[GRASS-SVN] r33605 - in grass/branches/develbranch_6: db/base display/d.grid display/d.thematic.area doc/vector/v.example general/g.mapset general/g.proj gui/wxpython/gui_modules imagery/i.ortho.photo/photo.2image imagery/i.ortho.photo/photo.2target imagery/i.points imagery/i.vpoints lib/db/dbmi_client lib/db/dbmi_driver lib/gis lib/gpde lib/ogsf lib/proj lib/sites lib/vector/Vlib lib/vector/diglib locale/templates raster/r.gwflow raster/r.le/r.le.patch raster/r.out.arc raster/r.out.gdal raster/r.to.vect scripts/d.vect.thematic scripts/r.tileset scripts/v.what.vect vector/v.clean vector/v.distance vector/v.edit vector/v.label.sa
Mon Sep 29 20:36:20 EDT 2008
Author: neteler
Date: 2008-09-29 20:36:19 -0400 (Mon, 29 Sep 2008)
New Revision: 33605
   grass/branches/develbranch_6/db/base/copy.c
   grass/branches/develbranch_6/display/d.grid/main.c
   grass/branches/develbranch_6/display/d.thematic.area/main.c
   grass/branches/develbranch_6/doc/vector/v.example/main.c
   grass/branches/develbranch_6/general/g.mapset/main.c
   grass/branches/develbranch_6/general/g.proj/datumtrans.c
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py
   grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/main.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/where.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
   grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/where.c
   grass/branches/develbranch_6/imagery/i.points/main.c
   grass/branches/develbranch_6/imagery/i.vpoints/drawvect.c
   grass/branches/develbranch_6/imagery/i.vpoints/main.c
   grass/branches/develbranch_6/imagery/i.vpoints/where.c
   grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
   grass/branches/develbranch_6/lib/db/dbmi_client/start.c
   grass/branches/develbranch_6/lib/db/dbmi_driver/driver.c
   grass/branches/develbranch_6/lib/gis/G.h
   grass/branches/develbranch_6/lib/gis/Makefile
   grass/branches/develbranch_6/lib/gis/cats.c
   grass/branches/develbranch_6/lib/gis/env.c
   grass/branches/develbranch_6/lib/gis/error.c
   grass/branches/develbranch_6/lib/gis/gdal.c
   grass/branches/develbranch_6/lib/gis/get_row.c
   grass/branches/develbranch_6/lib/gis/get_window.c
   grass/branches/develbranch_6/lib/gis/gisinit.c
   grass/branches/develbranch_6/lib/gpde/N_arrays_io.c
   grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
   grass/branches/develbranch_6/lib/proj/convert.c
   grass/branches/develbranch_6/lib/sites/sites.c
   grass/branches/develbranch_6/lib/vector/Vlib/area.c
   grass/branches/develbranch_6/lib/vector/Vlib/break_lines.c
   grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
   grass/branches/develbranch_6/lib/vector/Vlib/bridges.c
   grass/branches/develbranch_6/lib/vector/Vlib/buffer.c
   grass/branches/develbranch_6/lib/vector/Vlib/build.c
   grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
   grass/branches/develbranch_6/lib/vector/Vlib/dangles.c
   grass/branches/develbranch_6/lib/vector/Vlib/remove_duplicates.c
   grass/branches/develbranch_6/lib/vector/Vlib/snap.c
   grass/branches/develbranch_6/lib/vector/diglib/plus_struct.c
   grass/branches/develbranch_6/locale/templates/
   grass/branches/develbranch_6/raster/r.gwflow/main.c
   grass/branches/develbranch_6/raster/r.le/r.le.patch/patch.c
   grass/branches/develbranch_6/raster/r.out.arc/main.c
   grass/branches/develbranch_6/raster/r.out.gdal/main.c
   grass/branches/develbranch_6/raster/r.to.vect/main.c
   grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
   grass/branches/develbranch_6/scripts/r.tileset/r.tileset
   grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect
   grass/branches/develbranch_6/vector/v.clean/proto.h
   grass/branches/develbranch_6/vector/v.distance/main.c
   grass/branches/develbranch_6/vector/v.edit/a2b.c
   grass/branches/develbranch_6/vector/v.edit/args.c
   grass/branches/develbranch_6/vector/v.label.sa/main.c
glynn: typos fixed (merge from trunk, r33598)
Modified: grass/branches/develbranch_6/db/base/copy.c
--- grass/branches/develbranch_6/db/base/copy.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/db/base/copy.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -34,7 +34,7 @@
     module->keywords = _("database, attribute table, SQL");
     module->label = _("Copy a table.");
     module->description =
-	_("Either 'from_table' (optionaly with 'where') can be used "
+	_("Either 'from_table' (optionally with 'where') can be used "
 	  "or 'select' option, but not 'from_table' and 'select' at the same time.");
     from_driver = G_define_standard_option(G_OPT_DRIVER);
Modified: grass/branches/develbranch_6/display/d.grid/main.c
--- grass/branches/develbranch_6/display/d.grid/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/display/d.grid/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -151,7 +151,7 @@
     mark_type = MARK_GRID;
     if (cross->answer && fiducial->answer)
-	G_fatal_error(_("Chose a single mark style"));
+	G_fatal_error(_("Choose a single mark style"));
     if (cross->answer)
 	mark_type = MARK_CROSS;
     if (fiducial->answer)
Modified: grass/branches/develbranch_6/display/d.thematic.area/main.c
--- grass/branches/develbranch_6/display/d.thematic.area/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/display/d.thematic.area/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -77,7 +77,7 @@
     module = G_define_module();
     module->keywords = _("display");
-	_("Displays a thematic vector area map in the active"
+	_("Displays a thematic vector area map in the active "
 	  "frame on the graphics monitor.");
     map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/branches/develbranch_6/doc/vector/v.example/main.c
--- grass/branches/develbranch_6/doc/vector/v.example/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/doc/vector/v.example/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -164,7 +164,7 @@
 	    /* Now execute query */
 	    if (db_open_select_cursor(driver, &dbsql, &cursor, DB_SEQUENTIAL)
 		!= DB_OK)
-		G_warning(_("Unabale to get attribute data for cat %d"), cat);
+		G_warning(_("Unable to get attribute data for cat %d"), cat);
 	    else {
 		/* Result count */
 		nrows = db_get_num_rows(&cursor);
Modified: grass/branches/develbranch_6/general/g.mapset/main.c
--- grass/branches/develbranch_6/general/g.mapset/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/general/g.mapset/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -155,7 +155,7 @@
     /* Check if the mapset is in use */
     gis_lock = getenv("GIS_LOCK");
     if (!gis_lock)
-	G_fatal_error(_("Unable to read GIS_LOCK enviroment variable"));
+	G_fatal_error(_("Unable to read GIS_LOCK environment variable"));
     G_asprintf(&lock_prog, "%s/etc/lock", G_gisbase());
Modified: grass/branches/develbranch_6/general/g.proj/datumtrans.c
--- grass/branches/develbranch_6/general/g.proj/datumtrans.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/general/g.proj/datumtrans.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -94,7 +94,7 @@
 	    if (datumtrans > paramsets)
 		G_fatal_error
-		    ("Invalid tranformation number %d; valid range is 1 to %d",
+		    ("Invalid transformation number %d; valid range is 1 to %d",
 		     datumtrans, paramsets);
 	    list = GPJ_get_datum_transform_by_name(datum);
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menudata.py	2008-09-30 00:36:19 UTC (rev 33605)
@@ -1813,7 +1813,7 @@
                                 (_("Copy table"),
-                                 _("Copy a table. Either 'from_table' (optionaly with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."),
+                                 _("Copy a table. Either 'from_table' (optionally with 'where') can be used or 'select' option, but not 'from_table' and 'select' at the same time."),
                                  "self.OnMenuCmd",
                                  "db.copy"),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2008-09-30 00:36:19 UTC (rev 33605)
@@ -578,9 +578,9 @@
         gridSizer.Add(item=display, flag=wx.ALIGN_CENTER_VERTICAL,
                       pos=(0, 7))
-        # hight
+        # height
         gridSizer.Add(item=wx.StaticText(parent=panel, id=wx.ID_ANY,
-                                         label=_("Hight above surface:")),
+                                         label=_("Height above surface:")),
                       pos=(1, 0), flag=wx.ALIGN_CENTER_VERTICAL,
                       span=(1, 2))
@@ -685,7 +685,7 @@
         # high
                       span=(1, 2))
@@ -1211,7 +1211,7 @@
         # icon width
-                                         label=_("Witdh:")),
+                                         label=_("Width:")),
                       pos=(row, 2), flag=wx.ALIGN_CENTER_VERTICAL)
         iwidth = wx.SpinCtrl(parent=panel, id=wx.ID_ANY, size=(65, -1),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2008-09-30 00:36:19 UTC (rev 33605)
@@ -370,7 +370,7 @@
         # environment settings
-        # enviroment variables, like MAPSET, LOCATION_NAME, etc.
+        # environment variables, like MAPSET, LOCATION_NAME, etc.
         self.env         = {}
         # path to external gisrc
         self.gisrc = gisrc
@@ -570,7 +570,7 @@
         Get region settings (g.region -upgc)
-        Optionaly extent, raster or vector map layer can be given.
+        Optionally extent, raster or vector map layer can be given.
         @param rast raster name or None
         @param vect vector name or None
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-09-30 00:36:19 UTC (rev 33605)
@@ -413,7 +413,7 @@
         # only one dialog can be open
         self.settingsDialog   = None
-        # create toolbars (two rows optionaly)
+        # create toolbars (two rows optionally)
         self.toolbar = []
         self.numOfRows = 1 # number of rows for toolbar
         for row in range(0, self.numOfRows):
@@ -1144,7 +1144,7 @@
         Update list of available vector map layers.
