[GRASS-SVN] r39888 - in grass/trunk: include lib/gis lib/vector/Vlib vector/v.buffer vector/v.clean vector/v.delaunay vector/v.drape vector/v.extract vector/v.extrude vector/v.generalize vector/v.hull vector/v.kcv vector/v.neighbors vector/v.out.dxf vector/v.out.pov vector/v.out.svg
Fri Dec 4 02:21:43 EST 2009
Author: martinl
Date: 2009-12-04 02:21:40 -0500 (Fri, 04 Dec 2009)
New Revision: 39888
   grass/trunk/include/gis.h
   grass/trunk/lib/gis/parser_standard_options.c
   grass/trunk/lib/vector/Vlib/field.c
   grass/trunk/vector/v.buffer/main.c
   grass/trunk/vector/v.clean/main.c
   grass/trunk/vector/v.delaunay/in_out.c
   grass/trunk/vector/v.delaunay/main.c
   grass/trunk/vector/v.drape/main.c
   grass/trunk/vector/v.extract/main.c
   grass/trunk/vector/v.extrude/main.c
   grass/trunk/vector/v.generalize/main.c
   grass/trunk/vector/v.hull/main.c
   grass/trunk/vector/v.hull/read.c
   grass/trunk/vector/v.kcv/main.c
   grass/trunk/vector/v.neighbors/main.c
   grass/trunk/vector/v.out.dxf/main.c
   grass/trunk/vector/v.out.pov/main.c
   grass/trunk/vector/v.out.svg/main.c
synchronize vector modules (G_OPT_V_FIELD_ALL)
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/include/gis.h	2009-12-04 07:21:40 UTC (rev 39888)
@@ -188,6 +188,7 @@
     G_OPT_V_TYPE,		/* primitive type */
     G_OPT_V3_TYPE,		/* primitive type, 2D and 3D */
     G_OPT_V_FIELD,		/* layer number (layers used to be called fields) */
+    G_OPT_V_FIELD_ALL,		/* layer number (layers used to be called fields) */
     G_OPT_V_CAT,		/* one category */
     G_OPT_V_CATS,		/* more categories */
     G_OPT_V_ID, 		/* one feature id */
Modified: grass/trunk/lib/gis/parser_standard_options.c
--- grass/trunk/lib/gis/parser_standard_options.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/lib/gis/parser_standard_options.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -354,10 +354,22 @@
 	Opt->label = _("Layer number or name");
 	Opt->description =
 	    _("A single vector map can be connected to multiple database "
-	      "tables. This number determines which table to use. If reasonable '-1' selects all vector map layers. "
+	      "tables. This number determines which table to use. "
 	      "Layer name for OGR access.");
 	Opt->gisprompt = "old_layer,layer,layer";
 	break;
+    case G_OPT_V_FIELD_ALL:
+	Opt->key = "layer";
+	Opt->type = TYPE_STRING;
+	Opt->required = NO;
+	Opt->answer = "1";
+	Opt->label = _("Layer number or name ('-1' for all layers)");
+	Opt->description =
+	    _("A single vector map can be connected to multiple database "
+	      "Layer name for OGR access.");
+	Opt->gisprompt = "old_layer,layer,layer_all";
+	break;
     case G_OPT_V_CAT:
 	Opt->key = "cat";
 	Opt->type = TYPE_INTEGER;
Modified: grass/trunk/lib/vector/Vlib/field.c
--- grass/trunk/lib/vector/Vlib/field.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/lib/vector/Vlib/field.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -485,6 +485,7 @@
   \param field layer name
   \return layer number
+  \return -1 for all layers
   \return 0 if layer not found
 int Vect_get_field_number(const struct Map_info *Map, const char *field)
@@ -493,6 +494,9 @@
     G_debug(1, "Vect_get_field_number(): field = %s", field);
+    if (strcmp(field, "-1") == 0)
+	return -1;
     fi = Vect_get_field2(Map, field);
     if (fi)
Modified: grass/trunk/vector/v.buffer/main.c
--- grass/trunk/vector/v.buffer/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.buffer/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -157,7 +157,7 @@
     type_opt->answer = "point,line,area";
     type_opt->guisection = _("Selection");
-    field_opt = G_define_standard_option(G_OPT_V_FIELD);
+    field_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
     field_opt->guisection = _("Selection");
     dista_opt = G_define_option();
@@ -350,7 +350,7 @@
 	    if (!(ltype & type))
 		continue;
-	    if (!Vect_cat_get(Cats, field, &cat))
+	    if (field != -1 && !Vect_cat_get(Cats, field, &cat))
