[GRASS-SVN] r38906 - in grass/trunk: db/db.columns db/db.connect db/db.copy db/db.createdb db/db.databases db/db.describe db/db.drivers db/db.dropdb db/db.droptable db/db.execute db/db.login db/db.select db/db.tables db/drivers/dbf db/drivers/odbc db/drivers/ogr db/drivers/postgres db/drivers/sqlite display/d.barscale display/d.colorlist display/d.colortable display/d.erase display/d.font display/d.fontlist display/d.geodesic display/d.graph display/d.grid display/d.his display/d.histogram display/d.info display/d.labels display/d.legend display/d.linegraph display/d.nviz display/d.path display/d.profile display/d.rast display/d.rast.arrow display/d.rast.num display/d.rgb display/d.rhumbline display/d.text display/d.thematic.area display/d.title display/d.vect display/d.vect.chart display/d.where general/g.access general/g.copy general/g.dirseps general/g.filename general/g.findetc general/g.findfile general/g.gisenv general/g.gui general/g.list general/g.mapset general/g.mapsets general/g.message general/g.mkfontcap general/g.mlist general/g.mremove general/g.parser general/g.pnmcomp general/g.proj general/g.region general/g.remove general/g.rename general/g.tempfile general/g.transform general/g.version imagery/i.albedo imagery/i.atcorr imagery/i.biomass imagery/i.cca imagery/i.cluster imagery/i.eb.eta imagery/i.eb.evapfr imagery/i.eb.h_SEBAL01 imagery/i.eb.soilheatflux imagery/i.emissivity imagery/i.evapo.time_integration imagery/i.fft imagery/i.find imagery/i.gensig imagery/i.gensigset imagery/i.group imagery/i.his.rgb imagery/i.ifft imagery/i.latlong imagery/i.maxlik imagery/i.modis.qc imagery/i.pca imagery/i.rectify imagery/i.rgb.his imagery/i.smap imagery/i.sunhours imagery/i.target imagery/i.vi imagery/i.zc misc/m.cogo ps/ps.map raster/r.basins.fill raster/r.bitpattern raster/r.buffer raster/r.carve raster/r.category raster/r.circle raster/r.clump raster/r.coin raster/r.colors raster/r.colors.out raster/r.composite raster/r.compress raster/r.contour raster/r.cost raster/r.covar raster/r.cross raster/r.describe raster/r.distance raster/r.drain raster/r.external raster/r.external.out raster/r.fill.dir raster/r.flow raster/r.grow.distance raster/r.gwflow raster/r.his raster/r.horizon raster/r.in.arc raster/r.in.ascii raster/r.in.bin raster/r.in.gdal raster/r.in.gridatb raster/r.in.mat raster/r.in.poly raster/r.in.xyz raster/r.info raster/r.kappa raster/r.lake raster/r.li/r.li.cwed raster/r.li/r.li.dominance raster/r.li/r.li.edgedensity raster/r.li/r.li.mpa raster/r.li/r.li.mps raster/r.li/r.li.padcv raster/r.li/r.li.padrange raster/r.li/r.li.padsd raster/r.li/r.li.patchdensity raster/r.li/r.li.patchnum raster/r.li/r.li.richness raster/r.li/r.li.shannon raster/r.li/r.li.shape raster/r.li/r.li.simpson raster/r.los raster/r.mfilter raster/r.mode raster/r.neighbors raster/r.null raster/r.out.arc raster/r.out.ascii raster/r.out.bin raster/r.out.gdal raster/r.out.gridatb raster/r.out.mat raster/r.out.mpeg raster/r.out.png raster/r.out.pov raster/r.out.ppm raster/r.out.ppm3 raster/r.out.tiff raster/r.out.vrml raster/r.out.vtk raster/r.param.scale raster/r.patch raster/r.profile raster/r.proj raster/r.quant raster/r.quantile raster/r.random raster/r.random.cells raster/r.random.surface raster/r.reclass raster/r.recode raster/r.region raster/r.report raster/r.resamp.interp raster/r.resamp.rst raster/r.resamp.stats raster/r.resample raster/r.rescale raster/r.rescale.eq raster/r.ros raster/r.series raster/r.slope.aspect raster/r.spread raster/r.spreadpath raster/r.statistics raster/r.statistics2 raster/r.statistics3 raster/r.stats raster/r.sun raster/r.sunmask raster/r.support raster/r.support.stats raster/r.surf.area raster/r.surf.contour raster/r.surf.fractal raster/r.surf.gauss raster/r.surf.idw raster/r.surf.idw2 raster/r.surf.random raster/r.terraflow raster/r.texture raster/r.thin raster/r.timestamp raster/r.to.rast3 raster/r.to.rast3elev raster/r.to.vect raster/r.topidx raster/r.topmodel raster/r.transect raster/r.univar raster/r.uslek raster/r.usler raster/r.volume raster/r.walk raster/r.water.outlet raster/r.watershed/ram raster/r.watershed/seg raster/r.what raster/r.what.color raster3d/r3.cross.rast raster3d/r3.in.v5d raster3d/r3.mkdspf raster3d/r3.out.v5d raster3d/r3.out.vtk raster3d/r3.stats raster3d/r3.to.rast vector/lidar/v.lidar.correction vector/lidar/v.lidar.edgedetection vector/lidar/v.lidar.growing vector/lidar/v.outlier vector/lidar/v.surf.bspline vector/v.buffer vector/v.build vector/v.build.polylines vector/v.category vector/v.class vector/v.clean vector/v.convert vector/v.db.connect vector/v.db.select vector/v.delaunay vector/v.distance vector/v.drape vector/v.edit vector/v.external vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.in.ascii vector/v.in.db vector/v.in.dxf vector/v.in.ogr vector/v.in.region vector/v.in.sites vector/v.info vector/v.kcv vector/v.kernel vector/v.label vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.mkgrid vector/v.neighbors vector/v.net vector/v.net.alloc vector/v.net.iso vector/v.net.path vector/v.net.salesman vector/v.net.steiner vector/v.net.visibility vector/v.normal vector/v.out.ascii vector/v.out.dxf vector/v.out.ogr vector/v.out.pov vector/v.out.svg vector/v.out.vtk vector/v.overlay vector/v.parallel vector/v.patch vector/v.perturb vector/v.proj vector/v.qcount vector/v.random vector/v.reclass vector/v.sample vector/v.segment vector/v.select vector/v.split vector/v.support vector/v.surf.idw vector/v.surf.rst vector/v.to.3d vector/v.to.db vector/v.to.points vector/v.to.rast vector/v.to.rast3 vector/v.transform vector/v.type vector/v.univar vector/v.vol.rst vector/v.voronoi vector/v.what vector/v.what.rast visualization/xganim
Fri Aug 28 19:58:37 EDT 2009
Author: glynn
Date: 2009-08-28 19:58:33 -0400 (Fri, 28 Aug 2009)
New Revision: 38906
   grass/trunk/db/db.columns/Makefile
   grass/trunk/db/db.connect/Makefile
   grass/trunk/db/db.copy/Makefile
   grass/trunk/db/db.createdb/Makefile
   grass/trunk/db/db.databases/Makefile
   grass/trunk/db/db.describe/Makefile
   grass/trunk/db/db.drivers/Makefile
   grass/trunk/db/db.dropdb/Makefile
   grass/trunk/db/db.droptable/Makefile
   grass/trunk/db/db.execute/Makefile
   grass/trunk/db/db.login/Makefile
   grass/trunk/db/db.select/Makefile
   grass/trunk/db/db.tables/Makefile
   grass/trunk/db/drivers/dbf/Makefile
   grass/trunk/db/drivers/odbc/Makefile
   grass/trunk/db/drivers/ogr/Makefile
   grass/trunk/db/drivers/postgres/Makefile
   grass/trunk/db/drivers/sqlite/Makefile
   grass/trunk/display/d.barscale/Makefile
   grass/trunk/display/d.colorlist/Makefile
   grass/trunk/display/d.colortable/Makefile
   grass/trunk/display/d.erase/Makefile
   grass/trunk/display/d.font/Makefile
   grass/trunk/display/d.fontlist/Makefile
   grass/trunk/display/d.geodesic/Makefile
   grass/trunk/display/d.graph/Makefile
   grass/trunk/display/d.grid/Makefile
   grass/trunk/display/d.his/Makefile
   grass/trunk/display/d.histogram/Makefile
   grass/trunk/display/d.info/Makefile
   grass/trunk/display/d.labels/Makefile
   grass/trunk/display/d.legend/Makefile
   grass/trunk/display/d.linegraph/Makefile
   grass/trunk/display/d.nviz/Makefile
   grass/trunk/display/d.path/Makefile
   grass/trunk/display/d.profile/Makefile
   grass/trunk/display/d.rast.arrow/Makefile
   grass/trunk/display/d.rast.num/Makefile
   grass/trunk/display/d.rast/Makefile
   grass/trunk/display/d.rgb/Makefile
   grass/trunk/display/d.rhumbline/Makefile
   grass/trunk/display/d.text/Makefile
   grass/trunk/display/d.thematic.area/Makefile
   grass/trunk/display/d.title/Makefile
   grass/trunk/display/d.vect.chart/Makefile
   grass/trunk/display/d.vect/Makefile
   grass/trunk/display/d.where/Makefile
   grass/trunk/general/g.access/Makefile
   grass/trunk/general/g.copy/Makefile
   grass/trunk/general/g.dirseps/Makefile
   grass/trunk/general/g.filename/Makefile
   grass/trunk/general/g.findetc/Makefile
   grass/trunk/general/g.findfile/Makefile
   grass/trunk/general/g.gisenv/Makefile
   grass/trunk/general/g.gui/Makefile
   grass/trunk/general/g.list/Makefile
   grass/trunk/general/g.mapset/Makefile
   grass/trunk/general/g.mapsets/Makefile
   grass/trunk/general/g.message/Makefile
   grass/trunk/general/g.mkfontcap/Makefile
   grass/trunk/general/g.mlist/Makefile
   grass/trunk/general/g.mremove/Makefile
   grass/trunk/general/g.parser/Makefile
   grass/trunk/general/g.pnmcomp/Makefile
   grass/trunk/general/g.proj/Makefile
   grass/trunk/general/g.region/Makefile
   grass/trunk/general/g.remove/Makefile
   grass/trunk/general/g.rename/Makefile
   grass/trunk/general/g.tempfile/Makefile
   grass/trunk/general/g.transform/Makefile
   grass/trunk/general/g.version/Makefile
   grass/trunk/imagery/i.albedo/Makefile
   grass/trunk/imagery/i.atcorr/Makefile
   grass/trunk/imagery/i.biomass/Makefile
   grass/trunk/imagery/i.cca/Makefile
   grass/trunk/imagery/i.cluster/Makefile
   grass/trunk/imagery/i.eb.eta/Makefile
   grass/trunk/imagery/i.eb.evapfr/Makefile
   grass/trunk/imagery/i.eb.h_SEBAL01/Makefile
   grass/trunk/imagery/i.eb.soilheatflux/Makefile
   grass/trunk/imagery/i.emissivity/Makefile
   grass/trunk/imagery/i.evapo.time_integration/Makefile
   grass/trunk/imagery/i.fft/Makefile
   grass/trunk/imagery/i.find/Makefile
   grass/trunk/imagery/i.gensig/Makefile
   grass/trunk/imagery/i.gensigset/Makefile
   grass/trunk/imagery/i.group/Makefile
   grass/trunk/imagery/i.his.rgb/Makefile
   grass/trunk/imagery/i.ifft/Makefile
   grass/trunk/imagery/i.latlong/Makefile
   grass/trunk/imagery/i.maxlik/Makefile
   grass/trunk/imagery/i.modis.qc/Makefile
   grass/trunk/imagery/i.pca/Makefile
   grass/trunk/imagery/i.rectify/Makefile
   grass/trunk/imagery/i.rgb.his/Makefile
   grass/trunk/imagery/i.smap/Makefile
