[GRASS-SVN] r33613 - grass/trunk/imagery/i.vi
Tue Sep 30 06:19:18 EDT 2008
Author: martinl
Date: 2008-09-30 06:19:18 -0400 (Tue, 30 Sep 2008)
New Revision: 33613
   grass/trunk/imagery/i.vi/i.vi.html
   grass/trunk/imagery/i.vi/main.c
i.vi: follow GRASS coding style
	* use descriptions
	* don't use _() macro for key, etc.
	* use standardized messages only, see http://grass.osgeo.org/wiki/Development_Specs
	* manual page updated
Please update missing vi description...
Modified: grass/trunk/imagery/i.vi/i.vi.html
--- grass/trunk/imagery/i.vi/i.vi.html	2008-09-30 09:28:58 UTC (rev 33612)
+++ grass/trunk/imagery/i.vi/i.vi.html	2008-09-30 10:19:18 UTC (rev 33613)
@@ -1,21 +1,25 @@
 <H2>DESCRIPTION</H2>
-<EM>i.vi</EM> calculates vegetation indices based on biophysical parameters.
+<EM>i.vi</EM> calculates vegetation indices based on biophysical
+parameters.
-1. RVI: ratio vegetation index:
-2. NDVI: Normalized Difference Vegetation Index
-3: IPVI: Infrared Percentage Vegetation Index
-4: DVI: Difference Vegetation Index
-5: PVI: Perpendicular Vegetation Index
-6: WDVI: Weighted Difference Vegetation Index
-7: SAVI: Soil Adjusted Vegetation Index
-8: GARI: Green atmospherically resistant vegetation index
-9: MSAVI: Modified Soil Adjusted Vegetation Index
-10:MSAVI2: second Modified Soil Adjusted Vegetation Index
-11:GEMI: Global Environmental Monitoring Index
-12:ARVI: atmospherically resistant vegetation indices
-13:GVI: Green Vegetation Index
+<ul>
+  <li>RVI: ratio vegetation index</li>
+  <li>NDVI: Normalized Difference Vegetation Index</li>
+  <li>IPVI: Infrared Percentage Vegetation Index</li>
+  <li>DVI: Difference Vegetation Index</li>
+  <li>PVI: Perpendicular Vegetation Index</li>
+  <li>WDVI: Weighted Difference Vegetation Index</li>
+  <li>SAVI: Soil Adjusted Vegetation Index</li>
+  <li>GARI: Green atmospherically resistant vegetation index</li>
+  <li>MSAVI: Modified Soil Adjusted Vegetation Index</li>
+  <li>MSAVI2: second Modified Soil Adjusted Vegetation Index</li>
+  <li>GEMI: Global Environmental Monitoring Index</li>
+  <li>ARVI: atmospherically resistant vegetation indices</li>
+  <li>GVI: Green Vegetation Index</li>
+</ul>
+<pre>
 NDVI
 Data Type Band Numbers ([IR, Red])
 TM Bands= [4,3]
@@ -26,9 +30,11 @@
 (AVHRR) NDVI = (channel 2 - channel 1) / (channel 2 + channel 1)
+</pre>
+<H2>NOTES</H2>
-<H2>NOTES</H2>
+<pre>
 Originally from kepler.gps.caltech.edu
 A FAQ on Vegetation in Remote Sensing
 Written by Terrill W. Ray
@@ -40,21 +46,18 @@
 	     Caltech
 	     Mail Code 170-25
 	     Pasadena, CA  91125
+</pre>
-<H2>TODO</H2>
 <H2>SEE ALSO</H2>
 <em>
-<A HREF="i.albedo.html">i.albedo</A><br>
+  <a href="i.albedo.html">i.albedo</a>
 </em>
 <H2>AUTHORS</H2>
-Baburao Kamble, Asian Institute of Technology, Thailand<BR>
-Yann Chemin, Asian Institute of Technology, Thailand<BR>
+Baburao Kamble, Asian Institute of Technology, Thailand<br>
+Yann Chemin, Asian Institute of Technology, Thailand<br>
 <p>
 <i>Last changed: $Date: 2006/10/09 21:30:42 $</i>
Modified: grass/trunk/imagery/i.vi/main.c
--- grass/trunk/imagery/i.vi/main.c	2008-09-30 09:28:58 UTC (rev 33612)
+++ grass/trunk/imagery/i.vi/main.c	2008-09-30 10:19:18 UTC (rev 33613)
@@ -72,56 +72,75 @@
     G_gisinit(argv[0]);
     module = G_define_module();
-    module->keywords = _("vegetation index, biophysical parameters");
-    module->description =
-	_("14 types of vegetation indices from red and nir, and only some requiring additional bands");
+    module->keywords = _("imagery, vegetation index, biophysical parameters");
+    module->label =
+	_("Calculates different types of vegetation indices.");
+    module->description = _("Uses red and nir, "
+			    "and only some requiring additional bands.");
     /* Define the different options */
     input1 = G_define_option();
     input1->key = _("viname");
     input1->type = TYPE_STRING;
     input1->required = YES;
-    input1->gisprompt = _("Name of VI");
-    input1->description =
-	_("Name of VI: sr,ndvi,ipvi,dvi,evi,pvi,wdvi,savi,msavi,msavi2,gemi,arvi,gvi,gari.");
+    input1->description = _("Name of vegetation index");
+    input1->descriptions =_("sr;???"
