s>.\n"
+msgid "No socket to connect to for monitor <%s>."
+msgstr "Không có socket để nối với màn hình <%s>.\n"
 #, fuzzy
-#~ msgid "Socket is already in use or not accepting connections."
-#~ msgstr ""
-#~ "Socket đã được sử dụng hoặc không chấp nhận các kết nối.\n"
-#~ "Dùng d.mon để chọn một màn hình\n"
+msgid "Socket is already in use or not accepting connections."
+msgstr ""
+"Socket đã được sử dụng hoặc không chấp nhận các kết nối.\n"
+"Dùng d.mon để chọn một màn hình\n"
 #, fuzzy
-#~ msgid "Use d.mon to select a monitor"
+msgid "Use d.mon to select a monitor"
 #, fuzzy
-#~ msgstr ""
-#~ "Cố gắng kết nối tới thứ gì khác chứ không phải socket.\n"
-#~ "Có thể là lỗi chương trình.\n"
+msgstr ""
+"Cố gắng kết nối tới thứ gì khác chứ không phải socket.\n"
+"Có thể là lỗi chương trình.\n"
 #, fuzzy
-#~ msgid "Probably an error with the server."
-#~ msgstr "Cố gắng kết nối hết thời gian chờ. Có thể bị lỗi với server.\n"
+msgid "Probably an error with the server."
+msgstr "Cố gắng kết nối hết thời gian chờ. Có thể bị lỗi với server.\n"
 #, fuzzy
-#~ msgid "Connection failed."
-#~ msgstr "Kết nối thất bại.\n"
+msgid "Connection failed."
+msgstr "Kết nối thất bại.\n"
 #, fuzzy
-#~ msgstr "Không thể đọc biểu đồ histogram cho [%s in %s]"
+msgstr "Không thể đọc biểu đồ histogram cho [%s in %s]"
 #, fuzzy
-#~ msgid "Unable to open file %s"
-#~ msgstr "Không thể mở tập tin %s trong %s"
+msgid "Unable to open file %s"
 #, fuzzy
-#~ msgid "Unable to open temporary file"
+msgid "Unable to open temporary file"
-#~ msgid "Hit RETURN to cancel request\n"
-#~ msgstr "Bấm RETURN để hủy yêu cầu\n"
+msgid "Hit RETURN to cancel request\n"
+msgstr "Bấm RETURN để hủy yêu cầu\n"
-#~ msgid "Cannot open temp file"
-#~ msgstr "Không thể mở tập tin tạm"
+msgid "Cannot open temp file"
+msgstr "Không thể mở tập tin tạm"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify ellipsoid name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Vui lòng chỉ định tên ellipsoid\n"
+msgid ""
+"\n"
+"Please specify ellipsoid name\n"
+msgstr ""
+"\n"
+"Vui lòng chỉ định tên ellipsoid\n"
-#~ msgid "Enter 'list' for the list of available ellipsoids\n"
-#~ msgstr "Nhập 'list' để biết danh sách các ellipsoid đang có\n"
+msgid "Enter 'list' for the list of available ellipsoids\n"
+msgstr "Nhập 'list' để biết danh sách các ellipsoid đang có\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid ellipsoid\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ellipsoid không hợp lệ\n"
+msgid ""
+"\n"
+"invalid ellipsoid\n"
+msgstr ""
+"\n"
+"ellipsoid không hợp lệ\n"
-#~ msgid "Output name '%s' is not valid rast name."
-#~ msgstr "Tên đầu ra '%s' không phải là tên raster hợp lệ"
+msgid "Output name '%s' is not valid rast name."
+msgstr "Tên đầu ra '%s' không phải là tên raster hợp lệ"
-#~ msgid "Output map '%s' is used as input"
-#~ msgstr "Bản đồ đầu ra '%s' được sử dụng làm đầu vào"
+msgid "Output map '%s' is used as input"
+msgstr "Bản đồ đầu ra '%s' được sử dụng làm đầu vào"
-#~ msgid ""
-#~ "\n"
-#~ "Please specify datum name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Vui lòng chỉ định tên mốc tọa độ chuẩn\n"
+msgid ""
+"\n"
+"Please specify datum name\n"
+msgstr ""
+"\n"
+"Vui lòng chỉ định tên mốc tọa độ chuẩn\n"
-#~ msgid "Enter 'list' for the list of available datums\n"
-#~ msgstr "Nhập 'list' để có danh sách các mốc tọa độ chuẩn khả dụng\n"
+msgid "Enter 'list' for the list of available datums\n"
+msgstr "Nhập 'list' để có danh sách các mốc tọa độ chuẩn khả dụng\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid datum\n"
-#~ msgstr ""
-#~ "\n"
-#~ "mốc tọa độ chuẩn không hợp lệ\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"mốc tọa độ chuẩn không hợp lệ\n"
-#~ msgid "hit RETURN to continue -->"
-#~ msgstr "Bấm RETURN để tiếp tục -->"
+msgid "hit RETURN to continue -->"
+msgstr "Bấm RETURN để tiếp tục -->"
-#~ msgid "unable to open raster map [%s in %s]"
-#~ msgstr "không thể mở bản đồ raster [%s in %s]"
+msgid "unable to open raster map [%s in %s]"
+msgstr "không thể mở bản đồ raster [%s in %s]"
-#~ msgid "one moment...\n"
-#~ msgstr "chờ một chút...\n"
+msgid "one moment...\n"
+msgstr "chờ một chút...\n"
-#~ msgid "No help available for command [%s]\n"
-#~ msgstr "Không có trợ giúp cho lệnh [%s]\n"
+msgid "No help available for command [%s]\n"
+msgstr "Không có trợ giúp cho lệnh [%s]\n"
-#~ msgid " The raster map %s@%s is empty"
-#~ msgstr " Bản đồ raster %s@%s rỗng"
+msgid " The raster map %s@%s is empty"
+msgstr " Bản đồ raster %s@%s rỗng"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Color table needed for file [%s] in mapset [%s].\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Bảng màu cần cho tập tin [%s] trong bộ bản đồ [%s].\n"
+msgid ""
+"\n"
+"\n"
+"Color table needed for file [%s] in mapset [%s].\n"
+msgstr ""
+"\n"
+"\n"
+"Bảng màu cần cho tập tin [%s] trong bộ bản đồ [%s].\n"
-#~ msgid ""
-#~ "\n"
-#~ "Please identify the type desired:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Hãy xác định kiểu mong muốn:\n"
+msgid ""
+"\n"
+"Please identify the type desired:\n"
+msgstr ""
+"\n"
+"Hãy xác định kiểu mong muốn:\n"
-#~ msgid "    1:  Random colors\n"
-#~ msgstr "    1:  Các màu ngẫu nhiên\n"
+msgid "    1:  Random colors\n"
+msgstr "    1:  Các màu ngẫu nhiên\n"
-#~ msgid "    2:  Red, green, and blue color ramps\n"
-#~ msgstr "    2:  Đỏ, lục, và xanh tăng dần\n"
+msgid "    2:  Red, green, and blue color ramps\n"
+msgstr "    2:  Đỏ, lục, và xanh tăng dần\n"
-#~ msgid "    3:  Color wave\n"
-#~ msgstr "    3:  Farbenwelle\n"
+msgid "    3:  Color wave\n"
+msgstr "    3:  Farbenwelle\n"
-#~ msgid "    4:  Gray scale\n"
-#~ msgstr "    4:  Cấp độ xám\n"
+msgid "    4:  Gray scale\n"
+msgstr "    4:  Cấp độ xám\n"
-#~ msgid "    5:  Aspect\n"
-#~ msgstr "    5:  HÆ°á»›ng\n"
+msgid "    5:  Aspect\n"
+msgstr "    5:  HÆ°á»›ng\n"
-#~ msgid "    6:  Rainbow colors\n"
-#~ msgstr "    6:  Mầu cầu vồng\n"
+msgid "    6:  Rainbow colors\n"
+msgstr "    6:  Mầu cầu vồng\n"
-#~ msgid "    7:  Red through yellow to green\n"
-#~ msgstr "    7:  Đỏ qua vàng đến lục\n"
+msgid "    7:  Red through yellow to green\n"
+msgstr "    7:  Đỏ qua vàng đến lục\n"
-#~ msgid "    8:  Green through yellow to red\n"
-#~ msgstr "    8:  Lục qua vàng rồi đến đỏ\n"
+msgid "    8:  Green through yellow to red\n"
+msgstr "    8:  Lục qua vàng rồi đến đỏ\n"
-#~ msgid "RETURN  quit\n"
-#~ msgstr "ENTER  thoát ra\n"
+msgid "RETURN  quit\n"
+msgstr "ENTER  thoát ra\n"
-#~ msgid ""
-#~ "\n"
-#~ "%s invalid; Try again > "
-#~ msgstr ""
-#~ "\n"
-#~ "%s không hợp lệ; Hãy thử lại > "
+msgid ""
+"\n"
+"%s invalid; Try again > "
+msgstr ""
+"\n"
+"%s không hợp lệ; Hãy thử lại > "
-#~ msgid "%s not found"
-#~ msgstr "không tìm thấy %s"
+msgid "%s not found"
+msgstr "không tìm thấy %s"
-#~ msgid "ERROR in reading %s"
-#~ msgstr "LỖI khi đang đọc %s"
+msgid "ERROR in reading %s"
+msgstr "LỖI khi đang đọc %s"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Please specify projection name\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Vui lòng chỉ định tên phép chiếu\n"
+msgid ""
+"\n"
+"\n"
+"Please specify projection name\n"
+msgstr ""
+"\n"
+"\n"
+"Vui lòng chỉ định tên phép chiếu\n"
-#~ msgid "Enter 'list' for the list of available projections\n"
-#~ msgstr "Gõ 'list' để biết danh sách các phép chiếu hiện có\n"
+msgid "Enter 'list' for the list of available projections\n"
+msgstr "Gõ 'list' để biết danh sách các phép chiếu hiện có\n"
-#~ msgid ""
-#~ "\n"
-#~ "invalid projection\n"
-#~ msgstr ""
-#~ "\n"
-#~ "phép chiếu không hợp lệ\n"
+msgid ""
+"\n"
+"invalid projection\n"
+msgstr ""
+"\n"
+"phép chiếu không hợp lệ\n"
-#~ msgid "with titles"
-#~ msgstr "với các tiêu đề"
+msgid "with titles"
+msgstr "với các tiêu đề"
-#~ msgid "(no title)"
-#~ msgstr "(không tiêu đề)"
+msgid "(no title)"
+msgstr "(không tiêu đề)"
-#~ msgid ""
-#~ "\n"
-#~ "FLAG: Set the following flag?\n"
-#~ msgstr ""
-#~ "\n"
-#~ "CỜ: Thiết lập cờ sau?\n"
+msgid ""
+"\n"
+"FLAG: Set the following flag?\n"
+msgstr ""
+"\n"
+"CỜ: Thiết lập cờ sau?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "TÙY_CHỌN:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"TÙY_CHỌN:   %s\n"
-#~ msgid "     key: %s\n"
-#~ msgstr "     khóa: %s\n"
+msgid "     key: %s\n"
+msgstr "     khóa: %s\n"
-#~ msgid "  format: %s\n"
-#~ msgstr "  định dạng: %s\n"
+msgid "  format: %s\n"
+msgstr "  định dạng: %s\n"
-#~ msgid " default: %s\n"
-#~ msgstr " mặc định: %s\n"
+msgid " default: %s\n"
+msgstr " mặc định: %s\n"
-#~ msgid "required: %s\n"
-#~ msgstr "cần có: %s\n"
+msgid "required: %s\n"
+msgstr "cần có: %s\n"
-#~ msgid "multiple: %s\n"
-#~ msgstr "bá»™i: %s\n"
+msgid "multiple: %s\n"
+msgstr "bá»™i: %s\n"
-#~ msgid "enter option > "
-#~ msgstr "nhập tùy_chọn > "
+msgid "enter option > "
+msgstr "nhập tùy_chọn > "
-#~ msgid "   Try again? "
-#~ msgstr "   Thử lại? "
+msgid "   Try again? "
+msgstr "   Thử lại? "
-#~ msgid "Sorry, %s is not accepted.\n"
-#~ msgstr "Xin lỗi, %s không được chấp nhận.\n"
+msgid "Sorry, %s is not accepted.\n"
+msgstr "Xin lỗi, %s không được chấp nhận.\n"
-#~ msgid ""
-#~ "\n"
-#~ "You have chosen:\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bạn đã chọn:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"You have chosen:\n"
+"  %s\n"
+msgstr ""
+"\n"
+"Bạn đã chọn:\n"
+"  %s\n"
-#~ msgid "Is this correct? "
-#~ msgstr "Đã đúng chưa? "
+msgid "Is this correct? "
+msgstr "Đã đúng chưa? "
-#~ msgid "to accept the default"
-#~ msgstr "để chấp nhận mặc định"
+msgid "to accept the default"
+msgstr "để chấp nhận mặc định"
-#~ msgid "to cancel request"
-#~ msgstr "để hủy bỏ yêu cầu"
+msgid "to cancel request"
+msgstr "để hủy bỏ yêu cầu"
-#~ msgid "Enter a new %s file name"
-#~ msgstr "Nhập vào tên tập tin mới %s"
+msgid "Enter a new %s file name"
+msgstr "Nhập vào tên tập tin mới %s"
-#~ msgid "Enter the name of an existing %s file"
-#~ msgstr "Nhập vào tên một tập tin %s đã có"
+msgid "Enter the name of an existing %s file"
+msgstr "Nhập vào tên một tập tin %s đã có"
-#~ msgid "Enter %s file name"
-#~ msgstr "Nhập vào tên tập tin %s"
+msgid "Enter %s file name"
+msgstr "Nhập vào tên tập tin %s"
-#~ msgid "Enter 'list' for a list of existing %s files\n"
-#~ msgstr "Gõ 'list' để có danh sách các tập tin %s hiện có\n"
+msgid "Enter 'list' for a list of existing %s files\n"
+msgstr "Gõ 'list' để có danh sách các tập tin %s hiện có\n"
-#~ msgid "Enter 'list -f' for "
-#~ msgstr "Gõ 'list -f' để "
+msgid "Enter 'list -f' for "
+msgstr "Gõ 'list -f' để "
-#~ msgid "a list %s"
-#~ msgstr "có một danh sách %s"
+msgid "a list %s"
+msgstr "có một danh sách %s"
-#~ msgid "an extended list"
-#~ msgstr "danh sách mở rộng"
+msgid "an extended list"
+msgstr "danh sách mở rộng"
-#~ msgid "Hit RETURN %s\n"
-#~ msgstr "Bấm RETURN %s\n"
+msgid "Hit RETURN %s\n"
+msgstr "Bấm RETURN %s\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - not found **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - không tìm thấy **\n"
+msgid ""
+"\n"
+"** %s - not found **\n"
+msgstr ""
+"\n"
+"** %s - không tìm thấy **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s exists. ok to overwrite? "
-#~ msgstr ""
-#~ "\n"
-#~ "** %s tồn tại. Chấp nhận ghi đè? "
+msgid ""
+"\n"
+"** %s exists. ok to overwrite? "
+msgstr ""
+"\n"
+"** %s tồn tại. Chấp nhận ghi đè? "
-#~ msgid ""
-#~ "\n"
-#~ "**<%s> illegal name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> tên không hợp lệ **\n"
+msgid ""
+"\n"
+"**<%s> illegal name **\n"
+msgstr ""
+"\n"
+"**<%s> tên không hợp lệ **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - illegal request **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - yêu cầu không hợp lệ **\n"
+msgid ""
+"\n"
+"** %s - illegal request **\n"
+msgstr ""
+"\n"
+"** %s - yêu cầu không hợp lệ **\n"
-#~ msgid ""
-#~ "\n"
-#~ "** %s - exists, select another name **\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - đã có, chọn tên khác **\n"
+msgid ""
+"\n"
+"** %s - exists, select another name **\n"
+msgstr ""
+"\n"
+"** %s - đã có, chọn tên khác **\n"
-#~ msgid "ask: can't happen"
-#~ msgstr "yêu cầu: không thể xảy ra"
+msgid "ask: can't happen"
+msgstr "yêu cầu: không thể xảy ra"
-#~ msgid "Can't read header file for [%s in %s]\n"
-#~ msgstr "Không thể đọc tập tin header của [%s trong %s]\n"
+msgid "Can't read header file for [%s in %s]\n"
+msgstr "Không thể đọc tập tin header của [%s trong %s]\n"
-#~ msgid "Can't open header file for [%s in %s]"
-#~ msgstr "Không thể mở tập tin header của [%s trong %s]"
+msgid "Can't open header file for [%s in %s]"
+msgstr "Không thể mở tập tin header của [%s trong %s]"
 #, fuzzy
-#~ msgid "Cannot get field info"
-#~ msgstr "Không thể lấy thông tin lớp"
+msgid "Cannot get field info"
+msgstr "Không thể lấy thông tin lớp"
 #, fuzzy
-#~ msgid "Cannot open database"
+msgid "Cannot open database"
-#~ msgstr "Đang xây dựng tôpô ...\n"
+msgstr "Đang xây dựng tôpô ...\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "\r%d các vùng được xây dựng      \n"
-#~ "%d các đảo được xây dựng\n"
+msgid ""
+"%d isles built\n"
+msgstr ""
+"\r%d các vùng được xây dựng      \n"
+"%d các đảo được xây dựng\n"
 #, fuzzy
-#~ msgid "Cannot open database <%s> by driver <%s>"
+msgid "Cannot open database <%s> by driver <%s>"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
+msgstr "Kiểu đối tượng OGR %d không được hỗ trợ"
 #, fuzzy
-#~ msgstr "Vect_rewrite_line() cho định dạng/cấp này không được hỗ trợ"
+msgstr "Vect_rewrite_line() cho định dạng/cấp này không được hỗ trợ"
-#~ msgstr "Vect_delete_line() cho định dạng/cấp này không được hỗ trợ"
+msgstr "Vect_delete_line() cho định dạng/cấp này không được hỗ trợ"
-#~ msgstr "Không thể ghi lại đường"
+msgstr "Không thể ghi lại đường"
-#~ msgstr "Không thể xóa đường"
+msgstr "Không thể xóa đường"
-#~ msgid "Output name '%s' is not valid vector name."
-#~ msgstr "Tên bản đồ đầu ra '%s' không phải là tên vector hợp lệ"
+msgid "Output name '%s' is not valid vector name."
+msgstr "Tên bản đồ đầu ra '%s' không phải là tên vector hợp lệ"
-#~ msgid "Cannot copy vector '%s' to '%s'"
-#~ msgstr "Không thể sao chép vector '%s' tới '%s'"
+msgid "Cannot copy vector '%s' to '%s'"
+msgstr "Không thể sao chép vector '%s' tới '%s'"
 #, fuzzy
-#~ msgid "Cannot open existing vector map <%s>"
-#~ msgstr "Không thể xóa vector hiện có %s"
+msgid "Cannot open existing vector map <%s>"
+msgstr "Không thể xóa vector hiện có %s"
 #, fuzzy
-#~ msgid "Cannot delete existing vector <%s>"
+msgid "Cannot delete existing vector <%s>"
-#~ msgid "Cannot open new vector %s"
-#~ msgstr "Không thể mở vector mới %s"
+msgid "Cannot open new vector %s"
+msgstr "Không thể mở vector mới %s"
-#~ msgid "Cannot open history file for vector '%s'"
-#~ msgstr "Không thể mở tập tin lịch sử của vector '%s'"
+msgid "Cannot open history file for vector '%s'"
+msgstr "Không thể mở tập tin lịch sử của vector '%s'"
-#~ msgid "Could not stat file '%s'"
-#~ msgstr "Không thể khởi động tập tin %s"
+msgid "Could not stat file '%s'"
+msgstr "Không thể khởi động tập tin %s"
 #, fuzzy
-#~ msgid "Can't open directory %s"
-#~ msgstr "Không thể mở vector cũ %s"
+msgid "Can't open directory %s"
+msgstr "Không thể mở vector cũ %s"
-#~ msgid "%s - ** illegal name **"
-#~ msgstr "%s - ** tên không hợp lệ **"
+msgid "%s - ** illegal name **"
+msgstr "%s - ** tên không hợp lệ **"
-#~ msgid "No such graphics monitor as <%s>.\n"
-#~ msgstr "Không có màn hình đồ họa nào là <%s>.\n"
+msgid "No such graphics monitor as <%s>.\n"
+msgstr "Không có màn hình đồ họa nào là <%s>.\n"
-#~ msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
-#~ msgstr "Hãy chạy \"d.mon\" để chọn một màn hình đồ họa hợp lệ.\n"
+msgid "Please run \"d.mon\" to select a valid graphics monitor.\n"
+msgstr "Hãy chạy \"d.mon\" để chọn một màn hình đồ họa hợp lệ.\n"
-#~ msgid "Can't stat %s\n"
-#~ msgstr "Không thể khởi động %s\n"
+msgid "Can't stat %s\n"
+msgstr "Không thể khởi động %s\n"
-#~ msgid "Error - Monitor <%s> is in use.\n"
-#~ msgstr "Lỗi - Màn hình <%s> đang được sử dụng.\n"
+msgid "Error - Monitor <%s> is in use.\n"
+msgstr "Lỗi - Màn hình <%s> đang được sử dụng.\n"
-#~ msgid "Error - Monitor <%s> is in use by %s.\n"
-#~ msgstr "Lỗi - Màn hình <%s> đang được sử dụng bởi %s.\n"
+msgid "Error - Monitor <%s> is in use by %s.\n"
+msgstr "Lỗi - Màn hình <%s> đang được sử dụng bởi %s.\n"
-#~ msgid "Error - Could not complete locking process for monitor <%s>.\n"
-#~ msgstr "Lỗi - Không thể hoàn tất việc khóa màn hình <%s>.\n"
+msgid "Error - Could not complete locking process for monitor <%s>.\n"
+msgstr "Lỗi - Không thể hoàn tất việc khóa màn hình <%s>.\n"
-#~ msgid "Error - Can't set up pipe to graphics device.\n"
-#~ msgstr "Lỗi - Không thể thiết lập 'ống dẫn' tới thiết bị đồ họa.\n"
+msgid "Error - Can't set up pipe to graphics device.\n"
+msgstr "Lỗi - Không thể thiết lập 'ống dẫn' tới thiết bị đồ họa.\n"
-#~ msgid "Error - Graphics monitor <%s> not running!\n"
-#~ msgstr "Lỗi - Màn hình đồ họa <%s> không chạy!\n"
+msgid "Error - Graphics monitor <%s> not running!\n"
+msgstr "Lỗi - Màn hình đồ họa <%s> không chạy!\n"
-#~ msgid "Please start graphics monitor <%s>.\n"
-#~ msgstr "Hãy khởi động màn hình đồ họa <%s>.\n"
+msgid "Please start graphics monitor <%s>.\n"
+msgstr "Hãy khởi động màn hình đồ họa <%s>.\n"
-#~ msgid "Not connected...\n"
-#~ msgstr "Không kết nối ...\n"
+msgid "Not connected...\n"
+msgstr "Không kết nối ...\n"
-#~ msgid "Couldn't connect to monitor. Will try once more.\n"
-#~ msgstr "Không thể kết nối với màn hình. Sẽ cố gắng một lần nữa \n"
+msgid "Couldn't connect to monitor. Will try once more.\n"
+msgstr "Không thể kết nối với màn hình. Sẽ cố gắng một lần nữa \n"
-#~ msgid "G_dump: memory allocated to G__"
-#~ msgstr "G_dump: bộ nhớ cấp phát cho G__"
+msgid "G_dump: memory allocated to G__"
+msgstr "G_dump: bộ nhớ cấp phát cho G__"
-#~ msgstr "Kích thước của ô trong các bản đồ fp = %d"
+msgstr "Kích thước của ô trong các bản đồ fp = %d"
-#~ msgstr "Kiểu để ghi các bản đồ float = %d"
+msgstr "Kiểu để ghi các bản đồ float = %d"
-#~ msgstr "Cửa sổ hiện hành = %p"
+msgstr "Cửa sổ hiện hành = %p"
-#~ msgstr "Cờ: cửa sổ được thiết lập? %d"
+msgstr "Cờ: cửa sổ được thiết lập? %d"
-#~ msgstr "Trình mô tả tập tin cho mặt nạ tự động %d"
+msgstr "Trình mô tả tập tin cho mặt nạ tự động %d"
-#~ msgstr "Cờ biểu thị tạo mặt nạ tự động %d"
+msgstr "Cờ biểu thị tạo mặt nạ tự động %d"
-#~ msgstr "vùng đệm mặt nạ cho CELL %p"
+msgstr "vùng đệm mặt nạ cho CELL %p"
-#~ msgstr "Vùng đệm để đọc các hàng null %p"
+msgstr "Vùng đệm để đọc các hàng null %p"
-#~ msgstr "Vùng đệm dữ liệu trước/sau khi nén %p"
+msgstr "Vùng đệm dữ liệu trước/sau khi nén %p"
-#~ msgstr "kích thước của compressed_buf %d"
+msgstr "kích thước của compressed_buf %d"
-#~ msgstr "vùng đệm dữ liệu làm việc %p"
+msgstr "vùng đệm dữ liệu làm việc %p"
-#~ msgstr "kích thước của work_buf %d"
+msgstr "kích thước của work_buf %d"
-#~ msgstr "kích thước của null_buf %d"
+msgstr "kích thước của null_buf %d"
-#~ msgstr "kích thước của mask_buf %d"
+msgstr "kích thước của mask_buf %d"
-#~ msgstr "yêu cầu biểu đồ histogram %d"
+msgstr "yêu cầu biểu đồ histogram %d"
-#~ msgstr "G_dump: tập tin #%d"
+msgstr "G_dump: tập tin #%d"
-#~ msgstr "chế độ mở = %d"
+msgstr "chế độ mở = %d"
-#~ msgid "Cell header %p"
-#~ msgstr "header của cell %p"
+msgid "Cell header %p"
+msgstr "header của cell %p"
-#~ msgstr "Phân loại lại bảng %p"
+msgstr "Phân loại lại bảng %p"
-#~ msgid "Cell stats %p"
-#~ msgstr "Thống kê cell %p"
+msgid "Cell stats %p"
+msgstr "Thống kê cell %p"
-#~ msgstr "Cấu trúc miền %p"
+msgstr "Cấu trúc miền %p"
-#~ msgstr "Cấu trúc miền kiểu float %p"
+msgstr "Cấu trúc miền kiểu float %p"
-#~ msgstr "cần biểu đồ histogram?  %d"
+msgstr "cần biểu đồ histogram?  %d"
-#~ msgstr "Cờ phân loại lại tự động %d"
+msgstr "Cờ phân loại lại tự động %d"
-#~ msgstr "Các địa chỉ hàng tập tin %p"
+msgstr "Các địa chỉ hàng tập tin %p"
-#~ msgid "Data to window col mapping %p"
-#~ msgstr "Lập bản đồ cột Dữ-liệu-đến-cửa-sổ %p"
+msgid "Data to window col mapping %p"
+msgstr "Lập bản đồ cột Dữ-liệu-đến-cửa-sổ %p"
-#~ msgid "Data to window row constants %f,%f"
-#~ msgstr "Các hằng số hàng Dữ-liệu-đến-cửa-sổ %p"
+msgid "Data to window row constants %f,%f"
+msgstr "Các hằng số hàng Dữ-liệu-đến-cửa-sổ %p"
-#~ msgstr "Hàng dữ liệu hiện tại trong bộ nhớ %d"
+msgstr "Hàng dữ liệu hiện tại trong bộ nhớ %d"
-#~ msgstr "Hàng null hiện tại trong bộ nhớ %d"
+msgstr "Hàng null hiện tại trong bộ nhớ %d"
-#~ msgstr "nbytes trên cell của hàng hiện tại %d"
+msgstr "nbytes trên cell của hàng hiện tại %d"
-#~ msgid "Decompressed data buffer %s"
-#~ msgstr "Vùng đệm dữ liệu được giải nén %s"
+msgid "Decompressed data buffer %s"
+msgstr "Vùng đệm dữ liệu được giải nén %s"
-#~ msgstr "bytes trên cell %d"
+msgstr "bytes trên cell %d"
-#~ msgstr "Kiểu: bản đồ int, float hay double%d"
+msgstr "Kiểu: bản đồ int, float hay double%d"
-#~ msgid "Temporary name for NEW files %s"
-#~ msgstr "Tên tạm cho các tập tin MỚI %s"
+msgid "Temporary name for NEW files %s"
+msgstr "Tên tạm cho các tập tin MỚI %s"
-#~ msgid "Temporary name for NEW NULL files %s"
-#~ msgstr "Tên tạm cho các tập tin NULL MỚI %s"
+msgid "Temporary name for NEW NULL files %s"
+msgstr "Tên tạm cho các tập tin NULL MỚI %s"
-#~ msgid "Mapset of open file %s"
-#~ msgstr "Bộ bản đồ của tập tin mở %s"
+msgid "Mapset of open file %s"
+msgstr "Bộ bản đồ của tập tin mở %s"
-#~ msgstr "cảnh báo lỗi io (ra/vào) được đưa ra %d"
+msgstr "cảnh báo lỗi io (ra/vào) được đưa ra %d"
-#~ msgstr "xdr stream để đọc fp %p"
+msgstr "xdr stream để đọc fp %p"
-#~ msgstr "mảng NULL_ROWS [%d] = %p"
+msgstr "mảng NULL_ROWS [%d] = %p"
-#~ msgstr "vùng đệm dữ liệu để đọc các hàng null %p"
+msgstr "vùng đệm dữ liệu để đọc các hàng null %p"
-#~ msgstr "Số hàng null tối thiểu trong bộ nhớ %d"
+msgstr "Số hàng null tối thiểu trong bộ nhớ %d"
-#~ msgid "Quant ptr = %p"
-#~ msgstr "Quant ptr = %p"
+msgid "Quant ptr = %p"
+msgstr "Quant ptr = %p"
-#~ msgstr "G_dump: kết thúc"
+msgstr "G_dump: kết thúc"
-#~ msgid "getting graphics window"
-#~ msgstr "đang lấy cửa sổ đồ họa"
+msgid "getting graphics window"
+msgstr "đang lấy cửa sổ đồ họa"
-#~ msgid "clearing current graphics window"
-#~ msgstr "đang xóa cửa sổ đồ họa hiện tại"
+msgid "clearing current graphics window"
+msgstr "đang xóa cửa sổ đồ họa hiện tại"
-#~ msgid "Setting map window"
-#~ msgstr "Thiết lập cửa sổ bản đồ"
+msgid "Setting map window"
+msgstr "Thiết lập cửa sổ bản đồ"
-#~ msgstr "Cửa sổ hiện tại không thể thiết lập được"
+msgstr "Cửa sổ hiện tại không thể thiết lập được"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Không thể xóa cửa sổ bản đồ hiện tại"
+msgid "Can't clear current graphics window"
+msgstr "Không thể xóa cửa sổ bản đồ hiện tại"
-#~ msgid "Color file for [%s] not available"
-#~ msgstr "Tập tin màu cho [%s] không khả dụng"
+msgid "Color file for [%s] not available"
+msgstr "Tập tin màu cho [%s] không khả dụng"
-#~ msgstr "Không thể dùng cửa sổ hiện tại"
+msgstr "Không thể dùng cửa sổ hiện tại"
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "Không thể mở tập tin cell cho [%s]"
+msgid "Not able to open cellfile for [%s]"
+msgstr "Không thể mở tập tin cell cho [%s]"
-#~ msgid "Monitor: _send: write returned short count: %d of %d\n"
-#~ msgstr "Màn hình: _send: việc ghi trả lại phép đếm thiếu: %d trong %d\n"
+msgid "Monitor: _send: write returned short count: %d of %d\n"
+msgstr "Màn hình: _send: việc ghi trả lại phép đếm thiếu: %d trong %d\n"
-#~ msgid "Force overwrite of output files"
-#~ msgstr "Buộc ghi đè các tập tin đầu ra"
+msgid "Force overwrite of output files"
+msgstr "Buộc ghi đè các tập tin đầu ra"
+#~ msgid "Unable to allocate memory\n"
+#~ msgstr "Không thể cấp phát bộ nhớ\n"
+#, fuzzy
+#~ msgid "<%s>: bad mapset"
+#~ msgstr "<%s> trong bộ bản đồ <%s>"
+#~ msgid "unable to find [%s] in [%s]"
+#~ msgstr "không thể tìm thấy [%s] trong [%s]"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grasslibs_zh.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -574,9 +574,9 @@
 msgstr "无法打开椭球表文件:%s"
 #: ../lib/db/dbmi_client/copy_tab.c:157
-#, c-format
+#, fuzzy, c-format
 msgid "Table <%s> already exists in database <%s>"
-msgstr ""
+msgstr "无法打开椭球表文件:%s"
 #: ../lib/db/dbmi_client/copy_tab.c:199 ../lib/db/dbmi_client/copy_tab.c:276
 #: ../lib/db/dbmi_client/table.c:110
@@ -1308,12 +1308,12 @@
 #: ../lib/vector/Vlib/write_nat.c:640
 #, fuzzy
 msgid "Attempt to delete dead feature"
-msgstr "无法打开临时文件"
+msgstr "无法为区域 %d 计算质心"
 #: ../lib/vector/Vlib/write_nat.c:885
 #, fuzzy
 msgid "Attempt to restore alive feature"
-msgstr "无法打开临时文件"
 #: ../lib/vector/Vlib/level_two.c:210 ../lib/vector/Vlib/level_two.c:235
 #: ../lib/vector/Vlib/level_two.c:259 ../lib/vector/Vlib/level_two.c:278
@@ -2039,9 +2039,9 @@
 msgstr "替换默认窗口"
 #: ../lib/g3d/g3dcolor.c:332
-#, c-format
+#, fuzzy, c-format
 msgid "mapset <%s> is not the current mapset"
-msgstr ""
+msgstr "错误:试图更新不在当前地图集中的地图。"
 #: ../lib/g3d/g3dopen.c:20
 msgid "G3d_openCellOldNoHeader: error in G3d_maskOpenOld"
@@ -2102,7 +2102,7 @@
 #: ../lib/g3d/g3dopen.c:229
 #, fuzzy, c-format
 msgid "map <%s> is not in the current mapset"
-msgstr "当前地图集中没有 %s 文件\n"
 #: ../lib/g3d/g3dopen.c:239
 msgid "G3d_openCellNew: could not open file"
@@ -2301,7 +2301,7 @@
 #: ../lib/gis/opencell.c:932 ../lib/gis/opencell.c:1020
 #, fuzzy, c-format
 msgid "Unable to find '%s' in '%s'"
-msgstr "无法找到[%s]在[%s]中"
+msgstr "无法找到[%s]"
 #: ../lib/gis/opencell.c:965
 #, fuzzy, c-format
@@ -2364,9 +2364,9 @@
 msgstr ""
 #: ../lib/gis/find_file.c:82
-#, c-format
+#, fuzzy, c-format
 msgid "Using <%s@%s>"
-msgstr ""
+msgstr "无法找到[%s]"
 #: ../lib/gis/quant_io.c:89
 #, c-format
@@ -3917,9 +3917,9 @@
 msgstr "输入矢量'%s'未找到"
-#, c-format
+#, fuzzy, c-format
-msgstr ""
+msgstr "[%s]在地图集[%s]中 - 区域[%d]与当前的范围[%d]不同"
@@ -4290,7 +4290,7 @@
 #, fuzzy
-msgstr "无法打开%s"
+msgstr "无法打开文件 %s 在 %s 中"
 #, fuzzy
@@ -4440,636 +4440,646 @@
 msgid "Unable to define new light"
-#~ msgstr "无法打开数据库表 <%s>"
+msgstr "无法打开数据库表 <%s>"
-#~ msgstr "错误的%s来自图形驱动器。\n"
+msgstr "错误的%s来自图形驱动器。\n"
-#~ msgstr "错误 - 图形监视器的eof。\n"
+msgstr "错误 - 图形监视器的eof。\n"
-#~ msgstr "警告 - 图形监视器<%s>没有响应。\n"
+msgstr "警告 - 图形监视器<%s>没有响应。\n"
-#~ msgstr "请检查鼠标是否还能活动。\n"
+msgstr "请检查鼠标是否还能活动。\n"
-#~ msgstr "错误 - 图形监视器<%s>没有响应。\n"
+msgstr "错误 - 图形监视器<%s>没有响应。\n"
 #, fuzzy
-#~ msgstr "没有选择用来输出的图形监视器。\n"
+msgstr "没有选择用来输出的图形监视器。\n"
 #, fuzzy
-#~ msgstr "请运行\"d.mon\"来选择一个图形监视器。\n"
+msgstr "请运行\"d.mon\"来选择一个图形监视器。\n"
 #, fuzzy
-#~ msgstr "获取监视器<%s>的socket名称失败。\n"
+msgstr "获取监视器<%s>的socket名称失败。\n"
 #, fuzzy
-#~ msgstr "没有socket连接到监视器<%s>。\n"
+msgstr "没有socket连接到监视器<%s>。\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Socket已经在使用或是不接受连接。\n"
-#~ "请使用d.mon来选择一个监视器\n"
+msgstr ""
+"Socket已经在使用或是不接受连接。\n"
+"请使用d.mon来选择一个监视器\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Trying to connect to something not a socket."
-#~ msgstr ""
-#~ "尝试连接到别的东西而不是socket。\n"
-#~ "或许是程序出错。\n"
+msgid "Trying to connect to something not a socket."
+msgstr ""
+"尝试连接到别的东西而不是socket。\n"
+"或许是程序出错。\n"
 #, fuzzy
-#~ msgstr "尝试连接超时。可能是服务器出现错误。\n"
+msgstr "尝试连接超时。可能是服务器出现错误。\n"
 #, fuzzy
-#~ msgstr "连接失败。\n"
+msgstr "连接失败。\n"
 #, fuzzy
-#~ msgid "Cannot read topo for line [%d]"
-#~ msgstr "无法读取[ %s 在 %s 中]的直方图"
+msgid "Cannot read topo for line [%d]"
+msgstr "无法读取[ %s 在 %s 中]的直方图"
 #, fuzzy
-#~ msgstr "无法打开文件 %s 在 %s 中"
 #, fuzzy
-#~ msgstr "按回车取消请求\n"
+msgstr "按回车取消请求\n"
-#~ msgstr "无法打开临时文件"
+msgstr "无法打开临时文件"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "请指定椭球名称\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"请指定椭球名称\n"
-#~ msgstr "输入'list',列出所有可用的投影\n"
+msgstr "输入'list',列出所有可用的投影\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "无效的椭球\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"无效的椭球\n"
-#~ msgstr "输出的名称'%s'不是有效的栅格名称。"
+msgstr "输出的名称'%s'不是有效的栅格名称。"
-#~ msgstr "输出地图'%s'被用作输入"
+msgstr "输出地图'%s'被用作输入"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "请指定基准面名称\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"请指定基准面名称\n"
-#~ msgstr "输入'list',列出可用的基准面\n"
+msgstr "输入'list',列出可用的基准面\n"
-#~ msgid "or 'custom' if you wish to enter custom parameters\n"
-#~ msgstr "或输入'custom'进行自定义参数设置\n"
+msgid "or 'custom' if you wish to enter custom parameters\n"
+msgstr "或输入'custom'进行自定义参数设置\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "无效的基准面\n"
+msgid ""
+"\n"
+"invalid datum\n"
+msgstr ""
+"\n"
+"无效的基准面\n"
-#~ msgstr "按回车键继续 -->"
+msgstr "按回车键继续 -->"
-#~ msgstr "无法打开栅格图[%s在%s中]"
+msgstr "无法打开栅格图[%s在%s中]"
-#~ msgstr "请稍等片刻...\n"
+msgstr "请稍等片刻...\n"
-#~ msgstr "命令[%s]没有可用的帮助\n"
+msgstr "命令[%s]没有可用的帮助\n"
-#~ msgstr " 栅格图%s@%s是空的"
+msgstr " 栅格图%s@%s是空的"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "文件[%s]在地图集[%s]中,需要色彩表。\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"文件[%s]在地图集[%s]中,需要色彩表。\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "请确定需要的类型:\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"请确定需要的类型:\n"
-#~ msgstr "    1:  随机颜色\n"
+msgstr "    1:  随机颜色\n"
-#~ msgstr "    2:  红、绿、蓝色阶\n"
+msgstr "    2:  红、绿、蓝色阶\n"
-#~ msgstr "    3:  色波(Color wave)\n"
+msgstr "    3:  色波(Color wave)\n"
-#~ msgstr "    4:  灰度\n"
+msgstr "    4:  灰度\n"
-#~ msgstr "    5:  色相(Aspect)\n"
+msgstr "    5:  色相(Aspect)\n"
-#~ msgstr "    6:   色带(Rainbow colors)\n"
+msgstr "    6:   色带(Rainbow colors)\n"
-#~ msgstr "    7:  红到黄再到绿\n"
+msgstr "    7:  红到黄再到绿\n"
-#~ msgstr "    8:  绿到黄再到红\n"
+msgstr "    8:  绿到黄再到红\n"
-#~ msgstr "回车  退出\n"
+msgstr "回车  退出\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "%s无效:重试 > "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"%s无效:重试 > "
-#~ msgstr "未发现 %s"
+msgstr "未发现 %s"
-#~ msgstr "读取 %s 时出现错误"
+msgstr "读取 %s 时出现错误"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "请指定投影名称\n"
+msgid ""
+"\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"请指定投影名称\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "无效的投影\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"无效的投影\n"
-#~ msgstr "标题"
+msgstr "标题"
-#~ msgstr "(无标题)"
+msgid "(no title)"
+msgstr "(无标题)"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "标记:是否设置下面的标记?\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"标记:是否设置下面的标记?\n"
-#~ msgid ""
-#~ "\n"
-#~ "OPTION:   %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "选项:   %s\n"
+msgid ""
+"\n"
+"OPTION:   %s\n"
+msgstr ""
+"\n"
+"选项:   %s\n"
-#~ msgstr "     关键字: %s\n"
+msgid "     key: %s\n"
+msgstr "     关键字: %s\n"
-#~ msgstr "  格式: %s\n"
+msgstr "  格式: %s\n"
-#~ msgstr " 默认值: %s\n"
+msgstr " 默认值: %s\n"
-#~ msgstr " 必须值: %s\n"
+msgstr " 必须值: %s\n"
-#~ msgstr " 倍数: %s\n"
+msgstr " 倍数: %s\n"
-#~ msgstr "输入选项 > "
+msgstr "输入选项 > "
-#~ msgstr "   重试?"
+msgstr "   重试?"
-#~ msgstr "对不起,%s 不能被接受。\n"
+msgstr "对不起,%s 不能被接受。\n"
-#~ msgid ""
-#~ "\n"
-#~ "  %s\n"
-#~ msgstr ""
-#~ "\n"
-#~ "您选择了:\n"
-#~ "  %s\n"
+msgid ""
+"\n"
+"  %s\n"
+msgstr ""
+"\n"
+"您选择了:\n"
+"  %s\n"
-#~ msgstr "正确吗?"
+msgstr "正确吗?"
-#~ msgstr "接受默认值"
+msgstr "接受默认值"
-#~ msgstr "取消请求"
+msgstr "取消请求"
-#~ msgstr "输入一个新的 %s 文件名"
+msgstr "输入一个新的 %s 文件名"
-#~ msgstr "输入已有 %s 文件的名称"
+msgstr "输入已有 %s 文件的名称"
-#~ msgstr "输入 %s 文件名"
+msgstr "输入 %s 文件名"
-#~ msgstr "输入'list',列出已有的 %s 文件\n"
+msgstr "输入'list',列出已有的 %s 文件\n"
-#~ msgstr "输入'list -f',得到"
+msgstr "输入'list -f',得到"
-#~ msgstr "列表%s"
+msgid "a list %s"
+msgstr "列表%s"
-#~ msgstr "扩展列表"
+msgstr "扩展列表"
-#~ msgstr "按回车%s\n"
+msgstr "按回车%s\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 未发现 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 未发现 **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s 已经存在。您确定要覆盖? "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s 已经存在。您确定要覆盖? "
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "**<%s> 非法的名称 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"**<%s> 非法的名称 **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 非法的请求 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 非法的请求 **\n"
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "** %s - 已存在,请选择其它的名称 **\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"** %s - 已存在,请选择其它的名称 **\n"
-#~ msgstr "查询:无法完成"
+msgstr "查询:无法完成"
-#~ msgstr "无法读取[%s在%s中]的头文件\n"
+msgstr "无法读取[%s在%s中]的头文件\n"
-#~ msgstr "无法打开[%s在%s中]的头文件"
+msgstr "无法打开[%s在%s中]的头文件"
 #, fuzzy
-#~ msgstr "无法获取图层信息"
+msgstr "无法获取图层信息"
 #, fuzzy
-#~ msgstr "无法打开数据库 %s"
+msgstr "无法打开数据库 %s"
-#~ msgid "Building topology ...\n"
-#~ msgstr "建立拓扑...\n"
+msgid "Building topology ...\n"
+msgstr "建立拓扑...\n"
-#~ msgid ""
-#~ "\r%d areas built      \n"
-#~ "%d isles built\n"
-#~ msgstr ""
-#~ "\r建立 %d 个区域      \n"
-#~ "建立 %d 个岛\n"
+msgid ""
+"\r%d areas built      \n"
+"%d isles built\n"
+msgstr ""
+"\r建立 %d 个区域      \n"
+"建立 %d 个岛\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot get column info"
+msgid "Cannot get column info"
+msgstr "无法获取图层信息"
 #, fuzzy
-#~ msgstr "不支持的 OGR 要素类型 %d"
+msgstr "不支持的 OGR 要素类型 %d"
 #, fuzzy
-#~ msgid "Vect_rewrite_line() for this format/level not supported"
-#~ msgstr "这种格式/级别不支持 Vect_rewrite_line()"
+msgid "Vect_rewrite_line() for this format/level not supported"
+msgstr "这种格式/级别不支持 Vect_rewrite_line()"
-#~ msgid "Vect_delete_line() for this format/level not supported"
-#~ msgstr "这种格式/级别不支持 Vect_delete_line()"
+msgid "Vect_delete_line() for this format/level not supported"
+msgstr "这种格式/级别不支持 Vect_delete_line()"
-#~ msgid "Cannot rewrite line"
-#~ msgstr "无法重写线"
+msgid "Cannot rewrite line"
+msgstr "无法重写线"
-#~ msgid "Cannot delete line"
-#~ msgstr "无法删除想线"
+msgid "Cannot delete line"
+msgstr "无法删除想线"
-#~ msgstr "输出的名称'%s'不是有效的矢量名称。"
+msgstr "输出的名称'%s'不是有效的矢量名称。"
-#~ msgstr "无法将矢量'%s'拷贝为'%s'"
+msgstr "无法将矢量'%s'拷贝为'%s'"
 #, fuzzy
-#~ msgstr "无法删除已有矢量%s"
+msgstr "无法删除已有矢量%s"
 #, fuzzy
-#~ msgstr "无法打开新的矢量%s"
+msgstr "无法打开新的矢量%s"
-#~ msgstr "无法打开矢量'%s'的历史记录"
+msgstr "无法打开矢量'%s'的历史记录"
-#~ msgstr "无法统计文件'%s'"
+msgstr "无法统计文件'%s'"
 #, fuzzy
-#~ msgstr "无法打开旧的矢量%s"
+msgstr "无法打开旧的矢量%s"
-#~ msgstr "%s - ** 非法的名称 **"
+msgstr "%s - ** 非法的名称 **"
-#~ msgstr "没有名为<%s>的图形监视器。\n"
+msgstr "没有名为<%s>的图形监视器。\n"
-#~ msgstr "请运行\"d.mon\"来选择一个有效的图形监视器。\n"
+msgstr "请运行\"d.mon\"来选择一个有效的图形监视器。\n"
-#~ msgstr "无法统计%s\n"
+msgstr "无法统计%s\n"
-#~ msgstr "错误 - 监视器<%s>正在使用。\n"
+msgstr "错误 - 监视器<%s>正在使用。\n"
-#~ msgstr "错误 - 监视器<%s>正在被%s使用。\n"
+msgstr "错误 - 监视器<%s>正在被%s使用。\n"
-#~ msgstr "错误 - 不能为监视器<%s>完全锁定进程。\n"
+msgstr "错误 - 不能为监视器<%s>完全锁定进程。\n"
-#~ msgstr "错误 - 无法建立到图形设备的管道。\n"
+msgstr "错误 - 无法建立到图形设备的管道。\n"
-#~ msgstr "错误 - 图形监视器<%s>没有运行!\n"
+msgstr "错误 - 图形监视器<%s>没有运行!\n"
-#~ msgstr "请启动图形监视器<%s>。\n"
+msgstr "请启动图形监视器<%s>。\n"
-#~ msgstr "未连接...\n"
+msgstr "未连接...\n"
-#~ msgstr "不能连接到监视器。请再试一次。\n"
+msgstr "不能连接到监视器。请再试一次。\n"
-#~ msgstr "G_dump:为G__分配了内存"
+msgstr "G_dump:为G__分配了内存"
-#~ msgid "Size of cell in fp maps = %d"
-#~ msgstr "fp maps 的象元大小= %d"
+msgid "Size of cell in fp maps = %d"
+msgstr "fp maps 的象元大小= %d"
-#~ msgid "current window = %p"
-#~ msgstr "当前窗口 = %p"
+msgid "current window = %p"
+msgstr "当前窗口 = %p"
-#~ msgid "File descriptor for automatic mask %d"
-#~ msgstr "自动掩模的文件描述符 %d"
+msgid "File descriptor for automatic mask %d"
+msgstr "自动掩模的文件描述符 %d"
-#~ msgid "Flag denoting automatic masking %d"
-#~ msgstr "自动掩模的标记 %d"
+msgid "Flag denoting automatic masking %d"
+msgstr "自动掩模的标记 %d"
-#~ msgid "CELL mask buffer %p"
-#~ msgstr "像元掩膜的缓冲区%p"
+msgid "CELL mask buffer %p"
+msgstr "像元掩膜的缓冲区%p"
-#~ msgid "buffer for reading null rows %p"
-#~ msgstr "读取空行的缓冲区 %p"
+msgid "buffer for reading null rows %p"
+msgstr "读取空行的缓冲区 %p"
-#~ msgid "Pre/post compressed data buffer %p"
-#~ msgstr "(预/后)压缩数据的缓冲区 %p"
+msgid "Pre/post compressed data buffer %p"
+msgstr "(预/后)压缩数据的缓冲区 %p"
-#~ msgid "sizeof compressed_buf %d"
-#~ msgstr "压缩数据的缓冲区大小 %d"
+msgid "sizeof compressed_buf %d"
+msgstr "压缩数据的缓冲区大小 %d"
-#~ msgid "work data buffer %p"
-#~ msgstr "工作数据的缓冲区 %p"
+msgid "work data buffer %p"
+msgstr "工作数据的缓冲区 %p"
-#~ msgid "sizeof work_buf %d"
-#~ msgstr "工作数据的缓冲区大小 %d"
+msgid "sizeof work_buf %d"
+msgstr "工作数据的缓冲区大小 %d"
-#~ msgid "sizeof null_buf %d"
-#~ msgstr "空值缓冲区大小 %d"
+msgid "sizeof null_buf %d"
+msgstr "空值缓冲区大小 %d"
-#~ msgid "sizeof mask_buf %d"
-#~ msgstr "掩模缓冲区大小 %d"
+msgid "sizeof mask_buf %d"
+msgstr "掩模缓冲区大小 %d"
-#~ msgid "Histogram request %d"
-#~ msgstr "直方图需要 %d"
+msgid "Histogram request %d"
+msgstr "直方图需要 %d"
-#~ msgid "G_dump: file #%d"
-#~ msgstr "G_dump:文件 #%d"
+msgid "G_dump: file #%d"
+msgstr "G_dump:文件 #%d"
-#~ msgid "open mode = %d"
-#~ msgstr "打开模式 = %d"
+msgid "open mode = %d"
+msgstr "打开模式 = %d"
-#~ msgstr "像元的头信息 %p"
+msgstr "像元的头信息 %p"
-#~ msgid "Table reclass %p"
-#~ msgstr "表格重分类 %p"
+msgid "Table reclass %p"
+msgstr "表格重分类 %p"
-#~ msgstr "像元的统计值 %p"
+msgstr "像元的统计值 %p"
-#~ msgid "Range structure %p"
-#~ msgstr "范围构成 %p"
+msgid "Range structure %p"
+msgstr "范围构成 %p"
-#~ msgid "float Range structure %p"
-#~ msgstr "浮点范围构成 %p"
+msgid "float Range structure %p"
+msgstr "浮点范围构成 %p"
-#~ msgid "want histogram?  %d"
-#~ msgstr "需要直方图?  %d"
+msgid "want histogram?  %d"
+msgstr "需要直方图?  %d"
-#~ msgid "Automatic reclass flag %d"
-#~ msgstr "自动重分类标记 %d"
+msgid "Automatic reclass flag %d"
+msgstr "自动重分类标记 %d"
-#~ msgid "File row addresses %p"
-#~ msgstr "文件的行的地址 %p"
+msgid "File row addresses %p"
+msgstr "文件的行的地址 %p"
-#~ msgstr "数据到窗口列的映射%p"
+msgstr "数据到窗口列的映射%p"
-#~ msgstr "数据到窗口行的常量 %f,%f"
+msgstr "数据到窗口行的常量 %f,%f"
-#~ msgid "Current data row in memory %d"
-#~ msgstr "当前内存中的数据行 %d"
+msgid "Current data row in memory %d"
+msgstr "当前内存中的数据行 %d"
-#~ msgid "Current null row in memory %d"
-#~ msgstr "当前内存中的空行 %d"
+msgid "Current null row in memory %d"
+msgstr "当前内存中的空行 %d"
-#~ msgid "nbytes per cell for current row %d"
-#~ msgstr "当前行中每个像元所占的字节数 %d"
+msgid "nbytes per cell for current row %d"
+msgstr "当前行中每个像元所占的字节数 %d"
-#~ msgstr "解压数据的缓冲区%s"
+msgstr "解压数据的缓冲区%s"
-#~ msgid "bytes per cell %d"
-#~ msgstr "每个像元所占字节数 %d"
+msgid "bytes per cell %d"
+msgstr "每个像元所占字节数 %d"
-#~ msgid "type: int, float or double map %d"
-#~ msgstr "类型:整型、浮点或双精度地图 %d"
+msgid "type: int, float or double map %d"
+msgstr "类型:整型、浮点或双精度地图 %d"
-#~ msgstr "新文件的临时名称 %s"
+msgstr "新文件的临时名称 %s"
-#~ msgstr "新的空文件的临时名称 %s"
+msgstr "新的空文件的临时名称 %s"
-#~ msgstr "打开文件的地图集 %s"
+msgstr "打开文件的地图集 %s"
-#~ msgid "io error warning given %d"
-#~ msgstr "IO错误警告 %d"
+msgid "io error warning given %d"
+msgstr "IO错误警告 %d"
-#~ msgid "xdr stream for reading fp %p"
-#~ msgstr "读取 fp 的 xdr 流 %p"
+msgid "xdr stream for reading fp %p"
+msgstr "读取 fp 的 xdr 流 %p"
-#~ msgid "data buffer for reading null rows %p"
-#~ msgstr "读取空行的数据缓冲区 %p"
+msgid "data buffer for reading null rows %p"
+msgstr "读取空行的数据缓冲区 %p"
-#~ msgid "G_dump: end"
-#~ msgstr "G_dump:结束"
+msgid "G_dump: end"
+msgstr "G_dump:结束"
 #, fuzzy
-#~ msgid "Current window not settable"
+msgid "Current window not settable"
+msgstr "当前窗口 = %p"
 #, fuzzy
-#~ msgstr "区域  << %s >>  无效"
+msgstr "区域  << %s >>  无效"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
+msgstr "当前窗口 = %p"
 #, fuzzy
-#~ msgid "Too many open raster maps"
-#~ msgstr "打开太多的栅格文件"
+msgid "Too many open raster maps"
+msgstr "打开太多的栅格文件"
-#~ msgid "Too many open files"
-#~ msgstr "打开太多文件"
+msgid "Too many open files"
+msgstr "打开太多文件"
-#~ msgid "ERROR: GISBASE not set\n"
-#~ msgstr "错误:GISBASE没有设置\n"
+msgid "ERROR: GISBASE not set\n"
+msgstr "错误:GISBASE没有设置\n"
-#~ msgid "Error reading datum shift parameters for %s from table"
-#~ msgstr "从表中读取 %s 的基准面偏移参数时发生错误"
+msgid "Error reading datum shift parameters for %s from table"
+msgstr "从表中读取 %s 的基准面偏移参数时发生错误"
-#~ msgid "Error reading ellipsoid parameters for %s from table"
-#~ msgstr "从表中读取 %s 的椭球参数时发生错误"
+msgid "Error reading ellipsoid parameters for %s from table"
+msgstr "从表中读取 %s 的椭球参数时发生错误"
-#~ msgid "No ellipsoid field %s in file %s in %s"
-#~ msgstr "没有椭球信息字段 %s 在文件%s (在%s中)"
+msgid "No ellipsoid field %s in file %s in %s"
+msgstr "没有椭球信息字段 %s 在文件%s (在%s中)"
-#~ msgid "invalid value: field %s in file %s in %s"
-#~ msgstr "无效的值:字段%s 文件%s (在%s中)"
+msgid "invalid value: field %s in file %s in %s"
+msgstr "无效的值:字段%s 文件%s (在%s中)"
-#~ msgid "No n-dims in site_list"
-#~ msgstr "在站点列表中没有 n-dims"
+msgid "No n-dims in site_list"
+msgstr "在站点列表中没有 n-dims"
-#~ msgid "No double attributes in site_list"
-#~ msgstr "在站点列表中没有双精度属性"
+msgid "No double attributes in site_list"
+msgstr "在站点列表中没有双精度属性"
-#~ msgid "No string attributes in site_list"
-#~ msgstr "在站点列表中没有字符串属性"
+msgid "No string attributes in site_list"
+msgstr "在站点列表中没有字符串属性"
-#~ msgid "String attribute index out of range"
-#~ msgstr "字符串属性索引越界"
+msgid "String attribute index out of range"
+msgstr "字符串属性索引越界"
-#~ msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
-#~ msgstr "在调用 G_readsites_xyz() 时有未知的属性类型!\n"
+msgid "Unknown attribute type in call to G_readsites_xyz()!\n"
+msgstr "在调用 G_readsites_xyz() 时有未知的属性类型!\n"
-#~ msgid "Failed to convert string attribute."
-#~ msgstr "转换字符串属性失败。"
+msgid "Failed to convert string attribute."
+msgstr "转换字符串属性失败。"
-#~ msgid "Reading sites list ...                  "
-#~ msgstr "读取站点列表 ...                  "
+msgid "Reading sites list ...                  "
+msgstr "读取站点列表 ...                  "
-#~ msgid "failed to guess format"
-#~ msgstr "无法确定格式"
+msgid "failed to guess format"
+msgstr "无法确定格式"
-#~ msgid "decimal field %i not present in sites file"
-#~ msgstr "十进制字段 %i 不在站点文件中"
+msgid "decimal field %i not present in sites file"
+msgstr "十进制字段 %i 不在站点文件中"
-#~ msgid ""
-#~ "I'm finding records that do not have a floating point attributes (fields "
-#~ "prefixed with '%')."
-#~ msgstr "这些记录没有浮点属性(字段以'%'为前缀)."
+msgid ""
+"I'm finding records that do not have a floating point attributes (fields "
+"prefixed with '%')."
+msgstr "这些记录没有浮点属性(字段以'%'为前缀)."
+#~ msgstr "无法分配内存\n"
+#, fuzzy
+#~ msgstr "<%s>在地图集<%s>中"
+#~ msgstr "无法找到[%s]在[%s]中"
Modified: grass/trunk/locale/po/grassmods_ar.po
--- grass/trunk/locale/po/grassmods_ar.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_ar.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -5760,12 +5760,12 @@
 #: ../imagery/i.vi/main.c:133
 #, fuzzy
 msgid "Name of the chan5 channel surface reflectance map"
-msgstr "اسم الملف الراسترى الجديد"
+msgstr "اسم الخريطة الناتجة"
 #: ../imagery/i.vi/main.c:140
 #, fuzzy
 msgid "Name of the chan7 channel surface reflectance map"
 #: ../imagery/i.vi/main.c:306 ../imagery/i.albedo/main.c:389
 #: ../raster/r.los/main.c:382 ../raster/r.texture/main.c:333
@@ -10045,7 +10045,7 @@
 #: ../raster/r.what/main.c:335
 #, fuzzy, c-format
 msgid "Error reading <%s>"
-msgstr "تغلب على الخريطة المخرجة"
+msgstr "%s لم يتم العثور على الخريطة الراسترية"
 #: ../raster/r.sum/main.c:46
 msgid "Sums up the raster cell values."
@@ -11847,33 +11847,22 @@
 #: ../raster/r.uslek/main.c:58
 #, fuzzy
 msgid "Name of the Soil sand fraction map [0.0-1.0]"
-msgstr ""
-"#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
-"اسم الخريطة المدخلة\n"
-"اسم الخريطة الراسترية المدخلة"
+msgstr "اسم ملف الإرتفاعات الراسترى"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:66
 #, fuzzy
 msgid "Name of the Soil silt fraction map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:70
 #, fuzzy
 msgid "Name of the Soil Organic Matter map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:74
 #, fuzzy
@@ -16945,7 +16934,7 @@
 #: ../raster/r.out.mpeg/main.c:297
 #, fuzzy, c-format
 msgid "Error reading row <%d>"
 #: ../raster/r.out.mpeg/main.c:339 ../raster/r.out.mpeg/main.c:369
 msgid "mpeg_encode ERROR"
@@ -17287,7 +17276,7 @@
 #: ../raster/r.mapcalc/main.c:148
 #, fuzzy
 msgid "parse error"
-msgstr "%d تحديث الخطا\n"
+msgstr "الملف الراسترى المدخل"
 #: ../raster/r.mapcalc/main.c:157
 msgid "Floating point error(s) occured in the calculation"
@@ -18296,7 +18285,7 @@
 #: ../raster/r.statistics2/main.c:185
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
-msgstr "%s لم يمكن فتح ملف المدى ل"
+msgstr "بدء بالقيم فى الخريطة الراسترية"
 #: ../raster/r.statistics2/main.c:249
 msgid "First pass"
@@ -25920,8 +25909,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "الخريطة الراسترية لنقاط البدء"
 #: ../vector/v.net.steiner/main.c:447
 #, fuzzy
@@ -27247,2733 +27237,2779 @@
 msgstr "لم يمكن اختيار البيانات من الجدول"
 #, fuzzy
-#~ msgid "Illegal output file name"
-#~ msgstr "اسم ااملف المخرج"
+msgid "Illegal output file name"
+msgstr "اسم ااملف المخرج"
 #, fuzzy
-#~ msgid "Display manager for GRASS"
-#~ msgstr "عدد الأعمدة"
+msgid "Display manager for GRASS"
+msgstr "عدد الأعمدة"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "MAT-File(v4) اسم الملف"
+msgid "Name of .dmrc settings file"
+msgstr "MAT-File(v4) اسم الملف"
 #, fuzzy
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "تقرير عن الراستر المدخلة والخروج"
+msgid "Width in pixels of new display monitor"
+msgstr "تقرير عن الراستر المدخلة والخروج"
 #, fuzzy
-#~ msgid "Height in pixels of new display monitor"
+msgid "Height in pixels of new display monitor"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
+msgid "Moves displayed maps to another monitor"
+msgstr "اختيار الخط الذى سيعرض به النص على الشاشة"
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
+msgid "Saves the contents of the active display monitor to a graphics file."
 #, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "اسم ملف المرشح"
+msgid "Compression for PNG files"
+msgstr "اسم ملف المرشح"
 #, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "الملف الراسترى المخرج"
+msgid "Paper size for PostScript output"
+msgstr "الملف الراسترى المخرج"
 #, fuzzy
-#~ msgid "PostScript"
+msgid "PostScript"
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "عدد مرات تكرار المرشح"
+msgid "Number of lines to appear in the legend"
+msgstr "عدد مرات تكرار المرشح"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "خطا: لم يتم عرض الخريطة\n"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "خطا: لم يتم عرض الخريطة\n"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "طباعة مجموع المساحة"
+msgid "Redraw all frames"
+msgstr "طباعة مجموع المساحة"
 #, fuzzy
-#~ msgid "Resizes active display monitor"
+msgid "Resizes active display monitor"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "اسم خريطة الراستر المخرجة"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "اسم خريطة الراستر المخرجة"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "تحويل خريطة راسترية إلى فيكتورية"
+msgid "Show vector maps rather than raster maps"
+msgstr "تحويل خريطة راسترية إلى فيكتورية"
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "<%s> عدد مستويات الألوان المستخدمة فى"
+msgid "Number of seconds to pause between slides"
+msgstr "<%s> عدد مستويات الألوان المستخدمة فى"
 #, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "الخريطة الراسترية المطلوب تسجيلها"
+msgid "Enter raster map to display in 1st frame"
+msgstr "الخريطة الراسترية المطلوب تسجيلها"
 #, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
+msgid "Enter command to execute in 1st frame"
 #, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
+msgid "Enter raster map to display in 2nd frame"
 #, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
+msgid "Enter command to execute in 2nd frame"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
+msgid "Vector map to display thematically"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
+msgid "Vector map type"
+msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
 #, fuzzy
-#~ msgid "Type of thematic display"
-#~ msgstr "اسم الخريطة الراسترية  للعرض كخلفية"
+msgid "Type of thematic display"
+msgstr "اسم الخريطة الراسترية  للعرض كخلفية"
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "اسم الجدول"
+msgid "Points"
+msgstr "اسم الجدول"
 #, fuzzy
-#~ msgid "Vector point icon for point data"
-#~ msgstr "قطع بيانات النقط العشرية"
+msgid "Vector point icon for point data"
+msgstr "قطع بيانات النقط العشرية"
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
+msgid "Number of classes for interval theme (integer)"
 #, fuzzy
-#~ msgid "Misc"
-#~ msgstr "مترى"
+msgid "Misc"
+msgstr "مترى"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "طباعة إحداثيات الإتصال الحلى و الخروج"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "شكل فاصل المخرج"
+msgid "Output separator (default: newline)"
+msgstr "شكل فاصل المخرج"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "إدخال خريطة راسترية بينرية "
+msgid "Raster to remove"
+msgstr "إدخال خريطة راسترية بينرية "
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "الملف الراسترى الطلوب إدخالة"
+msgid "Vector to remove"
+msgstr "الملف الراسترى الطلوب إدخالة"
 #, fuzzy
-#~ msgid "Region to remove"
+msgid "Region to remove"
 #, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "<%s> لم يمكن فتح"
+msgid "Label to remove"
+msgstr "<%s> لم يمكن فتح"
 #, fuzzy
-#~ msgid "3dview to remove"
+msgid "3dview to remove"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "Group to remove"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "اسم الراستر المدخل"
+msgid "raster input maps"
+msgstr "اسم الراستر المدخل"
 #, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "تغلب على الخريطة المخرجة"
+msgid "write output to PNG image"
+msgstr "تغلب على الخريطة المخرجة"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "استخدام احداثيات مركز الخريطة\n"
+msgid "label with coordinates instead of numbering"
+msgstr "استخدام احداثيات مركز الخريطة\n"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "الإحتفاظ بأعداد الشرائح بدلا من استخدام اسماء لون الشرائح"
+msgid "Keep band numbers instead of using band color names."
+msgstr "الإحتفاظ بأعداد الشرائح بدلا من استخدام اسماء لون الشرائح"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "%s:لم يتم إنشاء الجدول"
+msgid "Do not overwrite existing map"
+msgstr "%s:لم يتم إنشاء الجدول"
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "تحويل راستر جراسى الى بينرى"
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "تحويل راستر جراسى الى بينرى"
 #, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "خريطة الإرتفاعات"
+msgid "Region sensitive output"
+msgstr "خريطة الإرتفاعات"
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "الفاصل الحقلى بين بيانات المخرج"
+msgid "Output field seperator"
+msgstr "الفاصل الحقلى بين بيانات المخرج"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "حساب إحصائيات المتغير الأحادى من خلايا ذات قيمة بالخريطة الراسترية"
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "حساب إحصائيات المتغير الأحادى من خلايا ذات قيمة بالخريطة الراسترية"
 #, fuzzy
-#~ msgid "A (grid3D file)"
+msgid "A (grid3D file)"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "اسم الملف المخرج"
+msgid "Name for output grid3D volume"
+msgstr "اسم الملف المخرج"
 #, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "غير موجود <%s> الراستر"
+msgid "%s: [%s] not found"
+msgstr "غير موجود <%s> الراستر"
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "اسم الملف الراسترى الموجود"
+msgid ""
+"Enter the file name or path\n"
+msgstr "اسم الملف الراسترى الموجود"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "إختيار النقاط الطرفية تفاغليا"
+msgid "Interactively select End-Points"
+msgstr "إختيار النقاط الطرفية تفاغليا"
 #, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "نقطة %d فى حاجة لإدخال على الأقل"
+msgid "Use mouse to select Start Point\n"
+msgstr "نقطة %d فى حاجة لإدخال على الأقل"
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"أزرار:\n"
 #, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "يسار:ماذا هنا\n"
+msgid "Left:   Mark next point\n"
+msgstr "يسار:ماذا هنا\n"
 #, fuzzy
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
+msgid "elevin raster map <%s> not found"
+msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
 #, fuzzy
-#~ msgid "aspin raster map <%s> not found"
+msgid "aspin raster map <%s> not found"
 #, fuzzy
-#~ msgid "linkein raster map <%s> not found"
+msgid "linkein raster map <%s> not found"
 #, fuzzy
-#~ msgid "albedo raster map <%s> not found"
+msgid "albedo raster map <%s> not found"
 #, fuzzy
-#~ msgid "latin raster map <%s> not found"
+msgid "latin raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
+msgid "coefbh raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
+msgid "coefdh raster map <%s> not found"
 #, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "%s لم يتم العثور على الخريطة الراسترية"
+msgid "Unable to find data map"
 #, fuzzy
-#~ msgid "Unable to find clump map"
+msgid "Unable to find clump map"
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "خريطة الراستر الغطاء"
+msgid "Terrain raster map (DEM)"
+msgstr "خريطة الراستر الغطاء"
 #, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Output raster map with lake"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "بدء بالقيم فى الخريطة الراسترية"
+msgid "Cannot write lake raster map <%s>!"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "غير موجودة <%s> الخريطة الراسترية "
+msgid "Terrain raster map <%s> not found!"
+msgstr "غير موجودة <%s> الخريطة الراسترية "
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "%s لم يتم فتح قاعدة البيانات"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "%s لم يتم فتح قاعدة البيانات"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "Seed map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
-#~ "الملف الفيكتورى غير موجود %s : تحذير\n"
-#~ "غير موجودة <%s> الخريطة الراسترية \n"
+msgid "%s: base raster map not found"
+msgstr ""
+"#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
+"الملف الفيكتورى غير موجود %s : تحذير\n"
+"غير موجودة <%s> الخريطة الراسترية \n"
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
+msgid "%s: cover raster map not found"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "اسم ملف القناع"
+msgid "Name of the vector points map with x,y locations"
+msgstr "اسم ملف القناع"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "عدد نقاط الإستيفاء"
+msgid "Number of time iterations (sec.)"
+msgstr "عدد نقاط الإستيفاء"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "اسم ملف الإرتفاعات الراسترى"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Quietly"
-#~ msgstr "بهدوء"
+msgid "Quietly"
+msgstr "بهدوء"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "وسيلة الإستيفاء ثنائى الخط للخرائط الراسترية"
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "وسيلة الإستيفاء ثنائى الخط للخرائط الراسترية"
 #, fuzzy
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr "تحديد قيم الأدخال لأقطاب الشمال والجنوب لشبكات خطوط الطول والعرض"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr "تحديد قيم الأدخال لأقطاب الشمال والجنوب لشبكات خطوط الطول والعرض"
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
+msgid "Illegal output file name <%s>"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "الخرائط الراسترية المدخلة"
+msgid "Raster input maps(s)"
+msgstr "الخرائط الراسترية المدخلة"
 #, fuzzy
-#~ msgid "Output file name"
+msgid "Output file name"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s لم يمكن فتح ملف المدى ل"
+msgid "%s: can't read fp range for [%s]"
+msgstr "%s لم يمكن فتح ملف المدى ل"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "الخريطة الراسترية المطلوب الضبط عليها"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "الخريطة الراسترية المطلوب الضبط عليها"
 #, fuzzy
-#~ msgid "Path to rules file"
-#~ msgstr "اسم الخريطة الراسترية الموجودة"
+msgid "Path to rules file"
+msgstr "اسم الخريطة الراسترية الموجودة"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
+msgid "RGB raster map <%s> not found"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "لم توجد<%s>الخريطة الفيكتورية"
+msgid "Vector cell map <%s> not found"
+msgstr "لم توجد<%s>الخريطة الفيكتورية"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]!"
+msgid "Cannot open raster map [%s]!"
 #, fuzzy
-#~ msgid "Raster file [%s] is empty."
+msgid "Raster file [%s] is empty."
 #, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "[%s]لم يتم فتح ملف الخلية ل "
+msgid "Unable to write header for [%s]."
+msgstr "[%s]لم يتم فتح ملف الخلية ل "
 #, fuzzy
-#~ msgid "        Number of rows"
-#~ msgstr "عدد الصفوف"
+msgid "        Number of rows"
+msgstr "عدد الصفوف"
 #, fuzzy
-#~ msgid "        Number of cols"
+msgid "        Number of cols"
 #, fuzzy
-#~ msgid "        Floating point map"
-#~ msgstr "تقريب بيانات النقط العشرية"
+msgid "        Floating point map"
+msgstr "تقريب بيانات النقط العشرية"
 #, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
+msgid "Raster file [%s] not found. Exiting."
 #, fuzzy
-#~ msgid "History file for [%s] updated."
-#~ msgstr "الملف الراستري للسطح"
+msgid "History file for [%s] updated."
+msgstr "الملف الراستري للسطح"
 #, fuzzy
-#~ msgid "Edit the history file for [%s]? "
+msgid "Edit the history file for [%s]? "
 #, fuzzy
-#~ msgid "%s map <%s> not found"
+msgid "%s map <%s> not found"
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
+msgid "Category file for <%s> not updated"
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
+msgid "Category file for <%s> updated"
-#~ msgid "Title, in quotes"
-#~ msgstr "وصف مبسط"
+msgid "Title, in quotes"
+msgstr "وصف مبسط"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "تخطى رسائل خطأ التقاطع الفردى"
+msgid "Suppress single crossing error messages"
+msgstr "تخطى رسائل خطأ التقاطع الفردى"
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
+msgid "Unable to find starting vector <%s> "
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
+msgid "Unable to find stop vector <%s>"
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
+msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "تطبيق المرشح على القيم الصفرية فقط"
+msgid "Apply filter only to zero data values"
+msgstr "تطبيق المرشح على القيم الصفرية فقط"
-#~ msgid "Run verbosly"
-#~ msgstr "تنفيذ بإسهاب"
+msgid "Run verbosly"
+msgstr "تنفيذ بإسهاب"
-#~ msgid "Run VERBOSELY"
+msgid "Run VERBOSELY"
 #, fuzzy
-#~ msgid "Cell file not found"
+msgid "Cell file not found"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
+msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "وحدات المسافة"
+msgid "Threshold distance"
+msgstr "وحدات المسافة"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
+msgid "Cannot execute: %s"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "%s:لم يتم الحشر بالجدول"
+msgid "Cannot link table: %s"
+msgstr "%s:لم يتم الحشر بالجدول"
 #, fuzzy
-#~ msgid "DXF input file"
-#~ msgstr "ملف المدخل"
+msgid "DXF input file"
+msgstr "ملف المدخل"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "dig_cats لم يتم فتح ملف"
+msgid "Cannot open new vector map <%s>"
+msgstr "dig_cats لم يتم فتح ملف"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
+msgid "Conversion of <%s> to vector map:"
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
 #, fuzzy
-#~ msgid "Create 3D file"
-#~ msgstr "الملف الراسترى المدخل"
+msgid "Create 3D file"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
+msgid "Network input map <%s> not found"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr " أحداثيات ( ): الخروج\n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr " أحداثيات ( ): الخروج\n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "%d: عدد النقاط التى أدخلت\n"
+msgid " Number of points that have been entered: %d\n"
+msgstr "%d: عدد النقاط التى أدخلت\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "من فضلك أجب بنعم أم لا"
+msgid "Please answer yes or no"
+msgstr "من فضلك أجب بنعم أم لا"
 #, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "%f : ارتفاع الخط\n"
+msgid "Line: %d\n"
+msgstr "%f : ارتفاع الخط\n"
 #, fuzzy
-#~ msgid "output raster map"
+msgid "output raster map"
 #, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "اسم الخريطة الراسترية المدخلة"
+msgid "Name of input raster map(s)"
+msgstr "اسم الخريطة الراسترية المدخلة"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Illegal file name for real part: %s"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "<%s> فى <%s>لم يمكن قراءة الملف للمنظر ثلاثى الأبعاد"
+msgid "** Can't read signature file <%s> **"
+msgstr "<%s> فى <%s>لم يمكن قراءة الملف للمنظر ثلاثى الأبعاد"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "!تم تحديد إحداثى شمال فارغ"
+msgid "Illegal group name <%s>"
+msgstr "!تم تحديد إحداثى شمال فارغ"
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
+msgid "Illegal signature file name <%s>"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "الملفات الراسترية المطلوب رؤيتها%d"
+msgid "Raster file(s) for Elevation"
+msgstr "الملفات الراسترية المطلوب رؤيتها%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgstr "لم يتم انشاء الدليل"
+msgstr "لم يتم انشاء الدليل"
 #, fuzzy
 #, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "ضبط من المنطقة الحالية"
+msgid "No current frame"
+msgstr "ضبط من المنطقة الحالية"
 #, fuzzy
-#~ msgid "Error reading raster map"
+msgid "Error reading raster map"
 #, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "اسم ملف انحناء التضاريس"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "اسم ملف انحناء التضاريس"
 #, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " وسط: سماح بألوان سريعة\n"
+msgid " Middle: toggle flash color\n"
+msgstr " وسط: سماح بألوان سريعة\n"
 #, fuzzy
-#~ msgid "Getting graphics window coordinates"
+msgid "Getting graphics window coordinates"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "اسم الخريطة الراسترية الجديدة"
+msgid "Font name or pathname of TTF file"
+msgstr "اسم الخريطة الراسترية الجديدة"
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "ضبط تحرير نوع حر\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+"ضبط تحرير نوع حر\n"
 #, fuzzy
-#~ msgid "Display number of colors"
+msgid "Display number of colors"
 #, fuzzy
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "اسم الخريطة الراسترية"
+msgid "Name of frame(s) to save"
+msgstr "اسم الخريطة الراسترية"
 #, fuzzy
-#~ msgid "Save current frame"
+msgid "Save current frame"
 #, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "%c :نوع غير معروف"
+msgid "Unknown item type in pad: %s"
+msgstr "%c :نوع غير معروف"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "استخدام خط ذو نوع حقيقى بما في ذلك اسم الملف "
+msgid "Path to TrueType font (including file name)"
+msgstr "استخدام خط ذو نوع حقيقى بما في ذلك اسم الملف "
 #, fuzzy
-#~ msgid "Invalid font: %s"
-#~ msgstr "%s:منطقة غير صالحة"
+msgid "Invalid font: %s"
+msgstr "%s:منطقة غير صالحة"
 #, fuzzy
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "القيمة التى تعنى قيمة منعدمة"
+msgid "Unable to write the temporary file"
+msgstr "القيمة التى تعنى قيمة منعدمة"
 #, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "اسم ملف درجات الألوان المحددة مسبقا"
+msgid "No predefined font"
+msgstr "اسم ملف درجات الألوان المحددة مسبقا"
 #, fuzzy
-#~ msgid " Left:    Place text here\n"
+msgid " Left:    Place text here\n"
 #, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr " يمين: خروج\n"
+msgid " Right:   Quit\n"
+msgstr " يمين: خروج\n"
 #, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "\"list\" items خطا: لم يمكن الحصول على \n"
+msgid "ERROR: can not get \"list\" items"
+msgstr "\"list\" items خطا: لم يمكن الحصول على \n"
 #, fuzzy
-#~ msgid "-j flag forced"
-#~ msgstr "-j إجبار على استخدام\n"
+msgid "-j flag forced"
+msgstr "-j إجبار على استخدام\n"
 #, fuzzy
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Interactively select route"
+msgid "Interactively select route"
 #, fuzzy
-#~ msgid "You must select at least four points"
+msgid "You must select at least four points"
 #, fuzzy
-#~ msgid "No raster or vector map displayed"
+msgid "No raster or vector map displayed"
 #, fuzzy
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "لم يتم اختيار شاشة العرض"
+msgid "Name of graphics monitor to select"
+msgstr "لم يتم اختيار شاشة العرض"
 #, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "عرض قائمة مستويات الكنتور"
+msgid "List all monitors"
+msgstr "عرض قائمة مستويات الكنتور"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
+msgid "Error - Locking mechanism failed"
+msgstr "خطا فى محاولة قراءة ملف قاعدة البيانات dbmscap\n"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "تسجيل الخرائط الراسترية "
+msgid "Error choosing frame [%s]\n"
+msgstr "تسجيل الخرائط الراسترية "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"أزرار:\n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
+msgid "Left:   Select frame\n"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
+msgid "Right:  Accept frame\n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
+msgid "Manages display frames on the user's graphics monitor."
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "اختر البيانات من قاعدة البيانات"
+msgid "Select a frame"
+msgstr "اختر البيانات من قاعدة البيانات"
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
 #, fuzzy
-#~ msgid "Print names of all frames"
+msgid "Print names of all frames"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Debugging output"
-#~ msgstr "درجة وضوح الخريطة المخرجة"
+msgid "Debugging output"
+msgstr "درجة وضوح الخريطة المخرجة"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
+msgid "Frame to be created/selected"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "أزرار:\n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"\n"
+"أزرار:\n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
+msgid "Left:   Select From\n"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "الشاشة: أمر تفاعلى يتم إعادة رسمه\n"
+msgid "Monitor: interactive command in redraw"
+msgstr "الشاشة: أمر تفاعلى يتم إعادة رسمه\n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "وجد %d مرئيات من نوع لون حقيقى\n"
+msgid "found %d visuals of type TrueColor"
+msgstr "وجد %d مرئيات من نوع لون حقيقى\n"
 #, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "البحث عن اعلى عمق بت\n"
+msgid "searching for highest bit depth"
+msgstr "البحث عن اعلى عمق بت\n"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "قد تم اختياره %d عمق البت\n"
+msgid "selected %d bit depth"
+msgstr "قد تم اختياره %d عمق البت\n"
 #, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "استخدم كمرئى اساس %s\n"
+msgid "using default visual which is %s"
+msgstr "استخدم كمرئى اساس %s\n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "الشاشة: ويتبد: متوقع %d ولكن تم الحصول على %d\n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "الشاشة: ويتبد: متوقع %d ولكن تم الحصول على %d\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "الشاشة: XGetWMName فشل\n"
+msgid "Monitor: XGetWMName failed"
+msgstr "الشاشة: XGetWMName فشل\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "الشاشة: XGetWMName: نتيجة سيئة\n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "الشاشة: XGetWMName: نتيجة سيئة\n"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
+msgid "Raster map to zoom into"
 #, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "لاتضبط المنطقة الحالية على ابعاد خريطة الارتفاعات"
+msgid "Save the current region to region definition file"
+msgstr "لاتضبط المنطقة الحالية على ابعاد خريطة الارتفاعات"
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
+msgid "<%s> is an illegal region name"
 #, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "الخريطة الفيكتورية لنقاط البدء"
+msgid "Erasing monitors ..."
+msgstr "الخريطة الفيكتورية لنقاط البدء"
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not open input file <%s>."
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Unable to open file: <%s>"
 #, fuzzy
-#~ msgid "not found\n"
+msgid "not found\n"
 #, fuzzy
-#~ msgid "Raster map not found."
+msgid "Raster map not found."
 #, fuzzy
-#~ msgid "%s: can't read range for [%s]"
+msgid "%s: can't read range for [%s]"
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
 #, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "لم يتم حساب شبه مركز المساحة"
+msgid "\rDuplicate area centroids: %5d"
+msgstr "لم يتم حساب شبه مركز المساحة"
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
+msgid "Unable to get category list <%s>, editing terminated"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "نوع غير معروف"
+msgid "Unknown query tool '%s'"
+msgstr "نوع غير معروف"
 #, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "موقع قاعدة البيانات"
+msgid "No layer database connection"
+msgstr "موقع قاعدة البيانات"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d فئات محملة من الجدول\n"
+msgid "%d categories loaded from the database"
+msgstr "%d فئات محملة من الجدول\n"
 #, fuzzy
-#~ msgid "Done"
-#~ msgstr "انتهى\n"
+msgid "Done"
+msgstr "انتهى\n"
 #, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
+msgid "Cannot open OGR data source '%s'"
 #, fuzzy
-#~ msgid "Cannot create layer"
+msgid "Cannot create layer"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "نوع العمود غير مدعم"
+msgid "Column type [%d] not supported"
+msgstr "نوع العمود غير مدعم"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr " <%s> فى <%s>لم يمكن قراءة العنوان الرئيسى ل"
+msgid "Cannot read map header for <%s>"
+msgstr " <%s> فى <%s>لم يمكن قراءة العنوان الرئيسى ل"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
+msgid "Cannot read category file for <%s>"
 #, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "طباعة عدات الخلية"
+msgid "Print;Shell Script"
+msgstr "طباعة عدات الخلية"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
+msgid "%s: <%s> raster map not found"
+msgstr ""
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 #, fuzzy
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
-#~ msgstr "%s لم يمكن فتح "
+msgid "%s: Cannot open [%s]"
+msgstr "%s لم يمكن فتح "
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "اسم خريطة الإرتفاعات"
+msgid "Raster map containing elevation data"
+msgstr "اسم خريطة الإرتفاعات"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "اسم الخريطة الناتجة"
+msgid "Raster map name for storing results"
-#~ msgid "Height of the viewing location"
-#~ msgstr "ارتفاع مكان الرؤية"
+msgid "Height of the viewing location"
+msgstr "ارتفاع مكان الرؤية"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
-#~ msgid "raster map <%s> not found"
+msgid "raster map <%s> not found"
-#~ msgid "can't read header for <%s> in <%s>"
+msgid "can't read header for <%s> in <%s>"
-#~ msgid "region <%s> not found"
-#~ msgstr "غير موجودة <%s> المنطقة"
+msgid "region <%s> not found"
+msgstr "غير موجودة <%s> المنطقة"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "<%s> فى <%s> لم يمكن قراءة المنطقة"
+msgid "can't read region <%s> in <%s>"
+msgstr "<%s> فى <%s> لم يمكن قراءة المنطقة"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "<%s> فى <%s>لم يمكن فتح الملف للمنظر ثلاثى الأبعاد"
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "<%s> فى <%s>لم يمكن فتح الملف للمنظر ثلاثى الأبعاد"
-#~ msgid "can't read 3dview file <%s> in <%s>"
+msgid "can't read 3dview file <%s> in <%s>"
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
+msgid "can't open vector map <%s> in <%s>"
+msgstr "<%s>فى<%s>لم يمكن فتح الملف الفيكتورى"
-#~ msgid "invalid region: %s"
+msgid "invalid region: %s"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
-#~ msgid "can't open %s"
+msgid "can't open %s"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
+msgid "elevation file [%s] not found"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "لم يمكن وصف الجدول"
+msgid "Cannot describe table <%s>"
+msgstr "لم يمكن وصف الجدول"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
+msgid "%s given an illegal number of points [%d]"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
+msgid "Unable to open database %s by driver %s"
+msgstr "%s بالمشغل %s لم يمكن فتح قاعدة البيانات"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "db.connect أضبط مستخدما<%s>لم يتم تعريف أوضاع الإتصال بقاعدة البيانات"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "db.connect أضبط مستخدما<%s>لم يتم تعريف أوضاع الإتصال بقاعدة البيانات"
 #, fuzzy
-#~ msgid "Could not find input %s"
-#~ msgstr "المدخل لم يوجد %s\n"
+msgid "Could not find input %s"
+msgstr "المدخل لم يوجد %s\n"
 #, fuzzy
-#~ msgid "Could not open input"
+msgid "Could not open input"
 #, fuzzy
-#~ msgid "Could not open output"
+msgid "Could not open output"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
 #, fuzzy
-#~ msgid "Unkown item type in pad: %s"
+msgid "Unkown item type in pad: %s"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "لم يعرف الأتصال بقاعدة البيانات\n"
+msgid "Database connection not defined\n"
+msgstr "لم يعرف الأتصال بقاعدة البيانات\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
 #, fuzzy
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s:خط %d:%s\n"
+msgid "%s in %s: %s"
+msgstr "%s:خط %d:%s\n"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Can't write region <%s>"
 #, fuzzy
-#~ msgid "No graphics device selected."
+msgid "No graphics device selected."
 #, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Unable to read raster row."
 #, fuzzy
-#~ msgid "Training map [%s] not found."
+msgid "Training map [%s] not found."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
-#~ msgid "input raster map"
-#~ msgstr "ادخل خريطة الراستر"
+msgid "input raster map"
+msgstr "ادخل خريطة الراستر"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "Illegal file name: %s"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "[%s]لم يتم فتح ملف الخلية ل \n"
-#~ "%s لم يتم فتح قاعدة البيانات"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr ""
+"[%s]لم يتم فتح ملف الخلية ل \n"
+"%s لم يتم فتح قاعدة البيانات"
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "قيم الغطاء المستنبطة من عناوين الفئات للخريطة الغطاء"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "قيم الغطاء المستنبطة من عناوين الفئات للخريطة الغطاء"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
+msgid "%s: %s - raster map not found"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "dig قراءة ملف...\n"
+msgid "Reading input map (%s)    ... "
+msgstr "dig قراءة ملف...\n"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
 #, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "%-5d dig_att قراءة ملف...\n"
+msgid "Reading raster map... "
+msgstr "%-5d dig_att قراءة ملف...\n"
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "كتابة ملف جديد...\n"
+msgid "Writing raster map... "
+msgstr "كتابة ملف جديد...\n"
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "قائمة الفئات"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "قائمة الفئات"
-#~ msgid "Output separator character (default: tab)"
+msgid "Output separator character (default: tab)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot find file %s"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Cannot create vector map %s"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "عدد الصفوف التى تحفظ فى الذاكرة"
+msgid "Number of raster rows to hold in memory"
+msgstr "عدد الصفوف التى تحفظ فى الذاكرة"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "طباعة نوع الملف الراسترى فقط"
+msgid "Print raster map title only"
+msgstr "طباعة نوع الملف الراسترى فقط"
 #, fuzzy
-#~ msgid "unknown type: %d"
+msgid "unknown type: %d"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
+msgid "Cannot open raster map [%s]"
+msgstr ""
 #, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "الخريطة الراسترية الغطاء"
+msgid "Cannot get raster band."
+msgstr "الخريطة الراسترية الغطاء"
 #, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
+msgid "Cannot allocate buffer for reading null values."
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Cannot read GRASS raster."
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
 #, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "اسم الخريطة المخرجة"
+msgid "Cannot open output map."
+msgstr "اسم الخريطة المخرجة"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
+msgid "memory allocation failure"
 #, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "لم يستطع عرض قواعد البيانات"
+msgid "Can't find data map."
+msgstr "لم يستطع عرض قواعد البيانات"
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "اسم ملف الإنحناء المماسى"
+msgid "Output terrain only vector map name"
+msgstr "اسم خريطة اتجاه الإنحدار"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
 #, fuzzy
-#~ msgid "No record for cat = %d"
-#~ msgstr "cat = %d لا يوجد تسجيل للخط"
+msgid "No record for cat = %d"
+msgstr "cat = %d لا يوجد تسجيل للخط"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "وصل الفئات...\n"
+msgid "Attaching islands ..."
+msgstr "وصل الفئات...\n"
 #, fuzzy
-#~ msgid "Cannot calculate area centroid."
+msgid "Cannot calculate area centroid."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
+msgid "Vector map <%s> not found in current mapset"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
+msgid "Error allocating memory for `lines_visited'"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
+msgid "The number of lines in the input vector map is [%d]"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "لم يتم الإتصال بقاعدة البيانات\n"
+msgid "Database connection not defined for layer <%d>"
+msgstr "لم يتم الإتصال بقاعدة البيانات\n"
 #, fuzzy
-#~ msgid "Cannot open select cursor"
-#~ msgstr "لم يتم فتح إختيار المؤشر"
+msgid "Cannot open select cursor"
+msgstr "لم يتم فتح إختيار المؤشر"
 #, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "لم بمكن قراءة معلومات الحقل"
+msgid "Cannot get layer info"
+msgstr "لم بمكن قراءة معلومات الحقل"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
+msgid "Cannot rewrite line %d"
 #, fuzzy
-#~ msgid "Editing tool"
+msgid "Editing tool"
 #, fuzzy
-#~ msgid "Snap also to vertex (not implemented yet)"
+msgid "Snap also to vertex (not implemented yet)"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d تم تخطى الخطوط الميتة\n"
+msgid "%d lines modified"
+msgstr "%-5d تم تخطى الخطوط الميتة\n"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
 #, fuzzy
-#~ msgid "Print vector map region only"
+msgid "Print vector map region only"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot get layer info for vector map <%s>"
 #, fuzzy
-#~ msgid "Cannot select attribute."
-#~ msgstr "لم يمكن اختيار البيانات من الجدول"
+msgid "Cannot select attribute."
+msgstr "لم يمكن اختيار البيانات من الجدول"
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Could not find vector map <%s> in current mapset"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 #, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d نقطة كتبت للمخرج\n"
+msgid "[%d] features written"
+msgstr "%d نقطة كتبت للمخرج\n"
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
+msgid "Parameter <%s> not set"
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "خريطة مخرجة حيث ستكتب النقاط"
+msgid "Output map where segments will be written"
+msgstr "خريطة مخرجة حيث ستكتب النقاط"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
+msgid "Database record for cat %d not found"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
-#~ msgid "driver name"
-#~ msgstr "اسم المشغل"
+msgid "driver name"
+msgstr "اسم المشغل"
-#~ msgid "database name"
-#~ msgstr "اسم قاعدة البيانات"
+msgid "database name"
+msgstr "اسم قاعدة البيانات"
 #, fuzzy
-#~ msgid "Driver name"
+msgid "Driver name"
-#~ msgid "Cannot list databases."
+msgid "Cannot list databases."
-#~ msgid "database location"
+msgid "database location"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "اسم الجدول, اختر الكل من هذا الجدول"
+msgid "Table name, select all from this table"
+msgstr "اسم الجدول, اختر الكل من هذا الجدول"
-#~ msgid "output field separator"
-#~ msgstr "الفاصل الحقلي للمخرج"
+msgid "output field separator"
+msgstr "الفاصل الحقلي للمخرج"
-#~ msgid "output vertical record separator"
-#~ msgstr "فاصل التسجيل الراسى للمخرج "
+msgid "output vertical record separator"
+msgstr "فاصل التسجيل الراسى للمخرج "
-#~ msgid "null value indicator"
-#~ msgstr "مؤشر القيمة المنعدمة"
+msgid "null value indicator"
+msgstr "مؤشر القيمة المنعدمة"
-#~ msgid "do not include column names in output"
-#~ msgstr "لاتشمل اسماء الأعمدة في المخرج"
+msgid "do not include column names in output"
+msgstr "لاتشمل اسماء الأعمدة في المخرج"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "(مخرج راسي (بدلا من الافقي"
+msgid "vertical output (instead of horizontal)"
+msgstr "(مخرج راسي (بدلا من الافقي"
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr ""
-#~ "اسم الملف الراسترى الموجود\n"
-#~ "اسم الخريطة الراسترية الموجودة"
+msgid "Name of existing raster map"
+msgstr ""
+"اسم الملف الراسترى الموجود\n"
+"اسم الخريطة الراسترية الموجودة"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "لم يمكن حشر صف جديد: %s"
+msgid "Cannot find mapset for %s"
+msgstr "لم يمكن حشر صف جديد: %s"
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Table to be imported"
+msgid "Table to be imported"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "اسم الخريطة الراسترية الناتجة"
+msgid "Unable to create raster map [%s]"
+msgstr "اسم الخريطة الراسترية الناتجة"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "الفيكتور المخرج  غير موجود"
+msgid "Input file [%s] not found."
+msgstr "الفيكتور المخرج  غير موجود"
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "المضروب فيه للبيانات الأسكية"
+msgid "Multiplier for ascii data"
+msgstr "المضروب فيه للبيانات الأسكية"
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "unable to create raster"
+msgid "unable to create raster"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "اسم السطح العشوائى المطلوب إنتاجه"
+msgid "Name of the random surface to be produced"
+msgstr "اسم السطح العشوائى المطلوب إنتاجه"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr ""
-#~ "db.connect إتصل مستخدما<%s>لم يتم تعريف مشغل الإتصال بقاعدة البيانات"
+msgid "No db connection for driver <%s> defined. Run db.connect."
+msgstr "db.connect إتصل مستخدما<%s>لم يتم تعريف مشغل الإتصال بقاعدة البيانات"
 #, fuzzy
-#~ msgid "Table name"
+msgid "Table name"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
+msgid "Cannot fetch data from table"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Querying input '%s' ... "
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "إنشاء نقاط على الخط المدخل"
+msgid "Copying %s input lines ... "
+msgstr "إنشاء نقاط على الخط المدخل"
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 #, fuzzy
-#~ msgid "no record for cat = %d"
+msgid "no record for cat = %d"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
+msgid "Cannot find line of cat %d"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
+msgid "Transforms a vector map via a set of tie points."
 #, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "إحداثيات الشرق والشمال لنقطة البدء"
+msgid "Read coordinates from standard input"
+msgstr "إحداثيات الشرق والشمال لنقطة البدء"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "'%s'لم يمكن بدء المشغل"
+msgid "Cannot start driver '%s'."
+msgstr "'%s'لم يمكن بدء المشغل"
-#~ msgid "Cannot describe table"
+msgid "Cannot describe table"
 #, fuzzy
-#~ msgid "Cannot start driver <%s>."
+msgid "Cannot start driver <%s>."
 #, fuzzy
-#~ msgid "Cannot write to <%s>"
+msgid "Cannot write to <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "اسم الخريطة الراسترية المخرجة"
+msgid "Unable to open raster map [%s]"
+msgstr "اسم الخريطة الراسترية المخرجة"
 #, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Cannot open driver %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
 #, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
+msgid "%s: %s - Unable to open the input raster map\n"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
 #, fuzzy
-#~ msgid "Cannot find %s"
+msgid "Cannot find %s"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Open raster map %s in %s = %d"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
-#~ msgid "Name of the new raster map"
-#~ msgstr "اسم الملف الراسترى الجديد"
+msgid "Name of the new raster map"
+msgstr "اسم الملف الراسترى الجديد"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
+msgid "can't open raster map <%s> in mapset %s"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr "PPM تحويل راستر جراسى الى صورة "
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr "PPM تحويل راستر جراسى الى صورة "
-#~ msgid "Raster input map"
+msgid "Raster input map"
-#~ msgid "Mapset of input map"
-#~ msgstr "اسم مجموعة الخرائط للخريطة المدخلة"
+msgid "Mapset of input map"
+msgstr "اسم مجموعة الخرائط للخريطة المدخلة"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "خريطة الراستر االناتجة"
+msgid "Checking location %s, mapset %s:"
+msgstr "خريطة الراستر االناتجة"
 #, fuzzy
-#~ msgid "Error writing output map"
+msgid "Error writing output map"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "لم تحدد خرائط مدخلة"
+msgid "no rules specified"
+msgstr "لم تحدد خرائط مدخلة"
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Can't open temp file [%s]"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "اسماء الملفات الراسترية الموجودة"
+msgid "Names of existing raster maps"
+msgstr "اسماء الملفات الراسترية الموجودة"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "%s in %s -can't open raster map"
 #, fuzzy
-#~ msgid "%s: can't create %s"
+msgid "%s: can't create %s"
 #, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "معايرة"
+msgid "Normalized"
+msgstr "معايرة"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Could not open elevation map"
+msgid "Could not open elevation map"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "unable to close output map"
+msgid "unable to close output map"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "Database's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgstr ""
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Could not find input map <%s> in current mapset."
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
+msgid "Could not find input vector map %s"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
+msgid "error opening raster map [%s]."
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "Patching file <%s@%s>"
 #, fuzzy
-#~ msgid "[%d] files patched"
+msgid "[%d] files patched"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
+msgid "Could not open vector map <%s>"
-#~ msgid "Name of output raster map"
+msgid "Name of output raster map"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
+msgid "name for new raster map"
 #, fuzzy
-#~ msgid "Output GRASS image file"
-#~ msgstr "اسم ملف الإنحدار المخرج"
+msgid "Output GRASS image file"
+msgstr "اسم ملف الإنحدار المخرج"
 #, fuzzy
-#~ msgid "Resulting output map"
+msgid "Resulting output map"
 #, fuzzy
-#~ msgid "name for new vector map"
+msgid "name for new vector map"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
+msgid "name for new vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "الخريطة الفيكتورية لنقاط الإنتهاء"
+msgid "Input vector map"
+msgstr "الخريطة الفيكتورية لنقاط الإنتهاء"
-#~ msgid "vector map <%s> not found"
+msgid "vector map <%s> not found"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
+msgid "<%s> raster map not found"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
-#~ msgstr ""
-#~ "خريطة الراستر الغطاء\n"
-#~ "%s لم يمكن فتح ملف المدى ل"
+msgid "%s - can't open raster map"
+msgstr ""
+"خريطة الراستر الغطاء\n"
+"%s لم يمكن فتح ملف المدى ل"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr " 2-%d اسماء الخرائط المدخلة"
+msgid "Can't get row %d from raster map %s"
+msgstr " 2-%d اسماء الخرائط المدخلة"
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
-#~ msgstr "الرمز الممثل لقيم خلية بدون بيانات"
+msgid "string representing no data cell value"
+msgstr "الرمز الممثل لقيم خلية بدون بيانات"
-#~ msgid "File name of classification result"
-#~ msgstr "اسم ملف ناتج التصنيف"
+msgid "File name of classification result"
+msgstr "اسم ملف ناتج التصنيف"
-#~ msgid "File name of reference classes"
-#~ msgstr "اسم ملف الأصناف المرجعية"
+msgid "File name of reference classes"
+msgstr "اسم ملف الأصناف المرجعية"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "تقرير مفصل من 132 عمود والأساس 80"
+msgid "wide report, 132 columns (default: 80)"
+msgstr "تقرير مفصل من 132 عمود والأساس 80"
-#~ msgid "quiet"
-#~ msgstr "خروج"
+msgid "quiet"
+msgstr "خروج"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "<%s> - illegal output file name"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
-#~ msgid "Base raster map"
-#~ msgstr "الخريطة الراسترية الأساس"
+msgid "Base raster map"
+msgstr "الخريطة الراسترية الأساس"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "dig عطل فى فتح ملف المدخل"
+msgid "Problem opening input file [%s]"
+msgstr "dig عطل فى فتح ملف المدخل"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
+msgid "Elevation map"
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "خريطة الدليل الطبوغرافى"
+msgid "Topographic index ln(a/tanB) map"
+msgstr "خريطة الدليل الطبوغرافى"
 #, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "إخراج بتفصيل"
+msgid "Output verbosely"
+msgstr "إخراج بتفصيل"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
+msgstr "%s لم يتم العثور على الخريطة الراسترية"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Input vector map <%s> not found."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
 #, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "عرض الهيئات المدعمة والخروج"
+msgid "List available formats and exit"
+msgstr "عرض الهيئات المدعمة والخروج"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
+msgid "SVG output file"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "Could not find vector '%s'"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
-#~ msgid "Raster output file"
+msgid "Raster output file"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "بقاء جدول الألوان الحالى "
+msgid "Keep existing color table"
+msgstr "بقاء جدول الألوان الحالى "
-#~ msgid "List rules"
-#~ msgstr "عرض درجات الألوان"
+msgid "List rules"
+msgstr "عرض درجات الألوان"
 #, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "تنفيذ باسهاب"
+msgid "Verbose mode."
+msgstr "تنفيذ باسهاب"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d راستر%s, %d فيكتور%s\n"
+msgid " %d rows, %d cols."
+msgstr "%d راستر%s, %d فيكتور%s\n"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
-#~ msgstr "لم يتم تحديث الحدود"
+msgid "%s - unable to create category file"
+msgstr "لم يتم تحديث الحدود"
 #, fuzzy
-#~ msgid "verbose mode"
+msgid "verbose mode"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "عدم انشاء جدول الخواص"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "عدم انشاء جدول الخواص"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
+msgid "Layer of the vector for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
+msgid "Name of existing raster map to be displayed"
-#~ msgid "driver name:"
-#~ msgstr ":اسم المشغل"
+msgid "driver name:"
+msgstr ":اسم المشغل"
-#~ msgid "Database name:"
-#~ msgstr ":اسم قاعدة البيانات"
+msgid "Database name:"
+msgstr ":اسم قاعدة البيانات"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
+msgid "column type not supported"
 #, fuzzy
-#~ msgid "cannot select data from table"
+msgid "cannot select data from table"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "%s لم يتم منح الإمتياز على الجدول"
+msgid "cannot grant privileges on table %s"
+msgstr "%s لم يتم منح الإمتياز على الجدول"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
+msgid "Cannot find vector map"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
 #, fuzzy
-#~ msgid "#%s"
-#~ msgstr "%s"
+msgid "#%s"
+msgstr "%s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
+msgid "Error while writing new cell map."
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
+msgid "Error in opening input file <%s>"
+msgstr "<%s>لم يتم العثور على الخريطة المدخلة\n"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "Unable to open cell man <%s> for input.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "Unable to read map raster row %d"
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
+msgid "Unable to write color table to raster [%s]"
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
+msgid "Name of predefined rules file"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "**[خارج النطاق  [0..255:R:G:B : %d:%d:%d : تحذير**\n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "**[خارج النطاق  [0..255:R:G:B : %d:%d:%d : تحذير**\n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr "**[خارج النطاق  [0..255:R:G:B ك: %d:%d:%d : تحذير**\n"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr "**[خارج النطاق  [0..255:R:G:B ك: %d:%d:%d : تحذير**\n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** تحذير  : هذه القيم غير موجودة **\n"
+msgid "no such value"
+msgstr "** تحذير  : هذه القيم غير موجودة **\n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
+msgid "%s:line %d:%s"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** لون غير مناسب **\n"
+msgid "bad color specification"
+msgstr "** لون غير مناسب **\n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - لون غير معروف\n"
+msgid "%s - unknown color"
+msgstr "%s - لون غير معروف\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "الألوان المتاحة هى:\n"
+msgid "Valid colors are:\n"
+msgstr "الألوان المتاحة هى:\n"
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
-#~ msgstr "<%s> لم يمكن فتح"
+msgid "Unable to find cover map <%s>"
+msgstr "<%s> لم يمكن فتح"
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
+msgid "%s: reading category file for %s"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "%s: unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
 #, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid "Unable to find [%s]."
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Could not open raster <%s>"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "أو خط ذو نوع حقيقى بما فيه اسم الملف -l اسم الخط عير مدعم تفاعليا استخدم "
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"أو خط ذو نوع حقيقى بما فيه اسم الملف -l اسم الخط عير مدعم تفاعليا استخدم "
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+msgid "%s: o_open_file: raster map %s not found"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "No record for category for [%d]"
 #, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr " خط أم مساحة"
+msgid "List of point coordinates. Required for add and move actions."
+msgstr " خط أم مساحة"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Could not find input vector '%s'"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "اسم الملف الفيكتورى المخرج"
+msgid "Failed opening output vector map '%s'"
+msgstr "اسم الملف الفيكتورى المخرج"
-#~ msgid "Do not create attribute table."
+msgid "Do not create attribute table."
-#~ msgid "Could not find input %s\n"
+msgid "Could not find input %s\n"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "عرض ملفات الراستر للموقع والخروج"
+msgid ""
+"List vector maps in input location and exit (a dummy value must be given for "
+"input)"
+msgstr "عرض ملفات الراستر للموقع والخروج"
 #, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr ""
-#~ "                الخــــــــريطة "
-#~ "الحالية        "
-#~ "الخـــــريطة الجــــــديدة\n"
+msgid "| Tool                            | Threshold     |"
+msgstr ""
+"                الخــــــــريطة "
+"الحالية        "
+"الخـــــريطة الجــــــديدة\n"
 #, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr ""
-#~ "                       إختبر متبقيـــــــــــــــات الخـــــــــريطة\n"
+msgid "| Break                           |  "
+msgstr "                       إختبر متبقيـــــــــــــــات الخـــــــــريطة\n"
 #, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr ""
+msgid "| Prune                           |  "
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
+msgid "%s: <%s> vector map not found"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
+msgid "Vector <%s> could not be open"
 #, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "مضاهاة"
+msgid "CrossCorrelation()"
+msgstr "مضاهاة"
 #, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "طريقة الاستيفاء المستخدمة"
+msgid "Interpolation()"
+msgstr "طريقة الاستيفاء المستخدمة"
 #, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
+msgid "Interpolation: Setting regions and boxes"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "Interpolation was a success!"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "%d نقاط تم تحميلها\n"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "%d نقاط تم تحميلها\n"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
-#~ msgstr "اسم ااملف المخرج"
+msgid "%s -- illegal output file name"
+msgstr "اسم ااملف المخرج"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Sorry, with method '%s' you have to define an output map."
 #, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "حساب الظلال من نموذج الإرتفاعت الرقمى"
+msgid "Calculation time"
+msgstr "حساب الظلال من نموذج الإرتفاعت الرقمى"
 #, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "عدد نقاط الإستيفاء"
+msgid "Maximum number of iteration"
+msgstr "عدد نقاط الإستيفاء"
-#~ msgid "Finished.\n"
-#~ msgstr "إنتهى\n"
+msgid "Finished.\n"
+msgstr "إنتهى\n"
 #, fuzzy
-#~ msgid "Existing raster map name"
-#~ msgstr "اسم الملف الراسترى الموجود"
+msgid "Existing raster map name"
+msgstr "اسم الملف الراسترى الموجود"
 #, fuzzy
-#~ msgid "Done!"
+msgid "Done!"
+msgstr "انتهى\n"
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "لم يتم الثور على شيئ\n"
+msgid "No line found."
+msgstr "لم يتم الثور على شيئ\n"
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
-#~ msgstr "%s لم يتم العثور على الخريطة الراسترية"
+msgid "Could not open ascii file [%s]"
 #, fuzzy
-#~ msgid "vector map to be created"
-#~ msgstr "الملف الراسترى الطلوب إدخالة"
+msgid "vector map to be created"
+msgstr "الملف الراسترى الطلوب إدخالة"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "تحويل خريطة راسترية إلى فيكتورية"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "تحويل خريطة راسترية إلى فيكتورية"
 #, fuzzy
-#~ msgid "Finished"
+msgid "Finished"
+msgstr "إنتهى\n"
 #, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "طباعة الأحصاء فى صورة شل سكربت"
+msgid "Print the current region (shell script style)"
+msgstr "طباعة الأحصاء فى صورة شل سكربت"
 #, fuzzy
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "%s لم يتم فتح قاعدة البيانات"
+msgid "%s: - no such database %s\n"
+msgstr "%s لم يتم فتح قاعدة البيانات"
 #, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "غير موجود <%s> الراستر"
+msgid "ERROR: <%s> not found\n"
+msgstr "غير موجود <%s> الراستر"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Cannot open toolbox: %s"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "Cannot open toolbox."
-#~ msgid "Could not find input map <%s>\n"
+msgid "Could not find input map <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s'تم الإنتهاء من تحويل الفيكتورات\n"
+msgid "'%s' has finished the transformation of the vectors.\n"
+msgstr "'%s'تم الإنتهاء من تحويل الفيكتورات\n"
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
+msgid ""
+"                          CHECK MAP RESIDUALS\n"
+"\n"
-#~ msgid "                Current Map                  New Map\n"
-#~ msgstr ""
-#~ "الحالية        "
+msgid "                Current Map                  New Map\n"
+msgstr ""
+"الحالية        "
-#~ msgid ""
-#~ " POINT      X coord    Y coord  |        X coord   Y coord    |      "
-#~ "residuals\n"
-#~ msgstr ""
-#~ "residuals\n"
+msgid ""
+" POINT      X coord    Y coord  |        X coord   Y coord    |      "
+"residuals\n"
+msgstr ""
+"residuals\n"
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "%f :متوسط المتبقيات\n"
+msgid "  Residual mean average   : %f\n"
+msgstr "%f :متوسط المتبقيات\n"
 #, fuzzy
-#~ msgid "Append files to existing file"
+msgid "Append files to existing file"
 #, fuzzy
-#~ msgid "No database updates."
+msgid "No database updates."
 #, fuzzy
-#~ msgid "Adding new features to vector file ..."
+msgid "Adding new features to vector file ..."
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "لم توجد<%s>الخريطة الفيكتورية"
+msgid "Vector map '%s' not found"
+msgstr "لم توجد<%s>الخريطة الفيكتورية"
 #, fuzzy
-#~ msgid "Input elevation file"
-#~ msgstr "اسم ملف الإرتفاعات الراستري"
+msgid "Input elevation file"
+msgstr "اسم ملف الإرتفاعات الراستري"
 #, fuzzy
-#~ msgid "Input aspect file"
-#~ msgstr "اسم خريطة اتجاه الإنحدار"
+msgid "Input aspect file"
 #, fuzzy
-#~ msgid "Input barrier file"
+msgid "Input barrier file"
 #, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "عملية التجميع"
+msgid "Quiet operation"
+msgstr "عملية التجميع"
 #, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s"
+msgid "%s\n"
+msgstr "%s"
 #, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "اسم الطبقة المخرجة"
+msgid "output layer name"
+msgstr "اسم الطبقة المخرجة"
 #, fuzzy
-#~ msgid "Transforming data..."
-#~ msgstr "التوقيع ..."
+msgid "Transforming data..."
+msgstr "التوقيع ..."
 #, fuzzy
-#~ msgid "Did not find input cell map."
+msgid "Did not find input cell map."
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "خروج :R الى :M من : L\n"
+msgid "L: from  M: to R: quit\n"
+msgstr "خروج :R الى :M من : L\n"
 #, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "الميعاد الزمنى ,الميعاد الزمنى الأولالميعاد الزمنى الثانى,أو لاشيئ"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "الميعاد الزمنى ,الميعاد الزمنى الأولالميعاد الزمنى الثانى,أو لاشيئ"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
+msgid ""
+"\n"
+"Done\n"
+msgstr "انتهى\n"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
 #, fuzzy
-#~ msgid "Name of vector output file"
-#~ msgstr "اسم الملف المخرج"
+msgid "Name of vector output file"
+msgstr "اسم الملف المخرج"
 #, fuzzy
-#~ msgid "centroids"
-#~ msgstr "%-5d أشباه المراكز قرات\n"
+msgid "centroids"
+msgstr "%-5d أشباه المراكز قرات\n"
 #, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "نقطة %d فى حاجة لإدخال على الأقل"
+msgid "ERROR: A line needs at least 2 points"
+msgstr "نقطة %d فى حاجة لإدخال على الأقل"
 #, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
+msgid "ERROR: An area needs at least 3 points"
 #, fuzzy
-#~ msgid "file type (ignored)"
+msgid "file type (ignored)"
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "[%s]لم يتم فتح ملف الخلية ل "
+msgid "Unable to create raster map for [%s]"
+msgstr "[%s]لم يتم فتح ملف الخلية ل "
-#~ msgid "Done\n"
+msgid "Done\n"
+msgstr "انتهى\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "قراءة خريطة ل اف بى كخريطة صحيحة الأعداد"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr "قراءة خريطة ل اف بى كخريطة صحيحة الأعداد"
-#~ msgid "Name for the resulting raster map"
+msgid "Name for the resulting raster map"
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "Open 3d raster map %s\n"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "%s:لم يتم إنشاء الجدول"
+msgid "Open elev raster map %s\n"
+msgstr "%s:لم يتم إنشاء الجدول"
 #, fuzzy
-#~ msgid "Could not open map %s\n"
+msgid "Could not open map %s\n"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "إدخال خريطة راسترية بينرية "
+msgid "Bin raster map to be imported"
+msgstr "إدخال خريطة راسترية بينرية "
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "المشتقات الجزئية المخرجة"
+msgid "Output partial derivatives instead"
+msgstr "المشتقات الجزئية المخرجة"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "لن يتم عرض شيئ ,minreg حجم المنطقة اقل من أصغر حجم مسجل\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr "لن يتم عرض شيئ ,minreg حجم المنطقة اقل من أصغر حجم مسجل\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr "لن يتم عرض شيئ ,maxreg حجم المنطقة اكبر من اكبرحجم مسجل\n"
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr "لن يتم عرض شيئ ,maxreg حجم المنطقة اكبر من اكبرحجم مسجل\n"
 #, fuzzy
-#~ msgid "Report only selected statistics"
-#~ msgstr "طريقة احصائيات ااشئ الموجة "
+msgid "Report only selected statistics"
+msgstr "طريقة احصائيات ااشئ الموجة "
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Enter imagery group to be registered"
-#~ msgstr "اسم الخرائط الراسترية المطلوب ترقيعها ببعضها "
+msgid "Enter imagery group to be registered"
+msgstr "اسم الخرائط الراسترية المطلوب ترقيعها ببعضها "
 #, fuzzy
-#~ msgid "Name for G3d raster map"
+msgid "Name for G3d raster map"
 #, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "خروج\n"
+msgid "Quiet mode"
+msgstr "خروج\n"
 #, fuzzy
-#~ msgid "done."
+msgid "done."
+msgstr "انتهى\n"
 #, fuzzy
-#~ msgid "output 3d raster map"
-#~ msgstr "الخريطة المخرجة"
+msgid "output 3d raster map"
+msgstr "الخريطة المخرجة"
 #, fuzzy
-#~ msgid "input raster map not found\n"
-#~ msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
+msgid "input raster map not found\n"
+msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
 #, fuzzy
-#~ msgid "elev raster map not found\n"
+msgid "elev raster map not found\n"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "DBMI اتصل بقاعدة البيانات من خلال"
+msgid "Connect to the database through DBMI."
+msgstr "DBMI اتصل بقاعدة البيانات من خلال"
-#~ msgid ""
-#~ "column '%s' : type text is stored as varchar(250) some data may be lost"
-#~ msgstr "نوع نص خزن كحروف متغيرة 250  قد يتم فقد بعض البيانات :'%s' العمود"
+msgid "column '%s' : type text is stored as varchar(250) some data may be lost"
+msgstr "نوع نص خزن كحروف متغيرة 250  قد يتم فقد بعض البيانات :'%s' العمود"
-#~ msgid "Zooming finished.\n"
-#~ msgstr "انتهى التكبير\n"
+msgid "Zooming finished.\n"
+msgstr "انتهى التكبير\n"
-#~ msgid "%s Pan\n"
-#~ msgstr "%s تحريك حر\n"
+msgid "%s Pan\n"
+msgstr "%s تحريك حر\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s خروج\n"
+msgid "%s Quit\n"
+msgstr "%s خروج\n"
-#~ msgid "%s Quit menu\n"
-#~ msgstr "%s الخروج من القائمة\n"
+msgid "%s Quit menu\n"
+msgstr "%s الخروج من القائمة\n"
-#~ msgid "Name of input map"
-#~ msgstr "اسم الخريطة المدخلة"
+msgid "Name of input map"
+msgstr "اسم الخريطة المدخلة"
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "احداثيات الشرق و الشمال لنقطة البدء"
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "احداثيات الشرق و الشمال لنقطة البدء"
-#~ msgid ""
-#~ "Output direction type AGNPS, ANSWERS or GRASS aspect\n"
-#~ "              default: GRASS"
-#~ msgstr ""
-#~ "AGNPS, ANSWERS or GRASS aspect\n"
-#~ "  نوع الإتجاه المخرج والأساس جراس"
+msgid ""
+"Output direction type AGNPS, ANSWERS or GRASS aspect\n"
+"              default: GRASS"
+msgstr ""
+"AGNPS, ANSWERS or GRASS aspect\n"
+"  نوع الإتجاه المخرج والأساس جراس"
-#~ msgid "Name of existing input raster map"
-#~ msgstr "اسم الخريطة الراسترية الموجودة"
+msgid "Name of existing input raster map"
+msgstr "اسم الخريطة الراسترية الموجودة"
 #, fuzzy
-#~ msgid "Slope"
-#~ msgstr "الإنحدار"
+msgid "Slope"
+msgstr "الإنحدار"
-#~ msgid "Aspect"
-#~ msgstr "اتجاه الإنحدار"
+msgid "Aspect"
+msgstr "اتجاه الإنحدار"
-#~ msgid "Profile curvature"
-#~ msgstr "انحناء التضاريس"
+msgid "Profile curvature"
+msgstr "انحناء التضاريس"
-#~ msgid "Tangential curvature"
-#~ msgstr "الإنحناء المماسى"
+msgid "Tangential curvature"
+msgstr "الإنحناء المماسى"
-#~ msgid "Mean curvature"
-#~ msgstr "الإنحناء المتوسط"
+msgid "Mean curvature"
+msgstr "الإنحناء المتوسط"
-#~ msgid "Tension"
-#~ msgstr "الشد"
+msgid "Tension"
+msgstr "الشد"
-#~ msgid "Output direct (beam) irradiance/irradiation file (raster)"
-#~ msgstr "إخراج ملف الإشعاع المباشر الراسترى"
+msgid "Output direct (beam) irradiance/irradiation file (raster)"
+msgstr "إخراج ملف الإشعاع المباشر الراسترى"
-#~ msgid "Output reflected irradiance/irradiation file (raster)"
-#~ msgstr "إخراج ملف الإشعاع المنعكس الراسترى"
+msgid "Output reflected irradiance/irradiation file (raster)"
+msgstr "إخراج ملف الإشعاع المنعكس الراسترى"
-#~ msgid "Sampling distance step coefficient (0.5-1.5)"
-#~ msgstr "(عامل المرحلة المسافية لأخذ العينات(0.5-1.5"
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr "(عامل المرحلة المسافية لأخذ العينات(0.5-1.5"
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "تنفيذ بسرعة ولكنها عملية مستهلكة للذاكرة"
+msgid "Invoke fast, but memory intensive operation"
+msgstr "تنفيذ بسرعة ولكنها عملية مستهلكة للذاكرة"
-#~ msgid ""
-#~ "GRASS module to create a fractal surface of a given fractal dimension. "
-#~ "Uses spectral synthesis method. Can create intermediate layers showing "
-#~ "the build up of different spectral coefficients (see Saupe, pp.106-107 "
-#~ "for an example of this). Use this module to generate naturally looking "
-#~ "synthetical elevation models (DEM)."
-#~ msgstr "برنامج أنشاء سطح فراكتالى مستخدما بعد فراكتالى معطى"
+msgid ""
+"GRASS module to create a fractal surface of a given fractal dimension. Uses "
+"spectral synthesis method. Can create intermediate layers showing the build "
+"up of different spectral coefficients (see Saupe, pp.106-107 for an example "
+"of this). Use this module to generate naturally looking synthetical "
+"elevation models (DEM)."
+msgstr "برنامج أنشاء سطح فراكتالى مستخدما بعد فراكتالى معطى"
+#, fuzzy
+#~ msgid "display, export"
+#~ msgstr "الملف الراسترى المدخل"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "اسم ملف التقرير"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "ملف المدخل"
+#, fuzzy
+#~ msgid "Data type"
+#~ msgstr "نوع المظهر"
+#, fuzzy
+#~ msgid "slopein raster map <%s> not found"
+#~ msgstr "غير موجود <%s>الملف للمنظر ثلاثى الأبعاد "
+#, fuzzy
+#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+#~ msgstr "%s لم يتم العثور على الخريطة الراسترية"
+#, fuzzy
+#~ msgid "Base raster map <%s> not found"
+#, fuzzy
+#~ msgid "Color table for <%s> updated"
+#~ msgstr " <%s> فى <%s>لم يمكن قراءة العنوان الرئيسى ل"
+#, fuzzy
+#~ msgid "Error reading raster map [%s]."
+#, fuzzy
+#~ msgid "Option <%s>: <%s> exists."
+#~ msgstr "غير موجودة <%s> المنطقة"
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "اسم ملف الإنحناء المماسى"
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "%s:منطقة غير صالحة"
+#, fuzzy
+#~ msgid "Name of the input raster map"
+#~ msgstr ""
+#~ "#-#-#-#-#  grassmods_ar.po (grassmods_ar)  #-#-#-#-#\n"
+#~ "اسم الخريطة المدخلة\n"
+#~ "اسم الخريطة الراسترية المدخلة"
Modified: grass/trunk/locale/po/grassmods_cs.po
--- grass/trunk/locale/po/grassmods_cs.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_cs.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -9942,7 +9942,7 @@
 #: ../raster/r.what/main.c:335
 #, fuzzy, c-format
 msgid "Error reading <%s>"
-msgstr "Chyba pøi ètení øádku"
+msgstr "Chyba pøi ètení rastrového souboru [%s]."
 #: ../raster/r.sum/main.c:46
 msgid "Sums up the raster cell values."
@@ -27100,1583 +27100,1564 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Nelze vybrat atributy bodu z <%s>"
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr "Tvorba nové grid3d volume mapy na základì výrazu pro r3.mapcalc."
+msgid "Calculates new grid3D volume from r3.mapcalc expression."
+msgstr "Tvorba nové grid3d volume mapy na základì výrazu pro r3.mapcalc."
-#~ msgid "A (grid3D file)"
-#~ msgstr "A (soubor grid3D)"
+msgid "A (grid3D file)"
+msgstr "A (soubor grid3D)"
-#~ msgid "B (grid3D file)"
-#~ msgstr "B (soubor grid3D)"
+msgid "B (grid3D file)"
+msgstr "B (soubor grid3D)"
-#~ msgid "C (grid3D file)"
-#~ msgstr "C (soubor grid3D)"
+msgid "C (grid3D file)"
+msgstr "C (soubor grid3D)"
-#~ msgid "D (grid3D file)"
-#~ msgstr "D (soubor grid3D)"
+msgid "D (grid3D file)"
+msgstr "D (soubor grid3D)"
-#~ msgid "E (grid3D file)"
-#~ msgstr "E (soubor grid3D)"
+msgid "E (grid3D file)"
+msgstr "E (soubor grid3D)"
-#~ msgid "F (grid3D file)"
-#~ msgstr "F (soubor grid3D)"
+msgid "F (grid3D file)"
+msgstr "F (soubor grid3D)"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Vzorec (napø. A-B nebo A*C+B)"
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Vzorec (napø. A-B nebo A*C+B)"
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Název výstupního souboru grid3D objem"
+msgid "Name for output grid3D volume"
+msgstr "Název výstupního souboru grid3D objem"
-#~ msgid "Show help"
-#~ msgstr "Zobraz nápovìdu"
+msgid "Show help"
+msgstr "Zobraz nápovìdu"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Expertní mód (zadejte soubor výrazù pro r3.mapcalc)"
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr "Expertní mód (zadejte soubor výrazù pro r3.mapcalc)"
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Nepøepisuj existující mapu"
+msgid "Do not overwrite existing map"
+msgstr "Nepøepisuj existující mapu"
-#~ msgid "Output field seperator"
-#~ msgstr "Výstupní oddìlovaè"
+msgid "Output field seperator"
+msgstr "Výstupní oddìlovaè"
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "Zobrazí rastrovou mapu spolu s legendou"
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "Zobrazí rastrovou mapu spolu s legendou"
-#~ msgid "omit entries with missing label"
-#~ msgstr "pøeskoèit záznamy bez popisku"
+msgid "omit entries with missing label"
+msgstr "pøeskoèit záznamy bez popisku"
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Poèet øádkù v legendì"
+msgid "Number of lines to appear in the legend"
+msgstr "Poèet øádkù v legendì"
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Tématicky zobrazuje vektorovou mapu"
+msgid "Displays thematic vectormap"
+msgstr "Tématicky zobrazuje vektorovou mapu"
-#~ msgid "display, legend"
-#~ msgstr "zobrazení, legenda"
+msgid "display, legend"
+msgstr "zobrazení, legenda"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Vektorová mapa, která bude tématicky zobrazena"
+msgid "Vector map to display thematically"
+msgstr "Vektorová mapa, která bude tématicky zobrazena"
-#~ msgid "Theme_prefs"
-#~ msgstr "Theme_prefs"
+msgid "Theme_prefs"
+msgstr "Theme_prefs"
-#~ msgid "Vector map type"
-#~ msgstr "Typ vektorové mapy"
+msgid "Vector map type"
+msgstr "Typ vektorové mapy"
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr ""
-#~ "Název sloupce atributu, který má být pou¾it pro tématické zobrazení (musí "
-#~ "být èíselný)"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr ""
+"Název sloupce atributu, který má být pou¾it pro tématické zobrazení (musí "
+"být èíselný)"
-#~ msgid "Type of thematic display"
-#~ msgstr "Typ tématu"
+msgid "Type of thematic display"
+msgstr "Typ tématu"
-#~ msgid "Thematic divisions of data for display"
-#~ msgstr "Zpùsob dìlení celkového rozsahu dat na intervaly pøi zobrazení"
+msgid "Thematic divisions of data for display"
+msgstr "Zpùsob dìlení celkového rozsahu dat na intervaly pøi zobrazení"
-#~ msgid ""
-#~ "Break points for custom breaks option. Separate values by spaces. (0 10 "
-#~ "20 30 ...)"
-#~ msgstr ""
-#~ "Hodnoty zastavení (break points). Hodnoty oddìlené mezerou (0 10 20 "
-#~ "30 ...)"
+msgid ""
+"Break points for custom breaks option. Separate values by spaces. (0 10 20 "
+"30 ...)"
+msgstr ""
+"Hodnoty zastavení (break points). Hodnoty oddìlené mezerou (0 10 20 30 ...)"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Vrstva pou¾itá k tématickému zobrazení"
+msgid "Layer to use for thematic display"
+msgstr "Vrstva pou¾itá k tématickému zobrazení"
-#~ msgid "Points"
-#~ msgstr "Body"
+msgid "Points"
+msgstr "Body"
-#~ msgid "Vector point icon for point data"
-#~ msgstr "Ikona pro bodová data"
+msgid "Vector point icon for point data"
+msgstr "Ikona pro bodová data"
-#~ msgid ""
-#~ "Icon size for point data (minimum icon size/line width for graduated "
-#~ "points/lines)"
-#~ msgstr ""
-#~ "Velikost ikony pro bodová data (minimální velikost ikony/¹íøka linie pro "
-#~ "zvìt¹ující se body nebo linie)"
+msgid ""
+"Icon size for point data (minimum icon size/line width for graduated points/"
+"lines)"
+msgstr ""
+"Velikost ikony pro bodová data (minimální velikost ikony/¹íøka linie pro "
+"zvìt¹ující se body nebo linie)"
-#~ msgid "Maximum icon size/line width for graduated points and lines"
-#~ msgstr ""
-#~ "Maximální velikost ikony nebo ¹íøka linie pro zvìt¹ující se body a linie"
+msgid "Maximum icon size/line width for graduated points and lines"
+msgstr ""
+"Maximální velikost ikony nebo ¹íøka linie pro zvìt¹ující se body a linie"
-#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Poèet tøíd pro intervalové téma (celé èíslo)"
+msgid "Number of classes for interval theme (integer)"
+msgstr "Poèet tøíd pro intervalové téma (celé èíslo)"
-#~ msgid ""
-#~ "Color scheme for graduated color mapping (select 'single_color' for "
-#~ "graduated point/line display)"
-#~ msgstr ""
-#~ "Barevné schéma pro gradující barvy (vyberte 'single_color' pro zobrazení "
-#~ "gradujících bodù/linií)"
+msgid ""
+"Color scheme for graduated color mapping (select 'single_color' for "
+"graduated point/line display)"
+msgstr ""
+"Barevné schéma pro gradující barvy (vyberte 'single_color' pro zobrazení "
+"gradujících bodù/linií)"
-#~ msgid ""
-#~ "Color for graduated points map (grass named color or R:G:B triplet). Set "
-#~ "color scheme to single color."
-#~ msgstr ""
-#~ "Barva pro gradující bodové mapy (jména barev definovaných GRASSem nebo "
-#~ "triplet R:G:B). Nastaví barevné téma na jednobarevné."
+msgid ""
+"Color for graduated points map (grass named color or R:G:B triplet). Set "
+"color scheme to single color."
+msgstr ""
+"Barva pro gradující bodové mapy (jména barev definovaných GRASSem nebo "
+"triplet R:G:B). Nastaví barevné téma na jednobarevné."
-#~ msgid ""
-#~ "Color for graduated lines or point/area outlines (grass named color or R:"
-#~ "G:B triplet). Set color scheme to single color."
-#~ msgstr ""
-#~ "Barva pro gradující linie nebo body/okraje ploch (barvy známé GRASSu nebo "
-#~ "triplet R:G:B). Nastavíbarevné schéma na jednu barvu."
+msgid ""
+"Color for graduated lines or point/area outlines (grass named color or R:G:B "
+"triplet). Set color scheme to single color."
+msgstr ""
+"Barva pro gradující linie nebo body/okraje ploch (barvy známé GRASSu nebo "
+"triplet R:G:B). Nastavíbarevné schéma na jednu barvu."
-#~ msgid ""
-#~ "Beginning color for custom color gradient. Must be expressed as R:G:B "
-#~ "triplet."
-#~ msgstr ""
-#~ "Poèáteèní barva pro vlastní barevný gradient. Musí být zadána jako trojce "
-#~ "R:G:B."
+msgid ""
+"Beginning color for custom color gradient. Must be expressed as R:G:B "
+"triplet."
+msgstr ""
+"Poèáteèní barva pro vlastní barevný gradient. Musí být zadána jako trojce R:"
+"G:B."
-#~ msgid ""
-#~ "Ending color for custom color gradient. Must be expressed as R:G:B triplet"
-#~ msgstr ""
-#~ "Koncová barva pro vlastní barevný gradient. Musí být zadána jako trojce R:"
-#~ "G:B."
+msgid ""
+"Ending color for custom color gradient. Must be expressed as R:G:B triplet"
+msgstr ""
+"Koncová barva pro vlastní barevný gradient. Musí být zadána jako trojce R:G:"
+"B."
-#~ msgid "Misc"
-#~ msgstr "Rùzné"
+msgid "Misc"
+msgstr "Rùzné"
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Vybrat pro zobrazení legendy monitor x1"
+msgid "Select x11 display monitor for legend"
+msgstr "Vybrat pro zobrazení legendy monitor x1"
-#~ msgid "Save thematic map commands to group file for GIS Manager"
-#~ msgstr ""
-#~ "Ulo¾ pøíkazy pro vytvoøení tématické mapy do souboru skupiny pro GIS "
-#~ "Manager"
+msgid "Save thematic map commands to group file for GIS Manager"
+msgstr ""
+"Ulo¾ pøíkazy pro vytvoøení tématické mapy do souboru skupiny pro GIS Manager"
-#~ msgid ""
-#~ "Root for the name of psmap instruction files to be in current directory "
-#~ "(if not set, no psmap instruction files will be created)"
-#~ msgstr ""
-#~ "Koøen názvu souborù psmap pro aktuální adresáø (pokud není nastaven, "
-#~ "¾ádný soubor s instrukcemi pro psmap nebude vytvoøen)"
+msgid ""
+"Root for the name of psmap instruction files to be in current directory (if "
+"not set, no psmap instruction files will be created)"
+msgstr ""
+"Koøen názvu souborù psmap pro aktuální adresáø (pokud není nastaven, ¾ádný "
+"soubor s instrukcemi pro psmap nebude vytvoøen)"
-#~ msgid "Name of group file where thematic map commands will be saved"
-#~ msgstr ""
-#~ "Jméno souboru skupiny kam budou ulo¾eny pøíkazy pro tématické zobrazení"
+msgid "Name of group file where thematic map commands will be saved"
+msgstr ""
+"Jméno souboru skupiny kam budou ulo¾eny pøíkazy pro tématické zobrazení"
-#~ msgid "Create graphic legend in x11 display monitor"
-#~ msgstr "Vytvoøit grafickou legendu v grafickém monitoru x1"
+msgid "Create graphic legend in x11 display monitor"
+msgstr "Vytvoøit grafickou legendu v grafickém monitoru x1"
-#~ msgid "Only draw fills (no outlines) for areas and points"
-#~ msgstr "Kreslit pouze výplnì (bez hranic) ploch a bodù"
+msgid "Only draw fills (no outlines) for areas and points"
+msgstr "Kreslit pouze výplnì (bez hranic) ploch a bodù"
-#~ msgid "Update color values to GRASSRGB column in attribute table"
-#~ msgstr "Ulo¾ barevné hodnoty do tabulky do sloupeèku GRASSRGB"
+msgid "Update color values to GRASSRGB column in attribute table"
+msgstr "Ulo¾ barevné hodnoty do tabulky do sloupeèku GRASSRGB"
-#~ msgid "Output legend for GIS Manager (for scripting use only)"
-#~ msgstr "Výstupní legenda pro GIS Manager (pouze pøi pou¾ití ve skriptech)"
+msgid "Output legend for GIS Manager (for scripting use only)"
+msgstr "Výstupní legenda pro GIS Manager (pouze pøi pou¾ití ve skriptech)"
-#~ msgid "Use math notation brackets in legend"
-#~ msgstr "Pou¾ij matematický zápis závorek v legendì"
+msgid "Use math notation brackets in legend"
+msgstr "Pou¾ij matematický zápis závorek v legendì"
 #, fuzzy
-#~ msgid "Removes data files using basic regular expressions and wildcards."
