[GRASS-SVN] r38868 - grass/branches/develbranch_6
Wed Aug 26 03:59:40 EDT 2009
Author: martinl
Date: 2009-08-26 03:59:39 -0400 (Wed, 26 Aug 2009)
New Revision: 38868
   grass/branches/develbranch_6/configure
   grass/branches/develbranch_6/configure.in
check initGEOS() geos_c
      (merge from trunk, r38867)
Modified: grass/branches/develbranch_6/configure
--- grass/branches/develbranch_6/configure	2009-08-26 07:45:30 UTC (rev 38867)
+++ grass/branches/develbranch_6/configure	2009-08-26 07:59:39 UTC (rev 38868)
@@ -8162,7 +8162,58 @@
 CPPFLAGS=$ac_save_cppflags
+ac_save_ldflags="$LDFLAGS"
+LDFLAGS="$GEOS_LIBS $LDFLAGS"
+echo $ac_n "checking for initGEOS in -lgeos_c""... $ac_c" 1>&6
+echo "configure:8172: checking for initGEOS in -lgeos_c" >&5
+ac_lib_var=`echo geos_c'_'initGEOS | sed 'y%./+-%__p_%'`
+ac_save_LIBS="$LIBS"
+LIBS="-lgeos_c  $LIBS"
+cat > conftest.$ac_ext <<EOF
+#line 8178 "configure"
+#include "confdefs.h"
+/* Override any gcc2 internal prototype to avoid an error.  */
+/* We use char because int might match the return type of a gcc2
+    builtin and then its argument prototype would still apply.  */
+char initGEOS();
+int main() {
+initGEOS()
+; return 0; }
+EOF
+if { (eval echo configure:8189: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=yes"
+else
+  echo "configure: failed program was:" >&5
+  cat conftest.$ac_ext >&5
+  rm -rf conftest*
+  eval "ac_cv_lib_$ac_lib_var=no"
+fi
+rm -f conftest*
+LIBS="$ac_save_LIBS"
+if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
+  echo "$ac_t""yes" 1>&6
+  GEOS_LIBS="$GEOS_LIBS -lgeos_c "
+else
+  echo "$ac_t""no" 1>&6
+LDFLAGS=${ac_save_ldflags}
+    { echo "configure: error: *** Unable to locate GEOS library." 1>&2; exit 1; }
+fi
   cat >> confdefs.h <<\EOF
 #define HAVE_GEOS 1
 EOF
@@ -8177,7 +8228,7 @@
 echo $ac_n "checking whether to use TIFF""... $ac_c" 1>&6
-echo "configure:8181: checking whether to use TIFF" >&5
+echo "configure:8232: checking whether to use TIFF" >&5
 echo "$ac_t"""$with_tiff"" 1>&6
 case "$with_tiff" in
 	"no")	USE_TIFF=	;;
@@ -8197,7 +8248,7 @@
 echo $ac_n "checking for location of TIFF includes""... $ac_c" 1>&6
-echo "configure:8201: checking for location of TIFF includes" >&5
+echo "configure:8252: checking for location of TIFF includes" >&5
 case "$with_tiff_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-includes." 1>&2; exit 1; }
@@ -8223,15 +8274,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:8227: checking for $ac_hdr" >&5
+echo "configure:8278: checking for $ac_hdr" >&5
-#line 8230 "configure"
+#line 8281 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:8235: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8286: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -8265,7 +8316,7 @@
 echo $ac_n "checking for location of TIFF library""... $ac_c" 1>&6
-echo "configure:8269: checking for location of TIFF library" >&5
+echo "configure:8320: checking for location of TIFF library" >&5
 case "$with_tiff_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tiff-libs." 1>&2; exit 1; }
@@ -8296,13 +8347,13 @@
 echo $ac_n "checking for TIFFOpen in -ltiff""... $ac_c" 1>&6
-echo "configure:8300: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8351: checking for TIFFOpen in -ltiff" >&5
 ac_lib_var=`echo tiff'_'TIFFOpen | sed 'y%./+-%__p_%'`
 LIBS="-ltiff  $LIBS"
-#line 8306 "configure"
+#line 8357 "configure"
@@ -8313,7 +8364,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8317: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8368: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8332,13 +8383,13 @@
-echo "configure:8336: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8387: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $MATHLIB $LIBS"
-#line 8342 "configure"
+#line 8393 "configure"
@@ -8349,7 +8400,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8353: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8404: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8368,13 +8419,13 @@
-echo "configure:8372: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8423: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $LIBS"
-#line 8378 "configure"
+#line 8429 "configure"
@@ -8385,7 +8436,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8389: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8440: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8404,13 +8455,13 @@
-echo "configure:8408: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8459: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $ZLIB $MATHLIB $LIBS"
-#line 8414 "configure"
+#line 8465 "configure"
@@ -8421,7 +8472,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8425: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8476: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8440,13 +8491,13 @@
-echo "configure:8444: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8495: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $LIBS"
-#line 8450 "configure"
+#line 8501 "configure"
@@ -8457,7 +8508,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8461: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8512: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8476,13 +8527,13 @@
-echo "configure:8480: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8531: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $MATHLIB $LIBS"
-#line 8486 "configure"
+#line 8537 "configure"
@@ -8493,7 +8544,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8497: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8548: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8512,13 +8563,13 @@
-echo "configure:8516: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8567: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $LIBS"
-#line 8522 "configure"
+#line 8573 "configure"
@@ -8529,7 +8580,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8548,13 +8599,13 @@
-echo "configure:8552: checking for TIFFOpen in -ltiff" >&5
+echo "configure:8603: checking for TIFFOpen in -ltiff" >&5
 LIBS="-ltiff $JPEGLIBPATH $JPEGLIB $ZLIB $MATHLIB $LIBS"
-#line 8558 "configure"
+#line 8609 "configure"
@@ -8565,7 +8616,7 @@
 TIFFOpen()
 ; return 0; }
 EOF
-if { (eval echo configure:8569: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8620: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8663,7 +8714,7 @@
 echo $ac_n "checking whether to use PNG""... $ac_c" 1>&6
-echo "configure:8667: checking whether to use PNG" >&5
+echo "configure:8718: checking whether to use PNG" >&5
 echo "$ac_t"""$with_png"" 1>&6
 case "$with_png" in
 	"no")	USE_PNG=	;;
@@ -8682,7 +8733,7 @@
 echo $ac_n "checking for location of PNG includes""... $ac_c" 1>&6
-echo "configure:8686: checking for location of PNG includes" >&5
+echo "configure:8737: checking for location of PNG includes" >&5
 case "$with_png_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-includes." 1>&2; exit 1; }
@@ -8708,15 +8759,15 @@
 do
-echo "configure:8712: checking for $ac_hdr" >&5
+echo "configure:8763: checking for $ac_hdr" >&5
-#line 8715 "configure"
+#line 8766 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8720: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8771: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8750,7 +8801,7 @@
 echo $ac_n "checking for location of PNG library""... $ac_c" 1>&6
-echo "configure:8754: checking for location of PNG library" >&5
+echo "configure:8805: checking for location of PNG library" >&5
 case "$with_png_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-png-libs." 1>&2; exit 1; }
@@ -8775,13 +8826,13 @@
 echo $ac_n "checking for png_read_image in -lpng""... $ac_c" 1>&6
-echo "configure:8779: checking for png_read_image in -lpng" >&5
+echo "configure:8830: checking for png_read_image in -lpng" >&5
 ac_lib_var=`echo png'_'png_read_image | sed 'y%./+-%__p_%'`
 LIBS="-lpng $ZLIB $MATHLIB $LIBS"
-#line 8785 "configure"
+#line 8836 "configure"
@@ -8792,7 +8843,7 @@
 png_read_image()
 ; return 0; }
 EOF
-if { (eval echo configure:8796: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:8847: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8834,7 +8885,7 @@
 echo $ac_n "checking whether to use PostgreSQL""... $ac_c" 1>&6
-echo "configure:8838: checking whether to use PostgreSQL" >&5
+echo "configure:8889: checking whether to use PostgreSQL" >&5
 echo "$ac_t"""$with_postgres"" 1>&6
 case "$with_postgres" in
 	"no")	USE_POSTGRES=	;;
@@ -8861,7 +8912,7 @@
 echo $ac_n "checking for location of PostgreSQL includes""... $ac_c" 1>&6
-echo "configure:8865: checking for location of PostgreSQL includes" >&5
+echo "configure:8916: checking for location of PostgreSQL includes" >&5
 case "$with_postgres_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-includes." 1>&2; exit 1; }
@@ -8887,15 +8938,15 @@
 do
-echo "configure:8891: checking for $ac_hdr" >&5
+echo "configure:8942: checking for $ac_hdr" >&5
-#line 8894 "configure"
+#line 8945 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:8899: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:8950: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -8933,7 +8984,7 @@
 echo $ac_n "checking for location of PostgreSQL library""... $ac_c" 1>&6
-echo "configure:8937: checking for location of PostgreSQL library" >&5
+echo "configure:8988: checking for location of PostgreSQL library" >&5
 case "$with_postgres_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-postgres-libs." 1>&2; exit 1; }
@@ -8962,13 +9013,13 @@
 echo $ac_n "checking for PQsetdbLogin in -lpq""... $ac_c" 1>&6
-echo "configure:8966: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9017: checking for PQsetdbLogin in -lpq" >&5
 ac_lib_var=`echo pq'_'PQsetdbLogin | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 8972 "configure"
+#line 9023 "configure"
@@ -8979,7 +9030,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:8983: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9034: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -8998,13 +9049,13 @@
-echo "configure:9002: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9053: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lssl -lcrypto $LIBS"
-#line 9008 "configure"
+#line 9059 "configure"
@@ -9015,7 +9066,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9019: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9070: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9034,13 +9085,13 @@
-echo "configure:9038: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9089: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt $LIBS"
-#line 9044 "configure"
+#line 9095 "configure"
@@ -9051,7 +9102,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9055: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9106: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9070,13 +9121,13 @@
-echo "configure:9074: checking for PQsetdbLogin in -lpq" >&5
+echo "configure:9125: checking for PQsetdbLogin in -lpq" >&5
 LIBS="-lpq -lcrypt -lssl -lcrypto $LIBS"
-#line 9080 "configure"
+#line 9131 "configure"
@@ -9087,7 +9138,7 @@
 PQsetdbLogin()
 ; return 0; }
 EOF
-if { (eval echo configure:9091: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9142: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9144,13 +9195,13 @@
 LDFLAGS="$LDFLAGS $PQLIBPATH"
 echo $ac_n "checking for PQcmdTuples in -lpq""... $ac_c" 1>&6
-echo "configure:9148: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9199: checking for PQcmdTuples in -lpq" >&5
 ac_lib_var=`echo pq'_'PQcmdTuples | sed 'y%./+-%__p_%'`
 LIBS="-lpq  $LIBS"
-#line 9154 "configure"
+#line 9205 "configure"
@@ -9161,7 +9212,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9165: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9183,13 +9234,13 @@
-echo "configure:9187: checking for PQcmdTuples in -lpq" >&5
+echo "configure:9238: checking for PQcmdTuples in -lpq" >&5
-#line 9193 "configure"
+#line 9244 "configure"
@@ -9200,7 +9251,7 @@
 PQcmdTuples()
 ; return 0; }
 EOF
-if { (eval echo configure:9204: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9255: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9243,7 +9294,7 @@
 echo $ac_n "checking whether to use MySQL""... $ac_c" 1>&6
-echo "configure:9247: checking whether to use MySQL" >&5
+echo "configure:9298: checking whether to use MySQL" >&5
 echo "$ac_t"""$with_mysql"" 1>&6
 case "$with_mysql" in
 	"no")	USE_MYSQL=	;;
@@ -9263,7 +9314,7 @@
 echo $ac_n "checking for location of MySQL includes""... $ac_c" 1>&6
-echo "configure:9267: checking for location of MySQL includes" >&5
+echo "configure:9318: checking for location of MySQL includes" >&5
 case "$with_mysql_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-includes." 1>&2; exit 1; }
@@ -9289,15 +9340,15 @@
 do
-echo "configure:9293: checking for $ac_hdr" >&5
+echo "configure:9344: checking for $ac_hdr" >&5
-#line 9296 "configure"
+#line 9347 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9301: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9352: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9334,7 +9385,7 @@
 echo $ac_n "checking for location of MySQL library""... $ac_c" 1>&6
-echo "configure:9338: checking for location of MySQL library" >&5
+echo "configure:9389: checking for location of MySQL library" >&5
 case "$with_mysql_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-mysql-libs." 1>&2; exit 1; }
@@ -9365,13 +9416,13 @@
 echo $ac_n "checking for mysql_query in -lmysqlclient""... $ac_c" 1>&6
-echo "configure:9369: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9420: checking for mysql_query in -lmysqlclient" >&5
 ac_lib_var=`echo mysqlclient'_'mysql_query | sed 'y%./+-%__p_%'`
 LIBS="-lmysqlclient  $LIBS"
-#line 9375 "configure"
+#line 9426 "configure"
@@ -9382,7 +9433,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9386: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9437: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9401,13 +9452,13 @@
-echo "configure:9405: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9456: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $MATHLIB $LIBS"
-#line 9411 "configure"
+#line 9462 "configure"
@@ -9418,7 +9469,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9473: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9437,13 +9488,13 @@
-echo "configure:9441: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9492: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $LIBS"
-#line 9447 "configure"
+#line 9498 "configure"
@@ -9454,7 +9505,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9458: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9509: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9473,13 +9524,13 @@
-echo "configure:9477: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9528: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $SOCKLIB $MATHLIB $LIBS"
-#line 9483 "configure"
+#line 9534 "configure"
@@ -9490,7 +9541,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9494: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9545: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9509,13 +9560,13 @@
-echo "configure:9513: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9564: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $LIBS"
-#line 9519 "configure"
+#line 9570 "configure"
@@ -9526,7 +9577,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9530: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9581: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9545,13 +9596,13 @@
-echo "configure:9549: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9600: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $MATHLIB $LIBS"
-#line 9555 "configure"
+#line 9606 "configure"
@@ -9562,7 +9613,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9566: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9617: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9581,13 +9632,13 @@
-echo "configure:9585: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9636: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $LIBS"
-#line 9591 "configure"
+#line 9642 "configure"
@@ -9598,7 +9649,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9602: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9653: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9617,13 +9668,13 @@
-echo "configure:9621: checking for mysql_query in -lmysqlclient" >&5
+echo "configure:9672: checking for mysql_query in -lmysqlclient" >&5
 LIBS="-lmysqlclient $ZLIB $SOCKLIB $MATHLIB $LIBS"
-#line 9627 "configure"
+#line 9678 "configure"
@@ -9634,7 +9685,7 @@
 mysql_query()
 ; return 0; }
 EOF
-if { (eval echo configure:9638: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9689: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9724,7 +9775,7 @@
   # Extract the first word of "mysql_config", so it can be a program name with args.
 set dummy mysql_config; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:9728: checking for $ac_word" >&5
+echo "configure:9779: checking for $ac_word" >&5
 case "$MYSQLD_CONFIG" in
@@ -9765,10 +9816,10 @@
     LIBS="$MYSQLDLIB $LIBS"
     echo $ac_n "checking for mysql_server_init""... $ac_c" 1>&6
-echo "configure:9769: checking for mysql_server_init" >&5
+echo "configure:9820: checking for mysql_server_init" >&5
-#line 9772 "configure"
+#line 9823 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char mysql_server_init(); below.  */
@@ -9791,7 +9842,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:9795: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:9846: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_mysql_server_init=yes"
 else
@@ -9829,7 +9880,7 @@
 echo $ac_n "checking whether to use SQLite""... $ac_c" 1>&6
-echo "configure:9833: checking whether to use SQLite" >&5
+echo "configure:9884: checking whether to use SQLite" >&5
 echo "$ac_t"""$with_sqlite"" 1>&6
 case "$with_sqlite" in
 	"no")	USE_SQLITE=	;;
@@ -9849,7 +9900,7 @@
 echo $ac_n "checking for location of SQLite includes""... $ac_c" 1>&6
-echo "configure:9853: checking for location of SQLite includes" >&5
+echo "configure:9904: checking for location of SQLite includes" >&5
 case "$with_sqlite_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-includes." 1>&2; exit 1; }
@@ -9875,15 +9926,15 @@
 do
-echo "configure:9879: checking for $ac_hdr" >&5
+echo "configure:9930: checking for $ac_hdr" >&5
-#line 9882 "configure"
+#line 9933 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:9887: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:9938: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -9926,7 +9977,7 @@
 echo $ac_n "checking for location of SQLite library""... $ac_c" 1>&6
-echo "configure:9930: checking for location of SQLite library" >&5
+echo "configure:9981: checking for location of SQLite library" >&5
 case "$with_sqlite_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-sqlite-libs." 1>&2; exit 1; }
@@ -9953,13 +10004,13 @@
 echo $ac_n "checking for sqlite3_open in -lsqlite3""... $ac_c" 1>&6
-echo "configure:9957: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10008: checking for sqlite3_open in -lsqlite3" >&5
 ac_lib_var=`echo sqlite3'_'sqlite3_open | sed 'y%./+-%__p_%'`
 LIBS="-lsqlite3  $LIBS"
-#line 9963 "configure"
+#line 10014 "configure"
@@ -9970,7 +10021,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:9974: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10025: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -9989,13 +10040,13 @@
-echo "configure:9993: checking for sqlite3_open in -lsqlite3" >&5
+echo "configure:10044: checking for sqlite3_open in -lsqlite3" >&5
 LIBS="-lsqlite3 $MATHLIB $LIBS"
-#line 9999 "configure"
+#line 10050 "configure"
@@ -10006,7 +10057,7 @@
 sqlite3_open()
 ; return 0; }
 EOF
-if { (eval echo configure:10010: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10061: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10059,7 +10110,7 @@
 echo $ac_n "checking whether to use FFMPEG""... $ac_c" 1>&6
-echo "configure:10063: checking whether to use FFMPEG" >&5
+echo "configure:10114: checking whether to use FFMPEG" >&5
 echo "$ac_t"""$with_ffmpeg"" 1>&6
 case "$with_ffmpeg" in
 	"no")	USE_FFMPEG=	;;
@@ -10079,7 +10130,7 @@
 echo $ac_n "checking for location of FFMPEG includes""... $ac_c" 1>&6
-echo "configure:10083: checking for location of FFMPEG includes" >&5
+echo "configure:10134: checking for location of FFMPEG includes" >&5
 case "$with_ffmpeg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-includes." 1>&2; exit 1; }
@@ -10105,15 +10156,15 @@
 do
-echo "configure:10109: checking for $ac_hdr" >&5
+echo "configure:10160: checking for $ac_hdr" >&5
-#line 10112 "configure"
+#line 10163 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10117: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10168: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10149,15 +10200,15 @@
 do
-echo "configure:10153: checking for $ac_hdr" >&5
+echo "configure:10204: checking for $ac_hdr" >&5
-#line 10156 "configure"
+#line 10207 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10161: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10212: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10193,15 +10244,15 @@
 do
-echo "configure:10197: checking for $ac_hdr" >&5
+echo "configure:10248: checking for $ac_hdr" >&5
-#line 10200 "configure"
+#line 10251 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10205: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10256: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10244,7 +10295,7 @@
 echo $ac_n "checking for location of FFMPEG library""... $ac_c" 1>&6
-echo "configure:10248: checking for location of FFMPEG library" >&5
+echo "configure:10299: checking for location of FFMPEG library" >&5
 case "$with_ffmpeg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-ffmpeg-libs." 1>&2; exit 1; }
@@ -10271,13 +10322,13 @@
 echo $ac_n "checking for av_free in -lavutil""... $ac_c" 1>&6
