[GRASS-SVN] r33585 - in grass/trunk/scripts: db.dropcol r.regression.line v.db.dropcol v.db.droptable
Sun Sep 28 17:55:11 EDT 2008
Author: glynn
Date: 2008-09-28 17:55:11 -0400 (Sun, 28 Sep 2008)
New Revision: 33585
Added:
   grass/trunk/scripts/db.dropcol/db.dropcol.py
   grass/trunk/scripts/r.regression.line/r.regression.line.py
   grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
Convert db.dropcol, v.db.dropcol, v.db.droptable, r.regression.line to Python
Added: grass/trunk/scripts/db.dropcol/db.dropcol.py
--- grass/trunk/scripts/db.dropcol/db.dropcol.py	                        (rev 0)
+++ grass/trunk/scripts/db.dropcol/db.dropcol.py	2008-09-28 21:55:11 UTC (rev 33585)
@@ -0,0 +1,122 @@
+#!/usr/bin/env python
+# MODULE:       db.dropcolumn
+# AUTHOR(S):   	Markus Neteler
+#               Converted to Python by Glynn Clements
+# PURPOSE:      interface to db.execute to drop a column from an
+#               attribute table
+#               - with special trick for SQLite
+# COPYRIGHT:    (C) 2007 by Markus Neteler and the GRASS Development Team
+#               This program is free software under the GNU General Public
+#               License (>=v2). Read the file COPYING that comes with GRASS
+#               for details.
+#%Module
+#%  description: Drops a column from selected attribute table
+#%  keywords: database, attribute table
+#%End
+#%flag
+#%  key: f
+#%  description: Force removal (required for actual deletion of files)
+#%end
+#%option
+#% key: table
+#% type: string
+#% key_desc : name
+#% description: Table from which to drop attribute column
+#% required : yes
+#% gisprompt: old,dbtable,dbtable
+#%end
+#%option
+#% key: column
+#% type: string
+#% description: Name of the column
+#% required : yes
+#% gisprompt: old,dbcolumn,dbcolumn
+#%end
+import sys
+import os
+import string
+import grass
+def main():
+    table = options['table']
+    column = options['column']
+    force = flags['f']
+    # check if DB parameters are set, and if not set them.
+    grass.run_command('db.connect', flags = 'c')
+    s = grass.read_command('db.connect', flags = 'p')
+    kv = grass.parse_key_val(s, sep = ':')
+    database = kv['database']
+    driver = kv['driver']
+    # schema needed for PG?
+    if force:
+	grass.message("Forcing ...")
+    if column == "cat":
+	grass.warning("Deleting <%s> column which may be needed to keep table connected to a vector map" % column)
+    s = grass.read_command('db.describe', flags = 'c', table = table)
+    cols = [l.split(':')[1].lstrip() for l in s.splitlines() if l.startswith('Column ')]
+    if column not in cols:
+	grass.fatal("Column <%s> not found in table" % column)
+    if not force:
+	grass.message("Column <%s> would be deleted." % column)
+	grass.message("")
+	grass.message("You must use the force flag to actually remove it. Exiting.")
+	sys.exit(0)
+    if driver == "sqlite":
+	#echo "Using special trick for SQLite"
+	# http://www.sqlite.org/faq.html#q13
+	colnames = []
+	coldef = []
+	for l in s.splitlines():
+	    if not l.startswith('Column '):
+		continue
+	    f = l.split(':')
+	    if f[1] == column:
+		continue
+	    colnames.append(f[1])
+	    coltypes.append("%s %s" % (f[1], f[2]))
+	colnames = ", ".join(colnames)
+	coltypes = ", ".join(coltypes)
+	cmds = [
+	    "BEGIN TRANSACTION",
+	    "CREATE TEMPORARY TABLE ${table}_backup(${coldef})",
+	    "INSERT INTO ${table}_backup SELECT ${colnames} FROM ${table}",
+	    "DROP TABLE ${table}",
+	    "CREATE TABLE ${table}(${coldef})",
+	    "INSERT INTO ${table} SELECT ${colnames} FROM ${table}_backup",
+	    "DROP TABLE ${table}_backup",
+	    "COMMIT"
+	tmpl = string.Template(';\n'.join(cmds))
+	sql = tmpl.substitute(table = table, coldef = coltypes, colnames = colnames)
+    else:
+	sql = "ALTER TABLE %s DROP COLUMN %s" % (table, column)
+    if grass.write_command('db.execute', database = database, driver = driver,
+			   stdin = sql) != 0:
+	grass.fatal("Cannot continue (problem deleting column).")
