[GRASS-SVN] r33367 - in grass-addons/vector: v.buffer2 v.parallel2
Wed Sep 10 04:59:00 EDT 2008
Author: rmatev
Date: 2008-09-10 04:59:00 -0400 (Wed, 10 Sep 2008)
New Revision: 33367
   grass-addons/vector/v.buffer2/dgraph.c
   grass-addons/vector/v.buffer2/e_intersect.c
   grass-addons/vector/v.buffer2/vlib_buffer.c
   grass-addons/vector/v.parallel2/dgraph.c
   grass-addons/vector/v.parallel2/e_intersect.c
   grass-addons/vector/v.parallel2/vlib_buffer.c
Removed C99 calls.
Modified: grass-addons/vector/v.buffer2/dgraph.c
--- grass-addons/vector/v.buffer2/dgraph.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.buffer2/dgraph.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -1,5 +1,4 @@
 #include <stdlib.h>
-#include <math.h>
 #include <grass/Vect.h>
 #include <grass/gis.h>
 #include "dgraph.h"
Modified: grass-addons/vector/v.buffer2/e_intersect.c
--- grass-addons/vector/v.buffer2/e_intersect.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.buffer2/e_intersect.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -1,9 +1,14 @@
 #include <stdlib.h>
-#include <math.h>
 #include "e_intersect.h"
 #define SWAP(a,b) {t = a; a = b; b = t;}
+#ifndef MIN
+    #define MIN(X,Y) ((X<Y)?X:Y)
+#endif
+#ifndef MAX
+    #define MAX(X,Y) ((X>Y)?X:Y)
+#endif
 #define D (ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2)
 #define DA (bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2)
 #define DB (ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1)
@@ -118,11 +123,11 @@
         return 1;
-    if ((fmax(ax1, ax2) < fmin(bx1, bx2)) || (fmax(bx1, bx2) < fmin(ax1, ax2))) {
+    if ((MAX(ax1, ax2) < MIN(bx1, bx2)) || (MAX(bx1, bx2) < MIN(ax1, ax2))) {
         G_debug(3, "    no intersection (disjoint bounding boxes)");
         return 0;
-    if ((fmax(ay1, ay2) < fmin(by1, by2)) || (fmax(by1, by2) < fmin(ay1, ay2))) {
+    if ((MAX(ay1, ay2) < MIN(by1, by2)) || (MAX(by1, by2) < MIN(ay1, ay2))) {
         return 0;
@@ -349,8 +354,8 @@
     G_debug(2, "    d1 = %.18g", d1);
     G_debug(2, "    d2 = %.18g", d2);
-    tola = tol/fmax(fabs(ax2-ax1), fabs(ay2-ay1));
-    tolb = tol/fmax(fabs(bx2-bx1), fabs(by2-by1));
+    tola = tol/MAX(fabs(ax2-ax1), fabs(ay2-ay1));
+    tolb = tol/MAX(fabs(bx2-bx1), fabs(by2-by1));
     G_debug(2, "    tol  = %.18g", tol);
     G_debug(2, "    tola = %.18g", tola);
     G_debug(2, "    tolb = %.18g", tolb);
@@ -366,7 +371,7 @@
             return 0;
-        ra = fmin(fmax(ra, 0), 1);
+        ra = MIN(MAX(ra, 0), 1);
         *x1 = ax1 + ra*(ax2 - ax1);
         *y1 = ay1 + ra*(ay2 - ay1);
@@ -595,11 +600,11 @@
         return 1;
         G_debug(DLEVEL, "    no intersection (disjoint bounding boxes)");
         return 0;
         return 0;
@@ -828,11 +833,11 @@
         return 1;
         G_debug(0, "    no intersection (disjoint bounding boxes)");
         return 0;
         return 0;
Modified: grass-addons/vector/v.buffer2/vlib_buffer.c
--- grass-addons/vector/v.buffer2/vlib_buffer.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.buffer2/vlib_buffer.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -5,7 +5,6 @@
 #include <stdlib.h>
-#include <math.h>
 #include "dgraph.h"
@@ -909,7 +908,7 @@
     int i, res, winding, isle;
     int more = 8;
     int isles_allocated = 0;
-    double max = fmax(da, db);
+    double max = MAX(da, db);
     G_debug(2, "Vect_area_buffer()");
Modified: grass-addons/vector/v.parallel2/dgraph.c
--- grass-addons/vector/v.parallel2/dgraph.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.parallel2/dgraph.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -1,5 +1,4 @@
 #include <stdlib.h>
-#include <math.h>
 #include "dgraph.h"
Modified: grass-addons/vector/v.parallel2/e_intersect.c
--- grass-addons/vector/v.parallel2/e_intersect.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.parallel2/e_intersect.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -1,9 +1,14 @@
 #include <stdlib.h>
-#include <math.h>
+#ifndef MIN
+#endif
+#ifndef MAX
+#endif
         return 1;
         return 0;
         return 0;
@@ -349,8 +354,8 @@
@@ -366,7 +371,7 @@
             return 0;
         return 1;
         return 0;
         return 0;
         return 1;
         return 0;
         return 0;
Modified: grass-addons/vector/v.parallel2/vlib_buffer.c
--- grass-addons/vector/v.parallel2/vlib_buffer.c	2008-09-10 07:34:42 UTC (rev 33366)
+++ grass-addons/vector/v.parallel2/vlib_buffer.c	2008-09-10 08:59:00 UTC (rev 33367)
@@ -5,7 +5,6 @@
 #include <stdlib.h>
-#include <math.h>
 #include "dgraph.h"
@@ -909,7 +908,7 @@
     int more = 8;
