[GRASS-SVN] r35240 - grass-addons
Tue Jan 6 10:15:34 EST 2009
Author: neteler
Date: 2009-01-06 10:15:33 -0500 (Tue, 06 Jan 2009)
New Revision: 35240
   grass-addons/README
explanations improved
Modified: grass-addons/README
--- grass-addons/README	2009-01-06 14:53:09 UTC (rev 35239)
+++ grass-addons/README	2009-01-06 15:15:33 UTC (rev 35240)
@@ -4,11 +4,15 @@
 Installation - Code Compilation
-* C code/Scripts, with configured GRASS source code on your computer:
+* C code/Scripts, with GRASS source code on your computer:
+  Preparations (assuming source code in $HOME/grass64/):
+    1. ./configure [opionally flags]
+    2. make lib
   The easiest way to compile GRASS Addons modules into your GRASS code
   is by setting MODULE_TOPDIR on the fly to tell 'make' where to
-  find the GRASS source code:
+  find the prepared GRASS source code:
     make MODULE_TOPDIR=$HOME/grass64/
@@ -18,10 +22,15 @@
 * C code/Scripts, with GRASS binaries on your computer:
+  compile GRASS Addons modules into your GRASS code by setting
+  MODULE_TOPDIR to where to the GRASS binaries are located:
+    make MODULE_TOPDIR=/usr/lib/grass640/
+* GEM:
   If you want to install into a *binary* GRASS package, you can use
   the "GRASS Extensions Manager (GEM)":
-  http://grass.osgeo.org/grass63/manuals/html63_user/gem/index.html
+  http://grass.osgeo.org/grass64/manuals/html64_user/gem/index.html
