[GRASS-SVN] r36580 - grass/branches/releasebranch_6_3/db/drivers/dbf
Fri Apr 3 04:13:15 EDT 2009
Author: neteler
Date: 2009-04-03 04:13:15 -0400 (Fri, 03 Apr 2009)
New Revision: 36580
   grass/branches/releasebranch_6_3/db/drivers/dbf/dbfexe.c
mlennert: check for nulls and sort them to the end in ORDER BY clauses (merge from devel6, 36574)
Modified: grass/branches/releasebranch_6_3/db/drivers/dbf/dbfexe.c
--- grass/branches/releasebranch_6_3/db/drivers/dbf/dbfexe.c	2009-04-03 08:09:12 UTC (rev 36579)
+++ grass/branches/releasebranch_6_3/db/drivers/dbf/dbfexe.c	2009-04-03 08:13:15 UTC (rev 36580)
@@ -1,3 +1,4 @@
 * MODULE:       DBF driver
@@ -32,49 +33,65 @@
 #define NODE_ERROR  4
 int yyparse(void);
-void get_col_def ( SQLPSTMT *st, int col, int *type, int *width, int *decimals );
+void get_col_def(SQLPSTMT * st, int col, int *type, int *width,
+		 int *decimals);
 int sel(SQLPSTMT * st, int tab, int **set);
-void eval_val(int tab, int row, int col, SQLPVALUE * inval, SQLPVALUE * result);
+void eval_val(int tab, int row, int col, SQLPVALUE * inval,
+	      SQLPVALUE * result);
 int set_val(int tab, int row, int col, SQLPVALUE * val);
 double eval_node(SQLPNODE *, int, int, SQLPVALUE *);
 int eval_node_type(SQLPNODE *, int);
 int execute(char *sql, cursor * c)
     int i, j, tab, ret;
     SQLPSTMT *st;
     ROW *dbrows;
     VALUE *dbval;
     int row, nrows;
     int *cols, ncols, col;
     int *selset;
     int dtype, stype;
     int width, decimals;
     char *tmpsql, name[500];
-    SQLPVALUE *calctmp; /* store for calculated values in UPDATE, if any */
+    SQLPVALUE *calctmp;		/* store for calculated values in UPDATE, if any */
     /* parse sql statement */
     /* I don't know why, but if the statement ends by string in quotes 'xxx' and is not
-    *  followed by space or '\n' it is not parsed properly -> */
-    tmpsql = (char*) G_malloc ( strlen(sql) + 2 );
-    sprintf ( tmpsql, "%s ", sql );
+     *  followed by space or '\n' it is not parsed properly -> */
+    tmpsql = (char *)G_malloc(strlen(sql) + 2);
+    sprintf(tmpsql, "%s ", sql);
     st = sqpInitStmt();
     st->stmt = tmpsql;
     sqpInitParser(st);
     if (yyparse() != 0) {
-	sqpFreeStmt(st);
-	G_free ( tmpsql) ;
+	G_free(tmpsql);
 	append_error("SQL parser error: %s\n", st->errmsg);
 	append_error("in statement:\n%s\n", sql);
+	sqpFreeStmt(st);
 	return DB_FAILED;
-    G_debug (3, "SQL statement parsed successfully: %s", sql );
+    G_free(tmpsql);
-    /* sqpPrintStmt(st); */ /* debug output only */
+    G_debug(3, "SQL statement parsed successfully: %s", sql);
+    /* sqpPrintStmt(st); *//* debug output only */
     /* find table */
     tab = find_table(st->table);
     if (tab < 0 && st->command != SQLP_CREATE) {
@@ -85,40 +102,41 @@
     /* For DROP we have to call load_table_head() because it reads permissions */
     if ((st->command != SQLP_CREATE)) {
 	ret = load_table_head(tab);
-	if ( ret == DB_FAILED ) {
-	    append_error( "Cannot load table head.\n");
+	if (ret == DB_FAILED) {
+	    append_error("Cannot load table head.\n");
 	    return DB_FAILED;
     if ((st->command == SQLP_DROP) || (st->command == SQLP_DELETE) ||
-        (st->command == SQLP_INSERT) || (st->command == SQLP_UPDATE) ||
-       	(st->command == SQLP_ADD_COLUMN) || (st->command == SQLP_DROP_COLUMN)
-	if ( db.tables[tab].write == FALSE ) {
-  	    append_error( "Cannot modify table, don't have write permission for DBF file.\n");
+	(st->command == SQLP_INSERT) || (st->command == SQLP_UPDATE) ||
+	(st->command == SQLP_ADD_COLUMN) || (st->command == SQLP_DROP_COLUMN)
+	if (db.tables[tab].write == FALSE) {
+	    append_error
+		("Cannot modify table, don't have write permission for DBF file.\n");
 	    return DB_FAILED;
     /* find columns */
     ncols = st->nCol;
     if (st->command == SQLP_INSERT || st->command == SQLP_SELECT
 	|| st->command == SQLP_UPDATE || st->command == SQLP_DROP_COLUMN) {
 	if (ncols > 0) {	/* colums were specified */
-	    cols = (int *) G_malloc (ncols * sizeof(int));
+	    cols = (int *)G_malloc(ncols * sizeof(int));
 	    for (i = 0; i < ncols; i++) {
 		cols[i] = find_column(tab, st->Col[i].s);
-		if ( cols[i] == -1 ) {
-	            append_error( "Column '%s' not found\n", st->Col[i].s);
-	            return DB_FAILED;
+		if (cols[i] == -1) {
+		    append_error("Column '%s' not found\n", st->Col[i].s);
+		    return DB_FAILED;
 	else {			/* all columns */
 	    ncols = db.tables[tab].ncols;
 		cols[i] = i;
@@ -128,13 +146,13 @@
     if (st->command == SQLP_INSERT || st->command == SQLP_UPDATE) {
 	for (i = 0; i < st->nVal; i++) {
 	    col = cols[i];
-	    if ( st->Val[i].type != SQLP_NULL && st->Val[i].type != SQLP_EXPR) {
+	    if (st->Val[i].type != SQLP_NULL && st->Val[i].type != SQLP_EXPR) {
 		dtype = db.tables[tab].cols[col].type;
 		stype = st->Val[i].type;
 		if ((dtype == DBF_INT && stype != SQLP_I)
 		    || (dtype == DBF_DOUBLE && stype == SQLP_S)
 		    || (dtype == DBF_CHAR && stype != SQLP_S)) {
-		     append_error("Incompatible value type.\n");
+		    append_error("Incompatible value type.\n");
 		    return DB_FAILED;
@@ -142,22 +160,25 @@
     /* do command */
-    G_debug(3,"Doing SQL command <%d> on DBF table... (see include/sqlp.h)", st->command);
+    G_debug(3, "Doing SQL command <%d> on DBF table... (see include/sqlp.h)",
+	    st->command);
     switch (st->command) {
     case (SQLP_ADD_COLUMN):
 	load_table(tab);
-	get_col_def ( st, 0, &dtype, &width, &decimals );
+	get_col_def(st, 0, &dtype, &width, &decimals);
 	ret = add_column(tab, dtype, st->Col[0].s, width, decimals);
 	    append_error("Cannot add column.\n");
 	    return DB_FAILED;
 	/* Add column to each row */
-	for ( i = 0; i < db.tables[tab].nrows; i++ ) {
-	    db.tables[tab].rows[i].values =
-	        (VALUE *) G_realloc ( db.tables[tab].rows[i].values, db.tables[tab].ncols * sizeof(VALUE));
-            dbval = &(db.tables[tab].rows[i].values[db.tables[tab].ncols-1]);
+	for (i = 0; i < db.tables[tab].nrows; i++) {
+	    db.tables[tab].rows[i].values =
+		(VALUE *) G_realloc(db.tables[tab].rows[i].values,
+				    db.tables[tab].ncols * sizeof(VALUE));
+	    dbval =
+		&(db.tables[tab].rows[i].values[db.tables[tab].ncols - 1]);
 	    dbval->i = 0;
 	    dbval->d = 0.0;
 	    dbval->c = NULL;
@@ -165,10 +186,10 @@
 	db.tables[tab].updated = TRUE;
 	break;
     case (SQLP_DROP_COLUMN):
 	load_table(tab);
-	if (drop_column (tab, st->Col[0].s) != DB_OK) {
+	if (drop_column(tab, st->Col[0].s) != DB_OK) {
 	    append_error("Cannot delete column.\n");
 	    return DB_FAILED;
@@ -180,19 +201,19 @@
 	    append_error("Table %s already exists\n", st->table);
 	    return DB_FAILED;
-	sprintf ( name, "%s.dbf", st->table );
-	add_table(st->table, name );
+	sprintf(name, "%s.dbf", st->table);
+	add_table(st->table, name);
 	db.tables[tab].read = TRUE;
 	db.tables[tab].write = TRUE;
-	    get_col_def ( st, i, &dtype, &width, &decimals );
+	    get_col_def(st, i, &dtype, &width, &decimals);
 	    ret = add_column(tab, dtype, st->Col[i].s, width, decimals);
 		append_error("Cannot create table.\n");
-	        db.tables[tab].alive = FALSE;
+		db.tables[tab].alive = FALSE;
 		return DB_FAILED;
@@ -213,20 +234,20 @@
 	if (db.tables[tab].nrows == db.tables[tab].arows) {
 	    db.tables[tab].arows += 1000;
 	    db.tables[tab].rows =
-		(ROW *) G_realloc (db.tables[tab].rows,
-				db.tables[tab].arows * sizeof(ROW));
+		(ROW *) G_realloc(db.tables[tab].rows,
+				  db.tables[tab].arows * sizeof(ROW));
 	dbrows = db.tables[tab].rows;
 	row = db.tables[tab].nrows;
 	dbrows[row].values =
-	    (VALUE *) G_calloc (db.tables[tab].ncols, sizeof(VALUE));
+	    (VALUE *) G_calloc(db.tables[tab].ncols, sizeof(VALUE));
 	dbrows[row].alive = TRUE;
 	/* set to null */
 	for (i = 0; i < db.tables[tab].ncols; i++) {
-      	    VALUE *dbval;
+	    VALUE *dbval;
-            dbval = &(dbrows[row].values[i]);
+	    dbval = &(dbrows[row].values[i]);
 	    dbval->is_null = 1;
@@ -241,7 +262,7 @@
 	break;
     case (SQLP_SELECT):
-	G_debug ( 2, "SELECT");
+	G_debug(2, "SELECT");
 	c->st = st;
 	c->table = tab;
 	c->cols = cols;
@@ -266,7 +287,8 @@
 	/* update rows */
 	for (i = 0; i < nrows; i++) {
 	    SQLPVALUE *temp_p;
-	    calctmp = (SQLPVALUE*)G_malloc((st->nVal) * sizeof(SQLPVALUE));
+	    calctmp = (SQLPVALUE *) G_malloc((st->nVal) * sizeof(SQLPVALUE));
 	    row = selset[i];
 	    for (j = 0; j < st->nVal; j++) {
 		col = cols[j];
@@ -301,98 +323,100 @@
 	break;
-    if ( st->command != SQLP_SELECT ) { /* because statement is released with cursor */
-        sqpFreeStmt(st);
+    if (st->command != SQLP_SELECT) {	/* because statement is released with cursor */
+	sqpFreeStmt(st);
     return DB_OK;
 /* for given parser result and column index finds dbf column definition */
+void get_col_def(SQLPSTMT * st, int col, int *type, int *width, int *decimals)
     switch (st->ColType[col]) {
-	case (SQLP_INTEGER):
-	    *type = DBF_INT;
-	    *width = 11;
-	    *decimals = 0;
-	    break;
-	case (SQLP_VARCHAR):
-	    *type = DBF_CHAR;
-	    *width = st->ColWidth[col];
-	    *decimals = 0;
-	    break;
