[GRASS-SVN] r33349 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Tue Sep 9 04:18:18 EDT 2008
Author: martinl
Date: 2008-09-09 04:18:18 -0400 (Tue, 09 Sep 2008)
New Revision: 33349
   grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
wxGUI: colorrules fixes
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py	2008-09-09 08:00:09 UTC (rev 33348)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py	2008-09-09 08:18:18 UTC (rev 33349)
@@ -106,7 +106,7 @@
                                    label='Attribute column:')
             self.cb_vrgb_label = wx.StaticText(parent=self, id=wx.ID_ANY,
                                    label='RGB color column:')
-            self.cb_vlayer = gselect.LayerSelect(self, vector='')
+            self.cb_vlayer = gselect.LayerSelect(self)
             self.cb_vcol = gselect.ColumnSelect(self, vector='', layer='')
             self.cb_vrgb = gselect.ColumnSelect(self, vector='', layer='')
@@ -281,18 +281,15 @@
             except:
                 pass
         elif self.cmd == 'vcolors':
-            try:
-                # initialize layer selection combobox
-                self.cb_vlayer.InsertLayers(self.inmap)
-                # initialize attribute table for layer=1
-                self.vtable = gselect.VectorDBInfo(self.inmap).layers[str(self.vlayer)]
-                # initialize column selection comboboxes
-                self.cb_vcol.InsertColumns(vector=self.inmap, layer=self.vlayer)
-                self.cb_vrgb.InsertColumns(vector=self.inmap, layer=self.vlayer)
-                self.Update()
-            except:
-                pass
+            # initialize layer selection combobox
+            self.cb_vlayer.InsertLayers(self.inmap)
+            # initialize attribute table for layer=1
+            self.vtable = gselect.VectorDBInfo(self.inmap).layers[int(self.vlayer)]['table']
+            # initialize column selection comboboxes
+            self.cb_vcol.InsertColumns(vector=self.inmap, layer=self.vlayer)
+            self.cb_vrgb.InsertColumns(vector=self.inmap, layer=self.vlayer)
+            self.Update()
     def OnLayerSelection(self, event):
         # reset choices in column selection comboboxes if layer changes
         self.vlayer = int(event.GetString())
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2008-09-09 08:00:09 UTC (rev 33348)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2008-09-09 08:18:18 UTC (rev 33349)
@@ -390,8 +390,7 @@
                         break
             self.tables[table] = columns
-            #print 'self tables =', self.tables[table]
         return True
     def Reset(self):
@@ -402,32 +401,31 @@
             for name in self.tables[table].keys():
                 self.tables[table][name]['values'] = []
                 self.tables[table][name]['ids']    = []
 class LayerSelect(wx.ComboBox):
     Creates combo box for selecting data layers defined for vector.
     The 'layer' terminology is likely to change for GRASS 7
     def __init__(self, parent,
-                 id=wx.ID_ANY, value='1', pos=wx.DefaultPosition,
-                 size=wx.DefaultSize, choices=['1'], **kargs):
+                 id=wx.ID_ANY, pos=wx.DefaultPosition,
+                 size=wx.DefaultSize, vector=None, choices=[]):
-        super(LayerSelect, self).__init__(parent, id, value, pos, size, choices)
+        super(LayerSelect, self).__init__(parent, id, pos=pos, size=size,
+                                          choices=choices)
-        lsvector = kargs['vector'] # vector map to check for attribute tables
+        if not vector:
+            return
-        if lsvector == '':
-            return
-        else:
-            self.InsertLayers(lsvector)
+        self.InsertLayers(vector)
     def InsertLayers(self, vector):
-        """insert layers for a vector into the layer combobox"""
+        """Insert layers for a vector into the layer combobox"""
         layerchoices = VectorDBInfo(vector).layers.keys()
-        self.SetItems(layerchoices)
-        self.SetSelection(0)
-        self.SetValue('1') # all vectors have a layer 1 by default
+        self.SetItems(map(str, layerchoices))
+        self.SetStringSelection('1')
 class ColumnSelect(wx.ComboBox):
     Creates combo box for selecting columns in the attribute table for a vector.
@@ -435,25 +433,22 @@
                  id=wx.ID_ANY, value='', pos=wx.DefaultPosition,
-                 size=wx.DefaultSize, choices=[''], **kargs):
+                 size=wx.DefaultSize, vector=None, layer=1, choices=[]):
         super(ColumnSelect, self).__init__(parent, id, value, pos, size, choices)
-        csvector = kargs['vector'] # vector map to check for attribute tables
-        cslayer = kargs['layer'] # data layer connected to attribute table
+        if not vector:
+            return
-        if csvector == '' or cslayer == '':
-            return
-        else:
-            self.InsertColumns(csvector, cslayer)
+        self.InsertColumns(vector, layer)
     def InsertColumns(self, vector, layer):
-        """insert columns for a vector attribute table into the columns combobox"""
-        if vector == '' or layer == '': return
-        table = VectorDBInfo(vector).layers[str(layer)]
-        columnchoices = VectorDBInfo(vector).tables[table]
+        """Insert columns for a vector attribute table into the columns combobox"""
+        dbInfo = VectorDBInfo(vector)
+        table = dbInfo.layers[int(layer)]['table']
+        columnchoices = dbInfo.tables[table]
         #columnchoices.sort()
-        self.SetItems(columnchoices)
+        self.SetItems(columnchoices.keys())
 class DbColumnSelect(wx.ComboBox):
@@ -478,14 +473,19 @@
         """insert columns for a table into the columns combobox"""
         if table == '' : return
-        cmd = ['db.columns','table=%s' % table]
-        if dbdriver != '': cmd.append('driver=%s' % dbdriver)
-        if dbdatabase != '': cmd.append('database=%s' % dbdatabase)
+        cmd = ['db.columns',
+               'table=%s' % table]
+        if dbdriver:
+            cmd.append('driver=%s' % dbdriver)
+        if dbdatabase:
+            cmd.append('database=%s' % dbdatabase)
         try:
             columnchoices = gcmd.Command(cmd).ReadStdOutput()
         except gcmd.CmdError:
             columnchoices = []
-        #columnchoices.sort()
+        # columnchoices.sort()
