[GRASS-SVN] r40114 - grass/branches/develbranch_6/raster/r.proj
Tue Dec 22 10:08:58 EST 2009
Author: epatton
Date: 2009-12-22 10:08:57 -0500 (Tue, 22 Dec 2009)
New Revision: 40114
   grass/branches/develbranch_6/raster/r.proj/description.html
Added example
Modified: grass/branches/develbranch_6/raster/r.proj/description.html
--- grass/branches/develbranch_6/raster/r.proj/description.html	2009-12-22 14:49:19 UTC (rev 40113)
+++ grass/branches/develbranch_6/raster/r.proj/description.html	2009-12-22 15:08:57 UTC (rev 40114)
@@ -150,6 +150,32 @@
 impossible) to find in projections other than latitude-longitude so results
 may be odd with trimming.
+<h2>EXAMPLES</h2>
+<div class="code"><pre>
+# In the source location, use v.in.region to generate a bounding box around the
+# region of interest:
+v.in.region output=bounds type=area
+# Now switch to the target location and import the vector bounding box
+# (you can run v.proj -l to get a list of vector maps in the source location):
+v.proj input=bounds location=source_location_name output=bounds_reprojected
+# Set the region in the target location with that of the newly-imported vector
+# bounds map, and align the resolution to the desired cell resolution of the
+# final, reprojected raster map:
+g.region vect=bounds_reprojected res=5 -a
+# Now reproject the raster into the target location
+r.proj input=elevation.dem output=elevation.dem.reproj \
+location=source_location_name mapset=PERMANENT res=5 method=cubic
 <h2>REFERENCES</h2>
 [1] Evenden, G.I.  (1990) <a href="http://proj.maptools.org/">Cartographic projection procedures for
