[GRASS-SVN] r33352 - grass/trunk/vector/v.build.polylines
Tue Sep 9 09:12:57 EDT 2008
Author: hamish
Date: 2008-09-09 09:12:57 -0400 (Tue, 09 Sep 2008)
New Revision: 33352
   grass/trunk/vector/v.build.polylines/main.c
remove -q flag, fix typo in G_message
Modified: grass/trunk/vector/v.build.polylines/main.c
--- grass/trunk/vector/v.build.polylines/main.c	2008-09-09 13:06:42 UTC (rev 33351)
+++ grass/trunk/vector/v.build.polylines/main.c	2008-09-09 13:12:57 UTC (rev 33352)
@@ -92,7 +92,6 @@
     struct Option *input;
     struct Option *output;
     struct Option *cats;
-    struct Flag *quietly;
     int polyline;
     int *lines_visited;
@@ -125,10 +124,6 @@
 			   "multi;Assign multiple category numbers to polyline");
     cats->answer = "no";
-    quietly = G_define_flag();
-    quietly->key = 'q';
-    quietly->description = _("Do not print polyline info");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -187,12 +182,9 @@
 	/* Find start of this polyline */
 	start_line = walk_back(&map, line);
 	start_type = Vect_read_line(&map, NULL, NULL, start_line);
-	if (!quietly->answer) {
-	    fprintf(stdout, "Polyline %d: start line = %d \n", polyline,
-		    start_line);
-	    fflush(stdout);
+	G_debug(1, "Polyline %d: start line = %d\n", polyline, start_line);
 	/* Walk forward and pick up coordinates */
 	points_in_polyline =
 	    walk_forward_and_pick_up_coords(&map, start_line, points,
@@ -207,7 +199,7 @@
     G_message(_("%d lines or boundaries found in vector map <%s@%s>"),
 	      nlines, Vect_get_name(&map), Vect_get_mapset(&map));
-    G_message(_("%d polylines stored to vector map <%s%s>"),
+    G_message(_("%d polylines stored in vector map <%s@%s>"),
 	      polyline, Vect_get_name(&Out), Vect_get_mapset(&Out));
     /* Copy (all linked) tables if needed */
