[GRASS-SVN] r36588 - in grass/trunk: include include/vect lib/vector/Vlib lib/vector/diglib vector/v.buffer2 vector/v.parallel2
Sun Apr 5 10:30:56 EDT 2009
Author: martinl
Date: 2009-04-05 10:30:56 -0400 (Sun, 05 Apr 2009)
New Revision: 36588
Removed:
   grass/trunk/vector/v.buffer2/local_proto.h
   grass/trunk/vector/v.parallel2/local_proto.h
   grass/trunk/include/Vect.h
   grass/trunk/include/vect/dig_externs.h
   grass/trunk/lib/vector/Vlib/area.c
   grass/trunk/lib/vector/Vlib/array.c
   grass/trunk/lib/vector/Vlib/box.c
   grass/trunk/lib/vector/Vlib/break_lines.c
   grass/trunk/lib/vector/Vlib/break_polygons.c
   grass/trunk/lib/vector/Vlib/bridges.c
   grass/trunk/lib/vector/Vlib/buffer.c
   grass/trunk/lib/vector/Vlib/buffer2.c
   grass/trunk/lib/vector/Vlib/build.c
   grass/trunk/lib/vector/Vlib/build_nat.c
   grass/trunk/lib/vector/Vlib/build_ogr.c
   grass/trunk/lib/vector/Vlib/cats.c
   grass/trunk/lib/vector/Vlib/cindex.c
   grass/trunk/lib/vector/Vlib/clean_nodes.c
   grass/trunk/lib/vector/Vlib/close.c
   grass/trunk/lib/vector/Vlib/close_nat.c
   grass/trunk/lib/vector/Vlib/close_ogr.c
   grass/trunk/lib/vector/Vlib/constraint.c
   grass/trunk/lib/vector/Vlib/dangles.c
   grass/trunk/lib/vector/Vlib/dbcolumns.c
   grass/trunk/lib/vector/Vlib/dgraph.c
   grass/trunk/lib/vector/Vlib/dgraph.h
   grass/trunk/lib/vector/Vlib/e_intersect.c
   grass/trunk/lib/vector/Vlib/error.c
   grass/trunk/lib/vector/Vlib/field.c
   grass/trunk/lib/vector/Vlib/find.c
   grass/trunk/lib/vector/Vlib/geos.c
   grass/trunk/lib/vector/Vlib/graph.c
   grass/trunk/lib/vector/Vlib/header.c
   grass/trunk/lib/vector/Vlib/hist.c
   grass/trunk/lib/vector/Vlib/init_head.c
   grass/trunk/lib/vector/Vlib/intersect.c
   grass/trunk/lib/vector/Vlib/legal_vname.c
   grass/trunk/lib/vector/Vlib/level.c
   grass/trunk/lib/vector/Vlib/level_two.c
   grass/trunk/lib/vector/Vlib/line.c
   grass/trunk/lib/vector/Vlib/list.c
   grass/trunk/lib/vector/Vlib/map.c
   grass/trunk/lib/vector/Vlib/net.c
   grass/trunk/lib/vector/Vlib/open.c
   grass/trunk/lib/vector/Vlib/open_nat.c
   grass/trunk/lib/vector/Vlib/open_ogr.c
   grass/trunk/lib/vector/Vlib/overlap.c
   grass/trunk/lib/vector/Vlib/overlay.c
   grass/trunk/lib/vector/Vlib/poly.c
   grass/trunk/lib/vector/Vlib/read.c
   grass/trunk/lib/vector/Vlib/read_nat.c
   grass/trunk/lib/vector/Vlib/read_ogr.c
   grass/trunk/lib/vector/Vlib/remove_areas.c
   grass/trunk/lib/vector/Vlib/remove_duplicates.c
   grass/trunk/lib/vector/Vlib/rewind.c
   grass/trunk/lib/vector/Vlib/rewind_nat.c
   grass/trunk/lib/vector/Vlib/rewind_ogr.c
   grass/trunk/lib/vector/Vlib/select.c
   grass/trunk/lib/vector/Vlib/sindex.c
   grass/trunk/lib/vector/Vlib/snap.c
   grass/trunk/lib/vector/Vlib/tin.c
   grass/trunk/lib/vector/Vlib/type.c
   grass/trunk/lib/vector/Vlib/window.c
   grass/trunk/lib/vector/Vlib/write.c
   grass/trunk/lib/vector/Vlib/write_nat.c
   grass/trunk/lib/vector/diglib/box.c
   grass/trunk/lib/vector/diglib/plus_line.c
   grass/trunk/lib/vector/diglib/plus_node.c
   grass/trunk/lib/vector/diglib/portable.c
   grass/trunk/lib/vector/diglib/spindex.c
   grass/trunk/vector/v.buffer2/main.c
   grass/trunk/vector/v.parallel2/main.c
vlib: modify prototypes to use 'const'
Modified: grass/trunk/include/Vect.h
--- grass/trunk/include/Vect.h	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/include/Vect.h	2009-04-05 14:30:56 UTC (rev 36588)
@@ -15,39 +15,39 @@
 /* Points (line) */
 struct line_pnts *Vect_new_line_struct(void);
 int Vect_append_point(struct line_pnts *, double, double, double);
-int Vect_append_points(struct line_pnts *, struct line_pnts *, int);
+int Vect_append_points(struct line_pnts *, const struct line_pnts *, int);
 int Vect_line_insert_point(struct line_pnts *, int, double, double, double);
 int Vect_line_delete_point(struct line_pnts *, int);
 int Vect_line_prune(struct line_pnts *);
 int Vect_line_prune_thresh(struct line_pnts *, double);
 void Vect_line_reverse(struct line_pnts *);
-int Vect_copy_xyz_to_pnts(struct line_pnts *, double *, double *, double *,
+int Vect_copy_xyz_to_pnts(struct line_pnts *, const double *, const double *, const double *,
 			  int);
-int Vect_copy_pnts_to_xyz(struct line_pnts *, double *, double *, double *,
+int Vect_copy_pnts_to_xyz(const struct line_pnts *, double *, double *, double *,
 			  int *);
 int Vect_reset_line(struct line_pnts *);
 int Vect_destroy_line_struct(struct line_pnts *);
-int Vect_point_on_line(struct line_pnts *, double, double *, double *,
+int Vect_point_on_line(const struct line_pnts *, double, double *, double *,
 		       double *, double *, double *);
-int Vect_line_segment(struct line_pnts *, double, double, struct line_pnts *);
-double Vect_line_length(struct line_pnts *);
-double Vect_area_perimeter(struct line_pnts *);
-double Vect_line_geodesic_length(struct line_pnts *);
-int Vect_line_distance(struct line_pnts *, double, double, double, int,
+int Vect_line_segment(const struct line_pnts *, double, double, struct line_pnts *);
+double Vect_line_length(const struct line_pnts *);
+double Vect_area_perimeter(const struct line_pnts *);
+double Vect_line_geodesic_length(const struct line_pnts *);
+int Vect_line_distance(const struct line_pnts *, double, double, double, int,
 		       double *, double *, double *, double *, double *,
 		       double *);
-int Vect_line_box(struct line_pnts *, BOUND_BOX *);
+int Vect_line_box(const struct line_pnts *, BOUND_BOX *);
 void Vect_line_parallel(struct line_pnts *, double, double, int,
 void Vect_line_parallel2(struct line_pnts *, double, double,
 			 double, int, int, double,
-void Vect_line_buffer(struct line_pnts *, double, double, struct line_pnts *);
-void Vect_line_buffer2(struct line_pnts *, double, double,
+void Vect_line_buffer(const struct line_pnts *, double, double, struct line_pnts *);
+void Vect_line_buffer2(const struct line_pnts *, double, double,
 		       struct line_pnts **,
 		       struct line_pnts ***, int *);
-void Vect_area_buffer2(struct Map_info *, int, double, double,
+void Vect_area_buffer2(const struct Map_info *, int, double, double,
@@ -59,31 +59,31 @@
 /* Categories */
 struct line_cats *Vect_new_cats_struct(void);
 int Vect_cat_set(struct line_cats *, int, int);
-int Vect_cat_get(struct line_cats *, int, int *);
+int Vect_cat_get(const struct line_cats *, int, int *);
 int Vect_cat_del(struct line_cats *, int);
 int Vect_field_cat_del(struct line_cats *, int, int);
-int Vect_field_cat_get(struct line_cats *, int, struct ilist *);
-int Vect_cat_in_array(int, int *, int);
+int Vect_field_cat_get(const struct line_cats *, int, struct ilist *);
+int Vect_cat_in_array(int, const int *, int);
 int Vect_reset_cats(struct line_cats *);
 int Vect_destroy_cats_struct(struct line_cats *);
-int Vect_get_area_cats(struct Map_info *, int, struct line_cats *);
-int Vect_get_area_cat(struct Map_info *, int, int);
-int Vect_get_line_cat(struct Map_info *, int, int);
+int Vect_get_area_cats(const struct Map_info *, int, struct line_cats *);
+int Vect_get_area_cat(const struct Map_info *, int, int);
+int Vect_get_line_cat(const struct Map_info *, int, int);
 /* List of categories */
 struct cat_list *Vect_new_cat_list(void);
 int Vect_str_to_cat_list(const char *, struct cat_list *);
-int Vect_array_to_cat_list(int *, int, struct cat_list *);
-int Vect_cat_in_cat_list(int, struct cat_list *);
+int Vect_array_to_cat_list(const int *, int, struct cat_list *);
+int Vect_cat_in_cat_list(int, const struct cat_list *);
 int Vect_destroy_cat_list(struct cat_list *);
 /* Vector array */
-VARRAY *Vect_new_varray(int size);
-int Vect_set_varray_from_cat_string(struct Map_info *, int, const char *, int,
+VARRAY *Vect_new_varray(int);
+int Vect_set_varray_from_cat_string(const struct Map_info *, int, const char *, int,
 				    int, VARRAY *);
-int Vect_set_varray_from_cat_list(struct Map_info *, int, struct cat_list *,
+int Vect_set_varray_from_cat_list(const struct Map_info *, int, struct cat_list *,
 				  int, int, VARRAY *);
-int Vect_set_varray_from_db(struct Map_info *, int, const char *, int, int,
+int Vect_set_varray_from_db(const struct Map_info *, int, const char *, int, int,
 			    VARRAY *);
 /* DB connection - field info */
@@ -91,109 +91,109 @@
 void Vect_reset_dblinks(struct dblinks *);
 int Vect_add_dblink(struct dblinks *, int, const char *,
 		    const char *, const char *, const char *, const char *);
-int Vect_check_dblink(struct dblinks *, int);
+int Vect_check_dblink(const struct dblinks *, int);
 int Vect_map_add_dblink(struct Map_info *, int, const char *,
 			const char *);
 int Vect_map_del_dblink(struct Map_info *, int);
-int Vect_map_check_dblink(struct Map_info *, int);
+int Vect_map_check_dblink(const struct Map_info *, int);
 int Vect_read_dblinks(struct Map_info *);
 int Vect_write_dblinks(struct Map_info *);
 struct field_info *Vect_default_field_info(struct Map_info *, int,
 					   const char *, int);
-struct field_info *Vect_get_dblink(struct Map_info *, int);
-struct field_info *Vect_get_field(struct Map_info *, int);
+struct field_info *Vect_get_dblink(const struct Map_info *, int);
+struct field_info *Vect_get_field(const struct Map_info *, int);
 void Vect_set_db_updated(struct Map_info *);
-const char *Vect_get_column_names(struct Map_info *, int);
-const char *Vect_get_column_types(struct Map_info *, int);
-const char *Vect_get_column_names_types(struct Map_info *, int);
+const char *Vect_get_column_names(const struct Map_info *, int);
+const char *Vect_get_column_types(const struct Map_info *, int);
+const char *Vect_get_column_names_types(const struct Map_info *, int);
 /* List of FID (feature ID) (integers) */
 struct ilist *Vect_new_list(void);
 int Vect_list_append(struct ilist *, int);
-int Vect_list_append_list(struct ilist *, struct ilist *);
+int Vect_list_append_list(struct ilist *, const struct ilist *);
 int Vect_list_delete(struct ilist *, int);
-int Vect_list_delete_list(struct ilist *, struct ilist *);
-int Vect_val_in_list(struct ilist *, int);
+int Vect_list_delete_list(struct ilist *, const struct ilist *);
+int Vect_val_in_list(const struct ilist *, int);
 int Vect_reset_list(struct ilist *);
 int Vect_destroy_list(struct ilist *);
 /* Bounding box (MBR) */
-int Vect_point_in_box(double, double, double, BOUND_BOX *);
-int Vect_box_overlap(BOUND_BOX *, BOUND_BOX *);
-int Vect_box_copy(BOUND_BOX *, BOUND_BOX *);
-int Vect_box_extend(BOUND_BOX *, BOUND_BOX *);
-int Vect_box_clip(double *, double *, double *, double *, BOUND_BOX *);
-int Vect_region_box(struct Cell_head *, BOUND_BOX *);
+int Vect_point_in_box(double, double, double, const BOUND_BOX *);
+int Vect_box_overlap(const BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_copy(BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_extend(BOUND_BOX *, const BOUND_BOX *);
+int Vect_box_clip(double *, double *, double *, double *, const BOUND_BOX *);
+int Vect_region_box(const struct Cell_head *, BOUND_BOX *);
 /* Spatial index */
 void Vect_spatial_index_init(SPATIAL_INDEX *);
 void Vect_spatial_index_destroy(SPATIAL_INDEX *);
-void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, BOUND_BOX *);
+void Vect_spatial_index_add_item(SPATIAL_INDEX *, int, const BOUND_BOX *);
 void Vect_spatial_index_del_item(SPATIAL_INDEX *, int);
-int Vect_spatial_index_select(SPATIAL_INDEX *, BOUND_BOX *, struct ilist *);
+int Vect_spatial_index_select(const SPATIAL_INDEX *, const BOUND_BOX *, struct ilist *);
 /* Category index */
-int Vect_cidx_get_num_fields(struct Map_info *);
-int Vect_cidx_get_field_number(struct Map_info *, int);
-int Vect_cidx_get_field_index(struct Map_info *, int);
-int Vect_cidx_get_num_unique_cats_by_index(struct Map_info *, int);
-int Vect_cidx_get_num_cats_by_index(struct Map_info *, int);
-int Vect_cidx_get_num_types_by_index(struct Map_info *, int);
-int Vect_cidx_get_type_count_by_index(struct Map_info *, int, int, int *,
+int Vect_cidx_get_num_fields(const struct Map_info *);
+int Vect_cidx_get_field_number(const struct Map_info *, int);
+int Vect_cidx_get_field_index(const struct Map_info *, int);
+int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_cats_by_index(const struct Map_info *, int);
+int Vect_cidx_get_num_types_by_index(const struct Map_info *, int);
+int Vect_cidx_get_type_count_by_index(const struct Map_info *, int, int, int *,
 				      int *);
-int Vect_cidx_get_type_count(struct Map_info *, int, int);
-int Vect_cidx_get_cat_by_index(struct Map_info *, int, int, int *, int *,
+int Vect_cidx_get_type_count(const struct Map_info *, int, int);
+int Vect_cidx_get_cat_by_index(const struct Map_info *, int, int, int *, int *,
 			       int *);
-int Vect_cidx_find_next(struct Map_info *, int, int, int, int, int *, int *);
-void Vect_cidx_find_all(struct Map_info *, int, int, int, struct ilist *);
-int Vect_cidx_dump(struct Map_info *, FILE *);
+int Vect_cidx_find_next(const struct Map_info *, int, int, int, int, int *, int *);
+void Vect_cidx_find_all(const struct Map_info *, int, int, int, struct ilist *);
+int Vect_cidx_dump(const struct Map_info *, FILE *);
 int Vect_cidx_save(struct Map_info *);
 int Vect_cidx_open(struct Map_info *, int);
 /* Set/get map header info */
 int Vect_read_header(struct Map_info *);
-int Vect_write_header(struct Map_info *);
-const char *Vect_get_name(struct Map_info *);
-const char *Vect_get_mapset(struct Map_info *);
-const char *Vect_get_full_name(struct Map_info *);
-int Vect_is_3d(struct Map_info *);
+int Vect_write_header(const struct Map_info *);
+const char *Vect_get_name(const struct Map_info *);
+const char *Vect_get_mapset(const struct Map_info *);
+const char *Vect_get_full_name(const struct Map_info *);
+int Vect_is_3d(const struct Map_info *);
 int Vect_set_organization(struct Map_info *, const char *);
-const char *Vect_get_organization(struct Map_info *);
+const char *Vect_get_organization(const struct Map_info *);
 int Vect_set_date(struct Map_info *, const char *);
-const char *Vect_get_date(struct Map_info *);
+const char *Vect_get_date(const struct Map_info *);
 int Vect_set_person(struct Map_info *, const char *);
-const char *Vect_get_person(struct Map_info *);
+const char *Vect_get_person(const struct Map_info *);
 int Vect_set_map_name(struct Map_info *, const char *);
-const char *Vect_get_map_name(struct Map_info *);
+const char *Vect_get_map_name(const struct Map_info *);
 int Vect_set_map_date(struct Map_info *, const char *);
-const char *Vect_get_map_date(struct Map_info *);
+const char *Vect_get_map_date(const struct Map_info *);
 int Vect_set_comment(struct Map_info *, const char *);
-const char *Vect_get_comment(struct Map_info *);
+const char *Vect_get_comment(const struct Map_info *);
 int Vect_set_scale(struct Map_info *, int);
-int Vect_get_scale(struct Map_info *);
+int Vect_get_scale(const struct Map_info *);
 int Vect_set_zone(struct Map_info *, int);
-int Vect_get_zone(struct Map_info *);
-int Vect_get_proj(struct Map_info *);
-const char *Vect_get_proj_name(struct Map_info *);
+int Vect_get_zone(const struct Map_info *);
+int Vect_get_proj(const struct Map_info *);
+const char *Vect_get_proj_name(const struct Map_info *);
 int Vect_set_thresh(struct Map_info *, double);
-double Vect_get_thresh(struct Map_info *);
-int Vect_get_constraint_box(struct Map_info *, BOUND_BOX *);
+double Vect_get_thresh(const struct Map_info *);
+int Vect_get_constraint_box(const struct Map_info *, BOUND_BOX *);
 /* Get map level 2 informations */
-int Vect_level(struct Map_info *);
-int Vect_get_num_nodes(struct Map_info *);
-int Vect_get_num_primitives(struct Map_info *, int);
-int Vect_get_num_lines(struct Map_info *);
-int Vect_get_num_areas(struct Map_info *);
-int Vect_get_num_faces(struct Map_info *);
-int Vect_get_num_islands(struct Map_info *);
-int Vect_get_line_box(struct Map_info *, int, BOUND_BOX *);
-int Vect_get_area_box(struct Map_info *, int, BOUND_BOX *);
-int Vect_get_isle_box(struct Map_info *, int, BOUND_BOX *);
-int Vect_get_map_box(struct Map_info *, BOUND_BOX *);
+int Vect_level(const struct Map_info *);
+int Vect_get_num_nodes(const struct Map_info *);
+int Vect_get_num_primitives(const struct Map_info *, int);
+int Vect_get_num_lines(const struct Map_info *);
+int Vect_get_num_areas(const struct Map_info *);
+int Vect_get_num_faces(const struct Map_info *);
+int Vect_get_num_islands(const struct Map_info *);
+int Vect_get_line_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_area_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_isle_box(const struct Map_info *, int, BOUND_BOX *);
+int Vect_get_map_box(const struct Map_info *, BOUND_BOX *);
 int V__map_overlap(struct Map_info *, double, double, double, double);
 void Vect_set_release_support(struct Map_info *);
 void Vect_set_category_index_update(struct Map_info *);
@@ -211,9 +211,9 @@
 int Vect_open_new(struct Map_info *, const char *, int);
 int Vect_open_update(struct Map_info *, const char *, const char *);
 int Vect_open_update_head(struct Map_info *, const char *, const char *);
-int Vect_copy_head_data(struct Map_info *, struct Map_info *);
+int Vect_copy_head_data(const struct Map_info *, struct Map_info *);
 int Vect_build(struct Map_info *);
-int Vect_get_built(struct Map_info *);
+int Vect_get_built(const struct Map_info *);
 int Vect_build_partial(struct Map_info *, int);
 int Vect_set_constraint_region(struct Map_info *, double, double, double,
@@ -224,71 +224,71 @@
 /* Read/write lines, nodes, areas */
 /* Level 1 and 2 */
-int Vect_read_next_line(struct Map_info *, struct line_pnts *,
+int Vect_read_next_line(const struct Map_info *, struct line_pnts *,
-off_t Vect_write_line(struct Map_info *, int, struct line_pnts *,
-		     struct line_cats *);
+off_t Vect_write_line(struct Map_info *, int, const struct line_pnts *,
+		      const struct line_cats *);
-int Vect_get_num_dblinks(struct Map_info *);
+int Vect_get_num_dblinks(const struct Map_info *);
 /* Level 2 only */
-int Vect_read_line(struct Map_info *, struct line_pnts *, struct line_cats *,
+int Vect_read_line(const struct Map_info *, struct line_pnts *, struct line_cats *,
 		   int);
-int Vect_rewrite_line(struct Map_info *, int, int, struct line_pnts *,
+int Vect_rewrite_line(struct Map_info *, int, int, const struct line_pnts *,
 int Vect_delete_line(struct Map_info *, int);
 int Vect_restore_line(struct Map_info *, int, off_t);
-int Vect_line_alive(struct Map_info *, int);
-int Vect_node_alive(struct Map_info *, int);
-int Vect_area_alive(struct Map_info *, int);
-int Vect_isle_alive(struct Map_info *, int);
-int Vect_get_line_nodes(struct Map_info *, int, int *, int *);
-int Vect_get_line_areas(struct Map_info *, int, int *, int *);
+int Vect_line_alive(const struct Map_info *, int);
+int Vect_node_alive(const struct Map_info *, int);
+int Vect_area_alive(const struct Map_info *, int);
+int Vect_isle_alive(const struct Map_info *, int);
+int Vect_get_line_nodes(const struct Map_info *, int, int *, int *);
+int Vect_get_line_areas(const struct Map_info *, int, int *, int *);
 off_t Vect_get_line_offset(const struct Map_info *, int);
-int Vect_get_node_coor(struct Map_info *, int, double *, double *, double *);
-int Vect_get_node_n_lines(struct Map_info *, int);
-int Vect_get_node_line(struct Map_info *, int, int);
-float Vect_get_node_line_angle(struct Map_info *, int, int);
+int Vect_get_node_coor(const struct Map_info *, int, double *, double *, double *);
+int Vect_get_node_n_lines(const struct Map_info *, int);
+int Vect_get_node_line(const struct Map_info *, int, int);
+float Vect_get_node_line_angle(const struct Map_info *, int, int);
-int Vect_get_area_points(struct Map_info *, int, struct line_pnts *);
-int Vect_get_area_centroid(struct Map_info *, int);
