[GRASS-SVN] r39974 - grass/trunk/vector/v.in.ogr
Fri Dec 11 04:26:56 EST 2009
Author: mmetz
Date: 2009-12-11 04:26:55 -0500 (Fri, 11 Dec 2009)
New Revision: 39974
   grass/trunk/vector/v.in.ogr/v.in.ogr.html
updated manual
Modified: grass/trunk/vector/v.in.ogr/v.in.ogr.html
--- grass/trunk/vector/v.in.ogr/v.in.ogr.html	2009-12-11 09:26:09 UTC (rev 39973)
+++ grass/trunk/vector/v.in.ogr/v.in.ogr.html	2009-12-11 09:26:55 UTC (rev 39974)
@@ -7,7 +7,9 @@
 install GDAL to use <em>v.in.ogr</em>.
 <P>
 If the <b>layer</b> parameter is not given, all available layers
-are imported.
+are imported as separate GRASS layers into one GRASS vector map. If
+several OGR layer names are given, all these layers are imported as
+separate GRASS layers into one GRASS vector map.
 <P>
 The optional <b>spatial</b> parameter defines spatial query extents.
 This parameter allows the user to restrict the region to a spatial subset
