[GRASS-SVN] r33558 - in grass/trunk: lib/python scripts/db.droptable scripts/db.out.ogr scripts/r.in.aster scripts/r.mask scripts/v.db.reconnect.all scripts/v.dissolve scripts/v.in.e00 scripts/v.in.geonames scripts/v.in.gns scripts/v.in.wfs scripts/v.rast.stats
Fri Sep 26 10:54:34 EDT 2008
Author: glynn
Date: 2008-09-26 10:54:34 -0400 (Fri, 26 Sep 2008)
New Revision: 33558
Added:
   grass/trunk/scripts/db.droptable/db.droptable.py
   grass/trunk/scripts/db.out.ogr/db.out.ogr.py
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
   grass/trunk/lib/python/grass.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/v.dissolve/v.dissolve.py
   grass/trunk/scripts/v.in.e00/v.in.e00.py
   grass/trunk/scripts/v.in.geonames/v.in.geonames.py
   grass/trunk/scripts/v.in.gns/v.in.gns.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
Convert db.droptable, db.out.ogr, v.db.reconnect.all to Python
Add, use several utility functions:
 overwrite, basename, find_program, try_remove, try_rmdir
Modified: grass/trunk/lib/python/grass.py
--- grass/trunk/lib/python/grass.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/lib/python/grass.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -1,5 +1,4 @@
 import os
-import os.path
 import sys
 import types
 import subprocess
@@ -249,3 +248,51 @@
         return tuple(float(v) / 255 for v in vals)
     return dflt
+# check GRASS_OVERWRITE
+def overwrite():
+    owstr = 'GRASS_OVERWRITE'
+    return owstr in os.environ and os.environ[owstr] != '0'
+## various utilities, not specific to GRASS
+# basename inc. extension stripping
+def basename(path, ext = None):
+    name = os.path.basename(path)
+    if not ext:
+	return name
+    fs = name.rsplit('.', 1)
+    if len(fs) > 1 and fs[1].lower() == ext:
+	name = fs[0]
+    return name
+# find a program (replacement for "which")
+def find_program(pgm):
+    nuldev = file(os.devnull, 'w+')
+    try:
+	subprocess.call([pgm], stdin = nuldev, stdout = nuldev, stderr = nuldev)
+	found = True
+    except:
+	found = False
+    nuldev.close()
+    return found
+# try to remove a file, without complaints
+def try_remove(path):
+    try:
+	os.remove(path)
+    except:
+	pass
+# try to remove a directory, without complaints
+def try_rmdir(path):
+    try:
+	os.rmdir(path)
+    except:
+	pass
Added: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py	                        (rev 0)
+++ grass/trunk/scripts/db.droptable/db.droptable.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -0,0 +1,98 @@
+#!/usr/bin/env python
+# MODULE:       db.droptable
+# AUTHOR(S):   	Markus Neteler
+#               Converted to Python by Glynn Clements
+# PURPOSE:      interface to db.execute to drop an attribute table
+# COPYRIGHT:    (C) 2007 by Markus Neteler and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Drops an attribute table.
+#%  keywords: database, attribute table
+#%End
+#%flag
+#%  key: f
+#%  description: Force removal (required for actual deletion of files)
+#%end
+#%option
+#% key: table
+#% type: string
+#% key_desc : name
+#% description: Table to drop
+#% required : yes
+#% gisprompt: old,dbtable,dbtable
+#%end
+import sys
+import os
+import grass
+import subprocess
+def main():
+    table = options['table']
+    force = flags['f']
+    # check if DB parameters are set, and if not set them.
+    grass.run_command('db.connect', flags = 'c')
+    s = grass.read_command('db.connect', flags = 'p')
+    kv = grass.parse_key_val(s, sep = ':')
+    database = kv['database']
+    driver = kv['driver']
+    # schema needed for PG?
+    if force:
+	grass.message("Forcing ...")
