[GRASS-SVN] r33926 - in grass/trunk/raster: . r.statistics3
    svn_grass at osgeo.org
    Fri Oct 17 12:37:26 EDT 2008
Author: glynn
Date: 2008-10-17 12:37:26 -0400 (Fri, 17 Oct 2008)
New Revision: 33926
Added:
   grass/trunk/raster/r.statistics3/
   grass/trunk/raster/r.statistics3/Makefile
   grass/trunk/raster/r.statistics3/main.c
   grass/trunk/raster/r.statistics3/r.statistics3.html
Add r.statistics3 (quantiles)
Property changes on: grass/trunk/raster/r.statistics3
___________________________________________________________________
   + *OBJ*
Added: grass/trunk/raster/r.statistics3/Makefile
--- grass/trunk/raster/r.statistics3/Makefile	                        (rev 0)
+++ grass/trunk/raster/r.statistics3/Makefile	2008-10-17 16:37:26 UTC (rev 33926)
@@ -0,0 +1,10 @@
+MODULE_TOPDIR = ../..
+PGM = r.statistics3
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass/trunk/raster/r.statistics3/main.c
--- grass/trunk/raster/r.statistics3/main.c	                        (rev 0)
+++ grass/trunk/raster/r.statistics3/main.c	2008-10-17 16:37:26 UTC (rev 33926)
@@ -0,0 +1,525 @@
+ * MODULE:       r.statistics3
+ * AUTHOR(S):    Glynn Clements <glynn gclements.plus.com> (original contributor),
+ * PURPOSE:      Compute category or object oriented quantiles using two passes
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+#include <stdlib.h>
+#include <string.h>
+#include <math.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <grass/spawn.h>
+#define MAX_CATS 1000
+struct bin
+    unsigned long origin;
+    DCELL min, max;
+    int base, count;
+struct basecat
+    unsigned int *slots;
+    unsigned long total;
+    int num_values;
+    unsigned char *slot_bins;
+    int num_bins;
+    struct bin *bins;
+    DCELL *values;
+    DCELL *quants;
+static int num_quants;
+static DCELL *quants;
+static DCELL fmin, fmax;
+static int num_slots;
+static DCELL slot_size;
+static int rows, cols;
+static int min, max;
+static int num_cats;
+static struct basecat *basecats;
+static inline int get_slot(DCELL c)
+    int i = (int)floor((c - min) / slot_size);
+    if (i < 0)
+	i = 0;
+    if (i > num_slots - 1)
+	i = num_slots - 1;
+    return i;
+static inline double get_quantile(struct basecat *bc, int n)
+    return (double)bc->total * quants[n];
+static void get_slot_counts(int basefile, int coverfile)
+    CELL *basebuf = G_allocate_c_raster_buf();
+    DCELL *coverbuf = G_allocate_d_raster_buf();
+    int row, col;
+    G_message(_("Computing histograms"));
+    for (row = 0; row < rows; row++) {
+	G_get_c_raster_row(basefile, basebuf, row);
+	G_get_d_raster_row(coverfile, coverbuf, row);
+	for (col = 0; col < cols; col++) {
+	    struct basecat *bc;
+	    int i;
+	    if (G_is_c_null_value(&basebuf[col]))
+		continue;
+	    if (G_is_d_null_value(&coverbuf[col]))
+		continue;
+	    i = get_slot(coverbuf[col]);
+	    bc = &basecats[basebuf[col] - min];
+	    bc->slots[i]++;
+	    bc->total++;
+	G_percent(row, rows, 2);
+    G_percent(rows, rows, 2);
+    G_free(basebuf);
+    G_free(coverbuf);
+static void initialize_bins(void)
+    int cat;
+    G_message(_("Computing bins"));
+    for (cat = 0; cat < num_cats; cat++) {
+	struct basecat *bc = &basecats[cat];
+	int slot;
+	double next;
+	int num_values = 0;
+	int bin = 0;
+	unsigned long accum = 0;
+	int quant = 0;
+	bc->bins = G_calloc(num_quants, sizeof(struct bin));
+	bc->slot_bins = G_calloc(num_slots, sizeof(unsigned char));
+	next = get_quantile(bc, quant);
+	for (slot = 0; slot < num_slots; slot++) {
+	    unsigned int count = bc->slots[slot];
+	    unsigned long accum2 = accum + count;
+	    if (accum2 > next) {
+		struct bin *b = &bc->bins[bin];
+		bc->slot_bins[slot] = ++bin;
+		b->origin = accum;
+		b->base = num_values;
+		b->count = 0;
+		b->min = min + slot_size * slot;
+		b->max = min + slot_size * (slot + 1);
+		while (accum2 > next)
+		    next = get_quantile(bc, ++quant);
+		num_values += count;
+	    accum = accum2;
+	bc->num_values = num_values;
+	bc->num_bins = bin;
+	G_free(bc->slots);
+	bc->values = G_calloc(num_values, sizeof(DCELL));
+static void fill_bins(int basefile, int coverfile)
+    int row, col;
+    G_message(_("Binning data"));
+	    int i, bin;
+	    struct bin *b;
+		continue;
+		continue;
+	    if (!bc->slot_bins[i])
+		continue;
+	    bin = bc->slot_bins[i] - 1;
+	    b = &bc->bins[bin];
+	    bc->values[b->base + b->count++] = coverbuf[col];
+    G_free(basebuf);
+    G_free(coverbuf);
+static int compare_dcell(const void *aa, const void *bb)
+    DCELL a = *(const DCELL *)aa;
+    DCELL b = *(const DCELL *)bb;
+    if (a < b)
+	return -1;
+    if (a > b)
+	return 1;
+    return 0;
+static void sort_bins(void)
+    int cat;
+    G_message(_("Sorting bins"));
+	int bin;
+	G_free(bc->slot_bins);
+	for (bin = 0; bin < bc->num_bins; bin++) {
+	    qsort(&bc->values[b->base], b->count, sizeof(DCELL), compare_dcell);
+	G_percent(cat, num_cats, 2);
+static void print_quantiles(void)
+    int cat;
+    G_message(_("Printing quantiles"));
+	int quant;
+	for (quant = 0; quant < num_quants; quant++)
+	    printf("%d:%d:%f:%f\n", min + cat, quant, 100 * quants[quant], bc->quants[quant]);
+static void compute_quantiles(void)
+    int cat;
+    G_message(_("Computing quantiles"));
+	struct bin *b = &bc->bins[0];
+	int quant;
+	bc->quants = G_malloc(num_quants * sizeof(DCELL));
+	for (quant = 0; quant < num_quants; quant++) {
+	    double next = get_quantile(bc, quant);
+	    double k, v;
+	    int i0, i1;
+	    while (b->origin + b->count < next)
+		b++;
+	    k = next - b->origin;
+	    i0 = (int)floor(k);
+	    i1 = (int)ceil(k);
+	    v = (i0 == i1)
+		? bc->values[b->base + i0]
+		: bc->values[b->base + i0] * (i1 - k) + bc->values[b->base + i1] * (k - i0);
+	    bc->quants[quant] = v;
+static void do_reclass(const char *basemap, char **outputs)
+    const char *tempfile = G_tempfile();
+    char *input_arg = G_malloc(strlen(basemap) + 7);
+    char *rules_arg = G_malloc(strlen(tempfile) + 7);
+    int quant;
+    G_message(_("Generating reclass maps"));
+    sprintf(input_arg, "input=%s", basemap);
+    sprintf(rules_arg, "rules=%s", tempfile);
+	const char *output = outputs[quant];
+	char *output_arg = G_malloc(strlen(output) + 8);
+	FILE *fp;
+	int cat;
+	sprintf(output_arg, "output=%s", output);
+	fp = fopen(tempfile, "w");
+	if (!fp)
+	    G_fatal_error(_("Unable to open temporary file"));
+	    fprintf(fp, "%d = %d %f\n", min + cat, min + cat, basecats[cat].quants[quant]);
+	fclose(fp);
+	G_spawn("r.reclass", "r.reclass", input_arg, output_arg, rules_arg, NULL);
+    remove(tempfile);
+static void do_output(int base_fd, char **outputs, const char *covermap)
+    int *out_fd = G_malloc(num_quants * sizeof(int));
+    CELL *base_buf = G_allocate_c_raster_buf();
+    DCELL *out_buf = G_allocate_d_raster_buf();
+    const char *mapset = G_mapset();
+    struct Colors colors;
+    int have_colors;
+    int quant;
+    int row, col;
+    G_message(_("Writing output maps"));
+	out_fd[quant] = G_open_fp_cell_new(output);
+	if (out_fd[quant] < 0)
+	    G_fatal_error(_("Unable to open output map <%s>"), output);
+    have_colors = G_read_colors(covermap, "", &colors) > 0;
+	G_get_c_raster_row(base_fd, base_buf, row);
+		if (G_is_c_null_value(&base_buf[col]))
+		    G_set_d_null_value(&out_buf[col], 1);
+		else
+		    out_buf[col] = basecats[base_buf[col] - min].quants[quant];
+	    G_put_d_raster_row(out_fd[quant], out_buf);
+	G_close_cell(out_fd[quant]);
+	if (have_colors)
+	    G_write_colors(outputs[quant], mapset, &colors);
+int main(int argc, char *argv[])
+    struct GModule *module;
+    struct
+	struct Option *quant, *perc, *slots, *basemap, *covermap, *output;
+    } opt;
+    struct {
+	struct Flag *r, *p;
+    } flag;
+    const char *basemap, *covermap;
+    char **outputs;
+    int reclass, print;
+    int cover_fd, base_fd;
+    struct Range range;
+    struct FPRange fprange;
+    int i;
+    G_gisinit(argv[0]);
+    module = G_define_module();
+    module->keywords = _("raster, statistics");
+    module->description = _("Compute category quantiles using two passes.");
+    opt.basemap = G_define_standard_option(G_OPT_R_BASE);
+    opt.covermap = G_define_standard_option(G_OPT_R_COVER);
+    opt.quant = G_define_option();
+    opt.quant->key = "quantiles";
+    opt.quant->type = TYPE_INTEGER;
+    opt.quant->required = NO;
+    opt.quant->description = _("Number of quantiles");
+    opt.perc = G_define_option();
+    opt.perc->key = "percentiles";
+    opt.perc->type = TYPE_DOUBLE;
+    opt.perc->multiple = YES;
+    opt.perc->description = _("List of percentiles");
+    opt.perc->answer = "50";
+    opt.slots = G_define_option();
+    opt.slots->key = "bins";
+    opt.slots->type = TYPE_INTEGER;
+    opt.slots->required = NO;
+    opt.slots->description = _("Number of bins to use");
+    opt.slots->answer = "1000";
+    opt.output = G_define_standard_option(G_OPT_R_OUTPUT);
+    opt.output->description = _("Resultant raster map(s)");
+    opt.output->required = NO;
+    opt.output->multiple = YES;
+    flag.r = G_define_flag();
+    flag.r->key = 'r';
+    flag.r->description =
+	_("Create reclass map with statistics as category labels");
+    flag.p = G_define_flag();
+    flag.p->key = 'p';
+    flag.p->description =
+	_("Don't create output maps; just print statistics");
+    if (G_parser(argc, argv))
+	exit(EXIT_FAILURE);
+    basemap = opt.basemap->answer;
