[GRASS-SVN] r33527 - grass/trunk/scripts/d.rast.leg
Thu Sep 25 03:47:33 EDT 2008
Author: neteler
Date: 2008-09-25 03:47:33 -0400 (Thu, 25 Sep 2008)
New Revision: 33527
   grass/trunk/scripts/d.rast.leg/d.rast.leg
   grass/trunk/scripts/d.rast.leg/d.rast.leg.html
added flip legend flap
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg
--- grass/trunk/scripts/d.rast.leg/d.rast.leg	2008-09-24 19:37:04 UTC (rev 33526)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg	2008-09-25 07:47:33 UTC (rev 33527)
@@ -29,8 +29,8 @@
 # See also:	d.rast, d.legend.
+# Jianping Xu and Scott Madry, Rutgers University. October 19, 1993
 # Markus Neteler 8/2002: added simple d.legend logic
-# Jianping Xu and Scott Madry, Rutgers University. October 19, 1993
 # Markus Neteler 10/2003: added g.parser
 # Michael Barton 12/2004: remove reference to (null)
@@ -40,9 +40,13 @@
 #%  keywords: display
 #%End
 #%flag
+#%  key: f
+#%  description: Flip legend
+#%end
+#%flag
 #%  key: n
-#%  description: omit entries with missing label
-#%END
+#%  description: Omit entries with missing label
+#%end
 #%option
 #% key: map
 #% type: string
@@ -70,6 +74,10 @@
   OMIT="-n"
 fi
+if [ $GIS_FLAG_F -eq 1 ] ; then
+  FLIP="-f"
+fi
 #for -n flag of d.legend
 eval `g.findfile el=cell file=$GIS_OPT_MAP`
 if [ ! "$file" ] ; then
@@ -103,9 +111,9 @@
        #draw legend
     	d.frame -s at=0,90,65,100 frame=right
         if test -f $HISTFILEDIR/$GIS_OPT_MAP/histogram ; then
-    	     d.legend -n map=$GIS_OPT_MAP
+    	     d.legend $FLIP -n map=$GIS_OPT_MAP
         else
-             d.legend $OMIT map=$GIS_OPT_MAP
+             d.legend $FLIP $OMIT map=$GIS_OPT_MAP
         fi
        #draw map
@@ -126,9 +134,9 @@
        #draw legend
-             d.legend -n map=$GIS_OPT_MAP lines=$GIS_OPT_NUM_OF_LINES
+             d.legend $FLIP -n map=$GIS_OPT_MAP lines=$GIS_OPT_NUM_OF_LINES
         else
         fi
        #draw map
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.html
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.html	2008-09-24 19:37:04 UTC (rev 33526)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.html	2008-09-25 07:47:33 UTC (rev 33527)
@@ -9,7 +9,8 @@
 <H2>NOTES</H2>
+The legend may be flipped with the <B>-f</B> flag.
+<P>
 If the <B>num_of_lines</B> parameter is not given then the legend frame will
 display as many lines as number of categories in the map, otherwise, it
 will display the first <B>num_of_lines</B> minus 1 categories with the
