[GRASS-SVN] r36796 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Apr 19 15:00:29 EDT 2009
Author: martinl
Date: 2009-04-19 15:00:28 -0400 (Sun, 19 Apr 2009)
New Revision: 36796
   grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
wxGUI/location wizard - search in codes/desc/params (see trac #554)
	       (merge from relbr64, r36795)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-04-19 18:57:12 UTC (rev 36795)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-04-19 19:00:28 UTC (rev 36796)
@@ -424,7 +424,7 @@
         """Search projection by desc"""
         str = event.GetString()
         try:
-            self.proj, self.projdesc = self.projlist.Search(index=1, str=event.GetString())
+            self.proj, self.projdesc = self.projlist.Search(index=1, pattern=event.GetString())
         except:
             self.proj = self.projdesc = ''
@@ -614,21 +614,21 @@
         """Used by listmix.ColumnSorterMixin"""
         return self
-    def Search (self, index, str):
+    def Search (self, index, pattern):
         """Search projection by description
         Return first found item or None
-        if str == '':
+        if pattern == '':
             self.Populate(self.sourceData)
             return []
         data = []
-        str = str.lower()
+        pattern = pattern.lower()
         for i in range(len(self.sourceData)):
             try:
-                value = self.sourceData[i][index].lower()
-                if str in value:
+                value = str(self.sourceData[i][index]).lower()
+                if pattern in value:
                     data.append(self.sourceData[i])
             except UnicodeDecodeError:
                 # osgeo4w problem (should be fixed)
@@ -866,7 +866,7 @@
     def OnDText(self, event):
         self.datum = event.GetString()
-        self.transformlist.Search(index=1, str=self.datum)
+        self.transformlist.Search(index=1, pattern=self.datum)
         if self.transformlist.GetItemCount() > 0:
             self.hastransform = True
         else:
@@ -909,8 +909,8 @@
     def OnDSearch(self, event):
         str =  self.searchb.GetValue()
         try:
-            self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=1, str=str)
+            self.datum, self.datumdesc, self.ellipsoid = self.datumlist.Search(index=1, pattern=str)
         except:
             self.datum = self.datumdesc = self.ellipsoid = ''
@@ -1050,7 +1050,7 @@
         try:
             self.ellipse, self.ellipsedesc = \
-                self.ellipselist.Search(index=1, str=event.GetString())
+                self.ellipselist.Search(index=1, pattern=event.GetString())
             self.ellipseparams = self.parent.ellipsoids[self.ellipse][1]
             self.proj4params = self.parent.ellipsoids[self.ellipse][2]
         except:
@@ -1246,9 +1246,11 @@
                                     style=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL)
         self.lcode= self.MakeLabel(_("EPSG code:"),
-        self.lsearch = self.MakeLabel(_("Search in description:"),
+        self.lsearch = self.MakeLabel(_("Search in"),
+        self.csearch = wx.Choice(parent = self, id = wx.ID_ANY,
+                                 choices = [_("codes"), _("description"), _("parameters")])
         # text input
         epsgdir = utils.PathJoin(os.environ["GRASS_PROJSHARE"], 'epsg')
         self.tfile = self.MakeTextCtrl(text=epsgdir, size=(200,-1))
@@ -1270,42 +1272,46 @@
         self.sizer.Add(item=self.lfile,
                        flag=wx.ALIGN_LEFT |
                        wx.ALIGN_CENTER_VERTICAL |
-                       wx.ALL, border=5, pos=(1, 1))
+                       wx.ALL, border=5, pos=(1, 1), span=(1, 2))
         self.sizer.Add(item=self.tfile,
-                       wx.ALL, border=5, pos=(1, 2))
+                       wx.ALL, border=5, pos=(1, 3))
         self.sizer.Add(item=self.bbrowse,
-                       wx.ALL, border=5, pos=(1, 3))
+                       wx.ALL, border=5, pos=(1, 4))
         self.sizer.Add(item=self.lcode,
-                       wx.ALL, border=5, pos=(2, 1))
+                       wx.ALL, border=5, pos=(2, 1), span=(1, 2))
         self.sizer.Add(item=self.tcode,
-                       wx.ALL, border=5, pos=(2, 2))
+                       wx.ALL, border=5, pos=(2, 3))
         self.sizer.Add(item=self.lsearch,
                        wx.ALL, border=5, pos=(3, 1))
+        self.sizer.Add(item=self.csearch,
+                       flag=wx.ALIGN_LEFT |
+                       wx.ALIGN_CENTER_VERTICAL |
+                       wx.ALL, border=5, pos=(3, 2))
         self.sizer.Add(item=self.searchb,
-                       wx.ALL, border=5, pos=(3, 2))
+                       wx.ALL, border=5, pos=(3, 3))
         self.sizer.Add(item=self.bbcodes,
-                       wx.ALL, border=5, pos=(3, 3))
+                       wx.ALL, border=5, pos=(3, 4))
         self.sizer.AddGrowableRow(4)
         self.sizer.Add(item=self.epsglist,
                        flag=wx.ALIGN_LEFT | wx.EXPAND, pos=(4, 1),
-                       span=(1, 3))
+                       span=(1, 4))
         # events
         self.bbrowse.Bind(wx.EVT_BUTTON, self.OnBrowse)
@@ -1364,7 +1370,8 @@
             return
         try:
-            self.epsgcode = self.epsglist.Search(index=1, str=value)[0]
+            self.epsgcode = self.epsglist.Search(index=self.csearch.GetSelection(),
+                                                 pattern=value)[0]
             self.tcode.SetValue(str(self.epsgcode))
         except IndexError: # -> no item found
             self.epsgcode = None
