[GRASS-SVN] r39946 - grass/branches/develbranch_6/vector
Tue Dec 8 06:01:02 EST 2009
Author: mmetz
Date: 2009-12-08 06:01:02 -0500 (Tue, 08 Dec 2009)
New Revision: 39946
   grass/branches/develbranch_6/vector/vectorintro.html
fix confusing terminology (backport from 64)
Modified: grass/branches/develbranch_6/vector/vectorintro.html
--- grass/branches/develbranch_6/vector/vectorintro.html	2009-12-08 10:59:16 UTC (rev 39945)
+++ grass/branches/develbranch_6/vector/vectorintro.html	2009-12-08 11:01:02 UTC (rev 39946)
@@ -100,7 +100,7 @@
 <li> volume: a 3D corpus, the topological composition of faces and kernel (not yet implemented). </li>
 </ul>
 <p>
-Note that all lines and boundaries can be polylines (with nodes in between).
+Note that all lines and boundaries can be polylines (with vertices in between).
 <p>
 Area topology also holds information about isles. These isles are located
 within that area, not touching the boundaries of the outer area. Isles