-echo "configure:10275: checking for av_free in -lavutil" >&5
+echo "configure:10326: checking for av_free in -lavutil" >&5
 ac_lib_var=`echo avutil'_'av_free | sed 'y%./+-%__p_%'`
 LIBS="-lavutil  $LIBS"
-#line 10281 "configure"
+#line 10332 "configure"
@@ -10288,7 +10339,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10292: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10343: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10307,13 +10358,13 @@
-echo "configure:10311: checking for av_free in -lavutil" >&5
+echo "configure:10362: checking for av_free in -lavutil" >&5
 LIBS="-lavutil $MATHLIB $LIBS"
-#line 10317 "configure"
+#line 10368 "configure"
@@ -10324,7 +10375,7 @@
 av_free()
 ; return 0; }
 EOF
-if { (eval echo configure:10328: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10379: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10369,13 +10420,13 @@
 echo $ac_n "checking for avcodec_init in -lavcodec""... $ac_c" 1>&6
-echo "configure:10373: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10424: checking for avcodec_init in -lavcodec" >&5
 ac_lib_var=`echo avcodec'_'avcodec_init | sed 'y%./+-%__p_%'`
 LIBS="-lavcodec $FFMPEGLIB  $LIBS"
-#line 10379 "configure"
+#line 10430 "configure"
@@ -10386,7 +10437,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10441: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10405,13 +10456,13 @@
-echo "configure:10409: checking for avcodec_init in -lavcodec" >&5
+echo "configure:10460: checking for avcodec_init in -lavcodec" >&5
 LIBS="-lavcodec $FFMPEGLIB $MATHLIB $LIBS"
-#line 10415 "configure"
+#line 10466 "configure"
@@ -10422,7 +10473,7 @@
 avcodec_init()
 ; return 0; }
 EOF
-if { (eval echo configure:10426: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10477: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10467,13 +10518,13 @@
 echo $ac_n "checking for av_set_parameters in -lavformat""... $ac_c" 1>&6
-echo "configure:10471: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10522: checking for av_set_parameters in -lavformat" >&5
 ac_lib_var=`echo avformat'_'av_set_parameters | sed 'y%./+-%__p_%'`
 LIBS="-lavformat $FFMPEGLIB  $LIBS"
-#line 10477 "configure"
+#line 10528 "configure"
@@ -10484,7 +10535,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10488: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10539: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10503,13 +10554,13 @@
-echo "configure:10507: checking for av_set_parameters in -lavformat" >&5
+echo "configure:10558: checking for av_set_parameters in -lavformat" >&5
 LIBS="-lavformat $FFMPEGLIB $MATHLIB $LIBS"
-#line 10513 "configure"
+#line 10564 "configure"
@@ -10520,7 +10571,7 @@
 av_set_parameters()
 ; return 0; }
 EOF
-if { (eval echo configure:10524: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10575: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10579,7 +10630,7 @@
 OPENGL_WINDOWS=
 echo $ac_n "checking whether to use OpenGL""... $ac_c" 1>&6
-echo "configure:10583: checking whether to use OpenGL" >&5
+echo "configure:10634: checking whether to use OpenGL" >&5
 echo "$ac_t"""$with_opengl"" 1>&6
 case "$with_opengl" in
 	n|no)
@@ -10613,7 +10664,7 @@
 echo $ac_n "checking for location of OpenGL includes""... $ac_c" 1>&6
-echo "configure:10617: checking for location of OpenGL includes" >&5
+echo "configure:10668: checking for location of OpenGL includes" >&5
 case "$with_opengl_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-includes." 1>&2; exit 1; }
@@ -10639,15 +10690,15 @@
 do
-echo "configure:10643: checking for $ac_hdr" >&5
+echo "configure:10694: checking for $ac_hdr" >&5
-#line 10646 "configure"
+#line 10697 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:10651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:10702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -10681,7 +10732,7 @@
 echo $ac_n "checking for location of OpenGL library""... $ac_c" 1>&6
-echo "configure:10685: checking for location of OpenGL library" >&5
+echo "configure:10736: checking for location of OpenGL library" >&5
 case "$with_opengl_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opengl-libs." 1>&2; exit 1; }
@@ -10710,13 +10761,13 @@
 echo $ac_n "checking for glBegin in -lGL""... $ac_c" 1>&6
-echo "configure:10714: checking for glBegin in -lGL" >&5
+echo "configure:10765: checking for glBegin in -lGL" >&5
 ac_lib_var=`echo GL'_'glBegin | sed 'y%./+-%__p_%'`
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10720 "configure"
+#line 10771 "configure"
@@ -10727,7 +10778,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10731: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10782: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10746,13 +10797,13 @@
-echo "configure:10750: checking for glBegin in -lGL" >&5
+echo "configure:10801: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lXext $LIBS"
-#line 10756 "configure"
+#line 10807 "configure"
@@ -10763,7 +10814,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10767: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10818: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10782,13 +10833,13 @@
-echo "configure:10786: checking for glBegin in -lGL" >&5
+echo "configure:10837: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread $LIBS"
-#line 10792 "configure"
+#line 10843 "configure"
@@ -10799,7 +10850,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10803: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10854: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10818,13 +10869,13 @@
-echo "configure:10822: checking for glBegin in -lGL" >&5
+echo "configure:10873: checking for glBegin in -lGL" >&5
 LIBS="-lGL $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lpthread -lXext $LIBS"
-#line 10828 "configure"
+#line 10879 "configure"
@@ -10835,7 +10886,7 @@
 glBegin()
 ; return 0; }
 EOF
-if { (eval echo configure:10839: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10890: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10897,13 +10948,13 @@
 echo $ac_n "checking for gluBeginCurve in -lGLU""... $ac_c" 1>&6
-echo "configure:10901: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10952: checking for gluBeginCurve in -lGLU" >&5
 ac_lib_var=`echo GLU'_'gluBeginCurve | sed 'y%./+-%__p_%'`
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 10907 "configure"
+#line 10958 "configure"
@@ -10914,7 +10965,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10918: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:10969: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10933,13 +10984,13 @@
-echo "configure:10937: checking for gluBeginCurve in -lGLU" >&5
+echo "configure:10988: checking for gluBeginCurve in -lGLU" >&5
 LIBS="-lGLU $OPENGLLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB -lstdc++ $LIBS"
-#line 10943 "configure"
+#line 10994 "configure"
@@ -10950,7 +11001,7 @@
 gluBeginCurve()
 ; return 0; }
 EOF
-if { (eval echo configure:10954: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11005: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -10994,10 +11045,10 @@
 LDFLAGS="$LDFLAGS $OPENGLLIB"
 echo $ac_n "checking for glXCreatePbuffer""... $ac_c" 1>&6
-echo "configure:10998: checking for glXCreatePbuffer" >&5
+echo "configure:11049: checking for glXCreatePbuffer" >&5
-#line 11001 "configure"
+#line 11052 "configure"
     which can conflict with char glXCreatePbuffer(); below.  */
@@ -11020,7 +11071,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11024: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11075: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreatePbuffer=yes"
 else
@@ -11042,10 +11093,10 @@
 fi
 echo $ac_n "checking for glXCreateGLXPixmap""... $ac_c" 1>&6
-echo "configure:11046: checking for glXCreateGLXPixmap" >&5
+echo "configure:11097: checking for glXCreateGLXPixmap" >&5
-#line 11049 "configure"
+#line 11100 "configure"
     which can conflict with char glXCreateGLXPixmap(); below.  */
@@ -11068,7 +11119,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11072: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11123: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glXCreateGLXPixmap=yes"
 else
@@ -11107,7 +11158,7 @@
-echo "configure:11111: checking for location of OpenGL includes" >&5
+echo "configure:11162: checking for location of OpenGL includes" >&5
@@ -11133,15 +11184,15 @@
 do
-echo "configure:11137: checking for $ac_hdr" >&5
+echo "configure:11188: checking for $ac_hdr" >&5
-#line 11140 "configure"
+#line 11191 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11145: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11196: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11176,10 +11227,10 @@
 LDFLAGS="$with_opengl_libs $LDFLAGS"
 echo $ac_n "checking for glBegin""... $ac_c" 1>&6
-echo "configure:11180: checking for glBegin" >&5
+echo "configure:11231: checking for glBegin" >&5
-#line 11183 "configure"
+#line 11234 "configure"
     which can conflict with char glBegin(); below.  */
@@ -11202,7 +11253,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11206: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11257: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_glBegin=yes"
 else
@@ -11217,10 +11268,10 @@
 echo $ac_n "checking for gluBeginCurve""... $ac_c" 1>&6
-echo "configure:11221: checking for gluBeginCurve" >&5
+echo "configure:11272: checking for gluBeginCurve" >&5
-#line 11224 "configure"
+#line 11275 "configure"
     which can conflict with char gluBeginCurve(); below.  */
@@ -11243,7 +11294,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:11247: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11298: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gluBeginCurve=yes"
 else
@@ -11287,7 +11338,7 @@
-echo "configure:11291: checking for location of OpenGL includes" >&5
+echo "configure:11342: checking for location of OpenGL includes" >&5
@@ -11313,15 +11364,15 @@
 do
-echo "configure:11317: checking for $ac_hdr" >&5
+echo "configure:11368: checking for $ac_hdr" >&5
-#line 11320 "configure"
+#line 11371 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11325: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11376: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11355,7 +11406,7 @@
-echo "configure:11359: checking for location of OpenGL library" >&5
+echo "configure:11410: checking for location of OpenGL library" >&5
@@ -11380,18 +11431,18 @@
 ac_save_libs="$LIBS"
 echo $ac_n "checking for OpenGL library""... $ac_c" 1>&6
-echo "configure:11384: checking for OpenGL library" >&5
+echo "configure:11435: checking for OpenGL library" >&5
 LDFLAGS="$OPENGL_LIB_PATH $LDFLAGS"
 LIBS="-lopengl32  "
-#line 11388 "configure"
+#line 11439 "configure"
 #include <GL/gl.h>
 int main() {
 glEnd();
 ; return 0; }
 EOF
-if { (eval echo configure:11395: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11446: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 echo "$ac_t""found" 1>&6
@@ -11415,18 +11466,18 @@
 echo $ac_n "checking for GLU library""... $ac_c" 1>&6
-echo "configure:11419: checking for GLU library" >&5
+echo "configure:11470: checking for GLU library" >&5
 LIBS="-lglu32 $OPENGLLIB "
-#line 11423 "configure"
+#line 11474 "configure"
 #include <GL/glu.h>
 int main() {
 gluNewQuadric();
 ; return 0; }
 EOF
-if { (eval echo configure:11430: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11481: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -11475,7 +11526,7 @@
 echo $ac_n "checking whether to use Tcl/Tk""... $ac_c" 1>&6
-echo "configure:11479: checking whether to use Tcl/Tk" >&5
+echo "configure:11530: checking whether to use Tcl/Tk" >&5
 echo "$ac_t"""$with_tcltk"" 1>&6
 case "$with_tcltk" in
 	"no")	USE_TCLTK=	;;
@@ -11495,7 +11546,7 @@
 echo $ac_n "checking for location of Tcl/Tk includes""... $ac_c" 1>&6
-echo "configure:11499: checking for location of Tcl/Tk includes" >&5
+echo "configure:11550: checking for location of Tcl/Tk includes" >&5
 case "$with_tcltk_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-includes." 1>&2; exit 1; }
@@ -11521,15 +11572,15 @@
 do
-echo "configure:11525: checking for $ac_hdr" >&5
+echo "configure:11576: checking for $ac_hdr" >&5
-#line 11528 "configure"
+#line 11579 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11533: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11584: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11566,15 +11617,15 @@
 do
-echo "configure:11570: checking for $ac_hdr" >&5
+echo "configure:11621: checking for $ac_hdr" >&5
-#line 11573 "configure"
+#line 11624 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:11578: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:11629: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -11607,7 +11658,7 @@
 # Tcl/Tk version checks
 echo $ac_n "checking Tcl version""... $ac_c" 1>&6
-echo "configure:11611: checking Tcl version" >&5
+echo "configure:11662: checking Tcl version" >&5
 ac_save_cppflags="$CPPFLAGS"
 CPPFLAGS="$TCLINCDIR $CPPFLAGS"
 if test "$cross_compiling" = yes; then
@@ -11615,7 +11666,7 @@
     echo "$ac_t""unknown (cross-compiling)" 1>&6
 else
-#line 11619 "configure"
+#line 11670 "configure"
 #include <stdio.h>
@@ -11627,7 +11678,7 @@
 EOF
-if { (eval echo configure:11631: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11682: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tcl_ver=`cat conftestdata`
     echo "$ac_t""$tcl_ver" 1>&6
@@ -11645,7 +11696,7 @@
 echo $ac_n "checking Tk version""... $ac_c" 1>&6
-echo "configure:11649: checking Tk version" >&5
+echo "configure:11700: checking Tk version" >&5
 CPPFLAGS="$TCLINCDIR $X_CFLAGS $CPPFLAGS"
@@ -11653,7 +11704,7 @@
 else
-#line 11657 "configure"
+#line 11708 "configure"
 #include <stdio.h>
@@ -11665,7 +11716,7 @@
 EOF
-if { (eval echo configure:11669: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
+if { (eval echo configure:11720: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext} && (./conftest; exit) 2>/dev/null
 then
      tk_ver=`cat conftestdata`
     echo "$ac_t""$tk_ver" 1>&6
@@ -11696,7 +11747,7 @@
 echo $ac_n "checking for location of Tcl/Tk library""... $ac_c" 1>&6
-echo "configure:11700: checking for location of Tcl/Tk library" >&5
+echo "configure:11751: checking for location of Tcl/Tk library" >&5
 case "$with_tcltk_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-tcltk-libs." 1>&2; exit 1; }
@@ -11744,13 +11795,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl""... $ac_c" 1>&6
-echo "configure:11748: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11799: checking for Tcl_Init in -ltcl" >&5
 ac_lib_var=`echo tcl'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl $MATHLIB $LIBS"
-#line 11754 "configure"
+#line 11805 "configure"
@@ -11761,7 +11812,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11765: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11816: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11780,13 +11831,13 @@
-echo "configure:11784: checking for Tcl_Init in -ltcl" >&5
+echo "configure:11835: checking for Tcl_Init in -ltcl" >&5
 LIBS="-ltcl $MATHLIB $DLLIB $LIBS"
-#line 11790 "configure"
+#line 11841 "configure"
@@ -11797,7 +11848,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11801: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11852: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11824,13 +11875,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver""... $ac_c" 1>&6
-echo "configure:11828: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11879: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 ac_lib_var=`echo tcl$tcltk_ver'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver $MATHLIB $LIBS"
-#line 11834 "configure"
+#line 11885 "configure"
@@ -11841,7 +11892,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11845: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11896: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11860,13 +11911,13 @@
-echo "configure:11864: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
+echo "configure:11915: checking for Tcl_Init in -ltcl$tcltk_ver" >&5
 LIBS="-ltcl$tcltk_ver $MATHLIB $DLLIB $LIBS"
-#line 11870 "configure"
+#line 11921 "configure"
@@ -11877,7 +11928,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11881: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11932: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11904,13 +11955,13 @@
 echo $ac_n "checking for Tcl_Init in -ltcl$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:11908: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11959: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 ac_lib_var=`echo tcl$tcltk_ver2'_'Tcl_Init | sed 'y%./+-%__p_%'`
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $LIBS"
-#line 11914 "configure"
+#line 11965 "configure"
@@ -11921,7 +11972,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11925: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:11976: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -11940,13 +11991,13 @@
-echo "configure:11944: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
+echo "configure:11995: checking for Tcl_Init in -ltcl$tcltk_ver2" >&5
 LIBS="-ltcl$tcltk_ver2 $MATHLIB $DLLIB $LIBS"
-#line 11950 "configure"
+#line 12001 "configure"
@@ -11957,7 +12008,7 @@
 Tcl_Init()
 ; return 0; }
 EOF
-if { (eval echo configure:11961: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12012: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12035,13 +12086,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk""... $ac_c" 1>&6
-echo "configure:12039: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12090: checking for Tk_MainWindow in -ltk" >&5
 ac_lib_var=`echo tk'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk $TCLLIB $MATHLIB $LIBS"
-#line 12045 "configure"
+#line 12096 "configure"
@@ -12052,7 +12103,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12056: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12071,13 +12122,13 @@
-echo "configure:12075: checking for Tk_MainWindow in -ltk" >&5
+echo "configure:12126: checking for Tk_MainWindow in -ltk" >&5
 LIBS="-ltk $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12081 "configure"
+#line 12132 "configure"
@@ -12088,7 +12139,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12092: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12143: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12115,13 +12166,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver""... $ac_c" 1>&6
-echo "configure:12119: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12170: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 ac_lib_var=`echo tk$tcltk_ver'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $LIBS"
-#line 12125 "configure"
+#line 12176 "configure"
@@ -12132,7 +12183,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12136: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12187: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12151,13 +12202,13 @@
-echo "configure:12155: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
+echo "configure:12206: checking for Tk_MainWindow in -ltk$tcltk_ver" >&5
 LIBS="-ltk$tcltk_ver $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12161 "configure"
+#line 12212 "configure"
@@ -12168,7 +12219,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12172: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12223: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12195,13 +12246,13 @@
 echo $ac_n "checking for Tk_MainWindow in -ltk$tcltk_ver2""... $ac_c" 1>&6
-echo "configure:12199: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12250: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 ac_lib_var=`echo tk$tcltk_ver2'_'Tk_MainWindow | sed 'y%./+-%__p_%'`
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $LIBS"
-#line 12205 "configure"
+#line 12256 "configure"
@@ -12212,7 +12263,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12216: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12267: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12231,13 +12282,13 @@
-echo "configure:12235: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
+echo "configure:12286: checking for Tk_MainWindow in -ltk$tcltk_ver2" >&5
 LIBS="-ltk$tcltk_ver2 $TCLLIB $MATHLIB $X_LIBS $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $LIBS"
-#line 12241 "configure"
+#line 12292 "configure"
@@ -12248,7 +12299,7 @@
 Tk_MainWindow()
 ; return 0; }
 EOF
-if { (eval echo configure:12252: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12303: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12347,7 +12398,7 @@
 echo $ac_n "checking whether to use ODBC""... $ac_c" 1>&6
-echo "configure:12351: checking whether to use ODBC" >&5
+echo "configure:12402: checking whether to use ODBC" >&5
 echo "$ac_t"""$with_odbc"" 1>&6
 case "$with_odbc" in
 	"no")	USE_ODBC=	;;
@@ -12366,7 +12417,7 @@
 echo $ac_n "checking for location of ODBC includes""... $ac_c" 1>&6
-echo "configure:12370: checking for location of ODBC includes" >&5
+echo "configure:12421: checking for location of ODBC includes" >&5
 case "$with_odbc_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-includes." 1>&2; exit 1; }
@@ -12392,15 +12443,15 @@
 do
-echo "configure:12396: checking for $ac_hdr" >&5
+echo "configure:12447: checking for $ac_hdr" >&5
-#line 12399 "configure"
+#line 12450 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12404: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12455: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12434,7 +12485,7 @@
 echo $ac_n "checking for location of ODBC library""... $ac_c" 1>&6
-echo "configure:12438: checking for location of ODBC library" >&5
+echo "configure:12489: checking for location of ODBC library" >&5
 case "$with_odbc_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-odbc-libs." 1>&2; exit 1; }