   grass/trunk/imagery/i.sunhours/Makefile
   grass/trunk/imagery/i.target/Makefile
   grass/trunk/imagery/i.vi/Makefile
   grass/trunk/imagery/i.zc/Makefile
   grass/trunk/misc/m.cogo/Makefile
   grass/trunk/ps/ps.map/Makefile
   grass/trunk/raster/r.basins.fill/Makefile
   grass/trunk/raster/r.bitpattern/Makefile
   grass/trunk/raster/r.buffer/Makefile
   grass/trunk/raster/r.carve/Makefile
   grass/trunk/raster/r.category/Makefile
   grass/trunk/raster/r.circle/Makefile
   grass/trunk/raster/r.clump/Makefile
   grass/trunk/raster/r.coin/Makefile
   grass/trunk/raster/r.colors.out/Makefile
   grass/trunk/raster/r.colors/Makefile
   grass/trunk/raster/r.composite/Makefile
   grass/trunk/raster/r.compress/Makefile
   grass/trunk/raster/r.contour/Makefile
   grass/trunk/raster/r.cost/Makefile
   grass/trunk/raster/r.covar/Makefile
   grass/trunk/raster/r.cross/Makefile
   grass/trunk/raster/r.describe/Makefile
   grass/trunk/raster/r.distance/Makefile
   grass/trunk/raster/r.drain/Makefile
   grass/trunk/raster/r.external.out/Makefile
   grass/trunk/raster/r.external/Makefile
   grass/trunk/raster/r.fill.dir/Makefile
   grass/trunk/raster/r.flow/Makefile
   grass/trunk/raster/r.grow.distance/Makefile
   grass/trunk/raster/r.gwflow/Makefile
   grass/trunk/raster/r.his/Makefile
   grass/trunk/raster/r.horizon/Makefile
   grass/trunk/raster/r.in.arc/Makefile
   grass/trunk/raster/r.in.ascii/Makefile
   grass/trunk/raster/r.in.bin/Makefile
   grass/trunk/raster/r.in.gdal/Makefile
   grass/trunk/raster/r.in.gridatb/Makefile
   grass/trunk/raster/r.in.mat/Makefile
   grass/trunk/raster/r.in.poly/Makefile
   grass/trunk/raster/r.in.xyz/Makefile
   grass/trunk/raster/r.info/Makefile
   grass/trunk/raster/r.kappa/Makefile
   grass/trunk/raster/r.lake/Makefile
   grass/trunk/raster/r.li/r.li.cwed/Makefile
   grass/trunk/raster/r.li/r.li.dominance/Makefile
   grass/trunk/raster/r.li/r.li.edgedensity/Makefile
   grass/trunk/raster/r.li/r.li.mpa/Makefile
   grass/trunk/raster/r.li/r.li.mps/Makefile
   grass/trunk/raster/r.li/r.li.padcv/Makefile
   grass/trunk/raster/r.li/r.li.padrange/Makefile
   grass/trunk/raster/r.li/r.li.padsd/Makefile
   grass/trunk/raster/r.li/r.li.patchdensity/Makefile
   grass/trunk/raster/r.li/r.li.patchnum/Makefile
   grass/trunk/raster/r.li/r.li.richness/Makefile
   grass/trunk/raster/r.li/r.li.shannon/Makefile
   grass/trunk/raster/r.li/r.li.shape/Makefile
   grass/trunk/raster/r.li/r.li.simpson/Makefile
   grass/trunk/raster/r.los/Makefile
   grass/trunk/raster/r.mfilter/Makefile
   grass/trunk/raster/r.mode/Makefile
   grass/trunk/raster/r.neighbors/Makefile
   grass/trunk/raster/r.null/Makefile
   grass/trunk/raster/r.out.arc/Makefile
   grass/trunk/raster/r.out.ascii/Makefile
   grass/trunk/raster/r.out.bin/Makefile
   grass/trunk/raster/r.out.gdal/Makefile
   grass/trunk/raster/r.out.gridatb/Makefile
   grass/trunk/raster/r.out.mat/Makefile
   grass/trunk/raster/r.out.mpeg/Makefile
   grass/trunk/raster/r.out.png/Makefile
   grass/trunk/raster/r.out.pov/Makefile
   grass/trunk/raster/r.out.ppm/Makefile
   grass/trunk/raster/r.out.ppm3/Makefile
   grass/trunk/raster/r.out.tiff/Makefile
   grass/trunk/raster/r.out.vrml/Makefile
   grass/trunk/raster/r.out.vtk/Makefile
   grass/trunk/raster/r.param.scale/Makefile
   grass/trunk/raster/r.patch/Makefile
   grass/trunk/raster/r.profile/Makefile
   grass/trunk/raster/r.proj/Makefile
   grass/trunk/raster/r.quant/Makefile
   grass/trunk/raster/r.quantile/Makefile
   grass/trunk/raster/r.random.cells/Makefile
   grass/trunk/raster/r.random.surface/Makefile
   grass/trunk/raster/r.random/Makefile
   grass/trunk/raster/r.reclass/Makefile
   grass/trunk/raster/r.recode/Makefile
   grass/trunk/raster/r.region/Makefile
   grass/trunk/raster/r.report/Makefile
   grass/trunk/raster/r.resamp.interp/Makefile
   grass/trunk/raster/r.resamp.rst/Makefile
   grass/trunk/raster/r.resamp.stats/Makefile
   grass/trunk/raster/r.resample/Makefile
   grass/trunk/raster/r.rescale.eq/Makefile
   grass/trunk/raster/r.rescale/Makefile
   grass/trunk/raster/r.ros/Makefile
   grass/trunk/raster/r.series/Makefile
   grass/trunk/raster/r.slope.aspect/Makefile
   grass/trunk/raster/r.spread/Makefile
   grass/trunk/raster/r.spreadpath/Makefile
   grass/trunk/raster/r.statistics/Makefile
   grass/trunk/raster/r.statistics2/Makefile
   grass/trunk/raster/r.statistics3/Makefile
   grass/trunk/raster/r.stats/Makefile
   grass/trunk/raster/r.sun/Makefile
   grass/trunk/raster/r.sunmask/Makefile
   grass/trunk/raster/r.support.stats/Makefile
   grass/trunk/raster/r.support/Makefile
   grass/trunk/raster/r.surf.area/Makefile
   grass/trunk/raster/r.surf.contour/Makefile
   grass/trunk/raster/r.surf.fractal/Makefile
   grass/trunk/raster/r.surf.gauss/Makefile
   grass/trunk/raster/r.surf.idw/Makefile
   grass/trunk/raster/r.surf.idw2/Makefile
   grass/trunk/raster/r.surf.random/Makefile
   grass/trunk/raster/r.terraflow/Makefile
   grass/trunk/raster/r.texture/Makefile
   grass/trunk/raster/r.thin/Makefile
   grass/trunk/raster/r.timestamp/Makefile
   grass/trunk/raster/r.to.rast3/Makefile
   grass/trunk/raster/r.to.rast3elev/Makefile
   grass/trunk/raster/r.to.vect/Makefile
   grass/trunk/raster/r.topidx/Makefile
   grass/trunk/raster/r.topmodel/Makefile
   grass/trunk/raster/r.transect/Makefile
   grass/trunk/raster/r.univar/Makefile
   grass/trunk/raster/r.uslek/Makefile
   grass/trunk/raster/r.usler/Makefile
   grass/trunk/raster/r.volume/Makefile
   grass/trunk/raster/r.walk/Makefile
   grass/trunk/raster/r.water.outlet/Makefile
   grass/trunk/raster/r.watershed/ram/Makefile
   grass/trunk/raster/r.watershed/seg/Makefile
   grass/trunk/raster/r.what.color/Makefile
   grass/trunk/raster/r.what/Makefile
   grass/trunk/raster3d/r3.cross.rast/Makefile
   grass/trunk/raster3d/r3.in.v5d/Makefile
   grass/trunk/raster3d/r3.mkdspf/Makefile
   grass/trunk/raster3d/r3.out.v5d/Makefile
   grass/trunk/raster3d/r3.out.vtk/Makefile
   grass/trunk/raster3d/r3.stats/Makefile
   grass/trunk/raster3d/r3.to.rast/Makefile
   grass/trunk/vector/lidar/v.lidar.correction/Makefile
   grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile
   grass/trunk/vector/lidar/v.lidar.growing/Makefile
   grass/trunk/vector/lidar/v.outlier/Makefile
   grass/trunk/vector/lidar/v.surf.bspline/Makefile
   grass/trunk/vector/v.buffer/Makefile
   grass/trunk/vector/v.build.polylines/Makefile
   grass/trunk/vector/v.build/Makefile
   grass/trunk/vector/v.category/Makefile
   grass/trunk/vector/v.class/Makefile
   grass/trunk/vector/v.clean/Makefile
   grass/trunk/vector/v.convert/Makefile
   grass/trunk/vector/v.db.connect/Makefile
   grass/trunk/vector/v.db.select/Makefile
   grass/trunk/vector/v.delaunay/Makefile
   grass/trunk/vector/v.distance/Makefile
   grass/trunk/vector/v.drape/Makefile
   grass/trunk/vector/v.edit/Makefile
   grass/trunk/vector/v.external/Makefile
   grass/trunk/vector/v.extract/Makefile
   grass/trunk/vector/v.extrude/Makefile
   grass/trunk/vector/v.generalize/Makefile
   grass/trunk/vector/v.hull/Makefile
   grass/trunk/vector/v.in.ascii/Makefile
   grass/trunk/vector/v.in.db/Makefile
   grass/trunk/vector/v.in.dxf/Makefile
   grass/trunk/vector/v.in.ogr/Makefile
   grass/trunk/vector/v.in.region/Makefile
   grass/trunk/vector/v.in.sites/Makefile
   grass/trunk/vector/v.info/Makefile
   grass/trunk/vector/v.kcv/Makefile
   grass/trunk/vector/v.kernel/Makefile
   grass/trunk/vector/v.label/Makefile
   grass/trunk/vector/v.lrs/v.lrs.create/Makefile
   grass/trunk/vector/v.lrs/v.lrs.label/Makefile
   grass/trunk/vector/v.lrs/v.lrs.segment/Makefile
   grass/trunk/vector/v.lrs/v.lrs.where/Makefile
   grass/trunk/vector/v.mkgrid/Makefile
   grass/trunk/vector/v.neighbors/Makefile
   grass/trunk/vector/v.net.alloc/Makefile
   grass/trunk/vector/v.net.iso/Makefile
   grass/trunk/vector/v.net.path/Makefile
   grass/trunk/vector/v.net.salesman/Makefile
   grass/trunk/vector/v.net.steiner/Makefile
   grass/trunk/vector/v.net.visibility/Makefile
   grass/trunk/vector/v.net/Makefile
   grass/trunk/vector/v.normal/Makefile
   grass/trunk/vector/v.out.ascii/Makefile
   grass/trunk/vector/v.out.dxf/Makefile
   grass/trunk/vector/v.out.ogr/Makefile
   grass/trunk/vector/v.out.pov/Makefile
   grass/trunk/vector/v.out.svg/Makefile
   grass/trunk/vector/v.out.vtk/Makefile
   grass/trunk/vector/v.overlay/Makefile
   grass/trunk/vector/v.parallel/Makefile
   grass/trunk/vector/v.patch/Makefile
   grass/trunk/vector/v.perturb/Makefile
   grass/trunk/vector/v.proj/Makefile
   grass/trunk/vector/v.qcount/Makefile
   grass/trunk/vector/v.random/Makefile
   grass/trunk/vector/v.reclass/Makefile
   grass/trunk/vector/v.sample/Makefile
   grass/trunk/vector/v.segment/Makefile
   grass/trunk/vector/v.select/Makefile
   grass/trunk/vector/v.split/Makefile
   grass/trunk/vector/v.support/Makefile
   grass/trunk/vector/v.surf.idw/Makefile
   grass/trunk/vector/v.surf.rst/Makefile
   grass/trunk/vector/v.to.3d/Makefile
   grass/trunk/vector/v.to.db/Makefile
   grass/trunk/vector/v.to.points/Makefile
   grass/trunk/vector/v.to.rast/Makefile
   grass/trunk/vector/v.to.rast3/Makefile
   grass/trunk/vector/v.transform/Makefile
   grass/trunk/vector/v.type/Makefile
   grass/trunk/vector/v.univar/Makefile
   grass/trunk/vector/v.vol.rst/Makefile
   grass/trunk/vector/v.voronoi/Makefile
   grass/trunk/vector/v.what.rast/Makefile
   grass/trunk/vector/v.what/Makefile
   grass/trunk/visualization/xganim/Makefile
Update LIBES, DEPENDENCIES from linkage database
Modified: grass/trunk/db/db.columns/Makefile
--- grass/trunk/db/db.columns/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.columns/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 MODULE_TOPDIR = ../..