         This list consists only editable layers (in the current mapset)
-        Optionaly also update toolbar
+        Optionally also update toolbar
         Debug.msg (4, "VDigitToolbar.UpdateListOfLayers(): updateTool=%d" % \
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbox.py	2008-09-30 00:36:19 UTC (rev 33605)
@@ -14,7 +14,7 @@
 </qgisgrass>
 test_modules = {"g.gisenv":"""
-<qgisgrassmodule label="GRASS enviroment variables" module="g.gisenv">
+<qgisgrassmodule label="GRASS environment variables" module="g.gisenv">
 </qgisgrassmodule>
 ""","r.to.vect.area":"""
 <qgisgrassmodule label="Convert a raster to vector areas" module="r.to.vect">
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -88,7 +88,7 @@
 	group.photo_points.count = 0;
     G_suppress_warnings(0);
-    /* determine tranformation equation */
+    /* determine transformation equation */
     Compute_equation();
     signal(SIGINT, SIG_IGN);
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/where.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/where.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2image/where.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -57,7 +57,7 @@
     sprintf(buf, "North: %10.2f", n1);
     Curses_write_window(w1, 4, 3, buf);
-    /* if tranformation equation is useable, determine point via equation */
+    /* if transformation equation is useable, determine point via equation */
     if (group.ref_equation_stat <= 0)
 	return 1;
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -134,7 +134,7 @@
 	    G_warning(msg);
-    /* get target info and enviroment */
+    /* get target info and environment */
     G_suppress_warnings(1);
     get_target();
     find_target_files();
@@ -153,7 +153,7 @@
     Compute_ref_equation();
     /* read group control points, format: image x,y,cfl; target E,N,Z */
@@ -169,7 +169,7 @@
 			 &group.control_points, group.E12, group.N12);
     fprintf(stderr, "Computing equations ...\n");
     if (group.control_points.count > 0)
 	Compute_ortho_equation();
Modified: grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/where.c
--- grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/where.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.ortho.photo/photo.2target/where.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -51,7 +51,7 @@
     sprintf(buf, "IMAGE Y: %10.2f", n1);
 	return 1;
Modified: grass/branches/develbranch_6/imagery/i.points/main.c
--- grass/branches/develbranch_6/imagery/i.points/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.points/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -103,7 +103,7 @@
     /* write group files to group list file */
     prepare_group_list();
     get_target();
@@ -113,7 +113,7 @@
 	group.points.count = 0;
     Compute_equation();
Modified: grass/branches/develbranch_6/imagery/i.vpoints/drawvect.c
--- grass/branches/develbranch_6/imagery/i.vpoints/drawvect.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.vpoints/drawvect.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -46,7 +46,7 @@
 static int drawvect(int zoomit,	/* -1 = refresh, 0 = new image, 1 = zoom, 2 = warp */
 		    View * zoom_view, double E[], double N[], int trans_order)
-{				/* order of tranformation if warping vectors */
+{				/* order of transformation if warping vectors */
     int stat = 0;
     int i;
     char name[GNAME_MAX], mapset[GMAPSET_MAX];
Modified: grass/branches/develbranch_6/imagery/i.vpoints/main.c
--- grass/branches/develbranch_6/imagery/i.vpoints/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.vpoints/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -98,7 +98,7 @@
     get_target();
@@ -108,7 +108,7 @@
     CRS_Compute_equation(1);
Modified: grass/branches/develbranch_6/imagery/i.vpoints/where.c
--- grass/branches/develbranch_6/imagery/i.vpoints/where.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/imagery/i.vpoints/where.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -54,7 +54,7 @@
     sprintf(buf, "N = %10.2f", n1);
     Curses_write_window(INFO_WINDOW, 18, 3, buf);
     if (group.equation_stat <= 0 || windnum == 2) {
 	Curses_write_window(INFO_WINDOW, 15, 18, "           ");
 	Curses_write_window(INFO_WINDOW, 17, 18, "                 ");
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/copy_tab.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -154,7 +154,7 @@
 	const char *tblname = db_get_string(&tblnames[i]);
 	if (strcmp(to_tblname, tblname) == 0) {
-	    G_warning(_("Table <%s> already existsin database <%s>"),
+	    G_warning(_("Table <%s> already exists in database <%s>"),
 		      to_dbname, to_dbname);
 	    db_close_database_shutdown_driver(to_driver);
 	    if (from_driver != to_driver)
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/start.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/start.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -56,7 +56,7 @@
     int stdin_fd, stdout_fd;
 #endif
-    /* Set some enviroment variables which are later read by driver.
+    /* Set some environment variables which are later read by driver.
      * This is necessary when application is running without GISRC file and all
      * gis variables are set by application.
      * Even if GISRC is set, application may change some variables during runtime,
@@ -82,7 +82,7 @@
     else {
 	/* Warning: GISRC_MODE_MEMORY _must_ be set to G_GISRC_MODE_FILE, because the module can be
-	 *          run from an application which previously set enviroment variable to G_GISRC_MODE_MEMORY */
+	 *          run from an application which previously set environment variable to G_GISRC_MODE_MEMORY */
 	sprintf(ebuf, "%d", G_GISRC_MODE_FILE);
 	G_putenv("GRASS_DB_DRIVER_GISRC_MODE", ebuf);
Modified: grass/branches/develbranch_6/lib/db/dbmi_driver/driver.c
--- grass/branches/develbranch_6/lib/db/dbmi_driver/driver.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/db/dbmi_driver/driver.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -44,7 +44,7 @@
     FILE *send, *recv;
     char *modestr;
-    /* Read and set enviroment variables, see dbmi_client/start.c */
+    /* Read and set environment variables, see dbmi_client/start.c */
     if ((modestr = getenv("GRASS_DB_DRIVER_GISRC_MODE"))) {
 	int mode;
Modified: grass/branches/develbranch_6/lib/gis/G.h
--- grass/branches/develbranch_6/lib/gis/G.h	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/G.h	2008-09-30 00:36:19 UTC (rev 33605)
@@ -30,6 +30,14 @@
 #endif
+#ifdef HAVE_GDAL
+extern CPLErr G_gdal_raster_IO(
+    GDALRasterBandH, GDALRWFlag,
+    int, int, int, int,
+    void *, int, int, GDALDataType,
+    int, int);
+#endif
 struct fileinfo			/* Information for opened cell files */
     int open_mode;		/* see defines below            */
Modified: grass/branches/develbranch_6/lib/gis/Makefile
--- grass/branches/develbranch_6/lib/gis/Makefile	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/Makefile	2008-09-30 00:36:19 UTC (rev 33605)
@@ -1,5 +1,8 @@
 MODULE_TOPDIR = ../..
