[GRASS-SVN] r40019 - grass/branches/develbranch_6/gui/wxpython
Tue Dec 15 08:02:55 EST 2009
Author: hamish
Date: 2009-12-15 08:02:55 -0500 (Tue, 15 Dec 2009)
New Revision: 40019
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
attempt fixup for #693
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-12-15 11:38:12 UTC (rev 40018)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2009-12-15 13:02:55 UTC (rev 40019)
@@ -247,7 +247,7 @@
             label += '\t' + shortcut
         menuItem = menu.Append(wx.ID_ANY, label, helpString, kind)
         self.menucmd[menuItem.GetId()] = gcmd
         if len(gcmd) > 0 and \
@@ -407,14 +407,14 @@
                     dlg.Destroy()
                     return
                 dlg.Destroy()
         self.gm_cb.GetPage(event.GetSelection()).maptree.Map.Clean()
         self.gm_cb.GetPage(event.GetSelection()).maptree.Close(True)
         self.curr_page = None
         event.Skip()
     def GetLogWindow(self):
         """!Get widget for command output"""
         return self.goutput
@@ -976,13 +976,13 @@
         # run the command
         command = ' '.join(command)
-        if sys.platform == "darwin":
-            try:
-                cmdlist = ['xterm', '-e', 'd.mon', xmon]
-                p = gcmd.Command(cmdlist, wait=False)
+        # bring up the xmon
+        cmdlist = ['d.mon', xmon]
+        p = gcmd.Command(cmdlist, wait=False)
+        if sys.platform == "darwin":
+            try:
                 cmdlist = ['xterm', '-e', command]
                 q = gcmd.Command(cmdlist, wait=False)
             except:
@@ -990,19 +990,15 @@
                               _('Command %s could not be run') % cmdlist[0])
         else:
-            gcmd.RunCommand('d.mon',
-                            start = xmon)
-            runbat = os.path.join(gisbase,'etc','grass-run.bat')
-            xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
-            grassrun = os.path.join(gisbase,'etc','grass-run.sh')
             if 'OS' in os.environ and os.environ['OS'] == "Windows_NT":
+                runbat = os.path.join(gisbase,'etc','grass-run.bat')
                 cmdlist = ["cmd.exe", "/c", 'start "%s"' % runbat, command]
             else:
-                cmdlist = [xtermwrapper, '-e "%s"' % grassrun, command]
+                xtermwrapper = os.path.join(gisbase,'etc','grass-xterm-wrapper')
+                grassrun = os.path.join(gisbase,'etc','grass-run.sh')
+                cmdlist = [xtermwrapper, '-e', grassrun, command]
-            p = gcmd.Command(cmdlist)
         # reset display mode
         os.environ['GRASS_RENDER_IMMEDIATE'] = 'TRUE'
@@ -1349,7 +1345,7 @@
         self.curr_page.maptree.mapdisplay.Show()
     def OnAddOverlay(self, event):
-        """!Add overlay menu"""
+        """!Add decoration overlay menu"""
         # start new map display if no display is available
         if not self.curr_page:
             self.NewDisplay(show=False)
