[GRASS-SVN] r33530 - grass/branches/develbranch_6/scripts/d.rast.leg
Thu Sep 25 04:35:26 EDT 2008
Author: neteler
Date: 2008-09-25 04:35:25 -0400 (Thu, 25 Sep 2008)
New Revision: 33530
   grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg
   grass/branches/develbranch_6/scripts/d.rast.leg/description.html
Added rast parameter for static legends 8merge fro trunk, r33529)
Modified: grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg
--- grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg	2008-09-25 08:35:08 UTC (rev 33529)
+++ grass/branches/develbranch_6/scripts/d.rast.leg/d.rast.leg	2008-09-25 08:35:25 UTC (rev 33530)
@@ -51,7 +51,7 @@
 #% key: map
 #% type: string
 #% gisprompt: old,cell,raster
-#% description: raster input map
+#% description: Name of raster map
 #% required : yes
 #%end
 #%option
@@ -60,6 +60,13 @@
 #% description: Number of lines to appear in the legend
 #% required : no
 #%end
+#%option
+#% key: rast
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Name of raster map to generate legend from
+#% required : no
+#%end
 if test "$GISBASE" = ""; then
  echo "You must be in GRASS GIS to run this program." >&2
@@ -87,6 +94,15 @@
 filemapset="${mapset}"
 HISTFILEDIR=$GISDBASE/$LOCATION_NAME/$filemapset/cell_misc/
+# for rast=
+if [ ! -z $GIS_OPT_RAST ] ; then
+	eval `g.findfile el=cell file=$GIS_OPT_RAST`
+	if [ ! "$file" ] ; then
+	   g.message -e "Raster map '$GIS_OPT_RAST' not found in mapset search path"
+	   exit 1
+	fi
+fi
 # save defined font setting
 FONTCMD=`d.frame -l | grep d.font | sed 's+"++1'| sed 's+"++1'`
 d.frame -e
@@ -110,11 +126,19 @@
        #draw legend
     	d.frame -s at=0,90,65,100 frame=right
-        if test -f $HISTFILEDIR/$GIS_OPT_MAP/histogram ; then
-    	     d.legend $FLIP -n map=$GIS_OPT_MAP
-        else
-             d.legend $FLIP $OMIT map=$GIS_OPT_MAP
-        fi
+	if [ -z $GIS_OPT_RAST ] ; then
+		if test -f $HISTFILEDIR/$GIS_OPT_MAP/histogram ; then
+	  	     d.legend $FLIP -n map=$GIS_OPT_MAP
+        	else
+	             d.legend $FLIP $OMIT map=$GIS_OPT_MAP
+        	fi
+	else
+		if test -f $HISTFILEDIR/$GIS_OPT_RAST/histogram ; then
+		     d.legend $FLIP -n map=$GIS_OPT_RAST
+		else
+		     d.legend $FLIP $OMIT map=$GIS_OPT_RAST
+		fi
+	fi
        #draw map
 	d.frame -s at=0,100,0,65 frame=left
@@ -133,11 +157,19 @@
        #draw legend
-             d.legend $FLIP -n map=$GIS_OPT_MAP lines=$GIS_OPT_NUM_OF_LINES
-        else
-        fi
+	             d.legend $FLIP -n map=$GIS_OPT_MAP lines=$GIS_OPT_NUM_OF_LINES
+        	else
+        	fi
+	else
+		     d.legend $FLIP -n map=$GIS_OPT_RAST lines=$GIS_OPT_NUM_OF_LINES
+		else
+		fi
+	fi
        #draw map
Modified: grass/branches/develbranch_6/scripts/d.rast.leg/description.html
--- grass/branches/develbranch_6/scripts/d.rast.leg/description.html	2008-09-25 08:35:08 UTC (rev 33529)
+++ grass/branches/develbranch_6/scripts/d.rast.leg/description.html	2008-09-25 08:35:25 UTC (rev 33530)
@@ -18,7 +18,12 @@
 <P>
 The user may adjust the <B>num_of_lines</B> parameter or
 the size of graphics window to get an appropriate result.
 <P>
+The user may specify a second raster map with the <b>rast</b> parameter from
+which the legend is generated. This is useful to visualize (time) series of
+raster maps with a common static legend instead of the default dynamic legend.
+<P>
 To remove all frames when clearing the display, use
 "<em><tt>d.erase -f</tt></em>".