-LIBES = $(DBMILIB) $(GISLIB) $(DATETIMELIB)
-DEPENDENCIES = $(GISDEP) $(DBMIDEP)
+LIBES = $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(DBMIDEP) $(GISDEP)
 PGM = db.columns
Modified: grass/trunk/db/db.connect/Makefile
--- grass/trunk/db/db.connect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.connect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.connect
Modified: grass/trunk/db/db.copy/Makefile
--- grass/trunk/db/db.copy/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.copy/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.copy
Modified: grass/trunk/db/db.createdb/Makefile
--- grass/trunk/db/db.createdb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.createdb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.createdb
Modified: grass/trunk/db/db.databases/Makefile
--- grass/trunk/db/db.databases/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.databases/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.databases
Modified: grass/trunk/db/db.describe/Makefile
--- grass/trunk/db/db.describe/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.describe/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.describe
Modified: grass/trunk/db/db.drivers/Makefile
--- grass/trunk/db/db.drivers/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.drivers/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.drivers
Modified: grass/trunk/db/db.dropdb/Makefile
--- grass/trunk/db/db.dropdb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.dropdb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.dropdb
Modified: grass/trunk/db/db.droptable/Makefile
--- grass/trunk/db/db.droptable/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.droptable/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.droptable
Modified: grass/trunk/db/db.execute/Makefile
--- grass/trunk/db/db.execute/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.execute/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.execute
Modified: grass/trunk/db/db.login/Makefile
--- grass/trunk/db/db.login/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.login/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,7 +2,7 @@
 PGM = db.login
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/db/db.select/Makefile
--- grass/trunk/db/db.select/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.select/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.select
Modified: grass/trunk/db/db.tables/Makefile
--- grass/trunk/db/db.tables/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/db.tables/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,8 +1,8 @@
 PGM = db.tables
Modified: grass/trunk/db/drivers/dbf/Makefile
--- grass/trunk/db/drivers/dbf/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/drivers/dbf/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../../..
+DEPENDENCIES = $(DBMIDRIVERDEP) $(DBMIBASEDEP) $(GISDEP)
 PGM = dbf
@@ -8,6 +8,6 @@
 MOD_OBJS := $(filter-out main_debug.o,$(AUTO_OBJS))
 include $(MODULE_TOPDIR)/include/Make/DB.make
-LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(DBMIEXTRALIB) $(SQLPLIB) $(SHAPELIB) $(DBSTUBSLIB) $(GISLIB) $(DATETIMELIB)
+LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(GISLIB) $(GDALLIBS) $(SHAPELIB) $(SQLPLIB)
 default: dbmi
Modified: grass/trunk/db/drivers/odbc/Makefile
--- grass/trunk/db/drivers/odbc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/drivers/odbc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = odbc
-LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(DBMIEXTRALIB) $(DBSTUBSLIB) $(GISLIB) $(DATETIMELIB) $(ODBCLIB)
+LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(GISLIB) $(ODBCLIB)
 default: dbmi
Modified: grass/trunk/db/drivers/ogr/Makefile
--- grass/trunk/db/drivers/ogr/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/drivers/ogr/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,13 +1,12 @@
 PGM = ogr
-LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(DBMIEXTRALIB) $(DBSTUBSLIB) \
-	$(GISLIB) $(DATETIMELIB) $(GDALLIBS)
 EXTRA_CFLAGS = $(GDALCFLAGS) $(TCLINCDIR) $(TKINCDIR)
-EXTRA_LDFLAGS = $(PQLIBPATH) $(TCLTKLIBPATH) $(TCLTKLIBS)
+EXTRA_LDFLAGS = $(PQLIBPATH) $(TCLTKLIBPATH) $(TCLTKLIBPATH) $(TCLTKLIBS)
 default: dbmi
Modified: grass/trunk/db/drivers/postgres/Makefile
--- grass/trunk/db/drivers/postgres/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/drivers/postgres/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,12 +1,11 @@
 PGM = pg
-	$(GISLIB) $(DATETIMELIB) $(PQLIB)
+LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(GISLIB) $(PQLIBPATH) $(PQLIB)
 EXTRA_CFLAGS = $(PQINCPATH)
Modified: grass/trunk/db/drivers/sqlite/Makefile
--- grass/trunk/db/drivers/sqlite/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/db/drivers/sqlite/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,12 +1,11 @@
 PGM = sqlite
-	$(GISLIB) $(DATETIMELIB) $(SQLITELIB)
+LIBES = $(DBMIDRIVERLIB) $(DBMIBASELIB) $(GISLIB) $(SQLITELIBPATH) $(SQLITELIB)
 EXTRA_CFLAGS = $(SQLITEINCPATH)
 EXTRA_LDFLAGS = $(SQLITELIBPATH)
Modified: grass/trunk/display/d.barscale/Makefile
--- grass/trunk/display/d.barscale/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.barscale/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.barscale
-LIBES     = $(DISPLAYLIB) $(GISLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(GISDEP)
Modified: grass/trunk/display/d.colorlist/Makefile
--- grass/trunk/display/d.colorlist/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.colorlist/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.colorlist
+LIBES = $(GISLIB)
+DEPENDENCIES = $(GISDEP)
Modified: grass/trunk/display/d.colortable/Makefile
--- grass/trunk/display/d.colortable/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.colortable/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.colortable
-LIBES     = $(DISPLAYLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(DISPLAYLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/display/d.erase/Makefile
--- grass/trunk/display/d.erase/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.erase/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.erase
Modified: grass/trunk/display/d.font/Makefile
--- grass/trunk/display/d.font/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.font/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.font
Modified: grass/trunk/display/d.fontlist/Makefile
--- grass/trunk/display/d.fontlist/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.fontlist/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.fontlist
-DEPENDENCIES= $(GISDEP)
Modified: grass/trunk/display/d.geodesic/Makefile
--- grass/trunk/display/d.geodesic/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.geodesic/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.geodesic
Modified: grass/trunk/display/d.graph/Makefile
--- grass/trunk/display/d.graph/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.graph/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.graph
-LIBES     = $(SYMBLIB) $(DISPLAYLIB) $(GISLIB)
-DEPENDENCIES= $(SYMBDEP) $(DISPLAYDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(SYMBLIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(SYMBDEP) $(GISDEP)
Modified: grass/trunk/display/d.grid/Makefile
--- grass/trunk/display/d.grid/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.grid/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.grid
-LIBES     = $(SYMBLIB) $(DISPLAYLIB) $(GPROJLIB) $(GISLIB)
-DEPENDENCIES= $(SYMBDEP) $(DISPLAYDEP) $(GPROJDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(GPROJDEP) $(SYMBDEP) $(GISDEP)
 EXTRA_INC = $(PROJINC)
Modified: grass/trunk/display/d.his/Makefile
--- grass/trunk/display/d.his/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.his/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.his
Modified: grass/trunk/display/d.histogram/Makefile
--- grass/trunk/display/d.histogram/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.histogram/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.histogram
Modified: grass/trunk/display/d.info/Makefile
--- grass/trunk/display/d.info/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.info/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,7 +2,7 @@
 PGM = d.info
Modified: grass/trunk/display/d.labels/Makefile
--- grass/trunk/display/d.labels/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.labels/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,7 +3,7 @@
 PGM = d.labels
+LIBES = $(DISPLAYLIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/display/d.legend/Makefile
--- grass/trunk/display/d.legend/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.legend/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.legend
Modified: grass/trunk/display/d.linegraph/Makefile
--- grass/trunk/display/d.linegraph/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.linegraph/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.linegraph
Modified: grass/trunk/display/d.nviz/Makefile
--- grass/trunk/display/d.nviz/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.nviz/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.nviz
-DEPENDENCIES = $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/display/d.path/Makefile
--- grass/trunk/display/d.path/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.path/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.path
-LIBES        = $(DISPLAYLIB) $(VECTLIB) $(GRAPHLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(VECTORLIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(VECTORDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/display/d.profile/Makefile
--- grass/trunk/display/d.profile/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.profile/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.profile
Modified: grass/trunk/display/d.rast/Makefile
--- grass/trunk/display/d.rast/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.rast/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.rast
Modified: grass/trunk/display/d.rast.arrow/Makefile
--- grass/trunk/display/d.rast.arrow/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.rast.arrow/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.rast.arrow
Modified: grass/trunk/display/d.rast.num/Makefile
--- grass/trunk/display/d.rast.num/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.rast.num/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.rast.num
Modified: grass/trunk/display/d.rgb/Makefile
--- grass/trunk/display/d.rgb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.rgb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,7 +2,7 @@
 PGM = d.rgb
 DEPLIBS= $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/display/d.rhumbline/Makefile
--- grass/trunk/display/d.rhumbline/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.rhumbline/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.rhumbline
Modified: grass/trunk/display/d.text/Makefile
--- grass/trunk/display/d.text/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.text/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.text
Modified: grass/trunk/display/d.thematic.area/Makefile
--- grass/trunk/display/d.thematic.area/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.thematic.area/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.thematic.area
-LIBES        = $(ARRAYSTATSLIB) $(DISPLAYLIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(SYMBLIB)
-DEPENDENCIES = $(ARRAYSTATSDEP) $(DISPLAYDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(SYMBDEP)
+LIBES = $(ARRAYSTATSLIB) $(DISPLAYLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(ARRAYSTATSDEP) $(DISPLAYDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/display/d.title/Makefile
--- grass/trunk/display/d.title/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.title/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.title
+LIBES = $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/display/d.vect/Makefile
--- grass/trunk/display/d.vect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.vect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.vect
-LIBES        = $(DISPLAYLIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(SYMBLIB)
-DEPENDENCIES = $(DISPLAYDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(SYMBDEP)
+LIBES = $(DISPLAYLIB) $(SYMBLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(SYMBDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/display/d.vect.chart/Makefile
--- grass/trunk/display/d.vect.chart/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.vect.chart/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = d.vect.chart
+LIBES = $(DISPLAYLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/display/d.where/Makefile
--- grass/trunk/display/d.where/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/display/d.where/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = d.where
-LIBES     = $(DISPLAYLIB) $(GPROJLIB) $(GISLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(GPROJDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(GPROJLIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(GPROJDEP) $(GISDEP)
Modified: grass/trunk/general/g.access/Makefile
--- grass/trunk/general/g.access/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.access/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = g.access
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.copy/Makefile
--- grass/trunk/general/g.copy/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.copy/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
-LIBES = $(MANAGELIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(G3DLIB)
-DEPENDENCIES = $(GISDEP) $(VECTDEP) $(DBMIDEP) $(MANAGEDEP) $(G3DDEP)
+LIBES = $(MANAGELIB) $(GISLIB)
+DEPENDENCIES = $(MANAGEDEP) $(GISDEP)
 default: cmd
Modified: grass/trunk/general/g.dirseps/Makefile
--- grass/trunk/general/g.dirseps/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.dirseps/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.dirseps
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.filename/Makefile
--- grass/trunk/general/g.filename/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.filename/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = g.filename
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.findetc/Makefile
--- grass/trunk/general/g.findetc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.findetc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = g.findetc
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.findfile/Makefile
