[GRASS-SVN] r38877 - grass/branches/develbranch_6/db/base
Wed Aug 26 14:26:58 EDT 2009
Author: martinl
Date: 2009-08-26 14:26:58 -0400 (Wed, 26 Aug 2009)
New Revision: 38877
   grass/branches/develbranch_6/db/base/select.c
db.select: option for output file added (see trac #710)
          more gui sections
	      (merge from trunk, r38876)
Modified: grass/branches/develbranch_6/db/base/select.c
--- grass/branches/develbranch_6/db/base/select.c	2009-08-26 18:23:59 UTC (rev 38876)
+++ grass/branches/develbranch_6/db/base/select.c	2009-08-26 18:26:58 UTC (rev 38877)
@@ -3,9 +3,13 @@
  * MODULE:       db.select
  * AUTHOR(S):    Radim Blazek <radim.blazek gmail.com> (original contributor)
- *               Huidae Cho <grass4u gmail.com>, Glynn Clements <glynn gclements.plus.com>, Jachym Cepicky <jachym les-ejk.cz>, Markus Neteler <neteler itc.it>, Stephan Holl
- * PURPOSE:      process one sql select statement
- * COPYRIGHT:    (C) 2002-2007 by the GRASS Development Team
+ *               Huidae Cho <grass4u gmail.com>,
+ *               Glynn Clements <glynn gclements.plus.com>,
+ *               Jachym Cepicky <jachym les-ejk.cz>,
+ *               Markus Neteler <neteler itc.it>
+ *               Stephan Holl
+ * PURPOSE:      Process one sql select statement
+ * COPYRIGHT:    (C) 2002-2009 by the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -14,16 +18,17 @@
 #include <stdlib.h>
+#include <string.h>
 #include <grass/gis.h>
 #include <grass/dbmi.h>
 #include <grass/codes.h>
 #include <grass/glocale.h>
 #include "local_proto.h"
 struct
-    char *driver, *database, *table, *sql, *fs, *vs, *nv, *input;
+    char *driver, *database, *table, *sql, *fs, *vs, *nv, *input, *output;
     int c, d, h, test_only;
 } parms;
@@ -120,6 +125,12 @@
 	return OK;
+    if (parms.output && strcmp(parms.output, "-") != 0) {
+	if (NULL == freopen(parms.output, "w", stdout)) {
+	    G_fatal_error(_("Unable to open file <%s> for writing"), parms.output);
     db_init_string(&value_string);
     /* column names if horizontal output */
@@ -167,7 +178,8 @@
 static void parse_command_line(int argc, char **argv)
-    struct Option *driver, *database, *table, *sql, *fs, *vs, *nv, *input;
+    struct Option *driver, *database, *table, *sql,
+      *fs, *vs, *nv, *input, *output;
     struct Flag *c, *d, *v, *flag_test;
     struct GModule *module;
     const char *drv, *db;
@@ -176,16 +188,19 @@
     G_gisinit(argv[0]);
     table = G_define_standard_option(G_OPT_TABLE);
+    table->guisection = _("Query");
     database = G_define_standard_option(G_OPT_DATABASE);
     if ((db = db_get_default_database_name()))
 	database->answer = (char *) db;
+    database->guisection = _("Query");
     driver = G_define_standard_option(G_OPT_DRIVER);
     driver->options = db_list_drivers();
     if ((drv = db_get_default_driver_name()))
 	driver->answer = (char *) drv;
+    driver->guisection = _("Query");
     sql = G_define_option();
     sql->key = "sql";
     sql->type = TYPE_STRING;
@@ -193,10 +208,12 @@
     sql->label = _("SQL select statement");
     sql->description =
 	_("For example: 'select * from rybniky where kapri = 'hodne'");
+    sql->guisection = _("Query");
     input = G_define_standard_option(G_OPT_F_INPUT);
     input->required = NO;
     input->description = _("Name of file with sql statement");
+    input->guisection = _("Query");
     fs = G_define_standard_option(G_OPT_F_SEP);
     fs->description = _("Output field separator");
@@ -215,6 +232,11 @@
     nv->description = _("Null value indicator");
     nv->guisection = _("Format");
+    output = G_define_standard_option(G_OPT_F_OUTPUT);
+    output->required = NO;
+    output->description =
+	_("Name for output file (if omitted or \"-\" output to stdout)");
     c = G_define_flag();
     c->key = 'c';
     c->description = _("Do not include column names in output");
@@ -223,6 +245,7 @@
     d = G_define_flag();
     d->key = 'd';
     d->description = _("Describe query only (don't run it)");
+    d->guisection = _("Query");
     v = G_define_flag();
     v->key = 'v';
@@ -232,11 +255,12 @@
     flag_test = G_define_flag();
     flag_test->key = 't';
     flag_test->description = _("Only test query, do not execute");
+    flag_test->guisection = _("Query");
     /* Set description */
     module = G_define_module();
     module->keywords = _("database, attribute table, SQL");
-    module->description = _("Selects data from table.");
+    module->description = _("Selects data from attribute table (performs SQL query statement(s)).");
     if (G_parser(argc, argv))
 	exit(EXIT_SUCCESS);
@@ -249,6 +273,8 @@
     parms.vs = vs->answer;
     parms.nv = nv->answer;
     parms.input = input->answer;
+    parms.output = output->answer;
     if (!c->answer)
 	parms.c = 1;
     else
