[GRASS-SVN] r38650 - grass/trunk/scripts/r.tileset
Sun Aug 9 05:12:34 EDT 2009
Author: hamish
Date: 2009-08-09 05:12:34 -0400 (Sun, 09 Aug 2009)
New Revision: 38650
   grass/trunk/scripts/r.tileset/r.tileset.html
trivial cosmetic whitespace
Modified: grass/trunk/scripts/r.tileset/r.tileset.html
--- grass/trunk/scripts/r.tileset/r.tileset.html	2009-08-09 09:10:30 UTC (rev 38649)
+++ grass/trunk/scripts/r.tileset/r.tileset.html	2009-08-09 09:12:34 UTC (rev 38650)
@@ -5,6 +5,7 @@
 the current region and its resolution are used, the bounds and
 resolution of another region can be used via the region option.
 <h2>NOTES</h2>
 <em>r.tileset</em> does not make "optimal" tilings (as few tiles of
@@ -14,7 +15,6 @@
 twice the necessary information. Furthermore, generating a tiling near
 a divergant point of a source projection, such as the poles of a
 cylindrical source projections, results in divergence of the tile set.
 <p>
 Not generating "optimal" tilings may have another consequence; the
 aspect ratio of cells in the destination region will not necessarily
@@ -23,6 +23,7 @@
 services presenting data in an inappropriate projection or with strict
 constraints on cell aspect ratio.
 <h2>OUTPUT FORMAT</h2>
 Each tile is listed on a seperate line in the output. The lines are
@@ -56,6 +57,7 @@
 http services.
 </dl>
 <h2>EXAMPLES</h2>
 <dl>
@@ -90,15 +92,18 @@
 work in a unix style shell.
 </dl>
 <h2>BUGS</h2>
 <ul>
 <li><em>r.tileset</em> does not know about meridians that
 "wrap-around" in projections.  </ul>
 <h2>AUTHORS</h2>
 Cedric Shock<br>
 Updated for GRASS 7 by Martin Landa, CTU in Prague, Czech Republic
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