+GDAL_LINK = $(USE_GDAL)
+GDAL_DYNAMIC = 1
 LIB_NAME = $(GIS_LIBNAME)
 EXTRA_LIBS = $(XDRLIB) $(SOCKLIB) $(DATETIMELIB) $(INTLLIB) $(MATHLIB)
 DATASRC = ellipse.table datum.table datumtransform.table FIPS.code state27 state83 projections gui.tcl
@@ -15,12 +18,23 @@
 ifneq ($(USE_LARGEFILES),)
 	EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
 endif
-ifneq ($(USE_GDAL),)
-EXTRA_CFLAGS += -DGDAL_LINK
+ifneq ($(GDAL_LINK),)
+EXTRA_CFLAGS += -DGDAL_LINK=1
 EXTRA_INC += $(PROJINC) $(GDALCFLAGS)
+ifneq ($(GDAL_DYNAMIC),)
+EXTRA_CFLAGS += -DGDAL_DYNAMIC=1
+ifneq ($(MINGW),)
+EXTRA_LIBS += -lkernel32
+else
+EXTRA_LIBS += $(DLLIB)
+endif
+else
 EXTRA_LIBS += $(GDALLIBS)
 endif
+endif
 default: lib $(FMODE_OBJ) $(DATAFILES) $(COLORFILES) $(ETC)/colors.desc $(ETC)/element_list
 $(FMODE_OBJ): fmode.dat
Modified: grass/branches/develbranch_6/lib/gis/cats.c
--- grass/branches/develbranch_6/lib/gis/cats.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/cats.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -52,7 +52,7 @@
  *       a blank line for the fmt will effectively suppress automatic
  *       label generation
- * Note: quant rules of Categories structures are heavily dependant
+ * Note: quant rules of Categories structures are heavily dependent
  * on the fact that rules are stored in the same order they are entered.
  * since i-th rule and i-th label are entered at the same time, we
  * know that i-th rule maps fp range to i, thus we know for sure
Modified: grass/branches/develbranch_6/lib/gis/env.c
--- grass/branches/develbranch_6/lib/gis/env.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/env.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -256,7 +256,7 @@
-   \brief Get enviroment variable
+   \brief Get environment variable
    Calls G_fatal_error() if name not set.
Modified: grass/branches/develbranch_6/lib/gis/error.c
--- grass/branches/develbranch_6/lib/gis/error.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/error.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -67,7 +67,7 @@
  * \brief Print a message to stderr
- * The output format depends on enviroment variable GRASS_MESSAGE_FORMAT
+ * The output format depends on environment variable GRASS_MESSAGE_FORMAT
  * \param msg string (cannot be NULL)
@@ -87,7 +87,7 @@
  * \brief Print a message to stderr but only if module is in verbose mode
- * The output format depends on enviroment variables
+ * The output format depends on environment variables
  *  GRASS_MESSAGE_FORMAT and GRASS_VERBOSE
@@ -111,7 +111,7 @@
  * Ususally just G_percent()/G_clicker() would be shown at this level.
  * This allows important non-error/warning messages to display as well.
@@ -132,7 +132,7 @@
  * \brief Print a fatal error message to stderr
  * By default, the message is handled by an internal routine which
@@ -161,7 +161,7 @@
  * \brief Print a warning message to stderr
  * A warning message can be suppressed by G_suppress_warnings()
@@ -246,7 +246,7 @@
     return 0;
-/* Print info to stderr and optionaly to log file and optionaly send mail */
+/* Print info to stderr and optionally to log file and optionally send mail */
 static int print_error(const char *msg, const int type)
     static char *prefix_std[3];
Modified: grass/branches/develbranch_6/lib/gis/gdal.c
--- grass/branches/develbranch_6/lib/gis/gdal.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/gdal.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -3,11 +3,126 @@
 #include <string.h>
 #include <grass/config.h>
 #include <grass/gis.h>
+#include <grass/glocale.h>
 #include "G.h"
+#ifndef HAVE_GDAL
+#undef GDAL_LINK
+#endif
+#ifdef GDAL_LINK
+#ifdef GDAL_DYNAMIC
+# if defined(__unix) || defined(__unix__)
+#  include <dlfcn.h>
+# endif
+# ifdef _WIN32
+#  include <windows.h>
+# endif
+#endif
+static void CPL_STDCALL (*pGDALAllRegister)(void);
+static void CPL_STDCALL (*pGDALClose)(GDALDatasetH);
+static GDALRasterBandH CPL_STDCALL (*pGDALGetRasterBand)(GDALDatasetH, int);
+static GDALDatasetH CPL_STDCALL (*pGDALOpen)(
+    const char *pszFilename, GDALAccess eAccess);
+static CPLErr CPL_STDCALL (*pGDALRasterIO)(
+    GDALRasterBandH hRBand, GDALRWFlag eRWFlag,
+    int nDSXOff, int nDSYOff, int nDSXSize, int nDSYSize,
+    void * pBuffer, int nBXSize, int nBYSize,GDALDataType eBDataType,
+    int nPixelSpace, int nLineSpace);
+#if GDAL_DYNAMIC
+# if defined(__unix) && !defined(__unix__)
+#  define __unix__ __unix
+# endif
+static void *library_h;
+static void *get_symbol(const char *name)
+    void *sym;
+# ifdef __unix__
+    sym = dlsym(library_h, name);
+# endif
+# ifdef _WIN32
+    sym = GetProcAddress((HINSTANCE) library_h, name);
+# endif
+    if (!sym)
+	G_fatal_error(_("Unable to locate symbol <%s>"), name);
+    return sym;
+static void try_load_library(const char *name)
+# ifdef __unix__
+    library_h = dlopen(name, RTLD_NOW);
+# endif
+# ifdef _WIN32
+    library_h = LoadLibrary(name);
+# endif
+static void load_library(void)
+    static const char * const candidates[] = {
+# ifdef __unix__
+	"libgdal.1.1.so",
+	"gdal.1.0.so",
+	"gdal.so.1.0",
+	"libgdal.so.1",
+	"libgdal.so",
+# endif
+# ifdef _WIN32
+	"gdal11.dll",
+	"gdal.1.0.dll",
+	"gdal.dll",
+# endif
+	NULL
+    int i;
+    for (i = 0; candidates[i]; i++) {
+	try_load_library(candidates[i]);
+	if (library_h)
+	    return;
+    G_fatal_error(_("Unable to load GDAL library"));
+static void init_gdal(void)
+    load_library();
+    pGDALAllRegister   = get_symbol("GDALAllRegister");
+    pGDALOpen          = get_symbol("GDALOpen");
+    pGDALClose         = get_symbol("GDALClose");
+    pGDALGetRasterBand = get_symbol("GDALGetRasterBand");
+    pGDALRasterIO      = get_symbol("GDALRasterIO");
+#else /* GDAL_DYNAMIC */
+    pGDALAllRegister   = &GDALAllRegister;
+    pGDALOpen          = &GDALOpen;
+    pGDALClose         = &GDALClose;
+    pGDALGetRasterBand = &GDALGetRasterBand;
+    pGDALRasterIO      = &GDALRasterIO;
+#endif /* GDAL_DYNAMIC */
+#endif /* GDAL_LINK */
 struct GDAL_link *G_get_gdal_link(const char *name, const char *mapset)
-#ifdef HAVE_GDAL
+#ifdef GDAL_LINK
     static int initialized;
     GDALDatasetH data;
     GDALRasterBandH band;
@@ -58,7 +173,7 @@
     else
 	null_val = atof(p);
-#ifdef HAVE_GDAL
+#ifdef GDAL_LINK
     p = G_find_key_value("type", key_val);
     if (!p)
 	return NULL;
@@ -86,17 +201,18 @@
 	return NULL;
     if (!initialized) {
-	GDALAllRegister();
+	init_gdal();
+	(*pGDALAllRegister)();
 	initialized = 1;
-    data = GDALOpen(filename, GA_ReadOnly);
+    data = (*pGDALOpen)(filename, GA_ReadOnly);
     if (!data)
 	return NULL;
-    band = GDALGetRasterBand(data, band_num);
+    band = (*pGDALGetRasterBand)(data, band_num);
     if (!band) {
-	GDALClose(data);
+	(*pGDALClose)(data);
 	return NULL;
 #endif
@@ -106,7 +222,7 @@
     gdal->filename = G_store(filename);
     gdal->band_num = band_num;
     gdal->null_val = null_val;
-#ifdef HAVE_GDAL
+#ifdef GDAL_LINK
     gdal->data = data;
     gdal->band = band;
     gdal->type = type;
@@ -117,9 +233,23 @@
 void G_close_gdal_link(struct GDAL_link *gdal)
-#ifdef HAVE_GDAL
-    GDALClose(gdal->data);
+#ifdef GDAL_LINK
+    (*pGDALClose)(gdal->data);
 #endif
     G_free(gdal->filename);
     G_free(gdal);
+#ifdef GDAL_LINK
+CPLErr G_gdal_raster_IO(
+    GDALRasterBandH band, GDALRWFlag rw_flag,
+    int x_off, int y_off, int x_size, int y_size,
+    void *buffer, int buf_x_size, int buf_y_size, GDALDataType buf_type,
+    int pixel_size, int line_size)
+    return (*pGDALRasterIO)(
+	band, rw_flag, x_off, y_off, x_size, y_size,
+	buffer, buf_x_size, buf_y_size, buf_type,
+	pixel_size, line_size);
+#endif
Modified: grass/branches/develbranch_6/lib/gis/get_row.c
--- grass/branches/develbranch_6/lib/gis/get_row.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/get_row.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -206,7 +206,7 @@
     *nbytes = fcb->nbytes;
-    err = GDALRasterIO(
+    err = G_gdal_raster_IO(
 	fcb->gdal->band, GF_Read, 0, row, fcb->cellhd.cols, 1, data_buf,
 	fcb->cellhd.cols, 1, fcb->gdal->type, 0, 0);
Modified: grass/branches/develbranch_6/lib/gis/get_window.c
--- grass/branches/develbranch_6/lib/gis/get_window.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/get_window.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -50,7 +50,7 @@
     static struct Cell_head dbwindow;
     char *regvar;
-    /* Optionaly read the region from enviroment variable */
+    /* Optionally read the region from environment variable */
     regvar = getenv("GRASS_REGION");
     if (regvar) {
Modified: grass/branches/develbranch_6/lib/gis/gisinit.c
--- grass/branches/develbranch_6/lib/gis/gisinit.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gis/gisinit.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -135,7 +135,7 @@
     /* Set masking flag unknown */
     G__.auto_mask = -1;
-    /* set architecture dependant bit patterns for embeded null vals */
+    /* set architecture dependent bit patterns for embeded null vals */
     G__init_null_patterns();
     initialized = 1;
Modified: grass/branches/develbranch_6/lib/gpde/N_arrays_io.c
--- grass/branches/develbranch_6/lib/gpde/N_arrays_io.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/gpde/N_arrays_io.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -224,17 +224,17 @@
 	if (type == CELL_TYPE)
 	    if (!G_put_c_raster_row(map, rast)) {
 		G_unopen_cell(map);	/*unopen the new raster map */
-		G_fatal_error(_("Unable to write rast row %i"), y);
+		G_fatal_error(_("Unable to write raster row %i"), y);
 	if (type == FCELL_TYPE)
 	    if (!G_put_f_raster_row(map, frast)) {
 	if (type == DCELL_TYPE)
 	    if (!G_put_d_raster_row(map, drast)) {
Modified: grass/branches/develbranch_6/lib/ogsf/gsd_legend.c
--- grass/branches/develbranch_6/lib/ogsf/gsd_legend.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/ogsf/gsd_legend.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -520,7 +520,7 @@
 		    G_get_color((CELL) tdcell, &red, &green, &blue, &colors);
 		RGB_TO_INT(red, green, blue, colr);
-		if (discrete) {	/* draw black-white-black seperator */
+		if (discrete) {	/* draw black-white-black separator */
 		    if (k > 0) {
 			*dv1 -= 2. * incr;
 			*dv2 -= 2. * incr;
Modified: grass/branches/develbranch_6/lib/proj/convert.c
--- grass/branches/develbranch_6/lib/proj/convert.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/proj/convert.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -437,7 +437,7 @@
 				   "You may want to look into this."), datum);
 		    else if (datumtrans > paramsets) {
-			G_warning(_("Invalid tranformation number %d; valid range is 1 to %d. "
+			G_warning(_("Invalid transformation number %d; valid range is 1 to %d. "
 				   "Leaving datum transform parameters unspecified."),
 			datumtrans = 0;
Modified: grass/branches/develbranch_6/lib/sites/sites.c
--- grass/branches/develbranch_6/lib/sites/sites.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/sites/sites.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -1093,7 +1093,7 @@
 char *G_site_format(const Site * s, const char *fs, int id)
-/* sprintf analog to G_site_put with the addition of a field seperator fs
+/* sprintf analog to G_site_put with the addition of a field separator fs
    and option of printing site attribute identifiers
Modified: grass/branches/develbranch_6/lib/vector/Vlib/area.c
--- grass/branches/develbranch_6/lib/vector/Vlib/area.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/area.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -50,7 +50,7 @@
     Area = Plus->Area[area];
     if (Area == NULL) {		/* dead area */
-	G_warning(_("Attempt to read points of nonexisting area"));
+	G_warning(_("Attempt to read points of nonexistent area"));
 	return -1;		/* error , because we should not read dead areas */
Modified: grass/branches/develbranch_6/lib/vector/Vlib/break_lines.c
--- grass/branches/develbranch_6/lib/vector/Vlib/break_lines.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/break_lines.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -46,7 +46,7 @@
    \brief Break selected lines in vector map at each intersection.
    Breaks selected lines specified by type in vector map. Points at
-   intersections may be optionaly written to error map. Input vector map
+   intersections may be optionally written to error map. Input vector map
    must be opened on level 2 for update at least on GV_BUILD_BASE.
    The function also breaks lines forming collapsed loop, for example
Modified: grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c
--- grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/break_polygons.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -44,7 +44,7 @@
    \brief Break polygons in vector map.
-   Breaks lines specified by type in vector map. Points at intersections may be optionaly
+   Breaks lines specified by type in vector map. Points at intersections may be optionally
    written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
    Function is optimized for closed polygons rigs (e.g. imported from OGR) but with clean geometry -
Modified: grass/branches/develbranch_6/lib/vector/Vlib/bridges.c
--- grass/branches/develbranch_6/lib/vector/Vlib/bridges.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/bridges.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -32,7 +32,7 @@
    Remove bridges (type boundary) connecting areas to islands or 2 islands.
    Islands and areas must be already clean, i.e. without dangles.
    Bridge may be formed by more lines.
-   Optionaly deleted bridges are written to error map.
+   Optionally deleted bridges are written to error map.
    Input map must be opened on level 2 for update at least on level GV_BUILD_BASE
    \param Map input map where bridges are deleted
@@ -54,7 +54,7 @@
    Change the type of bridges (type boundary) connecting areas to islands or 2 islands.
-   Optionaly changed bridges are written to error map.
+   Optionally changed bridges are written to error map.
    Input map must be opened on level 2 for update at least on level GV_BUILD_BASE.
    \param Map input map where bridges are changed
Modified: grass/branches/develbranch_6/lib/vector/Vlib/buffer.c
--- grass/branches/develbranch_6/lib/vector/Vlib/buffer.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/buffer.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -117,7 +117,7 @@
 /* clean_parallel - clean parallel line created by parallel_line:
  ** - looking for loops and if loop doesn't contain any other loop
  **   and centroid of loop is in buffer removes this loop (repeated)
- ** - optionaly removes all end points in buffer
+ ** - optionally removes all end points in buffer
  *    parameters:
  *      Points - parallel line
  *      origPoints - original line
Modified: grass/branches/develbranch_6/lib/vector/Vlib/build.c
--- grass/branches/develbranch_6/lib/vector/Vlib/build.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/build.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -93,7 +93,7 @@
    Should only be used in special cases of vector processing.
-   This functions optionaly builds only some parts of topology. Highest level is specified by build
+   This functions optionally builds only some parts of topology. Highest level is specified by build
    parameter which may be:
    - GV_BUILD_NONE - nothing is build;
    - GV_BUILD_BASE - basic topology, nodes, spatial index;
Modified: grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c
--- grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/build_nat.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -148,7 +148,7 @@
     plus = &(Map->plus);
     if (plus->Isle[isle] == NULL) {
-	G_warning(_("Request to find area outside nonexisting isle"));
+	G_warning(_("Request to find area outside nonexistent isle"));
 	return 0;
Modified: grass/branches/develbranch_6/lib/vector/Vlib/dangles.c
--- grass/branches/develbranch_6/lib/vector/Vlib/dangles.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/dangles.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -39,7 +39,7 @@
    such string of lines is taken as one dangle and either deleted are
    all parts or nothing.
-   Optionaly deleted dangles are written to error map.
+   Optionally deleted dangles are written to error map.
    Input map must be opened on level 2 for update.
@@ -67,7 +67,7 @@
    no other boundary.  If a dangle is formed by more boundaries, such
    string of boundaries is taken as one dangle.
@@ -114,9 +114,9 @@
    Line is considered to be a dangle if on at least one end node is no
    other line of given type(s). If a dangle is formed by more lines,
-   all parts or nothing.  Optionaly, if chtype is set to 1, only
+   all parts or nothing.  Optionally, if chtype is set to 1, only
    GV_BOUNDARY are checked for dangles, and if dangle is found lines
-   are not deleted but rewritten with type GVLINE.  Optionaly deleted
+   are not deleted but rewritten with type GVLINE.  Optionally deleted
    dangles are written to error map.  Input map must be opened on level
Modified: grass/branches/develbranch_6/lib/vector/Vlib/remove_duplicates.c
--- grass/branches/develbranch_6/lib/vector/Vlib/remove_duplicates.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/remove_duplicates.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -25,7 +25,7 @@
    \brief Remove duplicate lines from vector map.
-   Remove duplicate lines of given types from vector map. Duplicate lines may be optionaly
+   Remove duplicate lines of given types from vector map. Duplicate lines may be optionally
    written to error map. Input map must be opened on level 2 for update. Categories are merged.
    \param Map vector map where duplicate lines will be deleted
Modified: grass/branches/develbranch_6/lib/vector/Vlib/snap.c
--- grass/branches/develbranch_6/lib/vector/Vlib/snap.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/Vlib/snap.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -54,7 +54,7 @@
  * \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
- * Lines showing how vertices were snapped may be optionaly written to error map.
+ * Lines showing how vertices were snapped may be optionally written to error map.
  * Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
  * \param[in] Map input map where vertices will be snapped
Modified: grass/branches/develbranch_6/lib/vector/diglib/plus_struct.c
--- grass/branches/develbranch_6/lib/vector/diglib/plus_struct.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/lib/vector/diglib/plus_struct.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -25,7 +25,7 @@
  * if you dont want it written out, then dont call these routines
  * ie  check for deleted status before calling a write routine
  * in as much as it would be nice to hide that code in here,
- * this is a library routine and we chose to make it dependant on
+ * this is a library routine and we chose to make it dependent on
  * as few external files as possible
Property changes on: grass/branches/develbranch_6/locale/templates
___________________________________________________________________
   + *.pot
Modified: grass/branches/develbranch_6/raster/r.gwflow/main.c
--- grass/branches/develbranch_6/raster/r.gwflow/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/raster/r.gwflow/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -147,7 +147,7 @@
     param.river_bed->type = TYPE_STRING;
     param.river_bed->required = NO;
     param.river_bed->gisprompt = "old,raster,raster";
-    param.river_bed->description = _("The hight of the river bed in [m]");
+    param.river_bed->description = _("The height of the river bed in [m]");
     param.river_head = G_define_option();
     param.river_head->key = "river_head";
@@ -170,7 +170,7 @@
     param.drain_bed->type = TYPE_STRING;
     param.drain_bed->required = NO;
     param.drain_bed->gisprompt = "old,raster,raster";
-    param.drain_bed->description = _("The hight of the drainage bed in [m]");
+    param.drain_bed->description = _("The height of the drainage bed in [m]");
     param.drain_leak = G_define_option();
     param.drain_leak->key = "drain_leak";
Modified: grass/branches/develbranch_6/raster/r.le/r.le.patch/patch.c
--- grass/branches/develbranch_6/raster/r.le/r.le.patch/patch.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/raster/r.le/r.le.patch/patch.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -1594,7 +1594,7 @@
     /*Variables
        EXTERNAL
-       recl_count = an array containg the number of elements in each
+       recl_count = an array containing the number of elements in each
        row of the reclass table
        IN
        att     = the attribute value
Modified: grass/branches/develbranch_6/raster/r.out.arc/main.c
--- grass/branches/develbranch_6/raster/r.out.arc/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/raster/r.out.arc/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -87,7 +87,7 @@
     flag.noheader->key = 'h';
     flag.noheader->description = _("Suppress printing of header information");
-    /* Added to optionaly produce a single line output.     -- emes -- 12.10.92 */
+    /* Added to optionally produce a single line output.     -- emes -- 12.10.92 */
     flag.singleline = G_define_flag();
     flag.singleline->key = '1';
     flag.singleline->description =
Modified: grass/branches/develbranch_6/raster/r.out.gdal/main.c
--- grass/branches/develbranch_6/raster/r.out.gdal/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/raster/r.out.gdal/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -336,12 +336,12 @@
     if (n_nulls > 0) {
 	if (maptype == CELL_TYPE)
-	    G_warning(_("Input raster map constains cells with NULL-value (no-data). "
+	    G_warning(_("Input raster map contains cells with NULL-value (no-data). "
 		       "The value %d was used to represent no-data values in the input map."
