[GRASS-SVN] r33565 - in grass/trunk/imagery: i.albedo i.qc.modis
Sat Sep 27 12:25:01 EDT 2008
Author: ychemin
Date: 2008-09-27 12:25:01 -0400 (Sat, 27 Sep 2008)
New Revision: 33565
Added:
   grass/trunk/imagery/i.albedo/i.albedo.html
   grass/trunk/imagery/i.qc.modis/i.qc.modis.html
Removed:
   grass/trunk/imagery/i.albedo/description.html
   grass/trunk/imagery/i.qc.modis/description.html
fixed html help file names
Deleted: grass/trunk/imagery/i.albedo/description.html
--- grass/trunk/imagery/i.albedo/description.html	2008-09-27 15:11:05 UTC (rev 33564)
+++ grass/trunk/imagery/i.albedo/description.html	2008-09-27 16:25:01 UTC (rev 33565)
@@ -1,24 +0,0 @@
-<H2>DESCRIPTION</H2>
-<EM>i.albedo</EM> calculates the Albedo, that is the Shortwave surface reflectance in the range of 0.3-3 micro-meters.
-It takes input of individual bands of surface reflectance from Modis, AVHRR, Landsat or Aster and calculates the Albedo for those.
-This is an precursor to r.sun and any Energy-Balance processing.
-<H2>NOTES</H2>
-It assumes MODIS product surface reflectance in [0;10000]
-<H2>TODO</H2>
-Maybe change input requirement of MODIS to [0.0-1.0]?
-<H2>SEE ALSO</H2>
-<em>
-<A HREF="r.sun.html">r.sun</A><br>
-</em>
-<H2>AUTHORS</H2>
-Yann Chemin, International Rice Research Institute, The Philippines<BR>
-<p>
-<i>Last changed: $Date: 2006/10/08 11:41:43 $</i>
Copied: grass/trunk/imagery/i.albedo/i.albedo.html (from rev 33564, grass/trunk/imagery/i.albedo/description.html)
--- grass/trunk/imagery/i.albedo/i.albedo.html	                        (rev 0)
+++ grass/trunk/imagery/i.albedo/i.albedo.html	2008-09-27 16:25:01 UTC (rev 33565)
@@ -0,0 +1,24 @@
+<H2>DESCRIPTION</H2>
+<EM>i.albedo</EM> calculates the Albedo, that is the Shortwave surface reflectance in the range of 0.3-3 micro-meters.
+It takes input of individual bands of surface reflectance from Modis, AVHRR, Landsat or Aster and calculates the Albedo for those.
+This is an precursor to r.sun and any Energy-Balance processing.
+<H2>NOTES</H2>
+It assumes MODIS product surface reflectance in [0;10000]
+<H2>TODO</H2>
+Maybe change input requirement of MODIS to [0.0-1.0]?
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="r.sun.html">r.sun</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines<BR>
+<p>
+<i>Last changed: $Date: 2006/10/08 11:41:43 $</i>
Property changes on: grass/trunk/imagery/i.albedo/i.albedo.html
___________________________________________________________________
Deleted: grass/trunk/imagery/i.qc.modis/description.html
--- grass/trunk/imagery/i.qc.modis/description.html	2008-09-27 15:11:05 UTC (rev 33564)
+++ grass/trunk/imagery/i.qc.modis/description.html	2008-09-27 16:25:01 UTC (rev 33565)
@@ -1,63 +0,0 @@
-<EM>i.qc.modis</EM> Extracts Requested Quality Assessment flags from Modis 09 A and Q products.