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/scripts/db.dropcol/db.dropcol.py
___________________________________________________________________
Added: grass/trunk/scripts/r.regression.line/r.regression.line.py
--- grass/trunk/scripts/r.regression.line/r.regression.line.py	                        (rev 0)
+++ grass/trunk/scripts/r.regression.line/r.regression.line.py	2008-09-28 21:55:11 UTC (rev 33585)
@@ -0,0 +1,154 @@
+# MODULE:	r.regression line
+# AUTHOR(S):	Dr. Agustin Lobo - alobo at ija.csic.es
+#               Updated to GRASS 5.7 by Michael Barton
+# PURPOSE:	Calculates linear regression from two raster maps: y = a + b*x
+# COPYRIGHT:	(C) 2004 by the GRASS Development Team
+#		for details.
+#%Module
+#%  description: Calculates linear regression from two raster maps: y = a + b*x
+#%  keywords: raster, statistics
+#%End
+#%flag
+#%  key: g
+#%  description: Print in shell script style
+#%End
+#%flag
+#%  key: s
+#%  description: Slower but accurate (applies to FP maps only)
+#%End
+#%option
+#% key: map1
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Map for x coefficient
+#% required : yes
+#%end
+#%option
+#% key: map2
+#% type: string
+#% description: Map for y coefficient
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% gisprompt: new_file,file,output
+#% description: ASCII file for storing regression coefficients (output to screen if file not specified).
+#% required : no
+#%end
+import sys
+import os
+import math
+import grass
+def main():
+    shell = flags['g']
+    slow = flags['s']
+    map1 = options['map1']
+    map2 = options['map2']
+    output = options['output']
+    if not grass.find_file(map1)['name']:
+	grass.fatal("Raster map <%s> not found" % map1)
+    if not grass.find_file(map2)['name']:
+	grass.fatal("Raster map <%s> not found" % map2)
+    #calculate regression equation
+    if slow:
+	# slower but accurate
+	statsflags = 'n1'
+	#				 | sed 's+$+ 1+g' > "$TMP"
+    else:
+	# count "identical" pixels
+	statsflags = 'cnA'
+    p = grass.pipe_command('r.stats', flags = statsflags, input = (map1, map2))
+    tot = sumX = sumsqX = sumY = sumsqY = sumXY = 0.0
+    for line in p.stdout:
+	line = line.rstrip('\r\n')
+	if slow:
+	    line += ' 1'
+	f = line.split(' ')
+	if len(f) != 3:
+	    continue
+	x = float(f[0])
+	y = float(f[1])
+	n = float(f[2])
+	tot += n
+	sumX += n * x
+	sumsqX += n * x * x
+	sumY += n * y
+	sumsqY += n * y * y
+	sumXY += n * x * y
+    p.wait()
+    B = (sumXY - sumX*sumY/tot)/(sumsqX - sumX*sumX/tot)
+    R = (sumXY - sumX*sumY/tot)/math.sqrt((sumsqX - sumX*sumX/tot)*(sumsqY - sumY*sumY/tot))
+    mediaX = sumX/tot
+    sumsqX = sumsqX/tot
+    varX = sumsqX-(mediaX*mediaX)
+    sdX = math.sqrt(varX)
+    mediaY = sumY/tot
+    sumsqY = sumsqY/tot
+    varY = sumsqY-(mediaY*mediaY)
+    sdY = math.sqrt(varY)
+    A = mediaY - B*mediaX
+    F =  R*R/(1-R*R/tot-2)
+    vars = dict(
+	a = A,
+	b = B,
+	R = R,
+	N = tot,
+	F = F,
+	medX = mediaX,
+	sdX = sdX,
+	medY = mediaY,
+	sdY = sdY)
+    keys = ['a', 'b', 'R', 'N', 'F', 'medX', 'sdX', 'medY', 'sdY']
+    #send output to screen or text file
+    if output:
+	fh = file(output, 'w')
+    else:
+	fh = sys.stdout
+    if shell:
+	for k, v in vars.iteritems():
+	    fh.write('%s=%f\n' % (k, v))
+    else:
+	lines = [
+	    "y = a + b*x",
+            "   a: offset",
+            "   b: gain",
+            "   R: sumXY - sumX*sumY/tot",
+            "   N: number of elements",
+            "   medX, medY: Means",
+            "   sdX, sdY: Standard deviations",
+	    '  '.join(keys),
+	fh.write('\n'.join(lines) + '\n')
+	fh.write(' '.join([str(vars[k]) for k in keys]) + '\n')
+    main()
Property changes on: grass/trunk/scripts/r.regression.line/r.regression.line.py
Added: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
--- grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py	2008-09-28 21:55:11 UTC (rev 33585)
@@ -0,0 +1,127 @@
+# MODULE:       v.db.dropcolumn
+# PURPOSE:      interface to db.execute to drop a column from the
+#               attribute table connected to a given vector map
+#               - Based on v.db.addcol
+# COPYRIGHT:    (C) 2007 by the GRASS Development Team
+#               for details.