-	case (SQLP_DATE):  /* DATE treated as string unless SHAPELIB/DBFLIB supports date type */
-	    *type = DBF_CHAR;
-	    *width = 10;   /* 2004-01-23 = 10 chars */
-	    *decimals = 0;
-	    break;
-	case (SQLP_DOUBLE):
-	    *type = DBF_DOUBLE;
-	    *width = 20;
-	    *decimals = 6;
-	    break;
+    case (SQLP_INTEGER):
+	*type = DBF_INT;
+	*width = 11;
+	*decimals = 0;
+	break;
+    case (SQLP_VARCHAR):
+	*type = DBF_CHAR;
+	*width = st->ColWidth[col];
+	*decimals = 0;
+	break;
+    case (SQLP_DATE):		/* DATE treated as string unless SHAPELIB/DBFLIB supports date type */
+	*type = DBF_CHAR;
+	*width = 10;		/* 2004-01-23 = 10 chars */
+	*decimals = 0;
+	break;
+    case (SQLP_DOUBLE):
+	*type = DBF_DOUBLE;
+	*width = 20;
+	*decimals = 6;
+	break;
-void eval_val(int tab, int row, int col, SQLPVALUE * inval, SQLPVALUE *val)
+void eval_val(int tab, int row, int col, SQLPVALUE * inval, SQLPVALUE * val)
-  double retval;
-  /* XXX */
-    if ( inval->type == SQLP_EXPR ) {
-      retval = eval_node( inval->expr, tab, row, val );
-      if ( retval == NODE_NULL )
-	  val->type = SQLP_NULL;
+    double retval;
+    /* XXX */
+    if (inval->type == SQLP_EXPR) {
+	retval = eval_node(inval->expr, tab, row, val);
+	if (retval == NODE_NULL) {
+	    val->type = SQLP_NULL;
-      else if ( retval == NODE_TRUE )
-	  val->i = 1;
-	  val->d = 1.0;
-	  val->s = "TRUE";
+	else if (retval == NODE_TRUE) {
+	    val->i = 1;
+	    val->d = 1.0;
+	    val->s = "TRUE";
-      else if ( retval == NODE_FALSE )
-	  val->i = 0;
-	  val->d = 0.0;
-	  val->s = NULL;
+	else if (retval == NODE_FALSE) {
+	    val->i = 0;
+	    val->d = 0.0;
+	    val->s = NULL;
-      else if ( retval == NODE_VALUE )
-	  /* Ok, got a value, propagate it to the proper type */
-	  if( val->type == SQLP_I ){
-	    val->d = (double)val->i;
-	    val->s = (char*)G_malloc (32*sizeof(char));
-	    sprintf( val->s, "%d", val->i );
-	  }else if( val->type == SQLP_D ){
-	    val->i = (int)val->d;
-	    sprintf( val->s, "%g", val->d );
-	  }else if( val->type == SQLP_S ){
-	    val->i = atoi( val->s );
-	    val->d = atof( val->s );
-	  }else{
-	    G_fatal_error("This should not happen: wrong return type in parsing.");
+	else if (retval == NODE_VALUE) {
+	    /* Ok, got a value, propagate it to the proper type */
+	    if (val->type == SQLP_I) {
+		val->d = (double)val->i;
+		val->s = (char *)G_malloc(32 * sizeof(char));
+		sprintf(val->s, "%d", val->i);
+	    else if (val->type == SQLP_D) {
+		val->i = (int)val->d;
+		sprintf(val->s, "%g", val->d);
+	    else if (val->type == SQLP_S) {
+		val->i = atoi(val->s);
+		val->d = atof(val->s);
+	    else {
+		G_fatal_error
+		    ("This should not happen: wrong return type in parsing.");
-      else if ( retval == NODE_ERROR )
-	  G_fatal_error("This should not happen: got a wrong expression structure after parsing.");
+	else if (retval == NODE_ERROR) {
+	    G_fatal_error
+		("This should not happen: got a wrong expression structure after parsing.");
-      else
-	  G_fatal_error("Unknown return value calling eval_node from eval_val");
+	else {
+	    G_fatal_error
+		("Unknown return value calling eval_node from eval_val");
-    }else{
-       * TODO: maybe use this function to perform type "conversion",
-       * i.e. setting all of s,i,d to the same "value",as is done with
-       * the result of eval_node above.
-      val = inval;
+    else {
+	 * TODO: maybe use this function to perform type "conversion",
+	 * i.e. setting all of s,i,d to the same "value",as is done with
+	 * the result of eval_node above.
+	val = inval;
@@ -400,54 +424,55 @@
     VALUE *dbval;
     dbval = &(db.tables[tab].rows[row].values[col]);
-/* For debugging purposes; see FIXME below
-	fprintf(stderr, "In set_val : ");
-	fprintf(stderr, val->type==SQLP_EXPR?"sqlp_expr":
-			val->type==SQLP_NULL?"sqlp_null":
-			val->type==SQLP_I?"sqlp_i":
-			val->type==SQLP_D?"sqlp_d":
-			val->type==SQLP_S?"sqlp_s":
-			"other"); //DCA
-	fprintf(stderr,"%d\n",val->type);
-	fflush(stderr);
-    if ( val->type == SQLP_EXPR ){
-      eval_val( tab, row, col, val, val );
+    /* For debugging purposes; see FIXME below
+       fprintf(stderr, "In set_val : ");
+       fprintf(stderr, val->type==SQLP_EXPR?"sqlp_expr":
+       val->type==SQLP_NULL?"sqlp_null":
+       val->type==SQLP_I?"sqlp_i":
+       val->type==SQLP_D?"sqlp_d":
+       val->type==SQLP_S?"sqlp_s":
+       "other"); //DCA
+       fprintf(stderr,"%d\n",val->type);
+       fflush(stderr);
+    if (val->type == SQLP_EXPR) {
+	eval_val(tab, row, col, val, val);
     /* FIXME: SQLP_NULL is not always properly detected.
