[GRASS-SVN] r36067 - grass/branches/develbranch_6/raster/r.surf.idw
Mon Feb 23 20:10:50 EST 2009
Author: hamish
Date: 2009-02-23 20:10:50 -0500 (Mon, 23 Feb 2009)
New Revision: 36067
   grass/branches/develbranch_6/raster/r.surf.idw/description.html
html bug, html2man bug
Modified: grass/branches/develbranch_6/raster/r.surf.idw/description.html
--- grass/branches/develbranch_6/raster/r.surf.idw/description.html	2009-02-24 00:57:30 UTC (rev 36066)
+++ grass/branches/develbranch_6/raster/r.surf.idw/description.html	2009-02-24 01:10:50 UTC (rev 36067)
@@ -24,7 +24,8 @@
 The <b>npoints</b> parameter defines the number of nearest data points used
 to determine the interpolated value of an output raster cell.
-<A NAME="notes.html"><h2>NOTES</h2></a>
+<A NAME="notes.html"></a>
+<h2>NOTES</h2>
 <em>r.surf.idw</em> is a surface generation utility which
 uses inverse distance squared weighting (as described in
@@ -47,13 +48,13 @@
 <p>
-<em>r.surf.idw</em> will generally outperform <em><A
-HREF="r.surf.idw2.html">r.surf.idw2</a></em> except when the input data
+<em>r.surf.idw</em> will generally outperform
+<em><a href="r.surf.idw2.html">r.surf.idw2</a></em> except when the input data
 layer contains few non-zero data, i.e. when the cost of the search exceeds
-the cost of the additional distance calculations performed by <em><A
-HREF="r.surf.idw2.html">r.surf.idw2</a></em>. The relative performance of
-these utilities will depend on the comparative speed of boolean, integer and
-floating point operations on a particular platform.
+the cost of the additional distance calculations performed by
+<em><A HREF="r.surf.idw2.html">r.surf.idw2</a></em>. The relative performance
+of these utilities will depend on the comparative speed of boolean, integer
+and floating point operations on a particular platform.
 <p>
@@ -85,6 +86,7 @@
 This procedure may be helpful in choosing the number of nearest neighbors
 considered for surface generation.
 <h2>SEE ALSO</h2>
 <em><a href="r.surf.contour.html">r.surf.contour</a></em>,
@@ -95,16 +97,14 @@
 <em><a href="v.surf.idw.html">v.surf.idw</a></em>,
 <em><a href="v.surf.rst.html">v.surf.rst</a></em>
 <h2>AUTHOR</h2>
-Greg Koerper
-<br>
-Global Climate Research Project
-<br>
-U.S. EPA Environmental Research Laboratory
-<br>
-200 S.W. 35th Street, JSB
-<br>
+Greg Koerper <br>
+Global Climate Research Project <br>
+U.S. EPA Environmental Research Laboratory <br>
+200 S.W. 35th Street, JSB <br>
 Corvallis, OR 97333
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