--- grass/trunk/general/g.findfile/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.findfile/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = g.findfile
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.gisenv/Makefile
--- grass/trunk/general/g.gisenv/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.gisenv/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.gisenv
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.gui/Makefile
--- grass/trunk/general/g.gui/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.gui/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.gui
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.list/Makefile
--- grass/trunk/general/g.list/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.list/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
 default: cmd
Modified: grass/trunk/general/g.mapset/Makefile
--- grass/trunk/general/g.mapset/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.mapset/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,7 +2,7 @@
 PGM = g.mapset
-LIBES        = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.mapsets/Makefile
--- grass/trunk/general/g.mapsets/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.mapsets/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
 PGM = g.mapsets
 GUI = $(ETC)/gui/scripts/g.mapsets_picker.py
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.message/Makefile
--- grass/trunk/general/g.message/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.message/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.message
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.mkfontcap/Makefile
--- grass/trunk/general/g.mkfontcap/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.mkfontcap/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,7 +4,7 @@
 PGM = g.mkfontcap
 CAPFILE = $(ETC)/fontcap
-LIBES     = $(GISLIB) $(FTLIB)
+LIBES = $(GISLIB) $(FTLIB)
 EXTRA_CFLAGS = $(FTINC)
Modified: grass/trunk/general/g.mlist/Makefile
--- grass/trunk/general/g.mlist/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.mlist/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,7 +3,7 @@
 PGM = g.mlist
 EXTRA_INC = $(REGEXINCPATH)
-LIBES = $(MANAGELIB) $(GISLIB) $(REGEXLIBPATH) $(REGEXLIB)
Modified: grass/trunk/general/g.mremove/Makefile
--- grass/trunk/general/g.mremove/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.mremove/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.mremove
-LIBES = $(MANAGELIB) $(VECTLIB) $(G3DLIB) $(GISLIB) $(RASTERLIB) $(REGEXLIBPATH) $(REGEXLIB)
-DEPENDENCIES = $(MANAGEDEP) $(VECTDEP) $(G3DDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(MANAGELIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(MANAGEDEP) $(RASTERDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC) $(REGEXINCPATH)
Modified: grass/trunk/general/g.parser/Makefile
--- grass/trunk/general/g.parser/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.parser/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,7 +3,7 @@
 PGM = g.parser
 LIBES = $(GISLIB)
Modified: grass/trunk/general/g.pnmcomp/Makefile
--- grass/trunk/general/g.pnmcomp/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.pnmcomp/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.pnmcomp
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.proj/Makefile
--- grass/trunk/general/g.proj/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.proj/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = g.proj
-LIBES     = $(PROJLIB) $(GPROJLIB) $(GISLIB)
-DEPENDENCIES= $(GPROJDEP) $(GISDEP)
+LIBES = $(GPROJLIB) $(GISLIB) $(GDALLIBS) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(GISDEP)
Modified: grass/trunk/general/g.region/Makefile
--- grass/trunk/general/g.region/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.region/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.region
-LIBES     = $(VECTLIB) $(G3DLIB) $(GPROJLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(G3DDEP) $(GPROJDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
+LIBES = $(GPROJLIB) $(VECTORLIB) $(G3DLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(G3DDEP) $(RASTERDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC) $(PROJINC)
Modified: grass/trunk/general/g.remove/Makefile
--- grass/trunk/general/g.remove/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.remove/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
-LIBES = $(MANAGELIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(G3DLIB)
-DEPENDENCIES = $(GISDEP) $(VECTDEP) $(DBMIDEP) $(MANAGEDEP) $(RASTERDEP) $(G3DDEP)
 default: cmd
Modified: grass/trunk/general/g.rename/Makefile
--- grass/trunk/general/g.rename/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.rename/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
 default: cmd
Modified: grass/trunk/general/g.tempfile/Makefile
--- grass/trunk/general/g.tempfile/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.tempfile/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.tempfile
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/general/g.transform/Makefile
--- grass/trunk/general/g.transform/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.transform/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = g.transform
-LIBES     = $(IMAGERYLIB) $(GISLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GISDEP)
+LIBES = $(IMAGERYLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(GISDEP)
Modified: grass/trunk/general/g.version/Makefile
--- grass/trunk/general/g.version/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/general/g.version/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -9,8 +9,8 @@
 EXTRA_CFLAGS=-DGRASS_VERSION_NUMBER=\"'$(GRASS_VERSION_NUMBER)'\" -DGRASS_VERSION_DATE=\"'$(GRASS_VERSION_DATE)'\" -DGRASS_VERSION_UPDATE_PKG=\"'$(GRASS_VERSION_UPDATE_PKG)'\"  -DGRASS_CONFIGURE_PARAMS="\"$(GRASS_CONFIGURE_PARAMS)\"" -DCOPYING="\"$(COPYING)\""
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
Modified: grass/trunk/imagery/i.albedo/Makefile
--- grass/trunk/imagery/i.albedo/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.albedo/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.albedo
-LIBES = $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/imagery/i.atcorr/Makefile
--- grass/trunk/imagery/i.atcorr/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.atcorr/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
+LIBES = $(RASTERLIB) $(GISLIB) $(MATHLIB)
 LINK = $(CXX)
Modified: grass/trunk/imagery/i.biomass/Makefile
--- grass/trunk/imagery/i.biomass/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.biomass/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.biomass
Modified: grass/trunk/imagery/i.cca/Makefile
--- grass/trunk/imagery/i.cca/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.cca/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.cca
-LIBES     = $(IMAGERYLIB) $(GMATHLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GMATHDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(IMAGERYLIB) $(GMATHLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(GMATHDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.cluster/Makefile
--- grass/trunk/imagery/i.cluster/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.cluster/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.cluster
-LIBES     = $(CLUSTERLIB) $(IMAGERYLIB) $(GISLIB) $(RASTERLIB) $(GMATHLIB)
-DEPENDENCIES= $(CLUSTERDEP) $(IMAGERYDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
+LIBES = $(CLUSTERLIB) $(IMAGERYLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(CLUSTERDEP) $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.eb.eta/Makefile
--- grass/trunk/imagery/i.eb.eta/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.eb.eta/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.eb.eta
Modified: grass/trunk/imagery/i.eb.evapfr/Makefile
--- grass/trunk/imagery/i.eb.evapfr/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.eb.evapfr/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.eb.evapfr
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/Makefile
--- grass/trunk/imagery/i.eb.h_SEBAL01/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.eb.h_SEBAL01
Modified: grass/trunk/imagery/i.eb.soilheatflux/Makefile
--- grass/trunk/imagery/i.eb.soilheatflux/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.eb.soilheatflux/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.eb.soilheatflux
Modified: grass/trunk/imagery/i.emissivity/Makefile
--- grass/trunk/imagery/i.emissivity/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.emissivity/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.emissivity
Modified: grass/trunk/imagery/i.evapo.time_integration/Makefile
--- grass/trunk/imagery/i.evapo.time_integration/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.evapo.time_integration/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.evapo.time_integration
Modified: grass/trunk/imagery/i.fft/Makefile
--- grass/trunk/imagery/i.fft/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.fft/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.fft
-LIBES     = $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(MATHLIB)
-DEPENDENCIES= $(GMATHDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.find/Makefile
--- grass/trunk/imagery/i.find/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.find/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.find
-LIBES     = $(GISLIB)
+LIBES = $(GISLIB)
 include $(MODULE_TOPDIR)/include/Make/Etc.make
 include $(MODULE_TOPDIR)/include/Make/NoHtml.make
Modified: grass/trunk/imagery/i.gensig/Makefile
--- grass/trunk/imagery/i.gensig/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.gensig/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.gensig
-LIBES     = $(IMAGERYLIB) $(GISLIB) $(RASTERLIB) $(GMATHLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.gensigset/Makefile
--- grass/trunk/imagery/i.gensigset/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.gensigset/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.gensigset
Modified: grass/trunk/imagery/i.group/Makefile
--- grass/trunk/imagery/i.group/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.group/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.group
-LIBES     = $(IMAGERYLIB) $(GISLIB) $(GMATHLIB)
-DEPENDENCIES= $(IMAGERYDEP) $(GISDEP) $(GMATHDEP)
Modified: grass/trunk/imagery/i.his.rgb/Makefile
--- grass/trunk/imagery/i.his.rgb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.his.rgb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.his.rgb
Modified: grass/trunk/imagery/i.ifft/Makefile
--- grass/trunk/imagery/i.ifft/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.ifft/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.ifft
Modified: grass/trunk/imagery/i.latlong/Makefile
--- grass/trunk/imagery/i.latlong/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.latlong/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.latlong
-LIBES =  $(GPROJLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(PROJLIB)
+DEPENDENCIES = $(GPROJDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/imagery/i.maxlik/Makefile
--- grass/trunk/imagery/i.maxlik/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.maxlik/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.maxlik
Modified: grass/trunk/imagery/i.modis.qc/Makefile
--- grass/trunk/imagery/i.modis.qc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.modis.qc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.modis.qc
Modified: grass/trunk/imagery/i.pca/Makefile
--- grass/trunk/imagery/i.pca/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.pca/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.pca
Modified: grass/trunk/imagery/i.rectify/Makefile
--- grass/trunk/imagery/i.rectify/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.rectify/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.rectify
Modified: grass/trunk/imagery/i.rgb.his/Makefile
--- grass/trunk/imagery/i.rgb.his/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.rgb.his/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.rgb.his
Modified: grass/trunk/imagery/i.smap/Makefile
--- grass/trunk/imagery/i.smap/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.smap/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.smap
Modified: grass/trunk/imagery/i.sunhours/Makefile
--- grass/trunk/imagery/i.sunhours/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.sunhours/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.sunhours
Modified: grass/trunk/imagery/i.target/Makefile
--- grass/trunk/imagery/i.target/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.target/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.target
Modified: grass/trunk/imagery/i.vi/Makefile
--- grass/trunk/imagery/i.vi/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.vi/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.vi
Modified: grass/trunk/imagery/i.zc/Makefile
--- grass/trunk/imagery/i.zc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/imagery/i.zc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = i.zc
Modified: grass/trunk/misc/m.cogo/Makefile
--- grass/trunk/misc/m.cogo/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/misc/m.cogo/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,7 +4,7 @@
-LIBES = $(GISLIB)
+LIBES = $(GISLIB) $(MATHLIB)
 default: cmd
Modified: grass/trunk/ps/ps.map/Makefile
--- grass/trunk/ps/ps.map/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/ps/ps.map/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=ps.map
 PROLOG=$(ETC)/paint/prolog.ps
-LIBES     = $(VECTLIB) $(GPROJLIB) $(SYMBLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB) $(IMAGERYLIB) $(GMATHLIB)
-DEPENDENCIES = $(VECTDEP) $(SYMBDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP) $(IMAGERYDEP) $(GMATHDEP)
+LIBES = $(GPROJLIB) $(SYMBLIB) $(IMAGERYLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(GPROJDEP) $(SYMBDEP) $(IMAGERYDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.basins.fill/Makefile
--- grass/trunk/raster/r.basins.fill/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.basins.fill/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.basins.fill
Modified: grass/trunk/raster/r.bitpattern/Makefile
--- grass/trunk/raster/r.bitpattern/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.bitpattern/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.bitpattern
Modified: grass/trunk/raster/r.buffer/Makefile
--- grass/trunk/raster/r.buffer/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.buffer/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.buffer2
