[GRASS-SVN] r38786 - grass/trunk/gui/wxpython/gui_modules
Wed Aug 19 03:41:02 EDT 2009
Author: hamish
Date: 2009-08-19 03:41:02 -0400 (Wed, 19 Aug 2009)
New Revision: 38786
   grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
merge from devbr6-
 double-quotes for WinGrass;
 access tables not in the current mapset;
 skip non-column lines of db.describe -c;
 fix os.popen usage and quote DB (needs conversion to gcmd.RunCommand);
 quote DB in os.system (needs conversion to gcmd.RunCommand)
Modified: grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py
--- grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py	2009-08-19 07:38:34 UTC (rev 38785)
+++ grass/trunk/gui/wxpython/gui_modules/sqlbuilder.py	2009-08-19 07:41:02 UTC (rev 38786)
@@ -52,7 +52,7 @@
             self.vectmap = self.vectmap + "@" + grass.gisenv()['MAPSET']
         self.mapname, self.mapset = self.vectmap.split("@")
         self.layer,self.tablename, self.column, self.database, self.driver =\
-                 os.popen("v.db.connect -g fs='|' map=%s" %\
+                 os.popen("v.db.connect -g fs=\"|\" map=%s" %\
                 (self.vectmap)).readlines()[0].strip().split("|")
         self.qtype = qtype        # type of the uqery: SELECT, UPDATE, DELETE, ...
@@ -224,10 +224,16 @@
                               quiet = True,
                               read = True,
                               flags = 'c',
-                              table = self.tablename)
+                              table = self.tablename,
+                              database = self.database,
+                              driver = self.driver)
-        # skip ncols and nrows lines
         for line in ret.splitlines():
+            # skip ncols and nrows lines
+            linetype = line.strip().split(":")[0]
+            if linetype == "ncols" or linetype == "nrows":
+                continue
             num, name, ctype, length = line.strip().split(":")
             name.strip()
             #self.columns_names.append(name)
@@ -243,7 +249,7 @@
         self.list_values.Clear()
         column = self.list_columns.GetString(idx)
         i = 0
-        for line in os.popen("""!db.select -c database=%s driver=%s sql="SELECT %s FROM %s" """ %\
+        for line in os.popen("db.select -c database=\"%s\" driver=%s sql=\"SELECT %s FROM %s\"" %\
                 (self.database,self.driver,column,self.tablename)):
                 if justsample and i < 256 or \
                    not justsample:
@@ -314,7 +320,7 @@
                 pass
     def OnVerify(self,event):
         if self.text_sql.GetValue():
-            if os.system("""!db.select -t driver=%s database=%s sql="SELECT * FROM %s WHERE %s" """ % \
+            if os.system("""!db.select -t driver=%s database="%s" sql="SELECT * FROM %s WHERE %s" """ % \
                     (self.driver, self.database,self.tablename,
                         self.text_sql.GetValue().strip().replace("\n"," "))):
                 # FIXME: LOG
