[GRASS-SVN] r35719 - in grass/trunk: lib/form visualization/nviz/src
Sun Feb 1 14:42:46 EST 2009
Author: neteler
Date: 2009-02-01 14:42:45 -0500 (Sun, 01 Feb 2009)
New Revision: 35719
   grass/trunk/lib/form/form.c
   grass/trunk/visualization/nviz/src/anim_support.c
   grass/trunk/visualization/nviz/src/cutplane_obj.c
   grass/trunk/visualization/nviz/src/do_zoom.c
   grass/trunk/visualization/nviz/src/draw.c
   grass/trunk/visualization/nviz/src/exag.c
   grass/trunk/visualization/nviz/src/lights.c
   grass/trunk/visualization/nviz/src/map_obj.c
   grass/trunk/visualization/nviz/src/misc.c
   grass/trunk/visualization/nviz/src/nviz_init.c
   grass/trunk/visualization/nviz/src/position.c
   grass/trunk/visualization/nviz/src/togl_flythrough.c
   grass/trunk/visualization/nviz/src/volume.c
Funda Wang <fundawang mandriva.org>: fixes for deprecated Tcl interp->result (trac #462)
Modified: grass/trunk/lib/form/form.c
--- grass/trunk/lib/form/form.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/lib/form/form.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -192,7 +192,7 @@
 		    TCL_ERROR) {
 		    G_warning
 			("Could not set Tcl system encoding to '%s' (%s)",
-			 Columns[i].value, interp->result);
+			 Columns[i].value, Tcl_GetStringResult(interp));
 	    continue;
Modified: grass/trunk/visualization/nviz/src/anim_support.c
--- grass/trunk/visualization/nviz/src/anim_support.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/anim_support.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -39,7 +39,7 @@
     int mode;
     if (argc != 2) {
-	interp->result = "Error: should be Nset_interp_mode linear | spline";
+	Tcl_SetResult(interp, "Error: should be Nset_interp_mode linear | spline", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -48,8 +48,9 @@
     else if (!strncmp(argv[1], "spline", 6))
 	mode = KF_SPLINE;
     else {
-	interp->result =
-	    "Error: interpoloation type must be either linear or spline";
+	    "Error: interpoloation type must be either linear or spline",
+	    TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -83,7 +84,7 @@
     double tension;
     if (argc != 2) {
-	interp->result = "Error: should be Nset_tension float_value";
+	Tcl_SetResult(interp, "Error: should be Nset_tension float_value", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -91,8 +92,9 @@
 	return (TCL_ERROR);
     if ((tension < 0) || (tension > 1)) {
-	interp->result =
-	    "Error: float_value should be between 0 and 1 inclusive";
+	    "Error: float_value should be between 0 and 1 inclusive",
+		TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -129,7 +131,7 @@
     /* Parse arguments */
     if (argc != 1) {
-	interp->result = "Error: should be Nshowtension_start";
+	Tcl_SetResult(interp, "Error: should be Nshowtension_start", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -148,7 +150,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nupdate_tension";
+	Tcl_SetResult(interp, "Error: should be Nupdate_tension", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -167,7 +169,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nshowtension_stop";
+	Tcl_SetResult(interp, "Error: should be Nshowtension_stop", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -203,7 +205,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nupdate_frames";
+	Tcl_SetResult(interp, "Error: should be Nupdate_frames", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -239,7 +241,7 @@
     long num_frames;
     if (argc != 2) {
-	interp->result = "Error: should be Nset_numsteps #_frames";
+	Tcl_SetResult(interp, "Error: should be Nset_numsteps #_frames", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -276,7 +278,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nclear_keys";
+	Tcl_SetResult(interp, "Error: should be Nclear_keys", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -349,10 +351,11 @@
     int force_replace;
     const char **listels;
     int numels, i;
+    char tmp[128];
     if (argc != 5) {
-	interp->result =
-	    "Error: should be Nadd_key pos fmask_list force_replace precis";
+	    "Error: should be Nadd_key pos fmask_list force_replace precis", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -401,8 +404,9 @@
 	    fmask |= KF_ALL_MASK;
 	else {
-	    sprintf(interp->result, "Error: mask constant %s not understood",
+	    sprintf(tmp, "Error: mask constant %s not understood",
 		    listels[i]);
+	    Tcl_SetResult(interp, tmp, TCL_VOLATILE);
 	    Tcl_Free((char *)listels);
 	    return (TCL_ERROR);
@@ -446,9 +450,10 @@
     double pos, precis;
     int justone;
     int num_deleted;
+    char tmp[10];
     if (argc != 4) {
-	interp->result = "Error: should be Ndelete_key pos precis justone";
+	Tcl_SetResult(interp, "Error: should be Ndelete_key pos precis justone", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -462,7 +467,8 @@
     /* Call the function */
     num_deleted = GK_delete_key((float)pos, (float)precis, justone);
-    sprintf(interp->result, "%d", num_deleted);
+    sprintf(tmp, "%d", num_deleted);
     return (TCL_OK);
@@ -494,9 +500,10 @@
     double new_pos, old_pos, precis;
     int num_moved;
+    char tmp[10];
     if (argc != 4) {
-	interp->result = "Error: should be Nmove_key oldpos precis newpos";
+	Tcl_SetResult(interp, "Error: should be Nmove_key oldpos precis newpos", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -515,7 +522,8 @@
 	    (float)old_pos, (float)precis, (float)new_pos);
     G_debug(3, "Frames moved = %d\n", num_moved);
-    sprintf(interp->result, "%d", num_moved);
+    sprintf(tmp, "%d", num_moved);
     return (TCL_OK);
@@ -547,8 +555,8 @@
     int render_type;
     if (argc != 3) {
-	interp->result =
-	    "Error: should be Ndo_framestep frame_# [TRUE | FALSE]";
+	    "Error: should be Ndo_framestep frame_# [TRUE | FALSE]", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -589,7 +597,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nshow_site [ TRUE | FALSE] ";
+	Tcl_SetResult(interp, "Error: should be Nshow_site [ TRUE | FALSE] ", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -612,7 +620,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nprint_keys filename";
+	Tcl_SetResult(interp, "Error: should be Nprint_keys filename", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -633,7 +641,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nshow_vect [ TRUE | FALSE] ";
+	Tcl_SetResult(interp, "Error: should be Nshow_vect [ TRUE | FALSE] ", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -658,7 +666,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nshow_vol [ TRUE | FALSE] ";
+	Tcl_SetResult(interp, "Error: should be Nshow_vol [ TRUE | FALSE] ", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -683,7 +691,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nshow_lab [ TRUE | FALSE] ";
+	Tcl_SetResult(interp, "Error: should be Nshow_lab [ TRUE | FALSE] ", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -709,7 +717,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nshow_path [ TRUE | FALSE] ";
+	Tcl_SetResult(interp, "Error: should be Nshow_path [ TRUE | FALSE] ", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -746,7 +754,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Nwrite_ppm file_name";
+	Tcl_SetResult(interp, "Error: should be Nwrite_ppm file_name", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -779,7 +787,7 @@
     if (argc != 2) {
 	return (TCL_ERROR);
@@ -787,7 +795,7 @@
     GS_write_tif(argv[1]);
 #else
-    interp->result = "Error: no TIFF support";
+    Tcl_SetResult(interp, "Error: no TIFF support", TCL_VOLATILE);
     return (TCL_ERROR);
 #endif
@@ -809,7 +817,7 @@
     if (argc != 2) {
-	interp->result = "Error: should be Noff_screen flag";
