[GRASS-SVN] r34089 - in grass/trunk/scripts: . v.out.gpsbabel
Thu Oct 30 07:35:09 EDT 2008
Author: hamish
Date: 2008-10-30 07:35:09 -0400 (Thu, 30 Oct 2008)
New Revision: 34089
Added:
   grass/trunk/scripts/v.out.gpsbabel/
   grass/trunk/scripts/v.out.gpsbabel/Makefile
   grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel
   grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel.html
Removed:
v.out.gpbabel: add but not activated yet. (merge from devbr6)
Copied: grass/trunk/scripts/v.out.gpsbabel (from rev 34088, grass/branches/develbranch_6/scripts/v.out.gpsbabel)
Deleted: grass/trunk/scripts/v.out.gpsbabel/Makefile
--- grass/branches/develbranch_6/scripts/v.out.gpsbabel/Makefile	2008-10-30 11:30:22 UTC (rev 34088)
+++ grass/trunk/scripts/v.out.gpsbabel/Makefile	2008-10-30 11:35:09 UTC (rev 34089)
@@ -1,7 +0,0 @@
-MODULE_TOPDIR = ../..
-PGM = v.out.gpsbabel
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
Copied: grass/trunk/scripts/v.out.gpsbabel/Makefile (from rev 34088, grass/branches/develbranch_6/scripts/v.out.gpsbabel/Makefile)
--- grass/trunk/scripts/v.out.gpsbabel/Makefile	                        (rev 0)
@@ -0,0 +1,7 @@
+MODULE_TOPDIR = ../..
+PGM = v.out.gpsbabel
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Deleted: grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel
--- grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel	2008-10-30 11:30:22 UTC (rev 34088)
+++ grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel	2008-10-30 11:35:09 UTC (rev 34089)
@@ -1,314 +0,0 @@
-#!/bin/sh
-# MODULE:      v.out.gpsbabel
-# PURPOSE:     Exports a GRASS vector map to a GPS receiver
-#		or data file using GpsBabel
-# COPYRIGHT:   (c) 2008 Hamish Bowman, and the GRASS Development Team
-#	       This program is free software under the GNU General Public
-#	       License (>=v2). Read the file COPYING that comes with GRASS
-#	       for details.
-# AUTHOR:     Hamish Bowman, Dunedin, New Zealand
-# REQUIREMENTS:
-#      -  GpsBabel from 	http://gpsbabel.sourceforge.net
-#      -  cs2cs from PROJ.4 (for m.proj)	http://proj.osgeo.org
-#      - report supported GpsBabel formats:
-#	 gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
-# How to do it
-#   http://www.gdal.org/ogr/drv_gpx.html
-#   gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
-#%Module
-#%  description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
-#%  keywords: vector, export, GPS
-#%End
-#%flag
-#%  key: w
-#%  description: Export as waypoints
-#%end
-#%flag
-#%  key: r
-#%  description: Export as routes
-#%end
-#%flag
-#%  key: t
-#%  description: Export as tracks
-#%end
-############ TODO:
-##%flag
-##%  key: z
-##%  description: Export altitude from 3D vector's z-coordinate
-##%end
-#%option
-#% key: input
-#% type: string
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#% required: yes
-#%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type(s)
-#% options: point,centroid,line,boundary
-#% multiple: yes
-#%end
-#%option
-#% key: output
-#% type: string
-#% description: Name for output file or GPS device
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% required: yes
-#%end
-#%option
-#% key: format
-#% type: string
-#% description: GpsBabel supported output format
-#% answer: gpx
-#%end
-#%option
-#% key: layer
-#% type: integer
-#% label: Layer number
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% required : no
-#% guisection: Subset
-#%end
-#%option
-#% key: where
-#% type: string
-#% label: WHERE conditions of SQL statement without 'where' keyword
-#% description: Example: income < 1000 and inhab >= 10000
-#% required : no
-#%end
-if [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." 1>&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    # save command line
-    CMDLINE="`basename $0`"
-    for arg in "$@" ; do
-	CMDLINE="$CMDLINE \"$arg\""
-    done
-    export CMDLINE
-    exec g.parser "$0" "$@"
-fi
-# set environment so that awk works properly in all languages
-unset LC_ALL
-LC_NUMERIC=C
-export LC_NUMERIC
-eval `g.gisenv`
-: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
-LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
-PROG=`basename $0`
-#### check for gpsbabel
-if [ ! -x "`which gpsbabel`" ] ; then
-    g.message -e "The gpsbabel program was not found, please install it first.