@@ -12459,13 +12510,13 @@
 echo $ac_n "checking for SQLConnect in -lodbc""... $ac_c" 1>&6
-echo "configure:12463: checking for SQLConnect in -lodbc" >&5
+echo "configure:12514: checking for SQLConnect in -lodbc" >&5
 ac_lib_var=`echo odbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-lodbc $ICONVLIB  $LIBS"
-#line 12469 "configure"
+#line 12520 "configure"
@@ -12476,7 +12527,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12480: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12531: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12501,13 +12552,13 @@
 echo $ac_n "checking for SQLConnect in -liodbc""... $ac_c" 1>&6
-echo "configure:12505: checking for SQLConnect in -liodbc" >&5
+echo "configure:12556: checking for SQLConnect in -liodbc" >&5
 ac_lib_var=`echo iodbc'_'SQLConnect | sed 'y%./+-%__p_%'`
 LIBS="-liodbc  $LIBS"
-#line 12511 "configure"
+#line 12562 "configure"
@@ -12518,7 +12569,7 @@
 SQLConnect()
 ; return 0; }
 EOF
-if { (eval echo configure:12522: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12573: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12543,11 +12594,11 @@
 echo $ac_n "checking for ODBC library""... $ac_c" 1>&6
-echo "configure:12547: checking for ODBC library" >&5
+echo "configure:12598: checking for ODBC library" >&5
 LDFLAGS="$ODBCLIB $LDFLAGS"
 LIBS="-lodbc32  "
-#line 12551 "configure"
+#line 12602 "configure"
 #include <windows.h>
 #include <sql.h>
@@ -12555,7 +12606,7 @@
 SQLAllocEnv((SQLHENV *)0);
 ; return 0; }
 EOF
-if { (eval echo configure:12559: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12610: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
@@ -12604,7 +12655,7 @@
 echo $ac_n "checking whether to use FFTW""... $ac_c" 1>&6
-echo "configure:12608: checking whether to use FFTW" >&5
+echo "configure:12659: checking whether to use FFTW" >&5
 echo "$ac_t"""$with_fftw"" 1>&6
 case "$with_fftw" in
 	"no")	USE_FFTW=	;;
@@ -12623,7 +12674,7 @@
 echo $ac_n "checking for location of FFTW includes""... $ac_c" 1>&6
-echo "configure:12627: checking for location of FFTW includes" >&5
+echo "configure:12678: checking for location of FFTW includes" >&5
 case "$with_fftw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-includes." 1>&2; exit 1; }
@@ -12649,15 +12700,15 @@
 do
-echo "configure:12653: checking for $ac_hdr" >&5
+echo "configure:12704: checking for $ac_hdr" >&5
-#line 12656 "configure"
+#line 12707 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12661: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12712: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12685,15 +12736,15 @@
 do
-echo "configure:12689: checking for $ac_hdr" >&5
+echo "configure:12740: checking for $ac_hdr" >&5
-#line 12692 "configure"
+#line 12743 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12697: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12748: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12721,15 +12772,15 @@
 do
-echo "configure:12725: checking for $ac_hdr" >&5
+echo "configure:12776: checking for $ac_hdr" >&5
-#line 12728 "configure"
+#line 12779 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:12733: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:12784: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -12775,7 +12826,7 @@
 echo $ac_n "checking for location of FFTW library""... $ac_c" 1>&6
-echo "configure:12779: checking for location of FFTW library" >&5
+echo "configure:12830: checking for location of FFTW library" >&5
 case "$with_fftw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-fftw-libs." 1>&2; exit 1; }
@@ -12800,13 +12851,13 @@
 echo $ac_n "checking for fftw_execute in -lfftw3""... $ac_c" 1>&6
-echo "configure:12804: checking for fftw_execute in -lfftw3" >&5
+echo "configure:12855: checking for fftw_execute in -lfftw3" >&5
 ac_lib_var=`echo fftw3'_'fftw_execute | sed 'y%./+-%__p_%'`
 LIBS="-lfftw3 $MATHLIB $LIBS"
-#line 12810 "configure"
+#line 12861 "configure"
@@ -12817,7 +12868,7 @@
 fftw_execute()
 ; return 0; }
 EOF
-if { (eval echo configure:12821: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12872: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12842,13 +12893,13 @@
 echo $ac_n "checking for fftwnd_one in -lfftw""... $ac_c" 1>&6
-echo "configure:12846: checking for fftwnd_one in -lfftw" >&5
+echo "configure:12897: checking for fftwnd_one in -lfftw" >&5
 ac_lib_var=`echo fftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-lfftw $MATHLIB $LIBS"
-#line 12852 "configure"
+#line 12903 "configure"
@@ -12859,7 +12910,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12863: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12914: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12884,13 +12935,13 @@
 echo $ac_n "checking for fftwnd_one in -ldfftw""... $ac_c" 1>&6
-echo "configure:12888: checking for fftwnd_one in -ldfftw" >&5
+echo "configure:12939: checking for fftwnd_one in -ldfftw" >&5
 ac_lib_var=`echo dfftw'_'fftwnd_one | sed 'y%./+-%__p_%'`
 LIBS="-ldfftw $MATHLIB $LIBS"
-#line 12894 "configure"
+#line 12945 "configure"
@@ -12901,7 +12952,7 @@
 fftwnd_one()
 ; return 0; }
 EOF
-if { (eval echo configure:12905: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:12956: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -12958,7 +13009,7 @@
 echo $ac_n "checking whether to use BLAS""... $ac_c" 1>&6
-echo "configure:12962: checking whether to use BLAS" >&5
+echo "configure:13013: checking whether to use BLAS" >&5
 echo "$ac_t"""$with_blas"" 1>&6
 case "$with_blas" in
 	"no")	USE_BLAS=	;;
@@ -12979,7 +13030,7 @@
 echo $ac_n "checking for location of BLAS includes""... $ac_c" 1>&6
-echo "configure:12983: checking for location of BLAS includes" >&5
+echo "configure:13034: checking for location of BLAS includes" >&5
 case "$with_blas_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-includes." 1>&2; exit 1; }
@@ -12999,7 +13050,7 @@
 echo $ac_n "checking for location of BLAS library""... $ac_c" 1>&6
-echo "configure:13003: checking for location of BLAS library" >&5
+echo "configure:13054: checking for location of BLAS library" >&5
 case "$with_blas_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-blas-libs." 1>&2; exit 1; }
@@ -13025,15 +13076,15 @@
 do
-echo "configure:13029: checking for $ac_hdr" >&5
+echo "configure:13080: checking for $ac_hdr" >&5
-#line 13032 "configure"
+#line 13083 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13037: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13088: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13068,13 +13119,13 @@
 echo $ac_n "checking for dnrm2_ in -lblas""... $ac_c" 1>&6
-echo "configure:13072: checking for dnrm2_ in -lblas" >&5
+echo "configure:13123: checking for dnrm2_ in -lblas" >&5
 ac_lib_var=`echo blas'_'dnrm2_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas $MATHLIB  $LIBS"
-#line 13078 "configure"
+#line 13129 "configure"
@@ -13085,7 +13136,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13089: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13140: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13104,13 +13155,13 @@
-echo "configure:13108: checking for dnrm2_ in -lblas" >&5
+echo "configure:13159: checking for dnrm2_ in -lblas" >&5
 LIBS="-lblas $MATHLIB -lg2c $LIBS"
-#line 13114 "configure"
+#line 13165 "configure"
@@ -13121,7 +13172,7 @@
 dnrm2_()
 ; return 0; }
 EOF
-if { (eval echo configure:13125: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13176: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13165,13 +13216,13 @@
 save_LDFLAGS="$LDFLAGS"
 LDFLAGS="$BLASLIB $LDFLAGS"
 echo $ac_n "checking for ATL_xerbla in -latlas""... $ac_c" 1>&6
-echo "configure:13169: checking for ATL_xerbla in -latlas" >&5
+echo "configure:13220: checking for ATL_xerbla in -latlas" >&5
 ac_lib_var=`echo atlas'_'ATL_xerbla | sed 'y%./+-%__p_%'`
 ac_save_LIBS="$LIBS"
 LIBS="-latlas  $LIBS"
 cat > conftest.$ac_ext <<EOF
-#line 13175 "configure"
+#line 13226 "configure"
 #include "confdefs.h"
 /* Override any gcc2 internal prototype to avoid an error.  */
 /* We use char because int might match the return type of a gcc2
@@ -13182,7 +13233,7 @@
 ATL_xerbla()
 ; return 0; }
 EOF
-if { (eval echo configure:13186: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13237: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_lib_$ac_lib_var=yes"
 else
@@ -13197,13 +13248,13 @@
 if eval "test \"`echo '$ac_cv_lib_'$ac_lib_var`\" = yes"; then
   echo "$ac_t""yes" 1>&6
   echo $ac_n "checking for sgemm_ in -lf77blas""... $ac_c" 1>&6
-echo "configure:13201: checking for sgemm_ in -lf77blas" >&5
+echo "configure:13252: checking for sgemm_ in -lf77blas" >&5
 ac_lib_var=`echo f77blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lf77blas -latlas $LIBS"
-#line 13207 "configure"
+#line 13258 "configure"
@@ -13214,7 +13265,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13218: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13269: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13229,13 +13280,13 @@
   echo $ac_n "checking for cblas_dgemm in -lcblas""... $ac_c" 1>&6
-echo "configure:13233: checking for cblas_dgemm in -lcblas" >&5
+echo "configure:13284: checking for cblas_dgemm in -lcblas" >&5
 ac_lib_var=`echo cblas'_'cblas_dgemm | sed 'y%./+-%__p_%'`
 LIBS="-lcblas -lf77blas -latlas $LIBS"
-#line 13239 "configure"
+#line 13290 "configure"
@@ -13246,7 +13297,7 @@
 cblas_dgemm()
 ; return 0; }
 EOF
-if { (eval echo configure:13250: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13301: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13291,16 +13342,16 @@
 	save_LIBS="$LIBS"
 	LIBS="$vlib_flags $LIBS"
 	echo $ac_n "checking for sgemm in $vlib_flags""... $ac_c" 1>&6
-echo "configure:13295: checking for sgemm in $vlib_flags" >&5
+echo "configure:13346: checking for sgemm in $vlib_flags" >&5
-#line 13297 "configure"
+#line 13348 "configure"
 int main() {
 sgemm
 ; return 0; }
 EOF
-if { (eval echo configure:13304: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13355: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   blas_ok=yes; BLASLIB="$vlib_flags"
 else
@@ -13318,13 +13369,13 @@
 # BLAS in PhiPACK libraries? (requires generic BLAS, too)
 if test $blas_ok = no; then
 	echo $ac_n "checking for sgemm_ in -lblas""... $ac_c" 1>&6
-echo "configure:13322: checking for sgemm_ in -lblas" >&5
+echo "configure:13373: checking for sgemm_ in -lblas" >&5
 ac_lib_var=`echo blas'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lblas  $LIBS"
-#line 13328 "configure"
+#line 13379 "configure"
@@ -13335,7 +13386,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13339: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13390: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13350,13 +13401,13 @@
   echo $ac_n "checking for dgemm_ in -ldgemm""... $ac_c" 1>&6
-echo "configure:13354: checking for dgemm_ in -ldgemm" >&5
+echo "configure:13405: checking for dgemm_ in -ldgemm" >&5