+#%Module
+#%  description: Drops a column from the attribute table connected to a given vector map.
+#%  keywords: vector, database, attribute table
+#%End
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc : name
+#% description: Vector map for which to drop attribute column
+#% required : yes
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer where to drop column
+#% answer: 1
+#% required : no
+#%end
+#%option
+#% key: column
+#% type: string
+#% required : yes
+#%end
+import sys
+import os
+import string
+import grass
+def main():
+    map = options['map']
+    layer = options['layer']
+    mapset = grass.gisenv()['MAPSET']
+    # does map exist in CURRENT mapset?
+    if not grass.find_file(map, element = 'vector', mapset = mapset):
+	grass.fatal("Vector map <%s> not found in current mapset" % map)
+    s = grass.read_command('v.db.connect', flags = 'g', map = map, layer = layer);
+    if not s:
+	grass.fatal("An error occured while running v.db.connect")
+    f = s.split()
+    table = f[1]
+    keycol = f[2]
+    database = f[3]
+    driver = f[4]
+    if not table:
+	grass.fatal("There is no table connected to the input vector map Cannot delete any column")
+    if column == keycol:
+	grass.fatal("Cannot delete <$col> column as it is needed to keep table <%s> connected to the input vector map <%s>" % (table, map))
+    s = grass.read_command('v.info', flags = 'c', map = map, layer = layer, quiet = True)
+    if column not in [l.split('|')[1].lstrip() for l in s.splitlines()]:
+	grass.fatal("Column <%s> not found in table <%s>" % (column, table))
+	colnames = []
+	coldef = []
+		continue
+	    f = l.split(':')
+		continue
+	cmds = [
+	    "COMMIT"
+    else:
+    # write cmd history:
+    grass.run_command('v.support', map = map, cmdhist = os.environ['CMDLINE'])
+    main()
Property changes on: grass/trunk/scripts/v.db.dropcol/v.db.dropcol.py
Added: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	                        (rev 0)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2008-09-28 21:55:11 UTC (rev 33585)
@@ -0,0 +1,107 @@
+# MODULE:       v.db.droptable
+# PURPOSE:      interface to db.execute to drop an existing table of given vector map
+# COPYRIGHT:    (C) 2005, 2008 by the GRASS Development Team
+#               for details.
+#%Module
+#%  description: Removes existing attribute table of a vector map.
+#%End
+#%flag
+#%  key: f
+#%  description: Force removal (required for actual deletion of table)
+#%end
+#%option
+#% key: map
+#% type: string
+#% description: Vector map from which to remove attribute table
+#% required : yes
+#%end
+#%option
+#% key: table
+#% type: string
+#% description: Name of existing attribute table (default: vector map name)
+#% required : no
+#%end
+#%option
+#% key: layer
+#% type: integer
+#% description: Layer from which to drop linked attribute table
+#% answer: 1
+#% required : no
+#%end
+import sys
+import os
+import grass
+def main():
+    # do some paranoia tests as well:
+    if not s:
+    f = s.split()
+    if not table:
+	# Removing table name connected to selected layer
+	table = f[1]
+	if not table:
+	    grass.fatal("No table assigned to layer <$GIS_OPT_LAYER>")
+    else:
+	# Removing user specified table
+	existingtable = f[1]
+	if existingtable != table:
+	    grass.fatal("User selected table <%s> but the table <%s> is linked to layer <%s>"
+			% (table, existingtable, layer))
+    # we use the DB settings selected layer
+    database = f[3]
+    driver = f[4]
+    grass.message("Removing table <%s> linked to layer <%s> of vector map <%s>"
+		  % (table, layer, map))
+    if not force:
+	grass.message("You must use the -f (force) flag to actually remove the table. Exiting.")
+	grass.message("Leaving map/table unchanged.")
+	sys.exit(0)
+    grass.message("Dropping table <%s>..." % table)
+    if grass.write_command('db.execute', stdin = "DROP TABLE %s" % table) != 0:
+	grass.fatal("An error occured while running db.execute")
+    grass.run_command('v.db.connect', flags = 'd', map = map, layer = layer)
+    grass.message("Current attribute table link(s):")
+    # silently test first to avoid confusing error messages
+    nuldev = file(os.devnull, 'w')
+    if grass.run_command('v.db.connect', flags ='p', map = map, quiet = True,
+			 stdout = nuldev, stderr = nuldev) != 0:
+	grass.message("(No database links remaining)")
+    else:
+	grass.run_command('v.db.connect', flags ='p', map = map)
+    main()
Property changes on: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