-                  http://gpsbabel.sourceforge.net"
-    exit 1
-fi
-#### check for cs2cs
-if [ ! -x "`which cs2cs`" ] ; then
-    g.message -e "The cs2cs program was not found, please install it first.
-                   http://proj.osgeo.org"
-    exit 1
-fi
-# check if we will overwrite data
-if [ -e "$GIS_OPT_OUTPUT" ] ; then
-   if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
-      g.message -e "Output file already exists."
-      exit 1
-   fi
-fi
-#### set temporary files
-TMP="`g.tempfile pid=$$`"
-if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
-    g.message -e "Unable to create temporary files"
-    exit 1
-fi
-cleanup()
-   g.message -d "Cleaning up ..."
-   \rm -f "$TMP" "$TMP.gpx"
-   # only try to remove map if it exists to avoid ugly warnings
-   g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
-   if [ $? -eq 0 ] ; then
-      g.remove vect="tmp_vogb_epsg4326_$$"  --quiet
-   fi
-   g.findfile element=vector file="tmp_vogb_extr_$$" > /dev/null
-      g.remove vect="tmp_vogb_extr_$$"  --quiet
-   fi
-#### trap ctrl-c so that we can clean up tmp
-trap 'cleanup' 2 3 15
-#### process command line arguments
-WPT=$GIS_FLAG_W ; RTE=$GIS_FLAG_R ; TRK=$GIS_FLAG_T
-if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
-    g.message -e "One feature at a time please."
-    rm -f "${TMP}"
-    exit 1
-fi
-# logic eludes me at pressent..  [combine with above]
-if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
-    rm -f "${TMP}"
-    exit 1
-fi
-if [ $WPT -eq 0 ] && [ $RTE -eq 0 ] && [ $TRK -eq 0 ] ; then
-    g.message -e "No features requested for export."
-    cleanup
-    exit 1
-fi
-# set some reasonable defaults
-if [ $WPT -eq 1 ] ; then
-   if [ -z "$GIS_OPT_TYPE" ] ; then
-      GIS_OPT_TYPE="point"
-   fi
-else
-      GIS_OPT_TYPE="line"
-   fi
-fi
-# SQL extract if needed
-if [ -n "$GIS_OPT_WHERE" ] ; then
-   v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
-      type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
-      where="$GIS_OPT_WHERE" --quiet
-   if [ $? -ne 0 ] ; then
-       g.message -e "Error executing SQL query"
-       cleanup
-       exit 1
-   fi
-   eval `v.info -t map="tmp_vogb_extr_$$"`
-   if [ "$primitives" -eq 0 ] ; then
-      g.message -e "SQL query returned an empty map"
-      cleanup
-      exit 1
-   fi
-   INMAP="tmp_vogb_extr_$$"
-else
-   INMAP="$GIS_OPT_INPUT"
-fi
-#### set up projection info
-# TODO: check if we are already in ll/WGS84.  If so skip m.proj step.
-# TODO: multi layer will probably fail badly due to sed 's/^ 1   /'
-#   output as old GRASS 4 vector ascii and fight with dig_ascii/?
-# reproject to lat/lon WGS84
-v.out.ascii in="$INMAP" format=standard | \
-   sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1     /# 1  /' | \
-   tail -n +11 | m.proj -od --quiet | \
-   sed -e 's/\t\([-\.0-9]*\) .*/ \1/' \
-     -e 's/^\([-\.0-9]\)/ \1/' \
-     -e 's/^#//' | \
-    v.in.ascii out=tmp_vogb_epsg4326_$$ -n format=standard --quiet
-if [ $? -ne 0 ] ; then
-    g.message -e "Error reprojecting data"
-    cleanup
-    exit 1
-fi
-# export as GPX using v.out.ogr
-if [ $TRK -eq 1 ] ; then
-   LINETYPE="FORCE_GPX_TRACK=YES,"
-elif [ $RTE -eq 1 ] ; then
-   LINETYPE="FORCE_GPX_ROUTE=YES,"
-else
-   LINETYPE=""
-fi
-# TODO: cat is being reported as evelation? or is <ele>=element??
-# TODO: fix attribute output.  ogr2ogr -sql to rename columns?
-#        see http://www.gdal.org/ogr/drv_gpx.html
-v.out.ogr in=tmp_vogb_epsg4326_$$ dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
-  format=GPX lco="${LINETYPE}GPX_USE_EXTENSIONS=YES" --quiet
-    g.message -e "Error exporting data"
-    cleanup
-    exit 1
-fi
-if [ "$GIS_OPT_FORMAT" = gpx ] ; then
-   # short circuit, we have what we came for.
-   mv "$TMP.gpx" "$GIS_OPT_OUTPUT"
-   cleanup
-   g.message -d "Fast exit"
-   exit 0
-fi
-# run gpsbabel
-GTYPE=""
-   GTYPE="-w"
-elif [ $TRK -eq 1 ] ; then
-   GTYPE="-t"
-   GTYPE="-r"
-fi
-gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
-    -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
-    g.message -e "Error running GpsBabel"
-    cleanup
-    exit 1
-fi
-cleanup
-g.message -v "Done."
-exit
Copied: grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel (from rev 34088, grass/branches/develbranch_6/scripts/v.out.gpsbabel/v.out.gpsbabel)
--- grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel	                        (rev 0)
@@ -0,0 +1,314 @@
+#!/bin/sh
+# MODULE:      v.out.gpsbabel
+# PURPOSE:     Exports a GRASS vector map to a GPS receiver
+#		or data file using GpsBabel
+# COPYRIGHT:   (c) 2008 Hamish Bowman, and the GRASS Development Team
+#	       This program is free software under the GNU General Public
+#	       License (>=v2). Read the file COPYING that comes with GRASS
+#	       for details.
+# AUTHOR:     Hamish Bowman, Dunedin, New Zealand
+# REQUIREMENTS:
+#      -  GpsBabel from 	http://gpsbabel.sourceforge.net
+#      -  cs2cs from PROJ.4 (for m.proj)	http://proj.osgeo.org
+#      - report supported GpsBabel formats:
+#	 gpsbabel -^2 | tr '\t' ';' | sort -t';' -k3
+# How to do it
+#   http://www.gdal.org/ogr/drv_gpx.html
+#   gpsbabel [options] -i INTYPE -f INFILE -o OUTTYPE -F OUTFILE
+#%Module
+#%  description: Exports a vector map to a GPS receiver or file format supported by GpsBabel.
+#%  keywords: vector, export, GPS
+#%End
+#%flag
+#%  key: w
+#%  description: Export as waypoints
+#%end
+#%flag
+#%  key: r
+#%  description: Export as routes
+#%end
+#%flag
+#%  key: t
+#%  description: Export as tracks
+#%end
+############ TODO:
+##%flag
+##%  key: z
+##%  description: Export altitude from 3D vector's z-coordinate
+##%end
+#%option
+#% key: input
+#% type: string
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#% required: yes
+#%end
+#%option
+#% key: type
+#% type: string
+#% description: Feature type(s)
+#% options: point,centroid,line,boundary
+#% multiple: yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% description: Name for output file or GPS device
+#% gisprompt: new_file,file,output
+#% key_desc: name
+#% required: yes
+#%end
+#%option
+#% key: format
+#% type: string
+#% description: GpsBabel supported output format
+#% answer: gpx
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% label: Layer number
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% required : no
+#% guisection: Subset
+#%end
+#%option
+#% key: where
+#% type: string
+#% label: WHERE conditions of SQL statement without 'where' keyword
+#% description: Example: income < 1000 and inhab >= 10000
+#% required : no
+#%end
+if [ -z "$GISBASE" ] ; then
+    echo "You must be in GRASS GIS to run this program." 1>&2
+    exit 1
+fi
+if [ "$1" != "@ARGS_PARSED@" ] ; then
+    # save command line
+    CMDLINE="`basename $0`"
+    for arg in "$@" ; do
+	CMDLINE="$CMDLINE \"$arg\""
+    done
+    export CMDLINE
+    exec g.parser "$0" "$@"
+fi
+# set environment so that awk works properly in all languages
+unset LC_ALL
+LC_NUMERIC=C
+export LC_NUMERIC
+eval `g.gisenv`
+: ${GISBASE?} ${GISDBASE?} ${LOCATION_NAME?} ${MAPSET?}
+LOCATION="$GISDBASE"/"$LOCATION_NAME"/"$MAPSET"
+PROG=`basename $0`
+#### check for gpsbabel
+if [ ! -x "`which gpsbabel`" ] ; then
+    g.message -e "The gpsbabel program was not found, please install it first.
+                  http://gpsbabel.sourceforge.net"
+    exit 1
+fi
+#### check for cs2cs
+if [ ! -x "`which cs2cs`" ] ; then
+    g.message -e "The cs2cs program was not found, please install it first.