Modified: grass/trunk/raster/r.carve/Makefile
--- grass/trunk/raster/r.carve/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.carve/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.carve
-LIBES     = $(SITESLIB) $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(BITMAPDEP) $(LINKMDEP) $(SEGMENTDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(VECTORLIB) $(BITMAPLIB) $(DIG2LIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(BITMAPDEP) $(DIG2DEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.category/Makefile
--- grass/trunk/raster/r.category/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.category/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.category
Modified: grass/trunk/raster/r.circle/Makefile
--- grass/trunk/raster/r.circle/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.circle/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.circle
Modified: grass/trunk/raster/r.clump/Makefile
--- grass/trunk/raster/r.clump/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.clump/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.clump
Modified: grass/trunk/raster/r.coin/Makefile
--- grass/trunk/raster/r.coin/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.coin/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.coin
Modified: grass/trunk/raster/r.colors/Makefile
--- grass/trunk/raster/r.colors/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.colors/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.colors
Modified: grass/trunk/raster/r.colors.out/Makefile
--- grass/trunk/raster/r.colors.out/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.colors.out/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.colors.out
Modified: grass/trunk/raster/r.composite/Makefile
--- grass/trunk/raster/r.composite/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.composite/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.composite
Modified: grass/trunk/raster/r.compress/Makefile
--- grass/trunk/raster/r.compress/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.compress/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.compress
Modified: grass/trunk/raster/r.contour/Makefile
--- grass/trunk/raster/r.contour/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.contour/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=r.contour
-LIBES     = $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.cost/Makefile
--- grass/trunk/raster/r.cost/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.cost/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.cost
-LIBES = $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(GISDEP) $(RASTERDEP) $(SEGMENTDEP) $(DATETIMEDEP)
+LIBES = $(SEGMENTLIB) $(SITESLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(SITESDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.covar/Makefile
--- grass/trunk/raster/r.covar/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.covar/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.covar
Modified: grass/trunk/raster/r.cross/Makefile
--- grass/trunk/raster/r.cross/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.cross/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.cross
Modified: grass/trunk/raster/r.describe/Makefile
--- grass/trunk/raster/r.describe/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.describe/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.describe
Modified: grass/trunk/raster/r.distance/Makefile
--- grass/trunk/raster/r.distance/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.distance/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.distance
Modified: grass/trunk/raster/r.drain/Makefile
--- grass/trunk/raster/r.drain/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.drain/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.drain
+LIBES = $(SITESLIB) $(VECTORLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(SITESDEP) $(VECTORDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.external/Makefile
--- grass/trunk/raster/r.external/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.external/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM  = r.external
-LIBES= $(GPROJLIB) $(GISLIB) $(RASTERLIB) $(IMAGERYLIB) $(GDALLIBS) $(GMATHLIB)
-DEPENDENCIES = $(GPROJDEP) $(GISDEP) $(RASTERDEP) $(IMAGERYDEP) $(GMATHDEP)
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(GDALLIBS) $(MATHLIB)
 EXTRA_INC = $(PROJINC) $(GDALCFLAGS)
Modified: grass/trunk/raster/r.external.out/Makefile
--- grass/trunk/raster/r.external.out/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.external.out/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM  = r.external.out
-LIBES= $(GISLIB) $(GDALLIBS) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP) $(GMATHDEP)
+LIBES = $(GISLIB) $(GDALLIBS)
Modified: grass/trunk/raster/r.fill.dir/Makefile
--- grass/trunk/raster/r.fill.dir/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.fill.dir/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.fill.dir
Modified: grass/trunk/raster/r.flow/Makefile
--- grass/trunk/raster/r.flow/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.flow/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r.flow
-LIBES     = $(VECTLIB) $(DBMILIB) $(BITMAPLIB) $(LINKMLIB) $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
+LIBES = $(SEGMENTLIB) $(VECTORLIB) $(BITMAPLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(VECTORDEP) $(BITMAPDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.grow.distance/Makefile
--- grass/trunk/raster/r.grow.distance/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.grow.distance/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.grow.distance
-LIBES = $(GISLIB) $(RASTERLIB) $(MATHLIB)
Modified: grass/trunk/raster/r.gwflow/Makefile
--- grass/trunk/raster/r.gwflow/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.gwflow/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r.gwflow
-LIBES = $(GISLIB) $(RASTERLIB) $(GPDELIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(GPDEDEP)
+LIBES = $(GPDELIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GPDEDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.his/Makefile
--- grass/trunk/raster/r.his/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.his/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.his
Modified: grass/trunk/raster/r.horizon/Makefile
--- grass/trunk/raster/r.horizon/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.horizon/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.horizon
+LIBES = $(GPROJLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB) $(PROJLIB)
Modified: grass/trunk/raster/r.in.arc/Makefile
--- grass/trunk/raster/r.in.arc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.arc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.arc
Modified: grass/trunk/raster/r.in.ascii/Makefile
--- grass/trunk/raster/r.in.ascii/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.ascii/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.ascii
Modified: grass/trunk/raster/r.in.bin/Makefile
--- grass/trunk/raster/r.in.bin/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.bin/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.bin
Modified: grass/trunk/raster/r.in.gdal/Makefile
--- grass/trunk/raster/r.in.gdal/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.gdal/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM  = r.in.gdal
+LIBES = $(GPROJLIB) $(IMAGERYLIB) $(RASTERLIB) $(GISLIB) $(GDALLIBS) $(MATHLIB)
+DEPENDENCIES = $(GPROJDEP) $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.in.gridatb/Makefile
--- grass/trunk/raster/r.in.gridatb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.gridatb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.gridatb
Modified: grass/trunk/raster/r.in.mat/Makefile
--- grass/trunk/raster/r.in.mat/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.mat/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.mat
Modified: grass/trunk/raster/r.in.poly/Makefile
--- grass/trunk/raster/r.in.poly/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.poly/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.poly
Modified: grass/trunk/raster/r.in.xyz/Makefile
--- grass/trunk/raster/r.in.xyz/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.in.xyz/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.in.xyz
Modified: grass/trunk/raster/r.info/Makefile
--- grass/trunk/raster/r.info/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.info/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.info
Modified: grass/trunk/raster/r.kappa/Makefile
--- grass/trunk/raster/r.kappa/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.kappa/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.kappa
Modified: grass/trunk/raster/r.lake/Makefile
--- grass/trunk/raster/r.lake/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.lake/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
 PGM = r.lake
Modified: grass/trunk/raster/r.li/r.li.cwed/Makefile
--- grass/trunk/raster/r.li/r.li.cwed/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.cwed/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
-LIBES = $(GISLIB) $(RASTERLIB) $(RLILIB)
+LIBES = $(RLILIB) $(RASTERLIB) $(GISLIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(RLIDEP)
+DEPENDENCIES = $(RLIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.li/r.li.dominance/Makefile
--- grass/trunk/raster/r.li/r.li.dominance/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.dominance/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
+LIBES = $(RLILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/raster/r.li/r.li.edgedensity/Makefile
--- grass/trunk/raster/r.li/r.li.edgedensity/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.edgedensity/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.mpa/Makefile
--- grass/trunk/raster/r.li/r.li.mpa/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.mpa/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.mps/Makefile
--- grass/trunk/raster/r.li/r.li.mps/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.mps/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.padcv/Makefile
--- grass/trunk/raster/r.li/r.li.padcv/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.padcv/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.padrange/Makefile
--- grass/trunk/raster/r.li/r.li.padrange/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.padrange/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.padsd/Makefile
--- grass/trunk/raster/r.li/r.li.padsd/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.padsd/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.patchdensity/Makefile
--- grass/trunk/raster/r.li/r.li.patchdensity/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.patchdensity/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.patchnum/Makefile
--- grass/trunk/raster/r.li/r.li.patchnum/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.patchnum/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.richness/Makefile
--- grass/trunk/raster/r.li/r.li.richness/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.richness/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.shannon/Makefile
--- grass/trunk/raster/r.li/r.li.shannon/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.shannon/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.shape/Makefile
--- grass/trunk/raster/r.li/r.li.shape/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.shape/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.li/r.li.simpson/Makefile
--- grass/trunk/raster/r.li/r.li.simpson/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.li/r.li.simpson/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
Modified: grass/trunk/raster/r.los/Makefile
--- grass/trunk/raster/r.los/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.los/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.los
-LIBES = $(SEGMENTLIB) $(GPROJLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(GPROJDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(SEGMENTLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(SEGMENTDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.mfilter/Makefile
--- grass/trunk/raster/r.mfilter/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.mfilter/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.mfilter
-LIBES = $(ROWIOLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(ROWIODEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(ROWIOLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(ROWIODEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.mode/Makefile
--- grass/trunk/raster/r.mode/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.mode/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.mode
Modified: grass/trunk/raster/r.neighbors/Makefile
--- grass/trunk/raster/r.neighbors/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.neighbors/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.neighbors
-LIBES = $(STATSLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(STATSDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(STATSLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(STATSDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.null/Makefile
--- grass/trunk/raster/r.null/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.null/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.null
Modified: grass/trunk/raster/r.out.arc/Makefile
--- grass/trunk/raster/r.out.arc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.arc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.arc
Modified: grass/trunk/raster/r.out.ascii/Makefile
--- grass/trunk/raster/r.out.ascii/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.ascii/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.ascii
Modified: grass/trunk/raster/r.out.bin/Makefile
--- grass/trunk/raster/r.out.bin/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.bin/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.bin
Modified: grass/trunk/raster/r.out.gdal/Makefile
--- grass/trunk/raster/r.out.gdal/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.gdal/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM  = r.out.gdal
-LIBES= $(GPROJLIB) $(GISLIB) $(RASTERLIB) $(GDALLIBS) $(IMAGERYLIB) $(DBMIBASELIB)
+LIBES = $(GPROJLIB) $(IMAGERYLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(GDALLIBS) $(MATHLIB)
+DEPENDENCIES = $(GPROJDEP) $(IMAGERYDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.out.gridatb/Makefile
--- grass/trunk/raster/r.out.gridatb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.gridatb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.gridatb
Modified: grass/trunk/raster/r.out.mat/Makefile
--- grass/trunk/raster/r.out.mat/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.mat/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.mat
Modified: grass/trunk/raster/r.out.mpeg/Makefile
--- grass/trunk/raster/r.out.mpeg/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.mpeg/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.mpeg
Modified: grass/trunk/raster/r.out.png/Makefile
--- grass/trunk/raster/r.out.png/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.png/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 EXTRA_CFLAGS=$(PNGINC)
-LIBES = $(GISLIB) $(RASTERLIB) $(PNGLIB)
+LIBES = $(RASTERLIB) $(GISLIB) $(PNGLIB)
Modified: grass/trunk/raster/r.out.pov/Makefile
--- grass/trunk/raster/r.out.pov/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.pov/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.pov
Modified: grass/trunk/raster/r.out.ppm/Makefile
--- grass/trunk/raster/r.out.ppm/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.ppm/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.ppm
Modified: grass/trunk/raster/r.out.ppm3/Makefile
--- grass/trunk/raster/r.out.ppm3/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.ppm3/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.ppm3
Modified: grass/trunk/raster/r.out.tiff/Makefile
--- grass/trunk/raster/r.out.tiff/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.tiff/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,9 +6,9 @@
 EXTRA_CFLAGS = $(TIFFINCPATH)
-LIBES = $(GISLIB) $(RASTERLIB) $(TIFFLIBPATH) $(TIFFLIB)
+LIBES = $(RASTERLIB) $(GISLIB) $(TIFFLIBPATH) $(TIFFLIB)
-ifneq ($(strip $(TIFFLIB)),)
+ifneq ($(strip $(TIFFLIBPATH) $(TIFFLIB)),)
 default: cmd
 endif
Modified: grass/trunk/raster/r.out.vrml/Makefile
--- grass/trunk/raster/r.out.vrml/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.vrml/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.vrml
Modified: grass/trunk/raster/r.out.vtk/Makefile
--- grass/trunk/raster/r.out.vtk/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.out.vtk/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.out.vtk
Modified: grass/trunk/raster/r.param.scale/Makefile
--- grass/trunk/raster/r.param.scale/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.param.scale/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.param.scale
-LIBES = $(GISLIB) $(RASTERLIB) $(GMATHLIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(GMATHDEP)
+LIBES = $(GMATHLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/raster/r.patch/Makefile
--- grass/trunk/raster/r.patch/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.patch/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.patch
Modified: grass/trunk/raster/r.profile/Makefile
--- grass/trunk/raster/r.profile/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.profile/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.profile
Modified: grass/trunk/raster/r.proj/Makefile
--- grass/trunk/raster/r.proj/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.proj/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.proj
Modified: grass/trunk/raster/r.quant/Makefile
--- grass/trunk/raster/r.quant/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.quant/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.quant
Modified: grass/trunk/raster/r.quantile/Makefile
--- grass/trunk/raster/r.quantile/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.quantile/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.quantile
Modified: grass/trunk/raster/r.random/Makefile
--- grass/trunk/raster/r.random/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.random/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.random
-LIBES = $(VECTLIB) $(GISLIB) $(RASTERLIB) $(SEGMENTLIB) $(DATETIMELIB)
Modified: grass/trunk/raster/r.random.cells/Makefile
--- grass/trunk/raster/r.random.cells/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.random.cells/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.random.cells
Modified: grass/trunk/raster/r.random.surface/Makefile
--- grass/trunk/raster/r.random.surface/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.random.surface/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.random.surface
Modified: grass/trunk/raster/r.reclass/Makefile
--- grass/trunk/raster/r.reclass/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.reclass/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.reclass
Modified: grass/trunk/raster/r.recode/Makefile
--- grass/trunk/raster/r.recode/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.recode/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.recode
Modified: grass/trunk/raster/r.region/Makefile
--- grass/trunk/raster/r.region/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.region/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.region
+LIBES = $(VECTORLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.report/Makefile
--- grass/trunk/raster/r.report/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.report/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.report
Modified: grass/trunk/raster/r.resamp.interp/Makefile
--- grass/trunk/raster/r.resamp.interp/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.resamp.interp/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.resamp.interp
Modified: grass/trunk/raster/r.resamp.rst/Makefile
--- grass/trunk/raster/r.resamp.rst/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.resamp.rst/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,10 +4,8 @@
 EXTRA_CLEAN_DIRS=doxygenhtml
-LIBES     = $(QTREELIB) $(INTERPFLLIB) $(INTERPDATALIB) $(BITMAPLIB) $(LINKMLIB) \
-            $(VECTLIB) $(VECTLIB_REAL) $(SITESLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB) $(GMATHLIB)
-DEPENDENCIES = $(INTERPDATADEP) $(QTREEDEP) $(INTERPFLDEP) $(BITMAPDEP) $(LINKMDEP) \
-            $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP) $(GMATHDEP)
+LIBES = $(INTERPFLLIB) $(GMATHLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(INTERPFLDEP) $(GMATHDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.resamp.stats/Makefile
--- grass/trunk/raster/r.resamp.stats/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.resamp.stats/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.resamp.stats
Modified: grass/trunk/raster/r.resample/Makefile
--- grass/trunk/raster/r.resample/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.resample/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.resample
Modified: grass/trunk/raster/r.rescale/Makefile
--- grass/trunk/raster/r.rescale/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.rescale/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.rescale
Modified: grass/trunk/raster/r.rescale.eq/Makefile
--- grass/trunk/raster/r.rescale.eq/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.rescale.eq/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.rescale.eq
Modified: grass/trunk/raster/r.ros/Makefile
--- grass/trunk/raster/r.ros/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.ros/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.ros
Modified: grass/trunk/raster/r.series/Makefile
--- grass/trunk/raster/r.series/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.series/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.series
Modified: grass/trunk/raster/r.slope.aspect/Makefile
--- grass/trunk/raster/r.slope.aspect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.slope.aspect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.slope.aspect
Modified: grass/trunk/raster/r.spread/Makefile
--- grass/trunk/raster/r.spread/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.spread/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -8,8 +8,8 @@
 # LIBES = $(DISPLAYLIB) $(GISLIB) $(RASTERLIB)
 # DEPENDENCIES = $(DISPLAYDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.spreadpath/Makefile
--- grass/trunk/raster/r.spreadpath/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.spreadpath/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.spreadpath
-LIBES = $(SEGMENTLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(SEGMENTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/raster/r.statistics/Makefile
--- grass/trunk/raster/r.statistics/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.statistics/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.statistics
Modified: grass/trunk/raster/r.statistics2/Makefile
--- grass/trunk/raster/r.statistics2/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.statistics2/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.statistics2
Modified: grass/trunk/raster/r.statistics3/Makefile
--- grass/trunk/raster/r.statistics3/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.statistics3/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.statistics3
Modified: grass/trunk/raster/r.stats/Makefile
--- grass/trunk/raster/r.stats/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.stats/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.stats
Modified: grass/trunk/raster/r.sun/Makefile
--- grass/trunk/raster/r.sun/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.sun/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.sun
Modified: grass/trunk/raster/r.sunmask/Makefile
--- grass/trunk/raster/r.sunmask/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.sunmask/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.sunmask
Modified: grass/trunk/raster/r.support/Makefile
--- grass/trunk/raster/r.support/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.support/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.support
Modified: grass/trunk/raster/r.support.stats/Makefile
--- grass/trunk/raster/r.support.stats/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.support.stats/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.support.stats
Modified: grass/trunk/raster/r.surf.area/Makefile
--- grass/trunk/raster/r.surf.area/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.area/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.area
Modified: grass/trunk/raster/r.surf.contour/Makefile
--- grass/trunk/raster/r.surf.contour/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.contour/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.contour
Modified: grass/trunk/raster/r.surf.fractal/Makefile
--- grass/trunk/raster/r.surf.fractal/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.fractal/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.fractal
-DEPENDENCIES = $(GMATHDEP) $(GISDEP) $(RASTERDEP)
 EXTRA_INC = $(FFTWINC)
Modified: grass/trunk/raster/r.surf.gauss/Makefile
--- grass/trunk/raster/r.surf.gauss/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.gauss/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.gauss
Modified: grass/trunk/raster/r.surf.idw/Makefile
--- grass/trunk/raster/r.surf.idw/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.idw/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.idw
Modified: grass/trunk/raster/r.surf.idw2/Makefile
--- grass/trunk/raster/r.surf.idw2/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.idw2/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.idw2
-LIBES = $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
 include $(MODULE_TOPDIR)/include/Make/Module.make
Modified: grass/trunk/raster/r.surf.random/Makefile
--- grass/trunk/raster/r.surf.random/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.surf.random/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.surf.random
Modified: grass/trunk/raster/r.terraflow/Makefile
--- grass/trunk/raster/r.terraflow/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.terraflow/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.terraflow
-LIBES = $(GISLIB) $(RASTERLIB) $(IOSTREAMLIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(IOSTREAMDEP)
+LIBES = $(RASTERLIB) $(GISLIB) $(IOSTREAMLIB) $(MATHLIB)
+DEPENDENCIES = $(RASTERDEP) $(GISDEP) $(IOSTREAMDEP)
Modified: grass/trunk/raster/r.texture/Makefile
--- grass/trunk/raster/r.texture/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.texture/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.texture
Modified: grass/trunk/raster/r.thin/Makefile
--- grass/trunk/raster/r.thin/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.thin/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.thin
Modified: grass/trunk/raster/r.timestamp/Makefile
--- grass/trunk/raster/r.timestamp/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.timestamp/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.timestamp
-LIBES = $(GISLIB) $(DATETIMELIB)
-DEPENDENCIES = $(GISDEP) $(DATETIMEDEP)
+LIBES = $(GISLIB)
Modified: grass/trunk/raster/r.to.rast3/Makefile
--- grass/trunk/raster/r.to.rast3/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.to.rast3/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r.to.rast3
-LIBES = $(G3DLIB) $(GISLIB) $(RASTERLIB)
-DEPENDENCIES = $(G3DDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(G3DLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(G3DDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.to.rast3elev/Makefile
--- grass/trunk/raster/r.to.rast3elev/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.to.rast3elev/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r.to.rast3elev
Modified: grass/trunk/raster/r.to.vect/Makefile
--- grass/trunk/raster/r.to.vect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.to.vect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
Modified: grass/trunk/raster/r.topidx/Makefile
--- grass/trunk/raster/r.topidx/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.topidx/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.topidx
Modified: grass/trunk/raster/r.topmodel/Makefile
--- grass/trunk/raster/r.topmodel/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.topmodel/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.topmodel
Modified: grass/trunk/raster/r.transect/Makefile
--- grass/trunk/raster/r.transect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.transect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,7 +2,7 @@
 PGM = r.transect
-LIBES = $(GISLIB)
Modified: grass/trunk/raster/r.univar/Makefile
--- grass/trunk/raster/r.univar/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.univar/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -1,7 +1,8 @@
 MODULE_TOPDIR = ../..