+    covermap = opt.covermap->answer;
+    outputs = opt.output->answers;
+    reclass = flag.r->answer;
+    print = flag.p->answer;
+    if (!print && !opt.output->answers)
+	G_fatal_error(_("Either -p or output= must be given"));
+    if (print && opt.output->answers)
+	G_fatal_error(_("-p and output= are mutually exclusive"));
+    num_slots = atoi(opt.slots->answer);
+    if (opt.quant->answer) {
+	num_quants = atoi(opt.quant->answer) - 1;
+	quants = G_calloc(num_quants, sizeof(DCELL));
+	for (i = 0; i < num_quants; i++)
+	    quants[i] = 1.0 * (i + 1) / (num_quants + 1);
+    else {
+	for (i = 0; opt.perc->answers[i]; i++)
+	num_quants = i;
+	    quants[i] = atof(opt.perc->answers[i]) / 100;
+	qsort(quants, num_quants, sizeof(DCELL), compare_dcell);
+    if (opt.output->answer) {
+	for (i = 0; opt.output->answers[i]; i++)
+	if (i != num_quants)
+	    G_fatal_error(_("Number of quantiles (%d) does not match number of output maps (%d)"),
+			  num_quants, i);
+    base_fd = G_open_cell_old(basemap, "");
+    if (base_fd < 0)
+	G_fatal_error(_("Unable to open base map <%s>"), basemap);
+    cover_fd = G_open_cell_old(covermap, "");
+    if (cover_fd < 0)
+	G_fatal_error(_("Unable to open cover map <%s>"), covermap);
+    if (G_raster_map_is_fp(basemap, "") != 0)
+	G_fatal_error(_("The base map must be an integer (CELL) map"));
+    if (G_read_range(basemap, "", &range) < 0)
+	G_fatal_error(_("Unable to read range of base map <%s>"), basemap);
+    G_get_range_min_max(&range, &min, &max);
+    num_cats = max - min + 1;
+    if (num_cats > MAX_CATS)
+	G_fatal_error(_("Base map <%s> has too many categories (max: %d)"),
+		      basemap, MAX_CATS);
+    G_read_fp_range(covermap, "", &fprange);
+    G_get_fp_range_min_max(&fprange, &fmin, &fmax);
+    slot_size = (fmax - fmin) / num_slots;
+    basecats = G_calloc(num_cats, sizeof(struct basecat));
+    for (i = 0; i < num_cats; i++)
+	basecats[i].slots = G_calloc(num_slots, sizeof(unsigned int));
+    rows = G_window_rows();
+    cols = G_window_cols();
+    get_slot_counts(base_fd, cover_fd);
+    initialize_bins();
+    fill_bins(base_fd, cover_fd);
+    sort_bins();
+    compute_quantiles();
+    if (print)
+	print_quantiles();
+    else if (reclass)
+	do_reclass(basemap, outputs);
+    else
+	do_output(base_fd, outputs, covermap);
+    G_close_cell(cover_fd);
+    G_close_cell(base_fd);
+    return (EXIT_SUCCESS);
Added: grass/trunk/raster/r.statistics3/r.statistics3.html
--- grass/trunk/raster/r.statistics3/r.statistics3.html	                        (rev 0)
+++ grass/trunk/raster/r.statistics3/r.statistics3.html	2008-10-17 16:37:26 UTC (rev 33926)
@@ -0,0 +1,19 @@
+<h2>DESCRIPTION</h2>
+<em>r.statistics3</em> is intended to be a partial replacement for
+r.statistics, with support for floating-point cover maps. It provides
+quantile calculations, which are absent from <em>r.statistics2</em>.
+<h2>SEE ALSO</h2>
+<em>
+<a href="r.statistics.html">r.quant</a>
+<a href="r.statistics2.html">r.quant</a>
+</em>
+<h2>AUTHOR</h2>
+Glynn Clements
+<p>
+<i>Last changed: $Date: 2007-04-06 21:49:26 +0200 (Fri, 06 Apr 2007) $</i>
