[GRASS-SVN] r33980 - grass/trunk/scripts/v.db.join
Wed Oct 22 12:01:03 EDT 2008
Author: mlennert
Date: 2008-10-22 12:01:03 -0400 (Wed, 22 Oct 2008)
New Revision: 33980
   grass/trunk/scripts/v.db.join/v.db.join.py
fix bug #338
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2008-10-22 15:05:50 UTC (rev 33979)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2008-10-22 16:01:03 UTC (rev 33980)
@@ -98,14 +98,14 @@
 	    coltype = "%s" % col[1]
 	colspec = "%s %s" % (colname, coltype)
-	if grass.run_command('v.db.addcol', map = map, columns = colspec) != 0:
+	if grass.run_command('v.db.addcol', map = map, columns = colspec, layer = layer) != 0:
 	    grass.fatal("Error creating column <%s>." % colname)
 	stmt = template.substitute(table = maptable, column = column,
 				   otable = otable, ocolumn = ocolumn,
 				   colname = colname)
-	if grass.write_command('db.execute', stdin = stmt) != 0:
+	if grass.write_command('db.execute', stdin = stmt, database = database, driver = driver) != 0:
 	    grass.fatal("Error filling column <%s>." % colname)
     # write cmd history:
