[GRASS-SVN] r39996 - grass/branches/develbranch_6/raster/r.watershed/seg
Mon Dec 14 05:05:15 EST 2009
Author: mmetz
Date: 2009-12-14 05:05:15 -0500 (Mon, 14 Dec 2009)
New Revision: 39996
   grass/branches/develbranch_6/raster/r.watershed/seg/do_astar.c
   grass/branches/develbranch_6/raster/r.watershed/seg/no_stream.c
backporting fixes for flow direction and basin delineation from trunk, seg mode
Modified: grass/branches/develbranch_6/raster/r.watershed/seg/do_astar.c
--- grass/branches/develbranch_6/raster/r.watershed/seg/do_astar.c	2009-12-14 10:03:46 UTC (rev 39995)
+++ grass/branches/develbranch_6/raster/r.watershed/seg/do_astar.c	2009-12-14 10:05:15 UTC (rev 39996)
@@ -24,8 +24,8 @@
     int nbr_ew[8] = { 0, 1, 2, 3, 1, 0, 0, 1 };
     int nbr_ns[8] = { 0, 1, 2, 3, 3, 2, 3, 2 };
     double dx, dy, dist_to_nbr[8], ew_res, ns_res;
     double slope[8];
+    int skip_diag;
     G_message(_("SECTION 2: A * Search."));
@@ -82,54 +82,53 @@
 	    slope[ct_dir] = alt_nbr[ct_dir] = 0;
 	    /* check that upr, upc are within region */
 	    if (upr >= 0 && upr < nrows && upc >= 0 && upc < ncols) {
-		/* slope */
+		/* avoid diagonal flow direction bias */
 		bseg_get(&in_list, &in_val, upr, upc);
 		bseg_get(&worked, &work_val, upr, upc);
+		skip_diag = 0;
 		if (!work_val) {
 		    cseg_get(&alt, &alt_up, upr, upc);
 		    alt_nbr[ct_dir] = alt_up;
 		    slope[ct_dir] =
 			get_slope2(alt_val, alt_nbr[ct_dir],
 				   dist_to_nbr[ct_dir]);
-		    /* avoid diagonal flow direction bias */
-		    if (ct_dir > 3) {
-			if (slope[nbr_ew[ct_dir]]) {
+		if (!in_val) {
+		    if (ct_dir > 3 && slope[ct_dir] > 0) {
+			if (slope[nbr_ew[ct_dir]] > 0) {
 			    /* slope to ew nbr > slope to center */
 			    if (slope[ct_dir] <=
 				get_slope2(alt_nbr[nbr_ew[ct_dir]],
 					   alt_nbr[ct_dir], ew_res))
-				in_val = 1;
+				skip_diag = 1;
-			if (!in_val && slope[nbr_ns[ct_dir]]) {
+			if (!skip_diag && slope[nbr_ns[ct_dir]] > 0) {
 			    /* slope to ns nbr > slope to center */
 				get_slope2(alt_nbr[nbr_ns[ct_dir]],
 					   alt_nbr[ct_dir], ns_res))
-				in_val = 1;
+				skip_diag = 1;
 		/* put neighbour in search list if not yet in */
-		if (in_val == 0) {
+		if (in_val == 0 && skip_diag == 0) {
 		    add_pt(upr, upc, alt_up, alt_val);
 		    /* flow direction is set here */
 		    drain_val = drain[upr - r + 1][upc - c + 1];
 		    cseg_put(&asp, &drain_val, upr, upc);
-		else {
-		    /* check if neighbour has not been worked on,
-		     * update values for asp and wat */
-		    if (!work_val) {
-			cseg_get(&asp, &asp_up, upr, upc);
-			if (asp_up < 0) {
-			    drain_val = drain[upr - r + 1][upc - c + 1];
-			    cseg_put(&asp, &drain_val, upr, upc);
-			    dseg_get(&wat, &wat_val, r, c);
-			    if (wat_val > 0) {
-				wat_val = -wat_val;
-				dseg_put(&wat, &wat_val, r, c);
+		/* check if neighbour has not been worked on */
+		else if (in_val && !work_val) {
+		    cseg_get(&asp, &asp_up, upr, upc);
+		    if (asp_up < 0) {
+			drain_val = drain[upr - r + 1][upc - c + 1];
+			cseg_put(&asp, &drain_val, upr, upc);
+			dseg_get(&wat, &wat_val, r, c);
+			if (wat_val > 0) {
+			    wat_val = -wat_val;
+			    dseg_put(&wat, &wat_val, r, c);
Modified: grass/branches/develbranch_6/raster/r.watershed/seg/no_stream.c
--- grass/branches/develbranch_6/raster/r.watershed/seg/no_stream.c	2009-12-14 10:03:46 UTC (rev 39995)
+++ grass/branches/develbranch_6/raster/r.watershed/seg/no_stream.c	2009-12-14 10:05:15 UTC (rev 39996)
@@ -11,6 +11,7 @@
     SHORT updir, riteflag, leftflag, thisdir;
     while (1) {
+	cseg_put(&bas, &basin_num, row, col);
 	max_drain = -1;
 	for (r = row - 1, rr = 0; r <= row + 1; r++, rr++) {
 	    for (c = col - 1, cc = 0; c <= col + 1; c++, cc++) {
@@ -67,14 +68,15 @@
 			cseg_get(&asp, &aspect, r, c);
 			if (aspect == drain[rr][cc]) {
 			    thisdir = updrain[rr][cc];
-			    if (haf_basin_side(updir,
+			    switch (haf_basin_side(updir,
 					       (SHORT) downdir,
-					       thisdir) == RITE) {
+					       thisdir)) {
+			    case RITE:
 				overland_cells(r, c, basin_num, basin_num,
 					       &new_ele);
 				riteflag++;
-			    else {
+				break;
+			    case LEFT:
 				overland_cells(r, c, basin_num, basin_num - 1,
 					       &new_ele);
 				leftflag++;
@@ -83,7 +85,7 @@
-	    if (leftflag >= riteflag) {
+	    if (leftflag > riteflag) {
 		value = basin_num - 1;
 		cseg_put(&haf, &value, row, col);
@@ -100,6 +102,7 @@
 		    slope = MIN_SLOPE;
 		fprintf(fp, " %f %f\n", slope, stream_length);
+	    cseg_put(&haf, &basin_num, row, col);
 	    return 0;
