[GRASS-SVN] r36922 - in grass/trunk: . general/g.cairocomp include/Make
Thu Apr 30 10:18:33 EDT 2009
Author: martinl
Date: 2009-04-30 10:18:33 -0400 (Thu, 30 Apr 2009)
New Revision: 36922
   grass/trunk/configure
   grass/trunk/configure.in
   grass/trunk/general/g.cairocomp/Makefile
   grass/trunk/include/Make/Platform.make.in
Define CAIRO_HAS_XRENDER_SURFACE (trac #419)
Modified: grass/trunk/configure
--- grass/trunk/configure	2009-04-30 12:20:56 UTC (rev 36921)
+++ grass/trunk/configure	2009-04-30 14:18:33 UTC (rev 36922)
@@ -13744,7 +13744,7 @@
 else
   echo "$ac_t""no" 1>&6
-CAIRO_HAS_XRENDER=0
+CAIRO_HAS_XRENDER=
 fi
@@ -13753,6 +13753,65 @@
+ac_save_libs="$LIBS"
+ac_save_ldflags="$LDFLAGS"
+LIBS=" $CAIROLIB $LIBS"
+LDFLAGS=" $LDFLAGS"
+echo $ac_n "checking for cairo_xlib_surface_get_xrender_format""... $ac_c" 1>&6
+echo "configure:13762: checking for cairo_xlib_surface_get_xrender_format" >&5
+cat > conftest.$ac_ext <<EOF
+#line 13765 "configure"
+#include "confdefs.h"
+/* System header to define __stub macros and hopefully few prototypes,
+    which can conflict with char cairo_xlib_surface_get_xrender_format(); below.  */
+#include <assert.h>
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char cairo_xlib_surface_get_xrender_format();
+int main() {
+/* The GNU C library defines this for functions which it implements
+    to always fail with ENOSYS.  Some functions are actually named
+    something starting with __ and the normal name is an alias.  */
+#if defined (__stub_cairo_xlib_surface_get_xrender_format) || defined (__stub___cairo_xlib_surface_get_xrender_format)
+choke me
+#else
+cairo_xlib_surface_get_xrender_format();
+#endif
+; return 0; }
+EOF
+if { (eval echo configure:13788: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_func_cairo_xlib_surface_get_xrender_format=no"
+fi
+rm -f conftest*
+if eval "test \"`echo '$ac_cv_func_'cairo_xlib_surface_get_xrender_format`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+CAIRO_HAS_XRENDER_SURFACE=1
+else
+  echo "$ac_t""no" 1>&6
+fi
+LIBS=${ac_save_libs}
+LDFLAGS=${ac_save_ldflags}
 CAIROLIB="$CAIROLIB $CAIROLDFLAGS"
 fi # $USE_CAIRO
@@ -13767,7 +13826,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:13771: checking whether to use FreeType" >&5
+echo "configure:13830: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -13786,7 +13845,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:13790: checking for location of FreeType includes" >&5
+echo "configure:13849: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -13812,15 +13871,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13816: checking for $ac_hdr" >&5
+echo "configure:13875: checking for $ac_hdr" >&5
-#line 13819 "configure"
+#line 13878 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13824: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13883: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13854,7 +13913,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:13858: checking for location of FreeType library" >&5
+echo "configure:13917: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -13879,13 +13938,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:13883: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:13942: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-lfreetype  $LIBS"
-#line 13889 "configure"
+#line 13948 "configure"
@@ -13896,7 +13955,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:13900: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13959: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13937,7 +13996,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:13941: checking whether to use NLS" >&5
+echo "configure:14000: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -13957,10 +14016,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:13961: checking for gettext" >&5
+echo "configure:14020: checking for gettext" >&5
-#line 13964 "configure"
+#line 14023 "configure"
     which can conflict with char gettext(); below.  */
@@ -13983,7 +14042,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13987: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14046: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -14001,13 +14060,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:14005: checking for gettext in -lintl" >&5
+echo "configure:14064: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 14011 "configure"
+#line 14070 "configure"
@@ -14018,7 +14077,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:14022: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14081: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14053,7 +14112,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:14057: checking whether to use C++" >&5
+echo "configure:14116: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -14069,7 +14128,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:14073: checking for $ac_word" >&5
+echo "configure:14132: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -14098,7 +14157,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:14102: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:14161: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -14109,12 +14168,12 @@
 cat > conftest.$ac_ext << EOF
-#line 14113 "configure"
+#line 14172 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:14118: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14177: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -14140,19 +14199,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:14144: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:14203: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:14149: checking whether we are using GNU C++" >&5
+echo "configure:14208: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14156: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:14215: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -14170,7 +14229,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:14174: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:14233: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -14211,7 +14270,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:14215: checking whether to use openDWG" >&5
+echo "configure:14274: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -14231,7 +14290,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:14235: checking for location of openDGW includes" >&5
+echo "configure:14294: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -14257,15 +14316,15 @@
 do
-echo "configure:14261: checking for $ac_hdr" >&5
+echo "configure:14320: checking for $ac_hdr" >&5
-#line 14264 "configure"
+#line 14323 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14269: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14328: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14299,7 +14358,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:14303: checking for location of openDWG library" >&5
+echo "configure:14362: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -14340,7 +14399,7 @@
 echo $ac_n "checking whether to use POSIX threads""... $ac_c" 1>&6
-echo "configure:14344: checking whether to use POSIX threads" >&5
+echo "configure:14403: checking whether to use POSIX threads" >&5
 echo "$ac_t"""$with_pthread"" 1>&6
 case "$with_pthread" in
 	"no")	USE_PTHREAD=	;;
@@ -14360,7 +14419,7 @@
 echo $ac_n "checking for location of POSIX threads includes""... $ac_c" 1>&6
-echo "configure:14364: checking for location of POSIX threads includes" >&5
+echo "configure:14423: checking for location of POSIX threads includes" >&5
 case "$with_pthread_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-includes." 1>&2; exit 1; }
@@ -14386,15 +14445,15 @@
 do
-echo "configure:14390: checking for $ac_hdr" >&5
+echo "configure:14449: checking for $ac_hdr" >&5
-#line 14393 "configure"
+#line 14452 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14398: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14457: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14428,7 +14487,7 @@
 echo $ac_n "checking for location of POSIX threads library""... $ac_c" 1>&6
-echo "configure:14432: checking for location of POSIX threads library" >&5
+echo "configure:14491: checking for location of POSIX threads library" >&5
 case "$with_pthread_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-pthread-libs." 1>&2; exit 1; }
@@ -14453,10 +14512,10 @@
 LIBS="  $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for pthread_create""... $ac_c" 1>&6
-echo "configure:14457: checking for pthread_create" >&5
+echo "configure:14516: checking for pthread_create" >&5
-#line 14460 "configure"
+#line 14519 "configure"
     which can conflict with char pthread_create(); below.  */
@@ -14479,7 +14538,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14483: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14542: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_pthread_create=yes"
 else
@@ -14506,13 +14565,13 @@
 echo $ac_n "checking for pthread_create in -lpthread""... $ac_c" 1>&6
-echo "configure:14510: checking for pthread_create in -lpthread" >&5
+echo "configure:14569: checking for pthread_create in -lpthread" >&5
 ac_lib_var=`echo pthread'_'pthread_create | sed 'y%./+-%__p_%'`
 LIBS="-lpthread  $LIBS"
-#line 14516 "configure"
+#line 14575 "configure"
@@ -14523,7 +14582,7 @@
 pthread_create()
 ; return 0; }
 EOF
-if { (eval echo configure:14527: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14586: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14579,7 +14638,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:14583: checking for special C compiler options needed for large files" >&5
+echo "configure:14642: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -14587,7 +14646,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 14591 "configure"
+#line 14650 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -14603,7 +14662,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14607: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14666: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
@@ -14612,7 +14671,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 14616 "configure"
+#line 14675 "configure"
@@ -14628,7 +14687,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14632: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14691: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -14648,11 +14707,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:14652: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:14711: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 14656 "configure"
+#line 14715 "configure"
@@ -14668,14 +14727,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14672: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14731: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14679 "configure"
+#line 14738 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -14693,7 +14752,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14756: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -14712,11 +14771,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:14716: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:14775: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 14720 "configure"
+#line 14779 "configure"
@@ -14732,14 +14791,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14736: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14795: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14743 "configure"
+#line 14802 "configure"
 #define _LARGE_FILES 1
@@ -14757,7 +14816,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14820: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -14776,25 +14835,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:14780: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:14839: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 14784 "configure"
+#line 14843 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14791: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14850: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 14798 "configure"
+#line 14857 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -14803,7 +14862,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:14807: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14866: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -14824,10 +14883,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:14828: checking if system supports Large Files at all" >&5
+echo "configure:14887: checking if system supports Large Files at all" >&5
-#line 14831 "configure"
+#line 14890 "configure"
 #include <stdio.h>
@@ -14859,7 +14918,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:14863: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:14922: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -14888,7 +14947,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:14892: checking whether to use Python" >&5
+echo "configure:14951: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -14908,7 +14967,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:14912: checking for $ac_word" >&5
+echo "configure:14971: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -14953,15 +15012,15 @@
 do
-echo "configure:14957: checking for $ac_hdr" >&5
+echo "configure:15016: checking for $ac_hdr" >&5
-#line 14960 "configure"
+#line 15019 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14965: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15024: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15001,7 +15060,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15005: checking for $ac_word" >&5
+echo "configure:15064: checking for $ac_word" >&5
 case "$SWIG" in
@@ -15047,7 +15106,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:15051: checking whether to use wxWidgets" >&5
+echo "configure:15110: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -15067,7 +15126,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:15071: checking for $ac_word" >&5
+echo "configure:15130: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -15115,7 +15174,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:15119: checking wxWidgets version" >&5
+echo "configure:15178: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -15138,15 +15197,15 @@
 do
-echo "configure:15142: checking for $ac_hdr" >&5
+echo "configure:15201: checking for $ac_hdr" >&5
-#line 15145 "configure"
+#line 15204 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15150: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15209: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15436,6 +15495,7 @@
 s%@LAPACKLIB@%$LAPACKLIB%g
 s%@LAPACKINC@%$LAPACKINC%g
 s%@CAIRO_HAS_XRENDER@%$CAIRO_HAS_XRENDER%g
+s%@CAIRO_HAS_XRENDER_SURFACE@%$CAIRO_HAS_XRENDER_SURFACE%g
 s%@CAIROINC@%$CAIROINC%g
 s%@CAIROLIB@%$CAIROLIB%g
 s%@USE_CAIRO@%$USE_CAIRO%g
Modified: grass/trunk/configure.in
--- grass/trunk/configure.in	2009-04-30 12:20:56 UTC (rev 36921)
+++ grass/trunk/configure.in	2009-04-30 14:18:33 UTC (rev 36922)
@@ -8,7 +8,7 @@
 # PURPOSE:  	This configure runs all the tests to determine what components
 #   	    	are installed on the current system. It also defines certain
 #   	    	configuration variables for compilation and installation.
-# COPYRIGHT:    (C) 2000-2008 by the GRASS Development Team
+# COPYRIGHT:    (C) 2000-2009 by the GRASS Development Team
 #               This program is free software under the GNU General Public
 #   	    	License (>=v2). Read the file COPYING that comes with GRASS
@@ -1455,8 +1455,11 @@
 LOC_CHECK_FUNC(cairo_create,,,,,$CAIROLIB,[:])
 LOC_CHECK_FUNC(cairo_xlib_surface_create_with_xrender_format,,,,,$CAIROLIB,
-[CAIRO_HAS_XRENDER=1],[CAIRO_HAS_XRENDER=0])
+[CAIRO_HAS_XRENDER=1],[CAIRO_HAS_XRENDER=])
 AC_SUBST(CAIRO_HAS_XRENDER)
+LOC_CHECK_FUNC(cairo_xlib_surface_get_xrender_format,,,,,$CAIROLIB,
+[CAIRO_HAS_XRENDER_SURFACE=1],[CAIRO_HAS_XRENDER_SURFACE=])
+AC_SUBST(CAIRO_HAS_XRENDER_SURFACE)
Modified: grass/trunk/general/g.cairocomp/Makefile
--- grass/trunk/general/g.cairocomp/Makefile	2009-04-30 12:20:56 UTC (rev 36921)
+++ grass/trunk/general/g.cairocomp/Makefile	2009-04-30 14:18:33 UTC (rev 36922)
@@ -1,4 +1,3 @@
 MODULE_TOPDIR = ../..
 PGM = g.cairocomp
@@ -11,7 +10,9 @@
 ifneq ($(USE_CAIRO),)
 ifneq ($(USE_X11),)
 ifneq ($(CAIRO_HAS_XRENDER),)
+ifneq ($(CAIRO_HAS_XRENDER_SURFACE),)
 default: cmd
 endif
 endif
 endif
+endif
Modified: grass/trunk/include/Make/Platform.make.in
--- grass/trunk/include/Make/Platform.make.in	2009-04-30 12:20:56 UTC (rev 36921)
+++ grass/trunk/include/Make/Platform.make.in	2009-04-30 14:18:33 UTC (rev 36922)
@@ -212,10 +212,11 @@
 USE_OPENDWG         = @USE_OPENDWG@
 #cairo
-CAIROINC            = @CAIROINC@
-CAIROLIB            = @CAIROLIB@
-USE_CAIRO           = @USE_CAIRO@
-CAIRO_HAS_XRENDER   = @CAIRO_HAS_XRENDER@
+CAIROINC                  = @CAIROINC@
+CAIROLIB                  = @CAIROLIB@
+USE_CAIRO                 = @USE_CAIRO@
+CAIRO_HAS_XRENDER         = @CAIRO_HAS_XRENDER@
+CAIRO_HAS_XRENDER_SURFACE = @CAIRO_HAS_XRENDER_SURFACE@
 #Python
 PYTHONINC           = @PYTHONINC@
