[GRASS-SVN] r35163 - grass-addons/raster/mcda/r.mcda.regime
Fri Jan 2 09:58:02 EST 2009
Author: gianluca
Date: 2009-01-02 09:58:02 -0500 (Fri, 02 Jan 2009)
New Revision: 35163
   grass-addons/raster/mcda/r.mcda.regime/main.c
   grass-addons/raster/mcda/r.mcda.regime/regime.c
r.mcda.regime: more efficient code
Modified: grass-addons/raster/mcda/r.mcda.regime/main.c
--- grass-addons/raster/mcda/r.mcda.regime/main.c	2009-01-02 10:26:44 UTC (rev 35162)
+++ grass-addons/raster/mcda/r.mcda.regime/main.c	2009-01-02 14:58:02 UTC (rev 35163)
@@ -1,13 +1,13 @@
- * MODULE:	    r.mcda.electre
- * AUTHORS	    Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
+ * MODULE:	r.mcda.electre
+ * AUTHORS	Gianluca Massei (g_massa at libero.it) - Antonio Boggia (boggia at unipg.it)
  * PURPOSE:     Make a multi-criterio decision  analysis based on REGIME algorthm
- * COPYRIGHT:   (C) GRASS Development Team (2008)
+ * COPYRIGHT:   (C) G.Massei - A.Boggia (2008)
- *		        This program is free software under the GNU General Public
+ *		This program is free software under the GNU General Public
  *   	    	License (>=v2). Read the file COPYING that comes with GRASS
  *   	    	for details.
@@ -31,7 +31,7 @@
     int nrows, ncols;
     int row1, row2, col1, col2;
     int outfd_preference;		/* output file descriptor */
-	double *weight_vect, **regime_mat, ***decision_vol;
+	double *weight_vect, ***decision_vol;
     struct History history;	/* holds meta-data (title, comments,..) */
@@ -114,7 +114,7 @@
 		if(G_get_cellhd(p->name,p->mapset,&cellhd)<0)/* controlling, if we can open input raster */
 			G_fatal_error(_("Unable to read file header of <%s>"), p->name);
-		p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL   */
+		p->inrast = G_allocate_d_raster_buf(); /* Allocate an array of DCELL based on the number of columns in the current region. Return DCELL*/
 	result_preference=preference->answer; /* store outputn name in variables*/
@@ -128,8 +128,6 @@
 	nrows = G_window_rows();
     ncols = G_window_cols();
-	regime_mat=G_alloc_matrix((nrows*ncols),(nrows*ncols)); /* dinamicaly allocation memory and set value=0 */
 	/*memory allocation for-three dimensional matrix*/
 	decision_vol=G_malloc(nrows * sizeof(double*));
 	for (i=0; i<nrows; ++i)
@@ -167,7 +165,7 @@
 	G_message("build matrix: %s",G_date());
-	build_regime_matrix(nrows,ncols,ncriteria,weight_vect,regime_mat,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil regime index matrix */
+	build_regime_matrix(nrows,ncols,ncriteria,weight_vect,decision_vol); /*scan all DCELL, make a pairwise comparatione, buil regime index matrix */
 	for(row1 = 0; row1 < nrows; row1++)
@@ -187,7 +185,6 @@
 		G_free(attributes[i].inrast);
     G_free(outrast_preference);
-	G_free_matrix(regime_mat);
 	G_free(decision_vol);
     /* closing raster maps */
Modified: grass-addons/raster/mcda/r.mcda.regime/regime.c
--- grass-addons/raster/mcda/r.mcda.regime/regime.c	2009-01-02 10:26:44 UTC (rev 35162)
+++ grass-addons/raster/mcda/r.mcda.regime/regime.c	2009-01-02 14:58:02 UTC (rev 35163)
@@ -6,7 +6,7 @@
 void build_weight_vect(int nrows, int ncols, int ncriteria, struct Option *weight, double *weight_vect);
-void build_regime_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double **regime_mat, double ***decision_vol);
+void build_regime_matrix(int nrows, int ncols, int ncriteria, double *weight_vect, double ***decision_vol);
@@ -43,56 +43,50 @@
 	int row1,col1,row2,col2;
 	int i,j,k,cont;
-	double row_sum_regime;
+	double *row_sum_regime = G_alloc_vector(nrows * ncols);
-	k=0;	/* make pairwise comparation and built regime matrix*/
+	j=0;	/* make pairwise comparation and built regime matrix*/
 	for (row1 = 0; row1 < nrows; row1++)
-		G_percent(row1, nrows, 2);
 		for (col1 = 0; col1 < ncols; col1++)
-			j=0;
 			for (row2 = 0; row2 < nrows; row2++)
 				for (col2 = 0; col2 < ncols; col2++)
+					double reg = 0;
 					for(i=0;i<ncriteria;i++)
-						if(decision_vol[row1][col1][i]>decision_vol[row2][col2][i])
-							regime_mat[k][j]=(regime_mat[k][j])+(1*weight_vect[i]);
-						else if(decision_vol[row1][col1][i]<decision_vol[row2][col2][i])
-							regime_mat[k][j]=(regime_mat[k][j])+(-1*weight_vect[i]);
+						double d=decision_vol[row1][col1][i]-decision_vol[row2][col2][i];
+						if(d>0)
+							reg += (1*weight_vect[i]);
+						else if(d<0)
+							reg += (-1*weight_vect[i]);
 						else
-							regime_mat[k][j]=regime_mat[k][j];
+							reg += 0;
-					j++;/* increase rows index up to nrows*ncols*/
+					row_sum_regime[j] += reg;
-				k++; /* increase columns index up to nrows*ncols*/
+			j++;/* increase rows index up to nrows*ncols*/
+		G_percent(row1, nrows, 1);
 		/*calculate concordance and discordance index and storage in decision_vol*/
 	cont=0;
 	for(row1=0;row1<nrows;row1++)
 		for(col1=0;col1<ncols;col1++)
-			row_sum_regime=0;
-			 /* increase one value in regime_mat for each cicle */
-			for(i=0;i<nrows*ncols;i++)
-				/*regime index */
-				row_sum_regime=row_sum_regime+regime_mat[cont][i];
+			decision_vol[row1][col1][ncriteria]=row_sum_regime[cont]/(nrows*ncols-1);/*fill matrix with regime index for each DCELL*/
 			cont++;
-			decision_vol[row1][col1][ncriteria]=row_sum_regime/(nrows*ncols-1);/*fill matrix with regime index for each DCELL*/
+		G_percent(row1, nrows, 2);
