[GRASS-SVN] r39920 - grass/branches/releasebranch_6_4/gui/wxpython/support
Sun Dec 6 06:28:46 EST 2009
Author: martinl
Date: 2009-12-06 06:28:46 -0500 (Sun, 06 Dec 2009)
New Revision: 39920
   grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
print error message when menudata.xml is not found
     (merge r39918 from trunk)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
--- grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py	2009-12-06 11:26:20 UTC (rev 39919)
+++ grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py	2009-12-06 11:28:46 UTC (rev 39920)
@@ -112,11 +112,13 @@
 def writeData(data):
     """!Write updated menudata.xml"""
-    file = os.path.join('..', 'xml', 'menudata.xml')
+    file = os.path.join('xml', 'menudata.xml')
     try:
+        if not os.path.exists(file):
+            raise IOError
         data.tree.write(file)
     except IOError:
-        print >> sys.stderr, "'menudata.xml' not found. Please run the script from 'gui/wxpython/support'."
+        print >> sys.stderr, "'%s' not found. Please run the script from 'gui/wxpython'." % file
 def main(argv = None):
Property changes on: grass/branches/releasebranch_6_4/gui/wxpython/support/update_menudata.py
___________________________________________________________________
Deleted: svn:mergeinfo