+	Tcl_SetResult(interp, "Error: should be Noff_screen flag", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -818,14 +826,14 @@
     if (flag == 1) {
 	if (Create_OS_Ctx(width, height) == -1) {
-	    interp->result = "Error: Off screen context returned error";
+	    Tcl_SetResult(interp, "Error: Off screen context returned error", TCL_VOLATILE);
 	    return (TCL_ERROR);
     else {
 	if (Destroy_OS_Ctx() == -1) {
-	    interp->result = "Error: Destroy context returned error";
+	    Tcl_SetResult(interp, "Error: Destroy context returned error", TCL_VOLATILE);
 	    return (TCL_ERROR);
@@ -846,14 +854,14 @@
     if (argc != 2) {
-	interp->result = "Error: should be Ninit_mpeg file_name";
+	Tcl_SetResult(interp, "Error: should be Ninit_mpeg file_name", TCL_VOLATILE);
 	return (TCL_ERROR);
     if (gsd_init_mpeg(argv[1])) {
-	interp->result =
-	    "Error: gsd_init_mpeg failed to initialize MPEG stream";
+	    "Error: gsd_init_mpeg failed to initialize MPEG stream", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -872,7 +880,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nwrite_mpeg_frame";
+	Tcl_SetResult(interp, "Error: should be Nwrite_mpeg_frame", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -894,7 +902,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nclose_mpeg";
+	Tcl_SetResult(interp, "Error: should be Nclose_mpeg", TCL_VOLATILE);
 	return (TCL_ERROR);
Modified: grass/trunk/visualization/nviz/src/cutplane_obj.c
--- grass/trunk/visualization/nviz/src/cutplane_obj.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/cutplane_obj.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -19,8 +19,8 @@
     /* Verify arguments */
     if (argc != 2) {
-		"Usage: Nset_fence_color ABOVE | BELOW | BLEND | GREY | OFF");
+		"Usage: Nset_fence_color ABOVE | BELOW | BLEND | GREY | OFF", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -41,8 +41,8 @@
 	GS_set_fencecolor(FC_OFF);
     else {
-		"Error in Nset_fence_color, second argument must be one of ABOVE, BELOW, BLEND, GREY or OFF.");
+		"Error in Nset_fence_color, second argument must be one of ABOVE, BELOW, BLEND, GREY or OFF.", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -133,6 +133,7 @@
     int id;
+    char tmp[128];
     id = get_cp_idnum(argv[0]);
@@ -153,9 +154,10 @@
     else if (!strcmp(argv[1], "get_trans"))
 	return (cp_get_trans(data, interp, id, argv, argc));
     else {
+	sprintf(tmp,
 		"Usage: %s \tdraw [surf1 surf2]\n\t\ton\n\t\toff\n\t\tset_rot dx dy dz\n\t\tset_trans dx dy dz\n\t\tget_rot\n\t\tget_trans",
 		argv[0]);
 	return (TCL_ERROR);
@@ -189,7 +191,7 @@
     int num_id;
     if (argc != 2) {
-	interp->result = "Usage: Nnew_cutplane_obj id_num";
+	Tcl_SetResult(interp, "Usage: Nnew_cutplane_obj id_num", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -367,10 +369,12 @@
 	    int argc)
     int bound1, bound2;
+    char tmp[128];
     if ((argc != 2) && (argc != 4)) {
-	sprintf(interp->result, "Usage: %s draw [surf1 surf2]", argv[0]);
+	sprintf(tmp, "Usage: %s draw [surf1 surf2]", argv[0]);
 	return (TCL_ERROR);
@@ -380,16 +384,18 @@
     else {
 	if (Tcl_GetInt(interp, argv[2], &bound1) != TCL_OK) {
+	    sprintf(tmp,
 		    "Error in %s draw %s %s, expected integer argument in surf1 field",
 		    argv[0], argv[2], argv[3]);
 	    return (TCL_ERROR);
 	if (Tcl_GetInt(interp, argv[3], &bound2) != TCL_OK) {
+	    sprintf(tmp,
 		    "Error in %s draw %s %s, expected integer argument in surf2 field",
 	    return (TCL_ERROR);
@@ -416,9 +422,11 @@
 int
 on_cp_obj(Nv_data * data, Tcl_Interp * interp, int id, char **argv, int argc)
+    char tmp[128];
     /* Verify arguments are correct */
     if (argc != 2) {
-	sprintf(interp->result, "Usage: %s on", argv[0]);
+	sprintf(tmp, "Usage: %s on", argv[0]);
 	return (TCL_ERROR);
@@ -445,9 +453,11 @@
 int
 off_cp_obj(Nv_data * data, Tcl_Interp * interp, int id, char **argv, int argc)
