[GRASS-SVN] r36577 - grass/branches/develbranch_6/db/drivers/dbf
Fri Apr 3 04:07:48 EDT 2009
Author: neteler
Date: 2009-04-03 04:07:48 -0400 (Fri, 03 Apr 2009)
New Revision: 36577
   grass/branches/develbranch_6/db/drivers/dbf/grass-dbf.html
+ORDER BY
Modified: grass/branches/develbranch_6/db/drivers/dbf/grass-dbf.html
--- grass/branches/develbranch_6/db/drivers/dbf/grass-dbf.html	2009-04-03 08:03:34 UTC (rev 36576)
+++ grass/branches/develbranch_6/db/drivers/dbf/grass-dbf.html	2009-04-03 08:07:48 UTC (rev 36577)
@@ -44,6 +44,7 @@
   DROP TABLE table
   SELECT columns FROM table
   SELECT columns FROM table WHERE condition
+  SELECT columns FROM table ORDER BY column
   DELETE FROM table
   DELETE FROM table WHERE condition
   INSERT INTO table VALUES (value1[,value2,...])
@@ -80,6 +81,8 @@
 <p> NULLs can be tested by 'colname IS NULL' in conditions. The negation is 'colname NOT NULL'.</p>
+<p> Sorting: Empty fields in a character column are sorted to the end.</p>
 <h2>ERROR MESSAGES</h2>
 An error message such as:
