[GRASS-SVN] r33484 - in grass/trunk: raster/r.external raster/r.in.arc raster/r.in.ascii raster/r.in.bin raster/r.in.gdal raster/r.in.poly raster/r.neighbors raster/r.rescale raster/r.rescale.eq raster/r.support vector/v.support
Wed Sep 17 06:17:35 EDT 2008
Author: glynn
Date: 2008-09-17 06:17:35 -0400 (Wed, 17 Sep 2008)
New Revision: 33484
   grass/trunk/raster/r.external/main.c
   grass/trunk/raster/r.in.arc/main.c
   grass/trunk/raster/r.in.ascii/main.c
   grass/trunk/raster/r.in.bin/main.c
   grass/trunk/raster/r.in.gdal/main.c
   grass/trunk/raster/r.in.poly/main.c
   grass/trunk/raster/r.neighbors/main.c
   grass/trunk/raster/r.rescale.eq/main.c
   grass/trunk/raster/r.rescale/main.c
   grass/trunk/raster/r.support/main.c
   grass/trunk/vector/v.support/main.c
Don't use quotes in ->key_desc
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.external/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -530,7 +530,7 @@
     parm.title = G_define_option();
     parm.title->key = "title";
-    parm.title->key_desc = "\"phrase\"";
+    parm.title->key_desc = "phrase";
     parm.title->type = TYPE_STRING;
     parm.title->required = NO;
     parm.title->description = _("Title for resultant raster map");
Modified: grass/trunk/raster/r.in.arc/main.c
--- grass/trunk/raster/r.in.arc/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.in.arc/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -81,7 +81,7 @@
Modified: grass/trunk/raster/r.in.ascii/main.c
--- grass/trunk/raster/r.in.ascii/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.in.ascii/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -79,7 +79,7 @@
Modified: grass/trunk/raster/r.in.bin/main.c
--- grass/trunk/raster/r.in.bin/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.in.bin/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -160,7 +160,7 @@
Modified: grass/trunk/raster/r.in.gdal/main.c
--- grass/trunk/raster/r.in.gdal/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.in.gdal/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -108,7 +108,7 @@
Modified: grass/trunk/raster/r.in.poly/main.c
--- grass/trunk/raster/r.in.poly/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.in.poly/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -37,7 +37,7 @@
-    title->key_desc = "\"phrase\"";
+    title->key_desc = "phrase";
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.neighbors/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -138,7 +138,7 @@
     parm.title->description = _("Title of the output raster map");
Modified: grass/trunk/raster/r.rescale/main.c
--- grass/trunk/raster/r.rescale/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.rescale/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -77,7 +77,7 @@
     parm.title->description = _("Title for new raster map");
Modified: grass/trunk/raster/r.rescale.eq/main.c
--- grass/trunk/raster/r.rescale.eq/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.rescale.eq/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -81,7 +81,7 @@
Modified: grass/trunk/raster/r.support/main.c
--- grass/trunk/raster/r.support/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/raster/r.support/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -60,14 +60,14 @@
     title_opt = G_define_option();
     title_opt->key = "title";
-    title_opt->key_desc = "\"phrase\"";
+    title_opt->key_desc = "phrase";
     title_opt->type = TYPE_STRING;
     title_opt->required = NO;
     title_opt->description = _("Text to use for map title");
     history_opt = G_define_option();
     history_opt->key = "history";
-    history_opt->key_desc = "\"phrase\"";
+    history_opt->key_desc = "phrase";
     history_opt->type = TYPE_STRING;
     history_opt->required = NO;
     history_opt->description =
@@ -87,21 +87,21 @@
     datasrc1_opt = G_define_option();
     datasrc1_opt->key = "source1";
-    datasrc1_opt->key_desc = "\"phrase\"";
+    datasrc1_opt->key_desc = "phrase";
     datasrc1_opt->type = TYPE_STRING;
     datasrc1_opt->required = NO;
     datasrc1_opt->description = _("Text to use for data source, line 1");
     datasrc2_opt = G_define_option();
     datasrc2_opt->key = "source2";
-    datasrc2_opt->key_desc = "\"phrase\"";
+    datasrc2_opt->key_desc = "phrase";
     datasrc2_opt->type = TYPE_STRING;
     datasrc2_opt->required = NO;
     datasrc2_opt->description = _("Text to use for data source, line 2");
     datadesc_opt = G_define_option();
     datadesc_opt->key = "description";
-    datadesc_opt->key_desc = "\"phrase\"";
+    datadesc_opt->key_desc = "phrase";
     datadesc_opt->type = TYPE_STRING;
     datadesc_opt->required = NO;
     datadesc_opt->description =
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c	2008-09-17 10:16:32 UTC (rev 33483)
+++ grass/trunk/vector/v.support/main.c	2008-09-17 10:17:35 UTC (rev 33484)
@@ -44,7 +44,7 @@
     organization = G_define_option();
     organization->key = "organization";
-    organization->key_desc = "\"phrase\"";
+    organization->key_desc = "phrase";
     organization->type = TYPE_STRING;
     organization->required = NO;
     organization->description =
@@ -53,7 +53,7 @@
     /* don't predefine answers to not overwrite existing information */
     date = G_define_option();
     date->key = "date";
-    date->key_desc = "\"datestring\"";
+    date->key_desc = "datestring";
     date->type = TYPE_STRING;
     date->required = NO;
     date->description =
@@ -61,21 +61,21 @@
     person = G_define_option();
     person->key = "person";
-    person->key_desc = "\"phrase\"";
+    person->key_desc = "phrase";
     person->type = TYPE_STRING;
     person->required = NO;
     person->description = _("Person who created vector map");
     map_name = G_define_option();
     map_name->key = "map_name";
-    map_name->key_desc = "\"phrase\"";
+    map_name->key_desc = "phrase";
     map_name->type = TYPE_STRING;
     map_name->required = NO;
     map_name->description = _("Vector map title");
     map_date = G_define_option();
     map_date->key = "map_date";
-    map_date->key_desc = "\"datestring\"";
+    map_date->key_desc = "datestring";
     map_date->type = TYPE_STRING;
     map_date->required = NO;
     map_date->description =
@@ -102,7 +102,7 @@
     comment = G_define_option();
     comment->key = "comment";
-    comment->key_desc = "\"phrase\"";
+    comment->key_desc = "phrase";
     comment->type = TYPE_STRING;
     comment->required = NO;
     comment->description =
@@ -110,7 +110,7 @@
     cmdhist = G_define_option();
     cmdhist->key = "cmdhist";
-    cmdhist->key_desc = "\"command\"";
+    cmdhist->key_desc = "command";
     cmdhist->type = TYPE_STRING;
     cmdhist->required = NO;
     cmdhist->description =
