[GRASS-SVN] r39922 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sun Dec 6 15:20:04 EST 2009
Author: cmbarton
Date: 2009-12-06 15:20:01 -0500 (Sun, 06 Dec 2009)
New Revision: 39922
   grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
Fixed menu tree access on Macs and double-clicking item to run command
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py	2009-12-06 14:48:33 UTC (rev 39921)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/help.py	2009-12-06 20:20:01 UTC (rev 39922)
@@ -64,7 +64,8 @@
         wx.Frame.__init__(self, parent = parent, id = id, title = title, **kwargs)
         self.panel = wx.Panel(parent = self, id = wx.ID_ANY)
+        self.dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+                               label=" %s " % _("Menu tree (double-click to run command)"))
         # tree
         self.tree = MenuTree(parent = self.panel, data = menudata.Data())
         self.tree.Load()
@@ -115,10 +116,10 @@
         sizer = wx.BoxSizer(wx.VERTICAL)
         # body
-        dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
-                               label=" %s " % _("Menu tree (double-click to run command)"))
+#        dataBox = wx.StaticBox(parent = self.panel, id = wx.ID_ANY,
+#                               label=" %s " % _("Menu tree (double-click to run command)"))
-        dataSizer = wx.StaticBoxSizer(dataBox, wx.HORIZONTAL)
+        dataSizer = wx.StaticBoxSizer(self.dataBox, wx.HORIZONTAL)
         dataSizer.Add(item = self.tree, proportion =1,
                       flag = wx.EXPAND)
@@ -176,10 +177,14 @@
             return
         handler = 'self.parent.' + data['handler'].lstrip('self.')
-        if data['command']:
-            eval(handler)(event = None, cmd = data['command'].split())
+        print 'handler = '+data['handler']
+        if data['handler'] == 'self.OnXTerm':
+            wx.MessageBox('You must run this command from the menu or command line',
+                          'This command require an XTerm')
+        elif data['command']:
+            self.parent.goutput.RunCmd(data['command'], switchPage = True)
         else:
-            eval(handler)(None)
+            pass
         if self.closeOnRun.IsChecked():
             self.OnCloseWindow(None)