      * This workaround works, since type should be some of these
      * after passing through eval_val; otherwise it is NULL
-    if ( ! ( val->type == SQLP_I
-	||  val->type == SQLP_D
-	||  val->type == SQLP_S ) ) {
-        dbval->is_null = 1;
+    if (!(val->type == SQLP_I || val->type == SQLP_D || val->type == SQLP_S)) {
+	dbval->is_null = 1;
 	dbval->c = NULL;
 	dbval->i = 0;
 	dbval->d = 0.0;
-    } else {
-        dbval->is_null = 0;
+    else {
+	dbval->is_null = 0;
 	switch (db.tables[tab].cols[col].type) {
-	    case DBF_INT:
-		dbval->i = val->i;
-		break;
-	    case DBF_CHAR:
-		save_string(dbval, val->s);
-		break;
-	    case DBF_DOUBLE:
-		if (val->type == SQLP_I)
-		    dbval->d = val->i;
-		else if (val->type == SQLP_D)
-		    dbval->d = val->d;
-		else if (val->type == SQLP_S) {
-		    char* tailptr;
-		    double dval = strtod (val->s, &tailptr);
-		    if (!(*tailptr)) {
-			dbval->d = dval;
+	case DBF_INT:
+	    dbval->i = val->i;
+	    break;
+	case DBF_CHAR:
+	    save_string(dbval, val->s);
+	    break;
+	case DBF_DOUBLE:
+		dbval->d = val->i;
+		dbval->d = val->d;
+		char *tailptr;
+		double dval = strtod(val->s, &tailptr);
+		if (!(*tailptr)) {
+		    dbval->d = dval;
-		break;
+	    break;
     return (1);
@@ -455,116 +480,155 @@
 /* Comparison of 2 rows */
 static int cur_cmp_table;
 static int cur_cmp_ocol;
-static int cmp_row_asc ( const void *pa, const void *pb )
+static int cmp_row_asc(const void *pa, const void *pb)
-    int *row1 = (int*) pa;
-    int *row2 = (int*) pb;
+    int *row1 = (int *)pa;
+    int *row2 = (int *)pb;
     char *c1, *c2;
     int i1, i2;
     double d1, d2;
     TABLE *tbl;
     tbl = &(db.tables[cur_cmp_table]);
-    switch ( tbl->cols[cur_cmp_ocol].type ) {
-	case DBF_CHAR:
-	    c1 = tbl->rows[*row1].values[cur_cmp_ocol].c;
-	    c2 = tbl->rows[*row2].values[cur_cmp_ocol].c;
-	    return ( strcmp(c1, c2) );
-	    break;
-	case DBF_INT:
-	    i1 = tbl->rows[*row1].values[cur_cmp_ocol].i;
-	    i2 = tbl->rows[*row2].values[cur_cmp_ocol].i;
-	    if ( i1 < i2 ) return -1;
-	    if ( i1 > i2 ) return 1;
+    if (tbl->rows[*row1].values[cur_cmp_ocol].is_null) {
+	if (tbl->rows[*row2].values[cur_cmp_ocol].is_null) {
 	    return 0;
-	    break;
-	case DBF_DOUBLE:
-	    d1 = tbl->rows[*row1].values[cur_cmp_ocol].d;
-	    d2 = tbl->rows[*row2].values[cur_cmp_ocol].d;
-	    if ( d1 < d2 ) return -1;
-	    if ( d1 > d2 ) return 1;
+	else {
+	    return 1;
+    else {
+	    return -1;
+	else {
+	    switch (tbl->cols[cur_cmp_ocol].type) {
+	    case DBF_CHAR:
+		c1 = tbl->rows[*row1].values[cur_cmp_ocol].c;
+		c2 = tbl->rows[*row2].values[cur_cmp_ocol].c;
+		return (strcmp(c1, c2));
+		break;
+	    case DBF_INT:
+		i1 = tbl->rows[*row1].values[cur_cmp_ocol].i;
+		i2 = tbl->rows[*row2].values[cur_cmp_ocol].i;
+		if (i1 < i2)
+		    return -1;
+		if (i1 > i2)
+		    return 1;
+		return 0;
+		break;
+	    case DBF_DOUBLE:
+		d1 = tbl->rows[*row1].values[cur_cmp_ocol].d;
+		d2 = tbl->rows[*row2].values[cur_cmp_ocol].d;
+		if (d1 < d2)
+		    return -1;
+		if (d1 > d2)
+		    return 1;
+		return 0;
+		break;
 	    return 0;
-	    break;
-    return 0;
-static int cmp_row_desc ( const void *pa, const void *pb )
+static int cmp_row_desc(const void *pa, const void *pb)
-   return -cmp_row_asc (pa, pb);
+    return -cmp_row_asc(pa, pb);
 /* Select records, sets 'selset' to new array of items and returns
-*  number of items or -1 for error */
+ *  number of items or -1 for error */
 int sel(SQLPSTMT * st, int tab, int **selset)
     int i, ret, condition;
     int *set;			/* pointer to array of indexes to rows */
     int aset, nset;
-    G_debug ( 2, "sel(): tab = %d", tab);
+    G_debug(2, "sel(): tab = %d", tab);
     *selset = NULL;
     nset = 0;
     ret = load_table(tab);
-	append_error( "Cannot load table.\n");
+	append_error("Cannot load table.\n");
 	return -1;
     aset = 1;
-    set = (int *) G_malloc (aset * sizeof(int));
+    set = (int *)G_malloc(aset * sizeof(int));
     if (st->upperNodeptr) {
 	int node_type;
 	/* First eval node type */
-	node_type = eval_node_type( st->upperNodeptr, tab);
+	node_type = eval_node_type(st->upperNodeptr, tab);
 	G_debug(4, "node result type = %d", node_type);
-	if ( node_type == -1 ) {
-	    append_error( "Incompatible types in WHERE condition.\n");
+	if (node_type == -1) {
+	    append_error("Incompatible types in WHERE condition.\n");
 	    return -1;
-	} else if ( node_type == SQLP_S || node_type == SQLP_I || node_type == SQLP_D ) {
-	    append_error( "Result of WHERE condition is not of type BOOL.\n");
+	else if (node_type == SQLP_S || node_type == SQLP_I ||
+		 node_type == SQLP_D) {
+	    append_error("Result of WHERE condition is not of type BOOL.\n");
 	    return -1;
-	} else if ( node_type == SQLP_NULL ) {
+	else if (node_type == SQLP_NULL) {
 	    /* Conditions has undefined result -> nothing selected */
 	    return 0;
-	} else if ( node_type == SQLP_BOOL ) {
+	else if (node_type == SQLP_BOOL) {
 		SQLPVALUE value;
 		G_debug(4, "row %d", i);
-		condition = eval_node( st->upperNodeptr, tab, i, &value);
+		condition = eval_node(st->upperNodeptr, tab, i, &value);
 		G_debug(4, "condition = %d", condition);
-		if ( condition == NODE_ERROR ) { /* e.g. division by 0 */
-	    	    append_error( "Error in evaluation of WHERE condition.\n");
+		if (condition == NODE_ERROR) {	/* e.g. division by 0 */
+		    append_error("Error in evaluation of WHERE condition.\n");
 		    return (-1);
-		} else if ( condition == NODE_TRUE ) { /* true */
+		else if (condition == NODE_TRUE) {	/* true */
 		    if (nset == aset) {
 			aset += 1000;
-			set = (int *) G_realloc (set, aset * sizeof(int));
+			set = (int *)G_realloc(set, aset * sizeof(int));
 		    set[nset] = i;
 		    nset++;
-		} else if ( condition != NODE_FALSE && condition != NODE_NULL ) { /* Should not happen */
-		   append_error( "Unknown result (%d) of WHERE evaluation.\n", condition);
-		   return -1;
+		else if (condition != NODE_FALSE && condition != NODE_NULL) {	/* Should not happen */
+		    append_error("Unknown result (%d) of WHERE evaluation.\n",
+				 condition);
+		    return -1;
-	} else { /* Should not happen */
-	    append_error( "Unknown WHERE condition type (bug in DBF driver).\n");
+	else {			/* Should not happen */
+	    append_error
+		("Unknown WHERE condition type (bug in DBF driver).\n");
 	    return -1;
-    } else { /* Select all */
+    else {			/* Select all */
 	aset = db.tables[tab].nrows;
 	    set[i] = i;
@@ -572,33 +636,33 @@
     /* Order */
-    if ( st->command == SQLP_SELECT && st->orderCol ) {
+    if (st->command == SQLP_SELECT && st->orderCol) {
 	G_debug(3, "Order selection by %s", st->orderCol);
-        /* Find order col */
+	/* Find order col */
 	cur_cmp_ocol = -1;
-	for ( i = 0; i < db.tables[tab].ncols; i++ ) {
-	    if ( strcmp ( db.tables[tab].cols[i].name, st->orderCol ) == 0 ) {
+	for (i = 0; i < db.tables[tab].ncols; i++) {
+	    if (strcmp(db.tables[tab].cols[i].name, st->orderCol) == 0) {
 		cur_cmp_ocol = i;
 		break;
-	if ( cur_cmp_ocol < 0 ) {
-	    append_error( "Cannot find order column '%s'\n", st->orderCol);
+	if (cur_cmp_ocol < 0) {
+	    append_error("Cannot find order column '%s'\n", st->orderCol);
 	    return -1;
 	cur_cmp_table = tab;
-	if  (st->orderDir == SORT_DESC )
-	  qsort(set, nset, sizeof(int), cmp_row_desc);
-	} else {
-	  qsort(set, nset, sizeof(int), cmp_row_asc);
+	if (st->orderDir == SORT_DESC) {
+	    qsort(set, nset, sizeof(int), cmp_row_desc);
+	else {
+	    qsort(set, nset, sizeof(int), cmp_row_asc);
     *selset = set;
     return nset;
@@ -616,278 +680,307 @@
  * If results is NODE_VALUE, the 'value' is set, if value is type SQLP_S the string is not duplicated
  * and only pointer is set -> do not free value->s
-double eval_node(SQLPNODE *nptr, int tab, int row, SQLPVALUE *value)
+double eval_node(SQLPNODE * nptr, int tab, int row, SQLPVALUE * value)
-    int    left, right;
+    int left, right;
     SQLPVALUE left_value, right_value;
-    int    ccol;
+    int ccol;
     COLUMN *col;
-    VALUE  *val;
+    VALUE *val;
     double left_dval, right_dval, dval;
-    char   *rightbuf;
+    char *rightbuf;
     /* Note: node types were previously checked by eval_node_type */
-    G_debug ( 4, "eval_node node_type = %d", nptr->node_type );
+    G_debug(4, "eval_node node_type = %d", nptr->node_type);
-    switch ( nptr->node_type) {
-	case SQLP_NODE_VALUE:
-	    if ( nptr->value.type == SQLP_NULL )
-		return NODE_NULL;
-	    value->type = nptr->value.type;
-	    value->s = nptr->value.s;
-	    value->i = nptr->value.i;
-	    value->d = nptr->value.d;
-	    return NODE_VALUE;
+    switch (nptr->node_type) {
+    case SQLP_NODE_VALUE:
+	if (nptr->value.type == SQLP_NULL)
+	    return NODE_NULL;
+	value->type = nptr->value.type;
+	value->s = nptr->value.s;
+	value->i = nptr->value.i;
+	value->d = nptr->value.d;
+	return NODE_VALUE;
+	break;
+    case SQLP_NODE_COLUMN:
+	ccol = find_column(tab, nptr->column_name);
+	col = &(db.tables[tab].cols[ccol]);
+	val = &(db.tables[tab].rows[row].values[ccol]);
+	if (val->is_null)
+	    return NODE_NULL;
+	switch (col->type) {
+	case DBF_CHAR:
+	    value->s = val->c;
+	    value->type = SQLP_S;
 	    break;
+	case DBF_INT:
+	    value->i = val->i;
+	    value->type = SQLP_I;
+	    break;
+	case DBF_DOUBLE:
+	    value->d = val->d;
