[GRASS-SVN] r35268 - grass-addons/vector/v.db.calc
Wed Jan 7 11:12:09 EST 2009
Author: maxi
Date: 2009-01-07 11:12:09 -0500 (Wed, 07 Jan 2009)
New Revision: 35268
   grass-addons/vector/v.db.calc/v.db.calc
updated messages...
Modified: grass-addons/vector/v.db.calc/v.db.calc
--- grass-addons/vector/v.db.calc/v.db.calc	2009-01-07 15:53:20 UTC (rev 35267)
+++ grass-addons/vector/v.db.calc/v.db.calc	2009-01-07 16:12:09 UTC (rev 35268)
@@ -115,10 +115,11 @@
         return -1
     #Process and UPDATE
     else:
+        print "please wait while updating values...."
         #process lines
         for l in range(0,len(lines)-1):
-            if l%10==0:
-                print "."
+            #if l%10==0:
+            #    sys.stdout.write(".")
             cols = lines[l].split("|")
             evalexp = exp
             for i in range(len(uf)):
@@ -136,7 +137,7 @@
             #print updst
             cmdargs2=["map=%s"%table,"col=%s"%field,"val=%s"%str(value),"where=cat=%s"%cols[0],"--q"]
             os.spawnvp(os.P_WAIT,"v.db.update", ["v.db.update"] + cmdargs2)
+        print "....DONE"
     return
 if __name__ == "__main__":
@@ -144,11 +145,3 @@
         os.execvp("g.parser", [sys.argv[0]] + sys.argv)
     else:
 	main();