 		continue;
 	    if (bufcol_opt->answer) {
@@ -416,7 +416,7 @@
 		continue;
 	    Vect_read_line(&In, NULL, Cats, centroid);
+	    if (field > 0 && !Vect_cat_get(Cats, field, &cat))
 		continue;
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.clean/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -47,7 +47,7 @@
     module->description = _("Toolset for cleaning topology of vector map.");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
     type_opt = G_define_standard_option(G_OPT_V3_TYPE);
Modified: grass/trunk/vector/v.delaunay/in_out.c
--- grass/trunk/vector/v.delaunay/in_out.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.delaunay/in_out.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -187,7 +187,7 @@
 	if (!(type & GV_POINTS))
 	    continue;
-	if (Vect_cat_get(Cats, field, NULL) == 0)
+	if (field != -1 && Vect_cat_get(Cats, field, NULL) == 0)
 	    continue;
 	if (!complete_map) {
Modified: grass/trunk/vector/v.delaunay/main.c
--- grass/trunk/vector/v.delaunay/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.delaunay/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -64,7 +64,7 @@
 			    "vector map containing points or centroids.");
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
     reg_flag = G_define_flag();
Modified: grass/trunk/vector/v.drape/main.c
--- grass/trunk/vector/v.drape/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.drape/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -147,7 +147,7 @@
-    layer_opt = G_define_standard_option(G_OPT_V_FIELD);
+    layer_opt = G_define_standard_option(G_OPT_V_FIELD_ALL);
@@ -323,7 +323,9 @@
 		/* get the line type */
 		ltype = Vect_read_line(&In, Points, Cats, line);
+		if (layer != -1 && !Vect_cat_get(Cats, layer, NULL))
+		    continue;
 		/* write the new line file, with the updated Points struct */
 		if (sample_raster
 		    (ltype, fdrast, window, Points, method, scale, null_opt,
@@ -381,8 +383,8 @@
     else {
         /* close input vector */
         Vect_close(&In);
-	G_warning(_("No features drapped. Check Your computational region and input raster map."));
-	exit(EXIT_FAILURE);
+	G_warning(_("No features drapped. Check your computational region and input vector map."));
+	exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.extract/main.c
--- grass/trunk/vector/v.extract/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.extract/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -68,6 +68,7 @@
     int i, new_cat, type, ncats, *cats, c;
     int **ocats, *nocats, nfields, *fields;
+    int field;
     int dissolve = 0, x, y, type_only;
     char buffr[1024], text[80];
     char *input, *output;
@@ -116,10 +117,7 @@
     typopt->label = _("Types to be extracted");
     typopt->guisection = _("Selection");
-    fieldopt = G_define_standard_option(G_OPT_V_FIELD);
-    fieldopt->gisprompt = "old_layer,layer,layer_all";
-    fieldopt->label =
-	_("Layer number (if -1, all features in all layers of given type " "are extracted)");
+    fieldopt = G_define_standard_option(G_OPT_V_FIELD_ALL);
     fieldopt->guisection = _("Selection");
     listopt = G_define_standard_option(G_OPT_V_CATS);
@@ -202,7 +200,9 @@
     /* Do initial read of input file */
     Vect_set_open_level(2); /* topology required */
     Vect_open_old2(&In, input, "", fieldopt->answer);
+    field = Vect_get_field_number(&In, fieldopt->answer);
     type = Vect_option_to_types(typopt);
     if (type & GV_AREA) {
 	type |= GV_CENTROID;
@@ -261,7 +261,7 @@
     else if (whereopt->answer != NULL) {
-	Fi = Vect_get_field2(&In, fieldopt->answer);
+	Fi = Vect_get_field(&In, field);
 	if (!Fi) {
 	    G_fatal_error(_("Database connection not defined for layer <%s>"),
 			  fieldopt->answer);
@@ -292,7 +292,7 @@
     else if (nrandopt->answer != NULL) {	/* Generate random category list */
 	/* We operate on layer's CAT's and thus valid layer is required */
-	if (Vect_cidx_get_field_index(&In, atoi(fieldopt->answer)) < 0)
+	if (Vect_cidx_get_field_index(&In, field) < 0)
 	    G_fatal_error(_("This map has no categories attached. "
 			    "Use v.category to attach categories to this vector map."));
@@ -301,7 +301,7 @@
 	if (nrandom < 1)
 	    G_fatal_error(_("Please specify random number larger than 0"));
-	nfeatures = Vect_cidx_get_type_count(&In, atoi(fieldopt->answer), type);
+	nfeatures = Vect_cidx_get_type_count(&In, field, type);
 	if (nrandom >= nfeatures)
 	    G_fatal_error(_("Random category count must be smaller than feature count. "
 			   "There are only %d features of type(s): %s"),
@@ -309,7 +309,7 @@
 	/* Let's create an array of uniq CAT values
 	   According to Vlib/build.c, cidx should be allready sorted by dig_cidx_sort() */
-	ci = &(In.plus.cidx[Vect_cidx_get_field_index(&In, atoi(fieldopt->answer))]);
+	ci = &(In.plus.cidx[Vect_cidx_get_field_index(&In, field)]);
 	ucat_count = 0;
 	for (c = 0; c < ci->n_cats; c++) {
 	    /* Bitwise AND compares ci feature type with user's requested types */
@@ -364,8 +364,7 @@
     Vect_copy_head_data(&In, &Out);
     G_message(_("Extracting features..."));
-    xtract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve,
-		Vect_get_field_number(&In, fieldopt->answer),
+    xtract_line(cat_count, cat_array, &In, &Out, new_cat, type, dissolve, field,
 		type_only, r_flag->answer ? 1 : 0);
     Vect_build(&Out);
Modified: grass/trunk/vector/v.extrude/main.c
--- grass/trunk/vector/v.extrude/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.extrude/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -46,6 +46,7 @@
     struct Cell_head window;
     struct cat_list *Clist;
+    int field;
     int i, only_type, cat, ctype, fdrast = 0, areanum = 0;
     int nelements;
     int line, type;
@@ -77,7 +78,7 @@
     old = G_define_standard_option(G_OPT_V_INPUT);
     type_opt = G_define_standard_option(G_OPT_V_TYPE);
     type_opt->answer = "point,line,boundary,area";
@@ -149,6 +150,8 @@
     /* opening old vector */
     Vect_open_old2(&In, old->answer, "", field_opt->answer);
+    field = Vect_get_field_number(&In, field_opt->answer);
     Vect_hist_copy(&In, &Out);
     Vect_hist_command(&Out);
@@ -261,7 +264,7 @@
 		continue;
 	    /* fetch categories */
-	    if (Vect_cat_get(Cats, 1, &cat) == 0) {
+	    if (field != -1 && !Vect_cat_get(Cats, field, &cat)) {
 		Vect_cat_set(Cats, 1, i);
 		i++;
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.generalize/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -86,7 +86,7 @@
     /* Define the different options as defined in gis.h */
     map_in = G_define_standard_option(G_OPT_V_INPUT);
     type_opt->options = "line,boundary,area";
@@ -317,7 +317,7 @@
     /* parse filter option and select appropriate lines */
-    layer = atoi(field_opt->answer);
+    layer = Vect_get_field_number(&In, field_opt->answer);
     if (where_opt->answer) {
 	if (layer < 1)
 	    G_fatal_error(_("'%s' must be > 0 for '%s'"), "layer", "where");
@@ -372,6 +372,10 @@
 	   (type = Vect_read_next_line(&In, Points, Cats)) > 0) {
 	i++;
 	G_percent(i, n_lines, 1);
+	    continue;
 	if (type == GV_CENTROID && (mask_type & GV_BOUNDARY))
 	    continue;		/* skip old centroids,
 				 * we calculate new if we generalize boundarie */
@@ -443,6 +447,10 @@
 	n_lines = Vect_get_num_lines(&Out);
 	for (i = 1; i <= n_lines; i++) {
 	    type = Vect_read_line(&Out, Points, Cats, i);
+	    if (layer > 0 && !Vect_cat_get(Cats, layer, NULL))
+		continue;
 	    if (type != GV_BOUNDARY)
 		continue;
 	    Vect_get_line_areas(&Out, i, &left, &right);
Modified: grass/trunk/vector/v.hull/main.c
--- grass/trunk/vector/v.hull/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.hull/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -54,7 +54,7 @@
     input = G_define_standard_option(G_OPT_V_INPUT);
-    field = G_define_standard_option(G_OPT_V_FIELD);
+    field = G_define_standard_option(G_OPT_V_FIELD_ALL);
     output = G_define_standard_option(G_OPT_V_OUTPUT);
@@ -88,7 +88,7 @@
 	G_fatal_error(_("Error loading vector points map <%s>"), sitefile);
     if (numSitePoints < 3)
-	G_fatal_error(_("Convex hull calculation requires at least three points"));
+	G_fatal_error(_("Convex hull calculation requires at least three points (%d found)"), numSitePoints);
     /* create a 2D or a 3D hull? */
Modified: grass/trunk/vector/v.hull/read.c
--- grass/trunk/vector/v.hull/read.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.hull/read.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -24,7 +24,7 @@
 	if (type != GV_POINT)
 	    continue;
-	if (Vect_cat_get(cats, field, &cat) == 0)
+	if (field != -1 && Vect_cat_get(cats, field, &cat) == 0)
 	    continue;
 	G_debug(4, "Point: %f|%f|%f|#%d", sites->x[0], sites->y[0],
Modified: grass/trunk/vector/v.kcv/main.c
--- grass/trunk/vector/v.kcv/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.kcv/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -72,7 +72,7 @@
Modified: grass/trunk/vector/v.neighbors/main.c
--- grass/trunk/vector/v.neighbors/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.neighbors/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -30,7 +30,7 @@
     int out_fd;
     CELL *result, *rp;
     int nrows, ncols;
-    int row, col;
+    int row, col, count_sum;
     int field;
     struct GModule *module;
     struct Option *in_opt, *out_opt, *field_opt;
@@ -56,7 +56,7 @@
     out_opt = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -101,6 +101,7 @@
     box.T = PORT_DOUBLE_MAX;
     box.B = -PORT_DOUBLE_MAX;
+    count_sum = 0;
     for (row = 0; row < nrows; row++) {
 	double x, y;
@@ -130,7 +131,7 @@
 	    for (i = 0; i < List->n_values; i++) {
 		Vect_read_line(&In, Points, Cats, List->value[i]);
 		    continue;
 		if (Vect_points_distance(x, y, 0.0, Points->x[0],
@@ -143,6 +144,7 @@
 		Rast_set_d_value(rp, value, CELL_TYPE);
 	    rp = G_incr_void_ptr(rp, Rast_cell_size(CELL_TYPE));
+	    count_sum += count;
 	Rast_put_row(out_fd, result, CELL_TYPE);
@@ -152,5 +154,8 @@
     Vect_close(&In);
     Rast_close(out_fd);
+    if (count_sum < 1)
+	G_warning(_("No points found"));
     exit(EXIT_SUCCESS);
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.out.dxf/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -60,7 +60,7 @@
     output = G_define_standard_option(G_OPT_F_OUTPUT);
     output->required = YES;
@@ -157,7 +157,7 @@
 	ltype = Vect_read_line(Map, Points, Cats, line);
 	Vect_cat_get(Cats, field, &cat);
-	if (cat < 0)
+	if (field != -1 && cat < 0)
 	    continue;
 	sprintf(cat_num, "%d", cat);
Modified: grass/trunk/vector/v.out.pov/main.c
--- grass/trunk/vector/v.out.pov/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.out.pov/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -50,7 +50,7 @@
     type_opt->answer = "point,line,area,face";
@@ -117,7 +117,7 @@
 	    type = Vect_read_line(&In, Points, Cats, i);
 	    G_debug(2, "line = %d type = %d", i, type);
 		continue;
 	    if (!(otype & type)) {
@@ -175,7 +175,7 @@
 	    centroid = Vect_get_area_centroid(&In, i);
 	    if (centroid > 0) {
-		if (Vect_cat_get(Cats, field, NULL) < 0)
+		if (field != -1 && Vect_cat_get(Cats, field, NULL) < 0)
 		    continue;
 	    G_debug(2, "area = %d centroid = %d", i, centroid);
Modified: grass/trunk/vector/v.out.svg/main.c
--- grass/trunk/vector/v.out.svg/main.c	2009-12-04 02:59:43 UTC (rev 39887)
+++ grass/trunk/vector/v.out.svg/main.c	2009-12-04 07:21:40 UTC (rev 39888)
@@ -75,7 +75,7 @@
     out_opt = G_define_standard_option(G_OPT_F_OUTPUT);
     out_opt->description = _("Name for SVG output file");
@@ -250,7 +250,7 @@
 	    for (i = 1; i <= Vect_get_num_primitives(&In, GV_POINTS); i++) {
 		G_percent(i, Vect_get_num_primitives(&In, GV_POINTS), 10);
-		if (field > 0 && !Vect_cat_get(Cats, field, NULL))
+		if (field != -1 && !Vect_cat_get(Cats, field, NULL))
 		    continue;
 		for (j = 0; j < Points->n_points; j++) {
 		    fprintf(fpsvg, "  <circle ");