 ac_lib_var=`echo dgemm'_'dgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-ldgemm -lblas $LIBS"
-#line 13360 "configure"
+#line 13411 "configure"
@@ -13367,7 +13418,7 @@
 dgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13371: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13422: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13382,13 +13433,13 @@
   echo $ac_n "checking for sgemm_ in -lsgemm""... $ac_c" 1>&6
-echo "configure:13386: checking for sgemm_ in -lsgemm" >&5
+echo "configure:13437: checking for sgemm_ in -lsgemm" >&5
 ac_lib_var=`echo sgemm'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsgemm -lblas $LIBS"
-#line 13392 "configure"
+#line 13443 "configure"
@@ -13399,7 +13450,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13403: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13433,13 +13484,13 @@
 	if test "x$GCC" != xyes; then # only works with Sun CC
 		echo $ac_n "checking for acosp in -lsunmath""... $ac_c" 1>&6
-echo "configure:13437: checking for acosp in -lsunmath" >&5
+echo "configure:13488: checking for acosp in -lsunmath" >&5
 ac_lib_var=`echo sunmath'_'acosp | sed 'y%./+-%__p_%'`
 LIBS="-lsunmath  $LIBS"
-#line 13443 "configure"
+#line 13494 "configure"
@@ -13450,7 +13501,7 @@
 acosp()
 ; return 0; }
 EOF
-if { (eval echo configure:13454: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13505: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13465,13 +13516,13 @@
   echo $ac_n "checking for sgemm_ in -lsunperf""... $ac_c" 1>&6
-echo "configure:13469: checking for sgemm_ in -lsunperf" >&5
+echo "configure:13520: checking for sgemm_ in -lsunperf" >&5
 ac_lib_var=`echo sunperf'_'sgemm_ | sed 'y%./+-%__p_%'`
 LIBS="-lsunperf -lsunmath $LIBS"
-#line 13475 "configure"
+#line 13526 "configure"
@@ -13482,7 +13533,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13486: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13512,13 +13563,13 @@
 # Generic BLAS library
-echo "configure:13516: checking for sgemm_ in -lblas" >&5
+echo "configure:13567: checking for sgemm_ in -lblas" >&5
 LIBS="-lblas  $LIBS"
-#line 13522 "configure"
+#line 13573 "configure"
@@ -13529,7 +13580,7 @@
 sgemm_()
 ; return 0; }
 EOF
-if { (eval echo configure:13533: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13584: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13568,7 +13619,7 @@
 echo $ac_n "checking whether to use LAPACK""... $ac_c" 1>&6
-echo "configure:13572: checking whether to use LAPACK" >&5
+echo "configure:13623: checking whether to use LAPACK" >&5
 echo "$ac_t"""$with_lapack"" 1>&6
 case "$with_lapack" in
 	"no")	USE_LAPACK=	;;
@@ -13593,7 +13644,7 @@
 echo $ac_n "checking for location of LAPACK includes""... $ac_c" 1>&6
-echo "configure:13597: checking for location of LAPACK includes" >&5
+echo "configure:13648: checking for location of LAPACK includes" >&5
 case "$with_lapack_includes" in
 y | ye | yes | n | no)
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-includes." 1>&2; exit 1; }
@@ -13613,7 +13664,7 @@
 echo $ac_n "checking for location of LAPACK library""... $ac_c" 1>&6
-echo "configure:13617: checking for location of LAPACK library" >&5
+echo "configure:13668: checking for location of LAPACK library" >&5
 case "$with_lapack_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-lapack-libs." 1>&2; exit 1; }
@@ -13639,15 +13690,15 @@
 do
 ac_safe=`echo "$ac_hdr" | sed 'y%./+-%__p_%'`
 echo $ac_n "checking for $ac_hdr""... $ac_c" 1>&6
-echo "configure:13643: checking for $ac_hdr" >&5
+echo "configure:13694: checking for $ac_hdr" >&5
-#line 13646 "configure"
+#line 13697 "configure"
 #include <$ac_hdr>
 EOF
 ac_try="$ac_cpp conftest.$ac_ext >/dev/null 2>conftest.out"
-{ (eval echo configure:13651: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13702: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
 ac_err=`grep -v '^ *+' conftest.out | grep -v "^conftest.${ac_ext}\$"`
 if test -z "$ac_err"; then
   rm -rf conftest*
@@ -13679,10 +13730,10 @@
 	save_LIBS="$LIBS"; LIBS="$LIBS $BLASLIB $MATHLIB $FLIBS"
 	save_LDFLAGS="$LDFLAGS"; LDFLAGS="$LAPACKLIB $LDFLAGS"
 	echo $ac_n "checking for dsegv_""... $ac_c" 1>&6
-echo "configure:13683: checking for dsegv_" >&5
+echo "configure:13734: checking for dsegv_" >&5
-#line 13686 "configure"
+#line 13737 "configure"
     which can conflict with char dsegv_(); below.  */
@@ -13705,7 +13756,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:13709: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13760: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_dsegv_=yes"
 else
@@ -13732,13 +13783,13 @@
 	save_libs="$LIBS"; LIBS="$BLASLIB $MATHLIB $LIBS"
 	echo $ac_n "checking for desgv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13736: checking for desgv_ in -llapack" >&5
+echo "configure:13787: checking for desgv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'desgv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $FLIBS $LIBS"
-#line 13742 "configure"
+#line 13793 "configure"
@@ -13749,7 +13800,7 @@
 desgv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13753: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13804: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13781,13 +13832,13 @@
 echo $ac_n "checking for dgesv_ in -llapack""... $ac_c" 1>&6
-echo "configure:13785: checking for dgesv_ in -llapack" >&5
+echo "configure:13836: checking for dgesv_ in -llapack" >&5
 ac_lib_var=`echo lapack'_'dgesv_ | sed 'y%./+-%__p_%'`
 LIBS="-llapack $BLASLIB $MATHLIB  $LIBS"
-#line 13791 "configure"
+#line 13842 "configure"
@@ -13798,7 +13849,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13802: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13853: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13817,13 +13868,13 @@
   echo "$ac_t""no" 1>&6
-echo "configure:13821: checking for dgesv_ in -llapack" >&5
+echo "configure:13872: checking for dgesv_ in -llapack" >&5
 LIBS="-llapack $BLASLIB $MATHLIB -lg2c $LIBS"
-#line 13827 "configure"
+#line 13878 "configure"
@@ -13834,7 +13885,7 @@
 dgesv_()
 ; return 0; }
 EOF
-if { (eval echo configure:13838: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:13889: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -13890,7 +13941,7 @@
 echo $ac_n "checking whether to use Motif""... $ac_c" 1>&6
-echo "configure:13894: checking whether to use Motif" >&5
+echo "configure:13945: checking whether to use Motif" >&5
 echo "$ac_t"""$with_motif"" 1>&6
 case "$with_motif" in
 	"no")	USE_MOTIF=	;;
@@ -13909,7 +13960,7 @@
 echo $ac_n "checking for location of Motif includes""... $ac_c" 1>&6
-echo "configure:13913: checking for location of Motif includes" >&5
+echo "configure:13964: checking for location of Motif includes" >&5
 case "$with_motif_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-includes." 1>&2; exit 1; }
@@ -13935,15 +13986,15 @@
 do
-echo "configure:13939: checking for $ac_hdr" >&5
+echo "configure:13990: checking for $ac_hdr" >&5
-#line 13942 "configure"
+#line 13993 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:13947: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:13998: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -13977,7 +14028,7 @@
 echo $ac_n "checking for location of Motif library""... $ac_c" 1>&6
-echo "configure:13981: checking for location of Motif library" >&5
+echo "configure:14032: checking for location of Motif library" >&5
 case "$with_motif_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-motif-libs." 1>&2; exit 1; }
@@ -14002,13 +14053,13 @@
 echo $ac_n "checking for XmStringCreate in -lXm""... $ac_c" 1>&6
-echo "configure:14006: checking for XmStringCreate in -lXm" >&5
+echo "configure:14057: checking for XmStringCreate in -lXm" >&5
 ac_lib_var=`echo Xm'_'XmStringCreate | sed 'y%./+-%__p_%'`
 LIBS="-lXm $X_LIBS -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS  $LIBS"
-#line 14012 "configure"
+#line 14063 "configure"
@@ -14019,7 +14070,7 @@
 XmStringCreate()
 ; return 0; }
 EOF
-if { (eval echo configure:14023: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14074: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14060,7 +14111,7 @@
 echo $ac_n "checking whether to use Cairo""... $ac_c" 1>&6
-echo "configure:14064: checking whether to use Cairo" >&5
+echo "configure:14115: checking whether to use Cairo" >&5
 echo "$ac_t"""$with_cairo"" 1>&6
 case "$with_cairo" in
 	"no")	USE_CAIRO=	;;
@@ -14086,7 +14137,7 @@
 echo $ac_n "checking for location of cairo includes""... $ac_c" 1>&6
-echo "configure:14090: checking for location of cairo includes" >&5
+echo "configure:14141: checking for location of cairo includes" >&5
 case "$with_cairo_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-includes." 1>&2; exit 1; }
@@ -14112,15 +14163,15 @@
 do
-echo "configure:14116: checking for $ac_hdr" >&5
+echo "configure:14167: checking for $ac_hdr" >&5
-#line 14119 "configure"
+#line 14170 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14124: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14175: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14156,7 +14207,7 @@
 echo $ac_n "checking for location of cairo library""... $ac_c" 1>&6
-echo "configure:14160: checking for location of cairo library" >&5
+echo "configure:14211: checking for location of cairo library" >&5
 case "$with_cairo_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-libs." 1>&2; exit 1; }
@@ -14176,7 +14227,7 @@
 echo $ac_n "checking for cairo linking flags""... $ac_c" 1>&6
-echo "configure:14180: checking for cairo linking flags" >&5
+echo "configure:14231: checking for cairo linking flags" >&5
 case "$with_cairo_ldflags" in
 	{ echo "configure: error: *** You must supply a directory to --with-cairo-ldflags." 1>&2; exit 1; }
@@ -14192,10 +14243,10 @@
 LIBS=" $CAIROLIB $LIBS"
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_create""... $ac_c" 1>&6
-echo "configure:14196: checking for cairo_create" >&5
+echo "configure:14247: checking for cairo_create" >&5
-#line 14199 "configure"
+#line 14250 "configure"
     which can conflict with char cairo_create(); below.  */
@@ -14218,7 +14269,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14222: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14273: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_create=yes"
 else
@@ -14252,10 +14303,10 @@
 LDFLAGS=" $LDFLAGS"
 echo $ac_n "checking for cairo_xlib_surface_create_with_xrender_format""... $ac_c" 1>&6
-echo "configure:14256: checking for cairo_xlib_surface_create_with_xrender_format" >&5
+echo "configure:14307: checking for cairo_xlib_surface_create_with_xrender_format" >&5
-#line 14259 "configure"
+#line 14310 "configure"
     which can conflict with char cairo_xlib_surface_create_with_xrender_format(); below.  */
@@ -14278,7 +14329,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14282: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14333: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_cairo_xlib_surface_create_with_xrender_format=yes"