+	    value->type = SQLP_D;
+	    break;
+	break;
-	case SQLP_NODE_COLUMN:
-	    ccol = find_column(tab, nptr->column_name);
-	    col = &(db.tables[tab].cols[ccol]);
-	    val = &(db.tables[tab].rows[row].values[ccol]);
+    case SQLP_NODE_EXPRESSION:
+	/* Note: Some expressions (e.g. NOT) have only one side */
+	if (nptr->left) {
+	    left = eval_node(nptr->left, tab, row, &left_value);
+	    G_debug(4, "    left = %d", left);
-	    if ( val->is_null )
-		return NODE_NULL;
+	    if (left == NODE_ERROR)
+		return NODE_ERROR;
-	    switch (col->type) {
-		case DBF_CHAR:
-		    value->s = val->c;
-	    	    value->type = SQLP_S;
-		    break;
-		case DBF_INT:
-		    value->i = val->i;
-	    	    value->type = SQLP_I;
-		    break;
-		case DBF_DOUBLE:
-		    value->d = val->d;
-	    	    value->type = SQLP_D;
-		break;
+	    if (left != NODE_NULL) {
+		if (left_value.type == SQLP_I)
+		    left_dval = left_value.i;
+		else
+		    left_dval = left_value.d;
+		G_debug(4, "    left_dval = %f", left_dval);
-	    break;
-	case SQLP_NODE_EXPRESSION:
-	    /* Note: Some expressions (e.g. NOT) have only one side */
-	    if ( nptr->left ) {
-	        left = eval_node ( nptr->left, tab, row, &left_value);
-		G_debug ( 4, "    left = %d", left );
+	if (nptr->right) {
+	    right = eval_node(nptr->right, tab, row, &right_value);
+	    G_debug(4, "    right = %d", right);
-		if ( left == NODE_ERROR )
-		    return NODE_ERROR;
+	    if (right == NODE_ERROR)
-		if ( left != NODE_NULL ) {
-		    if ( left_value.type == SQLP_I )
-			left_dval = left_value.i;
-		    else
-			left_dval = left_value.d;
-		    G_debug ( 4, "    left_dval = %f", left_dval );
+	    if (right != NODE_NULL) {
+		if (right_value.type == SQLP_I)
+		    right_dval = right_value.i;
+		else
+		    right_dval = right_value.d;
+		G_debug(4, "    right_dval = %f", right_dval);
-	    if ( nptr->right ) {
-	        right = eval_node ( nptr->right, tab, row, &right_value);
-		G_debug ( 4, "    right = %d", right );
+	G_debug(4, "    operator = %d", nptr->oper);
-		if ( right == NODE_ERROR )
+	switch (nptr->oper) {
+	    /* Arithmetical */
+	case SQLP_ADD:
+	case SQLP_SUBTR:
+	case SQLP_MLTP:
+	case SQLP_DIV:
+	    if (left == NODE_NULL || right == NODE_NULL)
+		return NODE_NULL;
-		if ( right != NODE_NULL ) {
-		    if ( right_value.type == SQLP_I )
-			right_dval = right_value.i;
-		    else
-			right_dval = right_value.d;
-		    G_debug ( 4, "    right_dval = %f", right_dval );
+	    case SQLP_ADD:
+		dval = left_dval + right_dval;
+		break;
+	    case SQLP_SUBTR:
+		dval = left_dval - right_dval;
+		break;
+	    case SQLP_MLTP:
+		dval = left_dval * right_dval;
+		break;
+	    case SQLP_DIV:
+		if (right_dval != 0.0) {
+		    dval = left_dval / right_dval;
+		else {
+		    append_error("Division by zero\n");
+		break;
-	    G_debug ( 4, "    operator = %d", nptr->oper );
-	    switch ( nptr->oper ) {
-		/* Arithmetical */
-		case SQLP_ADD:
-		case SQLP_SUBTR:
-		case SQLP_MLTP:
-		case SQLP_DIV:
-		    if ( left == NODE_NULL || right == NODE_NULL )
-			return NODE_NULL;
+	    if (left_value.type == SQLP_I && right_value.type == SQLP_I &&
+		(nptr->oper == SQLP_ADD || nptr->oper == SQLP_SUBTR ||
+		 nptr->oper == SQLP_MLTP)) {
+		value->i = (int)dval;
+	    else {
+		value->d = dval;
-			case SQLP_ADD:
-			    dval = left_dval + right_dval;
-			    break;
-			case SQLP_SUBTR:
-			    dval = left_dval - right_dval;
-			    break;
-			case SQLP_MLTP:
-			    dval = left_dval * right_dval;
-			    break;
-			case SQLP_DIV:
-			    if ( right_dval != 0.0) {
-			        dval = left_dval / right_dval;
-			    } else {
-			        append_error ("Division by zero\n");
-			    break;
-		    if ( left_value.type == SQLP_I && right_value.type == SQLP_I &&
-			 ( nptr->oper == SQLP_ADD || nptr->oper == SQLP_SUBTR ||  nptr->oper == SQLP_MLTP ) )
-			value->i = (int) dval;
-		    } else {
-			value->d = dval;
+	    break;
-		    break;
+	    /* Comparison */
+	    /* Operators valid for all type */
+	case SQLP_EQ:
+	    if (left == NODE_NULL || right == NODE_NULL) {
+		return NODE_NULL;
+	    else if (left_value.type == SQLP_S) {	/* we checked before if right is also string */
+		if (left_value.s && right_value.s &&
+		    strcmp(left_value.s, right_value.s) == 0)
+		    return NODE_TRUE;
+		else
+		    return NODE_FALSE;
+	    else {		/* numbers */
+		if (left_dval == right_dval)
+		    return NODE_TRUE;
+		else
+	    break;
-		/* Comparison */
-		    /* Operators valid for all type */
-		case SQLP_EQ:
-		    if ( left == NODE_NULL || right == NODE_NULL ) {
-			return NODE_NULL;
-		    } else if ( left_value.type == SQLP_S ) { /* we checked before if right is also string */
-			if ( left_value.s && right_value.s && strcmp(left_value.s,right_value.s) == 0)
-			   return NODE_TRUE;
-			else
-			    return NODE_FALSE;
-		    } else { /* numbers */
-			if ( left_dval == right_dval )
-			    return NODE_TRUE;
-			else
-		    break;
+	case SQLP_NE:
+		return NODE_NULL;
+		    strcmp(left_value.s, right_value.s) != 0)
+		    return NODE_TRUE;
+		else
+		if (left_dval != right_dval)
+		    return NODE_TRUE;
+		else
-		case SQLP_NE:
-			return NODE_NULL;
-			if ( left_value.s && right_value.s && strcmp(left_value.s,right_value.s) != 0)
-			   return NODE_TRUE;
-			else
-			if ( left_dval != right_dval )
-			    return NODE_TRUE;
-			else
+	    /* Operators valid for numbers */
+	case SQLP_LT:
+		return NODE_NULL;
+	    else {
+		if (left_dval < right_dval)
+		    return NODE_TRUE;
+		else
-		    /* Operators valid for numbers */
-		case SQLP_LT:
-			return NODE_NULL;
-		    } else {
-			if ( left_dval < right_dval )
-			    return NODE_TRUE;
-			else
+	case SQLP_LE:
+		return NODE_NULL;
+	    else {
+		if (left_dval <= right_dval)
+		    return NODE_TRUE;
+		else
-		case SQLP_LE:
-			return NODE_NULL;
-		    } else {
-			if ( left_dval <= right_dval )
-			    return NODE_TRUE;
-			else
+	case SQLP_GT:
+		return NODE_NULL;
+	    else {
+		if (left_dval > right_dval)
+		    return NODE_TRUE;
+		else
-		case SQLP_GT:
-			return NODE_NULL;
-		    } else {
-			if ( left_dval > right_dval )
-			    return NODE_TRUE;
-			else
+	case SQLP_GE:
+		return NODE_NULL;
+	    else {
+		if (left_dval >= right_dval)
+		    return NODE_TRUE;
+		else
-		case SQLP_GE:
-			return NODE_NULL;
-		    } else {
-			if ( left_dval >= right_dval )
-			    return NODE_TRUE;
-			else
+	    /* Operator valid for string */
+	case SQLP_MTCH:
+		return NODE_NULL;
+	    else {
+		/* hack to get '%substring' and 'substring%' working */
+		rightbuf = G_str_replace(right_value.s, "%", "");
+		G_chop(rightbuf);
+		    strstr(left_value.s, rightbuf) != NULL) {
+		    G_free(rightbuf);
+		    return NODE_TRUE;
+		else {
+		    G_free(rightbuf);
-		    /* Operator valid for string */
-		case SQLP_MTCH:
-			return NODE_NULL;
-		    } else {
-			/* hack to get '%substring' and 'substring%' working */
-			rightbuf = G_str_replace ( right_value.s, "%", "" );
-			G_chop (rightbuf);
-			if ( left_value.s && right_value.s && strstr(left_value.s,rightbuf) != NULL){
-			    G_free (rightbuf);
-			    return NODE_TRUE;
-			else{
+	case SQLP_ISNULL:
+	    return right == NODE_NULL ? NODE_TRUE : NODE_FALSE;
-		case SQLP_ISNULL:
-		    return right == NODE_NULL ? NODE_TRUE : NODE_FALSE;
+	case SQLP_NOTNULL:
+	    return right != NODE_NULL ? NODE_TRUE : NODE_FALSE;
-		case SQLP_NOTNULL:
-		    return right != NODE_NULL ? NODE_TRUE : NODE_FALSE;
+	    /* Logical */
+	case SQLP_AND:
+		return NODE_NULL;
+	    else if (left == NODE_TRUE && right == NODE_TRUE) {
+		return NODE_TRUE;
+	    else if (left == NODE_VALUE || right == NODE_VALUE) {	/* Should not happen */
+		append_error("Value operand for AND\n");
+	    else {
+	case SQLP_OR:
+	    if (left == NODE_NULL && right == NODE_NULL) {
+		return NODE_NULL;
+	    else if (left == NODE_TRUE || right == NODE_TRUE) {
+		return NODE_TRUE;
+		append_error("Value operand for OR\n");
+	    else {
+	case SQLP_NOT:
+	    /* sub node stored on the right side */
+	    if (right == NODE_NULL) {
+		return NODE_NULL;
+	    else if (right == NODE_TRUE) {
+	    else if (right == NODE_VALUE) {	/* Should not happen */
+		append_error("Value operand for NOT\n");
+	    else {
+		return NODE_TRUE;
-		/* Logical */
-		case SQLP_AND:
-			return NODE_NULL;
-		    } else if ( left == NODE_TRUE && right == NODE_TRUE ) {
-			return NODE_TRUE;
-		    } else if ( left == NODE_VALUE || right == NODE_VALUE ) { /* Should not happen */
-	    	    	append_error ("Value operand for AND\n");
-		    } else {
-		case SQLP_OR:
-		    if ( left == NODE_NULL && right == NODE_NULL ) {
-			return NODE_NULL;
-		    } else if ( left == NODE_TRUE || right == NODE_TRUE ) {
-			return NODE_TRUE;
-	    	    	append_error ("Value operand for OR\n");
-		    } else {
-		case SQLP_NOT:
-		    /* sub node stored on the right side */
-		    if ( right == NODE_NULL ) {
-			return NODE_NULL;
-		    } else if ( right == NODE_TRUE ) {
-		    } else if ( right == NODE_VALUE ) { /* Should not happen */
-	    	    	append_error ("Value operand for NOT\n");
-		    } else {
-			return NODE_TRUE;
+	default:
+	    append_error("Unknown operator %d\n", nptr->oper);
-		default:
-	    	    append_error ("Unknown operator %d\n", nptr->oper);
-    return NODE_ERROR; /* Not reached */
+    return NODE_ERROR;		/* Not reached */
 /* Recursively get value/expression type.