-#~ msgstr "Pou¾ij regulární výrazy a zástupné znaky na g.list"
+msgid "Removes data files using basic regular expressions and wildcards."
+msgstr "Pou¾ij regulární výrazy a zástupné znaky na g.list"
-#~ msgid "Raster to remove"
-#~ msgstr "Rastrová mapa ke smazání"
+msgid "Raster to remove"
+msgstr "Rastrová mapa ke smazání"
-#~ msgid "3d raster to remove"
-#~ msgstr "3d rastrová mapa ke smazání"
+msgid "3d raster to remove"
+msgstr "3d rastrová mapa ke smazání"
-#~ msgid "Vector to remove"
-#~ msgstr "Vektorová mapa ke smazání"
+msgid "Vector to remove"
+msgstr "Vektorová mapa ke smazání"
-#~ msgid "Region to remove"
-#~ msgstr "Region ke smazání"
+msgid "Region to remove"
+msgstr "Region ke smazání"
-#~ msgid "Label to remove"
-#~ msgstr "©títky ke smazání"
+msgid "Label to remove"
+msgstr "©títky ke smazání"
-#~ msgid "3dview to remove"
-#~ msgstr "smazat 3dview"
+msgid "3dview to remove"
+msgstr "smazat 3dview"
-#~ msgid "Group to remove"
-#~ msgstr "Skupina ke smazání"
+msgid "Group to remove"
+msgstr "Skupina ke smazání"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Poèítá novou mapu z výrazu pro r.mapcalc."
+msgid "Calculate new raster map from a r.mapcalc expression."
+msgstr "Poèítá novou mapu z výrazu pro r.mapcalc."
-#~ msgid "A"
-#~ msgstr "A"
+msgid "A"
+msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
+msgid "B"
+msgstr "B"
-#~ msgid "C"
-#~ msgstr "C"
+msgid "C"
+msgstr "C"
-#~ msgid "D"
-#~ msgstr "D"
+msgid "D"
+msgstr "D"
-#~ msgid "E"
-#~ msgstr "E"
+msgid "E"
+msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
+msgid "F"
+msgstr "F"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Expertní mód (zadejte soubor výrazù pro r.mapcalc)"
+msgid "Expert mode (enter a set of r.mapcalc expressions)"
+msgstr "Expertní mód (zadejte soubor výrazù pro r.mapcalc)"
 #, fuzzy
-#~ msgid "Lists data files using basic regular expressions and wildcards."
+msgid "Lists data files using basic regular expressions and wildcards."
-#~ msgid "Data type"
-#~ msgstr "Typ dat"
+msgid "Data type"
+msgstr "Typ dat"
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset, ze kterého má být seznam udìlán (výchozí: aktuální)"
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Oddìlovaè výstupu (výchozí: øádkový zlom)"
+msgid "Output separator (default: newline)"
+msgstr "Oddìlovaè výstupu (výchozí: øádkový zlom)"
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr ""
-#~ "Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr ""
+"Exportuje GRASS rastry do jednoho z formátù podporovaných knihovnou GDAL."
-#~ msgid "Region sensitive output"
-#~ msgstr "Výstup s ohledem na region"
+msgid "Region sensitive output"
+msgstr "Výstup s ohledem na region"
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr "Volby pro ovladaè výstupního formátu. Volby je mo¾no kombinovat."
-#~ msgid "Current window not settable"
-#~ msgstr "Aktuální okno nelze nastavit"
+msgid "Current window not settable"
+msgstr "Aktuální okno nelze nastavit"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Chyba pøi pøepoèítávání"
+msgid "Error in calculating conversions"
+msgstr "Chyba pøi pøepoèítávání"
-#~ msgid "Display number of colors"
-#~ msgstr "Zobraz poèet barev"
+msgid "Display number of colors"
+msgstr "Zobraz poèet barev"
-#~ msgid "Rendering method for filled polygons"
-#~ msgstr "Vykreslovací metoda pro plné polygony"
+msgid "Rendering method for filled polygons"
+msgstr "Vykreslovací metoda pro plné polygony"
 #, fuzzy
-#~ msgid ""
-#~ "d;use the display library basic functions (features: polylines);c;use the "
-#~ "display library clipping functions (features: clipping);l;use the display "
-#~ "library culling functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "g;pou¾ití vykreslovacích funkcí(prvky:vystøihování);r;pou¾ití knihovny "
-#~ "funkcí pro rastrovou grafiku (prvky: lomená èára);d;pou¾ití knihovny "
-#~ "základních zobrazovacích funkcí (prvky: lomená èára);c; pou¾ití knihovny "
-#~ "zobrazovacích vystøihovacích funkcí (prvky: vystøihování);l;pou¾ití "
-#~ "knihovny zobrazovacích odstraòovacích funkcí (prvky: odstranìní, lomená "
-#~ "èára)"
+msgid ""
+"d;use the display library basic functions (features: polylines);c;use the "
+"display library clipping functions (features: clipping);l;use the display "
+"library culling functions (features: culling, polylines)"
+msgstr ""
+"g;pou¾ití vykreslovacích funkcí(prvky:vystøihování);r;pou¾ití knihovny "
+"funkcí pro rastrovou grafiku (prvky: lomená èára);d;pou¾ití knihovny "
+"základních zobrazovacích funkcí (prvky: lomená èára);c; pou¾ití knihovny "
+"zobrazovacích vystøihovacích funkcí (prvky: vystøihování);l;pou¾ití knihovny "
+"zobrazovacích odstraòovacích funkcí (prvky: odstranìní, lomená èára)"
 #, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Neplatná metoda: %s"
+msgid "Invalid rendering method <%s>"
+msgstr "Neplatná metoda: %s"
-#~ msgid "Error reading raster map"
-#~ msgstr "chyba pøi ètení rastrové mapy"
+msgid "Error reading raster map"
+msgstr "chyba pøi ètení rastrové mapy"
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Nástroj pro interaktivní vytváøení profilù s volitelným výstupem."
+msgid "Interactive profile plotting utility with optional output."
+msgstr "Nástroj pro interaktivní vytváøení profilù s volitelným výstupem."
-#~ msgid "Optional display raster"
-#~ msgstr "Volitelný rastr, který bude zobrazen"
+msgid "Optional display raster"
+msgstr "Volitelný rastr, který bude zobrazen"
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Výstupní data profilu ulo¾it do souboru(ù) s prefixem 'jméno'"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Výstupní data profilu ulo¾it do souboru(ù) s prefixem 'jméno'"
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Rastr ke zobrazení [%s] nenalezen. Pou¾iji rastr profilu."
+msgid "Display raster [%s] not found. Using profile raster."
+msgstr "Rastr ke zobrazení [%s] nenalezen. Pou¾iji rastr profilu."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Pou¾ít my¹ pro vybraní akce"
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr ""
+"\n"
+"\n"
+"Pou¾ít my¹ pro vybraní akce"
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Pou¾ijte 'd.frame -e' pro smazání zbylých rámcù"
+msgid "Use 'd.frame -e' to remove left over frames"
+msgstr "Pou¾ijte 'd.frame -e' pro smazání zbylých rámcù"
-#~ msgid "Error opening cell-file"
-#~ msgstr "Chyba pøi otevírání souboru cell"
+msgid "Error opening cell-file"
+msgstr "Chyba pøi otevírání souboru cell"
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Chyba pøi ètení souboru cell"
+msgid "Error reading from cell-file"
+msgstr "Chyba pøi ètení souboru cell"
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Záhadná chyba nekonzistence okna"
+msgid "Mysterious window inconsistancy error"
+msgstr "Záhadná chyba nekonzistence okna"
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: Nelze otevøít rastrový soubor <%s@%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "%s: Nelze otevøít rastrový soubor <%s@%s>"
-#~ msgid "%s: Couldn't read color table for <%s@%s>"
-#~ msgstr "%s: Nelze èíst tabulku barev pro <%s@%s>"
+msgid "%s: Couldn't read color table for <%s@%s>"
+msgstr "%s: Nelze èíst tabulku barev pro <%s@%s>"
-#~ msgid "one moment ..."
-#~ msgstr "momentíèek ..."
+msgid "one moment ..."
+msgstr "momentíèek ..."
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' dostala NULLový pointer!"
+msgid "%s: 'is_null_value()' got NULL pointer!"
+msgstr "%s: 'is_null_value()' dostala NULLový pointer!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' dostala negativní index sloupeèku"
+msgid "%s: 'is_null_value()' got negative column index"
+msgstr "%s: 'is_null_value()' dostala negativní index sloupeèku"
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Neznámý RASTER_MAP_TYPE '%d'"
+msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
+msgstr "%s: 'is_null_value()' Neznámý RASTER_MAP_TYPE '%d'"
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitor: waitpid: oèekával jsem %d, ale dostal jsem %d"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Monitor: waitpid: oèekával jsem %d, ale dostal jsem %d"
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XgetWMName selhalo"
+msgid "Monitor: XGetWMName failed"
+msgstr "Monitor: XgetWMName selhalo"
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: ¹patný výsledek"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Monitor: XGetWMName: ¹patný výsledek"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitor: interaktivní pøíkaz v pøekreslení"
+msgid "Monitor: interactive command in redraw"
+msgstr "Monitor: interaktivní pøíkaz v pøekreslení"
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "nalezeno %d zobrazení typu TrueColor"
+msgid "found %d visuals of type TrueColor"
+msgstr "nalezeno %d zobrazení typu TrueColor"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "hledám nejvìt¹í bitovou hloubku"
+msgid "searching for highest bit depth"
+msgstr "hledám nejvìt¹í bitovou hloubku"
-#~ msgid "selected %d bit depth"
-#~ msgstr "vybrána hloubka %d bitù"
+msgid "selected %d bit depth"
+msgstr "vybrána hloubka %d bitù"
-#~ msgid "using default visual which is %s"
-#~ msgstr "pou¾ívám výchozí zobrazení, co¾ je %s"
+msgid "using default visual which is %s"
+msgstr "pou¾ívám výchozí zobrazení, co¾ je %s"
-#~ msgid "Can't set current graphics window"
-#~ msgstr "Nelze pou¾ít aktuální okno"
+msgid "Can't set current graphics window"
+msgstr "Nelze pou¾ít aktuální okno"
 #, fuzzy
-#~ msgid "Database is not a %s"
-#~ msgstr "Název vstupní databáze není nastaven"
+msgid "Database is not a %s"
+msgstr "Název vstupní databáze není nastaven"
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
-#~ msgid "Hilight color for text"
-#~ msgstr "Zvýrazòující barva textu"
+msgid "Hilight color for text"
+msgstr "Zvýrazòující barva textu"
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "Vektorová mapa <%s> nebyla nalezena v souèasném mapsetu"
+msgid "Vector map <%s> not found in the current mapset"
+msgstr "Vektorová mapa <%s> nebyla nalezena v souèasném mapsetu"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Pro zero_array_cell není dostatek pamìti"
+msgid "Not enough memory for zero_array_cell"
+msgstr "Pro zero_array_cell není dostatek pamìti"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Plné místo na disku -- nemohu zapsat soubory"
+msgid "Not enough disk space -- cannot write files"
+msgstr "Plné místo na disku -- nemohu zapsat soubory"
 #, fuzzy
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "volba <%s>: <%s> ji¾ existuje"
+msgid "Option <%s>: <%s> exists."
+msgstr "volba <%s>: <%s> ji¾ existuje"
 #, fuzzy
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Pou¾ijte volbu output= pro zmìnu jména vektoru"
+msgid "Use '%s' option to change vector map name"
+msgstr "Pou¾ijte volbu output= pro zmìnu jména vektoru"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Vstupní mapa sí»ì <%s> nebyla nalezena"
+msgid "Network input map <%s> not found"
+msgstr "Vstupní mapa sí»ì <%s> nebyla nalezena"
-#~ msgid "Do not print polyline info"
-#~ msgstr "Nevypisovat info o zdvojených liniích "
+msgid "Do not print polyline info"
+msgstr "Nevypisovat info o zdvojených liniích "
-#~ msgid "Line: %d\n"
-#~ msgstr "Linie: %d\n"
+msgid "Line: %d\n"
+msgstr "Linie: %d\n"
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgstr "Vektorová mapa <%s> není v tomto mapsetu a nelze ji mìnit"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr "Vektorová mapa <%s> není v tomto mapsetu a nelze ji mìnit"
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: základní mapa nebyla nalezena"
+msgid "%s: base raster map not found"
+msgstr "%s: základní mapa nebyla nalezena"
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: pøekryvná mapa nebyla nalezena"
+msgid "%s: cover raster map not found"
+msgstr "%s: pøekryvná mapa nebyla nalezena"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: základní mapa a výstupní mapa musí být rùzné"
+msgid "%s: base map and output map must be different"
+msgstr "%s: základní mapa a výstupní mapa musí být rùzné"
-#~ msgid "Cell file not found"
-#~ msgstr "Rastrový (cell) soubor nebyl nalezen"
+msgid "Cell file not found"
+msgstr "Rastrový (cell) soubor nebyl nalezen"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "vstupní rastr s elevací <%s> nebyl nalezen"
+msgid "elevin raster map <%s> not found"
+msgstr "vstupní rastr s elevací <%s> nebyl nalezen"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "vstupní rastr s expozicí <%s> nebyl nalezen"
+msgid "aspin raster map <%s> not found"
+msgstr "vstupní rastr s expozicí <%s> nebyl nalezen"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "vstupní rastr sklonu <%s> nebyl nalezen"
+msgid "slopein raster map <%s> not found"
+msgstr "vstupní rastr sklonu <%s> nebyl nalezen"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "vstupní rastr s Linkovými koeficienty <%s> nebyl nalezen"
+msgid "linkein raster map <%s> not found"
+msgstr "vstupní rastr s Linkovými koeficienty <%s> nebyl nalezen"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "rastrový soubor albeda <%s> nebyl nalezen"
+msgid "albedo raster map <%s> not found"
+msgstr "rastrový soubor albeda <%s> nebyl nalezen"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "rastrový soubor se zem. ¹íøkou <%s> nebyl nalezen"
+msgid "latin raster map <%s> not found"
+msgstr "rastrový soubor se zem. ¹íøkou <%s> nebyl nalezen"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr ""
-#~ "raststrový soubor s koeficientem pøímého sluneèního záøení <%s> nebyl "
-#~ "nalezen"
+msgid "coefbh raster map <%s> not found"
+msgstr ""
+"raststrový soubor s koeficientem pøímého sluneèního záøení <%s> nebyl nalezen"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "rastrový soubor s koeficientem difíºzního záøení <%s> nebyl nalezen"
+msgid "coefdh raster map <%s> not found"
+msgstr "rastrový soubor s koeficientem difíºzního záøení <%s> nebyl nalezen"
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "Nelze otevøít vektorovou mapu <%s> v  <%s>"
+msgid "Unable to open vector map <%s> in <%s>"
+msgstr "Nelze otevøít vektorovou mapu <%s> v  <%s>"
 #, fuzzy
-#~ msgid "%s - not found"
-#~ msgstr "<%s> nenalezen"
+msgid "%s - not found"
+msgstr "<%s> nenalezen"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titulek v uvozovkách"
+msgid "Title, in quotes"
+msgstr "Titulek v uvozovkách"
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "RGB rastrová mapa <%s> nenalezena"
+msgid "RGB raster map <%s> not found"
+msgstr "RGB rastrová mapa <%s> nenalezena"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr "Nelze vytvoøit data RGB, prosím zadejte tøi mapy [r,g,b]"
+msgid "Cannot create RGB data, please provide three maps [r,g,b]"
+msgstr "Nelze vytvoøit data RGB, prosím zadejte tøi mapy [r,g,b]"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "Vektorová mapa buòek <%s> nebyla nalezena"
+msgid "Vector cell map <%s> not found"
+msgstr "Vektorová mapa buòek <%s> nebyla nalezena"
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr ""
-#~ "Nelze vytvoøit vektorová data, prosím zadejte tøi mapové vrstvy [x,y,z]"
+msgid "Cannot create vector data, please provide three maps [x,y,z]"
+msgstr ""
+"Nelze vytvoøit vektorová data, prosím zadejte tøi mapové vrstvy [x,y,z]"
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Nelze nalézt poèáteèní vektor <%s> "
+msgid "Unable to find starting vector <%s> "
+msgstr "Nelze nalézt poèáteèní vektor <%s> "
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Nelze nalézt koncový vektor <%s> "
+msgid "Unable to find stop vector <%s>"
+msgstr "Nelze nalézt koncový vektor <%s> "
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "Výstupní rastrová mapa <%s>  nenalezena (nebyly zadány start_points)"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "Výstupní rastrová mapa <%s>  nenalezena (nebyly zadány start_points)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Chyba pøi alokaci pamìti pøi ètení poèáteèních bodù z rastrové mapy %s"
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr "Chyba pøi alokaci pamìti pøi ètení poèáteèních bodù z rastrové mapy %s"
-#~ msgid "Run verbosly"
-#~ msgstr "Roz¹íøený výpis"
+msgid "Run verbosly"
+msgstr "Roz¹íøený výpis"
-#~ msgid "Run VERBOSELY"
+msgid "Run VERBOSELY"
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Nebyla zadána mapa spojitých oblastí a nastavena MASKa"
+msgid "No clump map specified and MASK not set."
+msgstr "Nebyla zadána mapa spojitých oblastí a nastavena MASKa"
-#~ msgid "Unable to find data map"
-#~ msgstr "Nelze nalézt mapu s daty"
+msgid "Unable to find data map"
+msgstr "Nelze nalézt mapu s daty"
-#~ msgid "Unable to find clump map"
-#~ msgstr "Nelze nalézt mapu shlukù (clump)"
+msgid "Unable to find clump map"
+msgstr "Nelze nalézt mapu shlukù (clump)"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Chyba pøi ètení z rastrové mapy <%s> v mapsetu <%s>"
+msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+msgstr "%s: Chyba pøi ètení z rastrové mapy <%s> v mapsetu <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "aspect;aspect oriented grey colors;aspectcolr;aspect oriented rainbow "
-#~ "colors;bcyr;blue through cyan through yellow to red;bgyr;blue through "
-#~ "green through yellow to red;byg;blue through yellow to green colors;byr;"
-#~ "blue through yellow to red colors;curvature;for terrain curvatures (from "
-#~ "v.surf.rst and r.slope.aspect curvature colors);differences;differences "
-#~ "oriented colors;elevation;maps percentage ranges of raster values to "
-#~ "elevation color ramp;etopo2;rainbow color ramp for the ETOPO2 2-minute "
-#~ "Worldwide Bathymetry/Topography dataset;evi;enhanced vegetative index "
-#~ "colors;grey;grey scale;grey1.0;grey scale for raster values between 0.0-"
-#~ "1.0;grey255;grey scale for raster values bewtween 0-255;grey.eq;histogram-"
-#~ "equalized grey scale;grey.log;histogram logarithmic transformed grey "
-#~ "scale;gyr;green through yellow to red colors;ndvi;Normalized Difference "
-#~ "Vegetation Index colors;population;color table covering human population "
-#~ "classification breaks;rainbow;rainbow color table;ramp;color ramp;random;"
-#~ "random color table;ryb;red through yellow to blue colors;ryg;red through "
-#~ "yellow to green colors;slope;r.slope.aspect-type slope colors for raster "
-#~ "values 0-90;srtm;color palette for Shuttle Radar Topography Mission "
-#~ "elevation values;terrain;global elevation color table covering -11000 to "
-#~ "+8850m;wave;color wave;"
-#~ msgstr ""
-#~ "aspect; mapa expozice v ¹edých barvách;aspectcolr;mapa expozice v barvách "
-#~ "duhy;"
+msgid ""
+"aspect;aspect oriented grey colors;aspectcolr;aspect oriented rainbow colors;"
+"bcyr;blue through cyan through yellow to red;bgyr;blue through green through "
+"yellow to red;byg;blue through yellow to green colors;byr;blue through "
+"yellow to red colors;curvature;for terrain curvatures (from v.surf.rst and r."
+"slope.aspect curvature colors);differences;differences oriented colors;"
+"elevation;maps percentage ranges of raster values to elevation color ramp;"
+"etopo2;rainbow color ramp for the ETOPO2 2-minute Worldwide Bathymetry/"
+"Topography dataset;evi;enhanced vegetative index colors;grey;grey scale;"
+"grey1.0;grey scale for raster values between 0.0-1.0;grey255;grey scale for "
+"raster values bewtween 0-255;grey.eq;histogram-equalized grey scale;grey.log;"
+"histogram logarithmic transformed grey scale;gyr;green through yellow to red "
+"colors;ndvi;Normalized Difference Vegetation Index colors;population;color "
+"table covering human population classification breaks;rainbow;rainbow color "
+"table;ramp;color ramp;random;random color table;ryb;red through yellow to "
+"blue colors;ryg;red through yellow to green colors;slope;r.slope.aspect-type "
+"slope colors for raster values 0-90;srtm;color palette for Shuttle Radar "
+"Topography Mission elevation values;terrain;global elevation color table "
+"covering -11000 to +8850m;wave;color wave;"
+msgstr ""
+"aspect; mapa expozice v ¹edých barvách;aspectcolr;mapa expozice v barvách "
+"duhy;"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Aplikuj filtr pouze na nulové hodnoty dat"
+msgid "Apply filter only to zero data values"
+msgstr "Aplikuj filtr pouze na nulové hodnoty dat"
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] nebyl nalezen"
+msgid "%s: [%s] not found"
+msgstr "%s: [%s] nebyl nalezen"
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "podkladová rastrová vrstva <%s> nebyla nalezena"
+msgid "Base raster map <%s> not found"
+msgstr "podkladová rastrová vrstva <%s> nebyla nalezena"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "Základní mapa a výstupní <%s> mapa musí být rùzné"
+msgid "Base map and output map <%s> must be different"
+msgstr "Základní mapa a výstupní <%s> mapa musí být rùzné"
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Nedostatek pamìti pro alokování datové struktury"
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Nedostatek pamìti pro alokování datové struktury"
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** Nelze èíst soubor s pøíznaky <%s> **"
+msgid "** Can't read signature file <%s> **"
+msgstr "** Nelze èíst soubor s pøíznaky <%s> **"
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Spoèítá základní statistiku z GRASS  rastrové mapy."
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "Spoèítá základní statistiku z GRASS  rastrové mapy."
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "roz¹íøená statistika (kvartily a percentily)"
+msgid "extended statistics (quartiles and percentile)"
+msgstr "roz¹íøená statistika (kvartily a percentily)"
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè -e)"
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "Percentil, který se má spoèítat (vy¾aduje pøepínaè -e)"
-#~ msgid ""
-#~ "displays spectral response at user specified locations in group or images"
-#~ msgstr ""
-#~ "zobrazí spektrální odrazivost na u¾ivatelem zadaných mapách ve skupinì "
-#~ "snímkù"
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+"zobrazí spektrální odrazivost na u¾ivatelem zadaných mapách ve skupinì snímkù"
-#~ msgid "imagery, raster, multispectral"
-#~ msgstr "rastr, dpz, multispektrální"
+msgid "imagery, raster, multispectral"
+msgstr "rastr, dpz, multispektrální"
-#~ msgid "group input"
-#~ msgstr "vstupní skupina"
+msgid "group input"
+msgstr "vstupní skupina"
-#~ msgid "raster input maps"
-#~ msgstr "Vstupní rastrové soubory"
+msgid "raster input maps"
+msgstr "Vstupní rastrové soubory"
-#~ msgid "write output to PNG image"
-#~ msgstr "Zapsat výstup jako soubor PNG"
+msgid "write output to PNG image"
+msgstr "Zapsat výstup jako soubor PNG"
-#~ msgid "Use image list and not group"
-#~ msgstr "Pou¾ij seznam snímkù a ne skupinu"
+msgid "Use image list and not group"
+msgstr "Pou¾ij seznam snímkù a ne skupinu"
-#~ msgid "Select multiple points"
-#~ msgstr "Vyber více bodù"
+msgid "Select multiple points"
+msgstr "Vyber více bodù"
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "oznaè souøadnicemi místo èíslováním"
+msgid "label with coordinates instead of numbering"
+msgstr "oznaè souøadnicemi místo èíslováním"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Mìní velikost aktivního monitoru"
+msgid "Resizes active display monitor"
+msgstr "Mìní velikost aktivního monitoru"
-#~ msgid "New width for window"
-#~ msgstr "Nová ¹íøka okna"
+msgid "New width for window"
+msgstr "Nová ¹íøka okna"
-#~ msgid "New height for window"
-#~ msgstr "Nová vý¹ka okna"
+msgid "New height for window"
+msgstr "Nová vý¹ka okna"
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Slide show rastrù/vektorù."
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Slide show rastrù/vektorù."
-#~ msgid "display, slideshow"
-#~ msgstr "zobrazení, prezentace"
+msgid "display, slideshow"
+msgstr "zobrazení, prezentace"
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Zobrazit vektory, místo rastrù"
+msgid "Show vector maps rather than raster maps"
+msgstr "Zobrazit vektory, místo rastrù"
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "Pøedpona mapy. Zadejte písmeno(na) pro zobrazení pouze vybraných map"
+msgid "Map prefix. Specify character(s) to view selected maps only"
+msgstr "Pøedpona mapy. Zadejte písmeno(na) pro zobrazení pouze vybraných map"
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Poèet map zobrazených na monitoru"
+msgid "Map number show across the monitor"
+msgstr "Poèet map zobrazených na monitoru"
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Poèet map zobrazených pod monitorem"
+msgid "Map number show down the monitor"
+msgstr "Poèet map zobrazených pod monitorem"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Mapset který bude pou¾it. Více mapsetù lze oddìlit èárkou"
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr "Mapset který bude pou¾it. Více mapsetù lze oddìlit èárkou"
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Poèet vteøin pro pøestávku mezi slidy."
+msgid "Number of seconds to pause between slides"
+msgstr "Poèet vteøin pro pøestávku mezi slidy."
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "Pou¾ij regulární výrazy a zástupné znaky pro g.remove "
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr "Pou¾ij regulární výrazy a zástupné znaky pro g.remove "
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Ulo¾í aktuální obsah monitoru do souboru PNG v domovském adresáøi"
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr "Ulo¾í aktuální obsah monitoru do souboru PNG v domovském adresáøi"
-#~ msgid "display, export"
-#~ msgstr "zobrazení, export"
+msgid "display, export"
+msgstr "zobrazení, export"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Rozli¹ení výstupního souboru (1x, 2x, 4x)"
+msgid "Resolution of output file (single=1, double=2, quad=4)"
+msgstr "Rozli¹ení výstupního souboru (1x, 2x, 4x)"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr "Exportuj monitor do souboru kompatibilním s GpsDrive"
+msgid "Export display monitor to a GpsDrive compatible backdrop image"
+msgstr "Exportuj monitor do souboru kompatibilním s GpsDrive"
-#~ msgid "display, export, GPS"
-#~ msgstr "zobrazení, export, GPS"
+msgid "display, export, GPS"
+msgstr "zobrazení, export, GPS"
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "jméno nového obrázku (bude ulo¾en do ~/.gpsdrive)"
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "jméno nového obrázku (bude ulo¾en do ~/.gpsdrive)"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Vytvoø JPEG místo PNG"
+msgid "Make JPEG instead of PNG image"
+msgstr "Vytvoø JPEG místo PNG"
-#~ msgid ""
-#~ "Divides active display into two frames & displays maps/executes commands "
-#~ "in each frame."
-#~ msgstr ""
-#~ "Rozdìlí aktivní monitor na dva rámy a v ka¾dém rámu zobrazí mapu a pøíkaz "
-#~ "pro její vytvoøení."
+msgid ""
+"Divides active display into two frames & displays maps/executes commands in "
+"each frame."
+msgstr ""
+"Rozdìlí aktivní monitor na dva rámy a v ka¾dém rámu zobrazí mapu a pøíkaz "
+"pro její vytvoøení."
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Rastrová mapa, která má být zobrazena v první rámu"
+msgid "Enter raster map to display in 1st frame"
+msgstr "Rastrová mapa, která má být zobrazena v první rámu"
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Vlo¾te pøíkaz pro vykonání v první rámu"
+msgid "Enter command to execute in 1st frame"
+msgstr "Vlo¾te pøíkaz pro vykonání v první rámu"
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Rastrová mapa, která má být zobrazena v druhém rámu"
+msgid "Enter raster map to display in 2nd frame"
+msgstr "Rastrová mapa, která má být zobrazena v druhém rámu"
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Vlo¾te pøíkaz pro vykonání v druhém rámu"
+msgid "Enter command to execute in 2nd frame"
+msgstr "Vlo¾te pøíkaz pro vykonání v druhém rámu"
-#~ msgid "How to split display"
-#~ msgstr "Jak rozdìlit monitor"
+msgid "How to split display"
+msgstr "Jak rozdìlit monitor"
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Pøekreslí aktuálnì zobrazené mapy v monitoru"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Pøekreslí aktuálnì zobrazené mapy v monitoru"
-#~ msgid "Redraw all frames"
-#~ msgstr "Pøekreslit v¹echny rámy"
+msgid "Redraw all frames"
+msgstr "Pøekreslit v¹echny rámy"
-#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr "Nedor¾ovat individuální regiony pokud pøekraslují v¹echny rámy"
+msgid "Do not preserve individual regions when redrawing all frames"
+msgstr "Nedor¾ovat individuální regiony pokud pøekraslují v¹echny rámy"
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Pøesune aktuálnì zobrazené mapy do jiného monitoru"
+msgid "Moves displayed maps to another monitor"
+msgstr "Pøesune aktuálnì zobrazené mapy do jiného monitoru"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "Vyèisti cílový monitor pøed pøesunem"
+msgid "clear target monitor before moving"
+msgstr "Vyèisti cílový monitor pøed pøesunem"
-#~ msgid "stay with source monitor"
-#~ msgstr "zùstaò ve zdrojovém monitoru"
+msgid "stay with source monitor"
+msgstr "zùstaò ve zdrojovém monitoru"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "zab zdrojový monitor po pøesunu"
+msgid "kill source monitor after moving"
+msgstr "zab zdrojový monitor po pøesunu"
-#~ msgid "Target monitor"
-#~ msgstr "Cílový monitor"
+msgid "Target monitor"
+msgstr "Cílový monitor"
-#~ msgid "Source monitor"
-#~ msgstr "Zdrojový monitor"
+msgid "Source monitor"
+msgstr "Zdrojový monitor"
-#~ msgid "Display manager for GRASS"
-#~ msgstr "GIS manager pro GRASS"
+msgid "Display manager for GRASS"
+msgstr "GIS manager pro GRASS"
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Jméno souboru s nastavením .dmrc"
+msgid "Name of .dmrc settings file"
+msgstr "Jméno souboru s nastavením .dmrc"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Vybere/nastartuje zadaný monitor o zadané velikosti"
+msgid "Selects/starts specified monitor at specified size"
+msgstr "Vybere/nastartuje zadaný monitor o zadané velikosti"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "©íøka nového monitoru v pixelech "
+msgid "Width in pixels of new display monitor"
+msgstr "©íøka nového monitoru v pixelech "
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Vý¹ka nového monitoru v pixelech"
+msgid "Height in pixels of new display monitor"
+msgstr "Vý¹ka nového monitoru v pixelech"
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Ulo¾í obsah aktuálního monitoru jako soubor s obrázkem."
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr "Ulo¾í obsah aktuálního monitoru jako soubor s obrázkem."
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Jméno obrázku (NEpøidávejte koncovku)"
+msgid "Name for output file (do NOT add extension)"
+msgstr "Jméno obrázku (NEpøidávejte koncovku)"
-#~ msgid "Dimensions of output file versus current window size"
-#~ msgstr "Rozmìry výstupu versus souèasná velikost okna"
+msgid "Dimensions of output file versus current window size"
+msgstr "Rozmìry výstupu versus souèasná velikost okna"
-#~ msgid "(same=1, double size=2, quadruple size=4)"
-#~ msgstr "(stejná velikost=1, dvojitá=2, ètyønásobná=4)"
+msgid "(same=1, double size=2, quadruple size=4)"
+msgstr "(stejná velikost=1, dvojitá=2, ètyønásobná=4)"
-#~ msgid "Images"
-#~ msgstr "Obrázky"
+msgid "Images"
+msgstr "Obrázky"
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr "©íøka a vý¹ka výstupního obrazu (pøepí¹e nastavení rozli¹ení)"
+msgid "Width and height of output image (overrides resolution setting)"
+msgstr "©íøka a vý¹ka výstupního obrazu (pøepí¹e nastavení rozli¹ení)"
-#~ msgid "Compression for PNG files"
-#~ msgstr "Komprese pro soubory PNG"
+msgid "Compression for PNG files"
+msgstr "Komprese pro soubory PNG"
-#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr "(0=nic, 1=nejrychleji, 9=bezeztrát; pouze èas vs velikost souboru)"
+msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+msgstr "(0=nic, 1=nejrychleji, 9=bezeztrát; pouze èas vs velikost souboru)"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Velikost/kvalita souboru JPEG"
+msgid "File size/quality for JPEG files"
+msgstr "Velikost/kvalita souboru JPEG"
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=nejmen¹í/nejhor¹í, 100=nejvìt¹í/nejlep¹í)"
+msgid "(10=smallest/worst, 100=largest/best)"
+msgstr "(10=nejmen¹í/nejhor¹í, 100=nejvìt¹í/nejlep¹í)"
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Velikost papíru pro výstup v PostScript."
+msgid "Paper size for PostScript output"
+msgstr "Velikost papíru pro výstup v PostScript."
-#~ msgid "PostScript"
-#~ msgstr "PostScript"
+msgid "PostScript"
+msgstr "PostScript"
-#~ msgid "PostScript level (only limits functionality!)"
-#~ msgstr "Úroveò Postscriptu ( pouze omezuje funkènost!)"
+msgid "PostScript level (only limits functionality!)"
+msgstr "Úroveò Postscriptu ( pouze omezuje funkènost!)"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Nastav barvu pozadí na èernou (bílá je výchozí)"
+msgid "Set background color to black (white default)"
+msgstr "Nastav barvu pozadí na èernou (bílá je výchozí)"
-#~ msgid "Set transparent background"
-#~ msgstr "Nastavit prùhledné pozadí"
+msgid "Set transparent background"
+msgstr "Nastavit prùhledné pozadí"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Pou¾ít ovladaè Cairo pro vykreslení obrazù"
+msgid "Use the Cario driver to render images"
+msgstr "Pou¾ít ovladaè Cairo pro vykreslení obrazù"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr "Nastavit papír na orientaci krajina (pro výstup Postscript)"
+msgid "Set paper orientation to landscape (for PostScript output)"
+msgstr "Nastavit papír na orientaci krajina (pro výstup Postscript)"
-#~ msgid "Illegal output file name"
-#~ msgstr "Neplatný název výstupního souboru"
+msgid "Illegal output file name"
+msgstr "Neplatný název výstupního souboru"
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Povolit interaktivní vyzívání (pouze s pou¾itím pøíkazového øádku)"
+msgid "Enable interactive prompting (for command-line use only)"
+msgstr "Povolit interaktivní vyzívání (pouze s pou¾itím pøíkazového øádku)"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "VAROVÁNÍ!  V této location ji¾ existuje soubor s projekcí\n"
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+"\n"
+"\n"
+"VAROVÁNÍ!  V této location ji¾ existuje soubor s projekcí\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr "Stále si pøejete pøepsat aktuální informace o projekci"
+msgid "Would you still like to overwrite the current projection information "
+msgstr "Stále si pøejete pøepsat aktuální informace o projekci"
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Informace o projekci nebudou aktualizovány."
+msgid "The projection information will not be updated."
+msgstr "Informace o projekci nebudou aktualizovány."
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> je neplatný název regionu"
+msgid "<%s> is an illegal region name"
+msgstr "<%s> je neplatný název regionu"
-#~ msgid "Erasing monitors..."
-#~ msgstr "Ma¾u monitory ... "
+msgid "Erasing monitors..."
+msgstr "Ma¾u monitory ... "
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Umo¾ni probliknutí (pomalej¹í)"
+msgid "Enable flashing (slower)"
+msgstr "Umo¾ni probliknutí (pomalej¹í)"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Prostøední: zmìnit barvu\n"
+msgid " Middle: toggle flash color\n"
+msgstr " Prostøední: zmìnit barvu\n"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Slou¾í k vytvoøení a kontrole grafického monitoru."
+msgid "To establish and control use of a graphics display monitor."
+msgstr "Slou¾í k vytvoøení a kontrole grafického monitoru."
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Jméno grafického monitoru, který bude spu¹tìn"
+msgid "Name of graphics monitor to start"
+msgstr "Jméno grafického monitoru, který bude spu¹tìn"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Jméno grafického monitoru, který bude vypnut"
+msgid "Name of graphics monitor to stop"
+msgstr "Jméno grafického monitoru, který bude vypnut"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Jméno grafického monitoru, který bude vybrán"
+msgid "Name of graphics monitor to select"
+msgstr "Jméno grafického monitoru, který bude vybrán"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Jméno monitoru k odemèení"
+msgid "Name of graphics monitor to unlock"
+msgstr "Jméno monitoru k odemèení"
-#~ msgid "List all monitors"
-#~ msgstr "Seznam v¹ech monitorù"
+msgid "List all monitors"
+msgstr "Seznam v¹ech monitorù"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Seznam monitorù (s aktuálním stavem)"
+msgid "List all monitors (with current status)"
+msgstr "Seznam monitorù (s aktuálním stavem)"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Vypi¹ jméno aktuálnì vybraného monitoru"
+msgid "Print name of currently selected monitor"
+msgstr "Vypi¹ jméno aktuálnì vybraného monitoru"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Uvolni souèasný vybraný monitor"
+msgid "Release currently selected monitor"
+msgstr "Uvolni souèasný vybraný monitor"
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "Nevybírej monitor automaticky pøi startu"
+msgid "Do not automatically select when starting"
+msgstr "Nevybírej monitor automaticky pøi startu"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problém pøi výbìru monitoru %s. Zkusím to je¹tì jednou"
+msgid "Problem selecting %s. Will try once more"
+msgstr "Problém pøi výbìru monitoru %s. Zkusím to je¹tì jednou"
-#~ msgid "Usage:  %s monitor_name"
-#~ msgstr "Pou¾ití: %s jmeno_monitoru"
+msgid "Usage:  %s monitor_name"
+msgstr "Pou¾ití: %s jmeno_monitoru"
-#~ msgid "%s: -%c unrecognized option"
-#~ msgstr "%s: -%c nerozpoznaná volba"
+msgid "%s: -%c unrecognized option"
+msgstr "%s: -%c nerozpoznaná volba"
-#~ msgid "Monitor <%s> released"
-#~ msgstr "monitor <%s> byl uvolnìn"
+msgid "Monitor <%s> released"
+msgstr "monitor <%s> byl uvolnìn"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> je pou¾íván jiným u¾ivatelem"
+msgid "Monitor <%s> in use by another user"
+msgstr "Monitor <%s> je pou¾íván jiným u¾ivatelem"
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "Monitor <%s> neexistuje"
+msgid "No such monitor as <%s>"
+msgstr "Monitor <%s> neexistuje"
-#~ msgid "Failed testing lock mechanism"
-#~ msgstr "Testování uzamykacího mechanismu selhalo"
+msgid "Failed testing lock mechanism"
+msgstr "Testování uzamykacího mechanismu selhalo"
-#~ msgid "Usage:  %s [-fv] [name]"
-#~ msgstr "Pou¾ití: %s [-fv] [jmeno]"
+msgid "Usage:  %s [-fv] [name]"
+msgstr "Pou¾ití: %s [-fv] [jmeno]"
-#~ msgid "Usage: %s [-f] monitor_name"
-#~ msgstr "Pou¾ití: %s [-f] jmeno_monitoru"
+msgid "Usage: %s [-f] monitor_name"
+msgstr "Pou¾ití: %s [-f] jmeno_monitoru"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' ukonèen"
+msgid "Monitor '%s' terminated"
+msgstr "Monitor '%s' ukonèen"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Chyba - Monitor '%s' nebì¾í"
+msgid "Error - Monitor '%s' was not running"
+msgstr "Chyba - Monitor '%s' nebì¾í"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Chyba - Monitor '%s' je pou¾íván jiným u¾ivatelem"
+msgid "Error - Monitor '%s' in use by another user"
+msgstr "Chyba - Monitor '%s' je pou¾íván jiným u¾ivatelem"
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Chyba - selhal zamykací mechanismus"
+msgid "Error - Locking mechanism failed"
+msgstr "Chyba - selhal zamykací mechanismus"
-#~ msgid "No current window"
-#~ msgstr "®ádné aktuální okno"
+msgid "No current window"
+msgstr "®ádné aktuální okno"
-#~ msgid "Current window not available"
-#~ msgstr "Aktuální okno není dostupné"
+msgid "Current window not available"
+msgstr "Aktuální okno není dostupné"
-#~ msgid "Setting map window"
-#~ msgstr "Nastavuji mapové okno"
+msgid "Setting map window"
+msgstr "Nastavuji mapové okno"
-#~ msgid "Getting screen window"
-#~ msgstr "Získání obrazového okna"
+msgid "Getting screen window"
+msgstr "Získání obrazového okna"
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "V aktuálním oknì neexistuje ¾ádná rastrová mapa"
+msgid "No raster map exists in the current window"
+msgstr "V aktuálním oknì neexistuje ¾ádná rastrová mapa"
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Tlaèítka my¹i:"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"Tlaèítka my¹i:"
-#~ msgid "Left:   Select From\n"
-#~ msgstr " Levé:    Vybrat z\n"
+msgid "Left:   Select From\n"
+msgstr " Levé:    Vybrat z\n"
-#~ msgid "Middle: Select To\n"
-#~ msgstr "Prostøední tlaèítko: Vybrat do\n"
+msgid "Middle: Select To\n"
+msgstr "Prostøední tlaèítko: Vybrat do\n"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ " Pravé tlaèítko: ukonèit\n"
-#~ "\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr ""
+" Pravé tlaèítko: ukonèit\n"
+"\n"
-#~ msgid ""
-#~ "g;use the libgis render functions (features: clipping);r;use the raster "
-#~ "graphics library functions (features: polylines);d;use the display "
-#~ "library basic functions (features: polylines);c;use the display library "
-#~ "clipping functions (features: clipping);l;use the display library culling "
-#~ "functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "èára)"
+msgid ""
+"g;use the libgis render functions (features: clipping);r;use the raster "
+"graphics library functions (features: polylines);d;use the display library "
+"basic functions (features: polylines);c;use the display library clipping "
+"functions (features: clipping);l;use the display library culling functions "
+"(features: culling, polylines)"
+msgstr ""
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Nepøidávej do seznamu vektorù a pøíkazù v monitoru (nebude vykresleno, "
-#~ "pokud monitoru bude pøekreslen)"
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+"Nepøidávej do seznamu vektorù a pøíkazù v monitoru (nebude vykresleno, pokud "
+"monitoru bude pøekreslen)"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Nelze vyèistit aktuální okno"
+msgid "Can't clear current graphics window"
+msgstr "Nelze vyèistit aktuální okno"
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Pou¾ít my¹ pro velikost a umístìní legendy"
+msgid "Use mouse to size & place legend"
+msgstr "Pou¾ít my¹ pro velikost a umístìní legendy"
-#~ msgid "No raster map exists in current window"
-#~ msgstr "V aktuálním oknì není ¾ádná rastrová mapa"
+msgid "No raster map exists in current window"
+msgstr "V aktuálním oknì není ¾ádná rastrová mapa"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Název rastrové nebo vektorové mapy, která bude zobrazena"
+msgid "No raster or vector map displayed"
+msgstr "Název rastrové nebo vektorové mapy, která bude zobrazena"
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Jméno  nebo cesta k TTF souboru."
+msgid "Font name or pathname of TTF file"
+msgstr "Jméno  nebo cesta k TTF souboru."
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Nastavuji verzi FreeType"
+msgid "Setting release of FreeType"
+msgstr "Nastavuji verzi FreeType"
-#~ msgid "No current frame"
-#~ msgstr "®ádný aktuální rámec"
+msgid "No current frame"
+msgstr "®ádný aktuální rámec"
-#~ msgid "Current frame not available"
-#~ msgstr "Aktuální rámec není dostupný"
+msgid "Current frame not available"
+msgstr "Aktuální rámec není dostupný"
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Vytvoøí seznam pøíkazù pro obnovení obsahu monitoru."
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr "Vytvoøí seznam pøíkazù pro obnovení obsahu monitoru."
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Název rámu(ù) urèeného k ulo¾ení"
+msgid "Name of frame(s) to save"
+msgstr "Název rámu(ù) urèeného k ulo¾ení"
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Seznam èísel objektù k vyjmutí, které jsou zobrazeny po \"#\" -1 pro "
-#~ "poslední objekt."
+msgid ""
+"List of object numbers to remove which are displayed after \"#\". -1 for the "
+"last object."
+msgstr ""
+"Seznam èísel objektù k vyjmutí, které jsou zobrazeny po \"#\" -1 pro "
+"poslední objekt."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Seznam èísel objektù, které budou pøejmenovány (\"from\" na \"to\"). "
-#~ "Nejprve bude provedena volba remove=."
+msgid ""
+"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
+"done first, if any."
+msgstr ""
+"Seznam èísel objektù, které budou pøejmenovány (\"from\" na \"to\"). Nejprve "
+"bude provedena volba remove=."
-#~ msgid "Save current frame"
-#~ msgstr "Ulo¾ souèasný rám"
+msgid "Save current frame"
+msgstr "Ulo¾ souèasný rám"
-#~ msgid "Save all the frames"
-#~ msgstr "Ulo¾ v¹echny rámy"
+msgid "Save all the frames"
+msgstr "Ulo¾ v¹echny rámy"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Pouze mapové objekty bez extra hlavièky a patièky"
+msgid "Only map objects without extra header and tailer"
+msgstr "Pouze mapové objekty bez extra hlavièky a patièky"
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Neznámý prvek v podlo¾ce: %s"
+msgid "Unknown item type in pad: %s"
+msgstr "Neznámý prvek v podlo¾ce: %s"
-#~ msgid "No current graphics window"
-#~ msgstr "®ádný vybraný monitor"
+msgid "No current graphics window"
+msgstr "®ádný vybraný monitor"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Aktuální monitor není dostupný"
+msgid "Current graphics window not available"
+msgstr "Aktuální monitor není dostupný"
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Chyba pøi výbìru rámce [%s]\n"
+msgid "Error choosing frame [%s]\n"
+msgstr "Chyba pøi výbìru rámce [%s]\n"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Tlaèítka:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"Tlaèítka:\n"
-#~ msgid "Left:   Select frame\n"
-#~ msgstr " Levé:    Vybrat rámec\n"
+msgid "Left:   Select frame\n"
+msgstr " Levé:    Vybrat rámec\n"
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Prostøední: Ponechat pùvodní rám\n"
+msgid "Middle: Keep original frame\n"
+msgstr "Prostøední: Ponechat pùvodní rám\n"
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Pravé: Potvrï rámec\n"
+msgid "Right:  Accept frame\n"
+msgstr "Pravé: Potvrï rámec\n"
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "Správa rámcù v grafickém monitoru"
+msgid "Manages display frames on the user's graphics monitor."
+msgstr "Správa rámcù v grafickém monitoru"
-#~ msgid "Create a new frame"
-#~ msgstr "Vytvoøit nový rámec"
+msgid "Create a new frame"
+msgstr "Vytvoøit nový rámec"
-#~ msgid "Select a frame"
-#~ msgstr "Vybrat rámec"
+msgid "Select a frame"
+msgstr "Vybrat rámec"
-#~ msgid "Print name of current frame"
-#~ msgstr "Vypsat aktuální rámec"
+msgid "Print name of current frame"
+msgstr "Vypsat aktuální rámec"
-#~ msgid "Print names of all frames"
-#~ msgstr "Vytisknout jména v¹ech rámcù"
+msgid "Print names of all frames"
+msgstr "Vytisknout jména v¹ech rámcù"
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Vypi¹ jména map zobrazených v grafickém monitoru"
+msgid "List map names displayed in GRASS monitor"
+msgstr "Vypi¹ jména map zobrazených v grafickém monitoru"
-#~ msgid "Debugging output"
-#~ msgstr "Roz¹íøený výstup"
+msgid "Debugging output"
+msgstr "Roz¹íøený výstup"
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Rámec, který má být vytvoøen/vybrán"
+msgid "Frame to be created/selected"
+msgstr "Rámec, který má být vytvoøen/vybrán"
-#~ msgid "bottom,top,left,right"
-#~ msgstr "spodní,svrchní,levý,pravý"
+msgid "bottom,top,left,right"
+msgstr "spodní,svrchní,levý,pravý"
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Kam umístit rám, hodnoty v procentech (potøebuje volbu -c)"
+msgid "Where to place the frame, values in percent (implies -c)"
+msgstr "Kam umístit rám, hodnoty v procentech (potøebuje volbu -c)"
-#~ msgid "Setting graphics window"
+msgid "Setting graphics window"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Pou¾ívám souøadnice monitoru"
+msgid "Getting graphics window coordinates"
+msgstr "Pou¾ívám souøadnice monitoru"
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Vytvoøí a zobrazí jednoduché grafické prvky na mapì vykreslené v aktivním "
-#~ "grafickém monitoru."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+"Vytvoøí a zobrazí jednoduché grafické prvky na mapì vykreslené v aktivním "
+"grafickém monitoru."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Soubor (Unix) obsahující grafické instrukce, pokud není zadáno, ète se "
-#~ "standardní vstup"
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+"Soubor (Unix) obsahující grafické instrukce, pokud není zadáno, ète se "
+"standardní vstup"
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Barva kresby, buï standardní GRASS barva nebo trojice R:G:B (oddìleno "
-#~ "dvojteèkou)"
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Barva kresby, buï standardní GRASS barva nebo trojice R:G:B (oddìleno "
+"dvojteèkou)"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Nepøidávat do seznamu rastrù a pøíkazù v monitoru"
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr "Nepøidávat do seznamu rastrù a pøíkazù v monitoru"
-#~ msgid "Interactively select route"
-#~ msgstr "Interaktivní výbìr trasy"
+msgid "Interactively select route"
+msgstr "Interaktivní výbìr trasy"
-#~ msgid "You must select more than one point"
-#~ msgstr "Je potøeba vybrat více ne¾ jeden bod"
+msgid "You must select more than one point"
+msgstr "Je potøeba vybrat více ne¾ jeden bod"
-#~ msgid "You must select at least four points"
-#~ msgstr "Musíte vybrat nejménì ètyøi body."
+msgid "You must select at least four points"
+msgstr "Musíte vybrat nejménì ètyøi body."
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Pou¾ít my¹ pro umístìní mìøítka"
+msgid "Use mouse to interactively place scale"
+msgstr "Pou¾ít my¹ pro umístìní mìøítka"
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr "Vytvoøit a zobrazit menu v aktivní rámci grafického monitoru."
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "Vytvoøit a zobrazit menu v aktivní rámci grafického monitoru."
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "Nastaví barvu pozadí menu"
+msgid "Sets the color of the menu background"
+msgstr "Nastaví barvu pozadí menu"
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Nastavit barvu textu v menu"
+msgid "Sets the color of the menu text"
+msgstr "Nastavit barvu textu v menu"
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Nastaví barvu linií oddìlujících øádky textu"
+msgid "Sets the color dividing lines of text"
+msgstr "Nastaví barvu linií oddìlujících øádky textu"
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Nastaví velikost písma v menu (procenta)"
+msgid "Sets the menu text size (in percent)"
+msgstr "Nastaví velikost písma v menu (procenta)"
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Menu musí obsahovat titulek a nejménì jednu volbu"
+msgid "Menu must contain a title and at least one option"
+msgstr "Menu musí obsahovat titulek a nejménì jednu volbu"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Nepøidávat do seznamu v monitoru pøíkazy"
+msgid "Don't add to list of commands in monitor"
+msgstr "Nepøidávat do seznamu v monitoru pøíkazy"
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Pou¾ít my¹ pro umístìní textu"
+msgid "Use mouse to interactively place text"
+msgstr "Pou¾ít my¹ pro umístìní textu"
-#~ msgid "Click!\n"
-#~ msgstr "Klik!\n"
+msgid "Click!\n"
+msgstr "Klik!\n"
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Levé:    Vlo¾it text sem\n"
+msgid " Left:    Place text here\n"
+msgstr " Levé:    Vlo¾it text sem\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Pravé :   ukonèit\n"
+msgid " Right:   Quit\n"
+msgstr " Pravé :   ukonèit\n"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "hodnota [%.0f,%.0f] je mimo interval [0-100]"
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr "hodnota [%.0f,%.0f] je mimo interval [0-100]"
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Vykreslí text v aktivním rámci grafického monitoru s vyu¾itím písma "
-#~ "TrueType"
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr ""
+"Vykreslí text v aktivním rámci grafického monitoru s vyu¾itím písma TrueType"
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Souøadnice v procentech rámce ([0,0] je vlevo dole)"
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr "Souøadnice v procentech rámce ([0,0] je vlevo dole)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Cesta k TrueType fontùm (vèetnì jména souboru)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Cesta k TrueType fontùm (vèetnì jména souboru)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Vý¹ka písmen (v procentech dostupné vý¹ky rámce)"
+msgid "Height of letters (in percent of available frame height)"
+msgstr "Vý¹ka písmen (v procentech dostupné vý¹ky rámce)"
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Mìl by být zadán buï text nebo -c"
+msgid "Either text or -c should be given"
+msgstr "Mìl by být zadán buï text nebo -c"
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Vyberte pro umístìní pouze jeden souøadnicový systém"
+msgid "Choose only one coordinate system for placement"
+msgstr "Vyberte pro umístìní pouze jeden souøadnicový systém"
-#~ msgid "No font selected"
-#~ msgstr "Nebylo vybráno ¾ádné písmo"
+msgid "No font selected"
+msgstr "Nebylo vybráno ¾ádné písmo"
-#~ msgid "Invalid font: %s"
-#~ msgstr "Chybné písmo: %s"
+msgid "Invalid font: %s"
+msgstr "Chybné písmo: %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Nelze vytvoøit textovou konverzi kontextu"
+msgid "Unable to create text conversion context"
+msgstr "Nelze vytvoøit textovou konverzi kontextu"
-#~ msgid "Text conversion error"
-#~ msgstr "Chyba pøi konverzi textu"
+msgid "Text conversion error"
+msgstr "Chyba pøi konverzi textu"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Nelze zapisovat do doèasného souboru"
+msgid "Unable to write the temporary file"
+msgstr "Nelze zapisovat do doèasného souboru"
-#~ msgid "No predefined font"
-#~ msgstr "®ádné pøeddefinované písmo"
+msgid "No predefined font"
+msgstr "®ádné pøeddefinované písmo"
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: Nelze èíst písmo"
+msgid "%s: Unable to read font"
+msgstr "%s: Nelze èíst písmo"
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr "%s: Nelze èíst definièní soubor FreeType; pou¾iji výchozí"
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: Žádný definièní soubor FreeType"
+msgid "%s: No FreeType definition file"
+msgstr "%s: Žádný definièní soubor FreeType"
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: Nelze èíst definièní soubor FreeType"
+msgid "%s: Unable to read FreeType definition file"
+msgstr "%s: Nelze èíst definièní soubor FreeType"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Pouze pøekresli zobrazené mapy s výchozími barvami."
+msgid "Just redraw given maps using default colors"
+msgstr "Pouze pøekresli zobrazené mapy s výchozími barvami."
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "CHYBA: nelze získat polo¾ky \"list\""
+msgid "ERROR: can not get \"list\" items"
+msgstr "CHYBA: nelze získat polo¾ky \"list\""
-#~ msgid "-j flag forced"
-#~ msgstr "volba -j byla nastavena nucenì"
+msgid "-j flag forced"
+msgstr "volba -j byla nastavena nucenì"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Nebyla zobrazena ¾ádná mapa v monitoru GRASSu"
+msgid "No map is displayed in GRASS monitor"
+msgstr "Nebyla zobrazena ¾ádná mapa v monitoru GRASSu"
-#~ msgid "One mouse click only"
-#~ msgstr "Pouze jedno kliknutí my¹í"
+msgid "One mouse click only"
+msgstr "Pouze jedno kliknutí my¹í"
-#~ msgid "Quiet; No chatter"
-#~ msgstr "Ti¹e; ¾ádné zprávy"
+msgid "Quiet; No chatter"
+msgstr "Ti¹e; ¾ádné zprávy"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coor():  Opou¹tím sezení...\n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr "ask_transform_coor():  Opou¹tím sezení...\n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr " Poèet zadaných bodù: %d\n"
+msgid " Number of points that have been entered: %d\n"
+msgstr " Poèet zadaných bodù: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Odpovìzte prosím yes (ano) nebo no (ne)"
+msgid "Please answer yes or no"
+msgstr "Odpovìzte prosím yes (ano) nebo no (ne)"
 #, fuzzy
-#~ msgid "No attribute table found"
-#~ msgstr "Atribut(y) nenalezeny"
+msgid "No attribute table found"
+msgstr "Atribut(y) nenalezeny"
 #, fuzzy
-#~ msgid "No numerical attributes found. Skipping export"
-#~ msgstr "Nic nebylo nalezeno, pøeskakuji type=poly"
+msgid "No numerical attributes found. Skipping export"
+msgstr "Nic nebylo nalezeno, pøeskakuji type=poly"
 #, fuzzy
-#~ msgid "Error reading value of attribute '%s'"
-#~ msgstr "Chyba pøi ètení kategorií: '%s'"
+msgid "Error reading value of attribute '%s'"
+msgstr "Chyba pøi ètení kategorií: '%s'"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Ti¹e - potlaè hlá¹ení o prùbìhu zpracování"
+msgid "Quiet - Do not show progress"
+msgstr "Ti¹e - potlaè hlá¹ení o prùbìhu zpracování"
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Neplatný název výstupního souboru <%s>"
+msgid "Illegal output file name <%s>"
+msgstr "Neplatný název výstupního souboru <%s>"
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead"
-#~ msgstr ""
-#~ "Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, "
-#~ "peou¾ijte pøepínaè '--quiet'."
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead"
+msgstr ""
+"Pøepínaè '-q' je zastaralý a bude v budoucnosti odstranìn. prosím, peou¾ijte "
+"pøepínaè '--quiet'."
-#~ msgid "Quietly"
-#~ msgstr "Potichu"
+msgid "Quietly"
+msgstr "Potichu"
 #, fuzzy
-#~ msgid "Name of terrain raster map (DEM)"
-#~ msgstr "Mapa s modelem terénu (DMT)"
+msgid "Name of terrain raster map (DEM)"
+msgstr "Mapa s modelem terénu (DMT)"
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "Schopnost spoèítat tabulku koincidence\n"
+msgid "GIS Coincidence Tabulation Facility\n"
+msgstr "Schopnost spoèítat tabulku koincidence\n"
-#~ msgid ""
-#~ "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr ""
-#~ "Tento nástroj vám umo¾ní porovnat coincidence dvou mapových vrstev\n"
+msgid ""
+"This utility will allow you to compare the coincidence of two map layers\n"
+msgstr "Tento nástroj vám umo¾ní porovnat coincidence dvou mapových vrstev\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "Zprávu lze vytvoøit za pomoci nìkteré z osmi jednotek."
+msgid "The report can be made in one of 8 units."
+msgstr "Zprávu lze vytvoøit za pomoci nìkteré z osmi jednotek."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Vyberte prosím jednotky zadáním jednoho z následujících písmen:"
+msgid "Please choose a unit by entering one of the following letter codes:"
+msgstr "Vyberte prosím jednotky zadáním jednoho z následujících písmen:"
-#~ msgid "     'c': cells"
-#~ msgstr "    'c': pixely"
+msgid "     'c': cells"
+msgstr "    'c': pixely"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': procenta pokryvnosti regionu"
+msgid "     'p': percent cover of region"
+msgstr "     'p': procenta pokryvnosti regionu"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': procenta '%s' kategorie (sloupec)"
+msgid "     'x': percent of '%s' category (column)"
+msgstr "     'x': procenta '%s' kategorie (sloupec)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': procenta '%s' kategorie (øádek)"
+msgid "     'y': percent of '%s' category (row)"
+msgstr "     'y': procenta '%s' kategorie (øádek)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': akry"
+msgid "     'a': acres"
+msgstr "     'a': akry"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': hektary"
+msgid "     'h': hectares"
+msgstr "     'h': hektary"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': ètvereèní kilometry"
+msgid "     'k': square kilometers"
+msgstr "     'k': ètvereèní kilometry"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': ètvereèní míle\n"
+msgid "     'm': square miles\n"
+msgstr "     'm': ètvereèní míle\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': konec"
+msgid "     'Q': quit"
+msgstr "     'Q': konec"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "Pøejete si ulo¾it tuto zprávu do souboru? (y/n) [n] "
+msgid "Do you wish to save this report in a file? (y/n) [n] "
+msgstr "Pøejete si ulo¾it tuto zprávu do souboru? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Zadejte jméno souboru\n"
+msgid ""
+"Enter the file name or path\n"
+msgstr ""
+"Zadejte jméno souboru\n"
-#~ msgid "'%s' being saved\n"
-#~ msgstr "'%s' ulo¾en\n"
+msgid "'%s' being saved\n"
+msgstr "'%s' ulo¾en\n"
-#~ msgid ""
-#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr ""
-#~ "Pøejete si vytisknout tuto zprávu (vy¾aduje Unixový pøíkaz lpr)? (y/n) "
-#~ "[n] "
+msgid ""
+"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr ""
+"Pøejete si vytisknout tuto zprávu (vy¾aduje Unixový pøíkaz lpr)? (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "Pøejete si vytisknout ji v 80 nebo 132 sloupcích?\n"
+msgid ""
+"Do you wish it printed in 80 or 132 columns?\n"
+msgstr ""
+"Pøejete si vytisknout ji v 80 nebo 132 sloupcích?\n"
-#~ msgid ""
-#~ "Do you wish to run this report with a different unit of measure? (y/n) "
-#~ "[y] "
-#~ msgstr "Pøejete si vytvoøit tuto zprávu s rùznými jednotkami? (y/n) [y]"
+msgid ""
+"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgstr "Pøejete si vytvoøit tuto zprávu s rùznými jednotkami? (y/n) [y]"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Interaktivní výbìr koncových bodù"
+msgid "Interactively select End-Points"
+msgstr "Interaktivní výbìr koncových bodù"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
+msgid "Use mouse to select Start Point\n"
+msgstr "Pro výbìr poèáteèního bodu pou¾ijte my¹\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Pou¾ít my¹ pro kreslení linie profilu\n"
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr ""
+"\n"
+"Pou¾ít my¹ pro kreslení linie profilu\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Tlaèítka:\n"
+msgid "Buttons:\n"
+msgstr "Tlaèítka:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Levé tlaèítko:  Oznaè dal¹í bod\n"
+msgid "Left:   Mark next point\n"
+msgstr "Levé tlaèítko:  Oznaè dal¹í bod\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
+msgid "Middle: Mark next point\n"
+msgstr "Prostøední tlaèítko: Oznaè dal¹í bod\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Pravé:  ukonèit profil a opustit\n"
-#~ "\n"
+msgid ""
+"Right:  Finish profile and exit\n"
+"\n"
+msgstr ""
+"Pravé:  ukonèit profil a opustit\n"
+"\n"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Potlaè chybové zprávy o pøekrytí"
+msgid "Suppress single crossing error messages"
+msgstr "Potlaè chybové zprávy o pøekrytí"
-#~ msgid ""
-#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
-#~ "Please use '--quiet' instead."
-#~ msgstr ""
-#~ "Volby '-q' a '-n' jsou zastaralé a budou v budoucnu odstranìny. Prosím "
-#~ "pou¾ijte pøepínaè '--quiet'."
+msgid ""
+"The '-q' and '-n' flag is superseded and will be removed in future. Please "
+"use '--quiet' instead."
+msgstr ""
+"Volby '-q' a '-n' jsou zastaralé a budou v budoucnu odstranìny. Prosím "
+"pou¾ijte pøepínaè '--quiet'."
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Nástroj pro bilineární interpolaci rastrových map."
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "Nástroj pro bilineární interpolaci rastrových map."
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "Specifická hodnota vstupu, která bude pøiøa¾ena severnímu a/nebo ji¾nímu "
-#~ "pólu pro rastrové mapy v systému zem. délka/¹íøka"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr ""
+"Specifická hodnota vstupu, která bude pøiøa¾ena severnímu a/nebo ji¾nímu "
+"pólu pro rastrové mapy v systému zem. délka/¹íøka"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "Tento modul je zastaralý. Prosím, pou¾ijte 'r.stats.interp'."
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr "Tento modul je zastaralý. Prosím, pou¾ijte 'r.stats.interp'."
-#~ msgid "Path to rules file"
-#~ msgstr "Cesta k souboru s pravidly"
+msgid "Path to rules file"
+msgstr "Cesta k souboru s pravidly"
-#~ msgid "Enter rules interactively"
-#~ msgstr "Spustit interaktivnì"
+msgid "Enter rules interactively"
+msgstr "Spustit interaktivnì"
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "Interaktivní mód nelze pou¾ít s volbami \"barva\", \"pravidlo\", a \"rastr"
+msgid ""
+"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
+"options"
+msgstr ""
+"Interaktivní mód nelze pou¾ít s volbami \"barva\", \"pravidlo\", a \"rastr\" "
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Který vektorový soubor vy¾aduje aktualizované kategorie?"
+msgid "Which vector map needs updated categories?"
+msgstr "Který vektorový soubor vy¾aduje aktualizované kategorie?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Který rastrový soubor vy¾aduje aktualizované kategorie?"
+msgid "Which raster map needs updated categories?"
+msgstr "Který rastrový soubor vy¾aduje aktualizované kategorie?"
-#~ msgid "%s map <%s> not found"
-#~ msgstr "%s mapa <%s> nebyla nalezena"
+msgid "%s map <%s> not found"
+msgstr "%s mapa <%s> nebyla nalezena"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Soubor s kategoriemi pro <%s> nebyl aktualizován."
+msgid "Category file for <%s> not updated"
+msgstr "Soubor s kategoriemi pro <%s> nebyl aktualizován."
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Soubor s kategoriemi pro <%s> byl aktualizován."
+msgid "Category file for <%s> updated"
+msgstr "Soubor s kategoriemi pro <%s> byl aktualizován."
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Stiknìte RETURN pro pokraèování -->"
+msgid ""
+"\n"
+"Hit RETURN to continue -->"
+msgstr ""
+"\n"
+"Stiknìte RETURN pro pokraèování -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Editovat hlavièku pro [%s]?"
+msgid "Edit header for [%s]? "
+msgstr "Editovat hlavièku pro [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "POZNÁMKA: [%s] je reklasifikací [%s z %s]"
+msgid ""
+"\n"
+"NOTE: [%s] is a reclass of [%s in %s]"
+msgstr ""
+"\n"
+"POZNÁMKA: [%s] je reklasifikací [%s z %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Stornování editace hlavièky."
+msgid "Canceling from edit header."
+msgstr "Stornování editace hlavièky."
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Editace souboru s kategoriemi pro [%s]? "
+msgid "Edit the category file for [%s]? "
+msgstr "Editace souboru s kategoriemi pro [%s]? "
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Vytvoøení/Aktualizace tabulky barev pro [%s]?"
+msgid "Create/Update the color table for [%s]? "
+msgstr "Vytvoøení/Aktualizace tabulky barev pro [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Editace souboru s historií pro [%s]?"
+msgid "Edit the history file for [%s]? "
+msgstr "Editace souboru s historií pro [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "Soubor \"null\" pro [%s] mù¾e naznaèovat, ¾e nìkteré buòky obsahují\n"
-#~ " \"¾ádná data\". Pokud tento soubor pro [%s] neexistuje, pak jsou nulové "
-#~ "buòky\n"
-#~ "interpretovány moduly GRASSu jako \"¾ádná data\"."
+msgid ""
+"\n"
+"The null file for [%s] may indicate that some cells contain\n"
+" no data. If the null file for [%s] doesn't exist, zero cells in\n"
+" it are treated by GRASS application programs as no data."
+msgstr ""
+"\n"
+"Soubor \"null\" pro [%s] mù¾e naznaèovat, ¾e nìkteré buòky obsahují\n"
+" \"¾ádná data\". Pokud tento soubor pro [%s] neexistuje, pak jsou nulové "
+"buòky\n"
+"interpretovány moduly GRASSu jako \"¾ádná data\"."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Pøejete si vytvoøit/obnovit soubor \"null\" pro [%s], tak¾e hodnoty bunìk "
-#~ "NULL budou pova¾ovány za platná data?"
+msgid ""
+"\n"
+"Do you want to create/reset the null file for [%s] so that null cell values "
+"are considered valid data? "
+msgstr ""
+"\n"
+"Pøejete si vytvoøit/obnovit soubor \"null\" pro [%s], tak¾e hodnoty bunìk "
+"NULL budou pova¾ovány za platná data?"
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Pøejete si odstranit soubor \"null\" pro [%s]\n"
-#~ "(v¹echny nulové buòky budou poté pova¾ovány za \"no data\")?"
+msgid ""
+"\n"
+"Do you want to delete the null file for [%s]\n"
+"(all zero cells will then be considered no data)? "
+msgstr ""
+"\n"
+"Pøejete si odstranit soubor \"null\" pro [%s]\n"
+"(v¹echny nulové buòky budou poté pova¾ovány za \"no data\")?"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Který rastrový soubor vy¾aduje aktualizovanou historii? "
+msgid "Which raster map needs an updated history? "
+msgstr "Který rastrový soubor vy¾aduje aktualizovanou historii? "
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Rastrový soubor [%s] nebyl nalezen. Ukonèuji se."
+msgid "Raster file [%s] not found. Exiting."
+msgstr "Rastrový soubor [%s] nebyl nalezen. Ukonèuji se."
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Soubor s historií pro [%s] byl aktualizován."
+msgid "History file for [%s] updated."
+msgstr "Soubor s historií pro [%s] byl aktualizován."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Soubor s historií pro [%s] nebyl aktualizován."
+msgid "History file for [%s] not updated."
+msgstr "Soubor s historií pro [%s] nebyl aktualizován."
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Který rastrový soubor vy¾aduje tabulku barev"
+msgid "Which raster map needs a color table"
+msgstr "Který rastrový soubor vy¾aduje tabulku barev"
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Tabulka barev pro <%s> byla aktualizována"
+msgid "Color table for <%s> updated"
+msgstr "Tabulka barev pro <%s> byla aktualizována"
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Stisknìte RETURN pro pokraèování -->"
+msgid ""
+"\n"
+"hit RETURN to continue -->"
+msgstr ""
+"\n"
+"Stisknìte RETURN pro pokraèování -->"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Edituj hlavièku pro [%s]\n"
+msgid "Edit header for [%s]\n"
+msgstr "Edituj hlavièku pro [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "[%s] nemù¾e být nalezen!"
+msgid "[%s] cannot be found!"
+msgstr "[%s] nemù¾e být nalezen!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "Pro kterou vrstvu má být upraven soubor s hlavièkou? "
+msgid "For what layer shall the header file be edited? "
+msgstr "Pro kterou vrstvu má být upraven soubor s hlavièkou? "
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] je reklasifikací [%s] - nemohu upravit hlavièku! Spus»te r.support "
-#~ "pro [%s]."
+msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgstr ""
+"[%s] je reklasifikací [%s] - nemohu upravit hlavièku! Spus»te r.support pro "
+"[%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "[%s] je reklasifikací [%s v %s] - nemohu upravit hlavièku!"
+msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
+msgstr "[%s] je reklasifikací [%s v %s] - nemohu upravit hlavièku!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Nelze otevøít rastrový soubor [%s]!"
+msgid "Cannot open raster map [%s]!"
+msgstr "Nelze otevøít rastrový soubor [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Rastrový soubor [%s] je prázdný."
+msgid "Raster file [%s] is empty."
+msgstr "Rastrový soubor [%s] je prázdný."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Chyba pøi ètení rastrového souboru [%s]."
+msgid "Error reading raster map [%s]."
+msgstr "Chyba pøi ètení rastrového souboru [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "komprese cellhd: %d\n"
+msgid "cellhd compression: %d\n"
+msgstr "komprese cellhd: %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "%sindikována 3.0 komprese\n"
+msgid "3.0 compression %sindicated\n"
+msgstr "%sindikována 3.0 komprese\n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "%sindikována pøedbì¾ná 3.0 komprese\n"
+msgid "Pre 3.0 compression %sindicated\n"
+msgstr "%sindikována pøedbì¾ná 3.0 komprese\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] se jeví jako komprimovaný. Je tomu tak?"
+msgid "[%s] appears to be compressed. Is it? "
+msgstr "[%s] se jeví jako komprimovaný. Je tomu tak?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Prosím, udejte typ komprese:\n"
+msgid "Please indicate the type of compression:\n"
+msgstr "Prosím, udejte typ komprese:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "  1. Pøedbì¾ná 3.0 komprese\n"
+msgid "  1. Pre 3.0 compression\n"
+msgstr "  1. Pøedbì¾ná 3.0 komprese\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "  2. 3.0 komprese\n"
+msgid "  2. 3.0 compression\n"
+msgstr "  2. 3.0 komprese\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "Hlavièka pro [%s] øíká, ¾e soubor není komprimován. "
+msgid "The header for [%s] says the file is not compressed. "
+msgstr "Hlavièka pro [%s] øíká, ¾e soubor není komprimován. "
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Soubor se ukazuje být komprimován.\n"
+msgid "The file appears to be compressed.\n"
+msgstr "Soubor se ukazuje být komprimován.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "Hlavièka je pravdìpodobnì chybná, rozhodnutí je na Vás.\n"
+msgid "Most likely the header is wrong, but I want you to decide.\n"
+msgstr "Hlavièka je pravdìpodobnì chybná, rozhodnutí je na Vás.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "Hlavièka pro [%s] øíká, ¾e je soubor komprimován. "
+msgid "The header for [%s] says the file is compressed. "
+msgstr "Hlavièka pro [%s] øíká, ¾e je soubor komprimován. "
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr ""
-#~ "Soubor se NEJEVÍ jako komprimovaný.\n"
-#~ "\n"
+msgid "The file does NOT appear to be compressed.\n"
+msgstr ""
+"Soubor se NEJEVÍ jako komprimovaný.\n"
+"\n"
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "Hlavièka uvádí %d øádkù %s v souboru, ale platný formát souboru uvádí %d "
-#~ "øádkù %s"
+msgid ""
+"Header indicates %d row%s in the raster map, but the actual file format "
+"indicates %d row%s"
+msgstr ""
+"Hlavièka uvádí %d øádkù %s v souboru, ale platný formát souboru uvádí %d "
+"øádkù %s"
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Nejsem schopen zapsat hlavièku pro [%s]"
+msgid "Unable to write header for [%s]."
+msgstr "Nejsem schopen zapsat hlavièku pro [%s]"
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Hlavièka rastrového souboru [%s] byla aktualizována."
+msgid "Header for raster map [%s] updated."
+msgstr "Hlavièka rastrového souboru [%s] byla aktualizována."
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Prosím, zadejte následující informace pro [%s]:"
+msgid "Please enter the following information for [%s]:"
+msgstr "Prosím, zadejte následující informace pro [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Poèet øádkù"
+msgid "        Number of rows"
+msgstr "        Poèet øádkù"
-#~ msgid "        Number of cols"
-#~ msgstr "        Poèet sloupcù"
+msgid "        Number of cols"
+msgstr "        Poèet sloupcù"
-#~ msgid "        Floating point map"
-#~ msgstr "        Mapa s plovoucí desetinnou èárkou"
+msgid "        Floating point map"
+msgstr "        Mapa s plovoucí desetinnou èárkou"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "øádky * sloupce * byty na buòku musí mít stejnou velikost jako soubor (%"
-#~ "lu)"
+msgid "rows * cols * bytes per cell must be same as file size (%lu)"
+msgstr ""
+"øádky * sloupce * byty na buòku musí mít stejnou velikost jako soubor (%lu)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Pokud potøebujete pomoc s vyèíslením, stisknìte ESC"
+msgid "If you need help figuring them out, just hit ESC"
+msgstr "Pokud potøebujete pomoc s vyèíslením, stisknìte ESC"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Záporné hodnoty nejsou povoleny!"
+msgid "** Negative values not allowed!"
+msgstr "** Záporné hodnoty nejsou povoleny!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Pouze kladné hodnoty, prosím!"
+msgid "** Positive values only please!"
+msgstr "** Pouze kladné hodnoty, prosím!"
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "Neplatný název souboru pro reálnou èást: %s"
+msgid "Illegal file name for real part: %s"
+msgstr "Neplatný název souboru pro reálnou èást: %s"
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "Neplatný název pro imaginární èást: %s"
+msgid "Illegal file name for imaginary part: %s"
+msgstr "Neplatný název pro imaginární èást: %s"
-#~ msgid "name=%s\n"
-#~ msgstr "name=%s\n"
+msgid "name=%s\n"
+msgstr "name=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "mapset=%s\n"
+msgid "mapset=%s\n"
+msgstr "mapset=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "fullname=%s\n"
+msgid "fullname=%s\n"
+msgstr "fullname=%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "pou¾ití: %s soubor [prompt %%x %%y]\n"
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr "pou¾ití: %s soubor [prompt %%x %%y]\n"
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Neplatné jméno skupiny <%s>"
+msgid "Illegal group name <%s>"
+msgstr "Neplatné jméno skupiny <%s>"
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Neplatný název souboru se signaturami <%s>."
+msgid "Illegal signature file name <%s>"
+msgstr "Neplatný název souboru se signaturami <%s>."
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Volitelná podmínka where (bez klíèového slova WHERE), napø.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Volitelná podmínka where (bez klíèového slova WHERE), napø.:\n"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- neplatný název souboru výsledných pøíznakù"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr ""
+"\n"
+"<%s> -- neplatný název souboru výsledných pøíznakù"
Modified: grass/trunk/locale/po/grassmods_de.po
--- grass/trunk/locale/po/grassmods_de.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_de.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -28073,3966 +28073,3941 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Kann folgende Attribute nicht auswählen: %s"
-#~ msgid ""
-#~ msgstr ""
-#~ "Optionale 'where'-Angabe (ohne 'WHERE' Schlüsselwort), z.B.:\n"
+msgid ""
+msgstr ""
+"Optionale 'where'-Angabe (ohne 'WHERE' Schlüsselwort), z.B.:\n"
-#~ msgstr "Ungültiger Ausgabedateiname"
+msgstr "Ungültiger Ausgabedateiname"
-#~ msgstr "Breite des neuen Grafik-Fensters in Pixel."
+msgstr "Breite des neuen Grafik-Fensters in Pixel."
-#~ msgstr "Höhe des neuen Grafik-Fensters in Pixel."
+msgstr "Höhe des neuen Grafik-Fensters in Pixel."
 #, fuzzy
-#~ msgstr ""
-#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
+msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
 #, fuzzy
-#~ msgstr "Verarbeite Punkte ... "
+msgstr "Verarbeite Punkte ... "
-#~ msgstr "Quell Grafik-Fenster."
+msgstr "Quell Grafik-Fenster."
 #, fuzzy
-#~ msgstr "Darstellung, Export"
+msgstr "Darstellung, Export"
-#~ msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
+msgstr "Erstelle ein JPEG anstelle des PNG Bildes."
 #, fuzzy
 #, fuzzy
-#~ msgstr ""
-#~ "Löscht den Inhalte des aktiven Grafik-Fensters mit einer "
-#~ "benutzerdefinierten Farbe."
+msgstr ""
+"Löscht den Inhalte des aktiven Grafik-Fensters mit einer benutzerdefinierten "
+"Farbe."
 #, fuzzy
-#~ msgstr "Name der PNG-Datei."
+msgstr "Name der PNG-Datei."
 #, fuzzy
-#~ msgstr "PostScript Ausgabedatei"
+msgstr "PostScript Ausgabedatei"
 #, fuzzy
+msgid "PostScript"
 #, fuzzy
-#~ msgstr "Bestimmt die Farbe des Menü Hintergrunds."
+msgstr "Bestimmt die Farbe des Menü Hintergrunds."
 #, fuzzy
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "Zeigt einen Maßstabsbalken im Grafik-Fenster an."
 #, fuzzy
-#~ msgid "omit entries with missing label"
-#~ msgstr "Überspringe Kategorien ohne Label."
+msgid "omit entries with missing label"
+msgstr "Überspringe Kategorien ohne Label."
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Wie oft soll der Filter wiederholt werden?"
+msgid "Number of lines to appear in the legend"
+msgstr "Wie oft soll der Filter wiederholt werden?"
 #, fuzzy
-#~ msgstr "Im Grafik-Fenster ist keine Karte dargestellt."
+msgstr "Im Grafik-Fenster ist keine Karte dargestellt."
 #, fuzzy
-#~ msgstr "Speichere alle Rahmen ab."
+msgstr "Speichere alle Rahmen ab."
 #, fuzzy
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Zeige Informationen über das aktive Grafik-Fenster."
+msgid "Resizes active display monitor"
+msgstr "Zeige Informationen über das aktive Grafik-Fenster."
-#~ msgid "New width for window"
-#~ msgstr "Neue Fensterbreite."
+msgid "New width for window"
+msgstr "Neue Fensterbreite."
-#~ msgid "New height for window"
-#~ msgstr "Neue Fensterhöhe."
+msgid "New height for window"
+msgstr "Neue Fensterhöhe."
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "von"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "von"
 #, fuzzy
-#~ msgid "display, slideshow"
-#~ msgstr "Darstellung, Setup"
+msgid "display, slideshow"
+msgstr "Darstellung, Setup"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Setze Region angepasst an diese Rasterkarte."
+msgid "Show vector maps rather than raster maps"
+msgstr "Setze Region angepasst an diese Rasterkarte."
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Anzahl der Zellen zwischen Fließlinien."
+msgid "Number of seconds to pause between slides"
+msgstr "Anzahl der Zellen zwischen Fließlinien."
 #, fuzzy
-#~ msgstr "Name der Rasterkarte, die angezeigt werden soll."
+msgstr "Name der Rasterkarte, die angezeigt werden soll."
-#~ msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
+msgstr "Geben Sie den Befehl an, der im 1. Rahmen ausgeführt werden soll."
 #, fuzzy
-#~ msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
+msgstr "Geben Sie den Befehl an, der im 2. Rahmen ausgeführt werden soll."
 #, fuzzy
-#~ msgstr "Darzustellender Text"
+msgstr "Darzustellender Text"
 #, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "Drehe Legende."
+msgid "display, legend"
+msgstr "Drehe Legende."
 #, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Vektorkartentyp."
+msgid "Vector map to display thematically"
+msgstr "Vektorkartentyp."
-#~ msgid "Theme_prefs"
-#~ msgstr "Theme_prefs"
+msgid "Theme_prefs"
+msgstr "Theme_prefs"
 #, fuzzy
-#~ msgid "Vector map type"
+msgid "Vector map type"
 #, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "Attribut-Spalte, die für die Pufferdistanz benutzt werden soll."
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr "Attribut-Spalte, die für die Pufferdistanz benutzt werden soll."
 #, fuzzy
-#~ msgid "Type of thematic display"
+msgid "Type of thematic display"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Text für einen neuen Kartentitel."
+msgid "Layer to use for thematic display"
+msgstr "Text für einen neuen Kartentitel."
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "Drucke"
+msgid "Points"
+msgstr "Drucke"
 #, fuzzy
-#~ msgid "Vector point icon for point data"
-#~ msgstr "Vektordatei die Beispielpunkte enthält."
+msgid "Vector point icon for point data"
+msgstr "Vektordatei die Beispielpunkte enthält."
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Anzahl der Kopien."
+msgid "Number of classes for interval theme (integer)"
+msgstr "Anzahl der Kopien."
 #, fuzzy
-#~ msgid "Misc"
-#~ msgstr "Metrisch"
+msgid "Misc"
+msgstr "Metrisch"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr ""
-#~ "Mapset, dessen Dateien ausgegeben werden sollen (Standard: aktueller "
-#~ "Suchpfad)."
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr ""
+"Mapset, dessen Dateien ausgegeben werden sollen (Standard: aktueller "
+"Suchpfad)."
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Name der Ausgabe-Rasterkarte (Standard: Eingabename)"
+msgid "Output separator (default: newline)"
+msgstr "Name der Ausgabe-Rasterkarte (Standard: Eingabename)"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "3D Raster, das entfernt werden soll."
+msgid "Raster to remove"
+msgstr "3D Raster, das entfernt werden soll."
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
+msgid "Vector to remove"
 #, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "Erzwinge das Löschen"
+msgid "Region to remove"
+msgstr "Erzwinge das Löschen"
 #, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "Kann nicht weitermachen."
+msgid "Label to remove"
+msgstr "Kann nicht weitermachen."
 #, fuzzy
-#~ msgid "3dview to remove"
-#~ msgstr "%-5d Zentroiden gelesen.\n"
+msgid "3dview to remove"
+msgstr "%-5d Zentroiden gelesen.\n"
 #, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "Gruppe, die entfernt werden soll."
+msgid "Group to remove"
+msgstr "Gruppe, die entfernt werden soll."
-#~ msgid "imagery, raster, multispectral"
-#~ msgstr "Bildverarbeitung, Raster, Multispektral"
+msgid "imagery, raster, multispectral"
+msgstr "Bildverarbeitung, Raster, Multispektral"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "Raster, Import"
+msgid "raster input maps"
+msgstr "Raster, Import"
 #, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "Überschreibe Ausgabedatei."
+msgid "write output to PNG image"
+msgstr "Überschreibe Ausgabedatei."
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
+msgid "label with coordinates instead of numbering"
+msgstr "Benutze Kartenkoordinaten anstatt xyz-Koordniaten."
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Verwende die Nummern der Kanäle anstatt der Farbenbezeichnungen."
+msgid "Keep band numbers instead of using band color names."
+msgstr "Verwende die Nummern der Kanäle anstatt der Farbenbezeichnungen."
 #, fuzzy
-#~ msgid "A"
-#~ msgstr "A:"
+msgid "A"
+msgstr "A:"
 #, fuzzy
-#~ msgid "B"
-#~ msgstr "B:"
+msgid "B"
+msgstr "B:"
 #, fuzzy
-#~ msgid "C"
-#~ msgstr "C:"
+msgid "C"
+msgstr "C:"
 #, fuzzy
-#~ msgid "D"
-#~ msgstr "D:"
+msgid "D"
+msgstr "D:"
 #, fuzzy
-#~ msgid "E"
-#~ msgstr "E:"
+msgid "E"
+msgstr "E:"
 #, fuzzy
-#~ msgid "F"
-#~ msgstr "F:"
+msgid "F"
+msgstr "F:"
 #, fuzzy
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formel (z.B. A-B oder A*C+B):"
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Formel (z.B. A-B oder A*C+B):"
-#~ msgid "Show help"
-#~ msgstr "Zeige die Hilfe an."
+msgid "Show help"
+msgstr "Zeige die Hilfe an."
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Name einer existierenden Rasterkarte."
+msgid "Do not overwrite existing map"
+msgstr "Name einer existierenden Rasterkarte."
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exportiert GRASS Rasterdaten in GDAL-unterstütze Formate."
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "Exportiert GRASS Rasterdaten in GDAL-unterstütze Formate."
 #, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Lese r.stats Ausgabe."
+msgid "Region sensitive output"
+msgstr "Lese r.stats Ausgabe."
 #, fuzzy
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr ""
-#~ "Optionen für den Ausgabeformat Treiber. Es können mehrere Optionen "
-#~ "angegeben werden."
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr ""
+"Optionen für den Ausgabeformat Treiber. Es können mehrere Optionen angegeben "
+"werden."
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Ausgabe Feld-Trennzeichen"
+msgid "Output field seperator"
+msgstr "Ausgabe Feld-Trennzeichen"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr ""
-#~ "Berechnet univariate Statistikparameter einer Rasterkarte (nur Nicht-Null-"
-#~ "Zellen)."
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr ""
+"Berechnet univariate Statistikparameter einer Rasterkarte (nur Nicht-Null-"
+"Zellen)."
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "Mehr statistische Kennzahlen (Quartile und Perzentile)."
+msgid "extended statistics (quartiles and percentile)"
+msgstr "Mehr statistische Kennzahlen (Quartile und Perzentile)."
 #, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Kann die Eingabekarte nicht schließen."
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "Kann die Eingabekarte nicht schließen."
 #, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "Eingabe-grid3D-Datei"
+msgid "A (grid3D file)"
+msgstr "Eingabe-grid3D-Datei"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Name der Ausgabedatei"
+msgid "Name for output grid3D volume"
+msgstr "Name der Ausgabedatei"
 #, fuzzy
-#~ msgid "raster, imagery, dehaze"
-#~ msgstr "Raster, Bildverarbeitung"
+msgid "raster, imagery, dehaze"
+msgstr "Raster, Bildverarbeitung"
 #, fuzzy
-#~ msgid "LANDSAT TM1 channel"
-#~ msgstr "LANDSAT roter Kanal"
+msgid "LANDSAT TM1 channel"
+msgstr "LANDSAT roter Kanal"
 #, fuzzy
-#~ msgid "LANDSAT TM2 channel"
+msgid "LANDSAT TM2 channel"
 #, fuzzy
-#~ msgid "LANDSAT TM3 channel"
+msgid "LANDSAT TM3 channel"
 #, fuzzy
-#~ msgid "LANDSAT TM4 channel"
+msgid "LANDSAT TM4 channel"
 #, fuzzy
-#~ msgid "LANDSAT TM5 channel"
+msgid "LANDSAT TM5 channel"
 #, fuzzy
-#~ msgid "LANDSAT TM7 channel"
+msgid "LANDSAT TM7 channel"
 #, fuzzy
-#~ msgid "raster output dehazed maps prefix"
-#~ msgstr "Prefix der Ausgabe-Rasterkarte."
+msgid "raster output dehazed maps prefix"
+msgstr "Prefix der Ausgabe-Rasterkarte."
 #, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: <%s> nicht gefunden."
+msgid "%s: [%s] not found"
+msgstr "%s: <%s> nicht gefunden."
-#~ msgstr "     'c': Zellen"
+msgstr "     'c': Zellen"
-#~ msgstr "     'p': Prozent Deckung der Region"
+msgstr "     'p': Prozent Deckung der Region"
 #, fuzzy
-#~ msgstr "     'x': Prozent der <%s> Kategorie (Spalte)"
+msgstr "     'x': Prozent der <%s> Kategorie (Spalte)"
 #, fuzzy
-#~ msgstr "     'y': Prozent der <%s> Kategorie (Zeile)"
+msgstr "     'y': Prozent der <%s> Kategorie (Zeile)"
-#~ msgstr "     'a': Acres"
+msgstr "     'a': Acres"
-#~ msgstr "     'h': Hektar"
+msgstr "     'h': Hektar"
-#~ msgstr "     'k': Quadratkilometer"
+msgstr "     'k': Quadratkilometer"
-#~ msgstr "     'm': Quadratmeilen\n"
+msgstr "     'm': Quadratmeilen\n"
-#~ msgstr "     'Q': Beenden"
+msgid "     'Q': quit"
+msgstr "     'Q': Beenden"
-#~ msgstr "Möchten Sie diesen Bericht in einer Datei speichern? (y/n) [n] "
+msgstr "Möchten Sie diesen Bericht in einer Datei speichern? (y/n) [n] "
-#~ msgid ""
-#~ msgstr ""
-#~ "Geben Sie den Dateinamen oder Pfad ein\n"
+msgid ""
+msgstr ""
+"Geben Sie den Dateinamen oder Pfad ein\n"
 #, fuzzy
-#~ msgstr "<%s> wird gespeichert\n"
+msgstr "<%s> wird gespeichert\n"
 #, fuzzy
-#~ msgid ""
-#~ msgstr "Möchten Sie diesen Bericht drucken? (y/n) [n] "
+msgid ""
+msgstr "Möchten Sie diesen Bericht drucken? (y/n) [n] "
-#~ msgid ""
-#~ msgstr ""
-#~ "Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
+msgid ""
+msgstr ""
+"Möchten Sie die Ausgabe in 80 oder 132 Spalten?\n"
-#~ msgid ""
-#~ "[y] "
-#~ msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
+msgid ""
+msgstr "Möchten Sie diesen Bericht mit einer anderen Maßeinheit? (y/n) [y] "
-#~ msgstr "End-Punkte interaktiv bestimmen."
+msgstr "End-Punkte interaktiv bestimmen."
 #, fuzzy
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Verwenden Sie die Maus, um eine Aktion auszuwählen."
+msgstr ""
+"\n"
+"\n"
+"Verwenden Sie die Maus, um eine Aktion auszuwählen."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"\n"
 #, fuzzy
-#~ msgstr ""
-#~ "\n"
-#~ "Maustasten:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"Maustasten:\n"
 #, fuzzy
-#~ msgstr "Links:   Verschieben\n"
+msgstr "Links:   Verschieben\n"
 #, fuzzy
-#~ msgstr "Mitte: Selektiere Nach\n"
+msgstr "Mitte: Selektiere Nach\n"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "elevin Rasterkarte <%s> nicht gefunden."
+msgid "elevin raster map <%s> not found"
+msgstr "elevin Rasterkarte <%s> nicht gefunden."
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "aspin Rasterkarte <%s> nicht gefunden."
+msgid "aspin raster map <%s> not found"
+msgstr "aspin Rasterkarte <%s> nicht gefunden."
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "linkin Rasterkarte <%s> wurde nicht gefunden."
+msgid "linkein raster map <%s> not found"
+msgstr "linkin Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
+msgid "albedo raster map <%s> not found"
+msgstr "albedo Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "latin Rasterkarte <%s> wurde nicht gefunden."
+msgid "latin raster map <%s> not found"
+msgstr "latin Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "coefbh Rasterkarte <%s> wurde nicht gefunden."
+msgid "coefbh raster map <%s> not found"
+msgstr "coefbh Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "coefdh Rasterkarte <%s> wurde nicht gefunden."
+msgid "coefdh raster map <%s> not found"
+msgstr "coefdh Rasterkarte <%s> wurde nicht gefunden."
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr ""
-#~ "Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht "
-#~ "gesetzt."
+msgid "No clump map specified and MASK not set."
+msgstr ""
+"Keine Klumpen-Karte angegeben. Außerdem ist die Maske (MASK) nicht gesetzt."
 #, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "Kann Rasterkarte <%s> nicht finden. "
+msgid "Unable to find data map"
+msgstr "Kann Rasterkarte <%s> nicht finden. "
 #, fuzzy
-#~ msgid "Unable to find clump map"
-#~ msgstr "Kann Rasterkarte %s nicht finden. "
+msgid "Unable to find clump map"
+msgstr "Kann Rasterkarte %s nicht finden. "
 #, fuzzy
-#~ msgid "Memory allocation error"
-#~ msgstr "Metrische Belegung."
+msgid "Memory allocation error"
+msgstr "Metrische Belegung."
 #, fuzzy
-#~ msgid "Saving new map"
-#~ msgstr "Lese Karte"
+msgid "Saving new map"
+msgstr "Lese Karte"
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Terrain Rasterkarte (DEM)."
+msgid "Terrain raster map (DEM)"
+msgstr "Terrain Rasterkarte (DEM)."
 #, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "Titel der Ausgabe-Rasterkarte."
+msgid "Output raster map with lake"
+msgstr "Titel der Ausgabe-Rasterkarte."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen"
+msgid "Cannot write lake raster map <%s>!"
+msgstr "Kann die Rasterkarte <%s> nicht erzeugen"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
+msgid "Terrain raster map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Kann Rasterkarte <%s> nicht öffnen!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "Kann Rasterkarte <%s> nicht öffnen!"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "%s: %s nicht gefunden."
+msgid "Seed map <%s> not found!"
+msgstr "%s: %s nicht gefunden."
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
+msgid "Failure to allocate memory for row pointers"
+msgstr "Kann keinen Speicherplatz für Zeilen-Puffer belegen."
 #, fuzzy
-#~ msgid "Loading maps: "
+msgid "Loading maps: "
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "Fehler beim Lesen der Datei dbmscap\n"
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "Fehler beim Lesen der Datei dbmscap\n"
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
 #, fuzzy
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr "Starte in:"
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr "Starte in:"
 #, fuzzy
-#~ msgid "Pass: %d\n"
-#~ msgstr "Maske: %s\n"
+msgid "Pass: %d\n"
+msgstr "Maske: %s\n"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Fehler beim Schreiben der Colr-Datei <%s>."
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Fehler beim Schreiben der Colr-Datei <%s>."
 #, fuzzy
-#~ msgid "All done."
-#~ msgstr "Fertig."
+msgid "All done."
+msgstr "Fertig."
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: Rasterkarte %s nicht gefunden."
+msgid "%s: base raster map not found"
+msgstr "%s: Rasterkarte %s nicht gefunden."
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s - Rasterkarte nicht gefunden."
+msgid "%s: cover raster map not found"
+msgstr "%s - Rasterkarte nicht gefunden."
 #, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Berechnet den Form-Index einer Rasterkarte."
+msgid "Calculates <simple> index on a raster map"
+msgstr "Berechnet den Form-Index einer Rasterkarte."
 #, fuzzy
-#~ msgid "raster, landscape structure analysis, job launcher"
-#~ msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
+msgid "raster, landscape structure analysis, job launcher"
+msgstr "Raster, Landschaftsstruktur Analyse, Patch-Index"
-#~ msgid "Quietly"
-#~ msgstr "ruhig"
+msgid "Quietly"
+msgstr "ruhig"
-#~ msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
+msgstr "Bilineares Interpolationswerkzeug für Rasterkarten."
 #, fuzzy
-#~ msgid ""
-#~ msgstr ""
-#~ "Spezieller Eingabewert, welcher zum Nord- und/oder Südpol bei Lat-Long-"
-#~ "Rastern zugewiesen werden soll."
+msgid ""
+msgstr ""
+"Spezieller Eingabewert, welcher zum Nord- und/oder Südpol bei Lat-Long-"
+"Rastern zugewiesen werden soll."
 #, fuzzy
-#~ msgstr ""
-#~ "Von der Verwendung dieses Moduls wird abgeraten. Bitte verwenden Sie "
-#~ "stattdessen 'r.stats.interp'."
+msgstr ""
+"Von der Verwendung dieses Moduls wird abgeraten. Bitte verwenden Sie "
+"stattdessen 'r.stats.interp'."
-#~ msgstr "Ungültiger Ausgabe-Dateiname<%s>."
+msgstr "Ungültiger Ausgabe-Dateiname<%s>."
-#~ msgid ""
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'"
+msgid ""
+"quiet' instead"
+msgstr ""
+"Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
+"ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Nicht genügend Speicher für zero_array_cell."
+msgid "Not enough memory for zero_array_cell"
+msgstr "Nicht genügend Speicher für zero_array_cell."
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr ""
-#~ "Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
-#~ "schreiben."
+msgid "Not enough disk space -- cannot write files"
+msgstr ""
+"Nicht genügend Speicher auf der Festplatte frei - kann die Dateien nicht "
+"schreiben."
 #, fuzzy
-#~ msgid "Raster input maps(s)"
-#~ msgstr "rote Eingabe-Rasterkarte."
+msgid "Raster input maps(s)"
+msgstr "rote Eingabe-Rasterkarte."
 #, fuzzy
-#~ msgid "Output file name"
-#~ msgstr "Ausgabe-Tabellenname"
+msgid "Output file name"
+msgstr "Ausgabe-Tabellenname"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: Kann die Spanne für <%s> nicht lesen."
+msgid "%s: can't read fp range for [%s]"
+msgstr "%s: Kann die Spanne für <%s> nicht lesen."
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "Rasterkarte <%s> existiert in der Gruppe."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "Rasterkarte <%s> existiert in der Gruppe."
 #, fuzzy
-#~ msgstr "Pfad zur resultierenden VTK-Datei."
+msgstr "Pfad zur resultierenden VTK-Datei."
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
+msgid "RGB raster map <%s> not found"
+msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr ""
-#~ "Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei karten zur "
-#~ "Verfügung [r,g,b]."
+msgid "Cannot create RGB data, please provide three maps [r,g,b]"
+msgstr ""
+"Kann RGB-Daten nicht erzeugen, bitte stellen Sie drei karten zur Verfügung "
+"[r,g,b]."
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "Vektorkarte <%s> nicht gefunden."
+msgid "Vector cell map <%s> not found"
+msgstr "Vektorkarte <%s> nicht gefunden."
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr ""
-#~ "Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]."
+msgid "Cannot create vector data, please provide three maps [x,y,z]"
+msgstr ""
+"Kann Vektor-Daten nicht erzeugen, bitte geben Sie drei Karten an [x,y,z]."
-#~ msgstr "Welche Rasterkarte braucht eine Farbtabelle"
+msgstr "Welche Rasterkarte braucht eine Farbtabelle"
 #, fuzzy
-#~ msgstr "Editiere Header für Karte <%s>.\n"
+msgstr "Editiere Header für Karte <%s>.\n"
 #, fuzzy
-#~ msgstr "<%s> konnte nicht gefunden werden!"
+msgstr "<%s> konnte nicht gefunden werden!"
-#~ msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
+msgstr "Für welchen Layer soll die Header-Datei editiert werden?"
 #, fuzzy
-#~ msgstr ""
-#~ "<%s> ist eine reklassifizierte Karte von <%s> - kann den Header nicht "
-#~ "editieren! Wende support für Karte <%s> an."
+msgstr ""
+"<%s> ist eine reklassifizierte Karte von <%s> - kann den Header nicht "
+"editieren! Wende support für Karte <%s> an."
 #, fuzzy
-#~ msgstr ""
-#~ "<%s> ist eine reklassifizierte Karte von [%s in %s] - kann den Header "
-#~ "nicht editieren!"
+msgstr ""
+"<%s> ist eine reklassifizierte Karte von [%s in %s] - kann den Header nicht "
+"editieren!"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Rasterkarte <%s> ist leer."
+msgstr "Rasterkarte <%s> ist leer."
-#~ msgstr "cellhd Kompression: %d\n"
+msgstr "cellhd Kompression: %d\n"
-#~ msgstr "3.0 Komprimierung %s angezeigt.\n"
+msgstr "3.0 Komprimierung %s angezeigt.\n"
-#~ msgstr "Pre 3.0 Komprimierung %s angezeigt.\n"
+msgstr "Pre 3.0 Komprimierung %s angezeigt.\n"
 #, fuzzy
-#~ msgstr "<%s> scheint komprimiert zu sein. Ist sie es?"
+msgstr "<%s> scheint komprimiert zu sein. Ist sie es?"
-#~ msgstr "Bitte geben Sie den Typ der Komprimierung an:\n"
+msgstr "Bitte geben Sie den Typ der Komprimierung an:\n"
-#~ msgstr "  1. Pre 3.0 Komprimierung\n"
+msgstr "  1. Pre 3.0 Komprimierung\n"
-#~ msgstr "  2. 3.0 Komprimierung\n"
+msgstr "  2. 3.0 Komprimierung\n"
 #, fuzzy
-#~ msgstr ""
-#~ "Der Header der Datei <%s> sagt, dass die Datei nicht komprimiert ist."
+msgstr "Der Header der Datei <%s> sagt, dass die Datei nicht komprimiert ist."
-#~ msgstr "Die Datei erscheint, als sei sie komprimiert.\n"
+msgstr "Die Datei erscheint, als sei sie komprimiert.\n"
-#~ msgstr ""
-#~ "Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
-#~ "möchte, dass Sie entscheiden.\n"
+msgstr ""
+"Höhstwahrscheinlich ist die Information aus dem Header falsch, aber ich "
+"möchte, dass Sie entscheiden.\n"
 #, fuzzy
-#~ msgstr "Der Header der Datei <%s> sagt, dass die Datei komprimiert ist."
+msgstr "Der Header der Datei <%s> sagt, dass die Datei komprimiert ist."
-#~ msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
+msgstr "Die Datei scheint NICHT komprimiert zu sein.\n"
-#~ msgid ""
-#~ msgstr ""
-#~ "Header gibt an, dass %d Reihe%s in der Rasterkarte enthalten sind, aber "
-#~ "die aktuelle Datei hat %d Reihe%s."
+msgid ""
+msgstr ""
+"Header gibt an, dass %d Reihe%s in der Rasterkarte enthalten sind, aber die "
+"aktuelle Datei hat %d Reihe%s."
 #, fuzzy
-#~ msgstr "Kann den Header für die Karte <%s> nicht schreiben."
+msgstr "Kann den Header für die Karte <%s> nicht schreiben."
 #, fuzzy
-#~ msgstr "Header der Rasterkarte <%s> wurde aktualisiert."
+msgstr "Header der Rasterkarte <%s> wurde aktualisiert."
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bitte RETURN drücken um fortzufahren -->"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Bitte RETURN drücken um fortzufahren -->"
 #, fuzzy
-#~ msgstr "Bitte geben Sie die folgenden Informationen für <%s>:"
+msgstr "Bitte geben Sie die folgenden Informationen für <%s>:"
-#~ msgstr "        Anzahl der Zeilen"
+msgstr "        Anzahl der Zeilen"
-#~ msgstr "        Anzahl der Spalten"
+msgstr "        Anzahl der Spalten"
-#~ msgstr "        Fließkomma-Karte"
+msgstr "        Fließkomma-Karte"
 #, fuzzy
-#~ msgstr ""
-#~ "Reihen * Spalten * Bytes* pro Zelle müssen die gleiche Größe wie die "
-#~ "Dateigröße ergeben (%ld)."
+msgstr ""
+"Reihen * Spalten * Bytes* pro Zelle müssen die gleiche Größe wie die "
+"Dateigröße ergeben (%ld)."
-#~ msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
+msgstr "Für Hilfe beim Herausfinden bitte ESC drücken."
-#~ msgstr "** Negative Werte sind nicht erlaubt!"
+msgstr "** Negative Werte sind nicht erlaubt!"
-#~ msgstr "** Bitte nur positive Werte!"
+msgstr "** Bitte nur positive Werte!"
-#~ msgstr "Welche Rasterkarte benötigt eine Aktualisierung der History?"
+msgstr "Welche Rasterkarte benötigt eine Aktualisierung der History?"
 #, fuzzy
-#~ msgstr "Rasterkarte <%s> nicht gefunden. Beenden mich. "
+msgstr "Rasterkarte <%s> nicht gefunden. Beenden mich. "
 #, fuzzy
-#~ msgstr "Die Historiedatei für die Karte <%s> wurde aktualisiert."
+msgstr "Die Historiedatei für die Karte <%s> wurde aktualisiert."
 #, fuzzy
-#~ msgstr "Die Historiedatei für die Karte <%s> wurde nicht aktualisiert."
+msgstr "Die Historiedatei für die Karte <%s> wurde nicht aktualisiert."
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Drücke RETURN zum Fortfahren -->"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Drücke RETURN zum Fortfahren -->"
 #, fuzzy
-#~ msgstr "Editiere Header der Karte <%s>?"
+msgstr "Editiere Header der Karte <%s>?"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "BEACHTE: <%s> ist eine reklassifizierte Karte von [%s in %s]."
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"BEACHTE: <%s> ist eine reklassifizierte Karte von [%s in %s]."
-#~ msgstr "Breche das Editieren der Headerdatei ab."
+msgstr "Breche das Editieren der Headerdatei ab."
 #, fuzzy
-#~ msgstr "Editiere die Kategorie-Datei für Karte <%s>?"
+msgstr "Editiere die Kategorie-Datei für Karte <%s>?"
 #, fuzzy
-#~ msgstr "Erzeuge/Aktualisiere die Farbtabelle für die Karte <%s>?"
+msgstr "Erzeuge/Aktualisiere die Farbtabelle für die Karte <%s>?"
 #, fuzzy
-#~ msgstr "Wollen Sie die History-Datei für Karte <%s> editieren?"
+msgstr "Wollen Sie die History-Datei für Karte <%s> editieren?"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Die null-Datei für Karte <%s> kann anzeigen, dass einige Zellen NODATA "
-#~ "enthalten. Falls die null-Datei für Karte <%s> nicht existiert, werden "
-#~ "zero (0)-Zellen von den GRASS-Modulen als NODATA behandelt. "
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Die null-Datei für Karte <%s> kann anzeigen, dass einige Zellen NODATA "
+"enthalten. Falls die null-Datei für Karte <%s> nicht existiert, werden zero "
+"(0)-Zellen von den GRASS-Modulen als NODATA behandelt. "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Wollen Sie eine null-Datei für Karte <%s> erzeugen/zurücksetzen, so dass "
-#~ "Zellen mit null-Werten als gültige Daten angesehen werden?"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Wollen Sie eine null-Datei für Karte <%s> erzeugen/zurücksetzen, so dass "
+"Zellen mit null-Werten als gültige Daten angesehen werden?"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Wollen Sie die Null-Datei für Karte <%s> löschen?\n"
-#~ "(alle 0 (zero)-Zellen werden dann NODATA sein.)"
+msgid ""
+"\n"
+msgstr ""
+"\n"
+"Wollen Sie die Null-Datei für Karte <%s> löschen?\n"
+"(alle 0 (zero)-Zellen werden dann NODATA sein.)"
-#~ msgstr "Für welche Vektordatei sollen die Kategorien aktualisiert werden?"
+msgstr "Für welche Vektordatei sollen die Kategorien aktualisiert werden?"
-#~ msgstr "Für welche Rasterkarte sollen die Kategorien aktualisiert werden?"
+msgstr "Für welche Rasterkarte sollen die Kategorien aktualisiert werden?"
 #, fuzzy
 #, fuzzy
-#~ msgstr "Kategorie-Datei für <%s> nicht aktualisiert."
+msgstr "Kategorie-Datei für <%s> nicht aktualisiert."
 #, fuzzy
-#~ msgstr "Kategorie-Datei für <%s> aktualisiert."
+msgstr "Kategorie-Datei für <%s> aktualisiert."
-#~ msgid "Title, in quotes"
-#~ msgstr "Titel, in Gänsefüßchen"
+msgid "Title, in quotes"
+msgstr "Titel, in Gänsefüßchen"
-#~ msgstr "Schweigsam - keinen Fortschritt anzeigen."
+msgstr "Schweigsam - keinen Fortschritt anzeigen."
-#~ msgid ""
-#~ msgstr ""
-#~ "Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der "
-#~ "kommenden Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen "
-#~ "'--quiet'."
+msgid ""
+msgstr ""
+"Die Schalter '-q' und '-n' wurden ersetzt und werden in einer der kommenden "
+"Versionen ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Kann der Startvektor %s nicht finden."
+msgid "Unable to find starting vector <%s> "
+msgstr "Kann der Startvektor %s nicht finden."
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Kann den Stoppvektor %s nicht finden."
+msgid "Unable to find stop vector <%s>"
+msgstr "Kann den Stoppvektor %s nicht finden."
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "Rasterausgabe %s - nicht gefunden (keine Start-Punkte angegeben)."
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "Rasterausgabe %s - nicht gefunden (keine Start-Punkte angegeben)."
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Fehler beim allozieren von Speicher während des Lesens der Startpunktes "
-#~ "der Rasterkarte %s."
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr ""
+"Fehler beim allozieren von Speicher während des Lesens der Startpunktes der "
+"Rasterkarte %s."
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Filter nur auf 0-Werte anwenden."
+msgid "Apply filter only to zero data values"
+msgstr "Filter nur auf 0-Werte anwenden."
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "G_put_raster_row failed (Dateisystem voll?)"
+msgid "G_put_raster_row failed (file system full?)"
+msgstr "G_put_raster_row failed (Dateisystem voll?)"
 #, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "Detaillierte Ausgabe"
+msgid "Run verbosly"
+msgstr "Detaillierte Ausgabe"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "Ausführliche Ausgabe."
+msgid "Run VERBOSELY"
+msgstr "Ausführliche Ausgabe."
-#~ msgid "Cell file not found"
-#~ msgstr "Cell-Datei nicht gefunden."
+msgid "Cell file not found"
+msgstr "Cell-Datei nicht gefunden."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
+msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Kann folgende Attribute nicht auswählen: %s"
+msgid "Cannot execute: %s"
+msgstr "Kann folgende Attribute nicht auswählen: %s"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Kann die Tabelle <%s> nicht verändern."
+msgid "Cannot link table: %s"
+msgstr "Kann die Tabelle <%s> nicht verändern."
 #, fuzzy
-#~ msgid "DXF input file"
-#~ msgstr "DXF Ausgabedatei."
+msgid "DXF input file"
+msgstr "DXF Ausgabedatei."
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "Kann die Datei <%s> nicht öffnen."
+msgid "Cannot open dxf file <%s>"
+msgstr "Kann die Datei <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr "Ausgabe option"
+msgid "Use output= option to change vector map name"
+msgstr "Ausgabe option"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
+msgid "Cannot open new vector map <%s>"
+msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Kann die Vektordatei %s nicht erzeugen."
+msgid "Conversion of <%s> to vector map:"
+msgstr "Kann die Vektordatei %s nicht erzeugen."
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgstr ""
-#~ "Vektor <%s> ist nicht im Benutzer Mapset und kann nicht aktualisiert "
-#~ "werden."
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr ""
+"Vektor <%s> ist nicht im Benutzer Mapset und kann nicht aktualisiert werden."
 #, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "Erzeugt keine Topologie im Punkt-Modus."
+msgid "Do not print polyline info"
+msgstr "Erzeugt keine Topologie im Punkt-Modus."
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
+msgid "Network input map <%s> not found"
-#~ msgstr "ask_transform_coor():  Verlasse session.. \n"
+msgstr "ask_transform_coor():  Verlasse session.. \n"
-#~ msgstr "Anzahl der Punkte, die eingegeben wurden: %d\n"
+msgstr "Anzahl der Punkte, die eingegeben wurden: %d\n"
-#~ msgstr "Bitte antworten Sie mit yes oder no."
+msgstr "Bitte antworten Sie mit yes oder no."
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "für"
+msgid "Hilight color for text"
+msgstr "für"
 #, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "Länge der Linie: %f\n"
+msgid "Line: %d\n"
+msgstr "Länge der Linie: %f\n"
 #, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
 #, fuzzy
-#~ msgid "Specified group does not exist"
-#~ msgstr "Angegebene Gruppe existiert nicht... Beende mich."
+msgid "Specified group does not exist"
+msgstr "Angegebene Gruppe existiert nicht... Beende mich."
 #, fuzzy
-#~ msgid "imagery group"
-#~ msgstr "Bildgruppe"
+msgid "imagery group"
+msgstr "Bildgruppe"
 #, fuzzy
-#~ msgid "imagery subgroup"
+msgid "imagery subgroup"
 #, fuzzy
-#~ msgid "output raster map"
-#~ msgstr "Farbton Ausgabe-Rasterkarte (hue)."
+msgid "output raster map"
+msgstr "Farbton Ausgabe-Rasterkarte (hue)."
 #, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Name der Eingabe-Rasterkarte."
+msgid "Name of input raster map(s)"
+msgstr "Name der Eingabe-Rasterkarte."
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr ""
-#~ "Dateieerweiterung der Ausgabekarte (Eingabedatei(en) + Dateierweiterung)."
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr ""
+"Dateieerweiterung der Ausgabekarte (Eingabedatei(en) + Dateierweiterung)."
-#~ msgstr "Name=%s\n"
+msgid "name=%s\n"
+msgstr "Name=%s\n"
-#~ msgstr "Mapset=%s\n"
+msgstr "Mapset=%s\n"
-#~ msgstr "Vollname=%s\n"
+msgstr "Vollname=%s\n"
-#~ msgstr "Benutzung: %s Datei [%%x %%y]\n"
+msgstr "Benutzung: %s Datei [%%x %%y]\n"
-#~ msgstr "%s: %s - Ungültiger Name für den realen Teil"
+msgstr "%s: %s - Ungültiger Name für den realen Teil"
-#~ msgstr "%s: %s - ungültiger Dateiname für den Bildteil"
+msgstr "%s: %s - ungültiger Dateiname für den Bildteil"
 #, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "Kann die Signaturdatei <%s> nicht lesen."
+msgid "** Can't read signature file <%s> **"
+msgstr "Kann die Signaturdatei <%s> nicht lesen."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ msgstr "Ungültiger Signaturdateiname <%s>."
+msgid ""
+"\n"
+msgstr "Ungültiger Signaturdateiname <%s>."
-#~ msgstr "Ungültiger Gruppen-Name <%s>."
+msgstr "Ungültiger Gruppen-Name <%s>."
-#~ msgid "Setting map window"
-#~ msgstr "Einstellung des Kartenfensters."
+msgid "Setting map window"
+msgstr "Einstellung des Kartenfensters."
-#~ msgid "Current window not settable"
-#~ msgstr "Aktuelles Fenster nicht einstellbar."
+msgid "Current window not settable"
+msgstr "Aktuelles Fenster nicht einstellbar."
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Kann aktuelles Grafik-Fenster nicht säubern."
+msgid "Can't clear current graphics window"
+msgstr "Kann aktuelles Grafik-Fenster nicht säubern."
-#~ msgid "Cannot use current window"
-#~ msgstr "Kann aktuelles Fenster nicht benutzen."
+msgid "Cannot use current window"
+msgstr "Kann aktuelles Fenster nicht benutzen."
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafik-Fenster "
-#~ "dar."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+"Erzeugt und stellt einfache Grafiken auf Karten im aktiven Grafik-Fenster "
+"dar."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht "
-#~ "angegeben ist, wird von der Standardeingabe gelesen."
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+"Unix-Datei, die Graphik-Instruktionen enthält. Falls diese nicht angegeben "
+"ist, wird von der Standardeingabe gelesen."
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
-#~ "Tripel (durch Doppelpunkte getrennt)."
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
+"Tripel (durch Doppelpunkte getrennt)."
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Nicht zu der Kommandoliste im Monitor hinzufügen."
+msgid "Don't add to list of commands in monitor"
+msgstr "Nicht zu der Kommandoliste im Monitor hinzufügen."
-#~ msgid "No current frame"
-#~ msgstr "Kein aktueller Frame."
+msgid "No current frame"
+msgstr "Kein aktueller Frame."
-#~ msgid "Current frame not available"
-#~ msgstr "Aktueller Frame nicht verfügbar."
+msgid "Current frame not available"
+msgstr "Aktueller Frame nicht verfügbar."
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' got NULL pointer!"
+msgid "%s: 'is_null_value()' got NULL pointer!"
+msgstr "%s: 'is_null_value()' got NULL pointer!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' hat einen negativen Spalten-Index."
+msgid "%s: 'is_null_value()' got negative column index"
+msgstr "%s: 'is_null_value()' hat einen negativen Spalten-Index."
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Unbekannter RASTER_MAP_TYPE '%d'"
+msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
+msgstr "%s: 'is_null_value()' Unbekannter RASTER_MAP_TYPE '%d'"
 #, fuzzy
-#~ msgid "Error reading raster map"
-#~ msgstr "Fehler beim Lesen der Rasterkarte."
+msgid "Error reading raster map"
+msgstr "Fehler beim Lesen der Rasterkarte."
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr ""
-#~ "Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
+msgid "Interactive profile plotting utility with optional output."
+msgstr ""
+"Interaktives Werkzeug zum Zeichnen von Profilen mit optionales Ausgabe."
-#~ msgid "Optional display raster"
-#~ msgstr "Rasterdarstellung optional"
+msgid "Optional display raster"
+msgstr "Rasterdarstellung optional"
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Gebe Profildaten in Datei(en) mit dem Prefix 'name'."
 #, fuzzy
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Darstellung."
+msgid "Display raster [%s] not found. Using profile raster."
+msgstr "Darstellung."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr ""
+"\n"
+"\n"
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr ""
-#~ "Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
+msgid "Use 'd.frame -e' to remove left over frames"
+msgstr ""
+"Benutzen Sie bitte 'd.frame -e' um übrig gebliebene Rahmen zu entfernen."
-#~ msgid "Error opening cell-file"
-#~ msgstr "Fehler beim Öffnen der Zell-Datei."
+msgid "Error opening cell-file"
+msgstr "Fehler beim Öffnen der Zell-Datei."
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Fehler beim Lesen der Zell-Datei."
+msgid "Error reading from cell-file"
+msgstr "Fehler beim Lesen der Zell-Datei."
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Mysteriöser Fenster-Inkonsistenz Fehler."
+msgid "Mysterious window inconsistancy error"
+msgstr "Mysteriöser Fenster-Inkonsistenz Fehler."
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: Kann die Rasterkarte <%s@%s> nicht öffnen."
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "%s: Kann die Rasterkarte <%s@%s> nicht öffnen."
-#~ msgid "one moment ..."
-#~ msgstr "eine Moment..."
+msgid "one moment ..."
+msgstr "eine Moment..."
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr ""
-#~ " Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
-#~ "sollen.\n"
+msgid " Middle: toggle flash color\n"
+msgstr ""
+" Mitte: wechselt zwischen den Farben, die auf dem Bildschirm aufleuchten "
+"sollen.\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Aufleuchten anschalten (ist langsamer)."
+msgid "Enable flashing (slower)"
+msgstr "Aufleuchten anschalten (ist langsamer)."
-#~ msgid "No raster map exists in current window"
-#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
+msgid "No raster map exists in current window"
+msgstr "Es existiert keine Rasterkarte im aktuellen Fenster."
-#~ msgid "No current window"
-#~ msgstr "Kein aktuelles Fenster."
+msgid "No current window"
+msgstr "Kein aktuelles Fenster."
-#~ msgid "Current window not available"
-#~ msgstr "Aktuelles Fenster ist nicht vorhanden."
+msgid "Current window not available"
+msgstr "Aktuelles Fenster ist nicht vorhanden."
-#~ msgid "Getting screen window"
-#~ msgstr "Hole Fenster."
+msgid "Getting screen window"
+msgstr "Hole Fenster."
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Fehler bei der Berechnung der Umwandlung."
+msgid "Error in calculating conversions"
+msgstr "Fehler bei der Berechnung der Umwandlung."
-#~ msgid "No current graphics window"
-#~ msgstr "Kein aktuelles Grafik-Fenster."
+msgid "No current graphics window"
+msgstr "Kein aktuelles Grafik-Fenster."
-#~ msgid "Current graphics window not available"
+msgid "Current graphics window not available"
-#~ msgid "Setting graphics window"
-#~ msgstr "Setze das Kartenfenster."
+msgid "Setting graphics window"
+msgstr "Setze das Kartenfenster."
-#~ msgid "Can't set current graphics window"
+msgid "Can't set current graphics window"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Hole Koordinaten des Grafik-Fensters."
+msgid "Getting graphics window coordinates"
+msgstr "Hole Koordinaten des Grafik-Fensters."
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr "Wert [%.0f,%.0f] außerhalb der Spanne [0-100]"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Ausgabename der neuen TIFF-Datei."
+msgid "Font name or pathname of TTF file"
+msgstr "Ausgabename der neuen TIFF-Datei."
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ " Einstellungen des FreeType-Releases\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+" Einstellungen des FreeType-Releases\n"
-#~ msgid "Display number of colors"
-#~ msgstr "Stelle die Anzahl der Farben dar."
+msgid "Display number of colors"
+msgstr "Stelle die Anzahl der Farben dar."
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
+msgid "Use mouse to size & place legend"
+msgstr "Benutze Maus zum Plazieren und zur Größeneinstellung der Legende."
 #, fuzzy
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr ""
-#~ "Erstelle eine Liste von Kommandos die zum Erstellen der aktuellen Grafik "
-#~ "nötig sind."
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr ""
+"Erstelle eine Liste von Kommandos die zum Erstellen der aktuellen Grafik "
+"nötig sind."
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Name der Rahmen zum speichern."
+msgid "Name of frame(s) to save"
+msgstr "Name der Rahmen zum speichern."
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
-#~ "angezeigt werden. -1 steht für das letzte Objekt."
+msgid ""
+"List of object numbers to remove which are displayed after \"#\". -1 for the "
+"last object."
+msgstr ""
+"Liste der Objektnummer, die entfernt werden sollen, die hinter \"#\" "
+"angezeigt werden. -1 steht für das letzte Objekt."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
-#~ "\"). Falls eine Option angegeben wurde, wird remove= als erstes "
-#~ "ausgeführt."
+msgid ""
+"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
+"done first, if any."
+msgstr ""
+"Liste der Objektnummern die verschoben werden sollen. (\"von\" nach \"nach"
+"\"). Falls eine Option angegeben wurde, wird remove= als erstes ausgeführt."
-#~ msgid "Save current frame"
-#~ msgstr "Speichere aktuellen Rahmen."
+msgid "Save current frame"
+msgstr "Speichere aktuellen Rahmen."
-#~ msgid "Save all the frames"
+msgid "Save all the frames"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Nur Kartenobjekte ohne extra Kopf und Ende."
+msgid "Only map objects without extra header and tailer"
+msgstr "Nur Kartenobjekte ohne extra Kopf und Ende."
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Unbekannter Typ in pad: %s"
+msgid "Unknown item type in pad: %s"
+msgstr "Unbekannter Typ in pad: %s"
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen "
-#~ "(Die Vektorkarte wird nicht gezeichnet, wenn das Grafik-Fenster "
-#~ "aktualisiert wird)."
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+"Nicht zu der Liste der Vektorkarten und Kommandos im Monitor hinzufügen (Die "
+"Vektorkarte wird nicht gezeichnet, wenn das Grafik-Fenster aktualisiert "
+"wird)."
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "Es existiert keine Rasterkarte im aktuellen Fenster. "
+msgid "No raster map exists in the current window"
+msgstr "Es existiert keine Rasterkarte im aktuellen Fenster. "
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr ""
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
-#~ msgid "Sets the color of the menu background"
+msgid "Sets the color of the menu background"
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Bestimmt die Farbe für den Menütext."
+msgid "Sets the color of the menu text"
+msgstr "Bestimmt die Farbe für den Menütext."
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Bestimmt die Farbe zum Trennen von Textzeilen."
+msgid "Sets the color dividing lines of text"
+msgstr "Bestimmt die Farbe zum Trennen von Textzeilen."
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Bestimmt die Menütextgröße (in Prozent)."
+msgid "Sets the menu text size (in percent)"
+msgstr "Bestimmt die Menütextgröße (in Prozent)."
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Das Menü muss mindestens einen Titel und eine Option enthalten."
+msgid "Menu must contain a title and at least one option"
+msgstr "Das Menü muss mindestens einen Titel und eine Option enthalten."
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-"
-#~ "Fensters zu zeichnen."
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr ""
+"Verwende TrueType-Schriften, um Text im aktiven Rahmen des Graphik-Fensters "
+"zu zeichnen."
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr "Koordinaten (in Prozent, [0,0] ist unten links)."
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Pfad zu den TrueType-Schriften (inklusive Dateiname)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Pfad zu den TrueType-Schriften (inklusive Dateiname)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Höhe der Buchstaben (in Prozent von der möglichen Rahmenhöhe)."
+msgid "Height of letters (in percent of available frame height)"
+msgstr "Höhe der Buchstaben (in Prozent von der möglichen Rahmenhöhe)."
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Entweder muss die Option '-c' oder text angegeben werden. "
+msgid "Either text or -c should be given"
+msgstr "Entweder muss die Option '-c' oder text angegeben werden. "
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Wählen Sie nur ein Koordinatensystem für die Plazierung aus."
+msgid "Choose only one coordinate system for placement"
+msgstr "Wählen Sie nur ein Koordinatensystem für die Plazierung aus."
-#~ msgid "No font selected"
-#~ msgstr "Keine Schrift ausgewählt."
+msgid "No font selected"
+msgstr "Keine Schrift ausgewählt."
-#~ msgid "Invalid font: %s"
-#~ msgstr "Ungültige Schrift: %s"
+msgid "Invalid font: %s"
+msgstr "Ungültige Schrift: %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Kann den Textkonvertierungszusammenhang nicht erstellen."
+msgid "Unable to create text conversion context"
+msgstr "Kann den Textkonvertierungszusammenhang nicht erstellen."
-#~ msgid "Text conversion error"
-#~ msgstr "Fehler beim Konvertieren von Text."
+msgid "Text conversion error"
+msgstr "Fehler beim Konvertieren von Text."
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Kann die temporäre Datei nicht schreiben."
+msgid "Unable to write the temporary file"
+msgstr "Kann die temporäre Datei nicht schreiben."
-#~ msgid "No predefined font"
-#~ msgstr "Keine vordefinierte Schrift gefunden."
+msgid "No predefined font"
+msgstr "Keine vordefinierte Schrift gefunden."
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: Kann diese Schrift nicht lesen."
+msgid "%s: Unable to read font"
+msgstr "%s: Kann diese Schrift nicht lesen."
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr ""
-#~ "%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr ""
+"%s: Kann die FreeType Definitionsdatei nicht lesen; nehme den Standard."
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: Keine FreeType Definitionsdatei gefunden."
+msgid "%s: No FreeType definition file"
+msgstr "%s: Keine FreeType Definitionsdatei gefunden."
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen."
+msgid "%s: Unable to read FreeType definition file"
+msgstr "%s: Kann die FreeType Definitionsdatei nicht lesen."
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr ""
-#~ "Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr ""
+"Nicht zu der Liste der Rasterkarten und Kommandos im Monitor hinzufügen."
-#~ msgid "One mouse click only"
-#~ msgstr "Nur ein Mausklick."
+msgid "One mouse click only"
+msgstr "Nur ein Mausklick."
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Benutze die Maus zum Interaktiven Plazieren des Maßstabs."
+msgid "Use mouse to interactively place scale"
+msgstr "Benutze die Maus zum Interaktiven Plazieren des Maßstabs."
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Benutze die Maus zum Interaktiven Platzieren des Maßstabs."
+msgid "Use mouse to interactively place text"
+msgstr "Benutze die Maus zum Interaktiven Platzieren des Maßstabs."
-#~ msgid "Click!\n"
-#~ msgstr "Klick!\n"
+msgid "Click!\n"
+msgstr "Klick!\n"
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Links:    Platziere Text hier.\n"
+msgid " Left:    Place text here\n"
+msgstr " Links:    Platziere Text hier.\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Rechts:  Beenden\n"
+msgid " Right:   Quit\n"
+msgstr " Rechts:  Beenden\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Nur die angegebene Karten mit ihren Standardfarben neu zeichnen."
+msgid "Just redraw given maps using default colors"
+msgstr "Nur die angegebene Karten mit ihren Standardfarben neu zeichnen."
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "FEHLER: Kann keine \"list\" Werte finden."
+msgid "ERROR: can not get \"list\" items"
+msgstr "FEHLER: Kann keine \"list\" Werte finden."
-#~ msgid "-j flag forced"
-#~ msgstr "Benutzung des Schalters -j erzwungen."
+msgid "-j flag forced"
+msgstr "Benutzung des Schalters -j erzwungen."
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
-#~ msgid "Interactively select route"
-#~ msgstr "Selectiere interaktiv eine Route."
+msgid "Interactively select route"
+msgstr "Selectiere interaktiv eine Route."
-#~ msgid "You must select more than one point"
-#~ msgstr "Es müssen mehr als ein Punkt selektiert werden."
+msgid "You must select more than one point"
+msgstr "Es müssen mehr als ein Punkt selektiert werden."
-#~ msgid "You must select at least four points"
-#~ msgstr "Es müssen mindestens 4 Punkte selektiert werden."
+msgid "You must select at least four points"
+msgstr "Es müssen mindestens 4 Punkte selektiert werden."
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Es wird keine Raster- oder Vektorkarte angezeigt."
+msgid "No raster or vector map displayed"
+msgstr "Es wird keine Raster- oder Vektorkarte angezeigt."
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Erzeugt und kontrolliert ein Grafik-Fenster."
+msgid "To establish and control use of a graphics display monitor."
+msgstr "Erzeugt und kontrolliert ein Grafik-Fenster."
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Name des Grafik-Fensters, das gestartet werden soll."
+msgid "Name of graphics monitor to start"
+msgstr "Name des Grafik-Fensters, das gestartet werden soll."
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Name des Grafik-Fensters, das gestoppt werden soll."
+msgid "Name of graphics monitor to stop"
+msgstr "Name des Grafik-Fensters, das gestoppt werden soll."
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Name des Grafik-Fensters, das ausgewählt werden soll."
+msgid "Name of graphics monitor to select"
+msgstr "Name des Grafik-Fensters, das ausgewählt werden soll."
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Name des Grafik-Fensters, das entriegelt werden soll."
+msgid "Name of graphics monitor to unlock"
+msgstr "Name des Grafik-Fensters, das entriegelt werden soll."
-#~ msgid "List all monitors"
-#~ msgstr "Liste aller Grafik-Fenster."
+msgid "List all monitors"
+msgstr "Liste aller Grafik-Fenster."
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Liste alle Grafik-Fenster (mit aktuellem Status)."
+msgid "List all monitors (with current status)"
+msgstr "Liste alle Grafik-Fenster (mit aktuellem Status)."
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Gib den Namen des aktuell selektierten Grafik-Fensters aus."
+msgid "Print name of currently selected monitor"
+msgstr "Gib den Namen des aktuell selektierten Grafik-Fensters aus."
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Gebe das aktuell ausgewählte Grafik-Fenster frei."
+msgid "Release currently selected monitor"
+msgstr "Gebe das aktuell ausgewählte Grafik-Fenster frei."
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "Nicht automatisch beim Starten selektieren."
+msgid "Do not automatically select when starting"
+msgstr "Nicht automatisch beim Starten selektieren."
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Probleme beim Auswählen von %s. Einmal versuche ich es noch..."
+msgid "Problem selecting %s. Will try once more"
+msgstr "Probleme beim Auswählen von %s. Einmal versuche ich es noch..."
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "Es gibt das Grafik-Fenster <%s> nicht."
+msgid "No such monitor as <%s>"
+msgstr "Es gibt das Grafik-Fenster <%s> nicht."
 #, fuzzy
-#~ msgid "Monitor <%s> released"
-#~ msgstr "Kein Grafik-Fenster ausgewählt."
+msgid "Monitor <%s> released"
+msgstr "Kein Grafik-Fenster ausgewählt."
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Fehler beim Schließen der ASCII-Datei."
+msgid "Error - Locking mechanism failed"
+msgstr "Fehler beim Schließen der ASCII-Datei."
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Fehler beim Lesen der Spanne für <%s>."
+msgid "Error choosing frame [%s]\n"
+msgstr "Fehler beim Lesen der Spanne für <%s>."
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Maustasten:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"Maustasten:\n"
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "Links:   Fenster (frame) auswählen.\n"
+msgid "Left:   Select frame\n"
+msgstr "Links:   Fenster (frame) auswählen.\n"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Rechts:  Menü beenden\n"
+msgid "Right:  Accept frame\n"
+msgstr "Rechts:  Menü beenden\n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr ""
-#~ "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
+msgid "Manages display frames on the user's graphics monitor."
+msgstr "Erzeugt und stellt ein Menü im aktiven Frame des Grafik-Fensters dar."
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Selektiere Daten aus der Datenbank."