+                   http://proj.osgeo.org"
+    exit 1
+fi
+# check if we will overwrite data
+if [ -e "$GIS_OPT_OUTPUT" ] ; then
+   if [ -z "$GRASS_OVERWRITE" ] || [ "$GRASS_OVERWRITE" -ne 1 ] ; then
+      g.message -e "Output file already exists."
+      exit 1
+   fi
+fi
+#### set temporary files
+TMP="`g.tempfile pid=$$`"
+if [ $? -ne 0 ] || [ -z "$TMP" ] ; then
+    g.message -e "Unable to create temporary files"
+    exit 1
+fi
+cleanup()
+   g.message -d "Cleaning up ..."
+   \rm -f "$TMP" "$TMP.gpx"
+   # only try to remove map if it exists to avoid ugly warnings
+   g.findfile element=vector file="tmp_vogb_epsg4326_$$" > /dev/null
+   if [ $? -eq 0 ] ; then
+      g.remove vect="tmp_vogb_epsg4326_$$"  --quiet
+   fi
+   g.findfile element=vector file="tmp_vogb_extr_$$" > /dev/null
+      g.remove vect="tmp_vogb_extr_$$"  --quiet
+   fi
+#### trap ctrl-c so that we can clean up tmp
+trap 'cleanup' 2 3 15
+#### process command line arguments
+WPT=$GIS_FLAG_W ; RTE=$GIS_FLAG_R ; TRK=$GIS_FLAG_T
+if [ $WPT -eq 1 ] && ([ $RTE -eq 1 ] || [ $TRK -eq 1 ]) ; then
+    g.message -e "One feature at a time please."
+    rm -f "${TMP}"
+    exit 1
+fi
+# logic eludes me at pressent..  [combine with above]
+if [ $RTE -eq 1 ] && [ $TRK -eq 1 ] ; then
+    rm -f "${TMP}"
+    exit 1
+fi
+if [ $WPT -eq 0 ] && [ $RTE -eq 0 ] && [ $TRK -eq 0 ] ; then
+    g.message -e "No features requested for export."
+    cleanup
+    exit 1
+fi
+# set some reasonable defaults
+if [ $WPT -eq 1 ] ; then
+   if [ -z "$GIS_OPT_TYPE" ] ; then
+      GIS_OPT_TYPE="point"
+   fi
+else
+      GIS_OPT_TYPE="line"
+   fi
+fi
+# SQL extract if needed
+if [ -n "$GIS_OPT_WHERE" ] ; then
+   v.extract in="$GIS_OPT_INPUT" out="tmp_vogb_extr_$$" \
+      type="$GIS_OPT_TYPE" layer="$GIS_OPT_LAYER" \
+      where="$GIS_OPT_WHERE" --quiet
+   if [ $? -ne 0 ] ; then
+       g.message -e "Error executing SQL query"
+       cleanup
+       exit 1
+   fi
+   eval `v.info -t map="tmp_vogb_extr_$$"`
+   if [ "$primitives" -eq 0 ] ; then
+      g.message -e "SQL query returned an empty map"
+      cleanup
+      exit 1
+   fi
+   INMAP="tmp_vogb_extr_$$"
+else
+   INMAP="$GIS_OPT_INPUT"
+fi
+#### set up projection info
+# TODO: check if we are already in ll/WGS84.  If so skip m.proj step.
+# TODO: multi layer will probably fail badly due to sed 's/^ 1   /'
+#   output as old GRASS 4 vector ascii and fight with dig_ascii/?
+# reproject to lat/lon WGS84
+v.out.ascii in="$INMAP" format=standard | \
+   sed -e 's/^\([PLBCFKA]\)/#\1/' -e 's/^ 1     /# 1  /' | \
+   tail -n +11 | m.proj -od --quiet | \
+   sed -e 's/\t\([-\.0-9]*\) .*/ \1/' \
+     -e 's/^\([-\.0-9]\)/ \1/' \
+     -e 's/^#//' | \
+    v.in.ascii out=tmp_vogb_epsg4326_$$ -n format=standard --quiet
+if [ $? -ne 0 ] ; then
+    g.message -e "Error reprojecting data"
+    cleanup
+    exit 1
+fi
+# export as GPX using v.out.ogr
+if [ $TRK -eq 1 ] ; then
+   LINETYPE="FORCE_GPX_TRACK=YES,"
+elif [ $RTE -eq 1 ] ; then
+   LINETYPE="FORCE_GPX_ROUTE=YES,"
+else
+   LINETYPE=""
+fi
+# TODO: cat is being reported as evelation? or is <ele>=element??