-<EM>MODLAND QA Bits 250m/500m bits[0-1]</EM>
-[00]= class 1: Corrected product produced at ideal quality -- all bands
-[01]= class 2: Corrected product produced at less than idel quality -- some or all bands
-[10]= class 3: Corrected product NOT produced due to cloud effect -- all bands
-[11]= class 4: Corrected product NOT produced due to other reasons -- some or all bands maybe be fill value (Note that a value of [11] overrides a value of [01])
-<EM> Cloud State 250m Unsigned Int bits[2-3] </EM>
-[00]= class 1: Clear -- No clouds
-[01]= class 2: Cloudy
-[10]= class 3: Mixed
-[11]= class 4: Not Set ; Assumed Clear
-<EM> Band-wise Data Quality 250m Unsigned Int bits[4-7][8-11]</EM>
-<EM> Band-wise Data Quality 500m long Int bits[2-5][6-9][10-13][14-17][18-21][22-25][26-29]</EM>
-[0000]= class 1: highest quality
-[0111]= class 2: noisy detector
-[1000]= class 3: dead detector; data interpolated in L1B
-[1001]= class 4: solar zenith ge 86 degrees
-[1010]= class 5: solar zenith ge 85 and lt 86 degrees
-[1011]= class 6: missing input
-[1100] class 7: internal constant used in place of climatological data for at least one atmospheric constant
-[1101]= class 8: correction out of bounds, pixel constrained to extreme allowable value
-[1110]= class 9: L1B data faulty
-[1111]= class 10: not processed due to deep ocean or cloud
-Class 11: Combination of bits unused
-<EM>Atmospheric correction 250m/500m bit[12]/[30]</EM>
-[00]= class 1: Not Corrected product
-<EM>Adjacency correction 250m/500m bit[13][31]</EM>
-<EM>Different orbit from 500m product, 250m Unsigned Int bit[14]</EM>
-[00]= class 1: same orbit as 500m
-[01]= class 2: different orbit from 500m
-<H2>NOTES</H2>
-<H2>TODO</H2>
-Testing is required.
-<H2>SEE ALSO</H2>
-<em>
-<A HREF="i.vi.html">i.vi</A><br>
-</em>
-<H2>AUTHORS</H2>
-Yann Chemin, International Rice Research Institute, The Philippines.<BR>
-<p>
-<i>Last changed: $Date: 2008/07/28 15:33:42 $</i>
Copied: grass/trunk/imagery/i.qc.modis/i.qc.modis.html (from rev 33564, grass/trunk/imagery/i.qc.modis/description.html)
--- grass/trunk/imagery/i.qc.modis/i.qc.modis.html	                        (rev 0)
+++ grass/trunk/imagery/i.qc.modis/i.qc.modis.html	2008-09-27 16:25:01 UTC (rev 33565)
@@ -0,0 +1,63 @@
+<EM>i.qc.modis</EM> Extracts Requested Quality Assessment flags from Modis 09 A and Q products.
+<EM>MODLAND QA Bits 250m/500m bits[0-1]</EM>
+[00]= class 1: Corrected product produced at ideal quality -- all bands
+[01]= class 2: Corrected product produced at less than idel quality -- some or all bands
+[10]= class 3: Corrected product NOT produced due to cloud effect -- all bands
+[11]= class 4: Corrected product NOT produced due to other reasons -- some or all bands maybe be fill value (Note that a value of [11] overrides a value of [01])
+<EM> Cloud State 250m Unsigned Int bits[2-3] </EM>
+[00]= class 1: Clear -- No clouds
+[01]= class 2: Cloudy
+[10]= class 3: Mixed
+[11]= class 4: Not Set ; Assumed Clear
+<EM> Band-wise Data Quality 250m Unsigned Int bits[4-7][8-11]</EM>
+<EM> Band-wise Data Quality 500m long Int bits[2-5][6-9][10-13][14-17][18-21][22-25][26-29]</EM>
+[0000]= class 1: highest quality
+[0111]= class 2: noisy detector
+[1000]= class 3: dead detector; data interpolated in L1B
+[1001]= class 4: solar zenith ge 86 degrees
+[1010]= class 5: solar zenith ge 85 and lt 86 degrees
+[1011]= class 6: missing input
+[1100] class 7: internal constant used in place of climatological data for at least one atmospheric constant
+[1101]= class 8: correction out of bounds, pixel constrained to extreme allowable value
+[1110]= class 9: L1B data faulty
+[1111]= class 10: not processed due to deep ocean or cloud
+Class 11: Combination of bits unused
+<EM>Atmospheric correction 250m/500m bit[12]/[30]</EM>
+[00]= class 1: Not Corrected product
+<EM>Adjacency correction 250m/500m bit[13][31]</EM>
+<EM>Different orbit from 500m product, 250m Unsigned Int bit[14]</EM>
+[00]= class 1: same orbit as 500m
+[01]= class 2: different orbit from 500m
+<H2>NOTES</H2>
+<H2>TODO</H2>
+Testing is required.
+<H2>SEE ALSO</H2>
+<em>
+<A HREF="i.vi.html">i.vi</A><br>
+</em>
+<H2>AUTHORS</H2>
+Yann Chemin, International Rice Research Institute, The Philippines.<BR>
+<p>
+<i>Last changed: $Date: 2008/07/28 15:33:42 $</i>
Property changes on: grass/trunk/imagery/i.qc.modis/i.qc.modis.html