+msgid "Select a frame"
+msgstr "Selektiere Daten aus der Datenbank."
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
 #, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "Gebe Flächensummen aus."
+msgid "Print names of all frames"
+msgstr "Gebe Flächensummen aus."
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
-#~ msgid "Debugging output"
-#~ msgstr "Debugging Ausgabe"
+msgid "Debugging output"
+msgstr "Debugging Ausgabe"
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Fenster (frame), das erstellt/ausgewählt werden soll."
+msgid "Frame to be created/selected"
+msgstr "Fenster (frame), das erstellt/ausgewählt werden soll."
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Maustasten:"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"Maustasten:"
-#~ msgid "Left:   Select From\n"
-#~ msgstr "Links:   Selektiere Von\n"
+msgid "Left:   Select From\n"
+msgstr "Links:   Selektiere Von\n"
-#~ msgid "Middle: Select To\n"
+msgid "Middle: Select To\n"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Rechts:  Beenden\n"
-#~ "\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr ""
+"Rechts:  Beenden\n"
+"\n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Grafik-Fenster: Interaktives Kommando zum erneuten Zeichnen\n"
+msgid "Monitor: interactive command in redraw"
+msgstr "Grafik-Fenster: Interaktives Kommando zum erneuten Zeichnen\n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "Habe %d Ansichten vom Typ TrueColor gefunden\n"
+msgid "found %d visuals of type TrueColor"
+msgstr "Habe %d Ansichten vom Typ TrueColor gefunden\n"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "Suche die höchste Bit-Tiefe"
+msgid "searching for highest bit depth"
+msgstr "Suche die höchste Bit-Tiefe"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "Ausgewählte Bit-Tiefe: %d\n"
+msgid "selected %d bit depth"
+msgstr "Ausgewählte Bit-Tiefe: %d\n"
 #, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "Benutze Standard-Ansicht mit <%s>.\n"
+msgid "using default visual which is %s"
+msgstr "Benutze Standard-Ansicht mit <%s>.\n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Grafik-Fenster: Waitpid: erwarte %d, habe aber %d bekommen.\n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Grafik-Fenster: Waitpid: erwarte %d, habe aber %d bekommen.\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Grafik-Fenster: XGetWMName fehlgeschlagen.\n"
+msgid "Monitor: XGetWMName failed"
+msgstr "Grafik-Fenster: XGetWMName fehlgeschlagen.\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Grafik-Fenster: XGetWMName: Falsches Ergebnis.\n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Grafik-Fenster: XGetWMName: Falsches Ergebnis.\n"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "WARNUNG! Eine Projektionsinformation für diese Location existiert "
-#~ "bereits!\n"
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+"\n"
+"\n"
+"WARNUNG! Eine Projektionsinformation für diese Location existiert bereits!\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
+msgid "Would you still like to overwrite the current projection information "
+msgstr "Wollen sie wirklich die aktuelle Projektionsinformation überschreiben?"
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Die Projektionsinformationen werden nicht aktualisiert."
+msgid "The projection information will not be updated."
+msgstr "Die Projektionsinformationen werden nicht aktualisiert."
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> - ungültiger Regions-Name."
+msgid "<%s> is an illegal region name"
+msgstr "<%s> - ungültiger Regions-Name."
 #, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Geo-Gitter Option ist für XY-Projektionen nicht verfügbar."
+msgid "No LatLong information for XY-Projection"
+msgstr "Geo-Gitter Option ist für XY-Projektionen nicht verfügbar."
 #, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "Verarbeite Punkte ... "
+msgid "Erasing monitors..."
+msgstr "Verarbeite Punkte ... "
 #, fuzzy
-#~ msgid "Display manager for GRASS"
+msgid "Display manager for GRASS"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Name der Farb-Datei."
+msgid "Name of .dmrc settings file"
+msgstr "Name der Farb-Datei."
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "von z"
+msgid "Name of the vector points map with x,y locations"
+msgstr "von z"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Anzahl der Interpolationspunkte."
+msgid "Number of time iterations (sec.)"
+msgstr "Anzahl der Interpolationspunkte."
 #, fuzzy
-#~ msgid "Multiscale simulation"
+msgid "Multiscale simulation"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Name der Rasterkarte, die Höheninformation enthält."
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "Name der Rasterkarte, die Höheninformation enthält."
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Name der Eingabe-Rasterkarte"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgstr "Name der Eingabe-Rasterkarte"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Threshold distance"
+msgid "Threshold distance"
 #, fuzzy
-#~ msgid "Create 3D file"
-#~ msgstr "Erzeuge eine 3D-Ausgabe."
+msgid "Create 3D file"
+msgstr "Erzeuge eine 3D-Ausgabe."
 #, fuzzy
-#~ msgid "visualization"
-#~ msgstr "Visualisieren"
+msgid "visualization"
+msgstr "Visualisieren"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Rasterkarte(n) für View%d"
+msgid "Raster file(s) for Elevation"
+msgstr "Rasterkarte(n) für View%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Rasterkarte, an die angepasst werden soll."
+msgid "Raster map to zoom into"
+msgstr "Rasterkarte, an die angepasst werden soll."
 #, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Übernehme Einstellungen von einer benannten Region."
+msgid "Save the current region to region definition file"
+msgstr "Übernehme Einstellungen von einer benannten Region."
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "Kann die Eingabedatei <%s> nicht öffnen."
+msgid "Could not open input file <%s>."
+msgstr "Kann die Eingabedatei <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "No such monitor as '%s'"
+msgid "No such monitor as '%s'"
 #, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
+msgid "Error - No such monitor as '%s'"
 #, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "** Die folgenden Rasterkarten in der Untergruppe <%s> existieren nicht:"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+"** Die folgenden Rasterkarten in der Untergruppe <%s> existieren nicht:"
 #, fuzzy
-#~ msgid "       %s"
-#~ msgstr "Fertig!       "
+msgid "       %s"
+msgstr "Fertig!       "
 #, fuzzy
-#~ msgid "Removing files from group"
+msgid "Removing files from group"
 #, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Lese Rasterkarte der Gruppe <%s> ..."
+msgid "Adding files to group [%s]"
+msgstr "Lese Rasterkarte der Gruppe <%s> ..."
 #, fuzzy
-#~ msgid "Adding files to subgroup [%s]"
+msgid "Adding files to subgroup [%s]"
 #, fuzzy
-#~ msgid "Skipping [%s]..."
-#~ msgstr "Schreibe <%s> ..."
+msgid "Skipping [%s]..."
+msgstr "Schreibe <%s> ..."
 #, fuzzy
-#~ msgid "Writing group REF"
-#~ msgstr "Schreibe Ausgabekarte ..."
+msgid "Writing group REF"
+msgstr "Schreibe Ausgabekarte ..."
 #, fuzzy
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Schreibe %s..."
+msgid "Writing subgroup REF"
+msgstr "Schreibe %s..."
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Habe Datei <%s@%s> in der Gruppe gefunden."
+msgid "Found file <%s@%s> in group."
+msgstr "Habe Datei <%s@%s> in der Gruppe gefunden."
-#~ msgid "Found file <%s@%s> in subgroup."
-#~ msgstr "Habe Datei <%s@%s> in Untergruppe gefunden."
+msgid "Found file <%s@%s> in subgroup."
+msgstr "Habe Datei <%s@%s> in Untergruppe gefunden."
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "Kann die Datei <%s> nicht öffnen"
+msgid "Unable to open file: <%s>"
+msgstr "Kann die Datei <%s> nicht öffnen"
 #, fuzzy
-#~ msgid "Multiplier"
-#~ msgstr "Multiplikator für Z-Werte."
+msgid "Multiplier"
+msgstr "Multiplikator für Z-Werte."
 #, fuzzy
-#~ msgid "Over-riding projection check."
-#~ msgstr "Übersteuere die Überprüfung der Projektion."
+msgid "Over-riding projection check."
+msgstr "Übersteuere die Überprüfung der Projektion."
 #, fuzzy
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr ""
-#~ "Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
-#~ "Location stimmen überein.\n"
-#~ "Fahre mit dem Import fort...\n"
+msgid ""
+"Projection of input dataset and current location appear to match.\n"
+"Proceeding with import...\n"
+msgstr ""
+"Die Projektionsinformationen des Eingabedatensatzes und der aktuellen "
+"Location stimmen überein.\n"
+"Fahre mit dem Import fort...\n"
 #, fuzzy
-#~ msgid "permission denied\n"
-#~ msgstr "Zugang verweigert"
+msgid "permission denied\n"
+msgstr "Zugang verweigert"
 #, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "nicht gefunden"
+msgid "not found\n"
+msgstr "nicht gefunden"
 #, fuzzy
-#~ msgid "%s: percent complete: "
-#~ msgstr "Prozent fertig: "
+msgid "%s: percent complete: "
+msgstr "Prozent fertig: "
 #, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "Rasterkarte nicht gefunden."
+msgid "Raster map not found."
+msgstr "Rasterkarte nicht gefunden."
 #, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "Kann Range-Datei für Karte %s nicht öffnen."
+msgid "%s: can't read range for [%s]"
+msgstr "Kann Range-Datei für Karte %s nicht öffnen."
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "3dview-Datei <%s> nicht gefunden."
+msgid "Raster file [%s] not found"
+msgstr "3dview-Datei <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "Kann <%s> nicht erzeugen."
+msgid "It was not possible writing in <%s>."
+msgstr "Kann <%s> nicht erzeugen."
 #, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "Doppelte Flächen-Zentroide: %5d"
+msgid "\rDuplicate area centroids: %5d"
+msgstr "Doppelte Flächen-Zentroide: %5d"
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Kann Tabelle <%s> nicht erzeugen."
+msgid "Cannot create table: '%s'"
+msgstr "Kann Tabelle <%s> nicht erzeugen."
-#~ msgid "defaulting to nearest neighbor sampling"
-#~ msgstr "Setze Standard auf 'nearest neighbor sampling'."
+msgid "defaulting to nearest neighbor sampling"
+msgstr "Setze Standard auf 'nearest neighbor sampling'."
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Zeige keine Kategorienummern."
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Zeige keine Kategorienummern."
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
 #, fuzzy
-#~ msgid "Unable to write line %d"
-#~ msgstr "Kann kein Face erzeugen."
+msgid "Unable to write line %d"
+msgstr "Kann kein Face erzeugen."
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Unbekannte Methode <%s>."
+msgid "Unknown query tool '%s'"
+msgstr "Unbekannte Methode <%s>."
 #, fuzzy
-#~ msgid ""
-#~ "If 'list', 'file' and 'where' options are not specified, all features of "
-#~ "given type and layer are extracted. Categories are not changed in that "
-#~ "case."
-#~ msgstr ""
-#~ "Selektiert Vektorobjekte aus einer vorhandenen Vektorkarte und schreibt "
-#~ "diese in einen neuen Datensatz. Wenn die Parameter 'list', 'file' und "
-#~ "'where' nicht angegeben werden, werden alle Objekte vom angegebenen Typ "
-#~ "extrahiert. Kategoriewerte werden in diesem Fall nicht verändert."
+msgid ""
+"If 'list', 'file' and 'where' options are not specified, all features of "
+"given type and layer are extracted. Categories are not changed in that case."
+msgstr ""
+"Selektiert Vektorobjekte aus einer vorhandenen Vektorkarte und schreibt "
+"diese in einen neuen Datensatz. Wenn die Parameter 'list', 'file' und "
+"'where' nicht angegeben werden, werden alle Objekte vom angegebenen Typ "
+"extrahiert. Kategoriewerte werden in diesem Fall nicht verändert."
 #, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Datenbankverbindung nicht definiert."
+msgid "No layer database connection"
+msgstr "Datenbankverbindung nicht definiert."
 #, fuzzy
-#~ msgid "Load categories from the database (table = %s, db = %s)."
-#~ msgstr "Lade Kategorien von der Datenbank (Tabelle = %s, DB = %s).\n"
+msgid "Load categories from the database (table = %s, db = %s)."
+msgstr "Lade Kategorien von der Datenbank (Tabelle = %s, DB = %s).\n"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "geladen von Tabelle"
+msgid "%d categories loaded from the database"
+msgstr "geladen von Tabelle"
 #, fuzzy
-#~ msgid "Done"
+msgid "Done"
+msgstr "Fertig."
 #, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Kann die Datenquelle %s nicht öffnen."
+msgid "Cannot open OGR data source '%s'"
+msgstr "Kann die Datenquelle %s nicht öffnen."
 #, fuzzy
-#~ msgid "Cannot create layer"
-#~ msgstr "Kann tree nicht erzeugen."
+msgid "Cannot create layer"
+msgstr "Kann tree nicht erzeugen."
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr ""
-#~ "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden."
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden."
 #, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr ""
-#~ "Lade Werte von den Vektoren in die Datenbank. Im Upload/Print-Modus "
-#~ "werden Kategoriewerte mit '-1' für 'keine Kategorie' gesetzt und "
-#~ "'null'/'-' wenn keine Kategorien gefunden werden konnte oder mehrere "
-#~ "Kategorien enthalten sind."
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr ""
+"Lade Werte von den Vektoren in die Datenbank. Im Upload/Print-Modus werden "
+"Kategoriewerte mit '-1' für 'keine Kategorie' gesetzt und 'null'/'-' wenn "
+"keine Kategorien gefunden werden konnte oder mehrere Kategorien enthalten "
+"sind."
 #, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "Spalte(n)."
+msgid "Column(s)"
+msgstr "Spalte(n)."
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Spaltentyp nicht unterstützt"
+msgid "Column type [%d] not supported"
+msgstr "Spaltentyp nicht unterstützt"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Kann die Headerinformationen für Karte <%s> nicht lesen."
+msgid "Cannot read map header for <%s>"
+msgstr "Kann die Headerinformationen für Karte <%s> nicht lesen."
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "Kann die Kategorie-Datei der Karte <%s> nicht lesen."
+msgid "Cannot read category file for <%s>"
+msgstr "Kann die Kategorie-Datei der Karte <%s> nicht lesen."
 #, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "Gebe die Statistik im Shell-Skript-Style aus."
+msgid "Print;Shell Script"
+msgstr "Gebe die Statistik im Shell-Skript-Style aus."
 #, fuzzy
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Erstelle Supportdateien für %s."
+msgid "Creating support files for [%s]."
+msgstr "Erstelle Supportdateien für %s."
 #, fuzzy
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Kategorie-Dateien für <%s> sind nicht vorhanden. "
+msgid "Category file for [%s] not available"
+msgstr "Kategorie-Dateien für <%s> sind nicht vorhanden. "
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
+msgid "%s: <%s> raster map not found"
 #, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
+msgid "%s: <%s> raster map exists already"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#~ msgstr "Kann die Kategorie-Datei der Karte <%s> nicht schreiben"
+msgid "Cannot read category file of raster map <%s>"
+msgstr "Kann die Kategorie-Datei der Karte <%s> nicht schreiben"
 #, fuzzy
-#~ msgid "%s - map not found"
-#~ msgstr "%s: %s nicht gefunden."
+msgid "%s - map not found"
+msgstr "%s: %s nicht gefunden."
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
-#~ msgstr "Kann %s nicht öffnen."
+msgid "%s: Cannot open [%s]"
+msgstr "Kann %s nicht öffnen."
 #, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "<%s> nicht gefunden"
+msgid "%s not found"
+msgstr "<%s> nicht gefunden"
 #, fuzzy
-#~ msgid "Could not access %s layer"
-#~ msgstr "Konnte G3D Karte nicht schließen."
+msgid "Could not access %s layer"
+msgstr "Konnte G3D Karte nicht schließen."
 #, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "Vektorkarte <%s> nicht gefunden"
+msgid "Vector map %s - not found"
+msgstr "Vektorkarte <%s> nicht gefunden"
 #, fuzzy
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Name einer existierenden Rasterkarte mit Höheninformationen."
+msgid "Raster map containing elevation data"
+msgstr "Name einer existierenden Rasterkarte mit Höheninformationen."
 #, fuzzy
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Rasterkarte mit den Klassifikationsergebnissen"
+msgid "Raster map name for storing results"
+msgstr "Rasterkarte mit den Klassifikationsergebnissen"
 #, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "Koordinate, die den Standpunkt identifiziert."
+msgid "Height of the viewing location"
+msgstr "Koordinate, die den Standpunkt identifiziert."
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: <%s> nicht gefunden."
+msgid "%s: <%s> cellfile not found"
+msgstr "%s: <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "Obere Karte <%s> nicht gefunden"
+msgid "rgb cell map [%s] not found\n"
+msgstr "Obere Karte <%s> nicht gefunden"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
 #, fuzzy
-#~ msgid "raster map <%s> not found"
+msgid "raster map <%s> not found"
 #, fuzzy
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "Kann den Header für die 3D-Rasterkarte <%s> in <%s> nicht lesen."
+msgid "can't read header for <%s> in <%s>"
+msgstr "Kann den Header für die 3D-Rasterkarte <%s> in <%s> nicht lesen."
 #, fuzzy
-#~ msgid "region <%s> not found"
-#~ msgstr "Region <%s> nicht gefunden."
+msgid "region <%s> not found"
+msgstr "Region <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "Kann Region <%s> in <%s> nicht lesen."
+msgid "can't read region <%s> in <%s>"
+msgstr "Kann Region <%s> in <%s> nicht lesen."
 #, fuzzy
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "Kann 3D-View-Datei <%s> in <%s> nicht öffnen."
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "Kann 3D-View-Datei <%s> in <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "Kann 3D-View-Datei <%s> in <%s> nicht lesen."
+msgid "can't read 3dview file <%s> in <%s>"
+msgstr "Kann 3D-View-Datei <%s> in <%s> nicht lesen."
 #, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "Kann die Vektorkarte %s nicht öffnen."
+msgid "can't open vector map <%s> in <%s>"
+msgstr "Kann die Vektorkarte %s nicht öffnen."
 #, fuzzy
-#~ msgid "invalid region: %s"
-#~ msgstr "Ungültige Region: %s."
+msgid "invalid region: %s"
+msgstr "Ungültige Region: %s."
 #, fuzzy
-#~ msgid "Creating support files"
-#~ msgstr "Erzeuge Supportdateien."
+msgid "Creating support files"
+msgstr "Erzeuge Supportdateien."
 #, fuzzy
-#~ msgid "can't open %s"
+msgid "can't open %s"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "Kann <%s> nicht öffnen."
+msgid "%s: unable to open %s"
+msgstr "Kann <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
-#~ msgstr "Kann die Zeile nicht lesen."
+msgid "Cannot read %s"
+msgstr "Kann die Zeile nicht lesen."
 #, fuzzy
-#~ msgid "map layer [%s] not legal for GRASS"
-#~ msgstr "GRASS"
+msgid "map layer [%s] not legal for GRASS"
+msgstr "GRASS"
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "Rasterkarte <%s> nicht gefunden."
+msgid "elevation file [%s] not found"
+msgstr "Rasterkarte <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr ""
-#~ "minimale berechnete Exposition%.4f  maximale berechnete Exposition %.4f."
+msgid "min computed aspect %.4f  max computed aspect %.4f"
+msgstr ""
+"minimale berechnete Exposition%.4f  maximale berechnete Exposition %.4f."
 #, fuzzy
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "Berechnete minimale Hangneigung %.4f, maximale Hangneigung %.4f."
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "Berechnete minimale Hangneigung %.4f, maximale Hangneigung %.4f."
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Kann Tabelle <%s> nicht beschreiben."
+msgid "Cannot describe table <%s>"
+msgstr "Kann Tabelle <%s> nicht beschreiben."
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
-#~ msgstr "Kann nicht an Tabelle <%s> anfügen."
+msgid "Cannot insert values: %s"
+msgstr "Kann nicht an Tabelle <%s> anfügen."
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s=%s - Ungültige Anzahl von Interpolationspunkten."
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s=%s - Ungültige Anzahl von Interpolationspunkten."
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "Kann Datenbank <%s> mit Treiber <%s> nicht öffnen."
+msgid "Unable to open database %s by driver %s"
+msgstr "Kann Datenbank <%s> mit Treiber <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "Datenbankverbindung nicht definiert. Benutzen Sie db.connect."
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Datenbankverbindung nicht definiert. Benutzen Sie db.connect."
 #, fuzzy
-#~ msgid "Could not find input %s"
-#~ msgstr "Kann die Karte %s nicht öffnen."
+msgid "Could not find input %s"
+msgstr "Kann die Karte %s nicht öffnen."
 #, fuzzy
-#~ msgid "Could not open input"
+msgid "Could not open input"
 #, fuzzy
-#~ msgid "Could not open output"
+msgid "Could not open output"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
 #, fuzzy
-#~ msgid "Unkown item type in pad: %s"
+msgid "Unkown item type in pad: %s"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
 #, fuzzy
-#~ msgid "Database connection not defined\n"
+msgid "Database connection not defined\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s in %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s in %s: %s"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+msgid "Can't write region <%s>"
+msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
 #, fuzzy
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** Ungültige Eingabe **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** Ungültige Eingabe **"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Keine Graphik-Ausgabe ausgewählt."
+msgid "No graphics device selected."
+msgstr "Keine Graphik-Ausgabe ausgewählt."
 #, fuzzy
-#~ msgid "Unable to read raster row."
-#~ msgstr "Kann die Rasterzeile nicht lesen."
+msgid "Unable to read raster row."
+msgstr "Kann die Rasterzeile nicht lesen."
 #, fuzzy
-#~ msgid "Training map [%s] not found."
+msgid "Training map [%s] not found."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
-#~ msgid "input raster map"
-#~ msgstr "rote Eingabe-Rasterkarte."
+msgid "input raster map"
+msgstr "rote Eingabe-Rasterkarte."
 #, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "Ungültiger Ausgabe-Dateiname<%s>."
+msgid "Illegal file name: %s"
+msgstr "Ungültiger Ausgabe-Dateiname<%s>."
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Kann die Layer-Informationen der Vektorkarte nicht bekommen"
+msgid "Cannot get layer info for vector map"
+msgstr "Kann die Layer-Informationen der Vektorkarte nicht bekommen"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr "Kann die Rasterkarte <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "Benutze die Kategorie-Werte, die von der Coverkarte bedeckt sind."
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "Benutze die Kategorie-Werte, die von der Coverkarte bedeckt sind."
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s: Rasterkarte %s nicht gefunden."
+msgid "%s: %s - raster map not found"
+msgstr "%s: Rasterkarte %s nicht gefunden."
 #, fuzzy
-#~ msgid "%s: %s - illegal name"
-#~ msgstr "%s=%s - unzulässiger Wert."
+msgid "%s: %s - illegal name"
+msgstr "%s=%s - unzulässiger Wert."
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "Fehler beim Lesen der Cats-Datei <%s>."
+msgid "%s: ERROR reading category file for %s"
+msgstr "Fehler beim Lesen der Cats-Datei <%s>."
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "%s: %s - illegal units"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "Lese Rasterkarte <%s> ..."
+msgid "Reading input map (%s)    ... "
+msgstr "Lese Rasterkarte <%s> ..."
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: Fehler  beim Ausführen des Kommandos %s."
+msgid "%s - ERROR reading %s"
+msgstr "%s: Fehler  beim Ausführen des Kommandos %s."
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "Schreibe Ausgabe-Rasterkarte %s ..."
+msgid "Writing output map (%s)   ... "
+msgstr "Schreibe Ausgabe-Rasterkarte %s ..."
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "%s - ERROR writing %s"
+msgid "%s - ERROR writing %s"
 #, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "Lese Rasterkarte..."
+msgid "Reading raster map... "
+msgstr "Lese Rasterkarte..."
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "Schreibe Rasterkarte..."
+msgid "Writing raster map... "
+msgstr "Schreibe Rasterkarte..."
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Kategorie-Liste, z.B.: 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Kategorie-Liste, z.B.: 1,3-8,13"
 #, fuzzy
-#~ msgid "Output separator character (default: tab)"
-#~ msgstr "Trennzeichen zur Ausgabe (Standard: Tabulator)"
+msgid "Output separator character (default: tab)"
+msgstr "Trennzeichen zur Ausgabe (Standard: Tabulator)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot find file %s"
-#~ msgstr "Kann Datei <%s> nicht finden."
+msgid "Cannot find file %s"
+msgstr "Kann Datei <%s> nicht finden."
 #, fuzzy
-#~ msgid "Cannot get header for %s"
-#~ msgstr "Kann den Header für die Karte <%s> nicht schreiben."
+msgid "Cannot get header for %s"
+msgstr "Kann den Header für die Karte <%s> nicht schreiben."
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
-#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen"
+msgid "Cannot create raster map %s"
+msgstr "Kann die Rasterkarte <%s> nicht erzeugen"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Cannot create vector map %s"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Anzahl der Reihen, die im Hauptspeicher gehalten werden sollen."
+msgid "Number of raster rows to hold in memory"
+msgstr "Anzahl der Reihen, die im Hauptspeicher gehalten werden sollen."
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Gebe nur Rasterkartentyp aus."
+msgid "Print raster map title only"
+msgstr "Gebe nur Rasterkartentyp aus."
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Unbekannter Typ: %c"
+msgid "unknown type: %d"
+msgstr "Unbekannter Typ: %c"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
 #, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr "Kann Speicherplatz zum Lesen des GRASS Rasterdaten nicht belegen."
+msgid "Cannot allocate buffer for reading null values."
+msgstr "Kann Speicherplatz zum Lesen des GRASS Rasterdaten nicht belegen."
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Kann Rasterzeile %d nicht lesen."
+msgid "Cannot read GRASS raster."
+msgstr "Kann Rasterzeile %d nicht lesen."
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
-#~ msgstr "Kann Rasterkarten nicht schreiben."
+msgid "Cannot write GDAL raster."
+msgstr "Kann Rasterkarten nicht schreiben."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Kann Datei %s nicht löschen."
+msgid "Cannot get [%s] driver"
+msgstr "Kann Datei %s nicht löschen."
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
-#~ msgstr "Kann Benutzer/Passwort nicht setzen."
+msgid "Couldn't set geo transform."
+msgstr "Kann Benutzer/Passwort nicht setzen."
 #, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "Kann die Projektionsdatei %s nicht erzeugen."
+msgid "Couldn't set projection."
+msgstr "Kann die Projektionsdatei %s nicht erzeugen."
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
 #, fuzzy
-#~ msgid "Cannot open output map."
+msgid "Cannot open output map."
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "Metrische Belegung."
+msgid "memory allocation failure"
+msgstr "Metrische Belegung."
 #, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "Kann Rasterkarte <%s> nicht finden. "
+msgid "Can't find data map."
+msgstr "Kann Rasterkarte <%s> nicht finden. "
 #, fuzzy
-#~ msgid "Can't find clump map."
-#~ msgstr "Kann Rasterkarte %s nicht finden. "
+msgid "Can't find clump map."
+msgstr "Kann Rasterkarte %s nicht finden. "
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Ausgabekarte mit Hangexposition."
+msgid "Output terrain only vector map name"
+msgstr "Ausgabekarte mit Hangexposition."
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#~ msgstr "Kann Vektorkarte <%s> in <%s> nicht öffnen."
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "Kann Vektorkarte <%s> in <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
-#~ msgstr "Baue Topologie neu auf..."
+msgid "Rebuilding topology ..."
+msgstr "Baue Topologie neu auf..."
 #, fuzzy
-#~ msgid "No record for cat = %d"
-#~ msgstr "Kein Eintrag für Linie (cat = %d)"
+msgid "No record for cat = %d"
+msgstr "Kein Eintrag für Linie (cat = %d)"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
-#~ msgstr "Entferne Doppelte ..."
+msgid "Removing duplicates ..."
+msgstr "Entferne Doppelte ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Füge Kategorien an...\n"
+msgid "Attaching islands ..."
+msgstr "Füge Kategorien an...\n"
 #, fuzzy
-#~ msgid "Cannot calculate area centroid."
-#~ msgstr "Kann den Flächenzentroiden nicht berechnen."
+msgid "Cannot calculate area centroid."
+msgstr "Kann den Flächenzentroiden nicht berechnen."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "Vektorkarte <%s> nicht gefunden."
+msgid "Vector map <%s> not found in current mapset"
+msgstr "Vektorkarte <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
-#~ msgstr "Allokiere Speicher für die bilineare Interpolation."
+msgid "Error allocating memory for `lines_visited'"
+msgstr "Allokiere Speicher für die bilineare Interpolation."
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Die minimale Anzahl der Eingabekarten ist zwei."
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Die minimale Anzahl der Eingabekarten ist zwei."
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "Die Datenbankverbindung für den Layer %d ist nicht definiert"
+msgid "Database connection not defined for layer <%d>"
+msgstr "Die Datenbankverbindung für den Layer %d ist nicht definiert"
 #, fuzzy
-#~ msgid "Attribute column(s)"
-#~ msgstr "Attribute"
+msgid "Attribute column(s)"
+msgstr "Attribute"
 #, fuzzy
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Kann den Select-Cursor <%s> nicht öffnen."
+msgid "Cannot open select cursor"
+msgstr "Kann den Select-Cursor <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen."
+msgid "Cannot get layer info"
+msgstr "Kann die Informationen zu Datenbankverbindung nicht lesen."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Building topology for %s ..."
-#~ msgstr ""
-#~ "\n"
-#~ "Erstelle Topologie für %s ..."
+msgid ""
+"\n"
+"Building topology for %s ..."
+msgstr ""
+"\n"
+"Erstelle Topologie für %s ..."
 #, fuzzy
-#~ msgid "cell file [%s] not found"
-#~ msgstr "Cell-Datei nicht gefunden."
+msgid "cell file [%s] not found"
+msgstr "Cell-Datei nicht gefunden."
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
+msgid "Cannot rewrite line %d"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Habe nichts zu zeigen."
+msgid "Editing tool"
+msgstr "Habe nichts zu zeigen."
 #, fuzzy
-#~ msgid "For tool 'add', see also 'thresh' parameter"
-#~ msgstr ""
-#~ "Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
+msgid "For tool 'add', see also 'thresh' parameter"
+msgstr ""
+"Kopiere die Attributtabelle nicht mit (bitte Parameter 'new' beachten)."
 #, fuzzy
-#~ msgid "Snap also to vertex (not implemented yet)"
+msgid "Snap also to vertex (not implemented yet)"
 #, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "nicht"
+msgid "Close boundaries"
+msgstr "nicht"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "Kann nicht von <%s> lesen."
+msgid "Cannot copy line %d, editing terminated"
+msgstr "Kann nicht von <%s> lesen."
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "Kann die Zeit nicht auslesen:"
+msgid "Cannot snap lines %d,%d"
+msgstr "Kann die Zeit nicht auslesen:"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d tote Linien (dead lines) übersprungen.\n"
+msgid "%d lines modified"
+msgstr "%-5d tote Linien (dead lines) übersprungen.\n"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgstr "Kann die ASCII-Datei %s nicht öffnen."
+msgid "Could not open ASCII file <%s>"
+msgstr "Kann die ASCII-Datei %s nicht öffnen."
 #, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "Gebe nur Rasterkartenausdehnung aus."
+msgid "Print vector map region only"
+msgstr "Gebe nur Rasterkartenausdehnung aus."
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "Kann die Layer-Informationen der Vektorkarte nicht auswählen."
+msgid "Cannot get layer info for vector map <%s>"
+msgstr "Kann die Layer-Informationen der Vektorkarte nicht auswählen."
 #, fuzzy
-#~ msgid "Rotation angle (degrees counter-clockwise from East)"
-#~ msgstr "Rotationswinkel in Grad (gegen den Uhrzeigersinn)."
+msgid "Rotation angle (degrees counter-clockwise from East)"
+msgstr "Rotationswinkel in Grad (gegen den Uhrzeigersinn)."
 #, fuzzy
-#~ msgid "Cannot select attribute."
-#~ msgstr "Kann folgende Attribute nicht auswählen: %s"
+msgid "Cannot select attribute."
+msgstr "Kann folgende Attribute nicht auswählen: %s"
 #, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "Erstelle neue Cats-Datei..."
+msgid "Creating vector grid..."
+msgstr "Erstelle neue Cats-Datei..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Could not find vector map <%s> in current mapset"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 #, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d Feature geschrieben."
+msgid "[%d] features written"
+msgstr "%d Feature geschrieben."
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "Benötigter Parameter <%s> wurde nicht angegeben"
+msgid "Parameter <%s> not set"
+msgstr "Benötigter Parameter <%s> wurde nicht angegeben"
 #, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "Eingabe-Vektorkarte, die Linien enthält"
+msgid "Input map containing lines"
+msgstr "Eingabe-Vektorkarte, die Linien enthält"
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Ausgabekarte mit den Punkten wird geschrieben."
+msgid "Output map where segments will be written"
+msgstr "Ausgabekarte mit den Punkten wird geschrieben."
 #, fuzzy
-#~ msgid "Cannot get layer information for vector map"
+msgid "Cannot get layer information for vector map"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
-#~ msgstr "aspin Rasterkarte <%s> nicht gefunden."
+msgid "Database record for cat %d not found"
+msgstr "aspin Rasterkarte <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Kann die Vektorkarte <%s> nicht öffnen"
+msgid "Not able to open vector map <%s>"
+msgstr "Kann die Vektorkarte <%s> nicht öffnen"
 #, fuzzy
-#~ msgid "No table."
-#~ msgstr "Keine Tabelle."
+msgid "No table."
+msgstr "Keine Tabelle."
 #, fuzzy
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
 #, fuzzy
-#~ msgid "driver name"
-#~ msgstr "Eingabe-Treibername"
+msgid "driver name"
+msgstr "Eingabe-Treibername"
 #, fuzzy
-#~ msgid "database name"
-#~ msgstr "Eingabe-Datenbankname"
+msgid "database name"
+msgstr "Eingabe-Datenbankname"
 #, fuzzy
-#~ msgid "Driver name"
+msgid "Driver name"
 #, fuzzy
-#~ msgid "Cannot list databases."
-#~ msgstr "Kann Datenbank <%s> nicht öffnen."
+msgid "Cannot list databases."
+msgstr "Kann Datenbank <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "database location"
-#~ msgstr "Pfad zur resultierenden VTK-Datei."
+msgid "database location"
+msgstr "Pfad zur resultierenden VTK-Datei."
 #, fuzzy
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Kann Daten nicht aus der Tabelle selektieren"
+msgid "Table name, select all from this table"
+msgstr "Kann Daten nicht aus der Tabelle selektieren"
 #, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "Ausgabe Feld-Trennzeichen"
+msgid "output field separator"
+msgstr "Ausgabe Feld-Trennzeichen"
 #, fuzzy
-#~ msgid "output vertical record separator"
-#~ msgstr "Vertikales Trennzeichen für die Ausgabe."
+msgid "output vertical record separator"
+msgstr "Vertikales Trennzeichen für die Ausgabe."
 #, fuzzy
-#~ msgid "null value indicator"
-#~ msgstr "Nullwert-Indikator"
+msgid "null value indicator"
+msgstr "Nullwert-Indikator"
 #, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "In der Ausgabe kein Spaltennamen ausgeben."
+msgid "do not include column names in output"
+msgstr "In der Ausgabe kein Spaltennamen ausgeben."
 #, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "Vertikale Ausgabe (anstatt horizontal)."
+msgid "vertical output (instead of horizontal)"
+msgstr "Vertikale Ausgabe (anstatt horizontal)."
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr "Name einer existierenden Rasterkarte."
+msgid "Name of existing raster map"
+msgstr "Name einer existierenden Rasterkarte."
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Kann neu Reihe <%s> nicht einfügen."
+msgid "Cannot find mapset for %s"
+msgstr "Kann neu Reihe <%s> nicht einfügen."
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "Kann grid3-Datei <%s> nicht finden."
+msgid "Not able to open file for [%s]"
+msgstr "Kann grid3-Datei <%s> nicht finden."
 #, fuzzy
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Layer <%s> ist nicht vorhanden."
+msgid "Label file [%s] not available"
+msgstr "Layer <%s> ist nicht vorhanden."
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
-#~ msgstr "Kann Rasterkarte <%s> in <%s> nicht öffnen."
+msgid "Unable to open raster map [%s] in [%s]"
+msgstr "Kann Rasterkarte <%s> in <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Table to be imported"
-#~ msgstr "Zu importierende Rasterdatei."
+msgid "Table to be imported"
+msgstr "Zu importierende Rasterdatei."
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "Unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "Kann die Ausgabekarte nicht erzeugen."
+msgid "Unable to create output <%s>"
+msgstr "Kann die Ausgabekarte nicht erzeugen."
 #, fuzzy
-#~ msgid "Input file [%s] not found."
+msgid "Input file [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
-#~ msgstr "Kann Ausgabedatei <%s> nicht öffnen."
+msgid "Unable to open output file <%s>."
+msgstr "Kann Ausgabedatei <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "Multiplikator für Ascii-Daten"
+msgid "Multiplier for ascii data"
+msgstr "Multiplikator für Ascii-Daten"
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#~ msgstr "Kann die temporäre Datei <%s> nicht öffnen"
+msgid "Could not open temporary file: [%s]"
+msgstr "Kann die temporäre Datei <%s> nicht öffnen"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "unable to create raster"
-#~ msgstr "Kann die Rasterkarte nicht erzeugen"
+msgid "unable to create raster"
+msgstr "Kann die Rasterkarte nicht erzeugen"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "Kann die Datei <%s> nicht öffnen."
+msgid "Cannot open file for <%s>"
+msgstr "Kann die Datei <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "Name der Ausgabe-Rasterkarte."
+msgid "Name of the random surface to be produced"
+msgstr "Name der Ausgabe-Rasterkarte."
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgstr "%s: Kann die Rasterkarte <%s> in Mapset <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
+msgid "No db connection for driver <%s> defined. Run db.connect."
 #, fuzzy
-#~ msgid "Table name"
-#~ msgstr "Eingabetabelle"
+msgid "Table name"
+msgstr "Eingabetabelle"
 #, fuzzy
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr "Gibt derzeitige Verbindungsparameter aus und beendet sich."
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr "Gibt derzeitige Verbindungsparameter aus und beendet sich."
 #, fuzzy
-#~ msgid "x column name"
-#~ msgstr "Spaltenname für Y-Koordinate."
+msgid "x column name"
+msgstr "Spaltenname für Y-Koordinate."
 #, fuzzy
-#~ msgid "z column name"
+msgid "z column name"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
-#~ msgstr "Kann die Tabelle <%s> nicht verändern."
+msgid "Cannot drop table: %s"
+msgstr "Kann die Tabelle <%s> nicht verändern."
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
-#~ msgstr "Kann Daten nicht aus der Tabelle selektieren."
+msgid "Cannot fetch data from table"
+msgstr "Kann Daten nicht aus der Tabelle selektieren."
 #, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "OGR Datenquelle.\n"
-#~ "\t\tESRI Shapefile: Verzeichnis, welches die Shapes beinhaltet.\n"
-#~ "\t\tMapInfo File: Verzeichnis, welches die MapInfo-Files enthält."
+msgid ""
+"OGR output datasource name. For example:\n"
+"\t\tESRI Shapefile: filename or directory for storage\n"
+"\t\tMapInfo File: filename or directory for storage"
+msgstr ""
+"OGR Datenquelle.\n"
+"\t\tESRI Shapefile: Verzeichnis, welches die Shapes beinhaltet.\n"
+"\t\tMapInfo File: Verzeichnis, welches die MapInfo-Files enthält."
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "<%s> konnte nicht gefunden werden!"
+msgid "SVG file <%s> cannot be opened"
+msgstr "<%s> konnte nicht gefunden werden!"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "Lese Eingabe ..."
+msgid "Querying input '%s' ... "
+msgstr "Lese Eingabe ..."
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Verarbeite ainput Zeilen ..."
+msgid "Copying %s input lines ... "
+msgstr "Verarbeite ainput Zeilen ..."
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 #, fuzzy
-#~ msgid "no record for cat = %d"
+msgid "no record for cat = %d"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "Kann die Vektorkarte <%s> nicht finden."
+msgid "Cannot find line of cat %d"
+msgstr "Kann die Vektorkarte <%s> nicht finden."
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr ""
-#~ "Datenbankverbindung für Layer <%d> nicht definiert. Bitte benutzen Sie "
-#~ "zuerst v.db.connect."
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgstr ""
+"Datenbankverbindung für Layer <%d> nicht definiert. Bitte benutzen Sie "
+"zuerst v.db.connect."
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Exportiert GRASS Vektorkarten in das DXF-Dateiformat."
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file holding transform coordinates (if not given transformation "
-#~ "options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be "
-#~ "used instead)"
-#~ msgstr ""
-#~ "Benutze Transformationsoptionen (xshift, yshift, zshift, xscale, yscale, "
-#~ "zscale, zrot) anstelle von Punkten."
+msgid ""
+"ASCII file holding transform coordinates (if not given transformation "
+"options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be used "
+"instead)"
+msgstr ""
+"Benutze Transformationsoptionen (xshift, yshift, zshift, xscale, yscale, "
+"zscale, zrot) anstelle von Punkten."
 #, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr ""
-#~ "ASCII-Datei, die in eine binäre Vektordatei konvertiert werden soll. Wenn "
-#~ "nichts angegeben wird, wird von der Standardeingabe gelesen."
+msgid "Read coordinates from standard input"
+msgstr ""
+"ASCII-Datei, die in eine binäre Vektordatei konvertiert werden soll. Wenn "
+"nichts angegeben wird, wird von der Standardeingabe gelesen."
 #, fuzzy
-#~ msgid "The '-s' flag is deprecated and will be removed in future"
-#~ msgstr ""
-#~ "Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
-#~ "ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
+msgid "The '-s' flag is deprecated and will be removed in future"
+msgstr ""
+"Der Schalter '-q' wurde ersetzt und wird in einer der kommenden Versionen "
+"ersatzlos gestrichen. Bitte verwenden Sie stattdessen '--quiet'."
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
+msgid "Raster map <%s>] not found"
+msgstr "Rasterkarte <%s> konnte nicht gefunden werden."
 #, fuzzy
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Kann Treiber <%s> nicht starten"
+msgid "Cannot start driver '%s'."
+msgstr "Kann Treiber <%s> nicht starten"
 #, fuzzy
-#~ msgid "Cannot describe table"
-#~ msgstr "Kann die Tabelle nicht kopieren."
+msgid "Cannot describe table"
+msgstr "Kann die Tabelle nicht kopieren."
 #, fuzzy
-#~ msgid "Cannot start driver <%s>."
+msgid "Cannot start driver <%s>."
 #, fuzzy
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "<%s> ist ein ungültiger Dateiname"
+msgid "[%s] is an illegal name"
+msgstr "<%s> ist ein ungültiger Dateiname"
 #, fuzzy
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Kann nicht in die Datei schreiben."
+msgid "Cannot write to <%s>"
+msgstr "Kann nicht in die Datei schreiben."
 #, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 #, fuzzy
-#~ msgid "Raster map [%s] not available"
+msgid "Raster map [%s] not available"
 #, fuzzy
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Farbtabelle für <%s> nicht vorhanden"
+msgid "color file for [%s] not available"
+msgstr "Farbtabelle für <%s> nicht vorhanden"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
+msgid "Raster file [%s] not available"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
 #, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Cannot open driver %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
 #, fuzzy
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Speicher ist zu Ende (Out-of-memory)."
+msgid "Out of Memory!\n"
+msgstr "Speicher ist zu Ende (Out-of-memory)."
 #, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "Kann Eingabe-Rasterkarte nicht richtig lesen."
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "Kann Eingabe-Rasterkarte nicht richtig lesen."
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#~ msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
+msgid "Insufficent memory for allocation of data sturcture"
+msgstr "Ungenügend Speicher für das Belegen der Datenstruktur."
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
-#~ msgid "Insufficent memory for allocation of data structure."
+msgid "Insufficent memory for allocation of data structure."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "Exportiert GRASS Rasterdaten in GDAL-unterstütze Formate."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "Exportiert GRASS Rasterdaten in GDAL-unterstütze Formate."
 #, fuzzy
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
-#~ msgid "CREATING SUPPORT FILES ..."
-#~ msgstr "Erstelle Support-Dateien...."
+msgid "CREATING SUPPORT FILES ..."
+msgstr "Erstelle Support-Dateien...."
 #, fuzzy
-#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "<%s> ist kein gültiger GRASS Kartenname."
+msgid "<%s> is not a valid GRASS map name"
+msgstr "<%s> ist kein gültiger GRASS Kartenname."
 #, fuzzy
-#~ msgid "Cannot find %s"
+msgid "Cannot find %s"
 #, fuzzy
-#~ msgid "could not read range file"
-#~ msgstr "Kann die Range-Datei nicht lesen."
+msgid "could not read range file"
+msgstr "Kann die Range-Datei nicht lesen."
-#~ msgid "OUT OF MEMORY !!!\n"
-#~ msgstr "Platz im Hauptspeicher reicht nicht aus !!!\n"
+msgid "OUT OF MEMORY !!!\n"
+msgstr "Platz im Hauptspeicher reicht nicht aus !!!\n"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Name of the input raster map"
-#~ msgstr "Name der Eingabe-Rasterkarte."
+msgid "Name of the input raster map"
+msgstr "Name der Eingabe-Rasterkarte."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#~ msgstr "Lese <%s> in <%s>"
+msgid "Filtering [%s] in [%s]"
+msgstr "Lese <%s> in <%s>"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "Lese Rasterkarte <%s in %s> ..."
+msgid "Open raster map %s in %s = %d"
+msgstr "Lese Rasterkarte <%s in %s> ..."
 #, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "Fehler beim Lesen der Rasterkarte."
+msgid "Closing raster map"
+msgstr "Fehler beim Lesen der Rasterkarte."
 #, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "Öffnen der temporären Datei nicht möglich."
+msgid "Swap temp files"
+msgstr "Öffnen der temporären Datei nicht möglich."
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
-#~ msgstr "%s: ungültiger Wert."
+msgid "%s: illegal map name"
+msgstr "%s: ungültiger Wert."
 #, fuzzy
-#~ msgid "Name of the new raster map"
-#~ msgstr "Name der zweiten Rasterkarte."
+msgid "Name of the new raster map"
+msgstr "Name der zweiten Rasterkarte."
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
+msgid "can't open raster map <%s> in mapset %s"
 #, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-"
-#~ "Auflösung der DERZEITIG EINGESTELLTEN REGION."
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr ""
+"Exportiert 3 GRASS Rasterkarten (R,G,B) als PPM-Bild mit der Pixel-Auflösung "
+"der DERZEITIG EINGESTELLTEN REGION."
 #, fuzzy
-#~ msgid "Raster input map"
+msgid "Raster input map"
 #, fuzzy
-#~ msgid "Mapset of input map"
+msgid "Mapset of input map"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "Prüfe Location %s, Mapset %s:"
+msgid "Checking location %s, mapset %s:"
+msgstr "Prüfe Location %s, Mapset %s:"
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr ""
-#~ "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden"
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgstr "Vektordatei <%s> in der Location <%s> im Mapset <%s> nicht vorhanden"
 #, fuzzy
-#~ msgid "Can't work with xy data"
-#~ msgstr "Kann die Daten nicht holen."
+msgid "Can't work with xy data"
+msgstr "Kann die Daten nicht holen."
 #, fuzzy
-#~ msgid "ns-res:\t%f"
-#~ msgstr "nsres=%f"
+msgid "ns-res:\t%f"
+msgstr "nsres=%f"
 #, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "Fehler beim Lesen der Zell-Daten."
+msgid "Error writing output map"
+msgstr "Fehler beim Lesen der Zell-Daten."
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "input map can NOT be the same as output map"
-#~ msgstr "Die Eingabekarte darf NICHT identisch sein mit der Ausgabekarte."
+msgid "input map can NOT be the same as output map"
+msgstr "Die Eingabekarte darf NICHT identisch sein mit der Ausgabekarte."
 #, fuzzy
-#~ msgid "no rules specified. [%s] not created"
-#~ msgstr "Keine Regeln angegeben. <%s> nicht erzeugt."
+msgid "no rules specified. [%s] not created"
+msgstr "Keine Regeln angegeben. <%s> nicht erzeugt."
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "Keine Regeln angegeben."
+msgid "no rules specified"
+msgstr "Keine Regeln angegeben."
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "Kann die Segmentdatei %s nicht öffnen."
+msgid "Can't open temp file [%s]"
+msgstr "Kann die Segmentdatei %s nicht öffnen."
 #, fuzzy
-#~ msgid "Names of existing raster maps"
-#~ msgstr "Name existierender Rasterkarte(n)"
+msgid "Names of existing raster maps"
+msgstr "Name existierender Rasterkarte(n)"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "CHILD[pid = %i] kann Rasterkarte nicht öffnen."
+msgid "%s in %s -can't open raster map"
+msgstr "CHILD[pid = %i] kann Rasterkarte nicht öffnen."
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
 #, fuzzy
-#~ msgid "%s=%s - illegal name"
+msgid "%s=%s - illegal name"
 #, fuzzy
-#~ msgid "%s: can't create %s"
-#~ msgstr "Fehler: Kann %s nicht erzeugen."
+msgid "%s: can't create %s"
+msgstr "Fehler: Kann %s nicht erzeugen."
-#~ msgid "Normalized"
-#~ msgstr "Normalisiert"
+msgid "Normalized"
+msgstr "Normalisiert"
 #, fuzzy
-#~ msgid "Out of memory!"
+msgid "Out of memory!"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Can't read current window parameters"
-#~ msgstr "Kann die aktuellen Regionsparameter nicht lesen."
+msgid "Can't read current window parameters"
+msgstr "Kann die aktuellen Regionsparameter nicht lesen."
 #, fuzzy
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr "Fehler beim Holen der Eingabe NULL-Zellen."
+msgid "Error getting input null cells at row %d from %s"
+msgstr "Fehler beim Holen der Eingabe NULL-Zellen."
-#~ msgid "[%s] file name not legal"
-#~ msgstr "[%s] ist ein ungültiger Name."
+msgid "[%s] file name not legal"
+msgstr "[%s] ist ein ungültiger Name."
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "[%s] ist ein ungültiger Name.\n"
+msgid "[%s] file name not legal\n"
+msgstr "[%s] ist ein ungültiger Name.\n"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "Angeforderte 3D-Rasterkarte nicht gefunden."
+msgid "Requested 3d raster map not found <%s>"
+msgstr "Angeforderte 3D-Rasterkarte nicht gefunden."
 #, fuzzy
-#~ msgid "Could not open elevation map"
-#~ msgstr "Kann die Höhenkarte nicht schließen"
+msgid "Could not open elevation map"
+msgstr "Kann die Höhenkarte nicht schließen"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "unable to close output map"
-#~ msgstr "Kann die Ausgabe-Karte nicht schließen."
+msgid "unable to close output map"
+msgstr "Kann die Ausgabe-Karte nicht schließen."
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "%s Datei(en), die entfernt werden sollen."
+msgid "Database's name couldn't be read"
+msgstr "%s Datei(en), die entfernt werden sollen."
 #, fuzzy
-#~ msgid "Driver's name couldn't be read"
+msgid "Driver's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
+msgid "Cannot open vector points map <%s>"
+msgstr "Kann die Vektor-Punktkarte <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Could not find input map <%s> in current mapset."
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
-#~ msgstr "von"
+msgid "Could not find input vector map %s"
+msgstr "von"
 #, fuzzy
-#~ msgid ""
-#~ "OGR layer name. If not given, all available layers are imported. "
-#~ "Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "OGR Layer-Name. Falls nicht angegeben, werden alle Layernamen in der "
-#~ "Datenquelle nur angezeigt.\n"
-#~ "\t\tESRI Shapefile: Shape-Name\n"
-#~ "\t\tMapInfo File: MapInfo-Name"
+msgid ""
+"OGR layer name. If not given, all available layers are imported. Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+"OGR Layer-Name. Falls nicht angegeben, werden alle Layernamen in der "
+"Datenquelle nur angezeigt.\n"
+"\t\tESRI Shapefile: Shape-Name\n"
+"\t\tMapInfo File: MapInfo-Name"
 #, fuzzy
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Die Datei <%s> existiert bereits."
+msgid "The vector '%s' already exists."
+msgstr "Die Datei <%s> existiert bereits."
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>"
+msgid "error opening raster map [%s]."
+msgstr "Fehler beim Öffnen der 3D-Rasterkarte <%s>"
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "Übetrage in die Karte ..."
+msgid "Patching file <%s@%s>"
+msgstr "Übetrage in die Karte ..."
 #, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "%d Einträge aktualisiert."
+msgid "[%d] files patched"
+msgstr "%d Einträge aktualisiert."
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
+msgid "Could not open vector map <%s>"
 #, fuzzy
-#~ msgid "Name of output raster map"
+msgid "Name of output raster map"
 #, fuzzy
-#~ msgid "Done          "
+msgid "Done          "
+msgstr "Fertig!       "
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
-#~ msgstr ""
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgstr ""
 #, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "Durchlauf %d (von %d)."
+msgid "Pass [%d] of [%d]:"
+msgstr "Durchlauf %d (von %d)."
 #, fuzzy
-#~ msgid "Illegal output name: '%s'"
+msgid "Illegal output name: '%s'"
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
 #, fuzzy
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "Kann die Eingabekarte nicht schließen."
+msgid "Could not close new 3d raster map"
+msgstr "Kann die Eingabekarte nicht schließen."
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Error reading wildcard."
-#~ msgstr "Fehler beim Lesen der Wildcard."
+msgid "Error reading wildcard."
+msgstr "Fehler beim Lesen der Wildcard."
 #, fuzzy
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
-#~ "Tripel (durch Doppelpunkte getrennt)."
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Farbe, die benutzt werden soll. Entweder GRASS Standardfarben oder R:G:B "
+"Tripel (durch Doppelpunkte getrennt)."
 #, fuzzy
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "Textfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "Textfarbe, entweder eine GRASS Standardfarbe oder ein R:G:B Tripel."
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr ""
-#~ "Kartenrand ist für eine LL-Location noch nicht implementiert; er wird "
-#~ "somit nicht gezeichnet."
+msgid "Border not yet implemented for LatLong locations: border not drawn."
+msgstr ""
+"Kartenrand ist für eine LL-Location noch nicht implementiert; er wird somit "
+"nicht gezeichnet."
 #, fuzzy
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Kann temporäre Datei nicht öffnen"
+msgid "Unable to open the temporary file."
+msgstr "Kann temporäre Datei nicht öffnen"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "Titel für die neue Rasterkarte."
+msgid "name for new raster map"
+msgstr "Titel für die neue Rasterkarte."
 #, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Output GRASS image file"
 #, fuzzy
-#~ msgid "Resulting output map"
-#~ msgstr "Auflösung der Ausgabe-Karte"
+msgid "Resulting output map"
+msgstr "Auflösung der Ausgabe-Karte"
 #, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "Name der Vektorkarte"
+msgid "name for new vector map"
+msgstr "Name der Vektorkarte"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Vektorausgabekarte mit den angepassten Punkten im Fluss."
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Vektorausgabekarte mit den angepassten Punkten im Fluss."
 #, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "Eingabe Vektorkarte mit Netzwerk"
+msgid "Input vector map"
+msgstr "Eingabe Vektorkarte mit Netzwerk"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "%s: Kann die temporäre Datei nicht öffnen"
+msgid "%s: ERROR can't open tempfile"
+msgstr "%s: Kann die temporäre Datei nicht öffnen"
 #, fuzzy
-#~ msgid "vector map <%s> not found"
+msgid "vector map <%s> not found"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"color\" specified - ignoring color"
-#~ msgstr ""
-#~ "Es wurden beide Optionen \"color\" UND \"rast\" angegeben - Ignoriere die "
-#~ "Option \"rast\"."
+msgid "Both \"-i\" AND \"color\" specified - ignoring color"
+msgstr ""
+"Es wurden beide Optionen \"color\" UND \"rast\" angegeben - Ignoriere die "
+"Option \"rast\"."
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
-#~ "Es wurden beide Optionen \"color\" UND \"rules\" angegeben - Ignoriere "
-#~ "die Option \"rules\". "
+msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
+msgstr ""
+"Es wurden beide Optionen \"color\" UND \"rules\" angegeben - Ignoriere die "
+"Option \"rules\". "
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
+msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
+msgstr ""
+"Option \"rast\"."
 #, fuzzy
-#~ msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
+msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
+msgstr ""
+"Option \"rast\"."
-#~ msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
+msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
+msgstr ""
 #, fuzzy
-#~ msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
-#~ msgstr ""
-#~ "Es wurden beide Optionen \"rast\" UND \"rules\" angegeben - Ignoriere die "
-#~ "Option \"rast\". "
+msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
+msgstr ""
+"Es wurden beide Optionen \"rast\" UND \"rules\" angegeben - Ignoriere die "
+"Option \"rast\". "
 #, fuzzy
-#~ msgid "<%s> raster map not found"
+msgid "<%s> raster map not found"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
+msgid "Can't get row %d from raster map %s"
+msgstr "Kann den Header der Rasterkarte <%s> nicht lesen."
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
 #, fuzzy
-#~ msgid "string representing no data cell value"
-#~ msgstr "Zeichenkette, die NODATA-Werte repräsentiert."
+msgid "string representing no data cell value"
+msgstr "Zeichenkette, die NODATA-Werte repräsentiert."
 #, fuzzy
-#~ msgid "File name of classification result"
+msgid "File name of classification result"
 #, fuzzy
-#~ msgid "File name of reference classes"
-#~ msgstr "Name der Datei mit den Referenz-Klassen"
+msgid "File name of reference classes"
+msgstr "Name der Datei mit den Referenz-Klassen"
 #, fuzzy
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "Breite Ausgabe mit 132 Spalten (Standard: 80)"
+msgid "wide report, 132 columns (default: 80)"
+msgstr "Breite Ausgabe mit 132 Spalten (Standard: 80)"
 #, fuzzy
-#~ msgid "quiet"
-#~ msgstr "schweigsam"
+msgid "quiet"
+msgstr "schweigsam"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "Ungültiger Ausgabedateiname"
+msgid "<%s> - illegal output file name"
+msgstr "Ungültiger Ausgabedateiname"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
 #, fuzzy
-#~ msgid "Base raster map"
-#~ msgstr "Name der Rasterkarte"
+msgid "Base raster map"
+msgstr "Name der Rasterkarte"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
-#~ msgid ""
-#~ "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr ""
-#~ "Rasterkarte, die die Höheninformationen beinhaltet. Wird für die 3D-"
-#~ "Informationen benötigt."
+msgid "Raster map that represents the elevation, used for the 3D information"
+msgstr ""
+"Rasterkarte, die die Höheninformationen beinhaltet. Wird für die 3D-"
+"Informationen benötigt."
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "Kann Ausgabedatei %s nicht öffnen."
+msgid "Problem opening input file [%s]"
+msgstr "Kann Ausgabedatei %s nicht öffnen."
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgstr "Kann den Header der Rasterkarte <%s> nicht lesen"
+msgid "Unable to read row %d in raster map [%s]"
+msgstr "Kann den Header der Rasterkarte <%s> nicht lesen"
 #, fuzzy
-#~ msgid "Elevation map"
-#~ msgstr "Höhenausrichtung"
+msgid "Elevation map"
+msgstr "Höhenausrichtung"
 #, fuzzy
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr ""
-#~ "(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter MASK)"
+msgid "Topographic index ln(a/tanB) map"
+msgstr ""
+"(o)   Karte des Topographischen Index ln(a/tanB) (mit angewandter MASK)"
 #, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "Detaillierte Ausgabe"
+msgid "Output verbosely"
+msgstr "Detaillierte Ausgabe"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgstr "Erstelle Support-Dateien."
+msgid "CREATING SUPPORT FILES"
+msgstr "Erstelle Support-Dateien."
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "Höhenprodukte für mapset [%s] in [%s]."
+msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
+msgstr "Höhenprodukte für mapset [%s] in [%s]."
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Auxiliar Table could not be dropped."
-#~ msgstr "Tabelle"
+msgid "Auxiliar Table could not be dropped."
+msgstr "Tabelle"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#~ msgstr "Kann %s nicht lesen."
+msgid "Cannot find input map <%s>"
+msgstr "Kann %s nicht lesen."
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "Eingabevektorkarte wurde nicht gefunden."
+msgid "Input vector map <%s> not found."
+msgstr "Eingabevektorkarte wurde nicht gefunden."
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Schreibe Attribute ..."
+msgid "Writing attributes ...\n"
+msgstr "Schreibe Attribute ..."
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "Kann die Eingabedatei <%s> nicht öffnen."
+msgid "Could not open temp file <%s>"
+msgstr "Kann die Eingabedatei <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "Zeigt die vorhandenen Layer und beendet sich."
+msgid "List available formats and exit"
+msgstr "Zeigt die vorhandenen Layer und beendet sich."
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "DXF Ausgabedatei."
+msgid "SVG output file"
+msgstr "DXF Ausgabedatei."
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "Could not find vector '%s'"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
 #, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "Keine Karte angegeben."
+msgid "No input coordinates provided"
+msgstr "Keine Karte angegeben."
 #, fuzzy
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Kann den Speicher nicht belegen."
+msgid "Unable to allocate memory."
+msgstr "Kann den Speicher nicht belegen."
 #, fuzzy
-#~ msgid "Raster output file"
-#~ msgstr "Name der Ausgabedatei"
+msgid "Raster output file"
+msgstr "Name der Ausgabedatei"
 #, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-#~ msgstr "Durchlauf %d (von %d) ..."
+msgid "Pass #%d (of %d) ... "
+msgstr "Durchlauf %d (von %d) ..."
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
 #, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "Behalte existierende Farbtabelle bei."
+msgid "Keep existing color table"
+msgstr "Behalte existierende Farbtabelle bei."
 #, fuzzy
-#~ msgid "List rules"
-#~ msgstr "Anzahl der Kontour-Level"
+msgid "List rules"
+msgstr "Anzahl der Kontour-Level"
 #, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "Gesprächiger Modus"
+msgid "Verbose mode."
+msgstr "Gesprächiger Modus"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d Reihen, %d Spalten."
+msgid " %d rows, %d cols."
+msgstr "%d Reihen, %d Spalten."
 #, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Integer-Zelltype.\n"
-#~ "Schreibe..."
+msgid ""
+"Integer cell type.\n"
+"Writing"
+msgstr ""
+"Integer-Zelltype.\n"
+"Schreibe..."
 #, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Fließkomma Zellentyp.\n"
-#~ "Schreibe..."
+msgid ""
+"Float cell type.\n"
+"Writing"
+msgstr ""
+"Fließkomma Zellentyp.\n"
+"Schreibe..."
 #, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Double Zelltype.\n"
-#~ "Schreibe..."
+msgid ""
+"Double cell type.\n"
+"Writing"
+msgstr ""
+"Double Zelltype.\n"
+"Schreibe..."
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#~ msgstr "Kann Header der Rasterkarte nicht lesen."
+msgid "%s in %s - can't read header file"
+msgstr "Kann Header der Rasterkarte nicht lesen."
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
-#~ msgstr "Kann die temporäre Datei nicht schreiben."
+msgid "%s - unable to create category file"
+msgstr "Kann die temporäre Datei nicht schreiben."
 #, fuzzy
-#~ msgid "verbose mode"
+msgid "verbose mode"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr ""
-#~ "Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
+msgid "Vector map with points for which to modify the attribute table"
+msgstr ""
+"Name der Vektorpunktekarte, dessen Attributtabelle editiert werden soll. "
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr ""
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Name der Rasterkarte, die angezeigt werden soll."
+msgid "Name of existing raster map to be displayed"
+msgstr "Name der Rasterkarte, die angezeigt werden soll."
 #, fuzzy
-#~ msgid "driver name:"
+msgid "driver name:"
 #, fuzzy
-#~ msgid "Database name:"
+msgid "Database name:"
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr ""
+msgid ""
+"ASCII file to be converted to binary vector map, if not given (or \"-\") "
+"reads from standard input"
+msgstr ""
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "Spaltentyp nicht unterstützt"
+msgid "column type not supported"
+msgstr "Spaltentyp nicht unterstützt"
 #, fuzzy
-#~ msgid "cannot select data from table"
-#~ msgstr "Kann die Daten (%s) nicht aus der Tabelle selektieren."
+msgid "cannot select data from table"
+msgstr "Kann die Daten (%s) nicht aus der Tabelle selektieren."
 #, fuzzy
-#~ msgid "cannot create table: %s"
-#~ msgstr "Kann Tabelle <%s> nicht erzeugen."
+msgid "cannot create table: %s"
+msgstr "Kann Tabelle <%s> nicht erzeugen."
 #, fuzzy
-#~ msgid "cannot create index"
-#~ msgstr "Kann keinen Index erstellen."
+msgid "cannot create index"
+msgstr "Kann keinen Index erstellen."
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "Kann Privilegien für die Tabelle <%s> nicht zuweisen."
+msgid "cannot grant privileges on table %s"
+msgstr "Kann Privilegien für die Tabelle <%s> nicht zuweisen."
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
-#~ msgstr "Kann Vektorkarte nicht lesen."
+msgid "Cannot find vector map"
+msgstr "Kann Vektorkarte nicht lesen."
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid ""
-#~ "Number of column used as z coordinate (first column is 1) for points "
-#~ "mode. If 0, z coordinate is not used."
-#~ msgstr ""
-#~ "Nummer der Spalte im Punkt-Modus, die als X-Koordinate genutzt werden "
-#~ "soll (erste Spalte is 1)."
+msgid ""
+"Number of column used as z coordinate (first column is 1) for points mode. "
+"If 0, z coordinate is not used."
+msgstr ""
+"Nummer der Spalte im Punkt-Modus, die als X-Koordinate genutzt werden soll "
+"(erste Spalte is 1)."
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
 #, fuzzy
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "Unbekanntes Wort <%s> im Vektor-Kopf"
+msgid "Unknown keyword [%s] in vector head."
+msgstr "Unbekanntes Wort <%s> im Vektor-Kopf"
 #, fuzzy
-#~ msgid "Region Growing"
-#~ msgstr "Rendering"
+msgid "Region Growing"
+msgstr "Rendering"
 #, fuzzy
-#~ msgid "#%s"
-#~ msgstr "%s"
+msgid "#%s"
+msgstr "%s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "Ein Fehler trat während des Lesens der Eingabe-Rasterkarte auf."
+msgid "Error while reading cell map."
+msgstr "Ein Fehler trat während des Lesens der Eingabe-Rasterkarte auf."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Fehler beim Entfernen der alten Maske MASK."
+msgid "Error while writing new cell map."
+msgstr "Fehler beim Entfernen der alten Maske MASK."
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#~ msgstr "Fehler beim Öffnen der Displaydatei <%s>."
+msgid "Error in opening output file <%s>"
+msgstr "Fehler beim Öffnen der Displaydatei <%s>."
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#~ msgstr "Kann Eingabe nicht von <%s> lesen."
+msgid "Unable to find input cell map <%s>"
+msgstr "Kann Eingabe nicht von <%s> lesen."
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Error in opening input file <%s>"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "Kann Zelldatei <%s> nicht zum Lesen öffnen."
+msgid "Unable to open cell man <%s> for input.\n"
+msgstr "Kann Zelldatei <%s> nicht zum Lesen öffnen."
 #, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "Unable to open cell map <%s> for output.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "Unable to read map raster row %d"
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Kann die Farbtabelle für %s nicht schreiben."
+msgid "Unable to write color table to raster [%s]"
+msgstr "Kann die Farbtabelle für %s nicht schreiben."
 #, fuzzy
-#~ msgid "Cannot find map %s"
-#~ msgstr "Kann %s nicht öffnen."
+msgid "Cannot find map %s"
+msgstr "Kann %s nicht öffnen."
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
 #, fuzzy
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Name der Filterdatei"
+msgid "Name of predefined rules file"
+msgstr "Name der Filterdatei"
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "R:G:B Werte liegen außerhalb der Spanne [0...255]: %d %d %d"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "R:G:B Werte liegen außerhalb der Spanne [0...255]: %d %d %d"
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgid "no such value"
-#~ msgstr "Solche Werte sind nicht vorhanden."
+msgid "no such value"
+msgstr "Solche Werte sind nicht vorhanden."
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:Linie %d:%s"
+msgid "%s:line %d:%s"
+msgstr "%s:Linie %d:%s"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "Punkt Klassifikation."
+msgid "bad color specification"
+msgstr "Punkt Klassifikation."
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - unbekannte Farbanfrage."
+msgid "%s - unknown color"
+msgstr "%s - unbekannte Farbanfrage."
 #, fuzzy
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Ungültige Farbe: %s"
+msgid "Valid colors are:\n"
+msgstr "Ungültige Farbe: %s"
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
-#~ msgstr "Kann die Rasterkarte <%s> nicht öffnen."
+msgid "Unable to find base map <%s>"
+msgstr "Kann die Rasterkarte <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
-#~ msgstr "Fehler beim Lesen der Cats-Datei <%s>."
+msgid "%s: reading category file for %s"
+msgstr "Fehler beim Lesen der Cats-Datei <%s>."
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#~ msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
+msgid "%s: unable to create raster map [%s]"
+msgstr "Kann die Rasterkarte <%s> nicht erzeugen."
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "Kann Datenbank <%s> mit Treiber <%s> nicht öffnen."
+msgid "Unable to open database %s with driver %s"
+msgstr "Kann Datenbank <%s> mit Treiber <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
 #, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid "Unable to find [%s]."
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#~ msgstr "Kann die Farbtabelle für %s nicht lesen."
+msgid "Unable to read cats table for %s"
+msgstr "Kann die Farbtabelle für %s nicht lesen."
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "%s: Kann die Rasterkarte <%s@%s> nicht öffnen."
+msgid "Could not open raster <%s>"
+msgstr "%s: Kann die Rasterkarte <%s@%s> nicht öffnen."
 #, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr ""
-#~ "Gibt Rahmenkoordinaten des aktuellen Grafik-Fensters in Prozent aus."
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "Gibt Rahmenkoordinaten des aktuellen Grafik-Fensters in Prozent aus."
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Schriftname oder Pfad zu den TrueType-Schriften inklusive Dateiname. Eine "
-#~ "interaktive Auswahl ist nicht möglich. Siehe auch Schalter -l."
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"Schriftname oder Pfad zu den TrueType-Schriften inklusive Dateiname. Eine "
+"interaktive Auswahl ist nicht möglich. Siehe auch Schalter -l."
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "slopein Rasterkarte <%s> nicht gefunden."
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "slopein Rasterkarte <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "Kein Eintrag für Kategorie [%d]."
+msgid "No record for category for [%d]"
+msgstr "Kein Eintrag für Kategorie [%d]."
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "Fehler beim Lesen der ascii-Datei <%s>."
+msgid "Error reading ASCII file <%s>"
+msgstr "Fehler beim Lesen der ascii-Datei <%s>."
-#~ msgid "Error reading categories: <%s>"
-#~ msgstr "Fehler beim Lesen der Kategorien: <%s>"
+msgid "Error reading categories: <%s>"
+msgstr "Fehler beim Lesen der Kategorien: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr "%d Punkte ohne Kategorie übersprungen."
+msgid "category [%d]"
+msgstr "%d Punkte ohne Kategorie übersprungen."
 #, fuzzy
-#~ msgid "No lines found"
-#~ msgstr "Keine DXF-Layer gefunden!"
+msgid "No lines found"
+msgstr "Keine DXF-Layer gefunden!"
 #, fuzzy
-#~ msgid "Assign cats to boundaries too"
+msgid "Assign cats to boundaries too"
 #, fuzzy
-#~ msgid "Lines could not be merged"
+msgid "Lines could not be merged"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "Kann den Stoppvektor %s nicht finden."
+msgid "Could not find input vector '%s'"
+msgstr "Kann den Stoppvektor %s nicht finden."
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Failed opening output vector map '%s'"
 #, fuzzy
-#~ msgid "Do not create attribute table."
-#~ msgstr "Keine Attributtabelle erzeugen."
+msgid "Do not create attribute table."
+msgstr "Keine Attributtabelle erzeugen."
 #, fuzzy
-#~ msgid "Could not find input %s\n"
-#~ msgstr "Kann die Karte %s nicht öffnen."
+msgid "Could not find input %s\n"
+msgstr "Kann die Karte %s nicht öffnen."
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr ""
-#~ "Listet alle Rasterkarten in der Eingabe-Location auf und beendet sich."
+msgid ""
+"List vector maps in input location and exit (a dummy value must be given for "
+"input)"
+msgstr "Listet alle Rasterkarten in der Eingabe-Location auf und beendet sich."
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr ""
-#~ "Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
-#~ "aktuellen Region."
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region"
+msgstr ""
+"Erlaubt dem Benutzer das interaktive Abfragen einer Vektorkarte in der "
+"aktuellen Region."
-#~ msgid "+---------------------------------+---------------+"
-#~ msgstr "+---------------------------------+---------------+"
+msgid "+---------------------------------+---------------+"
+msgstr "+---------------------------------+---------------+"
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "| Werkzeug                        | Schwellenwert |"
+msgid "| Tool                            | Threshold     |"
+msgstr "| Werkzeug                        | Schwellenwert |"
 #, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr " lambda    | mean (m)    | rms (m)     |\n"
+msgid "| Break                           |  "
+msgstr " lambda    | mean (m)    | rms (m)     |\n"
 #, fuzzy
-#~ msgid "| Remove dangles                  |  "
+msgid "| Remove dangles                  |  "
 #, fuzzy
-#~ msgid "| Remove bridges                  |  "
+msgid "| Remove bridges                  |  "
 #, fuzzy
-#~ msgid "| Prune                           |  "
+msgid "| Prune                           |  "
 #, fuzzy
-#~ msgid "| Remove small areas              |  "
-#~ msgstr "Entfernen"
+msgid "| Remove small areas              |  "
+msgstr "Entfernen"
 #, fuzzy
-#~ msgid "| Remove small angles at nodes    |  "
+msgid "| Remove small angles at nodes    |  "
+msgstr "Entfernen"
-#~ msgid " %13e |"
-#~ msgstr " %13e |"
+msgid " %13e |"
+msgstr " %13e |"
-#~ msgid "--------------------------------------------------"
-#~ msgstr "--------------------------------------------------"
+msgid "--------------------------------------------------"
+msgstr "--------------------------------------------------"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "Warnung: Vektorkarte <%s> wurde nicht gefunden.\n"
+msgid "%s: <%s> vector map not found"
+msgstr "Warnung: Vektorkarte <%s> wurde nicht gefunden.\n"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "Vektorkarte <%s> nicht gefunden"
+msgid "Vector <%s> could not be open"
+msgstr "Vektorkarte <%s> nicht gefunden"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Raster <%s> could not be open."
 #, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "Korrelation"
+msgid "CrossCorrelation()"
+msgstr "Korrelation"
 #, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "Interpolationsmethode"
+msgid "Interpolation()"
+msgstr "Interpolationsmethode"
 #, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "Setze das Kartenfenster."
+msgid "Interpolation: Setting regions and boxes"
+msgstr "Setze das Kartenfenster."
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d"
-#~ msgstr "Kein Eintrag für Linie (cat = %d)."
+msgid "Interpolation: (%d,%d): Number of points in <elaboration_box> is %d"
+msgstr "Kein Eintrag für Linie (cat = %d)."
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#~ msgstr "Allokiere Speicher für die bilineare Interpolation."
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgstr "Allokiere Speicher für die bilineare Interpolation."
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#~ msgstr "Allokiere Speicher für die bikubische Interpolation."
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgstr "Allokiere Speicher für die bikubische Interpolation."
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
-#~ msgstr "%s: Kann <%s> nicht öffnen."
+msgid "%s: Dropping <s>"
+msgstr "%s: Kann <%s> nicht öffnen."
 #, fuzzy
-#~ msgid "%s: Dropping: Auxiliar Table could not be drop"
+msgid "%s: Dropping: Auxiliar Table could not be drop"
+msgstr "Tabelle"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
-#~ msgstr "Zu benutzende Interpolationsmethode"
+msgid "Interpolation was a success!"
+msgstr "Zu benutzende Interpolationsmethode"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "%d Punkte in der Region."
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "%d Punkte in der Region."
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Nichts gefunden.\n"
+msgid "No line found."
+msgstr "Nichts gefunden.\n"
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "No features found"
-#~ msgstr "[%d] Feature verändert."
+msgid "No features found"
+msgstr "[%d] Feature verändert."
 #, fuzzy
-#~ msgid "vector map to be created"
-#~ msgstr "Es wird keine Vektordatei erstellt"
+msgid "vector map to be created"
+msgstr "Es wird keine Vektordatei erstellt"
-#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
-#~ msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
+msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+msgstr "%s: Fehler beim Lesen der Rasterkarte <%s> im Mapset <%s>."
 #, fuzzy
-#~ msgid "Color table for <%s> updated"
-#~ msgstr "Farbtabelle für <%s> aktualisiert."
+msgid "Color table for <%s> updated"
+msgstr "Farbtabelle für <%s> aktualisiert."
-#~ msgid "Error reading raster map <%s>."
-#~ msgstr "Fehler beim Lesen der Rasterkarte <%s>."
+msgid "Error reading raster map <%s>."
+msgstr "Fehler beim Lesen der Rasterkarte <%s>."
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "        Anzahl der Bytes pro Zelle"
+msgid "        Number of bytes per cell"
+msgstr "        Anzahl der Bytes pro Zelle"
 #, fuzzy
-#~ msgid "Option <%s>: <%s> exists."
-#~ msgstr "Region <%s> nicht gefunden."
+msgid "Option <%s>: <%s> exists."
+msgstr "Region <%s> nicht gefunden."
 #, fuzzy
-#~ msgid "Unable to create table: <%s>"
-#~ msgstr "Kann Datei <%s> nicht erzeugen."
+msgid "Unable to create table: <%s>"
+msgstr "Kann Datei <%s> nicht erzeugen."
-#~ msgid "Cannot insert new record: <%s>"
+msgid "Cannot insert new record: <%s>"
 #, fuzzy
-#~ msgid "Unable to insert new record: <%s>"
+msgid "Unable to insert new record: <%s>"
 #, fuzzy
-#~ msgid "No attribute table found"
-#~ msgstr "Attribut-Spalte(n)"
+msgid "No attribute table found"
+msgstr "Attribut-Spalte(n)"
 #, fuzzy
-#~ msgid "No numerical attributes found. Skipping export"
+msgid "No numerical attributes found. Skipping export"
 #, fuzzy
-#~ msgid "Error reading value of attribute <%s>"
-#~ msgstr "Fehler beim Lesen der Kategorien <%s>."
+msgid "Error reading value of attribute <%s>"
+msgstr "Fehler beim Lesen der Kategorien <%s>."
-#~ msgid "Illegal subgroup name <%s>"
-#~ msgstr "Ungültiger Untergruppenname <%s>."
+msgid "Illegal subgroup name <%s>"
+msgstr "Ungültiger Untergruppenname <%s>."
-#~ msgid "No monitor selected"
-#~ msgstr "Kein Grafik-Fenster ausgewählt."
+msgid "No monitor selected"
+msgstr "Kein Grafik-Fenster ausgewählt."
 #, fuzzy
-#~ msgid "Invalid rendering method <%s>"
-#~ msgstr "Ungültige Methode: %s."
+msgid "Invalid rendering method <%s>"
+msgstr "Ungültige Methode: %s."
-#~ msgid "Unable to create face"
-#~ msgstr "Kann kein Face erzeugen."
+msgid "Unable to create face"
+msgstr "Kann kein Face erzeugen."
-#~ msgid "Unable to set size"
-#~ msgstr "Kann die Größe nicht setzen."
+msgid "Unable to set size"
+msgstr "Kann die Größe nicht setzen."
 #, fuzzy
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
-#~ msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
+msgid ""
+"Displays the rhumbline joining two user-specified points, in the active "
+"frame on the user's graphics monitor."
+msgstr "Stellt GRASS Vektorkarten im aktiven Grafik-Fenster dar."
Modified: grass/trunk/locale/po/grassmods_es.po
--- grass/trunk/locale/po/grassmods_es.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_es.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -9095,7 +9095,7 @@
 #: ../raster/r.external/main.c:362
 #, fuzzy, c-format
 msgid "Unable to create fcell/%s file"
-msgstr "No se puede leer el archivo de color"
+msgstr "No se puede crear el índice"
 #: ../raster/r.external/main.c:394
 #, fuzzy, c-format
@@ -10153,7 +10153,7 @@
 #: ../raster/r.what/main.c:335
 #, fuzzy, c-format
 msgid "Error reading <%s>"
-msgstr "Error al leer el mapa '%s'"
+msgstr "Error al leer el mapa ráster [%s]."
 #: ../raster/r.sum/main.c:46
 msgid "Sums up the raster cell values."
@@ -16813,8 +16813,7 @@
 #: ../raster/r.quant/main.c:108
 #, fuzzy
 msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
-msgstr ""
-"Las opciones \"color\", \"rules\" y \"raster\" son excluyentes entre si"
+msgstr "weight= y -c son excluyentes mutuamente"
 #: ../raster/r.quant/main.c:116
 #, fuzzy
@@ -18738,8 +18737,9 @@
 msgstr "Muestra la tabla de colores asociada a una capa de mapa ráster."
 #: ../raster/r.colors.out/main.c:73
+#, fuzzy
 msgid "Path to rules file (\"-\" to write rules to stdin)"
-msgstr ""
+msgstr "Archivo de coordenadas de entrada (omitir para leer de stdin)"
 #: ../raster/r.colors.out/main.c:77
 #, fuzzy
@@ -27704,1817 +27704,1866 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "No se pueden seleccionar los atributos de los puntos de <%s>"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condición opcional dónde (sin la palabra clave WHERE), ej.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condición opcional dónde (sin la palabra clave WHERE), ej.:\n"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nombre de archivo de salida no admitido"
+msgid "Illegal output file name"
+msgstr "Nombre de archivo de salida no admitido"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selecciona/lanza un monitor determinado al tamaño especificado"
+msgid "Selects/starts specified monitor at specified size"
+msgstr "Selecciona/lanza un monitor determinado al tamaño especificado"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Anchura en pixels del nuevo monitor"
+msgid "Width in pixels of new display monitor"
+msgstr "Anchura en pixels del nuevo monitor"
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Altura en pixels del nuevo monitor"
+msgid "Height in pixels of new display monitor"
+msgstr "Altura en pixels del nuevo monitor"
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Mueve los mapas que se muestran a otro monitor"
+msgid "Moves displayed maps to another monitor"
+msgstr "Mueve los mapas que se muestran a otro monitor"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "borra el monitor de destino antes de moverlos"
+msgid "clear target monitor before moving"
+msgstr "borra el monitor de destino antes de moverlos"
-#~ msgid "stay with source monitor"
-#~ msgstr "permanecer en el monitor orginal"
+msgid "stay with source monitor"
+msgstr "permanecer en el monitor orginal"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "eliminar el monitor original después de moverlo"
+msgid "kill source monitor after moving"
+msgstr "eliminar el monitor original después de moverlo"
-#~ msgid "Target monitor"
-#~ msgstr "Monitor de destino"
+msgid "Target monitor"
+msgstr "Monitor de destino"
-#~ msgid "Source monitor"
-#~ msgstr "Monitor de origen"
+msgid "Source monitor"
+msgstr "Monitor de origen"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr ""
-#~ "Exporta el monitor visible a una imagen de fondo compatible con GpsDrive"
+msgid "Export display monitor to a GpsDrive compatible backdrop image"
+msgstr ""
+"Exporta el monitor visible a una imagen de fondo compatible con GpsDrive"
-#~ msgid "display, export, GPS"
-#~ msgstr "muestra, exporta, GPS"
+msgid "display, export, GPS"
+msgstr "muestra, exporta, GPS"
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "nombre para el nuevo mapa de imagen (reside en ~/.gpsdrive)"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Crea una imagen JPG en lugar de PNG"
+msgid "Make JPEG instead of PNG image"
+msgstr "Crea una imagen JPG en lugar de PNG"
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr "Guarda el contenido del monitor activo en un fichero gráfico."
-#~ msgid "display, export"
-#~ msgstr "muestra, exporta"
+msgid "display, export"
+msgstr "muestra, exporta"
-#~ msgid "Name for output file (do NOT add extension)"
-#~ msgstr "Nombre para el archivo de salida (NO añadir extensión)"
+msgid "Name for output file (do NOT add extension)"
+msgstr "Nombre para el archivo de salida (NO añadir extensión)"
-#~ msgid "Dimensions of output file versus current window size"
-#~ msgstr "Dimensiones de archivo de salida versus tamaño de la ventana actual"
+msgid "Dimensions of output file versus current window size"
+msgstr "Dimensiones de archivo de salida versus tamaño de la ventana actual"
-#~ msgid "(same=1, double size=2, quadruple size=4)"
-#~ msgstr "(igual=1, doble tamaño=2, cuádruple tamaño=4)"
+msgid "(same=1, double size=2, quadruple size=4)"
+msgstr "(igual=1, doble tamaño=2, cuádruple tamaño=4)"
-#~ msgid "Images"
-#~ msgstr "Imágenes"
+msgid "Images"
+msgstr "Imágenes"
-#~ msgid "Width and height of output image (overrides resolution setting)"
-#~ msgstr ""
-#~ "Anchura y altura de la imagen de salida (ignora la configuración de "
-#~ "resolución)"
+msgid "Width and height of output image (overrides resolution setting)"
+msgstr ""
+"Anchura y altura de la imagen de salida (ignora la configuración de "
+"resolución)"
-#~ msgid "Compression for PNG files"
-#~ msgstr "Compresión para archivos PNG"
+msgid "Compression for PNG files"
+msgstr "Compresión para archivos PNG"
-#~ msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
-#~ msgstr ""
-#~ "(0=ninguna, 1=la más rápida, 9=máxima; sin pérdida, sólo tiempo vs. "
-#~ "tamaño de archivo)"
+msgid "(0=none, 1=fastest, 9=most; lossless, only time vs. filesize)"
+msgstr ""
+"(0=ninguna, 1=la más rápida, 9=máxima; sin pérdida, sólo tiempo vs. tamaño "
+"de archivo)"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Tamaño/calidad de archivo para archivos JPEG"
+msgid "File size/quality for JPEG files"
+msgstr "Tamaño/calidad de archivo para archivos JPEG"
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr "(10=el más pequeño/peor, 100=el más grande/mejor)"
+msgid "(10=smallest/worst, 100=largest/best)"
+msgstr "(10=el más pequeño/peor, 100=el más grande/mejor)"
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Tamaño de papel para salida PostScript"
+msgid "Paper size for PostScript output"
+msgstr "Tamaño de papel para salida PostScript"
-#~ msgid "PostScript"
-#~ msgstr "PostScript"
+msgid "PostScript"
+msgstr "PostScript"
-#~ msgid "PostScript level (only limits functionality!)"
-#~ msgstr "Nivel PostScript (¡sólo limita la funcinalidad!)"
+msgid "PostScript level (only limits functionality!)"
+msgstr "Nivel PostScript (¡sólo limita la funcinalidad!)"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Ajustar el color de fondo a negro (blanco por omisión)"
+msgid "Set background color to black (white default)"
+msgstr "Ajustar el color de fondo a negro (blanco por omisión)"
-#~ msgid "Set transparent background"
-#~ msgstr "Establecer fondo transparente"
+msgid "Set transparent background"
+msgstr "Establecer fondo transparente"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Usar el controlador Cairo para representar las imágenes"
+msgid "Use the Cario driver to render images"
+msgstr "Usar el controlador Cairo para representar las imágenes"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr ""
-#~ "Establecer la orientación del papel a horizontal (para salida PostScript)"
+msgid "Set paper orientation to landscape (for PostScript output)"
+msgstr ""
+"Establecer la orientación del papel a horizontal (para salida PostScript)"
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "Muestra un mapa ráster y su leyenda en una ventana gráfica"
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "Muestra un mapa ráster y su leyenda en una ventana gráfica"
-#~ msgid "omit entries with missing label"
-#~ msgstr "omitir las entradas con una etiqueta perdida"
+#, fuzzy
+msgid "omit entries with missing label"
+msgstr "omitir las entradas con una etiqueta perdida"
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Número de líneas que deben aparecer en la leyenda"
+msgid "Number of lines to appear in the legend"
+msgstr "Número de líneas que deben aparecer en la leyenda"
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Vuelve a dibujar el marco activo en el monitor GRASS"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Vuelve a dibujar el marco activo en el monitor GRASS"
-#~ msgid "Redraw all frames"
-#~ msgstr "Redibujar todos los marcos"
+msgid "Redraw all frames"
+msgstr "Redibujar todos los marcos"
-#~ msgid "Do not preserve individual regions when redrawing all frames"
-#~ msgstr ""
-#~ "No preservar regiones individuales cuando se redibujan todos los marcos"
+msgid "Do not preserve individual regions when redrawing all frames"
+msgstr ""
+"No preservar regiones individuales cuando se redibujan todos los marcos"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Modifica el tamaño del monitor activo"
+msgid "Resizes active display monitor"
+msgstr "Modifica el tamaño del monitor activo"
-#~ msgid "New width for window"
-#~ msgstr "Nueva anchura de ventana"
+msgid "New width for window"
+msgstr "Nueva anchura de ventana"
-#~ msgid "New height for window"
-#~ msgstr "Nueva altura de ventana"
+msgid "New height for window"
+msgstr "Nueva altura de ventana"
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Presentación de mapas ráster/vectoriales de GRASS."
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Presentación de mapas ráster/vectoriales de GRASS."
-#~ msgid "display, slideshow"
-#~ msgstr "muestra, presentación"
+msgid "display, slideshow"
+msgstr "muestra, presentación"
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Muestra mapas vectoriales en vez de mapas ráster"
+msgid "Show vector maps rather than raster maps"
+msgstr "Muestra mapas vectoriales en vez de mapas ráster"
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "Prefijo de mapa. Especificar carácter(es) para ver sólo los mapas "
-#~ "seleccionados"
+msgid "Map prefix. Specify character(s) to view selected maps only"
+msgstr ""
+"Prefijo de mapa. Especificar carácter(es) para ver sólo los mapas "
+"seleccionados"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr ""
-#~ "Directorio de mapas a usar. Especificar múltiples directorios separados "
-#~ "por comas"
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr ""
+"Directorio de mapas a usar. Especificar múltiples directorios separados por "
+"comas"
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Número de segundos de pausa entre diapositivas"
+msgid "Number of seconds to pause between slides"
+msgstr "Número de segundos de pausa entre diapositivas"
 #, fuzzy
-#~ msgid "Split the display into subframes."
-#~ msgstr "Introducir mapa ráster a mostrar en el primer marco"
+msgid "Split the display into subframes."
+msgstr "Introducir mapa ráster a mostrar en el primer marco"
 #, fuzzy
-#~ msgid "Number of subframes"
-#~ msgstr "Número de fotogramas"
+msgid "Number of subframes"
+msgstr "Número de fotogramas"
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Visualizar mapa vectorial temático"
+msgid "Displays thematic vectormap"
+msgstr "Visualizar mapa vectorial temático"
-#~ msgid "display, legend"
-#~ msgstr "mostrar, leyenda"
+msgid "display, legend"
+msgstr "mostrar, leyenda"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "Mapa vectorial a mostrar temáticamente"
+msgid "Vector map to display thematically"
+msgstr "Mapa vectorial a mostrar temáticamente"
-#~ msgid "Theme_prefs"
-#~ msgstr "Preferencias de tema"
+msgid "Theme_prefs"
+msgstr "Preferencias de tema"
-#~ msgid "Vector map type"
-#~ msgstr "Tipo de mapa vectorial"
+msgid "Vector map type"
+msgstr "Tipo de mapa vectorial"
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr ""
-#~ "Columna de atributos a usar para presentación temática (debe ser numérico)"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr ""
+"Columna de atributos a usar para presentación temática (debe ser numérico)"
-#~ msgid "Type of thematic display"
-#~ msgstr "Tipo de visualización temática"
+msgid "Type of thematic display"
+msgstr "Tipo de visualización temática"
-#~ msgid "Thematic divisions of data for display"
-#~ msgstr "Divisiones temáticas de los datos a mostrar"
+msgid "Thematic divisions of data for display"
+msgstr "Divisiones temáticas de los datos a mostrar"
-#~ msgid ""
-#~ "Break points for custom breaks option. Separate values by spaces. (0 10 "
-#~ "20 30 ...)"
-#~ msgstr ""
-#~ "Puntos de ruptura para la opción de ruptura personalizada. Separar "
-#~ "valores por espacios (0 10 20 30...)"
+msgid ""
+"Break points for custom breaks option. Separate values by spaces. (0 10 20 "
+"30 ...)"
+msgstr ""
+"Puntos de ruptura para la opción de ruptura personalizada. Separar valores "
+"por espacios (0 10 20 30...)"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Capa a usar para visualización temática"
+msgid "Layer to use for thematic display"
+msgstr "Capa a usar para visualización temática"
-#~ msgid "Points"
-#~ msgstr "Puntos"
+msgid "Points"
+msgstr "Puntos"
-#~ msgid "Vector point icon for point data"
-#~ msgstr "Icono de punto vectorial para datos de puntos"
+msgid "Vector point icon for point data"
+msgstr "Icono de punto vectorial para datos de puntos"
-#~ msgid ""
-#~ "Icon size for point data (minimum icon size/line width for graduated "
-#~ "points/lines)"
-#~ msgstr ""
-#~ "Tamaño de icono para datos de puntos (tamaño de icono mínimo/anchura de "
-#~ "línea para gradiente de puntos/líneas)"
+msgid ""
+"Icon size for point data (minimum icon size/line width for graduated points/"
+"lines)"
+msgstr ""
+"Tamaño de icono para datos de puntos (tamaño de icono mínimo/anchura de "
+"línea para gradiente de puntos/líneas)"
-#~ msgid "Maximum icon size/line width for graduated points and lines"
-#~ msgstr ""
-#~ "Tamaño máximo de icono/anchura de línea para gradiente de puntos y líneas"
+msgid "Maximum icon size/line width for graduated points and lines"
+msgstr ""
+"Tamaño máximo de icono/anchura de línea para gradiente de puntos y líneas"
-#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Número de clases para tema de intervalo (entero)"
+msgid "Number of classes for interval theme (integer)"
+msgstr "Número de clases para tema de intervalo (entero)"
-#~ msgid ""
-#~ "Color scheme for graduated color mapping (select 'single_color' for "
-#~ "graduated point/line display)"
-#~ msgstr ""
-#~ "Esquema de colores para mapas en gradiente de color (seleccionar "
-#~ "'single_color' para mostrar gradiente de puntos/líneas)"
+msgid ""
+"Color scheme for graduated color mapping (select 'single_color' for "
+"graduated point/line display)"
+msgstr ""
+"Esquema de colores para mapas en gradiente de color (seleccionar "
+"'single_color' para mostrar gradiente de puntos/líneas)"
-#~ msgid ""
-#~ "Color for graduated points map (grass named color or R:G:B triplet). Set "
-#~ "color scheme to single color."
-#~ msgstr ""
-#~ "Color para mapa de gradiente de puntos (nombre de color de grass o "
-#~ "triplete R:G:B). Establecer esquema de color a un color."
+msgid ""
+"Color for graduated points map (grass named color or R:G:B triplet). Set "
+"color scheme to single color."
+msgstr ""
+"Color para mapa de gradiente de puntos (nombre de color de grass o triplete "
+"R:G:B). Establecer esquema de color a un color."
-#~ msgid ""
-#~ "Color for graduated lines or point/area outlines (grass named color or R:"
-#~ "G:B triplet). Set color scheme to single color."
-#~ msgstr ""
-#~ "Color para mapa de gradiente de líneas o puntos/bordes de área (nombre de "
-#~ "color de grass o triplete R:G:B). Establecer esquema de color a un color."
+msgid ""
+"Color for graduated lines or point/area outlines (grass named color or R:G:B "
+"triplet). Set color scheme to single color."
+msgstr ""
+"Color para mapa de gradiente de líneas o puntos/bordes de área (nombre de "
+"color de grass o triplete R:G:B). Establecer esquema de color a un color."
-#~ msgid ""
-#~ "Beginning color for custom color gradient. Must be expressed as R:G:B "
-#~ "triplet."
-#~ msgstr ""
-#~ "Color inicial para gradiente de color personalizado. Se debe expresar "
-#~ "como triplete R:G:B."
+msgid ""
+"Beginning color for custom color gradient. Must be expressed as R:G:B "
+"triplet."
+msgstr ""
+"Color inicial para gradiente de color personalizado. Se debe expresar como "
+"triplete R:G:B."
-#~ msgid ""
-#~ "Ending color for custom color gradient. Must be expressed as R:G:B triplet"
-#~ msgstr ""
-#~ "Color final para gradiente de color personalizado. Se debe expresar como "
-#~ "triplete R:G:B."
+msgid ""
+"Ending color for custom color gradient. Must be expressed as R:G:B triplet"
+msgstr ""
+"Color final para gradiente de color personalizado. Se debe expresar como "
+"triplete R:G:B."
-#~ msgid "Misc"
-#~ msgstr "Miscelánea"
+msgid "Misc"
+msgstr "Miscelánea"
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Seleccionar monitor x11 para la leyenda"
+msgid "Select x11 display monitor for legend"
+msgstr "Seleccionar monitor x11 para la leyenda"
-#~ msgid "Save thematic map commands to group file for GIS Manager"
-#~ msgstr ""
-#~ "Guardar comandos de mapa temático en archivo de grupo para el "
-#~ "Administrador GIS"
+msgid "Save thematic map commands to group file for GIS Manager"
+msgstr ""
+"Guardar comandos de mapa temático en archivo de grupo para el Administrador "
+"GIS"
-#~ msgid ""
-#~ "Root for the name of psmap instruction files to be in current directory "
-#~ "(if not set, no psmap instruction files will be created)"
-#~ msgstr ""
-#~ "Raíz para el nombre de los archivos de instrucciones psmap para estar en "
-#~ "el directorio actual ((si no se indica, no se creará ningún archivo de "
-#~ "instrucciones psmap)"
+msgid ""
+"Root for the name of psmap instruction files to be in current directory (if "
+"not set, no psmap instruction files will be created)"
+msgstr ""
+"Raíz para el nombre de los archivos de instrucciones psmap para estar en el "
+"directorio actual ((si no se indica, no se creará ningún archivo de "
+"instrucciones psmap)"
-#~ msgid "Name of group file where thematic map commands will be saved"
-#~ msgstr ""
-#~ "Nombre de archivo de grupo en el que se guardarán los comandos del mapa "
-#~ "temático"
+msgid "Name of group file where thematic map commands will be saved"
+msgstr ""
+"Nombre de archivo de grupo en el que se guardarán los comandos del mapa "
+"temático"
-#~ msgid "Create graphic legend in x11 display monitor"
-#~ msgstr "Crear leyenda gráfica en monitor x11"
+msgid "Create graphic legend in x11 display monitor"
+msgstr "Crear leyenda gráfica en monitor x11"
-#~ msgid "Only draw fills (no outlines) for areas and points"
-#~ msgstr "Dibujar sólo rellenos (no líneas exteriores) para áreas y puntos"
+msgid "Only draw fills (no outlines) for areas and points"
+msgstr "Dibujar sólo rellenos (no líneas exteriores) para áreas y puntos"
-#~ msgid "Update color values to GRASSRGB column in attribute table"
-#~ msgstr ""
-#~ "Actualizar valores de color a la columna GRASSRGB en la tabla de atributos"
+msgid "Update color values to GRASSRGB column in attribute table"
+msgstr ""
+"Actualizar valores de color a la columna GRASSRGB en la tabla de atributos"
-#~ msgid "Output legend for GIS Manager (for scripting use only)"
-#~ msgstr ""
-#~ "Producir leyenda para el Administrador GIS (sólo para uso en scripts)"
+msgid "Output legend for GIS Manager (for scripting use only)"
+msgstr "Producir leyenda para el Administrador GIS (sólo para uso en scripts)"
-#~ msgid "Use math notation brackets in legend"
-#~ msgstr "Usar corchetes de anotación matemática en la leyenda"
+msgid "Use math notation brackets in legend"
+msgstr "Usar corchetes de anotación matemática en la leyenda"
 #, fuzzy
-#~ msgid "Lists data files using basic regular expressions and wildcards."
-#~ msgstr "Aplicar expresiones regulares y comodines a g.list"
+msgid "Lists data files using basic regular expressions and wildcards."
+msgstr "Aplicar expresiones regulares y comodines a g.list"
-#~ msgid "Data type"
-#~ msgstr "Tipo de datos"
+msgid "Data type"
+msgstr "Tipo de datos"
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr ""
-#~ "Directorio(s) de mapas a listar (por omisión: ruta de búsqueda en el "
-#~ "directorio actual)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr ""
+"Directorio(s) de mapas a listar (por omisión: ruta de búsqueda en el "
+"directorio actual)"
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Separador de la salida (por omisión: nueva línea)"
+msgid "Output separator (default: newline)"
+msgstr "Separador de la salida (por omisión: nueva línea)"
 #, fuzzy
-#~ msgid "Removes data files using basic regular expressions and wildcards."
+msgid "Removes data files using basic regular expressions and wildcards."
-#~ msgid "Raster to remove"
-#~ msgstr "Ráster a eliminar"
+msgid "Raster to remove"
+msgstr "Ráster a eliminar"
-#~ msgid "3d raster to remove"
-#~ msgstr "Ráster 3D a eliminar"
+msgid "3d raster to remove"
+msgstr "Ráster 3D a eliminar"
-#~ msgid "Vector to remove"
-#~ msgstr "Vectorial a eliminar"
+msgid "Vector to remove"
+msgstr "Vectorial a eliminar"
-#~ msgid "Region to remove"
-#~ msgstr "Región a eliminar"
+msgid "Region to remove"
+msgstr "Región a eliminar"
-#~ msgid "Label to remove"
-#~ msgstr "Etiqueta a eliminar"
+msgid "Label to remove"
+msgstr "Etiqueta a eliminar"
-#~ msgid "3dview to remove"
-#~ msgstr "Vista 3D a eliminar"
+msgid "3dview to remove"
+msgstr "Vista 3D a eliminar"
-#~ msgid "Group to remove"
-#~ msgstr "Grupo a eliminar"
+msgid "Group to remove"
+msgstr "Grupo a eliminar"
-#~ msgid ""
-#~ "displays spectral response at user specified locations in group or images"
-#~ msgstr ""
-#~ "muestra la respuesta espectral en localizaciones especificadas por el "
-#~ "usuario en grupo o imágenes"
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+"muestra la respuesta espectral en localizaciones especificadas por el "
+"usuario en grupo o imágenes"
-#~ msgid "imagery, raster, multispectral"
-#~ msgstr "imaginería, ráster, multiespectral"
+msgid "imagery, raster, multispectral"
+msgstr "imaginería, ráster, multiespectral"
-#~ msgid "group input"
-#~ msgstr "entrada de grupo"
+msgid "group input"
+msgstr "entrada de grupo"
-#~ msgid "raster input maps"
-#~ msgstr "mapas ráster de entrada"
+msgid "raster input maps"
+msgstr "mapas ráster de entrada"
-#~ msgid "write output to PNG image"
-#~ msgstr "escribir la salida a imagen PNG"
+msgid "write output to PNG image"
+msgstr "escribir la salida a imagen PNG"
-#~ msgid "Use image list and not group"
-#~ msgstr "Usar lista de imágenes y no grupo"
+msgid "Use image list and not group"
+msgstr "Usar lista de imágenes y no grupo"
-#~ msgid "Select multiple points"
-#~ msgstr "Seleccionar múltiples puntos"
+msgid "Select multiple points"
+msgstr "Seleccionar múltiples puntos"
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Etiquetar con coordenadas en vez de numeración"
+msgid "label with coordinates instead of numbering"
+msgstr "Etiquetar con coordenadas en vez de numeración"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Calcular un nuevo mapa ráster a partir de una expresión r.mapcalc."
+msgid "Calculate new raster map from a r.mapcalc expression."
+msgstr "Calcular un nuevo mapa ráster a partir de una expresión r.mapcalc."
-#~ msgid "A"
-#~ msgstr "A"
+msgid "A"
+msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
+msgid "B"
+msgstr "B"
-#~ msgid "C"
-#~ msgstr "C"
+msgid "C"
+msgstr "C"
-#~ msgid "D"
-#~ msgstr "D"
+msgid "D"
+msgstr "D"
-#~ msgid "E"
-#~ msgstr "E"
+msgid "E"
+msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
+msgid "F"
+msgstr "F"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formula (ej. A-B o A*C+B)"
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Formula (ej. A-B o A*C+B)"
-#~ msgid "Show help"
-#~ msgstr "Mostrar ayuda"
+msgid "Show help"
+msgstr "Mostrar ayuda"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Modo avanzado (introducir un conjunto de expresiones de r.mapcalc)"
+msgid "Expert mode (enter a set of r.mapcalc expressions)"
+msgstr "Modo avanzado (introducir un conjunto de expresiones de r.mapcalc)"
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "No sobrescribir mapas existentes"
+msgid "Do not overwrite existing map"
+msgstr "No sobrescribir mapas existentes"
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "Exporta un ráster de GRASS a formatos soportados por GDAL."
-#~ msgid "Region sensitive output"
-#~ msgstr "Salida sensible a región"
+msgid "Region sensitive output"
+msgstr "Salida sensible a región"
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr ""
-#~ "Opción de creación para el controlador de formato de salida. Se pueden "
-#~ "indicar múltiples opciones."
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr ""
+"Opción de creación para el controlador de formato de salida. Se pueden "
+"indicar múltiples opciones."
-#~ msgid "Output field seperator"
-#~ msgstr "Separador de campos de salida"
+msgid "Output field seperator"
+msgstr "Separador de campos de salida"
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr ""
-#~ "Calcula un nuevo volumen grid3D a partir de una expresión r3.mapcalc."
+msgid "Calculates new grid3D volume from r3.mapcalc expression."
+msgstr "Calcula un nuevo volumen grid3D a partir de una expresión r3.mapcalc."
-#~ msgid "A (grid3D file)"
-#~ msgstr "A (archivo grid3D)"
+msgid "A (grid3D file)"
+msgstr "A (archivo grid3D)"
-#~ msgid "B (grid3D file)"
-#~ msgstr "B (archivo grid3D)"
+msgid "B (grid3D file)"
+msgstr "B (archivo grid3D)"
-#~ msgid "C (grid3D file)"
-#~ msgstr "C (archivo grid3D)"
+msgid "C (grid3D file)"
+msgstr "C (archivo grid3D)"
-#~ msgid "D (grid3D file)"
-#~ msgstr "D (archivo grid3D)"
+msgid "D (grid3D file)"
+msgstr "D (archivo grid3D)"
-#~ msgid "E (grid3D file)"
-#~ msgstr "E (archivo grid3D)"
+msgid "E (grid3D file)"
+msgstr "E (archivo grid3D)"
-#~ msgid "F (grid3D file)"
-#~ msgstr "F (archivo grid3D)"
+msgid "F (grid3D file)"
+msgstr "F (archivo grid3D)"
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Nombre para el volumen grid3D de salida"
+msgid "Name for output grid3D volume"
+msgstr "Nombre para el volumen grid3D de salida"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Modo experto (introducir un conjunto de expresiones r3.mapcalc)"
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr "Modo experto (introducir un conjunto de expresiones r3.mapcalc)"
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] no encontrado"
+msgid "%s: [%s] not found"
+msgstr "%s: [%s] no encontrado"
-#~ msgid "GIS Coincidence Tabulation Facility\n"
-#~ msgstr "Utilidd de tabulación de coincidencia GIS\n"
+msgid "GIS Coincidence Tabulation Facility\n"
+msgstr "Utilidd de tabulación de coincidencia GIS\n"
-#~ msgid ""
-#~ "This utility will allow you to compare the coincidence of two map layers\n"
-#~ msgstr ""
-#~ "Esta utilidad le permitirá comparar la coincidencia de dos capas de mapa\n"
+msgid ""
+"This utility will allow you to compare the coincidence of two map layers\n"
+msgstr ""
+"Esta utilidad le permitirá comparar la coincidencia de dos capas de mapa\n"
-#~ msgid "The report can be made in one of 8 units."
-#~ msgstr "El informe se puede hacer en una de 8 unidades."
+msgid "The report can be made in one of 8 units."
+msgstr "El informe se puede hacer en una de 8 unidades."
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr ""
-#~ "Por favor, elija una unidad introduciendo uno de los siguientes códigos "
-#~ "de letras:"
+msgid "Please choose a unit by entering one of the following letter codes:"
+msgstr ""
+"Por favor, elija una unidad introduciendo uno de los siguientes códigos de "
+"letras:"
-#~ msgid "     'c': cells"
-#~ msgstr "     'c': celdas"
+msgid "     'c': cells"
+msgstr "     'c': celdas"
-#~ msgid "     'p': percent cover of region"
-#~ msgstr "     'p': porcentaje de cobertura de región"
+msgid "     'p': percent cover of region"
+msgstr "     'p': porcentaje de cobertura de región"
-#~ msgid "     'x': percent of '%s' category (column)"
-#~ msgstr "     'x': porcentaje de categoría '%s' (columna)"
+msgid "     'x': percent of '%s' category (column)"
+msgstr "     'x': porcentaje de categoría '%s' (columna)"
-#~ msgid "     'y': percent of '%s' category (row)"
-#~ msgstr "     'y': porcentaje de categoría '%s' (fila)"
+msgid "     'y': percent of '%s' category (row)"
+msgstr "     'y': porcentaje de categoría '%s' (fila)"
-#~ msgid "     'a': acres"
-#~ msgstr "     'a': acres"
+msgid "     'a': acres"
+msgstr "     'a': acres"
-#~ msgid "     'h': hectares"
-#~ msgstr "     'h': hectáreas"
+msgid "     'h': hectares"
+msgstr "     'h': hectáreas"
-#~ msgid "     'k': square kilometers"
-#~ msgstr "     'k': kilómetros cuadrados"
+msgid "     'k': square kilometers"
+msgstr "     'k': kilómetros cuadrados"
-#~ msgid "     'm': square miles\n"
-#~ msgstr "     'm': millas cuadradas\n"
+msgid "     'm': square miles\n"
+msgstr "     'm': millas cuadradas\n"
-#~ msgid "     'Q': quit"
-#~ msgstr "     'Q': salir"
+msgid "     'Q': quit"
+msgstr "     'Q': salir"
-#~ msgid "Do you wish to save this report in a file? (y/n) [n] "
-#~ msgstr "¿Desea guardar este informe en un archivo? (y/n) [n] "
+msgid "Do you wish to save this report in a file? (y/n) [n] "
+msgstr "¿Desea guardar este informe en un archivo? (y/n) [n] "
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr ""
-#~ "Introduzca el nombre o ruta del archivo\n"
+msgid ""
+"Enter the file name or path\n"
+msgstr ""
+"Introduzca el nombre o ruta del archivo\n"
-#~ msgid "'%s' being saved\n"
-#~ msgstr "Guardando '%s?\n"
+msgid "'%s' being saved\n"
+msgstr "Guardando '%s?\n"
-#~ msgid ""
-#~ "Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
-#~ msgstr ""
-#~ "¿Desea imprimir este informe (requiere el comando Unix lpr)? (y/n) [n] "
+msgid ""
+"Do you wish to print this report (requires Unix lpr command)? (y/n) [n] "
+msgstr ""
+"¿Desea imprimir este informe (requiere el comando Unix lpr)? (y/n) [n] "
-#~ msgid ""
-#~ "Do you wish it printed in 80 or 132 columns?\n"
-#~ msgstr ""
-#~ "¿Desea imprimirlo a 80 ó 132 columnas?\n"
+msgid ""
+"Do you wish it printed in 80 or 132 columns?\n"
+msgstr ""
+"¿Desea imprimirlo a 80 ó 132 columnas?\n"
-#~ msgid ""
-#~ "Do you wish to run this report with a different unit of measure? (y/n) "
-#~ "[y] "
-#~ msgstr ""
-#~ "¿Desea ejecutar este informe con una unidad de medida diferente? (y/n) "
-#~ "[y] "
+msgid ""
+"Do you wish to run this report with a different unit of measure? (y/n) [y] "
+msgstr ""
+"¿Desea ejecutar este informe con una unidad de medida diferente? (y/n) [y] "
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Seleccionar puntos finales de forma interactiva"
+msgid "Interactively select End-Points"
+msgstr "Seleccionar puntos finales de forma interactiva"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Usar el ratón para seleccionar el Punto de Inicio\n"
+msgid "Use mouse to select Start Point\n"
+msgstr "Usar el ratón para seleccionar el Punto de Inicio\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Usar el ratón para dibujar la línea de perfil\n"
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr ""
+"\n"
+"Usar el ratón para dibujar la línea de perfil\n"
-#~ msgid "Buttons:\n"
-#~ msgstr "Botones:\n"
+msgid "Buttons:\n"
+msgstr "Botones:\n"
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Izquierda: marcar siguiente punto\n"
+msgid "Left:   Mark next point\n"
+msgstr "Izquierda: marcar siguiente punto\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Centro: marcar siguiente punto\n"
+msgid "Middle: Mark next point\n"
+msgstr "Centro: marcar siguiente punto\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Derecha: finalizar perfil y salir\n"
-#~ "\n"
+msgid ""
+"Right:  Finish profile and exit\n"
+"\n"
+msgstr ""
+"Derecha: finalizar perfil y salir\n"
+"\n"
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de elevación de entada <%s>"
+msgid "elevin raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster de elevación de entada <%s>"
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de orientación de entada <%s>"
+msgid "aspin raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster de orientación de entada <%s>"
-#~ msgid "slopein raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de pendiente de entada <%s>"
+msgid "slopein raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster de pendiente de entada <%s>"
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr ""
-#~ "No se encuentra el mapa ráster de coeficiente de turbidez atmosférica de "
-#~ "Linke de entada <%s>"
+msgid "linkein raster map <%s> not found"
+msgstr ""
+"No se encuentra el mapa ráster de coeficiente de turbidez atmosférica de "
+"Linke de entada <%s>"
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr ""
-#~ "No se encuentra el mapa ráster de entada de coeficiente albedo del "
-#~ "terreno <%s>"
+msgid "albedo raster map <%s> not found"
+msgstr ""
+"No se encuentra el mapa ráster de entada de coeficiente albedo del terreno <%"
+"s>"
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de latitudes de entada <%s>"
+msgid "latin raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster de latitudes de entada <%s>"
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster coefbh <%s>"
+msgid "coefbh raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster coefbh <%s>"
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster coefdh <%s>"
+msgid "coefdh raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster coefdh <%s>"
-#~ msgid "Unable to find data map"
-#~ msgstr "No se puede encontrar el mapa de datos"
+msgid "Unable to find data map"
+msgstr "No se puede encontrar el mapa de datos"
 #, fuzzy
-#~ msgid "Unable to find clump map"
-#~ msgstr "No se puede abrir el archivo <%s>"
+msgid "Unable to find clump map"
+msgstr "No se puede abrir el archivo <%s>"
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s: mapa ráster de base no encontrado"
+msgid "%s: base raster map not found"
+msgstr "%s: mapa ráster de base no encontrado"
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s: mapa ráster de cobetura no encontrado"
+msgid "%s: cover raster map not found"
+msgstr "%s: mapa ráster de cobetura no encontrado"
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr "%s: los mapas de base y de salida deben ser diferentes"
+msgid "%s: base map and output map must be different"
+msgstr "%s: los mapas de base y de salida deben ser diferentes"
-#~ msgstr ""
-#~ "%s: error al leer del mapa ráster <%s> en el directorio de mapas <%s>"
+msgstr "%s: error al leer del mapa ráster <%s> en el directorio de mapas <%s>"
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "Nombre de archivo de salida <%s> no admitido"
+msgid "Illegal output file name <%s>"
+msgstr "Nombre de archivo de salida <%s> no admitido"
-#~ msgid "Base raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster de base <%s>"
+msgid "Base raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster de base <%s>"
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr "El mapa de base y de salida <%s> deben ser diferentes"
+msgid "Base map and output map <%s> must be different"
+msgstr "El mapa de base y de salida <%s> deben ser diferentes"
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Memoria insuficiente para zero_array_cell"
+msgid "Not enough memory for zero_array_cell"
+msgstr "Memoria insuficiente para zero_array_cell"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Espacio en disco insuficiente -- no se pueden escribir archivos"
+msgid "Not enough disk space -- cannot write files"
+msgstr "Espacio en disco insuficiente -- no se pueden escribir archivos"
-#~ msgid "Path to rules file"
-#~ msgstr "Ruta al archivo de reglas"
+msgid "Path to rules file"
+msgstr "Ruta al archivo de reglas"
-#~ msgid "Enter rules interactively"
-#~ msgstr "Introducir reglas de forma interactiva"
+msgid "Enter rules interactively"
+msgstr "Introducir reglas de forma interactiva"
-#~ msgid ""
-#~ "Interactive mode is incompatible with \"color\", \"rules\", and \"raster"
-#~ "\" options"
-#~ msgstr ""
-#~ "El modo interactivo es incompatible con las opciones \"color\", \"reglas"
-#~ "\" y \"raster\""
+msgid ""
+"Interactive mode is incompatible with \"color\", \"rules\", and \"raster\" "
+"options"
+msgstr ""
+"El modo interactivo es incompatible con las opciones \"color\", \"reglas\" y "
+"\"raster\""
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "No se encuentra el mapa ráster RGB <%s>"
+msgid "RGB raster map <%s> not found"
+msgstr "No se encuentra el mapa ráster RGB <%s>"
-#~ msgid "Cannot create RGB data, please provide three maps [r,g,b]"
-#~ msgstr ""
-#~ "No se pueden crear los datos RGB. Por favor proporciones tres mapas [R,G,"
-#~ "B]"
+msgid "Cannot create RGB data, please provide three maps [r,g,b]"
+msgstr ""
+"No se pueden crear los datos RGB. Por favor proporciones tres mapas [R,G,B]"
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "No se encuentra el mapa de celdas vectorial <%s>"
+msgid "Vector cell map <%s> not found"
+msgstr "No se encuentra el mapa de celdas vectorial <%s>"
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr ""
-#~ "No se pueden crear los datos del vectorial. Por favor proporcione tres "
-#~ "mapas [X,Y,Z]"
+msgid "Cannot create vector data, please provide three maps [x,y,z]"
+msgstr ""
+"No se pueden crear los datos del vectorial. Por favor proporcione tres mapas "
+"[X,Y,Z]"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Qué mapa ráster necesita una tabla de color"
+msgid "Which raster map needs a color table"
+msgstr "Qué mapa ráster necesita una tabla de color"
-#~ msgstr "Tabla de color para <%s> actualizada"
+msgstr "Tabla de color para <%s> actualizada"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Editar cabecera para [%s]\n"
+msgid "Edit header for [%s]\n"
+msgstr "Editar cabecera para [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "¡No se puede encontrar [%s]!"
+msgid "[%s] cannot be found!"
+msgstr "¡No se puede encontrar [%s]!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "¿Para qué capa se editará el archivo de cabecera?"
+msgid "For what layer shall the header file be edited? "
+msgstr "¿Para qué capa se editará el archivo de cabecera?"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] es una reclasificación de [%s] - ¡No se puede editar la cabecera! "
-#~ "Ejecute support en [%s]."
+msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgstr ""
+"[%s] es una reclasificación de [%s] - ¡No se puede editar la cabecera! "
+"Ejecute support en [%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr ""
-#~ "[%s] es una reclasificación de [%s en %s] - ¡No se puede editar la "
-#~ "cabecera!"
+msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
+msgstr ""
+"[%s] es una reclasificación de [%s en %s] - ¡No se puede editar la cabecera!"
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "¡No se puede abrir el mapa ráster [%s]!"
+msgid "Cannot open raster map [%s]!"
+msgstr "¡No se puede abrir el mapa ráster [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "El archivo ráster [%s] está vacío."
+msgid "Raster file [%s] is empty."
+msgstr "El archivo ráster [%s] está vacío."
-#~ msgid "Error reading raster map [%s]."
-#~ msgstr "Error al leer el mapa ráster [%s]."
+msgid "Error reading raster map [%s]."
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "compresión cellhd: %d\n"
+msgid "cellhd compression: %d\n"
+msgstr "compresión cellhd: %d\n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] parece estar comprimido. ¿Lo está? "
+msgid "[%s] appears to be compressed. Is it? "
+msgstr "[%s] parece estar comprimido. ¿Lo está? "
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Por favor, indique el tipo de compresión:\n"
+msgid "Please indicate the type of compression:\n"
+msgstr "Por favor, indique el tipo de compresión:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "  1. Compresión pre 3.0 \n"
+msgid "  1. Pre 3.0 compression\n"
+msgstr "  1. Compresión pre 3.0 \n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "  2. compresión 3.0\n"
+msgid "  2. 3.0 compression\n"
+msgstr "  2. compresión 3.0\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "La cabecera de [%s] dice que el archivo no está comprimido. "
+msgid "The header for [%s] says the file is not compressed. "
+msgstr "La cabecera de [%s] dice que el archivo no está comprimido. "
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "El fichero parece estar comprimido.\n"
+msgid "The file appears to be compressed.\n"
+msgstr "El fichero parece estar comprimido.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr ""
-#~ "Con toda probabilidad la cabecera está equivocada, pero debe decidir.\n"
+msgid "Most likely the header is wrong, but I want you to decide.\n"
+msgstr ""
+"Con toda probabilidad la cabecera está equivocada, pero debe decidir.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "La cabecera de [%s] dice que el archivo está comprimido. "
+msgid "The header for [%s] says the file is compressed. "
+msgstr "La cabecera de [%s] dice que el archivo está comprimido. "
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "El archivo NO parece estar comprimido.\n"
+msgid "The file does NOT appear to be compressed.\n"
+msgstr "El archivo NO parece estar comprimido.\n"
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "La cabecera indica %d filas%s en el mapa ráster, pero el formato de "
-#~ "archivo actual indica %d filas%s"
+msgid ""
+"Header indicates %d row%s in the raster map, but the actual file format "
+"indicates %d row%s"
+msgstr ""
+"La cabecera indica %d filas%s en el mapa ráster, pero el formato de archivo "
+"actual indica %d filas%s"
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "No se puede escribir la cabecera para [%s]."
+msgid "Unable to write header for [%s]."
+msgstr "No se puede escribir la cabecera para [%s]."
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "Cabecera para el mapa ráster [%s] actualizada."
+msgid "Header for raster map [%s] updated."
+msgstr "Cabecera para el mapa ráster [%s] actualizada."
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "pulse INTRO para continuar -->"
+msgid ""
+"\n"
+"hit RETURN to continue -->"
+msgstr ""
+"\n"
+"pulse INTRO para continuar -->"
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Por favor, introduzca la siguiente información para [%s]:"
+msgid "Please enter the following information for [%s]:"
+msgstr "Por favor, introduzca la siguiente información para [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "        Número de filas"
+msgid "        Number of rows"
+msgstr "        Número de filas"
-#~ msgid "        Number of cols"
-#~ msgstr "        Número de columnas"
+msgid "        Number of cols"
+msgstr "        Número de columnas"
-#~ msgid "        Floating point map"
-#~ msgstr "        Mapa de coma flotante"
+msgid "        Floating point map"
+msgstr "        Mapa de coma flotante"
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "filas * columnas * bytes por celda deben ser igual que el tamaño de "
-#~ "archivo (%lu)"
+msgid "rows * cols * bytes per cell must be same as file size (%lu)"
+msgstr ""
+"filas * columnas * bytes por celda deben ser igual que el tamaño de archivo "
+"(%lu)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Si necesita ayuda para averiguarlos, presione ESC"
+msgid "If you need help figuring them out, just hit ESC"
+msgstr "Si necesita ayuda para averiguarlos, presione ESC"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** ¡No se permiten valores negativos!"
+msgid "** Negative values not allowed!"
+msgstr "** ¡No se permiten valores negativos!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** ¡Sólo valores positivos, por favor!"
+msgid "** Positive values only please!"
+msgstr "** ¡Sólo valores positivos, por favor!"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "¿Qué mapa ráster necesita un histórico actualizado? "
+msgid "Which raster map needs an updated history? "
+msgstr "¿Qué mapa ráster necesita un histórico actualizado? "
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Archivo ráster <%s> no encontrado. Saliendo."
+msgid "Raster file [%s] not found. Exiting."
+msgstr "Archivo ráster <%s> no encontrado. Saliendo."
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Archivo histórico para <%s> actualizado."
+msgid "History file for [%s] updated."
+msgstr "Archivo histórico para <%s> actualizado."
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Archivo histórico para <%s> no actualizado."
+msgid "History file for [%s] not updated."
+msgstr "Archivo histórico para <%s> no actualizado."
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Pulse INTRO para continuar -->"
+msgid ""
+"\n"
+"Hit RETURN to continue -->"
+msgstr ""
+"\n"
+"Pulse INTRO para continuar -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "¿Editar cabecera de [%s]? "
+msgid "Edit header for [%s]? "
+msgstr "¿Editar cabecera de [%s]? "
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "NOTA: [%s] es una reclasificación de [%s en %s]"
+msgid ""
+"\n"
+"NOTE: [%s] is a reclass of [%s in %s]"
+msgstr ""
+"\n"
+"NOTA: [%s] es una reclasificación de [%s en %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Cancelando desde la cabecera del editor."
+msgid "Canceling from edit header."
+msgstr "Cancelando desde la cabecera del editor."
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "¿Editar el archivo de categorías para [%s]?"
+msgid "Edit the category file for [%s]? "
+msgstr "¿Editar el archivo de categorías para [%s]?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "¿Crear/actualizar tabla de colores para [%s]?"
+msgid "Create/Update the color table for [%s]? "
+msgstr "¿Crear/actualizar tabla de colores para [%s]?"
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "¿Editar el archivo histórico de [%s]? "
+msgid "Edit the history file for [%s]? "
+msgstr "¿Editar el archivo histórico de [%s]? "
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "El archivo de nulos de [%s] puede indicar que algunas celdas no contienen "
-#~ "datos\n"
-#~ "Si el archivo de nulos de [%s] no existe, las celdas con valor cero son "
-#~ "tratadas por\n"
-#~ " los programas de la aplicación GRASS como sin datos."
+msgid ""
+"\n"
+"The null file for [%s] may indicate that some cells contain\n"
+" no data. If the null file for [%s] doesn't exist, zero cells in\n"
+" it are treated by GRASS application programs as no data."
+msgstr ""
+"\n"
+"El archivo de nulos de [%s] puede indicar que algunas celdas no contienen "
+"datos\n"
+"Si el archivo de nulos de [%s] no existe, las celdas con valor cero son "
+"tratadas por\n"
+" los programas de la aplicación GRASS como sin datos."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "¿Quiere crear/restablecer el archivo de nulos de [%s] de forma que los "
-#~ "valores de celdas nulas sean considerados datos válidos?"
+msgid ""
+"\n"
+"Do you want to create/reset the null file for [%s] so that null cell values "
+"are considered valid data? "
+msgstr ""
+"\n"
+"¿Quiere crear/restablecer el archivo de nulos de [%s] de forma que los "
+"valores de celdas nulas sean considerados datos válidos?"
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "¿Quiere borrar el archivo de nulos de [%s]?\n"
-#~ "(todas las celdas con cero serán consideradas sin datos)"
+msgid ""
+"\n"
+"Do you want to delete the null file for [%s]\n"
+"(all zero cells will then be considered no data)? "
+msgstr ""
+"\n"
+"¿Quiere borrar el archivo de nulos de [%s]?\n"
+"(todas las celdas con cero serán consideradas sin datos)"
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "¿Qué mapa vectorial necesita categorías actualizadas?"
+msgid "Which vector map needs updated categories?"
+msgstr "¿Qué mapa vectorial necesita categorías actualizadas?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "¿Qué mapa ráster necesita categorías actualizadas?"
+msgid "Which raster map needs updated categories?"
+msgstr "¿Qué mapa ráster necesita categorías actualizadas?"
-#~ msgid "%s map <%s> not found"
-#~ msgstr "No se encuentra el mapa %s <%s>"
+msgid "%s map <%s> not found"
+msgstr "No se encuentra el mapa %s <%s>"
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Archivo de categorías para <%s> no actualizado"
+msgid "Category file for <%s> not updated"
+msgstr "Archivo de categorías para <%s> no actualizado"
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Archivo de categorías para <%s> actualizado"
+msgid "Category file for <%s> updated"
+msgstr "Archivo de categorías para <%s> actualizado"
-#~ msgid "Title, in quotes"
-#~ msgstr "Título, entre comillas"
+msgid "Title, in quotes"
+msgstr "Título, entre comillas"
-#~ msgid "Unable to open vector map <%s> in <%s>"
-#~ msgstr "No se puede abrir el mapa vectorial <%s> en <%s>"
+msgid "Unable to open vector map <%s> in <%s>"
+msgstr "No se puede abrir el mapa vectorial <%s> en <%s>"
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "No se puede encontrar el vector de inicio <%s> "
+msgid "Unable to find starting vector <%s> "
+msgstr "No se puede encontrar el vector de inicio <%s> "
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "No se puede encontrar el vector de fin <%s>"
+msgid "Unable to find stop vector <%s>"
+msgstr "No se puede encontrar el vector de fin <%s>"
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "No se encuentra el mapa ráster de salida <%s> (no se indican puntos de "
-#~ "inicio)"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr ""
+"No se encuentra el mapa ráster de salida <%s> (no se indican puntos de "
+"inicio)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Error de asignación de memoria al leer los puntos de inicio del mapa "
-#~ "ráster %s"
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr ""
+"Error de asignación de memoria al leer los puntos de inicio del mapa ráster %"
+"s"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Aplicar filtro sólo a valores cero de datos"
+msgid "Apply filter only to zero data values"
+msgstr "Aplicar filtro sólo a valores cero de datos"
-#~ msgid "Run verbosly"
-#~ msgstr "Ejecutar de forma verbosa"
+msgid "Run verbosly"
+msgstr "Ejecutar de forma verbosa"
-#~ msgid "Run VERBOSELY"
-#~ msgstr "Ejecutar de forma VERBOSA"
+msgid "Run VERBOSELY"
+msgstr "Ejecutar de forma VERBOSA"
-#~ msgid "Cell file not found"
-#~ msgstr "No se encontró el mapa ráster"
+msgid "Cell file not found"
+msgstr "No se encontró el mapa ráster"
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr ""
-#~ "No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
+msgid "Vector map <%s> not found in the current mapset"
+msgstr ""
+"No se encuentra el mapa vectorial <%s> en el directorio de mapas actual"
 #, fuzzy
-#~ msgid "Layer %d: %s / %s\n"
-#~ msgstr "Capa %d: %s\n"
+msgid "Layer %d: %s / %s\n"
+msgstr "Capa %d: %s\n"
 #, fuzzy
-#~ msgstr "opción <%s>: <%s> existe."
+msgstr "opción <%s>: <%s> existe."
 #, fuzzy
-#~ msgid "Use '%s' option to change vector map name"
-#~ msgstr "Usar salida= opción de cambiar el nombre del mapa vectorial"
+msgid "Use '%s' option to change vector map name"
+msgstr "Usar salida= opción de cambiar el nombre del mapa vectorial"
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgstr ""
-#~ "El mapa vectorial <%s> no esta en el directorio de mapas del usuario y no "
-#~ "se puede actualizar"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr ""
+"El mapa vectorial <%s> no esta en el directorio de mapas del usuario y no se "
+"puede actualizar"
-#~ msgid "Do not print polyline info"
-#~ msgstr "No imprimir información de polilíneas"
+msgid "Do not print polyline info"
+msgstr "No imprimir información de polilíneas"
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "Mapa de red de entrada <%s> no encontrado"
+msgid "Network input map <%s> not found"
+msgstr "Mapa de red de entrada <%s> no encontrado"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coord():  Terminado sesión.. \n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr "ask_transform_coord():  Terminado sesión.. \n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "Número de puntos que han sido ingresados: %d\n"
+msgid " Number of points that have been entered: %d\n"
+msgstr "Número de puntos que han sido ingresados: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Por favor responda Si o No"
+msgid "Please answer yes or no"
+msgstr "Por favor responda Si o No"
-#~ msgid "Hilight color for text"
-#~ msgstr "Color de resalte para texto"
+msgid "Hilight color for text"
+msgstr "Color de resalte para texto"
-#~ msgid "Line: %d\n"
-#~ msgstr "Línea: %d\n"
+msgid "Line: %d\n"
+msgstr "Línea: %d\n"
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr ""
-#~ "Memoria insuficiente para la asignación de la estructura de los datos"
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Memoria insuficiente para la asignación de la estructura de los datos"
-#~ msgid "name=%s\n"
-#~ msgstr "nombre=%s\n"
+msgid "name=%s\n"
+msgstr "nombre=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "directorio de mapas=%s\n"
+msgid "mapset=%s\n"
+msgstr "directorio de mapas=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "nombre completo=%s\n"
+msgid "fullname=%s\n"
+msgstr "nombre completo=%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "uso: %s archivo [prompt %%x %%y]\n"
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr "uso: %s archivo [prompt %%x %%y]\n"
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "Nombre de archivo no admitido para la parte real: %s"
+msgid "Illegal file name for real part: %s"
+msgstr "Nombre de archivo no admitido para la parte real: %s"
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "Nombre de archivo no admitido para la parte imaginaria: %s"
+msgid "Illegal file name for imaginary part: %s"
+msgstr "Nombre de archivo no admitido para la parte imaginaria: %s"
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "** No se puede leer el archivo de firmas <%s> **"
+msgid "** Can't read signature file <%s> **"
+msgstr "** No se puede leer el archivo de firmas <%s> **"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nombre de archivo de firmas resultante no admitido"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr ""
+"\n"
+"<%s> -- nombre de archivo de firmas resultante no admitido"
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Nombre de grupo <%s> no admitido"
+msgid "Illegal group name <%s>"
+msgstr "Nombre de grupo <%s> no admitido"
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Nombre de archivo de firmas <%s> no admitido"
+msgid "Illegal signature file name <%s>"
+msgstr "Nombre de archivo de firmas <%s> no admitido"
-#~ msgid "Setting map window"
-#~ msgstr "Configurando ventana de mapa"
+msgid "Setting map window"
+msgstr "Configurando ventana de mapa"
-#~ msgid "Current window not settable"
-#~ msgstr "La ventana actual no es configurable"
+msgid "Current window not settable"
+msgstr "La ventana actual no es configurable"
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "No se puede borrar la ventana gráfica actual"
+msgid "Can't clear current graphics window"
+msgstr "No se puede borrar la ventana gráfica actual"
-#~ msgid "Cannot use current window"
-#~ msgstr "No se puede usar la ventana actual"
+msgid "Cannot use current window"
+msgstr "No se puede usar la ventana actual"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "No añadir a la lista de comandos en el monitor"
+msgid "Don't add to list of commands in monitor"
+msgstr "No añadir a la lista de comandos en el monitor"
-#~ msgid "No current frame"
-#~ msgstr "Ningún marco actual"
+msgid "No current frame"
+msgstr "Ningún marco actual"
-#~ msgid "Current frame not available"
-#~ msgstr "Marco actual no disponible"
+msgid "Current frame not available"
+msgstr "Marco actual no disponible"
-#~ msgid "%s: 'is_null_value()' got NULL pointer!"
-#~ msgstr "%s: 'is_null_value()' ¡se obtuvo puntero NULL!"
+msgid "%s: 'is_null_value()' got NULL pointer!"
+msgstr "%s: 'is_null_value()' ¡se obtuvo puntero NULL!"
-#~ msgid "%s: 'is_null_value()' got negative column index"
-#~ msgstr "%s: 'is_null_value()' obtuvo índice de columna negativo"
+msgid "%s: 'is_null_value()' got negative column index"
+msgstr "%s: 'is_null_value()' obtuvo índice de columna negativo"
-#~ msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
-#~ msgstr "%s: 'is_null_value()' Tipo de mapa ráster '%d' desconocido"
+msgid "%s: 'is_null_value()' Unknown RASTER_MAP_TYPE '%d'"
+msgstr "%s: 'is_null_value()' Tipo de mapa ráster '%d' desconocido"
-#~ msgid "Error reading raster map"
-#~ msgstr "Error leyendo mapa ráster"
+msgid "Error reading raster map"
+msgstr "Error leyendo mapa ráster"
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "Utilidad de ploteo de perfil interactivo con salida opcional."
+msgid "Interactive profile plotting utility with optional output."
+msgstr "Utilidad de ploteo de perfil interactivo con salida opcional."