 		       "You can specify nodata value by %s parameter."),
 		      (int)nodataval, nodatakey);
 	else
 		       "The value %g was used to represent no-data values in the input map."
Modified: grass/branches/develbranch_6/raster/r.to.vect/main.c
--- grass/branches/develbranch_6/raster/r.to.vect/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/raster/r.to.vect/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -235,7 +235,7 @@
 	Vect_build(&Map, stderr);
-    /* insert cats and optionaly labels if raster cats were used */
+    /* insert cats and optionally labels if raster cats were used */
     if (driver && value_flag) {
 	char buf[1000];
 	int c, i, cat, fidx, ncats, lastcat, tp, id;
Modified: grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic
--- grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/scripts/d.vect.thematic/d.vect.thematic	2008-09-30 00:36:19 UTC (rev 33605)
@@ -17,7 +17,7 @@
 #%Module
-#%  description: Displays thematic vectormap
+#%  description: Displays thematic vector map
 #%  keywords: display, legend
 #%End
 #%option
Modified: grass/branches/develbranch_6/scripts/r.tileset/r.tileset
--- grass/branches/develbranch_6/scripts/r.tileset/r.tileset	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/scripts/r.tileset/r.tileset	2008-09-30 00:36:19 UTC (rev 33605)
@@ -107,7 +107,7 @@
 #%option
 #% key: fs
 #% type: string
-#% description: Output field seperator
+#% description: Output field separator
 #% answer:|
 #%end
 #%option
Modified: grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect
--- grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/scripts/v.what.vect/v.what.vect	2008-09-30 00:36:19 UTC (rev 33605)
@@ -51,7 +51,7 @@
 #%option
 #% key: qlayer
 #% type: integer
-#% description: Layer of the query vector containg data
+#% description: Layer of the query vector containing data
 #% answer: 1
 #% required : no
 #%end
Modified: grass/branches/develbranch_6/vector/v.clean/proto.h
--- grass/branches/develbranch_6/vector/v.clean/proto.h	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/vector/v.clean/proto.h	2008-09-30 00:36:19 UTC (rev 33605)
@@ -10,7 +10,7 @@
 #define TOOL_PRUNE   10		/* remove vertices in threshold from lines and boundaries */
 #define TOOL_RMAREA  11		/* remove small areas */
 #define TOOL_RMSA    12		/* remove small angles between lines at nodes */
-#define TOOL_RMLINE  13		/* remove all line or boudaries of zero length */
+#define TOOL_RMLINE  13		/* remove all line or boundaries of zero length */
 #define SEP \
Modified: grass/branches/develbranch_6/vector/v.distance/main.c
--- grass/branches/develbranch_6/vector/v.distance/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/vector/v.distance/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -435,7 +435,7 @@
 		     && (fctype == DB_C_TYPE_STRING ||
 			 fctype == DB_C_TYPE_DATETIME))
-		    G_fatal_error(_("Incomatible column types"));
+		    G_fatal_error(_("Incompatible column types"));
Modified: grass/branches/develbranch_6/vector/v.edit/a2b.c
--- grass/branches/develbranch_6/vector/v.edit/a2b.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/vector/v.edit/a2b.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -274,7 +274,7 @@
-   \brief Close lines (boudaries)
+   \brief Close lines (boundaries)
    Using threshold distance (-1 for no limit)
Modified: grass/branches/develbranch_6/vector/v.edit/args.c
--- grass/branches/develbranch_6/vector/v.edit/args.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/vector/v.edit/args.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -170,7 +170,7 @@
 	_("For 'shorter' use negative threshold value, "
 	  "positive value for 'longer'");
     params->query->descriptions =
-	_("length;Select only lines or boudaries shorter"
+	_("length;Select only lines or boundaries shorter"
 	  "/longer than threshold distance;"
 	  "dangle;Select dangles shorter/longer than " "threshold distance");
     params->query->guisection = _("Query");
Modified: grass/branches/develbranch_6/vector/v.label.sa/main.c
--- grass/branches/develbranch_6/vector/v.label.sa/main.c	2008-09-29 23:50:04 UTC (rev 33604)
+++ grass/branches/develbranch_6/vector/v.label.sa/main.c	2008-09-30 00:36:19 UTC (rev 33605)
@@ -177,7 +177,7 @@
     p->hlcolor = G_define_option();
     p->hlcolor->key = "hcolor";
-    p->hlcolor->description = _("Hilight color for text");
+    p->hlcolor->description = _("Highlight color for text");
     p->hlcolor->type = TYPE_STRING;
     p->hlcolor->answer = "none";
     p->hlcolor->options =