+    # check if table exists
+    nuldev = file(os.devnull, 'w')
+    if grass.run_command('db.describe', flags = 'c', table = table,
+			 stdout = nuldev, stderr = nuldev):
+	grass.fatal("Table <%s> not found in current mapset" % table)
+    # check if table is used somewhere (connected to vector map)
+    used = []
+    vects = grass.list_strings('vect')
+    for vect in vects:
+	s = grass.read_command('v.db.connect', flags = 'g', map = vect, stderr = nuldev)
+	if not s:
+	    continue
+	for l in s.splitlines():
+	    f = l.split()
+	    if f[1] == table:
+		used.append(vect)
+		break
+    if used:
+	grass.warning("Deleting table <%s> which is attached to following map(s):" % table)
+	for vect in used:
+	    grass.message(vect)
+    if not force:
+	grass.message("The table <%s> would be deleted." % table)
+	grass.message("")
+	grass.message("You must use the force flag to actually remove it. Exiting.")
+	sys.exit(0)
+    p = grass.start_command('db.execute', database = database, driver = driver,
+			    stdin = subprocess.PIPE)
+    p.stdin.write("DROP TABLE " + table)
+    p.stdin.close()
+    p.wait()
+    if p.returncode != 0:
+  	grass.fatal("Cannot continue (problem deleting table).")
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/db.droptable/db.droptable.py
___________________________________________________________________
Added: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py	                        (rev 0)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -0,0 +1,103 @@
+# MODULE:       db.out.ogr
+# PURPOSE:      exports attribute tables into various formats
+#               for details.
+#%Module
+#%  description: Exports attribute tables into various formats.
+#%End
+#%option
+#% key: input
+#% type: string
+#% key_desc : name
+#% description: GRASS table name
+#% required : yes
+#%end
+#%option
+#% key: dsn
+#% type: string
+#% key_desc : name
+#% gisprompt: new_file,file,input
+#% description: Table file to be exported or DB connection string
+#% required : yes
+#%end
+#%option
+#% key: format
+#% type: string
+#% description: Table format
+#% required : yes
+#% options: CSV,DBF,GML,MySQL,PostgreSQL,SQLite
+#% answer: DBF
+#%end
+#%option
+#% key: db_table
+#% type: string
+#% key_desc : name
+#% description: Name for output table
+#% required : no
+#%end
+import sys
+import os
+import grass
+def main():
+    input = options['input']
+    format = options['format']
+    dsn = options['dsn']
+    table = options['db_table']
+    if format.lower() == 'dbf':
+	format = "ESRI_Shapefile"
+    olayer = {}
+    if format.lower() == 'csv':
+	olayer['olayer'] = grass.basename(dsn, 'csv')
+    #is there a simpler way of testing for --overwrite?
+    dbffile = input + '.dbf'
+    if os.path.exists(dbffile) and not grass.overwrite():
+	grass.fatal("File <%s> already exists" % dbffile)
+    if grass.run_command('v.out.ogr', quiet = True, input = input, dsn = dsn,
+			 format = format, type = 'point', **olayer) != 0:
+	sys.exit(1)
+    if format == "ESRI_Shapefile":
+	exts = ['shp', 'shx', 'prj']
+	if dsn.endswith('.dbf'):
+	    outname = grass.basename(dsn, 'dbf')
+	    for ext in exts:
+		try_remove("%s.%s" % (outname, ext))
+	    outname += '.dbf'
+	else:
+	    for ext in exts:
+		try_remove(os.path.join(dsn, "%s.%s" % (input, ext)))
+	    outname = os.path.join(dsn, input + ".dbf")
+    elif format.lower() == 'csv':
+	outname = dsn + '.csv'
+    else:
+	outname = input
+    grass.message("Exported table <%s>" % outname)
+    main()
Property changes on: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -169,7 +169,7 @@
     #cleanup
     message("Cleaning up ...")
-    os.remove(tempfile)
+    grass.try_remove(tempfile)
     message("Done.")
     return
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/r.mask/r.mask.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -70,9 +70,7 @@
  	else:
 	    grass.warning("No existing MASK to remove")
     else:
-	owstr = 'GRASS_OVERWRITE'
-	overwrite = owstr in os.environ and os.environ[owstr] != '0'
-	if exists and not overwrite:
+	if exists and not grass.overwrite():
 	    grass.fatal("MASK already found in current mapset. Delete first or overwrite")
 	p = grass.start_command('r.reclass', input = input, output = 'MASK', overwrite = True,
Added: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -0,0 +1,98 @@
+# MODULE:	v.db.reconnect.all
+# AUTHOR(S):	Radim Blazek
+# PURPOSE:	Reconnect vectors
+# COPYRIGHT:	(C) 2004 by the GRASS Development Team
+#		for details.
