[GRASS-SVN] r36728 - grass/branches/releasebranch_6_4/lib/vector/Vlib
Tue Apr 14 07:42:09 EDT 2009
Author: mmetz
Date: 2009-04-14 07:42:09 -0400 (Tue, 14 Apr 2009)
New Revision: 36728
   grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c
bugfix for #397 backported
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c	2009-04-14 11:40:35 UTC (rev 36727)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/build_nat.c	2009-04-14 11:42:09 UTC (rev 36728)
@@ -332,7 +332,6 @@
     static int first = 1;
     static struct ilist *List;
     P_AREA *Area;
-    P_NODE *Node;
     P_LINE *Line;
     struct Plus_head *plus;
@@ -365,6 +364,10 @@
      * to check if original area exist, unregister centroid from previous area.
      * To simplify code, this is implemented so that centroid is always firs unregistered
      * and if new area is found, it is registered again.
+     * This problem can be avoided altogether if properly attached centroids
+     * are skipped
+     * MM 2009
     Vect_select_lines_by_box(Map, box, GV_CENTROID, List);
@@ -374,18 +377,18 @@
 	centr = List->value[i];
 	Line = plus->Line[centr];
-	Node = plus->Node[Line->N1];
-	/* Unregister centroid */
+	/* only attach unregistered and duplicate centroids because
+	 * 1) all properly attached centroids are properly attached, really! Don't touch.
+	 * 2) Vect_find_area() below does not always return the correct area
+	 * 3) it's faster
+	if (Line->left > 0)
+	    continue;
 	orig_area = Line->left;
-	if (orig_area > 0) {
-	    if (plus->Area[orig_area] != NULL) {
-		plus->Area[orig_area]->centroid = 0;
-	Line->left = 0;
-	sel_area = Vect_find_area(Map, Node->x, Node->y);
+	sel_area = Vect_find_area(Map, Line->E, Line->N);
 	G_debug(3, "  centroid %d is in area %d", centr, sel_area);
 	if (sel_area > 0) {
 	    Area = plus->Area[sel_area];
@@ -393,12 +396,18 @@
 		G_debug(3, "  first centroid -> attach to area");
 		Area->centroid = centr;
 		Line->left = sel_area;
+		if (sel_area != orig_area && plus->do_uplist)
+		    dig_line_add_updated(plus, centr);
 	    else if (Area->centroid != centr) {	/* duplicate centroid */
 		/* Note: it cannot happen that Area->centroid == centr, because the centroid
-		 * was previously unregistered */
+		 * was not registered or a duplicate */
 		G_debug(3, "  duplicate centroid -> do not attach to area");
 		Line->left = -sel_area;
+		if (-sel_area != orig_area && plus->do_uplist)