-int Vect_get_area_num_isles(struct Map_info *, int);
-int Vect_get_area_isle(struct Map_info *, int, int);
-double Vect_get_area_area(struct Map_info *, int);
-int Vect_get_area_boundaries(struct Map_info *, int, struct ilist *);
+int Vect_get_area_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_area_centroid(const struct Map_info *, int);
+int Vect_get_area_num_isles(const struct Map_info *, int);
+int Vect_get_area_isle(const struct Map_info *, int, int);
+double Vect_get_area_area(const struct Map_info *, int);
+int Vect_get_area_boundaries(const struct Map_info *, int, struct ilist *);
-int Vect_get_isle_points(struct Map_info *, int, struct line_pnts *);
-int Vect_get_isle_area(struct Map_info *, int);
-int Vect_get_isle_boundaries(struct Map_info *, int, struct ilist *);
+int Vect_get_isle_points(const struct Map_info *, int, struct line_pnts *);
+int Vect_get_isle_area(const struct Map_info *, int);
+int Vect_get_isle_boundaries(const struct Map_info *, int, struct ilist *);
-int Vect_get_centroid_area(struct Map_info *, int);
+int Vect_get_centroid_area(const struct Map_info *, int);
 /* Level 2 update only */
-int Vect_get_num_updated_lines(struct Map_info *);
-int Vect_get_updated_line(struct Map_info *, int);
-int Vect_get_num_updated_nodes(struct Map_info *);
-int Vect_get_updated_node(struct Map_info *, int);
+int Vect_get_num_updated_lines(const struct Map_info *);
+int Vect_get_updated_line(const struct Map_info *, int);
+int Vect_get_num_updated_nodes(const struct Map_info *);
+int Vect_get_updated_node(const struct Map_info *, int);
 /* History */
 int Vect_hist_command(struct Map_info *);
 int Vect_hist_write(struct Map_info *, const char *);
-int Vect_hist_copy(struct Map_info *, struct Map_info *);
+int Vect_hist_copy(const struct Map_info *, struct Map_info *);
 void Vect_hist_rewind(struct Map_info *);
-char *Vect_hist_read(char *, int, struct Map_info *);
+char *Vect_hist_read(char *, int, const struct Map_info *);
 /* Selecting features */
-int Vect_select_lines_by_box(struct Map_info *, BOUND_BOX *, int,
+int Vect_select_lines_by_box(struct Map_info *, const BOUND_BOX *, int,
 			     struct ilist *);
-int Vect_select_areas_by_box(struct Map_info *, BOUND_BOX *, struct ilist *);
-int Vect_select_isles_by_box(struct Map_info *, BOUND_BOX *, struct ilist *);
-int Vect_select_nodes_by_box(struct Map_info *, BOUND_BOX *, struct ilist *);
+int Vect_select_areas_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_select_isles_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
+int Vect_select_nodes_by_box(struct Map_info *, const BOUND_BOX *, struct ilist *);
 int Vect_find_node(struct Map_info *, double, double, double, double, int);
 int Vect_find_line(struct Map_info *, double, double, double, int, double,
 		   int, int);
 int Vect_find_line_list(struct Map_info *, double, double, double, int,
-			double, int, struct ilist *, struct ilist *);
+			double, int, const struct ilist *, struct ilist *);
 int Vect_find_area(struct Map_info *, double, double);
 int Vect_find_island(struct Map_info *, double, double);
 int Vect_select_lines_by_polygon(struct Map_info *, struct line_pnts *, int,
@@ -297,21 +297,21 @@
 				 struct line_pnts **, struct ilist *);
 /* Analysis */
-int Vect_point_in_area(struct Map_info *, int, double, double);
+int Vect_point_in_area(const struct Map_info *, int, double, double);
 int Vect_tin_get_z(struct Map_info *, double, double, double *, double *,
 		   double *);
-int Vect_get_point_in_area(struct Map_info *, int, double *, double *);
+int Vect_get_point_in_area(const struct Map_info *, int, double *, double *);
 /* int Vect_point_in_islands (struct Map_info *, int, double, double); */
-int Vect_find_poly_centroid(struct line_pnts *, double *, double *);
-int Vect_get_point_in_poly_isl(struct line_pnts *, struct line_pnts **, int,
+int Vect_find_poly_centroid(const struct line_pnts *, double *, double *);
+int Vect_get_point_in_poly_isl(const struct line_pnts *, const struct line_pnts **, int,
-int Vect__intersect_line_with_poly(struct line_pnts *, double,
+int Vect__intersect_line_with_poly(const struct line_pnts *, double,
-int Vect_get_point_in_poly(struct line_pnts *, double *, double *);
-int Vect_point_in_poly(double, double, struct line_pnts *);
-int Vect_point_in_area_outer_ring(double, double, struct Map_info *, int);
-int Vect_point_in_island(double, double, struct Map_info *, int);
+int Vect_get_point_in_poly(const struct line_pnts *, double *, double *);
+int Vect_point_in_poly(double, double, const struct line_pnts *);
+int Vect_point_in_area_outer_ring(double, double, const struct Map_info *, int);
+int Vect_point_in_island(double, double, const struct Map_info *, int);
 /* Cleaning */
 void Vect_break_lines(struct Map_info *, int, struct Map_info *);
@@ -322,7 +322,7 @@
 int Vect_line_check_duplicate(const struct line_pnts *,
 void Vect_snap_lines(struct Map_info *, int, double, struct Map_info *);
-void Vect_snap_lines_list(struct Map_info *, struct ilist *, double,
+void Vect_snap_lines_list(struct Map_info *, const struct ilist *, double,
 			  struct Map_info *);
 void Vect_remove_dangles(struct Map_info *, int, double, struct Map_info *);
 void Vect_chtype_dangles(struct Map_info *, double, struct Map_info *);
@@ -355,8 +355,8 @@
 			 const char *, const char *, int, int);
 int Vect_net_shortest_path(struct Map_info *, int, int, struct ilist *,
 			   double *);
-int Vect_net_get_line_cost(struct Map_info *, int, int, double *);
-int Vect_net_get_node_cost(struct Map_info *, int, double *);
+int Vect_net_get_line_cost(const struct Map_info *, int, int, double *);
+int Vect_net_get_node_cost(const struct Map_info *, int, double *);
 int Vect_net_nearest_nodes(struct Map_info *, double, double, double, int,
 			   double, int *, int *, int *, double *, double *,
 			   struct line_pnts *, struct line_pnts *, double *);
@@ -367,18 +367,18 @@
 /* Miscellaneous */
-int Vect_topo_dump(struct Map_info *, FILE *);
+int Vect_topo_dump(const struct Map_info *, FILE *);
 double Vect_points_distance(double, double, double, double, double, double,
 			    int);
-int Vect_option_to_types(struct Option *);
+int Vect_option_to_types(const struct Option *);
 int Vect_copy_map_lines(struct Map_info *, struct Map_info *);
 int Vect_copy(const char *, const char *, const char *);
 int Vect_rename(const char *, const char *);
-int Vect_copy_table(struct Map_info *, struct Map_info *, int, int,
+int Vect_copy_table(const struct Map_info *, struct Map_info *, int, int,
 		    const char *, int);
-int Vect_copy_table_by_cats(struct Map_info *, struct Map_info *, int, int,
+int Vect_copy_table_by_cats(const struct Map_info *, struct Map_info *, int, int,
 			    const char *, int, int *, int);
-int Vect_copy_tables(struct Map_info *, struct Map_info *, int);
+int Vect_copy_tables(const struct Map_info *, struct Map_info *, int);
 int Vect_delete(const char *);
 int Vect_segment_intersection(double, double, double, double, double, double,
@@ -390,17 +390,17 @@
 int Vect_line_check_intersection(struct line_pnts *, struct line_pnts *, int);
 int Vect_line_get_intersections(struct line_pnts *, struct line_pnts *,
-char *Vect_subst_var(const char *str, struct Map_info *Map);
+char *Vect_subst_var(const char *, const struct Map_info *);
  * Internal functions, MUST NOT be used in modules
-int Vect_print_header(struct Map_info *);
+int Vect_print_header(const struct Map_info *);
 int Vect__init_head(struct Map_info *);
 /* Open/close/rewind map */
-int Vect_coor_info(struct Map_info *, struct Coor_info *);
-const char *Vect_maptype_info(struct Map_info *);
+int Vect_coor_info(const struct Map_info *, struct Coor_info *);
+const char *Vect_maptype_info(const struct Map_info *);
 int Vect_open_topo(struct Map_info *, int);
 int Vect_save_topo(struct Map_info *);
 int Vect_open_spatial_index(struct Map_info *);
@@ -409,7 +409,7 @@
 int Vect_build_sidx_from_topo(struct Map_info *);
 int Vect_build_spatial_index(struct Map_info *);
-int Vect__write_head(struct Map_info *);
+int Vect__write_head(const struct Map_info *);
 int Vect__read_head(struct Map_info *);
 int V1_open_old_nat(struct Map_info *, int);
 int V1_open_old_ogr(struct Map_info *, int);
@@ -442,18 +442,18 @@
 int V2_delete_line_nat(struct Map_info *, int);
 int V1_restore_line_nat(struct Map_info *, off_t);
 int V2_restore_line_nat(struct Map_info *, int, off_t);
-off_t V1_write_line_nat(struct Map_info *, int type, struct line_pnts *,
-off_t V2_write_line_nat(struct Map_info *, int type, struct line_pnts *,
+off_t V1_write_line_nat(struct Map_info *, int, const struct line_pnts *,
+off_t V2_write_line_nat(struct Map_info *, int, const struct line_pnts *,
 #if 0
-long V1_write_line_ogr(struct Map_info *, int type, struct line_pnts *,
+long V1_write_line_ogr(struct Map_info *, int, struct line_pnts *,
 #endif
-off_t V1_rewrite_line_nat(struct Map_info *, off_t offset, int type,
-			 struct line_pnts *, struct line_cats *);
-int V2_rewrite_line_nat(struct Map_info *, int line, int type,
+off_t V1_rewrite_line_nat(struct Map_info *, off_t, int,
+			  const struct line_pnts *, const struct line_cats *);
+int V2_rewrite_line_nat(struct Map_info *, int, int,
 #if 0
 long V1_rewrite_line_ogr(struct Map_info *, long offset, int type,
@@ -465,8 +465,8 @@
 int Vect_build_line_area(struct Map_info *, int, int);
 int Vect_isle_find_area(struct Map_info *, int);
 int Vect_attach_isle(struct Map_info *, int);
-int Vect_attach_isles(struct Map_info *, BOUND_BOX *);
-int Vect_attach_centroids(struct Map_info *, BOUND_BOX *);
+int Vect_attach_isles(struct Map_info *, const BOUND_BOX *);
+int Vect_attach_centroids(struct Map_info *, const BOUND_BOX *);
     /* GEOS support */
 #ifdef HAVE_GEOS
Modified: grass/trunk/include/vect/dig_externs.h
--- grass/trunk/include/vect/dig_externs.h	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/include/vect/dig_externs.h	2009-04-05 14:30:56 UTC (rev 36588)
@@ -56,14 +56,14 @@
 int dig__fread_port_I(int *, int, GVFILE *);
 int dig__fread_port_P(plus_t *, int, GVFILE *);
 int dig__fread_port_C(char *, int, GVFILE *);
-int dig__fwrite_port_D(double *, int, GVFILE *);
-int dig__fwrite_port_F(float *, int, GVFILE *);
-int dig__fwrite_port_O(off_t *, int, GVFILE *, int);
-int dig__fwrite_port_L(long *, int, GVFILE *);
-int dig__fwrite_port_S(short *, int, GVFILE *);
-int dig__fwrite_port_I(int *, int, GVFILE *);
-int dig__fwrite_port_P(plus_t *, int, GVFILE *);
-int dig__fwrite_port_C(char *, int, GVFILE *);
+int dig__fwrite_port_D(const double *, int, GVFILE *);
+int dig__fwrite_port_F(const float *, int, GVFILE *);
+int dig__fwrite_port_O(const off_t *, int, GVFILE *, int);
+int dig__fwrite_port_L(const long *, int, GVFILE *);
+int dig__fwrite_port_S(const short *, int, GVFILE *);
+int dig__fwrite_port_I(const int *, int, GVFILE *);
+int dig__fwrite_port_P(const plus_t *, int, GVFILE *);
+int dig__fwrite_port_C(const char *, int, GVFILE *);
@@ -81,7 +81,7 @@
 		   long);
 int dig_box_copy(BOUND_BOX *, BOUND_BOX *);
 int dig_box_extend(BOUND_BOX *, BOUND_BOX *);
-int dig_line_box(struct line_pnts *, BOUND_BOX *);
+int dig_line_box(const struct line_pnts *, BOUND_BOX *);
 int dig_line_set_box(struct Plus_head *, plus_t, BOUND_BOX *);
 int dig_line_get_box(struct Plus_head *, plus_t, BOUND_BOX *);
 int dig_area_set_box(struct Plus_head *, plus_t, BOUND_BOX *);
@@ -127,12 +127,12 @@
 int dig_add_node(struct Plus_head *, double, double, double);
 int dig_which_node(struct Plus_head *, double, double, double);
-int dig_add_line(struct Plus_head *, int, struct line_pnts *,
+int dig_add_line(struct Plus_head *, int, const struct line_pnts *,
 		 off_t);
 int dig_restore_line(struct Plus_head *, int, int, struct line_pnts *,
 		     off_t);
 int dig_del_line(struct Plus_head *, int);
-int dig_node_add_line(struct Plus_head *, int, int, struct line_pnts *, int);
+int dig_node_add_line(struct Plus_head *, int, int, const struct line_pnts *, int);
 float dig_node_line_angle(struct Plus_head *, int, int);
 int dig_node_angle_check(struct Plus_head *, int, int);
@@ -164,10 +164,10 @@
 int dig_spidx_del_area(struct Plus_head *, int);
 int dig_spidx_del_isle(struct Plus_head *, int);
-int dig_select_nodes(struct Plus_head *, BOUND_BOX *, struct ilist *);
-int dig_select_lines(struct Plus_head *, BOUND_BOX *, struct ilist *);
-int dig_select_areas(struct Plus_head *, BOUND_BOX *, struct ilist *);
-int dig_select_isles(struct Plus_head *, BOUND_BOX *, struct ilist *);
+int dig_select_nodes(struct Plus_head *, const BOUND_BOX *, struct ilist *);
+int dig_select_lines(struct Plus_head *, const BOUND_BOX *, struct ilist *);
+int dig_select_areas(struct Plus_head *, const BOUND_BOX *, struct ilist *);
+int dig_select_isles(struct Plus_head *, const BOUND_BOX *, struct ilist *);
 int dig_find_node(struct Plus_head *, double, double, double);
 int dig_spidx_init(struct Plus_head *);
Modified: grass/trunk/lib/vector/Vlib/area.c
--- grass/trunk/lib/vector/Vlib/area.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/area.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,11 +1,11 @@
    \file area.c
-   \brief Vector library - area feature related fns
+   \brief Vector library - area-related functions
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2008 by the GRASS Development Team
+   (C) 2001-2009 by the GRASS Development Team
    This program is free software under the
    GNU General Public License (>=v2).
@@ -13,9 +13,7 @@
    for details.
    \author Original author CERL, probably Dave Gerdes or Mike Higgins.
-   Update to GRASS 5.7 Radim Blazek and David D. Gray.
-   \date 2001-2008
+   \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
 #include <stdlib.h>
@@ -24,7 +22,7 @@
 #include <grass/glocale.h>
-   \brief Returns the polygon array of points in BPoints
+   \brief Returns polygon array of points of given area
    \param Map vector map
    \param area area id
@@ -34,11 +32,11 @@
    \return -1 on error
 int
-Vect_get_area_points(struct Map_info *Map,
+Vect_get_area_points(const struct Map_info *Map,
 		     int area, struct line_pnts *BPoints)
     int i, line, aline, dir;
-    struct Plus_head *Plus;
+    const struct Plus_head *Plus;
     P_AREA *Area;
     static int first_time = 1;
     static struct line_pnts *Points;
@@ -86,20 +84,21 @@
+   \brief Returns polygon array of points for given isle
    \param isle island id
    \param[out] BPoints points array
-   \return number of points or -1 on error
+   \return number of points
+   \return -1 on error
 int
-Vect_get_isle_points(struct Map_info *Map,
+Vect_get_isle_points(const struct Map_info *Map,
 		     int isle, struct line_pnts *BPoints)
     P_ISLE *Isle;
@@ -142,7 +141,7 @@
-   \brief Returns centroid number of area
+   \brief Returns centroid id for given area
    \param area area id
@@ -150,9 +149,9 @@
    \return centroid number of area
    \return 0 if no centroid found
-int Vect_get_area_centroid(struct Map_info *Map, int area)
+int Vect_get_area_centroid(const struct Map_info *Map, int area)
     P_AREA *Area;
     G_debug(3, "Vect_get_area_centroid(): area = %d", area);
@@ -167,19 +166,19 @@
-   \brief Creates list of boundaries for area
+   \brief Creates list of boundaries for given area
    \param area area id
-   \param List pointer to list of boundaries
+   \param[out] List pointer to list of boundaries
    \return number of boundaries
 int
-Vect_get_area_boundaries(struct Map_info *Map, int area, struct ilist *List)
+Vect_get_area_boundaries(const struct Map_info *Map, int area, struct ilist *List)
     int i, line;
     P_AREA *Area;
     G_debug(3, "Vect_get_area_boundaries(): area = %d", area);
@@ -201,19 +200,19 @@
-   \brief Creates list of boundaries for isle
+   \brief Creates list of boundaries for given isle
    \param isle island number
-   \param List pointer to list where boundaries are stored
+   \param[out] List pointer to list where boundaries are stored
 int
-Vect_get_isle_boundaries(struct Map_info *Map, int isle, struct ilist *List)
+Vect_get_isle_boundaries(const struct Map_info *Map, int isle, struct ilist *List)
     int i, line;
     P_ISLE *Isle;
     G_debug(3, "Vect_get_isle_boundaries(): isle = %d", isle);
@@ -224,7 +223,7 @@
     Isle = Plus->Isle[isle];
     if (Isle == NULL)
-	G_fatal_error("Attempt to read topo for dead isle (%d)", isle);
+	G_fatal_error(_("Attempt to read topo for dead isle (%d)"), isle);
     for (i = 0; i < Isle->n_lines; i++) {
 	line = Isle->lines[i];
@@ -235,7 +234,7 @@
-   \brief Returns number of isles for area
+   \brief Returns number of isles for given area
    \param area area id
@@ -243,9 +242,9 @@
    \return number of isles for area
    \return 0 if area not found
-int Vect_get_area_num_isles(struct Map_info *Map, int area)
+int Vect_get_area_num_isles(const struct Map_info *Map, int area)
     P_AREA *Area;
     G_debug(3, "Vect_get_area_num_isles(): area = %d", area);
@@ -263,18 +262,18 @@
-   \brief Returns isle for area
+   \brief Returns isle id for area
    \param area area id
-   \param isle isle id
+   \param isle isle index (0 .. nisles - 1)
-   \return isles for area
+   \return isle id
    \return 0 if no isle found
-int Vect_get_area_isle(struct Map_info *Map, int area, int isle)
+int Vect_get_area_isle(const struct Map_info *Map, int area, int isle)
     P_AREA *Area;
     G_debug(3, "Vect_get_area_isle(): area = %d isle = %d", area, isle);
@@ -291,17 +290,17 @@
-   \brief Returns area for isle
+   \brief Returns area id for isle
    \param Map vector
-   \param isle island number
+   \param isle isle number (0 .. nisles - 1)
    \return area id
    \return 0 area not found
-int Vect_get_isle_area(struct Map_info *Map, int isle)
+int Vect_get_isle_area(const struct Map_info *Map, int isle)
     P_ISLE *Isle;
     G_debug(3, "Vect_get_isle_area(): isle = %d", isle);
@@ -325,14 +324,14 @@
    \return area perimeter
-double Vect_area_perimeter(struct line_pnts *Points)
+double Vect_area_perimeter(const struct line_pnts *Points)
     return Vect_line_length(Points);
-   \brief Returns 1 if point is in area
+   \brief Check if point is in area
    \param area area id
@@ -341,10 +340,10 @@
    \return 1 if point is in area
    \return 0 if not
-int Vect_point_in_area(struct Map_info *Map, int area, double x, double y)
+int Vect_point_in_area(const struct Map_info *Map, int area, double x, double y)
     int i, isle;
     P_AREA *Area;
     int poly;
@@ -376,9 +375,9 @@
    \return area of area without areas of isles
-double Vect_get_area_area(struct Map_info *Map, int area)
+double Vect_get_area_area(const struct Map_info *Map, int area)
     P_AREA *Area;
     double size;
@@ -419,10 +418,10 @@
    \param area area id
    \param[out] Cats list of categories
-   \return 0 OK centroid found (but may be without categories)
+   \return 0 centroid found (but may be without categories)
    \return 1 no centroid found
-int Vect_get_area_cats(struct Map_info *Map, int area, struct line_cats *Cats)
+int Vect_get_area_cats(const struct Map_info *Map, int area, struct line_cats *Cats)
     int centroid;
@@ -450,7 +449,7 @@
    \return first found category of given field
    \return -1 no centroid or no category found
-int Vect_get_area_cat(struct Map_info *Map, int area, int field)
+int Vect_get_area_cat(const struct Map_info *Map, int area, int field)
     int i;
     static struct line_cats *Cats = NULL;
Modified: grass/trunk/lib/vector/Vlib/array.c
--- grass/trunk/lib/vector/Vlib/array.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/array.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,11 +1,11 @@
    \file array.c
-   \brief Vector library - array structure
+   \brief Vector library - category array
@@ -13,8 +13,6 @@
    for details.