+			    "ndvi;Normalized Difference Vegetation Index;"
+			    "ipvi;Infrared Percentage Vegetation Index;"
+			    "dvi;Difference Vegetation Index;"
+			    "evi;???"
+			    "pvi;Perpendicular Vegetation Index;"
+			    "wdvi;Weighted Difference Vegetation Index;"
+			    "savi;Soil Adjusted Vegetation Index;"
+			    "msavi;Modified Soil Adjusted Vegetation Index;"
+			    "msavi2;second Modified Soil Adjusted Vegetation Index;"
+			    "gemi;Global Environmental Monitoring Index;"
+			    "arvi;Atmospherically Resistant Vegetation Indices;"
+			    "gvi;Green Vegetation Index;"
+			    "gari;Green atmospherically resistant vegetation index;");
+    input1->answer = "ndvi";
-    input1->answer = _("ndvi");
     input2 = G_define_standard_option(G_OPT_R_INPUT);
-    input2->key = _("red");
-    input2->description =
-	_("Name of the RED Channel surface reflectance map [0.0;1.0]");
+    input2->key = "red";
+    input2->label =
+	_("Name of the red channel surface reflectance map");
+    input2->description = _("Range: [0.0;1.0]");
     input3 = G_define_standard_option(G_OPT_R_INPUT);
-    input3->key = _("nir");
-    input3->description =
-	_("Name of the NIR Channel surface reflectance map [0.0;1.0]");
+    input3->key = "nir";
+    input3->label =
+	_("Name of the nir channel surface reflectance map");
+    input3->description = _("Range: [0.0;1.0]");
     input4 = G_define_standard_option(G_OPT_R_INPUT);
-    input4->key = _("green");
+    input4->key = "green";
     input4->required = NO;
-    input4->description =
-	_("Name of the GREEN Channel surface reflectance map [0.0;1.0]");
+    input4->label =
+	_("Name of the green channel surface reflectance map");
+    input4->description = _("Range: [0.0;1.0]");
     input5 = G_define_standard_option(G_OPT_R_INPUT);
-    input5->key = _("blue");
+    input5->key = "blue";
     input5->required = NO;
-    input5->description =
-	_("Name of the BLUE Channel surface reflectance map [0.0;1.0]");
+    input5->label =
+	_("Name of the blue channel surface reflectance map");
+    input5->description = _("Range: [0.0;1.0]");
     input6 = G_define_standard_option(G_OPT_R_INPUT);
-    input6->key = _("chan5");
+    input6->key = "chan5";
     input6->required = NO;
-    input6->description =
-	_("Name of the CHAN5 Channel surface reflectance map [0.0;1.0]");
+    input6->label =
+	_("Name of the chan5 channel surface reflectance map");
+    input6->description = _("Range: [0.0;1.0]");
     input7 = G_define_standard_option(G_OPT_R_INPUT);
-    input7->key = _("chan7");
+    input7->key = "chan7";
     input7->required = NO;
-    input7->description =
-	_("Name of the CHAN7 Channel surface reflectance map [0.0;1.0]");
+    input7->label =
+	_("Name of the chan7 channel surface reflectance map");
+    input7->description = _("Range: [0.0;1.0]");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
-    output->description = _("Name of the output vi layer");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -136,34 +155,34 @@
     result = output->answer;
     if ((infd_redchan = G_open_cell_old(redchan, "")) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), redchan);
+	G_fatal_error(_("Unable to open raster map <%s>"), redchan);