@@ -928,148 +1021,165 @@
  *      Logical expressions
  *        In general, if we know that the result is NULL regardless actual values it returns SQLP_NULL
  *        so that tests for individual rows are not performed, otherwise SQLP_BOOL
- *        SQLP_BOOL SQLP_BOOL AND             	-> SQLP_BOOL
- *        SQLP_BOOL SQLP_NULL AND             	-> SQLP_NULL
- *        SQLP_NULL SQLP_NULL AND             	-> SQLP_NULL
- *        SQLP_BOOL SQLP_BOOL OR		-> SQLP_BOOL
- *        SQLP_BOOL SQLP_NULL OR		-> SQLP_BOOL
- *        SQLP_NULL SQLP_NULL OR		-> SQLP_NULL
- *        SQLP_BOOL -         NOT		-> SQLP_BOOL
- *        SQLP_NULL -         NOT		-> SQLP_NULL
+ *        SQLP_BOOL SQLP_BOOL AND               -> SQLP_BOOL
+ *        SQLP_BOOL SQLP_NULL AND               -> SQLP_NULL
+ *        SQLP_NULL SQLP_NULL AND               -> SQLP_NULL
+ *        SQLP_BOOL SQLP_BOOL OR                -> SQLP_BOOL
+ *        SQLP_BOOL SQLP_NULL OR                -> SQLP_BOOL
+ *        SQLP_NULL SQLP_NULL OR                -> SQLP_NULL
+ *        SQLP_BOOL -         NOT               -> SQLP_BOOL
+ *        SQLP_NULL -         NOT               -> SQLP_NULL
-int eval_node_type(SQLPNODE *nptr, int tab ) {
+int eval_node_type(SQLPNODE * nptr, int tab)
     int left, right;
     int ccol;
     COLUMN *col = NULL;
-	    return nptr->value.type;
+	return nptr->value.type;
+	break;
+	if (ccol == -1) {
+	    append_error("Column '%s' not found\n", nptr->column_name);
+	    return (-1);
+	case DBF_CHAR:
+	    return (SQLP_S);
 	    break;
+	case DBF_INT:
+	    return (SQLP_I);
+	    break;
+	case DBF_DOUBLE:
+	    return (SQLP_D);
+	    break;
+	break;
-	    ccol = find_column ( tab, nptr->column_name );
-	    if ( ccol == -1 ) {
-		append_error ("Column '%s' not found\n", nptr->column_name);
-		return (-1);
+	if (nptr->left) {
+	    left = eval_node_type(nptr->left, tab);
+	    if (left == -1)
+		return -1;
+	    right = eval_node_type(nptr->right, tab);
+	    if (right == -1)
+		return -1;
+	case SQLP_ADD:
+	case SQLP_SUBTR:
+	case SQLP_MLTP:
+	case SQLP_DIV:
+	    if (left == SQLP_S || right == SQLP_S) {
+		append_error
+		    ("Arithmetical operation with strings is not allowed\n");
+		return -1;
-		case DBF_CHAR:
-		    return (SQLP_S);
-		    break;
-		case DBF_INT:
-		    return (SQLP_I);
-		    break;
-		case DBF_DOUBLE:
-		    return (SQLP_D);
-		    break;
+	    else if (left == SQLP_NULL || right == SQLP_NULL) {
+		return SQLP_NULL;
+	    else if (left == SQLP_I && right == SQLP_I &&
+		return SQLP_I;
+	    else {
+		return SQLP_D;
 	    break;
-	        left = eval_node_type( nptr->left, tab);
-		if ( left == -1 )
-		    return -1;
+	    /* Comparison */
+	case SQLP_EQ:
+	case SQLP_NE:
+	    if ((left == SQLP_S && (right == SQLP_I || right == SQLP_D)) ||
+		(right == SQLP_S && (left == SQLP_I || left == SQLP_D))) {
+		append_error
+		    ("Comparison between string and number is not allowed\n");
+		return -1;
-	        right = eval_node_type( nptr->right, tab);
-		if ( right == -1 )
-		    return -1;
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
+	case SQLP_LT:
+	case SQLP_LE:
+	case SQLP_GT:
+	case SQLP_GE:
+		append_error("Comparison '%s' between strings not allowed\n",
+			     sqpOperatorName(nptr->oper));
+		return -1;
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
+	case SQLP_MTCH:
+	    if (left == SQLP_I || left == SQLP_D || right == SQLP_I ||
+		right == SQLP_D) {
+		append_error("Match (~) between numbers not allowed\n");
+		return -1;
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
-		case SQLP_ADD:
-		case SQLP_SUBTR:
-		case SQLP_MLTP:
-		case SQLP_DIV:
-		    if ( left == SQLP_S || right == SQLP_S ) {
-		        append_error ("Arithmetical operation with strings is not allowed\n" );
-			return -1;
-		    } else if ( left == SQLP_NULL || right == SQLP_NULL ) {
-			return SQLP_NULL;
-		    } else if ( left == SQLP_I && right == SQLP_I && ( nptr->oper == SQLP_ADD ||
-				nptr->oper == SQLP_SUBTR ||  nptr->oper == SQLP_MLTP ) )
-			return SQLP_I;
-		    } else {
-			return SQLP_D;
-		    break;
+	case SQLP_ISNULL:
+	    return SQLP_BOOL;
-		/* Comparison */
-		case SQLP_EQ:
-		case SQLP_NE:
-		    if ( ( left  == SQLP_S && ( right == SQLP_I || right == SQLP_D ) ) ||
-		         ( right == SQLP_S && ( left  == SQLP_I || left  == SQLP_D ) ) )
-		        append_error ("Comparison between string and number is not allowed\n" );
-			return -1;
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
-		case SQLP_LT:
-		case SQLP_LE:
-		case SQLP_GT:
-		case SQLP_GE:
-			append_error ("Comparison '%s' between strings not allowed\n",
-				       sqpOperatorName(nptr->oper) );
-			return -1;
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
-		case SQLP_MTCH:
-		    if ( left == SQLP_I || left == SQLP_D || right == SQLP_I || right == SQLP_D ) {
-			append_error ("Match (~) between numbers not allowed\n" );
-			return -1;
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
+	    /* Logical */
+	case SQLP_AND:
+	    if (left == SQLP_NULL || right == SQLP_NULL) {
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
+	case SQLP_OR:
+	    if (left == SQLP_NULL && right == SQLP_NULL) {
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
+	case SQLP_NOT:
+	    if (right == SQLP_NULL) {
+		return SQLP_NULL;
+	    else {
+		return SQLP_BOOL;
-		case SQLP_ISNULL:
-		    return SQLP_BOOL;
+	default:
+	    return -1;
-		/* Logical */
-		case SQLP_AND:
-		    if ( left == SQLP_NULL || right == SQLP_NULL ) {
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
-		case SQLP_OR:
-		    if ( left == SQLP_NULL && right == SQLP_NULL ) {
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
-		case SQLP_NOT:
-		    if ( right == SQLP_NULL ) {
-			return SQLP_NULL;
-		    } else {
-			return SQLP_BOOL;
-		default:
-		    return -1;
-    return -1; /* Not reached */
+    return -1;			/* Not reached */