    \author Radim Blazek
-   \date 2001-2008
 #include <stdlib.h>
@@ -62,27 +60,27 @@
-   \brief Set values in 'varray' to 'value'.
+   \brief Set values in 'varray' to 'value' from category string.
-   If category of object of given type is in 'cstring' (string
-   representing category list like: '1,3,5-7').  'type' may be either:
-   GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
+   If category of object of given type is in <em>cstring</em> (string
+   representing category list like: '1,3,5-7'). <em>type</em> may be
+   either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
-   Array is not reset to zero before, but old values (if any > 0) are overwritten.
-   Array must be initialised by Vect_new_varray(size) call.
+   Array is not reset to zero before, but old values (if any > 0) are
+   overwritten.  Array must be initialised by Vect_new_varray() call.
    \param field layer number
    \param cstring pointer to string with categories
    \param type feature type
    \param value value to set up
-   \param[in,out] varray varray structure to modify
+   \param[out] varray varray structure to modify
    \return number of items set
    \return -1 on error
 int
-Vect_set_varray_from_cat_string(struct Map_info *Map, int field,
+Vect_set_varray_from_cat_string(const struct Map_info *Map, int field,
 				const char *cstring, int type, int value,
 				VARRAY * varray)
@@ -96,7 +94,7 @@
     ret = Vect_str_to_cat_list(cstring, Clist);
     if (ret > 0)
-	G_warning(_("%d errors in category string."), ret);
+	G_warning(_("%d errors in category string"), ret);
     G_debug(4, "  %d ranges in clist", Clist->n_ranges);
@@ -109,27 +107,27 @@
+   \brief Set values in 'varray' to 'value' from category list
-   If category of object of given type is in 'clist' (category list).
-   'type' may be either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY |
-   GV_CENTROID
+   If category of object of given type is in <em>clist</em> (category
+   list).  <em>type</em> may be either: GV_AREA or: GV_POINT | GV_LINE
+   | GV_BOUNDARY | GV_CENTROID
    \param clist list of categories
    \return -1 on error
 int
-Vect_set_varray_from_cat_list(struct Map_info *Map, int field,
+Vect_set_varray_from_cat_list(const struct Map_info *Map, int field,
 			      struct cat_list *clist, int type, int value,
 			      VARRAY * varray)
@@ -228,27 +226,28 @@
+   \brief Set values in 'varray' to 'value' from DB (where statement)
-   if category of object of given type is in categories selected from
-   DB based on where statement (given without where).  'type' may be
-   either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY | GV_CENTROID
+   I category of object of given type is in categories selected from
+   DB based on where statement (given without where). <em>type</em>
+   may be either: GV_AREA or: GV_POINT | GV_LINE | GV_BOUNDARY |
+   GV_CENTROID
-   overwritten. Array must be initialised by Vect_new_varray(size) call.
    \param where where statement
    \return -1 on error
 int
-Vect_set_varray_from_db(struct Map_info *Map, int field, const char *where,
+Vect_set_varray_from_db(const struct Map_info *Map, int field, const char *where,
 			int type, int value, VARRAY * varray)
     int i, n, c, centr, cat, *cats;
Modified: grass/trunk/lib/vector/Vlib/box.c
--- grass/trunk/lib/vector/Vlib/box.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/box.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,11 +1,11 @@
    \file box.c
-   \brief Vector library - bounding box related fns
+   \brief Vector library - bounding box
@@ -13,8 +13,6 @@
    for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -30,7 +28,7 @@
    \return 1 point is in box
    \return 0 point is not in box
-int Vect_point_in_box(double x, double y, double z, BOUND_BOX * Box)
+int Vect_point_in_box(double x, double y, double z, const BOUND_BOX * Box)
     if (x >= Box->W && x <= Box->E &&
@@ -50,7 +48,7 @@
    \return 1 boxes overlap
    \return 0 boxes do not overlap
-int Vect_box_overlap(BOUND_BOX * A, BOUND_BOX * B)
+int Vect_box_overlap(const BOUND_BOX * A, const BOUND_BOX * B)
     if (A->E < B->W || A->W > B->E ||
@@ -69,7 +67,7 @@
    \return 1
-int Vect_box_copy(BOUND_BOX * A, BOUND_BOX * B)
+int Vect_box_copy(BOUND_BOX * A, const BOUND_BOX * B)
     A->N = B->N;
@@ -90,7 +88,7 @@
    \return 1
-int Vect_box_extend(BOUND_BOX * A, BOUND_BOX * B)
+int Vect_box_extend(BOUND_BOX * A, const BOUND_BOX * B)
     if (B->N > A->N)
@@ -113,18 +111,18 @@
  * \brief Clip coordinates to box, if necessary, lines extending outside of a box.
- * A line represented by the coordinates <b>x, y</b> and <b>c_x, c_y</b> is clipped to
- * the window defined by <b>s</b> (south), <b>n</b> (north), <b>w</b>
- * (west), and <b>e</b> (east). Note that the following constraints must be
+ * A line represented by the coordinates <em>x, y</em> and <em>c_x, c_y</em> is clipped to
+ * the window defined by <em>s</em> (south), <em>n</em> (north), <em>w</em>
+ * (west), and <em>e</em> (east). Note that the following constraints must be
  * true:
  * w <e
  * s <n
- * The <b>x</b> and <b>c_x</b> are values to be compared to <b>w</b> and
- * <b>e.</b> The <b>y</b> and <b>c_y</b> are values to be compared to
- * <b>s</b> and <b>n.</b>
- * The <b>x</b> and <b>c_x</b> values returned lie between <b>w</b> and
- * <b>e.</b> The <b>y</b> and <b>c_y</b> values returned lie between
+ * The <em>x</em> and <em>c_x</em> are values to be compared to <em>w</em> and
+ * <em>e.</em> The <em>y</em> and <em>c_y</em> are values to be compared to
+ * <em>s</em> and <em>n.</em>
+ * The <em>x</em> and <em>c_x</em> values returned lie between <em>w</em> and
+ * <em>e.</em> The <em>y</em> and <em>c_y</em> values returned lie between
  *  \param x, y coordinates (w, e)
  *  \param c_x,c_y coordinates (s, n)
@@ -135,7 +133,7 @@
 int
-Vect_box_clip(double *x, double *y, double *c_x, double *c_y, BOUND_BOX * Box)
+Vect_box_clip(double *x, double *y, double *c_x, double *c_y, const BOUND_BOX * Box)
     int mod;
@@ -196,18 +194,18 @@
-   \brief Get boundary box of line
+   \brief Get bounding box of given feature
-   \param line line id
+   \param line feature id
    \param[out] Box bounding box
    \return 1 on success
    \return 0 line is dead
-int Vect_get_line_box(struct Map_info *Map, int line, BOUND_BOX * Box)
+int Vect_get_line_box(const struct Map_info *Map, int line, BOUND_BOX * Box)
     P_LINE *Line;
     Plus = &(Map->plus);
@@ -235,7 +233,7 @@
-   \brief Get boundary box of area
+   \brief Get bounding box of area
    \param area area id
@@ -244,9 +242,9 @@
    \return 0 area is dead
-int Vect_get_area_box(struct Map_info *Map, int area, BOUND_BOX * Box)
+int Vect_get_area_box(const struct Map_info *Map, int area, BOUND_BOX * Box)
     P_AREA *Area;
@@ -274,7 +272,7 @@
-   \brief Get boundary box of isle
+   \brief Get bounding box of isle
    \param isle isle id
@@ -283,9 +281,9 @@
    \return 0 isle is dead
-int Vect_get_isle_box(struct Map_info *Map, int isle, BOUND_BOX * Box)
+int Vect_get_isle_box(const struct Map_info *Map, int isle, BOUND_BOX * Box)
     P_ISLE *Isle;
@@ -313,16 +311,17 @@
-   \brief Get boundary box of map
+   \brief Get bounding box of map (all features in the map)
    \param[out] Box bouding box
-   \return 1 on success, 0 on error
+   \return 1 on success
+   \return 0 on error
-int Vect_get_map_box(struct Map_info *Map, BOUND_BOX * Box)
+int Vect_get_map_box(const struct Map_info *Map, BOUND_BOX * Box)
@@ -338,14 +337,15 @@
-   \brief Copy region Window to Box
+   \brief Copy region window to bounding box
    \param Window region structure (raster-based)
    \param[out] Box boundary box (vector-based)
-int Vect_region_box(struct Cell_head *Window, BOUND_BOX * Box)
+int Vect_region_box(const struct Cell_head *Window, BOUND_BOX * Box)
     Box->N = Window->north;
Modified: grass/trunk/lib/vector/Vlib/break_lines.c
--- grass/trunk/lib/vector/Vlib/break_lines.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/break_lines.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,7 +3,7 @@
  * \brief Vector library - Clean vector map (break lines)
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2009 by the GRASS Development Team
  * This program is free software under the
  * GNU General Public License (>=v2).
@@ -11,8 +11,6 @@
  * for details.
  * \author Radim Blazek
- * \date 2001
 #include <stdlib.h>
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -12,9 +12,8 @@
    Read the file COPYING that comes with GRASS
    for details.
-   \author Radim Blazek, update for GRASS 7 Markus Metz
-   \date 2001-2008
+   \author Radim Blazek
+   \author Update for GRASS 7 Markus Metz
 #include <stdlib.h>
@@ -60,7 +59,7 @@
 /* function used by binary tree to compare items */
-int compare_xpnts(const void *Xpnta, const void *Xpntb)
+static int compare_xpnts(const void *Xpnta, const void *Xpntb)
     XPNT *a, *b;
@@ -80,20 +79,22 @@
 	    return 0;
-    G_warning("Break polygons: Bug in binary tree!");
+    G_warning(_("Break polygons: Bug in binary tree!"));
     return 1;
    \brief Break polygons in vector map.
-   Breaks lines specified by type in vector map. Points at intersections may be optionally
-   written to error map. Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+   Breaks lines specified by type in vector map. Points at
+   intersections may be optionally written to error map. Input map
+   must be opened on level 2 for update at least on GV_BUILD_BASE.
-   Function is optimized for closed polygons rigs (e.g. imported from OGR) but with clean geometry -
-   adjacent polygons mostly have identical boundary. Function creates database of ALL points
-   in the map, and then is looking for those where polygons should be broken.
-   Lines may be broken only at points existing in input map!
+   Function is optimized for closed polygons rigs (e.g. imported from
+   OGR) but with clean geometry - adjacent polygons mostly have
+   identical boundary. Function creates database of ALL points in the
+   map, and then is looking for those where polygons should be broken.
+   Lines may be broken only at points existing in input map!
    \param Map input map where polygons will be broken
    \param type type of line to be broken
Modified: grass/trunk/lib/vector/Vlib/bridges.c
--- grass/trunk/lib/vector/Vlib/bridges.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/bridges.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,7 +5,7 @@
@@ -13,8 +13,6 @@
    for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -28,18 +26,17 @@
    \brief Remove bridges from vector map.
-   Remove bridges (type boundary) connecting areas to islands or 2 islands.
-   Islands and areas must be already clean, i.e. without dangles.
-   Bridge may be formed by more lines.
-   Optionally deleted bridges are written to error map.
-   Input map must be opened on level 2 for update at least on level GV_BUILD_BASE
+   Remove bridges (type boundary) connecting areas to islands or 2
+   islands.  Islands and areas must be already clean, i.e. without
+   dangles.  Bridge may be formed by more lines.  Optionally deleted
+   bridges are written to error map.  Input map must be opened on
+   level 2 for update at least on level GV_BUILD_BASE
    \param Map input map where bridges are deleted
    \param Err vector map where deleted bridges are written or NULL
    \return
 void
 Vect_remove_bridges(struct Map_info *Map, struct Map_info *Err)
@@ -49,11 +46,12 @@
    \brief Change type of bridges in vector map.
-   Change the type of bridges (type boundary) connecting areas to islands or 2 islands.
-   Optionally changed bridges are written to error map.
-   Input map must be opened on level 2 for update at least on level GV_BUILD_BASE.
+   Change the type of bridges (type boundary) connecting areas to
+   islands or 2 islands. Islands and areas must be already clean,
+   i.e. without dangles. Bridge may be formed by more lines.
+   Optionally changed bridges are written to error map.  Input map
+   must be opened on level 2 for update at least on level
+   GV_BUILD_BASE.
    \param Map input map where bridges are changed
    \param Err vector map where changed bridges are written or NULL
Modified: grass/trunk/lib/vector/Vlib/buffer.c
--- grass/trunk/lib/vector/Vlib/buffer.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/buffer.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,16 @@
+   See buffer2.c for replacement.
    for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -342,6 +342,8 @@
    \brief Create parrallel line
+   This function is replaced by Vect_line_parallel2().
    \param InPoints input line
    \param distance create parrallel line in distance
    \param tolerance maximum distance between theoretical arc and polygon segments
@@ -368,16 +370,18 @@
    \brief Create buffer around the line line.
-   Buffer is closed counter clockwise polygon.
-   Warning: output line may contain loops!
+   This function is replaced by Vect_line_buffer().
+   Buffer is closed counter clockwise polygon. Warning: output line
+   may contain loops!
    \param distance create buffer in distance
    \param[out] OutPoints output line
 void
-Vect_line_buffer(struct line_pnts *InPoints, double distance,
+Vect_line_buffer(const struct line_pnts *InPoints, double distance,
 		 double tolerance, struct line_pnts *OutPoints)
     double dangle;
Modified: grass/trunk/lib/vector/Vlib/buffer2.c
--- grass/trunk/lib/vector/Vlib/buffer2.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/buffer2.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,7 +5,7 @@
@@ -14,8 +14,6 @@
    \author Original author Radim Blazek (see buffer.c)
    \author Rewritten by Rosen Matev (Google Summer of Code 2008)
-   \date 2008
 #include <stdlib.h>
@@ -186,19 +184,12 @@
 			  double tol, struct line_pnts *nPoints)
     int i, j, res, np;
     double *x, *y;
     double tx, ty, vx, vy, wx, wy, nx, ny, mx, my, rx, ry;
     double vx1, vy1, wx1, wy1;
     double a0, b0, c0, a1, b1, c1;
     double phi1, phi2, delta_phi;
     double nsegments, angular_tol, angular_step;
     int inner_corner, turns360;
     G_debug(3, "parallel_line()");
@@ -347,21 +338,13 @@
     int i, j, res, np;
     double *x, *y;
     double angle0, angle1;
     G_debug(3, "convolution_line() side = %d", side);
@@ -454,9 +437,8 @@
 		/* no need to append point in this case */
 	    else
-		G_fatal_error
-		    ("unexpected result of line_intersection() res = %d",
-		     res);
+		G_fatal_error(_("Unexpected result of line_intersection() res = %d"),
+			      res);
 	if (round && (!inner_corner) && (!turns360 || caps)) {
@@ -509,29 +491,21 @@
     int j;
     int v;			/* current vertex number */
     int v0;
     int eside;			/* side of the current edge */
     double eangle;		/* current edge angle with Ox (according to the current direction) */
     struct pg_vertex *vert;	/* current vertex */
     struct pg_vertex *vert0;	/* last vertex */
     struct pg_edge *edge;	/* current edge; must be edge of vert */
     /*    int cs; *//* on which side are we turning along the contour */
     /* we will always turn right and dont need that one */
     double opt_angle, tangle;
     int opt_j, opt_side, opt_flag;
-    G_debug(3,
-	    "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d",
+    G_debug(3, "extract_contour(): v1=%d, v2=%d, side=%d, stop_at_line_end=%d",
 	    first->v1, first->v2, side, stop_at_line_end);
     Vect_reset_line(nPoints);
@@ -712,7 +686,6 @@
     int i, w;
     G_debug(3, "extract_inner_contour()");
@@ -749,13 +722,9 @@
 			double db, double dalpha)
     int i, np;
     double cx, cy;
     double delta, delta_k, k;
     double vx, vy, wx, wy, mx, my, nx, ny;
     double len, tx, ty, d, da2;
     G_debug(3, "point_in_buf()");
@@ -824,7 +793,6 @@
 static int get_polygon_orientation(const double *x, const double *y, int n)
     double x1, y1, x2, y2;
     double area;
     x2 = x[n - 1];
@@ -877,21 +845,14 @@
 			 int *inner_count)
     struct planar_graph *pg2;
     struct line_pnts *sPoints, *cPoints;
     struct line_pnts **arrPoints;
     int i, count = 0;
     int res, winding;
     int auto_side;
     int more = 8;
     int allocated = 0;
     double px, py;
     G_debug(3, "buffer_lines()");
@@ -995,23 +956,18 @@
    \param[out] inner_count number of holes
    \param[out] iPoints array of output polygon's holes (cw order)
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db,
+void Vect_line_buffer2(const struct line_pnts *Points, double da, double db,
 		       double dalpha, int round, int caps, double tol,
 		       struct line_pnts **oPoints,
 		       struct line_pnts ***iPoints, int *inner_count)
     struct planar_graph *pg;
     struct line_pnts *tPoints, *outer;
     struct line_pnts **isles;
     int isles_count = 0;
     int res, winding;
     int more = 8;
     int isles_allocated = 0;
     G_debug(2, "Vect_line_buffer()");
@@ -1060,21 +1016,17 @@
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db,
+void Vect_area_buffer2(const struct Map_info *Map, int area, double da, double db,
     int i, isle;
     int more = 8;
     G_debug(2, "Vect_area_buffer()");
Modified: grass/trunk/lib/vector/Vlib/build.c
--- grass/trunk/lib/vector/Vlib/build.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/build.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,7 +5,7 @@
@@ -13,9 +13,7 @@
    for details.
-   \date 2001-2008
 #include <stdlib.h>
 #include <stdio.h>
@@ -63,7 +61,7 @@
    \return current highest built level
-int Vect_get_built(struct Map_info *Map)
+int Vect_get_built(const struct Map_info *Map)
     return (Map->plus.built);
@@ -82,27 +80,30 @@
    - GV_BUILD_CENTROIDS - assign centroids to areas;
    - GV_BUILD_ALL - top level, the same as GV_BUILD_CENTROIDS.
-   If functions is called with build lower than current value of the Map, the level is downgraded to
-   requested value.
+   If functions is called with build lower than current value of the
+   Map, the level is downgraded to requested value.
-   All calls to Vect_write_line(), Vect_rewrite_line(), Vect_delete_line() respect the last value of
-   build used in this function.
+   All calls to Vect_write_line(), Vect_rewrite_line(),
+   Vect_delete_line() respect the last value of build used in this
+   function.
-   Values lower than GV_BUILD_ALL are supported only by GV_FORMAT_NATIVE,
-   other formats ignore build and build always GV_BUILD_ALL
+   Values lower than GV_BUILD_ALL are supported only by
+   GV_FORMAT_NATIVE, other formats ignore build and build always
+   GV_BUILD_ALL
-   Note that the functions has effect only if requested level is higher than current level, to rebuild
-   part of topology, call first downgrade and then upgrade, for example:
+   Note that the functions has effect only if requested level is
+   higher than current level, to rebuild part of topology, call first
+   downgrade and then upgrade, for example:
-   Vect_build()
-   Vect_build_partial(,GV_BUILD_BASE,)
-   Vect_build_partial(,GV_BUILD_AREAS,)
+   - Vect_build()
+   - Vect_build_partial(,GV_BUILD_BASE,)
+   - Vect_build_partial(,GV_BUILD_AREAS,)
    \param build highest level of build
 int Vect_build_partial(struct Map_info *Map, int build)
@@ -234,7 +235,8 @@
 int Vect_save_topo(struct Map_info *Map)
@@ -279,7 +281,7 @@
    \return 0 on error
-int Vect_topo_dump(struct Map_info *Map, FILE * out)
+int Vect_topo_dump(const struct Map_info *Map, FILE * out)
     int i, j, line, isle;
     P_NODE *Node;
@@ -287,7 +289,7 @@
     P_AREA *Area;
     P_ISLE *Isle;
     BOUND_BOX box;
-    struct Plus_head *plus;
+    const struct Plus_head *plus;
     plus = &(Map->plus);
@@ -322,9 +324,9 @@
 	    continue;
 	Line = plus->Line[i];
-	fprintf(out, "line = %d, type = %d, offset = %ld n1 = %d, n2 = %d, "
+	fprintf(out, "line = %d, type = %d, offset = %lu n1 = %d, n2 = %d, "
 		"left/area = %d, right = %d\n",
-		i, Line->type, Line->offset, Line->N1, Line->N2,
+		i, Line->type, (unsigned long) Line->offset, Line->N1, Line->N2,
 		Line->left, Line->right);
 	fprintf(out, "N,S,E,W,T,B: %f, %f, %f, %f, %f, %f\n", Line->N,
 		Line->S, Line->E, Line->W, Line->T, Line->B);
Modified: grass/trunk/lib/vector/Vlib/build_nat.c
--- grass/trunk/lib/vector/Vlib/build_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/build_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,7 +3,7 @@
    \brief Vector library - Building topology for native format
@@ -11,9 +11,7 @@
    for details.
-   \date 2001-2008
 #include <grass/config.h>
@@ -135,7 +133,7 @@
     int j, line, node, sel_area, first, area, poly;
     static int first_call = 1;
     P_LINE *Line;
     P_NODE *Node;
     P_ISLE *Isle;
@@ -297,14 +295,14 @@
-   \brief (Re)Attach isles to areas in given box
+   \brief (Re)Attach isles to areas in given bounding box
    \param Map_info vector map
    \param box bounding box
    \return 0
-int Vect_attach_isles(struct Map_info *Map, BOUND_BOX * box)
+int Vect_attach_isles(struct Map_info *Map, const BOUND_BOX * box)
     int i, isle;
     static int first = 1;
@@ -331,14 +329,14 @@
-   \brief (Re)Attach centroids to areas in given box
+   \brief (Re)Attach centroids to areas in given bouding box
    \return 0
-int Vect_attach_centroids(struct Map_info *Map, BOUND_BOX * box)
+int Vect_attach_centroids(struct Map_info *Map, const BOUND_BOX * box)
     int i, sel_area, centr;
Modified: grass/trunk/lib/vector/Vlib/build_ogr.c
--- grass/trunk/lib/vector/Vlib/build_ogr.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/build_ogr.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,7 +5,7 @@
@@ -13,8 +13,6 @@
    for details.
    \author Radim Blazek, Piero Cavalieri
-   \date 2001-2008
 #include <string.h>
@@ -266,8 +264,9 @@
 	/* create virtual centroid */
 	ret =
-	    Vect_get_point_in_poly_isl(Points[0], Points + 1, nRings - 1, &x,
-				       &y);
+	    Vect_get_point_in_poly_isl((const struct line_pnts *) Points[0],
+				       (const struct line_pnts **) Points + 1, nRings - 1,
+				       &x, &y);
 	if (ret < -1) {
 	    G_warning(_("Unable to calculate centroid for area %d"),
 		      outer_area);
Modified: grass/trunk/lib/vector/Vlib/cats.c
--- grass/trunk/lib/vector/Vlib/cats.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/cats.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -7,10 +7,8 @@
- * This program is free software under the
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General Public License
+ * (>=v2).  Read the file COPYING that comes with GRASS for details.
  * \author Original author CERL, probably Dave Gerdes or Mike
  * Higgins
@@ -72,7 +70,8 @@
-   \brief Frees all memory associated with line_cats structure, including the struct itself.
+   \brief Frees all memory associated with line_cats structure,
+   including the struct itself.
    \param p line_cats structure
@@ -92,7 +91,8 @@
-   \brief Add new field/cat to category structure if doesn't exist yet.
+   \brief Add new field/cat to category structure if doesn't exist
+   yet.
    \param[in] Cats line_cats structure
    \param[in] field layer number
@@ -145,16 +145,16 @@
    \brief Get first found category of given field.
-   'cat' is set to first category found or -1 if field was not found
+   <em>cat</em> is set to first category found or -1 if field was not found
-   \param[in] Cats line_cats structure
-   \param[in] field layer number
-   \param[in] cat pointer to variable where cat will be written
+   \param Cats line_cats structure
+   \param field layer number
+   \param[out] cat pointer to variable where cat will be written
    \return 1 found
    \return 0 layer does not exist
-int Vect_cat_get(struct line_cats *Cats, int field, int *cat)
+int Vect_cat_get(const struct line_cats *Cats, int field, int *cat)
     register int n;
@@ -188,7 +188,7 @@
    \return number of found categories
    \return -1 on invalid field
-int Vect_field_cat_get(struct line_cats *Cats, int field, struct ilist *cats)
+int Vect_field_cat_get(const struct line_cats *Cats, int field, struct ilist *cats)
     int n;
@@ -212,8 +212,8 @@
    \brief Delete all categories of given layer
+   \param[in,out] Cats line_cats structure
    \return 1 deleted
@@ -247,9 +247,9 @@
    \brief Delete field/cat from line_cats structure
-   \param[in] cat category to be deleted or -1 to delete all cats of given field
+   \param cat category to be deleted or -1 to delete all cats of given field
    \return 1 deleted
    \return 0 field/category number does not exist
@@ -423,13 +423,13 @@
    \brief Convert ordered array of integers to cat_list structure.
-   \param[in] vals array of integers
-   \param[in] nvals number of values
+   \param vals array of integers
+   \param nvals number of values
    \param[out] list result cat_list structure
    \return number of ranges
-int Vect_array_to_cat_list(int *vals, int nvals, struct cat_list *list)
+int Vect_array_to_cat_list(const int *vals, int nvals, struct cat_list *list)
     int i, range;
@@ -463,13 +463,13 @@
    \brief Check if category number is in list.
-   \param[in] cat category number
-   \param[in] list cat_list structure
+   \param cat category number
+   \param list cat_list structure
    \return TRUE if cat is in list
    \return FALSE if it is not
-int Vect_cat_in_cat_list(int cat, struct cat_list *list)
+int Vect_cat_in_cat_list(int cat, const struct cat_list *list)
     int i;
@@ -483,14 +483,14 @@
    \brief Check if category is in ordered array of integers.
-   \param[in] array ordered array of integers
-   \param[in] ncats number of categories in array
+   \param array ordered array of integers
+   \param ncats number of categories in array
-int Vect_cat_in_array(int cat, int *array, int ncats)
+int Vect_cat_in_array(int cat, const int *array, int ncats)
     int *i;
Modified: grass/trunk/lib/vector/Vlib/cindex.c
--- grass/trunk/lib/vector/Vlib/cindex.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/cindex.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,13 +5,12 @@
  * Higher level functions for reading/writing/manipulating vectors.
- * \author Radim Blazek
- * (C) 2001-2007 by the GRASS Development Team
- * This program is free software under the GNU General Public
- *              License (>=v2). Read the file COPYING that comes with GRASS
- *              for details.
+ * \author Radim Blazek
 #include <stdlib.h>
@@ -25,7 +24,7 @@
 static int cmp_cat(const void *pa, const void *pb);
-static void check_status(struct Map_info *Map)
+static void check_status(const struct Map_info *Map)
     if (!Map->plus.cidx_up_to_date)
 	G_fatal_error(_("Category index is not up to date"));
@@ -34,11 +33,11 @@
    \brief Get number of layer in category index
-   \param[in] Map vector map
+   \param Map vector map
    \return number of layers
-int Vect_cidx_get_num_fields(struct Map_info *Map)
+int Vect_cidx_get_num_fields(const struct Map_info *Map)
     check_status(Map);
@@ -48,12 +47,12 @@
    \brief Get layer number for given index
-   \param[in] index layer index: from 0 to Vect_cidx_get_num_fields() - 1
+   \param index layer index: from 0 to Vect_cidx_get_num_fields() - 1
    \return layer number
-int Vect_cidx_get_field_number(struct Map_info *Map, int index)
+int Vect_cidx_get_field_number(const struct Map_info *Map, int index)
     check_status(Map);
@@ -66,16 +65,16 @@
    \brief Get layer index for given layer number
    \return layer index
    \return -1 if not found
-int Vect_cidx_get_field_index(struct Map_info *Map, int field)
+int Vect_cidx_get_field_index(const struct Map_info *Map, int field)
     int i;
     G_debug(2, "Vect_cidx_get_field_index() field = %d", field);
@@ -93,13 +92,13 @@
    \brief Get number of unique categories for given layer index
-   \param[in] index layer number
+   \param index layer number
    \return number of unique categories
    \return -1 on error
-int Vect_cidx_get_num_unique_cats_by_index(struct Map_info *Map, int index)
+int Vect_cidx_get_num_unique_cats_by_index(const struct Map_info *Map, int index)
     check_status(Map);
@@ -112,13 +111,13 @@
    \brief Get number of categories for given layer index
    \return number of categories
    \return -1 on error
-int Vect_cidx_get_num_cats_by_index(struct Map_info *Map, int index)
+int Vect_cidx_get_num_cats_by_index(const struct Map_info *Map, int index)
     check_status(Map);
     if (index >= Map->plus.n_cidx)
@@ -130,13 +129,13 @@
    \brief Get number of types for given layer index
-   \param[in] field_index layer index
+   \param field_index layer index
    \return number of types
    \return -1 on error
-int Vect_cidx_get_num_types_by_index(struct Map_info *Map, int field_index)
+int Vect_cidx_get_num_types_by_index(const struct Map_info *Map, int field_index)
     check_status(Map);
     if (field_index >= Map->plus.n_cidx)
@@ -148,17 +147,17 @@
    \brief Get type count field index and type index
-   \param[in] type_index type index
+   \param type_index type index
    \param[out] type feature type
    \param[out] count number of items
-   \return 1 OK
    \return 0 on error
 int
-Vect_cidx_get_type_count_by_index(struct Map_info *Map, int field_index,
+Vect_cidx_get_type_count_by_index(const struct Map_info *Map, int field_index,
 				  int type_index, int *type, int *count)
     check_status(Map);
@@ -168,20 +167,20 @@
     *type = Map->plus.cidx[field_index].type[type_index][0];
     *count = Map->plus.cidx[field_index].type[type_index][1];
-    return (1);
+    return 1;
    \brief Get count of features of certain type by layer and type
-   \param[in] type feature type
+   \param type feature type
    \return feature count
    \return 0 if no features, no such field or no such type in cidx
-int Vect_cidx_get_type_count(struct Map_info *Map, int field, int type)
+int Vect_cidx_get_type_count(const struct Map_info *Map, int field, int type)
     int i, fi, count = 0;
@@ -211,18 +210,18 @@
    \brief Get number of categories for given field and category index
-   \param[in] cat_index category index
+   \param cat_index category index
    \param[out] cat category number
    \param[out] id feature id
-   \return 1 OK
    \return 0 on error
 int
-Vect_cidx_get_cat_by_index(struct Map_info *Map, int field_index,
+Vect_cidx_get_cat_by_index(const struct Map_info *Map, int field_index,
 			   int cat_index, int *cat, int *type, int *id)
     check_status(Map);		/* This check is slow ? */
@@ -254,11 +253,11 @@
    \brief Find next line/area id for given category, start_index and type_mask
-   \param[in] type_mask requested type
-   \param[in] start_index start search at this index (0 - whole category index)
+   \param type_mask requested type
+   \param start_index start search at this index (0 - whole category index)
    \param[out] type returned type
    \param[out] id returned line/area id
@@ -266,7 +265,7 @@
    \return -1 not found
 int
-Vect_cidx_find_next(struct Map_info *Map, int field_index, int cat,
+Vect_cidx_find_next(const struct Map_info *Map, int field_index, int cat,
 		    int type_mask, int start_index, int *type, int *id)
     int *catp, cat_index;
@@ -331,15 +330,15 @@
    \brief Gind all line/area id's for given category
-   \param[in] layer layer number
-   \param[in] type_mask type of objects to search for
+   \param layer layer number
+   \param type_mask type of objects to search for
    \param[out] lines array of ids of found lines/points
    \return
-void Vect_cidx_find_all(struct Map_info *Map, int layer, int type_mask,
+void Vect_cidx_find_all(const struct Map_info *Map, int layer, int type_mask,
 			int cat, struct ilist *lines)
     int type, line;
@@ -379,13 +378,13 @@
    \brief Write category index in text form to file
    \param[out] out output file
    \return 0 on error
-int Vect_cidx_dump(struct Map_info *Map, FILE * out)
+int Vect_cidx_dump(const struct Map_info *Map, FILE * out)
     int i, field, nfields, ntypes;
@@ -435,7 +434,7 @@
    \brief Save category index
    \return 0 on success
    \return 1 on error
@@ -477,8 +476,8 @@
    \brief Read category index from file if exists
-   \param[in] head_only Read only header
+   \param head_only Read only header
    \return 1 if file does not exist
@@ -508,8 +507,8 @@
     fp.file = G_fopen_old(buf, GV_CIDX_ELEMENT, Map->mapset);
     if (fp.file == NULL) {	/* category index file is not available */
-	G_warning(_("Unable to open category index file for vector map <%s@%s>"),
-		  Map->name, Map->mapset);
+	G_warning(_("Unable to open category index file for vector map <%s>"),
+		  Vect_get_full_name(Map));
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/clean_nodes.c
--- grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/clean_nodes.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   This program is free software under the
-   GNU General Public License (>=v2).
-   Read the file COPYING that comes with GRASS
-   for details.
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -25,13 +21,13 @@
    \brief Clean small angles at nodes.
-   It may happen that even if the angle between 2 boundaries at node is
-   very small, the calculated angle is 0 because of
-   representation error.  The map must be built at least on level
-   GV_BUILD_BASE
+   It may happen that even if the angle between 2 boundaries at node
+   is very small, the calculated angle is 0 because of representation
+   error. The map must be built at least on level GV_BUILD_BASE
-   \param Err vector map where error line segments are written
+   \param otype feature type
+   \param[out] Err vector map where error line segments are written
    \return number of line modifications
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/close.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,19 +5,15 @@
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/close_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,27 +1,30 @@
+   \file close_nat.c
-* MODULE:       Vector library
-* AUTHOR(S):    Original author CERL, probably Dave Gerdes or Mike Higgins.
-*               Update to GRASS 5.7 Radim Blazek and David D. Gray.
-* PURPOSE:      Higher level functions for reading/writing/manipulating vectors.
-* COPYRIGHT:    (C) 2001 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*   	    	License (>=v2). Read the file COPYING that comes with GRASS
-*   	    	for details.
+   \brief Vector library - Close map (native format)
+   Higher level functions for reading/writing/manipulating vectors.
+   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
 #include <grass/Vect.h>
 #include <stdlib.h>
- ** return 0 on success
- **        non-zero on error
+  \brief Close vector map file
+  \param Map vector map to be closed
+  \return 0 on success
+  \return non-zero on error
 int V1_close_nat(struct Map_info *Map)
     struct Coor_info CInfo;
Modified: grass/trunk/lib/vector/Vlib/close_ogr.c
--- grass/trunk/lib/vector/Vlib/close_ogr.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/close_ogr.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,29 +1,34 @@
+   \file close_ogr.c
-* AUTHOR(S):    Radim Blazek, Piero Cavalieri
-*   	    	for details.
+   \brief Vector library - Close map (OGR)
+   \author Update to GRASS 5.7 Radim Blazek and Piero Cavalieri.
+#include <stdlib.h>
-#include <stdlib.h>
+#include <grass/glocale.h>
 #ifdef HAVE_OGR
 #include <ogr_api.h>
+  \brief Close OGR layer
 int V1_close_ogr(struct Map_info *Map)
     int i;
@@ -43,21 +48,23 @@
 	Vect_destroy_line_struct(Map->fInfo.ogr.lines[i]);
-    free(Map->fInfo.ogr.lines);
-    free(Map->fInfo.ogr.lines_types);
+    G_free(Map->fInfo.ogr.lines);
+    G_free(Map->fInfo.ogr.lines_types);
-    free(Map->fInfo.ogr.dsn);
-    free(Map->fInfo.ogr.layer_name);
+    G_free(Map->fInfo.ogr.dsn);
+    G_free(Map->fInfo.ogr.layer_name);
     return 0;
- *  Write OGR specific files (fidx)
- *  return 0 on success
- *         non-zero on error
+  \brief Write OGR specific files (fidx)
 int V2_close_ogr(struct Map_info *Map)
     char fname[1000], elem[1000];
@@ -79,7 +86,7 @@
 	dig_file_init(&fp);
 	fp.file = fopen(fname, "w");
-	    G_warning("Can't open fidx file for write: %s\n", fname);
+	    G_warning(_("Unable to open fidx file for write <%s>"), fname);
 	    return 1;
@@ -114,7 +121,7 @@
-    free(Map->fInfo.ogr.offset);
+    G_free(Map->fInfo.ogr.offset);
     return 0;
Modified: grass/trunk/lib/vector/Vlib/constraint.c
--- grass/trunk/lib/vector/Vlib/constraint.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/constraint.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,33 +5,30 @@
-   These routines can affect the read_next_line funtions
-   by restricting what they return.
-   They are applied on a per map basis.
+   These routines can affect the read_next_line funtions by
+   restricting what they return. They are applied on a per map basis.
    These do not affect the lower level direct read functions.
-   Normally, All 'Alive' lines will be returned unless overridden
-   by this function.   You can specified all the types you are interested
-   in  (by oring their types together).  You can use this to say
-   exclude Area type lines.
+   Normally, all 'Alive' lines will be returned unless overridden by
+   this function. You can specified all the types you are interested
+   in (by oring their types together). You can use this to say exclude
+   Area type lines.
-   By default all DEAD lines are ignored by the read_next_line () functions
-   This too can be overridden by including their types.
+   By default all DEAD lines are ignored by the read_next_line ()
+   functions This too can be overridden by including their types.
-   Refer to  dig_defines for the line type Defines
+   Refer to dig_defines for the line type Defines
    All lines can be forced to be read by setting type = -1
-   for details.
    \date 2001-2008
@@ -54,9 +51,9 @@
 			   double b)
     if (n <= s)
-	return (-1);
+	return -1;
     if (e <= w)
-	return (-1);
+	return -1;
     Map->Constraint_region_flag = 1;
     Map->Constraint_N = n;
@@ -67,18 +64,18 @@
     Map->Constraint_B = b;
     Map->proj = G_projection();
-    return (0);
+    return 0;
    \brief Get constraint box
-   \param Box bounding box
+   \param[out] Box bounding box
-   \return 0 on success
+   \return 0
-int Vect_get_constraint_box(struct Map_info *Map, BOUND_BOX * Box)
+int Vect_get_constraint_box(const struct Map_info *Map, BOUND_BOX * Box)
     Box->N = Map->Constraint_N;
     Box->S = Map->Constraint_S;
@@ -96,7 +93,7 @@
    \param type constraint type
+   \return 0
 int Vect_set_constraint_type(struct Map_info *Map, int type)
@@ -111,7 +108,7 @@
+   \return 0
 int Vect_remove_constraints(struct Map_info *Map)
Modified: grass/trunk/lib/vector/Vlib/dangles.c
--- grass/trunk/lib/vector/Vlib/dangles.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/dangles.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,18 +5,14 @@
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
 #include <grass/gis.h>
@@ -32,21 +28,22 @@
    \brief Remove dangles from vector map.
-   Remove dangles of given type shorter than maxlength from vector map.
+   Remove dangles of given type shorter than maxlength from vector
+   map.
    Line is considered to be a dangle if on at least one end node is no
-   other line of given type(s).  If a dangle is formed by more lines,
+   other line of given type(s). If a dangle is formed by more lines,
    such string of lines is taken as one dangle and either deleted are
    all parts or nothing.
-   Optionally deleted dangles are written to error map.
+   Optionally deleted dangles are written to error map.
    Input map must be opened on level 2 for update.
    \param Map input map where have to be deleted
    \param type type of dangles (GV_LINES, GV_LINE or GV_BOUNDARY)
    \param maxlength maxlength of dangles or -1 for all dangles
-   \param Err vector map where deleted dangles are written or NULL
+   \param[out] Err vector map where deleted dangles are written or NULL
    \return
@@ -62,9 +59,9 @@
    Change boundary dangles to lines.
-   Boundary is considered to be a dangle if on at least one end node is
-   no other boundary.  If a dangle is formed by more boundaries, such
-   string of boundaries is taken as one dangle.
+   Boundary is considered to be a dangle if on at least one end node
+   is no other boundary. If a dangle is formed by more boundaries,
+   such string of boundaries is taken as one dangle.
@@ -72,7 +69,7 @@
    \return
@@ -97,6 +94,7 @@
+   \param[out] List list of selected features
    \return
Modified: grass/trunk/lib/vector/Vlib/dbcolumns.c
--- grass/trunk/lib/vector/Vlib/dbcolumns.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/dbcolumns.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,18 +5,14 @@
-   (C) 2005-2008 by the GRASS Development Team
+   (C) 2005-2009 by the GRASS Development Team
-   for details.
    \author Markus Neteler
-   \date 2005-2008
 #include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
@@ -37,7 +33,7 @@
    \return list of column(s) names on success
    \return NULL on error
-const char *Vect_get_column_names(struct Map_info *Map, int field)
+const char *Vect_get_column_names(const struct Map_info *Map, int field)
     int num_dblinks, ncols, col;
     struct field_info *fi;
@@ -96,7 +92,7 @@
    \return list of column(s) types on success
-const char *Vect_get_column_types(struct Map_info *Map, int field)
+const char *Vect_get_column_types(const struct Map_info *Map, int field)
@@ -158,7 +154,7 @@
    \retutn NULL on error
-const char *Vect_get_column_names_types(struct Map_info *Map, int field)
+const char *Vect_get_column_names_types(const struct Map_info *Map, int field)
Modified: grass/trunk/lib/vector/Vlib/dgraph.c
--- grass/trunk/lib/vector/Vlib/dgraph.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/dgraph.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,6 +1,22 @@
+   \file dgraph.c
+   \brief Vector library - intersection (lower level functions)
+   (C) 2008-2009 by the GRASS Development Team
+   \author Rewritten by Rosen Matev (Google Summer of Code 2008)
 #include <stdlib.h>
 #include "dgraph.h"
 #include "e_intersect.h"
@@ -80,7 +96,7 @@
 /* internal use */
 void add_ipoint1(struct seg_intersection_list *il, int with, double dist,
-		 int ip)
+			int ip)
     struct seg_intersection *s;
@@ -100,8 +116,8 @@
 /* adds intersection point to the structure */
-void add_ipoint(struct line_pnts *Points, int first_seg, int second_seg,
-		double x, double y, struct seg_intersections *si)
+void add_ipoint(const struct line_pnts *Points, int first_seg, int second_seg,
+		       double x, double y, struct seg_intersections *si)
     struct intersection_point *t;
@@ -134,7 +150,6 @@
 void sort_intersection_list(struct seg_intersection_list *il)
     int n, i, j, min;
     struct seg_intersection t;
     G_debug(4, "sort_intersection_list()");
@@ -158,7 +173,7 @@
     return;
-static int compare(const void *a, const void *b)
+int compare(const void *a, const void *b)
     struct intersection_point *aa, *bb;
@@ -199,20 +214,14 @@
 /* currently O(n*n); future implementation O(nlogn) */
-struct seg_intersections *find_all_intersections(struct line_pnts *Points)
+struct seg_intersections *find_all_intersections(const struct line_pnts *Points)
     int i, j, np;
     int group, t;
     int looped;
     double EPSILON = 0.00000001;
     double *x, *y;
     int res;
     /*int res2
@@ -371,9 +380,7 @@
 int pg_existsedge(struct planar_graph *pg, int v1, int v2)
     struct pg_vertex *v;
     struct pg_edge *e;
     int i, ecount;
     if (pg->v[v1].ecount <= pg->v[v2].ecount)
@@ -420,8 +427,8 @@
 	return;
     if (pg->ecount == pg->eallocated) {
-	G_fatal_error
-	    ("Trying to add more edges to the planar_graph than the initial allocation size allows");
+	G_fatal_error(_("Trying to add more edges to the planar_graph "
+			"than the initial allocation size allows"));
     e = &(pg->e[pg->ecount]);
     e->v1 = v1;
@@ -437,16 +444,12 @@
     return;
-struct planar_graph *pg_create(struct line_pnts *Points)
+struct planar_graph *pg_create(const struct line_pnts *Points)
     struct seg_intersections *si;
     struct intersection_point *ip;
     int i, j, t, v;
Modified: grass/trunk/lib/vector/Vlib/dgraph.h
--- grass/trunk/lib/vector/Vlib/dgraph.h	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/dgraph.h	2009-04-05 14:30:56 UTC (rev 36588)
@@ -33,6 +33,6 @@
 void pg_destroy_struct(struct planar_graph *pg);
 int pg_existsedge(struct planar_graph *pg, int v1, int v2);
 void pg_addedge(struct planar_graph *pg, int v1, int v2);
-struct planar_graph* pg_create(struct line_pnts *Points);
+struct planar_graph* pg_create(const struct line_pnts *Points);
 #endif
Modified: grass/trunk/lib/vector/Vlib/e_intersect.c
--- grass/trunk/lib/vector/Vlib/e_intersect.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/e_intersect.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,3 +1,18 @@
+   \file e_intersect.c
 #include <stdlib.h>
 #include <math.h>
@@ -17,9 +32,7 @@
 #ifdef ASDASDASFDSAFFDAS
 mpf_t p11, p12, p21, p22, t1, t2;
 mpf_t dd, dda, ddb, delta;
 mpf_t rra, rrb;
 int initialized = 0;
Modified: grass/trunk/lib/vector/Vlib/error.c
--- grass/trunk/lib/vector/Vlib/error.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/error.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,19 +5,15 @@
-   for details.
-   \date 2001-2008
 #include <string.h>
@@ -33,7 +29,7 @@
    \param  err error type
+   \return 0
 int Vect_set_fatal_error(int err)
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/field.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,22 +5,19 @@
-   TODO: see Vect_read_dblinks; activate auto-FID detection once
-   OGR_L_GetFIDColumn() is working or solution found if FID not available
+   \todo see Vect_read_dblinks(); activate auto-FID detection once
+   OGR_L_GetFIDColumn() is working or solution found if FID not
+   available
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
 #include <stdio.h>
 #include <string.h>
@@ -158,7 +155,7 @@
-   \brief Check if db connection exists in dblinks structure
+   \brief Check if DB connection exists in dblinks structure
@@ -166,13 +163,13 @@
    \return 1 dblink for field exists
    \return 0 dblink does not exist for field
-int Vect_map_check_dblink(struct Map_info *Map, int field)
+int Vect_map_check_dblink(const struct Map_info *Map, int field)
     return Vect_check_dblink(Map->dblnk, field);
    \param p pointer to existing dblinks structure
@@ -180,7 +177,7 @@
-int Vect_check_dblink(struct dblinks *p, int field)
+int Vect_check_dblink(const struct dblinks *p, int field)
     int i;
@@ -196,7 +193,7 @@
-   \brief Add new db connection to dblinks structure
+   \brief Add new DB connection to dblinks structure
    \param number layer number
@@ -205,7 +202,7 @@
    \param db database name
    \param driver driver name
-   \return 0 OK
    \return -1 error
 int
@@ -359,7 +356,7 @@
    \return pointer to new field_info structure
-struct field_info *Vect_get_dblink(struct Map_info *Map, int link)
+struct field_info *Vect_get_dblink(const struct Map_info *Map, int link)
@@ -390,8 +387,8 @@
    \brief Get information about link to database.
-   Variables are substituted by values,
-   field is number of requested field
+   Variables are substituted by values, field is number of requested
+   field
@@ -399,7 +396,7 @@
    \return NULL if not found
-struct field_info *Vect_get_field(struct Map_info *Map, int field)
+struct field_info *Vect_get_field(const struct Map_info *Map, int field)
     int i;
     struct field_info *fi = NULL;
@@ -668,7 +665,7 @@
-   \return 0 OK
    \return -1 on error
 int Vect_write_dblinks(struct Map_info *Map)
@@ -722,7 +719,7 @@
    \return pointer to new string
-char *Vect_subst_var(const char *in, struct Map_info *Map)
+char *Vect_subst_var(const char *in, const struct Map_info *Map)
     char *c;
     char buf[1000], str[1000];
@@ -767,9 +764,9 @@
    \brief Rewrite 'dbln' file
-   Should be used by GRASS modules which update
-   database tables, so that other applications know that tables
-   were changed and can reload data.
+   Should be used by GRASS modules which update database tables, so
+   that other applications know that tables were changed and can
+   reload data.
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/find.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,14 +5,14 @@
- * \author Original author CERL, probably Dave Gerdes or Mike
- * Higgins. Update to GRASS 5.7 Radim Blazek and David D. Gray.
- *              for details.
+ * \author Original author CERL, probably Dave Gerdes or Mike
+ * Higgins.
+ * \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
 #include <math.h>
@@ -26,10 +26,10 @@
  * \brief Find the nearest node.
- * \param[in] Map vector map
- * \param[in] ux,uy,uz point coordinates
- * \param[in] maxdist max distance from the line
- * \param[in] with_z 3D (WITH_Z, WITHOUT_Z)
+ * \param Map vector map
+ * \param ux,uy,uz point coordinates
+ * \param maxdist max distance from the line
+ * \param with_z 3D (WITH_Z, WITHOUT_Z)
  * \return number of nearest node
  * \return 0 if not found
@@ -92,20 +92,19 @@
  * \brief Find the nearest line.
- * \param[in] map vector map
- * \param[in] ux,uy,uz points coordinates
- * \param[in] type feature type (GV_LINE, GV_POINT, GV_BOUNDARY or GV_CENTROID)
+ * \param map vector map
+ * \param ux,uy,uz points coordinates
+ * \param type feature type (GV_LINE, GV_POINT, GV_BOUNDARY or GV_CENTROID)
  * if only want to search certain types of lines or -1 if search all lines
- * \param[in] exclude if > 0 number of line which should be excluded from selection.
+ * \param exclude if > 0 number of line which should be excluded from selection.
  * May be useful if we need line nearest to other one.
  * \return number of nearest line
-/* original dig_point_to_line() in grass50 */
 int
 Vect_find_line(struct Map_info *map,
 	       double ux, double uy, double uz,
@@ -129,14 +128,14 @@
  * \brief Find the nearest line(s).
- * \param[in] exclude list of lines which should be excluded from selection
- * \param[in] found list of found lines (or NULL)
+ * \param exclude list of lines which should be excluded from selection
+ * \param found list of found lines (or NULL)
@@ -145,7 +144,7 @@
 Vect_find_line_list(struct Map_info *map,
 		    int type, double maxdist, int with_z,
-		    struct ilist *exclude, struct ilist *found)
+		    const struct ilist *exclude, struct ilist *found)
     int choice;
     double new_dist;
@@ -154,7 +153,7 @@
     int i, line;
     BOUND_BOX box;
     struct ilist *List;
@@ -238,13 +237,12 @@
  * \brief Find the nearest area
- * \param[in] x,y point coordinates
+ * \param x,y point coordinates
  * \return area number
-/* original dig_point_to_area() in grass50 */
 int Vect_find_area(struct Map_info *Map, double x, double y)
     int i, ret, area;
@@ -285,13 +283,12 @@
  * \brief Find the nearest island
- * \param[in] x,y points coordinates
+ * \param x,y points coordinates
  * \return island number,
 int Vect_find_island(struct Map_info *Map, double x, double y)
     int i, ret, island, current, current_size, size;
Modified: grass/trunk/lib/vector/Vlib/geos.c
--- grass/trunk/lib/vector/Vlib/geos.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/geos.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -8,7 +8,7 @@
  * (C) 2009 by the GRASS Development Team
- * (>=v2).  Read the file COPYING that comes with GRASS for details.
  * \author Martin Landa <landa.martin gmail.com>
Modified: grass/trunk/lib/vector/Vlib/graph.c
--- grass/trunk/lib/vector/Vlib/graph.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/graph.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,18 +5,14 @@
-   TODO: Vect_graph_free ( GRAPH *graph )
+   \todo Vect_graph_free ( GRAPH *graph )
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -92,8 +88,8 @@
    \brief Build network graph.
    Internal format for edge costs is integer, costs are multiplied
-   before conversion to int by 1000.
-   Costs -1 for infinity i.e. arc or node is closed and cannot be traversed.
+   before conversion to int by 1000.  Costs -1 for infinity i.e. arc
+   or node is closed and cannot be traversed.
    \param graph poiter to graph structure
@@ -114,8 +110,8 @@
    \brief Add edge to graph.
-   before conversion to int by 1000.  Costs -1 for infinity i.e. arc or
-   node is closed and cannot be traversed.
    \param from from node
@@ -147,8 +143,8 @@
    \brief Set node costs
    \param node node id
Modified: grass/trunk/lib/vector/Vlib/header.c
--- grass/trunk/lib/vector/Vlib/header.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/header.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,13 @@
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -34,7 +30,7 @@
-int Vect_print_header(struct Map_info *Map)
+int Vect_print_header(const struct Map_info *Map)
     fprintf(stdout, "\nSelected information from dig header\n");
     fprintf(stdout, " Organization:  %s\n", Vect_get_organization(Map));
@@ -51,7 +47,7 @@
+   \return 0
 int Vect_read_header(struct Map_info *Map)
@@ -65,9 +61,9 @@
+   \return 0
-int Vect_write_header(struct Map_info *Map)
+int Vect_write_header(const struct Map_info *Map)
     /* do some sanity checking here */
     Vect__write_head(Map);
@@ -80,12 +76,12 @@
-   \return GRASS_OK - success
-   \return GRASS_ERR - error
+   \return GRASS_OK on success
+   \return GRASS_ERR on error
-int Vect__write_head(struct Map_info *Map)
+int Vect__write_head(const struct Map_info *Map)
-    char buf[200];
+    char buf[GPATH_MAX];
     FILE *head_fp;
     sprintf(buf, "%s/%s", GRASS_VECT_DIRECTORY, Map->name);
@@ -116,13 +112,13 @@
 int Vect__read_head(struct Map_info *Map)
     FILE *head_fp;
-    char buff[2001];
+    char buff[GPATH_MAX];
     char *ptr;
     /* Reset / init */
@@ -198,7 +194,7 @@
    \return poiter to map name
-const char *Vect_get_name(struct Map_info *Map)
+const char *Vect_get_name(const struct Map_info *Map)
     return (Map->name);
@@ -210,7 +206,7 @@
    \return poiter to mapset name
-const char *Vect_get_mapset(struct Map_info *Map)
+const char *Vect_get_mapset(const struct Map_info *Map)
     return (Map->mapset);
@@ -218,11 +214,12 @@
    \brief Get full map name
+   Allocated string should be freed by G_free().
    \return poiter to map name (name at mapset)
-const char *Vect_get_full_name(struct Map_info *Map)
+const char *Vect_get_full_name(const struct Map_info *Map)
     char *ptr;
@@ -239,7 +236,7 @@
    \return 1 map is 3D
    \return 0 map is not 3D
-int Vect_is_3d(struct Map_info *Map)
+int Vect_is_3d(const struct Map_info *Map)
     return (Map->head.with_z);
@@ -267,7 +264,7 @@
    \return organization string
-const char *Vect_get_organization(struct Map_info *Map)
+const char *Vect_get_organization(const struct Map_info *Map)
     return (Map->head.organization);
@@ -281,13 +278,14 @@
    \param str data string
+   \return 0
 int Vect_set_date(struct Map_info *Map, const char *str)
     G_free(Map->head.date);
     Map->head.date = G_store(str);
-    return (0);
+    return 0;
@@ -300,7 +298,7 @@
    \return date of digitization string
-const char *Vect_get_date(struct Map_info *Map)
+const char *Vect_get_date(const struct Map_info *Map)
     return (Map->head.date);
@@ -317,7 +315,8 @@
     G_free(Map->head.your_name);
     Map->head.your_name = G_store(str);
-    return (0);
+    return 0;
@@ -327,7 +326,7 @@
    \return user name string
-const char *Vect_get_person(struct Map_info *Map)
+const char *Vect_get_person(const struct Map_info *Map)
     return (Map->head.your_name);
@@ -344,7 +343,8 @@
     G_free(Map->head.map_name);
     Map->head.map_name = G_store(str);
-    return (0);
+    return 0;
@@ -354,7 +354,7 @@
    \return map name string
-const char *Vect_get_map_name(struct Map_info *Map)
+const char *Vect_get_map_name(const struct Map_info *Map)
     return (Map->head.map_name);
@@ -371,7 +371,8 @@
     G_free(Map->head.source_date);
     Map->head.source_date = G_store(str);
-    return (0);
+    return 0;
@@ -381,7 +382,7 @@
    \return date when the source map was originally produced string
-const char *Vect_get_map_date(struct Map_info *Map)
+const char *Vect_get_map_date(const struct Map_info *Map)
     return (Map->head.source_date);
@@ -397,7 +398,8 @@
 int Vect_set_scale(struct Map_info *Map, int scale)
     Map->head.orig_scale = scale;
-    return (0);
+    return 0;
@@ -407,9 +409,9 @@
    \return map scale
-int Vect_get_scale(struct Map_info *Map)
+int Vect_get_scale(const struct Map_info *Map)
-    return ((int)Map->head.orig_scale);
+    return ((int) Map->head.orig_scale);
@@ -424,7 +426,8 @@
     G_free(Map->head.line_3);
     Map->head.line_3 = G_store(str);
-    return (0);
+    return 0;
@@ -434,7 +437,7 @@
    \return comment or other info string
-const char *Vect_get_comment(struct Map_info *Map)
+const char *Vect_get_comment(const struct Map_info *Map)
     return (Map->head.line_3);
@@ -450,7 +453,8 @@
 int Vect_set_zone(struct Map_info *Map, int zone)
     Map->head.plani_zone = zone;
-    return (0);
+    return 0;
@@ -461,7 +465,7 @@
    \return projection zone
-int Vect_get_zone(struct Map_info *Map)
+int Vect_get_zone(const struct Map_info *Map)
     return (Map->head.plani_zone);
@@ -471,12 +475,12 @@
-   \return PROJECTION_XY 0 - x,y (Raw imagery),
-   \return PROJECTION_UTM 1 - UTM   Universal Transverse Mercator,
-   \return PROJECTION_SP  2 - State Plane (in feet),
-   \return PROJECTION_LL  3 - Latitude-Longitude
+   \return PROJECTION_XY  - x,y (Raw imagery),
+   \return PROJECTION_UTM - UTM   Universal Transverse Mercator,
+   \return PROJECTION_SP  - State Plane (in feet),
+   \return PROJECTION_LL  - Latitude-Longitude
-int Vect_get_proj(struct Map_info *Map)
+int Vect_get_proj(const struct Map_info *Map)
     return (Map->proj);
@@ -486,15 +490,16 @@
    \brief Query cartographic projection name of vector map
    Returns a pointer to a string which is a printable name for
-   projection code <b>proj</b> (as returned by <i>Vect_get_proj()</i>). Returns
-   NULL if <b>proj</b> is not a valid projection.
+   projection code <em>proj</em> (as returned by
+   Vect_get_proj()).