+# TODO: fix attribute output.  ogr2ogr -sql to rename columns?
+#        see http://www.gdal.org/ogr/drv_gpx.html
+v.out.ogr in=tmp_vogb_epsg4326_$$ dsn="$TMP.gpx" type="$GIS_OPT_TYPE" \
+  format=GPX lco="${LINETYPE}GPX_USE_EXTENSIONS=YES" --quiet
+    g.message -e "Error exporting data"
+    cleanup
+    exit 1
+fi
+if [ "$GIS_OPT_FORMAT" = gpx ] ; then
+   # short circuit, we have what we came for.
+   mv "$TMP.gpx" "$GIS_OPT_OUTPUT"
+   cleanup
+   g.message -d "Fast exit"
+   exit 0
+fi
+# run gpsbabel
+GTYPE=""
+   GTYPE="-w"
+elif [ $TRK -eq 1 ] ; then
+   GTYPE="-t"
+   GTYPE="-r"
+fi
+gpsbabel $GTYPE -i gpx -f "$TMP.gpx" \
+    -o "$GIS_OPT_FORMAT" -F "$GIS_OPT_OUTPUT"
+    g.message -e "Error running GpsBabel"
+    cleanup
+    exit 1
+fi
+cleanup
+g.message -v "Done."
+exit
Added: grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel.html
--- grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel.html	                        (rev 0)
+++ grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel.html	2008-10-30 11:35:09 UTC (rev 34089)
@@ -0,0 +1,63 @@
+<H2>DESCRIPTION</H2>
+<EM>v.out.gpsbabel</EM> allows the user to export waypoint, route, and track
+data from a vector map into a locally connected GPS receiver or as a file in
+many common GPS data formats. Translation is done via the
+<EM><A HREF="http://www.gpsbabel.org">GpsBabel</a></EM> program.
+<P>
+Do not use as a primary means of navigation.
+<H2>NOTES</H2>
+<em>v.out.gpsbabel</em> automatically reprojects data from the
+projection settings of the current location to Lat/Lon WGS84.
+<p>
+GPX format is used for data interchange between GRASS and GpsBabel.
+If the requested output is GPX, then <tt>gpsbabel</tt> is never run.
+<P>
+The <b>layer</b> option is only used in conjunction with the
+<b>where</b> SQL query option.
+<H2>EXAMPLES</H2>
+<h3>GPX Export</h3>
+Export a vector lines map to a GPX track file:
+<div class="code"><pre>
+v.out.gpsbabel -t input=trail output=trail.gpx
+</pre></div>
+<h3>GPS device connected via USB adapter</h3>
+Export vector maps named <i>waypoints, tracks, routes</i> to a Garmin GPS
+connected to /dev/ttyUSB0:
+v.out.gpsbabel -w input=waypoints format=garmin output=/dev/ttyUSB0
+v.out.gpsbabel -t input=tracks format=garmin output=/dev/ttyUSB0
+v.out.gpsbabel -r input=routes format=garmin output=/dev/ttyUSB0
+</pre></div>
+<H2>SEE ALSO</H2>
+<EM><A HREF="m.proj.html">m.proj</A></EM><BR>
+<EM><A HREF="v.in.ascii.html">v.in.ascii</A></EM><BR>
+<EM><A HREF="v.out.ascii.html">v.out.ascii</A></EM><BR>
+<EM><A HREF="v.in.garmin.html">v.in.garmin</A></EM><BR>
+<EM><A HREF="v.in.gpsbabel.html">v.in.gpsbabel</A></EM><BR>
+<EM><A HREF="v.extract.html">v.extract</A></EM><BR>
+<BR>
+<A HREF="http://www.gpsbabel.org">GpsBabel.org</a><BR>
+The <A HREF="http://www.gdal.org/ogr/drv_gpx.html">GDAL/OGR GPX format page</a><BR>
+cs2cs from <A HREF="http://proj.osgeo.org">PROJ.4</a><BR>
+<H2>AUTHOR</H2>
+Hamish Bowman, Dunedin New Zealand
+<p>
+<i>Last changed: $Date$</i>
Property changes on: grass/trunk/scripts/v.out.gpsbabel/v.out.gpsbabel.html
___________________________________________________________________
   + text/html
   + Date
   + native