+LIBES2 = $(RASTERLIB) $(GISLIB) $(MATHLIB)
+LIBES3 = $(G3DLIB) $(GISLIB) $(MATHLIB)
 PROGRAMS = r.univar r3.univar
@@ -12,3 +13,6 @@
 include $(MODULE_TOPDIR)/include/Make/Multi.make
 default: multi
+$(BIN)/r.univar$(EXE): LIBES = $(LIBES2)
+$(BIN)/r3.univar$(EXE): LIBES = $(LIBES3)
Modified: grass/trunk/raster/r.uslek/Makefile
--- grass/trunk/raster/r.uslek/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.uslek/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.uslek
Modified: grass/trunk/raster/r.usler/Makefile
--- grass/trunk/raster/r.usler/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.usler/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.usler
Modified: grass/trunk/raster/r.volume/Makefile
--- grass/trunk/raster/r.volume/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.volume/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
-DEPENDENCIES = $(SITESDEP) $(VECTDEP) $(GISDEP) $(RASTERDEP)
+LIBES = $(SITESLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(SITESDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/raster/r.walk/Makefile
--- grass/trunk/raster/r.walk/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.walk/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.walk
Modified: grass/trunk/raster/r.water.outlet/Makefile
--- grass/trunk/raster/r.water.outlet/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.water.outlet/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.water.outlet
Modified: grass/trunk/raster/r.watershed/ram/Makefile
--- grass/trunk/raster/r.watershed/ram/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.watershed/ram/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.watershed.ram
Modified: grass/trunk/raster/r.watershed/seg/Makefile
--- grass/trunk/raster/r.watershed/seg/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.watershed/seg/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.watershed.seg
-LIBES = $(GISLIB) $(RASTERLIB) $(SEGMENTLIB)
-DEPENDENCIES = $(GISDEP) $(RASTERDEP) $(SEGMENTDEP)
Modified: grass/trunk/raster/r.what/Makefile
--- grass/trunk/raster/r.what/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.what/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.what
Modified: grass/trunk/raster/r.what.color/Makefile
--- grass/trunk/raster/r.what.color/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster/r.what.color/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r.what.color
Modified: grass/trunk/raster3d/r3.cross.rast/Makefile
--- grass/trunk/raster3d/r3.cross.rast/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.cross.rast/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r3.cross.rast
Modified: grass/trunk/raster3d/r3.in.v5d/Makefile
--- grass/trunk/raster3d/r3.in.v5d/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.in.v5d/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -10,7 +10,7 @@
 	EXTRA_CFLAGS += -D_FILE_OFFSET_BITS=64
 endif
+LIBES = $(G3DLIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/raster3d/r3.mkdspf/Makefile
--- grass/trunk/raster3d/r3.mkdspf/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.mkdspf/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -8,7 +8,7 @@
 EXTRA_CFLAGS    =       -I$(LDIR)
 # -I$(INCLUDE_DIR)
-LIBES = $(DSPFLIB) $(G3DLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
-DEPENDENCIES = $(DSPFDEP) $(G3DDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
+LIBES = $(DSPFLIB) $(G3DLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(DSPFDEP) $(G3DDEP) $(RASTERDEP) $(GISDEP)
 default: cmd
Modified: grass/trunk/raster3d/r3.out.v5d/Makefile
--- grass/trunk/raster3d/r3.out.v5d/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.out.v5d/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -10,7 +10,7 @@
 endif
Modified: grass/trunk/raster3d/r3.out.vtk/Makefile
--- grass/trunk/raster3d/r3.out.vtk/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.out.vtk/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r3.out.vtk
Modified: grass/trunk/raster3d/r3.stats/Makefile
--- grass/trunk/raster3d/r3.stats/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.stats/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = r3.stats
-LIBES = $(GISLIB) $(G3DLIB)
-DEPENDENCIES = $(GISDEP) $(G3DDEP)
+DEPENDENCIES = $(G3DDEP) $(GISDEP)
Modified: grass/trunk/raster3d/r3.to.rast/Makefile
--- grass/trunk/raster3d/r3.to.rast/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/raster3d/r3.to.rast/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=r3.to.rast
Modified: grass/trunk/vector/lidar/v.lidar.correction/Makefile
--- grass/trunk/vector/lidar/v.lidar.correction/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/lidar/v.lidar.correction/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.lidar.correction
-LIBES = $(LIDARLIB) $(VECTLIB) $(DBMILIB) $(GISLIB) $(RASTERLIB) $(MATHLIB) $(SEGMENTLIB) $(GMATHLIB)
-DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(BSPLINE_ARCH_OBJ) $(GMATHDEP)
+LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
Modified: grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile
--- grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/lidar/v.lidar.edgedetection/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.lidar.edgedetection
-DEPENDENCIES= $(LIDARDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP) $(RASTERDEP) $(GMATHDEP)
Modified: grass/trunk/vector/lidar/v.lidar.growing/Makefile
--- grass/trunk/vector/lidar/v.lidar.growing/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/lidar/v.lidar.growing/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.lidar.growing
+LIBES = $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/vector/lidar/v.outlier/Makefile
--- grass/trunk/vector/lidar/v.outlier/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/lidar/v.outlier/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.outlier
Modified: grass/trunk/vector/lidar/v.surf.bspline/Makefile
--- grass/trunk/vector/lidar/v.surf.bspline/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/lidar/v.surf.bspline/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.surf.bspline
+LIBES = $(LIDARLIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(LIDARDEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/vector/v.buffer/Makefile
--- grass/trunk/vector/v.buffer/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.buffer/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.buffer
-DEPENDENCIES= $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.build/Makefile
--- grass/trunk/vector/v.build/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.build/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.build
+LIBES = $(VECTORLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(GISDEP)
Modified: grass/trunk/vector/v.build.polylines/Makefile
--- grass/trunk/vector/v.build.polylines/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.build.polylines/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.build.polylines
Modified: grass/trunk/vector/v.category/Makefile
--- grass/trunk/vector/v.category/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.category/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.category
-DEPENDENCIES= $(VECTDEP) $(GISDEP)
Modified: grass/trunk/vector/v.class/Makefile
--- grass/trunk/vector/v.class/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.class/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.class
-LIBES     = $(ARRAYSTATSLIB) $(VECTLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(ARRAYSTATSDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(ARRAYSTATSLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(ARRAYSTATSDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.clean/Makefile
--- grass/trunk/vector/v.clean/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.clean/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.clean
 CLEAN_SUBDIRS = test
Modified: grass/trunk/vector/v.convert/Makefile
--- grass/trunk/vector/v.convert/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.convert/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.convert
-LIBES     = $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB) $(RASTERLIB)
+LIBES = $(VECTORLIB) $(DIG2LIB) $(DBMILIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DIG2DEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/vector/v.db.connect/Makefile
--- grass/trunk/vector/v.db.connect/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.db.connect/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.db.connect
Modified: grass/trunk/vector/v.db.select/Makefile
--- grass/trunk/vector/v.db.select/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.db.select/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.db.select
Modified: grass/trunk/vector/v.delaunay/Makefile
--- grass/trunk/vector/v.delaunay/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.delaunay/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=v.delaunay
Modified: grass/trunk/vector/v.distance/Makefile
--- grass/trunk/vector/v.distance/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.distance/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.distance
-LIBES     = $(VECTLIB) $(VECTLIB_REAL) $(GISLIB)
Modified: grass/trunk/vector/v.drape/Makefile
--- grass/trunk/vector/v.drape/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.drape/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.drape
-DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTERDEP)
Modified: grass/trunk/vector/v.edit/Makefile
--- grass/trunk/vector/v.edit/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.edit/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.edit
-LIBES = $(VEDITLIB) $(VECTLIB) $(GISLIB)
-DEPENDENCIES= $(VEDITDEP) $(VECTDEP) $(GISDEP)
+LIBES = $(VEDITLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VEDITDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.external/Makefile
--- grass/trunk/vector/v.external/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.external/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=v.external
-LIBES     = $(VECTLIB) $(GISLIB) $(GDALLIBS)
+LIBES = $(VECTORLIB) $(GISLIB) $(GDALLIBS)
Modified: grass/trunk/vector/v.extract/Makefile
--- grass/trunk/vector/v.extract/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.extract/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.extract
-LIBES     = $(GMATHLIB) $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(GMATHDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.extrude/Makefile
--- grass/trunk/vector/v.extrude/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.extrude/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.extrude
Modified: grass/trunk/vector/v.generalize/Makefile
--- grass/trunk/vector/v.generalize/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.generalize/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.generalize
+LIBES = $(VECTORLIB) $(DIG2LIB) $(GRAPHLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(DIG2DEP) $(GRAPHDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.hull/Makefile
--- grass/trunk/vector/v.hull/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.hull/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.hull
Modified: grass/trunk/vector/v.in.ascii/Makefile
--- grass/trunk/vector/v.in.ascii/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.ascii/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.in.ascii
Modified: grass/trunk/vector/v.in.db/Makefile
--- grass/trunk/vector/v.in.db/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.db/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.in.db
Modified: grass/trunk/vector/v.in.dxf/Makefile
--- grass/trunk/vector/v.in.dxf/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.dxf/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.in.dxf
Modified: grass/trunk/vector/v.in.ogr/Makefile
--- grass/trunk/vector/v.in.ogr/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.ogr/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=v.in.ogr
-LIBES     = $(VECTLIB) $(GPROJLIB) $(DBMILIB) $(GISLIB) $(GDALLIBS)
-DEPENDENCIES = $(VECTDEP) $(GPROJDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(GPROJLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(GDALLIBS) $(MATHLIB)
+DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.in.region/Makefile
--- grass/trunk/vector/v.in.region/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.region/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,9 +5,9 @@
Modified: grass/trunk/vector/v.in.sites/Makefile
--- grass/trunk/vector/v.in.sites/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.in.sites/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.in.sites
-LIBES = $(VECTLIB) $(SITESLIB) $(DBMILIB) $(GISLIB)
+LIBES = $(SITESLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(SITESDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC)
Modified: grass/trunk/vector/v.info/Makefile
--- grass/trunk/vector/v.info/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.info/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.info
+LIBES = $(VECTORLIB) $(DIG2LIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DIG2DEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.kcv/Makefile
--- grass/trunk/vector/v.kcv/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.kcv/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.kcv
Modified: grass/trunk/vector/v.kernel/Makefile
--- grass/trunk/vector/v.kernel/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.kernel/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=v.kernel