 else
@@ -14320,7 +14371,7 @@
 echo $ac_n "checking whether to use GLw""... $ac_c" 1>&6
-echo "configure:14324: checking whether to use GLw" >&5
+echo "configure:14375: checking whether to use GLw" >&5
 echo "$ac_t"""$with_glw"" 1>&6
 case "$with_glw" in
 	"no")	USE_GLW=	;;
@@ -14339,7 +14390,7 @@
 echo $ac_n "checking for location of GLw includes""... $ac_c" 1>&6
-echo "configure:14343: checking for location of GLw includes" >&5
+echo "configure:14394: checking for location of GLw includes" >&5
 case "$with_glw_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-includes." 1>&2; exit 1; }
@@ -14365,15 +14416,15 @@
 do
-echo "configure:14369: checking for $ac_hdr" >&5
+echo "configure:14420: checking for $ac_hdr" >&5
-#line 14372 "configure"
+#line 14423 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14377: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14428: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14401,15 +14452,15 @@
 do
-echo "configure:14405: checking for $ac_hdr" >&5
+echo "configure:14456: checking for $ac_hdr" >&5
-#line 14408 "configure"
+#line 14459 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:14413: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:14464: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -14449,7 +14500,7 @@
 echo $ac_n "checking for location of GLw library""... $ac_c" 1>&6
-echo "configure:14453: checking for location of GLw library" >&5
+echo "configure:14504: checking for location of GLw library" >&5
 case "$with_glw_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-glw-libs." 1>&2; exit 1; }
@@ -14474,13 +14525,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14478: checking for GLwCreateMDrawingArea in -lGLw" >&5
+echo "configure:14529: checking for GLwCreateMDrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14484 "configure"
+#line 14535 "configure"
@@ -14491,7 +14542,7 @@
 GLwCreateMDrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14495: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14546: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14516,13 +14567,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14520: checking for GLwCreateM1DrawingArea in -lGLw" >&5
+echo "configure:14571: checking for GLwCreateM1DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14526 "configure"
+#line 14577 "configure"
@@ -14533,7 +14584,7 @@
 GLwCreateM1DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14537: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14588: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14558,13 +14609,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLw""... $ac_c" 1>&6
-echo "configure:14562: checking for GLwCreateM2DrawingArea in -lGLw" >&5
+echo "configure:14613: checking for GLwCreateM2DrawingArea in -lGLw" >&5
 ac_lib_var=`echo GLw'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14568 "configure"
+#line 14619 "configure"
@@ -14575,7 +14626,7 @@
 GLwCreateM2DrawingArea()
 ; return 0; }
 EOF
-if { (eval echo configure:14579: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14630: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14600,13 +14651,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14604: checking for GLwCreateMDrawingArea in -lGLwM" >&5
+echo "configure:14655: checking for GLwCreateMDrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14610 "configure"
+#line 14661 "configure"
@@ -14617,7 +14668,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14621: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14672: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14642,13 +14693,13 @@
 echo $ac_n "checking for GLwCreateM1DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14646: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
+echo "configure:14697: checking for GLwCreateM1DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM1DrawingArea | sed 'y%./+-%__p_%'`
-#line 14652 "configure"
+#line 14703 "configure"
@@ -14659,7 +14710,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14663: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14714: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14684,13 +14735,13 @@
 echo $ac_n "checking for GLwCreateM2DrawingArea in -lGLwM""... $ac_c" 1>&6
-echo "configure:14688: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
+echo "configure:14739: checking for GLwCreateM2DrawingArea in -lGLwM" >&5
 ac_lib_var=`echo GLwM'_'GLwCreateM2DrawingArea | sed 'y%./+-%__p_%'`
-#line 14694 "configure"
+#line 14745 "configure"
@@ -14701,7 +14752,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14705: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14756: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14728,13 +14779,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLw""... $ac_c" 1>&6
-echo "configure:14732: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14783: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 ac_lib_var=`echo MesaGLw'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14738 "configure"
+#line 14789 "configure"
@@ -14745,7 +14796,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14749: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14800: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14764,13 +14815,13 @@
-echo "configure:14768: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
+echo "configure:14819: checking for GLwCreateMDrawingArea in -lMesaGLw" >&5
 LIBS="-lMesaGLw $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14774 "configure"
+#line 14825 "configure"
@@ -14781,7 +14832,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14785: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14836: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14808,13 +14859,13 @@
 echo $ac_n "checking for GLwCreateMDrawingArea in -lMesaGLwM""... $ac_c" 1>&6
-echo "configure:14812: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14863: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 ac_lib_var=`echo MesaGLwM'_'GLwCreateMDrawingArea | sed 'y%./+-%__p_%'`
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB  $LIBS"
-#line 14818 "configure"
+#line 14869 "configure"
@@ -14825,7 +14876,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14829: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14880: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14844,13 +14895,13 @@
-echo "configure:14848: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
+echo "configure:14899: checking for GLwCreateMDrawingArea in -lMesaGLwM" >&5
 LIBS="-lMesaGLwM $X_LIBS $OPENGLLIB -lXm -lXt $X_PRE_LIBS -lX11 $X_EXTRA_LIBS $MATHLIB $OPENGLULIB $LIBS"
-#line 14854 "configure"
+#line 14905 "configure"
@@ -14861,7 +14912,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:14865: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:14916: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -14974,7 +15025,7 @@
 echo $ac_n "checking whether to use FreeType""... $ac_c" 1>&6
-echo "configure:14978: checking whether to use FreeType" >&5
+echo "configure:15029: checking whether to use FreeType" >&5
 echo "$ac_t"""$with_freetype"" 1>&6
 case "$with_freetype" in
 	"no")	USE_FREETYPE=	;;
@@ -14993,7 +15044,7 @@
 echo $ac_n "checking for location of FreeType includes""... $ac_c" 1>&6
-echo "configure:14997: checking for location of FreeType includes" >&5
+echo "configure:15048: checking for location of FreeType includes" >&5
 case "$with_freetype_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-includes." 1>&2; exit 1; }
@@ -15019,15 +15070,15 @@
 do
-echo "configure:15023: checking for $ac_hdr" >&5
+echo "configure:15074: checking for $ac_hdr" >&5
-#line 15026 "configure"
+#line 15077 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15031: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15082: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15061,7 +15112,7 @@
 echo $ac_n "checking for location of FreeType library""... $ac_c" 1>&6
-echo "configure:15065: checking for location of FreeType library" >&5
+echo "configure:15116: checking for location of FreeType library" >&5
 case "$with_freetype_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-freetype-libs." 1>&2; exit 1; }
@@ -15086,13 +15137,13 @@
 echo $ac_n "checking for FT_Init_FreeType in -lfreetype""... $ac_c" 1>&6
-echo "configure:15090: checking for FT_Init_FreeType in -lfreetype" >&5
+echo "configure:15141: checking for FT_Init_FreeType in -lfreetype" >&5
 ac_lib_var=`echo freetype'_'FT_Init_FreeType | sed 'y%./+-%__p_%'`
 LIBS="-lfreetype  $LIBS"
-#line 15096 "configure"
+#line 15147 "configure"
@@ -15103,7 +15154,7 @@
 FT_Init_FreeType()
 ; return 0; }
 EOF
-if { (eval echo configure:15107: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15158: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15144,7 +15195,7 @@
 echo $ac_n "checking whether to use NLS""... $ac_c" 1>&6
-echo "configure:15148: checking whether to use NLS" >&5
+echo "configure:15199: checking whether to use NLS" >&5
 echo "$ac_t"""$with_nls"" 1>&6
 case "$with_nls" in
 	"no")	USE_NLS=	;;
@@ -15164,10 +15215,10 @@
 echo $ac_n "checking for gettext""... $ac_c" 1>&6
-echo "configure:15168: checking for gettext" >&5
+echo "configure:15219: checking for gettext" >&5
-#line 15171 "configure"
+#line 15222 "configure"
 /* System header to define __stub macros and hopefully few prototypes,
     which can conflict with char gettext(); below.  */
@@ -15190,7 +15241,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15194: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15245: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
   eval "ac_cv_func_gettext=yes"
 else
@@ -15208,13 +15259,13 @@
 echo $ac_n "checking for gettext in -lintl""... $ac_c" 1>&6
-echo "configure:15212: checking for gettext in -lintl" >&5
+echo "configure:15263: checking for gettext in -lintl" >&5
 ac_lib_var=`echo intl'_'gettext | sed 'y%./+-%__p_%'`
 LIBS="-lintl  $LIBS"
-#line 15218 "configure"
+#line 15269 "configure"
@@ -15225,7 +15276,7 @@
 gettext()
 ; return 0; }
 EOF
-if { (eval echo configure:15229: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15280: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   rm -rf conftest*
 else
@@ -15260,7 +15311,7 @@
 echo $ac_n "checking whether to use C++""... $ac_c" 1>&6
-echo "configure:15264: checking whether to use C++" >&5
+echo "configure:15315: checking whether to use C++" >&5
 echo "$ac_t"""$with_cxx"" 1>&6
 case "$with_cxx" in
 	"no")	USE_CXX=	;;
@@ -15276,7 +15327,7 @@
 # Extract the first word of "$ac_prog", so it can be a program name with args.
 set dummy $ac_prog; ac_word=$2
 echo $ac_n "checking for $ac_word""... $ac_c" 1>&6
-echo "configure:15280: checking for $ac_word" >&5
+echo "configure:15331: checking for $ac_word" >&5
 if test -n "$CXX"; then
   ac_cv_prog_CXX="$CXX" # Let the user override the test.