    \return poiter to projection name
+   \return NULL if <em>proj</em> is not a valid projection
-const char *Vect_get_proj_name(struct Map_info *Map)
+const char *Vect_get_proj_name(const struct Map_info *Map)
     char name[256];
     int n;
@@ -508,6 +513,7 @@
     if (!lookup(PROJECTION_FILE, "name", name, sizeof(name)))
 	strcpy(name, _("Unknown projection"));
     return G_store(name);
@@ -533,7 +539,7 @@
    \return threshold used for digitization
-double Vect_get_thresh(struct Map_info *Map)
+double Vect_get_thresh(const struct Map_info *Map)
     G_debug(1, "Vect_get_thresh(): thresh = %f", Map->head.digit_thresh);
     return (Map->head.digit_thresh);
Modified: grass/trunk/lib/vector/Vlib/hist.c
--- grass/trunk/lib/vector/Vlib/hist.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/hist.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   (C) 2001-2008 by the GRASS Development Team
+   (C) 2001-2009 by the GRASS Development Team
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
@@ -27,7 +23,7 @@
-   \return 0 OK
    \return -1 error
 int Vect_hist_command(struct Map_info *Map)
@@ -45,7 +41,8 @@
     sprintf(buf, "GISDBASE: %s\n", G_gisdbase());	/* Needed ? */
     Vect_hist_write(Map, buf);
-    sprintf(buf, "LOCATION: %s MAPSET: %s USER: %s DATE: %s\n", G_location(), G_mapset(), G_whoami(), G_date());	/* Needed ? */
+    sprintf(buf, "LOCATION: %s MAPSET: %s USER: %s DATE: %s\n",
+	    G_location(), G_mapset(), G_whoami(), G_date());	/* Needed ? */
     return 0;
@@ -73,7 +70,7 @@
    \brief Reads one line from history file without newline character
-   \param s buffer, allocated space must be size+1
+   \param[out] s buffer, allocated space must be size+1
    \param size maximum number of character
@@ -81,7 +78,7 @@
    \return EOF end of file
-char *Vect_hist_read(char *s, int size, struct Map_info *Map)
+char *Vect_hist_read(char *s, int size, const struct Map_info *Map)
     int ret;
@@ -117,12 +114,12 @@
    \brief Copy history from one map to another
    \param In input vector map
-   \param Out output vector map
+   \param[out] Out output vector map
-   \return 0 OK
-   \return -1 error
+   \return -1 on error
-int Vect_hist_copy(struct Map_info *In, struct Map_info *Out)
+int Vect_hist_copy(const struct Map_info *In, struct Map_info *Out)
     size_t red, ret;
     char buf[1000];
Modified: grass/trunk/lib/vector/Vlib/init_head.c
--- grass/trunk/lib/vector/Vlib/init_head.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/init_head.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,22 +5,18 @@
-   Initialize Head structure.  To make sure that we are not writing
-   out garbage to a file.
+   Initialize Head structure. To make sure that we are not writing out
+   garbage to a file.
-   for details.
-   Update to GRASS 5.7 Radim Blazek and David D. Gray.
+   \author Update to GRASS 5.7 Radim Blazek and David D. Gray.
-   \date 2001-2008
 #include <string.h>
@@ -66,11 +62,11 @@
    \brief Copy header data from one to another map
    \param from target vector map
-   \param to destination vector map
+   \param[out] to destination vector map
+   \return 0
-int Vect_copy_head_data(struct Map_info *from, struct Map_info *to)
+int Vect_copy_head_data(const struct Map_info *from, struct Map_info *to)
     Vect_set_organization(to, Vect_get_organization(from));
     Vect_set_date(to, Vect_get_date(from));
Modified: grass/trunk/lib/vector/Vlib/intersect.c
--- grass/trunk/lib/vector/Vlib/intersect.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/intersect.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,64 @@
+   Some parts of code taken from grass50 v.spag/linecros.c
+   Based on the following:
+   <code>
+   (ax2-ax1)r1 - (bx2-bx1)r2 = ax2 - ax1
+   (ay2-ay1)r1 - (by2-by1)r2 = ay2 - ay1
+   </code>
+   Solving for r1 and r2, if r1 and r2 are between 0 and 1, then line
+   segments (ax1,ay1)(ax2,ay2) and (bx1,by1)(bx2,by2) intersect.
-   for details.
+   Intersect 2 line segments.
+   Returns: 0 - do not intersect
+            1 - intersect at one point
+   <pre>
+           2 - partial overlap         ( \/                      )
+                ------      a          (    distance < threshold )
+                   ------   b          (                         )
+           3 - a contains b            ( /\                      )
+                ----------  a    ----------- a
+                   ----     b          ----- b
+	     4 - b contains a
+                   ----     a          ----- a
+                ----------  b    ----------- b
+            5 - identical
+                ----------  a
+                ----------  b
+  </pre>
+  Intersection points:
+  <pre>
+  return  point1 breakes: point2 breaks:    distance1 on:   distance2 on:
+      0        -              -                  -              -
+      1        a,b            -                  a              b
+      2        a              b                  a              b
+      3        a              a                  a              a
+      4        b              b                  b              b
+      5        -              -                  -              -
+  </pre>
+   Sometimes (often) is important to get the same coordinates for a x
+   b and b x a.  To reach this, the segments a,b are 'sorted' at the
+   beginning, so that for the same switched segments, results are
+   identical. (reason is that double values are always rounded because
+   of limited number of decimal places and for different order of
+   coordinates, the results would be different)
-   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
-   Update to GRASS 5.7 Radim Blazek.
-   \date 2001-2008
+   \author Update to GRASS 5.7 Radim Blazek.
 #include <stdlib.h>
@@ -36,68 +83,18 @@
 static int cross_seg(int id, int *arg);
 static int find_cross(int id, int *arg);
-/* Some parts of code taken from grass50 v.spag/linecros.c
- * Based on the following:
- *     (ax2-ax1)r1 - (bx2-bx1)r2 = ax2 - ax1
- *     (ay2-ay1)r1 - (by2-by1)r2 = ay2 - ay1
- * Solving for r1 and r2, if r1 and r2 are between 0 and 1,
- * then line segments (ax1,ay1)(ax2,ay2) and (bx1,by1)(bx2,by2)
- * intersect
 #define D  ((ax2-ax1)*(by1-by2) - (ay2-ay1)*(bx1-bx2))
 #define D1 ((bx1-ax1)*(by1-by2) - (by1-ay1)*(bx1-bx2))
 #define D2 ((ax2-ax1)*(by1-ay1) - (ay2-ay1)*(bx1-ax1))
-/* Intersect 2 line segments.
- *  Returns: 0 - do not intersect
- *           1 - intersect at one point
- *           2 - partial overlap         ( \/                      )
- *                ------      a          (    distance < threshold )
- *                   ------   b          (                         )
- *           3 - a contains b            ( /\                      )
- *                ----------  a    ----------- a
- *                   ----     b          ----- b
- *           4 - b contains a
- *                   ----     a          ----- a
- *                ----------  b    ----------- b
- *           5 - identical
- *                ----------  a
- *                ----------  b
- *  Intersection points:
- *  return  point1 breakes: point2 breaks:    distance1 on:   distance2 on:
- *     0        -              -                  -              -
- *     1        a,b            -                  a              b
- *     2        a              b                  a              b
- *     3        a              a                  a              a
- *     4        b              b                  b              b
- *     5        -              -                  -              -
- *  Sometimes (often) is important to get the same coordinates for a x b and b x a.
- *  To reach this, the segments a,b are 'sorted' at the beginning, so that for the same switched segments,
- *  results are identical. (reason is that double values are always rounded because of limited number
- *  of decimal places and for different order of coordinates, the results would be different)
  * \brief Check for intersect of 2 line segments.
- * \param[in] ax1,ay1,az1,ax2,ay2,az2 input line a
- * \param[in] bx1,by1,bz1,bx2,by2,bz2 input line b
+ * \param ax1,ay1,az1,ax2,ay2,az2 input line a
+ * \param bx1,by1,bz1,bx2,by2,bz2 input line b
  * \param[out] x1,y1,z1 intersection point1 (case 2-4)
  * \param[out] x2,y2,z2 intersection point2 (case 2-4)
- * \param[in] with_z use z coordinate (3D) (TODO)
+ * \param with_z use z coordinate (3D) (TODO)
  * \return 0 - do not intersect,
  * \return 1 - intersect at one point,
@@ -586,13 +583,13 @@
  * intersection with B line. Points (Points->n_points == 1) are not
  * supported.
- * \param[in] APoints first input line
- * \param[in] BPoints second input line
+ * \param APoints first input line
+ * \param BPoints second input line
  * \param[out] ALines array of new lines created from original A line
  * \param[out] BLines array of new lines created from original B line
  * \param[out] nalines number of new lines (ALines)
  * \param[out] nblines number of new lines (BLines)
- * \param[in] with_z 3D, not supported!
+ * \param with_z 3D, not supported!
  * \return 0 no intersection
  * \return 1 intersection found
@@ -1120,9 +1117,9 @@
  * Points (Points->n_points == 1) are also supported.
- * \param[in] with_z 3D, not supported (only if one or both are points)!
+ * \param with_z 3D, not supported (only if one or both are points)!
@@ -1294,10 +1291,10 @@
  * A wrapper around Vect_line_check_intersection() function.
  * \param[out] IPoints output with intersection points
Modified: grass/trunk/lib/vector/Vlib/legal_vname.c
--- grass/trunk/lib/vector/Vlib/legal_vname.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/legal_vname.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,16 +3,12 @@
    \brief Vector library - Check if map name is legal vector map name
-   for details.
-   \date 2001-2008
 #include <string.h>
@@ -27,7 +23,7 @@
    Check also for SQL keywords.
-   \param[in] s filename to be checked
+   \param s filename to be checked
    \return 1 OK
    \return -1 if name does not start with letter A..Za..z or if name does not continue with A..Za..z0..9_@
@@ -83,9 +79,9 @@
    - if can find input map
    - if input was found in current mapset, check if input != output
-   \param[in] input input name
-   \param[in] output output name
-   \param[in] error error type GV_FATAL_EXIT, GV_FATAL_PRINT, GV_FATAL_RETURN
+   \param input input name
+   \param output output name
+   \param error error type GV_FATAL_EXIT, GV_FATAL_PRINT, GV_FATAL_RETURN
    \return 0 OK
    \return 1 error
Modified: grass/trunk/lib/vector/Vlib/level.c
--- grass/trunk/lib/vector/Vlib/level.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/level.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,17 +3,13 @@
    \brief Vector library - level info
-   for details.
-   \date 2001-2008
@@ -30,7 +26,7 @@
    \return open level
    \return -1 on error
-int Vect_level(struct Map_info *Map)
+int Vect_level(const struct Map_info *Map)
     if (Map->open != VECT_OPEN_CODE) {
 	if (Map->open != VECT_CLOSED_CODE)
Modified: grass/trunk/lib/vector/Vlib/level_two.c
--- grass/trunk/lib/vector/Vlib/level_two.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/level_two.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,15 +3,13 @@
    \brief Vector library - topology level functions
-   \date 2001-2008
 #include <stdlib.h>
@@ -26,7 +24,7 @@
    \return number of nodes
-int Vect_get_num_nodes(struct Map_info *map)
+int Vect_get_num_nodes(const struct Map_info *map)
     return (map->plus.n_nodes);
@@ -39,7 +37,7 @@
    \return number of primitives
-int Vect_get_num_primitives(struct Map_info *map, int type)
+int Vect_get_num_primitives(const struct Map_info *map, int type)
     int num = 0;
@@ -66,7 +64,7 @@
    \return number of features
-int Vect_get_num_lines(struct Map_info *map)
+int Vect_get_num_lines(const struct Map_info *map)
     return (map->plus.n_lines);
@@ -78,7 +76,7 @@
    \return number of areas
-int Vect_get_num_areas(struct Map_info *map)
+int Vect_get_num_areas(const struct Map_info *map)
     return (map->plus.n_areas);
@@ -90,7 +88,7 @@
    \return number of faces
-int Vect_get_num_faces(struct Map_info *map)
+int Vect_get_num_faces(const struct Map_info *map)
     return (map->plus.n_flines);
@@ -102,7 +100,7 @@
    \return number of islands
-int Vect_get_num_islands(struct Map_info *map)
+int Vect_get_num_islands(const struct Map_info *map)
     return (map->plus.n_isles);
@@ -114,7 +112,7 @@
    \return number of dblinks
-int Vect_get_num_dblinks(struct Map_info *map)
+int Vect_get_num_dblinks(const struct Map_info *map)
     return (map->dblnk->n_fields);
@@ -126,7 +124,7 @@
    \return number of updated features
-int Vect_get_num_updated_lines(struct Map_info *map)
+int Vect_get_num_updated_lines(const struct Map_info *map)
     return (map->plus.n_uplines);
@@ -139,7 +137,7 @@
    \return updated line
-int Vect_get_updated_line(struct Map_info *map, int idx)
+int Vect_get_updated_line(const struct Map_info *map, int idx)
     return (map->plus.uplines[idx]);
@@ -151,7 +149,7 @@
    \return number of updated nodes
-int Vect_get_num_updated_nodes(struct Map_info *map)
+int Vect_get_num_updated_nodes(const struct Map_info *map)
     return (map->plus.n_upnodes);
@@ -164,7 +162,7 @@
    \return updated node
-int Vect_get_updated_node(struct Map_info *map, int idx)
+int Vect_get_updated_node(const struct Map_info *map, int idx)
     return (map->plus.upnodes[idx]);
@@ -179,7 +177,7 @@
    \return 0
 int
-Vect_get_node_coor(struct Map_info *map, int num, double *x, double *y,
+Vect_get_node_coor(const struct Map_info *map, int num, double *x, double *y,
 		   double *z)
     P_NODE *Node;
@@ -203,7 +201,7 @@
    \return 1
-int Vect_get_line_nodes(struct Map_info *Map, int line, int *n1, int *n2)
+int Vect_get_line_nodes(const struct Map_info *Map, int line, int *n1, int *n2)
     if (Map->level < 2)
@@ -228,7 +226,7 @@
    \return 1
-int Vect_get_line_areas(struct Map_info *Map, int line, int *left, int *right)
+int Vect_get_line_areas(const struct Map_info *Map, int line, int *left, int *right)
     if (Map->level < 2)
@@ -252,7 +250,7 @@
    \return numbers of lines
-int Vect_get_node_n_lines(struct Map_info *Map, int node)
+int Vect_get_node_n_lines(const struct Map_info *Map, int node)
     if (Map->level < 2)
@@ -272,7 +270,7 @@
    \return line id
-int Vect_get_node_line(struct Map_info *Map, int node, int line)
+int Vect_get_node_line(const struct Map_info *Map, int node, int line)
     if (Map->level < 2)
 	G_fatal_error(_("Vector map <%s> is not open on level >= 2"),
@@ -290,7 +288,7 @@
    \return angle of segment of the line connected to the node
-float Vect_get_node_line_angle(struct Map_info *Map, int node, int line)
+float Vect_get_node_line_angle(const struct Map_info *Map, int node, int line)
     if (Map->level < 2)
@@ -309,7 +307,7 @@
    \return 0 for not in area
    \return negative id if area/centroid (?) is duplicate
-int Vect_get_centroid_area(struct Map_info *Map, int centroid)
+int Vect_get_centroid_area(const struct Map_info *Map, int centroid)
     if (Map->level < 2)
Modified: grass/trunk/lib/vector/Vlib/line.c
--- grass/trunk/lib/vector/Vlib/line.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/line.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -3,19 +3,15 @@
    \brief Vector library - geometry manipulation
-   for details.
-   \date 2001-2008
 #include <stdlib.h>
 #include <math.h>
@@ -110,8 +106,8 @@
    \return -1 on out of memory
 int
-Vect_copy_xyz_to_pnts(struct line_pnts *Points, double *x, double *y,
-		      double *z, int n)
+Vect_copy_xyz_to_pnts(struct line_pnts *Points, const double *x, const double *y,
+		      const double *z, int n)
     register int i;
@@ -307,7 +303,7 @@
 int
-Vect_append_points(struct line_pnts *Points, struct line_pnts *APoints,
+Vect_append_points(struct line_pnts *Points, const struct line_pnts *APoints,
 		   int direction)
     int i, n, on, an;
@@ -354,7 +350,7 @@
    \return number of points copied
 int
-Vect_copy_pnts_to_xyz(struct line_pnts *Points, double *x, double *y,
+Vect_copy_pnts_to_xyz(const struct line_pnts *Points, double *x, double *y,
 		      double *z, int *n)
     register int i;
@@ -388,7 +384,7 @@
 int
-Vect_point_on_line(struct line_pnts *Points, double distance,
+Vect_point_on_line(const struct line_pnts *Points, double distance,
 		   double *x, double *y, double *z, double *angle,
 		   double *slope)
@@ -492,7 +488,7 @@
    \return 0 error when start > length or end < 0 or start < 0 or end > length
 int
-Vect_line_segment(struct line_pnts *InPoints, double start, double end,
+Vect_line_segment(const struct line_pnts *InPoints, double start, double end,
     int i, seg1, seg2;
@@ -545,11 +541,11 @@
    For Lat-Long use Vect_line_geodesic_length() instead.
-   \param Points line
+   \param Points line geometry
    \return line length
-double Vect_line_length(struct line_pnts *Points)
+double Vect_line_length(const struct line_pnts *Points)
     int j;
     double dx, dy, dz, len = 0;
@@ -573,11 +569,11 @@
    If projection is LL, the length is measured along the geodesic.
    \return line length
-double Vect_line_geodesic_length(struct line_pnts *Points)
+double Vect_line_geodesic_length(const struct line_pnts *Points)
     int j, dc;
     double dx, dy, dz, dxy, len = 0;
@@ -606,7 +602,7 @@
-   \brief calculate line distance.
+   \brief Calculate line distance.
    Sets (if not null):
    - px, py - point on line,
@@ -625,7 +621,7 @@
    \return nearest segment (first is 1)
 int
-Vect_line_distance(struct line_pnts *points,
+Vect_line_distance(const struct line_pnts *points,
 		   int with_z,
 		   double *px, double *py, double *pz,
@@ -765,7 +761,7 @@
    \return 0
-int Vect_line_box(struct line_pnts *Points, BOUND_BOX * Box)
+int Vect_line_box(const struct line_pnts *Points, BOUND_BOX * Box)
     dig_line_box(Points, Box);
     return 0;
@@ -809,7 +805,7 @@
    \return -1 no category
    \return category number (>=0)
-int Vect_get_line_cat(struct Map_info *Map, int line, int field)
+int Vect_get_line_cat(const struct Map_info *Map, int line, int field)
     static struct line_cats *cats = NULL;
Modified: grass/trunk/lib/vector/Vlib/list.c
--- grass/trunk/lib/vector/Vlib/list.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/list.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,21 +1,19 @@
  * \file list.c
  * \brief Vector library - list definition
- * (C) 2001-2008 by the GRASS Development Team
+ * (C) 2001-2009 by the GRASS Development Team
  * for details.
  * \author Original author CERL, probably Dave Gerdes or Mike Higgins.
- * Update to GRASS 5.7 Radim Blazek and David D. Gray
- * \date 2001-2008
 #include <stdlib.h>
@@ -88,7 +86,7 @@
  * \brief Append new item to the end of list if not yet present
  * \param[in,out] list pointer to ilist structure
- * \param[in] val new item to append to the end of list
+ * \param val new item to append to the end of list
  * \return 0 on success
  * \return 1 on error
@@ -122,12 +120,12 @@
  * \brief Append new items to the end of list if not yet present
  * \param[in,out] alist pointer to ilist structure where items will be appended
- * \param[in] blist pointer to ilist structure with new items
+ * \param blist pointer to ilist structure with new items
-int Vect_list_append_list(struct ilist *alist, struct ilist *blist)
+int Vect_list_append_list(struct ilist *alist, const struct ilist *blist)
     int i;
@@ -144,7 +142,7 @@
  * \brief Remove a given value (item) from list
- * \param[in] val to remove
+ * \param val to remove
@@ -173,12 +171,12 @@
  * \brief Delete list from existing list
  * \param[in,out] alist pointer to original ilist structure,
- * \param[in] blist pointer to ilist structure with items to delete
+ * \param blist pointer to ilist structure with items to delete
-int Vect_list_delete_list(struct ilist *alist, struct ilist *blist)
+int Vect_list_delete_list(struct ilist *alist, const struct ilist *blist)
     int i;
@@ -194,13 +192,13 @@
  * \brief Find a given item in the list
- * \param[in] list pointer to ilist structure
- * \param[in] val value of item
+ * \param list pointer to ilist structure
+ * \param val value of item
  * \return 1 if an item is found
  * \return 0 no found item in the list
-int Vect_val_in_list(struct ilist *list, int val)
+int Vect_val_in_list(const struct ilist *list, int val)
     int i;
Modified: grass/trunk/lib/vector/Vlib/map.c
--- grass/trunk/lib/vector/Vlib/map.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/map.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,14 @@
- * for details.
- * \date 2001-2008
+ * Higgins.
 #include <stdlib.h>
@@ -35,7 +32,7 @@
    \brief Copy all alive elements of opened vector map to another opened vector map
-   \param[in] In input vector map
+   \param In input vector map
@@ -101,7 +98,7 @@
    \brief Copy file
-   \param[in] src source file
+   \param src source file
    \param[out] dst destination file
    \return 0 OK
@@ -145,9 +142,9 @@
    Old vector is deleted
-   \param[in] in input vector map name
-   \param[in] mapset mapset name
-   \param[in] out output vector map name
+   \param in input vector map name
+   \param mapset mapset name
+   \param out output vector map name
    \return -1 error
    \return 0 success
@@ -297,8 +294,8 @@
    The original format (native/OGR) is used.
    Old map ('out') is deleted!!!
    \return -1 error
    \return 0 success
@@ -432,7 +429,7 @@
    \brief Delete vector map including attribute tables
-   \param[in] map vector map name
+   \param map vector map name
    \return -1 error
    \return 0 success
@@ -575,14 +572,14 @@
    Notice, that if input map has no tables defined, it will copy
    nothing and return 0 (success).
    \return -1 on error
-int Vect_copy_tables(struct Map_info *In, struct Map_info *Out, int field)
+int Vect_copy_tables(const struct Map_info *In, struct Map_info *Out, int field)
     int i, n, ret, type;
     struct field_info *Fi, *Fin;
@@ -650,18 +647,18 @@
    \brief Copy table linked to vector map based on type.