-#~ msgid "Optional display raster"
-#~ msgstr "Ráster de visualización opcional"
+msgid "Optional display raster"
+msgstr "Ráster de visualización opcional"
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Sacar datos del perfil al archivo(s) con prefijo 'nombre'"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Sacar datos del perfil al archivo(s) con prefijo 'nombre'"
-#~ msgid "Display raster [%s] not found. Using profile raster."
-#~ msgstr "Mostrar ráster[%s] no encontrado. Usando ráster de perfil."
+msgid "Display raster [%s] not found. Using profile raster."
+msgstr "Mostrar ráster[%s] no encontrado. Usando ráster de perfil."
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Usar el ratón para elegin acción"
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr ""
+"\n"
+"\n"
+"Usar el ratón para elegin acción"
 #, fuzzy
-#~ msgid "Use 'd.frame -e' to remove left over frames"
-#~ msgstr "Usar 'd.frame -e' para eliminar left over frames"
+msgid "Use 'd.frame -e' to remove left over frames"
+msgstr "Usar 'd.frame -e' para eliminar left over frames"
-#~ msgid "Error opening cell-file"
-#~ msgstr "Error al abrir el archivo de celdas"
+msgid "Error opening cell-file"
+msgstr "Error al abrir el archivo de celdas"
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Error al leer del archivo de celdas"
+msgid "Error reading from cell-file"
+msgstr "Error al leer del archivo de celdas"
-#~ msgid "Mysterious window inconsistancy error"
-#~ msgstr "Error de inconsistencia de ventana misterioso"
+msgid "Mysterious window inconsistancy error"
+msgstr "Error de inconsistencia de ventana misterioso"
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s: No se pudo abrir el ráster<%s@%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "%s: No se pudo abrir el ráster<%s@%s>"
-#~ msgid "one moment ..."
-#~ msgstr "un momento..."
+msgid "one moment ..."
+msgstr "un momento..."
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Centro: fijar color de parpadeo\n"
+msgid " Middle: toggle flash color\n"
+msgstr " Centro: fijar color de parpadeo\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Habilitar flashing (más lento)"
+msgid "Enable flashing (slower)"
+msgstr "Habilitar flashing (más lento)"
-#~ msgid "No raster map exists in current window"
-#~ msgstr "No existe ningún mapa ráster en la ventana actual"
+msgid "No raster map exists in current window"
+msgstr "No existe ningún mapa ráster en la ventana actual"
-#~ msgid "No current window"
-#~ msgstr "Ninguna ventana actual"
+msgid "No current window"
+msgstr "Ninguna ventana actual"
-#~ msgid "Current window not available"
-#~ msgstr "La ventana actual no está disponible"
+msgid "Current window not available"
+msgstr "La ventana actual no está disponible"
-#~ msgid "Getting screen window"
-#~ msgstr "Obteniendo ventana de la pantalla"
+msgid "Getting screen window"
+msgstr "Obteniendo ventana de la pantalla"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Error calculando conversiones"
+msgid "Error in calculating conversions"
+msgstr "Error calculando conversiones"
-#~ msgid "No current graphics window"
-#~ msgstr "Ninguna ventana de gráficos actual"
+msgid "No current graphics window"
+msgstr "Ninguna ventana de gráficos actual"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Ventana de gráficos actual no disponible"
+msgid "Current graphics window not available"
+msgstr "Ventana de gráficos actual no disponible"
-#~ msgid "Setting graphics window"
-#~ msgstr "Configurando la ventana de gráficos"
+msgid "Setting graphics window"
+msgstr "Configurando la ventana de gráficos"
-#~ msgid "Can't set current graphics window"
-#~ msgstr "No se puede configurar la ventana de gráficos actual"
+msgid "Can't set current graphics window"
+msgstr "No se puede configurar la ventana de gráficos actual"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Obteniendo coordenadas de la ventana de gráficos"
+msgid "Getting graphics window coordinates"
+msgstr "Obteniendo coordenadas de la ventana de gráficos"
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Nombre de fuente o ruta al archivo TTF"
+msgid "Font name or pathname of TTF file"
+msgstr "Nombre de fuente o ruta al archivo TTF"
-#~ msgid "Setting release of FreeType"
-#~ msgstr "Configurando el lanzamiento de FreeType"
+msgid "Setting release of FreeType"
+msgstr "Configurando el lanzamiento de FreeType"
-#~ msgid "Display number of colors"
-#~ msgstr "Mostrar número de colores"
+msgid "Display number of colors"
+msgstr "Mostrar número de colores"
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "Usar el ratón para dimensionar y situar la leyenda"
+msgid "Use mouse to size & place legend"
+msgstr "Usar el ratón para dimensionar y situar la leyenda"
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr "Crea una lista de comandos para recrear gráficos de pantalla."
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr "Crea una lista de comandos para recrear gráficos de pantalla."
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Nombre de marco(s) a guardar"
+msgid "Name of frame(s) to save"
+msgstr "Nombre de marco(s) a guardar"
-#~ msgid ""
-#~ "List of object numbers to remove which are displayed after \"#\". -1 for "
-#~ "the last object."
-#~ msgstr ""
-#~ "Lista de números de objeto a eliminar que son mostrados tras \"#\". -1 "
-#~ "para el último objeto."
+msgid ""
+"List of object numbers to remove which are displayed after \"#\". -1 for the "
+"last object."
+msgstr ""
+"Lista de números de objeto a eliminar que son mostrados tras \"#\". -1 para "
+"el último objeto."
-#~ msgid ""
-#~ "List of object numbers to move (\"from\" to \"to\"). remove= option will "
-#~ "be done first, if any."
-#~ msgstr ""
-#~ "Lista de números de objeto a mover (\"desde\" a \"a\"). eliminar= las "
-#~ "opciones se harán primero, si las hay."
+msgid ""
+"List of object numbers to move (\"from\" to \"to\"). remove= option will be "
+"done first, if any."
+msgstr ""
+"Lista de números de objeto a mover (\"desde\" a \"a\"). eliminar= las "
+"opciones se harán primero, si las hay."
-#~ msgid "Save current frame"
-#~ msgstr "Guardar el marco actual"
+msgid "Save current frame"
+msgstr "Guardar el marco actual"
-#~ msgid "Save all the frames"
-#~ msgstr "Guardar todos los marcos"
+msgid "Save all the frames"
+msgstr "Guardar todos los marcos"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Sólo objetos de mapa sin cabecera y cola extra"
+msgid "Only map objects without extra header and tailer"
+msgstr "Sólo objetos de mapa sin cabecera y cola extra"
 #, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Tipo de objeto desconocido en : %s"
+msgid "Unknown item type in pad: %s"
+msgstr "Tipo de objeto desconocido en : %s"
-#~ msgid "Rendering method for filled polygons"
-#~ msgstr "Método de renderizado para polígonos rellenos"
+msgid "Rendering method for filled polygons"
+msgstr "Método de renderizado para polígonos rellenos"
 #, fuzzy
-#~ msgid ""
-#~ "g;use the libgis render functions (features: clipping);r;use the raster "
-#~ "graphics library functions (features: polylines);d;use the display "
-#~ "library basic functions (features: polylines);c;use the display library "
-#~ "clipping functions (features: clipping);l;use the display library culling "
-#~ "functions (features: culling, polylines)"
-#~ msgstr ""
-#~ "g;usar las funciones de renderización de libgis (funciones: clipping);r;"
-#~ "usar las funciones de la biblioteca de gráficos ráster (funciones: "
-#~ "polilíneas);d;usar las funciones básicas de la biblioteca de "
-#~ "visualización (funciones: polilíneas);c;usar las funciones de clipping de "
-#~ "la biblioteca de visualización (funciones: clipping);l;usar las funciones "
-#~ "de culling de la biblioteca de visualización (funciones: culling, "
-#~ "polilíneas)"
+msgid ""
+"g;use the libgis render functions (features: clipping);r;use the raster "
+"graphics library functions (features: polylines);d;use the display library "
+"basic functions (features: polylines);c;use the display library clipping "
+"functions (features: clipping);l;use the display library culling functions "
+"(features: culling, polylines)"
+msgstr ""
+"g;usar las funciones de renderización de libgis (funciones: clipping);r;usar "
+"las funciones de la biblioteca de gráficos ráster (funciones: polilíneas);d;"
+"usar las funciones básicas de la biblioteca de visualización (funciones: "
+"polilíneas);c;usar las funciones de clipping de la biblioteca de "
+"visualización (funciones: clipping);l;usar las funciones de culling de la "
+"biblioteca de visualización (funciones: culling, polilíneas)"
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "No añadir a la lista de vectoriales y comandos en el monitor (no se "
-#~ "dibujarán si se refresca el monitor)"
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+"No añadir a la lista de vectoriales y comandos en el monitor (no se "
+"dibujarán si se refresca el monitor)"
-#~ msgid "No raster map exists in the current window"
+msgid "No raster map exists in the current window"
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr "Crea y muestra un menú en el marco activo de la pantalla."
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "Crea y muestra un menú en el marco activo de la pantalla."
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "Establece el color de fondo del menú"
+msgid "Sets the color of the menu background"
+msgstr "Establece el color de fondo del menú"
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Establece el color del texto del menú"
+msgid "Sets the color of the menu text"
+msgstr "Establece el color del texto del menú"
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "Establece el color de separación de líneas de texto"
+msgid "Sets the color dividing lines of text"
+msgstr "Establece el color de separación de líneas de texto"
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "Establece el tamaño de texto del menú (en porcentaje)"
+msgid "Sets the menu text size (in percent)"
+msgstr "Establece el tamaño de texto del menú (en porcentaje)"
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "El menú debe contener un título y al menos una opción"
+msgid "Menu must contain a title and at least one option"
+msgstr "El menú debe contener un título y al menos una opción"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "No añadir a la lista de rásters y comandos en el monitor"
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr "No añadir a la lista de rásters y comandos en el monitor"
-#~ msgid "One mouse click only"
-#~ msgstr "Un solo clic del ratón"
+msgid "One mouse click only"
+msgstr "Un solo clic del ratón"
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "Usar el ratón para situar la escala de forma interactiva"
+msgid "Use mouse to interactively place scale"
+msgstr "Usar el ratón para situar la escala de forma interactiva"
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "Usar el ratón para situar el texto de forma interactiva"
+msgid "Use mouse to interactively place text"
+msgstr "Usar el ratón para situar el texto de forma interactiva"
-#~ msgid "Click!\n"
-#~ msgstr "¡Clic!\n"
+msgid "Click!\n"
+msgstr "¡Clic!\n"
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Izquierda:    Sitúe el texto aquí\n"
+msgid " Left:    Place text here\n"
+msgstr " Izquierda:    Sitúe el texto aquí\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Derecha:   Salir\n"
+msgid " Right:   Quit\n"
+msgstr " Derecha:   Salir\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Sólo redibujar los mapas dados usando colores predeterminados"
+msgid "Just redraw given maps using default colors"
+msgstr "Sólo redibujar los mapas dados usando colores predeterminados"
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERROR: no se pueden obtener los elementos de \"lista\""
+msgid "ERROR: can not get \"list\" items"
+msgstr "ERROR: no se pueden obtener los elementos de \"lista\""
-#~ msgid "-j flag forced"
-#~ msgstr "Opción -j forzada"
+msgid "-j flag forced"
+msgstr "Opción -j forzada"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "Ningún mapa está mostrado en el monitor de GRASS"
+msgid "No map is displayed in GRASS monitor"
+msgstr "Ningún mapa está mostrado en el monitor de GRASS"
-#~ msgid "Interactively select route"
-#~ msgstr "Seleccionar ruta de forma interactiva"
+msgid "Interactively select route"
+msgstr "Seleccionar ruta de forma interactiva"
-#~ msgid "You must select more than one point"
-#~ msgstr "Debe seleccionar más de un punto"
+msgid "You must select more than one point"
+msgstr "Debe seleccionar más de un punto"
-#~ msgid "You must select at least four points"
-#~ msgstr "Debe seleccionar al menos cuatro puntos"
+msgid "You must select at least four points"
+msgstr "Debe seleccionar al menos cuatro puntos"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Ningún mapa ráster o vectorial mostrado"
+msgid "No raster or vector map displayed"
+msgstr "Ningún mapa ráster o vectorial mostrado"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "Para establecer y controlar el uso de una pantalla."
+msgid "To establish and control use of a graphics display monitor."
+msgstr "Para establecer y controlar el uso de una pantalla."
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nombre de la pantalla a iniciar"
+msgid "Name of graphics monitor to start"
+msgstr "Nombre de la pantalla a iniciar"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nombre de la pantalla a detener"
+msgid "Name of graphics monitor to stop"
+msgstr "Nombre de la pantalla a detener"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nombre de la pantalla a seleccionar"
+msgid "Name of graphics monitor to select"
+msgstr "Nombre de la pantalla a seleccionar"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nombre de la pantalla a desbloquear"
+msgid "Name of graphics monitor to unlock"
+msgstr "Nombre de la pantalla a desbloquear"
-#~ msgid "List all monitors"
-#~ msgstr "Listar todas las pantallas"
+msgid "List all monitors"
+msgstr "Listar todas las pantallas"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Listar todas las pantallas (con el estado actual)"
+msgid "List all monitors (with current status)"
+msgstr "Listar todas las pantallas (con el estado actual)"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Impirmir el nombre de la pantalla seleccionada actualmente"
+msgid "Print name of currently selected monitor"
+msgstr "Impirmir el nombre de la pantalla seleccionada actualmente"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Libera la pantalla seleccionada actualmente"
+msgid "Release currently selected monitor"
+msgstr "Libera la pantalla seleccionada actualmente"
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "No seleccionar automáticamente al empezar"
+msgid "Do not automatically select when starting"
+msgstr "No seleccionar automáticamente al empezar"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problema al seleccionar %s. Se intentará otra vez"
+msgid "Problem selecting %s. Will try once more"
+msgstr "Problema al seleccionar %s. Se intentará otra vez"
-#~ msgid "Usage:  %s monitor_name"
-#~ msgstr "Uso: %s nombre de monitor"
+msgid "Usage:  %s monitor_name"
+msgstr "Uso: %s nombre de monitor"
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "No hay tal monitor <%s>"
+msgid "No such monitor as <%s>"
+msgstr "No hay tal monitor <%s>"
-#~ msgid "%s: -%c unrecognized option"
-#~ msgstr "%s: opción -%c no reconocida"
+msgid "%s: -%c unrecognized option"
+msgstr "%s: opción -%c no reconocida"
-#~ msgid "Monitor <%s> released"
-#~ msgstr "Monitor <%s> liberado"
+msgid "Monitor <%s> released"
+msgstr "Monitor <%s> liberado"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> en uso por otro usuario"
+msgid "Monitor <%s> in use by another user"
+msgstr "Monitor <%s> en uso por otro usuario"
-#~ msgid "Failed testing lock mechanism"
-#~ msgstr "Fallo al probar el mecanismo de bloqueo"
+msgid "Failed testing lock mechanism"
+msgstr "Fallo al probar el mecanismo de bloqueo"
-#~ msgid "Usage:  %s [-fv] [name]"
-#~ msgstr "Uso: %s [-fv] [nombre]"
+msgid "Usage:  %s [-fv] [name]"
+msgstr "Uso: %s [-fv] [nombre]"
-#~ msgid "Usage: %s [-f] monitor_name"
-#~ msgstr "Uso: %s [-f] nombre de monitor"
+msgid "Usage: %s [-f] monitor_name"
+msgstr "Uso: %s [-f] nombre de monitor"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' terminado"
+msgid "Monitor '%s' terminated"
+msgstr "Monitor '%s' terminado"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Error - El monitor '%s' no estaba funcionando"
+msgid "Error - Monitor '%s' was not running"
+msgstr "Error - El monitor '%s' no estaba funcionando"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Error - Monitor '%s' en uso por otro usuario"
+msgid "Error - Monitor '%s' in use by another user"
+msgstr "Error - Monitor '%s' en uso por otro usuario"
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Error - Falló el mecanismo de bloqueo"
+msgid "Error - Locking mechanism failed"
+msgstr "Error - Falló el mecanismo de bloqueo"
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Error al elegir el marco [%s]\n"
+msgid "Error choosing frame [%s]\n"
+msgstr "Error al elegir el marco [%s]\n"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Botones:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"Botones:\n"
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "Izquierda:   Seleccionar marco\n"
+msgid "Left:   Select frame\n"
+msgstr "Izquierda:   Seleccionar marco\n"
-#~ msgid "Middle: Keep original frame\n"
-#~ msgstr "Centro: Mantener marco original\n"
+msgid "Middle: Keep original frame\n"
+msgstr "Centro: Mantener marco original\n"
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Derecha:  Aceptar marco\n"
+msgid "Right:  Accept frame\n"
+msgstr "Derecha:  Aceptar marco\n"
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr "Gestiona marcos de presentación en la pantalla del usuario."
+msgid "Manages display frames on the user's graphics monitor."
+msgstr "Gestiona marcos de presentación en la pantalla del usuario."
-#~ msgid "Create a new frame"
-#~ msgstr "Crea un nuevo marco"
+msgid "Create a new frame"
+msgstr "Crea un nuevo marco"
-#~ msgid "Select a frame"
-#~ msgstr "Seleccionar un marco"
+msgid "Select a frame"
+msgstr "Seleccionar un marco"
-#~ msgid "Print name of current frame"
-#~ msgstr "Imprimir el nombre del marco actual"
+msgid "Print name of current frame"
+msgstr "Imprimir el nombre del marco actual"
-#~ msgid "Print names of all frames"
-#~ msgstr "Imprimir el nombre de todos los marcos"
+msgid "Print names of all frames"
+msgstr "Imprimir el nombre de todos los marcos"
-#~ msgid "List map names displayed in GRASS monitor"
-#~ msgstr "Listar nombres de los mapas mostrados en el monitor de GRASS"
+msgid "List map names displayed in GRASS monitor"
+msgstr "Listar nombres de los mapas mostrados en el monitor de GRASS"
-#~ msgid "Debugging output"
-#~ msgstr "Salida de depuración"
+msgid "Debugging output"
+msgstr "Salida de depuración"
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Marco a crear/seleccionar"
+msgid "Frame to be created/selected"
+msgstr "Marco a crear/seleccionar"
-#~ msgid "bottom,top,left,right"
-#~ msgstr "inferior,superior,izquierda,derecha"
+msgid "bottom,top,left,right"
+msgstr "inferior,superior,izquierda,derecha"
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "Dónde colocar el marco, valores en porcentaje (implica -c)"
+msgid "Where to place the frame, values in percent (implies -c)"
+msgstr "Dónde colocar el marco, valores en porcentaje (implica -c)"
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "Botones del ratón:"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"Botones del ratón:"
-#~ msgid "Left:   Select From\n"
-#~ msgstr "Izquierda: seleccionar desde\n"
+msgid "Left:   Select From\n"
+msgstr "Izquierda: seleccionar desde\n"
-#~ msgid "Middle: Select To\n"
-#~ msgstr "Centro: seleccionar hasta\n"
+msgid "Middle: Select To\n"
+msgstr "Centro: seleccionar hasta\n"
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Derecho: salir\n"
-#~ "\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr ""
+"Derecho: salir\n"
+"\n"
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitor: comando interactivo en redibujar"
+msgid "Monitor: interactive command in redraw"
+msgstr "Monitor: comando interactivo en redibujar"
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "%d visuales encontrados de tipo TrueColor"
+msgid "found %d visuals of type TrueColor"
+msgstr "%d visuales encontrados de tipo TrueColor"
-#~ msgid "searching for highest bit depth"
-#~ msgstr "buscando la profundidad de bit más alta"
+msgid "searching for highest bit depth"
+msgstr "buscando la profundidad de bit más alta"
-#~ msgid "selected %d bit depth"
-#~ msgstr "profundidad de bit %d seleccionada"
+msgid "selected %d bit depth"
+msgstr "profundidad de bit %d seleccionada"
-#~ msgid "using default visual which is %s"
-#~ msgstr "utilizando el visual predeterminado, que es %s"
+msgid "using default visual which is %s"
+msgstr "utilizando el visual predeterminado, que es %s"
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitor: waitpid: se esperaba %d pero se obtuvo %d"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Monitor: waitpid: se esperaba %d pero se obtuvo %d"
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XGetWMName falló"
+msgid "Monitor: XGetWMName failed"
+msgstr "Monitor: XGetWMName falló"
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: mal resultado"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Monitor: XGetWMName: mal resultado"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "¡AVISO!  Ya existe un archivo de proyección para esta localización\n"
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+"\n"
+"\n"
+"¡AVISO!  Ya existe un archivo de proyección para esta localización\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "¿Todavía quiere sobrescribir la información de la proyección actual? "
+msgid "Would you still like to overwrite the current projection information "
+msgstr "¿Todavía quiere sobrescribir la información de la proyección actual? "
-#~ msgid "The projection information will not be updated."
-#~ msgstr "La información de la proyección no se actualizará."
+msgid "The projection information will not be updated."
+msgstr "La información de la proyección no se actualizará."
-#~ msgid "Enable interactive prompting (for command-line use only)"
-#~ msgstr "Activar introducción interactiva (sólo para línea de comandos)"
+msgid "Enable interactive prompting (for command-line use only)"
+msgstr "Activar introducción interactiva (sólo para línea de comandos)"
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> es un nombre de región no admitido"
+msgid "<%s> is an illegal region name"
+msgstr "<%s> es un nombre de región no admitido"
 #, fuzzy
-#~ msgid "Erasing monitors..."
-#~ msgstr "Borrando monitores..."
+msgid "Erasing monitors..."
+msgstr "Borrando monitores..."
-#~ msgid "Apply regular expressions and wildcards to g.remove"
-#~ msgstr "Aplicar expresiones regulares y comodines a g.remove"
+msgid "Apply regular expressions and wildcards to g.remove"
+msgstr "Aplicar expresiones regulares y comodines a g.remove"
-#~ msgid "Memory allocation error"
-#~ msgstr "Error de asignación de memoria"
+msgid "Memory allocation error"
+msgstr "Error de asignación de memoria"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "No se puede ejecutar: %s"
+msgid "Cannot execute: %s"
+msgstr "No se puede ejecutar: %s"
-#~ msgid "Cannot link table: %s"
-#~ msgstr "No se puede conectar la tabla: %s"
+msgid "Cannot link table: %s"
+msgstr "No se puede conectar la tabla: %s"
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nombre del mapa(s) ráster de entrada"
+msgid "Name of input raster map(s)"
+msgstr "Nombre del mapa(s) ráster de entrada"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr ""
-#~ "La extensión del archivo de salida (archivo(s) de salida + extensión)"
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr "La extensión del archivo de salida (archivo(s) de salida + extensión)"
-#~ msgid "Display manager for GRASS"
-#~ msgstr "Administrador de visualización para GRASS"
+msgid "Display manager for GRASS"
+msgstr "Administrador de visualización para GRASS"
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Nombre del archivo de configuración .dmrc"
+msgid "Name of .dmrc settings file"
+msgstr "Nombre del archivo de configuración .dmrc"
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "Guarda el monitor activo a un archivo PNG en el directorio home"
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr "Guarda el monitor activo a un archivo PNG en el directorio home"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Resolución del archivo de salida (único=1, doble=2, cuádruple=4)"
+msgid "Resolution of output file (single=1, double=2, quad=4)"
+msgstr "Resolución del archivo de salida (único=1, doble=2, cuádruple=4)"
-#~ msgid ""
-#~ "Divides active display into two frames & displays maps/executes commands "
-#~ "in each frame."
-#~ msgstr ""
-#~ "Divide la visualización activa en dos marcos y muestra los mapas/ejecuta "
-#~ "los comandos en cada uno."
+msgid ""
+"Divides active display into two frames & displays maps/executes commands in "
+"each frame."
+msgstr ""
+"Divide la visualización activa en dos marcos y muestra los mapas/ejecuta los "
+"comandos en cada uno."
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "Introducir comando a ejecutar en el primer marco"
+msgid "Enter command to execute in 1st frame"
+msgstr "Introducir comando a ejecutar en el primer marco"
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "Introducir mapa ráster a mostrar en el segundo marco"
+msgid "Enter raster map to display in 2nd frame"
+msgstr "Introducir mapa ráster a mostrar en el segundo marco"
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "Introducir comando a ejecutar en el segundo marco"
+msgid "Enter command to execute in 2nd frame"
+msgstr "Introducir comando a ejecutar en el segundo marco"
-#~ msgid "How to split display"
-#~ msgstr "Como dividir la visualización"
+msgid "How to split display"
+msgstr "Como dividir la visualización"
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr ""
-#~ "Mantener números de banda en vez de usar nombres de color de las bandas."
+msgid "Keep band numbers instead of using band color names."
+msgstr ""
+"Mantener números de banda en vez de usar nombres de color de las bandas."
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr ""
-#~ "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "Calcula estadísticas univariantes a partir de un mapa ráster de GRASS."
-#~ msgid "extended statistics (quartiles and percentile)"
-#~ msgstr "estadísticas ampliadas (cuartiles y percentiles)"
+msgid "extended statistics (quartiles and percentile)"
+msgstr "estadísticas ampliadas (cuartiles y percentiles)"
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "Percentil a calcular (requiere la opción -e)"
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "Percentil a calcular (requiere la opción -e)"
-#~ msgid "Saving new map"
-#~ msgstr "Guardando el nuevo mapa"
+msgid "Saving new map"
+msgstr "Guardando el nuevo mapa"
-#~ msgid "Cell area: %f"
-#~ msgstr "Área de celda: %f"
+msgid "Cell area: %f"
+msgstr "Área de celda: %f"
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Mapa ráster de terreno (MDT)"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Mapa ráster de terreno (MDT)"
-#~ msgid "Output raster map with lake"
-#~ msgstr "Producir mapa ráster con lago"
+msgid "Output raster map with lake"
+msgstr "Producir mapa ráster con lago"
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "¡No se puede escribir el mapa ráster de lago <%s>!"
+msgid "Cannot write lake raster map <%s>!"
+msgstr "¡No se puede escribir el mapa ráster de lago <%s>!"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "¡Mapa ráster de terreno <%s> no encontrado!"
+msgid "Terrain raster map <%s> not found!"
+msgstr "¡Mapa ráster de terreno <%s> no encontrado!"
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "¡No se puede abrir el mapa ráster de terreno <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "¡No se puede abrir el mapa ráster de terreno <%s@%s>!"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "mapa <%s> no encontrado"
+msgid "Seed map <%s> not found!"
+msgstr "mapa <%s> no encontrado"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "No se puede abrir la base de datos %s"
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "No se puede abrir la base de datos %s"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Fallo al asignar memoria para punteros de fila"
+msgid "Failure to allocate memory for row pointers"
+msgstr "Fallo al asignar memoria para punteros de fila"
-#~ msgid "Loading maps: "
-#~ msgstr "Cargando mapas: "
+msgid "Loading maps: "
+msgstr "Cargando mapas: "
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr ""
-#~ "Error al leer el mapa ráster de terreno. Probablemente el archivo está "
-#~ "corrupto."
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr ""
+"Error al leer el mapa ráster de terreno. Probablemente el archivo está "
+"corrupto."
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr ""
-#~ "Error al leer el mapa ráster de . Probablemente el archivo está corrupto."
+msgid "Error reading seed raster map. Probably broken file."
+msgstr ""
+"Error al leer el mapa ráster de . Probablemente el archivo está corrupto."
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "¡No se puede escribir el mapa ráster de lago <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "¡No se puede escribir el mapa ráster de lago <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Empezando el relleno del lago al nivel %8.4f en %d pases.\n"
-#~ "Porcentaje hecho:"
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr ""
+"Empezando el relleno del lago al nivel %8.4f en %d pases.\n"
+"Porcentaje hecho:"
-#~ msgid "Pass: %d\n"
-#~ msgstr "Pase: %d\n"
+msgid "Pass: %d\n"
+msgstr "Pase: %d\n"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "¡Error al escribir archivo de color para <%s@%s>!"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "¡Error al escribir archivo de color para <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Todo hecho."
+msgid "All done."
+msgstr "Todo hecho."
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Calcula el índice <simple> en un mapa ráster"
+msgid "Calculates <simple> index on a raster map"
+msgstr "Calcula el índice <simple> en un mapa ráster"
-#~ msgid "raster, landscape structure analysis, job launcher"
-#~ msgstr "ráster, análisis de estructura de paisaje, lanzador de trabajos"
+msgid "raster, landscape structure analysis, job launcher"
+msgstr "ráster, análisis de estructura de paisaje, lanzador de trabajos"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Utilidad de interpolación bilineal para capas de mapa ráster."
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "Utilidad de interpolación bilineal para capas de mapa ráster."
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "Valores de entrada específicos a asignar a los polos Norte y/o Sur para "
-#~ "cuadrículas longitud-latitud"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr ""
+"Valores de entrada específicos a asignar a los polos Norte y/o Sur para "
+"cuadrículas longitud-latitud"
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr ""
-#~ "Este módulo está despreciado. Por favor, use 'r.resamp.interp' en su "
-#~ "lugar."
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr ""
+"Este módulo está despreciado. Por favor, use 'r.resamp.interp' en su lugar."
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mapa(s) ráster de entrada"
+msgid "Raster input maps(s)"
+msgstr "Mapa(s) ráster de entrada"
-#~ msgid "Output file name"
-#~ msgstr "Nombre de archivo de salida"
+msgid "Output file name"
+msgstr "Nombre de archivo de salida"
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "%s: no se puede leer el rango fp para [%s]"
+msgid "%s: can't read fp range for [%s]"
+msgstr "%s: no se puede leer el rango fp para [%s]"
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr ""
-#~ "El mapa ráster [%s] ya existe.\n"
-#~ "Por favor, pruebe otro."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr ""
+"El mapa ráster [%s] ya existe.\n"
+"Por favor, pruebe otro."
-#~ msgid "DXF input file"
-#~ msgstr "Archivo DXF de entrada"
+msgid "DXF input file"
+msgstr "Archivo DXF de entrada"
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "No se puede abrir el archivo dxf <%s>"
+msgid "Cannot open dxf file <%s>"
+msgstr "No se puede abrir el archivo dxf <%s>"
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "No se puede abrir el nuevo mapa vectorial <%s>"
+msgid "Cannot open new vector map <%s>"
+msgstr "No se puede abrir el nuevo mapa vectorial <%s>"
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Conversión de <%s> a mapa vectorial:"
+msgid "Conversion of <%s> to vector map:"
+msgstr "Conversión de <%s> a mapa vectorial:"
 #, fuzzy
-#~ msgid "Specified group does not exist"
-#~ msgstr "El grupo especificado no existe... Saliendo."
+msgid "Specified group does not exist"
+msgstr "El grupo especificado no existe... Saliendo."
-#~ msgid "imagery group"
-#~ msgstr "grupo de imaginería"
+msgid "imagery group"
+msgstr "grupo de imaginería"
-#~ msgid "imagery subgroup"
-#~ msgstr "subgrupo de imágenes"
+msgid "imagery subgroup"
+msgstr "subgrupo de imágenes"
-#~ msgid "output raster map"
-#~ msgstr "mapa de salida ráster"
+msgid "output raster map"
+msgstr "mapa de salida ráster"
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Genera y muestra gráficos sencillos en capas de mapa dibujadas en el "
-#~ "marco de visualización del monitor activo."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+"Genera y muestra gráficos sencillos en capas de mapa dibujadas en el marco "
+"de visualización del monitor activo."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Archivo Unix que contiene instrucciones gráficas. Si no se indica lee de "
-#~ "la entrada estándar"
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+"Archivo Unix que contiene instrucciones gráficas. Si no se indica lee de la "
+"entrada estándar"
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Color con el que dibujar: color estándar de GRASS o triplete R:G:B "
-#~ "(separado por dos puntos)"
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Color con el que dibujar: color estándar de GRASS o triplete R:G:B (separado "
+"por dos puntos)"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "valor [%.0f,%.0f] fuera de rango [0-100]"
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr "valor [%.0f,%.0f] fuera de rango [0-100]"
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Escribe texto en el marco activo de la pantalla usando fuentes TrueType."
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr ""
+"Escribe texto en el marco activo de la pantalla usando fuentes TrueType."
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "Posición de pantalla (porcentaje, [0,0] es inferior izquierda)"
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr "Posición de pantalla (porcentaje, [0,0] es inferior izquierda)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Ruta del tipo de letra TrueType (incluir nombre de fichero)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Ruta del tipo de letra TrueType (incluir nombre de fichero)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "Altura de letras (en porcentaje de la altura del marco disponible)"
+msgid "Height of letters (in percent of available frame height)"
+msgstr "Altura de letras (en porcentaje de la altura del marco disponible)"
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Texto o se debe dar -c"
+msgid "Either text or -c should be given"
+msgstr "Texto o se debe dar -c"
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "Elegir sólo un sistema de coordenadas para la ubicación"
+msgid "Choose only one coordinate system for placement"
+msgstr "Elegir sólo un sistema de coordenadas para la ubicación"
-#~ msgid "No font selected"
-#~ msgstr "Ninguna fuente seleccionada"
+msgid "No font selected"
+msgstr "Ninguna fuente seleccionada"
-#~ msgid "Invalid font: %s"
-#~ msgstr "Fuente inválida: %s"
+msgid "Invalid font: %s"
+msgstr "Fuente inválida: %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "No se puede crear el contexto de conversión de texto"
+msgid "Unable to create text conversion context"
+msgstr "No se puede crear el contexto de conversión de texto"
-#~ msgid "Text conversion error"
-#~ msgstr "Error en la conversión de texto"
+msgid "Text conversion error"
+msgstr "Error en la conversión de texto"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "No se puede escribir el archivo temporal"
+msgid "Unable to write the temporary file"
+msgstr "No se puede escribir el archivo temporal"
-#~ msgid "No predefined font"
-#~ msgstr "Ninguna fuente predefinida"
+msgid "No predefined font"
+msgstr "Ninguna fuente predefinida"
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s: No se puede leer la fuente"
+msgid "%s: Unable to read font"
+msgstr "%s: No se puede leer la fuente"
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr ""
-#~ "%s: no se puede leer el archivo de definición FreeType; use el "
-#~ "predeterminado"
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr ""
+"%s: no se puede leer el archivo de definición FreeType; use el predeterminado"
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s: ninún archivo de definición FreeType"
+msgid "%s: No FreeType definition file"
+msgstr "%s: ninún archivo de definición FreeType"
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s: no se puede leer el archivo de definición FreeType"
+msgid "%s: Unable to read FreeType definition file"
+msgstr "%s: no se puede leer el archivo de definición FreeType"
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "Sin información de latitud/longitud para la proyección XY"
+msgid "No LatLong information for XY-Projection"
+msgstr "Sin información de latitud/longitud para la proyección XY"
-#~ msgid "Quietly"
-#~ msgstr "De forma silenciosa"
+msgid "Quietly"
+msgstr "De forma silenciosa"
-#~ msgid ""
-#~ "The '-q' flag is superseded and will be removed in future. Please use '--"
-#~ "quiet' instead"
-#~ msgstr ""
-#~ "La opción '-q' está suplantada y se eliminará en el futuro. Por favor, "
-#~ "use '--quiet' en su lugar"
+msgid ""
+"The '-q' flag is superseded and will be removed in future. Please use '--"
+"quiet' instead"
+msgstr ""
+"La opción '-q' está suplantada y se eliminará en el futuro. Por favor, use "
+"'--quiet' en su lugar"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silencioso - no muestra el progreso"
+msgid "Quiet - Do not show progress"
+msgstr "Silencioso - no muestra el progreso"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Suprime mensaje de error de cruzamiento simple"
+msgid "Suppress single crossing error messages"
+msgstr "Suprime mensaje de error de cruzamiento simple"
-#~ msgid ""
-#~ "The '-q' and '-n' flag is superseded and will be removed in future. "
-#~ "Please use '--quiet' instead."
-#~ msgstr ""
-#~ "Las opciones '-q' y '-n' son suplantadas y serán eliminadas en el futuro. "
-#~ "Por favor use '--quiet' en su lugar."
+msgid ""
+"The '-q' and '-n' flag is superseded and will be removed in future. Please "
+"use '--quiet' instead."
+msgstr ""
+"Las opciones '-q' y '-n' son suplantadas y serán eliminadas en el futuro. "
+"Por favor use '--quiet' en su lugar."
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "G_put_raster_row falló (¿sistema de archivos lleno?)"
+msgid "G_put_raster_row failed (file system full?)"
+msgstr "G_put_raster_row falló (¿sistema de archivos lleno?)"
-#~ msgid "Quiet; No chatter"
-#~ msgstr "En silencio; Sin comentarios"
+msgid "Quiet; No chatter"
+msgstr "En silencio; Sin comentarios"
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Archivo(s) ráster para elevación"
+msgid "Raster file(s) for Elevation"
+msgstr "Archivo(s) ráster para elevación"
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "Archivo(s) ráster para color"
+msgid "Raster file(s) for Color"
+msgstr "Archivo(s) ráster para color"
-#~ msgid ""
-#~ "Not enough data columns. Incorrect delimiter or column number?\n"
-#~ "[%s]"
-#~ msgstr ""
-#~ "Columnas de datos insuficientes. ¿Delimitador o número de columna "
-#~ "incorrecto?\n"
-#~ "[%s]"
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number?\n"
+"[%s]"
+msgstr ""
+"Columnas de datos insuficientes. ¿Delimitador o número de columna "
+"incorrecto?\n"
+"[%s]"
-#~ msgid ""
-#~ "Input raster map constains cells with NULL-value (no-data). For no-data "
-#~ "values was used value %g. You can specify nodata value by %s parameter."
-#~ msgstr ""
-#~ "El mapa ráster de entrada contiene celdas con valor NULO (sin datos). "
-#~ "Para los valores sin datos se usó el valor %g. Puede especificar el valor "
-#~ "para para las celdas sin datos con el parámetro %s."
+msgid ""
+"Input raster map constains cells with NULL-value (no-data). For no-data "
+"values was used value %g. You can specify nodata value by %s parameter."
+msgstr ""
+"El mapa ráster de entrada contiene celdas con valor NULO (sin datos). Para "
+"los valores sin datos se usó el valor %g. Puede especificar el valor para "
+"para las celdas sin datos con el parámetro %s."
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nombre del mapa vectorial de puntos con localizaciones X,Y"
+msgid "Name of the vector points map with x,y locations"
+msgstr "Nombre del mapa vectorial de puntos con localizaciones X,Y"
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "Número de repeticiones de tiempo (segundos)"
+msgid "Number of time iterations (sec.)"
+msgstr "Número de repeticiones de tiempo (segundos)"
-#~ msgid "Multiscale simulation"
-#~ msgstr "Simulación multiescala"
+msgid "Multiscale simulation"
+msgstr "Simulación multiescala"
-#~ msgid "Running MAY 10 version"
-#~ msgstr "Ejecutando la versión MAY 10"
+msgid "Running MAY 10 version"
+msgstr "Ejecutando la versión MAY 10"
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr ""
-#~ "Nombre del mapa ráster de elevaciones, en las mismas unidades que N,E: "
-#~ "[m] o [pies]"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr ""
+"Nombre del mapa ráster de elevaciones, en las mismas unidades que N,E: [m] o "
+"[pies]"
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nombre del mapa ráster de derivadas de X [m/m] o [pies/pies]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgstr "Nombre del mapa ráster de derivadas de X [m/m] o [pies/pies]"
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "Nombre del mapa ráster de derivadas de Y [m/m] o [pies/pies]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "Nombre del mapa ráster de derivadas de Y [m/m] o [pies/pies]"
-#~ msgid "Threshold distance set to %g map units (based on 2D resolution)"
-#~ msgstr ""
-#~ "Distancia umbral establecida a %g unidades de mapa (basado en resolución "
-#~ "2D)"
+msgid "Threshold distance set to %g map units (based on 2D resolution)"
+msgstr ""
+"Distancia umbral establecida a %g unidades de mapa (basado en resolución 2D)"
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Mapa ráster en el que hacer zum"
+msgid "Raster map to zoom into"
+msgstr "Mapa ráster en el que hacer zum"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "Guardar la región actual en archivo de definición de región"
+msgid "Save the current region to region definition file"
+msgstr "Guardar la región actual en archivo de definición de región"
-#~ msgid "Multiplier"
-#~ msgstr "Multiplicador"
+msgid "Multiplier"
+msgstr "Multiplicador"
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Herramienta de consulta '%s' desconocida"
+msgid "Unknown query tool '%s'"
+msgstr "Herramienta de consulta '%s' desconocida"
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Tipo de columna [%d] no soportado"
+msgid "Column type [%d] not supported"
+msgstr "Tipo de columna [%d] no soportado"
-#~ msgid "defaulting to nearest neighbor sampling"
-#~ msgstr "haciendo predeterminado el muestreo por el vecino más próximo"
+msgid "defaulting to nearest neighbor sampling"
+msgstr "haciendo predeterminado el muestreo por el vecino más próximo"
-#~ msgid "Only %d lines found, at least two needed"
-#~ msgstr "Sólo se han encontrado %d líneas, se necesitan el menos dos"
+msgid "Only %d lines found, at least two needed"
+msgstr "Sólo se han encontrado %d líneas, se necesitan el menos dos"
-#~ msgid "Unable to delete line %d"
-#~ msgstr "No se puede borrar la línea %d"
+msgid "Unable to delete line %d"
+msgstr "No se puede borrar la línea %d"
-#~ msgid "Unable to write line %d"
-#~ msgstr "No se puede escribir la línea %d"
+msgid "Unable to write line %d"
+msgstr "No se puede escribir la línea %d"
-#~ msgid "Unable to connect line id %d to line %d"
-#~ msgstr "No se puede conectar la línea con ID %d a la línea %d"
+msgid "Unable to connect line id %d to line %d"
+msgstr "No se puede conectar la línea con ID %d a la línea %d"
-#~ msgid ""
-#~ "Unable to connect line id %d to line %d because of threshold distance. "
-#~ "Run v.edit with other threshold distance value."
-#~ msgstr ""
-#~ "No se puede conectar la línea con ID %d a la línea %d por la distancia "
-#~ "umbral. Ejecute v.edit con otro valor de distancia umbral."
+msgid ""
+"Unable to connect line id %d to line %d because of threshold distance. Run v."
+"edit with other threshold distance value."
+msgstr ""
+"No se puede conectar la línea con ID %d a la línea %d por la distancia "
+"umbral. Ejecute v.edit con otro valor de distancia umbral."
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "No se puede obtener la lista de categorías <%s>, edición terminada"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "No se puede obtener la lista de categorías <%s>, edición terminada"
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "No se puede borrar la capa/categoría [%d/%d] línea %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "No se puede borrar la capa/categoría [%d/%d] línea %d"
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "\rCentroides de área duplicados: %5d"
+msgid "\rDuplicate area centroids: %5d"
+msgstr "\rCentroides de área duplicados: %5d"
-#~ msgid "\rRemoved vertices: %5d"
-#~ msgstr "\rVértices eliminados: %5d"
+msgid "\rRemoved vertices: %5d"
+msgstr "\rVértices eliminados: %5d"
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr ""
-#~ "Cargar valores de vectorial a base de datos. Para valores de categorías "
-#~ "subidos/impresos se usa '-1' para 'sin categoría' y 'null'/'-' si la "
-#~ "categoría no se puede encontrar o se encontraron múltiples categorías."
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr ""
+"Cargar valores de vectorial a base de datos. Para valores de categorías "
+"subidos/impresos se usa '-1' para 'sin categoría' y 'null'/'-' si la "
+"categoría no se puede encontrar o se encontraron múltiples categorías."
-#~ msgid "Column(s)"
-#~ msgstr "Columna(s)"
+msgid "Column(s)"
+msgstr "Columna(s)"
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "No se puede abrir el origen de datos OGR '%s'"
+msgid "Cannot open OGR data source '%s'"
+msgstr "No se puede abrir el origen de datos OGR '%s'"
-#~ msgid "Cannot create layer"
-#~ msgstr "No se puede crear la capa"
+msgid "Cannot create layer"
+msgstr "No se puede crear la capa"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+"\a\n"
+"** Los siguientes mapas ráster en el subgrupo [%s] no existen:"
+msgid "       %s"
+msgstr "       %s"
+#, fuzzy
+#~ msgid "Name of raster map to generate legend from"
+#~ msgstr "Nombre del mapa ráster a usar para <%s>"
+#, fuzzy
+#~ msgid "Enter raster map to display in 1st frame"
+#~ msgstr "Introducir mapa ráster a mostrar en el segundo marco"
+#~ msgid "        Number of bytes per cell"
+#~ msgstr "        Número de bytes por celda"
+#, fuzzy
+#~ msgid "No attribute table found"
+#~ msgstr "Atributo no encontrado"
+#, fuzzy
+#~ msgid "No numerical attributes found. Skipping export"
+#~ msgstr "No se encontraron áreas, se salta el tipo=polígono"
+#, fuzzy
+#~ msgid "Error reading value of attribute '%s'"
+#~ msgstr "Error al leer categorías: '%s'"
+#~ msgid "Illegal subgroup name <%s>"
+#~ msgstr "Nombre de subgrupo <%s> no admitido"
+#, fuzzy
+#~ msgid "Database is not a %s"
+#~ msgstr "Nombre de la base de datos de entrada"
+#~ msgid "No monitor selected"
+#~ msgstr " Ningún monitor seleccionado"
+#, fuzzy
 #~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
+#~ "d;use the display library basic functions (features: polylines);c;use the "
+#~ "display library clipping functions (features: clipping);l;use the display "
+#~ "library culling functions (features: culling, polylines)"
 #~ msgstr ""
-#~ "\a\n"
-#~ "** Los siguientes mapas ráster en el subgrupo [%s] no existen:"
+#~ "g;usar las funciones de renderización de libgis (funciones: clipping);r;"
+#~ "usar las funciones de la biblioteca de gráficos ráster (funciones: "
+#~ "polilíneas);d;usar las funciones básicas de la biblioteca de "
+#~ "visualización (funciones: polilíneas);c;usar las funciones de clipping de "
+#~ "la biblioteca de visualización (funciones: clipping);l;usar las funciones "
+#~ "de culling de la biblioteca de visualización (funciones: culling, "
+#~ "polilíneas)"
-#~ msgid "       %s"
-#~ msgstr "       %s"
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "Método no válido: %s"
+#, fuzzy
+#~ msgid "Unable to create face"
+#~ msgstr "No se puede crear el índice"
+#~ msgid "Unable to set size"
+#~ msgstr "No se puede establecer el tamaño"
+#~ msgid "format"
+#~ msgstr "formato"
+#, fuzzy
+#~ msgid "Apply regular expressions and wildcards to g.list"
+#~ msgstr "Aplicar expresiones regulares y comodines a g.remove"
Modified: grass/trunk/locale/po/grassmods_fr.po
--- grass/trunk/locale/po/grassmods_fr.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_fr.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -6,7 +6,7 @@
 # Laurent Courty, 2005.
 # Daniel Calvelo Aros <dca at users.sf.net>, 2005
 # Eve (alias 'phyto') <dendrosociology[a]yahoo.co.uk>, 2005, 2006
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmods_fr\n"
@@ -6111,12 +6111,12 @@
 #: ../imagery/i.vi/main.c:133
 #, fuzzy
 msgid "Name of the chan5 channel surface reflectance map"
-msgstr "Nom du nouveau fichier raster"
+msgstr "Nom de la couche en sortie"
 #: ../imagery/i.vi/main.c:140
 #, fuzzy
 msgid "Name of the chan7 channel surface reflectance map"
 # c-format
 #: ../imagery/i.vi/main.c:306 ../imagery/i.albedo/main.c:389
@@ -6981,7 +6981,7 @@
 #: ../imagery/i.albedo/main.c:166
 #, fuzzy
 msgid "At least two raster maps are required"
-msgstr "Coordonnées pour la requête"
+msgstr "Un nom de couche de cellule en sortie est requis."
 # c-format
 #: ../imagery/i.albedo/main.c:194
@@ -7012,7 +7012,7 @@
 #: ../imagery/i.modis.qc/main.c:80
 #, fuzzy
 msgid "Name of QC"
-msgstr "Nom du fichier PNG"
+msgstr "Nom du jeu de données en sortie"
 #: ../imagery/i.modis.qc/main.c:82
 msgid "modland_qa_bits"
@@ -7091,12 +7091,14 @@
 "Nom de la couche raster de sortie"
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:1
+#, fuzzy
 msgid "Configuration editor for r.li.'index'"
-msgstr ""
+msgstr "Nom du fichier de configuration illégal"
 #: ../locale/scriptstrings/r.li.setup_to_translate.c:2
+#, fuzzy
 msgid "raster, landscape structure analysis"
-msgstr ""
+msgstr "Statistiques de transition de classe."
 #: ../locale/scriptstrings/d.polar_to_translate.c:1
 msgid "Draws polar diagram of angle map such as aspect or flow directions"
@@ -7165,8 +7167,9 @@
 msgstr "Nom d'une couche raster"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
+#, fuzzy
 msgid "Width of display canvas"
-msgstr ""
+msgstr "Texte à afficher"
 #: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
 #, fuzzy
@@ -7301,8 +7304,9 @@
 msgstr "Afficher les pages de manuel GRASS au format HTML"
 #: ../locale/scriptstrings/g.manual_to_translate.c:2
+#, fuzzy
 msgid "general, manual, help"
-msgstr ""
+msgstr "Projection source"
 #: ../locale/scriptstrings/g.manual_to_translate.c:3
 #, fuzzy
@@ -7327,8 +7331,9 @@
 "panchromatique à haute résolution"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:2
+#, fuzzy
 msgid "raster, imagery, fusion"
-msgstr ""
+msgstr "Importation vecteur complète"
 #: ../locale/scriptstrings/i.fusion.brovey_to_translate.c:3
 msgid "sensor: LANDSAT"
@@ -7369,8 +7374,9 @@
 "couleurs; créer une couche *.mosaic"
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#, fuzzy
 msgid "raster, imagery, mosaicking"
-msgstr ""
 #: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
 msgid "1st map for mosaic (top of image stack)."
@@ -7486,12 +7492,14 @@
 "Convertit les coordonnées d'une projection à une autre (interface de cs2cs)."
 #: ../locale/scriptstrings/m.proj_to_translate.c:2
+#, fuzzy
 msgid "miscellaneous, projection"
-msgstr ""
 #: ../locale/scriptstrings/m.proj_to_translate.c:3
+#, fuzzy
 msgid "Input coordinate file (omit to read from stdin)"
-msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
+msgstr "Fichier de coordonnées en sortie (ne pas envoyer vers stdout)"
 #: ../locale/scriptstrings/m.proj_to_translate.c:4
 msgid "Output coordinate file (omit to send to stdout)"
@@ -8196,8 +8204,9 @@
 msgstr "Nom du fichier vecteur de sortie"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#, fuzzy
 msgid "Action to be taken"
-msgstr ""
+msgstr "Icone à supprimer"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:6
 #: ../locale/scriptstrings/v.report_to_translate.c:6
@@ -8206,8 +8215,9 @@
 msgstr "Code de couche"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:7
+#, fuzzy
 msgid "Category number starting value"
-msgstr ""
+msgstr "Nom de colonne de catégorie"
 #: ../locale/scriptstrings/v.centroids_to_translate.c:8
 #: ../vector/v.category/main.c:104
@@ -8433,8 +8443,9 @@
 "forme affichée par v.db.connect -c'est-à-dire en substituant les variables"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#, fuzzy
 msgid "Name of new database"
-msgstr "Nom de la nouvelle base de données"
+msgstr "Nom du fichier base de données"
 #: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
 msgid "Old schema"
@@ -8891,8 +8902,9 @@
 msgstr "Distance de zone-tampon en unités carte."
 #: ../locale/scriptstrings/gis.m_to_translate.c:1
+#, fuzzy
 msgid "GIS manager for GRASS"
-msgstr ""
+msgstr "Afficher les pages de manuel GRASS au format HTML"
 #: ../locale/scriptstrings/gis.m_to_translate.c:2
 #, fuzzy
@@ -9599,7 +9611,7 @@
 #: ../raster/r.external/main.c:339
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (data range)"
-msgstr "Table de couleur de [%s] mise à jour"
+msgstr "Création des fichiers support pour %s..."
 #: ../raster/r.external/main.c:353
 #, fuzzy, c-format
@@ -12626,33 +12638,22 @@
 #: ../raster/r.uslek/main.c:58
 #, fuzzy
 msgid "Name of the Soil sand fraction map [0.0-1.0]"
-msgstr ""
-"#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-"Nom du fichier raster source\n"
-"Nom de la couche raster source"
+msgstr "Nom du fichier raster source"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:66
 #, fuzzy
 msgid "Name of the Soil silt fraction map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:70
 #, fuzzy
 msgid "Name of the Soil Organic Matter map [0.0-1.0]"
-msgstr ""
 #: ../raster/r.uslek/main.c:74
 #, fuzzy
@@ -18541,19 +18542,19 @@
 msgstr "Couche raster sur laquelle ajuster la région"
 #: ../raster/r.mapcalc/main.c:119
+#, fuzzy
 msgid "Expression to evaluate"
-msgstr ""
+msgstr "Valeur de la chaîne de bit"
 #: ../raster/r.mapcalc/main.c:123
 #, fuzzy
 msgid "File containing expression to evaluate"
 msgstr "Fichier contenant les signatures initiales"
-# c-format
 #: ../raster/r.mapcalc/main.c:148
 #, fuzzy
 msgid "parse error"
-msgstr "%d erreurs de mise à jour"
+msgstr "Paramètres du cluster\n"
 #: ../raster/r.mapcalc/main.c:157
 msgid "Floating point error(s) occured in the calculation"
@@ -19642,7 +19643,7 @@
 #: ../raster/r.statistics2/main.c:185
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
-msgstr "%s: impossible de lire l'intervalle pour [%s]"
+msgstr "Impossible d'écrire la couche raster lac <%s>!"
 #: ../raster/r.statistics2/main.c:249
 msgid "First pass"
@@ -19806,8 +19807,9 @@
 msgstr "Creer/Modifier la table de couleurs associée à une couche raster."
 #: ../raster/r.colors.out/main.c:73
+#, fuzzy
 msgid "Path to rules file (\"-\" to write rules to stdin)"
-msgstr ""
+msgstr "Fichier de coordonnées en entrée (ne pas lire à partir de stdin)"
 #: ../raster/r.colors.out/main.c:77
 #, fuzzy
@@ -27835,8 +27837,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "couche vecteur des points de départ"
 #: ../vector/v.net.steiner/main.c:447
 #, fuzzy
@@ -29011,8 +29014,9 @@
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
+#, fuzzy
 msgid "Position"
-msgstr ""
 #: ../visualization/nviz2/cmd/args.c:301
 #, fuzzy
@@ -29213,4613 +29217,4680 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Impossible de sélectionner des données dans la table attributaire"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condition optionnelle (sans le mot-clef WHERE), ex: \n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condition optionnelle (sans le mot-clef WHERE), ex: \n"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nom du fichier de sortie illégal"
+msgid "Illegal output file name"
+msgstr "Nom du fichier de sortie illégal"
 #, fuzzy
-#~ msgstr "Afficher les pages de manuel GRASS au format HTML"
 #, fuzzy
-#~ msgstr "Nom du fichier MAT-File(v4) à importer"
+msgstr "Nom du fichier MAT-File(v4) à importer"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Sélectionne/démarre le moniteut désigné à la taille spécifiée"
+msgid "Selects/starts specified monitor at specified size"
+msgstr "Sélectionne/démarre le moniteut désigné à la taille spécifiée"
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Largeur en pixels du nouveau moniteur d'affichage"
+msgid "Width in pixels of new display monitor"
+msgstr "Largeur en pixels du nouveau moniteur d'affichage"
-#~ msgid "Height in pixels of new display monitor"
-#~ msgstr "Hauteur en pixels du nouveau moniteur d'affichage"
+msgid "Height in pixels of new display monitor"
+msgstr "Hauteur en pixels du nouveau moniteur d'affichage"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Déplacer les couches affichée vers un autre moniteur"
+msgid "Moves displayed maps to another monitor"
+msgstr "Déplacer les couches affichée vers un autre moniteur"
-#~ msgid "clear target monitor before moving"
-#~ msgstr "Nettoyer le moniteur cible avant de déplacer les couches"
+msgid "clear target monitor before moving"
+msgstr "Nettoyer le moniteur cible avant de déplacer les couches"
-#~ msgid "stay with source monitor"
-#~ msgstr "Conserver le moniteur source"
+msgid "stay with source monitor"
+msgstr "Conserver le moniteur source"
-#~ msgid "kill source monitor after moving"
-#~ msgstr "tuer le moniteur source après le déplacement"
+msgid "kill source monitor after moving"
+msgstr "tuer le moniteur source après le déplacement"
-#~ msgid "Target monitor"
-#~ msgstr "Cibler un moniteur"
+msgid "Target monitor"
+msgstr "Cibler un moniteur"
-#~ msgid "Source monitor"
-#~ msgstr "Moniteur source"
+msgid "Source monitor"
+msgstr "Moniteur source"
-#~ msgid "Export display monitor to a GpsDrive compatible backdrop image"
-#~ msgstr ""
-#~ "Exporter le moniteur d'affichage vers une image compatible avec un "
-#~ "récepteur GPS"
+msgid "Export display monitor to a GpsDrive compatible backdrop image"
+msgstr ""
+"Exporter le moniteur d'affichage vers une image compatible avec un récepteur "
+"GPS"
 #, fuzzy
-#~ msgid "display, export, GPS"
-#~ msgstr "Afficher l'index"
+msgid "display, export, GPS"
+msgstr "Afficher l'index"
-#~ msgid "name for new map image (lives in ~/.gpsdrive)"
-#~ msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
+msgid "name for new map image (lives in ~/.gpsdrive)"
+msgstr "nom pour une nouvelle couche image (dans ~/.gpsdrive)"
-#~ msgid "Make JPEG instead of PNG image"
-#~ msgstr "Faire un JPEG à la place d'une image PNG"
+msgid "Make JPEG instead of PNG image"
+msgstr "Faire un JPEG à la place d'une image PNG"
-#~ msgstr ""
-#~ "Sauvegarder l'affichage du moniteur actif en fichier PNG dans le "
-#~ "répertoire home"
+msgstr ""
+"Sauvegarder l'affichage du moniteur actif en fichier PNG dans le répertoire "
+"home"
-#~ msgstr "Résolution du fichier en sortie (simple=1, double=2, quad=4)"
+msgstr "Résolution du fichier en sortie (simple=1, double=2, quad=4)"
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr ""
-#~ "Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr ""
+"Sauvegarder le moniteur actif en fichier graphique dans le répertoire home"
 #, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "Compression des fichiers PNG (0=aucun, 1=rapide, 9=maximale)"
+msgid "Compression for PNG files"
+msgstr "Compression des fichiers PNG (0=aucun, 1=rapide, 9=maximale)"
 #, fuzzy
-#~ msgid "(10=smallest/worst, 100=largest/best)"
-#~ msgstr ""
-#~ "Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, "
-#~ "100=plus grande/moins dégradée)"
+msgid "(10=smallest/worst, 100=largest/best)"
+msgstr ""
+"Taille/qualité pour les fichiers JPEG (10=plus petit/très dégradée, 100=plus "
+"grande/moins dégradée)"
 #, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "Produit un script shell en sortie"
+msgid "Paper size for PostScript output"
+msgstr "Produit un script shell en sortie"
 #, fuzzy
-#~ msgid "PostScript"
-#~ msgstr "couche PostScript en sortie"
+msgid "PostScript"
+msgstr "couche PostScript en sortie"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Ajuster la couleur de fond en noir (par défaut blanc)"
+msgid "Set background color to black (white default)"
+msgstr "Ajuster la couleur de fond en noir (par défaut blanc)"
 #, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "Fond transparent"
+msgid "Set transparent background"
+msgstr "Fond transparent"
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "Affiche la couche raster et sa légende sur le moniteur actif."
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "Affiche la couche raster et sa légende sur le moniteur actif."
-#~ msgid "omit entries with missing label"
-#~ msgstr "Sauter les entrées dont l'étiquette est manquante"
+msgid "omit entries with missing label"
+msgstr "Sauter les entrées dont l'étiquette est manquante"
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Nombre de lignes apparaissant dans la légende"
+msgid "Number of lines to appear in the legend"
+msgstr "Nombre de lignes apparaissant dans la légende"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Rafraîchir les couches affichées dans le moniteur GRASS"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Rafraîchir les couches affichées dans le moniteur GRASS"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "Sauvegarder tous les cadres graphiques"
+msgid "Redraw all frames"
+msgstr "Sauvegarder tous les cadres graphiques"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Redimensionner le moniteur actif"
+msgid "Resizes active display monitor"
+msgstr "Redimensionner le moniteur actif"
-#~ msgid "New width for window"
-#~ msgstr "Nouvelle largeur pour la fenêtre"
+msgid "New width for window"
+msgstr "Nouvelle largeur pour la fenêtre"
-#~ msgid "New height for window"
-#~ msgstr "Nouvelle hauteur pour la fenêtre"
+msgid "New height for window"
+msgstr "Nouvelle hauteur pour la fenêtre"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Diaporama de couches GRASS raster/vecteur"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Diaporama de couches GRASS raster/vecteur"
 #, fuzzy
-#~ msgid "display, slideshow"
+msgid "display, slideshow"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Convertit des couches rasters 3D en couches rasters 2D"
+msgid "Show vector maps rather than raster maps"
+msgstr "Convertit des couches rasters 3D en couches rasters 2D"
 #, fuzzy
-#~ msgid "Map prefix. Specify character(s) to view selected maps only"
-#~ msgstr ""
-#~ "préfixe de couche. Spécifier les caractère(s) pour voir les couches "
-#~ "sélectionnées seulement"
+msgid "Map prefix. Specify character(s) to view selected maps only"
+msgstr ""
+"préfixe de couche. Spécifier les caractère(s) pour voir les couches "
+"sélectionnées seulement"
 #, fuzzy
-#~ msgid "Map number show across the monitor"
-#~ msgstr "Nombre de couches affichées en travers du moniteur"
+msgid "Map number show across the monitor"
+msgstr "Nombre de couches affichées en travers du moniteur"
 #, fuzzy
-#~ msgid "Map number show down the monitor"
-#~ msgstr "Nombres de couches affichées en bas du moniteur"
+msgid "Map number show down the monitor"
+msgstr "Nombres de couches affichées en bas du moniteur"
 #, fuzzy
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr ""
-#~ "Jeux de données à utiliser. Spécifier de multiples jeux de données en les "
-#~ "séparant par des virgules"
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr ""
+"Jeux de données à utiliser. Spécifier de multiples jeux de données en les "
+"séparant par des virgules"
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "Nombre de cellules entre les courants"
+msgid "Number of seconds to pause between slides"
+msgstr "Nombre de cellules entre les courants"
-#~ msgid ""
-#~ msgstr ""
-#~ "Divise l'affichage actif en deux cadres & affiche des couches/exécute des "
-#~ "commandes dans chaque cadre."
+msgid ""
+"each frame."
+msgstr ""
+"Divise l'affichage actif en deux cadres & affiche des couches/exécute des "
+"commandes dans chaque cadre."
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Entrer la couche raster à afficher dans le 1er cadre"
+msgid "Enter raster map to display in 1st frame"
+msgstr "Entrer la couche raster à afficher dans le 1er cadre"
-#~ msgstr "Entrer la commande à exécuter dans le 1er cadre"
+msgstr "Entrer la commande à exécuter dans le 1er cadre"
-#~ msgstr "Entrer la couche raster à afficher dans le 2ème cadre"
+msgstr "Entrer la couche raster à afficher dans le 2ème cadre"
-#~ msgstr "Entrer la commande à exécuter dans le 2ème cadre"
+msgstr "Entrer la commande à exécuter dans le 2ème cadre"
-#~ msgstr "Comment partager l'affichage"
+msgstr "Comment partager l'affichage"
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Afficher une couche vectorielle thématique"
+msgid "Displays thematic vectormap"
+msgstr "Afficher une couche vectorielle thématique"
 #, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "Faire pivoter le cartouche de légende"
+msgid "display, legend"
+msgstr "Faire pivoter le cartouche de légende"
-#~ msgid "Vector map to display thematically"
-#~ msgstr "couche vecteur à afficher (thématique)"
+msgid "Vector map to display thematically"
+msgstr "couche vecteur à afficher (thématique)"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "Type de couche vecteur"
+msgid "Vector map type"
+msgstr "Type de couche vecteur"
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr ""
-#~ "Colonne attributaire à utiliser pour l'affichage thématique (doit être "
-#~ "numérique)"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr ""
+"Colonne attributaire à utiliser pour l'affichage thématique (doit être "
+"numérique)"
-#~ msgid "Type of thematic display"
-#~ msgstr "Type d'affichage thématique"
+msgid "Type of thematic display"
+msgstr "Type d'affichage thématique"
-#~ msgid "Thematic divisions of data for display"
-#~ msgstr "Divisions thématiques des données à afficher"
+msgid "Thematic divisions of data for display"
+msgstr "Divisions thématiques des données à afficher"
-#~ msgid ""
-#~ "Break points for custom breaks option. Separate values by spaces. (0 10 "
-#~ "20 30 ...)"
-#~ msgstr ""
-#~ "Points de rupture pour l'option de rupture personnalisée. Valeurs "
-#~ "séparées par des espaces (0 10 20 30 ...)"
+msgid ""
+"Break points for custom breaks option. Separate values by spaces. (0 10 20 "
+"30 ...)"
+msgstr ""
+"Points de rupture pour l'option de rupture personnalisée. Valeurs séparées "
+"par des espaces (0 10 20 30 ...)"
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "Couche à utiliser pour l'affichage thématique"
+msgid "Layer to use for thematic display"
+msgstr "Couche à utiliser pour l'affichage thématique"
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "Afficher"
+msgid "Points"
+msgstr "Afficher"
-#~ msgid "Vector point icon for point data"
-#~ msgstr "Icone vecteur point pour les données ponctuelles"
+msgid "Vector point icon for point data"
+msgstr "Icone vecteur point pour les données ponctuelles"
-#~ msgid ""
-#~ "Icon size for point data (minimum icon size/line width for graduated "
-#~ "points/lines)"
-#~ msgstr ""
-#~ "Taille de l'icone pour des données ponctuelles (taille minimale de "
-#~ "l'icone/largeur de ligne pour les points gradués/lignes)"
+msgid ""
+"Icon size for point data (minimum icon size/line width for graduated points/"
+"lines)"
+msgstr ""
+"Taille de l'icone pour des données ponctuelles (taille minimale de l'icone/"
+"largeur de ligne pour les points gradués/lignes)"
-#~ msgid "Maximum icon size/line width for graduated points and lines"
-#~ msgstr ""
-#~ "Taille maximale de l'icone/largeur de ligne pour les points gradués/"
-#~ "lignes)"
+msgid "Maximum icon size/line width for graduated points and lines"
+msgstr ""
+"Taille maximale de l'icone/largeur de ligne pour les points gradués/lignes)"
-#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Nombre de classes pour l'intervalle thématique (entier)"
+msgid "Number of classes for interval theme (integer)"
+msgstr "Nombre de classes pour l'intervalle thématique (entier)"
-#~ msgid ""
-#~ "Color scheme for graduated color mapping (select 'single_color' for "
-#~ "graduated point/line display)"
-#~ msgstr ""
-#~ "Schéma de couleur pour la cartographie en couleurs graduelles (choisissez "
-#~ "'couleur simple' pour l'affichage point gradué/ligne)"
+msgid ""
+"Color scheme for graduated color mapping (select 'single_color' for "
+"graduated point/line display)"
+msgstr ""
+"Schéma de couleur pour la cartographie en couleurs graduelles (choisissez "
+"'couleur simple' pour l'affichage point gradué/ligne)"
 #, fuzzy
-#~ msgid ""
-#~ "Color for graduated points map (grass named color or R:G:B triplet). Set "
-#~ "color scheme to single color."
-#~ msgstr ""
-#~ "Couleur pour les lignes graduées ou les contours de points/entités "
-#~ "surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
-#~ "couleur pour couleur simple."
+msgid ""
+"Color for graduated points map (grass named color or R:G:B triplet). Set "
+"color scheme to single color."
+msgstr ""
+"Couleur pour les lignes graduées ou les contours de points/entités "
+"surfaciques (nom de couleur GRASS ou triplet R:G:B). Fixer le schéma de "
+"couleur pour couleur simple."
-#~ msgid ""
-#~ "Color for graduated lines or point/area outlines (grass named color or R:"
-#~ "G:B triplet). Set color scheme to single color."
-#~ msgstr ""
+msgid ""
+"Color for graduated lines or point/area outlines (grass named color or R:G:B "
+"triplet). Set color scheme to single color."
+msgstr ""
-#~ msgid ""
-#~ "Beginning color for custom color gradient. Must be expressed as R:G:B "
-#~ "triplet."
-#~ msgstr ""
-#~ "Couleur de départ pour le gardient de couleur personnalisé. Doit être "
-#~ "exprimé sous forme de triplet R:G:B."
+msgid ""
+"Beginning color for custom color gradient. Must be expressed as R:G:B "
+"triplet."
+msgstr ""
+"Couleur de départ pour le gardient de couleur personnalisé. Doit être "
+"exprimé sous forme de triplet R:G:B."
-#~ msgid ""
-#~ "Ending color for custom color gradient. Must be expressed as R:G:B triplet"
-#~ msgstr ""
-#~ "Couleur de fin pour le gradient de couleur personnalisé. Doit être "
+msgid ""
+"Ending color for custom color gradient. Must be expressed as R:G:B triplet"
+msgstr ""
+"Couleur de fin pour le gradient de couleur personnalisé. Doit être exprimé "
+"sous forme de triplet R:G:B."
 #, fuzzy
-#~ msgid "Misc"
-#~ msgstr "Métrique"
+msgid "Misc"
+msgstr "Métrique"
 #, fuzzy
-#~ msgid "Select x11 display monitor for legend"
-#~ msgstr "Sélectionner le moniteur d'affichage de la légende"
+msgid "Select x11 display monitor for legend"
+msgstr "Sélectionner le moniteur d'affichage de la légende"
-#~ msgid "Save thematic map commands to group file for GIS Manager"
-#~ msgstr ""
-#~ "Sauvegarder les commandes de cartographie thématique dans le fichier de "
-#~ "groupe dans le Gestionnaire SIG"
+msgid "Save thematic map commands to group file for GIS Manager"
+msgstr ""
+"Sauvegarder les commandes de cartographie thématique dans le fichier de "
+"groupe dans le Gestionnaire SIG"
-#~ msgid ""
-#~ "Root for the name of psmap instruction files to be in current directory "
-#~ "(if not set, no psmap instruction files will be created)"
-#~ msgstr ""
-#~ "Racine du nom du fichier d'instruction psmat dans le répertoire courant "
-#~ "(si non indiqué, aucun fichier d'instruction psmap ne sera créé)"
+msgid ""
+"Root for the name of psmap instruction files to be in current directory (if "
+"not set, no psmap instruction files will be created)"
+msgstr ""
+"Racine du nom du fichier d'instruction psmat dans le répertoire courant (si "
+"non indiqué, aucun fichier d'instruction psmap ne sera créé)"
-#~ msgid "Name of group file where thematic map commands will be saved"
-#~ msgstr ""
-#~ "Nom du fichier de groupe où les commandes de cartographie thématique "
-#~ "seront sauvegardées"
+msgid "Name of group file where thematic map commands will be saved"
+msgstr ""
+"Nom du fichier de groupe où les commandes de cartographie thématique seront "
+"sauvegardées"
 #, fuzzy
-#~ msgid "Create graphic legend in x11 display monitor"
-#~ msgstr "Créer une légende graphique dans le moniteur d'affichage"
+msgid "Create graphic legend in x11 display monitor"
+msgstr "Créer une légende graphique dans le moniteur d'affichage"
-#~ msgid "Only draw fills (no outlines) for areas and points"
-#~ msgstr ""
-#~ "Ne dessiner que le remplissage (sans contours) pour les entités "
-#~ "surfaciques et les points"
+msgid "Only draw fills (no outlines) for areas and points"
+msgstr ""
+"Ne dessiner que le remplissage (sans contours) pour les entités surfaciques "
+"et les points"
-#~ msgid "Update color values to GRASSRGB column in attribute table"
-#~ msgstr ""
-#~ "Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la "
-#~ "table attributaire"
+msgid "Update color values to GRASSRGB column in attribute table"
+msgstr ""
+"Mettre à jour les valeurs de couleurs de la colonne GRASSRGB dans la table "
+"attributaire"
-#~ msgid "Use math notation brackets in legend"
-#~ msgstr "Utilisez des crochets (type notation mathématique) dans la légende"
+msgid "Use math notation brackets in legend"
+msgstr "Utilisez des crochets (type notation mathématique) dans la légende"
-#~ msgid "Apply regular expressions and wildcards to g.list"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.list"
+msgid "Apply regular expressions and wildcards to g.list"
+msgstr "Appliquer des expressions régulières et des wildcards à g.list"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "jeu de données à lister (par défaut : chemin de recherche courant)"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : nouvelle ligne)"
+msgid "Output separator (default: newline)"
+msgstr "Caractère de séparation en sortie (par défaut : nouvelle ligne)"
-#~ msgstr "Appliquer des expressions régulières et des wildcards à g.remove"
+msgstr "Appliquer des expressions régulières et des wildcards à g.remove"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Couche raster 3D à supprimer"
+msgid "Raster to remove"
+msgstr "Couche raster 3D à supprimer"
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "Icone à supprimer"
+msgid "Vector to remove"
 #, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "Région à supprimer"
+msgid "Region to remove"
+msgstr "Région à supprimer"
 #, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "Etiquette à supprimer"
+msgid "Label to remove"
+msgstr "Etiquette à supprimer"
-#~ msgid "3dview to remove"
-#~ msgstr "3dview à supprimer"
+msgid "3dview to remove"
+msgstr "3dview à supprimer"
 #, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "groupe à supprimer"
+msgid "Group to remove"
+msgstr "groupe à supprimer"
-#~ msgid ""
-#~ "displays spectral response at user specified locations in group or images"
-#~ msgstr ""
-#~ "afficher la réponse spectrale à des emplacements précisés par "
-#~ "l'utilisateur dans un groupe ou dans des images"
+msgid ""
+"displays spectral response at user specified locations in group or images"
+msgstr ""
+"afficher la réponse spectrale à des emplacements précisés par l'utilisateur "
+"dans un groupe ou dans des images"
-#~ msgid "group input"
-#~ msgstr "Groupe en entrée"
+msgid "group input"
+msgstr "Groupe en entrée"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "couche raster en entrée"
+msgid "raster input maps"
+msgstr "couche raster en entrée"
 #, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "Écraser et réécrire le fichier de sortie"
+msgid "write output to PNG image"
+msgstr "Écraser et réécrire le fichier de sortie"
-#~ msgid "Use image list and not group"
-#~ msgstr "Utilisez une liste d'image et pas un groupe"
+msgid "Use image list and not group"
+msgstr "Utilisez une liste d'image et pas un groupe"
-#~ msgid "Select multiple points"
-#~ msgstr "Sélectionner des points multiples"
+msgid "Select multiple points"
+msgstr "Sélectionner des points multiples"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Etiquette avec coordonnées à la place d'un nombre"
+msgid "label with coordinates instead of numbering"
+msgstr "Etiquette avec coordonnées à la place d'un nombre"
-#~ msgstr ""
-#~ "Conserver les numéros de bande plutôt que d'utiliser les noms de couleur "
-#~ "des bandes"
+msgstr ""
+"Conserver les numéros de bande plutôt que d'utiliser les noms de couleur des "
+"bandes"
 #, fuzzy
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr ""
-#~ "r.mapcalculator - calcule une nouvelle couche raster à partir d'une "
-#~ "expression r.mapcalc"
+msgid "Calculate new raster map from a r.mapcalc expression."
+msgstr ""
+"r.mapcalculator - calcule une nouvelle couche raster à partir d'une "
+"expression r.mapcalc"
 #, fuzzy
-#~ msgid "A"
-#~ msgstr "A :"
+msgid "A"
+msgstr "A :"
 #, fuzzy
-#~ msgid "B"
-#~ msgstr "B :"
+msgid "B"
+msgstr "B :"
 #, fuzzy
-#~ msgid "C"
-#~ msgstr "C :"
+msgid "C"
+msgstr "C :"
 #, fuzzy
-#~ msgid "D"
-#~ msgstr "D :"
+msgid "D"
+msgstr "D :"
 #, fuzzy
-#~ msgid "E"
-#~ msgstr "E :"
+msgid "E"
+msgstr "E :"
 #, fuzzy
-#~ msgid "F"
-#~ msgstr "F :"
+msgid "F"
+msgstr "F :"
 #, fuzzy
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formule (par exemple A-B ou A*C+B"
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Formule (par exemple A-B ou A*C+B"
-#~ msgid "Show help"
-#~ msgstr "Montrer l'aide"
+msgid "Show help"
+msgstr "Montrer l'aide"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Mode expert (entrer un ensemble d'expressions r.mapcalc)"
+msgid "Expert mode (enter a set of r.mapcalc expressions)"
+msgstr "Mode expert (entrer un ensemble d'expressions r.mapcalc)"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Ne pas écraser la couche existante"
+msgid "Do not overwrite existing map"
+msgstr "Ne pas écraser la couche existante"
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Exporte un raster GRASS vers un tableau binaire."
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "Exporte un raster GRASS vers un tableau binaire."
 #, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Problème de lecture de r.stats en sortie"
+msgid "Region sensitive output"
+msgstr "Problème de lecture de r.stats en sortie"
 #, fuzzy
-#~ msgid ""
-#~ "Creation option to the output format driver. Multiple options may be "
-#~ "listed"
-#~ msgstr ""
-#~ "option de création du pilote de format de sortie. De multiples options "
-#~ "peuvent être disponibles"
+msgid ""
+"Creation option to the output format driver. Multiple options may be listed"
+msgstr ""
+"option de création du pilote de format de sortie. De multiples options "
+"peuvent être disponibles"
-#~ msgid "Output field seperator"
-#~ msgstr "Séparateur de champ en sortie"
+msgid "Output field seperator"
+msgstr "Séparateur de champ en sortie"
 #, fuzzy
-#~ msgstr ""
-#~ "Calcule des statistiques univariées à partir d'une couche raster GRASS "
-#~ "basée sur des objets vecteurs"
+msgstr ""
+"Calcule des statistiques univariées à partir d'une couche raster GRASS basée "
+"sur des objets vecteurs"
-#~ msgstr "Statistiques étendues (quartiles et centile)"
+msgstr "Statistiques étendues (quartiles et centile)"
 #, fuzzy
-#~ msgstr "Centile à calculer (requiert le drapeau -e)"
+msgstr "Centile à calculer (requiert le drapeau -e)"
 #, fuzzy
-#~ msgid "Calculates new grid3D volume from r3.mapcalc expression."
-#~ msgstr ""
+msgid "Calculates new grid3D volume from r3.mapcalc expression."
+msgstr ""
 #, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "Nom du fichier 3D de sortie"
+msgid "A (grid3D file)"
+msgstr "Nom du fichier 3D de sortie"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Nom du fichier de sortie"
+msgid "Name for output grid3D volume"
+msgstr "Nom du fichier de sortie"
 #, fuzzy
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgid ""
-#~ "Name and type of the new column(s) (types depend on database backend, but "
-#~ "all support VARCHAR(), INT, DOUBLE and DATE)"
-#~ msgstr ""
-#~ "Nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base "
-#~ "de données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE et DATE)"
+msgid ""
+"Name and type of the new column(s) (types depend on database backend, but "
+"all support VARCHAR(), INT, DOUBLE and DATE)"
+msgstr ""
+"Nom et type de(s) nouvelle(s) colonne(s) (les types dépendent de la base de "
+"données utilisée, mais toutes gèrent VARCHAR(), INT, DOUBLE et DATE)"
 # c-format
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] non trouvé"
+msgid "%s: [%s] not found"
+msgstr "%s: [%s] non trouvé"
 #, fuzzy
-#~ msgid "Please choose a unit by entering one of the following letter codes:"
-#~ msgstr "Veuillez choisir l'une des options suivantes\n"
+msgid "Please choose a unit by entering one of the following letter codes:"
+msgstr "Veuillez choisir l'une des options suivantes\n"
 # c-format
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "Le nom du fichier raster existe déjà"
+msgid ""
+"Enter the file name or path\n"
+msgstr "Le nom du fichier raster existe déjà"
-#~ msgid "Interactively select End-Points"
-#~ msgstr ""
-#~ "Sélectionner de façon interactive les points de début et de fin du profil"
+msgid "Interactively select End-Points"
+msgstr ""
+"Sélectionner de façon interactive les points de début et de fin du profil"
 #, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr ""
-#~ "Utiliser la souris pour dimensionner et positionner le cartouche de "
-#~ "légende"
+msgid "Use mouse to select Start Point\n"
+msgstr ""
+"Utiliser la souris pour dimensionner et positionner le cartouche de légende"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "légende"
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr ""
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"Boutons:\n"
 #, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "Gauche: "
+msgid "Left:   Mark next point\n"
+msgstr "Gauche: "
 #, fuzzy
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Milieu:"
+msgid "Middle: Mark next point\n"
+msgstr "Milieu:"
 # c-format
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "fichier de cellules elevin <%s> non trouvé"
+msgid "elevin raster map <%s> not found"
+msgstr "fichier de cellules elevin <%s> non trouvé"
 # c-format
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "fichier de cellules aspin <%s> non trouvé"
+msgid "aspin raster map <%s> not found"
+msgstr "fichier de cellules aspin <%s> non trouvé"
 # c-format
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "fichier de cellules linkein <%s> non trouvé"
+msgid "linkein raster map <%s> not found"
+msgstr "fichier de cellules linkein <%s> non trouvé"
 # c-format
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "fichier de cellules albedo <%s> non trouvé"
+msgid "albedo raster map <%s> not found"
+msgstr "fichier de cellules albedo <%s> non trouvé"
 # c-format
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "fichier de cellules latin <%s> non trouvé"
+msgid "latin raster map <%s> not found"
+msgstr "fichier de cellules latin <%s> non trouvé"
 # c-format
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "fichier de cellules coefbh <%s> non trouvé"
+msgid "coefbh raster map <%s> not found"
+msgstr "fichier de cellules coefbh <%s> non trouvé"
 # c-format
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "fichier de cellules coefdh <%s> non trouvé"
+msgid "coefdh raster map <%s> not found"
+msgstr "fichier de cellules coefdh <%s> non trouvé"
-#~ msgid "No clump map specified and MASK not set."
-#~ msgstr "Pas de couche de 'flaques' spécifiée et MASK n'est pas activé"
+msgid "No clump map specified and MASK not set."
+msgstr "Pas de couche de 'flaques' spécifiée et MASK n'est pas activé"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "Fichier raster introuvable : %s"
+msgid "Unable to find data map"
+msgstr "Fichier raster introuvable : %s"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find clump map"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
+msgid "Unable to find clump map"
+msgstr "Impossible d'ouvrir la couche raster <%s>"
-#~ msgid "Memory allocation error"
-#~ msgstr "Erreur d'allocation mémoire"
+msgid "Memory allocation error"
+msgstr "Erreur d'allocation mémoire"
-#~ msgid "Saving new map"
-#~ msgstr "Sauvegarde de la nouvelle couche"
+msgid "Saving new map"
+msgstr "Sauvegarde de la nouvelle couche"
 # c-format
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Couche raster de terrain (MNT)"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Couche raster de terrain (MNT)"
-#~ msgid "Output raster map with lake"
-#~ msgstr "couche raster en sortie contenant le lac"
+msgid "Output raster map with lake"
+msgstr "couche raster en sortie contenant le lac"
 # c-format
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
+msgid "Cannot write lake raster map <%s>!"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "couche raster terrain <%s> non trouvée!"
+msgid "Terrain raster map <%s> not found!"
+msgstr "couche raster terrain <%s> non trouvée!"
 # c-format
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche raster terrain <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "Impossible d'ouvrir la couche raster terrain <%s@%s>!"
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "couche de germes <%s> non trouvée!"
+msgid "Seed map <%s> not found!"
+msgstr "couche de germes <%s> non trouvée!"
 # c-format
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Impossible d'ouvrir la couche de germes <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "Impossible d'ouvrir la couche de germes <%s@%s>!"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
+msgid "Failure to allocate memory for row pointers"
+msgstr "Impossible d'allouer de la mémoire pour les pointeurs de ligne"
-#~ msgid "Loading maps: "
-#~ msgstr "Chargement des couches"
+msgid "Loading maps: "
+msgstr "Chargement des couches"
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "Erreur de lecture de la couche raster en entrée"
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "Erreur de lecture de la couche raster en entrée"
 # c-format
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr "Erreur de lecture du fichier raster [%s]"
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "Erreur de lecture du fichier raster [%s]"
 # c-format
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "Impossible d'écrire la couche raster lac <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "Impossible d'écrire la couche raster lac <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Commence le remplissage du lac au niveau de %8.4f en %d passages. \n"
-#~ "pourcentage achevé:"
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr ""
+"Commence le remplissage du lac au niveau de %8.4f en %d passages. \n"
+"pourcentage achevé:"
 #, fuzzy
-#~ msgid "Pass: %d\n"
-#~ msgstr "Masque: %s\n"
+msgid "Pass: %d\n"
+msgstr "Masque: %s\n"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Erreur d'écriture du fichier couleur pour <%s@%s>!"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Erreur d'écriture du fichier couleur pour <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Complètement terminé."
+msgid "All done."
+msgstr "Complètement terminé."
 # c-format
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr "%s : fichier de cellules <%s> non trouvé"
+msgid "%s: base raster map not found"
+msgstr "%s : fichier de cellules <%s> non trouvé"
 # c-format
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "%s - couche raster non trouvée"
+msgid "%s: cover raster map not found"
+msgstr "%s - couche raster non trouvée"
 #, fuzzy
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr ""
-#~ "Les coordonnées des germes et la couche de sortie= doivent être fixées!"
+msgid "%s: base map and output map must be different"
+msgstr ""
+"Les coordonnées des germes et la couche de sortie= doivent être fixées!"
 #, fuzzy
-#~ msgstr "Nom du fichier vecteur contenant les données en entrée"
+msgstr "Nom du fichier vecteur contenant les données en entrée"
 #, fuzzy
-#~ msgstr "Nombre de points d'interpolation"
+msgstr "Nombre de points d'interpolation"
 #, fuzzy
-#~ msgstr "Allocation métrique"
+msgstr "Allocation métrique"
 #, fuzzy
-#~ msgstr "Nom de la couche raster d'altitude (mètres)"
+msgstr "Nom de la couche raster d'altitude (mètres)"
 #, fuzzy
-#~ msgstr "Nom du fichier raster source"
 #, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "Calcule un <simple> index sur un fichier raster"
+msgid "Calculates <simple> index on a raster map"
+msgstr "Calcule un <simple> index sur un fichier raster"
-#~ msgid "Quietly"
-#~ msgstr "Silencieux"
+msgid "Quietly"
+msgstr "Silencieux"
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "Outil d'interpolation bilinéaire pour couches raster."
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "Outil d'interpolation bilinéaire pour couches raster."
 #, fuzzy
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour "
-#~ "des grilles données en latitude-longitude"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr ""
+"valeurs spécifiques qui seront assignées aux pôles nord et/ou sud pour des "
+"grilles données en latitude-longitude"
 #, fuzzy
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr ""
-#~ "Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez "
-#~ "l'instruction de mise en page cartographique \"scale\" à la place."
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr ""
+"Utiliser \"scale\" à partir de la console est obsolète. Veuillez utilisez "
+"l'instruction de mise en page cartographique \"scale\" à la place."
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
+msgid "Illegal output file name <%s>"
 #, fuzzy
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr ""
+msgid "Base map and output map <%s> must be different"
+msgstr ""
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "Mémoire insuffisante pour zero_array_cell"
+msgid "Not enough memory for zero_array_cell"
+msgstr "Mémoire insuffisante pour zero_array_cell"
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Espace disque insuffisant -- impossible d'écrire les fichiers"
+msgid "Not enough disk space -- cannot write files"
+msgstr "Espace disque insuffisant -- impossible d'écrire les fichiers"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Couche raster en entrée"
+msgid "Raster input maps(s)"
+msgstr "Couche raster en entrée"
-#~ msgid "Output file name"
+msgid "Output file name"
 # c-format
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr ""
-#~ "%s: impossible de lire l'intervalle en nombre à virgule flottante pour [%"
-#~ "s]"
+msgid "%s: can't read fp range for [%s]"
+msgstr ""
+"%s: impossible de lire l'intervalle en nombre à virgule flottante pour [%s]"
 # c-format
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "La couche raster [%s] existe dans le groupe."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "La couche raster [%s] existe dans le groupe."
 #, fuzzy
-#~ msgid "Path to rules file"
-#~ msgstr "Chemin du fichier VTK en sortie"
+msgid "Path to rules file"
+msgstr "Chemin du fichier VTK en sortie"
 #, fuzzy
-#~ msgid "Enter rules interactively"
-#~ msgstr "Exécuter de façon non-interactive"
+msgid "Enter rules interactively"
+msgstr "Exécuter de façon non-interactive"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "couche raster <%s> non trouvée"
+msgid "RGB raster map <%s> not found"
+msgstr "couche raster <%s> non trouvée"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "couche vecteur <%s> introuvable"
+msgid "Vector cell map <%s> not found"
+msgstr "couche vecteur <%s> introuvable"
 #, fuzzy
-#~ msgid "Cannot create vector data, please provide three maps [x,y,z]"
-#~ msgstr "Veuillez indiquer trois couches vecteurs g3d [x,y,z]"
+msgid "Cannot create vector data, please provide three maps [x,y,z]"
+msgstr "Veuillez indiquer trois couches vecteurs g3d [x,y,z]"
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "Quel fichier raster a besoin d'une table de couleurs?"
+msgid "Which raster map needs a color table"
+msgstr "Quel fichier raster a besoin d'une table de couleurs?"
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "Editer l'en-tête pour [%s]\n"
+msgid "Edit header for [%s]\n"
+msgstr "Editer l'en-tête pour [%s]\n"
-#~ msgid "[%s] cannot be found!"
-#~ msgstr "Impossible de trouver [%s]!"
+msgid "[%s] cannot be found!"
+msgstr "Impossible de trouver [%s]!"
-#~ msgid "For what layer shall the header file be edited? "
-#~ msgstr "Quelle est la couche dont l'en-tête de fichier doit être édité?"
+msgid "For what layer shall the header file be edited? "
+msgstr "Quelle est la couche dont l'en-tête de fichier doit être édité?"
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr ""
-#~ "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! "
-#~ "Exécutez r.support sur [%s]."
+msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgstr ""
+"[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête! "
+"Exécutez r.support sur [%s]."
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr ""
-#~ "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête!"
+msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
+msgstr "[%s] est une reclassification de [%s] - impossible d'éditer l'en-tête!"
 # c-format
-#~ msgid "Cannot open raster map [%s]!"
-#~ msgstr "Impossible d'ouvrir le fichier raster [%s]!"
+msgid "Cannot open raster map [%s]!"
+msgstr "Impossible d'ouvrir le fichier raster [%s]!"
 # c-format
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Le fichier raster [%s] est vide"
+msgid "Raster file [%s] is empty."
+msgstr "Le fichier raster [%s] est vide"
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "Compression cellhd : %d\n"
+msgid "cellhd compression: %d\n"
+msgstr "Compression cellhd : %d\n"
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "Compression 3.0 %s indiquée \n"
+msgid "3.0 compression %sindicated\n"
+msgstr "Compression 3.0 %s indiquée \n"
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "Pré-compression 3.0 %s indiquée \n"
+msgid "Pre 3.0 compression %sindicated\n"
+msgstr "Pré-compression 3.0 %s indiquée \n"
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "[%s] semble compressé. Est-ce le cas?"
+msgid "[%s] appears to be compressed. Is it? "
+msgstr "[%s] semble compressé. Est-ce le cas?"
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "Veuillez indiquer le type de compression:\n"
+msgid "Please indicate the type of compression:\n"
+msgstr "Veuillez indiquer le type de compression:\n"
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr " 1. Pré compression 3.0\n"
+msgid "  1. Pre 3.0 compression\n"
+msgstr " 1. Pré compression 3.0\n"
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr " 2. 3.0 compression\n"
+msgid "  2. 3.0 compression\n"
+msgstr " 2. 3.0 compression\n"
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "L'en-tête de [%s] indique que le fichier n'est pas compressé."
+msgid "The header for [%s] says the file is not compressed. "
+msgstr "L'en-tête de [%s] indique que le fichier n'est pas compressé."
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "Le fichier semble compressé.\n"
+msgid "The file appears to be compressed.\n"
+msgstr "Le fichier semble compressé.\n"
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr ""
-#~ "Il est probable que l'en-tête soit faux, mais vous devez confirmer.\n"
+msgid "Most likely the header is wrong, but I want you to decide.\n"
+msgstr "Il est probable que l'en-tête soit faux, mais vous devez confirmer.\n"
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "L'en-tête de [%s] indique que le fichier est compressé."
+msgid "The header for [%s] says the file is compressed. "
+msgstr "L'en-tête de [%s] indique que le fichier est compressé."
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "Le fichier ne semble PAS compressé.\n"
+msgid "The file does NOT appear to be compressed.\n"
+msgstr "Le fichier ne semble PAS compressé.\n"
-#~ msgid ""
-#~ "Header indicates %d row%s in the raster map, but the actual file format "
-#~ "indicates %d row%s"
-#~ msgstr ""
-#~ "L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format "
-#~ "de fichier actuel indique %d ligne%s"
+msgid ""
+"Header indicates %d row%s in the raster map, but the actual file format "
+"indicates %d row%s"
+msgstr ""
+"L'en-tête indique %d ligne%s dans le fichier de cellule, mais le format de "
+"fichier actuel indique %d ligne%s"
 # c-format
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Impossible d'écrire l'en-tête de [%s]"
+msgid "Unable to write header for [%s]."
+msgstr "Impossible d'écrire l'en-tête de [%s]"
-#~ msgid "Header for raster map [%s] updated."
-#~ msgstr "En-tête du fichier raster [%s] mis à jour"
+msgid "Header for raster map [%s] updated."
+msgstr "En-tête du fichier raster [%s] mis à jour"
-#~ msgid ""
-#~ "\n"
-#~ "hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Tapez ENTREE pour poursuivre -->"
+msgid ""
+"\n"
+"hit RETURN to continue -->"
+msgstr ""
+"\n"
+"Tapez ENTREE pour poursuivre -->"
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "Veuillez entrer l'information suivante pour [%s]:"
+msgid "Please enter the following information for [%s]:"
+msgstr "Veuillez entrer l'information suivante pour [%s]:"
-#~ msgid "        Number of rows"
-#~ msgstr "\t\tNombre de lignes"
+msgid "        Number of rows"
+msgstr "\t\tNombre de lignes"
-#~ msgid "        Number of cols"
-#~ msgstr "\t\tNombre de colonnes"
+msgid "        Number of cols"
+msgstr "\t\tNombre de colonnes"
-#~ msgid "        Floating point map"
-#~ msgstr "\t\tCouche de valeurs en virgule flottante"
+msgid "        Floating point map"
+msgstr "\t\tCouche de valeurs en virgule flottante"
 #, fuzzy
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr ""
-#~ "Lignes * colonnes * bits par cellule doivent être identique à la taille "
-#~ "de fichier (%ld)"
+msgid "rows * cols * bytes per cell must be same as file size (%lu)"
+msgstr ""
+"Lignes * colonnes * bits par cellule doivent être identique à la taille de "
+"fichier (%ld)"
-#~ msgid "If you need help figuring them out, just hit ESC"
-#~ msgstr "Si vous avez besoin de les connaître, tapez simplement ECHAP"
+msgid "If you need help figuring them out, just hit ESC"
+msgstr "Si vous avez besoin de les connaître, tapez simplement ECHAP"
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "** Les valeurs négatives ne sont pas autorisées!"
+msgid "** Negative values not allowed!"
+msgstr "** Les valeurs négatives ne sont pas autorisées!"
-#~ msgid "** Positive values only please!"
-#~ msgstr "** Veuillez vous servir uniquement de valeurs positives!"
+msgid "** Positive values only please!"
+msgstr "** Veuillez vous servir uniquement de valeurs positives!"
-#~ msgid "Which raster map needs an updated history? "
-#~ msgstr "Quel fichier raster a besoin d'une mise à jour de l'historique?"
+msgid "Which raster map needs an updated history? "
+msgstr "Quel fichier raster a besoin d'une mise à jour de l'historique?"
 # c-format
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "Fichier raster [%s] non trouvé. Sortie."
+msgid "Raster file [%s] not found. Exiting."
+msgstr "Fichier raster [%s] non trouvé. Sortie."
 # c-format
-#~ msgid "History file for [%s] updated."
-#~ msgstr "Fichier d'historique pour [%s] mis à jour"
+msgid "History file for [%s] updated."
+msgstr "Fichier d'historique pour [%s] mis à jour"
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "Fichier d'historique pour [%s] non mis à jour"
+msgid "History file for [%s] not updated."
+msgstr "Fichier d'historique pour [%s] non mis à jour"
-#~ msgid ""
-#~ "\n"
-#~ "Hit RETURN to continue -->"
-#~ msgstr ""
-#~ "\n"
-#~ "Taper ENTREE pour poursuivre -->"
+msgid ""
+"\n"
+"Hit RETURN to continue -->"
+msgstr ""
+"\n"
+"Taper ENTREE pour poursuivre -->"
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "Editer l'en-tête de [%s]?"
+msgid "Edit header for [%s]? "
+msgstr "Editer l'en-tête de [%s]?"
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr ""
-#~ "\n"
-#~ "NOTE: [%s] est une reclassification de [%s dans %s]"
+msgid ""
+"\n"
+"NOTE: [%s] is a reclass of [%s in %s]"
+msgstr ""
+"\n"
+"NOTE: [%s] est une reclassification de [%s dans %s]"
-#~ msgid "Canceling from edit header."
-#~ msgstr "Annulation de l'édition de l'en-tête"
+msgid "Canceling from edit header."
+msgstr "Annulation de l'édition de l'en-tête"
-#~ msgid "Edit the category file for [%s]? "
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
+msgid "Edit the category file for [%s]? "
+msgstr "Editer le fichier de catégorie de [%s]?"
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "Créer/mettre à jour la table de couleurs de [%s]?"
+msgid "Create/Update the color table for [%s]? "
+msgstr "Créer/mettre à jour la table de couleurs de [%s]?"
 # c-format
-#~ msgid "Edit the history file for [%s]? "
-#~ msgstr "Editer l'historique de fichier de [%s]"
+msgid "Edit the history file for [%s]? "
+msgstr "Editer l'historique de fichier de [%s]"
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "\n"
-#~ "le fichier null de [%s] semble indiquer que certaines cellules ne "
-#~ "contiennent\n"
-#~ " pas de données. Si le fichier null de [%s] n'existe pas, les cellules de "
-#~ "valeur zéro\n"
-#~ " sont traitées par les programmes GRASS comme sans données."
+msgid ""
+"\n"
+"The null file for [%s] may indicate that some cells contain\n"
+" no data. If the null file for [%s] doesn't exist, zero cells in\n"
+" it are treated by GRASS application programs as no data."
+msgstr ""
+"\n"
+"le fichier null de [%s] semble indiquer que certaines cellules ne "
+"contiennent\n"
+" pas de données. Si le fichier null de [%s] n'existe pas, les cellules de "
+"valeur zéro\n"
+" sont traitées par les programmes GRASS comme sans données."
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
-#~ msgstr ""
-#~ "\n"
-#~ "Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les "
-#~ "cellules de valeur null soient considérées comme des données valides? "
+msgid ""
+"\n"
+"Do you want to create/reset the null file for [%s] so that null cell values "
+"are considered valid data? "
+msgstr ""
+"\n"
+"Voulez-vous créer/réinitialiser le fichir null de [%s] pour que les cellules "
+"de valeur null soient considérées comme des données valides? "
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr ""
-#~ "\n"
-#~ "Voulez-vous effacer les fichiers null pour [%s]\n"
-#~ "(toutes les cellules null seront alors considérées comme sans données)? "
+msgid ""
+"\n"
+"Do you want to delete the null file for [%s]\n"
+"(all zero cells will then be considered no data)? "
+msgstr ""
+"\n"
+"Voulez-vous effacer les fichiers null pour [%s]\n"
+"(toutes les cellules null seront alors considérées comme sans données)? "
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "Quel fichier vectoriel a besoin d'une mise à jour des catégories?"
+msgid "Which vector map needs updated categories?"
+msgstr "Quel fichier vectoriel a besoin d'une mise à jour des catégories?"
-#~ msgid "Which raster map needs updated categories?"
-#~ msgstr "Quel fichier raster a besoin d'une mise à jour des catégories?"
+msgid "Which raster map needs updated categories?"
+msgstr "Quel fichier raster a besoin d'une mise à jour des catégories?"
 # c-format
 #, fuzzy
-#~ msgid "%s map <%s> not found"
-#~ msgstr "%s: <%s> non trouvé"
+msgid "%s map <%s> not found"
+msgstr "%s: <%s> non trouvé"
 # c-format
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "Fichier de catégorie pour [%s] non mis à jour"
+msgid "Category file for <%s> not updated"
+msgstr "Fichier de catégorie pour [%s] non mis à jour"
 # c-format
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
-#~ msgstr "Fichier de catégorie pour [%s] mis à jour"
+msgid "Category file for <%s> updated"
+msgstr "Fichier de catégorie pour [%s] mis à jour"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titre, entre guillemets"
+msgid "Title, in quotes"
+msgstr "Titre, entre guillemets"
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silencieux - ne pas montrer la progression"
+msgid "Quiet - Do not show progress"
+msgstr "Silencieux - ne pas montrer la progression"
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "Supprimer les messages d'erreur de croisement simple"
+msgid "Suppress single crossing error messages"
+msgstr "Supprimer les messages d'erreur de croisement simple"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "Vecteur de départ introuvable %s"
+msgid "Unable to find starting vector <%s> "
+msgstr "Vecteur de départ introuvable %s"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "Vecteur d'arrivée introuvable %s"
+msgid "Unable to find stop vector <%s>"
+msgstr "Vecteur d'arrivée introuvable %s"
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr ""
-#~ "Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr ""
+"Couche raster en sortie %s - introuvable (aucun point de départ spécifié)"
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr ""
-#~ "Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr ""
+"Erreur d'allocation mémoire à la lecture des points de la couche raster %s"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Appliquer le filtre uniquement aux valeurs de données zéro"
+msgid "Apply filter only to zero data values"
+msgstr "Appliquer le filtre uniquement aux valeurs de données zéro"
-#~ msgid "Error reading '%s' map"
-#~ msgstr "Erreur de lecture de la couche '%s'"
+msgid "Error reading '%s' map"
+msgstr "Erreur de lecture de la couche '%s'"
-#~ msgid "G_put_raster_row failed (file system full?)"
-#~ msgstr "Echec de G_put_raster_row (système de fichier surchargé?)"
+msgid "G_put_raster_row failed (file system full?)"
+msgstr "Echec de G_put_raster_row (système de fichier surchargé?)"
-#~ msgid "Run verbosly"
-#~ msgstr "Détails de l'exécution"
+msgid "Run verbosly"
+msgstr "Détails de l'exécution"
-#~ msgid "Run VERBOSELY"
+msgid "Run VERBOSELY"
 #, fuzzy
-#~ msgid "Cell file not found"
-#~ msgstr "fichier de cellules non trouvé\n"
+msgid "Cell file not found"
+msgstr "fichier de cellules non trouvé\n"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
+msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unités de distance"
+msgid "Threshold distance"
+msgstr "Unités de distance"
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Impossible d'exécuter: %s"
+msgid "Cannot execute: %s"
+msgstr "Impossible d'exécuter: %s"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Impossible d'ouvrir la table <%s>"
+msgid "Cannot link table: %s"
+msgstr "Impossible d'ouvrir la table <%s>"
-#~ msgid "DXF input file"
-#~ msgstr "Fichier DXF source"
+msgid "DXF input file"
+msgstr "Fichier DXF source"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
+msgid "Cannot open dxf file <%s>"
+msgstr "Impossible d'ouvrir le fichier [%s]"
-#~ msgid "Use output= option to change vector map name"
-#~ msgstr ""
-#~ "Utilisez l'option output= pour changer le nom de la couche vectorielle"
+#, fuzzy
+msgid "Use output= option to change vector map name"
+msgstr "Utilisez l'option output= pour changer le nom de la couche vectorielle"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "%s: impossible d'ouvrir le nouveau fichier vectoriel"
+msgid "Cannot open new vector map <%s>"
+msgstr "%s: impossible d'ouvrir le nouveau fichier vectoriel"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr ""
-#~ "\n"
-#~ "Conversion de %s en couche vectorielle:  "
+msgid "Conversion of <%s> to vector map:"
+msgstr ""
+"\n"
+"Conversion de %s en couche vectorielle:  "
 # c-format
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgid "Create 3D file"
-#~ msgstr "Crée fichier 3D"
+msgid "Create 3D file"
+msgstr "Crée fichier 3D"
 #, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "Ne construit pas de topologie en mode points"
+msgid "Do not print polyline info"
+msgstr "Ne construit pas de topologie en mode points"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
+msgid "Network input map <%s> not found"
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coord():  Fermeture de la session.. \n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr "ask_transform_coord():  Fermeture de la session.. \n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "Nombre de points ayant été entrés: %d\n"
+msgid " Number of points that have been entered: %d\n"
+msgstr "Nombre de points ayant été entrés: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Veuillez répondre par oui ou non"
+msgid "Please answer yes or no"
+msgstr "Veuillez répondre par oui ou non"
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Couleur de mise en valeur du texte"
+msgid "Hilight color for text"
+msgstr "Couleur de mise en valeur du texte"
 #, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "Hauteur de la ligne: %f\n"
+msgid "Line: %d\n"
+msgstr "Hauteur de la ligne: %f\n"
 #, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "Mémoire insuffisante pour allouer la structure de données."
+msgid "Insufficent memory for allocation of data structure"
+msgstr "Mémoire insuffisante pour allouer la structure de données."
-#~ msgid "imagery group"
-#~ msgstr "groupes d'images"
+msgid "imagery group"
+msgstr "groupes d'images"
-#~ msgid "imagery subgroup"
-#~ msgstr "sous-groupe d'images"
+msgid "imagery subgroup"
+msgstr "sous-groupe d'images"
-#~ msgid "output raster map"
-#~ msgstr "couche raster en sortie"
+msgid "output raster map"
+msgstr "couche raster en sortie"
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nom de(s) (la) couche(s) raster(s) en entrée"
+msgid "Name of input raster map(s)"
+msgstr "Nom de(s) (la) couche(s) raster(s) en entrée"
-#~ msgid "Output file extension (inputfile(s) + extension)"
-#~ msgstr "Extension du fichier de sortie (Fichiers en entrée + extension)"
+msgid "Output file extension (inputfile(s) + extension)"
+msgstr "Extension du fichier de sortie (Fichiers en entrée + extension)"
-#~ msgid "name=%s\n"
-#~ msgstr "nom =%s\n"
+msgid "name=%s\n"
+msgstr "nom =%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "jeu de données =%s\n"
+msgid "mapset=%s\n"
+msgstr "jeu de données =%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "nom complet =%s\n"
+msgid "fullname=%s\n"
+msgstr "nom complet =%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "Utilisation :  fichier %s [prompt %%x %%y]\n"
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr "Utilisation :  fichier %s [prompt %%x %%y]\n"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "%s : %s - nom de fichier illégal pour la partie réelle\n"
+msgid "Illegal file name for real part: %s"
+msgstr "%s : %s - nom de fichier illégal pour la partie réelle\n"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
-#~ msgstr "%s : %s - nom de fichier illégale pour la partie imaginaire\n"
+msgid "Illegal file name for imaginary part: %s"
+msgstr "%s : %s - nom de fichier illégale pour la partie imaginaire\n"
 # c-format
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "impossible de lire le fichier signature <%s> **"
+msgid "** Can't read signature file <%s> **"
+msgstr "impossible de lire le fichier signature <%s> **"
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr ""
-#~ "\n"
-#~ "<%s> -- nom du fichier de signature résultat illégal"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr ""
+"\n"
+"<%s> -- nom du fichier de signature résultat illégal"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Nom en sortie illégale : '%s'"
+msgid "Illegal group name <%s>"
+msgstr "Nom en sortie illégale : '%s'"
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Attention : nom de fichier de signatures illégal <%s>"
+msgid "Illegal signature file name <%s>"
+msgstr "Attention : nom de fichier de signatures illégal <%s>"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Fichier(s) raster pour la Vue%d"
+msgid "Raster file(s) for Elevation"
+msgstr "Fichier(s) raster pour la Vue%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
-#~ msgid "Setting map window"
-#~ msgstr "Paramétrage de la fenêtre d'affichage de la couche"
+msgid "Setting map window"
+msgstr "Paramétrage de la fenêtre d'affichage de la couche"
-#~ msgid "Current window not settable"
-#~ msgstr "Impossible de configurer la fenêtre actuelle"
+msgid "Current window not settable"
+msgstr "Impossible de configurer la fenêtre actuelle"
 #, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Impossible de créer la fenêtre graphique courante"
+msgid "Can't clear current graphics window"
+msgstr "Impossible de créer la fenêtre graphique courante"
-#~ msgid "Cannot use current window"
-#~ msgstr "Impossible de créer la fenêtre courante"
+msgid "Cannot use current window"
+msgstr "Impossible de créer la fenêtre courante"
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr ""
-#~ "Génére et affiche des graphiques sur les couches de données affichées "
-#~ "dans le moniteur actif."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr ""
+"Génére et affiche des graphiques sur les couches de données affichées dans "
+"le moniteur actif."
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr ""
-#~ "Le fichier Unix contient les instruction de dessin, s'il n'y en a pas "
-#~ "partir des instructions de la ligne de commande"
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr ""
+"Le fichier Unix contient les instruction de dessin, s'il n'y en a pas partir "
+"des instructions de la ligne de commande"
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B "
-#~ "(séparé par le signe :)"
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Couleur de traçage, soit une couleur GRASS standard soit un triplet R:G:B "
+"(séparé par le signe :)"
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "Ne pas ajouter à la liste des commandes dans le moniteur"
+msgid "Don't add to list of commands in monitor"
+msgstr "Ne pas ajouter à la liste des commandes dans le moniteur"
-#~ msgid "No current frame"
-#~ msgstr "Pas de cadre graphique actif"
+msgid "No current frame"
+msgstr "Pas de cadre graphique actif"
-#~ msgid "Current frame not available"
-#~ msgstr "Cadre graphique courant non disponible"
+msgid "Current frame not available"
+msgstr "Cadre graphique courant non disponible"
 #, fuzzy
-#~ msgid "Error reading raster map"
-#~ msgstr "Erreur de lecture des cellules de données"
+msgid "Error reading raster map"
+msgstr "Erreur de lecture des cellules de données"
 #, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Nom du préfixe du fichier raster en sortie"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Nom du préfixe du fichier raster en sortie"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr ""
-#~ "légende"
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr ""
 #, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "Erreur à l'ouverture du fichier raster 3D"
+msgid "Error opening cell-file"
+msgstr "Erreur à l'ouverture du fichier raster 3D"
 #, fuzzy
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Erreur de lecture de la ligne de données"
+msgid "Error reading from cell-file"
+msgstr "Erreur de lecture de la ligne de données"
 # c-format
 #, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "impossible d'ouvrir <%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "impossible d'ouvrir <%s>"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Milieu: couleur flash enclenchée\n"
+msgid " Middle: toggle flash color\n"
+msgstr " Milieu: couleur flash enclenchée\n"
-#~ msgid "Enable flashing (slower)"
-#~ msgstr "Permet le flashing (plus lent)"
+msgid "Enable flashing (slower)"
+msgstr "Permet le flashing (plus lent)"
-#~ msgid "No raster map exists in current window"
-#~ msgstr "Il n'y aucune couche raster dans la fenêtre active"
+msgid "No raster map exists in current window"
+msgstr "Il n'y aucune couche raster dans la fenêtre active"
-#~ msgid "No current window"
-#~ msgstr "Pas de fenêtre active"
+msgid "No current window"
+msgstr "Pas de fenêtre active"
-#~ msgid "Current window not available"
-#~ msgstr "Fenêtre courante non disponible"
+msgid "Current window not available"
+msgstr "Fenêtre courante non disponible"
-#~ msgid "Getting screen window"
-#~ msgstr "Récupération de la fenêtre"
+msgid "Getting screen window"
+msgstr "Récupération de la fenêtre"
-#~ msgid "Error in calculating conversions"
-#~ msgstr "Erreur dans le calcul de conversion"
+msgid "Error in calculating conversions"
+msgstr "Erreur dans le calcul de conversion"
-#~ msgid "No current graphics window"
-#~ msgstr "Pas de fenêtre graphique active"
+msgid "No current graphics window"
+msgstr "Pas de fenêtre graphique active"
-#~ msgid "Current graphics window not available"
-#~ msgstr "Fenêtre graphique courante non disponible"
+msgid "Current graphics window not available"
+msgstr "Fenêtre graphique courante non disponible"
-#~ msgid "Setting graphics window"
-#~ msgstr "Paramétrage de la fenêtre graphique"
+msgid "Setting graphics window"
+msgstr "Paramétrage de la fenêtre graphique"
-#~ msgid "Can't set current graphics window"
+msgid "Can't set current graphics window"
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "Prendre les coordonnées de la fenêtre graphique"
+msgid "Getting graphics window coordinates"
+msgstr "Prendre les coordonnées de la fenêtre graphique"
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "valeur [%.0f,%.0f] hors de l'intervalle [0-100]"
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr "valeur [%.0f,%.0f] hors de l'intervalle [0-100]"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Nom du nouveau fichier TIFF"
+msgid "Font name or pathname of TTF file"
+msgstr "Nom du nouveau fichier TIFF"
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "Paramétrage du nettoyage de FreeType\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+"Paramétrage du nettoyage de FreeType\n"
-#~ msgid "Display number of colors"
-#~ msgstr "Afficher le nombre de couleurs"
+msgid "Display number of colors"
+msgstr "Afficher le nombre de couleurs"
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr ""
-#~ "légende"
+msgid "Use mouse to size & place legend"
+msgstr ""
 #, fuzzy
-#~ msgid "Creates a list of commands for recreating screen graphics."
-#~ msgstr ""
-#~ "Créer une liste de commande pour recréer les effets graphiques à l'écran"
+msgid "Creates a list of commands for recreating screen graphics."
+msgstr ""
+"Créer une liste de commande pour recréer les effets graphiques à l'écran"
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Nom du/des cadre(s) graphique(s) à sauvegarder"
+msgid "Name of frame(s) to save"
+msgstr "Nom du/des cadre(s) graphique(s) à sauvegarder"
-#~ msgid "Save current frame"
-#~ msgstr "Sauvegarder cadre graphique actif"
+msgid "Save current frame"
+msgstr "Sauvegarder cadre graphique actif"
-#~ msgid "Save all the frames"
-#~ msgstr "Sauvegarder tous les cadres graphiques"
+msgid "Save all the frames"
+msgstr "Sauvegarder tous les cadres graphiques"
-#~ msgid "Only map objects without extra header and tailer"
-#~ msgstr "Seulement les objets de la carte sans compléments"
+msgid "Only map objects without extra header and tailer"
+msgstr "Seulement les objets de la carte sans compléments"
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Type d'objet inconnu: %s"
+msgid "Unknown item type in pad: %s"
+msgstr "Type d'objet inconnu: %s"
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr ""
-#~ "Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas "
-#~ "afficher sile moniteur est rafraîchi"
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr ""
+"Ne pas ajouter la liste des vecteurs dans le moniteur (cela ne sera pas "
+"afficher sile moniteur est rafraîchi"
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "Il n'y a pas de couche raster dans la fenêtre active"
+msgid "No raster map exists in the current window"
+msgstr "Il n'y a pas de couche raster dans la fenêtre active"
 #, fuzzy
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
 #, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Fixe la couleur du texte de la légende"
+msgid "Sets the color of the menu text"
+msgstr "Fixe la couleur du texte de la légende"
 #, fuzzy
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "Vous devez sélectionner au moins un outil"
+msgid "Menu must contain a title and at least one option"
+msgstr "Vous devez sélectionner au moins un outil"
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr ""
-#~ "Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr ""
+"Affiche du texte dans le moniteur actif en utilisant des polices TrueType"
 #, fuzzy
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr ""
-#~ "Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas "
-#~ "à gauche)"
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr ""
+"Les coordonnées sont en pourcentage du cadre graphique ([0,0] est en bas à "
+"gauche)"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Chemin pour la police TrueType (nom de fichier inclus)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Chemin pour la police TrueType (nom de fichier inclus)"
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr ""
-#~ "Hauteur des caractères (en pourcentage de la hauteur disponible du cadre "
-#~ "graphique)"
+msgid "Height of letters (in percent of available frame height)"
+msgstr ""
+"Hauteur des caractères (en pourcentage de la hauteur disponible du cadre "
+"graphique)"
-#~ msgid "Either text or -c should be given"
-#~ msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
+msgid "Either text or -c should be given"
+msgstr "L'une des options, soit texte soit -c, doit être sélectionnée."
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr ""
-#~ "Choisissez un seul système de coordonnées pour déterminer le placement"
+msgid "Choose only one coordinate system for placement"
+msgstr "Choisissez un seul système de coordonnées pour déterminer le placement"
-#~ msgid "No font selected"
-#~ msgstr "Pas de police sélectionnée"
+msgid "No font selected"
+msgstr "Pas de police sélectionnée"
 # c-format
-#~ msgid "Invalid font: %s"
-#~ msgstr "Police invalide : %s"
+msgid "Invalid font: %s"
+msgstr "Police invalide : %s"
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "Impossible de créer le contexte de conversion du texte"
+msgid "Unable to create text conversion context"
+msgstr "Impossible de créer le contexte de conversion du texte"
-#~ msgid "Text conversion error"
-#~ msgstr "Erreur de conversion du texte"
+msgid "Text conversion error"
+msgstr "Erreur de conversion du texte"
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Impossible d'écrire le fichier temporaire"
+msgid "Unable to write the temporary file"
+msgstr "Impossible d'écrire le fichier temporaire"
-#~ msgid "No predefined font"
-#~ msgstr "Pas de police pré-définie"
+msgid "No predefined font"
+msgstr "Pas de police pré-définie"
-#~ msgid "%s: Unable to read font"
-#~ msgstr "%s : impossible de lire la police"
+msgid "%s: Unable to read font"
+msgstr "%s : impossible de lire la police"
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr ""
-#~ "%s : impossible de lire le fichier de définition FreeType; on utilise les "
-#~ "paramètres par défaut"
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr ""
+"%s : impossible de lire le fichier de définition FreeType; on utilise les "
+"paramètres par défaut"
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "%s : pas de fichier de définition FreeType"
+msgid "%s: No FreeType definition file"
+msgstr "%s : pas de fichier de définition FreeType"
-#~ msgid "%s: Unable to read FreeType definition file"
-#~ msgstr "%s : impossible de lire le fichier FreeType de définition"
+msgid "%s: Unable to read FreeType definition file"
+msgstr "%s : impossible de lire le fichier FreeType de définition"
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "Ne pas ajouter à la liste des rasters du moniteur"
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr "Ne pas ajouter à la liste des rasters du moniteur"
-#~ msgid "One mouse click only"
-#~ msgstr "Cliquer une seule fois"
+msgid "One mouse click only"
+msgstr "Cliquer une seule fois"
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr ""
-#~ "Utilisez la souris pour positionner l'échelle graphique de façon "
-#~ "interactive"
+msgid "Use mouse to interactively place scale"
+msgstr ""
+"Utilisez la souris pour positionner l'échelle graphique de façon interactive"
 #, fuzzy
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr ""
-#~ "interactive"
+msgid "Use mouse to interactively place text"
+msgstr ""
 #, fuzzy
-#~ msgid " Left:    Place text here\n"
-#~ msgstr " Gauche:  qu'y a-t-il ici?\n"
+msgid " Left:    Place text here\n"
+msgstr " Gauche:  qu'y a-t-il ici?\n"
 #, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Droite: quitter\n"
+msgid " Right:   Quit\n"
+msgstr " Droite: quitter\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr ""
-#~ "Redessiner simplement les couches concernées en utilisant les couleurs "
-#~ "par défaut"
+msgid "Just redraw given maps using default colors"
+msgstr ""
+"Redessiner simplement les couches concernées en utilisant les couleurs par "
+"défaut"
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERREUR: impossible de récupérer les éléments de \"list\" "
+msgid "ERROR: can not get \"list\" items"
+msgstr "ERREUR: impossible de récupérer les éléments de \"list\" "
-#~ msgid "-j flag forced"
-#~ msgstr "Drapeau -j forcé"
+msgid "-j flag forced"
+msgstr "Drapeau -j forcé"
-#~ msgid "No map is displayed in GRASS monitor"
-#~ msgstr "ERREUR: Aucune couche n'est affichée dans le moniteur GRASS"
+msgid "No map is displayed in GRASS monitor"
+msgstr "ERREUR: Aucune couche n'est affichée dans le moniteur GRASS"
-#~ msgid "Interactively select route"
-#~ msgstr "Sélectionner de façon interactive l'itinéraire"
+msgid "Interactively select route"
+msgstr "Sélectionner de façon interactive l'itinéraire"
-#~ msgid "You must select more than one point"
-#~ msgstr "Vous devez sélectionner au moins un point"
+msgid "You must select more than one point"
+msgstr "Vous devez sélectionner au moins un point"
-#~ msgid "You must select at least four points"
-#~ msgstr "Vous devez sélectionner au moins quatre points."
+msgid "You must select at least four points"
+msgstr "Vous devez sélectionner au moins quatre points."
 #, fuzzy
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Nom de la couche raster d'aspect à afficher"
+msgid "No raster or vector map displayed"
+msgstr "Nom de la couche raster d'aspect à afficher"
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr ""
-#~ "Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
+msgid "To establish and control use of a graphics display monitor."
+msgstr ""
+"Pour gérer et contrôler l'utilisation des moniteurs graphiques d'affichage"
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nom du moniteur graphique à démarrer"
+msgid "Name of graphics monitor to start"
+msgstr "Nom du moniteur graphique à démarrer"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nom du moniteur graphique à arrêter"
+msgid "Name of graphics monitor to stop"
+msgstr "Nom du moniteur graphique à arrêter"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nom du moniteur graphique à sélectionner"
+msgid "Name of graphics monitor to select"
+msgstr "Nom du moniteur graphique à sélectionner"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nom du moniteur graphique à déverrouiller"
+msgid "Name of graphics monitor to unlock"
+msgstr "Nom du moniteur graphique à déverrouiller"
-#~ msgid "List all monitors"
-#~ msgstr "Lister tous les moniteurs"
+msgid "List all monitors"
+msgstr "Lister tous les moniteurs"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Lister tous les moniteurs (actifs)"
+msgid "List all monitors (with current status)"
+msgstr "Lister tous les moniteurs (actifs)"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Afficher le nom du moniteur sélectionné"
+msgid "Print name of currently selected monitor"
+msgstr "Afficher le nom du moniteur sélectionné"
-#~ msgid "Release currently selected monitor"
-#~ msgstr "Désélectionner le moniteur actif"
+msgid "Release currently selected monitor"
+msgstr "Désélectionner le moniteur actif"
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "Ne pas sélectionner automatiquement le moniteur au démarrage"
+msgid "Do not automatically select when starting"
+msgstr "Ne pas sélectionner automatiquement le moniteur au démarrage"
-#~ msgid "Problem selecting %s. Will try once more"
-#~ msgstr "Problème pour sélectionner %s. Nouvelle tentative."
+msgid "Problem selecting %s. Will try once more"
+msgstr "Problème pour sélectionner %s. Nouvelle tentative."
 #, fuzzy
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "[%s] ne correspond pas à une couleur connue"
+msgid "No such monitor as <%s>"
+msgstr "[%s] ne correspond pas à une couleur connue"
 #, fuzzy
-#~ msgid "Monitor <%s> released"
-#~ msgstr "Pas de moniteur sélectionné"
+msgid "Monitor <%s> released"
+msgstr "Pas de moniteur sélectionné"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "Erreur de fermeture du fichier VTK-ASCII"
+msgid "Error - Locking mechanism failed"
+msgstr "Erreur de fermeture du fichier VTK-ASCII"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Erreur de lecture de l'intervalle pour [%s]"
+msgid "Error choosing frame [%s]\n"
+msgstr "Erreur de lecture de l'intervalle pour [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"Boutons:\n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
+msgid "Left:   Select frame\n"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "%s Quitter le menu\n"
+msgid "Right:  Accept frame\n"
+msgstr "%s Quitter le menu\n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
+msgid "Manages display frames on the user's graphics monitor."
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Sélectionner les données depuis une base de données."
+msgid "Select a frame"
+msgstr "Sélectionner les données depuis une base de données."
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
 #, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "Affiche les totaux par surface"
+msgid "Print names of all frames"
+msgstr "Affiche les totaux par surface"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Fichier vecteur à créer"
+msgid "Frame to be created/selected"
+msgstr "Fichier vecteur à créer"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Boutons:\n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"\n"
+"Boutons:\n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
+msgid "Left:   Select From\n"
 #, fuzzy
-#~ msgid "Middle: Select To\n"
+msgid "Middle: Select To\n"
+msgstr "Milieu:"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Moniteur: commande interactive dans redraw\n"
+msgid "Monitor: interactive command in redraw"
+msgstr "Moniteur: commande interactive dans redraw\n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "%d visuels de type TrueColor\n"
+msgid "found %d visuals of type TrueColor"
+msgstr "%d visuels de type TrueColor\n"
 #, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "recherche du plus haut bit de profondeur\n"
+msgid "searching for highest bit depth"
+msgstr "recherche du plus haut bit de profondeur\n"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "profondeur %d bit sélectionnée\n"
+msgid "selected %d bit depth"
+msgstr "profondeur %d bit sélectionnée\n"
 #, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "utilisation du visuel %s par défaut\n"
+msgid "using default visual which is %s"
+msgstr "utilisation du visuel %s par défaut\n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Moniteur: waitpid: attendu %d mais reçu %d\n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Moniteur: waitpid: attendu %d mais reçu %d\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Moniteur: XGetWMName a échoué\n"
+msgid "Monitor: XGetWMName failed"
+msgstr "Moniteur: XGetWMName a échoué\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Moniteur: XGetWMName: mauvais résultat\n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Moniteur: XGetWMName: mauvais résultat\n"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ATTENTION! Un fichier de projection existe déjà pour ce Secteur\n"
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+"\n"
+"\n"
+"ATTENTION! Un fichier de projection existe déjà pour ce Secteur\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr ""
-#~ "Voulez-vous vraiment écraser les informations de projection courante "
+msgid "Would you still like to overwrite the current projection information "
+msgstr "Voulez-vous vraiment écraser les informations de projection courante "
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Les informations de projection ne seront pas mises à jour."
+msgid "The projection information will not be updated."
+msgstr "Les informations de projection ne seront pas mises à jour."
-#~ msgid "Raster map to zoom into"
-#~ msgstr "Couche raster sur laquelle zoomer"
+msgid "Raster map to zoom into"
+msgstr "Couche raster sur laquelle zoomer"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Sauvegarder la région courante dans le fichier de définition de la région"
+msgid "Save the current region to region definition file"
+msgstr ""
+"Sauvegarder la région courante dans le fichier de définition de la région"
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> - nom de région illégal"
+msgid "<%s> is an illegal region name"
+msgstr "<%s> - nom de région illégal"
 #, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "L'option Geo-Grid n'est pas disponible en projection XY"
+msgid "No LatLong information for XY-Projection"
+msgstr "L'option Geo-Grid n'est pas disponible en projection XY"
 # c-format
 #, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "Écriture %s..."
+msgid "Erasing monitors ..."
+msgstr "Écriture %s..."
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s>"
+msgid "Could not open input file <%s>."
+msgstr "impossible d'ouvrir le fichier vecteur <%s>"
 #, fuzzy
-#~ msgid "No such monitor as '%s'"
+msgid "No such monitor as '%s'"
 #, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
+msgid "Error - No such monitor as '%s'"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers rasters dans le sous-groupe [%s] n'existent pas :"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr ""
+"\a\n"
+"** Les fichiers rasters dans le sous-groupe [%s] n'existent pas :"
-#~ msgid "       %s"
-#~ msgstr "\t\t%s"
+msgid "       %s"
+msgstr "\t\t%s"
-#~ msgid "Removing files from group"
-#~ msgstr "Suppression des fichiers du groupe"
+msgid "Removing files from group"
+msgstr "Suppression des fichiers du groupe"
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "Ajouter les fichiers au groupe [%s]"
+msgid "Adding files to group [%s]"
+msgstr "Ajouter les fichiers au groupe [%s]"
-#~ msgid "Adding files to subgroup [%s]"
-#~ msgstr "Ajouter les fichiers au sous-groupe [%s]"
+msgid "Adding files to subgroup [%s]"
+msgstr "Ajouter les fichiers au sous-groupe [%s]"
-#~ msgid "Skipping [%s]..."
-#~ msgstr "Saut de [%s]..."
+msgid "Skipping [%s]..."
+msgstr "Saut de [%s]..."
-#~ msgid "Writing group REF"
-#~ msgstr "Ecriture du groupe REF"
+msgid "Writing group REF"
+msgstr "Ecriture du groupe REF"
-#~ msgid "Writing subgroup REF"
-#~ msgstr "Ecriture du sous-groupe REF"
+msgid "Writing subgroup REF"
+msgstr "Ecriture du sous-groupe REF"
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "Fichier <%s@%s> trouvé dans le groupe"
+msgid "Found file <%s@%s> in group."
+msgstr "Fichier <%s@%s> trouvé dans le groupe"
-#~ msgid "Found file <%s@%s> in subgroup."
-#~ msgstr "Fichier <%s@%s> trouvé dans le sous-groupe"
+msgid "Found file <%s@%s> in subgroup."
+msgstr "Fichier <%s@%s> trouvé dans le sous-groupe"
 # c-format
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
+msgid "Unable to open file: <%s>"
+msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#~ msgid "Multiplier"
-#~ msgstr "Multiplicateur"
+msgid "Multiplier"
+msgstr "Multiplicateur"
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr ""
-#~ "La projection des données en entrée et le Secteur (location) courant "
-#~ "semblent correspondre.\n"
-#~ "Poursuite de la procédure d'importation...\n"
+msgid ""
+"Projection of input dataset and current location appear to match.\n"
+"Proceeding with import...\n"
+msgstr ""
+"La projection des données en entrée et le Secteur (location) courant "
+"semblent correspondre.\n"
+"Poursuite de la procédure d'importation...\n"
 # c-format
 #, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "%s non trouvé"
+msgid "not found\n"
+msgstr "%s non trouvé"
-#~ msgid "%s: percent complete: "
-#~ msgstr "%s : pourcentage effectué :"
+msgid "%s: percent complete: "
+msgstr "%s : pourcentage effectué :"
 # c-format
-#~ msgid "Raster map not found."
-#~ msgstr "couche raster non trouvée"
+msgid "Raster map not found."
+msgstr "couche raster non trouvée"
 # c-format
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "%s: impossible de lire l'intervalle pour [%s]"
+msgid "%s: can't read range for [%s]"
+msgstr "%s: impossible de lire l'intervalle pour [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "Fichier raster <%s> non trouvé"
+msgid "Raster file [%s] not found"
+msgstr "Fichier raster <%s> non trouvé"
 # c-format
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "impossible de créer %s"
+msgid "It was not possible writing in <%s>."
+msgstr "impossible de créer %s"
 #, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
-#~ msgstr "Impossible de calculer le centroïde de la surface"
+msgid "\rDuplicate area centroids: %5d"
+msgstr "Impossible de calculer le centroïde de la surface"
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "Impossible de créer la table : %s"
+msgid "Cannot create table: '%s'"
+msgstr "Impossible de créer la table : %s"
-#~ msgid "defaulting to nearest neighbor sampling"
-#~ msgstr "Retour à l'échantillonnage au plus propre voisin par défaut"
+msgid "defaulting to nearest neighbor sampling"
+msgstr "Retour à l'échantillonnage au plus propre voisin par défaut"
 # c-format
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Impossible de lire <%s>"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Impossible de lire <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
 # c-format
 #, fuzzy
-#~ msgid "Unable to delete line %d"
-#~ msgstr "Impossible d'effacer le fichier %s\n"
+msgid "Unable to delete line %d"
+msgstr "Impossible d'effacer le fichier %s\n"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Type inconnu"
+msgid "Unknown query tool '%s'"
+msgstr "Type inconnu"
 #, fuzzy
-#~ msgid ""
-#~ "If 'list', 'file' and 'where' options are not specified, all features of "
-#~ "given type and layer are extracted. Categories are not changed in that "
-#~ "case."
-#~ msgstr ""
-#~ "Sélectionne les objets vectoriels d'une couche vectorielle existante et "
-#~ "crée une nouvelle couche contenant seulement les objets sélectionnés. Si "
-#~ "les options 'list', 'file' et 'where' ne sont pas spécifiées, tous les "
-#~ "objets d'un type et d'une couche données sont extraits,dans ce cas, les "
-#~ "catégories sont inchangées."
+msgid ""
+"If 'list', 'file' and 'where' options are not specified, all features of "
+"given type and layer are extracted. Categories are not changed in that case."
+msgstr ""
+"Sélectionne les objets vectoriels d'une couche vectorielle existante et crée "
+"une nouvelle couche contenant seulement les objets sélectionnés. Si les "
+"options 'list', 'file' et 'where' ne sont pas spécifiées, tous les objets "
+"d'un type et d'une couche données sont extraits,dans ce cas, les catégories "
+"sont inchangées."
 #, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "Pas de connexion de la couche à la base de données"
+msgid "No layer database connection"
+msgstr "Pas de connexion de la couche à la base de données"
 #, fuzzy
-#~ msgid "Load categories from the database (table = %s, db = %s)."
-#~ msgstr ""
-#~ "Charger les catégories à partir de la base de données (table = %s, db = %"
-#~ "s).\n"
+msgid "Load categories from the database (table = %s, db = %s)."
+msgstr ""
+"Charger les catégories à partir de la base de données (table = %s, db = %"
+"s).\n"
 # c-format
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d catégories chargées depuis la base de données\n"
+msgid "%d categories loaded from the database"
+msgstr "%d catégories chargées depuis la base de données\n"
-#~ msgid "Done"
-#~ msgstr "Terminé"
+msgid "Done"
+msgstr "Terminé"
 # c-format
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Impossible d'ouvrir la source de données OGR %s"
+msgid "Cannot open OGR data source '%s'"
+msgstr "Impossible d'ouvrir la source de données OGR %s"
-#~ msgid "Cannot create layer"
-#~ msgstr "Impossible de créer la couche"
+msgid "Cannot create layer"
+msgstr "Impossible de créer la couche"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Le fichier vecteur [%s] n'est pas disponible"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Le fichier vecteur [%s] n'est pas disponible"
 #, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr ""
-#~ "Charge les valeurs de vecteurs dans la base de données. Parmi les valeurs "
-#~ "de catégories chargées/affichées '-1est utilisé pour 'pas de catégorie' "
-#~ "et 'null'/'-' si la catégorie n'a pas été trouvée ouque de multiples "
-#~ "catégories ont été trouvées."
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr ""
+"Charge les valeurs de vecteurs dans la base de données. Parmi les valeurs de "
+"catégories chargées/affichées '-1est utilisé pour 'pas de catégorie' et "
+"'null'/'-' si la catégorie n'a pas été trouvée ouque de multiples catégories "
+"ont été trouvées."
 #, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "colonne(s)"
+msgid "Column(s)"
+msgstr "colonne(s)"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Type de colonne non géré"
+msgid "Column type [%d] not supported"
+msgstr "Type de colonne non géré"
 # c-format
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Impossible de trouver l'en-tête de fichier %s"
+msgid "Cannot read map header for <%s>"
+msgstr "Impossible de trouver l'en-tête de fichier %s"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
+msgid "Cannot read category file for <%s>"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Afficher;Shell Script"
+msgid "Print;Shell Script"
+msgstr "Afficher;Shell Script"
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "Créer des fichiers supports pour [%s]."
+msgid "Creating support files for [%s]."
+msgstr "Créer des fichiers supports pour [%s]."
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
+msgid "Category file for [%s] not available"
+msgstr "Le fichier de catégorie pour [%s] n'est pas disponible"
 # c-format
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "%s : fichier de cellules <%s> non trouvé"
+msgid "%s: <%s> raster map not found"
+msgstr "%s : fichier de cellules <%s> non trouvé"
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "%s : <%s> le fichier raster existe déjà"
+msgid "%s: <%s> raster map exists already"
+msgstr "%s : <%s> le fichier raster existe déjà"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 # c-format
-#~ msgid "%s - map not found"
-#~ msgstr "%s - couche non trouvée"
+msgid "%s - map not found"
+msgstr "%s - couche non trouvée"
 # c-format
-#~ msgid "%s: Cannot open [%s]"
-#~ msgstr "%s: Impossible d'ouvrir [%s]"
+msgid "%s: Cannot open [%s]"
+msgstr "%s: Impossible d'ouvrir [%s]"
 # c-format
-#~ msgid "%s not found"
+msgid "%s not found"
-#~ msgid "Could not access %s layer"
-#~ msgstr "Impossible d'accéder à la couche %s"
+msgid "Could not access %s layer"
+msgstr "Impossible d'accéder à la couche %s"
 # c-format
-#~ msgid "Vector map %s - not found"
-#~ msgstr "Couche vecteur %s introuvable"
+msgid "Vector map %s - not found"
+msgstr "Couche vecteur %s introuvable"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "couche raster contenant les données d'altitude"
+msgid "Raster map containing elevation data"
+msgstr "couche raster contenant les données d'altitude"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "couche raster où écrire les résultats"
+msgid "Raster map name for storing results"
+msgstr "couche raster où écrire les résultats"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altitude du point d'observation"
+msgid "Height of the viewing location"
+msgstr "Altitude du point d'observation"
 # c-format
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "%s: fichier de cellules <%s> non trouvé"
+msgid "%s: <%s> cellfile not found"
+msgstr "%s: fichier de cellules <%s> non trouvé"
 # c-format
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "Fichier de cellules [%s] non trouvé\n"
+msgid "Cell file [%s] not found\n"
+msgstr "Fichier de cellules [%s] non trouvé\n"
 # c-format
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé\n"
+msgid "rgb cell map [%s] not found\n"
+msgstr "fichier de cellules 3dview <%s> non trouvé\n"
 # c-format
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 # c-format
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
-#~ msgid "raster map <%s> not found"
+msgid "raster map <%s> not found"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête pour <%s> dans <%s>"
+msgid "can't read header for <%s> in <%s>"
+msgstr "impossible de trouver les en-tête pour <%s> dans <%s>"
-#~ msgid "region <%s> not found"
-#~ msgstr "région <%s> non trouvée"
+msgid "region <%s> not found"
+msgstr "région <%s> non trouvée"
-#~ msgid "can't read region <%s> in <%s>"
-#~ msgstr "impossible de lire la région <%s> dans <%s>"
+msgid "can't read region <%s> in <%s>"
+msgstr "impossible de lire la région <%s> dans <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "impossible d'ouvrir le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
-#~ msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
+msgid "can't read 3dview file <%s> in <%s>"
+msgstr "impossible de lire le fichier 3dview <%s> dans <%s>"
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
+msgid "can't open vector map <%s> in <%s>"
+msgstr "impossible d'ouvrir le fichier vecteur <%s> dans <%s>"
-#~ msgid "invalid region: %s"
-#~ msgstr "région incorrecte : %s"
+msgid "invalid region: %s"
+msgstr "région incorrecte : %s"
 # c-format
 #, fuzzy
-#~ msgid "Creating support files"
-#~ msgstr "impossible d'ouvrir le fichier pour %s"
+msgid "Creating support files"
+msgstr "impossible d'ouvrir le fichier pour %s"
-#~ msgid "can't open %s"
-#~ msgstr "Impossible d'ouvrir %s"
+msgid "can't open %s"
+msgstr "Impossible d'ouvrir %s"
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "%s fichier [%s] non trouvé!"
+msgid "%s file [%s] not found!"
+msgstr "%s fichier [%s] non trouvé!"
 # c-format
 #, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "%s: %s - non trouvé"
+msgid "%s: %s - map not found"
+msgstr "%s: %s - non trouvé"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
 # c-format
-#~ msgid "%s - not found"
+msgid "%s - not found"
 # c-format
-#~ msgid "Cannot read %s"
-#~ msgstr "Impossible de lire %s"
+msgid "Cannot read %s"
+msgstr "Impossible de lire %s"
-#~ msgid "map layer [%s] not legal for GRASS"
-#~ msgstr "la couche [%s] n'est pas légal pour GRASS"
+msgid "map layer [%s] not legal for GRASS"
+msgstr "la couche [%s] n'est pas légal pour GRASS"
 # c-format
-#~ msgid "[%s] map not found."
-#~ msgstr "[%s] couche non trouvée"
+msgid "[%s] map not found."
+msgstr "[%s] couche non trouvée"
 # c-format
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 # c-format
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "fichier d'altitude [%s] non trouvé"
+msgid "elevation file [%s] not found"
+msgstr "fichier d'altitude [%s] non trouvé"
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr "aspect minimum calculé %.4f aspect maximum calculé %.4f"
+msgid "min computed aspect %.4f  max computed aspect %.4f"
+msgstr "aspect minimum calculé %.4f aspect maximum calculé %.4f"
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "pente minimum calculée %.4f pente maximum calculée %.4f"
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "pente minimum calculée %.4f pente maximum calculée %.4f"
 # c-format
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "Impossible de décrire la table %s"
+msgid "Cannot describe table <%s>"
+msgstr "Impossible de décrire la table %s"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
-#~ msgstr "Impossible d'insérer dans la table: %s"
+msgid "Cannot insert values: %s"
+msgstr "Impossible d'insérer dans la table: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s donne un nombre illégal de sites [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s donne un nombre illégal de sites [%d]"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
+msgid "Unable to open database %s by driver %s"
+msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Pas de paramètres définis pour la connexion à la base de données. Faites-"
-#~ "le avec db.connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr ""
+"Pas de paramètres définis pour la connexion à la base de données. Faites-le "
+"avec db.connect"
 # c-format
-#~ msgid "Could not find input %s"
-#~ msgstr "Impossible de trouver l'entrée %s"
+msgid "Could not find input %s"
+msgstr "Impossible de trouver l'entrée %s"
-#~ msgid "Could not open input"
-#~ msgstr "Impossible d'ouvrir l'entrée %s"
+msgid "Could not open input"
+msgstr "Impossible d'ouvrir l'entrée %s"
-#~ msgid "Could not open output"
-#~ msgstr "Impossible d'ouvrir la sortie"
+msgid "Could not open output"
+msgstr "Impossible d'ouvrir la sortie"
 # c-format
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "couche d'entrée introuvable <%s>"
+msgid "Could not find input map <%s>"
+msgstr "couche d'entrée introuvable <%s>"
-#~ msgid "Unkown item type in pad: %s"
+msgid "Unkown item type in pad: %s"
 # c-format
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
+msgid "Unable to open driver <%s>"
+msgstr "Impossible d'ouvrir la couche raster <%s>"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "La connexion à la base de données n'a pas été définie\n"
+msgid "Database connection not defined\n"
+msgstr "La connexion à la base de données n'a pas été définie\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "impossible de trouver les en-tête de raster 3D <%s> dans <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "impossible de trouver les en-tête de raster 3D <%s> dans <%s>"
 # c-format
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s ligne %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s ligne %s: %s"
 # c-format
 #, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "impossible d'écrire la région <%s>"
+msgid "Can't write region <%s>"
+msgstr "impossible d'écrire la région <%s>"
 # c-format
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** valeur entrée invalide **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** valeur entrée invalide **"
-#~ msgid "No graphics device selected."
-#~ msgstr "Aucune sortie graphique n'est sélectionnée"
+msgid "No graphics device selected."
+msgstr "Aucune sortie graphique n'est sélectionnée"
-#~ msgid "Unable to read raster row."
-#~ msgstr "Impossible de lire la ligne raster."
+msgid "Unable to read raster row."
+msgstr "Impossible de lire la ligne raster."
-#~ msgid "Training map [%s] not found."
-#~ msgstr "couche d'apprentissage raster [%s] non trouvée"
+msgid "Training map [%s] not found."
+msgstr "couche d'apprentissage raster [%s] non trouvée"
 # c-format
-#~ msgid "%s map not found"
-#~ msgstr "%s couche non trouvée"
+msgid "%s map not found"
+msgstr "%s couche non trouvée"
 #, fuzzy
-#~ msgid "input raster map"
-#~ msgstr "couche raster source"
+msgid "input raster map"
+msgstr "couche raster source"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
-#~ msgstr "nom de fichier illégal [%s]"
+msgid "Illegal file name: %s"
+msgstr "nom de fichier illégal [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "Condition for update (everything after the 'where' sql statement; ex: "
-#~ "cat=1 or col1/col2>1)"
-#~ msgstr ""
-#~ "conditionnelle pour la mise à jour (tout ce qui se trouve après la clause "
-#~ "'where'; ex : cat=1 ou col1/col2>1)"
+msgid ""
+"Condition for update (everything after the 'where' sql statement; ex: cat=1 "
+"or col1/col2>1)"
+msgstr ""
+"conditionnelle pour la mise à jour (tout ce qui se trouve après la clause "
+"'where'; ex : cat=1 ou col1/col2>1)"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr ""
-#~ "Impossible de récupérer les informations de la couche pour cette couche "
-#~ "vectorielle"
+msgid "Cannot get layer info for vector map"
+msgstr ""
+"Impossible de récupérer les informations de la couche pour cette couche "
+"vectorielle"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
-#~ "Impossible d'ouvrir le fichier de cellules pour [%s]\n"
-#~ "Impossible d'ouvrir la couche raster [%s]"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr ""
+"#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
+"Impossible d'ouvrir le fichier de cellules pour [%s]\n"
+"Impossible d'ouvrir la couche raster [%s]"
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr ""
-#~ "valeurs de couverture extraites des étiquettes de catégorie de la couche "
-#~ "de couverture"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr ""
+"valeurs de couverture extraites des étiquettes de catégorie de la couche de "
+"couverture"
 # c-format
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s : %s - couche raster non trouvée"
+msgid "%s: %s - raster map not found"
+msgstr "%s : %s - couche raster non trouvée"
-#~ msgid "%s: %s - illegal name"
-#~ msgstr "%s: %s - nom illégal"
+msgid "%s: %s - illegal name"
+msgstr "%s: %s - nom illégal"
-#~ msgid "%s: ERROR reading category file for %s"
-#~ msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
+msgid "%s: ERROR reading category file for %s"
+msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
 # c-format
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "%s: %s - unités illégales"
+msgid "%s: %s - illegal units"
+msgstr "%s: %s - unités illégales"
 # c-format
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "Lecture de l'image..."
+msgid "Reading input map (%s)    ... "
+msgstr "Lecture de l'image..."
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "%s: ERREUR d'exécution de la commande %s"
+msgid "%s - ERROR reading %s"
+msgstr "%s: ERREUR d'exécution de la commande %s"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
+msgid "%s: %s - can't create raster map"
+msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
 # c-format
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "Ecriture de la couche raster en sortie %s..."
+msgid "Writing output map (%s)   ... "
+msgstr "Ecriture de la couche raster en sortie %s..."
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "%s - ERROR writing %s"
+msgid "%s - ERROR writing %s"
-#~ msgid "Reading raster map... "
-#~ msgstr "Lecteur du fichier raster..."
+msgid "Reading raster map... "
+msgstr "Lecteur du fichier raster..."
 # c-format
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr ""
-#~ "\n"
-#~ "Écriture du nouveau fichier raster..."
+msgid "Writing raster map... "
+msgstr ""
+"\n"
+"Écriture du nouveau fichier raster..."
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Liste de catégories. Exemple : 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Liste de catégories. Exemple : 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
-#~ msgstr "Caractère de séparation en sortie (par défaut : tabulation)"
+msgid "Output separator character (default: tab)"
+msgstr "Caractère de séparation en sortie (par défaut : tabulation)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#~ msgstr "Editer le fichier de catégorie de [%s]?"
+msgid "Cannot read category file of raster map <%s> in <%s>"
+msgstr "Editer le fichier de catégorie de [%s]?"
 # c-format
-#~ msgid "Cannot find file %s"
-#~ msgstr "Impossible de trouver le fichier %s"
+msgid "Cannot find file %s"
+msgstr "Impossible de trouver le fichier %s"
 # c-format
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
 # c-format
-#~ msgid "Cannot create raster map %s"
-#~ msgstr "Impossible de créer la couche raster %s"
+msgid "Cannot create raster map %s"
+msgstr "Impossible de créer la couche raster %s"
 # c-format
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "Impossible de créer la couche vecteur %s"
+msgid "Cannot create vector map %s"
+msgstr "Impossible de créer la couche vecteur %s"
 # c-format
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "Nombre de lignes à garder en mémoire"
+msgid "Number of raster rows to hold in memory"
+msgstr "Nombre de lignes à garder en mémoire"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Écrire uniquement le type de couche"
+msgid "Print raster map title only"
+msgstr "Écrire uniquement le type de couche"
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Type inconnu: %c"
+msgid "unknown type: %d"
+msgstr "Type inconnu: %c"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
+msgid "Cannot open raster map [%s]"
+msgstr ""
 #, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "Impossible d'ouvrir la couche raster"
+msgid "Cannot get raster band."
+msgstr "Impossible d'ouvrir la couche raster"
 #, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr ""
-#~ "Impossible de calculer le centroïde de la surface (problème d'allocation "
-#~ "mémoire)"
+msgid "Cannot allocate buffer for reading null values."
+msgstr ""
+"Impossible de calculer le centroïde de la surface (problème d'allocation "
+"mémoire)"
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "Impossible de lire la couche raster"
+msgid "Cannot read GRASS raster."
+msgstr "Impossible de lire la couche raster"
 # c-format
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
-#~ msgstr "Impossible d'écrire la couche raster lac <%s>!"
+msgid "Cannot write GDAL raster."
+msgstr "Impossible d'écrire la couche raster lac <%s>!"
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "Impossible de créer l'arborescence"
+msgid "Cannot get [%s] driver"
+msgstr "Impossible de créer l'arborescence"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
-#~ msgstr "Ligne de début de fichier raster introuvable\n"
+msgid "Couldn't set geo transform."
+msgstr "Ligne de début de fichier raster introuvable\n"
 #, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "Projection source"
+msgid "Couldn't set projection."
+msgstr "Projection source"
 # c-format
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#~ msgstr "Impossible d'ouvrir le fichier raster [%s]!"
+msgid "Cannot export [%s] raster map."
+msgstr "Impossible d'ouvrir le fichier raster [%s]!"
 # c-format
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 # c-format
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier %s"
+msgid "Cannot open TIFF file <%s>"
+msgstr "Impossible d'ouvrir le fichier %s"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
-#~ msgid "Cannot open output map."
-#~ msgstr "Impossible d'ouvrir la couche de sortie"
+msgid "Cannot open output map."
+msgstr "Impossible d'ouvrir la couche de sortie"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
-#~ msgstr "Nom du fichier de sortie illégal"
+msgid "Illegal file name. Please try another."
+msgstr "Nom du fichier de sortie illégal"
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "Erreur d'allocation mémoire"
+msgid "memory allocation failure"
+msgstr "Erreur d'allocation mémoire"
-#~ msgid "Can't find data map."
-#~ msgstr "Impossible de trouver la couche de données."
+msgid "Can't find data map."
+msgstr "Impossible de trouver la couche de données."
-#~ msgid "Can't find clump map."
-#~ msgstr "Impossible de trouver la couche de 'flaques'"
+msgid "Can't find clump map."
+msgstr "Impossible de trouver la couche de 'flaques'"
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Nom de fichier de sortie pour la courbure tangentielle"
+msgid "Output terrain only vector map name"
+msgstr "Nom de fichier de sortie pour la courbure tangentielle"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
 # c-format
-#~ msgid "No record for cat = %d"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
+msgid "No record for cat = %d"
+msgstr "Aucun enregistrement pour la ligne (cat = %d)"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
-#~ msgstr "Suppression des centroïdes en doublons..."
+msgid "Removing duplicates ..."
+msgstr "Suppression des centroïdes en doublons..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Rattachement des catégories...\n"
+msgid "Attaching islands ..."
+msgstr "Rattachement des catégories...\n"
-#~ msgid "Cannot calculate area centroid."
-#~ msgstr "Impossible de calculer le centroïde de l'entité surfacique"
+msgid "Cannot calculate area centroid."
+msgstr "Impossible de calculer le centroïde de l'entité surfacique"
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "couche vecteur <%s> introuvable"
+msgid "Vector map <%s> not found in current mapset"
+msgstr "couche vecteur <%s> introuvable"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
-#~ msgstr ""
-#~ "mémoire)"
+msgid "Error allocating memory for `lines_visited'"
+msgstr ""
+"mémoire)"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Le nombre minimum de couches spécifiées en entrée est de deux."
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Le nombre minimum de couches spécifiées en entrée est de deux."
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr ""
-#~ "La connexion à la base de données n'a pas été définie pour la couche <%d>"
+msgid "Database connection not defined for layer <%d>"
+msgstr ""
+"La connexion à la base de données n'a pas été définie pour la couche <%d>"
-#~ msgid "Attribute column(s)"
-#~ msgstr "Colonne(s) attributaire(s)"
+msgid "Attribute column(s)"
+msgstr "Colonne(s) attributaire(s)"
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Impossible d'ouvrir le curseur sélectionné"
+msgid "Cannot open select cursor"
+msgstr "Impossible d'ouvrir le curseur sélectionné"
 #, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "Impossible de lire les informations de liaison à la base de données"
+msgid "Cannot get layer info"
+msgstr "Impossible de lire les informations de liaison à la base de données"
 # c-format
-#~ msgid "cell file [%s] not found"
-#~ msgstr "fichier de cellules 3dview <%s> non trouvé"
+msgid "cell file [%s] not found"
+msgstr "fichier de cellules 3dview <%s> non trouvé"
 # c-format
-#~ msgid "can't open raster map [%s]"
-#~ msgstr "impossible d'ouvrir le fichier de cellule [%s]"
+msgid "can't open raster map [%s]"
+msgstr "impossible d'ouvrir le fichier de cellule [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossible de créer l'index"
+msgid "Cannot rewrite line %d"
+msgstr "Impossible de créer l'index"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Existant"
+msgid "Editing tool"
+msgstr "Existant"
 #, fuzzy
-#~ msgid "For tool 'add', see also 'thresh' parameter"
-#~ msgstr "Ne pas copier la table (voir aussi le paramètre 'new')"
+msgid "For tool 'add', see also 'thresh' parameter"
+msgstr "Ne pas copier la table (voir aussi le paramètre 'new')"
 #, fuzzy
-#~ msgid "Snap also to vertex (not implemented yet)"
+msgid "Snap also to vertex (not implemented yet)"
 #, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "impossible de mettre à jour les limites"
+msgid "Close boundaries"
+msgstr "impossible de mettre à jour les limites"
 # c-format
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 # c-format
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "Impossible d'ouvrir le fichier [%s]"
+msgid "Cannot snap lines %d,%d"
+msgstr "Impossible d'ouvrir le fichier [%s]"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%-5d lignes mortes sautées\n"
+msgid "%d lines modified"
+msgstr "%-5d lignes mortes sautées\n"
 # c-format
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
-#~ msgid "Print vector map region only"
-#~ msgstr "Afficher seulement la région de la couche vecteur"
+msgid "Print vector map region only"
+msgstr "Afficher seulement la région de la couche vecteur"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr ""
-#~ "vectorielle"
+msgid "Cannot get layer info for vector map <%s>"
+msgstr ""
+"vectorielle"
-#~ msgid "Rotation angle (degrees counter-clockwise from East)"
-#~ msgstr ""
-#~ "Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en "
-#~ "partant de l'Est)"
+msgid "Rotation angle (degrees counter-clockwise from East)"
+msgstr ""
+"Angle de rotation (en degrés, sens inverse des aiguilles d'une montre en "
+"partant de l'Est)"
-#~ msgid "Cannot select attribute."
-#~ msgstr "Impossible de sélectionner des données dans la table attributaire"
+msgid "Cannot select attribute."
+msgstr "Impossible de sélectionner des données dans la table attributaire"
 #, fuzzy
-#~ msgid "Creating vector grid..."
-#~ msgstr "Écriture du nouveau fichier cats..."
+msgid "Creating vector grid..."
+msgstr "Écriture du nouveau fichier cats..."
 # c-format
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Fichier vecteur introuvable : %s"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "Fichier vecteur introuvable : %s"
 # c-format
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 # c-format
 #, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d points  écrits dans la couche vecteur"
+msgid "[%d] features written"
+msgstr "%d points  écrits dans la couche vecteur"
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "incidout demande de fixer le paramètre d'heure"
+msgid "Parameter <%s> not set"
+msgstr "incidout demande de fixer le paramètre d'heure"
 #, fuzzy
-#~ msgid "Input map containing lines"
-#~ msgstr "Couche en entrée contenant les lignes"
+msgid "Input map containing lines"
+msgstr "Couche en entrée contenant les lignes"
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Couche en sortie où les points seront écrits"
+msgid "Output map where segments will be written"
+msgstr "Couche en sortie où les points seront écrits"
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "Impossible de trouver les informations sur la couche vectorielle"
+msgid "Cannot get layer information for vector map"
+msgstr "Impossible de trouver les informations sur la couche vectorielle"
 # c-format
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "fichier de cellules <%s> non trouvé"
+msgid "<%s> cellfile not found"
+msgstr "fichier de cellules <%s> non trouvé"
 # c-format
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
-#~ msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
+msgid "Database record for cat %d not found"
+msgstr "Aucun enregistrement pour la catégorie (cat = %d)"
 # c-format
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vecteur [%s]"
+msgid "Not able to open vector map <%s>"
+msgstr "Impossible d'ouvrir la couche vecteur [%s]"
-#~ msgid "No table."
-#~ msgstr "Pas de table."
+msgid "No table."
+msgstr "Pas de table."
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nom du pilote (driver)"
+msgid "driver name"
+msgstr "nom du pilote (driver)"
-#~ msgid "database name"
-#~ msgstr "nom de la base de donnée"
+msgid "database name"
+msgstr "nom de la base de donnée"
-#~ msgid "Driver name"
-#~ msgstr "Nom du pilote (driver)"
+msgid "Driver name"
+msgstr "Nom du pilote (driver)"
-#~ msgid "Cannot list databases."
-#~ msgstr "Impossible de lister les bases de données."
+msgid "Cannot list databases."
+msgstr "Impossible de lister les bases de données."
-#~ msgid "database location"
-#~ msgstr "Secteur (location) de la base de données"
+msgid "database location"
+msgstr "Secteur (location) de la base de données"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nom de table, tout sélectionner dans cette table"
+msgid "Table name, select all from this table"
+msgstr "Nom de table, tout sélectionner dans cette table"
-#~ msgid "output field separator"
-#~ msgstr "caractère de séparation de champs en sortie"
+msgid "output field separator"
+msgstr "caractère de séparation de champs en sortie"
-#~ msgid "output vertical record separator"
-#~ msgstr "caractère de séparation vertical d'enregistrements en sortie"
+msgid "output vertical record separator"
+msgstr "caractère de séparation vertical d'enregistrements en sortie"
-#~ msgid "null value indicator"
-#~ msgstr "indicateur de valeur vide ('null')"
+msgid "null value indicator"
+msgstr "indicateur de valeur vide ('null')"
-#~ msgid "do not include column names in output"
-#~ msgstr "ne pas inclure de nom de colonnes en sortie"
+msgid "do not include column names in output"
+msgstr "ne pas inclure de nom de colonnes en sortie"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "sortie verticale (à la place d'horizontale)"
+msgid "vertical output (instead of horizontal)"
+msgstr "sortie verticale (à la place d'horizontale)"
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr ""
-#~ "Nom du fichier raster existant\n"
-#~ "Nom de la couche raster existante"
+msgid "Name of existing raster map"
+msgstr ""
+"Nom du fichier raster existant\n"
+"Nom de la couche raster existante"
 # c-format
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Impossible de trouver le jeu de données (mapset) de %s"
+msgid "Cannot find mapset for %s"
+msgstr "Impossible de trouver le jeu de données (mapset) de %s"
 # c-format
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 # c-format
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
-#~ msgid "Label file [%s] not available"
-#~ msgstr "Fichier d'étiquette [%s] non disponible"
+msgid "Label file [%s] not available"
+msgstr "Fichier d'étiquette [%s] non disponible"
 # c-format
-#~ msgid "Can't open label file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier d'étiquettes pour %s"
+msgid "Can't open label file [%s]"
+msgstr "impossible d'ouvrir le fichier d'étiquettes pour %s"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
+msgid "unable to open [%s] in [%s]"
+msgstr "Impossible d'ouvrir la couche raster [%s] dans [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Table to be imported"
-#~ msgstr "Fichier raster à importer"
+msgid "Table to be imported"
+msgstr "Fichier raster à importer"
 # c-format
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "Impossible de créer la couche raster [%s]"
+msgid "Unable to create raster map [%s]"
+msgstr "Impossible de créer la couche raster [%s]"
 # c-format
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "impossible de créer la sortie <%s>"
+msgid "Unable to create output <%s>"
+msgstr "impossible de créer la sortie <%s>"
 # c-format
-#~ msgid "Input file [%s] not found."
-#~ msgstr "Le fichier en entrée [%s] n'a pas été trouvé."
+msgid "Input file [%s] not found."
+msgstr "Le fichier en entrée [%s] n'a pas été trouvé."
 # c-format
-#~ msgid "Unable to open output file <%s>."
-#~ msgstr "impossible d'ouvrir le fichier en sortie <%s>"
+msgid "Unable to open output file <%s>."
+msgstr "impossible d'ouvrir le fichier en sortie <%s>"
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "Multiplicateur pour les données ASCII"
+msgid "Multiplier for ascii data"
+msgstr "Multiplicateur pour les données ASCII"
 # c-format
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 # c-format
 #, fuzzy
-#~ msgid "unable to create raster"
-#~ msgstr "impossible de créer raster\n"
+msgid "unable to create raster"
+msgstr "impossible de créer raster\n"
 # c-format
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
-#~ msgstr "Impossible de créer la couche raster <%s>"
+msgid "Unable to create output raster map <%s>"
+msgstr "Impossible de créer la couche raster <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open file for <%s>"
+msgid "Cannot open file for <%s>"
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "Nom du relief aléatoire à produire"
+msgid "Name of the random surface to be produced"
+msgstr "Nom du relief aléatoire à produire"
 # c-format
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 # c-format
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr "Pas de connexion définie pour le pilote <%s>. Exécutez db.connect"
+msgid "No db connection for driver <%s> defined. Run db.connect."
+msgstr "Pas de connexion définie pour le pilote <%s>. Exécutez db.connect"
-#~ msgid "Table name"
-#~ msgstr "Nom de la table"
+msgid "Table name"
+msgstr "Nom de la table"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Affiche les paramètres de connexion courants et quitte (style script "
-#~ "shell)\n"
-#~ "\tformat:  couche[/nom de la couche] Table Clef primaire Base de données "
-#~ "PilotePilote"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr ""
+"Affiche les paramètres de connexion courants et quitte (style script shell)\n"
+"\tformat:  couche[/nom de la couche] Table Clef primaire Base de données "
+"PilotePilote"
-#~ msgid "x column name"
-#~ msgstr "Nom de la colonne x"
+msgid "x column name"
+msgstr "Nom de la colonne x"
-#~ msgid "z column name"
-#~ msgstr "Nom de la colonne z"
+msgid "z column name"
+msgstr "Nom de la colonne z"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
-#~ msgstr "Impossible d'ouvrir la table <%s>"
+msgid "Cannot drop table: %s"
+msgstr "Impossible d'ouvrir la table <%s>"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
-#~ msgstr "Impossible de sélectionner des données dans la table"
+msgid "Cannot fetch data from table"
+msgstr "Impossible de sélectionner des données dans la table"
 #, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "nom de la source de données OGR. Exemples\n"
-#~ "\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
-#~ "\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
+msgid ""
+"OGR output datasource name. For example:\n"
+"\t\tESRI Shapefile: filename or directory for storage\n"
+"\t\tMapInfo File: filename or directory for storage"
+msgstr ""
+"nom de la source de données OGR. Exemples\n"
+"\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
+"\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
 # c-format
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 # c-format
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "Lecture du fichier %s..."
+msgid "Querying input '%s' ... "
+msgstr "Lecture du fichier %s..."
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Vérification des points vecteurs..."
+msgid "Copying %s input lines ... "
+msgstr "Vérification des points vecteurs..."
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 # c-format
-#~ msgid "no record for cat = %d"
-#~ msgstr "Aucun enregistrement pour cat = %d"
+msgid "no record for cat = %d"
+msgstr "Aucun enregistrement pour cat = %d"
-#~ msgid "cannot insert row: %s"
-#~ msgstr "Impossible d'insérer une nouvelle ligne : %s"
+msgid "cannot insert row: %s"
+msgstr "Impossible d'insérer une nouvelle ligne : %s"
 # c-format
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "couche vectorielle d'entrée introuvable [%s]"
+msgid "Cannot find line of cat %d"
+msgstr "couche vectorielle d'entrée introuvable [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 # c-format
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr ""
-#~ "La connexion à la base de données n'a pas été définie pour la couche <%"
-#~ "d>. Utilisez d'abord v.db.connect."
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgstr ""
+"La connexion à la base de données n'a pas été définie pour la couche <%d>. "
+"Utilisez d'abord v.db.connect."
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr ""
-#~ "Transforme une couche vectorielle d'un système de coordonnées vers un "
-#~ "autre système de coordonnées."
+msgid "Transforms a vector map via a set of tie points."
+msgstr ""
+"Transforme une couche vectorielle d'un système de coordonnées vers un autre "
+"système de coordonnées."
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file holding transform coordinates (if not given transformation "
-#~ "options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be "
-#~ "used instead)"
-#~ msgstr ""
-#~ "A la place des points, utilisez les options de transformation (xshift, "
-#~ "yshift, zshift, xscale, yscale, zscale, zrot)"
+msgid ""
+"ASCII file holding transform coordinates (if not given transformation "
+"options [xshift, yshift, zshift, xscale, yscale, zscale, zrot] will be used "
+"instead)"
+msgstr ""
+"A la place des points, utilisez les options de transformation (xshift, "
+"yshift, zshift, xscale, yscale, zscale, zrot)"
 #, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
+msgid "Read coordinates from standard input"
+msgstr "Les coordonnées XY du/des foyer(s) initial(aux)"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "couche raster <%s> non trouvée"
+msgid "Raster map <%s>] not found"
+msgstr "couche raster <%s> non trouvée"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Impossible de lancer le pilote '%s'."
+msgid "Cannot start driver '%s'."
+msgstr "Impossible de lancer le pilote '%s'."
-#~ msgid "Cannot describe table"
-#~ msgstr "Impossible de décrire la table"
+msgid "Cannot describe table"
+msgstr "Impossible de décrire la table"
 # c-format
-#~ msgid "Cannot start driver <%s>."
+msgid "Cannot start driver <%s>."
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] n'est pas un nom légal"
+msgid "[%s] is an illegal name"
+msgstr "[%s] n'est pas un nom légal"
 # c-format
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Impossible d'écrire dans : %s"
+msgid "Cannot write to <%s>"
+msgstr "Impossible d'écrire dans : %s"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 # c-format
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "La couche raster [%s] n'est pas disponible"
+msgid "Raster map [%s] not available"
+msgstr "La couche raster [%s] n'est pas disponible"
-#~ msgid "color file for [%s] not available"
-#~ msgstr "Fichier de couleur de [%s] non disponible"
+msgid "color file for [%s] not available"
+msgstr "Fichier de couleur de [%s] non disponible"
 # c-format
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Fichier(s) raster [%s] non disponible"
+msgid "Raster file [%s] not available"
+msgstr "Fichier(s) raster [%s] non disponible"
 # c-format
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "Couche raster [%s] non trouvée"
+msgid "Raster map [%s] not found"
+msgstr "Couche raster [%s] non trouvée"
 # c-format
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir la couche raster [%s]"
+msgid "Unable to open raster map [%s]"
+msgstr "Impossible d'ouvrir la couche raster [%s]"
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
 # c-format
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Impossible d'utiliser le pilote %s"
+msgid "Cannot open driver %s"
+msgstr "Impossible d'utiliser le pilote %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "%s: <%s> nom illégal"
+msgid "<%s> illegal name"
+msgstr "%s: <%s> nom illégal"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Mémoire insuffisante!\n"
+msgid "Out of Memory!\n"
+msgstr "Mémoire insuffisante!\n"
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "%s: %s - impossible d'ouvrir la couche raster en entrée\n"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "%s: %s - impossible d'ouvrir la couche raster en entrée\n"
-#~ msgid "Insufficent memory for allocation of data sturcture"
-#~ msgstr "Mémoire insuffisante pour l'allocation de la structure de données"
+msgid "Insufficent memory for allocation of data sturcture"
+msgstr "Mémoire insuffisante pour l'allocation de la structure de données"
-#~ msgid "%s: %s - illegal name for output raster map."
-#~ msgstr "%s: %s - nom illégal de la couche raster en sortie"
+msgid "%s: %s - illegal name for output raster map."
+msgstr "%s: %s - nom illégal de la couche raster en sortie"
-#~ msgid "Insufficent memory for allocation of data structure."
-#~ msgstr "Mémoire insuffisante pour allouer la structure de données."
+msgid "Insufficent memory for allocation of data structure."
+msgstr "Mémoire insuffisante pour allouer la structure de données."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "Exporte un raster GRASS en différents formats (requiert GDAL)"
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "Exporte un raster GRASS en différents formats (requiert GDAL)"
-#~ msgid "Couldn't find raster map %s"
-#~ msgstr "Fichier raster introuvable : %s"
+msgid "Couldn't find raster map %s"
+msgstr "Fichier raster introuvable : %s"
 # c-format
-#~ msgid "%s: <%s> not found"
-#~ msgstr "%s: <%s> non trouvé"
+msgid "%s: <%s> not found"
+msgstr "%s: <%s> non trouvé"
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
 # c-format
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "%s: Impossible d'ouvrir <%s>"
+msgid "%s: Cannot open <%s>"
+msgstr "%s: Impossible d'ouvrir <%s>"
-#~ msgid "CREATING SUPPORT FILES ..."
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT..."
+msgid "CREATING SUPPORT FILES ..."
+msgstr "CREATION DE FICHIERS DE SUPPORT..."
-#~ msgid "<%s> is not a valid GRASS map name"
-#~ msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
+msgid "<%s> is not a valid GRASS map name"
+msgstr "<%s> n'est pas un nom valide pour une couche GRASS"
 # c-format
-#~ msgid "Cannot find %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s"
+msgid "Cannot find %s"
+msgstr "Impossible d'ouvrir la base de données %s"
-#~ msgid "could not read range file"
-#~ msgstr "Impossible de lire le fichier d'intervalle"
+msgid "could not read range file"
+msgstr "Impossible de lire le fichier d'intervalle"
-#~ msgid "OUT OF MEMORY !!!\n"
-#~ msgstr "MEMOIRE INSUFFISANTE !!!\n"
+msgid "OUT OF MEMORY !!!\n"
+msgstr "MEMOIRE INSUFFISANTE !!!\n"
 # c-format
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
+msgid "Open raster map %s in %s = %d"
+msgstr "Ouvrir le fichier raster 3D %s"
 #, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "couche raster de couverture"
+msgid "Closing raster map"
+msgstr "couche raster de couverture"
 # c-format
 #, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "Impossible d'ouvrir le fichier temporaire %s"
+msgid "Swap temp files"
+msgstr "Impossible d'ouvrir le fichier temporaire %s"
 # c-format
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
-#~ msgstr "%s - nom illégal"
+msgid "%s: illegal map name"
+msgstr "%s - nom illégal"
-#~ msgid "Name of the new raster map"
-#~ msgstr "Nom du nouveau fichier raster"
+msgid "Name of the new raster map"
+msgstr "Nom du nouveau fichier raster"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 # c-format
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr ""
-#~ "impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%"
-#~ "s>"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr ""
+"impossible d'ouvrir le fichier d'étiquettes <%s> dans le jeu de données <%s>"
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr ""
-#~ "Convertit une couche Raster GRASS en un fichier d'image PPM où la "
-#~ "résolution est celle de la région actuelle."
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr ""
+"Convertit une couche Raster GRASS en un fichier d'image PPM où la résolution "
+"est celle de la région actuelle."
-#~ msgid "Raster input map"
-#~ msgstr "couche raster d'entrée"
+msgid "Raster input map"
+msgstr "couche raster d'entrée"
-#~ msgid "Mapset of input map"
-#~ msgstr "Jeu de données (mapset) de la couche source"
+msgid "Mapset of input map"
+msgstr "Jeu de données (mapset) de la couche source"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "couche raster en entrée"
+msgid "Checking location %s, mapset %s:"
+msgstr "couche raster en entrée"
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgstr "groupe [%s] ciblé dans le Secteur [%s], jeu de données [%s]\n"
 #, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "Couche résultat en sortie"
+msgid "Error writing output map"
+msgstr "Couche résultat en sortie"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "Aucune couche de données spécifiée"
+msgid "no rules specified"
+msgstr "Aucune couche de données spécifiée"
 # c-format
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "impossible d'ouvrir le fichier temporaire %s"
+msgid "Can't open temp file [%s]"
+msgstr "impossible d'ouvrir le fichier temporaire %s"
-#~ msgid "Names of existing raster maps"
-#~ msgstr "Noms de fichiers raster existants"
+msgid "Names of existing raster maps"
+msgstr "Noms de fichiers raster existants"
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
-#~ msgstr ""
-#~ "Impossible d'ouvrir la couche en entrée <%s> dans le jeu de données <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr ""
+"Impossible d'ouvrir la couche en entrée <%s> dans le jeu de données <%s>"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 # c-format
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster"
+msgid "%s in %s -can't open raster map"
+msgstr "%s - impossible d'ouvrir le fichier raster"
 # c-format
 #, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgstr "%s - impossible d'ouvrir le fichier raster cellhd"
+msgid "%s - can't create raster map"
+msgstr "%s - impossible d'ouvrir le fichier raster cellhd"
-#~ msgid "%s=%s - illegal name"
-#~ msgstr "%s=%s - nom illégal"
+msgid "%s=%s - illegal name"
+msgstr "%s=%s - nom illégal"
 # c-format
-#~ msgid "%s: can't create %s"
-#~ msgstr "%s : Impossible de créer %s"
+msgid "%s: can't create %s"
+msgstr "%s : Impossible de créer %s"
-#~ msgid "Normalized"
-#~ msgstr "Normalisé"
+msgid "Normalized"
+msgstr "Normalisé"
 #, fuzzy
-#~ msgid "Out of memory!"
-#~ msgstr "Mémoire insuffisante"
+msgid "Out of memory!"
+msgstr "Mémoire insuffisante"
 # c-format
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
-#~ msgid "Can't read current window parameters"
-#~ msgstr "Impossible de lire les paramètres de la fenêtre courante"
+msgid "Can't read current window parameters"
+msgstr "Impossible de lire les paramètres de la fenêtre courante"
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr ""
-#~ "Erreur de récupération des cellules nulles en entrée à la ligne %d de %s"
+msgid "Error getting input null cells at row %d from %s"
+msgstr ""
+"Erreur de récupération des cellules nulles en entrée à la ligne %d de %s"
-#~ msgid "[%s] file name not legal"
+msgid "[%s] file name not legal"
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "[%s] n'est pas un nom légal\n"
+msgid "[%s] file name not legal\n"
+msgstr "[%s] n'est pas un nom légal\n"
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "Le fichier raster G3D <%s> demandé n'a pas été trouvé"
+msgid "Requested 3d raster map not found <%s>"
+msgstr "Le fichier raster G3D <%s> demandé n'a pas été trouvé"
 # c-format
 #, fuzzy
-#~ msgid "Could not open elevation map"
-#~ msgstr "Impossible d'ouvrir la couche de relief\n"
+msgid "Could not open elevation map"
+msgstr "Impossible d'ouvrir la couche de relief\n"
 #, fuzzy
-#~ msgid "Could not open output map"
-#~ msgstr "Impossible d'ouvrir la couche en sortie\n"
+msgid "Could not open output map"
+msgstr "Impossible d'ouvrir la couche en sortie\n"
-#~ msgid "unable to close output map"
-#~ msgstr "Impossible de fermer la couche de sortie"
+msgid "unable to close output map"
+msgstr "Impossible de fermer la couche de sortie"
 # c-format
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "Impossible de créer la couche cible : [%s]"
+msgid "Cannot create output map [%s]"
+msgstr "Impossible de créer la couche cible : [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "La connexion à la base de données n'a pas été définie"
+msgid "Database's name couldn't be read"
+msgstr "La connexion à la base de données n'a pas été définie"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
+msgid "Cannot open vector points map <%s>"
+msgstr "Impossible d'ouvrir la couche vectorielle de centroïdes"
 # c-format
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
 # c-format
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Could not find input map <%s> in current mapset."
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr ""
-#~ "Le fichier vecteur [%s] n'est pas disponible dans la liste de recherche"
+msgid "Vector file [%s] not available in search list"
+msgstr ""
+"Le fichier vecteur [%s] n'est pas disponible dans la liste de recherche"
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "Impossible d'ouvrir la base de données <%s>"
+msgid "Cannot open database <%s>"
+msgstr "Impossible d'ouvrir la base de données <%s>"
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 # c-format
-#~ msgid "Could not find input vector map %s"
-#~ msgstr "Couche d'entrée vecteur introuvable %s"
+msgid "Could not find input vector map %s"
+msgstr "Couche d'entrée vecteur introuvable %s"
-#~ msgid ""
-#~ "OGR layer name. If not given, all available layers are imported. "
-#~ "Examples:\n"
-#~ "\t\tESRI Shapefile: shapefile name\n"
-#~ "\t\tMapInfo File: mapinfo file name"
-#~ msgstr ""
-#~ "nom de la couche OGR. Si elle n'est pas spécifiée, toutes les couches "
-#~ "disponibles sont importées. Exemples:\n"
-#~ "\t\tShapefile ESRI : nom du shapefile\n"
-#~ "\t\tFichier MapInfo : nom du fichier mapinfo"
+msgid ""
+"OGR layer name. If not given, all available layers are imported. Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
+msgstr ""
+"nom de la couche OGR. Si elle n'est pas spécifiée, toutes les couches "
+"disponibles sont importées. Exemples:\n"
+"\t\tShapefile ESRI : nom du shapefile\n"
+"\t\tFichier MapInfo : nom du fichier mapinfo"
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "Le vecteur '%s' existe déjà."
+msgid "The vector '%s' already exists."
+msgstr "Le vecteur '%s' existe déjà."
 # c-format
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "couche d'entrée '%s' introuvable "
+msgid "Could not find input map '%s'."
+msgstr "couche d'entrée '%s' introuvable "
 # c-format
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "couche réseau d'entrée '%s' introuvable "
+msgid "Could not find network input map '%s'."
+msgstr "couche réseau d'entrée '%s' introuvable "
 # c-format
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Erreur d'ouverture de la couche raster [%s]."
+msgid "error opening raster map [%s]."
+msgstr "Erreur d'ouverture de la couche raster [%s]."
 #, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "La couche '%s' n'est pas disponible"
+msgid "Topology is not available"
+msgstr "La couche '%s' n'est pas disponible"
 # c-format
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "\tFichier du collage (patch) %s"
+msgid "Patching file <%s@%s>"
+msgstr "\tFichier du collage (patch) %s"
 # c-format
 #, fuzzy
-#~ msgid "[%d] files patched"
+msgid "[%d] files patched"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "impossible d'ouvrir le fichier vecteur <%s>"
+msgid "Could not open vector map <%s>"
+msgstr "impossible d'ouvrir le fichier vecteur <%s>"
 #, fuzzy
-#~ msgid "Name of output raster map"
-#~ msgstr ""
-#~ "Nom de la couche raster cible\n"
-#~ "Nom de la couche raster de sortie"
+msgid "Name of output raster map"
+msgstr ""
+"Nom de la couche raster cible\n"
+"Nom de la couche raster de sortie"
-#~ msgid "Done          "
-#~ msgstr "Terminé\t\t"
+msgid "Done          "
+msgstr "Terminé\t\t"
 # c-format
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
-#~ msgstr ""
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgstr ""
 #, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "classe %d (%d)\n"
+msgid "Pass [%d] of [%d]:"
+msgstr "classe %d (%d)\n"
-#~ msgid "Illegal output name: '%s'"
-#~ msgstr "Nom en sortie illégale : '%s'"
+msgid "Illegal output name: '%s'"
+msgstr "Nom en sortie illégale : '%s'"
-#~ msgid "Can't create output map"
-#~ msgstr "Impossible de créer la couche en sortie"
+msgid "Can't create output map"
+msgstr "Impossible de créer la couche en sortie"
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "Impossible de fermer la nouvelle couche g3d"
+msgid "Could not close new 3d raster map"
+msgstr "Impossible de fermer la nouvelle couche g3d"
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "%s: fichier de cellules [%s] non trouvé"
+msgid "%s: cellfile [%s] not found."
+msgstr "%s: fichier de cellules [%s] non trouvé"
-#~ msgid "Unable to open cellfile [%s]."
-#~ msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
+msgid "Unable to open cellfile [%s]."
+msgstr "Impossible d'ouvrir le fichier de cellules pour [%s]"
-#~ msgid "Error reading wildcard."
-#~ msgstr "Erreur de lecture de la wildcard"
+msgid "Error reading wildcard."
+msgstr "Erreur de lecture de la wildcard"
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr ""
-#~ "Fixe la couleur de la grille, soit une couleur GRASS standard, soit un "
-#~ "triplet R:G:B(séparé par le signe :)"
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr ""
+"Fixe la couleur de la grille, soit une couleur GRASS standard, soit un "
+"triplet R:G:B(séparé par le signe :)"
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr ""
-#~ "Fixe la couleur de la bordure, soit une couleur GRASS standard soit un "
-#~ "triplet R:G:B"
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr ""
+"Fixe la couleur de la bordure, soit une couleur GRASS standard soit un "
+"triplet R:G:B"
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr ""
-#~ "La bordure n'est pas encore implémentée dans les Secteurs latitude/"
-#~ "longitude : la bordure n'est pas tracée"
+msgid "Border not yet implemented for LatLong locations: border not drawn."
+msgstr ""
+"La bordure n'est pas encore implémentée dans les Secteurs latitude/"
+"longitude : la bordure n'est pas tracée"
-#~ msgid "Unable to open the temporary file."
-#~ msgstr "Impossible d'ouvrir le fichier temporaire"
+msgid "Unable to open the temporary file."
+msgstr "Impossible d'ouvrir le fichier temporaire"
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 # c-format
-#~ msgid "Unable to find raster [%s]."
-#~ msgstr "Fichier raster introuvable [%s]"
+msgid "Unable to find raster [%s]."
+msgstr "Fichier raster introuvable [%s]"
-#~ msgid "use regular expression instead of wildcard"
-#~ msgstr "utiliser une expression régulière à la place d'une wildcard"
+msgid "use regular expression instead of wildcard"
+msgstr "utiliser une expression régulière à la place d'une wildcard"
-#~ msgid "name for new raster map"
-#~ msgstr "Nom de la nouvelle couche raster"
+msgid "name for new raster map"
+msgstr "Nom de la nouvelle couche raster"
-#~ msgid "Output GRASS image file"
-#~ msgstr "Fichier d'image GRASS en sortie"
+msgid "Output GRASS image file"
+msgstr "Fichier d'image GRASS en sortie"
 #, fuzzy
-#~ msgid "Resulting output map"
-#~ msgstr "Résolution de la nouvelle couche"
+msgid "Resulting output map"
+msgstr "Résolution de la nouvelle couche"
 #, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "Nom du nouveau fichier vecteur binaire"
+msgid "name for new vector map"
+msgstr "Nom du nouveau fichier vecteur binaire"
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr ""
-#~ "Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
-#~ "stdout)"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr ""
+"Nom de la nouvelle couche vecteur (ne rien mettre pour l'affichage sur "
+"stdout)"
-#~ msgid "Input vector map"
-#~ msgstr "couche vecteur en entrée"
+msgid "Input vector map"
+msgstr "couche vecteur en entrée"
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "%s: ERREUR impossible d'ouvrir le fichier temporaire"
+msgid "%s: ERROR can't open tempfile"
+msgstr "%s: ERREUR impossible d'ouvrir le fichier temporaire"
-#~ msgid "vector map <%s> not found"
+msgid "vector map <%s> not found"
 # c-format
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"color\" specified - ignoring color"
-#~ msgstr ""
-#~ "L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
+msgid "Both \"-i\" AND \"color\" specified - ignoring color"
+msgstr ""
+"L'une des options \"color\", \"rast\" OU \"rules\" DOIT être spécifiée!"
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
+msgid "Both \"-i\" AND \"rules\" specified - ignoring rules"
+msgstr ""
 #, fuzzy
-#~ msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
+msgid "Both \"-i\" AND \"raster\" specified - ignoring raster"
+msgstr ""
 #, fuzzy
-#~ msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
-#~ msgstr ""
+msgid "Both options \"color\" AND \"raster\" specified - ignoring raster"
+msgstr ""
 #, fuzzy
-#~ msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
-#~ msgstr ""
+msgid "Both options \"color\" AND \"rules\" specified - ignoring rules"
+msgstr ""
 #, fuzzy
-#~ msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
-#~ msgstr ""
+msgid "Both options \"raster\" AND \"rules\" specified - ignoring raster"
+msgstr ""
-#~ msgid "<%s> raster map not found"
-#~ msgstr "<%s> fichier raster introuvable"
+msgid "<%s> raster map not found"
+msgstr "<%s> fichier raster introuvable"
 # c-format
-#~ msgid "<%s> unable to open raster map"
-#~ msgstr "<%s> impossible d'ouvrir le fichier raster"
+msgid "<%s> unable to open raster map"
+msgstr "<%s> impossible d'ouvrir le fichier raster"
 # c-format
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 # c-format
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
 # c-format
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
+msgid "Can't get row %d from raster map %s"
+msgstr "Impossible d'accéder à la ligne %d de la couche raster %s"
 # c-format
-#~ msgid "%s - raster map not found"
-#~ msgstr "%s - couche raster non trouvée"
+msgid "%s - raster map not found"
+msgstr "%s - couche raster non trouvée"
-#~ msgid "string representing no data cell value"
-#~ msgstr "chaîne représentant les cellules sans données"
+msgid "string representing no data cell value"
+msgstr "chaîne représentant les cellules sans données"
-#~ msgid "File name of classification result"
-#~ msgstr "Nom de fichier du résultat de la classification"
+msgid "File name of classification result"
+msgstr "Nom de fichier du résultat de la classification"
-#~ msgid "File name of reference classes"
-#~ msgstr "Nom de fichier des classes de référence"
+msgid "File name of reference classes"
+msgstr "Nom de fichier des classes de référence"
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "rapport étendu, 132 colonnes (80 par défaut)"
+msgid "wide report, 132 columns (default: 80)"
+msgstr "rapport étendu, 132 colonnes (80 par défaut)"
-#~ msgid "quiet"
-#~ msgstr "silencieux"
+msgid "quiet"
+msgstr "silencieux"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "%s -- Nom du fichier de sortie illégal"
+msgid "<%s> - illegal output file name"
+msgstr "%s -- Nom du fichier de sortie illégal"
 # c-format
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "%s: couche de référence <%s> introuvable"
+msgid "%s: <%s> reference map not found"
+msgstr "%s: couche de référence <%s> introuvable"
-#~ msgid "Base raster map"
-#~ msgstr "couche raster de base"
+msgid "Base raster map"
+msgstr "couche raster de base"
 # c-format
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
-#~ msgid ""
-#~ "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr ""
-#~ "La couche raster qui représente l'altitude, utilisée pour l'information 3D"
+msgid "Raster map that represents the elevation, used for the 3D information"
+msgstr ""
+"La couche raster qui représente l'altitude, utilisée pour l'information 3D"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "Erreur d'ouverture du fichier d'affichage [%s]"
+msgid "Problem opening input file [%s]"
+msgstr "Erreur d'ouverture du fichier d'affichage [%s]"
 # c-format
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 # c-format
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
-#~ msgid "Elevation map"
-#~ msgstr "couche d'altitude"
+msgid "Elevation map"
+msgstr "couche d'altitude"
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "couche d'indice topographique ln(a/tan(beta))"
+msgid "Topographic index ln(a/tanB) map"
+msgstr "couche d'indice topographique ln(a/tan(beta))"
-#~ msgid "Output verbosely"
-#~ msgstr "Détails de l'exécution"
+msgid "Output verbosely"
+msgstr "Détails de l'exécution"
 # c-format
-#~ msgid "Can't open raster map %s"
-#~ msgstr "Impossible d'ouvrir le fichier raster %s"
+msgid "Can't open raster map %s"
+msgstr "Impossible d'ouvrir le fichier raster %s"
-#~ msgid "CREATING SUPPORT FILES"
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT"
+msgid "CREATING SUPPORT FILES"
+msgstr "CREATION DE FICHIERS DE SUPPORT"
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "ALTITUDE pour le jeu de données [%s] dans [%s]"
+msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
+msgstr "ALTITUDE pour le jeu de données [%s] dans [%s]"
 # c-format
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 # c-format
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "Le vecteur en entrée n'a pas été trouvé."
+msgid "Input vector map <%s> not found."
+msgstr "Le vecteur en entrée n'a pas été trouvé."
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "Intervalle de catégories. Exemple : 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
+msgstr "Intervalle de catégories. Exemple : 1,3-8,13"
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "Écriture des attributs...\n"
+msgid "Writing attributes ...\n"
+msgstr "Écriture des attributs...\n"
 # c-format
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#~ msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
+msgid "Could not open ascii file <%s>"
+msgstr "Impossible d'ouvrir le fichier ascii : [%s]"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
-#~ msgid "List available formats and exit"
-#~ msgstr "Lister les formats disponibles et quitter"
+msgid "List available formats and exit"
+msgstr "Lister les formats disponibles et quitter"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "Fichier DXF source"
+msgid "SVG output file"
+msgstr "Fichier DXF source"
 # c-format
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Impossible de trouver la couche vecteur %s"
+msgid "Could not find vector '%s'"
+msgstr "Impossible de trouver la couche vecteur %s"
 # c-format
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 # c-format
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
 #, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "Coordonnées de la carte"
+msgid "No input coordinates provided"
+msgstr "Coordonnées de la carte"
-#~ msgid "Unable to allocate memory."
-#~ msgstr "Impossible d'allouer la mémoire."
+msgid "Unable to allocate memory."
+msgstr "Impossible d'allouer la mémoire."
-#~ msgid "Raster output file"
-#~ msgstr "couche raster de sortie"
+msgid "Raster output file"
+msgstr "couche raster de sortie"
 #, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
+msgid "Pass #%d (of %d) ... "
 # c-format
 #, fuzzy
-#~ msgid "Writing raster map ... "
-#~ msgstr "Couche raster %i créée \n"
+msgid "Writing raster map ... "
+msgstr "Couche raster %i créée \n"
-#~ msgid "Keep existing color table"
-#~ msgstr "Garder la table de couleurs existante"
+msgid "Keep existing color table"
+msgstr "Garder la table de couleurs existante"
-#~ msgid "List rules"
-#~ msgstr "Lister les règles"
+msgid "List rules"
+msgstr "Lister les règles"
-#~ msgid "Verbose mode."
-#~ msgstr "Détails de l'exécution."
+msgid "Verbose mode."
+msgstr "Détails de l'exécution."
 # c-format
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d lignes, %d colonnes"
+msgid " %d rows, %d cols."
+msgstr "%d lignes, %d colonnes"
 #, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule entier.\n"
-#~ "Ecriture..."
+msgid ""
+"Integer cell type.\n"
+"Writing"
+msgstr ""
+"Type de cellule entier.\n"
+"Ecriture..."
 #, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule flottant.\n"
-#~ "Ecriture..."
+msgid ""
+"Float cell type.\n"
+"Writing"
+msgstr ""
+"Type de cellule flottant.\n"
+"Ecriture..."
 #, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr ""
-#~ "Type de cellule double.\n"
-#~ "Ecriture..."
+msgid ""
+"Double cell type.\n"
+"Writing"
+msgstr ""
+"Type de cellule double.\n"
+"Ecriture..."
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 # c-format
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
-#~ msgstr "Impossible d'écrire les fichiers temporaires"
+msgid "%s - unable to create category file"
+msgstr "Impossible d'écrire les fichiers temporaires"
-#~ msgid "verbose mode"
+msgid "verbose mode"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nom de la couche de points vecteurs en entrée pour laquelle éditer la "
-#~ "table attributaire"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr ""
+"Nom de la couche de points vecteurs en entrée pour laquelle éditer la table "
+"attributaire"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour "
-#~ "la table attributaire"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr ""
+"Nom de la couche de points vecteurs en entrée pour laquelle mettre à jour la "
+"table attributaire"
 #, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "Impossible d'ouvrir le fichier de sortie"
+msgid "Path to an output file"
+msgstr "Impossible d'ouvrir le fichier de sortie"
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nom de la couche raster existante à afficher"
+msgid "Name of existing raster map to be displayed"
+msgstr "Nom de la couche raster existante à afficher"
-#~ msgid "driver name:"
-#~ msgstr "nom du pilote :"
+msgid "driver name:"
+msgstr "nom du pilote :"
-#~ msgid "Database name:"
-#~ msgstr "Nom de la base de donnée :"
+msgid "Database name:"
+msgstr "Nom de la base de donnée :"
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr ""
-#~ "Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est "
-#~ "indiqué prendreles paramètres saisis en ligne de commande"
+msgid ""
+"ASCII file to be converted to binary vector map, if not given (or \"-\") "
+"reads from standard input"
+msgstr ""
+"Fichier ASCII à convertir en fichier vecteur binaire, si rien n'est indiqué "
+"prendreles paramètres saisis en ligne de commande"
 # c-format
-#~ msgid "could not find input map <%s>"
-#~ msgstr "couche d'entrée introuvable <%s>"
+msgid "could not find input map <%s>"
+msgstr "couche d'entrée introuvable <%s>"
 # c-format
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "Impossible d'ouvrir le fichier de cellules [%s]"
+msgid "unable to open raster map [%s]"
+msgstr "Impossible d'ouvrir le fichier de cellules [%s]"
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr ""
-#~ "Impossible de récupérer les informations de la couche pour cette couche "
-#~ "vectorielle"
+msgid "cannot get layer info for vector map"
+msgstr ""
+"Impossible de récupérer les informations de la couche pour cette couche "
+"vectorielle"
-#~ msgid "cannot open database %s by driver %s"
-#~ msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
+msgid "cannot open database %s by driver %s"
+msgstr "Impossible d'ouvrir la base de données %s avec le pilote %s"
-#~ msgid "column type not supported"
-#~ msgstr "Type de colonne non géré"
+msgid "column type not supported"
+msgstr "Type de colonne non géré"
-#~ msgid "cannot select data from table"
+msgid "cannot select data from table"
-#~ msgid "cannot create table: %s"
-#~ msgstr "Impossible de créer la table: %s"
+msgid "cannot create table: %s"
+msgstr "Impossible de créer la table: %s"
-#~ msgid "cannot create index"
+msgid "cannot create index"
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "Impossible d'accorder des privilèges sur la table: %s"
+msgid "cannot grant privileges on table %s"
+msgstr "Impossible d'accorder des privilèges sur la table: %s"
-#~ msgid "Cannot find vector map"
-#~ msgstr "Impossible de trouver la couche vecteur"
+msgid "Cannot find vector map"
+msgstr "Impossible de trouver la couche vecteur"
-#~ msgid "Cannot find raster map"
-#~ msgstr "Impossible de trouver la couche raster"
+msgid "Cannot find raster map"
+msgstr "Impossible de trouver la couche raster"
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
-#~ msgid ""
-#~ "Number of column used as z coordinate (first column is 1) for points "
-#~ "mode. If 0, z coordinate is not used."
-#~ msgstr ""
-#~ "Nombre de colonnes utilisées comme coordonnées x (la première colonne est "
-#~ "1) en mode pointsSi la valeur est 0, les coordonnées z ne sont pas "
-#~ "utilisées."
+msgid ""
+"Number of column used as z coordinate (first column is 1) for points mode. "
+"If 0, z coordinate is not used."
+msgstr ""
+"Nombre de colonnes utilisées comme coordonnées x (la première colonne est 1) "
+"en mode pointsSi la valeur est 0, les coordonnées z ne sont pas utilisées."
 # c-format
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "Mot-clef inconnu [%s] dans l'en-tête de vecteur"
+msgid "Unknown keyword [%s] in vector head."
+msgstr "Mot-clef inconnu [%s] dans l'en-tête de vecteur"
-#~ msgid "#%s"
-#~ msgstr "#%s"
+msgid "#%s"
+msgstr "#%s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "Erreur de lecture de la couche raster en entrée"
+msgid "Error while reading cell map."
+msgstr "Erreur de lecture de la couche raster en entrée"
 #, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Erreur de suppression de l'ancienne couche MASK."
+msgid "Error while writing new cell map."
+msgstr "Erreur de suppression de l'ancienne couche MASK."
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
-#~ msgstr "Impossible d'ouvrir la couche raster <%s>"
+msgid "Unable to find input cell map <%s>"
+msgstr "Impossible d'ouvrir la couche raster <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Error in opening input file <%s>"
-#~ msgid "Unable to open cell man <%s> for input.\n"
-#~ msgstr "impossible d'ouvrir le fichier de cellule <%s> en entrée.\n"
+msgid "Unable to open cell man <%s> for input.\n"
+msgstr "impossible d'ouvrir le fichier de cellule <%s> en entrée.\n"
-#~ msgid "Unable to open cell map <%s> for output.\n"
-#~ msgstr "Impossible d'ouvrir la couche de cellule <%s> en sortie.\n"
+msgid "Unable to open cell map <%s> for output.\n"
+msgstr "Impossible d'ouvrir la couche de cellule <%s> en sortie.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
-#~ msgstr "Impossible de lire la ligne raster."
+msgid "Unable to read map raster row %d"
+msgstr "Impossible de lire la ligne raster."
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "Impossible de lire la table de couleur %s"
+msgid "Unable to write color table to raster [%s]"
+msgstr "Impossible de lire la table de couleur %s"
 # c-format
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
 # c-format
 #, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgstr "Impossible d'ouvrir %s"
+msgid "Cannot open map %s"
+msgstr "Impossible d'ouvrir %s"
-#~ msgid "Name of predefined rules file"
-#~ msgstr "Nom du fichier de règles prédéfinies"
+msgid "Name of predefined rules file"
+msgstr "Nom du fichier de règles prédéfinies"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites "
-#~ "[0..255]: %d:%d:%d **\n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr ""
+"** attention: la(es) valeur(s) R:V:B est(sont) en dehors des limites "
+"[0..255]: %d:%d:%d **\n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attention: la(es) valeur(s) R V B est(sont) en dehors des limites "
-#~ "[0..255]: %d %d %d **\n"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr ""
+"** attention: la(es) valeur(s) R V B est(sont) en dehors des limites "
+"[0..255]: %d %d %d **\n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attention: aucune valeur **\n"
+msgid "no such value"
+msgstr "** attention: aucune valeur **\n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:ligne %d:%s\n"
+msgid "%s:line %d:%s"
+msgstr "%s:ligne %d:%s\n"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** mauvaise indication de couleur **\n"
+msgid "bad color specification"
+msgstr "** mauvaise indication de couleur **\n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - couleur inconnue\n"
+msgid "%s - unknown color"
+msgstr "%s - couleur inconnue\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "Les couleurs valides sont:\n"
+msgid "Valid colors are:\n"
+msgstr "Les couleurs valides sont:\n"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "Unable to find base map <%s>"
 # c-format
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
-#~ msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
+msgid "%s: reading category file for %s"
+msgstr "%s: ERREUR de lecture du fichier de catégorie pour %s"
 # c-format
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
 # c-format
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "%s: unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
 # c-format
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 # c-format
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
 # c-format
-#~ msgid "Unable to find [%s]."
-#~ msgstr "impossible de trouver [%s]"
+msgid "Unable to find [%s]."
+msgstr "impossible de trouver [%s]"
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
 # c-format
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "Impossible d'ouvrir la couche %s"
+msgid "Could not open raster <%s>"
+msgstr "Impossible d'ouvrir la couche %s"
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr ""
-#~ "Coordonnées de l'écran pour le placement de la légende (exprimées en "
-#~ "pourcentage)"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr ""
+"Coordonnées de l'écran pour le placement de la légende (exprimées en "
+"pourcentage)"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nom de police (non géré en mode interactif, voir aussi le drapeau -l) ou "
-#~ "chemin vers une police TrueType (nom de fichier inclus)"
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"Nom de police (non géré en mode interactif, voir aussi le drapeau -l) ou "
+"chemin vers une police TrueType (nom de fichier inclus)"
 # c-format
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "fichier de cellules slopein <%s> non trouvé"
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "fichier de cellules slopein <%s> non trouvé"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 # c-format
 #, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "Aucun enregistrement pour la ligne (cat = %d)"
+msgid "No record for category for [%d]"
+msgstr "Aucun enregistrement pour la ligne (cat = %d)"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "Erreur de lecture du fichier cats de <%s>"
+msgid "Error reading ASCII file <%s>"
+msgstr "Erreur de lecture du fichier cats de <%s>"
 #, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error reading categories: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "couche: %d\n"
-#~ "catégorie: %d\n"
+msgid "category [%d]"
+msgstr ""
+"couche: %d\n"
+"catégorie: %d\n"
 #, fuzzy
-#~ msgid "No lines found"
-#~ msgstr ""
-#~ "\n"
-#~ "Aucune couche DXF trouvée!\n"
+msgid "No lines found"
+msgstr ""
+"\n"
+"Aucune couche DXF trouvée!\n"
 #, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "Sélectionner le type: ligne ou surface"
+msgid "List of point coordinates. Required for add and move actions."
+msgstr "Sélectionner le type: ligne ou surface"
 # c-format
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Could not find input vector '%s'"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "Nom du fichier vecteur de sortie"
+msgid "Failed opening output vector map '%s'"
+msgstr "Nom du fichier vecteur de sortie"
-#~ msgid "Do not create attribute table."
-#~ msgstr "Ne pas créer de table attributaire."
+msgid "Do not create attribute table."
+msgstr "Ne pas créer de table attributaire."
-#~ msgid "Could not find input %s\n"
-#~ msgstr "Entrée introuvable %s\n"
+msgid "Could not find input %s\n"
+msgstr "Entrée introuvable %s\n"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "Lister les couches raster de l'emplacement source et quitter"
+msgid ""
+"List vector maps in input location and exit (a dummy value must be given for "
+"input)"
+msgstr "Lister les couches raster de l'emplacement source et quitter"
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr ""
-#~ "Permet à l'utilisateur de requêter de façon interactive une couche "
-#~ "vectorielle sur des positions choisies par l'utilisateur dans la région "
-#~ "géographique courante"
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region"
+msgstr ""
+"Permet à l'utilisateur de requêter de façon interactive une couche "
+"vectorielle sur des positions choisies par l'utilisateur dans la région "
+"géographique courante"
 #, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "                couche courante                  Nouvelle couche\n"
+msgid "| Tool                            | Threshold     |"
+msgstr "                couche courante                  Nouvelle couche\n"
 #, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr ""
-#~ "                          VÉRIFICATION DES RÉSIDUS DE LA COUCHE\n"
-#~ "\n"
+msgid "| Break                           |  "
+msgstr ""
+"                          VÉRIFICATION DES RÉSIDUS DE LA COUCHE\n"
+"\n"
 #, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr ""
-#~ "\n"
+msgid "| Prune                           |  "
+msgstr ""
+"\n"
-#~ msgid "Patch complete. %d files patched."
-#~ msgstr "Collage achevé. Les fichiers %d sont collés."
+msgid "Patch complete. %d files patched."
+msgstr "Collage achevé. Les fichiers %d sont collés."
 # c-format
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "%s : couche vecteur <%s> introuvable"
+msgid "%s: <%s> vector map not found"
+msgstr "%s : couche vecteur <%s> introuvable"
 # c-format
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "couche vecteur <%s> introuvable"
+msgid "Vector <%s> could not be open"
+msgstr "couche vecteur <%s> introuvable"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "raster <%s> non trouvé"
+msgid "Raster <%s> could not be open."
+msgstr "raster <%s> non trouvé"
 #, fuzzy
-#~ msgid "CrossCorrelation()"
-#~ msgstr "Corrélation"
+msgid "CrossCorrelation()"
+msgstr "Corrélation"
 #, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "Méthode d'interpolation à utiliser"
+msgid "Interpolation()"
+msgstr "Méthode d'interpolation à utiliser"
 #, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "Paramétrage de la fenêtre graphique"
+msgid "Interpolation: Setting regions and boxes"
+msgstr "Paramétrage de la fenêtre graphique"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#~ msgstr "Nombre de points d'interpolation"
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgstr "Nombre de points d'interpolation"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
 # c-format
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "Interpolation was a success!"
 # c-format
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "%d points en dehors de la région courante"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "%d points en dehors de la région courante"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgid "Subgroup [%s] doesn't have any files."
-#~ msgstr "Le sous-groupe [%s] ne comprend aucun fichier"
+msgid "Subgroup [%s] doesn't have any files."
+msgstr "Le sous-groupe [%s] ne comprend aucun fichier"
-#~ msgid "Subgroup [%s] only has 1 file."
-#~ msgstr "Le sous-groupe [%s] ne comprend qu'un seul fichier"
+msgid "Subgroup [%s] only has 1 file."
+msgstr "Le sous-groupe [%s] ne comprend qu'un seul fichier"
-#~ msgid "%s -- illegal output file name"
+msgid "%s -- illegal output file name"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr ""
-#~ "\n"
-#~ "Désolé, vous devez choisir une couche en sortie."
+msgid "Sorry, with method '%s' you have to define an output map."
+msgstr ""
+"\n"
+"Désolé, vous devez choisir une couche en sortie."
 # c-format
 #, fuzzy
-#~ msgid "Writing "
-#~ msgstr "Écriture %s..."
+msgid "Writing "
+msgstr "Écriture %s..."
-#~ msgid "%s: %s in %s - can't read category file"
-#~ msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
+msgid "%s: %s in %s - can't read category file"
+msgstr "%s: %s dans %s - impossible de lire le fichier de catégorie"
 #, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "Calcul des moyennes de classes..."
+msgid "Calculation time"
+msgstr "Calcul des moyennes de classes..."
 #, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "Nombre maximum d'itération"
+msgid "Maximum number of iteration"
+msgstr "Nombre maximum d'itération"
-#~ msgid "Finished.\n"
-#~ msgstr "Terminé.\n"
+msgid "Finished.\n"
+msgstr "Terminé.\n"
 # c-format
-#~ msgid "Existing raster map name"
-#~ msgstr "Le nom du fichier raster existe déjà"
+msgid "Existing raster map name"
+msgstr "Le nom du fichier raster existe déjà"
 # c-format
-#~ msgid "%s - can't read raster cellhd"
+msgid "%s - can't read raster cellhd"
-#~ msgid "error reading cell data"
-#~ msgstr "Erreur de lecture des cellules de données"
+msgid "error reading cell data"
+msgstr "Erreur de lecture des cellules de données"
-#~ msgid "History line too long: truncating to %d characters"
-#~ msgstr "Ligne d'historique trop longue : tronquée à %d caractères"
+msgid "History line too long: truncating to %d characters"
+msgstr "Ligne d'historique trop longue : tronquée à %d caractères"
 #, fuzzy
-#~ msgid "Done!"
-#~ msgstr "Terminé"
+msgid "Done!"
+msgstr "Terminé"
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "Rien n'a été trouvé.\n"
+msgid "No line found."
+msgstr "Rien n'a été trouvé.\n"
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "Do not build topology."
-#~ msgstr "Ne construit pas de topologie en mode points"
+msgid "Do not build topology."
+msgstr "Ne construit pas de topologie en mode points"
 #, fuzzy
-#~ msgid "No features found"
-#~ msgstr ""
-#~ "\n"
+msgid "No features found"
+msgstr ""
+"\n"
 # c-format
-#~ msgid "Could not open ascii file [%s]"
+msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
-#~ msgstr "Fichier vecteur à créer"
+msgid "vector map to be created"
+msgstr "Fichier vecteur à créer"
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "%s: impossible d'ouvrir le fichier dxf"
+msgid "%s: Cannot open dxf file"
+msgstr "%s: impossible d'ouvrir le fichier dxf"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr ""
-#~ "\n"
-#~ "Conversion de %s en couche vectorielle:  "
+msgid "Conversion of [%s] to vector map ..."
+msgstr ""
+"\n"
+"Conversion de %s en couche vectorielle:  "
-#~ msgid "Finished"
+msgid "Finished"
+msgstr "Terminé"
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr ""
-#~ "Affiche les paramètres de la région courante (à la façon d'un script "
-#~ "shell)"
+msgid "Print the current region (shell script style)"
+msgstr ""
+"Affiche les paramètres de la région courante (à la façon d'un script shell)"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Où %s est un des:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Où %s est un des:\n"
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "%s: - cette base de données n'existe pas %s\n"
+msgid "%s: - no such database %s\n"
+msgstr "%s: - cette base de données n'existe pas %s\n"
-#~ msgid "must be even number of names"
-#~ msgstr "Les noms doivent être en nombre pair"
+msgid "must be even number of names"
+msgstr "Les noms doivent être en nombre pair"
 # c-format
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERREUR: <%s> non trouvé\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "ERREUR: <%s> non trouvé\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERREUR: <%s> - nom illégal\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "ERREUR: <%s> - nom illégal\n"
 # c-format
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Impossible d'ouvrir la boîte à outils %s"
+msgid "Cannot open toolbox: %s"
+msgstr "Impossible d'ouvrir la boîte à outils %s"
 # c-format
-#~ msgid "Cannot open toolbox."
-#~ msgstr "Impossible d'ouvrir la boîte à outils."
+msgid "Cannot open toolbox."
+msgstr "Impossible d'ouvrir la boîte à outils."
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "couche d'entrée introuvable <%s>\n"
+msgid "Could not find input map <%s>\n"
+msgstr "couche d'entrée introuvable <%s>\n"
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "'%s' a terminé la transformation des vecteurs.\n"
+msgid "'%s' has finished the transformation of the vectors.\n"
+msgstr "'%s' a terminé la transformation des vecteurs.\n"
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
+msgid ""
+"                          CHECK MAP RESIDUALS\n"
+"\n"
+msgstr ""
+"\n"
-#~ msgid "                Current Map                  New Map\n"
+msgid "                Current Map                  New Map\n"
-#~ msgid ""
-#~ " POINT      X coord    Y coord  |        X coord   Y coord    |      "
-#~ "residuals\n"
-#~ msgstr ""
-#~ " POINT      coord X   coordY |       coord X   coord Y    |      résidus\n"
+msgid ""
+" POINT      X coord    Y coord  |        X coord   Y coord    |      "
+"residuals\n"
+msgstr ""
+" POINT      coord X   coordY |       coord X   coord Y    |      résidus\n"
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "  Moyenne résiduelle   : %f\n"
+msgid "  Residual mean average   : %f\n"
+msgstr "  Moyenne résiduelle   : %f\n"
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "Couche(s) vectorielles -- source pour la composite"
+msgid "Vector map(s) -- source for composite"
+msgstr "Couche(s) vectorielles -- source pour la composite"
-#~ msgid "New vector composite"
-#~ msgstr "Nom du fichier vecoriel composite"
+msgid "New vector composite"
+msgstr "Nom du fichier vecoriel composite"
-#~ msgid "Append files to existing file"
-#~ msgstr "Modifie les fichier par rapport à un fichier existant"
+msgid "Append files to existing file"
+msgstr "Modifie les fichier par rapport à un fichier existant"
 #, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "nom de la base de donnée"
+msgid "No database updates."
+msgstr "nom de la base de donnée"
 #, fuzzy
-#~ msgid "Adding new features to vector file ..."
-#~ msgstr "Écriture du nouveau fichier cats..."
+msgid "Adding new features to vector file ..."
+msgstr "Écriture du nouveau fichier cats..."
 # c-format
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "Couche vecteur '%s' introuvable"
+msgid "Vector map '%s' not found"
+msgstr "Couche vecteur '%s' introuvable"
-#~ msgid "Input aspect file"
-#~ msgstr "Fichier d'aspect en entrée"
+msgid "Input aspect file"
+msgstr "Fichier d'aspect en entrée"
-#~ msgid "Input barrier file"
-#~ msgstr "Fichier source d'obstacles"
+msgid "Input barrier file"
+msgstr "Fichier source d'obstacles"
-#~ msgid "Quiet operation"
-#~ msgstr "Mode silencieux"
+msgid "Quiet operation"
+msgstr "Mode silencieux"
-#~ msgid "Display Reference Information"
-#~ msgstr "Afficher la position de référence"
+msgid "Display Reference Information"
+msgstr "Afficher la position de référence"
-#~ msgid ""
-#~ "Aspect file's resolution differs from                        current "
-#~ "region resolution"
-#~ msgstr ""
-#~ "Résolution de la couche en entrée ne correspond pas à la résolution de la "
-#~ "région courante!"
+msgid ""
+"Aspect file's resolution differs from                        current region "
+"resolution"
+msgstr ""
+"Résolution de la couche en entrée ne correspond pas à la résolution de la "
+"région courante!"
 #, fuzzy
-#~ msgid ""
-#~ "Calculates Simpson's diversity index on a raster map.\n"
-#~ "Return -1 if all the cells in the area are null"
-#~ msgstr ""
-#~ "Calcule un index de densité de patch sur un fichier raster, en utilisant "
-#~ "un algorithme de voisinage quatre"
+msgid ""
+"Calculates Simpson's diversity index on a raster map.\n"
+"Return -1 if all the cells in the area are null"
+msgstr ""
+"Calcule un index de densité de patch sur un fichier raster, en utilisant un "
+"algorithme de voisinage quatre"
 #, fuzzy
-#~ msgid ""
-#~ "Calculates Shannon's diversity index on a raster map\n"
-#~ msgstr ""
+msgid ""
+"Calculates Shannon's diversity index on a raster map\n"
+msgstr ""
 #, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map\n"
-#~ msgstr ""
+msgid ""
+"Calculates dominance's diversity index on a raster map\n"
+msgstr ""
 # c-format
-#~ msgid "%s\n"
-#~ msgstr "%s\n"
+msgid "%s\n"
+msgstr "%s\n"
 #, fuzzy
-#~ msgid ""
-#~ "Calculates dominance's diversity index on a raster map.\n"
-#~ msgstr ""
+msgid ""
+"Calculates dominance's diversity index on a raster map.\n"
+msgstr ""
 #, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Résolution"
+msgid "ILLEGAL Resolution!"
+msgstr "Résolution"
 #, fuzzy
-#~ msgid "input layer name"
-#~ msgstr "Nom de la couche source"
+msgid "input layer name"
+msgstr "Nom de la couche source"
 #, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "Nom de la couche de sortie"
+msgid "output layer name"
+msgstr "Nom de la couche de sortie"
 #, fuzzy
-#~ msgid "Transforming data..."
-#~ msgstr "Rotation des données ... "
+msgid "Transforming data..."
+msgstr "Rotation des données ... "
-#~ msgid "Hit RETURN -->"
-#~ msgstr "Tapez ENTREE -->"
+msgid "Hit RETURN -->"
+msgstr "Tapez ENTREE -->"
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr ""
-#~ "\a\n"
-#~ "** Les fichiers suivants du sous-groupe [%s] n'existent pas."
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist."
+msgstr ""
+"\a\n"
+"** Les fichiers suivants du sous-groupe [%s] n'existent pas."
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr ""
-#~ "Le sous-groupe doit comprendre au moins 2 fichiers pour exécuter %s."
+msgid "The subgroup must have at least 2 files to run %s."
+msgstr "Le sous-groupe doit comprendre au moins 2 fichiers pour exécuter %s."
-#~ msgid ""
-#~ "\n"
-#~ "If you continue the mask will be removed."
-#~ msgstr ""
-#~ "\n"
-#~ "Si vous continuez, le masque sera supprimé."
+msgid ""
+"\n"
+"If you continue the mask will be removed."
+msgstr ""
+"\n"
+"Si vous continuez, le masque sera supprimé."
-#~ msgid "Did not find input cell map."
-#~ msgstr "couche de cellules en entrée introuvable."
+msgid "Did not find input cell map."
+msgstr "couche de cellules en entrée introuvable."
-#~ msgid "Imagery files subgroup"
-#~ msgstr "Sous-groupe de fichiers image"
+msgid "Imagery files subgroup"
+msgstr "Sous-groupe de fichiers image"
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "Attention : nom de groupe illégal <%s>"
+msgid "Warning: illegal group name <%s>."
+msgstr "Attention : nom de groupe illégal <%s>"
-#~ msgid "Warning: illegal output file name <%s>."
-#~ msgstr "Attention : nom de fichier de sortie illégal <%s>"
+msgid "Warning: illegal output file name <%s>."
+msgstr "Attention : nom de fichier de sortie illégal <%s>"
-#~ msgid "An output cell map name is required."
-#~ msgstr "Un nom de couche de cellule en sortie est requis."
+msgid "An output cell map name is required."
+msgstr "Un nom de couche de cellule en sortie est requis."
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr ""
-#~ "Le nom de la couche de cellule en sortie ne peut dépasser 12 caractères."
+msgid "The output cell map name can not be longer than 12 characters."
+msgstr ""
+"Le nom de la couche de cellule en sortie ne peut dépasser 12 caractères."
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: depuis  M: vers R: quitter\n"
+msgid "L: from  M: to R: quit\n"
+msgstr "L: depuis  M: vers R: quitter\n"
-#~ msgid "Category <%d>: Area fill color and background color are the same!"
-#~ msgstr ""
-#~ "Catégories <%d>: la couleur de remplissage et la couleur de fond sont "
-#~ "identiques!"
+msgid "Category <%d>: Area fill color and background color are the same!"
+msgstr ""
+"Catégories <%d>: la couleur de remplissage et la couleur de fond sont "
+"identiques!"
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr ""
-#~ "Catégorie <%d>: la couleur de ligne et la couleur de fond sont identiques!"
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr ""
+"Catégorie <%d>: la couleur de ligne et la couleur de fond sont identiques!"
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "La couleur des lignes et du fond est identique!"
+msgid "Line color and background color are the same!"
+msgstr "La couleur des lignes et du fond est identique!"
-#~ msgid "Area fill color and background color are the same!"
-#~ msgstr ""
-#~ "La couleur de remplissage des entités surfaciques et la couleur de fond "
-#~ "sont identiques!"
+msgid "Area fill color and background color are the same!"
+msgstr ""
+"La couleur de remplissage des entités surfaciques et la couleur de fond sont "
+"identiques!"
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "Date&heure, date&heure1/date&heure2, ou aucune"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "Date&heure, date&heure1/date&heure2, ou aucune"
 # c-format
 #, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr ""
-#~ "G3dToRaster (Raster 3D en raster) : écrire %i couches rasters de "
-#~ "dimensions lignes %i colonnes"
+msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
+msgstr ""
+"G3dToRaster (Raster 3D en raster) : écrire %i couches rasters de dimensions "
+"lignes %i colonnes"
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Terminé\n"
+msgid ""
+"\n"
+"Done\n"
+msgstr ""
+"\n"
+"Terminé\n"
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "Ecriture des données Voxel VTK\n"
+msgid "Writing VTK VoxelData\n"
+msgstr "Ecriture des données Voxel VTK\n"
 # c-format
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
 # c-format
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
-#~ msgstr ""
-#~ "nom de la source de données OGR. \n"
-#~ "\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
-#~ "\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
+msgid ""
+"OGR datasource name.\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr ""
+"nom de la source de données OGR. \n"
+"\t\t Shapefile ESRI : répertoire contenant des shapefiles\n"
+"\t\tFichier MapInfo : répertoire contenant des fichiers mapinfo"
-#~ msgid "Vector import complete"
-#~ msgstr "Importation vecteur complète"
+msgid "Vector import complete"
+msgstr "Importation vecteur complète"
 #, fuzzy
-#~ msgid "Required parameter <points> not set"
-#~ msgstr "signature : points hors du périmètre"
+msgid "Required parameter <points> not set"
+msgstr "signature : points hors du périmètre"
 #, fuzzy
-#~ msgid "centroids"
-#~ msgstr "%-5d centroïdes lus\n"
+msgid "centroids"
+msgstr "%-5d centroïdes lus\n"
 #, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "Vous devez entrer au moins %d points."
+msgid "ERROR: A line needs at least 2 points"
+msgstr "Vous devez entrer au moins %d points."
 #, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
+msgid "ERROR: An area needs at least 3 points"
 #, fuzzy
-#~ msgid "Unknown GIS formats"
-#~ msgstr "Format d'étiquette date&heure inconnu: "
+msgid "Unknown GIS formats"
+msgstr "Format d'étiquette date&heure inconnu: "
 #, fuzzy
-#~ msgid "file type (ignored)"
-#~ msgstr "type de fichier"
+msgid "file type (ignored)"
+msgstr "type de fichier"
 # c-format
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Impossible de créer le fichier de cellules pour [%s]"
+msgid "Unable to create raster map for [%s]"
+msgstr "Impossible de créer le fichier de cellules pour [%s]"
 #, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr ""
-#~ "RasterToG3D(Raster vers Raster 3D) : créer %i couches rasters de "
+msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
+msgstr ""
+"RasterToG3D(Raster vers Raster 3D) : créer %i couches rasters de dimensions "
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "Ecriture de la tranche raster %i à partir du raster 3D \n"
+msgid "Writing g3d slice %i\n"
+msgstr "Ecriture de la tranche raster %i à partir du raster 3D \n"
-#~ msgid "out of memory!"
-#~ msgstr "Mémoire insuffisante!"
+msgid "out of memory!"
+msgstr "Mémoire insuffisante!"
-#~ msgid "error opening 3d raster map"
-#~ msgstr "Échec à l'ouverture du fichier raster 3D"
+msgid "error opening 3d raster map"
+msgstr "Échec à l'ouverture du fichier raster 3D"
-#~ msgid "Done\n"
-#~ msgstr "Terminé\n"
+msgid "Done\n"
+msgstr "Terminé\n"
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr ""
-#~ "Lire les couches en nombres à virgule flottante comme étant en nombres "
-#~ "entiers (utilise les règles de quantification de la couche)"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr ""
+"Lire les couches en nombres à virgule flottante comme étant en nombres "
+"entiers (utilise les règles de quantification de la couche)"
-#~ msgid "Name for the resulting raster map"
+msgid "Name for the resulting raster map"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "Ouvrir le fichier raster %s dans le jeu de données (mapset) %s\n"
+msgid "Open Raster file %s in Mapset %s"
+msgstr "Ouvrir le fichier raster %s dans le jeu de données (mapset) %s\n"
 #, fuzzy
-#~ msgid ""
-#~ "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i "
-#~ "and count %i."
-#~ msgstr ""
+msgid ""
+"elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and "
+"count %i."
+msgstr ""
 # c-format
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#~ msgstr "Ouvrir le fichier raster 3D %s"
+msgid "Open 3d raster map %s\n"
+msgstr "Ouvrir le fichier raster 3D %s"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "Nom de la couche d'altitude résultante"
+msgid "Open elev raster map %s\n"
+msgstr "Nom de la couche d'altitude résultante"
 # c-format
-#~ msgid "Could not open map %s\n"
-#~ msgstr "Impossible d'ouvrir la couche %s\n"
+msgid "Could not open map %s\n"
+msgstr "Impossible d'ouvrir la couche %s\n"
 #, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "Il faut utiliser soit le drapeau -i et/ou le paramètre itinéraire"
+msgid "Either -i flag and/or profile parameter must be used."
+msgstr "Il faut utiliser soit le drapeau -i et/ou le paramètre itinéraire"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Fichier binaire à importer"
+msgid "Bin raster map to be imported"
+msgstr "Fichier binaire à importer"
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "Sortie des dérivées partielles "
+msgid "Output partial derivatives instead"
+msgstr "Sortie des dérivées partielles "
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La taille de la région est plus petite que minreg, rien n'a été affiché.\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr ""
+"La taille de la région est plus petite que minreg, rien n'a été affiché.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La taille de la région est plus grande que maxreg, rien n'a été affiché.\n"
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr ""
+"La taille de la région est plus grande que maxreg, rien n'a été affiché.\n"
-#~ msgid "Maximum distance"
-#~ msgstr "Distance maximale"
+msgid "Maximum distance"
+msgstr "Distance maximale"
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "Ne pas reconstruire et stocker la topologie à la fin"
+msgid "Do not rebuild and store the topology at the end"
+msgstr "Ne pas reconstruire et stocker la topologie à la fin"
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr ""
-#~ "Construit des arbres 3D à partir du fichier source de vecteurs points"
+msgid "Makes 3D trees from input point vector map"
+msgstr "Construit des arbres 3D à partir du fichier source de vecteurs points"
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "Diamètre du feuillage de l'arbre en unités carte"
+msgid "Diameter of the tree crown in map units"
+msgstr "Diamètre du feuillage de l'arbre en unités carte"
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "Hauteur du tronc d'arbre (en mètres)"
+msgid "Height of tree trunk in meters"
+msgstr "Hauteur du tronc d'arbre (en mètres)"
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nom de la colonne contenant la largeur du feuillage de l'arbre"
+msgid "Name of the column with tree crown width"
+msgstr "Nom de la colonne contenant la largeur du feuillage de l'arbre"
-#~ msgid "Name of the column with tree height"
-#~ msgstr "Nom de la colonne contenant la hauteur de l'arbre"
+msgid "Name of the column with tree height"
+msgstr "Nom de la colonne contenant la hauteur de l'arbre"
-#~ msgid "Name of the column with tree species"
-#~ msgstr "Nom de la colonne contenant les essences d'arbres"
+msgid "Name of the column with tree species"
+msgstr "Nom de la colonne contenant les essences d'arbres"
-#~ msgid "Representation of spruce in percent"
-#~ msgstr "Représentation des sapins en pourcentage"
+msgid "Representation of spruce in percent"
+msgstr "Représentation des sapins en pourcentage"
-#~ msgid "Representation of fir in percent"
-#~ msgstr "Représentation des pins pignons en pourcentage"
+msgid "Representation of fir in percent"
+msgstr "Représentation des pins pignons en pourcentage"
-#~ msgid "Representation of pine in percent"
-#~ msgstr "Représentation des pins en pourcentage"
+msgid "Representation of pine in percent"
+msgstr "Représentation des pins en pourcentage"
-#~ msgid "Representation of larch in percent"
-#~ msgstr "Représentation des mélèzes en pourcentage"
+msgid "Representation of larch in percent"
+msgstr "Représentation des mélèzes en pourcentage"
-#~ msgid "Representation of beech in percent"
-#~ msgstr "Représentation des hêtres en pourcentage"
+msgid "Representation of beech in percent"
+msgstr "Représentation des hêtres en pourcentage"
-#~ msgid "Representation of oak in percent"
-#~ msgstr "Représentation des chênes en pourcentage"
+msgid "Representation of oak in percent"
+msgstr "Représentation des chênes en pourcentage"
-#~ msgid "Representation of douglas in percent"
-#~ msgstr "Représentation des pins douglas en pourcentage"
+msgid "Representation of douglas in percent"
+msgstr "Représentation des pins douglas en pourcentage"
-#~ msgid "Representation of maple in percent"
-#~ msgstr "Représentation des érables en pourcentage"
+msgid "Representation of maple in percent"
+msgstr "Représentation des érables en pourcentage"
-#~ msgid "Representation of alder in percent"
-#~ msgstr "Représentation des vernes/aulnes en pourcentage"
+msgid "Representation of alder in percent"
+msgstr "Représentation des vernes/aulnes en pourcentage"
-#~ msgid "Vertical variability of tree heights [% of height]"
-#~ msgstr "Variabilité verticale des hauteurs d'arbres [% de hauteur]"
+msgid "Vertical variability of tree heights [% of height]"
+msgstr "Variabilité verticale des hauteurs d'arbres [% de hauteur]"
-#~ msgid "Horizontal variability of tree position in map units"
-#~ msgstr "Variabilité horizontale de la position des arbres en unités cartes"
+msgid "Horizontal variability of tree position in map units"
+msgstr "Variabilité horizontale de la position des arbres en unités cartes"
-#~ msgid "Crown length [% of tree height]"
-#~ msgstr "Epaisseur du feuillage [en % de la hauteur de l'arbre]"
+msgid "Crown length [% of tree height]"
+msgstr "Epaisseur du feuillage [en % de la hauteur de l'arbre]"
-#~ msgid "Total species representation is > 100"
-#~ msgstr "Le total de représentation des essences est > 100"
+msgid "Total species representation is > 100"
+msgstr "Le total de représentation des essences est > 100"
-#~ msgid "Total species representation is < 100"
-#~ msgstr "Le total de représentation des essences est < 100"
+msgid "Total species representation is < 100"
+msgstr "Le total de représentation des essences est < 100"
 # c-format
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "Impossible de sélectionner les attributs pour le point #%d"
+msgid "Cannot select attributes for point #%d"
+msgstr "Impossible de sélectionner les attributs pour le point #%d"
-#~ msgid "Species <%s> not known. I'll use parameters for spruce instead"
-#~ msgstr ""
-#~ "L'essence <%s> est inconnue. J'utilise les paramètres pour les sapins à "
-#~ "la place"
+msgid "Species <%s> not known. I'll use parameters for spruce instead"
+msgstr ""
+"L'essence <%s> est inconnue. J'utilise les paramètres pour les sapins à la "
+"place"
-#~ msgid "Display active frame dimensions"
-#~ msgstr "Afficher les dimensions de la fenêtre active"
+msgid "Display active frame dimensions"
+msgstr "Afficher les dimensions de la fenêtre active"
-#~ msgid "Right: "
-#~ msgstr " Droite: "
+msgid "Right: "
+msgstr " Droite: "
-#~ msgid "%s Pan\n"
-#~ msgstr "%s Pan\n"
+msgid "%s Pan\n"
+msgstr "%s Pan\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Quitter\n"
+msgid "%s Quit\n"
+msgstr "%s Quitter\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Trace la grille géographique"
+msgid "Draw geographic grid"
+msgstr "Trace la grille géographique"
-#~ msgid "output 3d raster map which will be filled with the 2D raster slices"
-#~ msgstr ""
-#~ "Couche 3D en sortie qui va être interpolée à partir des tranches rasters "
-#~ "2D"
+msgid "output 3d raster map which will be filled with the 2D raster slices"
+msgstr ""
+"Couche 3D en sortie qui va être interpolée à partir des tranches rasters 2D"
-#~ msgid "Quiet mode"
+msgid "Quiet mode"
-#~ msgid "Raster map(s) to be converted to VTK-ASCII data format"
-#~ msgstr "Couche(s) raster(s) à convertir au format de données VTK-ASCII"
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgstr "Couche(s) raster(s) à convertir au format de données VTK-ASCII"
-#~ msgid ""
-#~ "3 raster maps (r,g,b) which are used to create rgb values [redmap,"
-#~ "greenmap,bluemap]"
-#~ msgstr ""
-#~ "3 couches rasters (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
+msgid ""
+"3 raster maps (r,g,b) which are used to create rgb values [redmap,greenmap,"
+"bluemap]"
+msgstr ""
+"3 couches rasters (r,g,b) utilisées pour créer les valeurs RGB [redmap,"
+"greenmap,bluemap]"
-#~ msgid "Please provide three RGB maps"
-#~ msgstr "Veuillez fournir trois couches RGB"
+msgid "Please provide three RGB maps"
+msgstr "Veuillez fournir trois couches RGB"
-#~ msgid "Running: %s"
-#~ msgstr "Exécution en cours: %s"
+msgid "Running: %s"
+msgstr "Exécution en cours: %s"
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 2: A * Recherche.                      Achevé (pourcentage): "
+msgid ""
+"\n"
+"SECTION 2: A * Search.                      Percent complete: "
+msgstr ""
+"\n"
+"SECTION 2: A * Recherche.                      Achevé (pourcentage): "
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION %d: Closing Maps."
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION %d: Fermeture des couches."
+msgid ""
+"\n"
+"\n"
+"SECTION %d: Closing Maps."
+msgstr ""
+"\n"
+"\n"
+"SECTION %d: Fermeture des couches."
-#~ msgid ""
-#~ "\n"
-#~ "SECTION 3: Accumulating Surface Flow.       Percent complete: "
-#~ msgstr ""
-#~ "\n"
-#~ "SECTION 3: Accumulation du courant de surface.       Achevé (pourcentage):"
+msgid ""
+"\n"
+"SECTION 3: Accumulating Surface Flow.       Percent complete: "
+msgstr ""
+"\n"
+"SECTION 3: Accumulation du courant de surface.       Achevé (pourcentage):"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Search.                      Percent complete:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "SECTION 2: A * Recherche.                      Achevé (pourcentage):"
+msgid ""
+"\n"
+"\n"
+"SECTION 2: A * Search.                      Percent complete:"
+msgstr ""
+"\n"
+"\n"
+"SECTION 2: A * Recherche.                      Achevé (pourcentage):"
-#~ msgid "    segments in row:\t%d"
-#~ msgstr "\tsegments en ligne:\t%d"
+msgid "    segments in row:\t%d"
+msgstr "\tsegments en ligne:\t%d"
-#~ msgid "segments in columns:\t%d"
-#~ msgstr "segments en colonnes:\t%d"
+msgid "segments in columns:\t%d"
+msgstr "segments en colonnes:\t%d"
-#~ msgid "     total segments:\t%d"
-#~ msgstr "\ttotal des segments:\t%d"
+msgid "     total segments:\t%d"
+msgstr "\ttotal des segments:\t%d"
-#~ msgid "      open segments:\t%d"
-#~ msgstr "\touvrir des segments:\t%d"
+msgid "      open segments:\t%d"
+msgstr "\touvrir des segments:\t%d"
-#~ msgid "CREATING SUPPORT FILES FOR %s"
-#~ msgstr "CREATION DE FICHIERS DE SUPPORT POUR %s"
+msgid "CREATING SUPPORT FILES FOR %s"
+msgstr "CREATION DE FICHIERS DE SUPPORT POUR %s"
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "%s[%d]: aucun fichier raster spécifié."
+msgid "%s[%d]: No raster map specified."
+msgstr "%s[%d]: aucun fichier raster spécifié."
-#~ msgid "Width of stream (in meters)"
-#~ msgstr "Largeur du cours d'eau (en mètres)"
+msgid "Width of stream (in meters)"
+msgstr "Largeur du cours d'eau (en mètres)"
-#~ msgid "done."
-#~ msgstr "Terminé."
+msgid "done."
+msgstr "Terminé."
-#~ msgid ""
-#~ "GRASS module to create a fractal surface of a given fractal dimension. "
-#~ "Uses spectral synthesis method. Can create intermediate layers showing "
-#~ "the build up of different spectral coefficients (see Saupe, pp.106-107 "
-#~ "for an example of this). Use this module to generate naturally looking "
-#~ "synthetical elevation models (DEM)."
-#~ msgstr ""
-#~ "Module GRASS pour créer une surface fractale de dimension fractale "
-#~ "donnée. Utilise la méthode de synthèse spectrale. Peut créer des couches "
-#~ "intermédiaires pour montrer la construction des différents coefficients "
-#~ "spectraux (voir Saupe, pp.106-107 pour un example). Utiliser ce module "
-#~ "pour générer des modèles numériques de terrain artificiels mais à "
-#~ "l'aspect naturel."
+msgid ""
+"GRASS module to create a fractal surface of a given fractal dimension. Uses "
+"spectral synthesis method. Can create intermediate layers showing the build "
+"up of different spectral coefficients (see Saupe, pp.106-107 for an example "
+"of this). Use this module to generate naturally looking synthetical "
+"elevation models (DEM)."
+msgstr ""
+"Module GRASS pour créer une surface fractale de dimension fractale donnée. "
+"Utilise la méthode de synthèse spectrale. Peut créer des couches "
+"intermédiaires pour montrer la construction des différents coefficients "
+"spectraux (voir Saupe, pp.106-107 pour un example). Utiliser ce module pour "
+"générer des modèles numériques de terrain artificiels mais à l'aspect "
+"naturel."
-#~ msgid ""
-#~ "Save graphic legend output in tlegend.txt file for d.graph display in GIS "
-#~ "Manager"
-#~ msgstr ""
-#~ "Sauvegarder la sortie graphique de légende dans un fichier tlegend.txt "
-#~ "pour l'affichage de d.graph dans le Gestionnaire SIG"
+msgid ""
+"Save graphic legend output in tlegend.txt file for d.graph display in GIS "
+"Manager"
+msgstr ""
+"Sauvegarder la sortie graphique de légende dans un fichier tlegend.txt pour "
+"l'affichage de d.graph dans le Gestionnaire SIG"
-#~ msgid "force removal (use only if you know what you are doing)"
-#~ msgstr "Forcer la suppression (à n'utiliser que si vous êtes sûr de vous)"
+msgid "force removal (use only if you know what you are doing)"
+msgstr "Forcer la suppression (à n'utiliser que si vous êtes sûr de vous)"
-#~ msgid "Column name (will be updated by qvector values)"
-#~ msgstr "Nom de la colonne (qui sera mise à jour par les valeurs vecteur)"
+msgid "Column name (will be updated by qvector values)"
+msgstr "Nom de la colonne (qui sera mise à jour par les valeurs vecteur)"
-#~ msgid "Query column name"
-#~ msgstr "Requêter le nom de la colonne"
+msgid "Query column name"
+msgstr "Requêter le nom de la colonne"
-#~ msgid ""
-#~ "convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
-#~ msgstr ""
-#~ "Convertir tous les anciens sites GRASS (versions antérieures à 5.7) en "
-#~ "couches vectorielles du jeu de données courant"
+msgid ""
+"convert all old GRASS < V5.7 sites maps to vector maps in current mapset"
+msgstr ""
+"Convertir tous les anciens sites GRASS (versions antérieures à 5.7) en "
+"couches vectorielles du jeu de données courant"
-#~ msgid "name for new binary vector map (omit for display to stdout)"
-#~ msgstr ""
-#~ "Nom de la nouvelle couche vecteur binaire (ne pas afficher dans stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
+msgstr ""
+"Nom de la nouvelle couche vecteur binaire (ne pas afficher dans stdout)"
-#~ msgid "any,grid3,3d raster"
-#~ msgstr "n'importe quel fichier raster 3D, grille 3D"
+msgid "any,grid3,3d raster"
+msgstr "n'importe quel fichier raster 3D, grille 3D"
-#~ msgid "Name for G3d raster map"
-#~ msgstr "Nom d'une couche raster 3D GRASS"
+msgid "Name for G3d raster map"
+msgstr "Nom d'une couche raster 3D GRASS"
-#~ msgid "No output maps"
-#~ msgstr "Nom des couches de sortie"
+msgid "No output maps"
+msgstr "Nom des couches de sortie"
-#~ msgid "Error opening 3d raster map <%s>. No Vector Data will be created."
-#~ msgstr ""
-#~ "Erreur d'ouverture du fichier G2D <%s>. Aucune donnée vecteur ne sera "
-#~ "créée."
+msgid "Error opening 3d raster map <%s>. No Vector Data will be created."
+msgstr ""
+"Erreur d'ouverture du fichier G2D <%s>. Aucune donnée vecteur ne sera créée."
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valeurs RGB erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr ""
+"Valeurs RGB erronées! Les valeurs doivent être comprises entre 0 et 255!\n"
-#~ msgid "Print all, inclusive range"
-#~ msgstr "Afficher toutes les valeurs sur l'intervalle, bornes incluses"
+msgid "Print all, inclusive range"
+msgstr "Afficher toutes les valeurs sur l'intervalle, bornes incluses"
-#~ msgid "Resolution of raster and raster3d maps should be equal!"
-#~ msgstr ""
-#~ "Attention, la résolution des couches rasters et rasters 3D doit être "
-#~ "identique!"
+msgid "Resolution of raster and raster3d maps should be equal!"
+msgstr ""
+"Attention, la résolution des couches rasters et rasters 3D doit être "
+"identique!"
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
-#~ msgstr "La résolution des couches raster et raster 3D doit être identique!"
+msgid "The resolution of raster and raster3d maps should be equal!"
+msgstr "La résolution des couches raster et raster 3D doit être identique!"
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "Connexion à la base de données via DBMI."
+msgid "Connect to the database through DBMI."
+msgstr "Connexion à la base de données via DBMI."
-#~ msgid ""
-#~ "Feature type. Possible combinations of more types: point,centroid or line,"
-#~ "boundary."
-#~ msgstr ""
-#~ "Type d'objet vectoriels. Il est possible de combiner plusieurs types : "
-#~ "point, centroïde ou ligne, contour"
+msgid ""
+"Feature type. Possible combinations of more types: point,centroid or line,"
+"boundary."
+msgstr ""
+"Type d'objet vectoriels. Il est possible de combiner plusieurs types : "
+"point, centroïde ou ligne, contour"
-#~ msgid "Line width of highlight color (only for ps.map output)"
-#~ msgstr ""
-#~ "Largeur de la ligne de mise en valeur des objets (seulement pour la "
-#~ "sortie ps.map)"
+msgid "Line width of highlight color (only for ps.map output)"
+msgstr ""
+"Largeur de la ligne de mise en valeur des objets (seulement pour la sortie "
+"ps.map)"
-#~ msgid "unknown interpolation method"
-#~ msgstr "Méthode d'interpolation à utiliser inconnue"
+msgid "unknown interpolation method"
+msgstr "Méthode d'interpolation à utiliser inconnue"
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "Coordonnées E et N du point de départ"
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "Coordonnées E et N du point de départ"
-#~ msgid "Name of existing raster map."
-#~ msgstr "Nom de la couche raster existante."
+msgid "Name of existing raster map."
+msgstr "Nom de la couche raster existante."
-#~ msgid "Name of input map"
+msgid "Name of input map"
-#~ msgid "Name of output map"
+msgid "Name of output map"
-#~ msgid "Name of existing input raster map"
-#~ msgstr "Nom du fichier raster source"
+msgid "Name of existing input raster map"
+msgstr "Nom du fichier raster source"
-#~ msgid "Wrong RGB maps. RGB output not added!"
-#~ msgstr "Couches RGB erronées. La sortie RGB n'est pas ajoutée!"
+msgid "Wrong RGB maps. RGB output not added!"
+msgstr "Couches RGB erronées. La sortie RGB n'est pas ajoutée!"
-#~ msgid "cover raster map"
-#~ msgstr "couche raster de couverture"
+msgid "cover raster map"
+msgstr "couche raster de couverture"
-#~ msgid "resultant raster map"
-#~ msgstr "couche raster résultante"
+msgid "resultant raster map"
+msgstr "couche raster résultante"
-#~ msgid "Sampling distance step coefficient (0.5-1.5)"
-#~ msgstr "Pas du coefficient d'échantillonnage (0.5-1.5)"
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr "Pas du coefficient d'échantillonnage (0.5-1.5)"
-#~ msgid "(i)   Rectangular elevation map"
-#~ msgstr "(i) Couche rectangulaire d'altitude"
+msgid "(i)   Rectangular elevation map"
+msgstr "(i) Couche rectangulaire d'altitude"
-#~ msgid "Name of the resulting map"
-#~ msgstr "Nom de la couche générée"
+msgid "Name of the resulting map"
+msgstr "Nom de la couche générée"
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "Utiliser une méthode rapide, mais gourmande en mémoire"
+msgid "Invoke fast, but memory intensive operation"
+msgstr "Utiliser une méthode rapide, mais gourmande en mémoire"
-#~ msgid "Fill areas with random colors according to category number"
-#~ msgstr ""
-#~ "Remplir les entités surfaciques avec des couleurs aléatoires en fonction "
-#~ "du code de catégorie"
+msgid "Fill areas with random colors according to category number"
+msgstr ""
+"Remplir les entités surfaciques avec des couleurs aléatoires en fonction du "
+"code de catégorie"
-#~ msgid "Done.\n"
+msgid "Done.\n"
-#~ msgid "Zooming finished.\n"
-#~ msgstr "Zoom terminé.\n"
+msgid "Zooming finished.\n"
+msgstr "Zoom terminé.\n"
-#~ msgid ""
-#~ "column '%s' : type text is stored as varchar(250) some data may be lost"
-#~ msgstr ""
-#~ "colonne '%s' : type text enregistré comme varchar(250) des données "
-#~ "peuvent être tronquées"
+msgid "column '%s' : type text is stored as varchar(250) some data may be lost"
+msgstr ""
+"colonne '%s' : type text enregistré comme varchar(250) des données peuvent "
+"être tronquées"
+msgid ""
+"Output direction type AGNPS, ANSWERS or GRASS aspect\n"
+"              default: GRASS"
+msgstr ""
+"Type de direction en sortie : AGNPS, ANSWERS ou GRASS\n"
+"              défaut: GRASS"
+msgid "Slope"
+msgstr "Pente"
+msgid "Aspect"
+msgstr "Aspect"
+msgid "Profile curvature"
+msgstr "Courbure du profile"
+msgid "Tangential curvature"
+msgstr "Courbure tangentielle"
+msgid "Mean curvature"
+msgstr "Courbure moyenne"
+msgid "Tension"
+msgstr "Tension"
+# c-format
+#~ msgid "slopein raster map <%s> not found"
+#~ msgstr "fichier de cellules slopein <%s> non trouvé"
+# c-format
+#, fuzzy
+#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+#~ msgstr "Erreur de lecture du fichier raster [%s]"
+# c-format
+#, fuzzy
+#~ msgid "Base raster map <%s> not found"
+#~ msgstr "fichier de cellules aspin <%s> non trouvé"
+#, fuzzy
+#~ msgid "Color table for <%s> updated"
+#~ msgstr "Table de couleur de [%s] mise à jour"
+# c-format
+#~ msgid "Error reading raster map [%s]."
+#~ msgid "        Number of bytes per cell"
+#~ msgstr "\t\tNombre de bits par cellule"
+#, fuzzy
+#~ msgid "Option <%s>: <%s> exists."
+#~ msgstr "région <%s> non trouvée"
+#, fuzzy
+#~ msgid "No attribute table found"
+#~ msgstr "Colonne(s) attributaire(s)"
+# c-format
+#, fuzzy
+#~ msgid "No numerical attributes found. Skipping export"
+#~ msgstr "%d points en dehors de la région courante"
+#, fuzzy
+#~ msgid "Error reading value of attribute '%s'"
+#~ msgstr "Erreur de lecture du fichier cats de <%s>"
+#, fuzzy
+#~ msgid "Illegal subgroup name <%s>"
+#~ msgstr "Attention : nom de sous-groupe illégal <%s>"
+#~ msgid "No monitor selected"
+#~ msgstr "Pas de moniteur sélectionné"
+# c-format
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "Police invalide : %s"
+#~ msgid "Unable to create face"
+#~ msgstr "Impossible de créer le texte"
+#~ msgid "Unable to set size"
+#~ msgstr "Impossible de paramétrer la taille"
+#, fuzzy
 #~ msgid ""
-#~ "Output direction type AGNPS, ANSWERS or GRASS aspect\n"
-#~ "              default: GRASS"
-#~ msgstr ""
-#~ "Type de direction en sortie : AGNPS, ANSWERS ou GRASS\n"
-#~ "              défaut: GRASS"
+#~ "Displays the rhumbline joining two user-specified points, in the active "
+#~ "frame on the user's graphics monitor."
+#~ msgstr "Afficher les données vectorielles GRASS dans le moniteur actif"
-#~ msgid "Slope"
-#~ msgstr "Pente"
+#, fuzzy
+#~ msgid "format"
+#~ msgstr "format OGR"
-#~ msgid "Aspect"
-#~ msgstr "Aspect"
+#, fuzzy
+#~ msgid "display, export"
+#~ msgstr "Afficher l'index"
-#~ msgid "Profile curvature"
-#~ msgstr "Courbure du profile"
+#~ msgid "Name of PNG file"
+#~ msgstr "Nom du fichier PNG"
-#~ msgid "Tangential curvature"
-#~ msgstr "Courbure tangentielle"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "Nom du fichier en sortie (ne PAS ajouter l'extension)"
-#~ msgid "Mean curvature"
-#~ msgstr "Courbure moyenne"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "Groupe de fichiers image"
-#~ msgid "Tension"
-#~ msgstr "Tension"
+#, fuzzy
+#~ msgid "Data type"
+#~ msgstr "Type de données"
+#, fuzzy
+#~ msgid "Name of the input raster map"
+#~ msgstr ""
+#~ "#-#-#-#-#  grassmods_fr.po (grassmods_fr)  #-#-#-#-#\n"
+#~ "Nom du fichier raster source\n"
+#~ "Nom de la couche raster source"
Modified: grass/trunk/locale/po/grassmods_hi.po
--- grass/trunk/locale/po/grassmods_hi.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_hi.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -6756,7 +6756,7 @@
 #: ../imagery/i.albedo/main.c:166
 #, fuzzy
 msgid "At least two raster maps are required"
-msgstr "के लिए"
+msgstr "है."
 #: ../imagery/i.albedo/main.c:194
 #, fuzzy, c-format
@@ -9187,7 +9187,7 @@
 #: ../raster/r.external/main.c:339
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (data range)"
-msgstr "के लिए."
+msgstr "बनाया जा रहा है के लिए."
 #: ../raster/r.external/main.c:353
 #, fuzzy, c-format
@@ -12121,8 +12121,9 @@
 msgstr "का"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
+msgstr "का"
 #: ../raster/r.uslek/main.c:66
 #, fuzzy
@@ -17736,8 +17737,9 @@
 msgstr "फ़ाइल"
 #: ../raster/r.mapcalc/main.c:148
+#, fuzzy
 msgid "parse error"
-msgstr ""
+msgstr "n"
 #: ../raster/r.mapcalc/main.c:157
 msgid "Floating point error(s) occured in the calculation"
@@ -18782,7 +18784,7 @@
 #: ../raster/r.statistics2/main.c:185
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
-msgstr "के लिए"
+msgstr "डाटाटाइप."
 #: ../raster/r.statistics2/main.c:249
 msgid "First pass"
@@ -26552,8 +26554,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "सदिश"
 #: ../vector/v.net.steiner/main.c:447
 #, fuzzy
@@ -27703,8 +27706,9 @@
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
+#, fuzzy
 msgid "Position"
-msgstr ""
+msgstr "नहीं n"
 #: ../visualization/nviz2/cmd/args.c:301
 #, fuzzy
@@ -27901,4595 +27905,4630 @@
 msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr "जी n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr "जी n"
 #, fuzzy
-#~ msgid "Display manager for GRASS"
-#~ msgstr "संख्या का"
+msgid "Display manager for GRASS"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "का"
+msgid "Name of .dmrc settings file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "फ्रेम्स चालू."
+msgid "Moves displayed maps to another monitor"
+msgstr "फ्रेम्स चालू."
 #, fuzzy
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "पाठ चालू."
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr "पाठ चालू."
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr "पाठ चालू."
 #, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "का."
+msgid "Compression for PNG files"
+msgstr "का."
 #, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "का"
+msgid "Set transparent background"
+msgstr "का"
 #, fuzzy
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "a के लिए a का."
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "a के लिए a का."
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "का फ़िल्टर"
+msgid "Number of lines to appear in the legend"
+msgstr "का फ़िल्टर"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "त्रुटि नहीं है n"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "त्रुटि नहीं है n"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "a"
+msgid "Redraw all frames"
+msgstr "a"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "का"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "का"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "सेट जोड़ा"
+msgid "Show vector maps rather than raster maps"
+msgstr "सेट जोड़ा"
 #, fuzzy
-#~ msgid "Map number show down the monitor"
-#~ msgstr "संख्या का खण्ड"
+msgid "Map number show down the monitor"
+msgstr "संख्या का खण्ड"
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "का"
+msgid "Number of seconds to pause between slides"
+msgstr "का"
 #, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "का a"
+msgid "Enter raster map to display in 1st frame"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "का a"
+msgid "Enter raster map to display in 2nd frame"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "का a"
+msgid "Enter command to execute in 2nd frame"
+msgstr "का a"
 #, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "गामा."
+msgid "display, legend"
+msgstr "गामा."
 #, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "सदिश"
+msgid "Vector map to display thematically"
+msgstr "सदिश"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "सदिश"
+msgid "Vector map type"
+msgstr "सदिश"
 #, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "के लिए"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Type of thematic display"
-#~ msgstr "का"
+msgid "Type of thematic display"
+msgstr "का"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "के लिए."
+msgid "Layer to use for thematic display"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "फ़ॉन्ट"
+msgid "Points"
+msgstr "फ़ॉन्ट"
 #, fuzzy
-#~ msgid "Vector point icon for point data"
-#~ msgstr "छोटा करें बिन्दु"
+msgid "Vector point icon for point data"
+msgstr "छोटा करें बिन्दु"
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
+msgid "Number of classes for interval theme (integer)"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "छापें"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "शीर्षक"
+msgid "Output separator (default: newline)"
+msgstr "शीर्षक"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "Bin"
+msgid "Raster to remove"
+msgstr "Bin"
 #, fuzzy
-#~ msgid "3d raster to remove"
-#~ msgstr "Bin"
+msgid "3d raster to remove"
+msgstr "Bin"
 #, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "चालू"
+msgid "Vector to remove"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "Region to remove"
-#~ msgstr "चालू"
+msgid "Region to remove"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "Label to remove"
-#~ msgstr "चालू"
+msgid "Label to remove"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "3dview to remove"
-#~ msgstr "चालू"
+msgid "3dview to remove"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "Group to remove"
-#~ msgstr "चालू"
+msgid "Group to remove"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "का"
+msgid "raster input maps"
+msgstr "का"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "का"
+msgid "label with coordinates instead of numbering"
+msgstr "का"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "रखें का"
+msgid "Keep band numbers instead of using band color names."
+msgstr "रखें का"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "डाटाटाइप."
+msgid "Do not overwrite existing map"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "a a."
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "a a."
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "फील्ड"
+msgid "Output field seperator"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "का a."
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "का a."
 #, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "छापें"
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "फ़ाइलनाम "
+msgid "A (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "के लिए"
+msgid "Name for output grid3D volume"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "नहीं"
+msgid "%s: [%s] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "त्रुटि"
+msgid ""
+"Enter the file name or path\n"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "आकार "
+msgid "Use mouse to select Start Point\n"
+msgstr "आकार "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr "आकार "
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr "आकार "
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr "n n"
+msgid "Buttons:\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr "n"
+msgid "Left:   Mark next point\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "elevin raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "aspin raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "aspin raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "linkein raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "linkein raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "albedo raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "albedo raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "latin raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "latin raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "coefbh raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "coefdh raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "का"
+msgid "Unable to find data map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Unable to find clump map"
+msgid "Unable to find clump map"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "i n"
+msgid "Terrain raster map (DEM)"
+msgstr "i n"
 #, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "शीर्षक"
+msgid "Output raster map with lake"
+msgstr "शीर्षक"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Cannot write lake raster map <%s>!"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "नहीं"
+msgid "Terrain raster map <%s> not found!"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "नहीं"
+msgid "Seed map <%s> not found!"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "के लिए"
+msgid "Failure to allocate memory for row pointers"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Loading maps: "
-#~ msgstr "त्रुटि के लिए"
+msgid "Loading maps: "
+msgstr "त्रुटि के लिए"
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "त्रुटि."
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Pass: %d\n"
-#~ msgstr "n"
+msgid "Pass: %d\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "त्रुटि के लिए."
+msgid "Error writing color file for <%s@%s>!"
+msgstr "त्रुटि के लिए."
 #, fuzzy
-#~ msgid "All done."
-#~ msgstr "n"
+msgid "All done."
+msgstr "n"
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr "नहीं"
+msgid "%s: base raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "नहीं"
+msgid "%s: cover raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "का"
+msgid "Name of the vector points map with x,y locations"
+msgstr "का"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "का"
+msgid "Number of time iterations (sec.)"
+msgstr "का"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "है a"
+msgid "Multiscale simulation"
+msgstr "है a"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "का मीटर्स"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "का मीटर्स"
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "का"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgstr "का"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "का"
 #, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "a"
+msgid "Calculates <simple> index on a raster map"
+msgstr "a"
 #, fuzzy
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "द्विरेखीय के लिए."
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "द्विरेखीय के लिए."
 #, fuzzy
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr "उत्तर दक्षिण के लिए"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr "उत्तर दक्षिण के लिए"
 #, fuzzy
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr "स्केल है स्केल."
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr "स्केल है स्केल."
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
-#~ msgstr "चेतावनी."
+msgid "Illegal output file name <%s>"
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "Not enough memory for zero_array_cell"
-#~ msgstr "के लिए"
+msgid "Not enough memory for zero_array_cell"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "डिस्क"
+msgid "Not enough disk space -- cannot write files"
+msgstr "डिस्क"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "के लिए"
+msgid "%s: can't read fp range for [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "समूह."
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "समूह."
 #, fuzzy
-#~ msgid "Path to rules file"
-#~ msgstr "का"
+msgid "Path to rules file"
+msgstr "का"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "RGB raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "नहीं"
+msgid "Vector cell map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Which raster map needs a color table"
-#~ msgstr "a"
+msgid "Which raster map needs a color table"
+msgstr "a"
 #, fuzzy
-#~ msgid "Edit header for [%s]\n"
-#~ msgstr "संपादन के लिए n"
+msgid "Edit header for [%s]\n"
+msgstr "संपादन के लिए n"
 #, fuzzy
-#~ msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
-#~ msgstr "है a का संपादन (_E) चालू."
+msgid "[%s] is a reclass of [%s] - cannot edit header! Run support on [%s]."
+msgstr "है a का संपादन (_E) चालू."
 #, fuzzy
-#~ msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
-#~ msgstr "है a का संपादन (_E)!"
+msgid "[%s] is a reclass of [%s in %s] - cannot edit header!"
+msgstr "है a का संपादन (_E)!"
 #, fuzzy
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "है."
+msgid "Raster file [%s] is empty."
+msgstr "है."
 #, fuzzy
-#~ msgid "cellhd compression: %d\n"
-#~ msgstr "n"
+msgid "cellhd compression: %d\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "3.0 compression %sindicated\n"
-#~ msgstr "n"
+msgid "3.0 compression %sindicated\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Pre 3.0 compression %sindicated\n"
-#~ msgstr "n"
+msgid "Pre 3.0 compression %sindicated\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "[%s] appears to be compressed. Is it? "
-#~ msgstr "है "
+msgid "[%s] appears to be compressed. Is it? "
+msgstr "है "
 #, fuzzy
-#~ msgid "Please indicate the type of compression:\n"
-#~ msgstr "का n"
+msgid "Please indicate the type of compression:\n"
+msgstr "का n"
 #, fuzzy
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "n"
+msgid "  1. Pre 3.0 compression\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "n"
+msgid "  2. 3.0 compression\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "The header for [%s] says the file is not compressed. "
-#~ msgstr "के लिए है नहीं "
+msgid "The header for [%s] says the file is not compressed. "
+msgstr "के लिए है नहीं "
 #, fuzzy
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "n"
+msgid "The file appears to be compressed.\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Most likely the header is wrong, but I want you to decide.\n"
-#~ msgstr "है n"
+msgid "Most likely the header is wrong, but I want you to decide.\n"
+msgstr "है n"
 #, fuzzy
-#~ msgid "The header for [%s] says the file is compressed. "
-#~ msgstr "के लिए है "
+msgid "The header for [%s] says the file is compressed. "
+msgstr "के लिए है "
 #, fuzzy
-#~ msgid "The file does NOT appear to be compressed.\n"
-#~ msgstr "n"
+msgid "The file does NOT appear to be compressed.\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Unable to write header for [%s]."
+msgid "Unable to write header for [%s]."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Header for raster map [%s] updated."
+msgid "Header for raster map [%s] updated."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Please enter the following information for [%s]:"
-#~ msgstr "के लिए:"
+msgid "Please enter the following information for [%s]:"
+msgstr "के लिए:"
 #, fuzzy
-#~ msgid "        Number of rows"
-#~ msgstr "का"
+msgid "        Number of rows"
+msgstr "का"
 #, fuzzy
-#~ msgid "        Number of cols"
-#~ msgstr "का"
+msgid "        Number of cols"
+msgstr "का"
 #, fuzzy
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "का बाइट्स"
+msgid "        Number of bytes per cell"
+msgstr "का बाइट्स"
 #, fuzzy
-#~ msgid "        Floating point map"
-#~ msgstr "फ्लोटिंग बिन्दु"
+msgid "        Floating point map"
+msgstr "फ्लोटिंग बिन्दु"
 #, fuzzy
-#~ msgid "rows * cols * bytes per cell must be same as file size (%lu)"
-#~ msgstr "बाइट्स आकार "
+msgid "rows * cols * bytes per cell must be same as file size (%lu)"
+msgstr "बाइट्स आकार "
 #, fuzzy
-#~ msgid "** Negative values not allowed!"
-#~ msgstr "ऋणात्मक नहीं!"
+msgid "** Negative values not allowed!"
+msgstr "ऋणात्मक नहीं!"
 #, fuzzy
-#~ msgid "** Positive values only please!"
-#~ msgstr "धनात्मक!"
+msgid "** Positive values only please!"
+msgstr "धनात्मक!"
 #, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "नहीं."
+msgid "Raster file [%s] not found. Exiting."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "History file for [%s] updated."
+msgid "History file for [%s] updated."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "History file for [%s] not updated."
-#~ msgstr "के लिए नहीं."
+msgid "History file for [%s] not updated."
+msgstr "के लिए नहीं."
 #, fuzzy
-#~ msgid "Edit header for [%s]? "
-#~ msgstr "संपादन के लिए "
+msgid "Edit header for [%s]? "
+msgstr "संपादन के लिए "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "NOTE: [%s] is a reclass of [%s in %s]"
-#~ msgstr "है a का"
+msgid ""
+"\n"
+"NOTE: [%s] is a reclass of [%s in %s]"
+msgstr "है a का"
 #, fuzzy
-#~ msgid "Canceling from edit header."
-#~ msgstr "संपादन (_E)."
+msgid "Canceling from edit header."
+msgstr "संपादन (_E)."
 #, fuzzy
-#~ msgid "Edit the category file for [%s]? "
+msgid "Edit the category file for [%s]? "
 #, fuzzy
-#~ msgid "Create/Update the color table for [%s]? "
-#~ msgstr "के लिए "
+msgid "Create/Update the color table for [%s]? "
+msgstr "के लिए "
 #, fuzzy
-#~ msgid "Edit the history file for [%s]? "
+msgid "Edit the history file for [%s]? "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "The null file for [%s] may indicate that some cells contain\n"
-#~ " no data. If the null file for [%s] doesn't exist, zero cells in\n"
-#~ " it are treated by GRASS application programs as no data."
-#~ msgstr ""
-#~ "के लिए रखे हुए\n"
-#~ " के लिए\n"
+msgid ""
+"\n"
+"The null file for [%s] may indicate that some cells contain\n"
+" no data. If the null file for [%s] doesn't exist, zero cells in\n"
+" it are treated by GRASS application programs as no data."
+msgstr ""
+"के लिए रखे हुए\n"
+" के लिए\n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to create/reset the null file for [%s] so that null cell "
-#~ "values are considered valid data? "
+msgid ""
+"\n"
+"Do you want to create/reset the null file for [%s] so that null cell values "
+"are considered valid data? "
+msgstr "के लिए "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Do you want to delete the null file for [%s]\n"
-#~ "(all zero cells will then be considered no data)? "
-#~ msgstr "के लिए n सभी "
+msgid ""
+"\n"
+"Do you want to delete the null file for [%s]\n"
+"(all zero cells will then be considered no data)? "
+msgstr "के लिए n सभी "
 #, fuzzy
-#~ msgid "%s map <%s> not found"
-#~ msgstr "नहीं"
+msgid "%s map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
+msgid "Category file for <%s> not updated"
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
+msgid "Category file for <%s> updated"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "एकल त्रुटि"
+msgid "Suppress single crossing error messages"
+msgstr "एकल त्रुटि"
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "का"
+msgid "Unable to find starting vector <%s> "
+msgstr "का"
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
+msgid "Unable to find stop vector <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "नहीं प्रारंभ"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "नहीं प्रारंभ"
 #, fuzzy
-#~ msgid "Memory allocation error on reading start points from raster map %s"
-#~ msgstr "त्रुटि चालू प्रारंभ"
+msgid "Memory allocation error on reading start points from raster map %s"
+msgstr "त्रुटि चालू प्रारंभ"
 #, fuzzy
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "लागू करें फ़िल्टर"
+msgid "Apply filter only to zero data values"
+msgstr "लागू करें फ़िल्टर"
 #, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Error reading '%s' map"
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Cell file not found"
-#~ msgstr "नहीं n"
+msgid "Cell file not found"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "नहीं"
+msgid "Vector map <%s> not found in the current mapset"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "सेट इंचेस"
+msgid "Threshold distance"
+msgstr "सेट इंचेस"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "चालू"
+msgid "Cannot execute: %s"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "फ़ाइल"
+msgid "Cannot link table: %s"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open dxf file <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "का"
+msgid "Cannot open new vector map <%s>"
+msgstr "का"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "a a."
+msgid "Conversion of <%s> to vector map:"
+msgstr "a a."
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgstr "नहीं"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "नहीं"
+msgid "Do not print polyline info"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "नहीं"
+msgid "Network input map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "पूछें n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr "पूछें n"
 #, fuzzy
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr "का n"
+msgid " Number of points that have been entered: %d\n"
+msgstr "का n"
 #, fuzzy
-#~ msgid "Quiet; No chatter"
-#~ msgstr "शांत नहीं"
+msgid "Quiet; No chatter"
+msgstr "शांत नहीं"
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "उभारें के लिए पाठ के लिए"
+msgid "Hilight color for text"
+msgstr "उभारें के लिए पाठ के लिए"
 #, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "ऊंचाई f n"
+msgid "Line: %d\n"
+msgstr "ऊंचाई f n"
 #, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure"
-#~ msgstr "के लिए का."
+msgid "Insufficent memory for allocation of data structure"
+msgstr "के लिए का."
 #, fuzzy
-#~ msgid "imagery group"
-#~ msgstr "समूह"
+msgid "imagery group"
+msgstr "समूह"
 #, fuzzy
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "का"
+msgid "Name of input raster map(s)"
+msgstr "का"
 #, fuzzy
-#~ msgid "name=%s\n"
-#~ msgstr "n"
+msgid "name=%s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "mapset=%s\n"
-#~ msgstr "n"
+msgid "mapset=%s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "fullname=%s\n"
-#~ msgstr "n"
+msgid "fullname=%s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "संकेत n"
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr "संकेत n"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "के लिए भाग n"
+msgid "Illegal file name for real part: %s"
+msgstr "के लिए भाग n"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
-#~ msgstr "n"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr "n"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
+msgid "Illegal group name <%s>"
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
+msgid "Illegal signature file name <%s>"
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "के लिए"
+msgid "Raster file(s) for Elevation"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "के लिए"
+msgid "Raster file(s) for Color"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Current window not settable"
-#~ msgstr "नहीं"
+msgid "Current window not settable"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "नहीं"
+msgid "Can't clear current graphics window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot use current window"
-#~ msgstr "नहीं"
+msgid "Cannot use current window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
-#~ msgstr "चालू."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
+msgstr "चालू."
 #, fuzzy
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr "नहीं"
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr "a R जी"
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr "a R जी"
 #, fuzzy
-#~ msgid "Don't add to list of commands in monitor"
-#~ msgstr "का"
+msgid "Don't add to list of commands in monitor"
+msgstr "का"
 #, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "नहीं"
+msgid "No current frame"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Current frame not available"
-#~ msgstr "नहीं"
+msgid "Current frame not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Error reading raster map"
+msgid "Error reading raster map"
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
-#~ msgstr "आकार "
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
+msgstr "आकार "
 #, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "त्रुटि"
+msgid "Error opening cell-file"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Error reading from cell-file"
+msgid "Error reading from cell-file"
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "नहीं"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr "n"
+msgid " Middle: toggle flash color\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "No raster map exists in current window"
-#~ msgstr "नहीं"
+msgid "No raster map exists in current window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "No current window"
-#~ msgstr "नहीं"
+msgid "No current window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Current window not available"
-#~ msgstr "नहीं"
+msgid "Current window not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Error in calculating conversions"
-#~ msgstr "त्रुटि"
+msgid "Error in calculating conversions"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "No current graphics window"
-#~ msgstr "नहीं"
+msgid "No current graphics window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Current graphics window not available"
-#~ msgstr "नहीं"
+msgid "Current graphics window not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Can't set current graphics window"
-#~ msgstr "नहीं"
+msgid "Can't set current graphics window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "n"
+msgid "Getting graphics window coordinates"
+msgstr "n"
 #, fuzzy
-#~ msgid "value [%.0f,%.0f] out of range [0-100]"
-#~ msgstr "का"
+msgid "value [%.0f,%.0f] out of range [0-100]"
+msgstr "का"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "फ़ाइल के लिए."
+msgid "Font name or pathname of TTF file"
+msgstr "फ़ाइल के लिए."
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr "रिलीज का फ्री-टाइप n"
+msgid "Setting release of FreeType"
+msgstr "रिलीज का फ्री-टाइप n"
 #, fuzzy
-#~ msgid "Display number of colors"
+msgid "Display number of colors"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Use mouse to size & place legend"
-#~ msgstr "आकार "
+msgid "Use mouse to size & place legend"
+msgstr "आकार "
 #, fuzzy
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "का"
+msgid "Name of frame(s) to save"
+msgstr "का"
 #, fuzzy
-#~ msgid "Save current frame"
-#~ msgstr "नहीं"
+msgid "Save current frame"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Save all the frames"
-#~ msgstr "a"
+msgid "Save all the frames"
+msgstr "a"
 #, fuzzy
-#~ msgid "No monitor selected"
-#~ msgstr "नहीं"
+msgid "No monitor selected"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "अज्ञात क़िस्म"
+msgid "Unknown item type in pad: %s"
+msgstr "अज्ञात क़िस्म"
 #, fuzzy
-#~ msgid ""
-#~ "Don't add to list of vectors and commands in monitor (it won't be drawn "
-#~ "if the monitor is refreshed)"
-#~ msgstr "का है"
+msgid ""
+"Don't add to list of vectors and commands in monitor (it won't be drawn if "
+"the monitor is refreshed)"
+msgstr "का है"
 #, fuzzy
-#~ msgid "No raster map exists in the current window"
-#~ msgstr "नहीं"
+msgid "No raster map exists in the current window"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "पाठ चालू."
 #, fuzzy
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "का"
+msgid "Sets the color of the menu background"
+msgstr "का"
 #, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "का पाठ"
+msgid "Sets the color of the menu text"
+msgstr "का पाठ"
 #, fuzzy
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "का पाठ"
+msgid "Sets the color dividing lines of text"
+msgstr "का पाठ"
 #, fuzzy
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "पाठ आकार  संख्या"
+msgid "Sets the menu text size (in percent)"
+msgstr "पाठ आकार  संख्या"
 #, fuzzy
-#~ msgid "Menu must contain a title and at least one option"
-#~ msgstr "पर एक"
+msgid "Menu must contain a title and at least one option"
+msgstr "पर एक"
 #, fuzzy
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr "पाठ."
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr "पाठ."
 #, fuzzy
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "का है तल बायाँ"
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr "का है तल बायाँ"
 #, fuzzy
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "ऊंचाई का का ऊंचाई"
+msgid "Height of letters (in percent of available frame height)"
+msgstr "ऊंचाई का का ऊंचाई"
 #, fuzzy
-#~ msgid "Either text or -c should be given"
-#~ msgstr "पाठ"
+msgid "Either text or -c should be given"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "Choose only one coordinate system for placement"
-#~ msgstr "एक के लिए"
+msgid "Choose only one coordinate system for placement"
+msgstr "एक के लिए"
 #, fuzzy
-#~ msgid "No font selected"
-#~ msgstr "नहीं"
+msgid "No font selected"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to create text conversion context"
-#~ msgstr "पाठ"
+msgid "Unable to create text conversion context"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "Text conversion error"
-#~ msgstr "त्रुटि"
+msgid "Text conversion error"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "नहीं"
+msgid "No predefined font"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file; use the default"
-#~ msgstr "फ्री-टाइप"
+msgid "%s: Unable to read FreeType definition file; use the default"
+msgstr "फ्री-टाइप"
 #, fuzzy
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "नहीं फ्री-टाइप"
+msgid "%s: No FreeType definition file"
+msgstr "नहीं फ्री-टाइप"
 #, fuzzy
-#~ msgid "%s: Unable to read FreeType definition file"
+msgid "%s: Unable to read FreeType definition file"
+msgstr "फ्री-टाइप"
 #, fuzzy
-#~ msgid "Don't add to list of rasters and commands in monitor"
-#~ msgstr "का"
+msgid "Don't add to list of rasters and commands in monitor"
+msgstr "का"
 #, fuzzy
-#~ msgid "One mouse click only"
-#~ msgstr "एक"
+msgid "One mouse click only"
+msgstr "एक"
 #, fuzzy
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "स्केल"
+msgid "Use mouse to interactively place scale"
+msgstr "स्केल"
 #, fuzzy
-#~ msgid "Use mouse to interactively place text"
-#~ msgstr "स्केल"
+msgid "Use mouse to interactively place text"
+msgstr "स्केल"
 #, fuzzy
-#~ msgid " Left:    Place text here\n"
-#~ msgstr "n"
+msgid " Left:    Place text here\n"
+msgstr "n"
 #, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr "n"
+msgid " Right:   Quit\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "त्रुटि नहीं n"
+msgid "ERROR: can not get \"list\" items"
+msgstr "त्रुटि नहीं n"
 #, fuzzy
-#~ msgid "-j flag forced"
-#~ msgstr "n"
+msgid "-j flag forced"
+msgstr "n"
 #, fuzzy
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "You must select more than one point"
-#~ msgstr "अधिक एक बिन्दु"
+msgid "You must select more than one point"
+msgstr "अधिक एक बिन्दु"
 #, fuzzy
-#~ msgid "You must select at least four points"
-#~ msgstr "पर"
+msgid "You must select at least four points"
+msgstr "पर"
 #, fuzzy
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "का"
+msgid "No raster or vector map displayed"
+msgstr "का"
 #, fuzzy
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "का a."
+msgid "To establish and control use of a graphics display monitor."
+msgstr "का a."
 #, fuzzy
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "का प्रारंभ"
+msgid "Name of graphics monitor to start"
+msgstr "का प्रारंभ"
 #, fuzzy
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "का"
+msgid "Name of graphics monitor to stop"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "का"
+msgid "Name of graphics monitor to select"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "का"
+msgid "Name of graphics monitor to unlock"
+msgstr "का"
 #, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "सभी"
+msgid "List all monitors"
+msgstr "सभी"
 #, fuzzy
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "सभी स्थिति"
+msgid "List all monitors (with current status)"
+msgstr "सभी स्थिति"
 #, fuzzy
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "छापें का"
+msgid "Print name of currently selected monitor"
+msgstr "छापें का"
 #, fuzzy
-#~ msgid "Release currently selected monitor"
+msgid "Release currently selected monitor"
+msgstr "छापें का"
 #, fuzzy
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "नहीं"
+msgid "Do not automatically select when starting"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "No such monitor as <%s>"
-#~ msgstr "नहीं"
+msgid "No such monitor as <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Monitor <%s> released"
-#~ msgstr "नहीं"
+msgid "Monitor <%s> released"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
-#~ msgstr "त्रुटि"
+msgid "Error - Locking mechanism failed"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
+msgid "Error choosing frame [%s]\n"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr "n n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "a"
+msgid "Left:   Select frame\n"
+msgstr "a"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "बाहर जाएँ n"
+msgid "Right:  Accept frame\n"
+msgstr "बाहर जाएँ n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
+msgid "Manages display frames on the user's graphics monitor."
 #, fuzzy
-#~ msgid "Create a new frame"
-#~ msgstr "a"
+msgid "Create a new frame"
+msgstr "a"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "a"
+msgid "Select a frame"
+msgstr "a"
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
+msgstr "छापें का"
 #, fuzzy
-#~ msgid "Print names of all frames"
+msgid "Print names of all frames"
+msgstr "छापें का"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Debugging output"
-#~ msgstr "डिबगिंग"
+msgid "Debugging output"
+msgstr "डिबगिंग"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "ढांचा"
+msgid "Frame to be created/selected"
+msgstr "ढांचा"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr "n n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr "n n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
-#~ msgstr "a"
+msgid "Left:   Select From\n"
+msgstr "a"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr "n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "n"
+msgid "Monitor: interactive command in redraw"
+msgstr "n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "का n"
+msgid "found %d visuals of type TrueColor"
+msgstr "का n"
 #, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "के लिए n"
+msgid "searching for highest bit depth"
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "n"
+msgid "selected %d bit depth"
+msgstr "n"
 #, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "है n"
+msgid "using default visual which is %s"
+msgstr "है n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "n"
+msgid "Monitor: XGetWMName failed"
+msgstr "n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "n"
 #, fuzzy
-#~ msgid "Save the current region to region definition file"
-#~ msgstr "सहेजें"
+msgid "Save the current region to region definition file"
+msgstr "सहेजें"
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "है"
+msgid "<%s> is an illegal region name"
+msgstr "है"
 #, fuzzy
-#~ msgid "No LatLong information for XY-Projection"
-#~ msgstr "है नहीं के लिए"
+msgid "No LatLong information for XY-Projection"
+msgstr "है नहीं के लिए"
 #, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "n"
+msgid "Erasing monitors ..."
+msgstr "n"
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "नहीं"
+msgid "Could not open input file <%s>."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "No such monitor as '%s'"
-#~ msgstr "नहीं"
+msgid "No such monitor as '%s'"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Error - No such monitor as '%s'"
-#~ msgstr "नहीं"
+msgid "Error - No such monitor as '%s'"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist:"
-#~ msgstr "n नहीं:"
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist:"
+msgstr "n नहीं:"
 #, fuzzy
-#~ msgid "Removing files from group"
-#~ msgstr "समूह"
+msgid "Removing files from group"
+msgstr "समूह"
 #, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "समूह"
+msgid "Adding files to group [%s]"
+msgstr "समूह"
 #, fuzzy
-#~ msgid "Writing group REF"
-#~ msgstr "समूह"
+msgid "Writing group REF"
+msgstr "समूह"
 #, fuzzy
-#~ msgid "Found file <%s@%s> in group."
-#~ msgstr "समूह."
+msgid "Found file <%s@%s> in group."
+msgstr "समूह."
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
-#~ msgstr "का"
+msgid "Unable to open file: <%s>"
+msgstr "का"
 #, fuzzy
-#~ msgid "Multiplier"
-#~ msgstr "के लिए ज़ेड"
+msgid "Multiplier"
+msgstr "के लिए ज़ेड"
 #, fuzzy
-#~ msgid ""
-#~ "Projection of input dataset and current location appear to match.\n"
-#~ "Proceeding with import...\n"
-#~ msgstr "का जोड़ा n"
+msgid ""
+"Projection of input dataset and current location appear to match.\n"
+"Proceeding with import...\n"
+msgstr "का जोड़ा n"
 #, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "नहीं"
+msgid "not found\n"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "नहीं"
+msgid "Raster map not found."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: can't read range for [%s]"
-#~ msgstr "के लिए"
+msgid "%s: can't read range for [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
-#~ msgstr "नहीं"
+msgid "Raster file [%s] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
-#~ msgstr "i n"
+msgid "It was not possible writing in <%s>."
+msgstr "i n"
 #, fuzzy
-#~ msgid "\rDuplicate area centroids: %5d"
+msgid "\rDuplicate area centroids: %5d"
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
-#~ msgstr "चालू"
+msgid "Cannot create table: '%s'"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "नहीं"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
-#~ msgstr "नहीं"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to write line %d"
-#~ msgstr "बनाया जा रहा है."
+msgid "Unable to write line %d"
+msgstr "बनाया जा रहा है."
 #, fuzzy
-#~ msgid "Unable to delete line %d"
-#~ msgstr "फ़ाइल"
+msgid "Unable to delete line %d"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Unknown query tool '%s'"
 #, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "नहीं"
+msgid "No layer database connection"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "लोड हो गया"
+msgid "%d categories loaded from the database"
+msgstr "लोड हो गया"
 #, fuzzy
-#~ msgid "Done"
-#~ msgstr "n"
+msgid "Done"
+msgstr "n"
 #, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "स्रोत"
+msgid "Cannot open OGR data source '%s'"
+msgstr "स्रोत"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "सदिश नहीं"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "सदिश नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr "है के लिए."
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr "है के लिए."
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "नहीं"
+msgid "Column type [%d] not supported"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "का"
+msgid "Cannot read map header for <%s>"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
+msgid "Cannot read category file for <%s>"
 #, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "छापें"
+msgid "Print;Shell Script"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "Creating support files for [%s]."
-#~ msgstr "बनाया जा रहा है के लिए."
+msgid "Creating support files for [%s]."
 #, fuzzy
-#~ msgid "Category file for [%s] not available"
-#~ msgstr "के लिए नहीं"
+msgid "Category file for [%s] not available"
+msgstr "के लिए नहीं"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr "नहीं"
+msgid "%s: <%s> raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 #, fuzzy
-#~ msgid "%s - map not found"
-#~ msgstr "नहीं"
+msgid "%s - map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
-#~ msgstr "फ़ाइल"
+msgid "%s: Cannot open [%s]"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "%s not found"
-#~ msgstr "नहीं"
+msgid "%s not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not access %s layer"
-#~ msgstr "नहीं"
+msgid "Could not access %s layer"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "नहीं"
+msgid "Vector map %s - not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Raster map name for storing results"
-#~ msgstr "के लिए"
+msgid "Raster map name for storing results"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "ऊंचाई का"
+msgid "Height of the viewing location"
+msgstr "ऊंचाई का"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
-#~ msgstr "नहीं"
+msgid "%s: <%s> cellfile not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
-#~ msgstr "नहीं n"
+msgid "Cell file [%s] not found\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
-#~ msgstr "नहीं"
+msgid "rgb cell map [%s] not found\n"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
-#~ msgstr "नहीं"
+msgid "vector cell map [%s] not found\n"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgstr "नहीं"
+msgid "%s - %s not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "raster map <%s> not found"
-#~ msgstr "नहीं"
+msgid "raster map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "के लिए"
+msgid "can't read header for <%s> in <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "region <%s> not found"
-#~ msgstr "नहीं"
+msgid "region <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "invalid region: %s"
-#~ msgstr "अवैध"
+msgid "invalid region: %s"
+msgstr "अवैध"
 #, fuzzy
-#~ msgid "Creating support files"
-#~ msgstr "बनाया जा रहा है के लिए"
+msgid "Creating support files"
+msgstr "बनाया जा रहा है के लिए"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
-#~ msgstr "नहीं!"
+msgid "%s file [%s] not found!"
+msgstr "नहीं!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
-#~ msgstr "नहीं"
+msgid "%s: %s - map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
-#~ msgstr "के लिए"
+msgid "%s: unable to open %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "%s - not found"
-#~ msgstr "नहीं"
+msgid "%s - not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "[%s] map not found."
-#~ msgstr "नहीं"
+msgid "[%s] map not found."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "[%s] map not found"
-#~ msgstr "नहीं"
+msgid "[%s] map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
-#~ msgstr "नहीं"
+msgid "elevation file [%s] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "ढाल ढाल"
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "ढाल ढाल"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot describe table <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
-#~ msgstr "के लिए"
+msgid "Cannot insert values: %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "स्रोत"
+msgid "Unable to open database %s by driver %s"
+msgstr "स्रोत"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr "नहीं सेट"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "नहीं सेट"
 #, fuzzy
-#~ msgid "Could not find input %s"
-#~ msgstr "नहीं"
+msgid "Could not find input %s"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open input"
-#~ msgstr "नहीं"
+msgid "Could not open input"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open output"
-#~ msgstr "नहीं"
+msgid "Could not open output"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "नहीं"
+msgid "Could not find input map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Database connection not defined\n"
-#~ msgstr "नहीं n"
+msgid "Database connection not defined\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "के लिए"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "के लिए"
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Can't write region <%s>"
 #, fuzzy
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "अवैध"
+msgid "<%s=%s> ** invalid input **"
+msgstr "अवैध"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "नहीं."
+msgid "No graphics device selected."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Training map [%s] not found."
-#~ msgstr "नहीं."
+msgid "Training map [%s] not found."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "%s map not found"
-#~ msgstr "नहीं"
+msgid "%s map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "input raster map"
-#~ msgstr "का"
+msgid "input raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "Illegal file name: %s"
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "के लिए"
+msgid "Cannot get layer info for vector map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr "के लिए"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "कवर का कवर"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "कवर का कवर"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "नहीं"
+msgid "%s: %s - raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "%s: ERROR reading category file for %s"
 #, fuzzy
-#~ msgid "%s: %s - not found"
-#~ msgstr "नहीं"
+msgid "%s: %s - not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
-#~ msgstr "है"
+msgid "%s: %s - illegal units"
+msgstr "है"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
-#~ msgstr "नहीं"
+msgid "%s: %s - can't open"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "छवि "
+msgid "Reading input map (%s)    ... "
+msgstr "छवि "
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
-#~ msgstr "त्रुटि चल रहा है..."
+msgid "%s - ERROR reading %s"
+msgstr "त्रुटि चल रहा है..."
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
-#~ msgstr "के लिए"
+msgid "%s: %s - can't create raster map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
-#~ msgstr "n"
+msgid "Writing output map (%s)   ... "
+msgstr "n"
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "%s - ERROR writing %s"
+msgid "%s - ERROR writing %s"
 #, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "n"
+msgid "Reading raster map... "
+msgstr "n"
 #, fuzzy
-#~ msgid "Writing raster map... "
-#~ msgstr "n"
+msgid "Writing raster map... "
+msgstr "n"
 #, fuzzy
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "जी 13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "जी 13"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot find file %s"
-#~ msgstr "फ़ाइल"
+msgid "Cannot find file %s"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
-#~ msgstr "का"
+msgid "Cannot get header for %s"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "के लिए"
+msgid "Cannot create vector map %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "का"
+msgid "Number of raster rows to hold in memory"
+msgstr "का"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "छापें"
+msgid "Print raster map title only"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "unknown type: %d"
+msgid "unknown type: %d"
 #, fuzzy
-#~ msgid "Cannot get raster band."
-#~ msgstr "फील्ड"
+msgid "Cannot get raster band."
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr "के लिए"
+msgid "Cannot allocate buffer for reading null values."
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "का"
+msgid "Cannot read GRASS raster."
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
-#~ msgstr "के लिए"
+msgid "Cannot get [%s] driver"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
-#~ msgstr "नहीं n"
+msgid "Couldn't set geo transform."
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Couldn't set projection."
-#~ msgstr "नहीं n"
+msgid "Couldn't set projection."
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
-#~ msgstr "का"
+msgid "Cannot export [%s] raster map."
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open TIFF file <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "नहीं"
+msgid "Cannot open output map."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "%s: can't open %s"
-#~ msgstr "नहीं"
+msgid "%s: can't open %s"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
-#~ msgstr "n"
+msgid "Reading raster map <%s> ..."
+msgstr "n"
 #, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "के लिए का"
+msgid "memory allocation failure"
+msgstr "के लिए का"
 #, fuzzy
-#~ msgid "Can't find clump map."
-#~ msgstr "नहीं."
+msgid "Can't find clump map."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "त्रुटि"
+msgid "Output terrain only vector map name"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
-#~ msgstr "n"
+msgid "Rebuilding topology ..."
+msgstr "n"
 #, fuzzy
-#~ msgid "No record for cat = %d"
-#~ msgstr "नहीं के लिए"
+msgid "No record for cat = %d"
+msgstr "नहीं के लिए"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "n"
+msgid "Attaching islands ..."
+msgstr "n"
 #, fuzzy
-#~ msgid "Attaching centroids ..."
-#~ msgstr "n"
+msgid "Attaching centroids ..."
+msgstr "n"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "नहीं"
+msgid "Vector map <%s> not found in current mapset"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
-#~ msgstr "के लिए"
+msgid "Error allocating memory for `lines_visited'"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "संख्या का पिक्सेल्स a"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "संख्या का पिक्सेल्स a"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "नहीं"
+msgid "Database connection not defined for layer <%d>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot get layer info"
-#~ msgstr "फील्ड"
+msgid "Cannot get layer info"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
-#~ msgstr "नहीं"
+msgid "cell file [%s] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
-#~ msgstr "के लिए"
+msgid "can't open raster map [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "के लिए"
+msgid "Cannot rewrite line %d"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "n"
+msgid "Editing tool"
+msgstr "n"
 #, fuzzy
-#~ msgid "Snap also to vertex (not implemented yet)"
-#~ msgstr "नहीं"
+msgid "Snap also to vertex (not implemented yet)"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "नहीं"
+msgid "Cannot copy line %d, editing terminated"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "No layer database connection."
-#~ msgstr "नहीं"
+msgid "No layer database connection."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
-#~ msgstr "फ़ाइल"
+msgid "Cannot snap lines %d,%d"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "n"
+msgid "%d lines modified"
+msgstr "n"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
-#~ msgstr "नहीं"
+msgid "Could not open ASCII file <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "छापें"
+msgid "Print vector map region only"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "के लिए"
+msgid "Cannot get layer info for vector map <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Rotation angle (degrees counter-clockwise from East)"
-#~ msgstr "कोण कोण पूर्व"
+msgid "Rotation angle (degrees counter-clockwise from East)"
+msgstr "कोण कोण पूर्व"
 #, fuzzy
-#~ msgid "Number of ROWS and COLUMNS in grid"
+msgid "Number of ROWS and COLUMNS in grid"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "नहीं"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
-#~ msgstr "नहीं"
+msgid "Could not find input map <%s>."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "का."
+msgid "Parameter <%s> not set"
+msgstr "का."
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "i n"
+msgid "Output map where segments will be written"
+msgstr "i n"
 #, fuzzy
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "के लिए"
+msgid "Cannot get layer information for vector map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
-#~ msgstr "नहीं."
+msgid "<%s> cellfile not found"
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
+msgid "Database record for cat %d not found"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
-#~ msgstr "के लिए"
+msgid "Not able to open vector map <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Table name, select all from this table"
-#~ msgstr "सभी"
+msgid "Table name, select all from this table"
+msgstr "सभी"
 #, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "फील्ड"
+msgid "output field separator"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "नहीं"
+msgid "do not include column names in output"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "का"
+msgid "vertical output (instead of horizontal)"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr "का"
+msgid "Name of existing raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "के लिए"
+msgid "Cannot find mapset for %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot open File %s"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open File %s"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
-#~ msgstr "के लिए"
+msgid "Not able to open file for [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Label file [%s] not available"
-#~ msgstr "नहीं"
+msgid "Label file [%s] not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "के लिए"
+msgid "unable to open [%s] in [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgstr "के लिए"
+msgid "warning: unable to open [%s] in [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Table to be imported"
-#~ msgstr "फ़ाइल"
+msgid "Table to be imported"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "का a"
+msgid "Unable to create raster map [%s]"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
-#~ msgstr "i n"
+msgid "Unable to create output <%s>"
+msgstr "i n"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "नहीं."
+msgid "Input file [%s] not found."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "के लिए"
+msgid "Multiplier for ascii data"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
-#~ msgstr "नहीं"
+msgid "Could not open temporary file: [%s]"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
-#~ msgstr "नहीं"
+msgid "Could not open input file [%s]"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Cannot open file for <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open file for <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Name of the random surface to be produced"
-#~ msgstr "का"
+msgid "Name of the random surface to be produced"
+msgstr "का"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#~ msgstr "नहीं"
+msgid "Vector <%s> could not be opened"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
+msgid "No db connection for driver <%s> defined. Run db.connect."
+msgstr "नहीं सेट"
 #, fuzzy
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr "छापें n"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr "छापें n"
 #, fuzzy
-#~ msgid "z column name"
-#~ msgstr "ज़ेड"
+msgid "z column name"
+msgstr "ज़ेड"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
-#~ msgstr "फ़ाइल"
+msgid "Cannot drop table: %s"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open labels <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr "n n फ़ाइल"
+msgid ""
+"OGR output datasource name. For example:\n"
+"\t\tESRI Shapefile: filename or directory for storage\n"
+"\t\tMapInfo File: filename or directory for storage"
+msgstr "n n फ़ाइल"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "नहीं"
+msgid "SVG file <%s> cannot be opened"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "छवि "
+msgid "Querying input '%s' ... "
+msgstr "छवि "
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "का"
+msgid "Copying %s input lines ... "
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
-#~ msgstr "चालू"
+msgid "Cannot create table <%s>"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "no record for cat = %d"
+msgid "no record for cat = %d"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
-#~ msgstr "के लिए"
+msgid "cannot insert row: %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "नहीं"
+msgid "Cannot find line of cat %d"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
-#~ msgstr "के लिए"
+msgid "Unalbe to open vector map <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
-#~ msgstr "नहीं के लिए."
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgstr "नहीं के लिए."
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "एक."
+msgid "Transforms a vector map via a set of tie points."
+msgstr "एक."
 #, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "का"
+msgid "Read coordinates from standard input"
+msgstr "का"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "नहीं"
+msgid "Raster map <%s>] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "प्रारंभ."
+msgid "Cannot start driver '%s'."
+msgstr "प्रारंभ."
 #, fuzzy
-#~ msgid "Cannot start driver <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "प्रारंभ."
 #, fuzzy
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "है"
+msgid "[%s] is an illegal name"
+msgstr "है"
 #, fuzzy
-#~ msgid "Not able to open cellfile for [%s]"
-#~ msgstr "के लिए"
+msgid "Not able to open cellfile for [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
-#~ msgstr "के लिए"
+msgid "Not able to find cellfile [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Raster map [%s] not available"
-#~ msgstr "नहीं"
+msgid "Raster map [%s] not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "color file for [%s] not available"
+msgid "color file for [%s] not available"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "नहीं"
+msgid "Raster file [%s] not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "नहीं"
+msgid "Raster map [%s] not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
-#~ msgstr "का a"
+msgid "Unable to open raster map [%s]"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
+msgstr "सदिश नहीं"
 #, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "है"
+msgid "<%s> illegal name"
+msgstr "है"
 #, fuzzy
-#~ msgid "Out of Memory!\n"
-#~ msgstr "का n"
+msgid "Out of Memory!\n"
+msgstr "का n"
 #, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
-#~ msgstr "n"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Insufficent memory for allocation of data sturcture"
+msgid "Insufficent memory for allocation of data sturcture"
+msgstr "के लिए का"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
-#~ msgstr "के लिए."
+msgid "%s: %s - illegal name for output raster map."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Insufficent memory for allocation of data structure."
+msgid "Insufficent memory for allocation of data structure."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgstr "a a."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgstr "a a."
 #, fuzzy
-#~ msgid "%s: <%s> not found"
-#~ msgstr "नहीं"
+msgid "%s: <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
-#~ msgstr "है"
+msgid "%s: <%s> illegal name"
+msgstr "है"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
-#~ msgstr "नहीं"
+msgid "%s: Cannot open <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "could not read range file"
-#~ msgstr "नहीं"
+msgid "could not read range file"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
-#~ msgstr "के लिए"
+msgid "Filtering [%s] in [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
-#~ msgstr "खोलें"
+msgid "Open raster map %s in %s = %d"
+msgstr "खोलें"
 #, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "बनाया जा रहा है n"
+msgid "Closing raster map"
+msgstr "बनाया जा रहा है n"
 #, fuzzy
-#~ msgid "Swap temp files"
-#~ msgstr "का"
+msgid "Swap temp files"
+msgstr "का"
 #, fuzzy
-#~ msgid "Writing [%s]"
-#~ msgstr "n"
+msgid "Writing [%s]"
+msgstr "n"
 #, fuzzy
-#~ msgid "%s: illegal map name"
-#~ msgstr "है"
+msgid "%s: illegal map name"
+msgstr "है"
 #, fuzzy
-#~ msgid "Name of the new raster map"
-#~ msgstr "का"
+msgid "Name of the new raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
-#~ msgstr "है"
+msgid "%s: <%s> illegal file name"
+msgstr "है"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr "a a छवि पर का."
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr "a a छवि पर का."
 #, fuzzy
-#~ msgid "Mapset of input map"
-#~ msgstr "का"
+msgid "Mapset of input map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "का"
+msgid "Checking location %s, mapset %s:"
+msgstr "का"
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "समूह के लिए n"
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgstr "समूह के लिए n"
 #, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "का"
+msgid "Error writing output map"
+msgstr "का"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
-#~ msgstr "है"
+msgid "<%s> is illegal file name"
+msgstr "है"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
-#~ msgstr "है"
+msgid "[%s] is an illegal file name"
+msgstr "है"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "नहीं."
+msgid "no rules specified"
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Names of existing raster maps"
-#~ msgstr "का"
+msgid "Names of existing raster maps"
+msgstr "का"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "%s - illegal name "
-#~ msgstr "है"
+msgid "%s - illegal name "
+msgstr "है"
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
-#~ msgstr "का"
+msgid "Couldn't find raster map [%s]"
+msgstr "का"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
-#~ msgstr "त्रुटि"
+msgid "%s in %s -can't open raster map"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
-#~ msgstr "के लिए"
+msgid "%s - can't create raster map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "सामान्य किया"
+msgid "Normalized"
+msgstr "सामान्य किया"
 #, fuzzy
-#~ msgid "Out of memory!"
-#~ msgstr "का"
+msgid "Out of memory!"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
-#~ msgstr "नहीं n"
+msgid "Cell file [%s] not found"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Error getting input null cells at row %d from %s"
-#~ msgstr "त्रुटि पर"
+msgid "Error getting input null cells at row %d from %s"
+msgstr "त्रुटि पर"
 #, fuzzy
-#~ msgid "[%s] file name not legal"
-#~ msgstr "है"
+msgid "[%s] file name not legal"
+msgstr "है"
 #, fuzzy
-#~ msgid "[%s] file name not legal\n"
-#~ msgstr "है"
+msgid "[%s] file name not legal\n"
+msgstr "है"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "नहीं"
+msgid "Requested 3d raster map not found <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open elevation map"
-#~ msgstr "नहीं n"
+msgid "Could not open elevation map"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Could not open output map"
-#~ msgstr "नहीं"
+msgid "Could not open output map"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
-#~ msgstr "का"
+msgid "Cannot create output map [%s]"
+msgstr "का"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
-#~ msgstr "नहीं"
+msgid "Database's name couldn't be read"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "का"
+msgid "Cannot open vector points map <%s>"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#~ msgstr "के लिए"
+msgid "Cannot create vector map <%s>"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
+msgstr "नहीं सेट"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
-#~ msgstr "नहीं"
+msgid "Could not find input map <%s> in current mapset."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
+msgstr "सदिश नहीं"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
-#~ msgstr "स्रोत"
+msgid "Cannot open database <%s>"
+msgstr "स्रोत"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open table <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open driver <%s>"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
-#~ msgstr "नहीं"
+msgid "Could not find input vector map %s"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
-#~ msgstr "नहीं."
+msgid "Could not find input map '%s'."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
-#~ msgstr "नहीं."
+msgid "Could not find network input map '%s'."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "त्रुटि."
+msgid "error opening raster map [%s]."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Topology is not available"
-#~ msgstr "नहीं"
+msgid "Topology is not available"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "n"
+msgid "Patching file <%s@%s>"
+msgstr "n"
 #, fuzzy
-#~ msgid "Column type  not supported"
-#~ msgstr "नहीं"
+msgid "Column type  not supported"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "नहीं"
+msgid "Could not open vector map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Name of output raster map"
-#~ msgstr "का"
+msgid "Name of output raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
 #, fuzzy
-#~ msgid "Pass [%d] of [%d]:"
-#~ msgstr "n"
+msgid "Pass [%d] of [%d]:"
+msgstr "n"
 #, fuzzy
-#~ msgid "Illegal output name: '%s'"
-#~ msgstr "चेतावनी."
+msgid "Illegal output name: '%s'"
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "Can't create output map"
-#~ msgstr "का"
+msgid "Can't create output map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Could not close new 3d raster map"
-#~ msgstr "नहीं"
+msgid "Could not close new 3d raster map"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "नहीं."
+msgid "%s: cellfile [%s] not found."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Error reading wildcard."
+msgid "Error reading wildcard."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ msgstr "a R जी"
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+msgstr "a R जी"
 #, fuzzy
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "a R जी"
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "a R जी"
 #, fuzzy
-#~ msgid "Border not yet implemented for LatLong locations: border not drawn."
-#~ msgstr "किनारा नहीं के लिए नहीं."
+msgid "Border not yet implemented for LatLong locations: border not drawn."
+msgstr "किनारा नहीं के लिए नहीं."
 #, fuzzy
-#~ msgid "name for new raster map"
-#~ msgstr "का"
+msgid "name for new raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Output GRASS image file"
-#~ msgstr "छवि."
+msgid "Output GRASS image file"
+msgstr "छवि."
 #, fuzzy
-#~ msgid "Resulting output map"
-#~ msgstr "का"
+msgid "Resulting output map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Resulting output grid3D volume"
-#~ msgstr "का"
+msgid "Resulting output grid3D volume"
+msgstr "का"
 #, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "का"
+msgid "name for new vector map"
+msgstr "का"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "के लिए के लिए"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "के लिए के लिए"
 #, fuzzy
-#~ msgid "Input vector map"
-#~ msgstr "का"
+msgid "Input vector map"
+msgstr "का"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
-#~ msgstr "त्रुटि"
+msgid "%s: ERROR can't open tempfile"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "vector map <%s> not found"
-#~ msgstr "नहीं"
+msgid "vector map <%s> not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "नहीं"
+msgid "<%s> raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
-#~ msgstr "का"
+msgid "<%s> unable to open raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#~ msgstr "नहीं"
+msgid "Cannot find vector map [%s]"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_hi.po (grassmods_hi)  #-#-#-#-#\n"
-#~ "त्रुटि\n"
+msgid "%s - can't open raster map"
+msgstr ""
+"#-#-#-#-#  grassmods_hi.po (grassmods_hi)  #-#-#-#-#\n"
+"त्रुटि\n"
 #, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgstr "नहीं"
+msgid "%s - raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "File name of classification result"
-#~ msgstr "फ़ाइल का"
+msgid "File name of classification result"
+msgstr "फ़ाइल का"
 #, fuzzy
-#~ msgid "File name of reference classes"
+msgid "File name of reference classes"
+msgstr "फ़ाइल का"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "n"
+msgid "<%s> - illegal output file name"
+msgstr "n"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
-#~ msgstr "नहीं"
+msgid "%s: <%s> reference map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "नहीं"
+msgid "%s: raster map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map that represents the elevation, used for the 3D information"
-#~ msgstr "के लिए"
+msgid "Raster map that represents the elevation, used for the 3D information"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
-#~ msgstr "त्रुटि"
+msgid "Problem opening input file [%s]"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#~ msgstr "का"
+msgid "Problem opening output file [%s]"
+msgstr "का"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
-#~ msgstr "संपादन के लिए "
+msgid "can't write category file for <%s>"
+msgstr "संपादन के लिए "
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
-#~ msgstr "त्रुटि"
+msgid "%s: can't open tempfile"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
-#~ msgstr "का a"
+msgid "Unable to read row %d in raster map [%s]"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Topographic index ln(a/tanB) map"
-#~ msgstr "a"
+msgid "Topographic index ln(a/tanB) map"
+msgstr "a"
 #, fuzzy
-#~ msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
-#~ msgstr "के लिए"
+msgid "ELEVATION PRODUCTS for mapset [%s] in [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
-#~ msgstr "नहीं"
+msgid "It could not be find input map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
-#~ msgstr "नहीं"
+msgid "It could not be found input map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
-#~ msgstr "नहीं"
+msgid "Cannot find input map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "नहीं."
+msgid "Input vector map <%s> not found."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
-#~ msgstr "जी 13"
+msgid "Category ranges: e.g. 1,3-8,13"
+msgstr "जी 13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
-#~ msgstr "छापें"
+msgid "Writing attributes ...\n"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
-#~ msgstr "नहीं"
+msgid "Could not open ascii file <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "नहीं"
+msgid "Could not open temp file <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#~ msgstr "नहीं"
+msgid "Vector map <%s> not fould"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "के लिए"
+msgid "SVG output file"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "नहीं"
+msgid "Could not find vector '%s'"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
-#~ msgstr "नहीं"
+msgid "Could not find vector map %s"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgstr "का a"
+msgid "Unable to get row %d from <%s>"
+msgstr "का a"
 #, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "नहीं."
+msgid "No input coordinates provided"
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Pass #%d (of %d) ... "
-#~ msgstr "n"
+msgid "Pass #%d (of %d) ... "
+msgstr "n"
 #, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "रखें"
+msgid "Keep existing color table"
+msgstr "रखें"
 #, fuzzy
-#~ msgid "Name of the output walkers site file"
-#~ msgstr "का"
+msgid "Name of the output walkers site file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "बड़बोला."
+msgid "Verbose mode."
+msgstr "बड़बोला."
 #, fuzzy
-#~ msgid ""
-#~ "Integer cell type.\n"
-#~ "Writing"
-#~ msgstr "पूर्णांक."
+msgid ""
+"Integer cell type.\n"
+"Writing"
+msgstr "पूर्णांक."
 #, fuzzy
-#~ msgid ""
-#~ "Float cell type.\n"
-#~ "Writing"
-#~ msgstr "फ्लोट."
+msgid ""
+"Float cell type.\n"
+"Writing"
+msgstr "फ्लोट."
 #, fuzzy
-#~ msgid ""
-#~ "Double cell type.\n"
-#~ "Writing"
-#~ msgstr "दोगुना."
+msgid ""
+"Double cell type.\n"
+"Writing"
+msgstr "दोगुना."
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
-#~ msgstr "त्रुटि"
+msgid "%s in %s - can't read header file"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
-#~ msgstr "का a"
+msgid "%s - unable to create raster map"
+msgstr "का a"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
 #, fuzzy
-#~ msgid "verbose mode"
-#~ msgstr "बड़बोला"
+msgid "verbose mode"
+msgstr "बड़बोला"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "का के लिए संपादन (_E)"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "का के लिए संपादन (_E)"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
+msgid "Layer of the vector for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "का"
+msgid "Path to an output file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "का"
+msgid "Name of existing raster map to be displayed"
+msgstr "का"
 #, fuzzy
-#~ msgid "Database name:"
-#~ msgstr "डाटाबेस का नामः"
+msgid "Database name:"
+msgstr "डाटाबेस का नामः"
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr "नहीं"
+msgid ""
+"ASCII file to be converted to binary vector map, if not given (or \"-\") "
+"reads from standard input"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
-#~ msgstr "नहीं"
+msgid "could not find input map <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
-#~ msgstr "के लिए"
+msgid "unable to open raster map [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "के लिए"
+msgid "cannot get layer info for vector map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
-#~ msgstr "स्रोत"
+msgid "cannot open database %s by driver %s"
+msgstr "स्रोत"
 #, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "नहीं"
+msgid "column type not supported"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "cannot create table: %s"
-#~ msgstr "चालू"
+msgid "cannot create table: %s"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "cannot create index"
-#~ msgstr "फील्ड"
+msgid "cannot create index"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "चालू"
+msgid "cannot grant privileges on table %s"
+msgstr "चालू"
 #, fuzzy
-#~ msgstr "नहीं"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid ""
-#~ "Number of column used as z coordinate (first column is 1) for points "
-#~ "mode. If 0, z coordinate is not used."
-#~ msgstr "का ज़ेड है के लिए ज़ेड है नहीं."
+msgid ""
+"Number of column used as z coordinate (first column is 1) for points mode. "
+"If 0, z coordinate is not used."
+msgstr "का ज़ेड है के लिए ज़ेड है नहीं."
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
+msgid "Error while writing new cell map."
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
-#~ msgstr "का"
+msgid "Error in opening output file <%s>"
+msgstr "का"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "नहीं"
+msgid "Error in opening input file <%s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "Unable to open cell man <%s> for input.\n"
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "Unable to open cell map <%s> for output.\n"
+msgstr "के लिए n"
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
-#~ msgstr "के लिए"
+msgid "Unable to write color table to raster [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot find map %s"
-#~ msgstr "के लिए"
+msgid "Cannot find map %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Cannot open map %s"
-#~ msgstr "नहीं n"
+msgid "Cannot open map %s"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Name of predefined rules file"
-#~ msgstr "का"
+msgid "Name of predefined rules file"
+msgstr "का"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr "R जी का n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr "R जी का n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr "R जी का n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "n"
+msgid "no such value"
+msgstr "n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "n"
+msgid "%s:line %d:%s"
+msgstr "n"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "n"
+msgid "bad color specification"
+msgstr "n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "n"
+msgid "%s - unknown color"
+msgstr "n"
 #, fuzzy
-#~ msgid "Valid colors are:\n"
-#~ msgstr "n"
+msgid "Valid colors are:\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "Unable to find base map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
-#~ msgstr "त्रुटि के लिए"
+msgid "%s: reading category file for %s"
+msgstr "त्रुटि के लिए"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
-#~ msgstr "के लिए"
+msgid "%s: unable to open raster map [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
-#~ msgstr "का a"
+msgid "%s: unable to create raster map [%s]"
+msgstr "का a"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
-#~ msgstr "स्रोत"
+msgid "Unable to open database %s with driver %s"
+msgstr "स्रोत"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
-#~ msgstr "का a"
+msgid "%s: Unable to read raster map [%s]"
+msgstr "का a"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
-#~ msgstr "i n"
+msgid "%s: Failed to read raster row %d"
+msgstr "i n"
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
-#~ msgstr "के लिए"
+msgid "Unable to read cats table for %s"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
-#~ msgstr "नहीं n"
+msgid "Could not open raster <%s>"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "स्क्रीन"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "स्क्रीन"
 #, fuzzy
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr "फ़ॉन्ट नहीं"
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr "फ़ॉन्ट नहीं"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "नहीं"
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "No record for category for [%d]"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
-#~ msgstr "त्रुटि के लिए."
+msgid "Error reading ASCII file <%s>"
+msgstr "त्रुटि के लिए."
 #, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error reading categories: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr "n"
+msgid "category [%d]"
+msgstr "n"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "नहीं"
+msgid "Could not find input vector '%s'"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
-#~ msgstr "का"
+msgid "Failed opening output vector map '%s'"
+msgstr "का"
 #, fuzzy
-#~ msgid "Do not create attribute table."
-#~ msgstr "नहीं."
+msgid "Do not create attribute table."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Could not find input %s\n"
-#~ msgstr "नहीं n"
+msgid "Could not find input %s\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr "a पर."
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region"
+msgstr "a पर."
 #, fuzzy
-#~ msgid "| Tool                            | Threshold     |"
-#~ msgstr "n"
+msgid "| Tool                            | Threshold     |"
+msgstr "n"
 #, fuzzy
-#~ msgid "| Break                           |  "
-#~ msgstr "n n"
+msgid "| Break                           |  "
+msgstr "n n"
 #, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr "n n"
+msgid "| Prune                           |  "
+msgstr "n n"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "नहीं"
+msgid "%s: <%s> vector map not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "नहीं"
+msgid "Vector <%s> could not be open"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
-#~ msgstr "नहीं"
+msgid "Raster <%s> could not be open."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "पद्धति"
+msgid "Interpolation()"
+msgstr "पद्धति"
 #, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "पद्धति"
+msgid "Interpolation: Setting regions and boxes"
+msgstr "पद्धति"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "पद्धति"
+msgid "Interpolation: nsply = %d"
+msgstr "पद्धति"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#~ msgstr "संख्या का"
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
-#~ msgstr "का"
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgstr "का"
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
-#~ msgstr "नहीं"
+msgid "%s: Dropping <s>"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
-#~ msgstr "पद्धति"
+msgid "Interpolation was a success!"
+msgstr "पद्धति"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "नहीं"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
-#~ msgstr "सभी"
+msgid "CrossCorrelation: It shouldn't take too long."
+msgstr "सभी"
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
-#~ msgstr "n"
+msgid "%s -- illegal output file name"
+msgstr "n"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
-#~ msgstr "नहीं"
+msgid "Sorry, with method '%s' you have to define an output map."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Calculation time"
-#~ msgstr "n"
+msgid "Calculation time"
+msgstr "n"
 #, fuzzy
-#~ msgid "Maximum number of iteration"
+msgid "Maximum number of iteration"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Finished.\n"
-#~ msgstr "पूर्ण n"
+msgid "Finished.\n"
+msgstr "पूर्ण n"
 #, fuzzy
-#~ msgid "%s - can't read raster cellhd"
-#~ msgstr "के लिए"
+msgid "%s - can't read raster cellhd"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "error reading cell data"
+msgid "error reading cell data"
+msgstr "त्रुटि."
 #, fuzzy
-#~ msgid "Done!"
-#~ msgstr "n"
+msgid "Done!"
+msgstr "n"
 #, fuzzy
-#~ msgid "No line found."
-#~ msgstr "n"
+msgid "No line found."
+msgstr "n"
 #, fuzzy
-#~ msgid "Nothing Found."
-#~ msgstr "n"
+msgid "Nothing Found."
+msgstr "n"
 #, fuzzy
-#~ msgid "Do not build topology."
-#~ msgstr "नहीं"
+msgid "Do not build topology."
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
-#~ msgstr "नहीं"
+msgid "Could not open ascii file [%s]"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "%s: Cannot open dxf file"
-#~ msgstr "नहीं"
+msgid "%s: Cannot open dxf file"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "a a."
+msgid "Conversion of [%s] to vector map ..."
+msgstr "a a."
 #, fuzzy
-#~ msgid "Finished"
+msgid "Finished"
+msgstr "पूर्ण n"
 #, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "छापें"
+msgid "Print the current region (shell script style)"
+msgstr "छापें"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr "है एक का n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr "है एक का n"
 #, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "नहीं"
+msgid "ERROR: <%s> not found\n"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "है"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "है"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "फ़ाइल"
+msgid "Cannot open toolbox: %s"
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
-#~ msgstr "फ़ाइल"
+msgid "Cannot open toolbox."
+msgstr "फ़ाइल"
 #, fuzzy
-#~ msgid "Could not find input map <%s>\n"
-#~ msgstr "नहीं n"
+msgid "Could not find input map <%s>\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "'%s' has finished the transformation of the vectors.\n"
-#~ msgstr "पूर्ण का n"
+msgid "'%s' has finished the transformation of the vectors.\n"
+msgstr "पूर्ण का n"
 #, fuzzy
-#~ msgid ""
-#~ "                          CHECK MAP RESIDUALS\n"
-#~ "\n"
-#~ msgstr "n n"
+msgid ""
+"                          CHECK MAP RESIDUALS\n"
+"\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid "                Current Map                  New Map\n"
-#~ msgstr "n"
+msgid "                Current Map                  New Map\n"
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ " POINT      X coord    Y coord  |        X coord   Y coord    |      "
-#~ "residuals\n"
-#~ msgstr "n"
+msgid ""
+" POINT      X coord    Y coord  |        X coord   Y coord    |      "
+"residuals\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  Residual mean average   : %f\n"
-#~ msgstr "f n"
+msgid "  Residual mean average   : %f\n"
+msgstr "f n"
 #, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
-#~ msgstr "स्रोत के लिए"
+msgid "Vector map(s) -- source for composite"
+msgstr "स्रोत के लिए"
 #, fuzzy
-#~ msgid "New vector composite"
-#~ msgstr "का"
+msgid "New vector composite"
+msgstr "का"
 #, fuzzy
-#~ msgid "Append files to existing file"
-#~ msgstr "का."
+msgid "Append files to existing file"
+msgstr "का."
 #, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "सभी."
+msgid "No database updates."
+msgstr "सभी."
 #, fuzzy
-#~ msgid "Adding new features to vector file ..."
+msgid "Adding new features to vector file ..."
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "नहीं"
+msgid "Vector map '%s' not found"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "शांत"
+msgid "Quiet operation"
+msgstr "शांत"
 #, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "जानकारी"
+msgid "Display Reference Information"
+msgstr "जानकारी"
 #, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "n"
+msgid "%s\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "output layer name"
-#~ msgstr "ढाल फ़ाइलनाम "
+msgid "output layer name"
+msgstr "ढाल फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Transforming data..."
-#~ msgstr "n"
+msgid "Transforming data..."
+msgstr "n"
 #, fuzzy
-#~ msgid ""
-#~ "\a\n"
-#~ "** The following raster maps in subgroup [%s] do not exist."
-#~ msgstr "n नहीं."
+msgid ""
+"\a\n"
+"** The following raster maps in subgroup [%s] do not exist."
+msgstr "n नहीं."
 #, fuzzy
-#~ msgid "The subgroup must have at least 2 files to run %s."
-#~ msgstr "पर."
+msgid "The subgroup must have at least 2 files to run %s."
+msgstr "पर."
 #, fuzzy
-#~ msgid "Did not find input cell map."
-#~ msgstr "नहीं."
+msgid "Did not find input cell map."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "Warning: illegal group name <%s>."
-#~ msgstr "चेतावनी समूह."
+msgid "Warning: illegal group name <%s>."
+msgstr "चेतावनी समूह."
 #, fuzzy
-#~ msgid "Warning: illegal output file name <%s>."
+msgid "Warning: illegal output file name <%s>."
+msgstr "चेतावनी."
 #, fuzzy
-#~ msgid "An output cell map name is required."
-#~ msgstr "है."
+msgid "An output cell map name is required."
+msgstr "है."
 #, fuzzy
-#~ msgid "The output cell map name can not be longer than 12 characters."
-#~ msgstr "नहीं."
+msgid "The output cell map name can not be longer than 12 characters."
+msgstr "नहीं."
 #, fuzzy
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "R n"
+msgid "L: from  M: to R: quit\n"
+msgstr "R n"
 #, fuzzy
-#~ msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
-#~ msgstr "i i."
+msgid "g3d_to_raster: Writing %i raster maps with rows %i cols."
+msgstr "i i."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "n"
+msgid ""
+"\n"
+"Done\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Writing VTK VoxelData\n"
-#~ msgstr "n"
+msgid "Writing VTK VoxelData\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
-#~ msgstr "खोलें"
+msgid "Open vector 3d raster map %s"
+msgstr "खोलें"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
-#~ msgstr "खोलें"
+msgid "Open 3d raster map %s"
+msgstr "खोलें"
 #, fuzzy
-#~ msgid ""
-#~ "OGR datasource name.\n"
-#~ "\t\tESRI Shapefile: directory containing shapefiles\n"
-#~ "\t\tMapInfo File: directory containing mapinfo files"
+msgid ""
+"OGR datasource name.\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
+msgstr "n n फ़ाइल"
 #, fuzzy
-#~ msgid "Name of vector output file"
-#~ msgstr "का"
+msgid "Name of vector output file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Vector import complete"
-#~ msgstr "सदिश"
+msgid "Vector import complete"
+msgstr "सदिश"
 #, fuzzy
-#~ msgid "centroids"
-#~ msgstr "n"
+msgid "centroids"
+msgstr "n"
 #, fuzzy
-#~ msgid "ERROR: A line needs at least 2 points"
-#~ msgstr "पर."
+msgid "ERROR: A line needs at least 2 points"
+msgstr "पर."
 #, fuzzy
-#~ msgid "ERROR: An area needs at least 3 points"
-#~ msgstr "पर."
+msgid "ERROR: An area needs at least 3 points"
+msgstr "पर."
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "के लिए"
+msgid "Unable to create raster map for [%s]"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
-#~ msgstr "i i."
+msgid "raster_to_g3d: Writing %i raster maps with rows %i cols."
+msgstr "i i."
 #, fuzzy
-#~ msgid "Writing g3d slice %i\n"
-#~ msgstr "i n"
+msgid "Writing g3d slice %i\n"
+msgstr "i n"
 #, fuzzy
-#~ msgid "out of memory!"
-#~ msgstr "का!"
+msgid "out of memory!"
+msgstr "का!"
 #, fuzzy
-#~ msgid "error opening 3d raster map"
-#~ msgstr "त्रुटि"
+msgid "error opening 3d raster map"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Done\n"
-#~ msgstr "n"
+msgid "Done\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Name for the resulting raster map"
-#~ msgstr "के लिए"
+msgid "Name for the resulting raster map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "खोलें n"
+msgid "Open Raster file %s in Mapset %s"
+msgstr "खोलें n"
 #, fuzzy
-#~ msgid ""
-#~ "elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i "
-#~ "and count %i."
-#~ msgstr "i i."
+msgid ""
+"elev_raster_to_g3d: Writing 3D raster map with depths %i rows %i cols %i and "
+"count %i."
+msgstr "i i."
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
-#~ msgstr "खोलें"
+msgid "Open 3d raster map %s\n"
+msgstr "खोलें"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
-#~ msgstr "डाटाटाइप."
+msgid "Open elev raster map %s\n"
+msgstr "डाटाटाइप."
 #, fuzzy
-#~ msgid "Could not open map %s\n"
-#~ msgstr "नहीं n"
+msgid "Could not open map %s\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Either -i flag and/or profile parameter must be used."
-#~ msgstr "i"
+msgid "Either -i flag and/or profile parameter must be used."
+msgstr "i"
 #, fuzzy
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr "आकार  है कुछ नहीं n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr "आकार  है कुछ नहीं n"
 #, fuzzy
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgid "Region size is greater than maxreg, nothing displayed.\n"
 #, fuzzy
-#~ msgid "Name for G3d raster map"
-#~ msgstr "के लिए"
+msgid "Name for G3d raster map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Do not rebuild and store the topology at the end"
-#~ msgstr "नहीं पर"
+msgid "Do not rebuild and store the topology at the end"
+msgstr "नहीं पर"
 #, fuzzy
-#~ msgid "QGIS vector output"
-#~ msgstr "का"
+msgid "QGIS vector output"
+msgstr "का"
 #, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "का"
+msgid "Makes 3D trees from input point vector map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Diameter of the tree crown in mapunits"
-#~ msgstr "त्रुटि"
+msgid "Diameter of the tree crown in mapunits"
+msgstr "त्रुटि"
 #, fuzzy
-#~ msgid "Height of tree trunk"
-#~ msgstr "ऊंचाई मीटर्स"
+msgid "Height of tree trunk"
+msgstr "ऊंचाई मीटर्स"
 #, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "का"
+msgid "Name of the column with tree crown width"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of the column with tree height"
-#~ msgstr "का"
+msgid "Name of the column with tree height"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of the column with tree species"
-#~ msgstr "का"
+msgid "Name of the column with tree species"
+msgstr "का"
 #, fuzzy
-#~ msgid "Horizontal variability in map units"
-#~ msgstr "का बिन्दु"
+msgid "Horizontal variability in map units"
+msgstr "का बिन्दु"
 #, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
-#~ msgstr "के लिए"
+msgid "Cannot select attributes for point #%d"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Calculate statistics for vector points within each raster cell of the "
-#~ "current region"
-#~ msgstr "का a के लिए सभी का."
+msgid ""
+"Calculate statistics for vector points within each raster cell of the "
+"current region"
+msgstr "का a के लिए सभी का."
 #, fuzzy
-#~ msgid ""
-#~ "Name of output vector points map (if not specified, the program writes to "
-#~ "standard output)"
+msgid ""
+"Name of output vector points map (if not specified, the program writes to "
+"standard output)"
 #, fuzzy
-#~ msgid "Report only selected statistics"
-#~ msgstr "का वस्तु"
+msgid "Report only selected statistics"
+msgstr "का वस्तु"
 #, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "शांत"
+msgid "Quiet mode"
+msgstr "शांत"
 #, fuzzy
-#~ msgid "Print the input data extent in shell script style"
-#~ msgstr "छापें"
+msgid "Print the input data extent in shell script style"
+msgstr "छापें"
 #, fuzzy
-#~ msgid "done."
-#~ msgstr "n"
+msgid "done."
+msgstr "n"
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Mark or search ground control points on image to be rectified."
-#~ msgstr "चिह्नित चालू छवि."
+msgid "Mark or search ground control points on image to be rectified."
+msgstr "चिह्नित चालू छवि."
 #, fuzzy
-#~ msgid "Enter imagery group to be registered"
-#~ msgstr "समूह"
+msgid "Enter imagery group to be registered"
+msgstr "समूह"
 #, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "आइसोसरफेस"
+msgid "Maximum distance"
+msgstr "आइसोसरफेस"
 #, fuzzy
-#~ msgid "Right: "
-#~ msgstr "n"
+msgid "Right: "
+msgstr "n"
 #, fuzzy
-#~ msgid "%s Pan\n"
-#~ msgstr "n"
+msgid "%s Pan\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "बाहर जाएँ n"
+msgid "%s Quit\n"
+msgstr "बाहर जाएँ n"
 #, fuzzy
-#~ msgid "Draw geographic grid"
-#~ msgstr "निकालें"
+msgid "Draw geographic grid"
+msgstr "निकालें"
 #, fuzzy
-#~ msgid ""
-#~ "3 raster maps (r,g,b) which are used to create rgb values [redmap,"
-#~ "greenmap,bluemap]"
-#~ msgstr "जी"
+msgid ""
+"3 raster maps (r,g,b) which are used to create rgb values [redmap,greenmap,"
+"bluemap]"
+msgstr "जी"
 #, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
+msgid "%s[%d]: No raster map specified."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid ""
-#~ "GRASS module to create a fractal surface of a given fractal dimension. "
-#~ "Uses spectral synthesis method. Can create intermediate layers showing "
-#~ "the build up of different spectral coefficients (see Saupe, pp.106-107 "
-#~ "for an example of this). Use this module to generate naturally looking "
-#~ "synthetical elevation models (DEM)."
-#~ msgstr "मॉडयूल a का a पद्धति का के लिए का मॉडयूल."
+msgid ""
+"GRASS module to create a fractal surface of a given fractal dimension. Uses "
+"spectral synthesis method. Can create intermediate layers showing the build "
+"up of different spectral coefficients (see Saupe, pp.106-107 for an example "
+"of this). Use this module to generate naturally looking synthetical "
+"elevation models (DEM)."
+msgstr "मॉडयूल a का a पद्धति का के लिए का मॉडयूल."
 #, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr "n"
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Resolution of raster and raster3d maps should be equal!"
-#~ msgstr "का के बराबर!"
+msgid "Resolution of raster and raster3d maps should be equal!"
+msgstr "का के बराबर!"
 #, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
+msgid "The resolution of raster and raster3d maps should be equal!"
 #, fuzzy
-#~ msgid "top raster map not found\n"
-#~ msgstr "नहीं n"
+msgid "top raster map not found\n"
+msgstr "नहीं n"
 #, fuzzy
-#~ msgid "Compute upslope flowlines"
-#~ msgstr "गणना करें"
+msgid "Compute upslope flowlines"
+msgstr "गणना करें"
 #, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "का a बिन्दु"
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "का a बिन्दु"
 #, fuzzy
-#~ msgid "Wrong RGB maps. RGB output not added!"
-#~ msgstr "नहीं!"
+msgid "Wrong RGB maps. RGB output not added!"
+msgstr "नहीं!"
 #, fuzzy
-#~ msgid "Done.\n"
-#~ msgstr "n"
+msgid "Done.\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Zooming finished.\n"
+msgid "Zooming finished.\n"
+msgstr "पूर्ण n"
 #, fuzzy
-#~ msgid "name of resulting vector map"
-#~ msgstr "का"
+msgid "name of resulting vector map"
+msgstr "का"
 #, fuzzy
-#~ msgid "\"Extrudes\" flat vector object to 3D with defined height."
-#~ msgstr "वस्तु ऊंचाई."
+msgid "\"Extrudes\" flat vector object to 3D with defined height."
+msgstr "वस्तु ऊंचाई."
 #, fuzzy
-#~ msgid "Column from attribute table with object height attribute"
-#~ msgstr "वस्तु ऊंचाई"
+msgid "Column from attribute table with object height attribute"
+msgstr "वस्तु ऊंचाई"
 #, fuzzy
-#~ msgid "You first need to run v.build on vector map <%s>"
-#~ msgstr "चालू"
+msgid "You first need to run v.build on vector map <%s>"
+msgstr "चालू"
 #, fuzzy
-#~ msgid "height of vector object"
-#~ msgstr "ऊंचाई का वस्तु"
+msgid "height of vector object"
+msgstr "ऊंचाई का वस्तु"
 #, fuzzy
-#~ msgid "Either a height column or a fixed height value have to be specified"
-#~ msgstr "a ऊंचाई a स्थिर ऊंचाई"
+msgid "Either a height column or a fixed height value have to be specified"
+msgstr "a ऊंचाई a स्थिर ऊंचाई"
 #, fuzzy
-#~ msgid "String column cannot be used for object heights"
-#~ msgstr "के लिए वस्तु"
+msgid "String column cannot be used for object heights"
+msgstr "के लिए वस्तु"
 #, fuzzy
-#~ msgid "DateTime column cannot be used for object heights"
+msgid "DateTime column cannot be used for object heights"
 #, fuzzy
-#~ msgid ""
-#~ "Feature type. Possible combinations of more types: point,centroid or line,"
-#~ "boundary."
-#~ msgstr "विशेषता का अधिक बिन्दु."
+msgid ""
+"Feature type. Possible combinations of more types: point,centroid or line,"
+"boundary."
+msgstr "विशेषता का अधिक बिन्दु."
 #, fuzzy
-#~ msgid "Don't understand: [%s]\n"
-#~ msgstr "n"
+msgid "Don't understand: [%s]\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Name of existing input raster map"
-#~ msgstr "का"
+msgid "Name of existing input raster map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of existing raster map."
-#~ msgstr "का."
+msgid "Name of existing raster map."
+msgstr "का."
 #, fuzzy
-#~ msgid "Name of new raster map."
-#~ msgstr "का."
+msgid "Name of new raster map."
+msgstr "का."
 #, fuzzy
-#~ msgid "Name of the resulting map"
-#~ msgstr "का"
+msgid "Name of the resulting map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Name of input map"
-#~ msgstr "का"
+msgid "Name of input map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
-#~ msgstr "बहुभुज."
+msgid "Write an Arc-Info line/polygon coverage in e00 format."
+msgstr "बहुभुज."
 #, fuzzy
-#~ msgid "Mapset holding vector map to be exported (Default = current)"
-#~ msgstr "डिफ़ॉल्ट"
+msgid "Mapset holding vector map to be exported (Default = current)"
+msgstr "डिफ़ॉल्ट"
 #, fuzzy
-#~ msgid "Prompt user for threshold"
-#~ msgstr "के लिए"
+msgid "Prompt user for threshold"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Set line types to:   \n"
-#~ "             source        same as in binary vector map\n"
-#~ "             line          lines\n"
-#~ "             area          area edges\n"
-#~ "             point         points (sites)\n"
-#~ msgstr ""
-#~ "सेट\n"
-#~ " स्रोत\n"
-#~ "\n"
-#~ "\n"
-#~ " बिन्दु n"
+msgid ""
+"Set line types to:   \n"
+"             source        same as in binary vector map\n"
+"             line          lines\n"
+"             area          area edges\n"
+"             point         points (sites)\n"
+msgstr ""
+"सेट\n"
+" स्रोत\n"
+"\n"
+"\n"
+" बिन्दु n"
 #, fuzzy
-#~ msgid "Output file is ASCII map"
-#~ msgstr "है"
+msgid "Output file is ASCII map"
+msgstr "है"
 #, fuzzy
-#~ msgid "Copy attributes and category files"
-#~ msgstr "नक़ल"
+msgid "Copy attributes and category files"
+msgstr "नक़ल"
 #, fuzzy
-#~ msgid ""
-#~ "Converts point data in a binary GRASS vector map layer into a GRASS "
-#~ "site_lists file."
-#~ msgstr "बिन्दु a a."
+msgid ""
+"Converts point data in a binary GRASS vector map layer into a GRASS "
+"site_lists file."
+msgstr "बिन्दु a a."
 #, fuzzy
-#~ msgid "Use Category NUMERIC data instead of attribute"
-#~ msgstr "का"
+msgid "Use Category NUMERIC data instead of attribute"
+msgstr "का"
 #, fuzzy
-#~ msgid "Use Category TEXT data instead of attribute"
-#~ msgstr "का"
+msgid "Use Category TEXT data instead of attribute"
+msgstr "का"
 #, fuzzy
-#~ msgid "Test routine for developing MIF import."
+msgid "Test routine for developing MIF import."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Debugging level : 0 (silent) - 3 (verbose)"
-#~ msgstr "डिबगिंग"
+msgid "Debugging level : 0 (silent) - 3 (verbose)"
+msgstr "डिबगिंग"
 #, fuzzy
-#~ msgid "Name of file where to log operations"
-#~ msgstr "का"
+msgid "Name of file where to log operations"
+msgstr "का"
 #, fuzzy
-#~ msgid "Snap distance in ground units (Default = 10^-10)"
+msgid "Snap distance in ground units (Default = 10^-10)"
+msgstr "डिफ़ॉल्ट"
 #, fuzzy
-#~ msgid "Set initial scale [1:2400]"
-#~ msgstr "सेट स्केल"
+msgid "Set initial scale [1:2400]"
+msgstr "सेट स्केल"
 #, fuzzy
-#~ msgid "Name of attribute to use as category"
-#~ msgstr "का"
+msgid "Name of attribute to use as category"
+msgstr "का"
 #, fuzzy
-#~ msgid "Allow overwrite of existing vector map with the same name"
-#~ msgstr "का"
+msgid "Allow overwrite of existing vector map with the same name"
+msgstr "का"
 #, fuzzy
-#~ msgid "Force writing  polygon coverage as a line coverage"
-#~ msgstr "बहुभुज a"
+msgid "Force writing  polygon coverage as a line coverage"
+msgstr "बहुभुज a"
 #, fuzzy
-#~ msgid "Create unique value for parts of compound object"
-#~ msgstr "के लिए का वस्तु"
+msgid "Create unique value for parts of compound object"
+msgstr "के लिए का वस्तु"
 #, fuzzy
-#~ msgid "List fields of DBF file"
-#~ msgstr "का"
+msgid "List fields of DBF file"
+msgstr "का"
 #, fuzzy
-#~ msgid "new categories table title"
-#~ msgstr "शीर्षक"
+msgid "new categories table title"
+msgstr "शीर्षक"
 #, fuzzy
-#~ msgid "Build topology info (default) OR Edit categories"
-#~ msgstr "संपादन"
+msgid "Build topology info (default) OR Edit categories"
+msgstr "संपादन"
 #, fuzzy
-#~ msgid "Prompt user for threshold         (Valid only with Build option)"
-#~ msgstr "के लिए"
+msgid "Prompt user for threshold         (Valid only with Build option)"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Set map region from data          (Valid only with Build option)"
-#~ msgstr "सेट"
+msgid "Set map region from data          (Valid only with Build option)"
+msgstr "सेट"
 #, fuzzy
-#~ msgid "Suppress drawing of text outlines"
-#~ msgstr "का पाठ"
+msgid "Suppress drawing of text outlines"
+msgstr "का पाठ"
 #, fuzzy
-#~ msgid "Prefix for dig or dig_ascii and dig_att output files"
-#~ msgstr "उपसर्ग के लिए"
+msgid "Prefix for dig or dig_ascii and dig_att output files"
+msgstr "उपसर्ग के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Where lines and labels are one or more of:\n"
-#~ "\n"
-#~ msgstr "n एक अधिक का n n"
+msgid ""
+"\n"
+"\n"
+"Where lines and labels are one or more of:\n"
+"\n"
+msgstr "n एक अधिक का n n"
 #, fuzzy
-#~ msgid ""
-#~ "    layername1[,layername2,layername3,...]\n"
-#~ "\n"
-#~ msgstr "n n"
+msgid ""
+"    layername1[,layername2,layername3,...]\n"
+"\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid ""
-#~ "      and/or   \n"
-#~ "\n"
-#~ msgstr "n n"
+msgid ""
+"      and/or   \n"
+"\n"
+msgstr "n n"
 #, fuzzy
-#~ msgid ""
-#~ "    in_layername1:out_layername1[,inlayername2:outlayername2,.....]\n"
-#~ msgstr "n"
+msgid "    in_layername1:out_layername1[,inlayername2:outlayername2,.....]\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "angle of rotation"
-#~ msgstr "कोण का"
+msgid "angle of rotation"
+msgstr "कोण का"
 #, fuzzy
-#~ msgid "provide attributes of type: const,rows,cols"
-#~ msgstr "का"
+msgid "provide attributes of type: const,rows,cols"
+msgstr "का"
 #, fuzzy
-#~ msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectacres)"
-#~ msgstr "f a h"
+msgid "mi(les),f(eet),me(ters),k(ilometers),a(cres),h(ectacres)"
+msgstr "f a h"
 #, fuzzy
-#~ msgid "Prints information about a binary GRASS vector map layer."
-#~ msgstr "a."
+msgid "Prints information about a binary GRASS vector map layer."
+msgstr "a."
 #, fuzzy
-#~ msgid "input vector map for ARC/INFO conversion"
-#~ msgstr "के लिए"
+msgid "input vector map for ARC/INFO conversion"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "prefix for ARC/INFO output filenames"
-#~ msgstr "के लिए"
+msgid "prefix for ARC/INFO output filenames"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "field separator"
-#~ msgstr "फील्ड"
+msgid "field separator"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation and topographic analysis from given contour data in vector "
-#~ "format to GRASS floating point raster format using regularized spline "
-#~ "with tension."
-#~ msgstr "बिन्दु."
+msgid ""
+"Interpolation and topographic analysis from given contour data in vector "
+"format to GRASS floating point raster format using regularized spline with "
+"tension."
+msgstr "बिन्दु."
 #, fuzzy
-#~ msgid "Version: GRASS5.0 beta,  update: Novemebr 1999"
-#~ msgstr "बीटा"
+msgid "Version: GRASS5.0 beta,  update: Novemebr 1999"
+msgstr "बीटा"
 #, fuzzy
-#~ msgid "Authors: original version -  H.Mitasova, L.Mitas"
-#~ msgstr "असली संस्करण एच"
+msgid "Authors: original version -  H.Mitasova, L.Mitas"
+msgstr "असली संस्करण एच"
 #, fuzzy
-#~ msgid "Methods used in this program are described in the following papers:"
-#~ msgstr "पद्धति प्रोग्राम:"
+msgid "Methods used in this program are described in the following papers:"
+msgstr "पद्धति प्रोग्राम:"
 #, fuzzy
-#~ msgid "Mitasova, H., and  Mitas, L., 1993,"
-#~ msgstr "एच"
+msgid "Mitasova, H., and  Mitas, L., 1993,"
+msgstr "एच"
 #, fuzzy
-#~ msgid "Mitasova, H., and Hofierka, L., 1993"
-#~ msgstr "एच"
+msgid "Mitasova, H., and Hofierka, L., 1993"
+msgstr "एच"
 #, fuzzy
-#~ msgid "Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,"
-#~ msgstr "एच प"
+msgid "Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,"
+msgstr "एच प"
 #, fuzzy
-#~ msgid "Baker, T., 1995, Modeling spatially and temporally"
-#~ msgstr "T"
+msgid "Baker, T., 1995, Modeling spatially and temporally"
+msgstr "T"
 #, fuzzy
-#~ msgid "distributed phenomena: New methods and tools for GRASS GIS."
+msgid "distributed phenomena: New methods and tools for GRASS GIS."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "International Journal of Geographic Information Systems,V(9), No(4)."
-#~ msgstr "का जियोग्राफिक जानकारी V नहीं."
+msgid "International Journal of Geographic Information Systems,V(9), No(4)."
+msgstr "का जियोग्राफिक जानकारी V नहीं."
 #, fuzzy
-#~ msgid "(special issue on Integration of GIS and Environmental Modeling)"
-#~ msgstr "चालू का"
+msgid "(special issue on Integration of GIS and Environmental Modeling)"
+msgstr "चालू का"
 #, fuzzy
-#~ msgid ""
-#~ "The postscript versions of these papers are available via Internet at"
-#~ msgstr "का पर"
+msgid "The postscript versions of these papers are available via Internet at"
+msgstr "का पर"
 #, fuzzy
-#~ msgid ""
-#~ "Please cite these references in publications where the results of this"
-#~ msgstr "का"
+msgid "Please cite these references in publications where the results of this"
+msgstr "का"
 #, fuzzy
-#~ msgid "Use category data instead of attribute"
-#~ msgstr "का"
+msgid "Use category data instead of attribute"
+msgstr "का"
 #, fuzzy
-#~ msgid "Output z-file (elevation)"
-#~ msgstr "ज़ेड"
+msgid "Output z-file (elevation)"
+msgstr "ज़ेड"
 #, fuzzy
-#~ msgid "Mean curvature"
-#~ msgstr "औसत"
+msgid "Mean curvature"
+msgstr "औसत"
 #, fuzzy
-#~ msgid "Min number of points for interpolation(>segmax)"
-#~ msgstr "संख्या का के लिए"
+msgid "Min number of points for interpolation(>segmax)"
+msgstr "संख्या का के लिए"
 #, fuzzy
-#~ msgid "path to GRASS database of input location"
-#~ msgstr "का"
+msgid "path to GRASS database of input location"
+msgstr "का"
 #, fuzzy
-#~ msgid "Automatically run \"v.support\" on newly created vector map."
-#~ msgstr "चालू."
+msgid "Automatically run \"v.support\" on newly created vector map."
+msgstr "चालू."
 #, fuzzy
-#~ msgid "Type of object to extract (area, line or both)"
+msgid "Type of object to extract (area, line or both)"
+msgstr "का वस्तु"
 #, fuzzy
-#~ msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
-#~ msgstr "बूलिये ओवरले."
+msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
+msgstr "बूलिये ओवरले."
 #, fuzzy
-#~ msgid "ARC/INFO label-text file"
-#~ msgstr "पाठ"
+msgid "ARC/INFO label-text file"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "resultant Vector output file"
-#~ msgstr "सदिश"
+msgid "resultant Vector output file"
+msgstr "सदिश"
 #, fuzzy
-#~ msgid "ID Number column in label-text file"
-#~ msgstr "पाठ"
+msgid "ID Number column in label-text file"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "GRASS category column in label-text file"
-#~ msgstr "पाठ"
+msgid "GRASS category column in label-text file"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "GRASS attribute column in label-text file"
-#~ msgstr "पाठ"
+msgid "GRASS attribute column in label-text file"
+msgstr "पाठ"
 #, fuzzy
-#~ msgid "reports attribute, label, and other information about a sites file"
-#~ msgstr "अन्य a"
+msgid "reports attribute, label, and other information about a sites file"
+msgstr "अन्य a"
 #, fuzzy
-#~ msgid "Name of sites file."
-#~ msgstr "का."
+msgid "Name of sites file."
+msgstr "का."
 #, fuzzy
-#~ msgid "Only count sites in current window for min/max."
+msgid "Only count sites in current window for min/max."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Show quartiles for decimal attributes"
-#~ msgstr "के लिए"
+msgid "Show quartiles for decimal attributes"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Name of input sites map"
-#~ msgstr "का"
+msgid "Name of input sites map"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Surface interpolation from sites data by Inverse Distance Weighted "
-#~ "algorithm."
-#~ msgstr "सतह."
+msgid ""
+"Surface interpolation from sites data by Inverse Distance Weighted algorithm."
+msgstr "सतह."
 #, fuzzy
-#~ msgid "Name of sites file to filter"
-#~ msgstr "का फ़िल्टर"
+msgid "Name of sites file to filter"
+msgstr "का फ़िल्टर"
 #, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS site list file into an ASCII listing of site locations "
-#~ "and their descriptions."
-#~ msgstr "a का."
+msgid ""
+"Converts a GRASS site list file into an ASCII listing of site locations and "
+"their descriptions."
+msgstr "a का."
 #, fuzzy
-#~ msgid "Name of input site list"
-#~ msgstr "का"
+msgid "Name of input site list"
+msgstr "का"
 #, fuzzy
-#~ msgid "Number of cells to surround site cell"
-#~ msgstr "का"
+msgid "Number of cells to surround site cell"
+msgstr "का"
 #, fuzzy
-#~ msgid "Attribute field type to use for operation"
-#~ msgstr "फील्ड के लिए"
+msgid "Attribute field type to use for operation"
+msgstr "फील्ड के लिए"
 #, fuzzy
-#~ msgid "Attribute field number to use for operation"
-#~ msgstr "फील्ड संख्या के लिए"
+msgid "Attribute field number to use for operation"
+msgstr "फील्ड संख्या के लिए"
 #, fuzzy
-#~ msgid "Create a single-valued (0/1) raster map"
-#~ msgstr "a एकल"
+msgid "Create a single-valued (0/1) raster map"
+msgstr "a एकल"
 #, fuzzy
-#~ msgid "Index of attribute type (ignored for cat)"
-#~ msgstr "का के लिए"
+msgid "Index of attribute type (ignored for cat)"
+msgstr "का के लिए"
 #, fuzzy
-#~ msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-#~ msgstr "जी ज़ेड"
+msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
+msgstr "जी ज़ेड"
 #, fuzzy
-#~ msgid ""
-#~ "Convert an ASCII listing of site locations into a GRASS site list file."
-#~ msgstr "का a."
+msgid "Convert an ASCII listing of site locations into a GRASS site list file."
+msgstr "का a."
 #, fuzzy
-#~ msgid "number of dimensions (default=2)"
+msgid "number of dimensions (default=2)"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "input field separator"
-#~ msgstr "फील्ड"
+msgid "input field separator"
+msgstr "फील्ड"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to re-project a sites file from one location to the "
-#~ "current location (no datum transformation yet)."
-#~ msgstr "a एक."
+msgid ""
+"Allows the user to re-project a sites file from one location to the current "
+"location (no datum transformation yet)."
+msgstr "a एक."
 #, fuzzy
-#~ msgid "location of input sites list"
-#~ msgstr "का"
+msgid "location of input sites list"
+msgstr "का"
 #, fuzzy
-#~ msgid "mapset of input sites list"
-#~ msgstr "का"
+msgid "mapset of input sites list"
+msgstr "का"
 #, fuzzy
-#~ msgid "Don't prompt for Map header information"
-#~ msgstr "संकेत के लिए"
+msgid "Don't prompt for Map header information"
+msgstr "संकेत के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
-#~ "category value (uses \"cat\" by default)"
+msgid ""
+"Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
+"category value (uses \"cat\" by default)"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively change the color table of a raster map "
-#~ "layer displayed on the graphics monitor."
-#~ msgstr "का a चालू."
+msgid ""
+"Allows the user to interactively change the color table of a raster map "
+"layer displayed on the graphics monitor."
+msgstr "का a चालू."
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively adjust the settings (zoom  and  pan) of "
-#~ "the current geographic region using a pointing device such as a mouse."
-#~ msgstr "पैन का a a."
+msgid ""
+"Allows the user to interactively adjust the settings (zoom  and  pan) of the "
+"current geographic region using a pointing device such as a mouse."
+msgstr "पैन का a a."
 #, fuzzy
-#~ msgid ""
-#~ "Displays text labels formatted for use with GRASS paint (p.labels, p.map) "
-#~ "output to the active frame on the graphics monitor."
-#~ msgstr "पाठ के लिए चालू."
+msgid ""
+"Displays text labels formatted for use with GRASS paint (p.labels, p.map) "
+"output to the active frame on the graphics monitor."
+msgstr "पाठ के लिए चालू."
 #, fuzzy
-#~ msgid "Color of lines separating the colors of the color table"
-#~ msgstr "का का"
+msgid "Color of lines separating the colors of the color table"
+msgstr "का का"
 #, fuzzy
-#~ msgid ""
-#~ "Displays points, as icons, at user-defined locations in the active "
-#~ "display frame on the graphics monitor."
-#~ msgstr "प्रतीक पर चालू."
+msgid ""
+"Displays points, as icons, at user-defined locations in the active display "
+"frame on the graphics monitor."
+msgstr "प्रतीक पर चालू."
 #, fuzzy
-#~ msgid "Name of existing sites file"
-#~ msgstr "का"
+msgid "Name of existing sites file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Identify just one site"
-#~ msgstr "पहचानें एक"
+msgid "Identify just one site"
+msgstr "पहचानें एक"
 #, fuzzy
-#~ msgid "one mouse click only"
-#~ msgstr "एक"
+msgid "one mouse click only"
+msgstr "एक"
 #, fuzzy
-#~ msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-#~ msgstr "का a के लिए"
+msgid "Name of a spheroid (for lat/lon coordinate conversion)"
+msgstr "का a के लिए"
 #, fuzzy
-#~ msgid "Displays three-dimensional images based on raster map layers"
-#~ msgstr "छवियाँ चालू"
+msgid "Displays three-dimensional images based on raster map layers"
+msgstr "छवियाँ चालू"
 #, fuzzy
-#~ msgid "The raster map used to generate the 3-d texture"
-#~ msgstr "संरचना"
+msgid "The raster map used to generate the 3-d texture"
+msgstr "संरचना"
 #, fuzzy
-#~ msgid "coordinates of center of view"
-#~ msgstr "का का"
+msgid "coordinates of center of view"
+msgstr "का का"
 #, fuzzy
-#~ msgid "Frequency of vector lines in output"
-#~ msgstr "आवृत्ति का"
+msgid "Frequency of vector lines in output"
+msgstr "आवृत्ति का"
 #, fuzzy
-#~ msgid "Field of view"
-#~ msgstr "फील्ड का"
+msgid "Field of view"
+msgstr "फील्ड का"
 #, fuzzy
-#~ msgid "Color of bounding box"
-#~ msgstr "का बक्सा"
+msgid "Color of bounding box"
+msgstr "का बक्सा"
 #, fuzzy
-#~ msgid ""
-#~ "Displays  a  legend  for a raster map layer in the active frame on the "
-#~ "graphics monitor."
-#~ msgstr "a के लिए a चालू."
+msgid ""
+"Displays  a  legend  for a raster map layer in the active frame on the "
+"graphics monitor."
+msgstr "a के लिए a चालू."
 #, fuzzy
-#~ msgid "Use a subset of the map range for the legend"
-#~ msgstr "a का के लिए"
+msgid "Use a subset of the map range for the legend"
+msgstr "a का के लिए"
 #, fuzzy
-#~ msgid "Draw labelled vector lines to the current display device"
+msgid "Draw labelled vector lines to the current display device"
+msgstr "निकालें"
 #, fuzzy
-#~ msgid "Name of existing vector map to draw"
-#~ msgstr "का"
+msgid "Name of existing vector map to draw"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Draw all lines using either a GRASS standard color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr "निकालें सभी a R जी"
+msgid ""
+"Draw all lines using either a GRASS standard color or R:G:B triplet "
+"(separated by colons)"
+msgstr "निकालें सभी a R जी"
 #, fuzzy
-#~ msgid ""
-#~ "Only draw areas with a matching category number (for constant color "
-#~ "option only)"
-#~ msgstr "a संख्या के लिए"
+msgid ""
+"Only draw areas with a matching category number (for constant color option "
+"only)"
+msgstr "a संख्या के लिए"
 #, fuzzy
-#~ msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-#~ msgstr "निकालें a<cat><R><G><B>"
+msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
+msgstr "निकालें a<cat><R><G><B>"
 #, fuzzy
-#~ msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "a R जी"
+msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "a R जी"
 #, fuzzy
-#~ msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "a R जी"
+msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "a R जी"
 #, fuzzy
-#~ msgid "Limit to matching category number(s) (constant color option only)"
-#~ msgstr "संख्या"
+msgid "Limit to matching category number(s) (constant color option only)"
+msgstr "संख्या"
 #, fuzzy
-#~ msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
-#~ msgstr "a<cat><R><G><B><R><G><B>"
+msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
+msgstr "a<cat><R><G><B><R><G><B>"
 #, fuzzy
-#~ msgid ""
-#~ "Displays site markers in the active display frame on the graphics monitor."
-#~ msgstr "चालू."
+msgid ""
+"Displays site markers in the active display frame on the graphics monitor."
+msgstr "चालू."
 #, fuzzy
-#~ msgid "Size, in pixels, in which the icon is to be drawn"
-#~ msgstr "पिक्सेल्स है"
+msgid "Size, in pixels, in which the icon is to be drawn"
+msgstr "पिक्सेल्स है"
 #, fuzzy
-#~ msgid "Specify the type of the icon"
-#~ msgstr "का"
+msgid "Specify the type of the icon"
+msgstr "का"
 #, fuzzy
-#~ msgid "Color used for the background, or \"none\""
-#~ msgstr "के लिए"
+msgid "Color used for the background, or \"none\""
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "the screen coordinates for top-left corner of label"
-#~ msgstr "के लिए शीर्ष बायाँ का"
+msgid "the screen coordinates for top-left corner of label"
+msgstr "के लिए शीर्ष बायाँ का"
 #, fuzzy
-#~ msgid ""
-#~ "Interactively label sites using a string or double attribute value or the "
-#~ "category value on the current graphics monitor."
-#~ msgstr "a चालू."
+msgid ""
+"Interactively label sites using a string or double attribute value or the "
+"category value on the current graphics monitor."
+msgstr "a चालू."
 #, fuzzy
-#~ msgid "Name of sites file"
-#~ msgstr "का"
+msgid "Name of sites file"
+msgstr "का"
 #, fuzzy
-#~ msgid "Type of attribute to use for labels"
+msgid "Type of attribute to use for labels"
+msgstr "का के लिए"
 #, fuzzy
-#~ msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-#~ msgstr "का उपेक्षित."
+msgid "Index of attribute. Ignored when attr=cat or attr=coords."
+msgstr "का उपेक्षित."
 #, fuzzy
-#~ msgid "Relative horizontal position 'left|center|right'"
-#~ msgstr "बायाँ दायाँ"
+msgid "Relative horizontal position 'left|center|right'"
+msgstr "बायाँ दायाँ"
 #, fuzzy
-#~ msgid "Relative vertical position 'top|center|bottom'"
-#~ msgstr "शीर्ष तल"
+msgid "Relative vertical position 'top|center|bottom'"
+msgstr "शीर्ष तल"
 #, fuzzy
-#~ msgid "Size of text (pixels)"
-#~ msgstr "का पाठ पिक्सेल्स"
+msgid "Size of text (pixels)"
+msgstr "का पाठ पिक्सेल्स"
 #, fuzzy
-#~ msgid "Color desired for drawing map"
-#~ msgstr "के लिए"
+msgid "Color desired for drawing map"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Vector category number(s) to be displayed"
-#~ msgstr "सदिश संख्या"
+msgid "Vector category number(s) to be displayed"
+msgstr "सदिश संख्या"
 #, fuzzy
-#~ msgid "Fill areas of selected polygons"
-#~ msgstr "का"
+msgid "Fill areas of selected polygons"
+msgstr "का"
 #, fuzzy
-#~ msgid "Draws text in the active display frame on the graphics monitor."
-#~ msgstr "पाठ चालू."
+msgid "Draws text in the active display frame on the graphics monitor."
+msgstr "पाठ चालू."
 #, fuzzy
-#~ msgid "Height of letters in percent of available frame height"
-#~ msgstr "ऊंचाई का का ऊंचाई"
+msgid "Height of letters in percent of available frame height"
+msgstr "ऊंचाई का का ऊंचाई"
 #, fuzzy
-#~ msgid "Color desired for drawing text"
-#~ msgstr "के लिए पाठ"
+msgid "Color desired for drawing text"
+msgstr "के लिए पाठ"
 #, fuzzy
-#~ msgid "The screen line number on which text will begin to be drawn "
-#~ msgstr "संख्या चालू पाठ "
+msgid "The screen line number on which text will begin to be drawn "
+msgstr "संख्या चालू पाठ "
 #, fuzzy
-#~ msgid ""
-#~ "Displays point graphics in the active frame on the graphics display "
-#~ "monitor."
-#~ msgstr "बिन्दु चालू."
+msgid ""
+"Displays point graphics in the active frame on the graphics display monitor."
+msgstr "बिन्दु चालू."
 #, fuzzy
-#~ msgid "Input is a UNIX file name"
-#~ msgstr "है a"
+msgid "Input is a UNIX file name"
+msgstr "है a"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to establish whether a map will be displayed using its "
-#~ "own color table or the fixed color table of the graphics monitor."
-#~ msgstr "a स्थिर का."
+msgid ""
+"Allows the user to establish whether a map will be displayed using its own "
+"color table or the fixed color table of the graphics monitor."
+msgstr "a स्थिर का."
 #, fuzzy
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
-#~ msgstr "दो चालू."
+msgid ""
+"Displays the rhumbline joining two user-specified points, in the active "
+"frame on the user's graphics monitor."
+msgstr "दो चालू."
 #, fuzzy
-#~ msgid "Creates and modifies icons for use with ps.map."
-#~ msgstr "प्रतीक के लिए."
+msgid "Creates and modifies icons for use with ps.map."
+msgstr "प्रतीक के लिए."
 #, fuzzy
-#~ msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-#~ msgstr "स्केल का जी"
+msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
+msgstr "स्केल का जी"
 #, fuzzy
-#~ msgid "number of copies to print"
+msgid "number of copies to print"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Selects a PostScript device for GRASS hardcopy output."
-#~ msgstr "a के लिए."
+msgid "Selects a PostScript device for GRASS hardcopy output."
+msgstr "a के लिए."
 #, fuzzy
-#~ msgid "name of PostScript painter to select"
-#~ msgstr "का"
+msgid "name of PostScript painter to select"
+msgstr "का"
 #, fuzzy
-#~ msgid "list all available PostScript painters"
-#~ msgstr "सभी"
+msgid "list all available PostScript painters"
+msgstr "सभी"
 #, fuzzy
-#~ msgid "print name of currently selected PostScript painter"
-#~ msgstr "का"
+msgid "print name of currently selected PostScript painter"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "An imagery function that performs contextual image classification using "
-#~ "sequential maximum a posteriori (SMAP) estimation."
-#~ msgstr "फंक्शन छवि a."
+msgid ""
+"An imagery function that performs contextual image classification using "
+"sequential maximum a posteriori (SMAP) estimation."
+msgstr "फंक्शन छवि a."
 #, fuzzy
-#~ msgid "Force Swapping (overrides default auto)"
-#~ msgstr "स्वचालित"
+msgid "Force Swapping (overrides default auto)"
+msgstr "स्वचालित"
 #, fuzzy
-#~ msgid "Use \"Map Coordinates\" for coordinates"
-#~ msgstr "के लिए"
+msgid "Use \"Map Coordinates\" for coordinates"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "output prefix of the GRASS raster maps to be created."
-#~ msgstr "का."
+msgid "output prefix of the GRASS raster maps to be created."
+msgstr "का."
 #, fuzzy
-#~ msgid "Number of columns to extract."
-#~ msgstr "का."
+msgid "Number of columns to extract."
+msgstr "का."
 #, fuzzy
-#~ msgid "Output 16-bit image (default 8)"
-#~ msgstr "छवि"
+msgid "Output 16-bit image (default 8)"
+msgstr "छवि"
 #, fuzzy
-#~ msgid "maximum number of sub-signatures in any class"
+msgid "maximum number of sub-signatures in any class"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "Generate statistics for i.smap from raster map layer."
-#~ msgstr "के लिए i."
+msgid "Generate statistics for i.smap from raster map layer."
+msgstr "के लिए i."
 #, fuzzy
-#~ msgid "Use symbols (instead of graphics)"
-#~ msgstr "का"
+msgid "Use symbols (instead of graphics)"
+msgstr "का"
 #, fuzzy
-#~ msgid "Import non-georeferenced PNG format image."
-#~ msgstr "आयात छवि."
+msgid "Import non-georeferenced PNG format image."
+msgstr "आयात छवि."
 #, fuzzy
-#~ msgid "Create floating-point maps (0.0 - 1.0)."
+msgid "Create floating-point maps (0.0 - 1.0)."
+msgstr "बिन्दु."
 #, fuzzy
-#~ msgid "Verbose mode on."
-#~ msgstr "बड़बोला चालू."
+msgid "Verbose mode on."
+msgstr "बड़बोला चालू."
 #, fuzzy
-#~ msgid "Enable extend memory option: Operation is slow"
-#~ msgstr "विस्तार दें है"
+msgid "Enable extend memory option: Operation is slow"
+msgstr "विस्तार दें है"
 #, fuzzy
-#~ msgid "Name of an output binary map (use out=- for stdout)"
+msgid "Name of an output binary map (use out=- for stdout)"
+msgstr "का के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Converts point data in a GRASS raster map layer into a GRASS site_lists "
-#~ "file."
+msgid ""
+"Converts point data in a GRASS raster map layer into a GRASS site_lists file."
 #, fuzzy
-#~ msgid "Output as third dimension rather than cat"
-#~ msgstr "तृतीय"
+msgid "Output as third dimension rather than cat"
+msgstr "तृतीय"
 #, fuzzy
-#~ msgid "Name of raster map."
-#~ msgstr "का."
+msgid "Name of raster map."
+msgstr "का."
 #, fuzzy
-#~ msgid ""
-#~ "Creates a new binary GRASS vector (v.digit) file by extracting linear "
-#~ "features from a thinned raster map."
-#~ msgstr "a a."
+msgid ""
+"Creates a new binary GRASS vector (v.digit) file by extracting linear "
+"features from a thinned raster map."
+msgstr "a a."
 #, fuzzy
-#~ msgid ""
-#~ "Creates a raster map layer and site list file containing randomly located "
-#~ "sites."
-#~ msgstr "a."
+msgid ""
+"Creates a raster map layer and site list file containing randomly located "
+"sites."
+msgstr "a."
 #, fuzzy
-#~ msgid "Name of the output sites map"
-#~ msgstr "का"
+msgid "Name of the output sites map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Generate sites for category zero also"
-#~ msgstr "के लिए"
+msgid "Generate sites for category zero also"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-#~ msgstr "a"
+msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
+msgstr "a"
 #, fuzzy
-#~ msgid "Name on TIFF file to input."
-#~ msgstr "चालू."
+msgid "Name on TIFF file to input."
+msgstr "चालू."
 #, fuzzy
-#~ msgid "Bayesian expert system development program."
-#~ msgstr "प्रोग्राम."
+msgid "Bayesian expert system development program."
+msgstr "प्रोग्राम."
 #, fuzzy
-#~ msgid ""
-#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
-#~ "(ercent_cover)"
-#~ msgstr "a h कवर"
+msgid ""
+"mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
+"(ercent_cover)"
+msgstr "a h कवर"
 #, fuzzy
-#~ msgid "name of an output file to hold the report"
-#~ msgstr "का"
+msgid "name of an output file to hold the report"
+msgstr "का"
 #, fuzzy
-#~ msgid "number of fp subranges to collect stats from"
+msgid "number of fp subranges to collect stats from"
+msgstr "संख्या का"
 #, fuzzy
-#~ msgid "filter out all no data cells"
-#~ msgstr "फ़िल्टर सभी"
+msgid "filter out all no data cells"
+msgstr "फ़िल्टर सभी"
 #, fuzzy
-#~ msgid "filter out cells where all maps have no data"
+msgid "filter out cells where all maps have no data"
 #, fuzzy
-#~ msgid "report for cats fp ranges (fp maps only)"
-#~ msgstr "के लिए"
+msgid "report for cats fp ranges (fp maps only)"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Generates an output raster map layer with contiguous areas grown by one "
-#~ "cell (pixel)."
-#~ msgstr "एक."
+msgid ""
+"Generates an output raster map layer with contiguous areas grown by one cell "
+"(pixel)."
+msgstr "एक."
 #, fuzzy
-#~ msgid ""
-#~ "re-project a raster map from one location to the current location (no "
-#~ "datum transformation yet)"
-#~ msgstr "a एक"
+msgid ""
+"re-project a raster map from one location to the current location (no datum "
+"transformation yet)"
+msgstr "a एक"
 #, fuzzy
-#~ msgid "interpolation method to use"
-#~ msgstr "पद्धति"
+msgid "interpolation method to use"
+msgstr "पद्धति"
 #, fuzzy
-#~ msgid "resolution of output map"
-#~ msgstr "का"
+msgid "resolution of output map"
+msgstr "का"
 #, fuzzy
-#~ msgid "Print grid coordinates (east and north) (requires -1 flag)"
-#~ msgstr "छापें पूर्व उत्तर"
+msgid "Print grid coordinates (east and north) (requires -1 flag)"
+msgstr "छापें पूर्व उत्तर"
 #, fuzzy
-#~ msgid "output is the interpolation error"
-#~ msgstr "है त्रुटि"
+msgid "output is the interpolation error"
+msgstr "है त्रुटि"
 #, fuzzy
-#~ msgid "format for reporting the slope"
-#~ msgstr "के लिए ढाल"
+msgid "format for reporting the slope"
+msgstr "के लिए ढाल"
 #, fuzzy
-#~ msgid "type of output aspect and slope maps"
-#~ msgstr "का ढाल"
+msgid "type of output aspect and slope maps"
+msgstr "का ढाल"
 #, fuzzy
-#~ msgid "Output E-W slope filename"
-#~ msgstr "प ढाल फ़ाइलनाम "
+msgid "Output E-W slope filename"
+msgstr "प ढाल फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Output N-S slope filename"
+msgid "Output N-S slope filename"
 #, fuzzy
-#~ msgid "Output partial derivative dxx filename"
-#~ msgstr "फ़ाइलनाम "
+msgid "Output partial derivative dxx filename"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Output partial derivative dyy filename"
+msgid "Output partial derivative dyy filename"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Output partial derivative dxy filename"
+msgid "Output partial derivative dxy filename"
+msgstr "फ़ाइलनाम "
 #, fuzzy
-#~ msgid "Name of file for output (use out=- for stdout)"
-#~ msgstr "का के लिए के लिए"
+msgid "Name of file for output (use out=- for stdout)"
+msgstr "का के लिए के लिए"
 #, fuzzy
-#~ msgid ""
-#~ "Converts raster data referenced using latitude and longitude coordinates "
-#~ "to a UTM-referenced map layer in GRASS raster format."
-#~ msgstr "a."
+msgid ""
+"Converts raster data referenced using latitude and longitude coordinates to "
+"a UTM-referenced map layer in GRASS raster format."
+msgstr "a."
 #, fuzzy
-#~ msgid ""
-#~ "one corner latitude and longitude of the input\n"
-#~ "format: {nw|ne|sw|se},%s,%s"
-#~ msgstr "एक का"
+msgid ""
+"one corner latitude and longitude of the input\n"
+"format: {nw|ne|sw|se},%s,%s"
+msgstr "एक का"
 #, fuzzy
-#~ msgid "resolution of the input (in arc seconds)"
-#~ msgstr "का चाप"
+msgid "resolution of the input (in arc seconds)"
+msgstr "का चाप"
 #, fuzzy
-#~ msgid "Stop points site file"
-#~ msgstr "रूकें"
+msgid "Stop points site file"
+msgstr "रूकें"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts area edges from a raster map layer and converts data to GRASS "
-#~ "vector format."
-#~ msgstr "a."
+msgid ""
+"Extracts area edges from a raster map layer and converts data to GRASS "
+"vector format."
+msgstr "a."
 #, fuzzy
-#~ msgid "Number of values printed before wrapping a line"
-#~ msgstr "का a"
+msgid "Number of values printed before wrapping a line"
+msgstr "का a"
 #, fuzzy
-#~ msgid "raster map name from which to copy color table"
-#~ msgstr "नक़ल"
+msgid "raster map name from which to copy color table"
+msgstr "नक़ल"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where color type is one of:\n"
+msgid ""
+"\n"
+"Where color type is one of:\n"
 #, fuzzy
-#~ msgid "  aspect    (aspect oriented grey colors)\n"
-#~ msgstr "n"
+msgid "  aspect    (aspect oriented grey colors)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  grey      (linear grey scale)\n"
-#~ msgstr "स्केल n"
+msgid "  grey      (linear grey scale)\n"
+msgstr "स्केल n"
 #, fuzzy
-#~ msgid "  grey.eq   (histogram equalized grey scale)\n"
+msgid "  grey.eq   (histogram equalized grey scale)\n"
+msgstr "स्केल n"
 #, fuzzy
-#~ msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
+msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
+msgstr "स्केल n"
 #, fuzzy
-#~ msgid "  byg       (blue through yellow to green colors)\n"
-#~ msgstr "n"
+msgid "  byg       (blue through yellow to green colors)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  byr       (blue through yellow to red colors)\n"
-#~ msgstr "n"
+msgid "  byr       (blue through yellow to red colors)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  gyr       (green through yellow to red colors)\n"
-#~ msgstr "n"
+msgid "  gyr       (green through yellow to red colors)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  rainbow   (rainbow color table)\n"
-#~ msgstr "इंद्रधनुष इंद्रधनुष n"
+msgid "  rainbow   (rainbow color table)\n"
+msgstr "इंद्रधनुष इंद्रधनुष n"
 #, fuzzy
-#~ msgid "  ramp      (color ramp)\n"
-#~ msgstr "n"
+msgid "  ramp      (color ramp)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  ryg       (red through yellow to green colors)\n"
-#~ msgstr "n"
+msgid "  ryg       (red through yellow to green colors)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  random    (random color table)\n"
-#~ msgstr "n"
+msgid "  random    (random color table)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  wave      (color wave)\n"
-#~ msgstr "n"
+msgid "  wave      (color wave)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  rules     (create new color table by rules)\n"
-#~ msgstr "n"
+msgid "  rules     (create new color table by rules)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "method of object-based statistic"
-#~ msgstr "पद्धति का वस्तु"
+msgid "method of object-based statistic"
+msgstr "पद्धति का वस्तु"
 #, fuzzy
-#~ msgid "resultant raster map (not used with 'distribution')"
-#~ msgstr "नहीं वितरण"
+msgid "resultant raster map (not used with 'distribution')"
+msgstr "नहीं वितरण"
 #, fuzzy
-#~ msgid "Northern limit of geographic region"
-#~ msgstr "का"
+msgid "Northern limit of geographic region"
+msgstr "का"
 #, fuzzy
-#~ msgid "Eastern limit of geographic region"
-#~ msgstr "का"
+msgid "Eastern limit of geographic region"
+msgstr "का"
 #, fuzzy
-#~ msgid "Western limit of geographic region"
-#~ msgstr "का"
+msgid "Western limit of geographic region"
+msgstr "का"
 #, fuzzy
-#~ msgid "Extend location extents based on new dataset."
-#~ msgstr "चालू."
+msgid "Extend location extents based on new dataset."
+msgstr "चालू."
 #, fuzzy
-#~ msgid "Maximum magnitude of random grid point offset"
+msgid "Maximum magnitude of random grid point offset"
+msgstr "का बिन्दु"
 #, fuzzy
-#~ msgid ""
-#~ "Outputs a raster map layer whose category values represent the "
-#~ "application of user-specified criteria (rules statements) to other raster "
-#~ "map layers' category values."
-#~ msgstr "a किसका का अन्य."
+msgid ""
+"Outputs a raster map layer whose category values represent the application "
+"of user-specified criteria (rules statements) to other raster map layers' "
+"category values."
+msgstr "a किसका का अन्य."
 #, fuzzy
-#~ msgid "Converts a PPM image file to GRASS raster map(s)."
-#~ msgstr "a छवि."
+msgid "Converts a PPM image file to GRASS raster map(s)."
+msgstr "a छवि."
 #, fuzzy
-#~ msgid ""
-#~ "Converts Universal Transverse Mercator (UTM) coordinates to geographic "
-#~ "(latitude/longitude) coordinates."
-#~ msgstr "यूनिवर्सल."
+msgid ""
+"Converts Universal Transverse Mercator (UTM) coordinates to geographic "
+"(latitude/longitude) coordinates."
+msgstr "यूनिवर्सल."
 #, fuzzy
-#~ msgid "Specified zone is in the southern hemisphere"
-#~ msgstr "है"
+msgid "Specified zone is in the southern hemisphere"
+msgstr "है"
 #, fuzzy
-#~ msgid "Input is reversed: north,east"
-#~ msgstr "है उत्तर पूर्व"
+msgid "Input is reversed: north,east"
+msgstr "है उत्तर पूर्व"
 #, fuzzy
-#~ msgid "Do not flag invalid east,north input lines as errors"
-#~ msgstr "नहीं अवैध पूर्व उत्तर"
+msgid "Do not flag invalid east,north input lines as errors"
+msgstr "नहीं अवैध पूर्व उत्तर"
 #, fuzzy
-#~ msgid "Flag other input lines as errors"
-#~ msgstr "ध्वज अन्य"
+msgid "Flag other input lines as errors"
+msgstr "ध्वज अन्य"
 #, fuzzy
-#~ msgid "Output in decimal degrees"
-#~ msgstr "कोण"
+msgid "Output in decimal degrees"
+msgstr "कोण"
 #, fuzzy
-#~ msgid ""
-#~ "Converts geographic coordinates to Universal Transverse Mercator (UTM) "
-#~ "coordinates."
+msgid ""
+"Converts geographic coordinates to Universal Transverse Mercator (UTM) "
+"coordinates."
 #, fuzzy
-#~ msgid "Input is reversed: lat,lon"
-#~ msgstr "है"
+msgid "Input is reversed: lat,lon"
+msgstr "है"
 #, fuzzy
-#~ msgid "Do not flag invalid lon,lat input lines as errors"
-#~ msgstr "नहीं अवैध"
+msgid "Do not flag invalid lon,lat input lines as errors"
+msgstr "नहीं अवैध"
 #, fuzzy
-#~ msgid ""
-#~ "Rotates elevation data extracted by either m.dted.extract or m."
-#~ "dmaUSGSread."
-#~ msgstr "मी मी."
+msgid ""
+"Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
+msgstr "मी मी."
 #, fuzzy
-#~ msgid "Number of bytes per cell (i.e. per data value)"
-#~ msgstr "का बाइट्स i"
+msgid "Number of bytes per cell (i.e. per data value)"
+msgstr "का बाइट्स i"
 #, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of level 1 and 2 digital terrain elevation "
-#~ "data (DTED) files produced and distributed by the Defense Mapping Agency "
-#~ "(DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "a का चालू इंच."
+msgid ""
+"Provides a terse description of level 1 and 2 digital terrain elevation data "
+"(DTED) files produced and distributed by the Defense Mapping Agency (DMA) on "
+"1/2-inch magnetic tapes."
+msgstr "a का चालू इंच."
 #, fuzzy
-#~ msgid "Name of tape drive device"
-#~ msgstr "का"
+msgid "Name of tape drive device"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Datum shift program. Return geographic coordinates based on a different "
-#~ "datum that the one used to obtain the original coordinates. "
-#~ msgstr "प्रोग्राम चालू a एक असली "
+msgid ""
+"Datum shift program. Return geographic coordinates based on a different "
+"datum that the one used to obtain the original coordinates. "
+msgstr "प्रोग्राम चालू a एक असली "
 #, fuzzy
-#~ msgid "use block shift transformation (default)"
-#~ msgstr "ब्लॉक"
+msgid "use block shift transformation (default)"
+msgstr "ब्लॉक"
 #, fuzzy
-#~ msgid "use bursa wolf 3d similarity transformation (not implemented)"
-#~ msgstr "नहीं"
+msgid "use bursa wolf 3d similarity transformation (not implemented)"
+msgstr "नहीं"
 #, fuzzy
-#~ msgid "height above ellipsoid"
-#~ msgstr "ऊंचाई"
+msgid "height above ellipsoid"
+msgstr "ऊंचाई"
 #, fuzzy
-#~ msgid "z shift"
-#~ msgstr "ज़ेड"
+msgid "z shift"
+msgstr "ज़ेड"
 #, fuzzy
-#~ msgid "spheroid geographic coordinates to base on. "
-#~ msgstr "बेस चालू "
+msgid "spheroid geographic coordinates to base on. "
+msgstr "बेस चालू "
 #, fuzzy
-#~ msgid ""
-#~ "Converts UTM coordinates falling within the current geographic region to "
-#~ "geographic (latitude/longitude) coordinates. "
-#~ msgstr "गिरता "
+msgid ""
+"Converts UTM coordinates falling within the current geographic region to "
+"geographic (latitude/longitude) coordinates. "
+msgstr "गिरता "
 #, fuzzy
-#~ msgid ""
-#~ "Flips elevation data extracted from systems that retrieve data by rows "
-#~ "from south to north."
-#~ msgstr "दक्षिण उत्तर."
+msgid ""
+"Flips elevation data extracted from systems that retrieve data by rows from "
+"south to north."
+msgstr "दक्षिण उत्तर."
 #, fuzzy
-#~ msgid "Number of bytes per cell (ie, per data value)"
-#~ msgstr "का बाइट्स"
+msgid "Number of bytes per cell (ie, per data value)"
+msgstr "का बाइट्स"
 #, fuzzy
-#~ msgid ""
-#~ "Finds geographic region information for U.S. Census Bureau TIGER input "
-#~ "data."
-#~ msgstr "के लिए."
+msgid ""
+"Finds geographic region information for U.S. Census Bureau TIGER input data."
+msgstr "के लिए."
 #, fuzzy
-#~ msgid "Filename for raw tiger data (type 1)"
-#~ msgstr "के लिए कच्चा"
+msgid "Filename for raw tiger data (type 1)"
+msgstr "के लिए कच्चा"
 #, fuzzy
-#~ msgid "UTM zone for this county"
-#~ msgstr "के लिए"
+msgid "UTM zone for this county"
+msgstr "के लिए"
 #, fuzzy
-#~ msgid "Name of spheroid to use"
-#~ msgstr "का"
+msgid "Name of spheroid to use"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of USGS Digital Elevation Model (DEM) data "
-#~ "files stored on 1/2-inch magnetic tape."
+msgid ""
+"Provides a terse description of USGS Digital Elevation Model (DEM) data "
+"files stored on 1/2-inch magnetic tape."
 #, fuzzy
-#~ msgid "Blocksize of tape data"
-#~ msgstr "का"
+msgid "Blocksize of tape data"
+msgstr "का"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced "
-#~ "and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic "
-#~ "tapes."
-#~ msgstr "चालू इंच."
+msgid ""
+"Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and "
+"supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
+msgstr "चालू इंच."
 #, fuzzy
-#~ msgid "Name of header output file"
-#~ msgstr "का"
+msgid "Name of header output file"
+msgstr "का"
 #, fuzzy
-#~ msgid "North latitude of region to extract (format: %s)"
-#~ msgstr "का"
+msgid "North latitude of region to extract (format: %s)"
+msgstr "का"
 #, fuzzy
-#~ msgid "South latitude of region to extract (format: %s)"
-#~ msgstr "का"
+msgid "South latitude of region to extract (format: %s)"
+msgstr "का"
 #, fuzzy
-#~ msgid "East longitude of region to extract (format: %s)"
-#~ msgstr "पूर्व का"
+msgid "East longitude of region to extract (format: %s)"
+msgstr "पूर्व का"
 #, fuzzy
-#~ msgid "West longitude of region to extract (format: %s)"
-#~ msgstr "पश्चिम का"
+msgid "West longitude of region to extract (format: %s)"
+msgstr "पश्चिम का"
 #, fuzzy
-#~ msgid "Read the entire tape in all cases"
-#~ msgstr "सभी"
+msgid "Read the entire tape in all cases"
+msgstr "सभी"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic "
-#~ "tape."
-#~ msgstr "इंच."
+msgid ""
+"Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
+msgstr "इंच."
 #, fuzzy
-#~ msgid "First file to look at"
-#~ msgstr "पर"
+msgid "First file to look at"
+msgstr "पर"
 #, fuzzy
-#~ msgid "Last file to look at"
-#~ msgstr "पर"
+msgid "Last file to look at"
+msgstr "पर"
 #, fuzzy
-#~ msgid "Selects a device (printer) for GRASS hardcopy output."
+msgid "Selects a device (printer) for GRASS hardcopy output."
+msgstr "a के लिए."
 #, fuzzy
-#~ msgid "list all available painters"
-#~ msgstr "सभी"
+msgid "list all available painters"
+msgstr "सभी"
 #, fuzzy
-#~ msgid "print name of currently selected painter"
-#~ msgstr "का"
+msgid "print name of currently selected painter"
+msgstr "का"
 #, fuzzy
-#~ msgid "Align region to resolution [default = align to bounds]"
-#~ msgstr "पंक्तिबद्ध करें"
+msgid "Align region to resolution [default = align to bounds]"
+msgstr "पंक्तिबद्ध करें"
 #, fuzzy
-#~ msgid "Set region to match this sites map"
-#~ msgstr "सेट जोड़ा"
+msgid "Set region to match this sites map"
+msgstr "सेट जोड़ा"
 #, fuzzy
-#~ msgid "Value for the eastern edge "
-#~ msgstr "के लिए "
+msgid "Value for the eastern edge "
+msgstr "के लिए "
 #, fuzzy
-#~ msgid "Value for the western edge "
+msgid "Value for the western edge "
+msgstr "के लिए "
 #, fuzzy
-#~ msgid "Grid resolution (both north-south and east-west)"
-#~ msgstr "उत्तर दक्षिण पूर्व पश्चिम"
+msgid "Grid resolution (both north-south and east-west)"
+msgstr "उत्तर दक्षिण पूर्व पश्चिम"
 #, fuzzy
-#~ msgid "  vect   (binary vector maps)\n"
-#~ msgstr "n"
+msgid "  vect   (binary vector maps)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  icon   (paint icon files)\n"
-#~ msgstr "n"
+msgid "  icon   (paint icon files)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  labels (paint label files)\n"
-#~ msgstr "n"
+msgid "  labels (paint label files)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  sites  (site list files)\n"
-#~ msgstr "n"
+msgid "  sites  (site list files)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  region (region definition files)\n"
-#~ msgstr "n"
+msgid "  region (region definition files)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "  group  (imagery group files)\n"
-#~ msgstr "समूह समूह n"
+msgid "  group  (imagery group files)\n"
+msgstr "समूह समूह n"
 #, fuzzy
-#~ msgid "  3dview (3D view parameters)\n"
-#~ msgstr "n"
+msgid "  3dview (3D view parameters)\n"
+msgstr "n"
 #, fuzzy
-#~ msgid "Print all, inclusive range"
-#~ msgstr "छापें सभी"
+msgid "Print all, inclusive range"
+msgstr "छापें सभी"
+#, fuzzy
+#~ msgid "display, export"
+#~ msgstr "गामा."
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "का"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "समूह"
+#, fuzzy
+#~ msgid "Data type"
+#~ msgstr "विशेषता"
+#, fuzzy
+#~ msgid "slopein raster map <%s> not found"
+#~ msgstr "नहीं"
+#, fuzzy
+#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+#~ msgstr "त्रुटि."
+#, fuzzy
+#~ msgid "Base raster map <%s> not found"
+#~ msgstr "नहीं"
+#, fuzzy
+#~ msgid "Color table for <%s> updated"
+#~ msgstr "के लिए."
+#, fuzzy
+#~ msgid "Error reading raster map [%s]."
+#, fuzzy
+#~ msgid "Option <%s>: <%s> exists."
+#~ msgstr "नहीं"
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "त्रुटि"
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "अवैध"
+#, fuzzy
+#~ msgid "Name of the input raster map"
+#~ msgstr "का"
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_it.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -5806,12 +5806,12 @@
 #: ../imagery/i.vi/main.c:133
 #, fuzzy
 msgid "Name of the chan5 channel surface reflectance map"
-msgstr "Nome di un nuovo file raster"
+msgstr "Nome della mappa con il risultato"
 #: ../imagery/i.vi/main.c:140
 #, fuzzy
 msgid "Name of the chan7 channel surface reflectance map"
 #: ../imagery/i.vi/main.c:306 ../imagery/i.albedo/main.c:389
 #: ../raster/r.los/main.c:382 ../raster/r.texture/main.c:333
@@ -11865,8 +11865,9 @@
 msgstr "Nome del file raster in input"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
+msgstr "Nome del file raster in input"
 #: ../raster/r.uslek/main.c:66
 #, fuzzy
@@ -17270,7 +17271,7 @@
 #: ../raster/r.mapcalc/main.c:148
 #, fuzzy
 msgid "parse error"
-msgstr "%s errori di aggiornamento\n"
+msgstr "Parametri"
 #: ../raster/r.mapcalc/main.c:157
 msgid "Floating point error(s) occured in the calculation"
@@ -25886,8 +25887,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "Punti di partenza del file raster"
 #: ../vector/v.net.steiner/main.c:447
 #, fuzzy
@@ -27014,8 +27016,9 @@
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
+#, fuzzy
 msgid "Position"
-msgstr ""
+msgstr "Nome del raster"
 #: ../visualization/nviz2/cmd/args.c:301
 #, fuzzy
@@ -27208,2815 +27211,2847 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Non riesco a mostrare i database"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Condizione opzionale where (senza la parola chiave WHERE), e.s.:\n"
 #, fuzzy
-#~ msgid "Illegal output file name"
-#~ msgstr "Nome del file di output"
+msgid "Illegal output file name"
+msgstr "Nome del file di output"
 #, fuzzy
-#~ msgid "Display manager for GRASS"
-#~ msgstr "Numero di colonne"
+msgid "Display manager for GRASS"
+msgstr "Numero di colonne"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "Nome di un file MAT-File(v4) esistente"
+msgid "Name of .dmrc settings file"
+msgstr "Nome di un file MAT-File(v4) esistente"
-#~ msgid "Selects/starts specified monitor at specified size"
-#~ msgstr "Selezione/avvia il monitor specificato alla dimensione specificata"
+msgid "Selects/starts specified monitor at specified size"
+msgstr "Selezione/avvia il monitor specificato alla dimensione specificata"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr ""
-#~ "Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
-#~ "nel monitor grafico dell'utente."
+msgid "Moves displayed maps to another monitor"
+msgstr ""
+"Seleziona il tipo di carattere con cui il testo deve essere rappresentato "
+"nel monitor grafico dell'utente."
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr ""
-#~ "Salva il monitor attivo visualizzato in un file PNG nella directory home"
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr ""
+"Salva il monitor attivo visualizzato in un file PNG nella directory home"
-#~ msgid "Resolution of output file (single=1, double=2, quad=4)"
-#~ msgstr "Risoluzione del file di uscita (singolo=1, doppio=2, quadruplo=4)"
+msgid "Resolution of output file (single=1, double=2, quad=4)"
+msgstr "Risoluzione del file di uscita (singolo=1, doppio=2, quadruplo=4)"
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
-#~ msgstr ""
+msgid "Saves the contents of the active display monitor to a graphics file."
+msgstr ""
 #, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "Nome del filtro file"
+msgid "Compression for PNG files"
+msgstr "Nome del filtro file"
-#~ msgid "File size/quality for JPEG files"
-#~ msgstr "Dimensione/qualità del file per JPEG"
+msgid "File size/quality for JPEG files"
+msgstr "Dimensione/qualità del file per JPEG"
 #, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "File raster in output"
+msgid "Paper size for PostScript output"
+msgstr "File raster in output"
 #, fuzzy
-#~ msgid "PostScript"
+msgid "PostScript"
-#~ msgid "Set background color to black (white default)"
-#~ msgstr "Imposta il colore dello sfondo nero (default bianco)"
+msgid "Set background color to black (white default)"
+msgstr "Imposta il colore dello sfondo nero (default bianco)"
-#~ msgid "Set transparent background"
-#~ msgstr "Imposta sfondo trasparente"
+msgid "Set transparent background"
+msgstr "Imposta sfondo trasparente"
-#~ msgid "Use the Cario driver to render images"
-#~ msgstr "Usa il driver Cario per restituire immagini"
+msgid "Use the Cario driver to render images"
+msgstr "Usa il driver Cario per restituire immagini"
-#~ msgid "Set paper orientation to landscape (for PostScript output)"
-#~ msgstr ""
-#~ "Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
+msgid "Set paper orientation to landscape (for PostScript output)"
+msgstr ""
+"Imposta l'orientazione del foglio in orizzontale (per uscita PostScript)"
 #, fuzzy
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr ""
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr ""
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Nume di righe da tenere in memoria"
+msgid "Number of lines to appear in the legend"
+msgstr "Nume di righe da tenere in memoria"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Non è mostrata nessuna mappa nel monitor GRASS"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Non è mostrata nessuna mappa nel monitor GRASS"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "Numero di righe"
+msgid "Redraw all frames"
+msgstr "Numero di righe"
-#~ msgid "Resizes active display monitor"
-#~ msgstr "Ridimensiona il monitor attivo visualizzato"
+msgid "Resizes active display monitor"
+msgstr "Ridimensiona il monitor attivo visualizzato"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Slide show dei file raster e vettoriali presenti"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Slide show dei file raster e vettoriali presenti"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "Converti una mappa raster in file height field per POVRAY"
+msgid "Show vector maps rather than raster maps"
+msgstr "Converti una mappa raster in file height field per POVRAY"
-#~ msgid "Mapsets to use. Specify multiple mapsets comma separated"
-#~ msgstr "Mapset da usare. Specificare multipli mapset separati dalla virgola"
+msgid "Mapsets to use. Specify multiple mapsets comma separated"
+msgstr "Mapset da usare. Specificare multipli mapset separati dalla virgola"
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
+msgid "Number of seconds to pause between slides"
 #, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "Mappa(e) raster da leggere"
+msgid "Enter raster map to display in 1st frame"
+msgstr "Mappa(e) raster da leggere"
 #, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
+msgid "Enter command to execute in 1st frame"
 #, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
+msgid "Enter raster map to display in 2nd frame"
 #, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
+msgid "Enter command to execute in 2nd frame"
-#~ msgid "Displays thematic vectormap"
-#~ msgstr "Mostra mappa vettoriale tematica"
+msgid "Displays thematic vectormap"
+msgstr "Mostra mappa vettoriale tematica"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
+msgid "Vector map to display thematically"
 #, fuzzy
-#~ msgid "Vector map type"
-#~ msgstr "File di input"
+msgid "Vector map type"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "Nome della mappa raster da utilizzare per <%s>"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr "Nome della mappa raster da utilizzare per <%s>"
 #, fuzzy
-#~ msgid "Type of thematic display"
-#~ msgstr "Nome del raster map in output"
+msgid "Type of thematic display"
+msgstr "Nome del raster map in output"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
+msgid "Layer to use for thematic display"
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "Stampa"
+msgid "Points"
+msgstr "Stampa"
-#~ msgid "Vector point icon for point data"
-#~ msgstr "Icona di punti vettoriali per dati puntiformi"
+msgid "Vector point icon for point data"
+msgstr "Icona di punti vettoriali per dati puntiformi"
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
-#~ msgstr "Numero di passi attraverso il dataset"
+msgid "Number of classes for interval theme (integer)"
+msgstr "Numero di passi attraverso il dataset"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "Mapset del quale fornire la lista (default: percorso corrente)"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Carattere di separatore in output (predefinito: tab)"
+msgid "Output separator (default: newline)"
+msgstr "Carattere di separatore in output (predefinito: tab)"
 #, fuzzy
-#~ msgid "Raster to remove"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Raster to remove"
+msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
 #, fuzzy
-#~ msgid "Vector to remove"
+msgid "Vector to remove"
 #, fuzzy
-#~ msgid "Region to remove"
+msgid "Region to remove"
 #, fuzzy
-#~ msgid "Label to remove"
+msgid "Label to remove"
 #, fuzzy
-#~ msgid "3dview to remove"
+msgid "3dview to remove"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "Group to remove"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "Mappa raster in input"
+msgid "raster input maps"
+msgstr "Mappa raster in input"
 #, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "Sovrascrivi file mappa in output"
+msgid "write output to PNG image"
+msgstr "Sovrascrivi file mappa in output"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Utilizzando le coordinate del centro della mappa\n"
+msgid "label with coordinates instead of numbering"
+msgstr "Utilizzando le coordinate del centro della mappa\n"
 #, fuzzy
-#~ msgid "Keep band numbers instead of using band color names."
-#~ msgstr "Usa i numeri delle bande invece che i nomi dei colori"
+msgid "Keep band numbers instead of using band color names."
+msgstr "Usa i numeri delle bande invece che i nomi dei colori"
-#~ msgid "Calculate new raster map from a r.mapcalc expression."
-#~ msgstr "Calcola una nuova mappa raster da un'espressione di r.mapcalc"
+msgid "Calculate new raster map from a r.mapcalc expression."
+msgstr "Calcola una nuova mappa raster da un'espressione di r.mapcalc"
-#~ msgid "A"
-#~ msgstr "A"
+msgid "A"
+msgstr "A"
-#~ msgid "B"
-#~ msgstr "B"
+msgid "B"
+msgstr "B"
-#~ msgid "C"
-#~ msgstr "C"
+msgid "C"
+msgstr "C"
-#~ msgid "D"
-#~ msgstr "D"
+msgid "D"
+msgstr "D"
-#~ msgid "E"
-#~ msgstr "E"
+msgid "E"
+msgstr "E"
-#~ msgid "F"
-#~ msgstr "F"
+msgid "F"
+msgstr "F"
-#~ msgid "Formula (e.g. A-B or A*C+B)"
-#~ msgstr "Formula (p.e. A-B o A*C+B)"
+msgid "Formula (e.g. A-B or A*C+B)"
+msgstr "Formula (p.e. A-B o A*C+B)"
-#~ msgid "Show help"
-#~ msgstr "Mostra help"
+msgid "Show help"
+msgstr "Mostra help"
-#~ msgid "Expert mode (enter a set of r.mapcalc expressions)"
-#~ msgstr "Modo esperto (inserisci un set di espressioni di r.mapcalc)"
+msgid "Expert mode (enter a set of r.mapcalc expressions)"
+msgstr "Modo esperto (inserisci un set di espressioni di r.mapcalc)"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Usa il flag -o per sovrascrivere il link esistente del layer <%d>"
+msgid "Do not overwrite existing map"
+msgstr "Usa il flag -o per sovrascrivere il link esistente del layer <%d>"
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Esporta un raster grass come array binario"
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "Esporta un raster grass come array binario"
 #, fuzzy
-#~ msgid "Region sensitive output"
-#~ msgstr "Mappa raster risultante"
+msgid "Region sensitive output"
+msgstr "Mappa raster risultante"
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Campo separatore in output"
+msgid "Output field seperator"
+msgstr "Campo separatore in output"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
+msgid "calculates univariate statistics from a GRASS raster map"
 #, fuzzy
-#~ msgid "A (grid3D file)"
+msgid "A (grid3D file)"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
-#~ msgstr "Nome del file in output"
+msgid "Name for output grid3D volume"
+msgstr "Nome del file in output"
-#~ msgid "Expert mode (enter a set of r3.mapcalc expressions)"
-#~ msgstr "Modo esperto (inserisci un set di espressioni r3.mapcalc)"
+msgid "Expert mode (enter a set of r3.mapcalc expressions)"
+msgstr "Modo esperto (inserisci un set di espressioni r3.mapcalc)"
 #, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "raster <%s> non trovato"
+msgid "%s: [%s] not found"
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "Nome del raster map esistente"
+msgid ""
+"Enter the file name or path\n"
+msgstr "Nome del raster map esistente"
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Usa mouse per selezionare Punto di inizio\n"
+msgid "Use mouse to select Start Point\n"
+msgstr "Usa mouse per selezionare Punto di inizio\n"
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Usa mouse per disegnare la linea di profilo\n"
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
+msgstr ""
+"\n"
+"Usa mouse per disegnare la linea di profilo\n"
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Bottoni:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"Bottoni:\n"
 #, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr " Sinistro:  mostra cosa c'è qui\n"
+msgid "Left:   Mark next point\n"
+msgstr " Sinistro:  mostra cosa c'è qui\n"
-#~ msgid "Middle: Mark next point\n"
-#~ msgstr "Centrale: Segna il prossimo punto\n"
+msgid "Middle: Mark next point\n"
+msgstr "Centrale: Segna il prossimo punto\n"
-#~ msgid ""
-#~ "Right:  Finish profile and exit\n"
-#~ "\n"
-#~ msgstr ""
-#~ "Destro: Finisci profilo ed esci\n"
-#~ "\n"
+msgid ""
+"Right:  Finish profile and exit\n"
+"\n"
+msgstr ""
+"Destro: Finisci profilo ed esci\n"
+"\n"
 #, fuzzy
-#~ msgid "elevin raster map <%s> not found"
+msgid "elevin raster map <%s> not found"
 #, fuzzy
-#~ msgid "aspin raster map <%s> not found"
+msgid "aspin raster map <%s> not found"
 #, fuzzy
-#~ msgid "linkein raster map <%s> not found"
+msgid "linkein raster map <%s> not found"
 #, fuzzy
-#~ msgid "albedo raster map <%s> not found"
+msgid "albedo raster map <%s> not found"
 #, fuzzy
-#~ msgid "latin raster map <%s> not found"
+msgid "latin raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
+msgid "coefbh raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
+msgid "coefdh raster map <%s> not found"
 #, fuzzy
-#~ msgid "Unable to find data map"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Unable to find data map"
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Unable to find clump map"
+msgid "Unable to find clump map"
 #, fuzzy
-#~ msgid "Saving new map"
+msgid "Saving new map"
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Nome del driver in input"
+msgid "Terrain raster map (DEM)"
+msgstr "Nome del driver in input"
 #, fuzzy
-#~ msgid "Output raster map with lake"
-#~ msgstr "Nome del driver in output"
+msgid "Output raster map with lake"
+msgstr "Nome del driver in output"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Cannot write lake raster map <%s>!"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
+msgid "Terrain raster map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
+msgid "Seed map <%s> not found!"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
+msgid "Failure to allocate memory for row pointers"
 #, fuzzy
-#~ msgid "Loading maps: "
+msgid "Loading maps: "
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
+msgid "Error reading terrain raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Errore nella lettura del file dbmscap\n"
 #, fuzzy
-#~ msgid "All done."
-#~ msgstr "Fatto.\n"
+msgid "All done."
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "%s: base raster map not found"
+msgid "%s: base raster map not found"
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
+msgid "%s: cover raster map not found"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "Name of the vector points map with x,y locations"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
+msgid "Number of time iterations (sec.)"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "locazione del database"
+msgid "Multiscale simulation"
+msgstr "locazione del database"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Nome del file raster in input"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Quietly"
-#~ msgstr "Silenziosamente"
+msgid "Quietly"
+msgstr "Silenziosamente"
 #, fuzzy
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr ""
-#~ "specifica un valore di output con cui assegnare i poli nord e/o sud per "
-#~ "la griglia di longitudine-latitudine"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr ""
+"specifica un valore di output con cui assegnare i poli nord e/o sud per la "
+"griglia di longitudine-latitudine"
 #, fuzzy
-#~ msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
-#~ msgstr ""
-#~ "L'uso dell'istruzione \"scale\" dalla linea di comando è deprecato. Per "
-#~ "favore inserisci l'istruzione \"scale\" nel file di istruzioni."
+msgid "This module is deprecated. Please use 'r.resamp.interp' instead."
+msgstr ""
+"L'uso dell'istruzione \"scale\" dalla linea di comando è deprecato. Per "
+"favore inserisci l'istruzione \"scale\" nel file di istruzioni."
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
+msgid "Illegal output file name <%s>"
-#~ msgid "Raster input maps(s)"
-#~ msgstr "Mappe raster in input"
+msgid "Raster input maps(s)"
+msgstr "Mappe raster in input"
 #, fuzzy
-#~ msgid "Output file name"
+msgid "Output file name"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "ERRORE: <%s> esiste già\n"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "ERRORE: <%s> esiste già\n"
 #, fuzzy
-#~ msgid "Path to rules file"
+msgid "Path to rules file"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
+msgid "RGB raster map <%s> not found"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
+msgid "Vector cell map <%s> not found"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]!"
+msgid "Cannot open raster map [%s]!"
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "Il file raster [%s] è vuoto."
+msgid "Raster file [%s] is empty."
+msgstr "Il file raster [%s] è vuoto."
 #, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Unable to write header for [%s]."
+msgstr "Non riesco ad aprire il cellfile per [%s]"
 #, fuzzy
-#~ msgid "        Number of rows"
+msgid "        Number of rows"
 #, fuzzy
-#~ msgid "        Number of cols"
+msgid "        Number of cols"
 #, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
+msgid "Raster file [%s] not found. Exiting."
 #, fuzzy
-#~ msgid "Edit the history file for [%s]? "
+msgid "Edit the history file for [%s]? "
 #, fuzzy
-#~ msgid "%s map <%s> not found"
+msgid "%s map <%s> not found"
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
-#~ msgstr "File category per [%s] non disponibile"
+msgid "Category file for <%s> not updated"
+msgstr "File category per [%s] non disponibile"
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
+msgid "Category file for <%s> updated"
-#~ msgid "Title, in quotes"
-#~ msgstr "Titolo, fra virgolette"
+msgid "Title, in quotes"
+msgstr "Titolo, fra virgolette"
 #, fuzzy
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "Silenzioso"
+msgid "Quiet - Do not show progress"
+msgstr "Silenzioso"
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
+msgid "Unable to find starting vector <%s> "
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
+msgid "Unable to find stop vector <%s>"
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
+msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "Applica soltanto il filtro per i valori uguali a zero"
+msgid "Apply filter only to zero data values"
+msgstr "Applica soltanto il filtro per i valori uguali a zero"
 #, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Error reading '%s' map"
 #, fuzzy
-#~ msgid "Cell file not found"
+msgid "Cell file not found"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
+msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "Unità della distanza"
+msgid "Threshold distance"
+msgstr "Unità della distanza"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Cannot execute: %s"
+msgstr "Non riesco ad impostare user/password"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "Cannot link table: %s"
+msgstr "Non posso scrivere i collegamenti del database"
 #, fuzzy
-#~ msgid "DXF input file"
+msgid "DXF input file"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "Cannot open new vector map <%s>"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
+msgid "Conversion of <%s> to vector map:"
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
+msgid "Network input map <%s> not found"
 #, fuzzy
-#~ msgid "Hilight color for text"
-#~ msgstr "Colore di evidenziazione del testo"
+msgid "Hilight color for text"
+msgstr "Colore di evidenziazione del testo"
-#~ msgid "Line: %d\n"
-#~ msgstr "Linea: %d\n"
+msgid "Line: %d\n"
+msgstr "Linea: %d\n"
 #, fuzzy
-#~ msgid "output raster map"
+msgid "output raster map"
-#~ msgid "Name of input raster map(s)"
-#~ msgstr "Nome della mappe raster in input"
+msgid "Name of input raster map(s)"
+msgstr "Nome della mappe raster in input"
-#~ msgid "name=%s\n"
-#~ msgstr "name=%s\n"
+msgid "name=%s\n"
+msgstr "name=%s\n"
-#~ msgid "mapset=%s\n"
-#~ msgstr "mapset=%s\n"
+msgid "mapset=%s\n"
+msgstr "mapset=%s\n"
-#~ msgid "fullname=%s\n"
-#~ msgstr "fullname=%s\n"
+msgid "fullname=%s\n"
+msgstr "fullname=%s\n"
-#~ msgid "usage: %s file [prompt %%x %%y]\n"
-#~ msgstr "uso %s file [prompt %%x %%y]\n"
+msgid "usage: %s file [prompt %%x %%y]\n"
+msgstr "uso %s file [prompt %%x %%y]\n"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Illegal file name for real part: %s"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
+msgid "Illegal group name <%s>"
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Nome file non valido [%s]."
+msgid "Illegal signature file name <%s>"
+msgstr "Nome file non valido [%s]."
-#~ msgid "visualization"
-#~ msgstr "visualizzazione"
+msgid "visualization"
+msgstr "visualizzazione"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "file raster per la Vista%d"
+msgid "Raster file(s) for Elevation"
+msgstr "file raster per la Vista%d"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Non riesco a descrivere la tabella"
+msgid "Can't clear current graphics window"
+msgstr "Non riesco a descrivere la tabella"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
-#~ msgid "Error reading raster map"
-#~ msgstr "Errore leggendo la mappa raster"
+msgid "Error reading raster map"
+msgstr "Errore leggendo la mappa raster"
 #, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "Mostra il titolo del file raster"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "Mostra il titolo del file raster"
 #, fuzzy
-#~ msgid "Error opening cell-file"
-#~ msgstr "Errore nell'apertura del file g3d"
+msgid "Error opening cell-file"
+msgstr "Errore nell'apertura del file g3d"
 #, fuzzy
-#~ msgid "Error reading from cell-file"
+msgid "Error reading from cell-file"
 #, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "Impossibile aprire <%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "Impossibile aprire <%s>"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Centrale: abilita colore flash\n"
+msgid " Middle: toggle flash color\n"
+msgstr " Centrale: abilita colore flash\n"
 #, fuzzy
-#~ msgid "No current graphics window"
+msgid "No current graphics window"
 #, fuzzy
-#~ msgid "Can't set current graphics window"
+msgid "Can't set current graphics window"
 #, fuzzy
-#~ msgid "Getting graphics window coordinates"
+msgid "Getting graphics window coordinates"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Nome di un nuovo file raster"
+msgid "Font name or pathname of TTF file"
+msgstr "Nome di un nuovo file raster"
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "Imposta la versione di FreeType\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+"Imposta la versione di FreeType\n"
-#~ msgid "Display number of colors"
-#~ msgstr "Mostra numero di colori"
+msgid "Display number of colors"
+msgstr "Mostra numero di colori"
 #, fuzzy
-#~ msgid "Name of frame(s) to save"
-#~ msgstr "Nome della mappa raster"
+msgid "Name of frame(s) to save"
+msgstr "Nome della mappa raster"
 #, fuzzy
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr ""
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr ""
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Percorso del carattere TrueType (nome del file incluso)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Percorso del carattere TrueType (nome del file incluso)"
 #, fuzzy
-#~ msgid "Either text or -c should be given"
-#~ msgstr "Devono essere fornite sia l'opzione 'from_table' che 'select' "
+msgid "Either text or -c should be given"
+msgstr "Devono essere fornite sia l'opzione 'from_table' che 'select' "
 #, fuzzy
-#~ msgid "Unable to write the temporary file"
-#~ msgstr "Valore da scrivere per null"
+msgid "Unable to write the temporary file"
+msgstr "Valore da scrivere per null"
 #, fuzzy
-#~ msgid "No predefined font"
-#~ msgstr "Nome del file con le regole predefinite"
+msgid "No predefined font"
+msgstr "Nome del file con le regole predefinite"
 #, fuzzy
-#~ msgid " Left:    Place text here\n"
+msgid " Left:    Place text here\n"
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Destro:  Esce\n"
+msgid " Right:   Quit\n"
+msgstr " Destro:  Esce\n"
 #, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "ERRORE: non riesco ad ottenere la \"lista\" degli oggetti\n"
+msgid "ERROR: can not get \"list\" items"
+msgstr "ERRORE: non riesco ad ottenere la \"lista\" degli oggetti\n"
 #, fuzzy
-#~ msgid "-j flag forced"
-#~ msgstr "-j flag forzato\n"
+msgid "-j flag forced"
+msgstr "-j flag forzato\n"
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
-#~ msgid "You must select more than one point"
-#~ msgstr "Devi selezionare più di un punto"
+msgid "You must select more than one point"
+msgstr "Devi selezionare più di un punto"
-#~ msgid "You must select at least four points"
-#~ msgstr "Devi selezionare almeno quattro punti"
+msgid "You must select at least four points"
+msgstr "Devi selezionare almeno quattro punti"
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "Nessuna mappa raster o vettoriale visualizzata"
+msgid "No raster or vector map displayed"
+msgstr "Nessuna mappa raster o vettoriale visualizzata"
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Nome del monitor grafico da avviare"
+msgid "Name of graphics monitor to start"
+msgstr "Nome del monitor grafico da avviare"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Nome del monitor grafico da chiudere"
+msgid "Name of graphics monitor to stop"
+msgstr "Nome del monitor grafico da chiudere"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Nome del monitor grafico da selezionare"
+msgid "Name of graphics monitor to select"
+msgstr "Nome del monitor grafico da selezionare"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Nome del monitor grafico da sbloccare"
+msgid "Name of graphics monitor to unlock"
+msgstr "Nome del monitor grafico da sbloccare"
-#~ msgid "List all monitors"
-#~ msgstr "Mostra di tutti i monitor"
+msgid "List all monitors"
+msgstr "Mostra di tutti i monitor"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Mostra tutti i monitor (con lo stato corrente)"
+msgid "List all monitors (with current status)"
+msgstr "Mostra tutti i monitor (con lo stato corrente)"
 #, fuzzy
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Utilizza la regione corrente"
+msgid "Print name of currently selected monitor"
+msgstr "Utilizza la regione corrente"
-#~ msgid "Monitor <%s> in use by another user"
-#~ msgstr "Monitor <%s> è in uso da un altro utente"
+msgid "Monitor <%s> in use by another user"
+msgstr "Monitor <%s> è in uso da un altro utente"
-#~ msgid "Monitor '%s' terminated"
-#~ msgstr "Monitor '%s' chiuso"
+msgid "Monitor '%s' terminated"
+msgstr "Monitor '%s' chiuso"
-#~ msgid "Error - Monitor '%s' was not running"
-#~ msgstr "Errore - Il monitor '%s' non è avviato"
+msgid "Error - Monitor '%s' was not running"
+msgstr "Errore - Il monitor '%s' non è avviato"
-#~ msgid "Error - Monitor '%s' in use by another user"
-#~ msgstr "Errore - Il monitor '%s' è in uso da un altro utente"
+msgid "Error - Monitor '%s' in use by another user"
+msgstr "Errore - Il monitor '%s' è in uso da un altro utente"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
+msgid "Error - Locking mechanism failed"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Errore nel leggere il range di [%s]"
+msgid "Error choosing frame [%s]\n"
+msgstr "Errore nel leggere il range di [%s]"
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Bottoni:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"Bottoni:\n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
+msgid "Left:   Select frame\n"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "%s Esce dal menu\n"
+msgid "Right:  Accept frame\n"
+msgstr "%s Esce dal menu\n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
-#~ msgstr ""
+msgid "Manages display frames on the user's graphics monitor."
+msgstr ""
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Estrae dati dal database."
+msgid "Select a frame"
+msgstr "Estrae dati dal database."
 #, fuzzy
-#~ msgid "Print name of current frame"
-#~ msgstr "Stampa la regione corrente"
+msgid "Print name of current frame"
+msgstr "Stampa la regione corrente"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "file vettoriale da creare"
+msgid "Frame to be created/selected"
+msgstr "file vettoriale da creare"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Bottoni:\n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"\n"
+"Bottoni:\n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
+msgid "Left:   Select From\n"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr " Destro: esce\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr " Destro: esce\n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitore: comandi interattivi per il ridisegnamento\n"
+msgid "Monitor: interactive command in redraw"
+msgstr "Monitore: comandi interattivi per il ridisegnamento\n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "trovate %d viste per il tipo TrueColor\n"
+msgid "found %d visuals of type TrueColor"
+msgstr "trovate %d viste per il tipo TrueColor\n"
 #, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "ricerca del valore massimo di bit depth\n"
+msgid "searching for highest bit depth"
+msgstr "ricerca del valore massimo di bit depth\n"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "bit depth %d selezionata\n"
+msgid "selected %d bit depth"
+msgstr "bit depth %d selezionata\n"
 #, fuzzy
-#~ msgid "using default visual which is %s"
-#~ msgstr "la vista predefinita utilizzata è %s\n"
+msgid "using default visual which is %s"
+msgstr "la vista predefinita utilizzata è %s\n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitor: waitpid: atteso %d ma ricevuto %d\n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Monitor: waitpid: atteso %d ma ricevuto %d\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitor: XGetWMName fallito\n"
+msgid "Monitor: XGetWMName failed"
+msgstr "Monitor: XGetWMName fallito\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitor: XGetWMName: risultato sbagliato\n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Monitor: XGetWMName: risultato sbagliato\n"
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "WARNING!  A projection file already exists for this location\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ATTENZIONE!  Un file della proiezione esiste già per questa location\n"
+msgid ""
+"\n"
+"\n"
+"WARNING!  A projection file already exists for this location\n"
+msgstr ""
+"\n"
+"\n"
+"ATTENZIONE!  Un file della proiezione esiste già per questa location\n"
-#~ msgid ""
-#~ "Would you still like to overwrite the current projection information "
-#~ msgstr "Vuoi ancora sovrascrivere le attuali informazioni sulla proiezione"
+msgid "Would you still like to overwrite the current projection information "
+msgstr "Vuoi ancora sovrascrivere le attuali informazioni sulla proiezione"
-#~ msgid "The projection information will not be updated."
-#~ msgstr "Le informazioni sulla proiezione non saranno aggiornate"
+msgid "The projection information will not be updated."
+msgstr "Le informazioni sulla proiezione non saranno aggiornate"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
+msgid "Raster map to zoom into"
-#~ msgid "Save the current region to region definition file"
-#~ msgstr ""
-#~ "Salva le impostazione della region corrente in un file di definizione "
-#~ "della region"
+msgid "Save the current region to region definition file"
+msgstr ""
+"Salva le impostazione della region corrente in un file di definizione della "
+"region"
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "<%s> è un nome di regione illegale"
+msgid "<%s> is an illegal region name"
+msgstr "<%s> è un nome di regione illegale"
 #, fuzzy
-#~ msgid "Erasing monitors ..."
-#~ msgstr "Sto disegnando ..."
+msgid "Erasing monitors ..."
+msgstr "Sto disegnando ..."
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not open input file <%s>."
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Unable to open file: <%s>"
 #, fuzzy
-#~ msgid "not found\n"
+msgid "not found\n"
 #, fuzzy
-#~ msgid "Raster map not found."
+msgid "Raster map not found."
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "It was not possible writing in <%s>."
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "Non riesco a leggere da <%s>"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "Non riesco a leggere da <%s>"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Nome del raster"
+msgid "Unknown query tool '%s'"
 #, fuzzy
-#~ msgid "No layer database connection"
+msgid "No layer database connection"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
+msgid "%d categories loaded from the database"
 #, fuzzy
-#~ msgid "Done"
+msgid "Done"
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "Cannot create layer"
+msgid "Cannot create layer"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "Impossibile trovare il vettoriale [%s]"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "Impossibile trovare il vettoriale [%s]"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Tipo di colonna non supportata"
+msgid "Column type [%d] not supported"
+msgstr "Tipo di colonna non supportata"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "Cannot read map header for <%s>"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "Impossibile salvare la region <%s>"
+msgid "Cannot read category file for <%s>"
+msgstr "Impossibile salvare la region <%s>"
-#~ msgid "Print;Shell Script"
-#~ msgstr "Stampa; script per la shell"
+msgid "Print;Shell Script"
+msgstr "Stampa; script per la shell"
-#~ msgid "Category file for [%s] not available"
+msgid "Category file for [%s] not available"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
+msgid "%s: <%s> raster map not found"
 #, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
+msgid "%s: <%s> raster map exists already"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
 #, fuzzy
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
+msgid "%s: Cannot open [%s]"
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
 #, fuzzy
-#~ msgid "Could not access %s layer"
+msgid "Could not access %s layer"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Mappa raster che contiene i valori delle altezze"
+msgid "Raster map containing elevation data"
+msgstr "Mappa raster che contiene i valori delle altezze"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Mappa raster con il nome dei risultati archiviati"
+msgid "Raster map name for storing results"
+msgstr "Mappa raster con il nome dei risultati archiviati"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Altezza della locazione visualizzata"
+msgid "Height of the viewing location"
+msgstr "Altezza della locazione visualizzata"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
+msgid "elevation file [%s] not found"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr "%s ha dato un numero non valido di sites [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "%s ha dato un numero non valido di sites [%d]"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
-#~ msgstr "Non riesco ad aprire il database %s col driver %s"
+msgid "Unable to open database %s by driver %s"
+msgstr "Non riesco ad aprire il database %s col driver %s"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nessuna impostazione definita per il database. Fallo usando db.connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr "Nessuna impostazione definita per il database. Fallo usando db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Non riesco a trovare l'input %s"
+msgid "Could not find input %s"
+msgstr "Non riesco a trovare l'input %s"
-#~ msgid "Could not open input"
-#~ msgstr "Non riesco ad aprire l'input"
+msgid "Could not open input"
+msgstr "Non riesco ad aprire l'input"
-#~ msgid "Could not open output"
-#~ msgstr "Non riesco ad aprire l'output"
+msgid "Could not open output"
+msgstr "Non riesco ad aprire l'output"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
-#~ msgid "Database connection not defined\n"
-#~ msgstr "Connessione al database non definita\n"
+msgid "Database connection not defined\n"
+msgstr "Connessione al database non definita\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "Impossibile leggere l'intestazione del raster 3D <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s in %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s in %s: %s"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
+msgid "Can't write region <%s>"
-#~ msgid "<%s=%s> ** invalid input **"
-#~ msgstr "<%s=%s> ** input non valido **"
+msgid "<%s=%s> ** invalid input **"
+msgstr "<%s=%s> ** input non valido **"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Nessun device grafico selezionato"
+msgid "No graphics device selected."
+msgstr "Nessun device grafico selezionato"
 #, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Unable to read raster row."
 #, fuzzy
-#~ msgid "Training map [%s] not found."
+msgid "Training map [%s] not found."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
-#~ msgid "input raster map"
+msgid "input raster map"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "Illegal file name: %s"
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "Impossibile ottenere informazioni sul layer vettoriale"
+msgid "Cannot get layer info for vector map"
+msgstr "Impossibile ottenere informazioni sul layer vettoriale"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr "Non riesco ad aprire il cellfile [%s]"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr "Non riesco ad aprire il cellfile [%s]"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
+msgid "%s: %s - raster map not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "%s: %s - illegal name"
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "%s: ERROR reading category file for %s"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "%s: %s - illegal units"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
+msgid "Reading input map (%s)    ... "
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "%s - ERROR reading %s"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
 #, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Reading raster map... "
 #, fuzzy
-#~ msgid "Writing raster map... "
+msgid "Writing raster map... "
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Categoria lista: es. 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Categoria lista: es. 1,3-8,13"
-#~ msgid "Output separator character (default: tab)"
+msgid "Output separator character (default: tab)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
 #, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot find file %s"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
+msgid "Cannot create vector map %s"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
+msgid "Number of raster rows to hold in memory"
 #, fuzzy
-#~ msgid "Print raster map title only"
-#~ msgstr "Stampa solo il tipo di mappa raster"
+msgid "Print raster map title only"
+msgstr "Stampa solo il tipo di mappa raster"
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "Tipo sconosciuto"
+msgid "unknown type: %d"
+msgstr "Tipo sconosciuto"
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Cannot read GRASS raster."
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Couldn't set geo transform."
 #, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "Couldn't set projection."
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
 #, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "Nome della mappa di output"
+msgid "Cannot open output map."
+msgstr "Nome della mappa di output"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
+msgid "memory allocation failure"
 #, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "Non riesco a mostrare i database"
+msgid "Can't find data map."
+msgstr "Non riesco a mostrare i database"
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "Nome del database in output"
+msgid "Output terrain only vector map name"
+msgstr "Nome della tabella in output"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
-#~ msgid "No record for cat = %d"
-#~ msgstr "Nessun record per la cat = %d"
+msgid "No record for cat = %d"
+msgstr "Nessun record per la cat = %d"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
+msgid "Attaching islands ..."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
+msgid "Vector map <%s> not found in current mapset"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
+msgid "Error allocating memory for `lines_visited'"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "Nome di  2-%d mappe raster in input"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "Nome di  2-%d mappe raster in input"
 #, fuzzy
-#~ msgid "The number of polylines in the output vector map is [%d]"
+msgid "The number of polylines in the output vector map is [%d]"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
+msgid "Database connection not defined for layer <%d>"
 #, fuzzy
-#~ msgid "Cannot open select cursor"
+msgid "Cannot open select cursor"
 #, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "Cannot get layer info"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "Impossibile creare l'indice"
+msgid "Cannot rewrite line %d"
+msgstr "Impossibile creare l'indice"
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Esistente"
+msgid "Editing tool"
+msgstr "Esistente"
 #, fuzzy
-#~ msgid "Close boundaries"
-#~ msgstr "Non riesco a copiare la tabella"
+msgid "Close boundaries"
+msgstr "Non riesco a copiare la tabella"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "%d categorie duplicate nel vettoriale"
+msgid "%d lines modified"
+msgstr "%d categorie duplicate nel vettoriale"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
 #, fuzzy
-#~ msgid "Print vector map region only"
+msgid "Print vector map region only"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
+msgid "Cannot get layer info for vector map <%s>"
 #, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Cannot select attribute."
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
+msgid "Could not find vector map <%s> in current mapset"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
+msgid "Parameter <%s> not set"
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
+msgid "Output map where segments will be written"
+msgstr "Mappa in uscita già esistente. Sarà sovrascritta!\n"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
-#~ msgstr "Nessun record nel database per la categoria %d"
+msgid "Database record for cat %d not found"
+msgstr "Nessun record nel database per la categoria %d"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
 #, fuzzy
-#~ msgid "Can't read raster"
+msgid "Can't read raster"
-#~ msgid "driver name"
-#~ msgstr "nome driver"
+msgid "driver name"
+msgstr "nome driver"
-#~ msgid "database name"
-#~ msgstr "nome database"
+msgid "database name"
+msgstr "nome database"
 #, fuzzy
-#~ msgid "Driver name"
+msgid "Driver name"
-#~ msgid "Cannot list databases."
+msgid "Cannot list databases."
-#~ msgid "database location"
+msgid "database location"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Nome tabella, seleziona tutto da questa tabella"
+msgid "Table name, select all from this table"
+msgstr "Nome tabella, seleziona tutto da questa tabella"
-#~ msgid "output field separator"
-#~ msgstr "campo separatore in output"
+msgid "output field separator"
+msgstr "campo separatore in output"
-#~ msgid "output vertical record separator"
-#~ msgstr "output verticale del separatore di record "
+msgid "output vertical record separator"
+msgstr "output verticale del separatore di record "
-#~ msgid "null value indicator"
-#~ msgstr "indicatore di valore nullo"
+msgid "null value indicator"
+msgstr "indicatore di valore nullo"
-#~ msgid "do not include column names in output"
-#~ msgstr "non includere i nomi delle colonne nell'output"
+msgid "do not include column names in output"
+msgstr "non includere i nomi delle colonne nell'output"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "output verticale (invece che orizzontale)"
+msgid "vertical output (instead of horizontal)"
+msgstr "output verticale (invece che orizzontale)"
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_it.po (grassmods_it)  #-#-#-#-#\n"
-#~ "Nome di un file raster esistente\n"
-#~ "Nome di una mappa raster esistente"
+msgid "Name of existing raster map"
+msgstr ""
+"#-#-#-#-#  grassmods_it.po (grassmods_it)  #-#-#-#-#\n"
+"Nome di un file raster esistente\n"
+"Nome di una mappa raster esistente"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "Cannot find mapset for %s"
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgid "Table to be imported"
-#~ msgstr "Il file raster da importare"
+msgid "Table to be imported"
+msgstr "Il file raster da importare"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
-#~ msgstr "Nome della mappa raster risultante"
+msgid "Unable to create raster map [%s]"
+msgstr "Nome della mappa raster risultante"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
+msgid "Input file [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr ""
+msgid "No db connection for driver <%s> defined. Run db.connect."
 #, fuzzy
-#~ msgid "Table name"
-#~ msgstr "nome tabella"
+msgid "Table name"
+msgstr "nome tabella"
-#~ msgid ""
-#~ "Print current map connection parameters and exit (shell script style)\n"
-#~ "\tformat:  layer[/layer name] table key database driver"
-#~ msgstr ""
-#~ "Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
+msgid ""
+"Print current map connection parameters and exit (shell script style)\n"
+"\tformat:  layer[/layer name] table key database driver"
+msgstr ""
+"Stampa i parametri di connessione correnti ed esce (stile shell script)\n"
 #, fuzzy
-#~ msgid "x column name"
+msgid "x column name"
 #, fuzzy
-#~ msgid "z column name"
+msgid "z column name"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
-#~ msgstr "Non riesco a selezionare dati dalla tabella"
+msgid "Cannot fetch data from table"
+msgstr "Non riesco a selezionare dati dalla tabella"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
+msgid "Querying input '%s' ... "
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
+msgid "Copying %s input lines ... "
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
+msgid "Cannot find line of cat %d"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
+msgid "Transforms a vector map via a set of tie points."
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Non riesco ad eseguire il driver '%s'"
+msgid "Cannot start driver '%s'."
+msgstr "Non riesco ad eseguire il driver '%s'"
-#~ msgid "Cannot describe table"
+msgid "Cannot describe table"
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Non riesco ad eseguire il driver <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "Non riesco ad eseguire il driver <%s>."
-#~ msgid "[%s] is an illegal name"
-#~ msgstr "[%s] è un nome illegale"
+msgid "[%s] is an illegal name"
+msgstr "[%s] è un nome illegale"
-#~ msgid "Cannot write to <%s>"
-#~ msgstr "Non riesco a scrivere su <%s>"
+msgid "Cannot write to <%s>"
+msgstr "Non riesco a scrivere su <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
+msgid "Raster file [%s] not available"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
-#~ msgid "Vector file [%s] not available"
+msgid "Vector file [%s] not available"
 #, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Cannot open driver %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
-#~ msgid "Out of Memory!\n"
-#~ msgstr "Memoria esaurita!\n"
+msgid "Out of Memory!\n"
+msgstr "Memoria esaurita!\n"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Open raster map %s in %s = %d"
 #, fuzzy
-#~ msgid "Closing raster map"
+msgid "Closing raster map"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
-#~ msgid "Name of the new raster map"
+msgid "Name of the new raster map"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "Impossibile aprire il file label <%s> nel mapset <%s>"
-#~ msgid "Raster input map"
+msgid "Raster input map"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "Checking location %s, mapset %s:"
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
 #, fuzzy
-#~ msgid "Error writing output map"
+msgid "Error writing output map"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "Nessuna mappa in input specificata"
+msgid "no rules specified"
+msgstr "Nessuna mappa in input specificata"
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Can't open temp file [%s]"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "%s in %s -can't open raster map"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
 #, fuzzy
-#~ msgid "Normalized"
-#~ msgstr "Normalizzata"
+msgid "Normalized"
+msgstr "Normalizzata"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
+msgid "Requested 3d raster map not found <%s>"
 #, fuzzy
-#~ msgid "Could not open elevation map"
+msgid "Could not open elevation map"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "unable to close output map"
+msgid "unable to close output map"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "Database's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
+msgid "Cannot open vector points map <%s>"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
-#~ msgstr ""
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Could not find input map <%s> in current mapset."
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
+msgid "Could not find input vector map %s"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
-#~ msgstr "Nome di mappa(e) raster esistente(i)"
+msgid "error opening raster map [%s]."
+msgstr "Nome di mappa(e) raster esistente(i)"
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "Patching file <%s@%s>"
 #, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "%d records aggiornati"
+msgid "[%d] files patched"
+msgstr "%d records aggiornati"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
+msgid "Could not open vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer <%d>. Use v.db.connect first."
+msgid "Database connection not defined for layer <%d>. Use v.db.connect first."
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
 #, fuzzy
-#~ msgid "Could not close new 3d raster map"
+msgid "Could not close new 3d raster map"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "Unable to open the temporary file."
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
+msgid "name for new raster map"
 #, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Output GRASS image file"
 #, fuzzy
-#~ msgid "Resulting output map"
+msgid "Resulting output map"
 #, fuzzy
-#~ msgid "name for new vector map"
+msgid "name for new vector map"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
-#~ msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "Nome del nuovo file PPM. (use out=- per lo standard output)"
 #, fuzzy
-#~ msgid "Input vector map"
+msgid "Input vector map"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid "%s: ERROR can't open tempfile"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
+msgid "<%s> raster map not found"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
+msgid "Can't get row %d from raster map %s"
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
-#~ msgid "string representing no data cell value"
-#~ msgstr "strighe che rappresentano le celle prive di valori"
+msgid "string representing no data cell value"
+msgstr "strighe che rappresentano le celle prive di valori"
-#~ msgid "File name of classification result"
-#~ msgstr "Nome del file con il risultato della classificazione"
+msgid "File name of classification result"
+msgstr "Nome del file con il risultato della classificazione"
-#~ msgid "quiet"
-#~ msgstr "silenzioso"
+msgid "quiet"
+msgstr "silenzioso"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
-#~ msgstr "Nome del file di output"
+msgid "<%s> - illegal output file name"
+msgstr "Nome del file di output"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
-#~ msgid "Base raster map"
-#~ msgstr "Mappa raster di base"
+msgid "Base raster map"
+msgstr "Mappa raster di base"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
-#~ msgstr "impossibile aprire <%s>"
+msgid "Problem opening output file [%s]"
+msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
 #, fuzzy
-#~ msgid "Output verbosely"
+msgid "Output verbosely"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Input vector map <%s> not found."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
 #, fuzzy
-#~ msgid "List available formats and exit"
-#~ msgstr "Visualizza i formati supportati ed esci"
+msgid "List available formats and exit"
+msgstr "Visualizza i formati supportati ed esci"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "File di input"
+msgid "SVG output file"
+msgstr "File di input"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
+msgid "Could not find vector '%s'"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
+msgid "Could not find vector map %s"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
 #, fuzzy
-#~ msgid "No input coordinates provided"
+msgid "No input coordinates provided"
-#~ msgid "Raster output file"
-#~ msgstr "File raster in output"
+msgid "Raster output file"
+msgstr "File raster in output"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "Mantieni la tabella colore esistente"
+msgid "Keep existing color table"
+msgstr "Mantieni la tabella colore esistente"
-#~ msgid "List rules"
-#~ msgstr "Mostra regole"
+msgid "List rules"
+msgstr "Mostra regole"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d raster%s, %d vettoriale%s\n"
+msgid " %d rows, %d cols."
+msgstr "%d raster%s, %d vettoriale%s\n"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
+msgid "Vector map with points for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr ""
-#~ "Nome della mappa vettoriale di punti della quale editare la tabella "
-#~ "attributi"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr ""
+"Nome della mappa vettoriale di punti della quale editare la tabella attributi"
 #, fuzzy
-#~ msgid "Path to an output file"
-#~ msgstr "Nome del file in output"
+msgid "Path to an output file"
+msgstr "Nome del file in output"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Nome di una mappa raster esistente"
+msgid "Name of existing raster map to be displayed"
+msgstr "Nome di una mappa raster esistente"
-#~ msgid "driver name:"
-#~ msgstr "nome del driver:"
+msgid "driver name:"
+msgstr "nome del driver:"
-#~ msgid "Database name:"
-#~ msgstr "Nome del database:"
+msgid "Database name:"
+msgstr "Nome del database:"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
-#~ msgstr "driver pg: colonna '%s', di tipo %d non supportata"
+msgid "column type not supported"
+msgstr "driver pg: colonna '%s', di tipo %d non supportata"
 #, fuzzy
-#~ msgid "cannot select data from table"
+msgid "cannot select data from table"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "cannot grant privileges on table %s"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
+msgid "Cannot find vector map"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
 #, fuzzy
-#~ msgid "Error while writing new cell map."
-#~ msgstr "Errore nella scrittura della grid. Disco pieno?"
+msgid "Error while writing new cell map."
+msgstr "Errore nella scrittura della grid. Disco pieno?"
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "Non riesco a trovare il file raster %s"
+msgid "Error in opening input file <%s>"
+msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "Unable to open cell man <%s> for input.\n"
+msgid "Unable to open cell man <%s> for input.\n"
 #, fuzzy
-#~ msgid "Unable to open cell map <%s> for output.\n"
+msgid "Unable to open cell map <%s> for output.\n"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "Unable to read map raster row %d"
+msgstr "Nome del raster"
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
+msgid "Unable to write color table to raster [%s]"
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
-#~ msgid "Name of predefined rules file"
+msgid "Name of predefined rules file"
 #, fuzzy
-#~ msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%"
-#~ "d:%d **\n"
+msgid "R:G:B value(s) out of range [0..255]: %d:%d:%d"
+msgstr ""
+"** attenzione: valore(i) R:G:B al di fuori dell'intervallo [0..255]: %d:%d:%"
+"d **\n"
 #, fuzzy
-#~ msgid "R G B value(s) out of range [0..255]: %d %d %d"
-#~ msgstr ""
-#~ "** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %"
-#~ "d %d **\n"
+msgid "R G B value(s) out of range [0..255]: %d %d %d"
+msgstr ""
+"** attenzione: valore(i) R G B al di fuori dell'intervallo [0..255]: %d %d %"
+"d **\n"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "** attenzione: non trovo il valore **\n"
+msgid "no such value"
+msgstr "** attenzione: non trovo il valore **\n"
 #, fuzzy
-#~ msgid "%s:line %d:%s"
-#~ msgstr "%s:linea %d:%s\n"
+msgid "%s:line %d:%s"
+msgstr "%s:linea %d:%s\n"
 #, fuzzy
-#~ msgid "bad color specification"
-#~ msgstr "** definizione errata del colore **\n"
+msgid "bad color specification"
+msgstr "** definizione errata del colore **\n"
 #, fuzzy
-#~ msgid "%s - unknown color"
-#~ msgstr "%s - colore sconosciuto\n"
+msgid "%s - unknown color"
+msgstr "%s - colore sconosciuto\n"
-#~ msgid "Valid colors are:\n"
-#~ msgstr "I colori validi sono:\n"
+msgid "Valid colors are:\n"
+msgstr "I colori validi sono:\n"
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
-#~ msgstr "Errore nella lettura del file dbmscap\n"
+msgid "%s: reading category file for %s"
+msgstr "Errore nella lettura del file dbmscap\n"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "%s: unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
 #, fuzzy
-#~ msgid "Unable to find [%s]."
+msgid "Unable to find [%s]."
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Could not open raster <%s>"
-#~ msgid ""
-#~ "Font name (not supported interactively, see also -l flag) or path to "
-#~ "TrueType font (including file name)"
-#~ msgstr ""
-#~ "Nome del tipo carattere (non supportato in maniera interattiva, in tal "
-#~ "caso vedi il flag -l) oppure percorso del font TrueType (completo del "
-#~ "nome del file)"
+msgid ""
+"Font name (not supported interactively, see also -l flag) or path to "
+"TrueType font (including file name)"
+msgstr ""
+"Nome del tipo carattere (non supportato in maniera interattiva, in tal caso "
+"vedi il flag -l) oppure percorso del font TrueType (completo del nome del "
+"file)"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
-#~ msgstr "raster <%s> non trovato"
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
+msgid "No record for category for [%d]"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "Error reading ASCII file <%s>"
 #, fuzzy
-#~ msgid "Error reading categories: <%s>"
+msgid "Error reading categories: <%s>"
 #, fuzzy
-#~ msgid "category [%d]"
-#~ msgstr ""
-#~ "Layer: %d\n"
-#~ "categoria: %d\n"
+msgid "category [%d]"
+msgstr ""
+"Layer: %d\n"
+"categoria: %d\n"
 #, fuzzy
-#~ msgid "No lines found"
-#~ msgstr "Non ho trovato nulla.\n"
+msgid "No lines found"
+msgstr "Non ho trovato nulla.\n"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
+msgid "Could not find input vector '%s'"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Failed opening output vector map '%s'"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
+msgid "%s: <%s> vector map not found"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
+msgid "Vector <%s> could not be open"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Raster <%s> could not be open."
 #, fuzzy
-#~ msgid "Interpolation()"
+msgid "Interpolation()"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
+msgid "Interpolation: nsply = %d"
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
+msgid "Interpolation was a success!"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
+msgid "CrossCorrelation: %d points read in region. "
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "%s -- illegal output file name"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Sorry, with method '%s' you have to define an output map."
 #, fuzzy
-#~ msgid "Writing "
+msgid "Writing "
 #, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "Numero di passi attraverso il dataset"
+msgid "Maximum number of iteration"
+msgstr "Numero di passi attraverso il dataset"
 #, fuzzy
-#~ msgid "Existing raster map name"
-#~ msgstr "Nome del raster map esistente"
+msgid "Existing raster map name"
+msgstr "Nome del raster map esistente"
 #, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "%s - can't read raster cellhd"
 #, fuzzy
-#~ msgid "error reading cell data"
+msgid "error reading cell data"
 #, fuzzy
-#~ msgid "Done!"
-#~ msgstr "Fatto.\n"
+msgid "Done!"
+msgstr "Fatto.\n"
 #, fuzzy
-#~ msgid "No line found."
+msgid "No line found."
 #, fuzzy
-#~ msgid "Nothing Found."
+msgid "Nothing Found."
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Could not open ascii file [%s]"
-#~ msgid "vector map to be created"
+msgid "vector map to be created"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "Mappa raster risultante"
+msgid "Conversion of [%s] to vector map ..."
+msgstr "Mappa raster risultante"
 #, fuzzy
-#~ msgid "EPSG code of projection to be created"
+msgid "EPSG code of projection to be created"
-#~ msgid "must be even number of names"
-#~ msgstr "deve essere un numero pari di nomi"
+msgid "must be even number of names"
+msgstr "deve essere un numero pari di nomi"
-#~ msgid "ERROR: <%s> not found\n"
-#~ msgstr "ERRORE: <%s> non trovato\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "ERRORE: <%s> non trovato\n"
-#~ msgid "ERROR: <%s> illegal name\n"
-#~ msgstr "ERRORE: <%s> nome illegale\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "ERRORE: <%s> nome illegale\n"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
-#~ msgstr "Non riesco ad impostare user/password"
+msgid "Cannot open toolbox: %s"
+msgstr "Non riesco ad impostare user/password"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "Cannot open toolbox."
 #, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
+msgid "Vector map(s) -- source for composite"
 #, fuzzy
-#~ msgid "New vector composite"
-#~ msgstr "Nome di un file vettoriale in output"
+msgid "New vector composite"
+msgstr "Nome di un file vettoriale in output"
 #, fuzzy
-#~ msgid ""
-#~ "Name of output vector points map (if not specified, the program writes to "
-#~ "standard output)"
-#~ msgstr ""
-#~ "attributi"
+msgid ""
+"Name of output vector points map (if not specified, the program writes to "
+"standard output)"
+msgstr ""
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
+msgid "Vector map '%s' not found"
 #, fuzzy
-#~ msgid "vector, segment, curvature"
-#~ msgstr "vettore da rimuovere"
+msgid "vector, segment, curvature"
+msgstr "vettore da rimuovere"
 #, fuzzy
-#~ msgid "More lines with category %d found"
+msgid "More lines with category %d found"
 #, fuzzy
-#~ msgid "%s\n"
-#~ msgstr "%s Sposta\n"
+msgid "%s\n"
+msgstr "%s Sposta\n"
 #, fuzzy
-#~ msgid "Raster '%s' not found"
+msgid "Raster '%s' not found"
 #, fuzzy
-#~ msgid "Cold not get raster row"
+msgid "Cold not get raster row"
 #, fuzzy
-#~ msgid "ILLEGAL Resolution!"
-#~ msgstr "Risoluzione"
+msgid "ILLEGAL Resolution!"
+msgstr "Risoluzione"
 #, fuzzy
-#~ msgid "Error opening raster map %s"
+msgid "Error opening raster map %s"
 #, fuzzy
-#~ msgid "Copy raster map <%s> into the memory"
+msgid "Copy raster map <%s> into the memory"
 #, fuzzy
-#~ msgid "vector map for which to edit attribute table"
+msgid "vector map for which to edit attribute table"
 #, fuzzy
-#~ msgid "Query layer"
+msgid "Query layer"
 #, fuzzy
-#~ msgid "Column name (will be updated by qvector values)"
-#~ msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
+msgid "Column name (will be updated by qvector values)"
+msgstr "Nome della colonna (che sarà aggiornata con i valori raster)"
 #, fuzzy
-#~ msgid "Query column name"
+msgid "Query column name"
 #, fuzzy
-#~ msgid "Enter imagery group to be registered"
+msgid "Enter imagery group to be registered"
 #, fuzzy
-#~ msgid "output layer name"
+msgid "output layer name"
-#~ msgid "L: from  M: to R: quit\n"
-#~ msgstr "L: da  M: a R: esci\n"
+msgid "L: from  M: to R: quit\n"
+msgstr "L: da  M: a R: esci\n"
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "Dove %s è uno di:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"Dove %s è uno di:\n"
 #, fuzzy
-#~ msgid "%s: - no such database %s\n"
-#~ msgstr "Non posso scrivere i collegamenti del database"
+msgid "%s: - no such database %s\n"
+msgstr "Non posso scrivere i collegamenti del database"
 #, fuzzy
-#~ msgid "No database updates."
+msgid "No database updates."
 #, fuzzy
-#~ msgid "Input aspect file"
-#~ msgstr "Nome della tabella in output"
+msgid "Input aspect file"
 #, fuzzy
-#~ msgid "Input barrier file"
+msgid "Input barrier file"
 #, fuzzy
-#~ msgid "Quiet operation"
+msgid "Quiet operation"
 #, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "nessuno"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "nessuno"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Done\n"
-#~ msgstr "Fatto\n"
+msgid ""
+"\n"
+"Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
 #, fuzzy
-#~ msgid "Vector import complete"
+msgid "Vector import complete"
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
-#~ msgstr "Non riesco ad aprire il cellfile per [%s]"
+msgid "Unable to create raster map for [%s]"
+msgstr "Non riesco ad aprire il cellfile per [%s]"
-#~ msgid "Done\n"
+msgid "Done\n"
+msgstr "Fatto\n"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
+msgid "Open Raster file %s in Mapset %s"
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "Open 3d raster map %s\n"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
+msgid "Open elev raster map %s\n"
 #, fuzzy
-#~ msgid "Could not open map %s\n"
+msgid "Could not open map %s\n"
-#~ msgid "Bin raster map to be imported"
-#~ msgstr "Il file raster bin è stato importato"
+msgid "Bin raster map to be imported"
+msgstr "Il file raster bin è stato importato"
-#~ msgid "Region size is lower than minreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è inferiore rispetto al valore di minreg, non "
-#~ "verrà visualizzato nulla.\n"
+msgid "Region size is lower than minreg, nothing displayed.\n"
+msgstr ""
+"La dimensione della regione è inferiore rispetto al valore di minreg, non "
+"verrà visualizzato nulla.\n"
-#~ msgid "Region size is greater than maxreg, nothing displayed.\n"
-#~ msgstr ""
-#~ "La dimensione della regione è superiore rispetto al valore di maxreg, non "
+msgid "Region size is greater than maxreg, nothing displayed.\n"
+msgstr ""
+"La dimensione della regione è superiore rispetto al valore di maxreg, non "
 #, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "Livello massimo di contorno"
+msgid "Maximum distance"
+msgstr "Livello massimo di contorno"
 #, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
+msgid "Makes 3D trees from input point vector map"
 #, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "Nome del file raster in input"
+msgid "Name of the column with tree crown width"
+msgstr "Nome del file raster in input"
 #, fuzzy
-#~ msgid "Name of the column with tree species"
+msgid "Name of the column with tree species"
 #, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
+msgid "Cannot select attributes for point #%d"
 #, fuzzy
-#~ msgid "Right: "
+msgid "Right: "
-#~ msgid "%s Pan\n"
+msgid "%s Pan\n"
-#~ msgid "%s Quit\n"
-#~ msgstr "%s Esce\n"
+msgid "%s Quit\n"
+msgstr "%s Esce\n"
-#~ msgid "Draw geographic grid"
-#~ msgstr "Disegna griglia geografica"
+msgid "Draw geographic grid"
+msgstr "Disegna griglia geografica"
 #, fuzzy
-#~ msgid "Quiet mode"
+msgid "Quiet mode"
 #, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
+msgid "%s[%d]: No raster map specified."
+#, fuzzy
+msgid "done."
+msgstr "Fatto.\n"
+#, fuzzy
+msgid "name for new binary vector map (omit for display to stdout)"
+#, fuzzy
+msgid "Name for G3d raster map"
+#, fuzzy
+msgid "No output maps"
+#, fuzzy
+msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
+msgstr ""
+"Valori della mappa g3d errati! I valori devono essere compresi tra 0 e 255!\n"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "Nome di un file vettoriale in output"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "File di input"
+#, fuzzy
+#~ msgid "Data type"
+#~ msgstr "Tipo di grafico"
+#, fuzzy
+#~ msgid "slopein raster map <%s> not found"
 #, fuzzy
-#~ msgid "done."
+#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+#~ msgstr "Non riesco a trovare il file raster %s"
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+#~ msgid "Base raster map <%s> not found"
+#~ msgstr "raster <%s> non trovato"
 #, fuzzy
-#~ msgid "Name for G3d raster map"
+#~ msgid "Color table for <%s> updated"
+#~ msgstr "impossibile aprire <%s>"
 #, fuzzy
-#~ msgid "No output maps"
+#~ msgid "Error reading raster map [%s]."
 #, fuzzy
-#~ msgid "Wrong rgb map values! Values should in between 0 and 255!\n"
-#~ msgstr ""
-#~ "Valori della mappa g3d errati! I valori devono essere compresi tra 0 e "
-#~ "255!\n"
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "Nome del database in output"
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "Area: %d  Numero di isole: %d\n"
+#~ msgid "Name of the input raster map"
+#~ msgstr "Nome del file raster in input"
Modified: grass/trunk/locale/po/grassmods_ja.po
--- grass/trunk/locale/po/grassmods_ja.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_ja.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -12082,8 +12082,9 @@
 msgstr "入力するファイル"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
+msgstr "入力するファイル"
 #: ../raster/r.uslek/main.c:66
 #, fuzzy
@@ -17650,8 +17651,9 @@
 msgstr "分解能を合わせるラスターマップ"
 #: ../raster/r.mapcalc/main.c:119
+#, fuzzy
 msgid "Expression to evaluate"
-msgstr ""
+msgstr "対象マップ"
 #: ../raster/r.mapcalc/main.c:123
 #, fuzzy
@@ -17659,8 +17661,9 @@
 msgstr "推論規則ファイル"
 #: ../raster/r.mapcalc/main.c:148
+#, fuzzy
 msgid "parse error"
-msgstr ""
+msgstr "セパレーション"
 #: ../raster/r.mapcalc/main.c:157
 msgid "Floating point error(s) occured in the calculation"
@@ -26399,8 +26402,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "ベクトルマップ"
 #: ../vector/v.net.steiner/main.c:447
 #, fuzzy
@@ -27555,8 +27559,9 @@
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
+#, fuzzy
 msgid "Position"
-msgstr ""
+msgstr "出力するファイル"
 #: ../visualization/nviz2/cmd/args.c:301
 #, fuzzy
@@ -27728,7 +27733,7 @@
 #: ../visualization/nviz2/cmd/vector.c:181
 #, fuzzy
 msgid "Unknown icon marker"
-msgstr "画像グループ"
+msgstr "出力するファイル"
 #: ../visualization/nviz2/cmd/volume.c:74
 #, fuzzy, c-format
@@ -27752,4477 +27757,4516 @@
 msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Illegal output file name"
-#~ msgstr "出力するファイル"
+msgid "Illegal output file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Display manager for GRASS"
-#~ msgstr "初期のクラスター数"
+msgid "Display manager for GRASS"
+msgstr "初期のクラスター数"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
+msgid "Name of .dmrc settings file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "ポイントマーカーを表示します"
+msgid "Width in pixels of new display monitor"
+msgstr "ポイントマーカーを表示します"
 #, fuzzy
-#~ msgid "Height in pixels of new display monitor"
+msgid "Height in pixels of new display monitor"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "選択しているモニター上でフレーム(四角形)の作成/管理を行います"
+msgid "Moves displayed maps to another monitor"
+msgstr "選択しているモニター上でフレーム(四角形)の作成/管理を行います"
 #, fuzzy
-#~ msgid "display, export, GPS"
-#~ msgstr "ガンマ"
+msgid "display, export, GPS"
+msgstr "ガンマ"
 #, fuzzy
-#~ msgid "Saves active display monitor to PNG file in home directory"
-#~ msgstr "テキストラベルの作成と表示を行います"
+msgid "Saves active display monitor to PNG file in home directory"
+msgstr "テキストラベルの作成と表示を行います"
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
+msgid "Saves the contents of the active display monitor to a graphics file."
 #, fuzzy
-#~ msgid "Compression for PNG files"
-#~ msgstr "入力するファイル"
+msgid "Compression for PNG files"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Paper size for PostScript output"
+msgid "Paper size for PostScript output"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "PostScript"
+msgid "PostScript"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "背景の色"
+msgid "Set transparent background"
+msgstr "背景の色"
 #, fuzzy
-#~ msgid "Displays a raster map and its legend on a graphics window"
-#~ msgstr "ラスターマップの凡例を表示します"
+msgid "Displays a raster map and its legend on a graphics window"
+msgstr "ラスターマップの凡例を表示します"
 #, fuzzy
-#~ msgid "omit entries with missing label"
-#~ msgstr "ラベルのないカテゴリーのスキップ"
+msgid "omit entries with missing label"
+msgstr "ラベルのないカテゴリーのスキップ"
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "フィルタをかける回数"
+msgid "Number of lines to appear in the legend"
+msgstr "フィルタをかける回数"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "モニターに表示されているマップ"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "モニターに表示されているマップ"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "フレームの作成"
+msgid "Redraw all frames"
+msgstr "フレームの作成"
 #, fuzzy
-#~ msgid "Resizes active display monitor"
+msgid "Resizes active display monitor"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "���"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "���"
 #, fuzzy
-#~ msgid "display, slideshow"
-#~ msgstr "ガンマ"
+msgid "display, slideshow"
+msgstr "ガンマ"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
-#~ msgstr "���."
+msgid "Show vector maps rather than raster maps"
+msgstr "���."
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
-#~ msgstr "流線間のセル数"
+msgid "Number of seconds to pause between slides"
+msgstr "流線間のセル数"
 #, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
-#~ msgstr "対象マップ"
+msgid "Enter raster map to display in 1st frame"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
-#~ msgstr "対象マップ"
+msgid "Enter command to execute in 1st frame"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
-#~ msgstr "対象マップ"
+msgid "Enter raster map to display in 2nd frame"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
-#~ msgstr "対象マップ"
+msgid "Enter command to execute in 2nd frame"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Displays thematic vectormap"
+msgid "Displays thematic vectormap"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "display, legend"
-#~ msgstr "凡例の反転"
+msgid "display, legend"
+msgstr "凡例の反転"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
-#~ msgstr "対象マップ"
+msgid "Vector map to display thematically"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Vector map type"
+msgid "Vector map type"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Attribute column to use for thematic display (must be numeric)"
-#~ msgstr "ラベルの属性"
+msgid "Attribute column to use for thematic display (must be numeric)"
+msgstr "ラベルの属性"
 #, fuzzy
-#~ msgid "Type of thematic display"
-#~ msgstr "タイトル"
+msgid "Type of thematic display"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Layer to use for thematic display"
-#~ msgstr "タイトル"
+msgid "Layer to use for thematic display"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "フォント"
+msgid "Points"
+msgstr "フォント"
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
+msgid "Number of classes for interval theme (integer)"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "対象マップセット(デフォルト=現在のマップセット)"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "対象マップセット(デフォルト=現在のマップセット)"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "区切り(デフォルト:タブ)"
+msgid "Output separator (default: newline)"
+msgstr "区切り(デフォルト:タブ)"
 #, fuzzy
-#~ msgid "Raster to remove"
+msgid "Raster to remove"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector to remove"
-#~ msgstr "対象ファイル<%s>"
+msgid "Vector to remove"
+msgstr "対象ファイル<%s>"
 #, fuzzy
-#~ msgid "Region to remove"
+msgid "Region to remove"
 #, fuzzy
-#~ msgid "Label to remove"
+msgid "Label to remove"
 #, fuzzy
-#~ msgid "3dview to remove"
+msgid "3dview to remove"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "Group to remove"
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "目的ファイルを含むマップセット"
+msgid "raster input maps"
+msgstr "目的ファイルを含むマップセット"
 #, fuzzy
-#~ msgid "write output to PNG image"
-#~ msgstr "出力ファイルの上書き"
+msgid "write output to PNG image"
+msgstr "出力ファイルの上書き"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "入力ファイルの座標を使用"
+msgid "label with coordinates instead of numbering"
+msgstr "入力ファイルの座標を使用"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
+msgid "Do not overwrite existing map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "ラスターマップをバイナリーファイルとしてエクスポートします"
 #, fuzzy
-#~ msgid "Region sensitive output"
+msgid "Region sensitive output"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "区切り"
+msgid "Output field seperator"
+msgstr "区切り"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "ラスターマップにおいて統計解析を行います"
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "ラスターマップにおいて統計解析を行います"
 #, fuzzy
-#~ msgid "Percentile to calculate (requires -e flag)"
-#~ msgstr "座標成分を出力"
+msgid "Percentile to calculate (requires -e flag)"
+msgstr "座標成分を出力"
 #, fuzzy
-#~ msgid "A (grid3D file)"
+msgid "A (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
+msgid "Name for output grid3D volume"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: [%s] not found"
+msgid "%s: [%s] not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
+msgid ""
+"Enter the file name or path\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Interactively select End-Points"
-#~ msgstr "対話形式で終点を選択"
+msgid "Interactively select End-Points"
+msgstr "対話形式で終点を選択"
 #, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "凡例のサイズと位置をマウスで決定"
+msgid "Use mouse to select Start Point\n"
+msgstr "凡例のサイズと位置をマウスで決定"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Use mouse to draw profile line\n"
+msgid ""
+"\n"
+"Use mouse to draw profile line\n"
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "���:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"���:\n"
 #, fuzzy
-#~ msgid "elevin raster map <%s> not found"
+msgid "elevin raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "aspin raster map <%s> not found"
+msgid "aspin raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "linkein raster map <%s> not found"
+msgid "linkein raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "albedo raster map <%s> not found"
+msgid "albedo raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "latin raster map <%s> not found"
+msgid "latin raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
+msgid "coefbh raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
+msgid "coefdh raster map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Unable to find data map"
+msgid "Unable to find data map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to find clump map"
+msgid "Unable to find clump map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Saving new map"
+msgid "Saving new map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
+msgid "Terrain raster map (DEM)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Output raster map with lake"
+msgid "Output raster map with lake"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s>!"
+msgid "Cannot write lake raster map <%s>!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "対象マップ"
+msgid "Terrain raster map <%s> not found!"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "対象マップ"
+msgid "Seed map <%s> not found!"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot open seed map <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "マップのカテゴリー値について統計解析を行います"
+msgid "Failure to allocate memory for row pointers"
+msgstr "マップのカテゴリー値について統計解析を行います"
 #, fuzzy
-#~ msgid "Loading maps: "
+msgid "Loading maps: "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Error reading terrain raster map. Probably broken file."
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Error reading seed raster map. Probably broken file."
+msgid "Error reading seed raster map. Probably broken file."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot write lake raster map <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Error writing color file for <%s@%s>!"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_ja.po (grassmods_ja)  #-#-#-#-#\n"
-#~ "対象マップ\n"
-#~ "入力するファイル"
+msgid "%s: base raster map not found"
+msgstr ""
+"#-#-#-#-#  grassmods_ja.po (grassmods_ja)  #-#-#-#-#\n"
+"対象マップ\n"
+"入力するファイル"
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "対象マップ"
+msgid "%s: cover raster map not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
+msgid "Name of the vector points map with x,y locations"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr "補間に用いる近傍点"
+msgid "Number of time iterations (sec.)"
+msgstr "補間に用いる近傍点"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "ロケーション"
+msgid "Multiscale simulation"
+msgstr "ロケーション"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Calculates <simple> index on a raster map"
-#~ msgstr "サイトマップにラスター形式のマスクをかけ新しいマップを作成します"
+msgid "Calculates <simple> index on a raster map"
+msgstr "サイトマップにラスター形式のマスクをかけ新しいマップを作成します"
 #, fuzzy
-#~ msgid "Quietly"
-#~ msgstr "説明なし"
+msgid "Quietly"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Bilinear interpolation utility for raster map layers."
-#~ msgstr "データ点から補間計算により曲面を推定します"
+msgid "Bilinear interpolation utility for raster map layers."
+msgstr "データ点から補間計算により曲面を推定します"
 #, fuzzy
-#~ msgid ""
-#~ "Specific input value to be assigned to the north and/or south poles for "
-#~ "longitude-latitude grids"
-#~ msgstr "経度 (ddd:mm:ss{E|W}) 緯度 (dd:mm:ss{N|S})"
+msgid ""
+"Specific input value to be assigned to the north and/or south poles for "
+"longitude-latitude grids"
+msgstr "経度 (ddd:mm:ss{E|W}) 緯度 (dd:mm:ss{N|S})"
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
+msgid "Illegal output file name <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Raster input maps(s)"
+msgid "Raster input maps(s)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Output file name"
+msgid "Output file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
+msgid "%s: can't read fp range for [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "対象マップ"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Path to rules file"
+msgid "Path to rules file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Enter rules interactively"
-#~ msgstr "マウスで位置を指定"
+msgid "Enter rules interactively"
+msgstr "マウスで位置を指定"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
-#~ msgstr "対象マップ"
+msgid "RGB raster map <%s> not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
-#~ msgstr "���"
+msgid "Vector cell map <%s> not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]!"
+msgid "Cannot open raster map [%s]!"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Raster file [%s] is empty."
-#~ msgstr "��."
+msgid "Raster file [%s] is empty."
+msgstr "��."
 #, fuzzy
-#~ msgid "  1. Pre 3.0 compression\n"
-#~ msgstr "圧縮形式"
+msgid "  1. Pre 3.0 compression\n"
+msgstr "圧縮形式"
 #, fuzzy
-#~ msgid "  2. 3.0 compression\n"
-#~ msgstr "圧縮形式"
+msgid "  2. 3.0 compression\n"
+msgstr "圧縮形式"
 #, fuzzy
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "対象ファイル<%s> (コピー元,コピー先)"
+msgid "The file appears to be compressed.\n"
+msgstr "対象ファイル<%s> (コピー元,コピー先)"
 #, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "NULL値に代入する値"
+msgid "Unable to write header for [%s]."
+msgstr "NULL値に代入する値"
 #, fuzzy
-#~ msgid "Header for raster map [%s] updated."
+msgid "Header for raster map [%s] updated."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "        Number of rows"
-#~ msgstr "行数"
+msgid "        Number of rows"
+msgstr "行数"
 #, fuzzy
-#~ msgid "        Number of cols"
-#~ msgstr "列数"
+msgid "        Number of cols"
+msgstr "列数"
 #, fuzzy
-#~ msgid "        Number of bytes per cell"
-#~ msgstr "1セルのバイト数"
+msgid "        Number of bytes per cell"
+msgstr "1セルのバイト数"
 #, fuzzy
-#~ msgid "        Floating point map"
-#~ msgstr "目的ファイルを含むロケーション"
+msgid "        Floating point map"
+msgstr "目的ファイルを含むロケーション"
 #, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
+msgid "Raster file [%s] not found. Exiting."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "History file for [%s] updated."
-#~ msgstr "色に用いるラスターマップ"
+msgid "History file for [%s] updated."
+msgstr "色に用いるラスターマップ"
 #, fuzzy
-#~ msgid "Which vector map needs updated categories?"
-#~ msgstr "���?"
+msgid "Which vector map needs updated categories?"
+msgstr "���?"
 #, fuzzy
-#~ msgid "%s map <%s> not found"
+msgid "%s map <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
+msgid "Category file for <%s> not updated"
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
+msgid "Category file for <%s> updated"
 #, fuzzy
-#~ msgid "Title, in quotes"
-#~ msgstr "タイトル"
+msgid "Title, in quotes"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Quiet - Do not show progress"
-#~ msgstr "説明なし"
+msgid "Quiet - Do not show progress"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Suppress single crossing error messages"
-#~ msgstr "単一交差に関するエラーメッセージを出力しない"
+msgid "Suppress single crossing error messages"
+msgstr "単一交差に関するエラーメッセージを出力しない"
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
-#~ msgstr "��� "
+msgid "Unable to find starting vector <%s> "
+msgstr "��� "
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
-#~ msgstr "���"
+msgid "Unable to find stop vector <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
-#~ msgstr "���"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "���"
 #, fuzzy
-#~ msgid "Apply filter only to zero data values"
-#~ msgstr "値0にのみフィルタを適用"
+msgid "Apply filter only to zero data values"
+msgstr "値0にのみフィルタを適用"
 #, fuzzy
-#~ msgid "Error reading '%s' map"
+msgid "Error reading '%s' map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Run verbosly"
-#~ msgstr "説明つき表示"
+msgid "Run verbosly"
+msgstr "説明つき表示"
 #, fuzzy
-#~ msgid "Cell file not found"
+msgid "Cell file not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
-#~ msgstr "���"
+msgid "Vector map <%s> not found in the current mapset"
+msgstr "���"
 #, fuzzy
-#~ msgid "Threshold distance"
-#~ msgstr "閾値"
+msgid "Threshold distance"
+msgstr "閾値"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
+msgid "Cannot execute: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "Cannot link table: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "DXF input file"
+msgid "DXF input file"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
+msgid "Cannot open new vector map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "���."
+msgid "Conversion of <%s> to vector map:"
+msgstr "���."
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
-#~ msgstr "���"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr "���"
 #, fuzzy
-#~ msgid "Create 3D file"
+msgid "Create 3D file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Do not print polyline info"
-#~ msgstr "統一する属性の値"
+msgid "Do not print polyline info"
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
-#~ msgstr "���"
+msgid "Network input map <%s> not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "Please answer yes or no"
-#~ msgstr "���� yes ��no"
+msgid "Please answer yes or no"
+msgstr "���� yes ��no"
 #, fuzzy
-#~ msgid "Quiet; No chatter"
-#~ msgstr "説明なし"
+msgid "Quiet; No chatter"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "imagery group"
-#~ msgstr "画像グループ"
+msgid "imagery group"
+msgstr "画像グループ"
 #, fuzzy
-#~ msgid "imagery subgroup"
-#~ msgstr "サブ画像グループ"
+msgid "imagery subgroup"
+msgstr "サブ画像グループ"
 #, fuzzy
-#~ msgid "output raster map"
+msgid "output raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of input raster map(s)"
+msgid "Name of input raster map(s)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
-#~ msgstr "虚部を含む入力ファイル"
+msgid "Illegal file name for real part: %s"
+msgstr "虚部を含む入力ファイル"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "シグネチャファイル"
+msgid "** Can't read signature file <%s> **"
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "<%s> -- illegal result signature file name"
+msgid ""
+"\n"
+"<%s> -- illegal result signature file name"
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
+msgid "Illegal group name <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
+msgid "Illegal signature file name <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
+msgid "Raster file(s) for Elevation"
 #, fuzzy
-#~ msgid "Raster file(s) for Color"
+msgid "Raster file(s) for Color"
 #, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "領域に名前を付けて保存"
+msgid "Can't clear current graphics window"
+msgstr "領域に名前を付けて保存"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
 #, fuzzy
-#~ msgid ""
-#~ "Generates and displays simple graphics on map layers drawn in the active "
-#~ "graphics monitor display frame."
+msgid ""
+"Generates and displays simple graphics on map layers drawn in the active "
+"graphics monitor display frame."
 #, fuzzy
-#~ msgid ""
-#~ "Unix file containg graphing instructions, if not given reads from "
-#~ "standard input"
-#~ msgstr "設定ファイル"
+msgid ""
+"Unix file containg graphing instructions, if not given reads from standard "
+"input"
+msgstr "設定ファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Color to draw with, either a standard GRASS color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr "線の色"
+msgid ""
+"Color to draw with, either a standard GRASS color or R:G:B triplet "
+"(separated by colons)"
+msgstr "線の色"
 #, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "現在選択されているフレーム"
+msgid "No current frame"
+msgstr "現在選択されているフレーム"
 #, fuzzy
-#~ msgid "Error reading raster map"
+msgid "Error reading raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Interactive profile plotting utility with optional output."
-#~ msgstr "ラスターマップの断面図を表示します"
+msgid "Interactive profile plotting utility with optional output."
+msgstr "ラスターマップの断面図を表示します"
 #, fuzzy
-#~ msgid "Optional display raster"
-#~ msgstr "表示するファイル"
+msgid "Optional display raster"
+msgstr "表示するファイル"
 #, fuzzy
-#~ msgid "Output profile data to file(s) with prefix 'name'"
-#~ msgstr "出力ファイル"
+msgid "Output profile data to file(s) with prefix 'name'"
+msgstr "出力ファイル"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Use mouse to choose action"
+msgid ""
+"\n"
+"\n"
+"Use mouse to choose action"
 #, fuzzy
-#~ msgid "Error opening cell-file"
+msgid "Error opening cell-file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Error reading from cell-file"
+msgid "Error reading from cell-file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Couldn't open raster <%s@%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No raster map exists in current window"
-#~ msgstr "対象マップ"
+msgid "No raster map exists in current window"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "No current window"
+msgid "No current window"
 #, fuzzy
-#~ msgid "No current graphics window"
+msgid "No current graphics window"
 #, fuzzy
-#~ msgid "Can't set current graphics window"
+msgid "Can't set current graphics window"
 #, fuzzy
-#~ msgid "Getting graphics window coordinates"
-#~ msgstr "始点と終点の座標値"
+msgid "Getting graphics window coordinates"
+msgstr "始点と終点の座標値"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
+msgid "Font name or pathname of TTF file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "FreeType設定を解除する\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+"FreeType設定を解除する\n"
 #, fuzzy
-#~ msgid "Display number of colors"
+msgid "Display number of colors"
+msgstr "初期のクラスター数"
 #, fuzzy
-#~ msgid "Use mouse to size & place legend"
+msgid "Use mouse to size & place legend"
 #, fuzzy
-#~ msgid "Name of frame(s) to save"
+msgid "Name of frame(s) to save"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Save current frame"
+msgid "Save current frame"
 #, fuzzy
-#~ msgid "Save all the frames"
+msgid "Save all the frames"
+msgstr "フレームの作成"
 #, fuzzy
-#~ msgid "No monitor selected"
-#~ msgstr "選択するモニター"
+msgid "No monitor selected"
+msgstr "選択するモニター"
 #, fuzzy
-#~ msgid ""
-#~ "Creates and displays a menu within the active frame on the graphics "
-#~ "monitor."
-#~ msgstr "���."
+msgid ""
+"Creates and displays a menu within the active frame on the graphics monitor."
+msgstr "���."
 #, fuzzy
-#~ msgid "Sets the color of the menu background"
-#~ msgstr "背景の色"
+msgid "Sets the color of the menu background"
+msgstr "背景の色"
 #, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "ラベルの色"
+msgid "Sets the color of the menu text"
+msgstr "ラベルの色"
 #, fuzzy
-#~ msgid "Sets the color dividing lines of text"
-#~ msgstr "ラベルの色"
+msgid "Sets the color dividing lines of text"
+msgstr "ラベルの色"
 #, fuzzy
-#~ msgid "Sets the menu text size (in percent)"
-#~ msgstr "ラベルのサイズ"
+msgid "Sets the menu text size (in percent)"
+msgstr "ラベルのサイズ"
 #, fuzzy
-#~ msgid ""
-#~ "Draws text in the graphics monitor's active display frame using TrueType "
-#~ "fonts."
-#~ msgstr "テキストを表示します"
+msgid ""
+"Draws text in the graphics monitor's active display frame using TrueType "
+"fonts."
+msgstr "テキストを表示します"
 #, fuzzy
-#~ msgid "Screen position (percentage, [0,0] is bottom left)"
-#~ msgstr "テキストを開始する行番号"
+msgid "Screen position (percentage, [0,0] is bottom left)"
+msgstr "テキストを開始する行番号"
 #, fuzzy
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "TrueTypeフォントへのパス(ファイル名含む)"
+msgid "Path to TrueType font (including file name)"
+msgstr "TrueTypeフォントへのパス(ファイル名含む)"
 #, fuzzy
-#~ msgid "Height of letters (in percent of available frame height)"
-#~ msgstr "サイズ"
+msgid "Height of letters (in percent of available frame height)"
+msgstr "サイズ"
 #, fuzzy
-#~ msgid "Text conversion error"
-#~ msgstr "閾値"
+msgid "Text conversion error"
+msgstr "閾値"
 #, fuzzy
-#~ msgid "Unable to write the temporary file"
+msgid "Unable to write the temporary file"
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid "No predefined font"
+msgid "No predefined font"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Unable to read font"
+msgid "%s: Unable to read font"
 #, fuzzy
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "  region (地域定義ファイル)\n"
+msgid "%s: No FreeType definition file"
+msgstr "  region (地域定義ファイル)\n"
 #, fuzzy
-#~ msgid "One mouse click only"
-#~ msgstr "1度のみ実行"
+msgid "One mouse click only"
+msgstr "1度のみ実行"
 #, fuzzy
-#~ msgid "Use mouse to interactively place scale"
-#~ msgstr "ラベルの位置をマウスで決定"
+msgid "Use mouse to interactively place scale"
+msgstr "ラベルの位置をマウスで決定"
 #, fuzzy
-#~ msgid "Use mouse to interactively place text"
+msgid "Use mouse to interactively place text"
 #, fuzzy
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "再描画"
+msgid "Just redraw given maps using default colors"
+msgstr "再描画"
 #, fuzzy
-#~ msgid "ERROR: can not get \"list\" items"
+msgid "ERROR: can not get \"list\" items"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Interactively select route"
+msgid "Interactively select route"
 #, fuzzy
-#~ msgid "No raster or vector map displayed"
-#~ msgstr "�����"
+msgid "No raster or vector map displayed"
+msgstr "�����"
 #, fuzzy
-#~ msgid "To establish and control use of a graphics display monitor."
-#~ msgstr "モニターの制御を行います"
+msgid "To establish and control use of a graphics display monitor."
+msgstr "モニターの制御を行います"
 #, fuzzy
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "開始するモニター"
+msgid "Name of graphics monitor to start"
+msgstr "開始するモニター"
 #, fuzzy
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "終了するモニター"
+msgid "Name of graphics monitor to stop"
+msgstr "終了するモニター"
 #, fuzzy
-#~ msgid "Name of graphics monitor to select"
+msgid "Name of graphics monitor to select"
+msgstr "選択するモニター"
 #, fuzzy
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "アンロックするモニター"
+msgid "Name of graphics monitor to unlock"
+msgstr "アンロックするモニター"
 #, fuzzy
-#~ msgid "List all monitors"
-#~ msgstr "モニターの一覧を表示"
+msgid "List all monitors"
+msgstr "モニターの一覧を表示"
 #, fuzzy
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "現在の全モニターの状況を表示"
+msgid "List all monitors (with current status)"
+msgstr "現在の全モニターの状況を表示"
 #, fuzzy
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "現在選択されているモニターを表示"
+msgid "Print name of currently selected monitor"
+msgstr "現在選択されているモニターを表示"
 #, fuzzy
-#~ msgid "Release currently selected monitor"
-#~ msgstr "モニターの選択を解除"
+msgid "Release currently selected monitor"
+msgstr "モニターの選択を解除"
 #, fuzzy
-#~ msgid "Do not automatically select when starting"
-#~ msgstr "開始するモニターを選択しない"
+msgid "Do not automatically select when starting"
+msgstr "開始するモニターを選択しない"
 #, fuzzy
-#~ msgid "Monitor <%s> released"
+msgid "Monitor <%s> released"
+msgstr "選択するモニター"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
+msgid "Error - Locking mechanism failed"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
+msgid "Error choosing frame [%s]\n"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "���:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"���:\n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
-#~ msgstr "フレームの選択"
+msgid "Left:   Select frame\n"
+msgstr "フレームの選択"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "説明なし"
+msgid "Right:  Accept frame\n"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
+msgid "Manages display frames on the user's graphics monitor."
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
+msgstr "フレームの作成"
 #, fuzzy
-#~ msgid "Select a frame"
+msgid "Select a frame"
+msgstr "フレームの選択"
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
 #, fuzzy
-#~ msgid "Print names of all frames"
-#~ msgstr "総面積(平方メートル)を出力"
+msgid "Print names of all frames"
+msgstr "総面積(平方メートル)を出力"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Debugging output"
-#~ msgstr "デバッグを出力"
+msgid "Debugging output"
+msgstr "デバッグを出力"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "作成/選択するフレーム"
+msgid "Frame to be created/selected"
+msgstr "作成/選択するフレーム"
 #, fuzzy
-#~ msgid "Where to place the frame, values in percent (implies -c)"
-#~ msgstr "フレームを作成する位置"
+msgid "Where to place the frame, values in percent (implies -c)"
+msgstr "フレームを作成する位置"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "���:\n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"\n"
+"���:\n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
+msgid "Left:   Select From\n"
+msgstr "フレームの選択"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr "説明なし"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Raster map to zoom into"
-#~ msgstr "ズームするラスターマップ"
+msgid "Raster map to zoom into"
+msgstr "ズームするラスターマップ"
 #, fuzzy
-#~ msgid "Save the current region to region definition file"
+msgid "Save the current region to region definition file"
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
+msgid "<%s> is an illegal region name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Erasing monitors ..."
+msgid "Erasing monitors ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
-#~ msgstr "���"
+msgid "Could not open input file <%s>."
+msgstr "���"
 #, fuzzy
-#~ msgid "Removing files from group"
+msgid "Removing files from group"
+msgstr "サブ画像グループ"
 #, fuzzy
-#~ msgid "Adding files to group [%s]"
-#~ msgstr "画像グループ"
+msgid "Adding files to group [%s]"
+msgstr "画像グループ"
 #, fuzzy
-#~ msgid "Adding files to subgroup [%s]"
+msgid "Adding files to subgroup [%s]"
+msgstr "サブ画像グループ"
 #, fuzzy
-#~ msgid "Writing subgroup REF"
+msgid "Writing subgroup REF"
+msgstr "サブ画像グループ"
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Unable to open file: <%s>"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Multiplier"
-#~ msgstr "高さの強調"
+msgid "Multiplier"
+msgstr "高さの強調"
 #, fuzzy
-#~ msgid "not found\n"
+msgid "not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Raster map not found."
-#~ msgstr "対象マップ"
+msgid "Raster map not found."
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "%s: can't read range for [%s]"
+msgid "%s: can't read range for [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "It was not possible writing in <%s>."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
-#~ msgstr "���"
+msgid "Unable to get category list <%s>, editing terminated"
+msgstr "���"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
+msgid "Unknown query tool '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No layer database connection"
-#~ msgstr "ロケーション"
+msgid "No layer database connection"
+msgstr "ロケーション"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "タイトル"
+msgid "%d categories loaded from the database"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Cannot open OGR data source '%s'"
+msgid "Cannot open OGR data source '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create layer"
+msgid "Cannot create layer"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
-#~ msgstr "対象マップ"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid ""
-#~ "Load values from vector to database. For uploaded/printed category values "
-#~ "'-1' is used for 'no category' and 'null'/'-' if category cannot be found "
-#~ "or multiple categories were found."
-#~ msgstr "���."
+msgid ""
+"Load values from vector to database. For uploaded/printed category values '-"
+"1' is used for 'no category' and 'null'/'-' if category cannot be found or "
+"multiple categories were found."
+msgstr "���."
 #, fuzzy
-#~ msgid "Column(s)"
-#~ msgstr "更新するカラム1"
+msgid "Column(s)"
+msgstr "更新するカラム1"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
+msgid "Cannot read map header for <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "���"
+msgid "Cannot read category file for <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Print;Shell Script"
-#~ msgstr "総セル数の出力"
+msgid "Print;Shell Script"
+msgstr "総セル数の出力"
 #, fuzzy
-#~ msgid "Creating support files for [%s]."
+msgid "Creating support files for [%s]."
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
-#~ "対象マップ\n"
-#~ "入力するファイル"
+msgid "%s: <%s> raster map not found"
+msgstr ""
+"対象マップ\n"
+"入力するファイル"
 #, fuzzy
-#~ msgid "%s: <%s> raster map exists already"
-#~ msgstr "対象マップ"
+msgid "%s: <%s> raster map exists already"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
-#~ msgstr "���"
+msgid "Cannot read category file of raster map <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "%s - map not found"
+msgid "%s - map not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
+msgid "%s: Cannot open [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
-#~ msgstr "���"
+msgid "Vector map %s - not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "Raster map containing elevation data"
+msgid "Raster map containing elevation data"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Raster map name for storing results"
+msgid "Raster map name for storing results"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Height of the viewing location"
-#~ msgstr "視点の高さ"
+msgid "Height of the viewing location"
+msgstr "視点の高さ"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s - %s not found"
+msgid "%s - %s not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "raster map <%s> not found"
-#~ msgstr "対象マップ"
+msgid "raster map <%s> not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "can't open vector map <%s> in <%s>"
-#~ msgstr "���"
+msgid "can't open vector map <%s> in <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "[%s] map not found."
+msgid "[%s] map not found."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "[%s] map not found"
+msgid "[%s] map not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
+msgid "elevation file [%s] not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "min computed aspect %.4f  max computed aspect %.4f"
-#~ msgstr "����� �����"
+msgid "min computed aspect %.4f  max computed aspect %.4f"
+msgstr "����� �����"
 #, fuzzy
-#~ msgid "min computed slope %.4f  max computed slope %.4f"
-#~ msgstr "��� ���"
+msgid "min computed slope %.4f  max computed slope %.4f"
+msgstr "��� ���"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
+msgid "Cannot insert values: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
+msgid "%s given an illegal number of points [%d]"
+msgstr "初期のクラスター数"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Unable to open database %s by driver %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not find input %s"
+msgid "Could not find input %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not find input map <%s>"
+msgid "Could not find input map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
-#~ msgstr "���"
+msgid "Can't read header for <%s> in <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgstr "���"
+msgid "Can't read header for 3D raster <%s> in <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "���"
+msgid "Can't write region <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "グラフィックデバイスが選択されていない"
+msgid "No graphics device selected."
+msgstr "グラフィックデバイスが選択されていない"
 #, fuzzy
-#~ msgid "Unable to read raster row."
+msgid "Unable to read raster row."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Training map [%s] not found."
-#~ msgstr "対象マップ"
+msgid "Training map [%s] not found."
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "input raster map"
+msgid "input raster map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "Illegal file name: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map"
-#~ msgstr "���"
+msgid "Cannot get layer info for vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
-#~ msgstr ""
-#~ "出力するファイル"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr ""
+"出力するファイル"
 #, fuzzy
-#~ msgid "cover values extracted from the category labels of the cover map"
-#~ msgstr "カテゴリー値の代わりにカテゴリーラベルを使用"
+msgid "cover values extracted from the category labels of the cover map"
+msgstr "カテゴリー値の代わりにカテゴリーラベルを使用"
 #, fuzzy
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "対象マップ"
+msgid "%s: %s - raster map not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "%s: %s - illegal name"
+msgid "%s: %s - illegal name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: ERROR reading category file for %s"
+msgid "%s: ERROR reading category file for %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - illegal units"
+msgid "%s: %s - illegal units"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
+msgid "Reading input map (%s)    ... "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s - ERROR reading %s"
+msgid "%s - ERROR reading %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s - ERROR re-reading %s"
+msgid "%s - ERROR re-reading %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Reading raster map... "
+msgid "Reading raster map... "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Writing raster map... "
+msgid "Writing raster map... "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "カテゴリーラベルのリスト(例 1,3-8,13)"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "カテゴリーラベルのリスト(例 1,3-8,13)"
 #, fuzzy
-#~ msgid "Output separator character (default: tab)"
+msgid "Output separator character (default: tab)"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
-#~ msgstr "���"
+msgid "Cannot read category file of raster map <%s> in <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot find file %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "���"
+msgid "Cannot create vector map %s"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
-#~ msgstr "メモリに残す行"
+msgid "Number of raster rows to hold in memory"
+msgstr "メモリに残す行"
 #, fuzzy
-#~ msgid "Print raster map title only"
+msgid "Print raster map title only"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "unknown type: %d"
-#~ msgstr "ファイルの種類"
+msgid "unknown type: %d"
+msgstr "ファイルの種類"
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]"
-#~ msgstr ""
-#~ "出力するファイル"
+msgid "Cannot open raster map [%s]"
+msgstr ""
+"出力するファイル"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
-#~ msgstr "���"
+msgid "Cannot read GRASS raster."
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot write GDAL raster."
+msgid "Cannot write GDAL raster."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Couldn't set geo transform."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "Couldn't set projection."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Reading raster map"
+msgid "Reading raster map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cannot open output map."
+msgid "Cannot open output map."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "memory allocation failure"
-#~ msgstr "ロケーション"
+msgid "memory allocation failure"
+msgstr "ロケーション"
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
-#~ msgstr "正接曲率を出力するファイル"
+msgid "Output terrain only vector map name"
+msgstr "傾斜の方位を出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
-#~ msgstr "���"
+msgid "Cannot open vector map <%s> at the topological level"
+msgstr "���"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Attaching islands ..."
+msgid "Attaching islands ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
-#~ msgstr "���"
+msgid "Vector map <%s> not found in current mapset"
+msgstr "���"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
+msgid "Error allocating memory for `lines_visited'"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
-#~ msgstr "ピクセルの最小値"
+msgid "The number of lines in the input vector map is [%d]"
+msgstr "ピクセルの最小値"
 #, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "Cannot get layer info"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "cell file [%s] not found"
+msgid "cell file [%s] not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
-#~ msgstr "���"
+msgid "Cannot rewrite line %d"
+msgstr "���"
 #, fuzzy
-#~ msgid "Editing tool"
+msgid "Editing tool"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
-#~ msgstr "���"
+msgid "Cannot copy line %d, editing terminated"
+msgstr "���"
 #, fuzzy
-#~ msgid "No layer database connection."
-#~ msgstr "ロケーション"
+msgid "No layer database connection."
+msgstr "ロケーション"
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%d lines modified"
-#~ msgstr "タイトル"
+msgid "%d lines modified"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Print vector map region only"
-#~ msgstr "���"
+msgid "Print vector map region only"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
-#~ msgstr "���"
+msgid "Cannot open vector map <%s> at topo level [%d]"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "���"
+msgid "Cannot get layer info for vector map <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot select attribute."
+msgid "Cannot select attribute."
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Number of ROWS and COLUMNS in grid"
-#~ msgstr "格子数"
+msgid "Number of ROWS and COLUMNS in grid"
+msgstr "格子数"
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "���"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "���"
 #, fuzzy
-#~ msgid "Could not find input map <%s>."
+msgid "Could not find input map <%s>."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "���"
+msgid "[%d] features written"
+msgstr "���"
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
-#~ msgstr "���."
+msgid "Parameter <%s> not set"
+msgstr "���."
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "���."
+msgid "Output map where segments will be written"
+msgstr "���."
 #, fuzzy
-#~ msgid "Cannot get layer information for vector map"
-#~ msgstr "���"
+msgid "Cannot get layer information for vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
+msgid "Database record for cat %d not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No table."
-#~ msgstr "テーブル"
+msgid "No table."
+msgstr "テーブル"
 #, fuzzy
-#~ msgid "Can't read raster"
-#~ msgstr "���"
+msgid "Can't read raster"
+msgstr "���"
 #, fuzzy
-#~ msgid "driver name"
-#~ msgstr "ドライバ"
+msgid "driver name"
+msgstr "ドライバ"
 #, fuzzy
-#~ msgid "database name"
-#~ msgstr "データベース"
+msgid "database name"
+msgstr "データベース"
 #, fuzzy
-#~ msgid "Driver name"
-#~ msgstr "ドライバ"
+msgid "Driver name"
+msgstr "ドライバ"
 #, fuzzy
-#~ msgid "database location"
-#~ msgstr "ロケーション"
+msgid "database location"
+msgstr "ロケーション"
 #, fuzzy
-#~ msgid "output field separator"
-#~ msgstr "区切り"
+msgid "output field separator"
+msgstr "区切り"
 #, fuzzy
-#~ msgid "output vertical record separator"
-#~ msgstr "上下方向の区切り"
+msgid "output vertical record separator"
+msgstr "上下方向の区切り"
 #, fuzzy
-#~ msgid "null value indicator"
-#~ msgstr "NULL値の識別子"
+msgid "null value indicator"
+msgstr "NULL値の識別子"
 #, fuzzy
-#~ msgid "do not include column names in output"
-#~ msgstr "ルートに沿ってセル値をコピー"
+msgid "do not include column names in output"
+msgstr "ルートに沿ってセル値をコピー"
 #, fuzzy
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "8bitで出力"
+msgid "vertical output (instead of horizontal)"
+msgstr "8bitで出力"
 #, fuzzy
-#~ msgid "Name of existing raster map"
-#~ msgstr ""
-#~ "入力するファイル\n"
-#~ "対象マップ"
+msgid "Name of existing raster map"
+msgstr ""
+"入力するファイル\n"
+"対象マップ"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
+msgid "Cannot find mapset for %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Label file [%s] not available"
+msgid "Label file [%s] not available"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "unable to open [%s] in [%s]"
+msgid "unable to open [%s] in [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "warning: unable to open [%s] in [%s]"
+msgid "warning: unable to open [%s] in [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s] in [%s]"
+msgid "Unable to open raster map [%s] in [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Table to be imported"
+msgid "Table to be imported"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "Unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "���."
+msgid "Input file [%s] not found."
+msgstr "���."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Multiplier for ascii data"
-#~ msgstr "高さの強調"
+msgid "Multiplier for ascii data"
+msgstr "高さの強調"
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "unable to create raster"
+msgid "unable to create raster"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
 #, fuzzy
-#~ msgid "Name of the random surface to be produced"
+msgid "Name of the random surface to be produced"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
-#~ msgstr "���"
+msgid "Vector <%s> could not be opened"
+msgstr "���"
 #, fuzzy
-#~ msgid "Table name"
-#~ msgstr "テーブル"
+msgid "Table name"
+msgstr "テーブル"
 #, fuzzy
-#~ msgid "x column name"
-#~ msgstr "キーカラム"
+msgid "x column name"
+msgstr "キーカラム"
 #, fuzzy
-#~ msgid "z column name"
-#~ msgstr "キーカラム"
+msgid "z column name"
+msgstr "キーカラム"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
-#~ msgstr "���"
+msgid "SVG file <%s> cannot be opened"
+msgstr "���"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "���%s ..."
+msgid "Querying input '%s' ... "
+msgstr "���%s ..."
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "���."
+msgid "Copying %s input lines ... "
+msgstr "���."
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "���"
+msgid "Cannot find line of cat %d"
+msgstr "���"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+msgid "Unalbe to open vector map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "ベクトルマップの座標変換を行います"
+msgid "Transforms a vector map via a set of tie points."
+msgstr "ベクトルマップの座標変換を行います"
 #, fuzzy
-#~ msgid "Read coordinates from standard input"
-#~ msgstr "始点の座標値"
+msgid "Read coordinates from standard input"
+msgstr "始点の座標値"
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
-#~ msgstr "対象マップ"
+msgid "Raster map <%s>] not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot start driver <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "color file for [%s] not available"
+msgid "color file for [%s] not available"
 #, fuzzy
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "��."
+msgid "Raster file [%s] not available"
+msgstr "��."
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
-#~ msgstr "対象マップ"
+msgid "Raster map [%s] not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Vector file [%s] not available"
-#~ msgstr "対象マップ"
+msgid "Vector file [%s] not available"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot open driver %s"
+msgid "Cannot open driver %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "<%s> illegal name"
+msgid "<%s> illegal name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
+msgid "%s: %s - Unable to open the input raster map\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
 #, fuzzy
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: <%s> illegal name"
+msgid "%s: <%s> illegal name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot find %s"
+msgid "Cannot find %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]."
+msgid "Unable to create raster map [%s]."
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
+msgid "Open raster map %s in %s = %d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Closing raster map"
-#~ msgstr "カバーマップ"
+msgid "Closing raster map"
+msgstr "カバーマップ"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of the new raster map"
+msgid "Name of the new raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
-#~ msgstr "���"
+msgid "can't open raster map <%s> in mapset %s"
+msgstr "���"
 #, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS raster map to a PPM image file at the pixel resolution "
-#~ "of the CURRENTLY DEFINED REGION."
-#~ msgstr "ラスターマップをPPMファイルとしてエクスポートします"
+msgid ""
+"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
+"the CURRENTLY DEFINED REGION."
+msgstr "ラスターマップをPPMファイルとしてエクスポートします"
 #, fuzzy
-#~ msgid "Raster input map"
+msgid "Raster input map"
 #, fuzzy
-#~ msgid "Mapset of input map"
+msgid "Mapset of input map"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
+msgid "Checking location %s, mapset %s:"
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
-#~ msgstr "���."
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgstr "���."
 #, fuzzy
-#~ msgid "Error writing output map"
-#~ msgstr "解像度"
+msgid "Error writing output map"
+msgstr "解像度"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "傾斜方位を示すファイル(入力)"
+msgid "no rules specified"
+msgstr "傾斜方位を示すファイル(入力)"
 #, fuzzy
-#~ msgid "Can't open temp file [%s]"
+msgid "Can't open temp file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Names of existing raster maps"
+msgid "Names of existing raster maps"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Unable to open input map <%s> in mapset <%s>"
+msgid "Unable to open input map <%s> in mapset <%s>"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "%s in %s -can't open raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Requested 3d raster map not found <%s>"
-#~ msgstr "���."
+msgid "Requested 3d raster map not found <%s>"
+msgstr "���."
 #, fuzzy
-#~ msgid "Could not open elevation map"
+msgid "Could not open elevation map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "unable to close output map"
+msgid "unable to close output map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Cannot open vector points map <%s>"
-#~ msgstr "���."
+msgid "Cannot open vector points map <%s>"
+msgstr "���."
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
-#~ msgstr "���"
+msgid "Cannot create vector map <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
-#~ msgstr "出力するファイル"
+msgid "Could not find input map <%s> in current mapset."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
-#~ msgstr "対象マップ"
+msgid "Vector file [%s] not available in search list"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
-#~ msgstr "���"
+msgid "Could not find input vector map %s"
+msgstr "���"
 #, fuzzy
-#~ msgid "The vector '%s' already exists."
-#~ msgstr "���."
+msgid "The vector '%s' already exists."
+msgstr "���."
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
+msgid "error opening raster map [%s]."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
-#~ msgstr "入力するファイル"
+msgid "Patching file <%s@%s>"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "[%d] files patched"
-#~ msgstr "���"
+msgid "[%d] files patched"
+msgstr "���"
 #, fuzzy
-#~ msgid "Could not open vector map <%s>"
-#~ msgstr "���"
+msgid "Could not open vector map <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Name of output raster map"
+msgid "Name of output raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Illegal output name: '%s'"
+msgid "Illegal output name: '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: cellfile [%s] not found."
+msgid "%s: cellfile [%s] not found."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Error reading wildcard."
+msgid "Error reading wildcard."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Sets the grid color, either a standard GRASS color or R:G:B triplet "
-#~ msgstr "線の色"
+msgid ""
+"Sets the grid color, either a standard GRASS color or R:G:B triplet "
+msgstr "線の色"
 #, fuzzy
-#~ msgid ""
-#~ "Sets the border color, either a standard GRASS color or R:G:B triplet"
-#~ msgstr "線の色"
+msgid "Sets the border color, either a standard GRASS color or R:G:B triplet"
+msgstr "線の色"
 #, fuzzy
-#~ msgid "Unable to open the temporary file."
+msgid "Unable to open the temporary file."
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "name for new raster map"
+msgid "name for new raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Output GRASS image file"
+msgid "Output GRASS image file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Resulting output map"
-#~ msgstr "解像度"
+msgid "Resulting output map"
+msgstr "解像度"
 #, fuzzy
-#~ msgid "name for new vector map"
-#~ msgstr "���"
+msgid "name for new vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
+msgid "name for new vector map (omit for display to stdout)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Input vector map"
+msgid "Input vector map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: ERROR can't open tempfile"
+msgid "%s: ERROR can't open tempfile"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "vector map <%s> not found"
-#~ msgstr "���"
+msgid "vector map <%s> not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "対象マップ"
+msgid "<%s> raster map not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot find vector map [%s]"
-#~ msgstr "���"
+msgid "Cannot find vector map [%s]"
+msgstr "���"
 #, fuzzy
-#~ msgid "%s - can't open raster map"
+msgid "%s - can't open raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Can't get row %d from raster map %s"
-#~ msgstr "対象マップ1"
+msgid "Can't get row %d from raster map %s"
+msgstr "対象マップ1"
 #, fuzzy
-#~ msgid "%s - raster map not found"
-#~ msgstr "対象マップ"
+msgid "%s - raster map not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "string representing no data cell value"
-#~ msgstr "データのないセルに代入する記号"
+msgid "string representing no data cell value"
+msgstr "データのないセルに代入する記号"
 #, fuzzy
-#~ msgid "File name of classification result"
-#~ msgstr "分類結果を出力するファイル"
+msgid "File name of classification result"
+msgstr "分類結果を出力するファイル"
 #, fuzzy
-#~ msgid "File name of reference classes"
-#~ msgstr "初期のクラスター数"
+msgid "File name of reference classes"
+msgstr "初期のクラスター数"
 #, fuzzy
-#~ msgid "wide report, 132 columns (default: 80)"
-#~ msgstr "レポート幅の拡大"
+msgid "wide report, 132 columns (default: 80)"
+msgstr "レポート幅の拡大"
 #, fuzzy
-#~ msgid "quiet"
-#~ msgstr "説明なし"
+msgid "quiet"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "<%s> - illegal output file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Base raster map"
-#~ msgstr "ベースマップ"
+msgid "Base raster map"
+msgstr "ベースマップ"
 #, fuzzy
-#~ msgid "%s: raster map not found"
-#~ msgstr "対象マップ"
+msgid "%s: raster map not found"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
-#~ msgstr "���"
+msgid "can't write category file for <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Output verbosely"
-#~ msgstr "説明つき表示"
+msgid "Output verbosely"
+msgstr "説明つき表示"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
-#~ msgstr "���."
+msgid "Input vector map <%s> not found."
+msgstr "���."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
-#~ msgstr "���"
+msgid "Could not open temp file <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
-#~ msgstr "���"
+msgid "Vector map <%s> not fould"
+msgstr "���"
 #, fuzzy
-#~ msgid "SVG output file"
+msgid "SVG output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "���"
+msgid "Could not find vector '%s'"
+msgstr "���"
 #, fuzzy
-#~ msgid "Could not find vector map %s"
-#~ msgstr "���"
+msgid "Could not find vector map %s"
+msgstr "���"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
-#~ msgstr "対象マップ1"
+msgid "Unable to get row %d from <%s>"
+msgstr "対象マップ1"
 #, fuzzy
-#~ msgid "No input coordinates provided"
-#~ msgstr "X座標値"
+msgid "No input coordinates provided"
+msgstr "X座標値"
 #, fuzzy
-#~ msgid "Unable to allocate memory."
+msgid "Unable to allocate memory."
 #, fuzzy
-#~ msgid "Raster output file"
+msgid "Raster output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Keep existing color table"
-#~ msgstr "カラーテーブルを上書きしない"
+msgid "Keep existing color table"
+msgstr "カラーテーブルを上書きしない"
 #, fuzzy
-#~ msgid "Name of the output walkers site file"
+msgid "Name of the output walkers site file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "説明付き表示"
+msgid "Verbose mode."
+msgstr "説明付き表示"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "���"
+msgid " %d rows, %d cols."
+msgstr "���"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
+msgstr "シグネチャファイル"
 #, fuzzy
-#~ msgid "verbose mode"
-#~ msgstr "説明付き表示"
+msgid "verbose mode"
+msgstr "説明付き表示"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "���"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "���"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
-#~ msgstr "���"
+msgid "Layer of the vector for which to modify the attribute table"
+msgstr "���"
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of existing raster map to be displayed"
+msgid "Name of existing raster map to be displayed"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Database name:"
-#~ msgstr "データベース"
+msgid "Database name:"
+msgstr "データベース"
 #, fuzzy
-#~ msgid ""
-#~ "ASCII file to be converted to binary vector map, if not given (or \"-\") "
-#~ "reads from standard input"
-#~ msgstr "���"
+msgid ""
+"ASCII file to be converted to binary vector map, if not given (or \"-\") "
+"reads from standard input"
+msgstr "���"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
-#~ msgstr "���"
+msgid "cannot get layer info for vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
+msgid "cannot grant privileges on table %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot find vector map"
-#~ msgstr "���"
+msgid "Cannot find vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unknown keyword [%s] in vector head."
-#~ msgstr "���."
+msgid "Unknown keyword [%s] in vector head."
+msgstr "���."
 #, fuzzy
-#~ msgid "Error while reading cell map."
+msgid "Error while reading cell map."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Error while writing new cell map."
+msgid "Error while writing new cell map."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
-#~ msgstr "���"
+msgid "Error in opening input file <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "Unable to read map raster row %d"
+msgid "Unable to read map raster row %d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to write color table to raster [%s]"
+msgid "Unable to write color table to raster [%s]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Cannot find map %s"
+msgid "Cannot find map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open map %s"
+msgid "Cannot open map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of predefined rules file"
+msgid "Name of predefined rules file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "no such value"
-#~ msgstr "閾値"
+msgid "no such value"
+msgstr "閾値"
 #, fuzzy
-#~ msgid "Unable to find base map <%s>"
+msgid "Unable to find base map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to find cover map <%s>"
+msgid "Unable to find cover map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: reading category file for %s"
+msgid "%s: reading category file for %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: unable to open raster map [%s]"
+msgid "%s: unable to open raster map [%s]"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: unable to create raster map [%s]"
+msgid "%s: unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to open database %s with driver %s"
+msgid "Unable to open database %s with driver %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Unable to read raster map [%s]"
+msgid "%s: Unable to read raster map [%s]"
 #, fuzzy
-#~ msgid "%s: unable to open raster map <%s>"
+msgid "%s: unable to open raster map <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Failed to read raster row %d"
+msgid "%s: Failed to read raster row %d"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Unable to read cats table for %s"
+msgid "Unable to read cats table for %s"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Could not open raster <%s>"
+msgid "Could not open raster <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Screen coordinates to place the legend (as percentage)"
-#~ msgstr "下,上,左,右の値(パーセンテージ)"
+msgid "Screen coordinates to place the legend (as percentage)"
+msgstr "下,上,左,右の値(パーセンテージ)"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s: o_open_file: could not open raster map %s in %s"
+msgid "%s: o_open_file: could not open raster map %s in %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No record for category for [%d]"
-#~ msgstr "���"
+msgid "No record for category for [%d]"
+msgstr "���"
 #, fuzzy
-#~ msgid "Error reading ASCII file <%s>"
+msgid "Error reading ASCII file <%s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No lines found"
+msgid "No lines found"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "List of point coordinates. Required for add and move actions."
-#~ msgstr "タイプ"
+msgid "List of point coordinates. Required for add and move actions."
+msgstr "タイプ"
 #, fuzzy
-#~ msgid "Could not find input vector '%s'"
-#~ msgstr "���"
+msgid "Could not find input vector '%s'"
+msgstr "���"
 #, fuzzy
-#~ msgid "Failed opening output vector map '%s'"
+msgid "Failed opening output vector map '%s'"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Do not create attribute table."
+msgid "Do not create attribute table."
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Error reading ascii file: [%s]"
+msgid "Error reading ascii file: [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "List vector maps in input location and exit (a dummy value must be given "
-#~ "for input)"
-#~ msgstr "目的ロケーション内のベクトルマップ一覧表示"
+msgid ""
+"List vector maps in input location and exit (a dummy value must be given for "
+"input)"
+msgstr "目的ロケーション内のベクトルマップ一覧表示"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively query a vector map layer at user-"
-#~ "selected locations within the current geographic region"
-#~ msgstr ""
-#~ "マウスで指定した位置でのベクトルマップのカテゴリー情報を表示します(ここは"
-#~ "どこ?なに?)"
+msgid ""
+"Allows the user to interactively query a vector map layer at user-selected "
+"locations within the current geographic region"
+msgstr ""
+"マウスで指定した位置でのベクトルマップのカテゴリー情報を表示します(ここはど"
+"こ?なに?)"
 #, fuzzy
-#~ msgid "| Prune                           |  "
-#~ msgstr "端点をスナップ"
+msgid "| Prune                           |  "
+msgstr "端点をスナップ"
 #, fuzzy
-#~ msgid "%s: <%s> vector map not found"
-#~ msgstr "���"
+msgid "%s: <%s> vector map not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "Vector <%s> could not be open"
-#~ msgstr "���"
+msgid "Vector <%s> could not be open"
+msgstr "���"
 #, fuzzy
-#~ msgid "Raster <%s> could not be open."
+msgid "Raster <%s> could not be open."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Interpolation()"
-#~ msgstr "補間方法"
+msgid "Interpolation()"
+msgstr "補間方法"
 #, fuzzy
-#~ msgid "Interpolation: Setting regions and boxes"
-#~ msgstr "補間方法"
+msgid "Interpolation: Setting regions and boxes"
+msgstr "補間方法"
 #, fuzzy
-#~ msgid "Interpolation: nsply = %d"
-#~ msgstr "補間方法"
+msgid "Interpolation: nsply = %d"
+msgstr "補間方法"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bilinear interpolation..."
-#~ msgstr "補間に用いる近傍点"
+msgid "Interpolation: (%d,%d): Bilinear interpolation..."
+msgstr "補間に用いる近傍点"
 #, fuzzy
-#~ msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgid "Interpolation: (%d,%d): Bicubic interpolation..."
+msgstr "補間に用いる近傍点"
 #, fuzzy
-#~ msgid "%s: Dropping <s>"
+msgid "%s: Dropping <s>"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Interpolation was a success!"
-#~ msgstr "補間方法"
+msgid "Interpolation was a success!"
+msgstr "補間方法"
 #, fuzzy
-#~ msgid "CrossCorrelation: %d points read in region. "
-#~ msgstr "現在の設定を表示"
+msgid "CrossCorrelation: %d points read in region. "
+msgstr "現在の設定を表示"
 #, fuzzy
-#~ msgid "CrossCorrelation: It shouldn't take too long."
+msgid "CrossCorrelation: It shouldn't take too long."
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "%s -- illegal output file name"
+msgid "%s -- illegal output file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Sorry, with method '%s' you have to define an output map."
+msgid "Sorry, with method '%s' you have to define an output map."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Maximum number of iteration"
-#~ msgstr "最大反復回数"
+msgid "Maximum number of iteration"
+msgstr "最大反復回数"
 #, fuzzy
-#~ msgid "Existing raster map name"
+msgid "Existing raster map name"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s - can't read raster cellhd"
+msgid "%s - can't read raster cellhd"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "error reading cell data"
+msgid "error reading cell data"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "No line found."
+msgid "No line found."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Do not build topology."
-#~ msgstr "統一する属性の値"
+msgid "Do not build topology."
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Could not open ascii file [%s]"
+msgid "Could not open ascii file [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "%s: Cannot open dxf file"
+msgid "%s: Cannot open dxf file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Conversion of [%s] to vector map ..."
-#~ msgstr "���."
+msgid "Conversion of [%s] to vector map ..."
+msgstr "���."
 #, fuzzy
-#~ msgid "Print the current region (shell script style)"
-#~ msgstr "現在の設定を表示(シェルスクリプト)"
+msgid "Print the current region (shell script style)"
+msgstr "現在の設定を表示(シェルスクリプト)"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where %s is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ここでの %s は次のうちのいずれかです:\n"
+msgid ""
+"\n"
+"Where %s is one of:\n"
+msgstr ""
+"\n"
+"ここでの %s は次のうちのいずれかです:\n"
 #, fuzzy
-#~ msgid "ERROR: <%s> not found\n"
+msgid "ERROR: <%s> not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "ERROR: <%s> illegal name\n"
+msgid "ERROR: <%s> illegal name\n"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open toolbox: %s"
+msgid "Cannot open toolbox: %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Cannot open toolbox."
+msgid "Cannot open toolbox."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Vector map(s) -- source for composite"
+msgid "Vector map(s) -- source for composite"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "New vector composite"
+msgid "New vector composite"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Append files to existing file"
+msgid "Append files to existing file"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "No database updates."
-#~ msgstr "データベース"
+msgid "No database updates."
+msgstr "データベース"
 #, fuzzy
-#~ msgid "Adding new features to vector file ..."
+msgid "Adding new features to vector file ..."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Vector map '%s' not found"
-#~ msgstr "���"
+msgid "Vector map '%s' not found"
+msgstr "���"
 #, fuzzy
-#~ msgid "Input elevation file"
-#~ msgstr "標高を示すファイル(入力)"
+msgid "Input elevation file"
+msgstr "標高を示すファイル(入力)"
 #, fuzzy
-#~ msgid "Input aspect file"
+msgid "Input aspect file"
 #, fuzzy
-#~ msgid "Input barrier file"
-#~ msgstr "バリアを示すファイル(入力)"
+msgid "Input barrier file"
+msgstr "バリアを示すファイル(入力)"
 #, fuzzy
-#~ msgid "Quiet operation"
-#~ msgstr "説明なし"
+msgid "Quiet operation"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Display Reference Information"
-#~ msgstr "ヘッダーの表示"
+msgid "Display Reference Information"
+msgstr "ヘッダーの表示"
 #, fuzzy
-#~ msgid ""
-#~ "Aspect file's resolution differs from                        current "
-#~ "region resolution"
-#~ msgstr "値の読みとり間隔(デフォルト:現在の解像度)"
+msgid ""
+"Aspect file's resolution differs from                        current region "
+"resolution"
+msgstr "値の読みとり間隔(デフォルト:現在の解像度)"
 #, fuzzy
-#~ msgid "output layer name"
+msgid "output layer name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Imagery files subgroup"
-#~ msgstr "サブ画像グループ"
+msgid "Imagery files subgroup"
+msgstr "サブ画像グループ"
 #, fuzzy
-#~ msgid "Warning: illegal output file name <%s>."
+msgid "Warning: illegal output file name <%s>."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Category <%d>: Line color and background color are the same!"
-#~ msgstr "���!"
+msgid "Category <%d>: Line color and background color are the same!"
+msgstr "���!"
 #, fuzzy
-#~ msgid "Line color and background color are the same!"
-#~ msgstr "���!"
+msgid "Line color and background color are the same!"
+msgstr "���!"
 #, fuzzy
-#~ msgid "datetime, datetime1/datetime2, or none"
-#~ msgstr "タイムスタンプ"
+msgid "datetime, datetime1/datetime2, or none"
+msgstr "タイムスタンプ"
 #, fuzzy
-#~ msgid "Open vector 3d raster map %s"
+msgid "Open vector 3d raster map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Open 3d raster map %s"
+msgid "Open 3d raster map %s"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Vector import complete"
+msgid "Vector import complete"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "centroid"
-#~ msgstr "座標変換先の楕円体"
+msgid "centroid"
+msgstr "座標変換先の楕円体"
 #, fuzzy
-#~ msgid "Unable to create raster map for [%s]"
+msgid "Unable to create raster map for [%s]"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "error opening 3d raster map"
+msgid "error opening 3d raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Read fp map as integer (use map's quant rules"
-#~ msgstr "実数を整数に変換して使用"
+msgid "Read fp map as integer (use map's quant rules"
+msgstr "実数を整数に変換して使用"
 #, fuzzy
-#~ msgid "Name for the resulting raster map"
+msgid "Name for the resulting raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Open Raster file %s in Mapset %s"
-#~ msgstr "���"
+msgid "Open Raster file %s in Mapset %s"
+msgstr "���"
 #, fuzzy
-#~ msgid "Open 3d raster map %s\n"
+msgid "Open 3d raster map %s\n"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Open elev raster map %s\n"
+msgid "Open elev raster map %s\n"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Could not open map %s\n"
+msgid "Could not open map %s\n"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Bin raster map to be imported"
+msgid "Bin raster map to be imported"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Output partial derivatives instead"
-#~ msgstr "傾斜値、傾斜方位、曲率の代わりに偏導関数を出力"
+msgid "Output partial derivatives instead"
+msgstr "傾斜値、傾斜方位、曲率の代わりに偏導関数を出力"
 #, fuzzy
-#~ msgid "Maximum distance"
-#~ msgstr "最大値"
+msgid "Maximum distance"
+msgstr "最大値"
 #, fuzzy
-#~ msgid "Makes 3D trees from input point vector map"
-#~ msgstr "���"
+msgid "Makes 3D trees from input point vector map"
+msgstr "���"
 #, fuzzy
-#~ msgid "Diameter of the tree crown in map units"
-#~ msgstr "視点座標"
+msgid "Diameter of the tree crown in map units"
+msgstr "視点座標"
 #, fuzzy
-#~ msgid "Height of tree trunk in meters"
-#~ msgstr "地表からの高さ(単位:メートル)"
+msgid "Height of tree trunk in meters"
+msgstr "地表からの高さ(単位:メートル)"
 #, fuzzy
-#~ msgid "Name of the column with tree crown width"
-#~ msgstr "最終レポートを出力するファイル"
+msgid "Name of the column with tree crown width"
+msgstr "最終レポートを出力するファイル"
 #, fuzzy
-#~ msgid "Name of the column with tree species"
+msgid "Name of the column with tree species"
 #, fuzzy
-#~ msgid "Cannot select attributes for point #%d"
+msgid "Cannot select attributes for point #%d"
+msgstr "統一する属性の値"
 #, fuzzy
-#~ msgid "Map coordinates"
-#~ msgstr "Z座標値"
+msgid "Map coordinates"
+msgstr "Z座標値"
 #, fuzzy
-#~ msgid "%s Quit\n"
-#~ msgstr "説明なし"
+msgid "%s Quit\n"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Quiet mode"
-#~ msgstr "説明なし"
+msgid "Quiet mode"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "%s[%d]: No raster map specified."
-#~ msgstr "対象マップ"
+msgid "%s[%d]: No raster map specified."
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Query column name"
-#~ msgstr "キーカラム"
+msgid "Query column name"
+msgstr "キーカラム"
 #, fuzzy
-#~ msgid "name for new binary vector map (omit for display to stdout)"
+msgid "name for new binary vector map (omit for display to stdout)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name for G3d raster map"
+msgid "Name for G3d raster map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "No output maps"
+msgid "No output maps"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Connect to the database through DBMI."
-#~ msgstr "データベースに接続します"
+msgid "Connect to the database through DBMI."
+msgstr "データベースに接続します"
 #, fuzzy
-#~ msgid "The resolution of raster and raster3d maps should be equal!"
+msgid "The resolution of raster and raster3d maps should be equal!"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "top raster map not found\n"
+msgid "top raster map not found\n"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Compute upslope flowlines"
-#~ msgstr "流路を遡って計算"
+msgid "Compute upslope flowlines"
+msgstr "流路を遡って計算"
 #, fuzzy
-#~ msgid "The map E and N grid coordinates of a starting point"
-#~ msgstr "始点の座標値"
+msgid "The map E and N grid coordinates of a starting point"
+msgstr "始点の座標値"
 #, fuzzy
-#~ msgid "Invoke fast, but memory intensive operation"
-#~ msgstr "高速計算(大きなメモリが必要)"
+msgid "Invoke fast, but memory intensive operation"
+msgstr "高速計算(大きなメモリが必要)"
 #, fuzzy
-#~ msgid "You first need to run v.build on vector map <%s>"
-#~ msgstr "���"
+msgid "You first need to run v.build on vector map <%s>"
+msgstr "���"
 #, fuzzy
-#~ msgid "unknown interpolation method"
-#~ msgstr "補間方法"
+msgid "unknown interpolation method"
+msgstr "補間方法"
 #, fuzzy
-#~ msgid "Name of existing raster map."
+msgid "Name of existing raster map."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Name of new raster map."
+msgid "Name of new raster map."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of input map"
+msgid "Name of input map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Name of output map"
+msgid "Name of output map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of existing input raster map"
+msgid "Name of existing input raster map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "cover raster map"
-#~ msgstr "カバーマップ"
+msgid "cover raster map"
+msgstr "カバーマップ"
 #, fuzzy
-#~ msgid "resultant raster map"
+msgid "resultant raster map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Input layer name"
+msgid "Input layer name"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Output layer name"
+msgid "Output layer name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Name of the resulting map"
+msgid "Name of the resulting map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Slope"
-#~ msgstr "傾斜値またはdx値を出力するファイル"
+msgid "Slope"
+msgstr "傾斜値またはdx値を出力するファイル"
 #, fuzzy
-#~ msgid "Aspect"
-#~ msgstr "傾斜方位またはdy値を出力するファイル"
+msgid "Aspect"
+msgstr "傾斜方位またはdy値を出力するファイル"
 #, fuzzy
-#~ msgid "Profile curvature"
-#~ msgstr "断面曲率またはdxx値を出力するファイル"
+msgid "Profile curvature"
+msgstr "断面曲率またはdxx値を出力するファイル"
 #, fuzzy
-#~ msgid "Tangential curvature"
-#~ msgstr "正接曲率またはdyy値を出力するファイル"
+msgid "Tangential curvature"
+msgstr "正接曲率またはdyy値を出力するファイル"
 #, fuzzy
-#~ msgid "Mean curvature"
-#~ msgstr "平均曲率またはdxy値を出力するファイル"
+msgid "Mean curvature"
+msgstr "平均曲率またはdxy値を出力するファイル"
 #, fuzzy
-#~ msgid "Tension"
-#~ msgstr "テンション"
+msgid "Tension"
+msgstr "テンション"
 #, fuzzy
-#~ msgid "Name for ascii output file"
+msgid "Name for ascii output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Enter name for the resulting signature file"
+msgid "Enter name for the resulting signature file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "page length (default: %d lines)"
-#~ msgstr "1ページの行数"
+msgid "page length (default: %d lines)"
+msgstr "1ページの行数"
 #, fuzzy
-#~ msgid "page width (default: %d characters)"
-#~ msgstr "1行の文字数"
+msgid "page width (default: %d characters)"
+msgstr "1行の文字数"
 #, fuzzy
-#~ msgid "suppress page headers"
-#~ msgstr "ヘッダーの削除"
+msgid "suppress page headers"
+msgstr "ヘッダーの削除"
 #, fuzzy
-#~ msgid "use formfeeds between pages"
-#~ msgstr "フォームフィードの使用"
+msgid "use formfeeds between pages"
+msgstr "フォームフィードの使用"
 #, fuzzy
-#~ msgid "scientific format"
-#~ msgstr "出力に指数を使用"
+msgid "scientific format"
+msgstr "出力に指数を使用"
 #, fuzzy
-#~ msgid "Write an Arc-Info line/polygon coverage in e00 format."
-#~ msgstr "ベクトルマップをARC/INFO E00ファイルとしてエクスポートします"
+msgid "Write an Arc-Info line/polygon coverage in e00 format."
+msgstr "ベクトルマップをARC/INFO E00ファイルとしてエクスポートします"
 #, fuzzy
-#~ msgid "Mapset holding vector map to be exported (Default = current)"
-#~ msgstr "入力するファイルを含むマップセット(デフォルト=現在のマップセット)"
+msgid "Mapset holding vector map to be exported (Default = current)"
+msgstr "入力するファイルを含むマップセット(デフォルト=現在のマップセット)"
 #, fuzzy
-#~ msgid "Name of .e00 output file (Default: stdout)"
+msgid "Name of .e00 output file (Default: stdout)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Process spaghetti-digitized binary vector map."
-#~ msgstr "スパゲッティデータ(バイナリー形式)の編集を行います"
+msgid "Process spaghetti-digitized binary vector map."
+msgstr "スパゲッティデータ(バイナリー形式)の編集を行います"
 #, fuzzy
-#~ msgid "Only run identical line tests"
-#~ msgstr "指定したラインのみで実行"
+msgid "Only run identical line tests"
+msgstr "指定したラインのみで実行"
 #, fuzzy
-#~ msgid "Snap nodes"
+msgid "Snap nodes"
+msgstr "端点をスナップ"
 #, fuzzy
-#~ msgid ""
-#~ "Set line types to:   \n"
-#~ "             source        same as in binary vector map\n"
-#~ "             line          lines\n"
-#~ "             area          area edges\n"
-#~ "             point         points (sites)\n"
-#~ msgstr ""
-#~ "線の種類:   \n"
-#~ "             source        元のベクトルマップと同じ\n"
-#~ "             line          ç·š\n"
-#~ "             area          エリアエッジ\n"
-#~ "             point         点(サイトデータ)\n"
+msgid ""
+"Set line types to:   \n"
+"             source        same as in binary vector map\n"
+"             line          lines\n"
+"             area          area edges\n"
+"             point         points (sites)\n"
+msgstr ""
+"線の種類:   \n"
+"             source        元のベクトルマップと同じ\n"
+"             line          ç·š\n"
+"             area          エリアエッジ\n"
+"             point         点(サイトデータ)\n"
 #, fuzzy
-#~ msgid "Output file is ASCII map"
-#~ msgstr "ASCII形式のベクトルマップを出力"
+msgid "Output file is ASCII map"
+msgstr "ASCII形式のベクトルマップを出力"
 #, fuzzy
-#~ msgid "Copy attributes and category files"
-#~ msgstr "属性およびカテゴリーファイルをコピー"
+msgid "Copy attributes and category files"
+msgstr "属性およびカテゴリーファイルをコピー"
 #, fuzzy
-#~ msgid ""
-#~ "Converts point data in a binary GRASS vector map layer into a GRASS "
-#~ "site_lists file."
-#~ msgstr "ベクトルマップからデータを抽出してサイトマップに変換します"
+msgid ""
+"Converts point data in a binary GRASS vector map layer into a GRASS "
+"site_lists file."
+msgstr "ベクトルマップからデータを抽出してサイトマップに変換します"
 #, fuzzy
-#~ msgid "sites file to be made from vector map"
+msgid "sites file to be made from vector map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Use Category NUMERIC data instead of attribute"
-#~ msgstr "属性の代わりに数値データを使用"
+msgid "Use Category NUMERIC data instead of attribute"
+msgstr "属性の代わりに数値データを使用"
 #, fuzzy
-#~ msgid "Use Category TEXT data instead of attribute"
-#~ msgstr "属性の代わりにテキストデータを使用"
+msgid "Use Category TEXT data instead of attribute"
+msgstr "属性の代わりにテキストデータを使用"
 #, fuzzy
-#~ msgid "Test routine for developing MIF import."
-#~ msgstr " ESRI シェープファイルをベクトルマップとしてインポートします"
+msgid "Test routine for developing MIF import."
+msgstr " ESRI シェープファイルをベクトルマップとしてインポートします"
 #, fuzzy
-#~ msgid "Debugging level : 0 (silent) - 3 (verbose)"
-#~ msgstr "デバッグレベル"
+msgid "Debugging level : 0 (silent) - 3 (verbose)"
+msgstr "デバッグレベル"
 #, fuzzy
-#~ msgid "Name of file where to log operations"
-#~ msgstr "ログファイル"
+msgid "Name of file where to log operations"
+msgstr "ログファイル"
 #, fuzzy
-#~ msgid "Snap distance in ground units (Default = 10^-10)"
-#~ msgstr "端点のスナップ距離"
+msgid "Snap distance in ground units (Default = 10^-10)"
+msgstr "端点のスナップ距離"
 #, fuzzy
-#~ msgid "Set initial scale [1:2400]"
-#~ msgstr "スケール"
+msgid "Set initial scale [1:2400]"
+msgstr "スケール"
 #, fuzzy
-#~ msgid "Name of attribute to use as category"
-#~ msgstr "属性番号のフィールド名"
+msgid "Name of attribute to use as category"
+msgstr "属性番号のフィールド名"
 #, fuzzy
-#~ msgid "Allow overwrite of existing vector map with the same name"
-#~ msgstr "上書き"
+msgid "Allow overwrite of existing vector map with the same name"
+msgstr "上書き"
 #, fuzzy
-#~ msgid "Force writing  polygon coverage as a line coverage"
-#~ msgstr "強制インポート"
+msgid "Force writing  polygon coverage as a line coverage"
+msgstr "強制インポート"
 #, fuzzy
-#~ msgid "Create unique value for parts of compound object"
-#~ msgstr "ID番号を属性として使用"
+msgid "Create unique value for parts of compound object"
+msgstr "ID番号を属性として使用"
 #, fuzzy
-#~ msgid "List fields of DBF file"
-#~ msgstr "データベースのフィールド一覧を表示して終了"
+msgid "List fields of DBF file"
+msgstr "データベースのフィールド一覧を表示して終了"
 #, fuzzy
-#~ msgid "new categories table title"
-#~ msgstr "タイトル"
+msgid "new categories table title"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Build topology info (default) OR Edit categories"
-#~ msgstr "トポロジーの構築かカテゴリーの編集"
+msgid "Build topology info (default) OR Edit categories"
+msgstr "トポロジーの構築かカテゴリーの編集"
 #, fuzzy
-#~ msgid "Prompt user for threshold         (Valid only with Build option)"
-#~ msgstr "閾値のユーザ定義"
+msgid "Prompt user for threshold         (Valid only with Build option)"
+msgstr "閾値のユーザ定義"
 #, fuzzy
-#~ msgid "read data into memory"
-#~ msgstr "タイトル"
+msgid "read data into memory"
+msgstr "タイトル"
 #, fuzzy
-#~ msgid "Set map region from data          (Valid only with Build option)"
-#~ msgstr "データから地域を設定"
+msgid "Set map region from data          (Valid only with Build option)"
+msgstr "データから地域を設定"
 #, fuzzy
-#~ msgid "Snap Threshold value       (Valid only with Build option and -s)"
-#~ msgstr "スナップの閾値"
+msgid "Snap Threshold value       (Valid only with Build option and -s)"
+msgstr "スナップの閾値"
 #, fuzzy
-#~ msgid "Suppress drawing of text outlines"
-#~ msgstr "テキストのアウトラインを非表示"
+msgid "Suppress drawing of text outlines"
+msgstr "テキストのアウトラインを非表示"
 #, fuzzy
-#~ msgid "DXF layers with line data"
-#~ msgstr "ラインデータを含むファイル"
+msgid "DXF layers with line data"
+msgstr "ラインデータを含むファイル"
 #, fuzzy
-#~ msgid "DXF layers with label data"
-#~ msgstr "ラベルデータを含むファイル"
+msgid "DXF layers with label data"
+msgstr "ラベルデータを含むファイル"
 #, fuzzy
-#~ msgid "Prefix for dig or dig_ascii and dig_att output files"
+msgid "Prefix for dig or dig_ascii and dig_att output files"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "\n"
-#~ "Where lines and labels are one or more of:\n"
-#~ "\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "ここでのlines,labelsの入力形式は以下の通りです:\n"
-#~ "\n"
+msgid ""
+"\n"
+"\n"
+"Where lines and labels are one or more of:\n"
+"\n"
+msgstr ""
+"\n"
+"\n"
+"ここでのlines,labelsの入力形式は以下の通りです:\n"
+"\n"
 #, fuzzy
-#~ msgid ""
-#~ "      and/or   \n"
-#~ "\n"
-#~ msgstr ""
-#~ "      または   \n"
-#~ "\n"
+msgid ""
+"      and/or   \n"
+"\n"
+msgstr ""
+"      または   \n"
+"\n"
 #, fuzzy
-#~ msgid "angle of rotation"
-#~ msgstr "回転角度"
+msgid "angle of rotation"
+msgstr "回転角度"
 #, fuzzy
-#~ msgid "provide attributes of type: const,rows,cols"
-#~ msgstr "属性タイプ"
+msgid "provide attributes of type: const,rows,cols"
+msgstr "属性タイプ"
 #, fuzzy
-#~ msgid "binary vector map to be converted to ascii"
+msgid "binary vector map to be converted to ascii"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Converts ASCII vector map layers into binary vector map layers."
-#~ msgstr " ASCII形式のファイルをベクトルマップとしてインポートします"
+msgid "Converts ASCII vector map layers into binary vector map layers."
+msgstr " ASCII形式のファイルをベクトルマップとしてインポートします"
 #, fuzzy
-#~ msgid "what load"
-#~ msgstr "更新する対象"
+msgid "what load"
+msgstr "更新する対象"
 #, fuzzy
-#~ msgid "key column"
-#~ msgstr "キーカラム"
+msgid "key column"
+msgstr "キーカラム"
 #, fuzzy
-#~ msgid "Prints information about a binary GRASS vector map layer."
-#~ msgstr "ベクトルマップについての情報を表示します"
+msgid "Prints information about a binary GRASS vector map layer."
+msgstr "ベクトルマップについての情報を表示します"
 #, fuzzy
-#~ msgid "Cleans out dead lines in GRASS vector maps."
-#~ msgstr "ベクトルマップのデータ中で削除マークの付いた線を全て取り除きます"
+msgid "Cleans out dead lines in GRASS vector maps."
+msgstr "ベクトルマップのデータ中で削除マークの付いた線を全て取り除きます"
 #, fuzzy
-#~ msgid "Key (id) column name"
-#~ msgstr "キーカラム"
+msgid "Key (id) column name"
+msgstr "キーカラム"
 #, fuzzy
-#~ msgid "Select area, line, or site "
-#~ msgstr "タイプ"
+msgid "Select area, line, or site "
+msgstr "タイプ"
 #, fuzzy
-#~ msgid "input vector map for ARC/INFO conversion"
+msgid "input vector map for ARC/INFO conversion"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "coverage type"
-#~ msgstr "抽出するタイプ"
+msgid "coverage type"
+msgstr "抽出するタイプ"
 #, fuzzy
-#~ msgid "prefix for ARC/INFO output filenames"
+msgid "prefix for ARC/INFO output filenames"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "The postscript versions of these papers are available via Internet at"
-#~ msgstr "これらの文献はポストスクリプト形式で下のURLから入手できます"
+msgid "The postscript versions of these papers are available via Internet at"
+msgstr "これらの文献はポストスクリプト形式で下のURLから入手できます"
 #, fuzzy
-#~ msgid ""
-#~ "Please cite these references in publications where the results of this"
-#~ msgstr "このプログラムの結果を論文等に公表する場合, "
+msgid "Please cite these references in publications where the results of this"
+msgstr "このプログラムの結果を論文等に公表する場合, "
 #, fuzzy
-#~ msgid "Use category data instead of attribute"
-#~ msgstr "属性の代わりにカテゴリーデータを標高値として出力"
+msgid "Use category data instead of attribute"
+msgstr "属性の代わりにカテゴリーデータを標高値として出力"
 #, fuzzy
-#~ msgid "Do zero attributes/cats represent elevation?"
-#~ msgstr "入力ファイルの値0を標高に置き換える"
+msgid "Do zero attributes/cats represent elevation?"
+msgstr "入力ファイルの値0を標高に置き換える"
 #, fuzzy
-#~ msgid "path to GRASS database of input location"
-#~ msgstr "目的ロケーションを含むデータベース"
+msgid "path to GRASS database of input location"
+msgstr "目的ロケーションを含むデータベース"
 #, fuzzy
-#~ msgid "output vector map"
+msgid "output vector map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Automatically run \"v.support\" on newly created vector map."
-#~ msgstr "'v.support'コマンドを自動的に実行"
+msgid "Automatically run \"v.support\" on newly created vector map."
+msgstr "'v.support'コマンドを自動的に実行"
 #, fuzzy
-#~ msgid "Type of object to extract (area, line or both)"
-#~ msgstr "抽出する線のタイプ"
+msgid "Type of object to extract (area, line or both)"
+msgstr "抽出する線のタイプ"
 #, fuzzy
-#~ msgid "Limit line output to area-edge arcs"
-#~ msgstr "エリアエッジのみ抽出"
+msgid "Limit line output to area-edge arcs"
+msgstr "エリアエッジのみ抽出"
 #, fuzzy
-#~ msgid "Limit line output to line arcs"
-#~ msgstr "線のみ抽出"
+msgid "Limit line output to line arcs"
+msgstr "線のみ抽出"
 #, fuzzy
-#~ msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
-#~ msgstr ""
-#~ "2つの既存するベクトルマップの交差関係にもとづいた演算(ブール代数のANDオー"
-#~ "バーレイ)を行い、新しいマップを作成します"
+msgid "Polygon Cookie Cutter  (Boolean AND Overlay)."
+msgstr ""
+"2つの既存するベクトルマップの交差関係にもとづいた演算(ブール代数のANDオーバー"
+"レイ)を行い、新しいマップを作成します"
 #, fuzzy
-#~ msgid "ARC/INFO ungenerate lines file"
-#~ msgstr "入力するラインファイル"
+msgid "ARC/INFO ungenerate lines file"
+msgstr "入力するラインファイル"
 #, fuzzy
-#~ msgid "ARC/INFO ungenerate label-points file"
-#~ msgstr "入力するラベル(ポイント)ファイル"
+msgid "ARC/INFO ungenerate label-points file"
+msgstr "入力するラベル(ポイント)ファイル"
 #, fuzzy
-#~ msgid "ARC/INFO label-text file"
-#~ msgstr "入力するラベル(テキスト)ファイル"
+msgid "ARC/INFO label-text file"
+msgstr "入力するラベル(テキスト)ファイル"
 #, fuzzy
-#~ msgid "resultant Vector output file"
+msgid "resultant Vector output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "ID Number column in label-text file"
-#~ msgstr "テキストの列数(ID番号)"
+msgid "ID Number column in label-text file"
+msgstr "テキストの列数(ID番号)"
 #, fuzzy
-#~ msgid "GRASS category column in label-text file"
-#~ msgstr "テキストの列数(カテゴリー値)"
+msgid "GRASS category column in label-text file"
+msgstr "テキストの列数(カテゴリー値)"
 #, fuzzy
-#~ msgid "GRASS attribute column in label-text file"
-#~ msgstr "テキストの列数(属性)"
+msgid "GRASS attribute column in label-text file"
+msgstr "テキストの列数(属性)"
 #, fuzzy
-#~ msgid "new pruned vector map"
+msgid "new pruned vector map"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "reports attribute, label, and other information about a sites file"
-#~ msgstr "サイトマップの基礎情報を出力します"
+msgid "reports attribute, label, and other information about a sites file"
+msgstr "サイトマップの基礎情報を出力します"
 #, fuzzy
-#~ msgid "Name of sites file."
-#~ msgstr "対象マップ"
+msgid "Name of sites file."
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Load quietly"
-#~ msgstr "説明なし"
+msgid "Load quietly"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Only count sites in current window for min/max."
-#~ msgstr "最大値と最小値のみ出力"
+msgid "Only count sites in current window for min/max."
+msgstr "最大値と最小値のみ出力"
 #, fuzzy
-#~ msgid "Show quartiles for decimal attributes"
-#~ msgstr "属性番号の出力"
+msgid "Show quartiles for decimal attributes"
+msgstr "属性番号の出力"
 #, fuzzy
-#~ msgid "Name of input sites map"
+msgid "Name of input sites map"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "which decimal attribute (if multiple)"
-#~ msgstr "属性番号"
+msgid "which decimal attribute (if multiple)"
+msgstr "属性番号"
 #, fuzzy
-#~ msgid "Use raster's region vs. current region"
-#~ msgstr "ラスターマップの領域の使用"
+msgid "Use raster's region vs. current region"
+msgstr "ラスターマップの領域の使用"
 #, fuzzy
-#~ msgid "Name of sites file to filter"
-#~ msgstr "入力するファイル(サイト)"
+msgid "Name of sites file to filter"
+msgstr "入力するファイル(サイト)"
 #, fuzzy
-#~ msgid ""
-#~ "Converts a GRASS site list file into an ASCII listing of site locations "
-#~ "and their descriptions."
-#~ msgstr "サイトマップをASCII形式のサイトリストとしてエクスポートします"
+msgid ""
+"Converts a GRASS site list file into an ASCII listing of site locations and "
+"their descriptions."
+msgstr "サイトマップをASCII形式のサイトリストとしてエクスポートします"
 #, fuzzy
-#~ msgid "Include site attributes in the output"
-#~ msgstr "カテゴリーラベルも出力"
+msgid "Include site attributes in the output"
+msgstr "カテゴリーラベルも出力"
 #, fuzzy
-#~ msgid "Include site attribute identifiers in the output"
-#~ msgstr "属性識別子も出力"
+msgid "Include site attribute identifiers in the output"
+msgstr "属性識別子も出力"
 #, fuzzy
-#~ msgid "Name of input site list"
+msgid "Name of input site list"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Number of cells to surround site cell"
-#~ msgstr "考慮する周辺のセル数"
+msgid "Number of cells to surround site cell"
+msgstr "考慮する周辺のセル数"
 #, fuzzy
-#~ msgid "Attribute field type to use for operation"
-#~ msgstr "属性タイプ"
+msgid "Attribute field type to use for operation"
+msgstr "属性タイプ"
 #, fuzzy
-#~ msgid "Attribute field number to use for operation"
-#~ msgstr "属性番号"
+msgid "Attribute field number to use for operation"
+msgstr "属性番号"
 #, fuzzy
-#~ msgid "String attribute number to use for description"
-#~ msgstr "文字型属性番号"
+msgid "String attribute number to use for description"
+msgstr "文字型属性番号"
 #, fuzzy
-#~ msgid "Create a single-valued (0/1) raster map"
-#~ msgstr "0と1のみで構成されるラスターマップを出力"
+msgid "Create a single-valued (0/1) raster map"
+msgstr "0と1のみで構成されるラスターマップを出力"
 #, fuzzy
-#~ msgid ""
-#~ "Average an attribute of a site_list for all the sites within each cell of "
-#~ "the current region."
-#~ msgstr "サイトマップ全体から属性の平均を出力します"
+msgid ""
+"Average an attribute of a site_list for all the sites within each cell of "
+"the current region."
+msgstr "サイトマップ全体から属性の平均を出力します"
 #, fuzzy
-#~ msgid "Attribute to average values over"
-#~ msgstr "属性タイプ"
+msgid "Attribute to average values over"
+msgstr "属性タイプ"
 #, fuzzy
-#~ msgid "Index of attribute type (ignored for cat)"
-#~ msgstr "属性番号"
+msgid "Index of attribute type (ignored for cat)"
+msgstr "属性番号"
 #, fuzzy
-#~ msgid "sites list to store means"
+msgid "sites list to store means"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Suppress windows with zero averages"
-#~ msgstr "データのないセルは出力しない"
+msgid "Suppress windows with zero averages"
+msgstr "データのないセルは出力しない"
 #, fuzzy
-#~ msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
-#~ msgstr "'g.gnuplot'コマンド形式で出力"
+msgid "Output in g.gnuplot format (overrides -z and writes to stdout)"
+msgstr "'g.gnuplot'コマンド形式で出力"
 #, fuzzy
-#~ msgid ""
-#~ "Convert an ASCII listing of site locations into a GRASS site list file."
+msgid "Convert an ASCII listing of site locations into a GRASS site list file."
 #, fuzzy
-#~ msgid "sites file to be created"
+msgid "sites file to be created"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "number of dimensions (default=2)"
-#~ msgstr "配列の数(デフォルト2)"
+msgid "number of dimensions (default=2)"
+msgstr "配列の数(デフォルト2)"
 #, fuzzy
-#~ msgid "input field separator"
-#~ msgstr "区切り"
+msgid "input field separator"
+msgstr "区切り"
 #, fuzzy
-#~ msgid "datetime or datetime1/datetime2"
+msgid "datetime or datetime1/datetime2"
+msgstr "タイムスタンプ"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to re-project a sites file from one location to the "
-#~ "current location (no datum transformation yet)."
-#~ msgstr "サイトマップの投影変換を行います"
+msgid ""
+"Allows the user to re-project a sites file from one location to the current "
+"location (no datum transformation yet)."
+msgstr "サイトマップの投影変換を行います"
 #, fuzzy
-#~ msgid "input sites list"
+msgid "input sites list"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "location of input sites list"
-#~ msgstr "再投影を行うロケーション"
+msgid "location of input sites list"
+msgstr "再投影を行うロケーション"
 #, fuzzy
-#~ msgid "mapset of input sites list"
-#~ msgstr "目的ファイルを含むマップセット"
+msgid "mapset of input sites list"
+msgstr "目的ファイルを含むマップセット"
 #, fuzzy
-#~ msgid "output sites list"
+msgid "output sites list"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "List sites files in input location and exit"
-#~ msgstr "目的ロケーション内のサイトマップ一覧表示"
+msgid "List sites files in input location and exit"
+msgstr "目的ロケーション内のサイトマップ一覧表示"
 #, fuzzy
-#~ msgid "Don't prompt for Map header information"
-#~ msgstr "ヘッダーを削除"
+msgid "Don't prompt for Map header information"
+msgstr "ヘッダーを削除"
 #, fuzzy
-#~ msgid ""
-#~ "Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
-#~ "category value (uses \"cat\" by default)"
-#~ msgstr "属性タイプまたは属性番号"
+msgid ""
+"Field type (\"string\", \"dim\", or \"decimal\") and index to use for "
+"category value (uses \"cat\" by default)"
+msgstr "属性タイプまたは属性番号"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to interactively adjust the settings (zoom  and  pan) of "
-#~ "the current geographic region using a pointing device such as a mouse."
-#~ msgstr "対象地域のズーム/パンをマウスにより行います"
+msgid ""
+"Allows the user to interactively adjust the settings (zoom  and  pan) of the "
+"current geographic region using a pointing device such as a mouse."
+msgstr "対象地域のズーム/パンをマウスにより行います"
 #, fuzzy
-#~ msgid "Color of lines separating the colors of the color table"
-#~ msgstr "セパレータの色"
+msgid "Color of lines separating the colors of the color table"
+msgstr "セパレータの色"
 #, fuzzy
-#~ msgid ""
-#~ "Displays points, as icons, at user-defined locations in the active "
-#~ "display frame on the graphics monitor."
-#~ msgstr "アイコンでポイントマーカーを表示します"
+msgid ""
+"Displays points, as icons, at user-defined locations in the active display "
+"frame on the graphics monitor."
+msgstr "アイコンでポイントマーカーを表示します"
 #, fuzzy
-#~ msgid "Name of existing sites file"
-#~ msgstr "対象マップ"
+msgid "Name of existing sites file"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid "Identify just one site"
-#~ msgstr "1度のみ実行"
+msgid "Identify just one site"
+msgstr "1度のみ実行"
 #, fuzzy
-#~ msgid "For parsing by programs: Terse output"
-#~ msgstr "簡易表示"
+msgid "For parsing by programs: Terse output"
+msgstr "簡易表示"
 #, fuzzy
-#~ msgid "Allows the user to interactively query site list descriptions. "
-#~ msgstr ""
-#~ "マウスで指定した位置でのサイトマップのカテゴリー情報を表示します(ここはど"
-#~ "こ?なに?)"
+msgid "Allows the user to interactively query site list descriptions. "
+msgstr ""
+"マウスで指定した位置でのサイトマップのカテゴリー情報を表示します(ここはどこ?"
+"なに?)"
 #, fuzzy
-#~ msgid "Color to erase with"
-#~ msgstr "塗りつぶす色"
+msgid "Color to erase with"
+msgstr "塗りつぶす色"
 #, fuzzy
-#~ msgid "Name of a spheroid (for lat/lon coordinate conversion)"
-#~ msgstr "変換先の楕円体"
+msgid "Name of a spheroid (for lat/lon coordinate conversion)"
+msgstr "変換先の楕円体"
 #, fuzzy
-#~ msgid "Displays three-dimensional images based on raster map layers"
-#~ msgstr "ラスターマップを3次元で表示します"
+msgid "Displays three-dimensional images based on raster map layers"
+msgstr "ラスターマップを3次元で表示します"
 #, fuzzy
-#~ msgid "The raster map used to generate the color"
-#~ msgstr "色のラスターマップ"
+msgid "The raster map used to generate the color"
+msgstr "色のラスターマップ"
 #, fuzzy
-#~ msgid "The raster map used to generate the 3-d texture"
-#~ msgstr "標高のラスターマップ"
+msgid "The raster map used to generate the 3-d texture"
+msgstr "標高のラスターマップ"
 #, fuzzy
-#~ msgid "coordinates of center of view"
-#~ msgstr "視野の中心座標"
+msgid "coordinates of center of view"
+msgstr "視野の中心座標"
 #, fuzzy
-#~ msgid "Frequency of vector lines in output"
-#~ msgstr "格子間隔"
+msgid "Frequency of vector lines in output"
+msgstr "格子間隔"
 #, fuzzy
-#~ msgid "Field of view"
-#~ msgstr "視野の角度"
+msgid "Field of view"
+msgstr "視野の角度"
 #, fuzzy
-#~ msgid "Color of bounding box"
-#~ msgstr "枠の色"
+msgid "Color of bounding box"
+msgstr "枠の色"
 #, fuzzy
-#~ msgid "Show null elevations"
-#~ msgstr "NULL値を表示"
+msgid "Show null elevations"
+msgstr "NULL値を表示"
 #, fuzzy
-#~ msgid "Draw labelled vector lines to the current display device"
-#~ msgstr "ベクトルラインを表示します"
+msgid "Draw labelled vector lines to the current display device"
+msgstr "ベクトルラインを表示します"
 #, fuzzy
-#~ msgid "Name of existing vector map to draw"
-#~ msgstr "対象マップ"
+msgid "Name of existing vector map to draw"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid ""
-#~ "Draw all lines using either a GRASS standard color or R:G:B triplet "
-#~ "(separated by colons)"
-#~ msgstr "線の色"
+msgid ""
+"Draw all lines using either a GRASS standard color or R:G:B triplet "
+"(separated by colons)"
+msgstr "線の色"
 #, fuzzy
-#~ msgid ""
-#~ "Only draw areas with a matching category number (for constant color "
-#~ "option only)"
-#~ msgstr "表示するカテゴリー番号"
+msgid ""
+"Only draw areas with a matching category number (for constant color option "
+"only)"
+msgstr "表示するカテゴリー番号"
 #, fuzzy
-#~ msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
-#~ msgstr "凡例用ファイル"
+msgid "Draw lines according to a legend file (<cat> <R> <G> <B>)"
+msgstr "凡例用ファイル"
 #, fuzzy
-#~ msgid "Use random colors"
-#~ msgstr "ランダムな色を使用"
+msgid "Use random colors"
+msgstr "ランダムな色を使用"
 #, fuzzy
-#~ msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "塗りつぶす色"
+msgid "Fill color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "塗りつぶす色"
 #, fuzzy
-#~ msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
-#~ msgstr "境界線の色"
+msgid "Line color -- a GRASS named color, an R:G:B triplet, or \"none\""
+msgstr "境界線の色"
 #, fuzzy
-#~ msgid "Limit to matching category number(s) (constant color option only)"
-#~ msgstr "表示するカテゴリー番号(色が指定されているときのみ有効)"
+msgid "Limit to matching category number(s) (constant color option only)"
+msgstr "表示するカテゴリー番号(色が指定されているときのみ有効)"
 #, fuzzy
-#~ msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
+msgid "Use a legend file: (<cat> <R> <G> <B> [<R> <G> <B>])"
+msgstr "凡例用ファイル"
 #, fuzzy
-#~ msgid "Sets the current color to that stated"
-#~ msgstr "色"
+msgid "Sets the current color to that stated"
+msgstr "色"
 #, fuzzy
-#~ msgid "Size, in pixels, in which the icon is to be drawn"
-#~ msgstr "アイコンのサイズ(ピクセル)"
+msgid "Size, in pixels, in which the icon is to be drawn"
+msgstr "アイコンのサイズ(ピクセル)"
 #, fuzzy
-#~ msgid ""
-#~ "Interactively label sites using a string or double attribute value or the "
-#~ "category value on the current graphics monitor."
-#~ msgstr "サイトラベルを表示します"
+msgid ""
+"Interactively label sites using a string or double attribute value or the "
+"category value on the current graphics monitor."
+msgstr "サイトラベルを表示します"
 #, fuzzy
-#~ msgid "Name of sites file"
+msgid "Name of sites file"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Index of attribute. Ignored when attr=cat or attr=coords."
-#~ msgstr "属性番号"
+msgid "Index of attribute. Ignored when attr=cat or attr=coords."
+msgstr "属性番号"
 #, fuzzy
-#~ msgid "Relative horizontal position 'left|center|right'"
-#~ msgstr "位置(水平方向)"
+msgid "Relative horizontal position 'left|center|right'"
+msgstr "位置(水平方向)"
 #, fuzzy
-#~ msgid "Relative vertical position 'top|center|bottom'"
-#~ msgstr "位置(鉛直方向)"
+msgid "Relative vertical position 'top|center|bottom'"
+msgstr "位置(鉛直方向)"
 #, fuzzy
-#~ msgid "Size of text (pixels)"
-#~ msgstr "テキストのサイズ"
+msgid "Size of text (pixels)"
+msgstr "テキストのサイズ"
 #, fuzzy
-#~ msgid "Sets the font"
-#~ msgstr "フォント"
+msgid "Sets the font"
+msgstr "フォント"
 #, fuzzy
-#~ msgid "Sets the current grid color"
-#~ msgstr "線の色"
+msgid "Sets the current grid color"
+msgstr "線の色"
 #, fuzzy
-#~ msgid ""
-#~ "displays vector maps, optionally only selected categories in current "
-#~ "monitor window."
-#~ msgstr "ベクトルマップを表示します"
+msgid ""
+"displays vector maps, optionally only selected categories in current monitor "
+"window."
+msgstr "ベクトルマップを表示します"
 #, fuzzy
-#~ msgid "Vector category number(s) to be displayed"
+msgid "Vector category number(s) to be displayed"
 #, fuzzy
-#~ msgid "Fill areas of selected polygons"
-#~ msgstr "選択したカテゴリー番号の領域を塗りつぶす"
+msgid "Fill areas of selected polygons"
+msgstr "選択したカテゴリー番号の領域を塗りつぶす"
 #, fuzzy
-#~ msgid "Input is a UNIX file name"
+msgid "Input is a UNIX file name"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Allows the user to establish whether a map will be displayed using its "
-#~ "own color table or the fixed color table of the graphics monitor."
-#~ msgstr "モニターに用いるカラーテーブルを設定します"
+msgid ""
+"Allows the user to establish whether a map will be displayed using its own "
+"color table or the fixed color table of the graphics monitor."
+msgstr "モニターに用いるカラーテーブルを設定します"
 #, fuzzy
-#~ msgid ""
-#~ "Displays the rhumbline joining two user-specified points, in the active "
-#~ "frame on the user's graphics monitor."
-#~ msgstr "指定した2地点を結ぶ航程線を描きます"
+msgid ""
+"Displays the rhumbline joining two user-specified points, in the active "
+"frame on the user's graphics monitor."
+msgstr "指定した2地点を結ぶ航程線を描きます"
 #, fuzzy
-#~ msgid "Creates and modifies icons for use with ps.map."
-#~ msgstr "ポストスクリプトマップに使用するアイコンの作成/編集を行います"
+msgid "Creates and modifies icons for use with ps.map."
+msgstr "ポストスクリプトマップに使用するアイコンの作成/編集を行います"
 #, fuzzy
-#~ msgid "icon filename"
+msgid "icon filename"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "file containing mapping instructions (or use input=- to enter from "
-#~ "keyboard)"
-#~ msgstr "設定ファイル"
+msgid ""
+"file containing mapping instructions (or use input=- to enter from keyboard)"
+msgstr "設定ファイル"
 #, fuzzy
-#~ msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
-#~ msgstr "スケール (例: 1:25000)"
+msgid "scale of the output map, e.g. 1:25000 (default: 1panel)"
+msgstr "スケール (例: 1:25000)"
 #, fuzzy
-#~ msgid "number of copies to print"
-#~ msgstr "部数"
+msgid "number of copies to print"
+msgstr "部数"
 #, fuzzy
-#~ msgid "Selects a PostScript device for GRASS hardcopy output."
-#~ msgstr "ハードコピーを出力するデバイスを選択します"
+msgid "Selects a PostScript device for GRASS hardcopy output."
+msgstr "ハードコピーを出力するデバイスを選択します"
 #, fuzzy
-#~ msgid "name of PostScript painter to select"
-#~ msgstr "使用するデバイス"
+msgid "name of PostScript painter to select"
+msgstr "使用するデバイス"
 #, fuzzy
-#~ msgid "list all available PostScript painters"
-#~ msgstr "ポストスクリプトペインタの一覧表示"
+msgid "list all available PostScript painters"
+msgstr "ポストスクリプトペインタの一覧表示"
 #, fuzzy
-#~ msgid "print name of currently selected PostScript painter"
-#~ msgstr "現在選択されているペインタ名を表示"
+msgid "print name of currently selected PostScript painter"
+msgstr "現在選択されているペインタ名を表示"
 #, fuzzy
-#~ msgid "quietly select PostScript painter"
-#~ msgstr "説明なし"
+msgid "quietly select PostScript painter"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Creates raster maps from ERDAS files."
-#~ msgstr "ERDAS/LANファイルをラスターマップとしてインポートします"
+msgid "Creates raster maps from ERDAS files."
+msgstr "ERDAS/LANファイルをラスターマップとしてインポートします"
 #, fuzzy
-#~ msgid "List the ERDAS header only"
-#~ msgstr "ヘッダーのみ一覧表示"
+msgid "List the ERDAS header only"
+msgstr "ヘッダーのみ一覧表示"
 #, fuzzy
-#~ msgid "Disable autoswap detection"
-#~ msgstr "自動でビット反転しない"
+msgid "Disable autoswap detection"
+msgstr "自動でビット反転しない"
 #, fuzzy
-#~ msgid "Force Swapping (overrides default auto)"
-#~ msgstr "強制ビット反転"
+msgid "Force Swapping (overrides default auto)"
+msgstr "強制ビット反転"
 #, fuzzy
-#~ msgid "output prefix of the GRASS raster maps to be created."
+msgid "output prefix of the GRASS raster maps to be created."
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Erdas trailer input file name"
-#~ msgstr "ERDASトレイラーファイル"
+msgid "Erdas trailer input file name"
+msgstr "ERDASトレイラーファイル"
 #, fuzzy
-#~ msgid "Starting row."
-#~ msgstr "開始行"
+msgid "Starting row."
+msgstr "開始行"
 #, fuzzy
-#~ msgid "Starting column."
-#~ msgstr "開始列"
+msgid "Starting column."
+msgstr "開始列"
 #, fuzzy
-#~ msgid "Number of columns to extract."
-#~ msgstr "抽出する列数"
+msgid "Number of columns to extract."
+msgstr "抽出する列数"
 #, fuzzy
-#~ msgid "Creates ERDAS files from raster maps."
-#~ msgstr "GRASSの画像ファイルをERDAS/LANファイルとしてエクスポートします"
+msgid "Creates ERDAS files from raster maps."
+msgstr "GRASSの画像ファイルをERDAS/LANファイルとしてエクスポートします"
 #, fuzzy
-#~ msgid "Output 16-bit image (default 8)"
-#~ msgstr "16bitイメージで出力"
+msgid "Output 16-bit image (default 8)"
+msgstr "16bitイメージで出力"
 #, fuzzy
-#~ msgid "Force byte swapping"
+msgid "Force byte swapping"
+msgstr "強制ビット反転"
 #, fuzzy
-#~ msgid "Erdas output file name"
+msgid "Erdas output file name"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "maximum number of sub-signatures in any class"
-#~ msgstr "サブシグネチャの最大値"
+msgid "maximum number of sub-signatures in any class"
+msgstr "サブシグネチャの最大値"
 #, fuzzy
-#~ msgid "Generate statistics for i.smap from raster map layer."
-#~ msgstr "'i.smap'用のファイルを非対話形式で作成します"
+msgid "Generate statistics for i.smap from raster map layer."
+msgstr "'i.smap'用のファイルを非対話形式で作成します"
 #, fuzzy
-#~ msgid ""
-#~ "Allows category values from several raster map layers to be combined."
-#~ msgstr "ラスターマップのカテゴリー値を論理操作します"
+msgid "Allows category values from several raster map layers to be combined."
+msgstr "ラスターマップのカテゴリー値を論理操作します"
 #, fuzzy
-#~ msgid "Use symbols (instead of graphics)"
-#~ msgstr "シンボルを使用"
+msgid "Use symbols (instead of graphics)"
+msgstr "シンボルを使用"
 #, fuzzy
-#~ msgid "Import non-georeferenced PNG format image."
-#~ msgstr "PNGファイルをラスターマップとしてインポートします"
+msgid "Import non-georeferenced PNG format image."
+msgstr "PNGファイルをラスターマップとしてインポートします"
 #, fuzzy
-#~ msgid "Create floating-point maps (0.0 - 1.0)."
-#~ msgstr "実数形式のマップを作成"
+msgid "Create floating-point maps (0.0 - 1.0)."
+msgstr "実数形式のマップを作成"
 #, fuzzy
-#~ msgid "Output image file header only."
-#~ msgstr "ヘッダーのみ出力"
+msgid "Output image file header only."
+msgstr "ヘッダーのみ出力"
 #, fuzzy
-#~ msgid "Verbose mode on."
-#~ msgstr "説明付き表示"
+msgid "Verbose mode on."
+msgstr "説明付き表示"
 #, fuzzy
-#~ msgid "Enable extend memory option: Operation is slow"
-#~ msgstr "仮想メモリを使用"
+msgid "Enable extend memory option: Operation is slow"
+msgstr "仮想メモリを使用"
 #, fuzzy
-#~ msgid "Name of an output binary map (use out=- for stdout)"
+msgid "Name of an output binary map (use out=- for stdout)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Converts point data in a GRASS raster map layer into a GRASS site_lists "
-#~ "file."
-#~ msgstr "ラスターマップからデータを抽出してサイトマップに変換します"
+msgid ""
+"Converts point data in a GRASS raster map layer into a GRASS site_lists file."
+msgstr "ラスターマップからデータを抽出してサイトマップに変換します"
 #, fuzzy
-#~ msgid "Output as decimal attribute rather than cat"
-#~ msgstr "属性番号として出力"
+msgid "Output as decimal attribute rather than cat"
+msgstr "属性番号として出力"
 #, fuzzy
-#~ msgid "Output as third dimension rather than cat"
-#~ msgstr "標高値として出力"
+msgid "Output as third dimension rather than cat"
+msgstr "標高値として出力"
 #, fuzzy
-#~ msgid "Name of raster map."
+msgid "Name of raster map."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "Creates a new binary GRASS vector (v.digit) file by extracting linear "
-#~ "features from a thinned raster map."
-#~ msgstr "細線化したラスターマップからベクトルマップを作成します"
+msgid ""
+"Creates a new binary GRASS vector (v.digit) file by extracting linear "
+"features from a thinned raster map."
+msgstr "細線化したラスターマップからベクトルマップを作成します"
 #, fuzzy
-#~ msgid "Line type of the extracted vectors"
-#~ msgstr "出力タイプ"
+msgid "Line type of the extracted vectors"
+msgstr "出力タイプ"
 #, fuzzy
-#~ msgid ""
-#~ "Creates a raster map layer and site list file containing randomly located "
-#~ "sites."
-#~ msgstr "任意抽出を行います"
+msgid ""
+"Creates a raster map layer and site list file containing randomly located "
+"sites."
+msgstr "任意抽出を行います"
 #, fuzzy
-#~ msgid "Name of the output sites map"
-#~ msgstr "出力するファイル(サイトマップ)"
+msgid "Name of the output sites map"
+msgstr "出力するファイル(サイトマップ)"
 #, fuzzy
-#~ msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
-#~ msgstr "TIFFファイルをラスターマップとしてインポートします"
+msgid "Imports a TIFF (8 or 24 bit) raster map into GRASS raster map(s)"
+msgstr "TIFFファイルをラスターマップとしてインポートします"
 #, fuzzy
-#~ msgid "Name on TIFF file to input."
-#~ msgstr "入力するファイル"
+msgid "Name on TIFF file to input."
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "Bayesian expert system development program."
-#~ msgstr ""
-#~ "ベイズの統計に基づいた推論規則を適用し新しいラスターマップを作成します"
+msgid "Bayesian expert system development program."
+msgstr "ベイズの統計に基づいた推論規則を適用し新しいラスターマップを作成します"
 #, fuzzy
-#~ msgid "Run verbosely with debugging output"
-#~ msgstr "説明付き表示"
+msgid "Run verbosely with debugging output"
+msgstr "説明付き表示"
 #, fuzzy
-#~ msgid "The site list"
-#~ msgstr "出力:クランプの重心を示すファイル"
+msgid "The site list"
+msgstr "出力:クランプの重心を示すファイル"
 #, fuzzy
-#~ msgid "raster map(s) to report on"
-#~ msgstr "対象マップ"
+msgid "raster map(s) to report on"
+msgstr "対象マップ"
 #, fuzzy
-#~ msgid ""
-#~ "mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
-#~ "(ercent_cover)"
-#~ msgstr "単位"
+msgid ""
+"mi(les),me(ters),k(ilometers),a(cres),h(ectacres),c(ell_counts),p"
+"(ercent_cover)"
+msgstr "単位"
 #, fuzzy
-#~ msgid "name of an output file to hold the report"
-#~ msgstr "出力するファイル"
+msgid "name of an output file to hold the report"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "number of fp subranges to collect stats from"
-#~ msgstr "誤差の桁数"
+msgid "number of fp subranges to collect stats from"
+msgstr "誤差の桁数"
 #, fuzzy
-#~ msgid "filter out all no data cells"
-#~ msgstr "NULL値を対象に含まない"
+msgid "filter out all no data cells"
+msgstr "NULL値を対象に含まない"
 #, fuzzy
-#~ msgid "filter out cells where all maps have no data"
-#~ msgstr "すべてのマップでNULL値となっているセルを除く"
+msgid "filter out cells where all maps have no data"
+msgstr "すべてのマップでNULL値となっているセルを除く"
 #, fuzzy
-#~ msgid "report for cats fp ranges (fp maps only)"
-#~ msgstr "実数でレポートを出力"
+msgid "report for cats fp ranges (fp maps only)"
+msgstr "実数でレポートを出力"
 #, fuzzy
-#~ msgid ""
-#~ "Generates an output raster map layer with contiguous areas grown by one "
-#~ "cell (pixel)."
-#~ msgstr "エリアを拡大したラスターマップを作成します"
+msgid ""
+"Generates an output raster map layer with contiguous areas grown by one cell "
+"(pixel)."
+msgstr "エリアを拡大したラスターマップを作成します"
 #, fuzzy
-#~ msgid ""
-#~ "re-project a raster map from one location to the current location (no "
-#~ "datum transformation yet)"
-#~ msgstr "ラスターマップの投影変換を行います"
+msgid ""
+"re-project a raster map from one location to the current location (no datum "
+"transformation yet)"
+msgstr "ラスターマップの投影変換を行います"
 #, fuzzy
-#~ msgid "mapset of input map"
+msgid "mapset of input map"
 #, fuzzy
-#~ msgid "resolution of output map"
-#~ msgstr "解像度"
+msgid "resolution of output map"
+msgstr "解像度"
 #, fuzzy
-#~ msgid "Don't attempt to crop output map"
-#~ msgstr "投影後の不要部分を削除しない"
+msgid "Don't attempt to crop output map"
+msgstr "投影後の不要部分を削除しない"
 #, fuzzy
-#~ msgid "Print grid coordinates (east and north) (requires -1 flag)"
-#~ msgstr "格子点の座標を出力"
+msgid "Print grid coordinates (east and north) (requires -1 flag)"
+msgstr "格子点の座標を出力"
 #, fuzzy
-#~ msgid "output is the interpolation error"
-#~ msgstr "誤差を出力"
+msgid "output is the interpolation error"
+msgstr "誤差を出力"
 #, fuzzy
-#~ msgid "read fp map as integer"
+msgid "read fp map as integer"
 #, fuzzy
-#~ msgid "format for reporting the slope"
-#~ msgstr "傾斜の単位"
+msgid "format for reporting the slope"
+msgstr "傾斜の単位"
 #, fuzzy
-#~ msgid "type of output aspect and slope maps"
-#~ msgstr "出力する値の型"
+msgid "type of output aspect and slope maps"
+msgstr "出力する値の型"
 #, fuzzy
-#~ msgid "Output E-W slope filename"
-#~ msgstr "東西方向の傾斜を出力するファイル"
+msgid "Output E-W slope filename"
+msgstr "東西方向の傾斜を出力するファイル"
 #, fuzzy
-#~ msgid "Output N-S slope filename"
-#~ msgstr "南北方向の傾斜を出力するファイル"
+msgid "Output N-S slope filename"
+msgstr "南北方向の傾斜を出力するファイル"
 #, fuzzy
-#~ msgid "Output partial derivative dxx filename"
-#~ msgstr "dxx値の偏導関数を出力するファイル"
+msgid "Output partial derivative dxx filename"
+msgstr "dxx値の偏導関数を出力するファイル"
 #, fuzzy
-#~ msgid "Output partial derivative dyy filename"
-#~ msgstr "dyy値の偏導関数を出力するファイル"
+msgid "Output partial derivative dyy filename"
+msgstr "dyy値の偏導関数を出力するファイル"
 #, fuzzy
-#~ msgid "Output partial derivative dxy filename"
-#~ msgstr "dxy値の偏導関数を出力するファイル"
+msgid "Output partial derivative dxy filename"
+msgstr "dxy値の偏導関数を出力するファイル"
 #, fuzzy
-#~ msgid "Name of file for output (use out=- for stdout)"
+msgid "Name of file for output (use out=- for stdout)"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "print range only."
+msgid "print range only."
 #, fuzzy
-#~ msgid ""
-#~ "Converts raster data referenced using latitude and longitude coordinates "
-#~ "to a UTM-referenced map layer in GRASS raster format."
-#~ msgstr "緯度/経度座標ファイルから UTM座標ファイルを作成します"
+msgid ""
+"Converts raster data referenced using latitude and longitude coordinates to "
+"a UTM-referenced map layer in GRASS raster format."
+msgstr "緯度/経度座標ファイルから UTM座標ファイルを作成します"
 #, fuzzy
-#~ msgid "input file"
+msgid "input file"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid ""
-#~ "one corner latitude and longitude of the input\n"
-#~ "format: {nw|ne|sw|se},%s,%s"
-#~ msgstr "領域の端の座標値 入力形式: {nw|ne|sw|se},%s,%s"
+msgid ""
+"one corner latitude and longitude of the input\n"
+"format: {nw|ne|sw|se},%s,%s"
+msgstr "領域の端の座標値 入力形式: {nw|ne|sw|se},%s,%s"
 #, fuzzy
-#~ msgid "resolution of the input (in arc seconds)"
-#~ msgstr "解像度(秒角)"
+msgid "resolution of the input (in arc seconds)"
+msgstr "解像度(秒角)"
 #, fuzzy
-#~ msgid "Starting points site file"
-#~ msgstr "始点を示すサイトマップ"
+msgid "Starting points site file"
+msgstr "始点を示すサイトマップ"
 #, fuzzy
-#~ msgid "Stop points site file"
-#~ msgstr "終点を示すサイトマップ"
+msgid "Stop points site file"
+msgstr "終点を示すサイトマップ"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts area edges from a raster map layer and converts data to GRASS "
-#~ "vector format."
-#~ msgstr "ラスターマップからエリアエッジを抽出してベクトルマップを作成します"
+msgid ""
+"Extracts area edges from a raster map layer and converts data to GRASS "
+"vector format."
+msgstr "ラスターマップからエリアエッジを抽出してベクトルマップを作成します"
 #, fuzzy
-#~ msgid "Output only area borders as vector lines"
-#~ msgstr "ベクトルラインを出力"
+msgid "Output only area borders as vector lines"
+msgstr "ベクトルラインを出力"
 #, fuzzy
-#~ msgid "Number of values printed before wrapping a line"
-#~ msgstr "読み込む桁数"
+msgid "Number of values printed before wrapping a line"
+msgstr "読み込む桁数"
 #, fuzzy
-#~ msgid "raster map name from which to copy color table"
-#~ msgstr "カラーテーブルに用いるラスターマップ"
+msgid "raster map name from which to copy color table"
+msgstr "カラーテーブルに用いるラスターマップ"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Where color type is one of:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "ここでのカラーテーブル(colorパラメータ)は次のうちのいずれかです:\n"
+msgid ""
+"\n"
+"Where color type is one of:\n"
+msgstr ""
+"\n"
+"ここでのカラーテーブル(colorパラメータ)は次のうちのいずれかです:\n"
 #, fuzzy
-#~ msgid "  aspect    (aspect oriented grey colors)\n"
-#~ msgstr "  aspect    (グレーカラー)\n"
+msgid "  aspect    (aspect oriented grey colors)\n"
+msgstr "  aspect    (グレーカラー)\n"
 #, fuzzy
-#~ msgid "  grey      (linear grey scale)\n"
-#~ msgstr "  grey      (グレースケール)\n"
+msgid "  grey      (linear grey scale)\n"
+msgstr "  grey      (グレースケール)\n"
 #, fuzzy
-#~ msgid "  grey.eq   (histogram equalized grey scale)\n"
-#~ msgstr "  grey.eq   (ヒストグラムを平滑化したグレースケール)\n"
+msgid "  grey.eq   (histogram equalized grey scale)\n"
+msgstr "  grey.eq   (ヒストグラムを平滑化したグレースケール)\n"
 #, fuzzy
-#~ msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
-#~ msgstr "  grey.log  (ヒストグラムを対数化したグレースケール)\n"
+msgid "  grey.log  (histogram logarithmic transformed grey scale)\n"
+msgstr "  grey.log  (ヒストグラムを対数化したグレースケール)\n"
 #, fuzzy
-#~ msgid "  byg       (blue through yellow to green colors)\n"
-#~ msgstr "  byg       (青→黄→緑)\n"
+msgid "  byg       (blue through yellow to green colors)\n"
+msgstr "  byg       (青→黄→緑)\n"
 #, fuzzy
-#~ msgid "  byr       (blue through yellow to red colors)\n"
-#~ msgstr "  byr       (青→黄→赤)\n"
+msgid "  byr       (blue through yellow to red colors)\n"
+msgstr "  byr       (青→黄→赤)\n"
 #, fuzzy
-#~ msgid "  gyr       (green through yellow to red colors)\n"
-#~ msgstr "  gyr       (緑→黄→赤)\n"
+msgid "  gyr       (green through yellow to red colors)\n"
+msgstr "  gyr       (緑→黄→赤)\n"
 #, fuzzy
-#~ msgid "  rainbow   (rainbow color table)\n"
-#~ msgstr "  rainbow   (レインボー)\n"
+msgid "  rainbow   (rainbow color table)\n"
+msgstr "  rainbow   (レインボー)\n"
 #, fuzzy
-#~ msgid "  ramp      (color ramp)\n"
-#~ msgstr "  ramp      (ランプ)\n"
+msgid "  ramp      (color ramp)\n"
+msgstr "  ramp      (ランプ)\n"
 #, fuzzy
-#~ msgid "  ryg       (red through yellow to green colors)\n"
-#~ msgstr "  ryg       (赤→黄→緑)\n"
+msgid "  ryg       (red through yellow to green colors)\n"
+msgstr "  ryg       (赤→黄→緑)\n"
 #, fuzzy
-#~ msgid "  random    (random color table)\n"
-#~ msgstr "  random    (ランダム)\n"
+msgid "  random    (random color table)\n"
+msgstr "  random    (ランダム)\n"
 #, fuzzy
-#~ msgid "  wave      (color wave)\n"
-#~ msgstr "  wave      (カラーウェーブ)\n"
+msgid "  wave      (color wave)\n"
+msgstr "  wave      (カラーウェーブ)\n"
 #, fuzzy
-#~ msgid "  rules     (create new color table by rules)\n"
-#~ msgstr "  rules     (ルールの新規作成)\n"
+msgid "  rules     (create new color table by rules)\n"
+msgstr "  rules     (ルールの新規作成)\n"
 #, fuzzy
-#~ msgid "method of object-based statistic"
-#~ msgstr "統計解析方法"
+msgid "method of object-based statistic"
+msgstr "統計解析方法"
 #, fuzzy
-#~ msgid "resultant raster map (not used with 'distribution')"
+msgid "resultant raster map (not used with 'distribution')"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Northern limit of geographic region"
-#~ msgstr "領域の北端"
+msgid "Northern limit of geographic region"
+msgstr "領域の北端"
 #, fuzzy
-#~ msgid "Eastern limit of geographic region"
-#~ msgstr "領域の東端"
+msgid "Eastern limit of geographic region"
+msgstr "領域の東端"
 #, fuzzy
-#~ msgid "Western limit of geographic region"
-#~ msgstr "領域の西端"
+msgid "Western limit of geographic region"
+msgstr "領域の西端"
 #, fuzzy
-#~ msgid "Override projection (use locations projection)"
-#~ msgstr "現在のロケーションの投影法を使用"
+msgid "Override projection (use locations projection)"
+msgstr "現在のロケーションの投影法を使用"
 #, fuzzy
-#~ msgid "Extend location extents based on new dataset."
-#~ msgstr "データセットをもとにロケーションを拡張"
+msgid "Extend location extents based on new dataset."
+msgstr "データセットをもとにロケーションを拡張"
 #, fuzzy
-#~ msgid "Maximum magnitude of random grid point offset"
-#~ msgstr "ランダムにとるオフセットの最大値"
+msgid "Maximum magnitude of random grid point offset"
+msgstr "ランダムにとるオフセットの最大値"
 #, fuzzy
-#~ msgid ""
-#~ "Outputs a raster map layer whose category values represent the "
-#~ "application of user-specified criteria (rules statements) to other raster "
-#~ "map layers' category values."
-#~ msgstr "指定した推論規則を適用し新しいラスターマップを作成します"
+msgid ""
+"Outputs a raster map layer whose category values represent the application "
+"of user-specified criteria (rules statements) to other raster map layers' "
+"category values."
+msgstr "指定した推論規則を適用し新しいラスターマップを作成します"
 #, fuzzy
-#~ msgid "Converts a PPM image file to GRASS raster map(s)."
-#~ msgstr "PPMファイルをラスターマップとしてインポートします"
+msgid "Converts a PPM image file to GRASS raster map(s)."
+msgstr "PPMファイルをラスターマップとしてインポートします"
 #, fuzzy
-#~ msgid "Create separate red/green/blue maps."
-#~ msgstr "赤/緑/青に対応するラスターマップを出力"
+msgid "Create separate red/green/blue maps."
+msgstr "赤/緑/青に対応するラスターマップを出力"
 #, fuzzy
-#~ msgid "Create composite color map."
-#~ msgstr "合成した色のラスターマップを出力"
+msgid "Create composite color map."
+msgstr "合成した色のラスターマップを出力"
 #, fuzzy
-#~ msgid ""
-#~ "Converts Universal Transverse Mercator (UTM) coordinates to geographic "
-#~ "(latitude/longitude) coordinates."
-#~ msgstr "UTM座標値から緯度/経度座標値に変換します"
+msgid ""
+"Converts Universal Transverse Mercator (UTM) coordinates to geographic "
+"(latitude/longitude) coordinates."
+msgstr "UTM座標値から緯度/経度座標値に変換します"
 #, fuzzy
-#~ msgid "reference spheroid (ellipsoid)"
-#~ msgstr "楕円体"
+msgid "reference spheroid (ellipsoid)"
+msgstr "楕円体"
 #, fuzzy
-#~ msgid "utm zone"
-#~ msgstr "UTMゾーン"
+msgid "utm zone"
+msgstr "UTMゾーン"
 #, fuzzy
-#~ msgid "Specified zone is in the southern hemisphere"
-#~ msgstr "領域を南半球で指定"
+msgid "Specified zone is in the southern hemisphere"
+msgstr "領域を南半球で指定"
 #, fuzzy
-#~ msgid "Input is reversed: north,east"
-#~ msgstr "入力する座標値を反転(north,east)"
+msgid "Input is reversed: north,east"
+msgstr "入力する座標値を反転(north,east)"
 #, fuzzy
-#~ msgid "Do not flag invalid east,north input lines as errors"
-#~ msgstr "領域外の座標が入力されても続行"
+msgid "Do not flag invalid east,north input lines as errors"
+msgstr "領域外の座標が入力されても続行"
 #, fuzzy
-#~ msgid "Flag other input lines as errors"
-#~ msgstr "他の形式で入力があった場合は中止"
+msgid "Flag other input lines as errors"
+msgstr "他の形式で入力があった場合は中止"
 #, fuzzy
-#~ msgid "Output in decimal degrees"
-#~ msgstr "10進数で出力"
+msgid "Output in decimal degrees"
+msgstr "10進数で出力"
 #, fuzzy
-#~ msgid ""
-#~ "Converts geographic coordinates to Universal Transverse Mercator (UTM) "
-#~ "coordinates."
-#~ msgstr "緯度/経度座標値からUTM座標値に変換します"
+msgid ""
+"Converts geographic coordinates to Universal Transverse Mercator (UTM) "
+"coordinates."
+msgstr "緯度/経度座標値からUTM座標値に変換します"
 #, fuzzy
-#~ msgid "utm zone (results will be forced into this zone)"
-#~ msgstr "UTMゾーン"
+msgid "utm zone (results will be forced into this zone)"
+msgstr "UTMゾーン"
 #, fuzzy
-#~ msgid "Input is reversed: lat,lon"
-#~ msgstr "入力する座標値を反転(経度,緯度)"
+msgid "Input is reversed: lat,lon"
+msgstr "入力する座標値を反転(経度,緯度)"
 #, fuzzy
-#~ msgid "Do not flag invalid lon,lat input lines as errors"
+msgid "Do not flag invalid lon,lat input lines as errors"
 #, fuzzy
-#~ msgid "Suppress printing the utm zone"
-#~ msgstr "UTMゾーンを出力しない"
+msgid "Suppress printing the utm zone"
+msgstr "UTMゾーンを出力しない"
 #, fuzzy
-#~ msgid ""
-#~ "Rotates elevation data extracted by either m.dted.extract or m."
-#~ "dmaUSGSread."
-#~ msgstr "抽出した標高データを90度回転します"
+msgid ""
+"Rotates elevation data extracted by either m.dted.extract or m.dmaUSGSread."
+msgstr "抽出した標高データを90度回転します"
 #, fuzzy
-#~ msgid "Output file"
+msgid "Output file"
+msgstr "出力するファイル"
 #, fuzzy
-#~ msgid "Number of bytes per cell (i.e. per data value)"
-#~ msgstr "1セルのバイト数"
+msgid "Number of bytes per cell (i.e. per data value)"
+msgstr "1セルのバイト数"
 #, fuzzy
-#~ msgid "latitude"
-#~ msgstr "緯度 (dd:mm:ss{N|S})"
+msgid "latitude"
+msgstr "緯度 (dd:mm:ss{N|S})"
 #, fuzzy
-#~ msgid "longitude"
-#~ msgstr "経度 (ddd:mm:ss{E|W})"
+msgid "longitude"
+msgstr "経度 (ddd:mm:ss{E|W})"
 #, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of level 1 and 2 digital terrain elevation "
-#~ "data (DTED) files produced and distributed by the Defense Mapping Agency "
-#~ "(DMA) on 1/2-inch magnetic tapes."
-#~ msgstr "1/2インチ磁気テープのデータからDTEDを簡易表示します"
+msgid ""
+"Provides a terse description of level 1 and 2 digital terrain elevation data "
+"(DTED) files produced and distributed by the Defense Mapping Agency (DMA) on "
+"1/2-inch magnetic tapes."
+msgstr "1/2インチ磁気テープのデータからDTEDを簡易表示します"
 #, fuzzy
-#~ msgid "Name of tape drive device"
-#~ msgstr "入力するデバイス"
+msgid "Name of tape drive device"
+msgstr "入力するデバイス"
 #, fuzzy
-#~ msgid ""
-#~ "Datum shift program. Return geographic coordinates based on a different "
-#~ "datum that the one used to obtain the original coordinates. "
-#~ msgstr "楕円体間のデータシフトを行います"
+msgid ""
+"Datum shift program. Return geographic coordinates based on a different "
+"datum that the one used to obtain the original coordinates. "
+msgstr "楕円体間のデータシフトを行います"
 #, fuzzy
-#~ msgid "use block shift transformation (default)"
-#~ msgstr "ブロック変換によるシフト(デフォルト)"
+msgid "use block shift transformation (default)"
+msgstr "ブロック変換によるシフト(デフォルト)"
 #, fuzzy
-#~ msgid "use bursa wolf 3d similarity transformation (not implemented)"
-#~ msgstr "BURSA変換によるシフト(未実装)"
+msgid "use bursa wolf 3d similarity transformation (not implemented)"
+msgstr "BURSA変換によるシフト(未実装)"
 #, fuzzy
-#~ msgid "height above ellipsoid"
-#~ msgstr "長円からの高さ"
+msgid "height above ellipsoid"
+msgstr "長円からの高さ"
 #, fuzzy
-#~ msgid "input spheroid"
-#~ msgstr "元の楕円体"
+msgid "input spheroid"
+msgstr "元の楕円体"
 #, fuzzy
-#~ msgid "output spheroid"
-#~ msgstr "シフト先の楕円体"
+msgid "output spheroid"
+msgstr "シフト先の楕円体"
 #, fuzzy
-#~ msgid "input datum"
-#~ msgstr "元のデータ"
+msgid "input datum"
+msgstr "元のデータ"
 #, fuzzy
-#~ msgid "output datum"
-#~ msgstr "シフト先のデータ"
+msgid "output datum"
+msgstr "シフト先のデータ"
 #, fuzzy
-#~ msgid "x shift"
-#~ msgstr "X方向のシフト"
+msgid "x shift"
+msgstr "X方向のシフト"
 #, fuzzy
-#~ msgid "y shift"
-#~ msgstr "Y方向のシフト"
+msgid "y shift"
+msgstr "Y方向のシフト"
 #, fuzzy
-#~ msgid "z shift"
-#~ msgstr "Z方向のシフト"
+msgid "z shift"
+msgstr "Z方向のシフト"
 #, fuzzy
-#~ msgid "Rx rotational parameter"
-#~ msgstr "スムージングパラメータ"
+msgid "Rx rotational parameter"
+msgstr "スムージングパラメータ"
 #, fuzzy
-#~ msgid "Ry rotational parameter"
+msgid "Ry rotational parameter"
 #, fuzzy
-#~ msgid "Rz rotational parameter"
+msgid "Rz rotational parameter"
 #, fuzzy
-#~ msgid "spheroid geographic coordinates to base on. "
-#~ msgstr "楕円体"
+msgid "spheroid geographic coordinates to base on. "
+msgstr "楕円体"
 #, fuzzy
-#~ msgid ""
-#~ "Converts UTM coordinates falling within the current geographic region to "
-#~ "geographic (latitude/longitude) coordinates. "
-#~ msgstr "現在の領域をUTM座標から緯度/経度座標に変換します"
+msgid ""
+"Converts UTM coordinates falling within the current geographic region to "
+"geographic (latitude/longitude) coordinates. "
+msgstr "現在の領域をUTM座標から緯度/経度座標に変換します"
 #, fuzzy
-#~ msgid ""
-#~ "Flips elevation data extracted from systems that retrieve data by rows "
-#~ "from south to north."
-#~ msgstr "抽出した標高データを180度回転します180度回転します"
+msgid ""
+"Flips elevation data extracted from systems that retrieve data by rows from "
+"south to north."
+msgstr "抽出した標高データを180度回転します180度回転します"
 #, fuzzy
-#~ msgid "Number of bytes per cell (ie, per data value)"
+msgid "Number of bytes per cell (ie, per data value)"
+msgstr "1セルのバイト数"
 #, fuzzy
-#~ msgid ""
-#~ "Finds geographic region information for U.S. Census Bureau TIGER input "
-#~ "data."
-#~ msgstr "TMS(TIGER MAPPING SERVISE)に入力する地域情報データを検索します"
+msgid ""
+"Finds geographic region information for U.S. Census Bureau TIGER input data."
+msgstr "TMS(TIGER MAPPING SERVISE)に入力する地域情報データを検索します"
 #, fuzzy
-#~ msgid "Filename for raw tiger data (type 1)"
+msgid "Filename for raw tiger data (type 1)"
+msgstr "入力するファイル"
 #, fuzzy
-#~ msgid "UTM zone for this county"
-#~ msgstr "UTMゾーン"
+msgid "UTM zone for this county"
+msgstr "UTMゾーン"
 #, fuzzy
-#~ msgid "Name of spheroid to use"
-#~ msgstr "楕円体"
+msgid "Name of spheroid to use"
+msgstr "楕円体"
 #, fuzzy
-#~ msgid ""
-#~ "Provides a terse description of USGS Digital Elevation Model (DEM) data "
-#~ "files stored on 1/2-inch magnetic tape."
-#~ msgstr "1/2インチ磁気テープのデータからDEMを簡易表示します"
+msgid ""
+"Provides a terse description of USGS Digital Elevation Model (DEM) data "
+"files stored on 1/2-inch magnetic tape."
+msgstr "1/2インチ磁気テープのデータからDEMを簡易表示します"
 #, fuzzy
-#~ msgid "Tape input device"
+msgid "Tape input device"
+msgstr "入力するデバイス"
 #, fuzzy
-#~ msgid "Blocksize of tape data"
-#~ msgstr "データのブロックサイズ"
+msgid "Blocksize of tape data"
+msgstr "データのブロックサイズ"
 #, fuzzy
-#~ msgid "First file to examine"
-#~ msgstr "開始ファイル"
+msgid "First file to examine"
+msgstr "開始ファイル"
 #, fuzzy
-#~ msgid "Last file to examine"
-#~ msgstr "終了ファイル"
+msgid "Last file to examine"
+msgstr "終了ファイル"
 #, fuzzy
-#~ msgid "y coordinate"
-#~ msgstr "Y座標値"
+msgid "y coordinate"
+msgstr "Y座標値"
 #, fuzzy
-#~ msgid "max iterations"
-#~ msgstr "最大反復回数"
+msgid "max iterations"
+msgstr "最大反復回数"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts digital terrain elevation data (DTED - levels 1 and 2) produced "
-#~ "and supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic "
-#~ "tapes."
-#~ msgstr "1/2インチ磁気テープのデータからDTEDを抽出します"
+msgid ""
+"Extracts digital terrain elevation data (DTED - levels 1 and 2) produced and "
+"supplied by the Defense Mapping Agency (DMA) on 1/2-inch magnetic tapes."
+msgstr "1/2インチ磁気テープのデータからDTEDを抽出します"
 #, fuzzy
-#~ msgid "Name of header output file"
-#~ msgstr "ヘッダーを出力するファイル"
+msgid "Name of header output file"
+msgstr "ヘッダーを出力するファイル"
 #, fuzzy
-#~ msgid "North latitude of region to extract (format: %s)"
-#~ msgstr "北端(入力形式: %s)"
+msgid "North latitude of region to extract (format: %s)"
+msgstr "北端(入力形式: %s)"
 #, fuzzy
-#~ msgid "South latitude of region to extract (format: %s)"
-#~ msgstr "南端(入力形式: %s)"
+msgid "South latitude of region to extract (format: %s)"
+msgstr "南端(入力形式: %s)"
 #, fuzzy
-#~ msgid "East longitude of region to extract (format: %s)"
-#~ msgstr "東端(入力形式: %s)"
+msgid "East longitude of region to extract (format: %s)"
+msgstr "東端(入力形式: %s)"
 #, fuzzy
-#~ msgid "West longitude of region to extract (format: %s)"
-#~ msgstr "西端(入力形式: %s)"
+msgid "West longitude of region to extract (format: %s)"
+msgstr "西端(入力形式: %s)"
 #, fuzzy
-#~ msgid "Read the entire tape in all cases"
-#~ msgstr "すべてのテープを読み込む"
+msgid "Read the entire tape in all cases"
+msgstr "すべてのテープを読み込む"
 #, fuzzy
-#~ msgid ""
-#~ "Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic "
-#~ "tape."
-#~ msgstr "1/2インチ磁気テープのデータからDEMデータを抽出します"
+msgid ""
+"Extracts USGS Digital Elevation Model (DEM) data from 1/2-inch magnetic tape."
+msgstr "1/2インチ磁気テープのデータからDEMデータを抽出します"
 #, fuzzy
-#~ msgid "Input device or file"
-#~ msgstr "入力するデバイスまたはファイル"
+msgid "Input device or file"
+msgstr "入力するデバイスまたはファイル"
 #, fuzzy
-#~ msgid "Output raster map (examine only if none specified)"
-#~ msgstr "出力するファイル(未入力の場合はチェックのみ)"
+msgid "Output raster map (examine only if none specified)"
+msgstr "出力するファイル(未入力の場合はチェックのみ)"
 #, fuzzy
-#~ msgid "First file to look at"
-#~ msgstr "開始ファイル"
+msgid "First file to look at"
+msgstr "開始ファイル"
 #, fuzzy
-#~ msgid "Last file to look at"
-#~ msgstr "終了ファイル"
+msgid "Last file to look at"
+msgstr "終了ファイル"
 #, fuzzy
-#~ msgid "Selects a device (printer) for GRASS hardcopy output."
+msgid "Selects a device (printer) for GRASS hardcopy output."
 #, fuzzy
-#~ msgid "list all available painters"
-#~ msgstr "ペインタの一覧表示"
+msgid "list all available painters"
+msgstr "ペインタの一覧表示"
 #, fuzzy
-#~ msgid "print name of currently selected painter"
+msgid "print name of currently selected painter"
 #, fuzzy
-#~ msgid "quietly select painter"
-#~ msgstr "説明なし"
+msgid "quietly select painter"
+msgstr "説明なし"
 #, fuzzy
-#~ msgid "Color map output utility."
-#~ msgstr "ハードコピー出力の設定を行います"
+msgid "Color map output utility."
+msgstr "ハードコピー出力の設定を行います"
 #, fuzzy
-#~ msgid "Align region to resolution [default = align to bounds]"
-#~ msgstr "境界を分解能に合わせる"
+msgid "Align region to resolution [default = align to bounds]"
+msgstr "境界を分解能に合わせる"
 #, fuzzy
-#~ msgid "Set region to match this sites map"
-#~ msgstr "設定に用いるサイトマップ"
+msgid "Set region to match this sites map"
+msgstr "設定に用いるサイトマップ"
 #, fuzzy
-#~ msgid "Value for the eastern edge "
-#~ msgstr "南端"
+msgid "Value for the eastern edge "
+msgstr "南端"
 #, fuzzy
-#~ msgid "Value for the western edge "
-#~ msgstr "西端"
+msgid "Value for the western edge "
+msgstr "西端"
 #, fuzzy
-#~ msgid "Grid resolution (both north-south and east-west)"
-#~ msgstr "格子の分解能"
+msgid "Grid resolution (both north-south and east-west)"
+msgstr "格子の分解能"
 #, fuzzy
-#~ msgid "Overwrite <to> file(s)"
-#~ msgstr "上書き"
+msgid "Overwrite <to> file(s)"
+msgstr "上書き"
 #, fuzzy
-#~ msgid "Overwrite <new> file(s)"
-#~ msgstr "上書き"
+msgid "Overwrite <new> file(s)"
+msgstr "上書き"
 #, fuzzy
-#~ msgid "  vect   (binary vector maps)\n"
-#~ msgstr "  vect   (ベクトルマップ)\n"
+msgid "  vect   (binary vector maps)\n"
+msgstr "  vect   (ベクトルマップ)\n"
 #, fuzzy
-#~ msgid "  icon   (paint icon files)\n"
-#~ msgstr "  icon   (ペイントアイコンファイル)\n"
+msgid "  icon   (paint icon files)\n"
+msgstr "  icon   (ペイントアイコンファイル)\n"
 #, fuzzy
-#~ msgid "  labels (paint label files)\n"
-#~ msgstr "  labels (ペイントラベルファイル)\n"
+msgid "  labels (paint label files)\n"
+msgstr "  labels (ペイントラベルファイル)\n"
 #, fuzzy
-#~ msgid "  sites  (site list files)\n"
-#~ msgstr "  sites  (サイトマップ)\n"
+msgid "  sites  (site list files)\n"
+msgstr "  sites  (サイトマップ)\n"
 #, fuzzy
-#~ msgid "  group  (imagery group files)\n"
-#~ msgstr "  group  (画像グループ)\n"
+msgid "  group  (imagery group files)\n"
+msgstr "  group  (画像グループ)\n"
 #, fuzzy
-#~ msgid "  3dview (3D view parameters)\n"
-#~ msgstr "  3dview (3次元表示パラメータファイル)\n"
+msgid "  3dview (3D view parameters)\n"
+msgstr "  3dview (3次元表示パラメータファイル)\n"
+#, fuzzy
+#~ msgid "display, export"
+#~ msgstr "ガンマ"
+#, fuzzy
+#~ msgid "Name for output file (do NOT add extension)"
+#~ msgstr "出力するファイル"
+#, fuzzy
+#~ msgid "Images"
+#~ msgstr "画像グループ"
+#, fuzzy
+#~ msgid "Data type"
+#~ msgstr "ファイルの種類"
+#, fuzzy
+#~ msgid "slopein raster map <%s> not found"
+#~ msgstr "入力するファイル"
+#, fuzzy
+#~ msgid "%s: Error reading from raster map <%s> in mapset <%s>"
+#, fuzzy
+#~ msgid "Base raster map <%s> not found"
+#, fuzzy
+#~ msgid "Color table for <%s> updated"
+#~ msgstr "色に用いるラスターマップ"
+#, fuzzy
+#~ msgid "Error reading raster map [%s]."
+#, fuzzy
+#~ msgid "Option <%s>: <%s> exists."
+#, fuzzy
+#~ msgid "Use '%s' option to change vector map name"
+#~ msgstr "正接曲率を出力するファイル"
+#, fuzzy
+#~ msgid "Invalid rendering method <%s>"
+#~ msgstr "初期のクラスター数"
+#, fuzzy
+#~ msgid "Name of the input raster map"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_ko.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -11253,20 +11253,24 @@
 msgstr ""
 #: ../raster/r.uslek/main.c:58
+#, fuzzy
 msgid "Name of the Soil sand fraction map [0.0-1.0]"
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../raster/r.uslek/main.c:62
+#, fuzzy
 msgid "Name of the Soil clay fraction map [0.0-1.0]"
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../raster/r.uslek/main.c:66
+#, fuzzy
 msgid "Name of the Soil silt fraction map [0.0-1.0]"
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../raster/r.uslek/main.c:70
+#, fuzzy
 msgid "Name of the Soil Organic Matter map [0.0-1.0]"
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../raster/r.uslek/main.c:74
 #, fuzzy
@@ -17446,8 +17450,9 @@
 msgstr "출력할 래스터맵"
 #: ../raster/r.grow.distance/main.c:121
+#, fuzzy
 msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../raster/r.grow.distance/main.c:131 ../raster/r.grow/main.c:147
 msgid "Metric"
@@ -24677,8 +24682,9 @@
 msgstr ""
 #: ../vector/v.net.steiner/main.c:388
+#, fuzzy
 msgid "Number of steiner points (-1 for all possible)"
-msgstr ""
+msgstr "출력할 래스터맵"
 #: ../vector/v.net.steiner/main.c:447
 msgid "Not enough terminals (< 2)"
@@ -25953,217 +25959,237 @@
 msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Name of .dmrc settings file"
-#~ msgstr "출력할 래스터맵"
+msgid "Name of .dmrc settings file"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Number of seconds to pause between slides"
+msgid "Number of seconds to pause between slides"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Enter raster map to display in 1st frame"
+msgid "Enter raster map to display in 1st frame"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Enter command to execute in 1st frame"
+msgid "Enter command to execute in 1st frame"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Enter raster map to display in 2nd frame"
+msgid "Enter raster map to display in 2nd frame"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Enter command to execute in 2nd frame"
+msgid "Enter command to execute in 2nd frame"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Vector map to display thematically"
+msgid "Vector map to display thematically"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Vector map type"
+msgid "Vector map type"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Raster to remove"
+msgid "Raster to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "3d raster to remove"
+msgid "3d raster to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Vector to remove"
+msgid "Vector to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Region to remove"
+msgid "Region to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Label to remove"
+msgid "Label to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Group to remove"
+msgid "Group to remove"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Name for output grid3D volume"
+msgid "Name for output grid3D volume"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to find data map"
+msgid "Unable to find data map"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to find clump map"
+msgid "Unable to find clump map"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Name of the vector points map with x,y locations"
+msgid "Name of the vector points map with x,y locations"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "RGB raster map <%s> not found"
+msgid "RGB raster map <%s> not found"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Vector cell map <%s> not found"
+msgid "Vector cell map <%s> not found"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "%s map <%s> not found"
+msgid "%s map <%s> not found"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Category file for <%s> not updated"
+msgid "Category file for <%s> not updated"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Category file for <%s> updated"
+msgid "Category file for <%s> updated"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to find stop vector <%s>"
+msgid "Unable to find stop vector <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Raster output map <%s> not found (no start_points given)"
+msgid "Raster output map <%s> not found (no start_points given)"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Network input map <%s> not found"
+msgid "Network input map <%s> not found"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "No raster or vector map displayed"
+msgid "No raster or vector map displayed"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to open file: <%s>"
+msgid "Unable to open file: <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to delete layer/category [%d/%d] line %d"
+msgid "Unable to delete layer/category [%d/%d] line %d"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to write line %d"
+msgid "Unable to write line %d"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to delete line %d"
+msgid "Unable to delete line %d"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s>"
+msgid "Cannot read category file of raster map <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "%s: unable to open %s"
+msgid "%s: unable to open %s"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot describe table <%s>"
+msgid "Cannot describe table <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to open database %s by driver %s"
+msgid "Unable to open database %s by driver %s"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to open driver <%s>"
+msgid "Unable to open driver <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "input raster map"
+msgid "input raster map"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot open raster map <%s> in <%s>"
+msgid "Cannot open raster map <%s> in <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot read category file of raster map <%s> in <%s>"
+msgid "Cannot read category file of raster map <%s> in <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Print raster map title only"
+msgid "Print raster map title only"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot rewrite line %d"
+msgid "Cannot rewrite line %d"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot snap lines %d,%d"
+msgid "Cannot snap lines %d,%d"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "%d lines modified"
+msgid "%d lines modified"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Creating vector grid..."
+msgid "Creating vector grid..."
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Parameter <%s> not set"
+msgid "Parameter <%s> not set"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Table to be imported"
+msgid "Table to be imported"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Unable to create output raster map <%s>"
+msgid "Unable to create output raster map <%s>"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot drop table: %s"
+msgid "Cannot drop table: %s"
+msgstr "출력할 래스터맵"
 #, fuzzy
-#~ msgid "Cannot create table <%s>"
+msgid "Cannot create table <%s>"
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgid "Unalbe to open vector map <%s>"
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgid "Open raster map %s in %s = %d"
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgid "Input vector map <%s> not found."
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgid "%s: o_open_file: raster map %s not found"
+msgstr "출력할 래스터맵"
+#, fuzzy
+#~ msgid "Type of thematic display"
 #, fuzzy
-#~ msgid "Unalbe to open vector map <%s>"
+#~ msgid "Name of terrain raster map (DEM)"
 #, fuzzy
-#~ msgid "Open raster map %s in %s = %d"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+#~ msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "%s: o_open_file: raster map %s not found"
+#~ msgid "Erasing monitors..."
Modified: grass/trunk/locale/po/grassmods_lv.po
--- grass/trunk/locale/po/grassmods_lv.po	2008-10-16 05:35:13 UTC (rev 33893)
+++ grass/trunk/locale/po/grassmods_lv.po	2008-10-16 06:00:55 UTC (rev 33894)
@@ -5729,12 +5729,12 @@
 #: ../imagery/i.vi/main.c:133
 #, fuzzy
 msgid "Name of the chan5 channel surface reflectance map"
-msgstr "Jaunas rastra kartes nosaukums"
+msgstr "Rezultējošās rastra kartes nosaukums"
 #: ../imagery/i.vi/main.c:140
 #, fuzzy
 msgid "Name of the chan7 channel surface reflectance map"
 #: ../imagery/i.vi/main.c:306 ../imagery/i.albedo/main.c:389
 #: ../raster/r.los/main.c:382 ../raster/r.texture/main.c:333
@@ -8904,7 +8904,7 @@
 #: ../raster/r.external/main.c:339
 #, fuzzy, c-format
 msgid "Setting grey color table for <%s> (data range)"
-msgstr "Krāsu tabula [%s] uzstādīta uz %s"
+msgstr "%s: Nevarēja nolasīt krāsu tabulu priekš <%s@%s>"
 #: ../raster/r.external/main.c:353
 #, fuzzy, c-format
@@ -9970,7 +9970,7 @@
 #: ../raster/r.what/main.c:335
 #, fuzzy, c-format
 msgid "Error reading <%s>"
-msgstr "Rezultējošās rastra kartes nosaukums"
+msgstr "Nevarēja atrast rastra failu %s"
 #: ../raster/r.sum/main.c:46
 msgid "Sums up the raster cell values."
@@ -11749,8 +11749,9 @@
 msgstr "Ieejas rastra faila nosaukums"
+#, fuzzy
-msgstr ""
+msgstr "Ieejas rastra faila nosaukums"
 #, fuzzy
@@ -18108,7 +18109,7 @@
 #: ../raster/r.statistics2/main.c:185
 #, fuzzy, c-format
 msgid "Unable to read range of base map <%s>"
-msgstr "cnevar atvērt nepieciešamo daļu faila priekš %s"
+msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
 #: ../raster/r.statistics2/main.c:249
 msgid "First pass"
@@ -25680,8 +25681,9 @@
 msgstr ""
+#, fuzzy
-msgstr ""
+msgstr "Vektorkartes nosaukums"
 #, fuzzy
@@ -26806,8 +26808,9 @@
 #: ../visualization/nviz2/cmd/args.c:289 ../visualization/nviz2/cmd/args.c:357
 #: ../visualization/nviz2/cmd/args.c:426
+#, fuzzy
 msgid "Position"
-msgstr ""
 #: ../visualization/nviz2/cmd/args.c:301
 #, fuzzy
@@ -26999,2627 +27002,2671 @@
 msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
 msgstr "Nevar iatlasīt datus no tabulas"
-#~ msgid ""
-#~ "Optional where condition (without WHERE key word), e.g.:\n"
-#~ "\t\tobec = 'Liptakov'"
-#~ msgstr ""
-#~ "Neobligāti kur nosacījums (bez WHERE atslēgas vārda), piem.:\n"
+msgid ""
+"Optional where condition (without WHERE key word), e.g.:\n"
+"\t\tobec = 'Liptakov'"
+msgstr ""
+"Neobligāti kur nosacījums (bez WHERE atslēgas vārda), piem.:\n"
-#~ msgid "Illegal output file name"
-#~ msgstr "Nederīgs izvades faila nosaukums"
+msgid "Illegal output file name"
+msgstr "Nederīgs izvades faila nosaukums"
 #, fuzzy
-#~ msgstr "Datu bāzes faila nosaukums"
+msgstr "Datu bāzes faila nosaukums"
 #, fuzzy
-#~ msgid "Width in pixels of new display monitor"
-#~ msgstr "Parādīt nulles šūnu unformāciju"
+msgid "Width in pixels of new display monitor"
+msgstr "Parādīt nulles šūnu unformāciju"
 #, fuzzy
-#~ msgid "Height in pixels of new display monitor"
+msgid "Height in pixels of new display monitor"
 #, fuzzy
-#~ msgid "Moves displayed maps to another monitor"
-#~ msgstr "Izvēlies fontu kurš tiks parādīts lietotāja grafiskajā vidē."
+msgid "Moves displayed maps to another monitor"
+msgstr "Izvēlies fontu kurš tiks parādīts lietotāja grafiskajā vidē."
 #, fuzzy
-#~ msgid "Saves the contents of the active display monitor to a graphics file."
+msgid "Saves the contents of the active display monitor to a graphics file."
 #, fuzzy
-#~ msgid "Compression for PNG files"
+msgid "Compression for PNG files"
 #, fuzzy
-#~ msgid "Paper size for PostScript output"
-#~ msgstr "PostScript izejas fails"
+msgid "Paper size for PostScript output"
+msgstr "PostScript izejas fails"
 #, fuzzy
-#~ msgid "PostScript"
-#~ msgstr "PostScript izvades fails"
+msgid "PostScript"
+msgstr "PostScript izvades fails"
 #, fuzzy
-#~ msgid "Set transparent background"
-#~ msgstr "Nosaka uzraksta teksta fona krāsu"
+msgid "Set transparent background"
+msgstr "Nosaka uzraksta teksta fona krāsu"
 #, fuzzy
-#~ msgid "omit entries with missing label"
-#~ msgstr "Izlaist kategorijas bez uzrakstiem"
+msgid "omit entries with missing label"
+msgstr "Izlaist kategorijas bez uzrakstiem"
 #, fuzzy
-#~ msgid "Number of lines to appear in the legend"
-#~ msgstr "Drukājamo kopiju sakits"
+msgid "Number of lines to appear in the legend"
+msgstr "Drukājamo kopiju sakits"
 #, fuzzy
-#~ msgid "Redraws the current display frame in the GRASS monitor"
-#~ msgstr "Nav karte parādīta GRASS monitorā"
+msgid "Redraws the current display frame in the GRASS monitor"
+msgstr "Nav karte parādīta GRASS monitorā"
 #, fuzzy
-#~ msgid "Redraw all frames"
-#~ msgstr "LÄ«niju skaits"
+msgid "Redraw all frames"
+msgstr "LÄ«niju skaits"
 #, fuzzy
-#~ msgid "Resizes active display monitor"
+msgid "Resizes active display monitor"
 #, fuzzy
-#~ msgid "Slide show of GRASS raster/vector maps."
-#~ msgstr "Izejas rastra kartes nosaukums"
+msgid "Slide show of GRASS raster/vector maps."
+msgstr "Izejas rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "Show vector maps rather than raster maps"
+msgid "Show vector maps rather than raster maps"
 #, fuzzy
-#~ msgstr "drukājamo kopiju sakits"
+msgstr "drukājamo kopiju sakits"
 #, fuzzy
-#~ msgstr "Attēlojamā rastra karte"
+msgstr "Attēlojamā rastra karte"
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgstr "vektora karte <%s> nav atrasta"
+msgstr "vektora karte <%s> nav atrasta"
 #, fuzzy
 #, fuzzy
-#~ msgid "Type of thematic display"
+msgid "Type of thematic display"
 #, fuzzy
-#~ msgid "Points"
-#~ msgstr "Drukāt"
+msgid "Points"
+msgstr "Drukāt"
 #, fuzzy
-#~ msgid "Number of classes for interval theme (integer)"
+msgid "Number of classes for interval theme (integer)"
 #, fuzzy
-#~ msgid "Misc"
-#~ msgstr "Metriskā"
+msgid "Misc"
+msgstr "Metriskā"
 #, fuzzy
-#~ msgid "Mapset(s) to list (default: current mapset search path)"
-#~ msgstr "drukā tekošās karšu biblotēkas/mapset meklēšanas ceļu"
+msgid "Mapset(s) to list (default: current mapset search path)"
+msgstr "drukā tekošās karšu biblotēkas/mapset meklēšanas ceļu"
 #, fuzzy
-#~ msgid "Output separator (default: newline)"
-#~ msgstr "Izvades rastra karte ar ezeru"
+msgid "Output separator (default: newline)"
+msgstr "Izvades rastra karte ar ezeru"
 #, fuzzy
-#~ msgstr "Rastra karte kura tiks pārkodēta"
+msgstr "Rastra karte kura tiks pārkodēta"
 #, fuzzy
 #, fuzzy
-#~ msgstr "%s fails(i) kuri tiks attālināti"
+msgstr "%s fails(i) kuri tiks attālināti"
 #, fuzzy
-#~ msgstr "neiespējami atvērt <%s>"
+msgstr "neiespējami atvērt <%s>"
 #, fuzzy
 #, fuzzy
-#~ msgid "3dview to remove"
+msgid "3dview to remove"
 #, fuzzy
 #, fuzzy
-#~ msgid "raster input maps"
-#~ msgstr "Rastra ievades kartes"
+msgid "raster input maps"
+msgstr "Rastra ievades kartes"
 #, fuzzy
-#~ msgid "label with coordinates instead of numbering"
-#~ msgstr "Lietojamās kartes centra koordinātes\n"
+msgid "label with coordinates instead of numbering"
+msgstr "Lietojamās kartes centra koordinātes\n"
 #, fuzzy
-#~ msgid "Do not overwrite existing map"
-#~ msgstr "Nevaratvērt datubāzi %s"
+msgid "Do not overwrite existing map"
+msgstr "Nevaratvērt datubāzi %s"
 #, fuzzy
-#~ msgid "Exports GRASS raster into GDAL supported formats."
-#~ msgstr "Eksportēt GRASS rastru uz GDAL atbalstītu formātu"
+msgid "Exports GRASS raster into GDAL supported formats."
+msgstr "Eksportēt GRASS rastru uz GDAL atbalstītu formātu"
 #, fuzzy
-#~ msgid "Output field seperator"
-#~ msgstr "Izvades lauku atdalītājs"
+msgid "Output field seperator"
+msgstr "Izvades lauku atdalītājs"
 #, fuzzy
-#~ msgid "calculates univariate statistics from a GRASS raster map"
-#~ msgstr "Ģenerē rastra karšu platību statistiku."
+msgid "calculates univariate statistics from a GRASS raster map"
+msgstr "Ģenerē rastra karšu platību statistiku."
 #, fuzzy
-#~ msgid "A (grid3D file)"
-#~ msgstr "ikonas faila nosaukums"
+msgid "A (grid3D file)"
+msgstr "ikonas faila nosaukums"
 #, fuzzy
-#~ msgid "B (grid3D file)"
+msgid "B (grid3D file)"
 #, fuzzy
-#~ msgid "C (grid3D file)"
+msgid "C (grid3D file)"
 #, fuzzy
-#~ msgid "D (grid3D file)"
+msgid "D (grid3D file)"
 #, fuzzy
-#~ msgid "E (grid3D file)"
+msgid "E (grid3D file)"
 #, fuzzy
-#~ msgid "F (grid3D file)"
+msgid "F (grid3D file)"
 #, fuzzy
-#~ msgid "%s: [%s] not found"
-#~ msgstr "%s: [%s] nav atrasts"
+msgid "%s: [%s] not found"
+msgstr "%s: [%s] nav atrasts"
 #, fuzzy
-#~ msgid ""
-#~ "Enter the file name or path\n"
-#~ msgstr "Rakstu jaunu failu... \n"
+msgid ""
+"Enter the file name or path\n"
+msgstr "Rakstu jaunu failu... \n"
-#~ msgid "Interactively select End-Points"
-#~ msgstr "Interaktīvi izvēlēties punktus"
+msgid "Interactively select End-Points"
+msgstr "Interaktīvi izvēlēties punktus"
 #, fuzzy
-#~ msgid "Use mouse to select Start Point\n"
-#~ msgstr "Ir jāievada kāminimums %d punkti."
+msgid "Use mouse to select Start Point\n"
+msgstr "Ir jāievada kāminimums %d punkti."
 #, fuzzy
-#~ msgid "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Pogas:\n"
+msgid "Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"Pogas:\n"
 #, fuzzy
-#~ msgid "Left:   Mark next point\n"
-#~ msgstr " Kreisais:  kas ir Å¡eit\n"
+msgid "Left:   Mark next point\n"
+msgstr " Kreisais:  kas ir Å¡eit\n"
 #, fuzzy
-#~ msgid "elevin raster map <%s> not found"
-#~ msgstr "3d skata fails <%s> nav atrasts"
+msgid "elevin raster map <%s> not found"
+msgstr "3d skata fails <%s> nav atrasts"
 #, fuzzy
-#~ msgid "aspin raster map <%s> not found"
+msgid "aspin raster map <%s> not found"
 #, fuzzy
-#~ msgid "linkein raster map <%s> not found"
+msgid "linkein raster map <%s> not found"
 #, fuzzy
-#~ msgid "albedo raster map <%s> not found"
+msgid "albedo raster map <%s> not found"
 #, fuzzy
-#~ msgid "latin raster map <%s> not found"
+msgid "latin raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefbh raster map <%s> not found"
+msgid "coefbh raster map <%s> not found"
 #, fuzzy
-#~ msgid "coefdh raster map <%s> not found"
+msgid "coefdh raster map <%s> not found"
 #, fuzzy
-#~ msgstr "Nevarēja atrast rastra failu %s"
 #, fuzzy
-#~ msgid "Terrain raster map (DEM)"
-#~ msgstr "Reljefa rastra karte (DEM)"
+#, fuzzy
+msgid "Terrain raster map (DEM)"
+msgstr "Reljefa rastra karte (DEM)"
-#~ msgid "Output raster map with lake"
+msgid "Output raster map with lake"
-#~ msgid "Cannot write lake raster map <%s>!"
-#~ msgstr "Nevar ierakstīt ezera rastra karti <%s>!"
+msgid "Cannot write lake raster map <%s>!"
-#~ msgid "Terrain raster map <%s> not found!"
-#~ msgstr "Reljefa rastra karte <%s> nav atrasta!"
+msgid "Terrain raster map <%s> not found!"
+msgstr "Reljefa rastra karte <%s> nav atrasta!"
-#~ msgid "Cannot open terrain raster map <%s@%s>!"
-#~ msgstr "Nevar atvērt reljefa rastra karti <%s@%s>!"
+msgid "Cannot open terrain raster map <%s@%s>!"
+msgstr "Nevar atvērt reljefa rastra karti <%s@%s>!"
-#~ msgid "Seed map <%s> not found!"
-#~ msgstr "Sākuma punkta karte <%s> nav atrasta!"
+msgid "Seed map <%s> not found!"
+msgstr "Sākuma punkta karte <%s> nav atrasta!"
-#~ msgid "Cannot open seed map <%s@%s>!"
-#~ msgstr "Nevar atvērt sākuma punkta karti <%s@%s>!"
+msgid "Cannot open seed map <%s@%s>!"
+msgstr "Nevar atvērt sākuma punkta karti <%s@%s>!"
-#~ msgid "Failure to allocate memory for row pointers"
-#~ msgstr "Neizdevās piešķirt atmiņu rindu norādēm"
+msgid "Failure to allocate memory for row pointers"
+msgstr "Neizdevās piešķirt atmiņu rindu norādēm"
-#~ msgid "Loading maps: "
-#~ msgstr "Karšu ielāde: "
+msgid "Loading maps: "
+msgstr "Karšu ielāde: "
-#~ msgid "Error reading terrain raster map. Probably broken file."
-#~ msgstr "Kļūda ielādējot reljefa karti. Iespējams, ka fails ir bojāts."
+msgid "Error reading terrain raster map. Probably broken file."
+msgstr "Kļūda ielādējot reljefa karti. Iespējams, ka fails ir bojāts."
-#~ msgid "Error reading seed raster map. Probably broken file."
-#~ msgstr ""
-#~ "Kļūda nolasot sākuma punkta rastra karti. Iespējams, ka fails ir bojāts."
+msgid "Error reading seed raster map. Probably broken file."
+msgstr ""
+"Kļūda nolasot sākuma punkta rastra karti. Iespējams, ka fails ir bojāts."
-#~ msgid "Cannot write lake raster map <%s@%s>!"
-#~ msgstr "Nevar ierakstīt ezera rastra karti <%s@%s>!"
+msgid "Cannot write lake raster map <%s@%s>!"
+msgstr "Nevar ierakstīt ezera rastra karti <%s@%s>!"
-#~ msgid ""
-#~ "Starting lake filling at level of %8.4f in %d passes. \n"
-#~ "Percent done:"
-#~ msgstr ""
-#~ "Tiek sākta ezera aizpildīšana ar līmeni %8.4f %d gājienos. \n"
-#~ "Paveikts:"
+msgid ""
+"Starting lake filling at level of %8.4f in %d passes. \n"
+"Percent done:"
+msgstr ""
+"Tiek sākta ezera aizpildīšana ar līmeni %8.4f %d gājienos. \n"
+"Paveikts:"
-#~ msgid "Pass: %d\n"
-#~ msgstr "Gājiens: %d\n"
+msgid "Pass: %d\n"
+msgstr "Gājiens: %d\n"
-#~ msgid "Error writing color file for <%s@%s>!"
-#~ msgstr "Kļūda rakstot krāsu failu priekš <%s@%s>!"
+msgid "Error writing color file for <%s@%s>!"
+msgstr "Kļūda rakstot krāsu failu priekš <%s@%s>!"
-#~ msgid "All done."
-#~ msgstr "Padarīts."
+msgid "All done."
+msgstr "Padarīts."
 #, fuzzy
-#~ msgid "%s: base raster map not found"
-#~ msgstr ""
-#~ "#-#-#-#-#  grassmods_lv.po (grassmods_lv)  #-#-#-#-#\n"
-#~ "brīdinājums: %s - vektora fails nav atrasts\n"
-#~ "rastra karte <%s> nav atrasta\n"
-#~ "reģions <%s> nav atrasts"
+msgid "%s: base raster map not found"
+msgstr ""
+"#-#-#-#-#  grassmods_lv.po (grassmods_lv)  #-#-#-#-#\n"
+"brīdinājums: %s - vektora fails nav atrasts\n"
+"rastra karte <%s> nav atrasta\n"
+"reģions <%s> nav atrasts"
 #, fuzzy
-#~ msgid "%s: cover raster map not found"
-#~ msgstr "rastra karte <%s> nav atrasta"
+msgid "%s: cover raster map not found"
+msgstr "rastra karte <%s> nav atrasta"
 #, fuzzy
-#~ msgid "%s: base map and output map must be different"
-#~ msgstr ""
-#~ "Sākuma punkta koordinātēm un izvades kartei lake= jābūt uz uzstādītiem!"
+msgid "%s: base map and output map must be different"
+msgstr ""
+"Sākuma punkta koordinātēm un izvades kartei lake= jābūt uz uzstādītiem!"
 #, fuzzy
 #, fuzzy
-#~ msgid "Number of time iterations (sec.)"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "  Punktu skaits: %d\n"
+msgid "Number of time iterations (sec.)"
+msgstr ""
+"\n"
+"\n"
+"  Punktu skaits: %d\n"
 #, fuzzy
-#~ msgid "Multiscale simulation"
-#~ msgstr "atubāzes atrašnās"
+msgid "Multiscale simulation"
+msgstr "atubāzes atrašnās"
 #, fuzzy
-#~ msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
-#~ msgstr "Ieejas rastra faila nosaukums"
+msgid "Name of the elevation raster map, same units as N,E: [m] or [ft] "
 #, fuzzy
-#~ msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the x-derivatives raster map [m/m] or [ft/ft]"
 #, fuzzy
-#~ msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
+msgid "Name of the y-derivatives raster map [m/m] or [ft/ft]"
-#~ msgid "Quietly"
-#~ msgstr "Klusi"
+msgid "Quietly"
+msgstr "Klusi"
 #, fuzzy
-#~ msgid "Illegal output file name <%s>"
+msgid "Illegal output file name <%s>"
 #, fuzzy
-#~ msgid "Base map and output map <%s> must be different"
-#~ msgstr ""
+msgid "Base map and output map <%s> must be different"
+msgstr ""
-#~ msgid "Not enough disk space -- cannot write files"
-#~ msgstr "Nevar ierakstīt failus, jo nepietiek diska telpas"
+msgid "Not enough disk space -- cannot write files"
+msgstr "Nevar ierakstīt failus, jo nepietiek diska telpas"
-#~ msgid "Raster input maps(s)"
+msgid "Raster input maps(s)"
-#~ msgid "Output file name"
-#~ msgstr "Izvades faila nosaukums"
+msgid "Output file name"
+msgstr "Izvades faila nosaukums"
 #, fuzzy
-#~ msgid "%s: can't read fp range for [%s]"
-#~ msgstr "cnevar atvērt nepieciešamo daļu faila priekš %s"
+msgid "%s: can't read fp range for [%s]"
+msgstr "cnevar atvērt nepieciešamo daļu faila priekš %s"
 #, fuzzy
-#~ msgid ""
-#~ "Raster map [%s] already exists.\n"
-#~ "Please try another."
-#~ msgstr "dig_att fails neeksistē"
+msgid ""
+"Raster map [%s] already exists.\n"
+"Please try another."
+msgstr "dig_att fails neeksistē"
 #, fuzzy
-#~ msgid "Path to rules file"
-#~ msgstr "Esošā rastra faila nosaukums"
+msgid "Path to rules file"
+msgstr "Esošā rastra faila nosaukums"
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot open raster map [%s]!"
+msgid "Cannot open raster map [%s]!"
 #, fuzzy
-#~ msgid "The file appears to be compressed.\n"
-#~ msgstr "%s fails(i) kopēšanai"
+msgid "The file appears to be compressed.\n"
+msgstr "%s fails(i) kopēšanai"
 #, fuzzy
-#~ msgid "Unable to write header for [%s]."
-#~ msgstr "Nav iespēju atvērt šūnu failu priekš[%s]"
+msgid "Unable to write header for [%s]."
+msgstr "Nav iespēju atvērt šūnu failu priekš[%s]"
 #, fuzzy
-#~ msgid "        Number of cols"
+msgid "        Number of cols"
 #, fuzzy
-#~ msgid "Raster file [%s] not found. Exiting."
-#~ msgstr "rastrs <%s> nav atrasts"
+msgid "Raster file [%s] not found. Exiting."
+msgstr "rastrs <%s> nav atrasts"
 #, fuzzy
-#~ msgid "Edit the history file for [%s]? "
+msgid "Edit the history file for [%s]? "
 #, fuzzy
 #, fuzzy
-#~ msgstr "krāsu fails priekš [%s] nav pieejams"
+msgstr "krāsu fails priekš [%s] nav pieejams"
 #, fuzzy
-#~ msgstr "Krāsu tabula [%s] uzstādīta uz %s"
+msgstr "Krāsu tabula [%s] uzstādīta uz %s"
 #, fuzzy
-#~ msgid "Unable to find starting vector <%s> "
+msgid "Unable to find starting vector <%s> "
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgid "Cell file not found"
+msgid "Cell file not found"
 #, fuzzy
-#~ msgid "Vector map <%s> not found in the current mapset"
+msgid "Vector map <%s> not found in the current mapset"
 #, fuzzy
-#~ msgid "Cannot execute: %s"
-#~ msgstr "Nevar izveidot tabulu: %s"
+msgid "Cannot execute: %s"
+msgstr "Nevar izveidot tabulu: %s"
 #, fuzzy
-#~ msgid "Cannot link table: %s"
+msgid "Cannot link table: %s"
 #, fuzzy
-#~ msgid "DXF input file"
-#~ msgstr "Ieejas fails"
+msgid "DXF input file"
+msgstr "Ieejas fails"
 #, fuzzy
-#~ msgid "Cannot open dxf file <%s>"
+msgid "Cannot open dxf file <%s>"
 #, fuzzy
-#~ msgid "Cannot open new vector map <%s>"
-#~ msgstr "nevar atvērt vektorfailu <%s> iekš <%s>"
+msgid "Cannot open new vector map <%s>"
+msgstr "nevar atvērt vektorfailu <%s> iekš <%s>"
 #, fuzzy
-#~ msgid "Conversion of <%s> to vector map:"
-#~ msgstr "Eksistējošas vektorkartes nosaukums"
+msgid "Conversion of <%s> to vector map:"
+msgstr "Eksistējošas vektorkartes nosaukums"
 #, fuzzy
 #, fuzzy
-#~ msgid "ask_transform_coor():  Leaving session.. \n"
-#~ msgstr "ask_transform_coor():  Beigt sesiju.. \n"
+msgid "ask_transform_coor():  Leaving session.. \n"
+msgstr "ask_transform_coor():  Beigt sesiju.. \n"
-#~ msgid " Number of points that have been entered: %d\n"
-#~ msgstr " Ievadīto punktu skaits: %d\n"
+msgid " Number of points that have been entered: %d\n"
+msgstr " Ievadīto punktu skaits: %d\n"
-#~ msgid "Please answer yes or no"
-#~ msgstr "Lūdzu atbildi 'jā' vai 'nē' "
+msgid "Please answer yes or no"
+msgstr "Lūdzu atbildi 'jā' vai 'nē' "
 #, fuzzy
-#~ msgid "Line: %d\n"
-#~ msgstr "LÄ«nijas augstums: %f\n"
+msgid "Line: %d\n"
+msgstr "LÄ«nijas augstums: %f\n"
 #, fuzzy
-#~ msgid "Illegal file name for real part: %s"
+msgid "Illegal file name for real part: %s"
 #, fuzzy
-#~ msgid "Illegal file name for imaginary part: %s"
+msgid "Illegal file name for imaginary part: %s"
 #, fuzzy
-#~ msgid "** Can't read signature file <%s> **"
-#~ msgstr "nevar nolasīt 3dview failu <%s> iekš <%s>"
+msgid "** Can't read signature file <%s> **"
+msgstr "nevar nolasīt 3dview failu <%s> iekš <%s>"
 #, fuzzy
-#~ msgid "Illegal group name <%s>"
-#~ msgstr "Nederīga x koordināta <%s>"
+msgid "Illegal group name <%s>"
+msgstr "Nederīga x koordināta <%s>"
 #, fuzzy
-#~ msgid "Illegal signature file name <%s>"
-#~ msgstr "Nederīgs faila nosaukums: %s"
+msgid "Illegal signature file name <%s>"
+msgstr "Nederīgs faila nosaukums: %s"
 #, fuzzy
-#~ msgid "Raster file(s) for Elevation"
-#~ msgstr "Rastra fails(i) priekš Skata%d"
+msgid "Raster file(s) for Elevation"
+msgstr "Rastra fails(i) priekš Skata%d"
-#~ msgid "Raster file(s) for Color"
-#~ msgstr "Rastra fails(i) priekš Krāsām%d"
+msgid "Raster file(s) for Color"
+msgstr "Rastra fails(i) priekš Krāsām%d"
 #, fuzzy
-#~ msgid "Can't clear current graphics window"
-#~ msgstr "Nevar izveidot index"
+msgid "Can't clear current graphics window"
+msgstr "Nevar izveidot index"
 #, fuzzy
-#~ msgid "Cannot use current window"
+msgid "Cannot use current window"
 #, fuzzy
-#~ msgid "No current frame"
-#~ msgstr "Tekošā reģiona nosaukums"
+msgid "No current frame"
+msgstr "Tekošā reģiona nosaukums"
 #, fuzzy
-#~ msgid "Error reading raster map"
-#~ msgstr "kļūda nolasot šūnu failu"
+msgid "Error reading raster map"
+msgstr "kļūda nolasot šūnu failu"
-#~ msgid "Error opening cell-file"
-#~ msgstr "Kļūda atverot šūnu failu"
+msgid "Error opening cell-file"
+msgstr "Kļūda atverot šūnu failu"
-#~ msgid "Error reading from cell-file"
-#~ msgstr "Kļūda nolasot no šūnu faila"
+msgid "Error reading from cell-file"
+msgstr "Kļūda nolasot no šūnu faila"
-#~ msgid "%s: Couldn't open raster <%s@%s>"
-#~ msgstr "%s:Nevarēja atvērt rastra failu <%s@%s>"
+msgid "%s: Couldn't open raster <%s@%s>"
+msgstr "%s:Nevarēja atvērt rastra failu <%s@%s>"
-#~ msgid " Middle: toggle flash color\n"
-#~ msgstr " Vidējā: garena, atšķirīgā krāsā\n"
+msgid " Middle: toggle flash color\n"
+msgstr " Vidējā: garena, atšķirīgā krāsā\n"
 #, fuzzy
-#~ msgid "No current graphics window"
+msgid "No current graphics window"
 #, fuzzy
-#~ msgid "Can't set current graphics window"
+msgid "Can't set current graphics window"
 #, fuzzy
-#~ msgid "Getting graphics window coordinates"
+msgid "Getting graphics window coordinates"
 #, fuzzy
-#~ msgid "Font name or pathname of TTF file"
-#~ msgstr "Ieejas TIFF faila nosaukums"
+msgid "Font name or pathname of TTF file"
+msgstr "Ieejas TIFF faila nosaukums"
 #, fuzzy
-#~ msgid "Setting release of FreeType"
-#~ msgstr ""
-#~ "\n"
-#~ "Ietvara atbrīvošana no FreeType\n"
+msgid "Setting release of FreeType"
+msgstr ""
+"\n"
+"Ietvara atbrīvošana no FreeType\n"
 #, fuzzy
-#~ msgid "Name of frame(s) to save"
+msgid "Name of frame(s) to save"
 #, fuzzy
-#~ msgid "Save current frame"
+msgid "Save current frame"
 #, fuzzy
-#~ msgid "Unknown item type in pad: %s"
-#~ msgstr "Nenosakāms tips: %c"
+msgid "Unknown item type in pad: %s"
+msgstr "Nenosakāms tips: %c"
 #, fuzzy
-#~ msgid "Sets the color of the menu background"
+msgid "Sets the color of the menu background"
 #, fuzzy
-#~ msgid "Sets the color of the menu text"
-#~ msgstr "Nosaka uzraksta krāsu"
+msgid "Sets the color of the menu text"
+msgstr "Nosaka uzraksta krāsu"
 #, fuzzy
-#~ msgid "Sets the color dividing lines of text"
+msgid "Sets the color dividing lines of text"
-#~ msgid "Path to TrueType font (including file name)"
-#~ msgstr "Ceļš līdz TrueType fontam (ieskaitot faila nosaukumu)"
+msgid "Path to TrueType font (including file name)"
+msgstr "Ceļš līdz TrueType fontam (ieskaitot faila nosaukumu)"
 #, fuzzy
-#~ msgid "Invalid font: %s"
-#~ msgstr "nederīgs reģions: %s"
+msgid "Invalid font: %s"
+msgstr "nederīgs reģions: %s"
 #, fuzzy
-#~ msgid "%s: No FreeType definition file"
-#~ msgstr "  reģieons (reģiona definīcijas fails)\n"
+msgid "%s: No FreeType definition file"
+msgstr "  reģieons (reģiona definīcijas fails)\n"
 #, fuzzy
-#~ msgid "One mouse click only"
-#~ msgstr "tikai viens peles klikšķis"
+msgid "One mouse click only"
+msgstr "tikai viens peles klikšķis"
 #, fuzzy
-#~ msgid " Left:    Place text here\n"
+msgid " Left:    Place text here\n"
 #, fuzzy
-#~ msgid " Right:   Quit\n"
-#~ msgstr " Labā: beigt\n"
+msgid " Right:   Quit\n"
+msgstr " Labā: beigt\n"
-#~ msgid "Just redraw given maps using default colors"
-#~ msgstr "Pārzīmēt dotās kartes lietojot noklusētās krāsas"
+msgid "Just redraw given maps using default colors"
+msgstr "Pārzīmēt dotās kartes lietojot noklusētās krāsas"
-#~ msgid "ERROR: can not get \"list\" items"
-#~ msgstr "KĻŪDA: nevar iegūt \"list\" ierakstus"
+msgid "ERROR: can not get \"list\" items"
+msgstr "KĻŪDA: nevar iegūt \"list\" ierakstus"
-#~ msgid "-j flag forced"
-#~ msgstr "-j karogs piespiedu kārtā"
+msgid "-j flag forced"
+msgstr "-j karogs piespiedu kārtā"
-#~ msgid "No map is displayed in GRASS monitor"
+msgid "No map is displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "You must select at least four points"
+msgid "You must select at least four points"
 #, fuzzy
-#~ msgid "Name of graphics monitor to start"
-#~ msgstr "Startējamā/palaižamā grafiskā monitora nosaukums"
+msgid "Name of graphics monitor to start"
+msgstr "Startējamā/palaižamā grafiskā monitora nosaukums"
-#~ msgid "Name of graphics monitor to stop"
-#~ msgstr "Apstādināmā/izslēdzamā grafiskā monitora mosaukums"
+msgid "Name of graphics monitor to stop"
+msgstr "Apstādināmā/izslēdzamā grafiskā monitora mosaukums"
-#~ msgid "Name of graphics monitor to select"
-#~ msgstr "Izvēlētā grafiskā monitora nosaukums"
+msgid "Name of graphics monitor to select"
+msgstr "Izvēlētā grafiskā monitora nosaukums"
-#~ msgid "Name of graphics monitor to unlock"
-#~ msgstr "Atslēdzamā grafiskā monitora nosaukums"
+msgid "Name of graphics monitor to unlock"
+msgstr "Atslēdzamā grafiskā monitora nosaukums"
-#~ msgid "List all monitors"
-#~ msgstr "Izveidot visu ekrānu sarakstu"
+msgid "List all monitors"
+msgstr "Izveidot visu ekrānu sarakstu"
-#~ msgid "List all monitors (with current status)"
-#~ msgstr "Izveidot visu monitoru sarkstu (ar pašreizējo statusu)"
+msgid "List all monitors (with current status)"
+msgstr "Izveidot visu monitoru sarkstu (ar pašreizējo statusu)"
-#~ msgid "Print name of currently selected monitor"
-#~ msgstr "Drukāt izvēlētā ekrāna nosaukumu"
+msgid "Print name of currently selected monitor"
+msgstr "Drukāt izvēlētā ekrāna nosaukumu"
 #, fuzzy
-#~ msgid "Monitor <%s> released"
+msgid "Monitor <%s> released"
 #, fuzzy
-#~ msgid "Error - Locking mechanism failed"
+msgid "Error - Locking mechanism failed"
 #, fuzzy
-#~ msgid "Error choosing frame [%s]\n"
-#~ msgstr "Pārkodēt rastra kartes."
+msgid "Error choosing frame [%s]\n"
+msgstr "Pārkodēt rastra kartes."
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Buttons:\n"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Pogas:\n"
+msgid ""
+"\n"
+"Buttons:\n"
+msgstr ""
+"\n"
+"\n"
+"Pogas:\n"
 #, fuzzy
-#~ msgid "Left:   Select frame\n"
+msgid "Left:   Select frame\n"
 #, fuzzy
-#~ msgid "Right:  Accept frame\n"
-#~ msgstr "Labais: Pamest izvēlni\n"
+msgid "Right:  Accept frame\n"
+msgstr "Labais: Pamest izvēlni\n"
 #, fuzzy
-#~ msgid "Manages display frames on the user's graphics monitor."
+msgid "Manages display frames on the user's graphics monitor."
 #, fuzzy
-#~ msgid "Create a new frame"
+msgid "Create a new frame"
 #, fuzzy
-#~ msgid "Select a frame"
-#~ msgstr "Atlasīt datus no datubāzes."
+msgid "Select a frame"
+msgstr "Atlasīt datus no datubāzes."
 #, fuzzy
-#~ msgid "Print name of current frame"
+msgid "Print name of current frame"
 #, fuzzy
-#~ msgid "List map names displayed in GRASS monitor"
+msgid "List map names displayed in GRASS monitor"
 #, fuzzy
-#~ msgid "Frame to be created/selected"
-#~ msgstr "Fails kurš tiks grizīts/rotēts"
+msgid "Frame to be created/selected"
+msgstr "Fails kurš tiks grizīts/rotēts"
 #, fuzzy
-#~ msgid ""
-#~ "\n"
-#~ "Mouse Buttons:"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
-#~ "Pogas:\n"
+msgid ""
+"\n"
+"Mouse Buttons:"
+msgstr ""
+"\n"
+"\n"
+"Pogas:\n"
 #, fuzzy
-#~ msgid "Left:   Select From\n"
+msgid "Left:   Select From\n"
 #, fuzzy
-#~ msgid ""
-#~ "Right:  Quit\n"
-#~ "\n"
-#~ msgstr "Labā: Iziet\n"
+msgid ""
+"Right:  Quit\n"
+"\n"
+msgstr "Labā: Iziet\n"
 #, fuzzy
-#~ msgid "Monitor: interactive command in redraw"
-#~ msgstr "Monitors: inetraktīvā konada pārzīmēšanā\n"
+msgid "Monitor: interactive command in redraw"
+msgstr "Monitors: inetraktīvā konada pārzīmēšanā\n"
 #, fuzzy
-#~ msgid "found %d visuals of type TrueColor"
-#~ msgstr "atrasti %d uzskates līdzekļi ar TrueColor\n"
+msgid "found %d visuals of type TrueColor"
+msgstr "atrasti %d uzskates līdzekļi ar TrueColor\n"
 #, fuzzy
-#~ msgid "searching for highest bit depth"
-#~ msgstr "meklējam lielāku bitu dziļumu\n"
+msgid "searching for highest bit depth"
+msgstr "meklējam lielāku bitu dziļumu\n"
 #, fuzzy
-#~ msgid "selected %d bit depth"
-#~ msgstr "izvēlēts %d bitu dziļums\n"
+msgid "selected %d bit depth"
+msgstr "izvēlēts %d bitu dziļums\n"
 #, fuzzy
-#~ msgid "Monitor: waitpid: expected %d but got %d"
-#~ msgstr "Monitors: waitpid: sagaidāmais %d iegūtais %d\n"
+msgid "Monitor: waitpid: expected %d but got %d"
+msgstr "Monitors: waitpid: sagaidāmais %d iegūtais %d\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName failed"
-#~ msgstr "Monitors: XGetWMName izgāzies\n"
+msgid "Monitor: XGetWMName failed"
+msgstr "Monitors: XGetWMName izgāzies\n"
 #, fuzzy
-#~ msgid "Monitor: XGetWMName: bad result"
-#~ msgstr "Monitors: XGetWMName: slikts rezultāts\n"
+msgid "Monitor: XGetWMName: bad result"
+msgstr "Monitors: XGetWMName: slikts rezultāts\n"
 #, fuzzy
-#~ msgid "<%s> is an illegal region name"
-#~ msgstr "izejas līmeņa nosaukums"
+msgid "<%s> is an illegal region name"
+msgstr "izejas līmeņa nosaukums"
 #, fuzzy
-#~ msgid "Erasing monitors ..."
+msgid "Erasing monitors ..."
 #, fuzzy
-#~ msgid "Could not open input file <%s>."
+msgid "Could not open input file <%s>."
 #, fuzzy
-#~ msgstr "Neiespējami atvērt šūnu failu[%s]"
+msgstr "Neiespējami atvērt šūnu failu[%s]"
-#~ msgid "Over-riding projection check."
-#~ msgstr "Ignorē projekciju pārbaudi."
+msgid "Over-riding projection check."
+msgstr "Ignorē projekciju pārbaudi."
 #, fuzzy
-#~ msgid "not found\n"
-#~ msgstr "reģions <%s> nav atrasts"
+msgid "not found\n"
+msgstr "reģions <%s> nav atrasts"
 #, fuzzy
-#~ msgid "Raster map not found."
+msgid "Raster map not found."
 #, fuzzy
-#~ msgid "%s: can't read range for [%s]"
+msgid "%s: can't read range for [%s]"
 #, fuzzy
-#~ msgid "Raster file [%s] not found"
+msgid "Raster file [%s] not found"
 #, fuzzy
-#~ msgid "It was not possible writing in <%s>."
+msgid "It was not possible writing in <%s>."
 #, fuzzy
-#~ msgid "Cannot create table: '%s'"
+msgid "Cannot create table: '%s'"
 #, fuzzy
-#~ msgid "Unable to get category list <%s>, editing terminated"
+msgid "Unable to get category list <%s>, editing terminated"
 #, fuzzy
 #, fuzzy
 #, fuzzy
 #, fuzzy
-#~ msgid "Unknown query tool '%s'"
-#~ msgstr "Nezināms/nepazīstms tips"
+msgid "Unknown query tool '%s'"
+msgstr "Nezināms/nepazīstms tips"
 #, fuzzy
-#~ msgid "No layer database connection"
+msgid "No layer database connection"
 #, fuzzy
-#~ msgid "%d categories loaded from the database"
-#~ msgstr "%d kategorijas ielādētas no tabulas\n"
+msgid "%d categories loaded from the database"
+msgstr "%d kategorijas ielādētas no tabulas\n"
 #, fuzzy
-#~ msgid "Done"
-#~ msgstr "Padarīts\n"
+msgid "Done"
+msgstr "Padarīts\n"
-#~ msgid "Cannot open OGR data source '%s'"
-#~ msgstr "Nevar atvērt OGR datu avotu '%s'"
+msgid "Cannot open OGR data source '%s'"
+msgstr "Nevar atvērt OGR datu avotu '%s'"
-#~ msgid "Cannot create layer"
-#~ msgstr "Nevar izveidot slāni"
+msgid "Cannot create layer"
+msgstr "Nevar izveidot slāni"
 #, fuzzy
-#~ msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
+msgid "Vector map <%s> in location <%s> in mapset <%s> not available"
 #, fuzzy
-#~ msgid "Column type [%d] not supported"
-#~ msgstr "Kolonas tips nav atbalstīts"
+msgid "Column type [%d] not supported"
+msgstr "Kolonas tips nav atbalstīts"
 #, fuzzy
-#~ msgid "Cannot read map header for <%s>"
-#~ msgstr "Nevar nolasīt faila informāciju"
+msgid "Cannot read map header for <%s>"
+msgstr "Nevar nolasīt faila informāciju"
 #, fuzzy
-#~ msgid "Cannot read category file for <%s>"
-#~ msgstr "nevar nolasīt reģionu <%s> pie <%s>"
+msgid "Cannot read category file for <%s>"
+msgstr "nevar nolasīt reģionu <%s> pie <%s>"
 #, fuzzy
-#~ msgid "%s: <%s> raster map not found"
-#~ msgstr ""
+msgid "%s: <%s> raster map not found"
+msgstr ""
 #, fuzzy
-#~ msgid "%s - map not found"
-#~ msgstr "%s - karte nav atrasta"
+msgid "%s - map not found"
+msgstr "%s - karte nav atrasta"
 #, fuzzy
-#~ msgid "%s: Cannot open [%s]"
-#~ msgstr "nevar atvērt %s"
+msgid "%s: Cannot open [%s]"
+msgstr "nevar atvērt %s"
 #, fuzzy
-#~ msgid "%s not found"
+msgid "%s not found"
 #, fuzzy
-#~ msgid "Vector map %s - not found"
+msgid "Vector map %s - not found"
-#~ msgid "Raster map containing elevation data"
-#~ msgstr "Reljefa rastra karte"
+msgid "Raster map containing elevation data"
+msgstr "Reljefa rastra karte"
-#~ msgid "Raster map name for storing results"
-#~ msgstr "Rastra kartes nosaukums, kur saglabāt rezultātus"
+msgid "Raster map name for storing results"
+msgstr "Rastra kartes nosaukums, kur saglabāt rezultātus"
-#~ msgid "Height of the viewing location"
-#~ msgstr "Skatu punkta augstums"
+msgid "Height of the viewing location"
+msgstr "Skatu punkta augstums"
 #, fuzzy
-#~ msgid "%s: <%s> cellfile not found"
+msgid "%s: <%s> cellfile not found"
 #, fuzzy
-#~ msgid "Cell file [%s] not found\n"
+msgid "Cell file [%s] not found\n"
 #, fuzzy
-#~ msgid "rgb cell map [%s] not found\n"
+msgid "rgb cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "vector cell map [%s] not found\n"
+msgid "vector cell map [%s] not found\n"
 #, fuzzy
-#~ msgid "%s - %s not found"
-#~ msgstr "%s - nav atrasts"
+msgid "%s - %s not found"
+msgstr "%s - nav atrasts"
-#~ msgid "can't read header for <%s> in <%s>"
-#~ msgstr "nevar nolasīt ievadu <%s> pie <%s>"
+msgid "can't read header for <%s> in <%s>"
+msgstr "nevar nolasīt ievadu <%s> pie <%s>"
-#~ msgid "region <%s> not found"
+msgid "region <%s> not found"
-#~ msgid "can't read region <%s> in <%s>"
+msgid "can't read region <%s> in <%s>"
-#~ msgid "can't open 3dview file <%s> in <%s>"
-#~ msgstr "nevar atvērt 3d skata failu <%s> no <%s>"
+msgid "can't open 3dview file <%s> in <%s>"
+msgstr "nevar atvērt 3d skata failu <%s> no <%s>"
-#~ msgid "can't read 3dview file <%s> in <%s>"
+msgid "can't read 3dview file <%s> in <%s>"
-#~ msgid "can't open vector map <%s> in <%s>"
+msgid "can't open vector map <%s> in <%s>"
-#~ msgid "invalid region: %s"
+msgid "invalid region: %s"
 #, fuzzy
-#~ msgid "Creating support files"
+msgid "Creating support files"
-#~ msgid "can't open %s"
+msgid "can't open %s"
 #, fuzzy
-#~ msgid "%s file [%s] not found!"
+msgid "%s file [%s] not found!"
 #, fuzzy
-#~ msgid "%s: %s - map not found"
+msgid "%s: %s - map not found"
 #, fuzzy
-#~ msgid "%s - not found"
+msgid "%s - not found"
 #, fuzzy
-#~ msgid "Cannot read %s"
+msgid "Cannot read %s"
-#~ msgid "[%s] map not found."
-#~ msgstr "[%s] karte nav atrasta."
+msgid "[%s] map not found."
+msgstr "[%s] karte nav atrasta."
-#~ msgid "[%s] map not found"
-#~ msgstr "[%s] karte nav atrasta"
+msgid "[%s] map not found"
+msgstr "[%s] karte nav atrasta"
 #, fuzzy
-#~ msgid "elevation file [%s] not found"
+msgid "elevation file [%s] not found"
 #, fuzzy
-#~ msgstr "Nevar aprakstīt tabulu %s"
+msgstr "Nevar aprakstīt tabulu %s"
 #, fuzzy
-#~ msgid "Cannot insert values: %s"
-#~ msgstr "Nevar izveidot ierakstu tabulā: %s"
+msgid "Cannot insert values: %s"
+msgstr "Nevar izveidot ierakstu tabulā: %s"
 #, fuzzy
-#~ msgid "%s given an illegal number of points [%d]"
-#~ msgstr ""
-#~ "\n"
-#~ "\n"
+msgid "%s given an illegal number of points [%d]"
+msgstr ""
+"\n"
+"\n"
 #, fuzzy
-#~ msgstr "Nevar atvērt datubāzi  %s pēc adreses %s"
+msgstr "Nevar atvērt datubāzi  %s pēc adreses %s"
 #, fuzzy
-#~ msgid "No DB connection settings defined. Set with db.connect"
-#~ msgstr ""
-#~ "Nav db pieslēguma nosacījumi definēti. Nosacījumus definēt ar db.connect"
+msgid "No DB connection settings defined. Set with db.connect"
+msgstr ""
+"Nav db pieslēguma nosacījumi definēti. Nosacījumus definēt ar db.connect"
-#~ msgid "Could not find input %s"
-#~ msgstr "Nevar atrast ieeju %s"
+msgid "Could not find input %s"
+msgstr "Nevar atrast ieeju %s"
-#~ msgid "Could not find input map <%s>"
-#~ msgstr "Nevar atrast ieejas karti <%s>"
+msgid "Could not find input map <%s>"
+msgstr "Nevar atrast ieejas karti <%s>"
 #, fuzzy
-#~ msgid "Unkown item type in pad: %s"
+msgid "Unkown item type in pad: %s"
 #, fuzzy
-#~ msgid "Database connection not defined\n"
-#~ msgstr "Datubāzes pieslēgums nav definēts\n"
+msgid "Database connection not defined\n"
+msgstr "Datubāzes pieslēgums nav definēts\n"
 #, fuzzy
-#~ msgid "Can't read header for <%s> in <%s>"
+msgid "Can't read header for <%s> in <%s>"
 #, fuzzy
-#~ msgid "Can't read header for 3D raster <%s> in <%s>"
+msgid "Can't read header for 3D raster <%s> in <%s>"
-#~ msgid "%s in %s: %s"
-#~ msgstr "%s iekš %s: %s"
+msgid "%s in %s: %s"
+msgstr "%s iekš %s: %s"
 #, fuzzy
-#~ msgid "Can't write region <%s>"
-#~ msgstr "Nevar rakstīt <%s>"
+msgid "Can't write region <%s>"
+msgstr "Nevar rakstīt <%s>"
 #, fuzzy
-#~ msgid "No graphics device selected."
-#~ msgstr "Nav grafiskā iekārta izvēlēta"
+msgid "No graphics device selected."
+msgstr "Nav grafiskā iekārta izvēlēta"
 #, fuzzy
-#~ msgid "Unable to read raster row."
-#~ msgstr "Rastra kartes nosaukums"
+msgid "Unable to read raster row."
+msgstr "Rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "Training map [%s] not found."
+msgid "Training map [%s] not found."
 #, fuzzy
-#~ msgid "%s map not found"
+msgid "%s map not found"
 #, fuzzy
 #, fuzzy
-#~ msgid "Illegal file name: %s"
+msgid "Illegal file name: %s"
 #, fuzzy
-#~ msgstr "Nav iespēju atvērt šūnu failu [%s]"
+msgstr "Nav iespēju atvērt šūnu failu [%s]"
-#~ msgid "%s: %s - raster map not found"
-#~ msgstr "%s: %s - rastra karte nav atrasta"
+msgid "%s: %s - raster map not found"
+msgstr "%s: %s - rastra karte nav atrasta"
 #, fuzzy
-#~ msgid "%s: %s - not found"
+msgid "%s: %s - not found"
 #, fuzzy
-#~ msgid "%s: %s - can't open"
+msgid "%s: %s - can't open"
 #, fuzzy
-#~ msgid "Reading input map (%s)    ... "
-#~ msgstr "Lasam dig failu... \n"
+msgid "Reading input map (%s)    ... "
+msgstr "Lasam dig failu... \n"
 #, fuzzy
-#~ msgid "%s: %s - can't create raster map"
+msgid "%s: %s - can't create raster map"
 #, fuzzy
-#~ msgid "Writing output map (%s)   ... "
+msgid "Writing output map (%s)   ... "
 #, fuzzy
-#~ msgid "Reading raster map... "
-#~ msgstr "Lasam dig_att failu...\n"
+msgid "Reading raster map... "
+msgstr "Lasam dig_att failu...\n"
 #, fuzzy
-#~ msgid "Writing raster map... "
+msgid "Writing raster map... "
-#~ msgid "Category list: e.g. 1,3-8,13"
-#~ msgstr "Kategoriju liste: piem. 1,3-8,13"
+msgid "Category list: e.g. 1,3-8,13"
+msgstr "Kategoriju liste: piem. 1,3-8,13"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find file %s"
+msgid "Cannot find file %s"
 #, fuzzy
-#~ msgid "Cannot get header for %s"
+msgid "Cannot get header for %s"
 #, fuzzy
-#~ msgid "Cannot create raster map %s"
+msgid "Cannot create raster map %s"
 #, fuzzy
-#~ msgid "Cannot create vector map %s"
-#~ msgstr "Nevar atrast ieejas karti <%s>\n"
+msgid "Cannot create vector map %s"
+msgstr "Nevar atrast ieejas karti <%s>\n"
 #, fuzzy
-#~ msgid "Cannot create raster map '%s'"
+msgid "Cannot create raster map '%s'"
 #, fuzzy
-#~ msgid "Number of raster rows to hold in memory"
+msgid "Number of raster rows to hold in memory"
 #, fuzzy
-#~ msgstr "Drukāt tikai rastra kartes tipu"
+msgstr "Drukāt tikai rastra kartes tipu"
 #, fuzzy
-#~ msgid "unknown type: %d"
+msgid "unknown type: %d"
-#~ msgid "Cannot open raster map [%s]"
+msgid "Cannot open raster map [%s]"
 #, fuzzy
-#~ msgid "Cannot get raster band."
+msgid "Cannot get raster band."
 #, fuzzy
-#~ msgid "Cannot allocate buffer for reading null values."
-#~ msgstr "Nevar noteikt laukuma centroīdu"
+msgid "Cannot allocate buffer for reading null values."
+msgstr "Nevar noteikt laukuma centroīdu"
 #, fuzzy
-#~ msgid "Cannot read GRASS raster."
+msgid "Cannot read GRASS raster."
-#~ msgid "Cannot write GDAL raster."
-#~ msgstr "Nevar rakstīt GDAL rastru."
+msgid "Cannot write GDAL raster."
+msgstr "Nevar rakstīt GDAL rastru."
 #, fuzzy
-#~ msgid "Cannot get [%s] driver"
+msgid "Cannot get [%s] driver"
 #, fuzzy
-#~ msgid "Couldn't set geo transform."
+msgid "Couldn't set geo transform."
 #, fuzzy
-#~ msgid "Couldn't set projection."
+msgid "Couldn't set projection."
 #, fuzzy
-#~ msgid "Cannot export [%s] raster map."
+msgid "Cannot export [%s] raster map."
 #, fuzzy
-#~ msgid "Cannot create [%s] raster map using [%s] driver."
+msgid "Cannot create [%s] raster map using [%s] driver."
 #, fuzzy
-#~ msgid "Cannot read header of raster map <%s>"
+msgid "Cannot read header of raster map <%s>"
 #, fuzzy
-#~ msgid "Cannot open TIFF file <%s>"
+msgid "Cannot open TIFF file <%s>"
 #, fuzzy
-#~ msgid "Cannot open output map."
-#~ msgstr "Nevar atvērt dig_cats failu"
+msgid "Cannot open output map."
+msgstr "Nevar atvērt dig_cats failu"
 #, fuzzy
-#~ msgid "Illegal file name. Please try another."
+msgid "Illegal file name. Please try another."
 #, fuzzy
-#~ msgid "%s: can't open %s"
+msgid "%s: can't open %s"
 #, fuzzy
-#~ msgid "Reading raster map <%s> ..."
+msgid "Reading raster map <%s> ..."
 #, fuzzy
-#~ msgid "memory allocation failure"
+msgid "memory allocation failure"
 #, fuzzy
-#~ msgid "Can't find data map."
-#~ msgstr "Nevar izveidot datubāzu sarakstu"
+msgid "Can't find data map."
+msgstr "Nevar izveidot datubāzu sarakstu"
 #, fuzzy
-#~ msgid "Output terrain only vector map name"
+msgid "Output terrain only vector map name"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at the topological level"
+msgid "Cannot open vector map <%s> at the topological level"
 #, fuzzy
-#~ msgid "Rebuilding topology ..."
+msgid "Rebuilding topology ..."
-#~ msgid "No record for cat = %d"
-#~ msgstr "Nav ieraksta priekš līnijas cat= %d"
+msgid "No record for cat = %d"
+msgstr "Nav ieraksta priekš līnijas cat= %d"
 #, fuzzy
-#~ msgid "Removing duplicates ..."
+msgid "Removing duplicates ..."
 #, fuzzy
-#~ msgid "Attaching islands ..."
-#~ msgstr "Pievieno kategorijas...\n"
+msgid "Attaching islands ..."
+msgstr "Pievieno kategorijas...\n"
 #, fuzzy
-#~ msgid "Cannot calculate area centroid."
+msgid "Cannot calculate area centroid."
 #, fuzzy
-#~ msgid "Attaching centroids ..."
+msgid "Attaching centroids ..."
 #, fuzzy
-#~ msgid "Vector map <%s> not found in current mapset"
+msgid "Vector map <%s> not found in current mapset"
 #, fuzzy
-#~ msgid "Error allocating memory for `lines_visited'"
+msgid "Error allocating memory for `lines_visited'"
 #, fuzzy
-#~ msgid "The number of lines in the input vector map is [%d]"
+msgid "The number of lines in the input vector map is [%d]"
 #, fuzzy
-#~ msgid "Database connection not defined for layer <%d>"
-#~ msgstr "Datubāzes konekcija nav definēta"
+msgid "Database connection not defined for layer <%d>"
+msgstr "Datubāzes konekcija nav definēta"
-#~ msgid "Cannot open select cursor"
-#~ msgstr "Nevar atvērt izvēlēto marķieri/kursoru"
+msgid "Cannot open select cursor"
+msgstr "Nevar atvērt izvēlēto marķieri/kursoru"
 #, fuzzy
-#~ msgid "Cannot get layer info"
+msgid "Cannot get layer info"
 #, fuzzy
-#~ msgid "can't open raster map [%s]"
+msgid "can't open raster map [%s]"
 #, fuzzy
 #, fuzzy
-#~ msgid "Editing tool"
-#~ msgstr "Tīrīšanas rīks"
+msgid "Editing tool"
+msgstr "Tīrīšanas rīks"
 #, fuzzy
-#~ msgid "Snap also to vertex (not implemented yet)"
+msgid "Snap also to vertex (not implemented yet)"
 #, fuzzy
-#~ msgid "Cannot copy line %d, editing terminated"
+msgid "Cannot copy line %d, editing terminated"
 #, fuzzy
-#~ msgid "No layer database connection."
+msgid "No layer database connection."
 #, fuzzy
 #, fuzzy
-#~ msgstr "%-5d mirušās/neizmantotās līnijas izlaistas\n"
+msgstr "%-5d mirušās/neizmantotās līnijas izlaistas\n"
 #, fuzzy
-#~ msgid "Could not open ASCII file <%s>"
+msgid "Could not open ASCII file <%s>"
-#~ msgid "Print vector map region only"
-#~ msgstr "Drukāt tikai vektoru kartes reģionu"
+msgid "Print vector map region only"
+msgstr "Drukāt tikai vektoru kartes reģionu"
 #, fuzzy
-#~ msgid "Cannot open vector map <%s> at topo level [%d]"
+msgid "Cannot open vector map <%s> at topo level [%d]"
 #, fuzzy
-#~ msgid "Cannot get layer info for vector map <%s>"
-#~ msgstr "Vektorkartes nosaukums"
+msgid "Cannot get layer info for vector map <%s>"
 #, fuzzy
 #, fuzzy
-#~ msgid "Could not find vector map <%s> in current mapset"
-#~ msgstr "Nevar atrast ieejas vektoru karti <%s>"
+msgid "Could not find vector map <%s> in current mapset"
+msgstr "Nevar atrast ieejas vektoru karti <%s>"
-#~ msgid "Could not find input map <%s>."
-#~ msgstr "Nevar atrast ieejas karti <%s>."
+msgid "Could not find input map <%s>."
+msgstr "Nevar atrast ieejas karti <%s>."
 #, fuzzy
-#~ msgid "[%d] features written"
-#~ msgstr "%d punkti ierakstīti izejas kartē\n"
+msgid "[%d] features written"
+msgstr "%d punkti ierakstīti izejas kartē\n"
 #, fuzzy
 #, fuzzy
-#~ msgid "Output map where segments will be written"
-#~ msgstr "Izejas karte kurā tiks ierakstīti punkti"
+msgid "Output map where segments will be written"
+msgstr "Izejas karte kurā tiks ierakstīti punkti"
 #, fuzzy
-#~ msgid "<%s> cellfile not found"
+msgid "<%s> cellfile not found"
 #, fuzzy
-#~ msgid "Database record for cat %d not found"
+msgid "Database record for cat %d not found"
 #, fuzzy
-#~ msgid "Not able to open vector map <%s>"
+msgid "Not able to open vector map <%s>"
 #, fuzzy
-#~ msgid "No table."
-#~ msgstr "DB tabula"
+msgid "No table."
+msgstr "DB tabula"
-#~ msgid "driver name"
-#~ msgstr "draivera nosaukums"
+msgid "driver name"
+msgstr "draivera nosaukums"
-#~ msgid "database name"
-#~ msgstr "datbāzes vārds"
+msgid "database name"
+msgstr "datbāzes vārds"
-#~ msgid "Driver name"
-#~ msgstr "Draivera nosaukums"
+msgid "Driver name"
+msgstr "Draivera nosaukums"
-#~ msgid "Cannot list databases."
+msgid "Cannot list databases."
-#~ msgid "database location"
-#~ msgstr "datubāzes atrašnās"
+msgid "database location"
+msgstr "datubāzes atrašnās"
-#~ msgid "Table name, select all from this table"
-#~ msgstr "Tabulas nosaukums, atlasīt visu no šīs tabulas"
+msgid "Table name, select all from this table"
+msgstr "Tabulas nosaukums, atlasīt visu no šīs tabulas"
-#~ msgid "output field separator"
-#~ msgstr "izejas faila starplika/dalītājs"
+msgid "output field separator"
+msgstr "izejas faila starplika/dalītājs"
-#~ msgid "output vertical record separator"
-#~ msgstr "izvejas vertikālā starplika/dalītājs"
+msgid "output vertical record separator"
+msgstr "izvejas vertikālā starplika/dalītājs"
-#~ msgid "null value indicator"
-#~ msgstr "nulles vērtības indikators"
+msgid "null value indicator"
+msgstr "nulles vērtības indikators"
-#~ msgid "do not include column names in output"
-#~ msgstr "neiekļaut kolonu vārdus izejas datos"
+msgid "do not include column names in output"
+msgstr "neiekļaut kolonu vārdus izejas datos"
-#~ msgid "vertical output (instead of horizontal)"
-#~ msgstr "vertikālā izdruka(pretēji horizontālai)"
+msgid "vertical output (instead of horizontal)"
+msgstr "vertikālā izdruka(pretēji horizontālai)"
-#~ msgid "Name of existing raster map"
-#~ msgstr "Eksistējošas rastra kartes nosaukums"
+msgid "Name of existing raster map"
+msgstr "Eksistējošas rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "Cannot find mapset for %s"
-#~ msgstr "Nevar izveidot jaunu rindu: %s"
+msgid "Cannot find mapset for %s"
+msgstr "Nevar izveidot jaunu rindu: %s"
 #, fuzzy
-#~ msgid "Cannot open File %s"
+msgid "Cannot open File %s"
 #, fuzzy
-#~ msgid "Not able to open file for [%s]"
+msgid "Not able to open file for [%s]"
 #, fuzzy
-#~ msgid "Can't open label file [%s]"
+msgid "Can't open label file [%s]"
-#~ msgid "unable to open [%s] in [%s]"
-#~ msgstr "nav iespēju atvērt [%s] iekš [%s]"
+msgid "unable to open [%s] in [%s]"
+msgstr "nav iespēju atvērt [%s] iekš [%s]"
-#~ msgid "warning: unable to open [%s] in [%s]"
-#~ msgstr "brīdinājums: neiespējami atvērt [%s] iekš [%s]"
+msgid "warning: unable to open [%s] in [%s]"
+msgstr "brīdinājums: neiespējami atvērt [%s] iekš [%s]"
 #, fuzzy
-#~ msgid "Unable to find input cell map '%s'"
+msgid "Unable to find input cell map '%s'"
 #, fuzzy
-#~ msgstr "Importējamais rastra fails"
+msgstr "Importējamais rastra fails"
 #, fuzzy
-#~ msgid "Unable to create raster map [%s]"
+msgid "Unable to create raster map [%s]"
 #, fuzzy
-#~ msgid "Unable to create output <%s>"
+msgid "Unable to create output <%s>"
 #, fuzzy
-#~ msgid "Input file [%s] not found."
-#~ msgstr "Ieejas vektors netika atrasts."
+msgid "Input file [%s] not found."
+msgstr "Ieejas vektors netika atrasts."
 #, fuzzy
-#~ msgid "Unable to open output file <%s>."
+msgid "Unable to open output file <%s>."
 #, fuzzy
-#~ msgid "Could not open temporary file: [%s]"
+msgid "Could not open temporary file: [%s]"
 #, fuzzy
-#~ msgid "Could not open input file [%s]"
+msgid "Could not open input file [%s]"
 #, fuzzy
-#~ msgid "unable to create raster"
+msgid "unable to create raster"
 #, fuzzy
 #, fuzzy
-#~ msgid "%s: Unable to find raster map <%s>"
+msgid "%s: Unable to find raster map <%s>"
 #, fuzzy
-#~ msgid "%s: Unable to open raster map <%s> in mapset <%s>"
+msgid "%s: Unable to open raster map <%s> in mapset <%s>"
 #, fuzzy
-#~ msgid "%s:  Unable to open output raster map <%s>"
+msgid "%s:  Unable to open output raster map <%s>"
 #, fuzzy
-#~ msgid "Vector <%s> could not be opened"
+msgid "Vector <%s> could not be opened"
 #, fuzzy
-#~ msgid "No db connection for driver <%s> defined. Run db.connect."
-#~ msgstr "Nav db pieslēgums draiverim <%s> definēts. Run db.connect"
+msgid "No db connection for driver <%s> defined. Run db.connect."
+msgstr "Nav db pieslēgums draiverim <%s> definēts. Run db.connect"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot open labels <%s>"
+msgid "Cannot open labels <%s>"
 #, fuzzy
-#~ msgid "Cannot fetch data from table"
-#~ msgstr "Nevar atlasīt datus no tabulas"
+msgid "Cannot fetch data from table"
+msgstr "Nevar atlasīt datus no tabulas"
 #, fuzzy
-#~ msgid ""
-#~ "OGR output datasource name. For example:\n"
-#~ "\t\tESRI Shapefile: filename or directory for storage\n"
-#~ "\t\tMapInfo File: filename or directory for storage"
-#~ msgstr ""
-#~ "OGR datu avota nosaukums. Piemēri:\n"
-#~ "\t\tESRI Shapefile: mape ar failiem\n"
-#~ "\t\tMapInfo fails: mape ar failiem"
+msgid ""
+"OGR output datasource name. For example:\n"
+"\t\tESRI Shapefile: filename or directory for storage\n"
+"\t\tMapInfo File: filename or directory for storage"
+msgstr ""
+"OGR datu avota nosaukums. Piemēri:\n"
+"\t\tESRI Shapefile: mape ar failiem\n"
+"\t\tMapInfo fails: mape ar failiem"
 #, fuzzy
-#~ msgid "SVG file <%s> cannot be opened"
+msgid "SVG file <%s> cannot be opened"
 #, fuzzy
-#~ msgid "Querying input '%s' ... "
-#~ msgstr "Lasa %s ..."
+msgid "Querying input '%s' ... "
+msgstr "Lasa %s ..."
 #, fuzzy
-#~ msgid "Copying %s input lines ... "
-#~ msgstr "Izveidot punktus visā garumā ilīniju garumā"
+msgid "Copying %s input lines ... "
+msgstr "Izveidot punktus visā garumā ilīniju garumā"
 #, fuzzy
 #, fuzzy
-#~ msgid "no record for cat = %d"
-#~ msgstr "Nav ieraksta priekš līnijas (cat= %d)"
+msgid "no record for cat = %d"
+msgstr "Nav ieraksta priekš līnijas (cat= %d)"
 #, fuzzy
-#~ msgid "cannot insert row: %s"
+msgid "cannot insert row: %s"
 #, fuzzy
-#~ msgid "Cannot find line of cat %d"
-#~ msgstr "Nevar atrast vektoru karti [%s]"
+msgid "Cannot find line of cat %d"
+msgstr "Nevar atrast vektoru karti [%s]"
 #, fuzzy
 #, fuzzy
-#~ msgid ""
-#~ "Database connection not defined for layer [%d]. Use v.db.connect first"
+msgid "Database connection not defined for layer [%d]. Use v.db.connect first"
 #, fuzzy
-#~ msgid "Transforms a vector map via a set of tie points."
-#~ msgstr "Eksportēt GRASS rastru uz bināro masīvu."
+msgid "Transforms a vector map via a set of tie points."
+msgstr "Eksportēt GRASS rastru uz bināro masīvu."
 #, fuzzy
-#~ msgid "Raster map <%s>] not found"
+msgid "Raster map <%s>] not found"
-#~ msgid "Cannot start driver '%s'."
-#~ msgstr "Nevar iedarbināt draiveri '%s'."
+msgid "Cannot start driver '%s'."
+msgstr "Nevar iedarbināt draiveri '%s'."
-#~ msgid "Cannot describe table"
-#~ msgstr "Nevar aprakstīt tabulu "
+msgid "Cannot describe table"
+msgstr "Nevar aprakstīt tabulu "
-#~ msgid "Cannot start driver <%s>."
-#~ msgstr "Nevar iedarbināt draiveri <%s>."
+msgid "Cannot start driver <%s>."
+msgstr "Nevar iedarbināt draiveri <%s>."
-#~ msgid "Cannot write to <%s>"
+msgid "Cannot write to <%s>"
-#~ msgid "Not able to open cellfile for [%s]"
+msgid "Not able to open cellfile for [%s]"
 #, fuzzy
-#~ msgid "Not able to find cellfile [%s]"
+msgid "Not able to find cellfile [%s]"
-#~ msgid "Raster file [%s] not available"
-#~ msgstr "Rastra fails [%s] nav pieejams"
+msgid "Raster file [%s] not available"
+msgstr "Rastra fails [%s] nav pieejams"
 #, fuzzy
-#~ msgid "Raster map [%s] not found"
+msgid "Raster map [%s] not found"
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]"
+msgid "Unable to open raster map [%s]"
-#~ msgid "Vector file [%s] not available"
-#~ msgstr "Vektoru fails [%s] nav pieejams"
+msgid "Vector file [%s] not available"
+msgstr "Vektoru fails [%s] nav pieejams"
-#~ msgid "Cannot open driver %s"
-#~ msgstr "Nevar atvērt draiveri %s"
+msgid "Cannot open driver %s"
+msgstr "Nevar atvērt draiveri %s"
 #, fuzzy
-#~ msgid "<%s> illegal name"
-#~ msgstr "%s - nederīgs nosaukums"
+msgid "<%s> illegal name"
+msgstr "%s - nederīgs nosaukums"
 #, fuzzy
-#~ msgid "%s: %s - Unable to open the input raster map\n"
+msgid "%s: %s - Unable to open the input raster map\n"
 #, fuzzy
-#~ msgid "%s: %s - illegal name for output raster map."
+msgid "%s: %s - illegal name for output raster map."
 #, fuzzy
-#~ msgid "Exports GRASS raster data into various formats (requires GDAL)."
+msgid "Exports GRASS raster data into various formats (requires GDAL)."
-#~ msgid "Couldn't find raster map %s"
+msgid "Couldn't find raster map %s"
 #, fuzzy
-#~ msgid "%s: <%s> not found"
+msgid "%s: <%s> not found"
 #, fuzzy
-#~ msgid "%s: Cannot open <%s>"
+msgid "%s: Cannot open <%s>"
-#~ msgid "Cannot find %s"
-#~ msgstr "Nevar atrast %s"
+msgid "Cannot find %s"
+msgstr "Nevar atrast %s"
 #, fuzzy
-#~ msgid "could not read range file"
+msgid "could not read range file"
 #, fuzzy
-#~ msgid "Filtering [%s] in [%s]"
+msgid "Filtering [%s] in [%s]"
 #, fuzzy
 #, fuzzy
-#~ msgid "Closing raster map"
+msgid "Closing raster map"
 #, fuzzy
-#~ msgid "Swap temp files"
+msgid "Swap temp files"
 #, fuzzy
-#~ msgid "Writing [%s]"
+msgid "Writing [%s]"
 #, fuzzy
-#~ msgid "%s: illegal map name"
+msgid "%s: illegal map name"
-#~ msgid "Name of the new raster map"
-#~ msgstr "Jaunas rastra kartes nosaukums"
+msgid "Name of the new raster map"
+msgstr "Jaunas rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "%s: <%s> illegal file name"
+msgid "%s: <%s> illegal file name"
 #, fuzzy
-#~ msgid "can't open raster map <%s> in mapset %s"
+msgid "can't open raster map <%s> in mapset %s"
 #, fuzzy
-#~ msgid "Checking location %s, mapset %s:"
-#~ msgstr "nevar nolasīt līniju ieejas paaugstinājumu kartē "
+msgid "Checking location %s, mapset %s:"
+msgstr "nevar nolasīt līniju ieejas paaugstinājumu kartē "
 #, fuzzy
-#~ msgid "Input map [%s] in location [%s] in mapset [%s] not found."
+msgid "Input map [%s] in location [%s] in mapset [%s] not found."
 #, fuzzy
-#~ msgid "Error writing output map"
+msgid "Error writing output map"
 #, fuzzy
-#~ msgid "<%s> is illegal file name"
+msgid "<%s> is illegal file name"
 #, fuzzy
-#~ msgid "[%s] is an illegal file name"
+msgid "[%s] is an illegal file name"
 #, fuzzy
-#~ msgid "no rules specified"
-#~ msgstr "Nav norādīta karte"
+msgid "no rules specified"
+msgstr "Nav norādīta karte"
-#~ msgid "Can't open temp file [%s]"
-#~ msgstr "Nevar atvērt pagaidu failu [%s]"
+msgid "Can't open temp file [%s]"
+msgstr "Nevar atvērt pagaidu failu [%s]"
 #, fuzzy
-#~ msgid "%s - illegal name "
+msgid "%s - illegal name "
 #, fuzzy
-#~ msgid "Couldn't find raster map [%s]"
+msgid "Couldn't find raster map [%s]"
 #, fuzzy
-#~ msgid "%s in %s -can't open raster map"
+msgid "%s in %s -can't open raster map"
 #, fuzzy
-#~ msgid "%s - can't create raster map"
+msgid "%s - can't create raster map"
 #, fuzzy
-#~ msgid "%s: can't create %s"
+msgid "%s: can't create %s"
 #, fuzzy
-#~ msgid "Cell file [%s] not found"
+msgid "Cell file [%s] not found"
 #, fuzzy
-#~ msgid "Could not open elevation map"
-#~ msgstr "Nevar atvērt karti %s"
+msgid "Could not open elevation map"
+msgstr "Nevar atvērt karti %s"
 #, fuzzy
-#~ msgid "Could not open output map"
+msgid "Could not open output map"
 #, fuzzy
-#~ msgid "Cannot create output map [%s]"
+msgid "Cannot create output map [%s]"
 #, fuzzy
-#~ msgid "Database's name couldn't be read"
+msgid "Database's name couldn't be read"
 #, fuzzy
-#~ msgid "Cannot create vector map <%s>"
+msgid "Cannot create vector map <%s>"
 #, fuzzy
-#~ msgid ""
-#~ "Interpolation: No database connection for driver <%s> defined. Run db."
-#~ "connect"
+msgid ""
+"Interpolation: No database connection for driver <%s> defined. Run db.connect"
 #, fuzzy
-#~ msgid "Could not find input map <%s> in current mapset."
+msgid "Could not find input map <%s> in current mapset."
 #, fuzzy
-#~ msgid "Vector file [%s] not available in search list"
+msgid "Vector file [%s] not available in search list"
 #, fuzzy
-#~ msgid "Cannot open database <%s>"
+msgid "Cannot open database <%s>"
 #, fuzzy
-#~ msgid "Cannot open table <%s>"
+msgid "Cannot open table <%s>"
 #, fuzzy
-#~ msgid "Cannot open driver <%s>"
+msgid "Cannot open driver <%s>"
 #, fuzzy
-#~ msgid "Could not find input vector map %s"
+msgid "Could not find input vector map %s"
 #, fuzzy
-#~ msgid "Could not find input map '%s'."
+msgid "Could not find input map '%s'."
 #, fuzzy
-#~ msgid "Could not find network input map '%s'."
+msgid "Could not find network input map '%s'."
 #, fuzzy
-#~ msgid "error opening raster map [%s]."
+msgid "error opening raster map [%s]."
 #, fuzzy
-#~ msgid "Topology is not available"
+msgid "Topology is not available"
-#~ msgid "Cannot describe table %s"
+msgid "Cannot describe table %s"
 #, fuzzy
-#~ msgid "Patching file <%s@%s>"
+msgid "Patching file <%s@%s>"
 #, fuzzy
-#~ msgid "[%d] files patched"
+msgid "[%d] files patched"
 #, fuzzy
-#~ msgid "Column type  not supported"
+msgid "Column type  not supported"
 #, fuzzy
-#~ msgid "Can't create output map"
+msgid "Can't create output map"
-#~ msgid "%s: cellfile [%s] not found."
-#~ msgstr "%s: Å¡Å«nu fails [%s] nav atrasts"
+msgid "%s: cellfile [%s] not found."
+msgstr "%s: Å¡Å«nu fails [%s] nav atrasts"
-#~ msgid "Unable to open cellfile [%s]."
+msgid "Unable to open cellfile [%s]."
 #, fuzzy
-#~ msgid "Unable to open raster map [%s]."
+msgid "Unable to open raster map [%s]."
 #, fuzzy
-#~ msgid "Unable to find raster [%s]."
+msgid "Unable to find raster [%s]."
 #, fuzzy
-#~ msgid "name for new raster map"
+msgid "name for new raster map"
 #, fuzzy
-#~ msgid "Output GRASS image file"
-#~ msgstr "Nogāžu slīpuma izvades rastra kartes nosaukums"
+msgid "Output GRASS image file"
+msgstr "Nogāžu slīpuma izvades rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "Resulting output map"
+msgid "Resulting output map"
 #, fuzzy
-#~ msgid "name for new vector map"
+msgid "name for new vector map"
 #, fuzzy
-#~ msgid "name for new vector map (omit for display to stdout)"
+msgid "name for new vector map (omit for display to stdout)"
 #, fuzzy
-#~ msgid "Input vector map"
+msgid "Input vector map"
-#~ msgid "vector map <%s> not found"
+msgid "vector map <%s> not found"
 #, fuzzy
-#~ msgid "unable to find raster map [%s]"
+msgid "unable to find raster map [%s]"
 #, fuzzy
-#~ msgid "<%s> raster map not found"
-#~ msgstr "brīdinājums: %s - vektora fails nav atrasts\n"
+msgid "<%s> raster map not found"
+msgstr "brīdinājums: %s - vektora fails nav atrasts\n"
 #, fuzzy
-#~ msgid "<%s> unable to open raster map"
+msgid "<%s> unable to open raster map"
-#~ msgid "Cannot find vector map [%s]"
+msgid "Cannot find vector map [%s]"
-#~ msgid "%s - can't open raster map"
-#~ msgstr "%s - nav iespējams atvērt rastra failu"
+msgid "%s - can't open raster map"
+msgstr "%s - nav iespējams atvērt rastra failu"
 #, fuzzy
-#~ msgid "%s - raster map not found"
+msgid "%s - raster map not found"
-#~ msgid "quiet"
-#~ msgstr "klusi"
+msgid "quiet"
+msgstr "klusi"
 #, fuzzy
-#~ msgid "<%s> - illegal output file name"
+msgid "<%s> - illegal output file name"
 #, fuzzy
-#~ msgid "%s: <%s> reference map not found"
+msgid "%s: <%s> reference map not found"
 #, fuzzy
-#~ msgid "%s: raster map not found"
+msgid "%s: raster map not found"
 #, fuzzy
-#~ msgid "Problem opening input file [%s]"
+msgid "Problem opening input file [%s]"
 #, fuzzy
-#~ msgid "Problem opening output file [%s]"
+msgid "Problem opening output file [%s]"
 #, fuzzy
-#~ msgid "can't write category file for <%s>"
+msgid "can't write category file for <%s>"
 #, fuzzy
-#~ msgid "%s: can't open tempfile"
+msgid "%s: can't open tempfile"
 #, fuzzy
-#~ msgid "Unable to read row %d in raster map [%s]"
+msgid "Unable to read row %d in raster map [%s]"
 #, fuzzy
-#~ msgid "Can't open raster map %s"
+msgid "Can't open raster map %s"
 #, fuzzy
-#~ msgid "It could not be find input map <%s>"
+msgid "It could not be find input map <%s>"
 #, fuzzy
-#~ msgid "It could not be found input map <%s>"
+msgid "It could not be found input map <%s>"
 #, fuzzy
-#~ msgid "Cannot find input map <%s>"
+msgid "Cannot find input map <%s>"
 #, fuzzy
-#~ msgid "Input vector map <%s> not found."
+msgid "Input vector map <%s> not found."
 #, fuzzy
-#~ msgid "Category ranges: e.g. 1,3-8,13"
+msgid "Category ranges: e.g. 1,3-8,13"
 #, fuzzy
-#~ msgid "Writing attributes ...\n"
+msgid "Writing attributes ...\n"
 #, fuzzy
-#~ msgid "Could not open ascii file <%s>"
+msgid "Could not open ascii file <%s>"
+msgstr "Nevarēja atrast rastra failu %s"
 #, fuzzy
-#~ msgid "Could not open temp file <%s>"
+msgid "Could not open temp file <%s>"
 #, fuzzy
-#~ msgid "Vector map <%s> not fould"
+msgid "Vector map <%s> not fould"
 #, fuzzy
-#~ msgid "SVG output file"
-#~ msgstr "Rastra izejas fails"
+msgid "SVG output file"
+msgstr "Rastra izejas fails"
 #, fuzzy
-#~ msgid "Could not find vector '%s'"
-#~ msgstr "Nevar atrast ieeju %s\n"
+msgid "Could not find vector '%s'"
+msgstr "Nevar atrast ieeju %s\n"
 #, fuzzy
-#~ msgid "Unable to get row %d from <%s>"
+msgid "Unable to get row %d from <%s>"
 #, fuzzy
-#~ msgid "No input coordinates provided"
+msgid "No input coordinates provided"
-#~ msgid "Raster output file"
+msgid "Raster output file"
 #, fuzzy
-#~ msgid "Writing raster map ... "
+msgid "Writing raster map ... "
-#~ msgid "Keep existing color table"
-#~ msgstr "Saglabāt esošo krāsu tabulu"
+msgid "Keep existing color table"
+msgstr "Saglabāt esošo krāsu tabulu"
-#~ msgid "List rules"
-#~ msgstr "Parādīt noteikumus"
+msgid "List rules"
+msgstr "Parādīt noteikumus"
 #, fuzzy
-#~ msgid "Verbose mode."
-#~ msgstr "Izvērstā režīmā"
+msgid "Verbose mode."
+msgstr "Izvērstā režīmā"
 #, fuzzy
-#~ msgid " %d rows, %d cols."
-#~ msgstr "%d rastrs %s, %d vektors %s\n"
+msgid " %d rows, %d cols."
+msgstr "%d rastrs %s, %d vektors %s\n"
 #, fuzzy
-#~ msgid "%s in %s - can't read header file"
+msgid "%s in %s - can't read header file"
 #, fuzzy
-#~ msgid "%s - unable to create raster map"
+msgid "%s - unable to create raster map"
 #, fuzzy
-#~ msgid "%s - unable to create category file"
+msgid "%s - unable to create category file"
 #, fuzzy
-#~ msgid "verbose mode"
+msgid "verbose mode"
 #, fuzzy
-#~ msgid "Vector map with points for which to modify the attribute table"
-#~ msgstr "Rastra karte, kuras histogramma tiks parādīta"
+msgid "Vector map with points for which to modify the attribute table"
+msgstr "Rastra karte, kuras histogramma tiks parādīta"
 #, fuzzy
-#~ msgid "Layer of the vector for which to modify the attribute table"
+msgid "Layer of the vector for which to modify the attribute table"
 #, fuzzy
-#~ msgid "Path to an output file"
+msgid "Path to an output file"
-#~ msgid "Name of existing raster map to be displayed"
-#~ msgstr "Eksistējošas attēlojamās rastra kartes nosaukums"
+msgid "Name of existing raster map to be displayed"
+msgstr "Eksistējošas attēlojamās rastra kartes nosaukums"
-#~ msgid "driver name:"
-#~ msgstr "draivera nosaukums:"
+msgid "driver name:"
+msgstr "draivera nosaukums:"
-#~ msgid "Database name:"
-#~ msgstr "Datubāzes nosaukums:"
+msgid "Database name:"
+msgstr "Datubāzes nosaukums:"
 #, fuzzy
-#~ msgid "could not find input map <%s>"
+msgid "could not find input map <%s>"
 #, fuzzy
-#~ msgid "unable to open raster map [%s]"
+msgid "unable to open raster map [%s]"
 #, fuzzy
-#~ msgid "cannot get layer info for vector map"
+msgid "cannot get layer info for vector map"
+msgstr "Vektorkartes nosaukums"
 #, fuzzy
-#~ msgid "cannot open database %s by driver %s"
+msgid "cannot open database %s by driver %s"
 #, fuzzy
-#~ msgid "column type not supported"
+msgid "column type not supported"
 #, fuzzy
-#~ msgid "cannot select data from table"
-#~ msgstr "Nevar iatlasīt datus no tabulas"
+msgid "cannot select data from table"
+msgstr "Nevar iatlasīt datus no tabulas"
 #, fuzzy
-#~ msgid "cannot create table: %s"
+msgid "cannot create table: %s"
 #, fuzzy
-#~ msgid "cannot create index"
+msgid "cannot create index"
 #, fuzzy
-#~ msgid "cannot grant privileges on table %s"
-#~ msgstr "Nevar piešķirt privilēģijas tabulai %s"
+msgid "cannot grant privileges on table %s"
+msgstr "Nevar piešķirt privilēģijas tabulai %s"
 #, fuzzy
 #, fuzzy
-#~ msgid "Cannot find vector map"
+msgid "Cannot find vector map"
 #, fuzzy
-#~ msgid "Cannot find raster map"
+msgid "Cannot find raster map"
 #, fuzzy
-#~ msgid "Cannot open raster map"
+msgid "Cannot open raster map"
 #, fuzzy
-#~ msgid "Can't open temp file %s"
+msgid "Can't open temp file %s"
 #, fuzzy
-#~ msgid "#%s"
-#~ msgstr "%s"
+msgid "#%s"
+msgstr "%s"
 #, fuzzy
-#~ msgid "Error while reading cell map."
-#~ msgstr "Rezultējošās rastra kartes nosaukums"
+msgid "Error while reading cell map."
+msgstr "Rezultējošās rastra kartes nosaukums"
 #, fuzzy
-#~ msgid "Error while writing new cell map."
+msgid "Error while writing new cell map."
 #, fuzzy
-#~ msgid "Error in opening output file <%s>"
+msgid "Error in opening output file <%s>"
 #, fuzzy
-#~ msgid "Unable to find input cell map <%s>"
+msgid "Unable to find input cell map <%s>"
 #, fuzzy
-#~ msgid "Error in opening input file <%s>"
+msgid "Error in opening input fil