+    char tmp[128];
     if (argc != 2) {
-	sprintf(interp->result, "Usage: %s off", argv[0]);
+	sprintf(tmp, "Usage: %s off", argv[0]);
 	return (TCL_ERROR);
@@ -474,9 +484,11 @@
 state_cp_obj(Nv_data * data, Tcl_Interp * interp, int id, char **argv,
 	     int argc)
+    char tmp[128];
     if (argc != 2) {
-	sprintf(interp->result, "Usage: %s state", argv[0]);
+	sprintf(tmp, "Usage: %s state", argv[0]);
 	return (TCL_ERROR);
@@ -505,32 +517,37 @@
 cp_set_rot(Nv_data * data, Tcl_Interp * interp, int id, char **argv, int argc)
     double dx, dy, dz;
+    char tmp[128];
     if (argc != 5) {
-	sprintf(interp->result, "Usage: %s set_rot dx dy dz", argv[0]);
+	sprintf(tmp, "Usage: %s set_rot dx dy dz", argv[0]);
 	return (TCL_ERROR);
     /* Extract nummerical arguments */
     if (Tcl_GetDouble(interp, argv[2], &dx) != TCL_OK) {
+	sprintf(tmp,
 		"Error in %s set_rot %s %s %s, expected numerical argument in dx field",
 		argv[0], argv[2], argv[3], argv[4]);
 	return (TCL_ERROR);
     if (Tcl_GetDouble(interp, argv[3], &dy) != TCL_OK) {
+	sprintf(tmp,
 		"Error in %s set_rot %s %s %s, expected numerical argument in dy field",
 	return (TCL_ERROR);
     if (Tcl_GetDouble(interp, argv[4], &dz) != TCL_OK) {
+	sprintf(tmp,
 		"Error in %s set_rot %s %s %s, expected numerical argument in dz field",
 	return (TCL_ERROR);
@@ -563,32 +580,37 @@
 	     int argc)
     double dx, dy, dz;
+    char tmp[128];
     if (argc != 5) {
-	sprintf(interp->result, "Usage: %s set_trans dx dy dz", argv[0]);
+	sprintf(tmp, "Usage: %s set_trans dx dy dz", argv[0]);
 	return (TCL_ERROR);
+	sprintf(tmp,
 		"Error in %s set_trans %s %s %s, expected numerical argument in dx field",
 	return (TCL_ERROR);
+	sprintf(tmp,
 		"Error in %s set_trans %s %s %s, expected numerical argument in dy field",
 	return (TCL_ERROR);
+	sprintf(tmp,
 		"Error in %s set_trans %s %s %s, expected numerical argument in dz field",
 	return (TCL_ERROR);
@@ -614,9 +636,11 @@
 cp_get_rot(Nv_data * data, Tcl_Interp * interp, int id, char **argv, int argc)
     char x[32], y[32], z[32];
+    char tmp[128];
     if (argc != 2) {
-	sprintf(interp->result, "Usage: %s get_rot", argv[0]);
+	sprintf(tmp, "Usage: %s get_rot", argv[0]);
 	return (TCL_ERROR);
@@ -642,9 +666,11 @@
 	     int argc)
+    char tmp[128];
     if (argc != 2) {
-	sprintf(interp->result, "Usage: %s get_trans", argv[0]);
+	sprintf(tmp, "Usage: %s get_trans", argv[0]);
 	return (TCL_ERROR);
Modified: grass/trunk/visualization/nviz/src/do_zoom.c
--- grass/trunk/visualization/nviz/src/do_zoom.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/do_zoom.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -67,8 +67,8 @@
     if (argc != 4) {
-	interp->result =
-	    "Error: should be Nstart_zoom file_name width height";
+	    "Error: should be Nstart_zoom file_name width height", TCL_VOLATILE);
 	return (TCL_ERROR);
Modified: grass/trunk/visualization/nviz/src/draw.c
--- grass/trunk/visualization/nviz/src/draw.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/draw.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -242,8 +242,7 @@
     list[2] = z;
     list[3] = NULL;
-    interp->result = Tcl_Merge(3, list);
-    interp->freeProc = TCL_DYNAMIC;
+    Tcl_SetResult(interp, Tcl_Merge(3, list), TCL_DYNAMIC);
     return (TCL_OK);
Modified: grass/trunk/visualization/nviz/src/exag.c
--- grass/trunk/visualization/nviz/src/exag.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/exag.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -127,8 +127,7 @@
     list[1] = min;
     list[2] = max;
     list[3] = NULL;
     return TCL_OK;
Modified: grass/trunk/visualization/nviz/src/lights.c
--- grass/trunk/visualization/nviz/src/lights.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/lights.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -120,8 +120,7 @@
     list[2] = b;
     list[3] = NULL;
     return (TCL_OK);
@@ -142,8 +141,7 @@
     list[2] = b;
     list[3] = NULL;
     return (TCL_OK);
@@ -166,8 +164,7 @@
     list[3] = w;
     list[4] = NULL;
-    interp->result = Tcl_Merge(4, list);
+    Tcl_SetResult(interp, Tcl_Merge(4, list), TCL_DYNAMIC);
     return (TCL_OK);
Modified: grass/trunk/visualization/nviz/src/map_obj.c
--- grass/trunk/visualization/nviz/src/map_obj.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/map_obj.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -905,8 +905,7 @@
     list[2] = wire;
     list[3] = NULL;
     return (TCL_OK);
@@ -1028,8 +1027,7 @@
 	return (TCL_ERROR);
-    interp->result = Tcl_Merge(n, list);
+    Tcl_SetResult(interp, Tcl_Merge(n, list), TCL_DYNAMIC);
     return (TCL_OK);
@@ -1193,8 +1191,7 @@
     list[2] = ztrans;
     list[3] = NULL;
     return (TCL_OK);
@@ -2020,6 +2017,7 @@
 int get_mask_mode(int id, int type, Nv_data * data, Tcl_Interp * interp)
     int mode;
+    char tmp[10];
     if (type != SURF) {
 	Tcl_SetResult(interp, "Type must be SURF for get_mask_mode",
@@ -2028,7 +2026,9 @@
     GS_get_maskmode(id, &mode);
-    sprintf(interp->result, "%d", mode);
+    sprintf(tmp, "%d", mode);
+    Tcl_ResetResult(interp);
+    Tcl_AppendResult(interp, tmp);
     return (TCL_OK);
Modified: grass/trunk/visualization/nviz/src/misc.c
--- grass/trunk/visualization/nviz/src/misc.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/misc.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -33,7 +33,7 @@
     /* Parse Arguments */
     if (argc != 2) {
-	interp->result = "Error: should be Nset_SDsurf id";
+	Tcl_SetResult(interp, "Error: should be Nset_SDsurf id", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -51,7 +51,7 @@
     if (argc != 1) {
-	interp->result = "Error: should be Nunset_SDsurf";
+	Tcl_SetResult(interp, "Error: should be Nunset_SDsurf", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -69,7 +69,7 @@
     float scale;
     if (argc != 2) {
-	interp->result = "Error: should be Nset_SDscale scale";
+	Tcl_SetResult(interp, "Error: should be Nset_SDscale scale", TCL_VOLATILE);
 	return (TCL_ERROR);
Modified: grass/trunk/visualization/nviz/src/nviz_init.c
--- grass/trunk/visualization/nviz/src/nviz_init.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/nviz_init.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -165,7 +165,7 @@
     /* Put in the "please wait..." message unless we are in demo mode */
     if ((strstr(argv[0], "nviz") != NULL) && (!demo->answer)) {
 	if (Tcl_Eval(interp, startup_script) != TCL_OK)
-	    G_fatal_error("%s", interp->result);
+	    G_fatal_error("%s", Tcl_GetStringResult(interp));
@@ -219,7 +219,7 @@
     /* Look for scriptkill flag */
     if (script_kill->answer) {
 	if (Tcl_VarEval(interp, "set NvizScriptKill 1 ", NULL) != TCL_OK)
     /* See if an alternative panel path is specified */
@@ -228,14 +228,14 @@
 	if (Tcl_VarEval(interp, "set NvizAltPath ", panel_path->answer,
 			NULL) != TCL_OK)
     /* Get State file from command line */
     if (state->answer) {
 	if (Tcl_VarEval(interp, "set NvizLoadState ", state->answer,
 			NULL) != TCL_OK)
     /* See if a script file was specified */
@@ -243,7 +243,7 @@
 	/* If so then set the variable NvizPlayScript to the file */
 	if (Tcl_VarEval(interp, "set NvizPlayScript ", script->answer,
 			NULL) != TCL_OK)
 #ifdef XSCRIPT
@@ -294,16 +294,16 @@
 	    /* See if we should autoload the color file */
 	    if (aload) {
-		strncpy(tmp, interp->result, 29);
+		strncpy(tmp, Tcl_GetStringResult(interp), 29);
 		if (colr->answers) {
 		    if (Tcl_VarEval(interp, tmp, " set_att color ",
 				    colr->answers[i], NULL) != TCL_OK)
 		else {
 				    elev->answers[i], NULL) != TCL_OK)
Modified: grass/trunk/visualization/nviz/src/position.c
