[GRASS-SVN] r36791 - grass/trunk/gui/wxpython/gui_modules
Sun Apr 19 13:12:37 EDT 2009
Author: martinl
Date: 2009-04-19 13:12:36 -0400 (Sun, 19 Apr 2009)
New Revision: 36791
   grass/trunk/gui/wxpython/gui_modules/menuform.py
Attempt to fix trac #552 (add vector map layer in layer manager doesn't show any paramter window)
       (merge from relber64, r36789)
Modified: grass/trunk/gui/wxpython/gui_modules/menuform.py
--- grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-04-19 17:08:36 UTC (rev 36790)
+++ grass/trunk/gui/wxpython/gui_modules/menuform.py	2009-04-19 17:12:36 UTC (rev 36791)
@@ -53,6 +53,7 @@
 import os
 import time
 import copy
+import locale
 ### i18N
 import gettext
@@ -1729,8 +1730,14 @@
         # parse the interface decription
         self.grass_task = grassTask()
         handler = processTask(self.grass_task)
-        xml.sax.parseString( getInterfaceDescription(cmd[0]), handler )
+        enc = locale.getdefaultlocale()[1]
+        if enc and enc.lower() not in ("utf8", "utf-8"):
+            xml.sax.parseString(getInterfaceDescription(cmd[0]).decode(enc).encode("utf-8"),
+                                handler)
+        else:
+            xml.sax.parseString(getInterfaceDescription(cmd[0]),
+                                handler)
         # if layer parameters previously set, re-insert them into dialog
         if completed is not None:
             if 'params' in dcmd_params:
