[GRASS-SVN] r39892 - grass/trunk/gui/wxpython/scripts
Fri Dec 4 04:07:21 EST 2009
Author: hcho
Date: 2009-12-04 04:07:21 -0500 (Fri, 04 Dec 2009)
New Revision: 39892
Added:
   grass/trunk/gui/wxpython/scripts/p.cmd.py
   grass/trunk/gui/wxpython/scripts/p.db.py
   grass/trunk/gui/wxpython/scripts/p.mon.py
   grass/trunk/gui/wxpython/scripts/p.rast.py
   grass/trunk/gui/wxpython/scripts/p.vect.py
Pythonized p.db, p.mon, p.cmd, p.rast, and p.vect.
Added an opacity= option to p.rast and p.vect.
Added: grass/trunk/gui/wxpython/scripts/p.cmd.py
--- grass/trunk/gui/wxpython/scripts/p.cmd.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/scripts/p.cmd.py	2009-12-04 09:07:21 UTC (rev 39892)
@@ -0,0 +1,65 @@
+#!/usr/bin/env python
+# MODULE:       p.cmd
+# AUTHOR(S):    Martin Landa, Hamish Bowman
+#               Converted to Python by Huidae Cho
+# PURPOSE:      Wrapper for display commands and pX monitors
+# COPYRIGHT:    (C) 2009 by The GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#% description: Wrapper for display commands and pX monitors
+#% keywords: display
+#%End
+#%Option
+#% key: cmd
+#% type: string
+#% required: yes
+#% multiple: no
+#% label: Command to be performed
+#% description: Example: "d.rast map=elevation.dem at PERMANENT catlist=1300-1400 -i"
+#%End
+#%Option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% description: Opacity level in percentage
+#% answer: 100
+#%End
+import os
+import grass.script as grass
+def main():
+    cmd_file = grass.gisenv()["GRASS_PYCMDFILE"]
+    if cmd_file == "" or os.path.exists(cmd_file) == False:
+        grass.message(_("GRASS_PYCMDFILE - File not found. Run p.mon."), "e")
+        return
+    cmd = options["cmd"]
+    opacity = options["opacity"]
+    fp = open(cmd_file, "a")
+    fp.write("%s opacity=%s\n" % (cmd, opacity))
+    fp.close()
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/trunk/gui/wxpython/scripts/p.cmd.py
___________________________________________________________________
Added: svn:executable
Added: grass/trunk/gui/wxpython/scripts/p.db.py
--- grass/trunk/gui/wxpython/scripts/p.db.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/scripts/p.db.py	2009-12-04 09:07:21 UTC (rev 39892)
@@ -0,0 +1,44 @@
+# MODULE:       p.db
+# AUTHOR(S):    Jachym Cepicky, Markus Neteler, Hamish Bowman
+# PURPOSE:      Start stand-alone attribute table manager
+#%Module
+#% description: Start stand-alone attribute table manager
+#% keywords: database
+#%End
+#%Option
+#% key: table
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Table name
+#%End
+import os
+def main():
+    table = options["table"]
+    os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/wxpython/gui_modules/dbm.py" % os.environ["GISBASE"], table)
+    main()
Property changes on: grass/trunk/gui/wxpython/scripts/p.db.py
Added: grass/trunk/gui/wxpython/scripts/p.mon.py
--- grass/trunk/gui/wxpython/scripts/p.mon.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/scripts/p.mon.py	2009-12-04 09:07:21 UTC (rev 39892)
@@ -0,0 +1,107 @@
+# MODULE:       p.mon
+# AUTHOR(S):    Jachym Cepicky, Michael Barton, Martin Landa, Markus Neteler,
+#               Hamish Bowman
+# PURPOSE:      To establish and control use of a graphics display monitor.
+#%Module
+#% description: To establish and control use of a graphics display monitor.
+#%End
+##%Flag
+##% key: l
+##% description: List all monitors
+##%End
+##%Flag
+##% key: L
+##% description: List all monitors (with current status)
+##%End
+##%Flag
+##% key: p
+##% description: Print name of currently selected monitor
+##%End
+##%Flag
+##% key: r
+##% description: Release currently selected monitor
+##%End
+##%Flag
+##% key: s
+##% description: Do not automatically select when starting
+##%End
+#%Option
+#% key: start
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Name of graphics monitor to start (p0-p9)
+#%End
+##%Option
+##% key: stop
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to stop
+##%End
+##%Option
+##% key: select
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to select
+##%End
+##%Option
+##% key: unlock
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to unlock
+##%End
+import os
+def main():
+    start = options["start"]
+#    select = options["select"]
+#    stop = options["stop"]
+#    unlock = options["unlock"]
+    # create the command file
+    command_file = grass.tempfile()
+    os.system("g.gisenv set=GRASS_PYCMDFILE=%s" % command_file)
+    if start != "":
+        os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/wxpython/gui_modules/mapdisp.py" % os.environ["GISBASE"], start, command_file)
+        return
+#    if stop != "" or select != "" or unlock != "":
+#        grass.message(_("Not implemented yet"), "w")
+    main()
Property changes on: grass/trunk/gui/wxpython/scripts/p.mon.py
Added: grass/trunk/gui/wxpython/scripts/p.rast.py
--- grass/trunk/gui/wxpython/scripts/p.rast.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/scripts/p.rast.py	2009-12-04 09:07:21 UTC (rev 39892)
@@ -0,0 +1,110 @@
+# MODULE:       p.rast
+# AUTHOR(S):    Jachym Cepicky, Martin Landa, Hamish Bowman
+# PURPOSE:      Displays raster map layer in the active map display window.
+#%module
+#% description: Displays raster map layer in the active map display window.
+#% keywords: display, raster
+#%end
+#%flag
+#% key: n
+#% description: Make null cells opaque
+#%end
+#%flag
+#% key: i
+#% description: Invert catlist
+#% guisection: Selection
+#%end
+#%option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Raster map to be displayed
+#% gisprompt: old,cell,raster
+#%end
+#%option
+#% key: catlist
+#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: cat[-cat]
+#% description: List of categories to be displayed (INT maps)
+#%end
+#%option
+#% key: vallist
+#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: val[-val]
+#% description: List of values to be displayed (FP maps)
+#%end
+#%option
+#% key: bg
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: color
+#% description: Background color (for null)
+#% gisprompt: old_color,color,color
+#%end
+#%option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% answer: 100
+#% description: Set opacity between 0-100%
+#%end
+import sys
+import os
+def construct_command(cmd):
+    line = cmd
+    for key, val in options.iteritems():
+        if val != "":
+            line += " %s=%s" % (key, val)
+    for key, val in flags.iteritems():
+        if val == True:
+            line += " -%s" % key
+    return line
+def main():
+        return
+    cmd = construct_command("d"+os.path.basename(sys.argv[0])[1:-3])
+    fp.write("%s\n" % cmd)
+    fp.close()
+    main()
Property changes on: grass/trunk/gui/wxpython/scripts/p.rast.py
Added: grass/trunk/gui/wxpython/scripts/p.vect.py
--- grass/trunk/gui/wxpython/scripts/p.vect.py	                        (rev 0)
+++ grass/trunk/gui/wxpython/scripts/p.vect.py	2009-12-04 09:07:21 UTC (rev 39892)
@@ -0,0 +1,367 @@
+# MODULE:       p.vect
+# AUTHOR(S):    Jachym Cepicky, Hamish Bowman
+# PURPOSE:      Displays vector map layer in the active map display window.
+#%module
+#% description: Displays vector map layer in the active map display window.