-   \param[in] field_in input layer number
-   \param[in] field_out output layer number
-   \param[in] field_name layer name
+   \param field_in input layer number
+   \param field_out output layer number
+   \param field_name layer name
    \return -1 on error
 int
-Vect_copy_table(struct Map_info *In, struct Map_info *Out, int field_in,
+Vect_copy_table(const struct Map_info *In, struct Map_info *Out, int field_in,
 		int field_out, const char *field_name, int type)
     return Vect_copy_table_by_cats(In, Out, field_in, field_out, field_name,
@@ -671,20 +668,20 @@
    \brief Copy table linked to vector map based on category numbers.
-   \param[in] cats pointer to array of cats or NULL
-   \param[in] ncats number of cats in 'cats'
+   \param cats pointer to array of cats or NULL
+   \param ncats number of cats in 'cats'
    \return -1 on error
 int
-Vect_copy_table_by_cats(struct Map_info *In, struct Map_info *Out,
+Vect_copy_table_by_cats(const struct Map_info *In, struct Map_info *Out,
 			int field_in, int field_out, const char *field_name,
 			int type, int *cats, int ncats)
@@ -753,7 +750,8 @@
-   \brief By default, category index is not updated if vector is changed, this function sets category index update.
+   \brief By default, category index is not updated if vector is
+   changed, this function sets category index update.
    WARNING: currently only category for elements is updated
    not for areas
Modified: grass/trunk/lib/vector/Vlib/net.c
--- grass/trunk/lib/vector/Vlib/net.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/net.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
- * for details.
- * \date 2001-2008
 #include<stdlib.h>
@@ -554,7 +550,7 @@
    \return 0 does not exist (was not inserted)
 int
-Vect_net_get_line_cost(struct Map_info *Map, int line, int direction,
+Vect_net_get_line_cost(const struct Map_info *Map, int line, int direction,
 		       double *cost)
     /* dglInt32_t *pEdge; */
@@ -607,7 +603,7 @@
    \return 1
-int Vect_net_get_node_cost(struct Map_info *Map, int node, double *cost)
+int Vect_net_get_node_cost(const struct Map_info *Map, int node, double *cost)
     G_debug(3, "Vect_net_get_node_cost(): node = %d", node);
@@ -625,14 +621,14 @@
    \param x,y,z point coordinates (z coordinate NOT USED !)
    \param direction (GV_FORWARD - from point to net, GV_BACKWARD - from net to point)
    \param maxdist maximum distance to the network
-   \param node1 pointer where to store the node number (or NULL)
-   \param node2 pointer where to store the node number (or NULL)
-   \param ln    pointer where to store the nearest line number (or NULL)
-   \param costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
-   \param costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
-   \param Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
-   \param Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
-   \param pointer where to distance to the line (or NULL)
+   \param[out] node1 pointer where to store the node number (or NULL)
+   \param[out] node2 pointer where to store the node number (or NULL)
+   \param[out] ln    pointer where to store the nearest line number (or NULL)
+   \param[out] costs1 pointer where to store costs on nearest line to node1 (not costs from x,y,z to the line) (or NULL)
+   \param[out] costs2 pointer where to store costs on nearest line to node2 (not costs from x,y,z to the line) (or NULL)
+   \param[out] Points1 pointer to structure where to store vertices on nearest line to node1 (or NULL)
+   \param[out] Points2 pointer to structure where to store vertices on nearest line to node2 (or NULL)
+   \param[out] pointer where to distance to the line (or NULL)
    \return number of nodes found (0,1,2)
@@ -844,15 +840,16 @@
    \param tx,ty,tz to point x coordinate (z ignored)
    \param fmax maximum distance to the network from 'from'
    \param tmax maximum distance to the network from 'to'
-   \param costs pointer where to store costs on the network (or NULL)
-   \param Points pointer to the structure where to store vertices of shortest path (or NULL)
-   \param List pointer to the structure where list of lines on the network is stored (or NULL)
-   \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
-   \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
-   \param fdist distance from 'from' to the net (or NULL)
-   \param tdist distance from 'to' to the net (or NULL)
+   \param[out] costs pointer where to store costs on the network (or NULL)
+   \param[out] Points pointer to the structure where to store vertices of shortest path (or NULL)
+   \param[out] List pointer to the structure where list of lines on the network is stored (or NULL)
+   \param[out] FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+   \param[out] TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+   \param[out] fdist distance from 'from' to the net (or NULL)
+   \param[out] tdist distance from 'to' to the net (or NULL)
-   \return 1 OK, 0 not reachable
+   \return 1 OK
+   \return 0 not reachable
 int
 Vect_net_shortest_path_coor(struct Map_info *Map,
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/open.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,14 @@
- * GNU General Public License (>=v2).
- * Read the file COPYING that comes with GRASS
- * for details.
+ * This program is free software under the GNU General Public License
+ * (>=v2).  Read the file COPYING that comes with GRASS for details.
- * \date 2001-2008
+ * Higgins.
 #include <grass/config.h>
 #include <stdlib.h>
@@ -88,7 +85,7 @@
  * will be downward compatible and which your programs should
  * support by default.
- * \param[in] level vector (topo) level
+ * \param level vector (topo) level
@@ -114,10 +111,10 @@
  * In case of error, the functions respect fatal error settings.
  * \param[out] Map vector map
- * \param[in] name name of vector map to open
- * \param[in] mapset mapset name
- * \param[in] update open for update
- * \param[in] head_only read only header info from 'head', 'dbln', 'topo', 'cidx' is not opened. The header may be opened on level 2 only.
+ * \param name name of vector map to open
+ * \param mapset mapset name
+ * \param update open for update
+ * \param head_only read only header info from 'head', 'dbln', 'topo', 'cidx' is not opened. The header may be opened on level 2 only.
  * \return level of openness (1, 2)
  * \return -1 in error
@@ -408,8 +405,8 @@
  * \return level of openness [1, 2, (3)]
  * \return -1 on error
@@ -425,8 +422,8 @@
- * \param[in] name name of vector map to update
+ * \param name name of vector map to update
@@ -462,8 +459,8 @@
- * \param[in] name name of vector map to read
+ * \param name name of vector map to read
@@ -480,8 +477,8 @@
@@ -512,8 +509,8 @@
  * \brief Open new vector for reading/writing
- * \param[in] with_z 2D/3D vector map
+ * \param with_z 2D/3D vector map
  * \return 1 on success
@@ -606,13 +603,13 @@
  * \brief Update Coor_info structure
  * \param[out] Info Coor_info structure
  * \return 0 on error
-int Vect_coor_info(struct Map_info *Map, struct Coor_info *Info)
+int Vect_coor_info(const struct Map_info *Map, struct Coor_info *Info)
     char buf[2000], path[2000];
     struct stat stat_buf;
@@ -646,7 +643,7 @@
 	Info->mtime = 0L;
 	break;
-    G_debug(1, "Info->size = %ld, Info->mtime = %ld", Info->size,
+    G_debug(1, "Info->size = %lu, Info->mtime = %ld", (unsigned long) Info->size,
 	    Info->mtime);
     return 1;
@@ -655,12 +652,15 @@
  * \brief Gets maptype (native, shape, postgis)
+ * Note: string is allocated by G_store(). Free allocated memory with
+ * G_free().
  * \return maptype string on success
  * \return error message on error
-const char *Vect_maptype_info(struct Map_info *Map)
+const char *Vect_maptype_info(const struct Map_info *Map)
     char maptype[1000];
@@ -684,7 +684,7 @@
  * \brief Open topo file
  * \param[in,out] Map vector map
- * \param[in] head_only open only head
+ * \param head_only open only head
  * \return 1 file does not exist
@@ -726,8 +726,8 @@
     if (dig_Rd_Plus_head(&fp, Plus) == -1)
 	return -1;
-    G_debug(1, "Topo head: coor size = %ld, coor mtime = %ld",
-	    Plus->coor_size, Plus->coor_mtime);
+    G_debug(1, "Topo head: coor size = %lu, coor mtime = %ld",
+	    (unsigned long) Plus->coor_size, Plus->coor_mtime);
     /* do checks */
     err = 0;
Modified: grass/trunk/lib/vector/Vlib/open_nat.c
--- grass/trunk/lib/vector/Vlib/open_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/open_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,13 @@
-   for details.
-   \date 2001
@@ -58,7 +54,7 @@
 	    G_fopen_old(buf, GRASS_VECT_COOR_ELEMENT, Map->mapset);
     if (Map->dig_fp.file == NULL) {
-        G_warning("Could not open coor file for vector map <%s>", Map->name);
+        G_warning(_("Unable to open coor file for vector map <%s>"), Map->name);
         return -1;
@@ -78,13 +74,13 @@
     if (!update)
 	dig_file_load(&(Map->dig_fp)); /* has currently no effect, file never loaded */
-    return (0);
+    return 0;
    \brief Open/Create new vector map.
-   \param Map pointer to vector map
+   \param[out] Map pointer to vector map
    \param name map name
    \param with_z 2D or 3D (unused?)
@@ -147,8 +143,8 @@
     Vect_coor_info(Map, &CInfo);
     dif = CInfo.size - Map->head.size;
-    G_debug(1, "coor size in head = %ld, real coor file size= %ld",
-	    Map->head.size, CInfo.size);
+    G_debug(1, "coor size in head = %lu, real coor file size= %lu",
+	    (unsigned long) Map->head.size, (unsigned long) CInfo.size);
     if (dif > 0) {
 	G_warning(_("Coor files of vector map <%s@%s> is larger than it should be "
Modified: grass/trunk/lib/vector/Vlib/open_ogr.c
--- grass/trunk/lib/vector/Vlib/open_ogr.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/open_ogr.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,13 @@
-   for details.
-   \date 2001
 #include <unistd.h>
@@ -35,7 +31,7 @@
    Map->name and Map->mapset must be set before.
    \param update non-zero for write mode, otherwise read-only
    (write mode is currently not supported)
@@ -106,7 +102,7 @@
    \brief Open OGR specific level 2 files (feature index)
    \return 0 success
    \return -1 error
Modified: grass/trunk/lib/vector/Vlib/overlap.c
--- grass/trunk/lib/vector/Vlib/overlap.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/overlap.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,23 +1,30 @@
- * MODULE:       Vector library
- * AUTHOR(S):    Original author CERL, probably Dave Gerdes or Mike Higgins.
- *               Update to GRASS 5.7 Radim Blazek and David D. Gray.
- * PURPOSE:      Higher level functions for reading/writing/manipulating vectors.
- * COPYRIGHT:    (C) 2001 by the GRASS Development Team
- *               This program is free software under the GNU General Public
- *              License (>=v2). Read the file COPYING that comes with GRASS
- *              for details.
+   \file overlap.c
+   \brief Vector library - region/window overlap
+  Check if region overlaps with map extent.
+  \param n,s,e,w region bounding box
+  \return 1 if regions overlap
+  \return 0 if not
 int
 V__map_overlap(struct Map_info *Map, double n, double s, double e, double w)
Modified: grass/trunk/lib/vector/Vlib/overlay.c
--- grass/trunk/lib/vector/Vlib/overlay.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/overlay.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -8,18 +8,14 @@
    This is file is just example and starting point for writing overlay
    functions!!!
-   for details.
    \author Radim Blazek
-   \date 2001
 #include <string.h>
@@ -57,7 +53,7 @@
    \param BList unused ?
    \param BAList unused ?
    \param operator operator code
-   \param OMap output vector map
+   \param[out] OMap output vector map
@@ -94,6 +90,7 @@
+   \param OMap output vector map
    \return 0 on error
Modified: grass/trunk/lib/vector/Vlib/poly.c
--- grass/trunk/lib/vector/Vlib/poly.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/poly.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,17 +5,13 @@
-   for details.
-   \date 2001
 #include <math.h>
@@ -37,11 +33,10 @@
 static int V__within(double, double, double);
 int Vect__intersect_line_with_poly();
 static void destroy_links(struct Slink *);
-static int Vect__divide_and_conquer(struct Slink *, struct line_pnts *,
+static int Vect__divide_and_conquer(struct Slink *, const struct line_pnts *,
 				    struct link_head *, double *, double *,
 				    int);
    \brief Get point inside area and outside all islands.
@@ -58,7 +53,7 @@
    \return -1 on error
 int
-Vect_get_point_in_area(struct Map_info *Map, int area, double *X, double *Y)
+Vect_get_point_in_area(const struct Map_info *Map, int area, double *X, double *Y)
     static struct line_pnts *Points;
     static struct line_pnts **IPoints;
@@ -92,7 +87,8 @@
 				 IPoints[i]))
 	    return -1;
-    return (Vect_get_point_in_poly_isl(Points, IPoints, n_isles, X, Y));
+    return (Vect_get_point_in_poly_isl((const struct line_pnts*) Points,
+				       (const struct line_pnts**) IPoints, n_isles, X, Y));
     return -1;
@@ -133,7 +129,7 @@
    \return -1 on error
 int
-Vect__intersect_line_with_poly(struct line_pnts *Points,
+Vect__intersect_line_with_poly(const struct line_pnts *Points,
 			       double y, struct line_pnts *Inter)
     int i;
@@ -172,7 +168,7 @@
    \return -1 on error
-int Vect_get_point_in_poly(struct line_pnts *Points, double *X, double *Y)
+int Vect_get_point_in_poly(const struct line_pnts *Points, double *X, double *Y)
     double cent_x, cent_y;
     struct Slink *Head;
@@ -260,7 +256,7 @@
 static int
 Vect__divide_and_conquer(struct Slink *Head,
-			 struct line_pnts *Points,
+			 const struct line_pnts *Points,
 			 struct link_head *Token,
 			 double *X, double *Y, int levels)
@@ -322,7 +318,7 @@
    \return -1 on error
 int
-Vect_find_poly_centroid(struct line_pnts *points,
+Vect_find_poly_centroid(const struct line_pnts *points,
 			double *cent_x, double *cent_y)
     int i;
@@ -416,8 +412,8 @@
    \return -1 on error
 int
-Vect_get_point_in_poly_isl(struct line_pnts *Points,
-			   struct line_pnts **IPoints, int n_isles,
+Vect_get_point_in_poly_isl(const struct line_pnts *Points,
+			   const struct line_pnts **IPoints, int n_isles,
 			   double *att_x, double *att_y)
     static struct line_pnts *Intersects;
@@ -546,7 +542,7 @@
  * Returns: -1 point exactly on segment
  *          number of intersections
-static int segments_x_ray(double X, double Y, struct line_pnts *Points)
+static int segments_x_ray(double X, double Y, const struct line_pnts *Points)
     double x1, x2, y1, y2;
     double x_inter;
@@ -663,7 +659,7 @@
    \return 1 - inside
    \return 2 - on the boundary (exactly may be said only for vertex of vertical/horizontal line)
-int Vect_point_in_poly(double X, double Y, struct line_pnts *Points)
+int Vect_point_in_poly(double X, double Y, const struct line_pnts *Points)
     int n_intersects;
@@ -693,14 +689,14 @@
 int
-Vect_point_in_area_outer_ring(double X, double Y, struct Map_info *Map,
+Vect_point_in_area_outer_ring(double X, double Y, const struct Map_info *Map,
 			      int area)
     static int first = 1;
     int n_intersects, inter;
     int i, line;
-    struct Plus_head *Plus;
+    const struct Plus_head *Plus;
     P_LINE *Line;
     P_AREA *Area;
@@ -758,13 +754,13 @@
    \return 1 - inside
-int Vect_point_in_island(double X, double Y, struct Map_info *Map, int isle)
+int Vect_point_in_island(double X, double Y, const struct Map_info *Map, int isle)
     int i, line;
     P_LINE *Line;
     P_ISLE *Isle;
Modified: grass/trunk/lib/vector/Vlib/read.c
--- grass/trunk/lib/vector/Vlib/read.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/read.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,15 +5,13 @@
-   \date 2001-2008
@@ -66,7 +64,7 @@
    \return -1 out of memory
    \return -2 EOF
-int Vect_read_next_line(struct Map_info *Map,
+int Vect_read_next_line(const struct Map_info *Map,
 			struct line_pnts *line_p, struct line_cats *line_c)
@@ -91,7 +89,7 @@
    \return -1 out of memory,
    \return -2 EOF
-int Vect_read_line(struct Map_info *Map,
+int Vect_read_line(const struct Map_info *Map,
 		   struct line_pnts *line_p, struct line_cats *line_c, int line)
@@ -117,7 +115,7 @@
    \return 1 if feature alive
    \return 0 if feature is dead
-int Vect_line_alive(struct Map_info *Map, int line)
+int Vect_line_alive(const struct Map_info *Map, int line)
     if (Map->plus.Line[line] != NULL)
 	return 1;
@@ -134,7 +132,7 @@
    \return 1 if node alive
    \return 0 if node is dead
-int Vect_node_alive(struct Map_info *Map, int node)
+int Vect_node_alive(const struct Map_info *Map, int node)
     if (Map->plus.Node[node] != NULL)
 	return 1;
@@ -151,7 +149,7 @@
    \return 1 if area alive
    \return 0 if area is dead
-int Vect_area_alive(struct Map_info *Map, int area)
+int Vect_area_alive(const struct Map_info *Map, int area)
     if (Map->plus.Area[area] != NULL)
 	return 1;
@@ -168,7 +166,7 @@
    \return 1 if isle alive
    \return 0 if isle is dead
-int Vect_isle_alive(struct Map_info *Map, int isle)
+int Vect_isle_alive(const struct Map_info *Map, int isle)
     if (Map->plus.Isle[isle] != NULL)
 	return 1;
@@ -187,7 +185,7 @@
   \return feature offset
   \return -1 on error
-off_t Vect_get_line_offset(const struct Map_info *Map, int line)
+off_t Vect_get_line_offset(const const struct Map_info *Map, int line)
     if (line < 1 || line > Map->plus.n_lines)
 	return -1;
Modified: grass/trunk/lib/vector/Vlib/read_nat.c
--- grass/trunk/lib/vector/Vlib/read_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/read_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -10,17 +10,13 @@
    - Vect_read_constraint_type()
    - Vect_remove_constraints()
-   This program is free software under the
-   GNU General Public License (>=v2).
-   Read the file COPYING that comes with GRASS
-   for details.
+   This program is free software under the GNU General Public License
+   (>=v2).  Read the file COPYING that comes with GRASS for details.
-   \date 2001
@@ -37,8 +33,8 @@
  * \brief Read line from coor file on given offset.
- * \param Points container used to store line points within
- * \param Cats container used to store line categories within
+ * \param[out] Points container used to store line points within
+ * \param[out] Cats container used to store line categories within
  * \param offset given offset
  * \return line type
@@ -58,8 +54,8 @@
  * \brief Read next line from coor file.
  * \param Map vector map layer
- * \param line_p container used to store line points within
- * \param line_c container used to store line categories within
+ * \param[out] line_p container used to store line points within
+ * \param[out] line_c container used to store line categories within
  * \return line type
  * \return 0 dead line
@@ -113,8 +109,8 @@
  * \brief Reads any specified line, this is NOT affected by constraints
  * \param line line id
  * \return line type ( > 0 )
@@ -144,8 +140,8 @@
  * \brief Reads next unread line each time called.  Use Vect_rewind to reset.
@@ -201,8 +197,8 @@
- * \param p container used to store line points within
- * \param c container used to store line categories within
+ * \param[out] p container used to store line points within
+ * \param[out] c container used to store line categories within
@@ -222,7 +218,7 @@
     char rhead, nc;
     short field;
-    G_debug(3, "Vect__Read_line_nat: offset = %ld", offset);
+    G_debug(3, "Vect__Read_line_nat: offset = %lu", (unsigned long) offset);
     Map->head.last_offset = offset;
@@ -335,7 +331,7 @@
 	dig_fseek(&(Map->dig_fp), size, SEEK_CUR);
-    G_debug(3, "    off = %ld", dig_ftell(&(Map->dig_fp)));
+    G_debug(3, "    off = %lu", (unsigned long) dig_ftell(&(Map->dig_fp)));
     if (dead)
 	return 0;
Modified: grass/trunk/lib/vector/Vlib/read_ogr.c
--- grass/trunk/lib/vector/Vlib/read_ogr.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/read_ogr.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
    \author Radim Blazek, Piero Cavalieri
-   \date 2001
@@ -30,7 +26,7 @@
  * ftype : if > 0 use this type (because parts of Polygon are read as wkbLineString)
- * \param hGeom OGR geometry
+ * \param[out] hGeom OGR geometry
  * \param ftype feature type
  * \return 0 OK
@@ -132,8 +128,8 @@
  *   - Vect_remove_constraints()
  * \return  line type
  * \return  -2 no more features (EOF)
@@ -231,8 +227,8 @@
  * \brief Read next line from OGR layer.
  * \return  line type
@@ -254,12 +250,12 @@
- * \param Points container used to store line pointes within
+ * \param[out] Points container used to store line pointes within
  * \return 0 OK
  * \return 1 error
-static int read_line(struct Map_info *Map, OGRGeometryH hGeom, long offset,
+static int read_line(const struct Map_info *Map, OGRGeometryH hGeom, long offset,
     int i, nPoints;
@@ -313,8 +309,8 @@
  * \brief Read line from layer on given offset.
