[GRASS-SVN] r38580 - grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing
Sun Aug 2 09:25:50 EDT 2009
Author: neteler
Date: 2009-08-02 09:25:50 -0400 (Sun, 02 Aug 2009)
New Revision: 38580
   grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c
strip off mapset from input for SQL
Modified: grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c
--- grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c	2009-08-02 13:25:23 UTC (rev 38579)
+++ grass/branches/releasebranch_6_4/vector/lidar/v.lidar.growing/main.c	2009-08-02 13:25:50 UTC (rev 38580)
@@ -46,6 +46,7 @@
     double Thres_j, Thres_d, ew_resol, ns_resol;
     double minNS, minEW, maxNS, maxEW;
     char *mapset, buf[1024];
+    char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
     int colorBordo, ripieno, conta, lungPunti, lungHull, xi, c1, c2;
     double altPiano;
@@ -117,6 +118,8 @@
     /* Open input vector */
     Vect_check_input_output_name(in_opt->answer, out_opt->answer,
 				 GV_FATAL_EXIT);
+    if(G__name_is_fully_qualified(in_opt->answer, xname, xmapset) < 0 ) /* strip off mapset from input for SQL*/
+	G_fatal_error(_("Vector map <%s> not found"), xname);
     if ((mapset = G_find_vector2(in_opt->answer, "")) == NULL) {
 	G_fatal_error(_("Vector map <%s> not found"), in_opt->answer);
@@ -169,11 +172,12 @@
     db_zero_string(&sql);
     sprintf(buf, "SELECT Interp,ID FROM %s_edge_Interpolation",
-	    in_opt->answer);
+	    xname);
+    G_debug(1,"buf: %s", buf);
     db_append_string(&sql, buf);
     if (db_open_select_cursor(driver, &sql, &cursor, DB_SEQUENTIAL) != DB_OK)
-	G_fatal_error(_("It was impossible to open table"));
+	G_fatal_error(_("Unable to create table <%s_edge_Interpolation>"), xname);
     count_obj = 1;
@@ -494,6 +498,6 @@
     db_close_database_shutdown_driver(driver);
-    G_done_msg("");
+    G_done_msg(" ");
     exit(EXIT_SUCCESS);