+#% keywords: display, vector
+#%end
+#%flag
+#% key: a
+#% description: Get colors from map table column (of form RRR:GGG:BBB)
+#% guisection: Colors
+#%end
+#%flag
+#% key: c
+#% description: Random colors according to category number (or layer number if 'layer=-1' is given)
+#%end
+#%flag
+#% key: i
+#% description: Use values from 'cats' option as feature id
+#%end
+#%flag
+#% key: z
+#% description: Colorize polygons according to z height
+#%end
+#%option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: display
+#% type: string
+#% required: no
+#% multiple: yes
+#% options: shape,cat,topo,dir,attr,zcoor
+#% answer: shape
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: yes
+#% options: point,line,boundary,centroid,area,face
+#% description: Feature type
+#% answer: point,line,boundary,centroid,area,face
+#%end
+#%option
+#% key: layer
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Layer number (if -1, all layers are displayed)
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% gisprompt: old_layer,layer,layer_all
+#%end
+#%option
+#% key: cats
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: range
+#% label: Category values
+#% description: Example: 1,3,7-9,13
+#%end
+#%option
+#% key: where
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: sql_query
+#% label: WHERE conditions of SQL statement without 'where' keyword
+#% description: Example: income < 1000 and inhab >= 10000
+#%end
+#%option
+#% key: color
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Line color
+#% description: Either a standard GRASS color, R:G:B triplet, or "none"
+#% answer: black
+#% gisprompt: old_color,color,color_none
+#%end
+#%option
+#% key: fcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Area fill color
+#% answer: 200:200:200
+#%end
+#%option
+#% key: rgb_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of color definition column (for use with -a flag)
+#% answer: GRASSRGB
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#%end
+#%option
+#% key: zcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: style
+#% description: Type of color table (for use with -z flag)
+#% answer: terrain
+#%end
+#%option
+#% key: width
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Line width
+#% answer: 0
+#% guisection: Lines
+#%end
+#%option
+#% key: wcolumn
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of column for line widths (these values will be scaled by wscale)
+#%end
+#%option
+#% key: wscale
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Scale factor for wcolumn
+#% answer: 1
+#%end
+#%option
+#% key: icon
+#% type: string
+#% required: no
+#% multiple: no
+#% options: basic/marker,basic/circle,basic/arrow1,basic/star,basic/point,basic/triangle,basic/box,basic/arrow2,basic/octagon,basic/cross2,basic/pushpin,basic/diamond,basic/cross1,basic/x,demo/smrk,demo/muchomurka,extra/dive_flag,extra/half-box,extra/bridge,extra/fiducial,extra/ping,extra/offbox_ne,extra/adcp,extra/alpha_flag,extra/4pt_star,extra/half-circle,extra/offbox_nw,extra/fancy_compass,extra/airport,extra/compass,extra/offbox_se,extra/fish,extra/target,extra/offbox_sw,extra/n_arrow1,extra/pentagon,extra/n_arrow2,geology/strike_circle,geology/strike_box,geology/strike_line,geology/strike_triangle
+#% description: Point and centroid symbol
+#% answer: basic/x
+#% guisection: Symbols
+#%end
+#%option
+#% key: size
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Symbol size
+#% answer: 5
+#%end
+#%option
+#% key: size_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of numeric column containing symbol size
+#%end
+#%option
+#% key: rot_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name of numeric column containing symbol rotation angle
+#% description: Measured in degrees CCW from east
+#%end
+#%option
+#% key: llayer
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Layer number or name
+#% description: Layer number for labels (default: the given layer number)
+#% answer: 1
+#% guisection: Labels
+#%end
+#%option
+#% key: attrcol
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of column to be displayed
+#%end
+#%option
+#% key: lcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label color
+#% description: Either a standard color name or R:G:B triplet
+#% answer: red
+#%end
+#%option
+#% key: bgcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label background color
+#% answer: none
+#%end
+#%option
+#% key: bcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label border color
+#% answer: none
+#%end
+#%option
+#% key: lsize
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Label size (pixels)
+#% answer: 8
+#%end
+#%option
+#% key: font
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Font name
+#%end
+#%option
+#% key: encoding
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Text encoding
+#%end
+#%option
+#% key: xref
+#% type: string
+#% required: no
+#% multiple: no
+#% options: left,center,right
+#% description: Label horizontal justification
+#% answer: left
+#%end
+#%option
+#% key: yref
+#% type: string
+#% required: no
+#% multiple: no
+#% options: top,center,bottom
+#% description: Label vertical justification
+#% answer: center
+#%end
+#%option
+#% key: minreg
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Minimum region size (average from height and width) when map is displayed
+#%end
+#%option
+#% key: maxreg
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Maximum region size (average from height and width) when map is displayed
+#%end
+#%option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% answer: 100
+#%end
+import sys
+import os
+    line = cmd
+        if val != "":
+        if val == True:
+    return line
+def main():
+        return
+    fp.close()
+    main()
Property changes on: grass/trunk/gui/wxpython/scripts/p.vect.py