  * \return line type
Modified: grass/trunk/lib/vector/Vlib/remove_areas.c
--- grass/trunk/lib/vector/Vlib/remove_areas.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/remove_areas.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
 #include <stdlib.h>
@@ -25,13 +21,12 @@
    \brief Remove small areas from the map map.
-   Centroid of the area and the longest boundary
-   with adjacent area is removed.
-   Map topology must be built GV_BUILD_CENTROIDS.
+   Centroid of the area and the longest boundary with adjacent area is
+   removed.  Map topology must be built GV_BUILD_CENTROIDS.
-   \param Map vector map
+   \param[in,out] Map vector map
    \param thresh maximum area size for removed areas
-   \param Err vector map where removed lines and centroids are written
+   \param[out] Err vector map where removed lines and centroids are written
    \param removed_area  pointer to where total size of removed area is stored or NULL
    \return number of removed areas
Modified: grass/trunk/lib/vector/Vlib/remove_duplicates.c
--- grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/remove_duplicates.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
 #include <stdlib.h>
@@ -23,14 +19,15 @@
 #include <grass/glocale.h>
-   \brief Remove duplicate lines from vector map.
+   \brief Remove duplicate features from vector map.
-   Remove duplicate lines of given types from vector map. Duplicate lines may be optionally
-   written to error map. Input map must be opened on level 2 for update. Categories are merged.
+   Remove duplicate lines of given types from vector map. Duplicate
+   lines may be optionally written to error map. Input map must be
+   opened on level 2 for update. Categories are merged.
-   \param Map vector map where duplicate lines will be deleted
+   \param[in,out] Map vector map where duplicate lines will be deleted
    \param type type of line to be delete
-   \param Err vector map where duplicate lines will be written or NULL
+   \param[out] Err vector map where duplicate lines will be written or NULL
    \return void
Modified: grass/trunk/lib/vector/Vlib/rewind.c
--- grass/trunk/lib/vector/Vlib/rewind.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/rewind.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,19 +5,15 @@
-   for details.
-   \date 2001
 #include <grass/Vect.h>
Modified: grass/trunk/lib/vector/Vlib/rewind_nat.c
--- grass/trunk/lib/vector/Vlib/rewind_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/rewind_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,31 +1,42 @@
- *              for details.
+   \file rewind.c
+   \brief Vector library - rewind data (native format)
+   Higher level functions for reading/writing/manipulating vectors.
+   \author Original author CERL, probably Dave Gerdes or Mike Higgins.
-/* Rewind vector data file to cause reads to start at beginning.
- ** returns 0 on success
- **        -1 on error
+  \brief Rewind vector data file to cause reads to start at beginning (level 1)
+  \param Map vector map
+  \return 0 on success
 int V1_rewind_nat(struct Map_info *Map)
     return (dig_fseek(&(Map->dig_fp), Map->head.head_size, SEEK_SET));
+  \brief Rewind vector data file to cause reads to start at beginning (level 2)
 int V2_rewind_nat(struct Map_info *Map)
     Map->next_line = 1;
Modified: grass/trunk/lib/vector/Vlib/rewind_ogr.c
--- grass/trunk/lib/vector/Vlib/rewind_ogr.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/rewind_ogr.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,28 +1,31 @@
+   \file rewind.c
-* MODULE:       Vector library
-* AUTHOR(S):    Radim Blazek, Piero Cavalieri
-* PURPOSE:      Higher level functions for reading/writing/manipulating vectors.
-* COPYRIGHT:    (C) 2001 by the GRASS Development Team
-*               This program is free software under the GNU General Public
-*   	    	License (>=v2). Read the file COPYING that comes with GRASS
-*   	    	for details.
+   \author Radim Blazek, Piero Cavalieri
 #include <grass/gis.h>
 #ifdef HAVE_OGR
 #include <ogr_api.h>
- **        -1 on error
 int V1_rewind_ogr(struct Map_info *Map)
@@ -36,6 +39,14 @@
     return 0;
 int V2_rewind_ogr(struct Map_info *Map)
     G_debug(2, "V2_rewind_ogr(): name = %s", Map->name);
Modified: grass/trunk/lib/vector/Vlib/select.c
--- grass/trunk/lib/vector/Vlib/select.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/select.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
 #include <stdlib.h>
@@ -24,8 +20,8 @@
    \brief Select lines by box.
-   Select lines whose boxes overlap specified box!!!
-   It means that selected line may or may not overlap the box.
+   Select lines whose boxes overlap specified box!!!  It means that
+   selected line may or may not overlap the box.
    \param Box bounding box
@@ -35,7 +31,7 @@
    \return number of lines
 int
-Vect_select_lines_by_box(struct Map_info *Map, BOUND_BOX * Box,
+Vect_select_lines_by_box(struct Map_info *Map, const BOUND_BOX * Box,
 			 int type, struct ilist *list)
     int i, line, nlines;
@@ -89,7 +85,7 @@
 int
-Vect_select_areas_by_box(struct Map_info *Map, BOUND_BOX * Box,
+Vect_select_areas_by_box(struct Map_info *Map, const BOUND_BOX * Box,
 			 struct ilist *list)
     int i;
@@ -140,7 +136,7 @@
    \return number of isles
 int
-Vect_select_isles_by_box(struct Map_info *Map, BOUND_BOX * Box,
+Vect_select_isles_by_box(struct Map_info *Map, const BOUND_BOX * Box,
 			 struct ilist *list)
     G_debug(3, "Vect_select_isles_by_box()");
@@ -168,7 +164,7 @@
 int
-Vect_select_nodes_by_box(struct Map_info *Map, BOUND_BOX * Box,
+Vect_select_nodes_by_box(struct Map_info *Map, const BOUND_BOX * Box,
 			 struct ilist *list)
     struct Plus_head *plus;
@@ -292,8 +288,7 @@
    Polygons should be closed, i.e. first and last points must be identical.
    Warning : values in list may be duplicate!
    \param Polygon outer ring
    \param nisles number of islands or 0
Modified: grass/trunk/lib/vector/Vlib/sindex.c
--- grass/trunk/lib/vector/Vlib/sindex.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/sindex.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
 #include <stdlib.h>
@@ -31,7 +27,7 @@
    \return void
-void Vect_spatial_index_init(SPATIAL_INDEX * si)
+void Vect_spatial_index_init(SPATIAL_INDEX *si)
     G_debug(1, "Vect_spatial_index_init()");
@@ -47,7 +43,7 @@
    \return void
-void Vect_spatial_index_destroy(SPATIAL_INDEX * si)
+void Vect_spatial_index_destroy(SPATIAL_INDEX *si)
     G_debug(1, "Vect_spatial_index_destroy()");
@@ -57,13 +53,13 @@
    \brief Add a new item to spatial index
-   \param  si pointer to spatial index structure
+   \param[in,out] si pointer to spatial index structure
    \param id item identifier
    \param box pointer to item bounding box
    \return void
-void Vect_spatial_index_add_item(SPATIAL_INDEX * si, int id, BOUND_BOX * box)
+void Vect_spatial_index_add_item(SPATIAL_INDEX *si, int id, const BOUND_BOX *box)
     struct Rect rect;
@@ -81,7 +77,7 @@
    \brief Delete item from spatial index
    \return void
@@ -115,7 +111,7 @@
    To be used in modules.
    Map must be opened on level 2.
+   \param[in,out] Map pointer to vector map
    \param out print progress here
    \return 0 OK
@@ -245,14 +241,14 @@
    \brief Select items by bounding box to list
+   \param si pointer to spatial index structure
    \param box bounding box
    \param list pointer to list where selected items are stored
    \return number of selected items
 int
-Vect_spatial_index_select(SPATIAL_INDEX * si, BOUND_BOX * box,
+Vect_spatial_index_select(const SPATIAL_INDEX * si, const BOUND_BOX * box,
 			  struct ilist *list)
     struct Rect rect;
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/snap.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -7,15 +7,11 @@
- * for details.
  * \author Radim Blazek
- *         update to GRASS 7 Markus Metz
- * \date 2009
+ * \author update to GRASS 7 Markus Metz
 #include <stdlib.h>
@@ -79,24 +75,17 @@
- * \brief Snap selected lines to existing vertex in threshold.
- * Snap selected lines to existing vertices.
- * \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
- * Lines showing how vertices were snapped may be optionally written to error map.
- * Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
- * \param[in] Map input map where vertices will be snapped
- * \param[in] List_lines list of lines to snap
- * \param[in] thresh threshold in which snap vertices
- * \param[out] Err vector map where lines representing snap are written or NULL
- * \return void
-/* As mentioned above, lines are not necessarily snapped to nearest vertex! For example:
+  \brief Snap selected lines to existing vertex in threshold.
+  Snap selected lines to existing vertices.
+  \warning Lines are not necessarily snapped to nearest vertex, but to vertex in threshold!
+  Lines showing how vertices were snapped may be optionally written to error map.
+  Input map must be opened on level 2 for update at least on GV_BUILD_BASE.
+  As mentioned above, lines are not necessarily snapped to nearest vertex! For example:
+  <pre>
    | 1         line 3 is snapped to line 1,
    |           then line 2 is not snapped to common node at lines 1 and 3,
@@ -106,16 +95,24 @@
    | 2
+   </pre>
    The algorithm selects anchor vertices and snaps non-anchor vertices
    to these anchors.
    The distance between anchor vertices is always > threshold.
    If there is more than one anchor vertex within threshold around a
    non-anchor vertex, this vertex is snapped to the nearest anchor
    vertex within threshold.
+   \param Map input map where vertices will be snapped
+   \param List_lines list of lines to snap
+   \param thresh threshold in which snap vertices
+   \param[out] Err vector map where lines representing snap are written or NULL
+   \return void
 void
-Vect_snap_lines_list(struct Map_info *Map, struct ilist *List_lines,
+Vect_snap_lines_list(struct Map_info *Map, const struct ilist *List_lines,
 		     double thresh, struct Map_info *Err)
     struct line_pnts *Points, *NPoints;
Modified: grass/trunk/lib/vector/Vlib/tin.c
--- grass/trunk/lib/vector/Vlib/tin.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/tin.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
Modified: grass/trunk/lib/vector/Vlib/type.c
--- grass/trunk/lib/vector/Vlib/type.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/type.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,12 @@
-   for details.
-   \date 2001
@@ -28,7 +24,7 @@
    \return types
    \return -1 on error
-int Vect_option_to_types(struct Option *type_opt)
+int Vect_option_to_types(const struct Option *type_opt)
     int i = 0;
     int type = 0;
Modified: grass/trunk/lib/vector/Vlib/window.c
--- grass/trunk/lib/vector/Vlib/window.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/window.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,20 +1,17 @@
- *              for details.
+   \file window.c
+   \brief Vector library - window/region
Modified: grass/trunk/lib/vector/Vlib/write.c
--- grass/trunk/lib/vector/Vlib/write.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/write.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -5,16 +5,13 @@
-   for details.
-   \date 2001
+   \author Updated by Martin Landa <landa.martin gmail.com> (restore lines)
@@ -126,7 +123,7 @@
 off_t
 Vect_write_line(struct Map_info *Map,
-		int type, struct line_pnts *points, struct line_cats *cats)
+		int type, const struct line_pnts *points, const struct line_cats *cats)
     off_t offset;
@@ -174,7 +171,7 @@
 int
 Vect_rewrite_line(struct Map_info *Map,
 		  int line,
     long ret;
Modified: grass/trunk/lib/vector/Vlib/write_nat.c
--- grass/trunk/lib/vector/Vlib/write_nat.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/Vlib/write_nat.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -11,7 +11,7 @@
     - Delete feature
     - Restore feature
@@ -19,8 +19,6 @@
    \author V*_restore_line() by Martin Landa <landa.martin gmail.com> (2008)
-   \date 2001
@@ -131,7 +129,7 @@
     Note that 1) and 2) is done by the same code.
 static void add_line_to_topo(struct Map_info *Map, int line,
-			     struct line_pnts *points, struct line_cats *cats)
+			     const struct line_pnts *points, const struct line_cats *cats)
     int first, s, n, i;
     int type, node, next_line, area, side, sel_area, new_area[2];
@@ -299,8 +297,8 @@
     return;
-off_t V1__rewrite_line_nat(struct Map_info *Map, off_t offset, int type,
-			  struct line_pnts *points, struct line_cats *cats);
+static off_t V1__rewrite_line_nat(struct Map_info *Map, off_t offset, int type,
+				  const struct line_pnts *points, const struct line_cats *cats);
   \brief Writes feature to 'coor' file
@@ -314,7 +312,7 @@
   \return -1 on error
 off_t V1_write_line_nat(struct Map_info *Map,
     off_t offset;
@@ -340,7 +338,7 @@
   \return -1 on error
 off_t V2_write_line_nat(struct Map_info *Map,
     int line;
     off_t offset;
@@ -399,9 +397,9 @@
   \return -1 on error
 off_t V1_rewrite_line_nat(struct Map_info *Map,
-			 off_t offset,
-			 int type,
+			  off_t offset,
+			  int type,
     int old_type;
     struct line_pnts *old_points;
@@ -461,7 +459,7 @@
 int V2_rewrite_line_nat(struct Map_info *Map,
 			int line,
 			int type,
     /* TODO: this is just quick shortcut because we have already V2_delete_nat()
      *        and V2_write_nat() this function first deletes old line
@@ -487,9 +485,9 @@
   \return -1 on error
-			  off_t offset,
-			  int type,
+			   off_t offset,
+			   int type,
     int i, n_points;
     char rhead, nc;
@@ -588,7 +586,7 @@
     char rhead;
     GVFILE *dig_fp;
-    G_debug(3, "V1_delete_line_nat(), offset = %ld", offset);
+    G_debug(3, "V1_delete_line_nat(), offset = %lu", (unsigned long) offset);
     dig_set_cur_port(&(Map->head.port));
     dig_fp = &(Map->dig_fp);
@@ -827,7 +825,7 @@
     char rhead;
     GVFILE *dig_fp;
-    G_debug(3, "V1_restore_line_nat(), offset = %ld", offset);
+    G_debug(3, "V1_restore_line_nat(), offset = %lu", (unsigned long) offset);
Modified: grass/trunk/lib/vector/diglib/box.c
--- grass/trunk/lib/vector/diglib/box.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/diglib/box.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -21,7 +21,7 @@
  *  dig_line_box ()
  *  set box to points extent
-int dig_line_box(struct line_pnts *Points, BOUND_BOX * Box)
+int dig_line_box(const struct line_pnts *Points, BOUND_BOX * Box)
     int i;
Modified: grass/trunk/lib/vector/diglib/plus_line.c
--- grass/trunk/lib/vector/diglib/plus_line.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/diglib/plus_line.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -19,7 +19,7 @@
 #include <stdlib.h>
-static int add_line(struct Plus_head *plus, int lineid, int type, struct line_pnts *Points,
+static int add_line(struct Plus_head *plus, int lineid, int type, const struct line_pnts *Points,
 		    off_t offset)
     int node, lp;
@@ -101,7 +101,7 @@
  * \return line id
 int
-dig_add_line(struct Plus_head *plus, int type, struct line_pnts *Points,
+dig_add_line(struct Plus_head *plus, int type, const struct line_pnts *Points,
 	     off_t offset)
     int ret;
Modified: grass/trunk/lib/vector/diglib/plus_node.c
--- grass/trunk/lib/vector/diglib/plus_node.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/diglib/plus_node.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -40,7 +40,7 @@
 int
 dig_node_add_line(struct Plus_head *plus, int nodeid, int lineid,
-		  struct line_pnts *points, int type)
+		  const struct line_pnts *points, int type)
     register int i, j, nlines;
     float angle;
Modified: grass/trunk/lib/vector/diglib/portable.c
--- grass/trunk/lib/vector/diglib/portable.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/diglib/portable.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -460,7 +460,7 @@
 /***************************** WRITE ************************************/
-int dig__fwrite_port_D(double *buf,	/* DOUBLE */
+int dig__fwrite_port_D(const double *buf,	/* DOUBLE */
 		       int cnt, GVFILE * fp)
     int i, j;
@@ -486,7 +486,7 @@
     return 0;
-int dig__fwrite_port_F(float *buf,	/* FLOAT */
+int dig__fwrite_port_F(const float *buf,	/* FLOAT */
     int i, j;
@@ -512,7 +512,7 @@
     return 0;
-int dig__fwrite_port_O(off_t *buf,	/* OFF_T */
+int dig__fwrite_port_O(const off_t *buf,	/* OFF_T */
 		       int cnt, GVFILE * fp, int port_off_t_size)
     int i, j;
@@ -565,7 +565,7 @@
     return 0;
-int dig__fwrite_port_L(long *buf,	/* LONG */
+int dig__fwrite_port_L(const long *buf,	/* LONG */
     int i, j;
@@ -608,7 +608,7 @@
     return 0;
-int dig__fwrite_port_I(int *buf,	/* INT */
+int dig__fwrite_port_I(const int *buf,	/* INT */
     int i, j;
@@ -651,7 +651,7 @@
     return 0;
-int dig__fwrite_port_S(short *buf,	/* SHORT */
+int dig__fwrite_port_S(const short *buf,	/* SHORT */
     int i, j;
@@ -695,13 +695,13 @@
 /* plus_t is defined as int so we only retype pointer and use int function */
-int dig__fwrite_port_P(plus_t * buf,	/* PLUS_T->INT */
+int dig__fwrite_port_P(const plus_t * buf,	/* PLUS_T->INT */
     return (dig__fwrite_port_I((int *)buf, cnt, fp));
-int dig__fwrite_port_C(char *buf,	/* CHAR */
+int dig__fwrite_port_C(const char *buf,	/* CHAR */
     if (dig_fwrite(buf, PORT_CHAR, cnt, fp) == cnt)
Modified: grass/trunk/lib/vector/diglib/spindex.c
--- grass/trunk/lib/vector/diglib/spindex.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/lib/vector/diglib/spindex.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -382,7 +382,7 @@
    \return -1 on error
 int
-dig_select_nodes(struct Plus_head *Plus, BOUND_BOX * box, struct ilist *list)
+dig_select_nodes(struct Plus_head *Plus, const BOUND_BOX * box, struct ilist *list)
     struct Rect rect;
@@ -450,7 +450,7 @@
    \return number of selected lines
 int
-dig_select_lines(struct Plus_head *Plus, BOUND_BOX * box, struct ilist *list)
+dig_select_lines(struct Plus_head *Plus, const BOUND_BOX * box, struct ilist *list)
     struct Rect rect;
@@ -479,7 +479,7 @@
    \return number of selected areas
 int
-dig_select_areas(struct Plus_head *Plus, BOUND_BOX * box, struct ilist *list)
+dig_select_areas(struct Plus_head *Plus, const BOUND_BOX * box, struct ilist *list)
     struct Rect rect;
@@ -508,7 +508,7 @@
    \return number of selected isles
 int
-dig_select_isles(struct Plus_head *Plus, BOUND_BOX * box, struct ilist *list)
+dig_select_isles(struct Plus_head *Plus, const BOUND_BOX * box, struct ilist *list)
     struct Rect rect;
Deleted: grass/trunk/vector/v.buffer2/local_proto.h
--- grass/trunk/vector/v.buffer2/local_proto.h	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/vector/v.buffer2/local_proto.h	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,9 +0,0 @@
-#ifndef LOCAL_PROTO_H
-#define LOCAL_PROTO_H
-void Vect_line_buffer2(struct line_pnts *Points, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_area_buffer2(struct Map_info *Map, int area, double da, double db, double dalpha, int round, int caps, double tol, struct line_pnts **oPoints, struct line_pnts ***iPoints, int *inner_count);
-void Vect_point_buffer2(double px, double py, double da, double db, double dalpha, int round, double tol, struct line_pnts **oPoints);
-void Vect_line_parallel2(struct line_pnts *InPoints, double da, double db, double dalpha, int side, int round, double tol, struct line_pnts *OutPoints);
-#endif
Modified: grass/trunk/vector/v.buffer2/main.c
--- grass/trunk/vector/v.buffer2/main.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/vector/v.buffer2/main.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -22,7 +22,6 @@
 #include <grass/dbmi.h>
-#include "local_proto.h"
 #define PI M_PI
 #ifndef MIN
Deleted: grass/trunk/vector/v.parallel2/local_proto.h
--- grass/trunk/vector/v.parallel2/local_proto.h	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/vector/v.parallel2/local_proto.h	2009-04-05 14:30:56 UTC (rev 36588)
@@ -1,9 +0,0 @@
-#endif
Modified: grass/trunk/vector/v.parallel2/main.c
--- grass/trunk/vector/v.parallel2/main.c	2009-04-05 03:22:12 UTC (rev 36587)
+++ grass/trunk/vector/v.parallel2/main.c	2009-04-05 14:30:56 UTC (rev 36588)
@@ -21,7 +21,6 @@
 int main(int argc, char *argv[])