--- grass/trunk/visualization/nviz/src/position.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/position.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -36,8 +36,7 @@
     list[3] = NULL;
     return (TCL_OK);
@@ -61,8 +60,7 @@
     list[3] = NULL;
     return (TCL_OK);
@@ -283,7 +281,7 @@
     else if (state_flag == 0)
 	GS_set_nofocus();	/* no center of view -- use viewdir */
     else {
-	interp->result = "Error: Flag must be either 0|1";
+	Tcl_SetResult(interp, "Error: Flag must be either 0|1", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -459,8 +457,7 @@
     sprintf(fov_name, "%d", fov);
     list[0] = fov_name;
     list[1] = NULL;
-    interp->result = Tcl_Merge(1, list);
+    Tcl_SetResult(interp, Tcl_Merge(1, list), TCL_DYNAMIC);
     return (TCL_OK);
@@ -498,8 +495,7 @@
     sprintf(twist_name, "%d", twist);
     list[0] = twist_name;
     list[1] = NULL;
     return (TCL_OK);
@@ -525,8 +521,7 @@
     list[3] = west;
     list[4] = NULL;
     return (TCL_OK);
@@ -551,8 +546,7 @@
     if (!GS_get_selected_point_on_surface(sx, sy, &id, &x, &y, &z)) {
 	list[0] = NULL;
-	interp->result = Tcl_Merge(0, list);
+	Tcl_SetResult(interp, Tcl_Merge(0, list), TCL_DYNAMIC);
 	return (TCL_OK);
@@ -568,8 +562,7 @@
     list[3] = idname;
     list[4] = NULL;
     return (TCL_OK);
@@ -600,8 +593,7 @@
 	list[0] = NULL;
 	return (TCL_OK);
@@ -618,8 +610,7 @@
     list[4] = (char *)query_vect(name, x, y);
     list[5] = NULL;
-    interp->result = Tcl_Merge(5, list);
+    Tcl_SetResult(interp, Tcl_Merge(5, list), TCL_DYNAMIC);
     return (TCL_OK);
@@ -791,8 +782,7 @@
     list[2] = NULL;
-    interp->result = Tcl_Merge(2, list);
+    Tcl_SetResult(interp, Tcl_Merge(2, list), TCL_DYNAMIC);
     return (TCL_OK);
@@ -802,7 +792,7 @@
     char temp[40];
     if (argc != 1) {
-	interp->result = "Usage: Nget_xyrange";
+	Tcl_SetResult(interp, "Usage: Nget_xyrange", TCL_VOLATILE);
 	return (TCL_ERROR);
@@ -834,8 +824,7 @@
     list[2] = cmid;
     list[3] = NULL;
     return (TCL_OK);
@@ -894,7 +883,7 @@
     /* Try and find a surface to use as a reference */
     if ((Tcl_Eval(interp, "Nget_surf_list") != TCL_OK) ||
-	(Tcl_SplitList(interp, interp->result, &list_count, &list_space) !=
+	(Tcl_SplitList(interp, Tcl_GetStringResult(interp), &list_count, &list_space) !=
 	 TCL_OK)) {
 		      "Internal Error: Parse failure in Nsave_3dview_cmd",
@@ -941,7 +930,7 @@
 	 TCL_OK)) {
Modified: grass/trunk/visualization/nviz/src/togl_flythrough.c
--- grass/trunk/visualization/nviz/src/togl_flythrough.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/togl_flythrough.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -193,8 +193,7 @@
     list[0] = scale0;
     list[1] = scale1;
     return (TCL_OK);
Modified: grass/trunk/visualization/nviz/src/volume.c
--- grass/trunk/visualization/nviz/src/volume.c	2009-02-01 19:35:50 UTC (rev 35718)
+++ grass/trunk/visualization/nviz/src/volume.c	2009-02-01 19:42:45 UTC (rev 35719)
@@ -48,8 +48,7 @@
     list[2] = z;
     list[3] = NULL;
     return (TCL_OK);
@@ -332,6 +331,7 @@
 int isosurf_get_mask_mode(int id, Tcl_Interp * interp, int argc, char *argv[])
     int mode, isosurf_id;
+    char tmp[128];
     if (argc != 4) {
@@ -343,7 +343,8 @@
     isosurf_id = atoi(argv[3]);
     GVL_isosurf_get_maskmode(id, isosurf_id, &mode);
     return (TCL_OK);
@@ -454,8 +455,7 @@
     list[2] = z;
     list[3] = NULL;
     return (TCL_OK);
@@ -577,8 +577,7 @@
     list[6] = rdir;
     list[7] = NULL;
-    interp->result = Tcl_Merge(7, list);
+    Tcl_SetResult(interp, Tcl_Merge(7, list), TCL_DYNAMIC);
     return (TCL_OK);
@@ -699,6 +698,7 @@
 int slice_get_transp(int id, Tcl_Interp * interp, int argc, char *argv[])
     int slice_id, transp;
+    char tmp[128];
     if (argc != 4) {
@@ -711,7 +711,8 @@
     GVL_slice_get_transp(id, slice_id, &transp);
-    sprintf(interp->result, "%d", transp);
+    sprintf(tmp, "%d", transp);
     return (TCL_OK);
