[GRASS-SVN] r38626 - grass/trunk/vector/v.buffer
Thu Aug 6 04:48:42 EDT 2009
Author: hamish
Date: 2009-08-06 04:48:41 -0400 (Thu, 06 Aug 2009)
New Revision: 38626
   grass/trunk/vector/v.buffer/main.c
+missing guisections (merge from devbr6)
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2009-08-06 08:48:27 UTC (rev 38625)
+++ grass/trunk/vector/v.buffer/main.c	2009-08-06 08:48:41 UTC (rev 38626)
@@ -180,6 +180,7 @@
     angle_opt->required = NO;
     angle_opt->answer = "0";
     angle_opt->description = _("Angle of major axis in degrees");
+    angle_opt->guisection = _("Distance");
     bufcol_opt = G_define_standard_option(G_OPT_DB_COLUMN);
     bufcol_opt->key = "bufcolumn";
@@ -193,6 +194,7 @@
     scale_opt->required = NO;
     scale_opt->answer = "1.0";
     scale_opt->description = _("Scaling factor for attribute column values");
+    scale_opt->guisection = _("Distance");
     tol_opt = G_define_option();
     tol_opt->key = "tolerance";
