[GRASS-SVN] r35852 - grass/trunk/gui/wxpython/gui_modules
Wed Feb 11 13:10:05 EST 2009
Author: martinl
Date: 2009-02-11 13:10:05 -0500 (Wed, 11 Feb 2009)
New Revision: 35852
   grass/trunk/gui/wxpython/gui_modules/render.py
Quit wxGUI gracefully when g.region crashes (trac #493)
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2009-02-11 06:37:33 UTC (rev 35851)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2009-02-11 18:10:05 UTC (rev 35852)
@@ -624,10 +624,16 @@
             elif vect:
                 e.message = _("Unable to zoom to vector map <%s>.") % vect[0] + \
                 '%s%s' % (os.linesep, os.linesep) + e.message
+            else:
+                e.message = _("Unable to get current geographic extent. "
+                              "Force quiting wxGUI. Please run manually g.region to "
+                              "fix the problem.")
+            e.Show()
+            if not rast and not vect:
+                sys.exit(1)
+            else:
+                return self.region
-            print >> sys.stderr, e
-            return self.region
         for reg in ret.splitlines():
             key, val = reg.split("=", 1)
             try:
