[GRASS-SVN] r33904 - grass/trunk/raster/r.series
Thu Oct 16 07:11:29 EDT 2008
Author: neteler
Date: 2008-10-16 07:11:29 -0400 (Thu, 16 Oct 2008)
New Revision: 33904
   grass/trunk/raster/r.series/r.series.html
range explanations expanded
Modified: grass/trunk/raster/r.series/r.series.html
--- grass/trunk/raster/r.series/r.series.html	2008-10-16 10:08:44 UTC (rev 33903)
+++ grass/trunk/raster/r.series/r.series.html	2008-10-16 11:11:29 UTC (rev 33904)
@@ -43,6 +43,12 @@
 <p>
 If the <em>range=</em> option is given, any values which fall outside
 that range will be treated as if they were NULL.
+The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
+values outside of this range are treated as NULL (i.e., they will be
+ignored by most aggregates, or will cause the result to be NULL if -n is given).
+The <em>low,high</em> thresholds are floating point, so use <em>-inf</em> or
+<em>inf</em> for a single threshold (e.g., <em>range=0,inf</em> to ignore
+negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
 <h2>EXAMPLES</h2>