     inrast_redchan = G_allocate_d_raster_buf();
     if ((infd_nirchan = G_open_cell_old(nirchan, "")) < 0)
-	G_fatal_error(_("Cannot open cell file [%s]"), nirchan);
+	G_fatal_error(_("Unable to open raster map <%s>"), nirchan);
     inrast_nirchan = G_allocate_d_raster_buf();
     if (greenchan) {
 	if ((infd_greenchan = G_open_cell_old(greenchan, "")) < 0)
-	    G_fatal_error(_("Cannot open cell file [%s]"), greenchan);
+	    G_fatal_error(_("Unable to open raster map <%s>"), greenchan);
 	inrast_greenchan = G_allocate_d_raster_buf();
     if (bluechan) {
 	if ((infd_bluechan = G_open_cell_old(bluechan, "")) < 0)
-	    G_fatal_error(_("Cannot open cell file [%s]"), bluechan);
+	    G_fatal_error(_("Unable to open raster map <%s>"), bluechan);
 	inrast_bluechan = G_allocate_d_raster_buf();
     if (chan5chan) {
 	if ((infd_chan5chan = G_open_cell_old(chan5chan, "")) < 0)
-	    G_fatal_error(_("Cannot open cell file [%s]"), chan5chan);
+	    G_fatal_error(_("Unable to open raster map <%s>"), chan5chan);
 	inrast_chan5chan = G_allocate_d_raster_buf();
     if (chan7chan) {
 	if ((infd_chan7chan = G_open_cell_old(chan7chan, "")) < 0)
-	    G_fatal_error(_("Cannot open cell file [%s]"), chan7chan);
+	    G_fatal_error(_("Unable to open raster map <%s>"), chan7chan);
 	inrast_chan7chan = G_allocate_d_raster_buf();
@@ -173,12 +192,11 @@
     /* Create New raster files */
     if ((outfd = G_open_raster_new(result, DCELL_TYPE)) < 0)
-	G_fatal_error(_("Could not open <%s>"), result);
+	G_fatal_error(_("Unable to create raster map <%s>"), result);
     /* Process pixels */
     for (row = 0; row < nrows; row++)
-	DCELL d;
 	DCELL d_bluechan;
 	DCELL d_greenchan;
 	DCELL d_redchan;
@@ -189,24 +207,30 @@
 	G_percent(row, nrows, 2);
 	if (G_get_d_raster_row(infd_redchan, inrast_redchan, row) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), redchan);
+	    G_fatal_error(_("Unable to read raster map <%s> row %d"),
+			  redchan, row);
 	if (G_get_d_raster_row(infd_nirchan, inrast_nirchan, row) < 0)
-	    G_fatal_error(_("Could not read from <%s>"), nirchan);
+			  nirchan, row);
 	if (greenchan) {
 	    if (G_get_d_raster_row(infd_greenchan, inrast_greenchan, row) < 0)
-		G_fatal_error(_("Could not read from <%s>"), greenchan);
+			      greenchan, row);
 	if (bluechan) {
 	    if (G_get_d_raster_row(infd_bluechan, inrast_bluechan, row) < 0)
-		G_fatal_error(_("Could not read from <%s>"), bluechan);
+			      bluechan, row);
 	if (chan5chan) {
 	    if (G_get_d_raster_row(infd_chan5chan, inrast_chan5chan, row) < 0)
-		G_fatal_error(_("Could not read from <%s>"), chan5chan);
+			      chan5chan, row);
 	if (chan7chan) {
 	    if (G_get_d_raster_row(infd_chan7chan, inrast_chan7chan, row) < 0)
-		G_fatal_error(_("Could not read from <%s>"), chan7chan);
+			      chan7chan, row);
 	/* process the data */
@@ -279,7 +303,8 @@
 	if (G_put_d_raster_row(outfd, outrast) < 0)
-	    G_fatal_error(_("Cannot write to output raster file"));
+	    G_fatal_error(_("Failed writing raster map <%s> row %d"),
+			  result, row);
     G_free(inrast_redchan);
@@ -312,6 +337,7 @@
     G_short_history(result, "raster", &history);
     G_command_history(&history);
     G_write_history(result, &history);
     exit(EXIT_SUCCESS);