-LIBES     = $(VECTLIB) $(DBMILIB) $(GMATHLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GMATHDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
+LIBES = $(GMATHLIB) $(VECTORLIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(GMATHDEP) $(VECTORDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/vector/v.label/Makefile
--- grass/trunk/vector/v.label/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.label/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.label
-LIBES = $(DISPLAYLIB) $(VECTLIB) $(GISLIB)
-DEPENDENCIES= $(DISPLAYDEP) $(VECTDEP) $(GISDEP)
+LIBES = $(DISPLAYLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(DISPLAYDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.lrs/v.lrs.create/Makefile
--- grass/trunk/vector/v.lrs/v.lrs.create/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.lrs/v.lrs.create/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
-DEPENDENCIES = $(LRSDEP) $(VECTDEP) $(DBMIDEP) $(GISDEP)
-LIBES        = $(LRSLIB) $(VECTLIB) $(DBMILIB) $(GISLIB)
+DEPENDENCIES = $(LRSDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
+LIBES = $(LRSLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/vector/v.lrs/v.lrs.label/Makefile
--- grass/trunk/vector/v.lrs/v.lrs.label/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.lrs/v.lrs.label/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/Makefile
--- grass/trunk/vector/v.lrs/v.lrs.segment/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
Modified: grass/trunk/vector/v.lrs/v.lrs.where/Makefile
--- grass/trunk/vector/v.lrs/v.lrs.where/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.lrs/v.lrs.where/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
Modified: grass/trunk/vector/v.mkgrid/Makefile
--- grass/trunk/vector/v.mkgrid/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.mkgrid/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.mkgrid
Modified: grass/trunk/vector/v.neighbors/Makefile
--- grass/trunk/vector/v.neighbors/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.neighbors/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.neighbors
Modified: grass/trunk/vector/v.net/Makefile
--- grass/trunk/vector/v.net/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.net
Modified: grass/trunk/vector/v.net.alloc/Makefile
--- grass/trunk/vector/v.net.alloc/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.alloc/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.alloc
-LIBES        = $(VECTLIB) $(GRAPHLIB) $(DBMILIB) $(GISLIB)
Modified: grass/trunk/vector/v.net.iso/Makefile
--- grass/trunk/vector/v.net.iso/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.iso/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.iso
Modified: grass/trunk/vector/v.net.path/Makefile
--- grass/trunk/vector/v.net.path/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.path/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.path
Modified: grass/trunk/vector/v.net.salesman/Makefile
--- grass/trunk/vector/v.net.salesman/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.salesman/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.salesman
Modified: grass/trunk/vector/v.net.steiner/Makefile
--- grass/trunk/vector/v.net.steiner/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.steiner/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.steiner
Modified: grass/trunk/vector/v.net.visibility/Makefile
--- grass/trunk/vector/v.net.visibility/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.net.visibility/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.net.visibility
+LIBES = $(VECTORLIB) $(GRAPHLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(GRAPHDEP) $(GISDEP)
 EXTRA_CFLAGS = $(VECT_CFLAGS) -Wall
Modified: grass/trunk/vector/v.normal/Makefile
--- grass/trunk/vector/v.normal/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.normal/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.normal
-LIBES = $(VECTLIB) $(CDHCLIB) $(GISLIB)
-DEPENDENCIES= $(VECTDEP) $(CDHCDEP) $(GISDEP)
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(CDHCLIB) $(MATHLIB)
Modified: grass/trunk/vector/v.out.ascii/Makefile
--- grass/trunk/vector/v.out.ascii/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.ascii/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.out.ascii
Modified: grass/trunk/vector/v.out.dxf/Makefile
--- grass/trunk/vector/v.out.dxf/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.dxf/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.out.dxf
Modified: grass/trunk/vector/v.out.ogr/Makefile
--- grass/trunk/vector/v.out.ogr/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.ogr/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -6,8 +6,8 @@
 OBJS = main.o
-LIBES     = $(VECTLIB) $(GPROJLIB) $(GISLIB) $(GDALLIBS)
-DEPENDENCIES = $(VECTDEP) $(GPROJDEP) $(GISDEP)
 EXTRA_INC = $(VECT_INC) $(PROJINC)
Modified: grass/trunk/vector/v.out.pov/Makefile
--- grass/trunk/vector/v.out.pov/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.pov/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
 OBJS = main.o
Modified: grass/trunk/vector/v.out.svg/Makefile
--- grass/trunk/vector/v.out.svg/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.svg/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.out.svg
Modified: grass/trunk/vector/v.out.vtk/Makefile
--- grass/trunk/vector/v.out.vtk/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.out.vtk/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.out.vtk
Modified: grass/trunk/vector/v.overlay/Makefile
--- grass/trunk/vector/v.overlay/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.overlay/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.overlay
Modified: grass/trunk/vector/v.parallel/Makefile
--- grass/trunk/vector/v.parallel/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.parallel/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.parallel
Modified: grass/trunk/vector/v.patch/Makefile
--- grass/trunk/vector/v.patch/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.patch/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.patch
Modified: grass/trunk/vector/v.perturb/Makefile
--- grass/trunk/vector/v.perturb/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.perturb/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.perturb
Modified: grass/trunk/vector/v.proj/Makefile
--- grass/trunk/vector/v.proj/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.proj/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.proj
-DEPENDENCIES= $(VECTDEP) $(GPROJDEP) $(GISDEP)
+LIBES = $(GPROJLIB) $(VECTORLIB) $(GISLIB)
+DEPENDENCIES = $(GPROJDEP) $(VECTORDEP) $(GISDEP)
Modified: grass/trunk/vector/v.qcount/Makefile
--- grass/trunk/vector/v.qcount/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.qcount/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.qcount
+LIBES = $(VECTORLIB) $(GISLIB) $(MATHLIB)
Modified: grass/trunk/vector/v.random/Makefile
--- grass/trunk/vector/v.random/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.random/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.random
-LIBES = $(VECTLIB) $(GISLIB) $(DATETIMELIB)
-DEPENDENCIES= $(VECTDEP) $(GISDEP) $(DATETIMEDEP)
Modified: grass/trunk/vector/v.reclass/Makefile
--- grass/trunk/vector/v.reclass/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.reclass/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.reclass
Modified: grass/trunk/vector/v.sample/Makefile
--- grass/trunk/vector/v.sample/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.sample/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.sample
Modified: grass/trunk/vector/v.segment/Makefile
--- grass/trunk/vector/v.segment/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.segment/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
Modified: grass/trunk/vector/v.select/Makefile
--- grass/trunk/vector/v.select/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.select/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.select
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(GEOSLIBS)
Modified: grass/trunk/vector/v.split/Makefile
--- grass/trunk/vector/v.split/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.split/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.split
Modified: grass/trunk/vector/v.support/Makefile
--- grass/trunk/vector/v.support/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.support/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.support
Modified: grass/trunk/vector/v.surf.idw/Makefile
--- grass/trunk/vector/v.surf.idw/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.surf.idw/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.surf.idw
-LIBES = $(VECTLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB)
-DEPENDENCIES= $(VECTDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP)
Modified: grass/trunk/vector/v.surf.rst/Makefile
--- grass/trunk/vector/v.surf.rst/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.surf.rst/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,13 +4,11 @@
-LIBES     = $(INTERPDATALIB) $(QTREELIB) $(INTERPFLLIB) $(BITMAPLIB) $(LINKMLIB) \
-            $(VECTLIB) $(VECTLIB_REAL) $(DBMILIB) $(SITESLIB) $(GISLIB) $(DATETIMELIB) $(GMATHLIB)
-            $(VECTDEP) $(DBMIDEP) $(GISDEP) $(DATETIMEDEP) $(GMATHDEP)
+LIBES = $(INTERPFLLIB) $(QTREELIB) $(INTERPDATALIB) $(GMATHLIB) $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(INTERPFLDEP) $(QTREEDEP) $(INTERPDATADEP) $(GMATHDEP) $(VECTORDEP) $(DBMIDEP) $(GISDEP)
 default: cmd
Modified: grass/trunk/vector/v.to.3d/Makefile
--- grass/trunk/vector/v.to.3d/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.to.3d/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM=v.to.3d
Modified: grass/trunk/vector/v.to.db/Makefile
--- grass/trunk/vector/v.to.db/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.to.db/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.to.db
Modified: grass/trunk/vector/v.to.points/Makefile
--- grass/trunk/vector/v.to.points/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.to.points/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,9 +5,9 @@
Modified: grass/trunk/vector/v.to.rast/Makefile
--- grass/trunk/vector/v.to.rast/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.to.rast/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.to.rast
Modified: grass/trunk/vector/v.to.rast3/Makefile
--- grass/trunk/vector/v.to.rast3/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.to.rast3/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.to.rast3
-LIBES     = $(VECTLIB) $(DBMILIB) $(G3DLIB) $(GISLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(G3DDEP) $(GISDEP)
+LIBES = $(VECTORLIB) $(G3DLIB) $(DBMILIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(VECTORDEP) $(G3DDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.transform/Makefile
--- grass/trunk/vector/v.transform/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.transform/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -5,8 +5,8 @@
-LIBES     = $(VECTLIB) $(DBMILIB) $(TRANSLIB) $(EXTRA_LIB) $(GISLIB)
+LIBES = $(VECTORLIB) $(DBMILIB) $(GISLIB) $(MATHLIB) $(TRANSLIB)
Modified: grass/trunk/vector/v.type/Makefile
--- grass/trunk/vector/v.type/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.type/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM = v.type
Modified: grass/trunk/vector/v.univar/Makefile
--- grass/trunk/vector/v.univar/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.univar/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.univar
Modified: grass/trunk/vector/v.vol.rst/Makefile
--- grass/trunk/vector/v.vol.rst/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.vol.rst/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -2,8 +2,8 @@
 PGM = v.vol.rst
-LIBES = $(G3DLIB) $(SITESLIB) $(VECTLIB) $(GISLIB) $(RASTERLIB) $(DATETIMELIB) $(BITMAPLIB) $(LINKMLIB)
-DEPENDENCIES = $(G3DDEP) $(SITESDEP) $(VECTDEP) $(GISDEP) $(RASTERDEP) $(DATETIMEDEP) $(BITMAPDEP) $(LINKMDEP)
+LIBES = $(SITESLIB) $(VECTORLIB) $(G3DLIB) $(BITMAPLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB) $(MATHLIB)
+DEPENDENCIES = $(SITESDEP) $(VECTORDEP) $(G3DDEP) $(BITMAPDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/vector/v.voronoi/Makefile
--- grass/trunk/vector/v.voronoi/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.voronoi/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -8,8 +8,8 @@
 v_voronoi_OBJS = vo_main.o vo_extend.o vo_write.o $(SWEEP_OBJS)
Modified: grass/trunk/vector/v.what/Makefile
--- grass/trunk/vector/v.what/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.what/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,9 +3,9 @@
 PGM = v.what
-LIBES        = $(VECTLIB) $(DBMILIB) $(GISLIB)
-DEPENDENCIES = $(VECTDEP) $(DBMIDEP) $(GISDEP)
Modified: grass/trunk/vector/v.what.rast/Makefile
--- grass/trunk/vector/v.what.rast/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/vector/v.what.rast/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -3,8 +3,8 @@
 PGM=v.what.rast
+LIBES = $(VECTORLIB) $(DBMILIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(VECTORDEP) $(DBMIDEP) $(RASTERDEP) $(GISDEP)
Modified: grass/trunk/visualization/xganim/Makefile
--- grass/trunk/visualization/xganim/Makefile	2009-08-28 16:39:00 UTC (rev 38905)
+++ grass/trunk/visualization/xganim/Makefile	2009-08-28 23:58:33 UTC (rev 38906)
@@ -4,8 +4,8 @@
 EXTRA_CFLAGS = $(WXWIDGETSCXXFLAGS) -DWXINTL_NO_GETTEXT_MACRO
-LIBES = $(GISLIB) $(RASTERLIB) $(WXWIDGETSLIB)
+LIBES = $(RASTERLIB) $(GISLIB) $(WXWIDGETSLIB)
