[GRASS-SVN] r33281 - in grass/branches/develbranch_6/gui/wxpython: gui_modules vdigit
Fri Sep 5 16:14:00 EDT 2008
Author: martinl
Date: 2008-09-05 16:14:00 -0400 (Fri, 05 Sep 2008)
New Revision: 33281
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
wxGUI: trac #276 --- vdigit: please render closed areas transparent
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -312,7 +312,8 @@
                 # for all non-display commands.
                 if compReg:
                     tmpreg = os.getenv("GRASS_REGION")
-                    del os.environ["GRASS_REGION"]
+                    if os.environ.has_key("GRASS_REGION"):
+                        del os.environ["GRASS_REGION"]
                 if len(cmdlist) == 1:
                     import menuform
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -476,10 +476,8 @@
         Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
         dc = wx.BufferedPaintDC(self, self.buffer)
-        # we need to clear the dc BEFORE calling PrepareDC
-        #bg = wx.Brush(self.GetBackgroundColour())
-        dc.SetBackground(wx.Brush("White"))
+        ### dc.SetBackground(wx.Brush("White"))
         dc.Clear()
         # use PrepareDC to set position correctly
@@ -496,7 +494,9 @@
             # draw vector map layer
             if self.pdcVector:
-                self.pdcVector.DrawToDCClipped(dc, rgn)
+                # decorate with GDDC (transparency)
+                gcdc = wx.GCDC(dc)
+                self.pdcVector.DrawToDCClipped(gcdc, rgn)
             self.bufferLast = None
         else: # do not redraw pdc and pdcVector
@@ -505,8 +505,10 @@
                 self.pdc.DrawToDC(dc)
                 if self.pdcVector:
-                    self.pdcVector.DrawToDC(dc)
+                    self.pdcVector.DrawToDC(gcdc)
                 # store buffered image
                 # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
                 self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
@@ -518,7 +520,7 @@
         # draw temporary object on the foreground
         # self.pdcTmp.DrawToDCClipped(dc, rgn)
         self.pdcTmp.DrawToDC(dc)
     def OnSize(self, event):
         Scale map image so that it is
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -680,13 +680,11 @@
                     except ValueError:
                         pass
         else: # -> write settings
-            if type(value) == type(wx.Colour(0, 0, 0, 0)):
-                print value, type(value)
             if type(value) == type(()): # -> color
                 value = str(value[0]) + ':' +\
                     str(value[1]) + ':' + \
                     str(value[2])
         return value
     def Get(self, group, key=None, subkey=None, internal=False):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -1050,8 +1050,14 @@
         self.parent.MapWindow.pdcVector = wx.PseudoDC()
         self.parent.digit.driver.SetDevice(self.parent.MapWindow.pdcVector)
         # self.parent.MapWindow.UpdateMap()
         if not self.parent.MapWindow.resize:
             self.parent.MapWindow.UpdateMap(render=True)
+        opacity = mapLayer.GetOpacity(float=True)
+        if opacity < 1.0:
+            alpha = int(opacity * 255)
+            self.parent.digit.driver.UpdateSettings(alpha)
         return True
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -1531,7 +1531,7 @@
         """Show/hide selected features"""
         self.__display.DrawSelected(draw)
-    def UpdateSettings(self):
+    def UpdateSettings(self, alpha=255):
         """Update display driver settings"""
         # TODO map units
@@ -1559,9 +1559,8 @@
                                      UserSettings.Get(group='vdigit', key='symbol',
                                                       subkey=[symbol, 'color'])[1],
-                                                      subkey=[symbol, 'color'])[2],
-                                     255).GetRGB()
+                                                      subkey=[symbol, 'color'])[2]).GetRGB()
         self.__display.UpdateSettings (color['highlight'],
                                        UserSettings.Get(group='vdigit', key='checkForDupl',
                                                         subkey='enabled'),
@@ -1606,7 +1605,8 @@
                                                         subkey=['direction', 'enabled']),
                                        color['direction'],
                                        UserSettings.Get(group='vdigit', key='lineWidth',
-                                                        subkey='value'))
+                                                        subkey='value'),
+                                       alpha)
 class VDigitSettingsDialog(wx.Dialog):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-09-05 20:14:00 UTC (rev 33281)
@@ -484,7 +484,7 @@
         dlg.CentreOnParent()
         if dlg.ShowModal() == wx.ID_OK:
-            new_opacity = dlg.GetOpacity() # string
+            new_opacity = dlg.GetOpacity() # string
             self.Map.ChangeOpacity(maplayer, new_opacity)
             maplayer.SetOpacity(new_opacity)
             opacity_pct = int(new_opacity * 100)
@@ -493,6 +493,12 @@
             self.SetItemText(self.layer_selected,
                              layerbase + ' (opacity: ' + str(opacity_pct) + '%)')
+            # vector layer currently edited
+            if self.mapdisplay.toolbars['vdigit'] and \
+                    self.mapdisplay.toolbars['vdigit'].GetLayer() == maplayer:
+                alpha = int(new_opacity * 255)
+                self.mapdisplay.digit.driver.UpdateSettings(alpha)
             # redraw map if auto-rendering is enabled
             self.rerender = True
             self.reorder = True
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-09-05 20:14:00 UTC (rev 33281)
@@ -293,7 +293,7 @@
 				   bool eVertex,      unsigned long cVertex,
 				   bool eArea,        unsigned long cArea,
 				   bool eDirection,   unsigned long cDirection,
-				   int lineWidth)
+				   int lineWidth, int alpha)
     settings.highlight.Set(highlight);
@@ -334,7 +334,7 @@
     settings.area.color.Set(settings.area.color.Red(),
 			    settings.area.color.Green(),
 			    settings.area.color.Blue(),
-			    100); /* transparency */
+			    alpha);
     settings.direction.enabled = eDirection;
     settings.direction.color.Set(cDirection);
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2008-09-05 14:04:15 UTC (rev 33280)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.h	2008-09-05 20:14:00 UTC (rev 33281)
@@ -210,7 +210,7 @@
 			bool, unsigned long,
-			int);
+			int, int);
 int print_error(const char *, int);