@@ -15305,7 +15356,7 @@
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works""... $ac_c" 1>&6
-echo "configure:15309: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
+echo "configure:15360: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) works" >&5
 ac_ext=C
 # CXXFLAGS is not in ac_cpp because -g, -O, etc. are not valid cpp options.
@@ -15316,12 +15367,12 @@
 cat > conftest.$ac_ext << EOF
-#line 15320 "configure"
+#line 15371 "configure"
 int main(){return(0);}
 EOF
-if { (eval echo configure:15325: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
+if { (eval echo configure:15376: \"$ac_link\") 1>&5; (eval $ac_link) 2>&5; } && test -s conftest${ac_exeext}; then
   ac_cv_prog_cxx_works=yes
   # If we can't run a trivial program, we are probably using a cross compiler.
   if (./conftest; exit) 2>/dev/null; then
@@ -15347,19 +15398,19 @@
   { echo "configure: error: installation or configuration problem: C++ compiler cannot create executables." 1>&2; exit 1; }
 fi
 echo $ac_n "checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler""... $ac_c" 1>&6
-echo "configure:15351: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
+echo "configure:15402: checking whether the C++ compiler ($CXX $CXXFLAGS $LDFLAGS) is a cross-compiler" >&5
 echo "$ac_t""$ac_cv_prog_cxx_cross" 1>&6
 cross_compiling=$ac_cv_prog_cxx_cross
 echo $ac_n "checking whether we are using GNU C++""... $ac_c" 1>&6
-echo "configure:15356: checking whether we are using GNU C++" >&5
+echo "configure:15407: checking whether we are using GNU C++" >&5
 cat > conftest.C <<EOF
 #ifdef __GNUC__
   yes;
 #endif
 EOF
-if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15363: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
+if { ac_try='${CXX-g++} -E conftest.C'; { (eval echo configure:15414: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }; } | egrep yes >/dev/null 2>&1; then
   ac_cv_prog_gxx=yes
 else
   ac_cv_prog_gxx=no
@@ -15377,7 +15428,7 @@
 ac_save_CXXFLAGS="$CXXFLAGS"
 CXXFLAGS=
 echo $ac_n "checking whether ${CXX-g++} accepts -g""... $ac_c" 1>&6
-echo "configure:15381: checking whether ${CXX-g++} accepts -g" >&5
+echo "configure:15432: checking whether ${CXX-g++} accepts -g" >&5
 echo 'void f(){}' > conftest.cc
 if test -z "`${CXX-g++} -g -c conftest.cc 2>&1`"; then
@@ -15418,7 +15469,7 @@
 echo $ac_n "checking whether to use openDWG""... $ac_c" 1>&6
-echo "configure:15422: checking whether to use openDWG" >&5
+echo "configure:15473: checking whether to use openDWG" >&5
 echo "$ac_t"""$with_opendwg"" 1>&6
 case "$with_opendwg" in
 	"no")	USE_OPENDWG=	;;
@@ -15438,7 +15489,7 @@
 echo $ac_n "checking for location of openDGW includes""... $ac_c" 1>&6
-echo "configure:15442: checking for location of openDGW includes" >&5
+echo "configure:15493: checking for location of openDGW includes" >&5
 case "$with_opendwg_includes" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-includes." 1>&2; exit 1; }
@@ -15464,15 +15515,15 @@
 do
-echo "configure:15468: checking for $ac_hdr" >&5
+echo "configure:15519: checking for $ac_hdr" >&5
-#line 15471 "configure"
+#line 15522 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15476: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15527: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15506,7 +15557,7 @@
 echo $ac_n "checking for location of openDWG library""... $ac_c" 1>&6
-echo "configure:15510: checking for location of openDWG library" >&5
+echo "configure:15561: checking for location of openDWG library" >&5
 case "$with_opendwg_libs" in
 	{ echo "configure: error: *** You must supply a directory to --with-opendwg-libs." 1>&2; exit 1; }
@@ -15553,7 +15604,7 @@
    if test "$enable_largefile" = yes; then
      echo $ac_n "checking for special C compiler options needed for large files""... $ac_c" 1>&6
-echo "configure:15557: checking for special C compiler options needed for large files" >&5
+echo "configure:15608: checking for special C compiler options needed for large files" >&5
 ac_cv_sys_largefile_CC=no
         largefile_cc_opt=""
@@ -15561,7 +15612,7 @@
 	  # IRIX 6.2 and later do not support large files by default,
 	  # so use the C compiler's -n32 option if that helps.
-#line 15565 "configure"
+#line 15616 "configure"
 #include <sys/types.h>
     /* Check that off_t can represent 2**63 - 1 correctly.
@@ -15577,7 +15628,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15581: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15632: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   echo "configure: failed program was:" >&5
@@ -15586,7 +15637,7 @@
   ac_save_CC="${CC-cc}"
 	     CC="$CC -n32"
-#line 15590 "configure"
+#line 15641 "configure"
@@ -15602,7 +15653,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15606: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15657: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_CC=' -n32'
 else
@@ -15622,11 +15673,11 @@
      fi
      echo $ac_n "checking for _FILE_OFFSET_BITS value needed for large files""... $ac_c" 1>&6
-echo "configure:15626: checking for _FILE_OFFSET_BITS value needed for large files" >&5
+echo "configure:15677: checking for _FILE_OFFSET_BITS value needed for large files" >&5
 ac_cv_sys_file_offset_bits=no
-#line 15630 "configure"
+#line 15681 "configure"
@@ -15642,14 +15693,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15646: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15697: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   cat conftest.$ac_ext >&5
   rm -rf conftest*
-#line 15653 "configure"
+#line 15704 "configure"
 #define _FILE_OFFSET_BITS 64
@@ -15667,7 +15718,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15671: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15722: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_file_offset_bits=64
 else
@@ -15686,11 +15737,11 @@
    fi
      echo $ac_n "checking for _LARGE_FILES value needed for large files""... $ac_c" 1>&6
-echo "configure:15690: checking for _LARGE_FILES value needed for large files" >&5
+echo "configure:15741: checking for _LARGE_FILES value needed for large files" >&5
 ac_cv_sys_large_files=no
-#line 15694 "configure"
+#line 15745 "configure"
@@ -15706,14 +15757,14 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15710: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15761: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15717 "configure"
+#line 15768 "configure"
 #define _LARGE_FILES 1
@@ -15731,7 +15782,7 @@
 ; return 0; }
 EOF
-if { (eval echo configure:15735: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15786: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_large_files=1
 else
@@ -15750,25 +15801,25 @@
    fi
      echo $ac_n "checking for _LARGEFILE_SOURCE value needed for large files""... $ac_c" 1>&6
-echo "configure:15754: checking for _LARGEFILE_SOURCE value needed for large files" >&5
+echo "configure:15805: checking for _LARGEFILE_SOURCE value needed for large files" >&5
 ac_cv_sys_largefile_source=no
-#line 15758 "configure"
+#line 15809 "configure"
 #include <stdio.h>
 int main() {
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15765: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15816: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
 else
   rm -rf conftest*
-#line 15772 "configure"
+#line 15823 "configure"
 #define _LARGEFILE_SOURCE 1
 #include <stdio.h>
@@ -15777,7 +15828,7 @@
 return !fseeko;
 ; return 0; }
 EOF
-if { (eval echo configure:15781: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15832: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_sys_largefile_source=1
 else
@@ -15798,10 +15849,10 @@
    fi
 echo $ac_n "checking if system supports Large Files at all""... $ac_c" 1>&6
-echo "configure:15802: checking if system supports Large Files at all" >&5
+echo "configure:15853: checking if system supports Large Files at all" >&5
-#line 15805 "configure"
+#line 15856 "configure"
 #include <stdio.h>
@@ -15833,7 +15884,7 @@
 #endif
 ; return 0; }
 EOF
-if { (eval echo configure:15837: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
+if { (eval echo configure:15888: \"$ac_compile\") 1>&5; (eval $ac_compile) 2>&5; }; then
   rm -rf conftest*
   ac_cv_largefiles=yes
 else
@@ -15862,7 +15913,7 @@
 # Python check
 echo $ac_n "checking whether to use Python""... $ac_c" 1>&6
-echo "configure:15866: checking whether to use Python" >&5
+echo "configure:15917: checking whether to use Python" >&5
 PYTHONINC=
 PYTHONCFLAGS=
@@ -15882,7 +15933,7 @@
   # Extract the first word of "python-config", so it can be a program name with args.
 set dummy python-config; ac_word=$2
-echo "configure:15886: checking for $ac_word" >&5
+echo "configure:15937: checking for $ac_word" >&5
 case "$PY_CONFIG" in
@@ -15924,15 +15975,15 @@
 do
-echo "configure:15928: checking for $ac_hdr" >&5
+echo "configure:15979: checking for $ac_hdr" >&5
-#line 15931 "configure"
+#line 15982 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:15936: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:15987: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
@@ -15973,7 +16024,7 @@
   # Extract the first word of "swig", so it can be a program name with args.
 set dummy swig; ac_word=$2
-echo "configure:15977: checking for $ac_word" >&5
+echo "configure:16028: checking for $ac_word" >&5
 case "$SWIG" in
@@ -16019,7 +16070,7 @@
 # Enable wxWidgets support (for wxGUI)
 echo $ac_n "checking whether to use wxWidgets""... $ac_c" 1>&6
-echo "configure:16023: checking whether to use wxWidgets" >&5
+echo "configure:16074: checking whether to use wxWidgets" >&5
 WXVERSION=
 WXWIDGETSCXXFLAGS=
@@ -16039,7 +16090,7 @@
   # Extract the first word of "wx-config", so it can be a program name with args.
 set dummy wx-config; ac_word=$2
-echo "configure:16043: checking for $ac_word" >&5
+echo "configure:16094: checking for $ac_word" >&5
 case "$WX_CONFIG" in
@@ -16087,7 +16138,7 @@
  REQWX="2.8.1"
  echo $ac_n "checking wxWidgets version""... $ac_c" 1>&6
-echo "configure:16091: checking wxWidgets version" >&5
+echo "configure:16142: checking wxWidgets version" >&5
  if WXVERSION=`"$WX_CONFIG" --version`; then
    echo "$ac_t""$WXVERSION" 1>&6
  else
@@ -16110,15 +16161,15 @@
 do
-echo "configure:16114: checking for $ac_hdr" >&5
+echo "configure:16165: checking for $ac_hdr" >&5
-#line 16117 "configure"
+#line 16168 "configure"
 #include <$ac_hdr>
 EOF
-{ (eval echo configure:16122: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
+{ (eval echo configure:16173: \"$ac_try\") 1>&5; (eval $ac_try) 2>&5; }
   rm -rf conftest*
Modified: grass/branches/develbranch_6/configure.in
--- grass/branches/develbranch_6/configure.in	2009-08-26 07:45:30 UTC (rev 38867)
+++ grass/branches/develbranch_6/configure.in	2009-08-26 07:59:39 UTC (rev 38868)
@@ -808,7 +808,7 @@
   fi
   LOC_CHECK_INCLUDES(geos_c.h,GEOS,$GEOS_CFLAGS)
+  LOC_CHECK_LIBS(geos_c,initGEOS,GEOS,$GEOS_LIBS,GEOS_LIBS)
   AC_DEFINE(HAVE_GEOS)
 fi