+#%Module
+#% description: Reconnects vectors to a new database.
+#% keywords: vector, database, attribute table
+#%End
+#%option
+#% key: old_database
+#% type: string
+#% description: Name of old database. The database must be in form printed by v.db.connect -g, i.e. with substituted variables
+#% required : yes
+#%END
+#%option
+#% key: new_database
+#% type: string
+#% description: Name of new database
+#% required : yes
+#%END
+#%option
+#% key: old_schema
+#% type: string
+#% description: Old schema
+#% required : no
+#%END
+#%option
+#% key: new_schema
+#% type: string
+#% description: New schema
+#% required : no
+#%END
+import sys
+import os
+import grass
+import subprocess
+def main():
+    old_database = options['old_database']
+    new_database = options['new_database']
+    old_schema = options['old_schema']
+    new_schema = options['new_schema']
+    mapset = grass.gisenv()['MAPSET']
+    for vect in grass.list_grouped('vect')[mapset]:
+	vect = "%s@%s" % (vect, mapset)
+	grass.message("Reconnecting vector <%s>" % vect)
+	for link in s.splitlines():
+	    f = link.split()
+	    layer = f[0]
+	    schema_table = f[1]
+	    key = f[2]
+	    database = f[3]
+	    driver = f[4]
+	    if '.' in schema_table:
+		st = schema_table.split('.', 1)
+		schema = st[0]
+		table = st[1]
+	    else:
+		schema = ''
+		table = schema_table
+	    if new_schema:
+		new_schema_table = "%s.%s" % (new_schema, table)
+	    else:
+		new_schema_table = table
+	    grass.message("SCHEMA = %s TABLE = %s NEW_SCHEMA_TABLE = %s" % (schema, table, new_schema_table))
+	    if database == old_database and schema == old_schema:
+		grass.message("Reconnecting layer " + layer)
+		grass.message("v.db.connect -o map=%s layer=%s driver=%s database=%s table=%s key=%s" %
+			      (vect, layer, driver, new_database, new_schema_table, key))
+		grass.run_command('v.db.connect', flags = 'o', map = vect,
+				  layer = layer, driver = driver, database = new_database,
+				  table = new_schema_table, key = key)
+	    else:
+		grass.message("Layer <%s> will not be reconnected, database or schema do not match." % layer)
+    main()
Property changes on: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -67,7 +67,7 @@
     column = options['column']
     # save command line
-    cmdline = os.path.basename(sys.argv[0])
+    cmdline = grass.basename(sys.argv[0])
     cmdline += ' input=' + input
     cmdline += ' output=' + output
     if layer:
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -58,24 +58,13 @@
 import glob
 import grass
-def find_program(pgm):
-    nuldev = file(os.devnull, 'w+')
-    try:
-	subprocess.call([pgm], stdin = nuldev, stdout = nuldev, stderr = nuldev)
-	found = True
-    except:
-	found = False
-    nuldev.close()
-    return found
 def main():
     filename = options['file']
     type = options['type']
     vect = options['vect']
     # save command line
     cmdline += ' file=' + filename
     cmdline += ' type=' + type
     if vect:
@@ -84,13 +73,13 @@
     e00tmp = str(os.getpid())
     #### check for avcimport
-    if not find_program('avcimport'):
+    if not grass.find_program('avcimport'):
 	grass.fatal("'avcimport' program not found, install it first" +
 		    "\n" +
 		    "http://avce00.maptools.org")
     #### check for e00conv
-    if not find_program('e00conv'):
+    if not grass.find_program('e00conv'):
 	grass.fatal("'e00conv' program not found, install it first" +
 		    "\n" +
@@ -99,10 +88,7 @@
     if type not in ['point','line','area']:
 	grass.fatal('Must specify one of "point", "line", or "area".')
-    e00name = os.path.basename(filename)
-    fs = os.path.splitext(e00name)
-    if fs[1].lower() == '.e00':
-	e00name = fs[0]
+    e00name = grass.basename(filename, 'e00')
     # avcimport only accepts 13 chars:
     e00shortname = e00name[:13]
@@ -121,10 +107,7 @@
     #make a temporary directory
     tmpdir = grass.tempfile()
-    try:
-	os.remove(tmpdir)
-    except:
-	pass
+    grass.try_remove(tmpdir)
     os.mkdir(tmpdir)
     files = glob.glob(e00name + '.e[0-9][0-9]') + glob.glob(e00name + '.E[0-9][0-9]')
@@ -154,11 +137,8 @@
 	grass.message("E00 ASCII found and converted to Arc Coverage in current directory")
     else:
 	grass.message("E00 Compressed ASCII found. Will uncompress first...")
-	try:
-	    os.remove(e00shortname)
-	    os.remove(info)
-	except:
-	    pass
+	grass.try_remove(e00shortname)
+	grass.try_remove(info)
 	subprocess.call(['e00conv', filename, e00tmp + '.e00'])
 	grass.message("...converted to Arc Coverage in current directory")
 	subprocess.call(['avcimport', e00tmp + '.e00', e00shortname], stderr = nuldev)
@@ -183,16 +163,10 @@
     for root, dirs, files in os.walk('.', False):
 	for f in files:
 	    path = os.path.join(root, f)
-	    try:
-		os.remove(path)
-	    except:
-		pass
+	    grass.try_remove(path)
 	for d in dirs:
 	    path = os.path.join(root, d)
-	    try:
-		os.rmdir(path)
-	    except:
-		pass
+	    grass.try_rmdir(path)
     os.chdir('..')
     os.rmdir(tmpdir)
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -52,7 +52,7 @@
     outfile = options['output']
     # save command line
     if infile:
 	cmdline += ' input=' + infile
     if outfile:
@@ -148,7 +148,7 @@
 		      input = tmpfile, output = outfile,
 		      columns = columns)
-    os.remove(tmpfile)
+    grass.try_remove(tmpfile)
     # write cmd history:
     grass.run_command('v.support', map = outfile, cmdhist = cmdline)
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -52,17 +52,14 @@
     filevect = options['vect']
     # save command line
     if fileorig:
 	cmdline += ' file=' + fileorig
     if filevect:
 	cmdline += ' vect=' + filevect
     if not filevect:
-	filevect = os.path.basename(fileorig)
-	fs = os.path.splitext(filevect)
-	if fs[1].lower() == '.txt':
-	    filevect = fs[0]
+	filevect = grass.basename(fileorig, 'txt')
     #are we in LatLong location?
     s = grass.read_command("g.proj", flags='j')
@@ -154,7 +151,7 @@
 		      input = tmpfile, output = filevect,
 		      columns = columns)
     grass.run_command('v.support', map = filevect, cmdhist = cmdline)
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -56,7 +56,7 @@
     outf.close()
     grass.run_command('v.in.ogr', flags = 'o', dsn = tmpxml, out = out)
-    os.remove(tmpxml)
+    grass.try_remove(tmpxml)
     grass.message("Vector points map <%s> imported from WFS." % out)
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2008-09-26 06:49:40 UTC (rev 33557)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2008-09-26 14:54:34 UTC (rev 33558)
@@ -87,10 +87,7 @@
 	grass.message("Restoring previous MASK...")
 	grass.run_command('g.rename', rast = (tmpname + "_origmask", 'MASK'), quiet = True)
     for f in [tmp, tmpname, sqltmp]:
-	try:
-	    os.remove(f)
-	except:
-	    pass
+	grass.try_remove(f)
 def main():
     global tmp, sqltmp, tmpname, nuldev, vector, mask_found
@@ -98,7 +95,7 @@
     tmp = grass.tempfile()
     sqltmp = tmp + ".sql"
     # we need a random name
-    tmpname = os.path.basename(tmp)
+    tmpname = grass.basename(tmp)
@@ -222,10 +219,7 @@
     grass.verbose("Processing data ...")
     # get rid of any earlier attempts
-    try:
-	os.remove(sqltmp)
-    except:
-	pass
+    grass.try_remove(sqltmp)
     # do extended stats?
     if flags['e']:
